commit 6d9e8c651dd979aa666bee15f086745f3ea9c4b3 upstream.
Patch series "use div64_ul() instead of div_u64() if the divisor is
unsigned long".
We were first inspired by commit b0ab99e7736a ("sched: Fix possible divide
by zero in avg_atom () calculation"), then refer to the recently analyzed
mm code, we found this suspicious place.
201 if (min) {
202 min *= this_bw;
203 do_div(min, tot_bw);
204 }
And we also disassembled and confirmed it:
/usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 201
0xffffffff811c37da <__wb_calc_thresh+234>: xor %r10d,%r10d
0xffffffff811c37dd <__wb_calc_thresh+237>: test %rax,%rax
0xffffffff811c37e0 <__wb_calc_thresh+240>: je 0xffffffff811c3800 <__wb_calc_thresh+272>
/usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 202
0xffffffff811c37e2 <__wb_calc_thresh+242>: imul %r8,%rax
/usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 203
0xffffffff811c37e6 <__wb_calc_thresh+246>: mov %r9d,%r10d ---> truncates it to 32 bits here
0xffffffff811c37e9 <__wb_calc_thresh+249>: xor %edx,%edx
0xffffffff811c37eb <__wb_calc_thresh+251>: div %r10
0xffffffff811c37ee <__wb_calc_thresh+254>: imul %rbx,%rax
0xffffffff811c37f2 <__wb_calc_thresh+258>: shr $0x2,%rax
0xffffffff811c37f6 <__wb_calc_thresh+262>: mul %rcx
0xffffffff811c37f9 <__wb_calc_thresh+265>: shr $0x2,%rdx
0xffffffff811c37fd <__wb_calc_thresh+269>: mov %rdx,%r10
This series uses div64_ul() instead of div_u64() if the divisor is
unsigned long, to avoid truncation to 32-bit on 64-bit platforms.
This patch (of 3):
The variables 'min' and 'max' are unsigned long and do_div truncates
them to 32 bits, which means it can test non-zero and be truncated to
zero for division. Fix this issue by using div64_ul() instead.
Link: http://lkml.kernel.org/r/20200102081442.8273-2-wenyang@linux.alibaba.com
Fixes: 693108a8a667 ("writeback: make bdi->min/max_ratio handling cgroup writeback aware")
Signed-off-by: Wen Yang <wenyang@linux.alibaba.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Qian Cai <cai@lca.pw>
Cc: Tejun Heo <tj@kernel.org>
There's an inherent mismatch between memcg and writeback. The former
trackes ownership per-page while the latter per-inode. This was a
deliberate design decision because honoring per-page ownership in the
writeback path is complicated, may lead to higher CPU and IO overheads
and deemed unnecessary given that write-sharing an inode across
different cgroups isn't a common use-case.
Combined with inode majority-writer ownership switching, this works
well enough in most cases but there are some pathological cases. For
example, let's say there are two cgroups A and B which keep writing to
different but confined parts of the same inode. B owns the inode and
A's memory is limited far below B's. A's dirty ratio can rise enough
to trigger balance_dirty_pages() sleeps but B's can be low enough to
avoid triggering background writeback. A will be slowed down without
a way to make writeback of the dirty pages happen.
This patch implements foreign dirty recording and foreign mechanism so
that when a memcg encounters a condition as above it can trigger
flushes on bdi_writebacks which can clean its pages. Please see the
comment on top of mem_cgroup_track_foreign_dirty_slowpath() for
details.
A reproducer follows.
write-range.c::
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/types.h>
static const char *usage = "write-range FILE START SIZE\n";
int main(int argc, char **argv)
int fd;
unsigned long start, size, end, pos;
char *endp;
char buf[4096];
if (argc < 4) {
fprintf(stderr, usage);
return 1;
fd = open(argv[1], O_WRONLY);
if (fd < 0) {
perror("open");
return 1;
start = strtoul(argv[2], &endp, 0);
if (*endp != '\0') {
return 1;
size = strtoul(argv[3], &endp, 0);
return 1;
end = start + size;
while (1) {
for (pos = start; pos < end; ) {
long bread, bwritten = 0;
if (lseek(fd, pos, SEEK_SET) < 0) {
perror("lseek");
return 1;
bread = read(0, buf, sizeof(buf) < end - pos ?
sizeof(buf) : end - pos);
if (bread < 0) {
perror("read");
return 1;
if (bread == 0)
return 0;
while (bwritten < bread) {
long this;
this = write(fd, buf + bwritten,
bread - bwritten);
if (this < 0) {
perror("write");
return 1;
bwritten += this;
pos += bwritten;
repro.sh::
#!/bin/bash
set -e
set -x
sysctl -w vm.dirty_expire_centisecs=300000
sysctl -w vm.dirty_writeback_centisecs=300000
sysctl -w vm.dirtytime_expire_seconds=300000
echo 3 > /proc/sys/vm/drop_caches
TEST=/sys/fs/cgroup/test
A=$TEST/A
B=$TEST/B
mkdir -p $A $B
echo "+memory +io" > $TEST/cgroup.subtree_control
echo $((1<<30)) > $A/memory.high
echo $((32<<30)) > $B/memory.high
rm -f testfile
touch testfile
fallocate -l 4G testfile
echo "Starting B"
(echo $BASHPID > $B/cgroup.procs
pv -q --rate-limit 70M < /dev/urandom | ./write-range testfile $((2<<30)) $((2<<30))) &
echo "Waiting 10s to ensure B claims the testfile inode"
sleep 5
sync
sleep 5
sync
echo "Starting A"
(echo $BASHPID > $A/cgroup.procs
pv < /dev/urandom | ./write-range testfile 0 $((2<<30)))
v2: Added comments explaining why the specific intervals are being used.
v3: Use 0 @nr when calling cgroup_writeback_by_id() to use best-effort
flushing while avoding possible livelocks.
v4: Use get_jiffies_64() and time_before/after64() instead of raw
jiffies_64 and arthimetic comparisons as suggested by Jan.
account_page_dirtied() is only used by our set_page_dirty() helpers and
should not be used anywhere else.
Link: http://lkml.kernel.org/r/20190605183702.30572-1-hch@lst.de
Add SPDX license identifiers to all files which:
- Have no license information of any form
- Have EXPORT_.*_SYMBOL_GPL inside which was used in the
initial scan/conversion to ignore the file
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Recently there have been some hung tasks on our server due to
wait_on_page_writeback(), and we want to know the details of this
PG_writeback, i.e. this page is writing back to which device. But it is
not so convenient to get the details.
I think it would be better to introduce a tracepoint for diagnosing the
writeback details.
Link: http://lkml.kernel.org/r/1556274402-19018-1-git-send-email-laoar.shao@gmail.com
Signed-off-by: Yafang Shao <laoar.shao@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Michal Hocko <mhocko@suse.com>
Many kernel-doc comments in mm/ have the return value descriptions
either misformatted or omitted at all which makes kernel-doc script
unhappy:
$ make V=1 htmldocs
./mm/util.c:36: info: Scanning doc for kstrdup
./mm/util.c:41: warning: No description found for return value of 'kstrdup'
./mm/util.c:57: info: Scanning doc for kstrdup_const
./mm/util.c:66: warning: No description found for return value of 'kstrdup_const'
./mm/util.c:75: info: Scanning doc for kstrndup
./mm/util.c:83: warning: No description found for return value of 'kstrndup'
Fixing the formatting and adding the missing return value descriptions
eliminates ~100 such warnings.
Link: http://lkml.kernel.org/r/1549549644-4903-4-git-send-email-rppt@linux.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Jonathan Corbet <corbet@lwn.net>
write_cache_pages() is used in both background and integrity writeback
scenarios by various filesystems. Background writeback is mostly
concerned with cleaning a certain number of dirty pages based on various
mm heuristics. It may not write the full set of dirty pages or wait for
I/O to complete. Integrity writeback is responsible for persisting a set
of dirty pages before the writeback job completes. For example, an
fsync() call must perform integrity writeback to ensure data is on disk
before the call returns.
write_cache_pages() unconditionally breaks out of its processing loop in
the event of a ->writepage() error. This is fine for background
writeback, which had no strict requirements and will eventually come
around again. This can cause problems for integrity writeback on
filesystems that might need to clean up state associated with failed page
writeouts. For example, XFS performs internal delayed allocation
accounting before returning a ->writepage() error, where applicable. If
the current writeback happens to be associated with an unmount and
write_cache_pages() completes the writeback prematurely due to error, the
filesystem is unmounted in an inconsistent state if dirty+delalloc pages
still exist.
To handle this problem, update write_cache_pages() to always process the
full set of pages for integrity writeback regardless of ->writepage()
errors. Save the first encountered error and return it to the caller once
complete. This facilitates XFS (or any other fs that expects integrity
writeback to process the entire set of dirty pages) to clean up its
internal state completely in the event of persistent mapping errors.
Background writeback continues to exit on the first error encountered.
[akpm@linux-foundation.org: fix typo in comment]
Link: http://lkml.kernel.org/r/20181116134304.32440-1-bfoster@redhat.com
Signed-off-by: Brian Foster <bfoster@redhat.com>
Pull XArray conversion from Matthew Wilcox:
"The XArray provides an improved interface to the radix tree data
structure, providing locking as part of the API, specifying GFP flags
at allocation time, eliminating preloading, less re-walking the tree,
more efficient iterations and not exposing RCU-protected pointers to
its users.
This patch set
1. Introduces the XArray implementation
2. Converts the pagecache to use it
3. Converts memremap to use it
The page cache is the most complex and important user of the radix
tree, so converting it was most important. Converting the memremap
code removes the only other user of the multiorder code, which allows
us to remove the radix tree code that supported it.
I have 40+ followup patches to convert many other users of the radix
tree over to the XArray, but I'd like to get this part in first. The
other conversions haven't been in linux-next and aren't suitable for
applying yet, but you can see them in the xarray-conv branch if you're
interested"
* 'xarray' of git://git.infradead.org/users/willy/linux-dax: (90 commits)
radix tree: Remove multiorder support
radix tree test: Convert multiorder tests to XArray
radix tree tests: Convert item_delete_rcu to XArray
radix tree tests: Convert item_kill_tree to XArray
radix tree tests: Move item_insert_order
radix tree test suite: Remove multiorder benchmarking
radix tree test suite: Remove __item_insert
memremap: Convert to XArray
xarray: Add range store functionality
xarray: Move multiorder_check to in-kernel tests
xarray: Move multiorder_shrink to kernel tests
xarray: Move multiorder account test in-kernel
radix tree test suite: Convert iteration test to XArray
radix tree test suite: Convert tag_tagged_items to XArray
radix tree: Remove radix_tree_clear_tags
radix tree: Remove radix_tree_maybe_preload_order
radix tree: Remove split/join code
radix tree: Remove radix_tree_update_node_t
page cache: Finish XArray conversion
dax: Convert page fault handlers to XArray
We've recently seen a workload on XFS filesystems with a repeatable
deadlock between background writeback and a multi-process application
doing concurrent writes and fsyncs to a small range of a file.
range_cyclic
writeback Process 1 Process 2
xfs_vm_writepages
write_cache_pages
writeback_index = 2
cycled = 0
find page 2 dirty
lock Page 2
->writepage
page 2 writeback
page 2 clean
page 2 added to bio
no more pages
write()
locks page 1
dirties page 1
locks page 2
dirties page 1
fsync()
xfs_vm_writepages
write_cache_pages
start index 0
find page 1 towrite
lock Page 1
->writepage
page 1 writeback
page 1 clean
page 1 added to bio
find page 2 towrite
lock Page 2
page 2 is writeback
<blocks>
write()
locks page 1
dirties page 1
fsync()
xfs_vm_writepages
write_cache_pages
start index 0
!done && !cycled
sets index to 0, restarts lookup
find page 1 dirty
find page 1 towrite
lock Page 1
page 1 is writeback
<blocks>
lock Page 1
<blocks>
DEADLOCK because:
- process 1 needs page 2 writeback to complete to make
enough progress to issue IO pending for page 1
- writeback needs page 1 writeback to complete so process 2
can progress and unlock the page it is blocked on, then it
can issue the IO pending for page 2
- process 2 can't make progress until process 1 issues IO
for page 1
The underlying cause of the problem here is that range_cyclic writeback is
processing pages in descending index order as we hold higher index pages
in a structure controlled from above write_cache_pages(). The
write_cache_pages() caller needs to be able to submit these pages for IO
before write_cache_pages restarts writeback at mapping index 0 to avoid
wcp inverting the page lock/writeback wait order.
generic_writepages() is not susceptible to this bug as it has no private
context held across write_cache_pages() - filesystems using this
infrastructure always submit pages in ->writepage immediately and so there
is no problem with range_cyclic going back to mapping index 0.
However:
mpage_writepages() has a private bio context,
exofs_writepages() has page_collect
fuse_writepages() has fuse_fill_wb_data
nfs_writepages() has nfs_pageio_descriptor
xfs_vm_writepages() has xfs_writepage_ctx
All of these ->writepages implementations can hold pages under writeback
in their private structures until write_cache_pages() returns, and hence
they are all susceptible to this deadlock.
Also worth noting is that ext4 has it's own bastardised version of
write_cache_pages() and so it /may/ have an equivalent deadlock. I looked
at the code long enough to understand that it has a similar retry loop for
range_cyclic writeback reaching the end of the file and then promptly ran
away before my eyes bled too much. I'll leave it for the ext4 developers
to determine if their code is actually has this deadlock and how to fix it
if it has.
There's a few ways I can see avoid this deadlock. There's probably more,
but these are the first I've though of:
1. get rid of range_cyclic altogether
2. range_cyclic always stops at EOF, and we start again from
writeback index 0 on the next call into write_cache_pages()
2a. wcp also returns EAGAIN to ->writepages implementations to
indicate range cyclic has hit EOF. writepages implementations can
then flush the current context and call wpc again to continue. i.e.
lift the retry into the ->writepages implementation
3. range_cyclic uses trylock_page() rather than lock_page(), and it
skips pages it can't lock without blocking. It will already do this
for pages under writeback, so this seems like a no-brainer
3a. all non-WB_SYNC_ALL writeback uses trylock_page() to avoid
blocking as per pages under writeback.
I don't think #1 is an option - range_cyclic prevents frequently
dirtied lower file offset from starving background writeback of
rarely touched higher file offsets.
#2 is simple, and I don't think it will have any impact on
performance as going back to the start of the file implies an
immediate seek. We'll have exactly the same number of seeks if we
switch writeback to another inode, and then come back to this one
later and restart from index 0.
#2a is pretty much "status quo without the deadlock". Moving the
retry loop up into the wcp caller means we can issue IO on the
pending pages before calling wcp again, and so avoid locking or
waiting on pages in the wrong order. I'm not convinced we need to do
this given that we get the same thing from #2 on the next writeback
call from the writeback infrastructure.
#3 is really just a band-aid - it doesn't fix the access/wait
inversion problem, just prevents it from becoming a deadlock
situation. I'd prefer we fix the inversion, not sweep it under the
carpet like this.
#3a is really an optimisation that just so happens to include the
band-aid fix of #3.
So it seems that the simplest way to fix this issue is to implement
solution #2
Link: http://lkml.kernel.org/r/20181005054526.21507-1-david@fromorbit.com
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Jan Kara <jack@suse.de>
Cc: Nicholas Piggin <npiggin@gmail.com>
Includes moving mapping_tagged() to fs.h as a static inline, and
changing it to return bool.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
The conversion of the hotplug notifiers to a state machine left the
notifier.h includes around in some places. Remove them.
Signed-off-by: Mukesh Ojha <mojha@codeaurora.org>
Link: https://lkml.kernel.org/r/1535114033-4605-1-git-send-email-mojha@codeaurora.org
Commit 93f78d882865 ("writeback: move backing_dev_info->bdi_stat[] into
bdi_writeback") replaced BDI_DIRTIED with WB_DIRTIED in
account_page_redirty(). Update comment to track that change.
BDI_DIRTIED => WB_DIRTIED
BDI_WRITTEN => WB_WRITTEN
Link: http://lkml.kernel.org/r/20180625171526.173483-1-gthelen@google.com
Signed-off-by: Greg Thelen <gthelen@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
lock_page_memcg()/unlock_page_memcg() use spin_lock_irqsave/restore() if
the page's memcg is undergoing move accounting, which occurs when a
process leaves its memcg for a new one that has
memory.move_charge_at_immigrate set.
unlocked_inode_to_wb_begin,end() use spin_lock_irq/spin_unlock_irq() if
the given inode is switching writeback domains. Switches occur when
enough writes are issued from a new domain.
This existing pattern is thus suspicious:
lock_page_memcg(page);
unlocked_inode_to_wb_begin(inode, &locked);
unlocked_inode_to_wb_end(inode, locked);
unlock_page_memcg(page);
If both inode switch and process memcg migration are both in-flight then
unlocked_inode_to_wb_end() will unconditionally enable interrupts while
still holding the lock_page_memcg() irq spinlock. This suggests the
possibility of deadlock if an interrupt occurs before unlock_page_memcg().
truncate
__cancel_dirty_page
lock_page_memcg
<interrupts mistakenly enabled>
<interrupt>
end_page_writeback
test_clear_page_writeback
lock_page_memcg
<deadlock>
unlock_page_memcg
Due to configuration limitations this deadlock is not currently possible
because we don't mix cgroup writeback (a cgroupv2 feature) and
memory.move_charge_at_immigrate (a cgroupv1 feature).
If the kernel is hacked to always claim inode switching and memcg
moving_account, then this script triggers lockup in less than a minute:
cd /mnt/cgroup/memory
mkdir a b
echo 1 > a/memory.move_charge_at_immigrate
echo 1 > b/memory.move_charge_at_immigrate
echo $BASHPID > a/cgroup.procs
while true; do
dd if=/dev/zero of=/mnt/big bs=1M count=256
done
while true; do
sync
done &
sleep 1h &
SLEEP=$!
while true; do
echo $SLEEP > a/cgroup.procs
echo $SLEEP > b/cgroup.procs
done
The deadlock does not seem possible, so it's debatable if there's any
reason to modify the kernel. I suggest we should to prevent future
surprises. And Wang Long said "this deadlock occurs three times in our
environment", so there's more reason to apply this, even to stable.
Stable 4.4 has minor conflicts applying this patch. For a clean 4.4 patch
see "[PATCH for-4.4] writeback: safer lock nesting"
https://lkml.org/lkml/2018/4/11/146
Wang Long said "this deadlock occurs three times in our environment"
[gthelen@google.com: v4]
Link: http://lkml.kernel.org/r/20180411084653.254724-1-gthelen@google.com
[akpm@linux-foundation.org: comment tweaks, struct initialization simplification]
Change-Id: Ibb773e8045852978f6207074491d262f1b3fb613
Link: http://lkml.kernel.org/r/20180410005908.167976-1-gthelen@google.com
Fixes: 682aa8e1a6a1 ("writeback: implement unlocked_inode_to_wb transaction and use it for stat updates")
Reported-by: Wang Long <wanglong19@meituan.com>
Acked-by: Wang Long <wanglong19@meituan.com>
Cc: <stable@vger.kernel.org> [v4.2+]
Remove the address_space ->tree_lock and use the xa_lock newly added to
the radix_tree_root. Rename the address_space ->page_tree to ->i_pages,
since we don't really care that it's a tree.
[willy@infradead.org: fix nds32, fs/dax.c]
Link: http://lkml.kernel.org/r/20180406145415.GB20605@bombadil.infradead.orgLink: http://lkml.kernel.org/r/20180313132639.17387-9-willy@infradead.org
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
are illogical"
This reverts commit 0f6d24f87856 ("mm/page-writeback.c: print a warning
if the vm dirtiness settings are illogical") because it causes false
positive warnings during OOM situations as noticed by Tetsuo Handa:
Node 0 active_anon:3525940kB inactive_anon:8372kB active_file:216kB inactive_file:1872kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:2504kB dirty:52kB writeback:0kB shmem:8660kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 636928kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
Node 0 DMA free:14848kB min:284kB low:352kB high:420kB active_anon:992kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15988kB managed:15904kB mlocked:0kB kernel_stack:0kB pagetables:24kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 2687 3645 3645
Node 0 DMA32 free:53004kB min:49608kB low:62008kB high:74408kB active_anon:2712648kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:3129216kB managed:2773132kB mlocked:0kB kernel_stack:96kB pagetables:5096kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 0 958 958
Node 0 Normal free:17140kB min:17684kB low:22104kB high:26524kB active_anon:812300kB inactive_anon:8372kB active_file:1228kB inactive_file:1868kB unevictable:0kB writepending:52kB present:1048576kB managed:981224kB mlocked:0kB kernel_stack:3520kB pagetables:8552kB bounce:0kB free_pcp:120kB local_pcp:120kB free_cma:0kB
lowmem_reserve[]: 0 0 0 0
Out of memory: Kill process 8459 (a.out) score 999 or sacrifice child
Killed process 8459 (a.out) total-vm:4180kB, anon-rss:88kB, file-rss:0kB, shmem-rss:0kB
oom_reaper: reaped process 8459 (a.out), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
vm direct limit must be set greater than background limit.
The problem is that both thresh and bg_thresh will be 0 if
available_memory is less than 4 pages when evaluating
global_dirtyable_memory.
While this might be worked around the whole point of the warning is
dubious at best. We do rely on admins to do sensible things when
changing tunable knobs. Dirty memory writeback knobs are not any
special in that regards so revert the warning rather than adding more
hacks to work this around.
Debugged by Yafang Shao.
Link: http://lkml.kernel.org/r/20171127091939.tahb77nznytcxw55@dhcp22.suse.cz
Fixes: 0f6d24f87856 ("mm/page-writeback.c: print a warning if the vm dirtiness settings are illogical")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Yafang Shao <laoar.shao@gmail.com>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: linux-block@vger.kernel.org
Cc: linux-mm@kvack.org
The parameter `struct bdi_writeback *wb` is not been used in the
function body. Remove it.
Link: http://lkml.kernel.org/r/1509685485-15278-1-git-send-email-wanglong19@meituan.com
Signed-off-by: Wang Long <wanglong19@meituan.com>
Every pagevec_init user claims the pages being released are hot even in
cases where it is unlikely the pages are hot. As no one cares about the
hotness of pages being released to the allocator, just ditch the
parameter.
No performance impact is expected as the overhead is marginal. The
parameter is removed simply because it is a bit stupid to have a useless
parameter copied everywhere.
Link: http://lkml.kernel.org/r/20171018075952.10627-6-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Patch series "Speed up page cache truncation", v1.
When rebasing our enterprise distro to a newer kernel (from 4.4 to 4.12)
we have noticed a regression in bonnie++ benchmark when deleting files.
Eventually we have tracked this down to a fact that page cache
truncation got slower by about 10%. There were both gains and losses in
the above interval of kernels but we have been able to identify that
commit 83929372f629 ("filemap: prepare find and delete operations for
huge pages") caused about 10% regression on its own.
After some investigation it didn't seem easily possible to fix the
regression while maintaining the THP in page cache functionality so
we've decided to optimize the page cache truncation path instead to make
up for the change. This series is a result of that effort.
Patch 1 is an easy speedup of cancel_dirty_page(). Patches 2-6 refactor
page cache truncation code so that it is easier to batch radix tree
operations. Patch 7 implements batching of deletes from the radix tree
which more than makes up for the original regression.
This patch (of 7):
cancel_dirty_page() does quite some work even for clean pages (fetching
of mapping, locking of memcg, atomic bit op on page flags) so it
accounts for ~2.5% of cost of truncation of a clean page. That is not
much but still dumb for something we don't need at all. Check whether a
page is actually dirty and avoid any work if not.
Link: http://lkml.kernel.org/r/20171010151937.26984-2-jack@suse.cz
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
to all timer callbacks, switch to using the new timer_setup() and
from_timer() to pass the timer pointer explicitly.
Link: http://lkml.kernel.org/r/20171016225913.GA99214@beast
All users of pagevec_lookup() and pagevec_lookup_range() now pass
PAGEVEC_SIZE as a desired number of pages. Just drop the argument.
Link: http://lkml.kernel.org/r/20171009151359.31984-15-jack@suse.cz
Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Use pagevec_lookup_range_tag() in write_cache_pages() as it is
interested only in pages from given range. Remove unnecessary code
resulting from this.
Link: http://lkml.kernel.org/r/20171009151359.31984-12-jack@suse.cz
The vm direct limit setting must be set greater than vm background limit
setting. Otherwise print a warning to help the operator to figure out
that the vm dirtiness settings is in illogical state.
Link: http://lkml.kernel.org/r/1506592464-30962-1-git-send-email-laoar.shao@gmail.com
Cc: Michal Hocko <mhocko@kernel.org>
"mapping" parameter to balance_dirty_pages() is not used anymore.
Fixes: dfb8ae567835 ("writeback: let balance_dirty_pages() work on the matching cgroup bdi_writeback")
Link: http://lkml.kernel.org/r/20170927221311.23263-1-tahsin@google.com
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
immediately
This patch is the followup of the prvious patch:
[writeback: schedule periodic writeback with sysctl].
There's another issue to fix.
For example,
- When the tunable was set to one hour and is reset to one second, the
new setting will not take effect for up to one hour.
Kicking the flusher threads immediately fixes it.
After disable periodic writeback by writing 0 to
dirty_writeback_centisecs, the handler wb_workfn() will not be
entered again until the dirty background limit reaches or
sync syscall is executed or no enough free memory available or
vmscan is triggered.
So the periodic writeback can't be enabled by writing a non-zero
value to dirty_writeback_centisecs.
As it can be disabled by sysctl, it should be able to enable by
sysctl as well.
Laptop mode really wants to writeback the number of dirty
pages and inodes. Instead of calculating this in the caller,
just pass in 0 and let wakeup_flusher_threads() handle it.
Use the new wakeup_flusher_threads_bdi() instead of rolling
our own.
Tested-by: Chris Mason <clm@fb.com>
All the callers pass in 'true' for range_cyclic, so kill the
argument.
global_page_state is error prone as a recent bug report pointed out [1].
It only returns proper values for zone based counters as the enum it
gets suggests. We already have global_node_page_state so let's rename
global_page_state to global_zone_page_state to be more explicit here.
All existing users seems to be correct:
$ git grep "global_page_state(NR_" | sed 's@.*(\(NR_[A-Z_]*\)).*@\1@' | sort | uniq -c
2 NR_BOUNCE
2 NR_FREE_CMA_PAGES
11 NR_FREE_PAGES
1 NR_KERNEL_STACK_KB
1 NR_MLOCK
2 NR_PAGETABLE
This patch shouldn't introduce any functional change.
[1] http://lkml.kernel.org/r/201707260628.v6Q6SmaS030814@www262.sakura.ne.jp
Link: http://lkml.kernel.org/r/20170801134256.5400-2-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Josef Bacik <josef@toxicpanda.com>
Jaegeuk and Brad report a NULL pointer crash when writeback ending tries
to update the memcg stats:
BUG: unable to handle kernel NULL pointer dereference at 00000000000003b0
IP: test_clear_page_writeback+0x12e/0x2c0
RIP: 0010:test_clear_page_writeback+0x12e/0x2c0
Call Trace:
<IRQ>
end_page_writeback+0x47/0x70
f2fs_write_end_io+0x76/0x180 [f2fs]
bio_endio+0x9f/0x120
blk_update_request+0xa8/0x2f0
scsi_end_request+0x39/0x1d0
scsi_io_completion+0x211/0x690
scsi_finish_command+0xd9/0x120
scsi_softirq_done+0x127/0x150
__blk_mq_complete_request_remote+0x13/0x20
flush_smp_call_function_queue+0x56/0x110
generic_smp_call_function_single_interrupt+0x13/0x30
smp_call_function_single_interrupt+0x27/0x40
call_function_single_interrupt+0x89/0x90
RIP: 0010:native_safe_halt+0x6/0x10
(gdb) l *(test_clear_page_writeback+0x12e)
0xffffffff811bae3e is in test_clear_page_writeback (./include/linux/memcontrol.h:619).
614 mod_node_page_state(page_pgdat(page), idx, val);
615 if (mem_cgroup_disabled() || !page->mem_cgroup)
616 return;
617 mod_memcg_state(page->mem_cgroup, idx, val);
618 pn = page->mem_cgroup->nodeinfo[page_to_nid(page)];
619 this_cpu_add(pn->lruvec_stat->count[idx], val);
620 }
621
622 unsigned long mem_cgroup_soft_limit_reclaim(pg_data_t *pgdat, int order,
623 gfp_t gfp_mask,
The issue is that writeback doesn't hold a page reference and the page
might get freed after PG_writeback is cleared (and the mapping is
unlocked) in test_clear_page_writeback(). The stat functions looking up
the page's node or zone are safe, as those attributes are static across
allocation and free cycles. But page->mem_cgroup is not, and it will
get cleared if we race with truncation or migration.
It appears this race window has been around for a while, but less likely
to trigger when the memcg stats were updated first thing after
PG_writeback is cleared. Recent changes reshuffled this code to update
the global node stats before the memcg ones, though, stretching the race
window out to an extent where people can reproduce the problem.
Update test_clear_page_writeback() to look up and pin page->mem_cgroup
before clearing PG_writeback, then not use that pointer afterward. It
is a partial revert of 62cccb8c8e7a ("mm: simplify lock_page_memcg()")
but leaves the pageref-holding callsites that aren't affected alone.
Link: http://lkml.kernel.org/r/20170809183825.GA26387@cmpxchg.org
Fixes: 62cccb8c8e7a ("mm: simplify lock_page_memcg()")
Reported-by: Jaegeuk Kim <jaegeuk@kernel.org>
Tested-by: Jaegeuk Kim <jaegeuk@kernel.org>
Reported-by: Bradley Bolen <bradleybolen@gmail.com>
Tested-by: Brad Bolen <bradleybolen@gmail.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.6+]
Currently the writeback statistics code uses a percpu counters to hold
various statistics. Furthermore we have 2 families of functions - those
which disable local irq and those which doesn't and whose names begin
with double underscore. However, they both end up calling
__add_wb_stats which in turn calls percpu_counter_add_batch which is
already irq-safe.
Exploiting this fact allows to eliminated the __wb_* functions since
they don't add any further protection than we already have.
Furthermore, refactor the wb_* function to call __add_wb_stat directly
without the irq-disabling dance. This will likely result in better
runtime of code which deals with modifying the stat counters.
While at it also document why percpu_counter_add_batch is in fact
preempt and irq-safe since at least 3 people got confused.
Link: http://lkml.kernel.org/r/1498029937-27293-1-git-send-email-nborisov@suse.com
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Cc: Josef Bacik <jbacik@fb.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull Writeback error handling fixes from Jeff Layton:
"The main rationale for all of these changes is to tighten up writeback
error reporting to userland. There are many ways now that writeback
errors can be lost, such that fsync/fdatasync/msync return 0 when
writeback actually failed.
This pile contains a small set of cleanups and writeback error
handling fixes that I was able to break off from the main pile (#2).
Two of the patches in this pile are trivial. The exceptions are the
patch to fix up error handling in write_one_page, and the patch to
make JFS pay attention to write_one_page errors"
* tag 'for-linus-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
fs: remove call_fsync helper function
mm: clean up error handling in write_one_page
JFS: do not ignore return code from write_one_page()
mm: drop "wait" parameter from write_one_page()
lruvecs are at the intersection of the NUMA node and memcg, which is the
scope for most paging activity.
Introduce a convenient accounting infrastructure that maintains
statistics per node, per memcg, and the lruvec itself.
Then convert over accounting sites for statistics that are already
tracked in both nodes and memcgs and can be easily switched.
[hannes@cmpxchg.org: fix crash in the new cgroup stat keeping code]
Link: http://lkml.kernel.org/r/20170531171450.GA10481@cmpxchg.org
[hannes@cmpxchg.org: don't track uncharged pages at all
Link: http://lkml.kernel.org/r/20170605175254.GA8547@cmpxchg.org
[hannes@cmpxchg.org: add missing free_percpu()]
Link: http://lkml.kernel.org/r/20170605175354.GB8547@cmpxchg.org
[linux@roeck-us.net: hexagon: fix build error caused by include file order]
Link: http://lkml.kernel.org/r/20170617153721.GA4382@roeck-us.net
Link: http://lkml.kernel.org/r/20170530181724.27197-6-hannes@cmpxchg.org
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Don't try to check PageError since that's potentially racy and not
necessarily going to be set after writepage errors out.
Instead, check the mapping for an error after writepage returns. That
should also help us detect errors that occurred if the VM tried to
clean the page earlier due to memory pressure.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
The callers all set it to 1.
Also, make it clear that this function will not set any sort of AS_*
error, and that the caller must do so if necessary. No existing caller
uses this on normal files, so none of them need it.
Also, add __must_check here since, in general, the callers need to handle
an error here in some fashion.
Link: http://lkml.kernel.org/r/20170525103303.6524-1-jlayton@redhat.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
- add GETFSMAP support
- some performance improvements for very large file systems and for
random write workloads into a preallocated file
- bug fixes and cleanups.
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: cleanup write flags handling from jbd2_write_superblock()
ext4: mark superblock writes synchronous for nobarrier mounts
ext4: inherit encryption xattr before other xattrs
ext4: replace BUG_ON with WARN_ONCE in ext4_end_bio()
ext4: avoid unnecessary transaction stalls during writeback
ext4: preload block group descriptors
ext4: make ext4_shutdown() static
ext4: support GETFSMAP ioctls
vfs: add common GETFSMAP ioctl definitions
ext4: evict inline data when writing to memory map
ext4: remove ext4_xattr_check_entry()
ext4: rename ext4_xattr_check_names() to ext4_xattr_check_entries()
ext4: merge ext4_xattr_list() into ext4_listxattr()
ext4: constify static data that is never modified
ext4: trim return value and 'dir' argument from ext4_insert_dentry()
jbd2: fix dbench4 performance regression for 'nobarrier' mounts
jbd2: Fix lockdep splat with generic/270 test
mm: retry writepages() on ENOMEM when doing an data integrity writeback
The memory controllers stat function names are awkwardly long and
arbitrarily different from the zone and node stat functions.
The current interface is named:
mem_cgroup_read_stat()
mem_cgroup_update_stat()
mem_cgroup_inc_stat()
mem_cgroup_dec_stat()
mem_cgroup_update_page_stat()
mem_cgroup_inc_page_stat()
mem_cgroup_dec_page_stat()
This patch renames it to match the corresponding node stat functions:
memcg_page_state() [node_page_state()]
mod_memcg_state() [mod_node_state()]
inc_memcg_state() [inc_node_state()]
dec_memcg_state() [dec_node_state()]
mod_memcg_page_state() [mod_node_page_state()]
inc_memcg_page_state() [inc_node_page_state()]
dec_memcg_page_state() [dec_node_page_state()]
Link: http://lkml.kernel.org/r/20170404220148.28338-4-hannes@cmpxchg.org
The current duplication is a high-maintenance mess, and it's painful to
add new items or query memcg state from the rest of the VM.
This increases the size of the stat array marginally, but we should aim
to track all these stats on a per-cgroup level anyway.
Link: http://lkml.kernel.org/r/20170404220148.28338-3-hannes@cmpxchg.org
Use setup_deferrable_timer() instead of init_timer_deferrable() to
simplify the code.
Link: http://lkml.kernel.org/r/e8e3d4280a34facbc007346f31df833cec28801e.1488070291.git.geliangtang@gmail.com
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Currently, file system's writepages() function must not fail with an
ENOMEM, since if they do, it's possible for buffered data to be lost.
This is because on a data integrity writeback writepages() gets called
but once, and if it returns ENOMEM, if you're lucky the error will get
reflected back to the userspace process calling fsync(). If you
aren't lucky, the user is unmounting the file system, and the dirty
pages will simply be lost.
For this reason, file system code generally will use GFP_NOFS, and in
some cases, will retry the allocation in a loop, on the theory that
"kernel livelocks are temporary; data loss is forever".
Unfortunately, this can indeed cause livelocks, since inside the
writepages() call, the file system is holding various mutexes, and
these mutexes may prevent the OOM killer from killing its targetted
victim if it is also holding on to those mutexes.
A better solution would be to allow writepages() to call the memory
allocator with flags that give greater latitude to the allocator to
fail, and then release its locks and return ENOMEM, and in the case of
background writeback, the writes can be retried at a later time. In
the case of data-integrity writeback retry after waiting a brief
amount of time.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
dependency
Instead of including the full <linux/signal.h>, we are going to include the
types-only <linux/signal_types.h> header in <linux/sched.h>, to further
decouple the scheduler header from the signal headers.
This means that various files which relied on the full <linux/signal.h> need
to be updated to gain an explicit dependency on it.
Update the code that relies on sched.h's inclusion of the <linux/signal.h> header.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Fix typos and add the following to the scripts/spelling.txt:
comsume||consume
comsumer||consumer
comsuming||consuming
I see some variable names with this pattern, but this commit is only
touching comment blocks to avoid unexpected impact.
Link: http://lkml.kernel.org/r/1481573103-11329-19-git-send-email-yamada.masahiro@socionext.com
wb_domain_writeout_inc()
The likely/unlikely profiler noticed that the unlikely statement in
wb_domain_writeout_inc() is constantly wrong. This is due to the "not"
(!) being outside the unlikely statement. It is likely that
dom->period_time will be set, but unlikely that it wont be. Move the
not into the unlikely statement.
Link: http://lkml.kernel.org/r/20170206120035.3c2e2b91@gandalf.local.home
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
We will want to have struct backing_dev_info allocated separately from
struct request_queue. As the first step add pointer to backing_dev_info
to request_queue and convert all users touching it. No functional
changes in this patch.
Signed-off-by: Jens Axboe <axboe@fb.com>
This is an exceptionally complicated function with just one caller
(tag_pages_for_writeback). We devote a large portion of the runtime of
the test suite to testing this one function which has one caller. By
introducing the new function radix_tree_iter_tag_set(), we can eliminate
all of the complexity while keeping the performance. The caller can now
use a fairly standard radix_tree_for_each() loop, and it doesn't need to
worry about tricksy things like 'start' wrapping.
The test suite continues to spend a large amount of time investigating
this function, but now it's testing the underlying primitives such as
radix_tree_iter_resume() and the radix_tree_for_each_tagged() iterator
which are also used by other parts of the kernel.
Link: http://lkml.kernel.org/r/1480369871-5271-57-git-send-email-mawilcox@linuxonhyperv.com
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Note in the bdi_writeback structure whenever a task ends up sleeping
waiting for progress. We can use that information in the lower layers
to increase the priority of writes.
File pages use a set of radix tree tags (DIRTY, TOWRITE, WRITEBACK,
etc.) to accelerate finding the pages with a specific tag in the radix
tree during inode writeback. But for anonymous pages in the swap cache,
there is no inode writeback. So there is no need to find the pages with
some writeback tags in the radix tree. It is not necessary to touch
radix tree writeback tags for pages in the swap cache.
Per Rik van Riel's suggestion, a new flag AS_NO_WRITEBACK_TAGS is
introduced for address spaces which don't need to update the writeback
tags. The flag is set for swap caches. It may be used for DAX file
systems, etc.
With this patch, the swap out bandwidth improved 22.3% (from ~1.2GB/s to
~1.48GBps) in the vm-scalability swap-w-seq test case with 8 processes.
The test is done on a Xeon E5 v3 system. The swap device used is a RAM
simulated PMEM (persistent memory) device. The improvement comes from
the reduced contention on the swap cache radix tree lock. To test
sequential swapping out, the test case uses 8 processes, which
sequentially allocate and write to the anonymous pages until RAM and
part of the swap device is used up.
Details of comparison is as follow,
base base+patch
%stddev %change %stddev
2506952 ± 2% +28.1% 3212076 ± 7% vm-scalability.throughput
1207402 ± 7% +22.3% 1476578 ± 6% vmstat.swap.so
10.86 ± 12% -23.4% 8.31 ± 16% perf-profile.cycles-pp._raw_spin_lock_irq.__add_to_swap_cache.add_to_swap_cache.add_to_swap.shrink_page_list
10.82 ± 13% -33.1% 7.24 ± 14% perf-profile.cycles-pp._raw_spin_lock_irqsave.__remove_mapping.shrink_page_list.shrink_inactive_list.shrink_zone_memcg
10.36 ± 11% -100.0% 0.00 ± -1% perf-profile.cycles-pp._raw_spin_lock_irqsave.__test_set_page_writeback.bdev_write_page.__swap_writepage.swap_writepage
10.52 ± 12% -100.0% 0.00 ± -1% perf-profile.cycles-pp._raw_spin_lock_irqsave.test_clear_page_writeback.end_page_writeback.page_endio.pmem_rw_page
Link: http://lkml.kernel.org/r/1472578089-5560-1-git-send-email-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
throttle_vm_writeout() was introduced back in 2005 to fix OOMs caused by
excessive pageout activity during the reclaim. Too many pages could be
put under writeback therefore LRUs would be full of unreclaimable pages
until the IO completes and in turn the OOM killer could be invoked.
There have been some important changes introduced since then in the
reclaim path though. Writers are throttled by balance_dirty_pages when
initiating the buffered IO and later during the memory pressure, the
direct reclaim is throttled by wait_iff_congested if the node is
considered congested by dirty pages on LRUs and the underlying bdi is
congested by the queued IO. The kswapd is throttled as well if it
encounters pages marked for immediate reclaim or under writeback which
signals that that there are too many pages under writeback already.
Finally should_reclaim_retry does congestion_wait if the reclaim cannot
make any progress and there are too many dirty/writeback pages.
Another important aspect is that we do not issue any IO from the direct
reclaim context anymore. In a heavy parallel load this could queue a
lot of IO which would be very scattered and thus unefficient which would
just make the problem worse.
This three mechanisms should throttle and keep the amount of IO in a
steady state even under heavy IO and memory pressure so yet another
throttling point doesn't really seem helpful. Quite contrary, Mikulas
Patocka has reported that swap backed by dm-crypt doesn't work properly
because the swapout IO cannot make sufficient progress as the writeout
path depends on dm_crypt worker which has to allocate memory to perform
the encryption. In order to guarantee a forward progress it relies on
the mempool allocator. mempool_alloc(), however, prefers to use the
underlying (usually page) allocator before it grabs objects from the
pool. Such an allocation can dive into the memory reclaim and
consequently to throttle_vm_writeout. If there are too many dirty or
pages under writeback it will get throttled even though it is in fact a
flusher to clear pending pages.
kworker/u4:0 D ffff88003df7f438 10488 6 2 0x00000000
Workqueue: kcryptd kcryptd_crypt [dm_crypt]
Call Trace:
schedule+0x3c/0x90
schedule_timeout+0x1d8/0x360
io_schedule_timeout+0xa4/0x110
congestion_wait+0x86/0x1f0
throttle_vm_writeout+0x44/0xd0
shrink_zone_memcg+0x613/0x720
shrink_zone+0xe0/0x300
do_try_to_free_pages+0x1ad/0x450
try_to_free_pages+0xef/0x300
__alloc_pages_nodemask+0x879/0x1210
alloc_pages_current+0xa1/0x1f0
new_slab+0x2d7/0x6a0
___slab_alloc+0x3fb/0x5c0
__slab_alloc+0x51/0x90
kmem_cache_alloc+0x27b/0x310
mempool_alloc_slab+0x1d/0x30
mempool_alloc+0x91/0x230
bio_alloc_bioset+0xbd/0x260
kcryptd_crypt+0x114/0x3b0 [dm_crypt]
Let's just drop throttle_vm_writeout altogether. It is not very much
helpful anymore.
I have tried to test a potential writeback IO runaway similar to the one
described in the original patch which has introduced that [1]. Small
virtual machine (512MB RAM, 4 CPUs, 2G of swap space and disk image on a
rather slow NFS in a sync mode on the host) with 8 parallel writers each
writing 1G worth of data. As soon as the pagecache fills up and the
direct reclaim hits then I start anon memory consumer in a loop
(allocating 300M and exiting after populating it) in the background to
make the memory pressure even stronger as well as to disrupt the steady
state for the IO. The direct reclaim is throttled because of the
congestion as well as kswapd hitting congestion_wait due to nr_immediate
but throttle_vm_writeout doesn't ever trigger the sleep throughout the
test. Dirty+writeback are close to nr_dirty_threshold with some
fluctuations caused by the anon consumer.
[1] https://www2.kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.9-rc1/2.6.9-rc1-mm3/broken-out/vm-pageout-throttling.patch
Link: http://lkml.kernel.org/r/1471171473-21418-1-git-send-email-mhocko@kernel.org
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: NeilBrown <neilb@suse.com>
Cc: Ondrej Kozina <okozina@redhat.com>
Install the callbacks via the state machine and let the core invoke
the callbacks on the already online CPUs.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Jens Axboe <axboe@fb.com>
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-6-bigeasy@linutronix.de
If per-zone LRU accounting is available then there is no point
approximating whether reclaim and compaction should retry based on pgdat
statistics. This is effectively a revert of "mm, vmstat: remove zone
and node double accounting by approximating retries" with the difference
that inactive/active stats are still available. This preserves the
history of why the approximation was retried and why it had to be
reverted to handle OOM kills on 32-bit systems.
Link: http://lkml.kernel.org/r/1469110261-7365-4-git-send-email-mgorman@techsingularity.net
Acked-by: Minchan Kim <minchan@kernel.org>
