path: root/mm/page_alloc.c
2007-08-31process_zones(): fix recovery codeAndrew Morton
Don't try to free memory which we didn't allocate. Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22Apply memory policies to top two highest zones when highest zone is ZONE_MOVABLEMel Gorman
The NUMA layer only supports NUMA policies for the highest zone. When ZONE_MOVABLE is configured with kernelcore=, the the highest zone becomes ZONE_MOVABLE. The result is that policies are only applied to allocations like anonymous pages and page cache allocated from ZONE_MOVABLE when the zone is used. This patch applies policies to the two highest zones when the highest zone is ZONE_MOVABLE. As ZONE_MOVABLE consists of pages from the highest "real" zone, it's always functionally equivalent. The patch has been tested on a variety of machines both NUMA and non-NUMA covering x86, x86_64 and ppc64. No abnormal results were seen in kernbench, tbench, dbench or hackbench. It passes regression tests from the numactl package with and without kernelcore= once numactl tests are patched to wait for vmstat counters to update. akpm: this is the nasty hack to fix NUMA mempolicies in the presence of ZONE_MOVABLE and kernelcore= in 2.6.23. Christoph says "For .24 either merge the mobility or get the other solution that Mel is working on. That solution would only use a single zonelist per node and filter on the fly. That may help performance and also help to make memory policies work better." Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Do not trigger OOM-killer for high-order allocation failuresMel Gorman
out_of_memory() may be called when an allocation is failing and the direct reclaim is not making any progress. This does not take into account the requested order of the allocation. If the request if for an order larger than PAGE_ALLOC_COSTLY_ORDER, it is reasonable to fail the allocation because the kernel makes no guarantees about those allocations succeeding. This false OOM situation can occur if a user is trying to grow the hugepage pool in a script like; #!/bin/bash REQUIRED=$1 echo 1 > /proc/sys/vm/hugepages_treat_as_movable echo $REQUIRED > /proc/sys/vm/nr_hugepages ACTUAL=`cat /proc/sys/vm/nr_hugepages` while [ $REQUIRED -ne $ACTUAL ]; do echo Huge page pool at $ACTUAL growing to $REQUIRED echo $REQUIRED > /proc/sys/vm/nr_hugepages ACTUAL=`cat /proc/sys/vm/nr_hugepages` sleep 1 done This is a reasonable scenario when ZONE_MOVABLE is in use but triggers OOM easily on 2.6.23-rc1. This patch will fail an allocation for an order above PAGE_ALLOC_COSTLY_ORDER instead of killing processes and retrying. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Introduce CONFIG_SUSPEND for suspend-to-Ram and standbyRafael J. Wysocki
Introduce CONFIG_SUSPEND representing the ability to enter system sleep states, such as the ACPI S3 state, and allow the user to choose SUSPEND and HIBERNATION independently of each other. Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has been chosen and the kernel is intended for SMP systems. Also, introduce CONFIG_PM_SLEEP which is automatically selected if CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the code needed for both suspend and hibernation. The top-level power management headers and the ACPI code related to suspend and hibernation are modified to use the new definitions (the changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce the number of ifdefs). There are many other files in which CONFIG_PM can be replaced with CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26Allow nodes to exist that only contain ZONE_MOVABLEMel Gorman
With the introduction of kernelcore=, a configurable zone is created on request. In some cases, this value will be small enough that some nodes contain only ZONE_MOVABLE. On some NUMA configurations when this occurs, arch-independent zone-sizing will get the size of the memory holes within the node incorrect. The value of present_pages goes negative and the boot fails. This patch fixes the bug in the calculation of the size of the hole. The test case is to boot test a NUMA machine with a low value of kernelcore= before and after the patch is applied. While this bug exists in early kernel it cannot be triggered in practice. This patch has been boot-tested on a variety machines with and without kernelcore= set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20mm: fix memory hotplug oops from ZONE_MOVABLE changes.Paul Mundt
zone_movable_pfn is presently marked as __initdata and referenced from adjust_zone_range_for_zone_movable(), which in turn is referenced by zone_spanned_pages_in_node(). Both of these are __meminit annotated. When memory hotplug is enabled, this will oops on a hot-add, due to zone_movable_pfn having been freed. __meminitdata annotation gives the desired behaviour. This will only impact platforms that enable both memory hotplug and ARCH_POPULATES_NODE_MAP. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: share PG_readahead and PG_reclaimFengguang Wu
Share the same page flag bit for PG_readahead and PG_reclaim. One is used only on file reads, another is only for emergency writes. One is used mostly for fresh/young pages, another is for old pages. Combinations of possible interactions are: a) clear PG_reclaim => implicit clear of PG_readahead it will delay an asynchronous readahead into a synchronous one it actually does _good_ for readahead: the pages will be reclaimed soon, it's readahead thrashing! in this case, synchronous readahead makes more sense. b) clear PG_readahead => implicit clear of PG_reclaim one(and only one) page will not be reclaimed in time it can be avoided by checking PageWriteback(page) in readahead first c) set PG_reclaim => implicit set of PG_readahead will confuse readahead and make it restart the size rampup process it's a trivial problem, and can mostly be avoided by checking PageWriteback(page) first in readahead d) set PG_readahead => implicit set of PG_reclaim PG_readahead will never be set on already cached pages. PG_reclaim will always be cleared on dirtying a page. so not a problem. In summary, a) we get better behavior b,d) possible interactions can be avoided c) racy condition exists that might affect readahead, but the chance is _really_ low, and the hurt on readahead is trivial. Compound pages also use PG_reclaim, but for now they do not interact with reclaim/readahead code. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: introduce PG_readaheadFengguang Wu
Introduce a new page flag: PG_readahead. It acts as a look-ahead mark, which tells the page reader: Hey, it's time to invoke the read-ahead logic. For the sake of I/O pipelining, don't wait until it runs out of cached pages! Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: vary maximum delegation limit based on RAM sizeMeelap Shah
Our original NFSv4 delegation policy was to give out a read delegation on any open when it was possible to. Since the lifetime of a delegation isn't limited to that of an open, a client may quite reasonably hang on to a delegation as long as it has the inode cached. This becomes an obvious problem the first time a client's inode cache approaches the size of the server's total memory. Our first quick solution was to add a hard-coded limit. This patch makes a mild incremental improvement by varying that limit according to the server's total memory size, allowing at most 4 delegations per megabyte of RAM. My quick back-of-the-envelope calculation finds that in the worst case (where every delegation is for a different inode), a delegation could take about 1.5K, which would make the worst case usage about 6% of memory. The new limit works out to be about the same as the old on a 1-gig server. [akpm@linux-foundation.org: Don't needlessly bloat vmlinux] [akpm@linux-foundation.org: Make it right for highmem machines] Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Lumpy Reclaim V4Andy Whitcroft
When we are out of memory of a suitable size we enter reclaim. The current reclaim algorithm targets pages in LRU order, which is great for fairness at order-0 but highly unsuitable if you desire pages at higher orders. To get pages of higher order we must shoot down a very high proportion of memory; >95% in a lot of cases. This patch set adds a lumpy reclaim algorithm to the allocator. It targets groups of pages at the specified order anchored at the end of the active and inactive lists. This encourages groups of pages at the requested orders to move from active to inactive, and active to free lists. This behaviour is only triggered out of direct reclaim when higher order pages have been requested. This patch set is particularly effective when utilised with an anti-fragmentation scheme which groups pages of similar reclaimability together. This patch set is based on Peter Zijlstra's lumpy reclaim V2 patch which forms the foundation. Credit to Mel Gorman for sanitity checking. Mel said: The patches have an application with hugepage pool resizing. When lumpy-reclaim is used used with ZONE_MOVABLE, the hugepages pool can be resized with greater reliability. Testing on a desktop machine with 2GB of RAM showed that growing the hugepage pool with ZONE_MOVABLE on it's own was very slow as the success rate was quite low. Without lumpy-reclaim, each attempt to grow the pool by 100 pages would yield 1 or 2 hugepages. With lumpy-reclaim, getting 40 to 70 hugepages on each attempt was typical. [akpm@osdl.org: ia64 pfn_to_nid fixes and loop cleanup] [bunk@stusta.de: static declarations for internal functions] [a.p.zijlstra@chello.nl: initial lumpy V2 implementation] Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add a movablecore= parameter for sizing ZONE_MOVABLEMel Gorman
This patch adds a new parameter for sizing ZONE_MOVABLE called movablecore=. While kernelcore= is used to specify the minimum amount of memory that must be available for all allocation types, movablecore= is used to specify the minimum amount of memory that is used for migratable allocations. The amount of memory used for migratable allocations determines how large the huge page pool could be dynamically resized to at runtime for example. How movablecore is actually handled is that the total number of pages in the system is calculated and a value is set for kernelcore that is kernelcore == totalpages - movablecore Both kernelcore= and movablecore= can be safely specified at the same time. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17handle kernelcore=: genericMel Gorman
This patch adds the kernelcore= parameter for x86. Once all patches are applied, a new command-line parameter exist and a new sysctl. This patch adds the necessary documentation. From: Yasunori Goto <y-goto@jp.fujitsu.com> When "kernelcore" boot option is specified, kernel can't boot up on ia64 because of an infinite loop. In addition, the parsing code can be handled in an architecture-independent manner. This patch uses common code to handle the kernelcore= parameter. It is only available to architectures that support arch-independent zone-sizing (i.e. define CONFIG_ARCH_POPULATES_NODE_MAP). Other architectures will ignore the boot parameter. [bunk@stusta.de: make cmdline_parse_kernelcore() static] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Create the ZONE_MOVABLE zoneMel Gorman
The following 8 patches against 2.6.20-mm2 create a zone called ZONE_MOVABLE that is only usable by allocations that specify both __GFP_HIGHMEM and __GFP_MOVABLE. This has the effect of keeping all non-movable pages within a single memory partition while allowing movable allocations to be satisfied from either partition. The patches may be applied with the list-based anti-fragmentation patches that groups pages together based on mobility. The size of the zone is determined by a kernelcore= parameter specified at boot-time. This specifies how much memory is usable by non-movable allocations and the remainder is used for ZONE_MOVABLE. Any range of pages within ZONE_MOVABLE can be released by migrating the pages or by reclaiming. When selecting a zone to take pages from for ZONE_MOVABLE, there are two things to consider. First, only memory from the highest populated zone is used for ZONE_MOVABLE. On the x86, this is probably going to be ZONE_HIGHMEM but it would be ZONE_DMA on ppc64 or possibly ZONE_DMA32 on x86_64. Second, the amount of memory usable by the kernel will be spread evenly throughout NUMA nodes where possible. If the nodes are not of equal size, the amount of memory usable by the kernel on some nodes may be greater than others. By default, the zone is not as useful for hugetlb allocations because they are pinned and non-migratable (currently at least). A sysctl is provided that allows huge pages to be allocated from that zone. This means that the huge page pool can be resized to the size of ZONE_MOVABLE during the lifetime of the system assuming that pages are not mlocked. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. Credit goes to Andy Whitcroft for catching a large variety of problems during review of the patches. This patch creates an additional zone, ZONE_MOVABLE. This zone is only usable by allocations which specify both __GFP_HIGHMEM and __GFP_MOVABLE. Hot-added memory continues to be placed in their existing destination as there is no mechanism to redirect them to a specific zone. [y-goto@jp.fujitsu.com: Fix section mismatch of memory hotplug related code] [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fault-injection: add min-order parameter to fail_page_allocAkinobu Mita
Limiting smaller allocation failures by fault injection helps to find real possible bugs. Because higher order allocations are likely to fail and zero-order allocations are not likely to fail. This patch adds min-order parameter to fail_page_alloc. It specifies the minimum page allocation order to be injected failures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mm/page_alloc.c: lower printk severityDan Aloni
Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mm: more __meminit annotationsPaul Mundt
Currently zone_spanned_pages_in_node() and zone_absent_pages_in_node() are non-static for ARCH_POPULATES_NODE_MAP and static otherwise. However, only the non-static versions are __meminit annotated, despite only being called from __meminit functions in either case. zone_init_free_lists() is currently non-static and not __meminit annotated either, despite only being called once in the entire tree by init_currently_empty_zone(), which too is __meminit. So make it static and properly annotated. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mm: fix improper .init-type section referencesJan Beulich
.. which modpost started warning about. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16MM: alloc_large_system_hash() can free some memory for non power-of-two ↵Eric Dumazet
bucketsize alloc_large_system_hash() is called at boot time to allocate space for several large hash tables. Lately, TCP hash table was changed and its bucketsize is not a power-of-two anymore. On most setups, alloc_large_system_hash() allocates one big page (order > 0) with __get_free_pages(GFP_ATOMIC, order). This single high_order page has a power-of-two size, bigger than the needed size. We can free all pages that wont be used by the hash table. On a 1GB i386 machine, this patch saves 128 KB of LOWMEM memory. TCP established hash table entries: 32768 (order: 6, 393216 bytes) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16change zonelist order: zonelist order selection logicKAMEZAWA Hiroyuki
Make zonelist creation policy selectable from sysctl/boot option v6. This patch makes NUMA's zonelist (of pgdat) order selectable. Available order are Default(automatic)/ Node-based / Zone-based. [Default Order] The kernel selects Node-based or Zone-based order automatically. [Node-based Order] This policy treats the locality of memory as the most important parameter. Zonelist order is created by each zone's locality. This means lower zones (ex. ZONE_DMA) can be used before higher zone (ex. ZONE_NORMAL) exhausion. IOW. ZONE_DMA will be in the middle of zonelist. current 2.6.21 kernel uses this. Pros. * A user can expect local memory as much as possible. Cons. * lower zone will be exhansted before higher zone. This may cause OOM_KILL. Maybe suitable if ZONE_DMA is relatively big and you never see OOM_KILL because of ZONE_DMA exhaution and you need the best locality. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(0)'s DMA -> node(1)'s NORMAL. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. [Zone-based order] This policy treats the zone type as the most important parameter. Zonelist order is created by zone-type order. This means lower zone never be used bofere higher zone exhaustion. IOW. ZONE_DMA will be always at the tail of zonelist. Pros. * OOM_KILL(bacause of lower zone) occurs only if the whole zones are exhausted. Cons. * memory locality may not be best. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(1)'s NORMAL -> node(0)'s DMA. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. bootoption "numa_zonelist_order=" and proc/sysctl is supporetd. command: %echo N > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Node-based order. command: %echo Z > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Zone-based order. Thanks to Lee Schermerhorn, he gives me much help and codes. [Lee.Schermerhorn@hp.com: add check_highest_zone to build_zonelists_in_zone_order] [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "jesse.barnes@intel.com" <jesse.barnes@intel.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-15mm: Fix memory/cpu hotplug section mismatch and oops.Paul Mundt
When building with memory hotplug enabled and cpu hotplug disabled, we end up with the following section mismatch: WARNING: mm/built-in.o(.text+0x4e58): Section mismatch: reference to .init.text: (between 'free_area_init_node' and '__build_all_zonelists') This happens as a result of: -> free_area_init_node() -> free_area_init_core() -> zone_pcp_init() <-- all __meminit up to this point -> zone_batchsize() <-- marked as __cpuinit fo This happens because CONFIG_HOTPLUG_CPU=n sets __cpuinit to __init, but CONFIG_MEMORY_HOTPLUG=y unsets __meminit. Changing zone_batchsize() to __devinit fixes this. __devinit is the only thing that is common between CONFIG_HOTPLUG_CPU=y and CONFIG_MEMORY_HOTPLUG=y. In the long run, perhaps this should be moved to another section identifier completely. Without this, memory hot-add of offline nodes (via hotadd_new_pgdat()) will oops if CPU hotplug is not also enabled. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> -- mm/page_alloc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
2007-05-31m68k: discontinuous memory supportRoman Zippel
Fix support for discontinuous memory Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23fix unused setup_nr_node_idsMiklos Szeredi
mm/page_alloc.c:931: warning: 'setup_nr_node_ids' defined but not used This is now the only (!) compiler warning I get in my UML build :) Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19mm: fix section mismatch warningsSam Ravnborg
modpost had two cases hardcoded for mm/ Shift over to __init_refok and kill the hardcoded function names in modpost. This has the drawback that the functions will always be kept no matter configuration. With previous code the function were placed in init section if configuration allowed it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-10early_pfn_to_nid needs to be __meminitStephen Rothwell
Since it is referenced by memmap_init_zone (which is __meminit) via the early_pfn_in_nid macro when CONFIG_NODES_SPAN_OTHER_NODES is set (which basically means PowerPC 64). This removes a section mismatch warning in those circumstances. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Move remote node draining out of slab allocatorsChristoph Lameter
Currently the slab allocators contain callbacks into the page allocator to perform the draining of pagesets on remote nodes. This requires SLUB to have a whole subsystem in order to be compatible with SLAB. Moving node draining out of the slab allocators avoids a section of code in SLUB. Move the node draining so that is is done when the vm statistics are updated. At that point we are already touching all the cachelines with the pagesets of a processor. Add a expire counter there. If we have to update per zone or global vm statistics then assume that the pageset will require subsequent draining. The expire counter will be decremented on each vm stats update pass until it reaches zero. Then we will drain one batch from the pageset. The draining will cause vm counter updates which will then cause another expiration until the pcp is empty. So we will drain a batch every 3 seconds. Note that remote node draining is a somewhat esoteric feature that is required on large NUMA systems because otherwise significant portions of system memory can become trapped in pcp queues. The number of pcp is determined by the number of processors and nodes in a system. A system with 4 processors and 2 nodes has 8 pcps which is okay. But a system with 1024 processors and 512 nodes has 512k pcps with a high potential for large amount of memory being caught in them. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add white list into modpost.c for memory hotplug code and ia64's machvec sectionYasunori Goto
This patch is add white list into modpost.c for some functions and ia64's section to fix section mismatchs. sparse_index_alloc() and zone_wait_table_init() calls bootmem allocator at boot time, and kmalloc/vmalloc at hotplug time. If config memory hotplug is on, there are references of bootmem allocater(init text) from them (normal text). This is cause of section mismatch. Bootmem is called by many functions and it must be used only at boot time. I think __init of them should keep for section mismatch check. So, I would like to register sparse_index_alloc() and zone_wait_table_init() into white list. In addition, ia64's .machvec section is function table of some platform dependent code. It is mixture of .init.text and normal text. These reference of __init functions are valid too. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use inline functions for changing page flagsRafael J. Wysocki
Replace direct invocations of SetPageNosave(), SetPageNosaveFree() etc. with calls to inline functions that can be changed in subsequent patches without modifying the code calling them. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: optimize compound_head() by avoiding a shared page flagChristoph Lameter
The patch adds PageTail(page) and PageHead(page) to check if a page is the head or the tail of a compound page. This is done by masking the two bits describing the state of a compound page and then comparing them. So one comparision and a branch instead of two bit checks and two branches. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Do not disable interrupts when reading min_free_kbytesMel Gorman
The sysctl handler for min_free_kbytes calls setup_per_zone_pages_min() on read or write. This function iterates through every zone and calls spin_lock_irqsave() on the zone LRU lock. When reading min_free_kbytes, this is a total waste of time that disables interrupts on the local processor. It might even be noticable machines with large numbers of zones if a process started constantly reading min_free_kbytes. This patch only calls setup_per_zone_pages_min() only on write. Tested on an x86 laptop and it did the right thing. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07add pfn_valid_within helper for sub-MAX_ORDER hole detectionAndy Whitcroft
Generally we work under the assumption that memory the mem_map array is contigious and valid out to MAX_ORDER_NR_PAGES block of pages, ie. that if we have validated any page within this MAX_ORDER_NR_PAGES block we need not check any other. This is not true when CONFIG_HOLES_IN_ZONE is set and we must check each and every reference we make from a pfn. Add a pfn_valid_within() helper which should be used when scanning pages within a MAX_ORDER_NR_PAGES block when we have already checked the validility of the block normally with pfn_valid(). This can then be optimised away when we do not have holes within a MAX_ORDER_NR_PAGES block of pages. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Safer nr_node_ids and nr_node_ids determination and initial valuesChristoph Lameter
The nr_cpu_ids value is currently only calculated in smp_init. However, it may be needed before (SLUB needs it on kmem_cache_init!) and other kernel components may also want to allocate dynamically sized per cpu array before smp_init. So move the determination of possible cpus into sched_init() where we already loop over all possible cpus early in boot. Also initialize both nr_node_ids and nr_cpu_ids with the highest value they could take. If we have accidental users before these values are determined then the current valud of 0 may cause too small per cpu and per node arrays to be allocated. If it is set to the maximum possible then we only waste some memory for early boot users. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] Rename PG_checked to PG_owner_priv_1Nick Piggin
Rename PG_checked to PG_owner_priv_1 to reflect its availablilty as a private flag for use by the owner/allocator of the page. In the case of pagecache pages (which might be considered to be owned by the mm), filesystems may use the flag. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] slab: reduce size of alien cache to cover only possible nodesChristoph Lameter
The alien cache is a per cpu per node array allocated for every slab on the system. Currently we size this array for all nodes that the kernel does support. For IA64 this is 1024 nodes. So we allocate an array with 1024 objects even if we only boot a system with 4 nodes. This patch uses "nr_node_ids" to determine the number of possible nodes supported by a hardware configuration and only allocates an alien cache sized for possible nodes. The initialization of nr_node_ids occurred too late relative to the bootstrap of the slab allocator and so I moved the setup_nr_node_ids() into free_area_init_nodes(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] Replace highest_possible_node_id() with nr_node_idsChristoph Lameter
highest_possible_node_id() is currently used to calculate the last possible node idso that the network subsystem can figure out how to size per node arrays. I think having the ability to determine the maximum amount of nodes in a system at runtime is useful but then we should name this entry correspondingly, it should return the number of node_ids, and the the value needs to be setup only once on bootup. The node_possible_map does not change after bootup. This patch introduces nr_node_ids and replaces the use of highest_possible_node_id(). nr_node_ids is calculated on bootup when the page allocators pagesets are initialized. [deweerdt@free.fr: fix oops] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] optional ZONE_DMA: optional ZONE_DMA in the VMChristoph Lameter
Make ZONE_DMA optional in core code. - ifdef all code for ZONE_DMA and related definitions following the example for ZONE_DMA32 and ZONE_HIGHMEM. - Without ZONE_DMA, ZONE_HIGHMEM and ZONE_DMA32 we get to a ZONES_SHIFT of 0. - Modify the VM statistics to work correctly without a DMA zone. - Modify slab to not create DMA slabs if there is no ZONE_DMA. [akpm@osdl.org: cleanup] [jdike@addtoit.com: build fix] [apw@shadowen.org: Simplify calculation of the number of bits we need for ZONES_SHIFT] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] optional ZONE_DMA: deal with cases of ZONE_DMA meaning the first zoneChristoph Lameter
This patchset follows up on the earlier work in Andrew's tree to reduce the number of zones. The patches allow to go to a minimum of 2 zones. This one allows also to make ZONE_DMA optional and therefore the number of zones can be reduced to one. ZONE_DMA is usually used for ISA DMA devices. There are a number of reasons why we would not want to have ZONE_DMA 1. Some arches do not need ZONE_DMA at all. 2. With the advent of IOMMUs DMA zones are no longer needed. The necessity of DMA zones may drastically be reduced in the future. This patchset allows a compilation of a kernel without that overhead. 3. Devices that require ISA DMA get rare these days. All my systems do not have any need for ISA DMA. 4. The presence of an additional zone unecessarily complicates VM operations because it must be scanned and balancing logic must operate on its. 5. With only ZONE_NORMAL one can reach the situation where we have only one zone. This will allow the unrolling of many loops in the VM and allows the optimization of varous code paths in the VM. 6. Having only a single zone in a NUMA system results in a 1-1 correspondence between nodes and zones. Various additional optimizations to critical VM paths become possible. Many systems today can operate just fine with a single zone. If you look at what is in ZONE_DMA then one usually sees that nothing uses it. The DMA slabs are empty (Some arches use ZONE_DMA instead of ZONE_NORMAL, then ZONE_NORMAL will be empty instead). On all of my systems (i386, x86_64, ia64) ZONE_DMA is completely empty. Why constantly look at an empty zone in /proc/zoneinfo and empty slab in /proc/slabinfo? Non i386 also frequently have no need for ZONE_DMA and zones stay empty. The patchset was tested on i386 (UP / SMP), x86_64 (UP, NUMA) and ia64 (NUMA). The RFC posted earlier (see http://marc.theaimsgroup.com/?l=linux-kernel&m=115231723513008&w=2) had lots of #ifdefs in them. An effort has been made to minize the number of #ifdefs and make this as compact as possible. The job was made much easier by the ongoing efforts of others to extract common arch specific functionality. I have been running this for awhile now on my desktop and finally Linux is using all my available RAM instead of leaving the 16MB in ZONE_DMA untouched: christoph@pentium940:~$ cat /proc/zoneinfo Node 0, zone Normal pages free 4435 min 1448 low 1810 high 2172 active 241786 inactive 210170 scanned 0 (a: 0 i: 0) spanned 524224 present 524224 nr_anon_pages 61680 nr_mapped 14271 nr_file_pages 390264 nr_slab_reclaimable 27564 nr_slab_unreclaimable 1793 nr_page_table_pages 449 nr_dirty 39 nr_writeback 0 nr_unstable 0 nr_bounce 0 cpu: 0 pcp: 0 count: 156 high: 186 batch: 31 cpu: 0 pcp: 1 count: 9 high: 62 batch: 15 vm stats threshold: 20 cpu: 1 pcp: 0 count: 177 high: 186 batch: 31 cpu: 1 pcp: 1 count: 12 high: 62 batch: 15 vm stats threshold: 20 all_unreclaimable: 0 prev_priority: 12 temp_priority: 12 start_pfn: 0 This patch: In two places in the VM we use ZONE_DMA to refer to the first zone. If ZONE_DMA is optional then other zones may be first. So simply replace ZONE_DMA with zone 0. This also fixes ZONETABLE_PGSHIFT. If we have only a single zone then ZONES_PGSHIFT may become 0 because there is no need anymore to encode the zone number related to a pgdat. However, we still need a zonetable to index all the zones for each node if this is a NUMA system. Therefore define ZONETABLE_SHIFT unconditionally as the offset of the ZONE field in page flags. [apw@shadowen.org: fix mismerge] Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop get_zone_counts()Christoph Lameter
Values are available via ZVC sums. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop nr_free_pages_pgdat()Christoph Lameter
Function is unnecessary now. We can use the summing features of the ZVCs to get the values we need. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop free_pages()Christoph Lameter
nr_free_pages is now a simple access to a global variable. Make it a macro instead of a function. The nr_free_pages now requires vmstat.h to be included. There is one occurrence in power management where we need to add the include. Directly refrer to global_page_state() there to clarify why the #include was added. [akpm@osdl.org: arm build fix] [akpm@osdl.org: sparc64 build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Use ZVC for free_pagesChristoph Lameter
This is again simplifies some of the VM counter calculations through the use of the ZVC consolidated counters. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Use ZVC for inactive and active countsChristoph Lameter
The determination of the dirty ratio to determine writeback behavior is currently based on the number of total pages on the system. However, not all pages in the system may be dirtied. Thus the ratio is always too low and can never reach 100%. The ratio may be particularly skewed if large hugepage allocations, slab allocations or device driver buffers make large sections of memory not available anymore. In that case we may get into a situation in which f.e. the background writeback ratio of 40% cannot be reached anymore which leads to undesired writeback behavior. This patchset fixes that issue by determining the ratio based on the actual pages that may potentially be dirty. These are the pages on the active and the inactive list plus free pages. The problem with those counts has so far been that it is expensive to calculate these because counts from multiple nodes and multiple zones will have to be summed up. This patchset makes these counters ZVC counters. This means that a current sum per zone, per node and for the whole system is always available via global variables and not expensive anymore to calculate. The patchset results in some other good side effects: - Removal of the various functions that sum up free, active and inactive page counts - Cleanup of the functions that display information via the proc filesystem. This patch: The use of a ZVC for nr_inactive and nr_active allows a simplification of some counter operations. More ZVC functionality is used for sums etc in the following patches. [akpm@osdl.org: UP build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Avoid excessive sorting of early_node_map[]Mel Gorman
find_min_pfn_for_node() and find_min_pfn_with_active_regions() sort early_node_map[] on every call. This is an excessive amount of sorting and that can be avoided. This patch always searches the whole early_node_map[] in find_min_pfn_for_node() instead of returning the first value found. The map is then only sorted once when required. Successfully boot tested on a number of machines. [akpm@osdl.org: cleanup] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] mm: show bounce pages in oom killer outputAndrew Morton
Also split that long line up - people like to send us wordwrapped oom-kill traces. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-31Revert "[PATCH] mm: micro optimise zone_watermark_ok"Linus Torvalds
This reverts commit e80ee884ae0e3794ef2b65a18a767d502ad712ee. Pawel Sikora had a boot-time oops due to it - because the sign change invalidates the following comparisons, since 'free_pages' can be negative. The micro-optimization just isn't worth it. Bisected-by: Pawel Sikora <pluto@agmk.net> Acked-by: Andrew Morton <akpm@osdl.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] Fix sparsemem on CellDave Hansen
Fix an oops experienced on the Cell architecture when init-time functions, early_*(), are called at runtime. It alters the call paths to make sure that the callers explicitly say whether the call is being made on behalf of a hotplug even, or happening at boot-time. It has been compile tested on ppc64, ia64, s390, i386 and x86_64. Acked-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] Check for populated zone in __drain_pagesChristoph Lameter
Both process_zones() and drain_node_pages() check for populated zones before touching pagesets. However, __drain_pages does not do so, This may result in a NULL pointer dereference for pagesets in unpopulated zones if a NUMA setup is combined with cpu hotplug. Initially the unpopulated zone has the pcp pointers pointing to the boot pagesets. Since the zone is not populated the boot pageset pointers will not be changed during page allocator and slab bootstrap. If a cpu is later brought down (first call to __drain_pages()) then the pcp pointers for cpus in unpopulated zones are set to NULL since __drain_pages does not first check for an unpopulated zone. If the cpu is then brought up again then we call process_zones() which will ignore the unpopulated zone. So the pageset pointers will still be NULL. If the cpu is then again brought down then __drain_pages will attempt to drain pages by following the NULL pageset pointer for unpopulated zones. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] Sanely size hash tables when using large base pagesPaul Mundt
At the moment the inode/dentry cache hash tables (common by way of alloc_large_system_hash()) are incorrectly sized by their respective detection logic when we attempt to use large base pages on systems with little memory. This results in odd behaviour when using a 64kB PAGE_SIZE, such as: Dentry cache hash table entries: 8192 (order: -1, 32768 bytes) Inode-cache hash table entries: 4096 (order: -2, 16384 bytes) The mount cache hash table is seemingly the only one that gets this right by directly taking PAGE_SIZE in to account. The following patch attempts to catch the bogus values and round it up to at least 0-order. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
