path: root/mm/pagewalk.c
2011-03-22pagewalk: only split huge pages when necessaryDave Hansen
Right now, if a mm_walk has either ->pte_entry or ->pmd_entry set, it will unconditionally split any transparent huge pages it runs in to. In practice, that means that anyone doing a cat /proc/$pid/smaps will unconditionally break down every huge page in the process and depend on khugepaged to re-collapse it later. This is fairly suboptimal. This patch changes that behavior. It teaches each ->pmd_entry handler (there are five) that they must break down the THPs themselves. Also, the _generic_ code will never break down a THP unless a ->pte_entry handler is actually set. This means that the ->pmd_entry handlers can now choose to deal with THPs without breaking them down. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Eric B Munson <emunson@mgebm.net> Tested-by: Eric B Munson <emunson@mgebm.net> Cc: Michael J Wolf <mjwolf@us.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: split_huge_page_mm/vmaAndrea Arcangeli
split_huge_page_pmd compat code. Each one of those would need to be expanded to hundred of lines of complex code without a fully reliable split_huge_page_pmd design. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25mm: remove call to find_vma in pagewalk for non-hugetlbfsDavid Sterba
Commit d33b9f45 ("mm: hugetlb: fix hugepage memory leak in walk_page_range()") introduces a check if a vma is a hugetlbfs one and later in 5dc37642 ("mm hugetlb: add hugepage support to pagemap") it is moved under #ifdef CONFIG_HUGETLB_PAGE but a needless find_vma call is left behind and its result is not used anywhere else in the function. The side-effect of caching vma for @addr inside walk->mm is neither utilized in walk_page_range() nor in called functions. Signed-off-by: David Sterba <dsterba@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Rientjes <rientjes@google.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07pagemap: fix pfn calculation for hugepageNaoya Horiguchi
When we look into pagemap using page-types with option -p, the value of pfn for hugepages looks wrong (see below.) This is because pte was evaluated only once for one vma although it should be updated for each hugepage. This patch fixes it. $ page-types -p 3277 -Nl -b huge voffset offset len flags 7f21e8a00 11e400 1 ___U___________H_G________________ 7f21e8a01 11e401 1ff ________________TG________________ ^^^ 7f21e8c00 11e400 1 ___U___________H_G________________ 7f21e8c01 11e401 1ff ________________TG________________ ^^^ One hugepage contains 1 head page and 511 tail pages in x86_64 and each two lines represent each hugepage. Voffset and offset mean virtual address and physical address in the page unit, respectively. The different hugepages should not have the same offset value. With this patch applied: $ page-types -p 3386 -Nl -b huge voffset offset len flags 7fec7a600 112c00 1 ___UD__________H_G________________ 7fec7a601 112c01 1ff ________________TG________________ ^^^ 7fec7a800 113200 1 ___UD__________H_G________________ 7fec7a801 113201 1ff ________________TG________________ ^^^ OK More info: - This patch modifies walk_page_range()'s hugepage walker. But the change only affects pagemap_read(), which is the only caller of hugepage callback. - Without this patch, hugetlb_entry() callback is called per vma, that doesn't match the natural expectation from its name. - With this patch, hugetlb_entry() is called per hugepte entry and the callback can become much simpler. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm hugetlb: add hugepage support to pagemapNaoya Horiguchi
This patch enables extraction of the pfn of a hugepage from /proc/pid/pagemap in an architecture independent manner. Details ------- My test program (leak_pagemap) works as follows: - creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,) - read()/write() something on it, - call page-types with option -p, - munmap() and unlink() the file on hugetlbfs Without my patches ------------------ $ ./leak_pagemap flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 1 0 __________________________________ 0x0000000000000804 1 0 __R________M______________________ referenced,mmap 0x000000000000086c 81 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap 0x0000000000005808 5 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked 0x0000000000005868 12 0 ___U_lA____Ma_b___________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 1 0 __RU_lA____Ma_b___________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 101 0 The output of page-types don't show any hugepage. With my patches --------------- $ ./leak_pagemap flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 1 0 __________________________________ 0x0000000000030000 51100 199 ________________TG________________ compound_tail,huge 0x0000000000028018 100 0 ___UD__________H_G________________ uptodate,dirty,compound_head,huge 0x0000000000000804 1 0 __R________M______________________ referenced,mmap 0x000000000000080c 1 0 __RU_______M______________________ referenced,uptodate,mmap 0x000000000000086c 80 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap 0x0000000000005808 4 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked 0x0000000000005868 12 0 ___U_lA____Ma_b___________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 1 0 __RU_lA____Ma_b___________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 51300 200 The output of page-types shows 51200 pages contributing to hugepages, containing 100 head pages and 51100 tail pages as expected. [akpm@linux-foundation.org: build fix] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: hugetlb: fix hugepage memory leak in walk_page_range()Naoya Horiguchi
Most callers of pmd_none_or_clear_bad() check whether the target page is in a hugepage or not, but walk_page_range() do not check it. So if we read /proc/pid/pagemap for the hugepage on x86 machine, the hugepage memory is leaked as shown below. This patch fixes it. Details ======= My test program (leak_pagemap) works as follows: - creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,) - read()/write() something on it, - call page-types with option -p (walk around the page tables), - munmap() and unlink() the file on hugetlbfs Without my patches ------------------ $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_pagemap [snip output] $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 900 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs/ $ 100 hugepages are accounted as used while there is no file on hugetlbfs. With my patches --------------- $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_pagemap [snip output] $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs $ No memory leaks. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12pagemap: pass mm into pagewalkersDave Hansen
We need this at least for huge page detection for now, because powerpc needs the vm_area_struct to be able to determine whether a virtual address is referring to a huge page (its pmd_huge() doesn't work). It might also come in handy for some of the other users. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: fix possible off-by-one in walk_pte_range()Johannes Weiner
After the loop in walk_pte_range() pte might point to the first address after the pmd it walks. The pte_unmap() is then applied to something bad. Spotted by Roel Kluin and Andreas Schwab. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Roel Kluin <12o3l@tiscali.nl> Cc: Andreas Schwab <schwab@suse.de> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Mikael Pettersson <mikpe@it.uu.se> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19mm: fix various kernel-doc commentsRandy Dunlap
Fix various kernel-doc notation in mm/: filemap.c: add function short description; convert 2 to kernel-doc fremap.c: change parameter 'prot' to @prot pagewalk.c: change "-" in function parameters to ":" slab.c: fix short description of kmem_ptr_validate() swap.c: fix description & parameters of put_pages_list() swap_state.c: fix function parameters vmalloc.c: change "@returns" to "Returns:" since that is not a parameter Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: introduce a generic page walkerMatt Mackall
Introduce a general page table walker Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
