path: root/mm/pgtable-generic.c
2015-06-24mm: clarify that the function operates on hugepage pteAneesh Kumar K.V
We have confusing functions to clear pmd, pmd_clear_* and pmd_clear. Add _huge_ to pmdp_clear functions so that we are clear that they operate on hugepage pte. We don't bother about other functions like pmdp_set_wrprotect, pmdp_clear_flush_young, because they operate on PTE bits and hence indicate they are operating on hugepage ptes Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24powerpc/mm: use generic version of pmdp_clear_flush()Aneesh Kumar K.V
Also move the pmd_trans_huge check to generic code. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: convert p[te|md]_mknonnuma and remaining page table manipulationsMel Gorman
With PROT_NONE, the traditional page table manipulation functions are sufficient. [andre.przywara@arm.com: fix compiler warning in pmdp_invalidate()] [akpm@linux-foundation.org: fix build with STRICT_MM_TYPECHECKS] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: convert p[te|md]_numa users to p[te|md]_protnone_numaMel Gorman
Convert existing users of pte_numa and friends to the new helper. Note that the kernel is broken after this patch is applied until the other page table modifiers are also altered. This patch layout is to make review easier. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-29mm: actually clear pmd_numa before invalidatingMatthew Wilcox
Commit 67f87463d3a3 ("mm: clear pmd_numa before invalidating") cleared the NUMA bit in a copy of the PMD entry, but then wrote back the original Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: clear pmd_numa before invalidatingMel Gorman
On x86, PMD entries are similar to _PAGE_PROTNONE protection and are handled as NUMA hinting faults. The following two page table protection bits are what defines them _PAGE_NUMA:set _PAGE_PRESENT:clear A PMD is considered present if any of the _PAGE_PRESENT, _PAGE_PROTNONE, _PAGE_PSE or _PAGE_NUMA bits are set. If pmdp_invalidate encounters a pmd_numa, it clears the present bit leaving _PAGE_NUMA which will be considered not present by the CPU but present by pmd_present. The existing caller of pmdp_invalidate should handle it but it's an inconsistent state for a PMD. This patch keeps the state consistent when calling pmdp_invalidate. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: convert the rest to new page table lock apiKirill A. Shutemov
Only trivial cases left. Let's convert them altogether. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm, thp: do not access mm->pmd_huge_pte directlyKirill A. Shutemov
Currently mm->pmd_huge_pte protected by page table lock. It will not work with split lock. We have to have per-pmd pmd_huge_pte for proper access serialization. For now, let's just introduce wrapper to access mm->pmd_huge_pte. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Eric W . Biederman" <ebiederm@xmission.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kees Cook <keescook@chromium.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Robin Holt <robinmholt@gmail.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm: move pgtable related functions to right placeJoonsoo Kim
pgtable related functions are mostly in pgtable-generic.c. So move remaining functions from memory.c to pgtable-generic.c. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-20mm/THP: add pmd args to pgtable deposit and withdraw APIsAneesh Kumar K.V
This will be later used by powerpc THP support. In powerpc we want to use pgtable for storing the hash index values. So instead of adding them to mm_context list, we would like to store them in the second half of pmd Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-12-11mm: Only flush the TLB when clearing an accessible pteRik van Riel
If ptep_clear_flush() is called to clear a page table entry that is accessible anyway by the CPU, eg. a _PAGE_PROTNONE page table entry, there is no need to flush the TLB on remote CPUs. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-vm3rkzevahelwhejx5uwm8ex@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-11mm,generic: only flush the local TLB in ptep_set_access_flagsRik van Riel
The function ptep_set_access_flags is only ever used to upgrade access permissions to a page. That means the only negative side effect of not flushing remote TLBs is that other CPUs may incur spurious page faults, if they happen to access the same address, and still have a PTE with the old permissions cached in their TLB. Having another CPU maybe incur a spurious page fault is faster than always incurring the cost of a remote TLB flush, so replace the remote TLB flush with a purely local one. This should be safe on every architecture that correctly implements flush_tlb_fix_spurious_fault() to actually invalidate the local TLB entry that caused a page fault, as well as on architectures where the hardware invalidates TLB entries that cause page faults. In the unlikely event that you are hitting what appears to be an infinite loop of page faults, and 'git bisect' took you to this changeset, your architecture needs to implement flush_tlb_fix_spurious_fault to actually flush the TLB entry. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michel Lespinasse <walken@google.com> Cc: Ingo Molnar <mingo@kernel.org>
2012-10-09thp: introduce pmdp_invalidate()Gerald Schaefer
On s390, a valid page table entry must not be changed while it is attached to any CPU. So instead of pmd_mknotpresent() and set_pmd_at(), an IDTE operation would be necessary there. This patch introduces the pmdp_invalidate() function, to allow architecture-specific implementations. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp: remove assumptions on pgtable_t typeGerald Schaefer
The thp page table pre-allocation code currently assumes that pgtable_t is of type "struct page *". This may not be true for all architectures, so this patch removes that assumption by replacing the functions prepare_pmd_huge_pte() and get_pmd_huge_pte() with two new functions that can be defined architecture-specific. It also removes two VM_BUG_ON checks for page_count() and page_mapcount() operating on a pgtable_t. Apart from the VM_BUG_ON removal, there will be no functional change introduced by this patch. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-25arch/tile: allow building Linux with transparent huge pages enabledChris Metcalf
The change adds some infrastructure for managing tile pmd's more generally, using pte_pmd() and pmd_pte() methods to translate pmd values to and from ptes, since on TILEPro a pmd is really just a nested structure holding a pgd (aka pte). Several existing pmd methods are moved into this framework, and a whole raft of additional pmd accessors are defined that are used by the transparent hugepage framework. The tile PTE now has a "client2" bit. The bit is used to indicate a transparent huge page is in the process of being split into subpages. This change also fixes a generic bug where the return value of the generic pmdp_splitting_flush() was incorrect. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-03-21thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGENaoya Horiguchi
These macros will be used in a later patch, where all usages are expected to be optimized away without #ifdef CONFIG_TRANSPARENT_HUGEPAGE. But to detect unexpected usages, we convert the existing BUG() to BUILD_BUG(). [akpm@linux-foundation.org: fix build in mm/pgtable-generic.c] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26mm/pgtable-generic.c: fix CONFIG_SWAP=n buildAndrew Morton
mips (and sparc32): In file included from arch/mips/include/asm/tlb.h:21, from mm/pgtable-generic.c:9: include/asm-generic/tlb.h: In function `tlb_flush_mmu': include/asm-generic/tlb.h:76: error: implicit declaration of function `release_pages' include/asm-generic/tlb.h: In function `tlb_remove_page': include/asm-generic/tlb.h:105: error: implicit declaration of function `page_cache_release' free_pages_and_swap_cache() and free_page_and_swap_cache() are macros which call release_pages() and page_cache_release(). The obvious fix is to include pagemap.h in swap.h, where those macros are defined. But that breaks sparc for weird reasons. So fix it within mm/pgtable-generic.c instead. Reported-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16fix non-x86 build failure in pmdp_get_and_clearAndrea Arcangeli
pmdp_get_and_clear/pmdp_clear_flush/pmdp_splitting_flush were trapped as BUG() and they were defined only to diminish the risk of build issues on not-x86 archs and to be consistent with the generic pte methods previously defined in include/asm-generic/pgtable.h. But they are causing more trouble than they were supposed to solve, so it's simpler not to define them when THP is off. This is also correcting the export of pmdp_splitting_flush which is currently unused (x86 isn't using the generic implementation in mm/pgtable-generic.c and no other arch needs that [yet]). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Sam Ravnborg <sam@ravnborg.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: add pmd mangling generic functionsAndrea Arcangeli
Some are needed to build but not actually used on archs not supporting transparent hugepages. Others like pmdp_clear_flush are used by x86 too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
