path: root/mm/process_vm_access.c
2015-04-11process_vm_access: switch to {compat_,}import_iovec()Al Viro
2015-02-11mm: gup: use get_user_pages_unlockedAndrea Arcangeli
This allows those get_user_pages calls to pass FAULT_FLAG_ALLOW_RETRY to the page fault in order to release the mmap_sem during the I/O. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Peter Feiner <pfeiner@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06start adding the tag to iov_iterAl Viro
For now, just use the same thing we pass to ->direct_IO() - it's all iovec-based at the moment. Pass it explicitly to iov_iter_init() and account for kvec vs. iovec in there, by the same kludge NFS ->direct_IO() uses. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06kill iov_iter_copy_from_user()Al Viro
all callers can use copy_page_from_iter() and it actually simplifies them. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-03mm/process_vm_access.c: mark function as staticRashika Kheria
Mark function as static in process_vm_access.c because it is not used outside this file. This eliminates the following warning in mm/process_vm_access.c: mm/process_vm_access.c:416:1: warning: no previous prototype for `compat_process_vm_rw' [-Wmissing-prototypes] [akpm@linux-foundation.org: remove unneeded asmlinkage - compat_process_vm_rw isn't referenced from asm] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-01process_vm_access: tidy up a bitAl Viro
saner variable names, update linuxdoc comments, etc. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01process_vm_access: don't bother with returning the amounts of bytes copiedAl Viro
we can calculate that in the caller just fine, TYVM Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01process_vm_rw_pages(): pass accurate amount of bytesAl Viro
... makes passing the amount of pages unnecessary Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01process_vm_access: take get_user_pages/put_pages one level upAl Viro
... and trim the fuck out of process_vm_rw_pages() argument list. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01process_vm_access: switch to copy_page_to_iter/iov_iter_copy_from_userAl Viro
... rather than open-coding those. As a side benefit, we get much saner loop calling those; we can just feed entire pages, instead of the "copy would span the iovec boundary, let's do it in two loop iterations" mess. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01process_vm_access: switch to iov_iterAl Viro
instead of keeping its pieces in separate variables and passing pointers to all of them... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01untangling process_vm_..., part 4Al Viro
instead of passing vector size (by value) and index (by reference), pass the number of elements remaining. That's all we care about in these functions by that point. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01untangling process_vm_..., part 3Al Viro
lift iov one more level out - from process_vm_rw_single_vec to process_vm_rw_core(). Same story as with the previous commit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01untangling process_vm_..., part 2Al Viro
move iov to caller's stack frame; the value we assign to it on the next call of process_vm_rw_pages() is equal to the value it had when the last time we were leaving process_vm_rw_pages(). drop lvec argument of process_vm_rw_pages() - it's not used anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01untangling process_vm_..., part 1Al Viro
we want to massage it to use of iov_iter. This one is an equivalent transformation - just introduce a local variable mirroring lvec + *lvec_current. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-06mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter typesHeiko Carstens
In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that performs proper zero and sign extension convert all 64 bit parameters to their corresponding 32 bit compat counterparts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-03-12Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-02Fix race in process_vm_rw_coreChristopher Yeoh
This fixes the race in process_vm_core found by Oleg (see http://article.gmane.org/gmane.linux.kernel/1235667/ for details). This has been updated since I last sent it as the creation of the new mm_access() function did almost exactly the same thing as parts of the previous version of this patch did. In order to use mm_access() even when /proc isn't enabled, we move it to kernel/fork.c where other related process mm access functions already are. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
