path: root/mm/readahead.c
2006-01-03[PATCH] add AOP_TRUNCATED_PAGE, prepend AOP_ to WRITEPAGE_ACTIVATEZach Brown
readpage(), prepare_write(), and commit_write() callers are updated to understand the special return code AOP_TRUNCATED_PAGE in the style of writepage() and WRITEPAGE_ACTIVATE. AOP_TRUNCATED_PAGE tells the caller that the callee has unlocked the page and that the operation should be tried again with a new page. OCFS2 uses this to detect and work around a lock inversion in its aop methods. There should be no change in behaviour for methods that don't return AOP_TRUNCATED_PAGE. WRITEPAGE_ACTIVATE is also prepended with AOP_ for consistency and they are made enums so that kerneldoc can be used to document their semantics. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2005-11-07[PATCH] readahead commentaryAndrew Morton
Add a few comments surrounding the generic readahead API. Also convert some ulongs into pgoff_t: the identifier for PAGE_CACHE_SIZE offsets into pagecache. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] readahead: reset cache_hit earlierSteven Pratt
We don't reset the cache hit count until after readahead does a successful readahead. This seems to leave a corner case open where we miss in cache, but don't restart the readhead right away. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
