path: root/mm/shmem.c
2011-11-30ashmem for 2.6.27.Robert Love
Forward port of ashmem to 2.6.27. Signed-off-by: Robert Love <rlove@google.com> ashmem: Don't install fault handler for private mmaps. Ashmem is used to create named private heaps. If this heap is backed by a tmpfs file it will allocate two pages for every page touched. In 2.6.27, the extra page would later be freed, but 2.6.29 does not scan anonymous pages when running without swap so the memory is not freed while the file is referenced. This change changes the behavior of private ashmem mmaps to match /dev/zero instead tmpfs. Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: Add common prefix to name reported in /proc/pid/maps Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: don't require a page aligned size This makes ashmem more similar to shmem and mmap, by not requiring the specified size to be page aligned, instead rounding it internally as needed. Signed-off-by: Marco Nelissen <marcone@android.com>
2011-08-03mm: clarify the radix_tree exceptional casesHugh Dickins
Make the radix_tree exceptional cases, mostly in filemap.c, clearer. It's hard to devise a suitable snappy name that illuminates the use by shmem/tmpfs for swap, while keeping filemap/pagecache/radix_tree generality. And akpm points out that /* radix_tree_deref_retry(page) */ comments look like calls that have been commented out for unknown reason. Skirt the naming difficulty by rearranging these blocks to handle the transient radix_tree_deref_retry(page) case first; then just explain the remaining shmem/tmpfs swap case in a comment. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs radix_tree: locate_item to speed up swapoffHugh Dickins
We have already acknowledged that swapoff of a tmpfs file is slower than it was before conversion to the generic radix_tree: a little slower there will be acceptable, if the hotter paths are faster. But it was a shock to find swapoff of a 500MB file 20 times slower on my laptop, taking 10 minutes; and at that rate it significantly slows down my testing. Now, most of that turned out to be overhead from PROVE_LOCKING and PROVE_RCU: without those it was only 4 times slower than before; and more realistic tests on other machines don't fare as badly. I've tried a number of things to improve it, including tagging the swap entries, then doing lookup by tag: I'd expected that to halve the time, but in practice it's erratic, and often counter-productive. The only change I've so far found to make a consistent improvement, is to short-circuit the way we go back and forth, gang lookup packing entries into the array supplied, then shmem scanning that array for the target entry. Scanning in place doubles the speed, so it's now only twice as slow as before (or three times slower when the PROVEs are on). So, add radix_tree_locate_item() as an expedient, once-off, single-caller hack to do the lookup directly in place. #ifdef it on CONFIG_SHMEM and CONFIG_SWAP, as much to document its limited applicability as save space in other configurations. And, sadly, #include sched.h for cond_resched(). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: use kmemdup for short symlinksHugh Dickins
But we've not yet removed the old swp_entry_t i_direct[16] from shmem_inode_info. That's because it was still being shared with the inline symlink. Remove it now (saving 64 or 128 bytes from shmem inode size), and use kmemdup() for short symlinks, say, those up to 128 bytes. I wonder why mpol_free_shared_policy() is done in shmem_destroy_inode() rather than shmem_evict_inode(), where we usually do such freeing? I guess it doesn't matter, and I'm not into NUMA mpol testing right now. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert shmem_writepage and enable swapHugh Dickins
Convert shmem_writepage() to use shmem_delete_from_page_cache() to use shmem_radix_tree_replace() to substitute swap entry for page pointer atomically in the radix tree. As with shmem_add_to_page_cache(), it's not entirely satisfactory to be copying such code from delete_from_swap_cache, but again judged easier to sell than making its other callers go through the extras. Remove the toy implementation's shmem_put_swap() and shmem_get_swap(), now unreferenced, and the hack to disable swap: it's now good to go. The way things have worked out, info->lock no longer helps to guard the shmem_swaplist: we increment swapped under shmem_swaplist_mutex only. That global mutex exclusion between shmem_writepage() and shmem_unuse() is not pretty, and we ought to find another way; but it's been forced on us by recent race discoveries, not a consequence of this patchset. And what has become of the WARN_ON_ONCE(1) free_swap_and_cache() if a swap entry was found already present? That's no longer possible, the (unknown) one inserting this page into filecache would hit the swap entry occupying that slot. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert mem_cgroup shmem to radix-swapHugh Dickins
Remove mem_cgroup_shmem_charge_fallback(): it was only required when we had to move swappage to filecache with GFP_NOWAIT. Remove the GFP_NOWAIT special case from mem_cgroup_cache_charge(), by moving its call out from shmem_add_to_page_cache() to two of thats three callers. But leave it doing mem_cgroup_uncharge_cache_page() on error: although asymmetrical, it's easier for all 3 callers to handle. These two changes would also be appropriate if anyone were to start using shmem_read_mapping_page_gfp() with GFP_NOWAIT. Remove mem_cgroup_get_shmem_target(): mc_handle_file_pte() can test radix_tree_exceptional_entry() to get what it needs for itself. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert shmem_getpage_gfp to radix-swapHugh Dickins
Convert shmem_getpage_gfp(), the engine-room of shmem, to expect page or swap entry returned from radix tree by find_lock_page(). Whereas the repetitive old method proceeded mainly under info->lock, dropping and repeating whenever one of the conditions needed was not met, now we can proceed without it, leaving shmem_add_to_page_cache() to check for a race. This way there is no need to preallocate a page, no need for an early radix_tree_preload(), no need for mem_cgroup_shmem_charge_fallback(). Move the error unwinding down to the bottom instead of repeating it throughout. ENOSPC handling is a little different from before: there is no longer any race between find_lock_page() and finding swap, but we can arrive at ENOSPC before calling shmem_recalc_inode(), which might occasionally discover freed space. Be stricter to check i_size before returning. info->lock is used for little but alloced, swapped, i_blocks updates. Move i_blocks updates out from under the max_blocks check, so even an unlimited size=0 mount can show accurate du. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert shmem_unuse_inode to radix-swapHugh Dickins
Convert shmem_unuse_inode() to use a lockless gang lookup of the radix tree, searching for matching swap. This is somewhat slower than the old method: because of repeated radix tree descents, because of copying entries up, but probably most because the old method noted and skipped once a vector page was cleared of swap. Perhaps we can devise a use of radix tree tagging to achieve that later. shmem_add_to_page_cache() uses shmem_radix_tree_replace() to compensate for the lockless lookup by checking that the expected entry is in place, under lock. It is not very satisfactory to be copying this much from add_to_page_cache_locked(), but I think easier to sell than insisting that every caller of add_to_page_cache*() go through the extras. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert shmem_truncate_range to radix-swapHugh Dickins
Disable the toy swapping implementation in shmem_writepage() - it's hard to support two schemes at once - and convert shmem_truncate_range() to a lockless gang lookup of swap entries along with pages, freeing both. Since the second loop tightens its noose until all entries of either kind have been squeezed out (and we shall make sure that there's not an instant when neither is visible), there is no longer a need for yet another pass below. shmem_radix_tree_replace() compensates for the lockless lookup by checking that the expected entry is in place, under lock, before replacing it. Here it just deletes, but will be used in later patches to substitute swap entry for page or page for swap entry. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: copy truncate_inode_pages_rangeHugh Dickins
Bring truncate.c's code for truncate_inode_pages_range() inline into shmem_truncate_range(), replacing its first call (there's a followup call below, but leave that one, it will disappear next). Don't play with it yet, apart from leaving out the cleancache flush, and (importantly) the nrpages == 0 skip, and moving shmem_setattr()'s partial page preparation into its partial page handling. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: miscellaneous trivial cleanupsHugh Dickins
While it's at its least, make a number of boring nitpicky cleanups to shmem.c, mostly for consistency of variable naming. Things like "swap" instead of "entry", "pgoff_t index" instead of "unsigned long idx". And since everything else here is prefixed "shmem_", better change init_tmpfs() to shmem_init(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: demolish old swap vector supportHugh Dickins
The maximum size of a shmem/tmpfs file has been limited by the maximum size of its triple-indirect swap vector. With 4kB page size, maximum filesize was just over 2TB on a 32-bit kernel, but sadly one eighth of that on a 64-bit kernel. (With 8kB page size, maximum filesize was just over 4TB on a 64-bit kernel, but 16TB on a 32-bit kernel, MAX_LFS_FILESIZE being then more restrictive than swap vector layout.) It's a shame that tmpfs should be more restrictive than ramfs, and this limitation has now been noticed. Add another level to the swap vector? No, it became obscure and hard to maintain, once I complicated it to make use of highmem pages nine years ago: better choose another way. Surely, if 2.4 had had the radix tree pagecache introduced in 2.5, then tmpfs would never have invented its own peculiar radix tree: we would have fitted swap entries into the common radix tree instead, in much the same way as we fit swap entries into page tables. And why should each file have a separate radix tree for its pages and for its swap entries? The swap entries are required precisely where and when the pages are not. We want to put them together in a single radix tree: which can then avoid much of the locking which was needed to prevent them from being exchanged underneath us. This also avoids the waste of memory devoted to swap vectors, first in the shmem_inode itself, then at least two more pages once a file grew beyond 16 data pages (pages accounted by df and du, but not by memcg). Allocated upfront, to avoid allocation when under swapping pressure, but pure waste when CONFIG_SWAP is not set - I have never spattered around the ifdefs to prevent that, preferring this move to sharing the common radix tree instead. There are three downsides to sharing the radix tree. One, that it binds tmpfs more tightly to the rest of mm, either requiring knowledge of swap entries in radix tree there, or duplication of its code here in shmem.c. I believe that the simplications and memory savings (and probable higher performance, not yet measured) justify that. Two, that on HIGHMEM systems with SWAP enabled, it's the lowmem radix nodes that cannot be freed under memory pressure - whereas before it was the less precious highmem swap vector pages that could not be freed. I'm hoping that 64-bit has now been accessible for long enough, that the highmem argument has grown much less persuasive. Three, that swapoff is slower than it used to be on tmpfs files, since it's using a simple generic mechanism not tailored to it: I find this noticeable, and shall want to improve, but maybe nobody else will notice. So... now remove most of the old swap vector code from shmem.c. But, for the moment, keep the simple i_direct vector of 16 pages, with simple accessors shmem_put_swap() and shmem_get_swap(), as a toy implementation to help mark where swap needs to be handled in subsequent patches. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25tmpfs: simplify unuse and writepageHugh Dickins
shmem_unuse_inode() and shmem_writepage() contain a little code to cope with pages inserted independently into the filecache, probably by a filesystem stacked on top of tmpfs, then fed to its ->readpage() or ->writepage(). Unionfs was indeed experimenting with working in that way three years ago, but I find no current examples: nowadays the stacking filesystems use vfs interfaces to the lower filesystem. It's now illegal: remove most of that code, adding some WARN_ON_ONCEs. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Erez Zadok <ezk@fsl.cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: simplify filepage/swappageHugh Dickins
We can now simplify shmem_getpage_gfp(): there is no longer a dilemma of filepage passed in via shmem_readpage(), then swappage found, which must then be copied over to it. Although at first it's tempting to replace the **pagep arg by returning struct page *, that makes a mess of IS_ERR_OR_NULL(page)s in all the callers, so leave as is. Insert BUG_ON(!PageUptodate) when we find and lock page: some of the complication came from uninitialized pages inserted into filecache prior to readpage; but now we're in control, and only release pagelock on filecache once it's uptodate (if an error occurs in reading back from swap, the page remains in swapcache, never moved to filecache). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: simplify prealloc_pageHugh Dickins
The prealloc_page handling in shmem_getpage_gfp() is unnecessarily complicated: first simplify that before going on to filepage/swappage. That's right, don't report ENOMEM when the preallocation fails: we may or may not need the page. But simply report ENOMEM once we find we do need it, instead of dropping lock, repeating allocation, unwinding on failure etc. And leave the out label on the fast path, don't goto. Fix something that looks like a bug but turns out not to be: set PageSwapBacked on prealloc_page before its mem_cgroup_cache_charge(), as the removed case was doing. That's important before adding to LRU (determines which LRU the page goes on), and does affect which path it takes through memcontrol.c, but in the end MEM_CGROUP_CHANGE_TYPE_ SHMEM is handled no differently from CACHE. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Cc: "Zhang, Yanmin" <yanmin.zhang@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: remove_shmem_readpageHugh Dickins
Remove that pernicious shmem_readpage() at last: the things we needed it for (splice, loop, sendfile, i915 GEM) are now fully taken care of by shmem_file_splice_read() and shmem_read_mapping_page_gfp(). This removal clears the way for a simpler shmem_getpage_gfp(), since page is never passed in; but leave most of that cleanup until after. sys_readahead() and sys_fadvise(POSIX_FADV_WILLNEED) will now EINVAL, instead of unexpectedly trying to read ahead on tmpfs: if that proves to be an issue for someone, then we can either arrange for them to return success instead, or try to implement async readahead on tmpfs. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: pass gfp to shmem_getpage_gfpHugh Dickins
Make shmem_getpage() a wrapper, passing mapping_gfp_mask() down to shmem_getpage_gfp(), which in turn passes gfp down to shmem_swp_alloc(). Change shmem_read_mapping_page_gfp() to use shmem_getpage_gfp() in the CONFIG_SHMEM case; but leave tiny !SHMEM using read_cache_page_gfp(). Add a BUG_ON() in case anyone happens to call this on a non-shmem mapping; though we might later want to let that case route to read_cache_page_gfp(). It annoys me to have these two almost-redundant args, gfp and fault_type: I can't find a better way; but initialize fault_type only in shmem_fault(). Note that before, read_cache_page_gfp() was allocating i915_gem's pages with __GFP_NORETRY as intended; but the corresponding swap vector pages got allocated without it, leaving a small possibility of OOM. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: refine shmem_file_splice_readHugh Dickins
Tidy up shmem_file_splice_read(): Remove readahead: okay, we could implement shmem readahead on swap, but have never done so before, swap being the slow exceptional path. Use shmem_getpage() instead of find_or_create_page() plus ->readpage(). Remove several comments: sorry, I found them more distracting than helpful, and this will not be the reference version of splice_read(). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: clone shmem_file_splice_read()Hugh Dickins
Copy __generic_file_splice_read() and generic_file_splice_read() from fs/splice.c to shmem_file_splice_read() in mm/shmem.c. Make page_cache_pipe_buf_ops and spd_release_page() accessible to it. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25tmpfs: no need to use i_lockHugh Dickins
2.6.36's 7e496299d4d2 ("tmpfs: make tmpfs scalable with percpu_counter for used blocks") to make tmpfs scalable with percpu_counter used inode->i_lock in place of sbinfo->stat_lock around i_blocks updates; but that was adverse to scalability, and unnecessary, since info->lock is already held there in the fast paths. Remove those uses of i_lock, and add info->lock in the three error paths where it's then needed across shmem_free_blocks(). It's not actually needed across shmem_unacct_blocks(), but they're so often paired that it looks wrong to split them apart. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-27tmpfs: add shmem_read_mapping_page_gfpHugh Dickins
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp() is unsuited to tmpfs, because it inserts a page into pagecache before calling the filesystem's ->readpage: tmpfs may have pages in swapcache which only it knows how to locate and switch to filecache. At present tmpfs provides a ->readpage method, and copes with this by copying pages; but soon we can simplify it by removing its ->readpage. Provide shmem_read_mapping_page_gfp() now, ready for that transition, Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h, with shmem_read_mapping_page() inline for the common mapping_gfp case. (shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the read_mapping_page functions use the mapping's ->readpage, and the read_cache_page functions use the supplied filler, so I think read_cache_page_gfp was slightly misnamed.) Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28tmpfs: fix race between truncate and writepageHugh Dickins
While running fsx on tmpfs with a memhog then swapoff, swapoff was hanging (interruptibly), repeatedly failing to locate the owner of a 0xff entry in the swap_map. Although shmem_writepage() does abandon when it sees incoming page index is beyond eof, there was still a window in which shmem_truncate_range() could come in between writepage's dropping lock and updating swap_map, find the half-completed swap_map entry, and in trying to free it, leave it in a state that swap_shmem_alloc() could not correct. Arguably a bug in __swap_duplicate()'s and swap_entry_free()'s handling of the different cases, but easiest to fix by moving swap_shmem_alloc() under cover of the lock. More interesting than the bug: it's been there since 2.6.33, why could I not see it with earlier kernels? The mmotm of two weeks ago seems to have some magic for generating races, this is just one of three I found. With yesterday's git I first saw this in mainline, bisected in search of that magic, but the easy reproducibility evaporated. Oh well, fix the bug. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add the pagefault count into memcg statsYing Han
Two new stats in per-memcg memory.stat which tracks the number of page faults and number of major page faults. "pgfault" "pgmajfault" They are different from "pgpgin"/"pgpgout" stat which count number of pages charged/discharged to the cgroup and have no meaning of reading/ writing page to disk. It is valuable to track the two stats for both measuring application's performance as well as the efficiency of the kernel page reclaim path. Counting pagefaults per process is useful, but we also need the aggregated value since processes are monitored and controlled in cgroup basis in memcg. Functional test: check the total number of pgfault/pgmajfault of all memcgs and compare with global vmstat value: $ cat /proc/vmstat | grep fault pgfault 1070751 pgmajfault 553 $ cat /dev/cgroup/memory.stat | grep fault pgfault 1071138 pgmajfault 553 total_pgfault 1071142 total_pgmajfault 553 $ cat /dev/cgroup/A/memory.stat | grep fault pgfault 199 pgmajfault 0 total_pgfault 199 total_pgmajfault 0 Performance test: run page fault test(pft) wit 16 thread on faulting in 15G anon pages in 16G container. There is no regression noticed on the "flt/cpu/s" Sample output from pft: TAG pft:anon-sys-default: Gb Thr CLine User System Wall flt/cpu/s fault/wsec 15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260 +-------------------------------------------------------------------------+ N Min Max Median Avg Stddev x 10 16682.962 17344.027 16913.524 16928.812 166.5362 + 10 16695.568 16923.896 16820.604 16824.652 84.816568 No difference proven at 95.0% confidence [akpm@linux-foundation.org: fix build] [hughd@google.com: shmem fix] Signed-off-by: Ying Han <yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25tmpfs: implement generic xattr supportEric Paris
Implement generic xattrs for tmpfs filesystems. The Feodra project, while trying to replace suid apps with file capabilities, realized that tmpfs, which is used on the build systems, does not support file capabilities and thus cannot be used to build packages which use file capabilities. Xattrs are also needed for overlayfs. The xattr interface is a bit odd. If a filesystem does not implement any {get,set,list}xattr functions the VFS will call into some random LSM hooks and the running LSM can then implement some method for handling xattrs. SELinux for example provides a method to support security.selinux but no other security.* xattrs. As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have xattr handler routines specifically to handle acls. Because of this tmpfs would loose the VFS/LSM helpers to support the running LSM. To make up for that tmpfs had stub functions that did nothing but call into the LSM hooks which implement the helpers. This new patch does not use the LSM fallback functions and instead just implements a native get/set/list xattr feature for the full security.* and trusted.* namespace like a normal filesystem. This means that tmpfs can now support both security.selinux and security.capability, which was not previously possible. The basic implementation is that I attach a: struct shmem_xattr { struct list_head list; /* anchored by shmem_inode_info->xattr_list */ char *name; size_t size; char value[0]; }; Into the struct shmem_inode_info for each xattr that is set. This implementation could easily support the user.* namespace as well, except some care needs to be taken to prevent large amounts of unswappable memory being allocated for unprivileged users. [mszeredi@suse.cz: new config option, suport trusted.*, support symlinks] Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Hugh Dickins <hughd@google.com> Tested-by: Jordi Pujol <jordipujolp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20tmpfs: fix highmem swapoff crash regressionHugh Dickins
Commit 778dd893ae78 ("tmpfs: fix race between umount and swapoff") forgot the new rules for strict atomic kmap nesting, causing WARNING: at arch/x86/mm/highmem_32.c:81 from __kunmap_atomic(), then BUG: unable to handle kernel paging request at fffb9000 from shmem_swp_set() when shmem_unuse_inode() is handling swapoff with highmem in use. My disgrace again. See https://bugzilla.kernel.org/show_bug.cgi?id=35352 Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-14tmpfs: fix race between swapoff and writepageHugh Dickins
Shame on me! Commit b1dea800ac39 "tmpfs: fix race between umount and writepage" fixed the advertized race, but introduced another: as even its comment makes clear, we cannot safely rely on a peek at list_empty() while holding no lock - until info->swapped is set, shmem_unuse_inode() may delete any formerly-swapped inode from the shmem_swaplist, which in this case would leave a swap area impossible to swapoff. Although I don't relish taking the mutex every time, I don't care much for the alternatives either; and at least the peek at list_empty() in shmem_evict_inode() (a hotter path since most inodes would never have been swapped) remains safe, because we already truncated the whole file. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix spurious ENOSPC when racing with unswapHugh Dickins
Testing the shmem_swaplist replacements for igrab() revealed another bug: writes to /dev/loop0 on a tmpfs file which fills its filesystem were sometimes failing with "Buffer I/O error"s. These came from ENOSPC failures of shmem_getpage(), when racing with swapoff: the same could happen when racing with another shmem_getpage(), pulling the page in from swap in between our find_lock_page() and our taking the info->lock (though not in the single-threaded loop case). This is unacceptable, and surprising that I've not noticed it before: it dates back many years, but (presumably) was made a lot easier to reproduce in 2.6.36, which sited a page preallocation in the race window. Fix it by rechecking the page cache before settling on an ENOSPC error. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix race between umount and swapoffHugh Dickins
The use of igrab() in swapoff's shmem_unuse_inode() is just as vulnerable to umount as that in shmem_writepage(). Fix this instance by extending the protection of shmem_swaplist_mutex right across shmem_unuse_inode(): while it's on the list, the inode cannot be evicted (and the filesystem cannot be unmounted) without shmem_evict_inode() taking that mutex to remove it from the list. But since shmem_writepage() might take that mutex, we should avoid making memory allocations or memcg charges while holding it: prepare them at the outer level in shmem_unuse(). When mem_cgroup_cache_charge() was originally placed, we didn't know until that point that the page from swap was actually a shmem page; but nowadays it's noted in the swap_map, so we're safe to charge upfront. For the radix_tree, do as is done in shmem_getpage(): preload upfront, but don't pin to the cpu; so we make a habit of refreshing the node pool, but might dip into GFP_NOWAIT reserves on occasion if subsequently preempted. With the allocation and charge moved out from shmem_unuse_inode(), we can also hold index map and info->lock over from finding the entry. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix race between umount and writepageHugh Dickins
Konstanin Khlebnikov reports that a dangerous race between umount and shmem_writepage can be reproduced by this script: for i in {1..300} ; do mkdir $i while true ; do mount -t tmpfs none $i dd if=/dev/zero of=$i/test bs=1M count=$(($RANDOM % 100)) umount $i done & done on a 6xCPU node with 8Gb RAM: kernel very unstable after this accident. =) Kernel log: VFS: Busy inodes after unmount of tmpfs. Self-destruct in 5 seconds. Have a nice day... WARNING: at lib/list_debug.c:53 __list_del_entry+0x8d/0x98() list_del corruption. prev->next should be ffff880222fdaac8, but was (null) Pid: 11222, comm: mount.tmpfs Not tainted 2.6.39-rc2+ #4 Call Trace: warn_slowpath_common+0x80/0x98 warn_slowpath_fmt+0x41/0x43 __list_del_entry+0x8d/0x98 evict+0x50/0x113 iput+0x138/0x141 ... BUG: unable to handle kernel paging request at ffffffffffffffff IP: shmem_free_blocks+0x18/0x4c Pid: 10422, comm: dd Tainted: G W 2.6.39-rc2+ #4 Call Trace: shmem_recalc_inode+0x61/0x66 shmem_writepage+0xba/0x1dc pageout+0x13c/0x24c shrink_page_list+0x28e/0x4be shrink_inactive_list+0x21f/0x382 ... shmem_writepage() calls igrab() on the inode for the page which came from page reclaim, to add it later into shmem_swaplist for swapoff operation. This igrab() can race with super-block deactivating process: shrink_inactive_list() deactivate_super() pageout() tmpfs_fs_type->kill_sb() shmem_writepage() kill_litter_super() generic_shutdown_super() evict_inodes() igrab() atomic_read(&inode->i_count) skip-inode iput() if (!list_empty(&sb->s_inodes)) printk("VFS: Busy inodes after... This igrap-iput pair was added in commit 1b1b32f2c6f6 "tmpfs: fix shmem_swaplist races" based on incorrect assumptions: igrab() protects the inode from concurrent eviction by deletion, but it does nothing to protect it from concurrent unmounting, which goes ahead despite the raised i_count. So this use of igrab() was wrong all along, but the race made much worse in 2.6.37 when commit 63997e98a3be "split invalidate_inodes()" replaced two attempts at invalidate_inodes() by a single evict_inodes(). Konstantin posted a plausible patch, raising sb->s_active too: I'm unsure whether it was correct or not; but burnt once by igrab(), I am sure that we don't want to rely more deeply upon externals here. Fix it by adding the inode to shmem_swaplist earlier, while the page lock on page in page cache still secures the inode against eviction, without artifically raising i_count. It was originally added later because shmem_unuse_inode() is liable to remove an inode from the list while it's unswapped; but we can guard against that by taking spinlock before dropping mutex. Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14tmpfs: fix off-by-one in max_blocks checksHugh Dickins
If you fill up a tmpfs, df was showing tmpfs 460800 - - - /tmp because of an off-by-one in the max_blocks checks. Fix it so df shows tmpfs 460800 460800 0 100% /tmp Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-22shmem: let shared anonymous be nonlinear againHugh Dickins
Up to 2.6.22, you could use remap_file_pages(2) on a tmpfs file or a shared mapping of /dev/zero or a shared anonymous mapping. In 2.6.23 we disabled it by default, but set VM_CAN_NONLINEAR to enable it on safe mappings. We made sure to set it in shmem_mmap() for tmpfs files, but missed it in shmem_zero_setup() for the others. Fix that at last. Reported-by: Kenny Simpson <theonetruekenny@yahoo.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: shmem: change remove_from_page_cacheMinchan Kim
This patch series changes remove_from_page_cache()'s page ref counting rule. Page cache ref count is decreased in delete_from_page_cache(). So we don't need to decrease the page reference in callers. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: inode_unhashed()Al Viro
note: for race-free uses you inode_lock held Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-17shmem: put_super must percpu_counter_destroyHugh Dickins
list_add() corruption messages reported from shmem_fill_super()'s recently introduced percpu_counter_init(): shmem_put_super() needs to remember to percpu_counter_destroy(). And also check error from percpu_counter_init(). Reported-bisected-and-tested-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09shmem: reduce pagefault lock contentionShaohua Li
I'm running a shmem pagefault test case (see attached file) under a 64 CPU system. Profile shows shmem_inode_info->lock is heavily contented and 100% CPUs time are trying to get the lock. In the pagefault (no swap) case, shmem_getpage gets the lock twice, the last one is avoidable if we prealloc a page so we could reduce one time of locking. This is what below patch does. The result of the test case: 2.6.35-rc3: ~20s 2.6.35-rc3 + patch: ~12s so this is 40% improvement. One might argue if we could have better locking for shmem. But even shmem is lockless, the pagefault will soon have pagecache lock heavily contented because shmem must add new page to pagecache. So before we have better locking for pagecache, improving shmem locking doesn't have too much improvement. I did a similar pagefault test against a ramfs file, the test result is ~10.5s. [akpm@linux-foundation.org: fix comment, clean up code layout, elimintate code duplication] Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: "Zhang, Yanmin" <yanmin.zhang@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
