path: root/mm/shmem.c
2011-05-28tmpfs: fix race between truncate and writepageHugh Dickins
While running fsx on tmpfs with a memhog then swapoff, swapoff was hanging (interruptibly), repeatedly failing to locate the owner of a 0xff entry in the swap_map. Although shmem_writepage() does abandon when it sees incoming page index is beyond eof, there was still a window in which shmem_truncate_range() could come in between writepage's dropping lock and updating swap_map, find the half-completed swap_map entry, and in trying to free it, leave it in a state that swap_shmem_alloc() could not correct. Arguably a bug in __swap_duplicate()'s and swap_entry_free()'s handling of the different cases, but easiest to fix by moving swap_shmem_alloc() under cover of the lock. More interesting than the bug: it's been there since 2.6.33, why could I not see it with earlier kernels? The mmotm of two weeks ago seems to have some magic for generating races, this is just one of three I found. With yesterday's git I first saw this in mainline, bisected in search of that magic, but the easy reproducibility evaporated. Oh well, fix the bug. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26memcg: add the pagefault count into memcg statsYing Han
Two new stats in per-memcg memory.stat which tracks the number of page faults and number of major page faults. "pgfault" "pgmajfault" They are different from "pgpgin"/"pgpgout" stat which count number of pages charged/discharged to the cgroup and have no meaning of reading/ writing page to disk. It is valuable to track the two stats for both measuring application's performance as well as the efficiency of the kernel page reclaim path. Counting pagefaults per process is useful, but we also need the aggregated value since processes are monitored and controlled in cgroup basis in memcg. Functional test: check the total number of pgfault/pgmajfault of all memcgs and compare with global vmstat value: $ cat /proc/vmstat | grep fault pgfault 1070751 pgmajfault 553 $ cat /dev/cgroup/memory.stat | grep fault pgfault 1071138 pgmajfault 553 total_pgfault 1071142 total_pgmajfault 553 $ cat /dev/cgroup/A/memory.stat | grep fault pgfault 199 pgmajfault 0 total_pgfault 199 total_pgmajfault 0 Performance test: run page fault test(pft) wit 16 thread on faulting in 15G anon pages in 16G container. There is no regression noticed on the "flt/cpu/s" Sample output from pft: TAG pft:anon-sys-default: Gb Thr CLine User System Wall flt/cpu/s fault/wsec 15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260 +-------------------------------------------------------------------------+ N Min Max Median Avg Stddev x 10 16682.962 17344.027 16913.524 16928.812 166.5362 + 10 16695.568 16923.896 16820.604 16824.652 84.816568 No difference proven at 95.0% confidence [akpm@linux-foundation.org: fix build] [hughd@google.com: shmem fix] Signed-off-by: Ying Han <yinghan@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25tmpfs: implement generic xattr supportEric Paris
Implement generic xattrs for tmpfs filesystems. The Feodra project, while trying to replace suid apps with file capabilities, realized that tmpfs, which is used on the build systems, does not support file capabilities and thus cannot be used to build packages which use file capabilities. Xattrs are also needed for overlayfs. The xattr interface is a bit odd. If a filesystem does not implement any {get,set,list}xattr functions the VFS will call into some random LSM hooks and the running LSM can then implement some method for handling xattrs. SELinux for example provides a method to support security.selinux but no other security.* xattrs. As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have xattr handler routines specifically to handle acls. Because of this tmpfs would loose the VFS/LSM helpers to support the running LSM. To make up for that tmpfs had stub functions that did nothing but call into the LSM hooks which implement the helpers. This new patch does not use the LSM fallback functions and instead just implements a native get/set/list xattr feature for the full security.* and trusted.* namespace like a normal filesystem. This means that tmpfs can now support both security.selinux and security.capability, which was not previously possible. The basic implementation is that I attach a: struct shmem_xattr { struct list_head list; /* anchored by shmem_inode_info->xattr_list */ char *name; size_t size; char value[0]; }; Into the struct shmem_inode_info for each xattr that is set. This implementation could easily support the user.* namespace as well, except some care needs to be taken to prevent large amounts of unswappable memory being allocated for unprivileged users. [mszeredi@suse.cz: new config option, suport trusted.*, support symlinks] Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Hugh Dickins <hughd@google.com> Tested-by: Jordi Pujol <jordipujolp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-20tmpfs: fix highmem swapoff crash regressionHugh Dickins
Commit 778dd893ae78 ("tmpfs: fix race between umount and swapoff") forgot the new rules for strict atomic kmap nesting, causing WARNING: at arch/x86/mm/highmem_32.c:81 from __kunmap_atomic(), then BUG: unable to handle kernel paging request at fffb9000 from shmem_swp_set() when shmem_unuse_inode() is handling swapoff with highmem in use. My disgrace again. See https://bugzilla.kernel.org/show_bug.cgi?id=35352 Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-14tmpfs: fix race between swapoff and writepageHugh Dickins
Shame on me! Commit b1dea800ac39 "tmpfs: fix race between umount and writepage" fixed the advertized race, but introduced another: as even its comment makes clear, we cannot safely rely on a peek at list_empty() while holding no lock - until info->swapped is set, shmem_unuse_inode() may delete any formerly-swapped inode from the shmem_swaplist, which in this case would leave a swap area impossible to swapoff. Although I don't relish taking the mutex every time, I don't care much for the alternatives either; and at least the peek at list_empty() in shmem_evict_inode() (a hotter path since most inodes would never have been swapped) remains safe, because we already truncated the whole file. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix spurious ENOSPC when racing with unswapHugh Dickins
Testing the shmem_swaplist replacements for igrab() revealed another bug: writes to /dev/loop0 on a tmpfs file which fills its filesystem were sometimes failing with "Buffer I/O error"s. These came from ENOSPC failures of shmem_getpage(), when racing with swapoff: the same could happen when racing with another shmem_getpage(), pulling the page in from swap in between our find_lock_page() and our taking the info->lock (though not in the single-threaded loop case). This is unacceptable, and surprising that I've not noticed it before: it dates back many years, but (presumably) was made a lot easier to reproduce in 2.6.36, which sited a page preallocation in the race window. Fix it by rechecking the page cache before settling on an ENOSPC error. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix race between umount and swapoffHugh Dickins
The use of igrab() in swapoff's shmem_unuse_inode() is just as vulnerable to umount as that in shmem_writepage(). Fix this instance by extending the protection of shmem_swaplist_mutex right across shmem_unuse_inode(): while it's on the list, the inode cannot be evicted (and the filesystem cannot be unmounted) without shmem_evict_inode() taking that mutex to remove it from the list. But since shmem_writepage() might take that mutex, we should avoid making memory allocations or memcg charges while holding it: prepare them at the outer level in shmem_unuse(). When mem_cgroup_cache_charge() was originally placed, we didn't know until that point that the page from swap was actually a shmem page; but nowadays it's noted in the swap_map, so we're safe to charge upfront. For the radix_tree, do as is done in shmem_getpage(): preload upfront, but don't pin to the cpu; so we make a habit of refreshing the node pool, but might dip into GFP_NOWAIT reserves on occasion if subsequently preempted. With the allocation and charge moved out from shmem_unuse_inode(), we can also hold index map and info->lock over from finding the entry. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11tmpfs: fix race between umount and writepageHugh Dickins
Konstanin Khlebnikov reports that a dangerous race between umount and shmem_writepage can be reproduced by this script: for i in {1..300} ; do mkdir $i while true ; do mount -t tmpfs none $i dd if=/dev/zero of=$i/test bs=1M count=$(($RANDOM % 100)) umount $i done & done on a 6xCPU node with 8Gb RAM: kernel very unstable after this accident. =) Kernel log: VFS: Busy inodes after unmount of tmpfs. Self-destruct in 5 seconds. Have a nice day... WARNING: at lib/list_debug.c:53 __list_del_entry+0x8d/0x98() list_del corruption. prev->next should be ffff880222fdaac8, but was (null) Pid: 11222, comm: mount.tmpfs Not tainted 2.6.39-rc2+ #4 Call Trace: warn_slowpath_common+0x80/0x98 warn_slowpath_fmt+0x41/0x43 __list_del_entry+0x8d/0x98 evict+0x50/0x113 iput+0x138/0x141 ... BUG: unable to handle kernel paging request at ffffffffffffffff IP: shmem_free_blocks+0x18/0x4c Pid: 10422, comm: dd Tainted: G W 2.6.39-rc2+ #4 Call Trace: shmem_recalc_inode+0x61/0x66 shmem_writepage+0xba/0x1dc pageout+0x13c/0x24c shrink_page_list+0x28e/0x4be shrink_inactive_list+0x21f/0x382 ... shmem_writepage() calls igrab() on the inode for the page which came from page reclaim, to add it later into shmem_swaplist for swapoff operation. This igrab() can race with super-block deactivating process: shrink_inactive_list() deactivate_super() pageout() tmpfs_fs_type->kill_sb() shmem_writepage() kill_litter_super() generic_shutdown_super() evict_inodes() igrab() atomic_read(&inode->i_count) skip-inode iput() if (!list_empty(&sb->s_inodes)) printk("VFS: Busy inodes after... This igrap-iput pair was added in commit 1b1b32f2c6f6 "tmpfs: fix shmem_swaplist races" based on incorrect assumptions: igrab() protects the inode from concurrent eviction by deletion, but it does nothing to protect it from concurrent unmounting, which goes ahead despite the raised i_count. So this use of igrab() was wrong all along, but the race made much worse in 2.6.37 when commit 63997e98a3be "split invalidate_inodes()" replaced two attempts at invalidate_inodes() by a single evict_inodes(). Konstantin posted a plausible patch, raising sb->s_active too: I'm unsure whether it was correct or not; but burnt once by igrab(), I am sure that we don't want to rely more deeply upon externals here. Fix it by adding the inode to shmem_swaplist earlier, while the page lock on page in page cache still secures the inode against eviction, without artifically raising i_count. It was originally added later because shmem_unuse_inode() is liable to remove an inode from the list while it's unswapped; but we can guard against that by taking spinlock before dropping mutex. Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14tmpfs: fix off-by-one in max_blocks checksHugh Dickins
If you fill up a tmpfs, df was showing tmpfs 460800 - - - /tmp because of an off-by-one in the max_blocks checks. Fix it so df shows tmpfs 460800 460800 0 100% /tmp Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-22shmem: let shared anonymous be nonlinear againHugh Dickins
Up to 2.6.22, you could use remap_file_pages(2) on a tmpfs file or a shared mapping of /dev/zero or a shared anonymous mapping. In 2.6.23 we disabled it by default, but set VM_CAN_NONLINEAR to enable it on safe mappings. We made sure to set it in shmem_mmap() for tmpfs files, but missed it in shmem_zero_setup() for the others. Fix that at last. Reported-by: Kenny Simpson <theonetruekenny@yahoo.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: shmem: change remove_from_page_cacheMinchan Kim
This patch series changes remove_from_page_cache()'s page ref counting rule. Page cache ref count is decreased in delete_from_page_cache(). So we don't need to decrease the page reference in callers. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: inode_unhashed()Al Viro
note: for race-free uses you inode_lock held Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-17shmem: put_super must percpu_counter_destroyHugh Dickins
list_add() corruption messages reported from shmem_fill_super()'s recently introduced percpu_counter_init(): shmem_put_super() needs to remember to percpu_counter_destroy(). And also check error from percpu_counter_init(). Reported-bisected-and-tested-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09shmem: reduce pagefault lock contentionShaohua Li
I'm running a shmem pagefault test case (see attached file) under a 64 CPU system. Profile shows shmem_inode_info->lock is heavily contented and 100% CPUs time are trying to get the lock. In the pagefault (no swap) case, shmem_getpage gets the lock twice, the last one is avoidable if we prealloc a page so we could reduce one time of locking. This is what below patch does. The result of the test case: 2.6.35-rc3: ~20s 2.6.35-rc3 + patch: ~12s so this is 40% improvement. One might argue if we could have better locking for shmem. But even shmem is lockless, the pagefault will soon have pagecache lock heavily contented because shmem must add new page to pagecache. So before we have better locking for pagecache, improving shmem locking doesn't have too much improvement. I did a similar pagefault test against a ramfs file, the test result is ~10.5s. [akpm@linux-foundation.org: fix comment, clean up code layout, elimintate code duplication] Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: "Zhang, Yanmin" <yanmin.zhang@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09tmpfs: make tmpfs scalable with percpu_counter for used blocksTim Chen
The current implementation of tmpfs is not scalable. We found that stat_lock is contended by multiple threads when we need to get a new page, leading to useless spinning inside this spin lock. This patch makes use of the percpu_counter library to maintain local count of used blocks to speed up getting and returning of pages. So the acquisition of stat_lock is unnecessary for getting and returning blocks, improving the performance of tmpfs on system with large number of cpus. On a 4 socket 32 core NHM-EX system, we saw improvement of 270%. The implementation below has a slight chance of race between threads causing a slight overshoot of the maximum configured blocks. However, any overshoot is small, and is bounded by the number of cpus. This happens when the number of used blocks is slightly below the maximum configured blocks when a thread checks the used block count, and another thread allocates the last block before the current thread does. This should not be a problem for tmpfs, as the overshoot is most likely to be a few blocks and bounded. If a strict limit is really desired, then configured the max blocks to be the limit less the number of cpus in system. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09switch shmem.c to ->evice_inode()Al Viro
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09always call inode_change_ok early in ->setattrChristoph Hellwig
Make sure we call inode_change_ok before doing any changes in ->setattr, and make sure to call it even if our fs wants to ignore normal UNIX permissions, but use the ATTR_FORCE to skip those. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-04fix truncate inode time modification breakageNick Piggin
mtime and ctime should be changed only if the file size has actually changed. Patches changing ext2 and tmpfs from vmtruncate to new truncate sequence has caused regressions where they always update timestamps. There is some strange cases in POSIX where truncate(2) must not update times unless the size has acutally changed, see 6e656be89. This area is all still rather buggy in different ways in a lot of filesystems and needs a cleanup and audit (ideally the vfs will provide a simple attribute or call to direct all filesystems exactly which attributes to change). But coming up with the best solution will take a while and is not appropriate for rc anyway. So fix recent regression for now. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27tmpfs: convert to use the new truncate conventionnpiggin@suse.de
Cc: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27memcg: move charge of file pagesDaisuke Nishimura
This patch adds support for moving charge of file pages, which include normal file, tmpfs file and swaps of tmpfs file. It's enabled by setting bit 1 of <target cgroup>/memory.move_charge_at_immigrate. Unlike the case of anonymous pages, file pages(and swaps) in the range mmapped by the task will be moved even if the task hasn't done page fault, i.e. they might not be the task's "RSS", but other task's "RSS" that maps the same file. And mapcount of the page is ignored(the page can be moved even if page_mapcount(page) > 1). So, conditions that the page/swap should be met to be moved is that it must be in the range mmapped by the target task and it must be charged to the old cgroup. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix warning] Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25shmem: remove redundant codeHuang Shijie
prep_new_page() will call set_page_private(page, 0) to initialise the page, so the code is redundant. Signed-off-by: Huang Shijie <shijie8@gmail.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21ramfs: replace inode uid,gid,mode initialization with helper functionDmitry Monakhov
- seems what ramfs_get_inode is only locally, make it static. [AV: the hell it is; it's used by shmem, so shmem needed conversion too and no, that function can't be made static] Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21fs: xattr_handler table should be constStephen Hemminger
The entries in xattr handler table should be immutable (ie const) like other operation tables. Later patches convert common filesystems. Uncoverted filesystems will still work, but will generate a compiler warning. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Fix breakage in shmem.cAl Viro
Replacing error = 0; if (error) op with nothing is not quite an equivalent transformation ;-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16make generic_acl slightly more genericChristoph Hellwig
Now that we cache the ACL pointers in the generic inode all the generic_acl cruft can go away and generic_acl.c can directly implement xattr handlers dealing with the full Posix ACL semantics for in-memory filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Untangling ima mess, part 1: alloc_file()Al Viro
There are 2 groups of alloc_file() callers: * ones that are followed by ima_counts_get * ones giving non-regular files So let's pull that ima_counts_get() into alloc_file(); it's a no-op in case of non-regular files. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch shmem_file_setup() to alloc_file()Al Viro
2009-12-15swap_info: note SWAP_MAP_SHMEMHugh Dickins
While we're fiddling with the swap_map values, let's assign a particular value to shmem/tmpfs swap pages: their swap counts are never incremented, and it helps swapoff's try_to_unuse() a little if it can immediately distinguish those pages from process pages. Since we've no use for SWAP_MAP_BAD | COUNT_CONTINUED, we might as well use that 0xbf value for SWAP_MAP_SHMEM. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-25Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: writeback_inodes_sb() should use bdi_start_writeback() writeback: don't delay inodes redirtied by a fast dirtier writeback: make the super_block pinning more efficient writeback: don't resort for a single super_block in move_expired_inodes() writeback: move inodes from one super_block together writeback: get rid to incorrect references to pdflush in comments writeback: improve readability of the wb_writeback() continue/break logic writeback: cleanup writeback_single_inode() writeback: kupdate writeback shall not stop when more io is possible writeback: stop background writeback when below background threshold writeback: balance_dirty_pages() shall write more than dirtied pages fs: Fix busyloop in wb_writeback()
2009-09-25writeback: get rid to incorrect references to pdflush in commentsJens Axboe
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-22shmem: initialize struct shmem_sb_info to zeroPekka Enberg
Fixes the following kmemcheck false positive (the compiler is using a 32-bit mov to load the 16-bit sbinfo->mode in shmem_fill_super): [ 0.337000] Total of 1 processors activated (3088.38 BogoMIPS). [ 0.352000] CPU0 attaching NULL sched-domain. [ 0.360000] WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (9f8020fc) [ 0.361000] a44240820000000041f6998100000000000000000000000000000000ff030000 [ 0.368000] i i i i i i i i i i i i i i i i u u u u i i i i i i i i i i u u [ 0.375000] ^ [ 0.376000] [ 0.377000] Pid: 9, comm: khelper Not tainted (2.6.31-tip #206) P4DC6 [ 0.378000] EIP: 0060:[<810a3a95>] EFLAGS: 00010246 CPU: 0 [ 0.379000] EIP is at shmem_fill_super+0xb5/0x120 [ 0.380000] EAX: 00000000 EBX: 9f845400 ECX: 824042a4 EDX: 8199f641 [ 0.381000] ESI: 9f8020c0 EDI: 9f845400 EBP: 9f81af68 ESP: 81cd6eec [ 0.382000] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [ 0.383000] CR0: 8005003b CR2: 9f806200 CR3: 01ccd000 CR4: 000006d0 [ 0.384000] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 0.385000] DR6: ffff4ff0 DR7: 00000400 [ 0.386000] [<810c25fc>] get_sb_nodev+0x3c/0x80 [ 0.388000] [<810a3514>] shmem_get_sb+0x14/0x20 [ 0.390000] [<810c207f>] vfs_kern_mount+0x4f/0x120 [ 0.392000] [<81b2849e>] init_tmpfs+0x7e/0xb0 [ 0.394000] [<81b11597>] do_basic_setup+0x17/0x30 [ 0.396000] [<81b11907>] kernel_init+0x57/0xa0 [ 0.398000] [<810039b7>] kernel_thread_helper+0x7/0x10 [ 0.400000] [<ffffffff>] 0xffffffff [ 0.402000] khelper used greatest stack depth: 2820 bytes left [ 0.407000] calling init_mmap_min_addr+0x0/0x10 @ 1 [ 0.408000] initcall init_mmap_min_addr+0x0/0x10 returned 0 after 0 usecs Reported-by: Ingo Molnar <mingo@elte.hu> Analysed-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
