path: root/mm/shmem.c
2019-12-21mm/shmem.c: cast the type of unmap_start to u64Chen Jun
commit aa71ecd8d86500da6081a72da6b0b524007e0627 upstream. In 64bit system. sb->s_maxbytes of shmem filesystem is MAX_LFS_FILESIZE, which equal LLONG_MAX. If offset > LLONG_MAX - PAGE_SIZE, offset + len < LLONG_MAX in shmem_fallocate, which will pass the checking in vfs_fallocate. /* Check for wrap through zero too */ if (((offset + len) > inode->i_sb->s_maxbytes) || ((offset + len) < 0)) return -EFBIG; loff_t unmap_start = round_up(offset, PAGE_SIZE) in shmem_fallocate causes a overflow. Syzkaller reports a overflow problem in mm/shmem: UBSAN: Undefined behaviour in mm/shmem.c:2014:10 signed integer overflow: '9223372036854775807 + 1' cannot be represented in type 'long long int' CPU: 0 PID:17076 Comm: syz-executor0 Not tainted 4.1.46+ #1 Hardware name: linux, dummy-virt (DT) Call trace: dump_backtrace+0x0/0x2c8 arch/arm64/kernel/traps.c:100 show_stack+0x20/0x30 arch/arm64/kernel/traps.c:238 __dump_stack lib/dump_stack.c:15 [inline] ubsan_epilogue+0x18/0x70 lib/ubsan.c:164 handle_overflow+0x158/0x1b0 lib/ubsan.c:195 shmem_fallocate+0x6d0/0x820 mm/shmem.c:2104 vfs_fallocate+0x238/0x428 fs/open.c:312 SYSC_fallocate fs/open.c:335 [inline] SyS_fallocate+0x54/0xc8 fs/open.c:239 The highest bit of unmap_start will be appended with sign bit 1 (overflow) when calculate shmem_falloc.start: shmem_falloc.start = unmap_start >> PAGE_SHIFT. Fix it by casting the type of unmap_start to u64, when right shifted. This bug is found in LTS Linux 4.1. It also seems to exist in mainline. Link: http://lkml.kernel.org/r/1573867464-5107-1-git-send-email-chenjun102@huawei.com Signed-off-by: Chen Jun <chenjun102@huawei.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Qian Cai <cai@lca.pw> Cc: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-25memfd: Use radix_tree_deref_slot_protected to avoid the warning.zhong jiang
The commit eb4058d8daf8 ("memfd: Fix locking when tagging pins") introduces the following warning messages. *WARNING: suspicious RCU usage in memfd_wait_for_pins* It is because we still use radix_tree_deref_slot without read_rcu_lock. We should use radix_tree_deref_slot_protected instead in the case. Cc: stable@vger.kernel.org Fixes: eb4058d8daf8 ("memfd: Fix locking when tagging pins") Signed-off-by: zhong jiang <zhongjiang@huawei.com> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29memfd: Fix locking when tagging pinsMatthew Wilcox (Oracle)
The RCU lock is insufficient to protect the radix tree iteration as a deletion from the tree can occur before we take the spinlock to tag the entry. In 4.19, this has manifested as a bug with the following trace: kernel BUG at lib/radix-tree.c:1429! invalid opcode: 0000 [#1] SMP KASAN PTI CPU: 7 PID: 6935 Comm: syz-executor.2 Not tainted 4.19.36 #25 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:radix_tree_tag_set+0x200/0x2f0 lib/radix-tree.c:1429 Code: 00 00 5b 5d 41 5c 41 5d 41 5e 41 5f c3 48 89 44 24 10 e8 a3 29 7e fe 48 8b 44 24 10 48 0f ab 03 e9 d2 fe ff ff e8 90 29 7e fe <0f> 0b 48 c7 c7 e0 5a 87 84 e8 f0 e7 08 ff 4c 89 ef e8 4a ff ac fe RSP: 0018:ffff88837b13fb60 EFLAGS: 00010016 RAX: 0000000000040000 RBX: ffff8883c5515d58 RCX: ffffffff82cb2ef0 RDX: 0000000000000b72 RSI: ffffc90004cf2000 RDI: ffff8883c5515d98 RBP: ffff88837b13fb98 R08: ffffed106f627f7e R09: ffffed106f627f7e R10: 0000000000000001 R11: ffffed106f627f7d R12: 0000000000000004 R13: ffffea000d7fea80 R14: 1ffff1106f627f6f R15: 0000000000000002 FS: 00007fa1b8df2700(0000) GS:ffff8883e2fc0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fa1b8df1db8 CR3: 000000037d4d2001 CR4: 0000000000160ee0 Call Trace: memfd_tag_pins mm/memfd.c:51 [inline] memfd_wait_for_pins+0x2c5/0x12d0 mm/memfd.c:81 memfd_add_seals mm/memfd.c:215 [inline] memfd_fcntl+0x33d/0x4a0 mm/memfd.c:247 do_fcntl+0x589/0xeb0 fs/fcntl.c:421 __do_sys_fcntl fs/fcntl.c:463 [inline] __se_sys_fcntl fs/fcntl.c:448 [inline] __x64_sys_fcntl+0x12d/0x180 fs/fcntl.c:448 do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:293 The problem does not occur in mainline due to the XArray rewrite which changed the locking to exclude modification of the tree during iteration. At the time, nobody realised this was a bugfix. Backport the locking changes to stable. Cc: stable@vger.kernel.org Reported-by: zhong jiang <zhongjiang@huawei.com> Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-03-23tmpfs: fix uninitialized return value in shmem_linkDarrick J. Wong
[ Upstream commit 29b00e609960ae0fcff382f4c7079dd0874a5311 ] When we made the shmem_reserve_inode call in shmem_link conditional, we forgot to update the declaration for ret so that it always has a known value. Dan Carpenter pointed out this deficiency in the original patch. Fixes: 1062af920c07 ("tmpfs: fix link accounting when a tmpfile is linked in") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Matej Kupljen <matej.kupljen@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-03-23tmpfs: fix link accounting when a tmpfile is linked inDarrick J. Wong
[ Upstream commit 1062af920c07f5b54cf5060fde3339da6df0cf6b ] tmpfs has a peculiarity of accounting hard links as if they were separate inodes: so that when the number of inodes is limited, as it is by default, a user cannot soak up an unlimited amount of unreclaimable dcache memory just by repeatedly linking a file. But when v3.11 added O_TMPFILE, and the ability to use linkat() on the fd, we missed accommodating this new case in tmpfs: "df -i" shows that an extra "inode" remains accounted after the file is unlinked and the fd closed and the actual inode evicted. If a user repeatedly links tmpfiles into a tmpfs, the limit will be hit (ENOSPC) even after they are deleted. Just skip the extra reservation from shmem_link() in this case: there's a sense in which this first link of a tmpfile is then cheaper than a hard link of another file, but the accounting works out, and there's still good limiting, so no need to do anything more complicated. Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1902182134370.7035@eggly.anvils Fixes: f4e0c30c191 ("allow the temp files created by open() to be linked to") Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Matej Kupljen <matej.kupljen@gmail.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-01tmpfs: make lseek(SEEK_DATA/SEK_HOLE) return ENXIO with a negative offsetYufen Yu
[ Upstream commit 1a413646931cb14442065cfc17561e50f5b5bb44 ] Other filesystems such as ext4, f2fs and ubifs all return ENXIO when lseek (SEEK_DATA or SEEK_HOLE) requests a negative offset. man 2 lseek says : EINVAL whence is not valid. Or: the resulting file offset would be : negative, or beyond the end of a seekable device. : : ENXIO whence is SEEK_DATA or SEEK_HOLE, and the file offset is beyond : the end of the file. Make tmpfs return ENXIO under these circumstances as well. After this, tmpfs also passes xfstests's generic/448. [akpm@linux-foundation.org: rewrite changelog] Link: http://lkml.kernel.org/r/1540434176-14349-1-git-send-email-yuyufen@huawei.com Signed-off-by: Yufen Yu <yuyufen@huawei.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hughd@google.com> Cc: William Kucharski <william.kucharski@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-09-29mm: shmem.c: Correctly annotate new inodes for lockdepJoel Fernandes (Google)
commit b45d71fb89ab8adfe727b9d0ee188ed58582a647 upstream. Directories and inodes don't necessarily need to be in the same lockdep class. For ex, hugetlbfs splits them out too to prevent false positives in lockdep. Annotate correctly after new inode creation. If its a directory inode, it will be put into a different class. This should fix a lockdep splat reported by syzbot: > ====================================================== > WARNING: possible circular locking dependency detected > 4.18.0-rc8-next-20180810+ #36 Not tainted > ------------------------------------------------------ > syz-executor900/4483 is trying to acquire lock: > 00000000d2bfc8fe (&sb->s_type->i_mutex_key#9){++++}, at: inode_lock > include/linux/fs.h:765 [inline] > 00000000d2bfc8fe (&sb->s_type->i_mutex_key#9){++++}, at: > shmem_fallocate+0x18b/0x12e0 mm/shmem.c:2602 > > but task is already holding lock: > 0000000025208078 (ashmem_mutex){+.+.}, at: ashmem_shrink_scan+0xb4/0x630 > drivers/staging/android/ashmem.c:448 > > which lock already depends on the new lock. > > -> #2 (ashmem_mutex){+.+.}: > __mutex_lock_common kernel/locking/mutex.c:925 [inline] > __mutex_lock+0x171/0x1700 kernel/locking/mutex.c:1073 > mutex_lock_nested+0x16/0x20 kernel/locking/mutex.c:1088 > ashmem_mmap+0x55/0x520 drivers/staging/android/ashmem.c:361 > call_mmap include/linux/fs.h:1844 [inline] > mmap_region+0xf27/0x1c50 mm/mmap.c:1762 > do_mmap+0xa10/0x1220 mm/mmap.c:1535 > do_mmap_pgoff include/linux/mm.h:2298 [inline] > vm_mmap_pgoff+0x213/0x2c0 mm/util.c:357 > ksys_mmap_pgoff+0x4da/0x660 mm/mmap.c:1585 > __do_sys_mmap arch/x86/kernel/sys_x86_64.c:100 [inline] > __se_sys_mmap arch/x86/kernel/sys_x86_64.c:91 [inline] > __x64_sys_mmap+0xe9/0x1b0 arch/x86/kernel/sys_x86_64.c:91 > do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 > entry_SYSCALL_64_after_hwframe+0x49/0xbe > > -> #1 (&mm->mmap_sem){++++}: > __might_fault+0x155/0x1e0 mm/memory.c:4568 > _copy_to_user+0x30/0x110 lib/usercopy.c:25 > copy_to_user include/linux/uaccess.h:155 [inline] > filldir+0x1ea/0x3a0 fs/readdir.c:196 > dir_emit_dot include/linux/fs.h:3464 [inline] > dir_emit_dots include/linux/fs.h:3475 [inline] > dcache_readdir+0x13a/0x620 fs/libfs.c:193 > iterate_dir+0x48b/0x5d0 fs/readdir.c:51 > __do_sys_getdents fs/readdir.c:231 [inline] > __se_sys_getdents fs/readdir.c:212 [inline] > __x64_sys_getdents+0x29f/0x510 fs/readdir.c:212 > do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 > entry_SYSCALL_64_after_hwframe+0x49/0xbe > > -> #0 (&sb->s_type->i_mutex_key#9){++++}: > lock_acquire+0x1e4/0x540 kernel/locking/lockdep.c:3924 > down_write+0x8f/0x130 kernel/locking/rwsem.c:70 > inode_lock include/linux/fs.h:765 [inline] > shmem_fallocate+0x18b/0x12e0 mm/shmem.c:2602 > ashmem_shrink_scan+0x236/0x630 drivers/staging/android/ashmem.c:455 > ashmem_ioctl+0x3ae/0x13a0 drivers/staging/android/ashmem.c:797 > vfs_ioctl fs/ioctl.c:46 [inline] > file_ioctl fs/ioctl.c:501 [inline] > do_vfs_ioctl+0x1de/0x1720 fs/ioctl.c:685 > ksys_ioctl+0xa9/0xd0 fs/ioctl.c:702 > __do_sys_ioctl fs/ioctl.c:709 [inline] > __se_sys_ioctl fs/ioctl.c:707 [inline] > __x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:707 > do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 > entry_SYSCALL_64_after_hwframe+0x49/0xbe > > other info that might help us debug this: > > Chain exists of: > &sb->s_type->i_mutex_key#9 --> &mm->mmap_sem --> ashmem_mutex > > Possible unsafe locking scenario: > > CPU0 CPU1 > ---- ---- > lock(ashmem_mutex); > lock(&mm->mmap_sem); > lock(ashmem_mutex); > lock(&sb->s_type->i_mutex_key#9); > > *** DEADLOCK *** > > 1 lock held by syz-executor900/4483: > #0: 0000000025208078 (ashmem_mutex){+.+.}, at: > ashmem_shrink_scan+0xb4/0x630 drivers/staging/android/ashmem.c:448 Link: http://lkml.kernel.org/r/20180821231835.166639-1-joel@joelfernandes.org Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org> Reported-by: syzbot <syzkaller@googlegroups.com> Reviewed-by: NeilBrown <neilb@suse.com> Suggested-by: NeilBrown <neilb@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27tmpfs: fix regression hang in fallocate undoHugh Dickins
commit 7f556567036cb7f89aabe2f0954b08566b4efb53 upstream. The well-spotted fallocate undo fix is good in most cases, but not when fallocate failed on the very first page. index 0 then passes lend -1 to shmem_undo_range(), and that has two bad effects: (a) that it will undo every fallocation throughout the file, unrestricted by the current range; but more importantly (b) it can cause the undo to hang, because lend -1 is treated as truncation, which makes it keep on retrying until every page has gone, but those already fully instantiated will never go away. Big thank you to xfstests generic/269 which demonstrates this. Fixes: b9b4bb26af01 ("tmpfs: don't undo fallocate past its last page") Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27tmpfs: don't undo fallocate past its last pageAnthony Romano
commit b9b4bb26af017dbe930cd4df7f9b2fc3a0497bfe upstream. When fallocate is interrupted it will undo a range that extends one byte past its range of allocated pages. This can corrupt an in-use page by zeroing out its first byte. Instead, undo using the inclusive byte range. Fixes: 1635f6a74152f1d ("tmpfs: undo fallocation on failure") Link: http://lkml.kernel.org/r/1462713387-16724-1-git-send-email-anthony.romano@coreos.com Signed-off-by: Anthony Romano <anthony.romano@coreos.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Brandon Philips <brandon@ifup.co> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03make sure that freeing shmem fast symlinks is RCU-delayedAl Viro
commit 3ed47db34f480df7caf44436e3e63e555351ae9a upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-12tmpfs: fix shmem_evict_inode() warnings on i_blocksHugh Dickins
Dmitry Vyukov provides a little program, autogenerated by syzkaller, which races a fault on a mapping of a sparse memfd object, against truncation of that object below the fault address: run repeatedly for a few minutes, it reliably generates shmem_evict_inode()'s WARN_ON(inode->i_blocks). (But there's nothing specific to memfd here, nor to the fstat which it happened to use to generate the fault: though that looked suspicious, since a shmem_recalc_inode() had been added there recently. The same problem can be reproduced with open+unlink in place of memfd_create, and with fstatfs in place of fstat.) v3.7 commit 0f3c42f522dc ("tmpfs: change final i_blocks BUG to WARNING") explains one cause of such a warning (a race with shmem_writepage to swap), and possible solutions; but we never took it further, and this syzkaller incident turns out to have a different cause. shmem_getpage_gfp()'s error recovery, when a freshly allocated page is then found to be beyond eof, looks plausible - decrementing the alloced count that was just before incremented - but in fact can go wrong, if a racing thread (the truncator, for example) gets its shmem_recalc_inode() in just after our delete_from_page_cache(). delete_from_page_cache() decrements nrpages, that shmem_recalc_inode() will balance the books by decrementing alloced itself, then our decrement of alloced take it one too low: leading to the WARNING when the object is finally evicted. Once the new page has been exposed in the page cache, shmem_getpage_gfp() must leave it to shmem_recalc_inode() itself to get the accounting right in all cases (and not fall through from "trunc:" to "decused:"). Adjust that error recovery block; and the reinitialization of info and sbinfo can be removed too. While we're here, fix shmem_writepage() to avoid the original issue: it will be safe against a racing shmem_recalc_inode(), if it merely increments swapped before the shmem_delete_from_page_cache() which decrements nrpages (but it must then do its own shmem_recalc_inode() before that, while still in balance, instead of after). (Aside: why do we shmem_recalc_inode() here in the swap path? Because its raison d'etre is to cope with clean sparse shmem pages being reclaimed behind our back: so here when swapping is a good place to look for that case.) But I've not now managed to reproduce this bug, even without the patch. I don't see why I didn't do that earlier: perhaps inhibited by the preference to eliminate shmem_recalc_inode() altogether. Driven by this incident, I do now have a patch to do so at last; but still want to sit on it for a bit, there's a couple of questions yet to be resolved. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: page_alloc: hide some GFP internals and document the bits and flag ↵Mel Gorman
combinations Andrew stated the following We have quite a history of remote parts of the kernel using weird/wrong/inexplicable combinations of __GFP_ flags. I tend to think that this is because we didn't adequately explain the interface. And I don't think that gfp.h really improved much in this area as a result of this patchset. Could you go through it some time and decide if we've adequately documented all this stuff? This patches first moves some GFP flag combinations that are part of the MM internals to mm/internal.h. The rest of the patch documents the __GFP_FOO bits under various headings and then documents the flag combinations. It will not help callers that are brain damaged but the clarity might motivate some fixes and avoid future mistakes. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05tmpfs: avoid a little creat and stat slowdownHugh Dickins
LKP reports that v4.2 commit afa2db2fb6f1 ("tmpfs: truncate prealloc blocks past i_size") causes a 14.5% slowdown in the AIM9 creat-clo benchmark. creat-clo does just what you'd expect from the name, and creat's O_TRUNC on 0-length file does indeed get into more overhead now shmem_setattr() tests "0 <= 0" instead of "0 < 0". I'm not sure how much we care, but I think it would not be too VW-like to add in a check for whether any pages (or swap) are allocated: if none are allocated, there's none to remove from the radix_tree. At first I thought that check would be good enough for the unmaps too, but no: we should not skip the unlikely case of unmapping pages beyond the new EOF, which were COWed from holes which have now been reclaimed, leaving none. This gives me an 8.5% speedup: on Haswell instead of LKP's Westmere, and running a debug config before and after: I hope those account for the lesser speedup. And probably someone has a benchmark where a thousand threads keep on stat'ing the same file repeatedly: forestall that report by adjusting v4.3 commit 44a30220bc0a ("shmem: recalculate file inode when fstat") not to take the spinlock in shmem_getattr() when there's no work to do. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Ying Huang <ying.huang@linux.intel.com> Tested-by: Ying Huang <ying.huang@linux.intel.com> Cc: Josef Bacik <jbacik@fb.com> Cc: Yu Zhao <yuzhao@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05mm: rename mem_cgroup_migrate to mem_cgroup_replace_pageHugh Dickins
After v4.3's commit 0610c25daa3e ("memcg: fix dirty page migration") mem_cgroup_migrate() doesn't have much to offer in page migration: convert migrate_misplaced_transhuge_page() to set_page_memcg() instead. Then rename mem_cgroup_migrate() to mem_cgroup_replace_page(), since its remaining callers are replace_page_cache_page() and shmem_replace_page(): both of whom passed lrucare true, so just eliminate that argument. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08shmem: recalculate file inode when fstatYu Zhao
Shmem uses shmem_recalc_inode to update i_blocks when it allocates page, undoes range or swaps. But mm can drop clean page without notifying shmem. This makes fstat sometimes return out-of-date block size. The problem can be partially solved when we add inode_operations->getattr which calls shmem_recalc_inode to update i_blocks for fstat. shmem_recalc_inode also updates counter used by statfs and vm_committed_as. For them the situation is not changed. They still suffer from the discrepancy after dropping clean page and before the function is called by aforementioned triggers. Signed-off-by: Yu Zhao <yuzhao@google.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07ipc: use private shmem or hugetlbfs inodes for shm segments.Stephen Smalley
The shm implementation internally uses shmem or hugetlbfs inodes for shm segments. As these inodes are never directly exposed to userspace and only accessed through the shm operations which are already hooked by security modules, mark the inodes with the S_PRIVATE flag so that inode security initialization and permission checking is skipped. This was motivated by the following lockdep warning: ====================================================== [ INFO: possible circular locking dependency detected ] 4.2.0-0.rc3.git0.1.fc24.x86_64+debug #1 Tainted: G W ------------------------------------------------------- httpd/1597 is trying to acquire lock: (&ids->rwsem){+++++.}, at: shm_close+0x34/0x130 but task is already holding lock: (&mm->mmap_sem){++++++}, at: SyS_shmdt+0x4b/0x180 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #3 (&mm->mmap_sem){++++++}: lock_acquire+0xc7/0x270 __might_fault+0x7a/0xa0 filldir+0x9e/0x130 xfs_dir2_block_getdents.isra.12+0x198/0x1c0 [xfs] xfs_readdir+0x1b4/0x330 [xfs] xfs_file_readdir+0x2b/0x30 [xfs] iterate_dir+0x97/0x130 SyS_getdents+0x91/0x120 entry_SYSCALL_64_fastpath+0x12/0x76 -> #2 (&xfs_dir_ilock_class){++++.+}: lock_acquire+0xc7/0x270 down_read_nested+0x57/0xa0 xfs_ilock+0x167/0x350 [xfs] xfs_ilock_attr_map_shared+0x38/0x50 [xfs] xfs_attr_get+0xbd/0x190 [xfs] xfs_xattr_get+0x3d/0x70 [xfs] generic_getxattr+0x4f/0x70 inode_doinit_with_dentry+0x162/0x670 sb_finish_set_opts+0xd9/0x230 selinux_set_mnt_opts+0x35c/0x660 superblock_doinit+0x77/0xf0 delayed_superblock_init+0x10/0x20 iterate_supers+0xb3/0x110 selinux_complete_init+0x2f/0x40 security_load_policy+0x103/0x600 sel_write_load+0xc1/0x750 __vfs_write+0x37/0x100 vfs_write+0xa9/0x1a0 SyS_write+0x58/0xd0 entry_SYSCALL_64_fastpath+0x12/0x76 ... Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Reported-by: Morten Stevens <mstevens@fedoraproject.org> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24tmpfs: truncate prealloc blocks past i_sizeJosef Bacik
One of the rocksdb people noticed that when you do something like this fallocate(fd, FALLOC_FL_KEEP_SIZE, 0, 10M) pwrite(fd, buf, 5M, 0) ftruncate(5M) on tmpfs, the file would still take up 10M: which led to super fun issues because we were getting ENOSPC before we thought we should be getting ENOSPC. This patch fixes the problem, and mirrors what all the other fs'es do (and was agreed to be the correct behaviour at LSF). I tested it locally to make sure it worked properly with the following xfs_io -f -c "falloc -k 0 10M" -c "pwrite 0 5M" -c "truncate 5M" file Without the patch we have "Blocks: 20480", with the patch we have the correct value of "Blocks: 10240". Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-22Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "In this pile: pathname resolution rewrite. - recursion in link_path_walk() is gone. - nesting limits on symlinks are gone (the only limit remaining is that the total amount of symlinks is no more than 40, no matter how nested). - "fast" (inline) symlinks are handled without leaving rcuwalk mode. - stack footprint (independent of the nesting) is below kilobyte now, about on par with what it used to be with one level of nested symlinks and ~2.8 times lower than it used to be in the worst case. - struct nameidata is entirely private to fs/namei.c now (not even opaque pointers are being passed around). - ->follow_link() and ->put_link() calling conventions had been changed; all in-tree filesystems converted, out-of-tree should be able to follow reasonably easily. For out-of-tree conversions, see Documentation/filesystems/porting for details (and in-tree filesystems for examples of conversion). That has sat in -next since mid-May, seems to survive all testing without regressions and merges clean with v4.1" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (131 commits) turn user_{path_at,path,lpath,path_dir}() into static inlines namei: move saved_nd pointer into struct nameidata inline user_path_create() inline user_path_parent() namei: trim do_last() arguments namei: stash dfd and name into nameidata namei: fold path_cleanup() into terminate_walk() namei: saner calling conventions for filename_parentat() namei: saner calling conventions for filename_create() namei: shift nameidata down into filename_parentat() namei: make filename_lookup() reject ERR_PTR() passed as name namei: shift nameidata inside filename_lookup() namei: move putname() call into filename_lookup() namei: pass the struct path to store the result down into path_lookupat() namei: uninline set_root{,_rcu}() namei: be careful with mountpoint crossings in follow_dotdot_rcu() Documentation: remove outdated information from automount-support.txt get rid of assorted nameidata-related debris lustre: kill unused helper lustre: kill unused macro (LOOKUP_CONTINUE) ...
2015-06-17mm: shmem_zero_setup skip security check and lockdep conflict with XFSHugh Dickins
It appears that, at some point last year, XFS made directory handling changes which bring it into lockdep conflict with shmem_zero_setup(): it is surprising that mmap() can clone an inode while holding mmap_sem, but that has been so for many years. Since those few lockdep traces that I've seen all implicated selinux, I'm hoping that we can use the __shmem_file_setup(,,,S_PRIVATE) which v3.13's commit c7277090927a ("security: shmem: implement kernel private shmem inodes") introduced to avoid LSM checks on kernel-internal inodes: the mmap("/dev/zero") cloned inode is indeed a kernel-internal detail. This also covers the !CONFIG_SHMEM use of ramfs to support /dev/zero (and MAP_SHARED|MAP_ANONYMOUS). I thought there were also drivers which cloned inode in mmap(), but if so, I cannot locate them now. Reported-and-tested-by: Prarit Bhargava <prarit@redhat.com> Reported-and-tested-by: Daniel Wagner <wagi@monom.org> Reported-and-tested-by: Morten Stevens <mstevens@fedoraproject.org> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-11switch ->put_link() from dentry to inodeAl Viro
only one instance looks at that argument at all; that sole exception wants inode rather than dentry. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10don't pass nameidata to ->follow_link()Al Viro
its only use is getting passed to nd_jump_link(), which can obtain it from current->nameidata Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10new ->follow_link() and ->put_link() calling conventionsAl Viro
a) instead of storing the symlink body (via nd_set_link()) and returning an opaque pointer later passed to ->put_link(), ->follow_link() _stores_ that opaque pointer (into void * passed by address by caller) and returns the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic symlinks) and pointer to symlink body for normal symlinks. Stored pointer is ignored in all cases except the last one. Storing NULL for opaque pointer (or not storing it at all) means no call of ->put_link(). b) the body used to be passed to ->put_link() implicitly (via nameidata). Now only the opaque pointer is. In the cases when we used the symlink body to free stuff, ->follow_link() now should store it as opaque pointer in addition to returning it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10shmem: switch to simple_follow_link()Al Viro
Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: assorted weird filesystems: d_inode() annotationsDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Merge branch 'iocb' into for-nextAl Viro
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-23mm: shmem: check for mapping owner before dereferencingSasha Levin
mapping->host can be NULL and shouldn't be dereferenced before being checked. [ 1295.741844] GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] SMP KASAN [ 1295.746387] Dumping ftrace buffer: [ 1295.748217] (ftrace buffer empty) [ 1295.749527] Modules linked in: [ 1295.750268] CPU: 62 PID: 23410 Comm: trinity-c70 Not tainted 3.19.0-next-20150219-sasha-00045-g9130270f #1939 [ 1295.750268] task: ffff8803a49db000 ti: ffff8803a4dc8000 task.ti: ffff8803a4dc8000 [ 1295.750268] RIP: shmem_mapping (mm/shmem.c:1458) [ 1295.750268] RSP: 0000:ffff8803a4dcfbf8 EFLAGS: 00010206 [ 1295.750268] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 00000000000f2804 [ 1295.750268] RDX: 0000000000000005 RSI: 0400000000000794 RDI: 0000000000000028 [ 1295.750268] RBP: ffff8803a4dcfc08 R08: 0000000000000000 R09: 00000000031de000 [ 1295.750268] R10: dffffc0000000000 R11: 00000000031c1000 R12: 0400000000000794 [ 1295.750268] R13: 00000000031c2000 R14: 00000000031de000 R15: ffff880e3bdc1000 [ 1295.750268] FS: 00007f8703c7e700(0000) GS:ffff881164800000(0000) knlGS:0000000000000000 [ 1295.750268] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 1295.750268] CR2: 0000000004e58000 CR3: 00000003a9f3c000 CR4: 00000000000007a0 [ 1295.750268] DR0: ffffffff81000000 DR1: 0000009494949494 DR2: 0000000000000000 [ 1295.750268] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 00000000000d0602 [ 1295.750268] Stack: [ 1295.750268] ffff8803a4dcfec8 ffffffffbb1dc770 ffff8803a4dcfc38 ffffffffad6f230b [ 1295.750268] ffffffffad6f2b0d 0000014100000000 ffff88001e17c08b ffff880d9453fe08 [ 1295.750268] ffff8803a4dcfd18 ffffffffad6f2ce2 ffff8803a49dbcd8 ffff8803a49dbce0 [ 1295.750268] Call Trace: [ 1295.750268] mincore_page (mm/mincore.c:61) [ 1295.750268] ? mincore_pte_range (include/linux/spinlock.h:312 mm/mincore.c:131) [ 1295.750268] mincore_pte_range (mm/mincore.c:151) [ 1295.750268] ? mincore_unmapped_range (mm/mincore.c:113) [ 1295.750268] __walk_page_range (mm/pagewalk.c:51 mm/pagewalk.c:90 mm/pagewalk.c:116 mm/pagewalk.c:204) [ 1295.750268] walk_page_range (mm/pagewalk.c:275) [ 1295.750268] SyS_mincore (mm/mincore.c:191 mm/mincore.c:253 mm/mincore.c:220) [ 1295.750268] ? mincore_pte_range (mm/mincore.c:220) [ 1295.750268] ? mincore_unmapped_range (mm/mincore.c:113) [ 1295.750268] ? __mincore_unmapped_range (mm/mincore.c:105) [ 1295.750268] ? ptlock_free (mm/mincore.c:24) [ 1295.750268] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1610) [ 1295.750268] ia32_do_call (arch/x86/ia32/ia32entry.S:446) [ 1295.750268] Code: e5 48 c1 ea 03 53 48 89 fb 48 83 ec 08 80 3c 02 00 75 4f 48 b8 00 00 00 00 00 fc ff df 48 8b 1b 48 8d 7b 28 48 89 fa 48 c1 ea 03 <80> 3c 02 00 75 3f 48 b8 00 00 00 00 00 fc ff df 48 8b 5b 28 48 All code ======== 0: e5 48 in $0x48,%eax 2: c1 ea 03 shr $0x3,%edx 5: 53 push %rbx 6: 48 89 fb mov %rdi,%rbx 9: 48 83 ec 08 sub $0x8,%rsp d: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) 11: 75 4f jne 0x62 13: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax 1a: fc ff df 1d: 48 8b 1b mov (%rbx),%rbx 20: 48 8d 7b 28 lea 0x28(%rbx),%rdi 24: 48 89 fa mov %rdi,%rdx 27: 48 c1 ea 03 shr $0x3,%rdx 2b:* 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) <-- trapping instruction 2f: 75 3f jne 0x70 31: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax 38: fc ff df 3b: 48 8b 5b 28 mov 0x28(%rbx),%rbx 3f: 48 rex.W ... Code starting with the faulting instruction =========================================== 0: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) 4: 75 3f jne 0x45 6: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax d: fc ff df 10: 48 8b 5b 28 mov 0x28(%rbx),%rbx 14: 48 rex.W ... [ 1295.750268] RIP shmem_mapping (mm/shmem.c:1458) [ 1295.750268] RSP <ffff8803a4dcfbf8> Fixes: 97b713ba3e ("fs: kill BDI_CAP_SWAP_BACKED") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-12Merge branch 'for-3.20/bdi' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull backing device changes from Jens Axboe: "This contains a cleanup of how the backing device is handled, in preparation for a rework of the life time rules. In this part, the most important change is to split the unrelated nommu mmap flags from it, but also removing a backing_dev_info pointer from the address_space (and inode), and a cleanup of other various minor bits. Christoph did all the work here, I just fixed an oops with pages that have a swap backing. Arnd fixed a missing export, and Oleg killed the lustre backing_dev_info from staging. Last patch was from Al, unexporting parts that are now no longer needed outside" * 'for-3.20/bdi' of git://git.kernel.dk/linux-block: Make super_blocks and sb_lock static mtd: export new mtd_mmap_capabilities fs: make inode_to_bdi() handle NULL inode staging/lustre/llite: get rid of backing_dev_info fs: remove default_backing_dev_info fs: don't reassign dirty inodes to default_backing_dev_info nfs: don't call bdi_unregister ceph: remove call to bdi_unregister fs: remove mapping->backing_dev_info fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info nilfs2: set up s_bdi like the generic mount_bdev code block_dev: get bdev inode bdi directly from the block device block_dev: only write bdev inode on close fs: introduce f_op->mmap_capabilities for nommu mmap support fs: kill BDI_CAP_SWAP_BACKED fs: deduplicate noop_backing_dev_info
2015-02-11swap: remove unused mem_cgroup_uncharge_swapcache declarationVladimir Davydov
The body of this function was removed by commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API"). Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10mm: drop vm_ops->remap_pages and generic_file_remap_pages() stubKirill A. Shutemov
Nobody uses it anymore. [akpm@linux-foundation.org: fix filemap_xip.c] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-05memcg, shmem: fix shmem migration to use lrucareMichal Hocko
It has been reported that 965GM might trigger VM_BUG_ON_PAGE(!lrucare && PageLRU(oldpage), oldpage) in mem_cgroup_migrate when shmem wants to replace a swap cache page because of shmem_should_replace_page (the page is allocated from an inappropriate zone). shmem_replace_page expects that the oldpage is not on LRU list and calls mem_cgroup_migrate without lrucare. This is obviously incorrect because swapcache pages might be on the LRU list (e.g. swapin readahead page). Fix this by enabling lrucare for the migration in shmem_replace_page. Also clarify that lrucare should be used even if one of the pages might be on LRU list. The BUG_ON will trigger only when CONFIG_DEBUG_VM is enabled but even without that the migration code might leave the old page on an inappropriate memcg' LRU which is not that critical because the page would get removed with its last reference but it is still confusing. Fixes: 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API") Signed-off-by: Michal Hocko <mhocko@suse.cz> Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Reported-by: Dave Airlie <airlied@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [3.17+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-20fs: kill BDI_CAP_SWAP_BACKEDChristoph Hellwig
This bdi flag isn't too useful - we can determine that a vma is backed by either swap or shmem trivially in the caller. This also allows removing the backing_dev_info instaces for swap and shmem in favor of noop_backing_dev_info. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-17new helper: iter_is_iovec()Al Viro
2014-10-24shmem: support RENAME_WHITEOUTMiklos Szeredi
Allocate a dentry, initialize it with a whiteout and hash it in the place of the old dentry. Later the old dentry will be moved away and the whiteout will remain. i_mutex protects agains concurrent readdir. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Hugh Dickins <hughd@google.com>
2014-10-10Merge branch 'for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "A lot of activities on percpu front. Notable changes are... - percpu allocator now can take @gfp. If @gfp doesn't contain GFP_KERNEL, it tries to allocate from what's already available to the allocator and a work item tries to keep the reserve around certain level so that these atomic allocations usually succeed. This will replace the ad-hoc percpu memory pool used by blk-throttle and also be used by the planned blkcg support for writeback IOs. Please note that I noticed a bug in how @gfp is interpreted while preparing this pull request and applied the fix 6ae833c7fe0c ("percpu: fix how @gfp is interpreted by the percpu allocator") just now. - percpu_ref now uses longs for percpu and global counters instead of ints. It leads to more sparse packing of the percpu counters on 64bit machines but the overhead should be negligible and this allows using percpu_ref for refcnting pages and in-memory objects directly. - The switching between percpu and single counter modes of a percpu_ref is made independent of putting the base ref and a percpu_ref can now optionally be initialized in single or killed mode. This allows avoiding percpu shutdown latency for cases where the refcounted objects may be synchronously created and destroyed in rapid succession with only a fraction of them reaching fully operational status (SCSI probing does this when combined with blk-mq support). It's also planned to be used to implement forced single mode to detect underflow more timely for debugging. There's a separate branch percpu/for-3.18-consistent-ops which cleans up the duplicate percpu accessors. That branch causes a number of conflicts with s390 and other trees. I'll send a separate pull request w/ resolutions once other branches are merged" * 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits) percpu: fix how @gfp is interpreted by the percpu allocator blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky percpu_ref: add PERCPU_REF_INIT_* flags percpu_ref: decouple switching to percpu mode and reinit percpu_ref: decouple switching to atomic mode and killing percpu_ref: add PCPU_REF_DEAD percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch percpu_ref: replace pcpu_ prefix with percpu_ percpu_ref: minor code and comment updates percpu_ref: relocate percpu_ref_reinit() Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe" Revert "percpu: free percpu allocation info for uniprocessor system" percpu-refcount: make percpu_ref based on longs instead of ints percpu-refcount: improve WARN messages percpu: fix locking regression in the failure path of pcpu_alloc() percpu-refcount: add @gfp to percpu_ref_init() proportions: add @gfp to init functions percpu_counter: add @gfp to percpu_counter_init() percpu_counter: make percpu_counters_lock irq-safe ...
2014-10-09include/linux/migrate.h: remove migrate_page #defineAndrew Morton
This is designed to avoid a few ifdefs in .c files but it's obnoxious because it can cause unsuspecting "migrate_page" symbols to get turned into "NULL". Just nuke it and use the ifdefs. Cc: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-26shmem: fix nlink for rename overwrite directoryMiklos Szeredi
If overwriting an empty directory with rename, then need to drop the extra nlink. Test prog: #include <stdio.h> #include <fcntl.h> #include <err.h> #include <sys/stat.h> int main(void) { const char *test_dir1 = "test-dir1"; const char *test_dir2 = "test-dir2"; int res; int fd; struct stat statbuf; res = mkdir(test_dir1, 0777); if (res == -1) err(1, "mkdir(\"%s\")", test_dir1); res = mkdir(test_dir2, 0777); if (res == -1) err(1, "mkdir(\"%s\")", test_dir2); fd = open(test_dir2, O_RDONLY); if (fd == -1) err(1, "open(\"%s\")", test_dir2); res = rename(test_dir1, test_dir2); if (res == -1) err(1, "rename(\"%s\", \"%s\")", test_dir1, test_dir2); res = fstat(fd, &statbuf); if (res == -1) err(1, "fstat(%i)", fd); if (statbuf.st_nlink != 0) { fprintf(stderr, "nlink is %lu, should be 0\n", statbuf.st_nlink); return 1; } return 0; } Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-08-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Stuff in here: - acct.c fixes and general rework of mnt_pin mechanism. That allows to go for delayed-mntput stuff, which will permit mntput() on deep stack without worrying about stack overflows - fs shutdown will happen on shallow stack. IOW, we can do Eric's umount-on-rmdir series without introducing tons of stack overflows on new mntput() call chains it introduces. - Bruce's d_splice_alias() patches - more Miklos' rename() stuff. - a couple of regression fixes (stable fodder, in the end of branch) and a fix for API idiocy in iov_iter.c. There definitely will be another pile, maybe even two. I'd like to get Eric's series in this time, but even if we miss it, it'll go right in the beginning of for-next in the next cycle - the tricky part of prereqs is in this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits) fix copy_tree() regression __generic_file_write_iter(): fix handling of sync error after DIO switch iov_iter_get_pages() to passing maximal number of pages fs: mark __d_obtain_alias static dcache: d_splice_alias should detect loops exportfs: update Exporting documentation dcache: d_find_alias needn't recheck IS_ROOT && DCACHE_DISCONNECTED dcache: remove unused d_find_alias parameter dcache: d_obtain_alias callers don't all want DISCONNECTED dcache: d_splice_alias should ignore DCACHE_DISCONNECTED dcache: d_splice_alias mustn't create directory aliases dcache: close d_move race in d_splice_alias dcache: move d_splice_alias namei: trivial fix to vfs_rename_dir comment VFS: allow ->d_manage() to declare -EISDIR in rcu_walk mode. cifs: support RENAME_NOREPLACE hostfs: support rename flags shmem: support RENAME_EXCHANGE shmem: support RENAME_NOREPLACE btrfs: add RENAME_NOREPLACE ...
2014-08-08shm: wait for pins to be released when sealingDavid Herrmann
If we set SEAL_WRITE on a file, we must make sure there cannot be any ongoing write-operations on the file. For write() calls, we simply lock the inode mutex, for mmap() we simply verify there're no writable mappings. However, there might be pages pinned by AIO, Direct-IO and similar operations via GUP. We must make sure those do not write to the memfd file after we set SEAL_WRITE. As there is no way to notify GUP users to drop pages or to wait for them to be done, we implement the wait ourself: When setting SEAL_WRITE, we check all pages for their ref-count. If it's bigger than 1, we know there's some user of the page. We then mark the page and wait for up to 150ms for those ref-counts to be dropped. If the ref-counts are not dropped in time, we refuse the seal operation. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08shm: add memfd_create() syscallDavid Herrmann
memfd_create() is similar to mmap(MAP_ANON), but returns a file-descriptor that you can pass to mmap(). It can support sealing and avoids any connection to user-visible mount-points. Thus, it's not subject to quotas on mounted file-systems, but can be used like malloc()'ed memory, but with a file-descriptor to it. memfd_create() returns the raw shmem file, so calls like ftruncate() can be used to modify the underlying inode. Also calls like fstat() will return proper information and mark the file as regular file. If you want sealing, you can specify MFD_ALLOW_SEALING. Otherwise, sealing is not supported (like on all other regular files). Compared to O_TMPFILE, it does not require a tmpfs mount-point and is not subject to a filesystem size limit. It is still properly accounted to memcg limits, though, and to the same overcommit or no-overcommit accounting as all user memory. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08shm: add sealing APIDavid Herrmann
If two processes share a common memory region, they usually want some guarantees to allow safe access. This often includes: - one side cannot overwrite data while the other reads it - one side cannot shrink the buffer while the other accesses it - one side cannot grow the buffer beyond previously set boundaries If there is a trust-relationship between both parties, there is no need for policy enforcement. However, if there's no trust relationship (eg., for general-purpose IPC) sharing memory-regions is highly fragile and often not possible without local copies. Look at the following two use-cases: 1) A graphics client wants to share its rendering-buffer with a graphics-server. The memory-region is allocated by the client for read/write access and a second FD is passed to the server. While scanning out from the memory region, the server has no guarantee that the client doesn't shrink the buffer at any time, requiring rather cumbersome SIGBUS handling. 2) A process wants to perform an RPC on another process. To avoid huge bandwidth consumption, zero-copy is preferred. After a message is assembled in-memory and a FD is passed to the remote side, both sides want to be sure that neither modifies this shared copy, anymore. The source may have put sensible data into the message without a separate copy and the target may want to parse the message inline, to avoid a local copy. While SIGBUS handling, POSIX mandatory locking and MAP_DENYWRITE provide ways to achieve most of this, the first one is unproportionally ugly to use in libraries and the latter two are broken/racy or even disabled due to denial of service attacks. This patch introduces the concept of SEALING. If you seal a file, a specific set of operations is blocked on that file forever. Unlike locks, seals can only be set, never removed. Hence, once you verified a specific set of seals is set, you're guaranteed that no-one can perform the blocked operations on this file, anymore. An initial set of SEALS is introduced by this patch: - SHRINK: If SEAL_SHRINK is set, the file in question cannot be reduced in size. This affects ftruncate() and open(O_TRUNC). - GROW: If SEAL_GROW is set, the file in question cannot be increased in size. This affects ftruncate(), fallocate() and write(). - WRITE: If SEAL_WRITE is set, no write operations (besides resizing) are possible. This affects fallocate(PUNCH_HOLE), mmap() and write(). - SEAL: If SEAL_SEAL is set, no further seals can be added to a file. This basically prevents the F_ADD_SEAL operation on a file and can be set to prevent others from adding further seals that you don't want. The described use-cases can easily use these seals to provide safe use without any trust-relationship: 1) The graphics server can verify that a passed file-descriptor has SEAL_SHRINK set. This allows safe scanout, while the client is allowed to increase buffer size for window-resizing on-the-fly. Concurrent writes are explicitly allowed. 2) For general-purpose IPC, both processes can verify that SEAL_SHRINK, SEAL_GROW and SEAL_WRITE are set. This guarantees that neither process can modify the data while the other side parses it. Furthermore, it guarantees that even with writable FDs passed to the peer, it cannot increase the size to hit memory-limits of the source process (in case the file-storage is accounted to the source). The new API is an extension to fcntl(), adding two new commands: F_GET_SEALS: Return a bitset describing the seals on the file. This can be called on any FD if the underlying file supports sealing. F_ADD_SEALS: Change the seals of a given file. This requires WRITE access to the file and F_SEAL_SEAL may not already be set. Furthermore, the underlying file must support sealing and there may not be any existing shared mapping of that file. Otherwise, EBADF/EPERM is returned. The given seals are _added_ to the existing set of seals on the file. You cannot remove seals again. The fcntl() handler is currently specific to shmem and disabled on all files. A file needs to explicitly support sealing for this interface to work. A separate syscall is added in a follow-up, which creates files that support sealing. There is no intention to support this on other file-systems. Semantics are unclear for non-volatile files and we lack any use-case right now. Therefore, the implementation is specific to shmem. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ryan Lortie <desrt@desrt.ca> Cc: Lennart Poettering <lennart@poettering.net> Cc: Daniel Mack <zonque@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite charge APIJohannes Weiner
These patches rework memcg charge lifetime to integrate more naturally with the lifetime of user pages. This drastically simplifies the code and reduces charging and uncharging overhead. The most expensive part of charging and uncharging is the page_cgroup bit spinlock, which is removed entirely after this series. Here are the top-10 profile entries of a stress test that reads a 128G sparse file on a freshly booted box, without even a dedicated cgroup (i.e. executing in the root memcg). Before: 15.36% cat [kernel.kallsyms] [k] copy_user_generic_string 13.31% cat [kernel.kallsyms] [k] memset 11.48% cat [kernel.kallsyms] [k] do_mpage_readpage 4.23% cat [kernel.kallsyms] [k] get_page_from_freelist 2.38% cat [kernel.kallsyms] [k] put_page 2.32% cat [kernel.kallsyms] [k] __mem_cgroup_commit_charge 2.18% kswapd0 [kernel.kallsyms] [k] __mem_cgroup_uncharge_common 1.92% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.86% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.62% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn After: 15.67% cat [kernel.kallsyms] [k] copy_user_generic_string 13.48% cat [kernel.kallsyms] [k] memset 11.42% cat [kernel.kallsyms] [k] do_mpage_readpage 3.98% cat [kernel.kallsyms] [k] get_page_from_freelist 2.46% cat [kernel.kallsyms] [k] put_page 2.13% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.88% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.67% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn 1.39% kswapd0 [kernel.kallsyms] [k] free_pcppages_bulk 1.30% cat [kernel.kallsyms] [k] kfree As you can see, the memcg footprint has shrunk quite a bit. text data bss dec hex filename 37970 9892 400 48262 bc86 mm/memcontrol.o.old 35239 9892 400 45531 b1db mm/memcontrol.o This patch (of 4): The memcg charge API charges pages before they are rmapped - i.e. have an actual "type" - and so every callsite needs its own set of charge and uncharge functions to know what type is being operated on. Worse, uncharge has to happen from a context that is still type-specific, rather than at the end of the page's lifetime with exclusive access, and so requires a lot of synchronization. Rewrite the charge API to provide a generic set of try_charge(), commit_charge() and cancel_charge() transaction operations, much like what's currently done for swap-in: mem_cgroup_try_charge() attempts to reserve a charge, reclaiming pages from the memcg if necessary. mem_cgroup_commit_charge() commits the page to the charge once it has a valid page->mapping and PageAnon() reliably tells the type. mem_cgroup_cancel_charge() aborts the transaction. This reduces the charge API and enables subsequent patches to drastically simplify uncharging. As pages need to be committed after rmap is established but before they are added to the LRU, page_add_new_anon_rmap() must stop doing LRU additions again. Revive lru_cache_add_active_or_unevictable(). [hughd@google.com: fix shmem_unuse] [hughd@google.com: Add comments on the private use of -EAGAIN] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-07shmem: support RENAME_EXCHANGEMiklos Szeredi
This is really simple in tmpfs since the VFS already takes care of shuffling the dentries. Just adjust nlink on parent directories and touch c & mtimes. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-07shmem: support RENAME_NOREPLACEMiklos Szeredi
Implement ->rename2 instead of ->rename. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-06mm/shmem.c: remove the unused gfp arg to shmem_add_to_page_cache()Wang Sheng-Hui
The gfp arg is not used in shmem_add_to_page_cache. Remove this unused arg. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
