commit e4f8e513c3d353c134ad4eef9fd0bba12406c7c8 upstream.
A long time ago we fixed a similar deadlock in show_slab_objects() [1].
However, it is apparently due to the commits like 01fb58bcba63 ("slab:
remove synchronous synchronize_sched() from memcg cache deactivation
path") and 03afc0e25f7f ("slab: get_online_mems for
kmem_cache_{create,destroy,shrink}"), this kind of deadlock is back by
just reading files in /sys/kernel/slab which will generate a lockdep
splat below.
Since the "mem_hotplug_lock" here is only to obtain a stable online node
mask while racing with NUMA node hotplug, in the worst case, the results
may me miscalculated while doing NUMA node hotplug, but they shall be
corrected by later reads of the same files.
WARNING: possible circular locking dependency detected
cat/5224 is trying to acquire lock:
ffff900012ac3120 (mem_hotplug_lock.rw_sem){++++}, at:
show_slab_objects+0x94/0x3a8
but task is already holding lock:
b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (kn->count#45){++++}:
lock_acquire+0x31c/0x360
__kernfs_remove+0x290/0x490
kernfs_remove+0x30/0x44
sysfs_remove_dir+0x70/0x88
kobject_del+0x50/0xb0
sysfs_slab_unlink+0x2c/0x38
shutdown_cache+0xa0/0xf0
kmemcg_cache_shutdown_fn+0x1c/0x34
kmemcg_workfn+0x44/0x64
process_one_work+0x4f4/0x950
worker_thread+0x390/0x4bc
kthread+0x1cc/0x1e8
ret_from_fork+0x10/0x18
-> #1 (slab_mutex){+.+.}:
__mutex_lock_common+0x16c/0xf78
mutex_lock_nested+0x40/0x50
memcg_create_kmem_cache+0x38/0x16c
memcg_kmem_cache_create_func+0x3c/0x70
kthread+0x1cc/0x1e8
-> #0 (mem_hotplug_lock.rw_sem){++++}:
validate_chain+0xd10/0x2bcc
__lock_acquire+0x7f4/0xb8c
get_online_mems+0x54/0x150
total_objects_show+0x28/0x34
slab_attr_show+0x38/0x54
sysfs_kf_seq_show+0x198/0x2d4
kernfs_seq_show+0xa4/0xcc
seq_read+0x30c/0x8a8
kernfs_fop_read+0xa8/0x314
__vfs_read+0x88/0x20c
vfs_read+0xd8/0x10c
ksys_read+0xb0/0x120
__arm64_sys_read+0x54/0x88
el0_svc_handler+0x170/0x240
el0_svc+0x8/0xc
Chain exists of:
mem_hotplug_lock.rw_sem --> slab_mutex --> kn->count#45
Possible unsafe locking scenario:
CPU0 CPU1
lock(kn->count#45);
lock(slab_mutex);
lock(kn->count#45);
lock(mem_hotplug_lock.rw_sem);
*** DEADLOCK ***
3 locks held by cat/5224:
#0: 9eff00095b14b2a0 (&p->lock){+.+.}, at: seq_read+0x4c/0x8a8
#1: 0eff008997041480 (&of->mutex){+.+.}, at: kernfs_seq_start+0x34/0xf0
#2: b8ff009693eee398 (kn->count#45){++++}, at:
stack backtrace:
Call trace:
dump_backtrace+0x0/0x248
show_stack+0x20/0x2c
dump_stack+0xd0/0x140
print_circular_bug+0x368/0x380
check_noncircular+0x248/0x250
vfs_read+0xd8/0x10c
el0_svc+0x8/0xc
I think it is important to mention that this doesn't expose the
show_slab_objects to use-after-free. There is only a single path that
might really race here and that is the slab hotplug notifier callback
__kmem_cache_shrink (via slab_mem_going_offline_callback) but that path
doesn't really destroy kmem_cache_node data structures.
[1] http://lkml.iu.edu/hypermail/linux/kernel/1101.0/02850.html
[akpm@linux-foundation.org: add comment explaining why we don't need mem_hotplug_lock]
Link: http://lkml.kernel.org/r/1570192309-10132-1-git-send-email-cai@lca.pw
Fixes: 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path")
Fixes: 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}")
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Roman Gushchin <guro@fb.com>
Cc: <stable@vger.kernel.org>
commit e5d9998f3e09359b372a037a6ac55ba235d95d57 upstream.
* cpu_partial determined the maximum number of objects
* kept in the per cpu partial lists of a processor.
Can't be negative.
Link: http://lkml.kernel.org/r/20180305200730.15812-15-adobriyan@gmail.com
Acked-by: Christoph Lameter <cl@linux.com>
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
[ Upstream commit a38965bf941b7c2af50de09c96bc5f03e136caef ]
__printf is useful to verify format and arguments. Remove the following
warning (with W=1):
mm/slub.c:721:2: warning: function might be possible candidate for `gnu_printf' format attribute [-Wsuggest-attribute=format]
Link: http://lkml.kernel.org/r/20180505200706.19986-1-malat@debian.org
Signed-off-by: Mathieu Malaterre <malat@debian.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
commit d50d82faa0c964e31f7a946ba8aba7c715ca7ab0 upstream.
In kernel 4.17 I removed some code from dm-bufio that did slab cache
merging (commit 21bb13276768: "dm bufio: remove code that merges slab
caches") - both slab and slub support merging caches with identical
attributes, so dm-bufio now just calls kmem_cache_create and relies on
implicit merging.
This uncovered a bug in the slub subsystem - if we delete a cache and
immediatelly create another cache with the same attributes, it fails
because of duplicate filename in /sys/kernel/slab/. The slub subsystem
offloads freeing the cache to a workqueue - and if we create the new
cache before the workqueue runs, it complains because of duplicate
filename in sysfs.
This patch fixes the bug by moving the call of kobject_del from
sysfs_slab_remove_workfn to shutdown_cache. kobject_del must be called
while we hold slab_mutex - so that the sysfs entry is deleted before a
cache with the same attributes could be created.
Running device-mapper-test-suite with:
dmtest run --suite thin-provisioning -n /commit_failure_causes_fallback/
triggered:
Buffer I/O error on dev dm-0, logical block 1572848, async page read
device-mapper: thin: 253:1: metadata operation 'dm_pool_alloc_data_block' failed: error = -5
device-mapper: thin: 253:1: aborting current metadata transaction
sysfs: cannot create duplicate filename '/kernel/slab/:a-0000144'
CPU: 2 PID: 1037 Comm: kworker/u48:1 Not tainted 4.17.0.snitm+ #25
Hardware name: Supermicro SYS-1029P-WTR/X11DDW-L, BIOS 2.0a 12/06/2017
Workqueue: dm-thin do_worker [dm_thin_pool]
Call Trace:
dump_stack+0x5a/0x73
sysfs_warn_dup+0x58/0x70
sysfs_create_dir_ns+0x77/0x80
kobject_add_internal+0xba/0x2e0
kobject_init_and_add+0x70/0xb0
sysfs_slab_add+0xb1/0x250
__kmem_cache_create+0x116/0x150
create_cache+0xd9/0x1f0
kmem_cache_create_usercopy+0x1c1/0x250
kmem_cache_create+0x18/0x20
dm_bufio_client_create+0x1ae/0x410 [dm_bufio]
dm_block_manager_create+0x5e/0x90 [dm_persistent_data]
__create_persistent_data_objects+0x38/0x940 [dm_thin_pool]
dm_pool_abort_metadata+0x64/0x90 [dm_thin_pool]
metadata_operation_failed+0x59/0x100 [dm_thin_pool]
alloc_data_block.isra.53+0x86/0x180 [dm_thin_pool]
process_cell+0x2a3/0x550 [dm_thin_pool]
do_worker+0x28d/0x8f0 [dm_thin_pool]
process_one_work+0x171/0x370
worker_thread+0x49/0x3f0
kthread+0xf8/0x130
ret_from_fork+0x35/0x40
kobject_add_internal failed for :a-0000144 with -EEXIST, don't try to register things with the same name in the same directory.
kmem_cache_create(dm_bufio_buffer-16) failed with error -17
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1806151817130.6333@file01.intranet.prod.int.rdu2.redhat.com
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Reported-by: Mike Snitzer <snitzer@redhat.com>
Tested-by: Mike Snitzer <snitzer@redhat.com>
commit 4675ff05de2d76d167336b368bd07f3fef6ed5a6 upstream.
Fix up makefiles, remove references, and git rm kmemcheck.
Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Tim Hansen <devtimhansen@gmail.com>
commit d8be75663cec0069b85f80191abd2682ce4a512f upstream.
Now that kmemcheck is gone, we don't need the NOTRACK flags.
Link: http://lkml.kernel.org/r/20171007030159.22241-5-alexander.levin@verizon.com
commit 75f296d93bcebcfe375884ddac79e30263a31766 upstream.
Convert all allocations that used a NOTRACK flag to stop using it.
Link: http://lkml.kernel.org/r/20171007030159.22241-3-alexander.levin@verizon.com
commit 4950276672fce5c241857540f8561c440663673d upstream.
Patch series "kmemcheck: kill kmemcheck", v2.
As discussed at LSF/MM, kill kmemcheck.
KASan is a replacement that is able to work without the limitation of
kmemcheck (single CPU, slow). KASan is already upstream.
We are also not aware of any users of kmemcheck (or users who don't
consider KASan as a suitable replacement).
The only objection was that since KASAN wasn't supported by all GCC
versions provided by distros at that time we should hold off for 2
years, and try again.
Now that 2 years have passed, and all distros provide gcc that supports
KASAN, kill kmemcheck again for the very same reasons.
This patch (of 4):
Remove kmemcheck annotations, and calls to kmemcheck from the kernel.
[alexander.levin@verizon.com: correctly remove kmemcheck call from dma_map_sg_attrs]
Link: http://lkml.kernel.org/r/20171012192151.26531-1-alexander.levin@verizon.com
Link: http://lkml.kernel.org/r/20171007030159.22241-2-alexander.levin@verizon.com
[ Upstream commit 11066386efa692f77171484c32ea30f6e5a0d729 ]
When slub_debug=O is set. It is possible to clear debug flags for an
"unmergeable" slab cache in kmem_cache_open(). It makes the "unmergeable"
cache became "mergeable" in sysfs_slab_add().
These caches will generate their "unique IDs" by create_unique_id(), but
it is possible to create identical unique IDs. In my experiment,
sgpool-128, names_cache, biovec-256 generate the same ID ":Ft-0004096" and
the kernel reports "sysfs: cannot create duplicate filename
'/kernel/slab/:Ft-0004096'".
To repeat my experiment, set disable_higher_order_debug=1,
CONFIG_SLUB_DEBUG_ON=y in kernel-4.14.
Fix this issue by setting unmergeable=1 if slub_debug=O and the the
default slub_debug contains any no-merge flags.
call path:
kmem_cache_create()
__kmem_cache_alias() -> we set SLAB_NEVER_MERGE flags here
create_cache()
__kmem_cache_create()
kmem_cache_open() -> clear DEBUG_METADATA_FLAGS
sysfs_slab_add() -> the slab cache is mergeable now
sysfs: cannot create duplicate filename '/kernel/slab/:Ft-0004096'
WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x60/0x7c
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.14.0-rc7ajb-00131-gd4c2e9f-dirty #123
Hardware name: linux,dummy-virt (DT)
task: ffffffc07d4e0080 task.stack: ffffff8008008000
PC is at sysfs_warn_dup+0x60/0x7c
LR is at sysfs_warn_dup+0x60/0x7c
pc : lr : pstate: 60000145
Call trace:
sysfs_create_dir_ns+0x98/0xa0
kobject_add_internal+0xa0/0x294
kobject_init_and_add+0x90/0xb4
sysfs_slab_add+0x90/0x200
__kmem_cache_create+0x26c/0x438
kmem_cache_create+0x164/0x1f4
sg_pool_init+0x60/0x100
do_one_initcall+0x38/0x12c
kernel_init_freeable+0x138/0x1d4
kernel_init+0x10/0xfc
Link: http://lkml.kernel.org/r/1510365805-5155-1-git-send-email-miles.chen@mediatek.com
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
GFP_TEMPORARY was introduced by commit e12ba74d8ff3 ("Group short-lived
and reclaimable kernel allocations") along with __GFP_RECLAIMABLE. It's
primary motivation was to allow users to tell that an allocation is
short lived and so the allocator can try to place such allocations close
together and prevent long term fragmentation. As much as this sounds
like a reasonable semantic it becomes much less clear when to use the
highlevel GFP_TEMPORARY allocation flag. How long is temporary? Can the
context holding that memory sleep? Can it take locks? It seems there is
no good answer for those questions.
The current implementation of GFP_TEMPORARY is basically GFP_KERNEL |
__GFP_RECLAIMABLE which in itself is tricky because basically none of
the existing caller provide a way to reclaim the allocated memory. So
this is rather misleading and hard to evaluate for any benefits.
I have checked some random users and none of them has added the flag
with a specific justification. I suspect most of them just copied from
other existing users and others just thought it might be a good idea to
use without any measuring. This suggests that GFP_TEMPORARY just
motivates for cargo cult usage without any reasoning.
I believe that our gfp flags are quite complex already and especially
those with highlevel semantic should be clearly defined to prevent from
confusion and abuse. Therefore I propose dropping GFP_TEMPORARY and
replace all existing users to simply use GFP_KERNEL. Please note that
SLAB users with shrinkers will still get __GFP_RECLAIMABLE heuristic and
so they will be placed properly for memory fragmentation prevention.
I can see reasons we might want some gfp flag to reflect shorterm
allocations but I propose starting from a clear semantic definition and
only then add users with proper justification.
This was been brought up before LSF this year by Matthew [1] and it
turned out that GFP_TEMPORARY really doesn't have a clear semantic. It
seems to be a heuristic without any measured advantage for most (if not
all) its current users. The follow up discussion has revealed that
opinions on what might be temporary allocation differ a lot between
developers. So rather than trying to tweak existing users into a
semantic which they haven't expected I propose to simply remove the flag
and start from scratch if we really need a semantic for short term
allocations.
[1] http://lkml.kernel.org/r/20170118054945.GD18349@bombadil.infradead.org
[akpm@linux-foundation.org: fix typo]
[sfr@canb.auug.org.au: drm/i915: fix up]
Link: http://lkml.kernel.org/r/20170816144703.378d4f4d@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170728091904.14627-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "Theodore Ts'o" <tytso@mit.edu>
First, number of CPUs can't be negative number.
Second, different signnnedness leads to suboptimal code in the following
cases:
1)
kmalloc(nr_cpu_ids * sizeof(X));
"int" has to be sign extended to size_t.
2)
while (loff_t *pos < nr_cpu_ids)
MOVSXD is 1 byte longed than the same MOV.
Other cases exist as well. Basically compiler is told that nr_cpu_ids
can't be negative which can't be deduced if it is "int".
Code savings on allyesconfig kernel: -3KB
add/remove: 0/0 grow/shrink: 25/264 up/down: 261/-3631 (-3370)
function old new delta
coretemp_cpu_online 450 512 +62
rcu_init_one 1234 1272 +38
pci_device_probe 374 399 +25
pgdat_reclaimable_pages 628 556 -72
select_fallback_rq 446 369 -77
task_numa_find_cpu 1923 1807 -116
Link: http://lkml.kernel.org/r/20170819114959.GA30580@avx2
attribute_group are not supposed to change at runtime. All functions
working with attribute_group provided by <linux/sysfs.h> work with const
attribute_group. So mark the non-const structs as const.
Link: http://lkml.kernel.org/r/1501157186-3749-1-git-send-email-arvind.yadav.cs@gmail.com
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Add an assertion similar to "fasttop" check in GNU C Library allocator
as a part of SLAB_FREELIST_HARDENED feature. An object added to a
singly linked freelist should not point to itself. That helps to detect
some double free errors (e.g. CVE-2017-2636) without slub_debug and
KASAN.
Link: http://lkml.kernel.org/r/1502468246-1262-1-git-send-email-alex.popov@linux.com
Signed-off-by: Alexander Popov <alex.popov@linux.com>
Cc: Paul E McKenney <paulmck@linux.vnet.ibm.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Tycho Andersen <tycho@docker.com>
This SLUB free list pointer obfuscation code is modified from Brad
Spengler/PaX Team's code in the last public patch of grsecurity/PaX
based on my understanding of the code. Changes or omissions from the
original code are mine and don't reflect the original grsecurity/PaX
code.
This adds a per-cache random value to SLUB caches that is XORed with
their freelist pointer address and value. This adds nearly zero
overhead and frustrates the very common heap overflow exploitation
method of overwriting freelist pointers.
A recent example of the attack is written up here:
http://cyseclabs.com/blog/cve-2016-6187-heap-off-by-one-exploit
and there is a section dedicated to the technique the book "A Guide to
Kernel Exploitation: Attacking the Core".
This is based on patches by Daniel Micay, and refactored to minimize the
use of #ifdef.
With 200-count cycles of "hackbench -g 20 -l 1000" I saw the following
run times:
before:
mean 10.11882499999999999995
variance .03320378329145728642
stdev .18221905304181911048
after:
mean 10.12654000000000000014
variance .04700556623115577889
stdev .21680767106160192064
The difference gets lost in the noise, but if the above is to be taken
literally, using CONFIG_FREELIST_HARDENED is 0.07% slower.
Link: http://lkml.kernel.org/r/20170802180609.GA66807@beast
Suggested-by: Daniel Micay <danielmicay@gmail.com>
Cc: Alexander Popov <alex.popov@linux.com>
- free_kmem_cache_nodes() frees the cache node before nulling out a
reference to it
- init_kmem_cache_nodes() publishes the cache node before initializing
it
Neither of these matter at runtime because the cache nodes cannot be
looked up by any other thread. But it's neater and more consistent to
reorder these.
Link: http://lkml.kernel.org/r/20170707083408.40410-1-glider@google.com
Signed-off-by: Alexander Potapenko <glider@google.com>
To avoid a possible deadlock, sysfs_slab_remove() schedules an
asynchronous work to delete sysfs entries corresponding to the kmem
cache. To ensure the cache isn't freed before the work function is
called, it takes a reference to the cache kobject. The reference is
supposed to be released by the work function.
However, the work function (sysfs_slab_remove_workfn()) does nothing in
case the cache sysfs entry has already been deleted, leaking the kobject
and the corresponding cache.
This may happen on a per memcg cache destruction, because sysfs entries
of a per memcg cache are deleted on memcg offline if the cache is empty
(see __kmemcg_cache_deactivate()).
The kmemleak report looks like this:
unreferenced object 0xffff9f798a79f540 (size 32):
comm "kworker/1:4", pid 15416, jiffies 4307432429 (age 28687.554s)
hex dump (first 32 bytes):
6b 6d 61 6c 6c 6f 63 2d 31 36 28 31 35 39 39 3a kmalloc-16(1599:
6e 65 77 72 6f 6f 74 29 00 23 6b c0 ff ff ff ff newroot).#k.....
backtrace:
kmemleak_alloc+0x4a/0xa0
__kmalloc_track_caller+0x148/0x2c0
kvasprintf+0x66/0xd0
kasprintf+0x49/0x70
memcg_create_kmem_cache+0xe6/0x160
memcg_kmem_cache_create_func+0x20/0x110
process_one_work+0x205/0x5d0
worker_thread+0x4e/0x3a0
kthread+0x109/0x140
ret_from_fork+0x2a/0x40
unreferenced object 0xffff9f79b6136840 (size 416):
comm "kworker/1:4", pid 15416, jiffies 4307432429 (age 28687.573s)
40 fb 80 c2 3e 33 00 00 00 00 00 40 00 00 00 00 @...>3.....@....
00 00 00 00 00 00 00 00 10 00 00 00 10 00 00 00 ................
backtrace:
kmem_cache_alloc+0x128/0x280
create_cache+0x3b/0x1e0
memcg_create_kmem_cache+0x118/0x160
kthread+0x109/0x140
Fix the leak by adding the missing call to kobject_put() to
sysfs_slab_remove_workfn().
Link: http://lkml.kernel.org/r/20170812181134.25027-1-vdavydov.dev@gmail.com
Fixes: 3b7b314053d02 ("slub: make sysfs file removal asynchronous")
Signed-off-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Reported-by: Andrei Vagin <avagin@gmail.com>
Tested-by: Andrei Vagin <avagin@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: <stable@vger.kernel.org> [4.12.x]
Josef's redesign of the balancing between slab caches and the page cache
requires slab cache statistics at the lruvec level.
Link: http://lkml.kernel.org/r/20170530181724.27197-7-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Josef Bacik <josef@toxicpanda.com>
Cc: Michal Hocko <mhocko@suse.com>
Patch series "mm: per-lruvec slab stats"
Josef is working on a new approach to balancing slab caches and the page
cache. For this to work, he needs slab cache statistics on the lruvec
level. These patches implement that by adding infrastructure that
allows updating and reading generic VM stat items per lruvec, then
switches some existing VM accounting sites, including the slab
accounting ones, to this new cgroup-aware API.
I'll follow up with more patches on this, because there is actually
substantial simplification that can be done to the memory controller
when we replace private memcg accounting with making the existing VM
accounting sites cgroup-aware. But this is enough for Josef to base his
slab reclaim work on, so here goes.
This patch (of 5):
To re-implement slab cache vs. page cache balancing, we'll need the
slab counters at the lruvec level, which, ever since lru reclaim was
moved from the zone to the node, is the intersection of the node, not
the zone, and the memcg.
We could retain the per-zone counters for when the page allocator dumps
its memory information on failures, and have counters on both levels -
which on all but NUMA node 0 is usually redundant. But let's keep it
simple for now and just move them. If anybody complains we can restore
the per-zone counters.
[hannes@cmpxchg.org: fix oops]
Link: http://lkml.kernel.org/r/20170605183511.GA8915@cmpxchg.org
Link: http://lkml.kernel.org/r/20170530181724.27197-3-hannes@cmpxchg.org
kmem_cache->cpu_partial is just used when CONFIG_SLUB_CPU_PARTIAL is
set, so wrap it with config CONFIG_SLUB_CPU_PARTIAL will save some space
on 32bit arch.
This patch wraps kmem_cache->cpu_partial in config CONFIG_SLUB_CPU_PARTIAL
and wraps its sysfs too.
Link: http://lkml.kernel.org/r/20170502144533.10729-4-richard.weiyang@gmail.com
Signed-off-by: Wei Yang <richard.weiyang@gmail.com>
cpu_slab's field partial is used when CONFIG_SLUB_CPU_PARTIAL is set,
which means we can save a pointer's space on each cpu for every slub
item.
This patch wraps cpu_slab->partial in CONFIG_SLUB_CPU_PARTIAL and wraps
its sysfs use too.
[akpm@linux-foundation.org: avoid strange 80-col tricks]
Link: http://lkml.kernel.org/r/20170502144533.10729-3-richard.weiyang@gmail.com
Each time a slab is deactivated, the page and freelist pointer should be
reset.
This patch just merges these two options into deactivate_slab().
Link: http://lkml.kernel.org/r/20170507031215.3130-2-richard.weiyang@gmail.com
When the code comes to this point, there are two cases:
1. cpu_slab is deactivated
2. cpu_slab is empty
In both cased, cpu_slab->freelist is NULL at this moment.
This patch removes the redundant assignment of cpu_slab->freelist.
Link: http://lkml.kernel.org/r/20170507031215.3130-1-richard.weiyang@gmail.com
Commit bf5eb3de3847 ("slub: separate out sysfs_slab_release() from
sysfs_slab_remove()") made slub sysfs file removals synchronous to
kmem_cache shutdown.
Unfortunately, this created a possible ABBA deadlock between slab_mutex
and sysfs draining mechanism triggering the following lockdep warning.
[ INFO: possible circular locking dependency detected ]
4.10.0-test+ #48 Not tainted
rmmod/1211 is trying to acquire lock:
(s_active#120){++++.+}, at: [<ffffffff81308073>] kernfs_remove+0x23/0x40
(slab_mutex){+.+.+.}, at: [<ffffffff8120f691>] kmem_cache_destroy+0x41/0x2d0
-> #1 (slab_mutex){+.+.+.}:
lock_acquire+0xf6/0x1f0
__mutex_lock+0x75/0x950
mutex_lock_nested+0x1b/0x20
slab_attr_store+0x75/0xd0
sysfs_kf_write+0x45/0x60
kernfs_fop_write+0x13c/0x1c0
__vfs_write+0x28/0x120
vfs_write+0xc8/0x1e0
SyS_write+0x49/0xa0
entry_SYSCALL_64_fastpath+0x1f/0xc2
-> #0 (s_active#120){++++.+}:
__lock_acquire+0x10ed/0x1260
__kernfs_remove+0x254/0x320
sysfs_remove_dir+0x51/0x80
kobject_del+0x18/0x50
__kmem_cache_shutdown+0x3e6/0x460
kmem_cache_destroy+0x1fb/0x2d0
kvm_exit+0x2d/0x80 [kvm]
vmx_exit+0x19/0xa1b [kvm_intel]
SyS_delete_module+0x198/0x1f0
CPU0 CPU1
lock(slab_mutex);
lock(s_active#120);
lock(slab_mutex);
lock(s_active#120);
*** DEADLOCK ***
2 locks held by rmmod/1211:
#0: (cpu_hotplug.dep_map){++++++}, at: [<ffffffff810a7877>] get_online_cpus+0x37/0x80
#1: (slab_mutex){+.+.+.}, at: [<ffffffff8120f691>] kmem_cache_destroy+0x41/0x2d0
stack backtrace:
CPU: 3 PID: 1211 Comm: rmmod Not tainted 4.10.0-test+ #48
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
Call Trace:
print_circular_bug+0x1be/0x210
? SyS_delete_module+0x5/0x1f0
It'd be the cleanest to deal with the issue by removing sysfs files
without holding slab_mutex before the rest of shutdown; however, given
the current code structure, it is pretty difficult to do so.
This patch punts sysfs file removal to a work item. Before commit
bf5eb3de3847, the removal was punted to a RCU delayed work item which is
executed after release. Now, we're punting to a different work item on
shutdown which still maintains the goal removing the sysfs files earlier
when destroying kmem_caches.
Link: http://lkml.kernel.org/r/20170620204512.GI21326@htj.duckdns.org
Fixes: bf5eb3de3847 ("slub: separate out sysfs_slab_release() from sysfs_slab_remove()")
Reported-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Tested-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
memcg_propagate_slab_attrs() abuses the sysfs attribute file functions
to propagate settings from the root kmem_cache to a newly created
kmem_cache. It does that with:
attr->show(root, buf);
attr->store(new, buf, strlen(bug);
Aside of being a lazy and absurd hackery this is broken because it does
not check the return value of the show() function.
Some of the show() functions return 0 w/o touching the buffer. That
means in such a case the store function is called with the stale content
of the previous show(). That causes nonsense like invoking
kmem_cache_shrink() on a newly created kmem_cache. In the worst case it
would cause handing in an uninitialized buffer.
This should be rewritten proper by adding a propagate() callback to
those slub_attributes which must be propagated and avoid that insane
conversion to and from ASCII, but that's too large for a hot fix.
Check at least the return value of the show() function, so calling
store() with stale content is prevented.
Steven said:
"It can cause a deadlock with get_online_cpus() that has been uncovered
by recent cpu hotplug and lockdep changes that Thomas and Peter have
been doing.
CPU0 CPU1
lock(cpu_hotplug.lock);
lock(slab_mutex);
lock(slab_mutex);
*** DEADLOCK ***"
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705201244540.2255@nanos
Reported-by: Steven Rostedt <rostedt@goodmis.org>
A group of Linux kernel hackers reported chasing a bug that resulted
from their assumption that SLAB_DESTROY_BY_RCU provided an existence
guarantee, that is, that no block from such a slab would be reallocated
during an RCU read-side critical section. Of course, that is not the
case. Instead, SLAB_DESTROY_BY_RCU only prevents freeing of an entire
slab of blocks.
However, there is a phrase for this, namely "type safety". This commit
therefore renames SLAB_DESTROY_BY_RCU to SLAB_TYPESAFE_BY_RCU in order
to avoid future instances of this sort of confusion.
Cc: <linux-mm@kvack.org>
[ paulmck: Add comments mentioning the old name, as requested by Eric
Dumazet, in order to help people familiar with the old name find
the new one. ]
SLUB creates a per-cache directory under /sys/kernel/slab which hosts a
bunch of debug files. Usually, there aren't that many caches on a
system and this doesn't really matter; however, if memcg is in use, each
cache can have per-cgroup sub-caches. SLUB creates the same directories
for these sub-caches under /sys/kernel/slab/$CACHE/cgroup.
Unfortunately, because there can be a lot of cgroups, active or
draining, the product of the numbers of caches, cgroups and files in
each directory can reach a very high number - hundreds of thousands is
commonplace. Millions and beyond aren't difficult to reach either.
What's under /sys/kernel/slab is primarily for debugging and the
information and control on the a root cache already cover its
sub-caches. While having a separate directory for each sub-cache can be
helpful for development, it doesn't make much sense to pay this amount
of overhead by default.
This patch introduces a boot parameter slub_memcg_sysfs which determines
whether to create sysfs directories for per-memcg sub-caches. It also
adds CONFIG_SLUB_MEMCG_SYSFS_ON which determines the boot parameter's
default value and defaults to 0.
[akpm@linux-foundation.org: kset_unregister(NULL) is legal]
Link: http://lkml.kernel.org/r/20170204145203.GB26958@mtj.duckdns.org
With kmem cgroup support enabled, kmem_caches can be created and
destroyed frequently and a great number of near empty kmem_caches can
accumulate if there are a lot of transient cgroups and the system is not
under memory pressure. When memory reclaim starts under such
conditions, it can lead to consecutive deactivation and destruction of
many kmem_caches, easily hundreds of thousands on moderately large
systems, exposing scalability issues in the current slab management
code. This is one of the patches to address the issue.
Each cache has a number of sysfs interface files under /sys/kernel/slab.
On a system with a lot of memory and transient memcgs, the number of
interface files which have to be removed once memory reclaim kicks in
can reach millions.
Link: http://lkml.kernel.org/r/20170117235411.9408-10-tj@kernel.org
Reported-by: Jay Vana <jsvana@fb.com>
slub uses synchronize_sched() to deactivate a memcg cache.
synchronize_sched() is an expensive and slow operation and doesn't scale
when a huge number of caches are destroyed back-to-back. While there
used to be a simple batching mechanism, the batching was too restricted
to be helpful.
This patch implements slab_deactivate_memcg_cache_rcu_sched() which slub
can use to schedule sched RCU callback instead of performing
synchronize_sched() synchronously while holding cgroup_mutex. While
this adds online cpus, mems and slab_mutex operations, operating on
these locks back-to-back from the same kworker, which is what's gonna
happen when there are many to deactivate, isn't expensive at all and
this gets rid of the scalability problem completely.
Link: http://lkml.kernel.org/r/20170117235411.9408-9-tj@kernel.org
__kmem_cache_shrink() is called with %true @deactivate only for memcg
caches. Remove @deactivate from __kmem_cache_shrink() and introduce
__kmemcg_cache_deactivate() instead. Each memcg-supporting allocator
should implement it and it should deactivate and drain the cache.
This is to allow memcg cache deactivation behavior to further deviate
from simple shrinking without messing up __kmem_cache_shrink().
This is pure reorganization and doesn't introduce any observable
behavior changes.
v2: Dropped unnecessary ifdef in mm/slab.h as suggested by Vladimir.
Link: http://lkml.kernel.org/r/20170117235411.9408-8-tj@kernel.org
slab_caches currently lists all caches including root and memcg ones.
This is the only data structure which lists the root caches and
iterating root caches can only be done by walking the list while
skipping over memcg caches. As there can be a huge number of memcg
caches, this can become very expensive.
This also can make /proc/slabinfo behave very badly. seq_file processes
reads in 4k chunks and seeks to the previous Nth position on slab_caches
list to resume after each chunk. With a lot of memcg cache churns on
the list, reading /proc/slabinfo can become very slow and its content
often ends up with duplicate and/or missing entries.
This patch adds a new list slab_root_caches which lists only the root
caches. When memcg is not enabled, it becomes just an alias of
slab_caches. memcg specific list operations are collected into
memcg_[un]link_cache().
Link: http://lkml.kernel.org/r/20170117235411.9408-7-tj@kernel.org
Acked-by: Vladimir Davydov <vdavydov@tarantool.org>
Separate out slub sysfs removal and release, and call the former earlier
from __kmem_cache_shutdown(). There's no reason to defer sysfs removal
through RCU and this will later allow us to remove sysfs files way
earlier during memory cgroup offline instead of release.
Link: http://lkml.kernel.org/r/20170117235411.9408-3-tj@kernel.org
Patch series "slab: make memcg slab destruction scalable", v3.
code.
I've seen machines which end up with hundred thousands of caches and
many millions of kernfs_nodes. The current code is O(N^2) on the total
number of caches and has synchronous rcu_barrier() and
synchronize_sched() in cgroup offline / release path which is executed
while holding cgroup_mutex. Combined, this leads to very expensive and
slow cache destruction operations which can easily keep running for half
a day.
This also messes up /proc/slabinfo along with other cache iterating
operations. seq_file operates on 4k chunks and on each 4k boundary
tries to seek to the last position in the list. With a huge number of
caches on the list, this becomes very slow and very prone to the list
content changing underneath it leading to a lot of missing and/or
duplicate entries.
This patchset addresses the scalability problem.
* Add root and per-memcg lists. Update each user to use the
appropriate list.
* Make rcu_barrier() for SLAB_DESTROY_BY_RCU caches globally batched
and asynchronous.
* For dying empty slub caches, remove the sysfs files after
deactivation so that we don't end up with millions of sysfs files
without any useful information on them.
This patchset contains the following nine patches.
0001-Revert-slub-move-synchronize_sched-out-of-slab_mutex.patch
0002-slub-separate-out-sysfs_slab_release-from-sysfs_slab.patch
0003-slab-remove-synchronous-rcu_barrier-call-in-memcg-ca.patch
0004-slab-reorganize-memcg_cache_params.patch
0005-slab-link-memcg-kmem_caches-on-their-associated-memo.patch
0006-slab-implement-slab_root_caches-list.patch
0007-slab-introduce-__kmemcg_cache_deactivate.patch
0008-slab-remove-synchronous-synchronize_sched-from-memcg.patch
0009-slab-remove-slub-sysfs-interface-files-early-for-emp.patch
0010-slab-use-memcg_kmem_cache_wq-for-slab-destruction-op.patch
0001 reverts an existing optimization to prepare for the following
changes. 0002 is a prep patch. 0003 makes rcu_barrier() in release
path batched and asynchronous. 0004-0006 separate out the lists.
0007-0008 replace synchronize_sched() in slub destruction path with
call_rcu_sched(). 0009 removes sysfs files early for empty dying
caches. 0010 makes destruction work items use a workqueue with limited
concurrency.
This patch (of 10):
Revert 89e364db71fb5e ("slub: move synchronize_sched out of slab_mutex on
shrink").
With kmem cgroup support enabled, kmem_caches can be created and destroyed
frequently and a great number of near empty kmem_caches can accumulate if
there are a lot of transient cgroups and the system is not under memory
pressure. When memory reclaim starts under such conditions, it can lead
to consecutive deactivation and destruction of many kmem_caches, easily
hundreds of thousands on moderately large systems, exposing scalability
issues in the current slab management code. This is one of the patches to
address the issue.
Moving synchronize_sched() out of slab_mutex isn't enough as it's still
inside cgroup_mutex. The whole deactivation / release path will be
updated to avoid all synchronous RCU operations. Revert this insufficient
optimization in preparation to ease future changes.
Link: http://lkml.kernel.org/r/20170117235411.9408-2-tj@kernel.org
We wish to know who is doing such a thing. slab.c does this.
Link: http://lkml.kernel.org/r/20170116091643.15260-1-bp@alien8.de
Commit 210e7a43fa90 ("mm: SLUB freelist randomization") broke USB hub
initialisation as described in
https://bugzilla.kernel.org/show_bug.cgi?id=177551.
Bail out early from init_cache_random_seq if s->random_seq is already
initialised. This prevents destroying the previously computed
random_seq offsets later in the function.
If the offsets are destroyed, then shuffle_freelist will truncate
page->freelist to just the first object (orphaning the rest).
Fixes: 210e7a43fa90 ("mm: SLUB freelist randomization")
Link: http://lkml.kernel.org/r/20170207140707.20824-1-sean@erifax.org
Signed-off-by: Sean Rees <sean@erifax.org>
Reported-by: <userwithuid@gmail.com>
Cc: Thomas Garnier <thgarnie@google.com>
Currently when trace is enabled (e.g. slub_debug=T,kmalloc-128 ) the
trace messages are mostly output at KERN_INFO. However the trace code
also calls print_section() to hexdump the head of a free object. This
is hard coded to use KERN_ERR, meaning the console is deluged with trace
messages even if we've asked for quiet.
Fix this the obvious way but adding a level parameter to
print_section(), allowing calls from the trace code to use the same
trace level as other trace messages.
Link: http://lkml.kernel.org/r/20170113154850.518-1-daniel.thompson@linaro.org
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
The slub allocator gives us some incorrect warnings when
CONFIG_PROFILE_ANNOTATED_BRANCHES is set, as the unlikely() macro
prevents it from seeing that the return code matches what it was before:
mm/slub.c: In function `kmem_cache_free_bulk':
mm/slub.c:262:23: error: `df.s' may be used uninitialized in this function [-Werror=maybe-uninitialized]
mm/slub.c:2943:3: error: `df.cnt' may be used uninitialized in this function [-Werror=maybe-uninitialized]
mm/slub.c:2933:4470: error: `df.freelist' may be used uninitialized in this function [-Werror=maybe-uninitialized]
mm/slub.c:2943:3: error: `df.tail' may be used uninitialized in this function [-Werror=maybe-uninitialized]
I have not been able to come up with a perfect way for dealing with
this, the three options I see are:
- add a bogus initialization, which would increase the runtime overhead
- replace unlikely() with unlikely_notrace()
- remove the unlikely() annotation completely
I checked the object code for a typical x86 configuration and the last
two cases produce the same result, so I went for the last one, which is
the simplest.
Link: http://lkml.kernel.org/r/20161024155704.3114445-1-arnd@arndb.de
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Laura Abbott <labbott@fedoraproject.org>
synchronize_sched() is a heavy operation and calling it per each cache
owned by a memory cgroup being destroyed may take quite some time. What
is worse, it's currently called under the slab_mutex, stalling all works
doing cache creation/destruction.
Actually, there isn't much point in calling synchronize_sched() for each
cache - it's enough to call it just once - after setting cpu_partial for
all caches and before shrinking them. This way, we can also move it out
of the slab_mutex, which we have to hold for iterating over the slab
cache list.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=172991
Link: http://lkml.kernel.org/r/0a10d71ecae3db00fb4421bcd3f82bcc911f4be4.1475329751.git.vdavydov.dev@gmail.com
Reported-by: Doug Smythies <dsmythies@telus.net>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Install the callbacks via the state machine.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: linux-mm@kvack.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-5-bigeasy@linutronix.de
With debugobjects enabled and using SLAB_DESTROY_BY_RCU, when a
kmem_cache_node is destroyed the call_rcu() may trigger a slab
allocation to fill the debug object pool (__debug_object_init:fill_pool).
Everywhere but during kmem_cache_destroy(), discard_slab() is performed
outside of the kmem_cache_node->list_lock and avoids a lockdep warning
about potential recursion:
[ INFO: possible recursive locking detected ]
4.8.0-rc1-gfxbench+ #1 Tainted: G U
rmmod/8895 is trying to acquire lock:
(&(&n->list_lock)->rlock){-.-...}, at: [<ffffffff811c80d7>] get_partial_node.isra.63+0x47/0x430
(&(&n->list_lock)->rlock){-.-...}, at: [<ffffffff811cbda4>] __kmem_cache_shutdown+0x54/0x320
CPU0
lock(&(&n->list_lock)->rlock);
*** DEADLOCK ***
May be due to missing lock nesting notation
5 locks held by rmmod/8895:
#0: (&dev->mutex){......}, at: driver_detach+0x42/0xc0
#1: (&dev->mutex){......}, at: driver_detach+0x50/0xc0
#2: (cpu_hotplug.dep_map){++++++}, at: get_online_cpus+0x2d/0x80
#3: (slab_mutex){+.+.+.}, at: kmem_cache_destroy+0x3c/0x220
#4: (&(&n->list_lock)->rlock){-.-...}, at: __kmem_cache_shutdown+0x54/0x320
stack backtrace:
CPU: 6 PID: 8895 Comm: rmmod Tainted: G U 4.8.0-rc1-gfxbench+ #1
Hardware name: Gigabyte Technology Co., Ltd. H87M-D3H/H87M-D3H, BIOS F11 08/18/2015
Call Trace:
__lock_acquire+0x1646/0x1ad0
lock_acquire+0xb2/0x200
_raw_spin_lock+0x36/0x50
___slab_alloc.constprop.67+0x1a7/0x3b0
__slab_alloc.isra.64.constprop.66+0x43/0x80
kmem_cache_alloc+0x236/0x2d0
__debug_object_init+0x2de/0x400
debug_object_activate+0x109/0x1e0
__call_rcu.constprop.63+0x32/0x2f0
call_rcu+0x12/0x20
discard_slab+0x3d/0x40
__kmem_cache_shutdown+0xdb/0x320
shutdown_cache+0x19/0x60
kmem_cache_destroy+0x1ae/0x220
i915_gem_load_cleanup+0x14/0x40 [i915]
i915_driver_unload+0x151/0x180 [i915]
i915_pci_remove+0x14/0x20 [i915]
pci_device_remove+0x34/0xb0
__device_release_driver+0x95/0x140
driver_detach+0xb6/0xc0
bus_remove_driver+0x53/0xd0
driver_unregister+0x27/0x50
pci_unregister_driver+0x25/0x70
i915_exit+0x1a/0x1e2 [i915]
SyS_delete_module+0x193/0x1f0
entry_SYSCALL_64_fastpath+0x1c/0xac
Fixes: 52b4b950b507 ("mm: slab: free kmem_cache_node after destroy sysfs file")
Link: http://lkml.kernel.org/r/1470759070-18743-1-git-send-email-chris@chris-wilson.co.uk
Reported-by: Dave Gordon <david.s.gordon@intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Gordon <david.s.gordon@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull usercopy protection from Kees Cook:
"Tbhis implements HARDENED_USERCOPY verification of copy_to_user and
copy_from_user bounds checking for most architectures on SLAB and
SLUB"
* tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
mm: SLUB hardened usercopy support
mm: SLAB hardened usercopy support
s390/uaccess: Enable hardened usercopy
sparc/uaccess: Enable hardened usercopy
powerpc/uaccess: Enable hardened usercopy
ia64/uaccess: Enable hardened usercopy
arm64/uaccess: Enable hardened usercopy
ARM: uaccess: Enable hardened usercopy
x86/uaccess: Enable hardened usercopy
mm: Hardened usercopy
mm: Implement stack frame object validation
mm: Add is_migrate_cma_page
With m68k-linux-gnu-gcc-4.1:
include/linux/slub_def.h:126: warning: `fixup_red_left' declared inline after being called
include/linux/slub_def.h:126: warning: previous declaration of `fixup_red_left' was here
Commit c146a2b98eb5 ("mm, kasan: account for object redzone in SLUB's
nearest_obj()") made fixup_red_left() global, but forgot to remove the
inline keyword.
Fixes: c146a2b98eb5898e ("mm, kasan: account for object redzone in SLUB's nearest_obj()")
Link: http://lkml.kernel.org/r/1470256262-1586-1-git-send-email-geert@linux-m68k.org
The state of object currently tracked in two places - shadow memory, and
the ->state field in struct kasan_alloc_meta. We can get rid of the
latter. The will save us a little bit of memory. Also, this allow us
to move free stack into struct kasan_alloc_meta, without increasing
memory consumption. So now we should always know when the last time the
object was freed. This may be useful for long delayed use-after-free
bugs.
As a side effect this fixes following UBSAN warning:
UBSAN: Undefined behaviour in mm/kasan/quarantine.c:102:13
member access within misaligned address ffff88000d1efebc for type 'struct qlist_node'
which requires 8 byte alignment
Link: http://lkml.kernel.org/r/1470062715-14077-5-git-send-email-aryabinin@virtuozzo.com
Reported-by: kernel test robot <xiaolong.ye@intel.com>
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
For KASAN builds:
- switch SLUB allocator to using stackdepot instead of storing the
allocation/deallocation stacks in the objects;
- change the freelist hook so that parts of the freelist can be put
into the quarantine.
[aryabinin@virtuozzo.com: fixes]
Link: http://lkml.kernel.org/r/1468601423-28676-1-git-send-email-aryabinin@virtuozzo.com
Link: http://lkml.kernel.org/r/1468347165-41906-3-git-send-email-glider@google.com
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Steven Rostedt (Red Hat) <rostedt@goodmis.org>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Kuthonuzo Luruo <kuthonuzo.luruo@hpe.com>
When looking up the nearest SLUB object for a given address, correctly
calculate its offset if SLAB_RED_ZONE is enabled for that cache.
Previously, when KASAN had detected an error on an object from a cache
with SLAB_RED_ZONE set, the actual start address of the object was
miscalculated, which led to random stacks having been reported.
Fixes: 7ed2f9e663854db ("mm, kasan: SLAB support")
Link: http://lkml.kernel.org/r/1468347165-41906-2-git-send-email-glider@google.com
Currently, to charge a non-slab allocation to kmemcg one has to use
alloc_kmem_pages helper with __GFP_ACCOUNT flag. A page allocated with
this helper should finally be freed using free_kmem_pages, otherwise it
won't be uncharged.
This API suits its current users fine, but it turns out to be impossible
to use along with page reference counting, i.e. when an allocation is
supposed to be freed with put_page, as it is the case with pipe or unix
socket buffers.
To overcome this limitation, this patch moves charging/uncharging to
generic page allocator paths, i.e. to __alloc_pages_nodemask and
free_pages_prepare, and zaps alloc/free_kmem_pages helpers. This way,
one can use any of the available page allocation functions to get the
allocated page charged to kmemcg - it's enough to pass __GFP_ACCOUNT,
just like in case of kmalloc and friends. A charged page will be
automatically uncharged on free.
To make it possible, we need to mark pages charged to kmemcg somehow.
To avoid introducing a new page flag, we make use of page->_mapcount for
marking such pages. Since pages charged to kmemcg are not supposed to
be mapped to userspace, it should work just fine. There are other
(ab)users of page->_mapcount - buddy and balloon pages - but we don't
conflict with them.
In case kmemcg is compiled out or not used at runtime, this patch
introduces no overhead to generic page allocator paths. If kmemcg is
used, it will be plus one gfp flags check on alloc and plus one
page->_mapcount check on free, which shouldn't hurt performance, because
the data accessed are hot.
Link: http://lkml.kernel.org/r/a9736d856f895bcb465d9f257b54efe32eda6f99.1464079538.git.vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Minchan Kim <minchan@kernel.org>
Both SLAB and SLUB BUG() when a caller provides an invalid gfp_mask.
This is a rather harsh way to announce a non-critical issue. Allocator
is free to ignore invalid flags. Let's simply replace BUG() by
dump_stack to tell the offender and fixup the mask to move on with the
allocation request.
This is an example for kmalloc(GFP_KERNEL|__GFP_HIGHMEM) from a test
module:
Unexpected gfp: 0x2 (__GFP_HIGHMEM). Fixing up to gfp: 0x24000c0 (GFP_KERNEL). Fix your code!
CPU: 0 PID: 2916 Comm: insmod Tainted: G O 4.6.0-slabgfp2-00002-g4cdfc2ef4892-dirty #936
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
Call Trace:
dump_stack+0x67/0x90
cache_alloc_refill+0x201/0x617
kmem_cache_alloc_trace+0xa7/0x24a
? 0xffffffffa0005000
mymodule_init+0x20/0x1000 [test_slab]
do_one_initcall+0xe7/0x16c
? rcu_read_lock_sched_held+0x61/0x69
? kmem_cache_alloc_trace+0x197/0x24a
do_init_module+0x5f/0x1d9
load_module+0x1a3d/0x1f21
? retint_kernel+0x2d/0x2d
SyS_init_module+0xe8/0x10e
? SyS_init_module+0xe8/0x10e
do_syscall_64+0x68/0x13f
entry_SYSCALL64_slow_path+0x25/0x25
Link: http://lkml.kernel.org/r/1465548200-11384-2-git-send-email-mhocko@kernel.org
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
printk offers %pGg for quite some time so let's use it to get a human
readable list of invalid flags.
The original output would be
[ 429.191962] gfp: 2
after the change
[ 429.191962] Unexpected gfp: 0x2 (__GFP_HIGHMEM)
Link: http://lkml.kernel.org/r/1465548200-11384-1-git-send-email-mhocko@kernel.org
Implements freelist randomization for the SLUB allocator. It was
previous implemented for the SLAB allocator. Both use the same
configuration option (CONFIG_SLAB_FREELIST_RANDOM).
The list is randomized during initialization of a new set of pages. The
order on different freelist sizes is pre-computed at boot for
performance. Each kmem_cache has its own randomized freelist.
This security feature reduces the predictability of the kernel SLUB
allocator against heap overflows rendering attacks much less stable.
For example these attacks exploit the predictability of the heap:
- Linux Kernel CAN SLUB overflow (https://goo.gl/oMNWkU)
- Exploiting Linux Kernel Heap corruptions (http://goo.gl/EXLn95)
Performance results:
slab_test impact is between 3% to 4% on average for 100000 attempts
without smp. It is a very focused testing, kernbench show the overall
impact on the system is way lower.
Before:
Single thread testing
1. Kmalloc: Repeatedly allocate then free test
100000 times kmalloc(8) -> 49 cycles kfree -> 77 cycles
100000 times kmalloc(16) -> 51 cycles kfree -> 79 cycles
100000 times kmalloc(32) -> 53 cycles kfree -> 83 cycles
100000 times kmalloc(64) -> 62 cycles kfree -> 90 cycles
100000 times kmalloc(128) -> 81 cycles kfree -> 97 cycles
100000 times kmalloc(256) -> 98 cycles kfree -> 121 cycles
100000 times kmalloc(512) -> 95 cycles kfree -> 122 cycles
100000 times kmalloc(1024) -> 96 cycles kfree -> 126 cycles
100000 times kmalloc(2048) -> 115 cycles kfree -> 140 cycles
100000 times kmalloc(4096) -> 149 cycles kfree -> 171 cycles
2. Kmalloc: alloc/free test
100000 times kmalloc(8)/kfree -> 70 cycles
100000 times kmalloc(16)/kfree -> 70 cycles
100000 times kmalloc(32)/kfree -> 70 cycles
100000 times kmalloc(64)/kfree -> 70 cycles
100000 times kmalloc(128)/kfree -> 70 cycles
100000 times kmalloc(256)/kfree -> 69 cycles
100000 times kmalloc(512)/kfree -> 70 cycles
100000 times kmalloc(1024)/kfree -> 73 cycles
100000 times kmalloc(2048)/kfree -> 72 cycles
100000 times kmalloc(4096)/kfree -> 71 cycles
After:
100000 times kmalloc(8) -> 57 cycles kfree -> 78 cycles
100000 times kmalloc(16) -> 61 cycles kfree -> 81 cycles
100000 times kmalloc(32) -> 76 cycles kfree -> 93 cycles
100000 times kmalloc(64) -> 83 cycles kfree -> 94 cycles
100000 times kmalloc(128) -> 106 cycles kfree -> 107 cycles
100000 times kmalloc(256) -> 118 cycles kfree -> 117 cycles
100000 times kmalloc(512) -> 114 cycles kfree -> 116 cycles
100000 times kmalloc(1024) -> 115 cycles kfree -> 118 cycles
100000 times kmalloc(2048) -> 147 cycles kfree -> 131 cycles
100000 times kmalloc(4096) -> 214 cycles kfree -> 161 cycles
100000 times kmalloc(8)/kfree -> 66 cycles
100000 times kmalloc(16)/kfree -> 66 cycles
100000 times kmalloc(32)/kfree -> 66 cycles
100000 times kmalloc(64)/kfree -> 66 cycles
100000 times kmalloc(128)/kfree -> 65 cycles
100000 times kmalloc(256)/kfree -> 67 cycles
100000 times kmalloc(512)/kfree -> 67 cycles
100000 times kmalloc(1024)/kfree -> 64 cycles
100000 times kmalloc(2048)/kfree -> 67 cycles
100000 times kmalloc(4096)/kfree -> 67 cycles
Kernbench, before:
Average Optimal load -j 12 Run (std deviation):
Elapsed Time 101.873 (1.16069)
User Time 1045.22 (1.60447)
System Time 88.969 (0.559195)
Percent CPU 1112.9 (13.8279)
Context Switches 189140 (2282.15)
Sleeps 99008.6 (768.091)
After:
Elapsed Time 102.47 (0.562732)
User Time 1045.3 (1.34263)
System Time 88.311 (0.342554)
Percent CPU 1105.8 (6.49444)
Context Switches 189081 (2355.78)
Sleeps 99231.5 (800.358)
Link: http://lkml.kernel.org/r/1464295031-26375-3-git-send-email-thgarnie@google.com
Signed-off-by: Thomas Garnier <thgarnie@google.com>
Under CONFIG_HARDENED_USERCOPY, this adds object size checking to the
SLUB allocator to catch any copies that may span objects. Includes a
redzone handling fix discovered by Michael Ellerman.
Based on code from PaX and grsecurity.
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
Reviwed-by: Laura Abbott <labbott@redhat.com>
