[ Upstream commit a38965bf941b7c2af50de09c96bc5f03e136caef ]
__printf is useful to verify format and arguments. Remove the following
warning (with W=1):
mm/slub.c:721:2: warning: function might be possible candidate for `gnu_printf' format attribute [-Wsuggest-attribute=format]
Link: http://lkml.kernel.org/r/20180505200706.19986-1-malat@debian.org
Signed-off-by: Mathieu Malaterre <malat@debian.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 478fe3037b2278d276d4cd9cd0ab06c4cb2e9b32 upstream.
memcg_propagate_slab_attrs() abuses the sysfs attribute file functions
to propagate settings from the root kmem_cache to a newly created
kmem_cache. It does that with:
attr->show(root, buf);
attr->store(new, buf, strlen(bug);
Aside of being a lazy and absurd hackery this is broken because it does
not check the return value of the show() function.
Some of the show() functions return 0 w/o touching the buffer. That
means in such a case the store function is called with the stale content
of the previous show(). That causes nonsense like invoking
kmem_cache_shrink() on a newly created kmem_cache. In the worst case it
would cause handing in an uninitialized buffer.
This should be rewritten proper by adding a propagate() callback to
those slub_attributes which must be propagated and avoid that insane
conversion to and from ASCII, but that's too large for a hot fix.
Check at least the return value of the show() function, so calling
store() with stale content is prevented.
Steven said:
"It can cause a deadlock with get_online_cpus() that has been uncovered
by recent cpu hotplug and lockdep changes that Thomas and Peter have
been doing.
Possible unsafe locking scenario:
CPU0 CPU1
lock(cpu_hotplug.lock);
lock(slab_mutex);
lock(slab_mutex);
*** DEADLOCK ***"
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705201244540.2255@nanos
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit 376bf125ac781d32e202760ed7deb1ae4ed35d31 upstream.
This change is primarily an attempt to make it easier to realize the
optimizations the compiler performs in-case CONFIG_MEMCG_KMEM is not
enabled.
Performance wise, even when CONFIG_MEMCG_KMEM is compiled in, the
overhead is zero. This is because, as long as no process have enabled
kmem cgroups accounting, the assignment is replaced by asm-NOP
operations. This is possible because memcg_kmem_enabled() uses a
static_key_false() construct.
It also helps readability as it avoid accessing the p[] array like:
p[size - 1] which "expose" that the array is processed backwards inside
helper function build_detached_freelist().
Lastly this also makes the code more robust, in error case like passing
NULL pointers in the array. Which were previously handled before commit
033745189b1b ("slub: add missing kmem cgroup support to
kmem_cache_free_bulk").
Fixes: 033745189b1b ("slub: add missing kmem cgroup support to kmem_cache_free_bulk")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Adjust kmem_cache_alloc_bulk API before we have any real users.
Adjust API to return type 'int' instead of previously type 'bool'. This
is done to allow future extension of the bulk alloc API.
A future extension could be to allow SLUB to stop at a page boundary, when
specified by a flag, and then return the number of objects.
The advantage of this approach, would make it easier to make bulk alloc
run without local IRQs disabled. With an approach of cmpxchg "stealing"
the entire c->freelist or page->freelist. To avoid overshooting we would
stop processing at a slab-page boundary. Else we always end up returning
some objects at the cost of another cmpxchg.
To keep compatible with future users of this API linking against an older
kernel when using the new flag, we need to return the number of allocated
objects with this API change.
Acked-by: Christoph Lameter <cl@linux.com>
Initial implementation missed support for kmem cgroup support in
kmem_cache_free_bulk() call, add this.
If CONFIG_MEMCG_KMEM is not enabled, the compiler should be smart enough
to not add any asm code.
Incoming bulk free objects can belong to different kmem cgroups, and
object free call can happen at a later point outside memcg context. Thus,
we need to keep the orig kmem_cache, to correctly verify if a memcg object
match against its "root_cache" (s->memcg_params.root_cache).
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
The call slab_pre_alloc_hook() interacts with kmemgc and is not allowed to
be called several times inside the bulk alloc for loop, due to the call to
memcg_kmem_get_cache().
This would result in hitting the VM_BUG_ON in __memcg_kmem_get_cache.
As suggested by Vladimir Davydov, change slab_post_alloc_hook() to be able
to handle an array of objects.
A subtle detail is, loop iterator "i" in slab_post_alloc_hook() must have
same type (size_t) as size argument. This helps the compiler to easier
realize that it can remove the loop, when all debug statements inside loop
evaluates to nothing. Note, this is only an issue because the kernel is
compiled with GCC option: -fno-strict-overflow
In slab_alloc_node() the compiler inlines and optimizes the invocation of
slab_post_alloc_hook(s, flags, 1, &object) by removing the loop and access
object directly.
Reported-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com>
This change focus on improving the speed of object freeing in the
"slowpath" of kmem_cache_free_bulk.
The calls slab_free (fastpath) and __slab_free (slowpath) have been
extended with support for bulk free, which amortize the overhead of
the (locked) cmpxchg_double.
To use the new bulking feature, we build what I call a detached
freelist. The detached freelist takes advantage of three properties:
1) the free function call owns the object that is about to be freed,
thus writing into this memory is synchronization-free.
2) many freelist's can co-exist side-by-side in the same slab-page
each with a separate head pointer.
3) it is the visibility of the head pointer that needs synchronization.
Given these properties, the brilliant part is that the detached
freelist can be constructed without any need for synchronization. The
freelist is constructed directly in the page objects, without any
synchronization needed. The detached freelist is allocated on the
stack of the function call kmem_cache_free_bulk. Thus, the freelist
head pointer is not visible to other CPUs.
All objects in a SLUB freelist must belong to the same slab-page.
Thus, constructing the detached freelist is about matching objects
that belong to the same slab-page. The bulk free array is scanned is
a progressive manor with a limited look-ahead facility.
Kmem debug support is handled in call of slab_free().
Notice kmem_cache_free_bulk no longer need to disable IRQs. This
only slowed down single free bulk with approx 3 cycles.
Performance data:
Benchmarked[1] obj size 256 bytes on CPU i7-4790K @ 4.00GHz
SLUB fastpath single object quick reuse: 47 cycles(tsc) 11.931 ns
To get stable and comparable numbers, the kernel have been booted with
"slab_merge" (this also improve performance for larger bulk sizes).
Performance data, compared against fallback bulking:
bulk - fallback bulk - improvement with this patch
1 - 62 cycles(tsc) 15.662 ns - 49 cycles(tsc) 12.407 ns- improved 21.0%
2 - 55 cycles(tsc) 13.935 ns - 30 cycles(tsc) 7.506 ns - improved 45.5%
3 - 53 cycles(tsc) 13.341 ns - 23 cycles(tsc) 5.865 ns - improved 56.6%
4 - 52 cycles(tsc) 13.081 ns - 20 cycles(tsc) 5.048 ns - improved 61.5%
8 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.659 ns - improved 64.0%
16 - 49 cycles(tsc) 12.412 ns - 17 cycles(tsc) 4.495 ns - improved 65.3%
30 - 49 cycles(tsc) 12.484 ns - 18 cycles(tsc) 4.533 ns - improved 63.3%
32 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.707 ns - improved 64.0%
34 - 96 cycles(tsc) 24.243 ns - 23 cycles(tsc) 5.976 ns - improved 76.0%
48 - 83 cycles(tsc) 20.818 ns - 21 cycles(tsc) 5.329 ns - improved 74.7%
64 - 74 cycles(tsc) 18.700 ns - 20 cycles(tsc) 5.127 ns - improved 73.0%
128 - 90 cycles(tsc) 22.734 ns - 27 cycles(tsc) 6.833 ns - improved 70.0%
158 - 99 cycles(tsc) 24.776 ns - 30 cycles(tsc) 7.583 ns - improved 69.7%
250 - 104 cycles(tsc) 26.089 ns - 37 cycles(tsc) 9.280 ns - improved 64.4%
Performance data, compared current in-kernel bulking:
bulk - curr in-kernel - improvement with this patch
1 - 46 cycles(tsc) - 49 cycles(tsc) - improved (cycles:-3) -6.5%
2 - 27 cycles(tsc) - 30 cycles(tsc) - improved (cycles:-3) -11.1%
3 - 21 cycles(tsc) - 23 cycles(tsc) - improved (cycles:-2) -9.5%
4 - 18 cycles(tsc) - 20 cycles(tsc) - improved (cycles:-2) -11.1%
8 - 17 cycles(tsc) - 18 cycles(tsc) - improved (cycles:-1) -5.9%
16 - 18 cycles(tsc) - 17 cycles(tsc) - improved (cycles: 1) 5.6%
30 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
32 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
34 - 78 cycles(tsc) - 23 cycles(tsc) - improved (cycles:55) 70.5%
48 - 60 cycles(tsc) - 21 cycles(tsc) - improved (cycles:39) 65.0%
64 - 49 cycles(tsc) - 20 cycles(tsc) - improved (cycles:29) 59.2%
128 - 69 cycles(tsc) - 27 cycles(tsc) - improved (cycles:42) 60.9%
158 - 79 cycles(tsc) - 30 cycles(tsc) - improved (cycles:49) 62.0%
250 - 86 cycles(tsc) - 37 cycles(tsc) - improved (cycles:49) 57.0%
Performance with normal SLUB merging is significantly slower for
larger bulking. This is believed to (primarily) be an effect of not
having to share the per-CPU data-structures, as tuning per-CPU size
can achieve similar performance.
bulk - slab_nomerge - normal SLUB merge
1 - 49 cycles(tsc) - 49 cycles(tsc) - merge slower with cycles:0
2 - 30 cycles(tsc) - 30 cycles(tsc) - merge slower with cycles:0
3 - 23 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:0
4 - 20 cycles(tsc) - 20 cycles(tsc) - merge slower with cycles:0
8 - 18 cycles(tsc) - 18 cycles(tsc) - merge slower with cycles:0
16 - 17 cycles(tsc) - 17 cycles(tsc) - merge slower with cycles:0
30 - 18 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:5
32 - 18 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:4
34 - 23 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:-1
48 - 21 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:1
64 - 20 cycles(tsc) - 48 cycles(tsc) - merge slower with cycles:28
128 - 27 cycles(tsc) - 57 cycles(tsc) - merge slower with cycles:30
158 - 30 cycles(tsc) - 59 cycles(tsc) - merge slower with cycles:29
250 - 37 cycles(tsc) - 56 cycles(tsc) - merge slower with cycles:19
Joint work with Alexander Duyck.
[1] https://github.com/netoptimizer/prototype-kernel/blob/master/kernel/mm/slab_bulk_test01.c
[akpm@linux-foundation.org: BUG_ON -> WARN_ON;return]
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Make it possible to free a freelist with several objects by adjusting API
of slab_free() and __slab_free() to have head, tail and an objects counter
(cnt).
Tail being NULL indicate single object free of head object. This allow
compiler inline constant propagation in slab_free() and
slab_free_freelist_hook() to avoid adding any overhead in case of single
object free.
This allows a freelist with several objects (all within the same
slab-page) to be free'ed using a single locked cmpxchg_double in
__slab_free() and with an unlocked cmpxchg_double in slab_free().
Object debugging on the free path is also extended to handle these
freelists. When CONFIG_SLUB_DEBUG is enabled it will also detect if
objects don't belong to the same slab-page.
These changes are needed for the next patch to bulk free the detached
freelists it introduces and constructs.
Micro benchmarking showed no performance reduction due to this change,
when debugging is turned off (compiled with CONFIG_SLUB_DEBUG).
The #ifdef of CONFIG_SLUB_DEBUG is located very far from the associated
#else. For readability mark it with a comment.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Use the new function that can do allocation while interrupts are disabled.
Avoids irq on/off sequences.
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Bulk alloc needs a function like that because it enables interrupts before
calling __slab_alloc which promptly disables them again using the expensive
local_irq_save().
We have properly typed page->rcu_head, no need to cast page->lru.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Vitaly Wool <vitalywool@gmail.com>
It's recommended to have slub's user tracking enabled with CONFIG_KASAN,
because:
a) User tracking disables slab merging which improves
detecting out-of-bounds accesses.
b) User tracking metadata acts as redzone which also improves
c) User tracking provides additional information about object.
This information helps to understand bugs.
Currently it is not enabled by default. Besides recompiling the kernel
with KASAN and reinstalling it, user also have to change the boot cmdline,
which is not very handy.
Enable slub user tracking by default with KASAN=y, since there is no good
reason to not do this.
[akpm@linux-foundation.org: little fixes, per David]
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
We have memcg_kmem_charge and memcg_kmem_uncharge methods for charging and
uncharging kmem pages to memcg, but currently they are not used for
charging slab pages (i.e. they are only used for charging pages allocated
with alloc_kmem_pages). The only reason why the slab subsystem uses
special helpers, memcg_charge_slab and memcg_uncharge_slab, is that it
needs to charge to the memcg of kmem cache while memcg_charge_kmem charges
to the memcg that the current task belongs to.
To remove this diversity, this patch adds an extra argument to
__memcg_kmem_charge that can be a pointer to a memcg or NULL. If it is
not NULL, the function tries to charge to the memcg it points to,
otherwise it charge to the current context. Next, it makes the slab
subsystem use this function to charge slab pages.
Since memcg_charge_kmem and memcg_uncharge_kmem helpers are now used only
in __memcg_kmem_charge and __memcg_kmem_uncharge, they are inlined. Since
__memcg_kmem_charge stores a pointer to the memcg in the page struct, we
don't need memcg_uncharge_slab anymore and can use free_kmem_pages.
Besides, one can now detect which memcg a slab page belongs to by reading
/proc/kpagecgroup.
Note, this patch switches slab to charge-after-alloc design. Since this
design is already used for all other memcg charges, it should not make any
difference.
[hannes@cmpxchg.org: better to have an outer function than a magic parameter for the memcg lookup]
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
In slub_order(), the order starts from max(min_order,
get_order(min_objects * size)). When (min_objects * size) has different
order from (min_objects * size + reserved), it will skip this order via a
check in the loop.
This patch optimizes this a little by calculating the start order with
`reserved' in consideration and removing the check in loop.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
get_order() is more easy to understand.
This patch just replaces it.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
In calculate_order(), it tries to calculate the best order by adjusting
the fraction and min_objects. On each iteration on min_objects, fraction
iterates on 16, 8, 4. Which means the acceptable waste increases with
1/16, 1/8, 1/4.
This patch corrects the comment according to the code.
alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page
allocator: do not check NUMA node ID when the caller knows the node is
valid") as an optimized variant of alloc_pages_node(), that doesn't
fallback to current node for nid == NUMA_NO_NODE. Unfortunately the
name of the function can easily suggest that the allocation is
restricted to the given node and fails otherwise. In truth, the node is
only preferred, unless __GFP_THISNODE is passed among the gfp flags.
The misleading name has lead to mistakes in the past, see for example
commits 5265047ac301 ("mm, thp: really limit transparent hugepage
allocation to local node") and b360edb43f8e ("mm, mempolicy:
migrate_to_node should only migrate to node").
Another issue with the name is that there's a family of
alloc_pages_exact*() functions where 'exact' means exact size (instead
of page order), which leads to more confusion.
To prevent further mistakes, this patch effectively renames
alloc_pages_exact_node() to __alloc_pages_node() to better convey that
it's an optimized variant of alloc_pages_node() not intended for general
usage. Both functions get described in comments.
It has been also considered to really provide a convenience function for
allocations restricted to a node, but the major opinion seems to be that
__GFP_THISNODE already provides that functionality and we shouldn't
duplicate the API needlessly. The number of users would be small
anyway.
Existing callers of alloc_pages_exact_node() are simply converted to
call __alloc_pages_node(), with the exception of sba_alloc_coherent()
which open-codes the check for NUMA_NO_NODE, so it is converted to use
alloc_pages_node() instead. This means it no longer performs some
VM_BUG_ON checks, and since the current check for nid in
alloc_pages_node() uses a 'nid < 0' comparison (which includes
NUMA_NO_NODE), it may hide wrong values which would be previously
exposed.
Both differences will be rectified by the next patch.
To sum up, this patch makes no functional changes, except temporarily
hiding potentially buggy callers. Restricting the checks in
alloc_pages_node() is left for the next patch which can in turn expose
more existing buggy callers.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Robin Holt <robinmholt@gmail.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Cliff Whickman <cpw@sgi.com>
Description is almost copied from commit fb05e7a89f50 ("net: don't wait
for order-3 page allocation").
I saw excessive direct memory reclaim/compaction triggered by slub. This
causes performance issues and add latency. Slub uses high-order
allocation to reduce internal fragmentation and management overhead. But,
direct memory reclaim/compaction has high overhead and the benefit of
high-order allocation can't compensate the overhead of both work.
This patch makes auxiliary high-order allocation atomic. If there is no
memory pressure and memory isn't fragmented, the alloction will still
success, so we don't sacrifice high-order allocation's benefit here. If
the atomic allocation fails, direct memory reclaim/compaction will not be
triggered, allocation fallback to low-order immediately, hence the direct
memory reclaim/compaction overhead is avoided. In the allocation failure
case, kswapd is waken up and trying to make high-order freepages, so
allocation could success next time.
Following is the test to measure effect of this patch.
System: QEMU, CPU 8, 512 MB
Mem: 25% memory is allocated at random position to make fragmentation.
Memory-hogger occupies 150 MB memory.
Workload: hackbench -g 20 -l 1000
Average result by 10 runs (Base va Patched)
elapsed_time(s): 4.3468 vs 2.9838
compact_stall: 461.7 vs 73.6
pgmigrate_success: 28315.9 vs 7256.1
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Eric Dumazet <edumazet@google.com>
sysfs_slab_add() shouldn't call kobject_put at error path: this puts last
reference of kmem-cache kobject and frees it. Kmem cache will be freed
second time at error path in kmem_cache_create().
For example this happens when slub debug was enabled in runtime and
somebody creates new kmem cache:
# echo 1 | tee /sys/kernel/slab/*/sanity_checks
# modprobe configfs
"configfs_dir_cache" cannot be merged because existing slab have debug and
cannot create new slab because unique name ":t-0000096" already taken.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Initializing a new slab can introduce rather large latencies because most
of the initialization runs always with interrupts disabled.
There is no point in doing so. The newly allocated slab is not visible
yet, so there is no reason to protect it against concurrent alloc/free.
Move the expensive parts of the initialization into allocate_slab(), so
for all allocations with GFP_WAIT set, interrupts are enabled.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Per request of Joonsoo Kim adding kmem debug support.
I've tested that when debugging is disabled, then there is almost no
performance impact as this code basically gets removed by the compiler.
Need some guidance in enabling and testing this.
bulk- PREVIOUS - THIS-PATCH
1 - 43 cycles(tsc) 10.811 ns - 44 cycles(tsc) 11.236 ns improved -2.3%
2 - 27 cycles(tsc) 6.867 ns - 28 cycles(tsc) 7.019 ns improved -3.7%
3 - 21 cycles(tsc) 5.496 ns - 22 cycles(tsc) 5.526 ns improved -4.8%
4 - 24 cycles(tsc) 6.038 ns - 19 cycles(tsc) 4.786 ns improved 20.8%
8 - 17 cycles(tsc) 4.280 ns - 18 cycles(tsc) 4.572 ns improved -5.9%
16 - 17 cycles(tsc) 4.483 ns - 18 cycles(tsc) 4.658 ns improved -5.9%
30 - 18 cycles(tsc) 4.531 ns - 18 cycles(tsc) 4.568 ns improved 0.0%
32 - 58 cycles(tsc) 14.586 ns - 65 cycles(tsc) 16.454 ns improved -12.1%
34 - 53 cycles(tsc) 13.391 ns - 63 cycles(tsc) 15.932 ns improved -18.9%
48 - 65 cycles(tsc) 16.268 ns - 50 cycles(tsc) 12.506 ns improved 23.1%
64 - 53 cycles(tsc) 13.440 ns - 63 cycles(tsc) 15.929 ns improved -18.9%
128 - 79 cycles(tsc) 19.899 ns - 86 cycles(tsc) 21.583 ns improved -8.9%
158 - 90 cycles(tsc) 22.732 ns - 90 cycles(tsc) 22.552 ns improved 0.0%
250 - 95 cycles(tsc) 23.916 ns - 98 cycles(tsc) 24.589 ns improved -3.2%
This implements SLUB specific kmem_cache_free_bulk(). SLUB allocator now
both have bulk alloc and free implemented.
Choose to reenable local IRQs while calling slowpath __slab_free(). In
worst case, where all objects hit slowpath call, the performance should
still be faster than fallback function __kmem_cache_free_bulk(), because
local_irq_{disable+enable} is very fast (7-cycles), while the fallback
invokes this_cpu_cmpxchg() which is slightly slower (9-cycles).
Nitpicking, this should be faster for N>=4, due to the entry cost of
local_irq_{disable+enable}.
Do notice that the save+restore variant is very expensive, this is key to
why this optimization works.
CPU: i7-4790K CPU @ 4.00GHz
* local_irq_{disable,enable}: 7 cycles(tsc) - 1.821 ns
* local_irq_{save,restore} : 37 cycles(tsc) - 9.443 ns
Measurements on CPU CPU i7-4790K @ 4.00GHz
Baseline normal fastpath (alloc+free cost): 43 cycles(tsc) 10.834 ns
Bulk- fallback - this-patch
1 - 58 cycles(tsc) 14.542 ns - 43 cycles(tsc) 10.811 ns improved 25.9%
2 - 50 cycles(tsc) 12.659 ns - 27 cycles(tsc) 6.867 ns improved 46.0%
3 - 48 cycles(tsc) 12.168 ns - 21 cycles(tsc) 5.496 ns improved 56.2%
4 - 47 cycles(tsc) 11.987 ns - 24 cycles(tsc) 6.038 ns improved 48.9%
8 - 46 cycles(tsc) 11.518 ns - 17 cycles(tsc) 4.280 ns improved 63.0%
16 - 45 cycles(tsc) 11.366 ns - 17 cycles(tsc) 4.483 ns improved 62.2%
30 - 45 cycles(tsc) 11.433 ns - 18 cycles(tsc) 4.531 ns improved 60.0%
32 - 75 cycles(tsc) 18.983 ns - 58 cycles(tsc) 14.586 ns improved 22.7%
34 - 71 cycles(tsc) 17.940 ns - 53 cycles(tsc) 13.391 ns improved 25.4%
48 - 80 cycles(tsc) 20.077 ns - 65 cycles(tsc) 16.268 ns improved 18.8%
64 - 71 cycles(tsc) 17.799 ns - 53 cycles(tsc) 13.440 ns improved 25.4%
128 - 91 cycles(tsc) 22.980 ns - 79 cycles(tsc) 19.899 ns improved 13.2%
158 - 100 cycles(tsc) 25.241 ns - 90 cycles(tsc) 22.732 ns improved 10.0%
250 - 102 cycles(tsc) 25.583 ns - 95 cycles(tsc) 23.916 ns improved 6.9%
Call slowpath __slab_alloc() from within the bulk loop, as the side-effect
of this call likely repopulates c->freelist.
Choose to reenable local IRQs while calling slowpath.
Saving some optimizations for later. E.g. it is possible to extract
parts of __slab_alloc() and avoid the unnecessary and expensive (37
cycles) local_irq_{save,restore}. For now, be happy calling
__slab_alloc() this lower icache impact of this func and I don't have to
worry about correctness.
Baseline normal fastpath (alloc+free cost): 42 cycles(tsc) 10.601 ns
1 - 58 cycles(tsc) 14.516 ns - 49 cycles(tsc) 12.459 ns improved 15.5%
2 - 51 cycles(tsc) 12.930 ns - 38 cycles(tsc) 9.605 ns improved 25.5%
3 - 49 cycles(tsc) 12.274 ns - 34 cycles(tsc) 8.525 ns improved 30.6%
4 - 48 cycles(tsc) 12.058 ns - 32 cycles(tsc) 8.036 ns improved 33.3%
8 - 46 cycles(tsc) 11.609 ns - 31 cycles(tsc) 7.756 ns improved 32.6%
16 - 45 cycles(tsc) 11.451 ns - 32 cycles(tsc) 8.148 ns improved 28.9%
30 - 79 cycles(tsc) 19.865 ns - 68 cycles(tsc) 17.164 ns improved 13.9%
32 - 76 cycles(tsc) 19.212 ns - 66 cycles(tsc) 16.584 ns improved 13.2%
34 - 74 cycles(tsc) 18.600 ns - 63 cycles(tsc) 15.954 ns improved 14.9%
48 - 88 cycles(tsc) 22.092 ns - 77 cycles(tsc) 19.373 ns improved 12.5%
64 - 80 cycles(tsc) 20.043 ns - 68 cycles(tsc) 17.188 ns improved 15.0%
128 - 99 cycles(tsc) 24.818 ns - 89 cycles(tsc) 22.404 ns improved 10.1%
158 - 99 cycles(tsc) 24.977 ns - 92 cycles(tsc) 23.089 ns improved 7.1%
250 - 106 cycles(tsc) 26.552 ns - 99 cycles(tsc) 24.785 ns improved 6.6%
First piece: acceleration of retrieval of per cpu objects
If we are allocating lots of objects then it is advantageous to disable
interrupts and avoid the this_cpu_cmpxchg() operation to get these objects
faster.
Note that we cannot do the fast operation if debugging is enabled, because
we would have to add extra code to do all the debugging checks. And it
would not be fast anyway.
Note also that the requirement of having interrupts disabled avoids having
to do processor flag operations.
Allocate as many objects as possible in the fast way and then fall back to
the generic implementation for the rest of the objects.
Baseline normal fastpath (alloc+free cost): 42 cycles(tsc) 10.554 ns
1 - 57 cycles(tsc) 14.432 ns - 48 cycles(tsc) 12.155 ns improved 15.8%
2 - 50 cycles(tsc) 12.746 ns - 37 cycles(tsc) 9.390 ns improved 26.0%
3 - 48 cycles(tsc) 12.180 ns - 33 cycles(tsc) 8.417 ns improved 31.2%
4 - 48 cycles(tsc) 12.015 ns - 32 cycles(tsc) 8.045 ns improved 33.3%
8 - 46 cycles(tsc) 11.526 ns - 30 cycles(tsc) 7.699 ns improved 34.8%
16 - 45 cycles(tsc) 11.418 ns - 32 cycles(tsc) 8.205 ns improved 28.9%
30 - 80 cycles(tsc) 20.246 ns - 73 cycles(tsc) 18.328 ns improved 8.8%
32 - 79 cycles(tsc) 19.946 ns - 72 cycles(tsc) 18.208 ns improved 8.9%
34 - 78 cycles(tsc) 19.659 ns - 71 cycles(tsc) 17.987 ns improved 9.0%
48 - 86 cycles(tsc) 21.516 ns - 82 cycles(tsc) 20.566 ns improved 4.7%
64 - 93 cycles(tsc) 23.423 ns - 89 cycles(tsc) 22.480 ns improved 4.3%
128 - 100 cycles(tsc) 25.170 ns - 99 cycles(tsc) 24.871 ns improved 1.0%
158 - 102 cycles(tsc) 25.549 ns - 101 cycles(tsc) 25.375 ns improved 1.0%
250 - 101 cycles(tsc) 25.344 ns - 100 cycles(tsc) 25.182 ns improved 1.0%
Add the basic infrastructure for alloc/free operations on pointer arrays.
It includes a generic function in the common slab code that is used in
this infrastructure patch to create the unoptimized functionality for slab
bulk operations.
Allocators can then provide optimized allocation functions for situations
in which large numbers of objects are needed. These optimization may
avoid taking locks repeatedly and bypass metadata creation if all objects
in slab pages can be used to provide the objects required.
Allocators can extend the skeletons provided and add their own code to the
bulk alloc and free functions. They can keep the generic allocation and
freeing and just fall back to those if optimizations would not work (like
for example when debugging is on).
With this patchset the SLUB allocator now has both bulk alloc and free
implemented.
This patchset mostly optimizes the "fastpath" where objects are available
on the per CPU fastpath page. This mostly amortize the less-heavy
none-locked cmpxchg_double used on fastpath.
The "fallback" bulking (e.g __kmem_cache_free_bulk) provides a good basis
for comparison. Measurements[1] of the fallback functions
__kmem_cache_{free,alloc}_bulk have been copied from slab_common.c and
forced "noinline" to force a function call like slab_common.c.
Measurements last-patch with disabled debugging:
1 - 57 cycles(tsc) 14.448 ns - 44 cycles(tsc) 11.236 ns improved 22.8%
2 - 51 cycles(tsc) 12.768 ns - 28 cycles(tsc) 7.019 ns improved 45.1%
3 - 48 cycles(tsc) 12.232 ns - 22 cycles(tsc) 5.526 ns improved 54.2%
4 - 48 cycles(tsc) 12.025 ns - 19 cycles(tsc) 4.786 ns improved 60.4%
8 - 46 cycles(tsc) 11.558 ns - 18 cycles(tsc) 4.572 ns improved 60.9%
16 - 45 cycles(tsc) 11.458 ns - 18 cycles(tsc) 4.658 ns improved 60.0%
30 - 45 cycles(tsc) 11.499 ns - 18 cycles(tsc) 4.568 ns improved 60.0%
32 - 79 cycles(tsc) 19.917 ns - 65 cycles(tsc) 16.454 ns improved 17.7%
34 - 78 cycles(tsc) 19.655 ns - 63 cycles(tsc) 15.932 ns improved 19.2%
48 - 68 cycles(tsc) 17.049 ns - 50 cycles(tsc) 12.506 ns improved 26.5%
64 - 80 cycles(tsc) 20.009 ns - 63 cycles(tsc) 15.929 ns improved 21.3%
128 - 94 cycles(tsc) 23.749 ns - 86 cycles(tsc) 21.583 ns improved 8.5%
158 - 97 cycles(tsc) 24.299 ns - 90 cycles(tsc) 22.552 ns improved 7.2%
250 - 102 cycles(tsc) 25.681 ns - 98 cycles(tsc) 24.589 ns improved 3.9%
Benchmarking shows impressive improvements in the "fastpath" with a small
number of objects in the working set. Once the working set increases,
resulting in activating the "slowpath" (that contains the heavier locked
cmpxchg_double) the improvement decreases.
I'm currently working on also optimizing the "slowpath" (as network stack
use-case hits this), but this patchset should provide a good foundation
for further improvements. Rest of my patch queue in this area needs some
more work, but preliminary results are good. I'm attending Netfilter
Workshop[2] next week, and I'll hopefully return working on further
improvements in this area.
This patch (of 6):
s/succedd/succeed/
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
Cc: <stable@vger.kernel.org> [3.6+]
This patch moves the initialization of the size_index table slightly
earlier so that the first few kmem_cache_node's can be safely allocated
when KMALLOC_MIN_SIZE is large.
There are currently two ways to generate indices into kmalloc_caches (via
kmalloc_index() and via the size_index table in slab_common.c) and on some
arches (possibly only MIPS) they potentially disagree with each other
until create_kmalloc_caches() has been called. It seems that the
intention is that the size_index table is a fast equivalent to
kmalloc_index() and that create_kmalloc_caches() patches the table to
return the correct value for the cases where kmalloc_index()'s
if-statements apply.
The failing sequence was:
* kmalloc_caches contains NULL elements
* kmem_cache_init initialises the element that 'struct
kmem_cache_node' will be allocated to. For 32-bit Mips, this is a
56-byte struct and kmalloc_index returns KMALLOC_SHIFT_LOW (7).
* init_list is called which calls kmalloc_node to allocate a 'struct
kmem_cache_node'.
* kmalloc_slab selects the kmem_caches element using
size_index[size_index_elem(size)]. For MIPS, size is 56, and the
expression returns 6.
* This element of kmalloc_caches is NULL and allocation fails.
* If it had not already failed, it would have called
create_kmalloc_caches() at this point which would have changed
size_index[size_index_elem(size)] to 7.
I don't believe the bug to be LLVM specific but GCC doesn't normally
encounter the problem. I haven't been able to identify exactly what GCC
is doing better (probably inlining) but it seems that GCC is managing to
optimize to the point that it eliminates the problematic allocations.
This theory is supported by the fact that GCC can be made to fail in the
same way by changing inline, __inline, __inline__, and __always_inline in
include/linux/compiler-gcc.h such that they don't actually inline things.
Signed-off-by: Daniel Sanders <daniel.sanders@imgtec.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/
tree since it doesn't work reliably on non-scalar types.
This patch removes the rest of the usages of ACCESS_ONCE, and use the new
READ_ONCE API for the read accesses. This makes things cleaner, instead
of using separate/multiple sets of APIs.
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Use the normal return values for bool functions
By moving the O option detection into the switch statement, we allow this
parameter to be combined with other options correctly. Previously options
like slub_debug=OFZ would only detect the 'o' and use DEBUG_DEFAULT_FLAGS
to fill in the rest of the flags.
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
Commit 9aabf810a67c ("mm/slub: optimize alloc/free fastpath by removing
preemption on/off") introduced an occasional hang for kernels built with
CONFIG_PREEMPT && !CONFIG_SMP.
The problem is the following loop the patch introduced to
slab_alloc_node and slab_free:
do {
tid = this_cpu_read(s->cpu_slab->tid);
c = raw_cpu_ptr(s->cpu_slab);
} while (IS_ENABLED(CONFIG_PREEMPT) && unlikely(tid != c->tid));
GCC 4.9 has been observed to hoist the load of c and c->tid above the
loop for !SMP kernels (as in this case raw_cpu_ptr(x) is compile-time
constant and does not force a reload). On arm64 the generated assembly
looks like:
ldr x4, [x0,#8]
loop:
ldr x1, [x0,#8]
cmp x1, x4
b.ne loop
If the thread is preempted between the load of c->tid (into x1) and tid
(into x4), and an allocation or free occurs in another thread (bumping
the cpu_slab's tid), the thread will be stuck in the loop until
s->cpu_slab->tid wraps, which may be forever in the absence of
allocations/frees on the same CPU.
This patch changes the loop condition to access c->tid with READ_ONCE.
This ensures that the value is reloaded even when the compiler would
otherwise assume it could cache the value, and also ensures that the
load will not be torn.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Steve Capper <steve.capper@linaro.org>
With this patch kasan will be able to catch bugs in memory allocated by
slub. Initially all objects in newly allocated slab page, marked as
redzone. Later, when allocation of slub object happens, requested by
caller number of bytes marked as accessible, and the rest of the object
(including slub's metadata) marked as redzone (inaccessible).
We also mark object as accessible if ksize was called for this object.
There is some places in kernel where ksize function is called to inquire
size of really allocated area. Such callers could validly access whole
allocated memory, so it should be marked as accessible.
Code in slub.c and slab_common.c files could validly access to object's
metadata, so instrumentation for this files are disabled.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Signed-off-by: Dmitry Chernenkov <dmitryc@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
It's ok for slub to access memory that marked by kasan as inaccessible
(object's metadata). Kasan shouldn't print report in that case because
these accesses are valid. Disabling instrumentation of slub.c code is not
enough to achieve this because slub passes pointer to object's metadata
into external functions like memchr_inv().
We don't want to disable instrumentation for memchr_inv() because this is
quite generic function, and we don't want to miss bugs.
metadata_access_enable/metadata_access_disable used to tell KASan where
accesses to metadata starts/end, so we could temporarily disable KASan
reports.
Cc: Dmitry Chernenkov <dmitryc@google.com>
Remove static and add function declarations to linux/slub_def.h so it
could be used by kernel address sanitizer.
printk and friends can now format bitmaps using '%*pb[l]'. cpumask
and nodemask also provide cpumask_pr_args() and nodemask_pr_args()
respectively which can be used to generate the two printf arguments
necessary to format the specified cpu/nodemask.
* This is an equivalent conversion but the whole function should be
converted to use scnprinf famiily of functions rather than
performing custom output length predictions in multiple places.
To speed up further allocations SLUB may store empty slabs in per cpu/node
partial lists instead of freeing them immediately. This prevents per
memcg caches destruction, because kmem caches created for a memory cgroup
are only destroyed after the last page charged to the cgroup is freed.
To fix this issue, this patch resurrects approach first proposed in [1].
It forbids SLUB to cache empty slabs after the memory cgroup that the
cache belongs to was destroyed. It is achieved by setting kmem_cache's
cpu_partial and min_partial constants to 0 and tuning put_cpu_partial() so
that it would drop frozen empty slabs immediately if cpu_partial = 0.
The runtime overhead is minimal. From all the hot functions, we only
touch relatively cold put_cpu_partial(): we make it call
unfreeze_partials() after freezing a slab that belongs to an offline
memory cgroup. Since slab freezing exists to avoid moving slabs from/to a
partial list on free/alloc, and there can't be allocations from dead
caches, it shouldn't cause any overhead. We do have to disable preemption
for put_cpu_partial() to achieve that though.
The original patch was accepted well and even merged to the mm tree.
However, I decided to withdraw it due to changes happening to the memcg
core at that time. I had an idea of introducing per-memcg shrinkers for
kmem caches, but now, as memcg has finally settled down, I do not see it
as an option, because SLUB shrinker would be too costly to call since SLUB
does not keep free slabs on a separate list. Besides, we currently do not
even call per-memcg shrinkers for offline memcgs. Overall, it would
introduce much more complexity to both SLUB and memcg than this small
patch.
Regarding to SLAB, there's no problem with it, because it shrinks
per-cpu/node caches periodically. Thanks to list_lru reparenting, we no
longer keep entries for offline cgroups in per-memcg arrays (such as
memcg_cache_params->memcg_caches), so we do not have to bother if a
per-memcg cache will be shrunk a bit later than it could be.
[1] http://thread.gmane.org/gmane.linux.kernel.mm/118649/focus=118650
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
It is supposed to return 0 if the cache has no remaining objects and 1
otherwise, while currently it always returns 0. Fix it.
SLUB's version of __kmem_cache_shrink() not only removes empty slabs, but
also tries to rearrange the partial lists to place slabs filled up most to
the head to cope with fragmentation. To achieve that, it allocates a
temporary array of lists used to sort slabs by the number of objects in
use. If the allocation fails, the whole procedure is aborted.
This is unacceptable for the kernel memory accounting extension of the
memory cgroup, where we want to make sure that kmem_cache_shrink()
successfully discarded empty slabs. Although the allocation failure is
utterly unlikely with the current page allocator implementation, which
retries GFP_KERNEL allocations of order <= 2 infinitely, it is better not
to rely on that.
This patch therefore makes __kmem_cache_shrink() allocate the array on
stack instead of calling kmalloc, which may fail. The array size is
chosen to be equal to 32, because most SLUB caches store not more than 32
objects per slab page. Slab pages with <= 32 free objects are sorted
using the array by the number of objects in use and promoted to the head
of the partial list, while slab pages with > 32 free objects are left in
the end of the list without any ordering imposed on them.
Cc: Huang Ying <ying.huang@intel.com>
Sometimes, we need to iterate over all memcg copies of a particular root
kmem cache. Currently, we use memcg_cache_params->memcg_caches array for
that, because it contains all existing memcg caches.
However, it's a bad practice to keep all caches, including those that
belong to offline cgroups, in this array, because it will be growing
beyond any bounds then. I'm going to wipe away dead caches from it to
save space. To still be able to perform iterations over all memcg caches
of the same kind, let us link them into a list.
Cc: Tejun Heo <tj@kernel.org>
Currently, kmem_cache stores a pointer to struct memcg_cache_params
instead of embedding it. The rationale is to save memory when kmem
accounting is disabled. However, the memcg_cache_params has shrivelled
drastically since it was first introduced:
* Initially:
struct memcg_cache_params {
bool is_root_cache;
union {
struct kmem_cache *memcg_caches[0];
struct {
struct mem_cgroup *memcg;
struct list_head list;
struct kmem_cache *root_cache;
bool dead;
atomic_t nr_pages;
struct work_struct destroy;
* Now:
bool is_root_cache;
union {
struct {
struct rcu_head rcu_head;
struct {
So the memory saving does not seem to be a clear win anymore.
OTOH, keeping a pointer to memcg_cache_params struct instead of embedding
it results in touching one more cache line on kmem alloc/free hot paths.
Besides, it makes linking kmem caches in a list chained by a field of
struct memcg_cache_params really painful due to a level of indirection,
while I want to make them linked in the following patch. That said, let
us embed it.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
We had to insert a preempt enable/disable in the fastpath a while ago in
order to guarantee that tid and kmem_cache_cpu are retrieved on the same
cpu. It is the problem only for CONFIG_PREEMPT in which scheduler can
move the process to other cpu during retrieving data.
Now, I reach the solution to remove preempt enable/disable in the
fastpath. If tid is matched with kmem_cache_cpu's tid after tid and
kmem_cache_cpu are retrieved by separate this_cpu operation, it means
that they are retrieved on the same cpu. If not matched, we just have
to retry it.
With this guarantee, preemption enable/disable isn't need at all even if
CONFIG_PREEMPT, so this patch removes it.
I saw roughly 5% win in a fast-path loop over kmem_cache_alloc/free in
CONFIG_PREEMPT. (14.821 ns -> 14.049 ns)
Below is the result of Christoph's slab_test reported by Jesper Dangaard
Brouer.
* Before
Single thread testing
1. Kmalloc: Repeatedly allocate then free test
10000 times kmalloc(8) -> 49 cycles kfree -> 62 cycles
10000 times kmalloc(16) -> 48 cycles kfree -> 64 cycles
10000 times kmalloc(32) -> 53 cycles kfree -> 70 cycles
10000 times kmalloc(64) -> 64 cycles kfree -> 77 cycles
10000 times kmalloc(128) -> 74 cycles kfree -> 84 cycles
10000 times kmalloc(256) -> 84 cycles kfree -> 114 cycles
10000 times kmalloc(512) -> 83 cycles kfree -> 116 cycles
10000 times kmalloc(1024) -> 81 cycles kfree -> 120 cycles
10000 times kmalloc(2048) -> 104 cycles kfree -> 136 cycles
10000 times kmalloc(4096) -> 142 cycles kfree -> 165 cycles
10000 times kmalloc(8192) -> 238 cycles kfree -> 226 cycles
10000 times kmalloc(16384) -> 403 cycles kfree -> 264 cycles
2. Kmalloc: alloc/free test
10000 times kmalloc(8)/kfree -> 68 cycles
10000 times kmalloc(16)/kfree -> 68 cycles
10000 times kmalloc(32)/kfree -> 69 cycles
10000 times kmalloc(64)/kfree -> 68 cycles
10000 times kmalloc(128)/kfree -> 68 cycles
10000 times kmalloc(256)/kfree -> 68 cycles
10000 times kmalloc(512)/kfree -> 74 cycles
10000 times kmalloc(1024)/kfree -> 75 cycles
10000 times kmalloc(2048)/kfree -> 74 cycles
10000 times kmalloc(4096)/kfree -> 74 cycles
10000 times kmalloc(8192)/kfree -> 75 cycles
10000 times kmalloc(16384)/kfree -> 510 cycles
* After
10000 times kmalloc(8) -> 46 cycles kfree -> 61 cycles
10000 times kmalloc(16) -> 46 cycles kfree -> 63 cycles
10000 times kmalloc(32) -> 49 cycles kfree -> 69 cycles
10000 times kmalloc(64) -> 57 cycles kfree -> 76 cycles
10000 times kmalloc(128) -> 66 cycles kfree -> 83 cycles
10000 times kmalloc(256) -> 84 cycles kfree -> 110 cycles
10000 times kmalloc(512) -> 77 cycles kfree -> 114 cycles
10000 times kmalloc(1024) -> 80 cycles kfree -> 116 cycles
10000 times kmalloc(2048) -> 102 cycles kfree -> 131 cycles
10000 times kmalloc(4096) -> 135 cycles kfree -> 163 cycles
10000 times kmalloc(8192) -> 238 cycles kfree -> 218 cycles
10000 times kmalloc(16384) -> 399 cycles kfree -> 262 cycles
10000 times kmalloc(8)/kfree -> 65 cycles
10000 times kmalloc(16)/kfree -> 66 cycles
10000 times kmalloc(32)/kfree -> 65 cycles
10000 times kmalloc(64)/kfree -> 66 cycles
10000 times kmalloc(128)/kfree -> 66 cycles
10000 times kmalloc(256)/kfree -> 71 cycles
10000 times kmalloc(512)/kfree -> 72 cycles
10000 times kmalloc(1024)/kfree -> 71 cycles
10000 times kmalloc(2048)/kfree -> 71 cycles
10000 times kmalloc(4096)/kfree -> 71 cycles
10000 times kmalloc(8192)/kfree -> 65 cycles
10000 times kmalloc(16384)/kfree -> 511 cycles
Most of the results are better than before.
Note that this change slightly worses performance in !CONFIG_PREEMPT,
roughly 0.3%. Implementing each case separately would help performance,
but, since it's so marginal, I didn't do that. This would help
maintanance since we have same code for all cases.
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
If we fail to allocate from the current node's stock, we look for free
objects on other nodes before calling the page allocator (see
get_any_partial). While checking other nodes we respect cpuset
constraints by calling cpuset_zone_allowed. We enforce hardwall check.
As a result, we will fallback to the page allocator even if there are some
pages cached on other nodes, but the current cpuset doesn't have them set.
However, the page allocator uses softwall check for kernel allocations,
so it may allocate from one of the other nodes in this case.
Therefore we should use softwall cpuset check in get_any_partial to
conform with the cpuset check in the page allocator.
Acked-by: Zefan Li <lizefan@huawei.com>
Suppose task @t that belongs to a memory cgroup @memcg is going to
allocate an object from a kmem cache @c. The copy of @c corresponding to
@memcg, @mc, is empty. Then if kmem_cache_alloc races with the memory
cgroup destruction we can access the memory cgroup's copy of the cache
after it was destroyed:
CPU0 CPU1
[ current=@t
@mc->memcg_params->nr_pages=0 ]
kmem_cache_alloc(@c):
call memcg_kmem_get_cache(@c);
proceed to allocation from @mc:
alloc a page for @mc:
move @t from @memcg
destroy @memcg:
mem_cgroup_css_offline(@memcg):
memcg_unregister_all_caches(@memcg):
kmem_cache_destroy(@mc)
add page to @mc
We could fix this issue by taking a reference to a per-memcg cache, but
that would require adding a per-cpu reference counter to per-memcg caches,
which would look cumbersome.
Instead, let's take a reference to a memory cgroup, which already has a
per-cpu reference counter, in the beginning of kmem_cache_alloc to be
dropped in the end, and move per memcg caches destruction from css offline
to css free. As a side effect, per-memcg caches will be destroyed not one
by one, but all at once when the last page accounted to the memory cgroup
is freed. This doesn't sound as a high price for code readability though.
Note, this patch does add some overhead to the kmem_cache_alloc hot path,
but it is pretty negligible - it's just a function call plus a per cpu
counter decrement, which is comparable to what we already have in
memcg_kmem_get_cache. Besides, it's only relevant if there are memory
cgroups with kmem accounting enabled. I don't think we can find a way to
handle this race w/o it, because alloc_page called from kmem_cache_alloc
may sleep so we can't flush all pending kmallocs w/o reference counting.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup update from Tejun Heo:
"cpuset got simplified a bit. cgroup core got a fix on unified
hierarchy and grew some effective css related interfaces which will be
used for blkio support for writeback IO traffic which is currently
being worked on"
* 'for-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: implement cgroup_get_e_css()
cgroup: add cgroup_subsys->css_e_css_changed()
cgroup: add cgroup_subsys->css_released()
cgroup: fix the async css offline wait logic in cgroup_subtree_control_write()
cgroup: restructure child_subsys_mask handling in cgroup_subtree_control_write()
cgroup: separate out cgroup_calc_child_subsys_mask() from cgroup_refresh_child_subsys_mask()
cpuset: lock vs unlock typo
cpuset: simplify cpuset_node_allowed API
cpuset: convert callback_mutex to a spinlock
The code goes BUG, but doesn't tell us which bits were unexpectedly set.
Print that out.
Adding __printf(3, 4) to slab_err exposed following:
mm/slub.c: In function `check_slab':
mm/slub.c:852:4: warning: format `%u' expects argument of type `unsigned int', but argument 4 has type `const char *' [-Wformat=]
s->name, page->objects, maxobj);
mm/slub.c:852:4: warning: too many arguments for format [-Wformat-extra-args]
mm/slub.c:857:4: warning: format `%u' expects argument of type `unsigned int', but argument 4 has type `const char *' [-Wformat=]
s->name, page->inuse, page->objects);
mm/slub.c:857:4: warning: too many arguments for format [-Wformat-extra-args]
mm/slub.c: In function `on_freelist':
mm/slub.c:905:4: warning: format `%d' expects argument of type `int', but argument 5 has type `long unsigned int' [-Wformat=]
"should be %d", page->objects, max_objects);
Fix first two warnings by removing redundant s->name.
Fix the last by changing type of max_object from unsigned long to int.
