path: root/mm/slub.c
2009-03-30Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (33 commits) lockdep: fix deadlock in lockdep_trace_alloc lockdep: annotate reclaim context (__GFP_NOFS), fix SLOB lockdep: annotate reclaim context (__GFP_NOFS), fix lockdep: build fix for !PROVE_LOCKING lockstat: warn about disabled lock debugging lockdep: use stringify.h lockdep: simplify check_prev_add_irq() lockdep: get_user_chars() redo lockdep: simplify get_user_chars() lockdep: add comments to mark_lock_irq() lockdep: remove macro usage from mark_held_locks() lockdep: fully reduce mark_lock_irq() lockdep: merge the !_READ mark_lock_irq() helpers lockdep: merge the _READ mark_lock_irq() helpers lockdep: simplify mark_lock_irq() helpers #3 lockdep: further simplify mark_lock_irq() helpers lockdep: simplify the mark_lock_irq() helpers lockdep: split up mark_lock_irq() lockdep: generate usage strings lockdep: generate the state bit definitions ...
2009-03-24Merge branches 'topic/slob/cleanups', 'topic/slob/fixes', 'topic/slub/core', ↵Pekka Enberg
'topic/slub/cleanups' and 'topic/slub/perf' into for-linus
2009-03-23slub: use get_track()Akinobu Mita
Use get_track() in set_track() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-25slub: rename calculate_min_partial() to set_min_partial()David Rientjes
As suggested by Christoph Lameter, rename calculate_min_partial() to set_min_partial() as the function doesn't really do any calculations. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-23slub: add min_partial sysfs tunableDavid Rientjes
Now that a cache's min_partial has been moved to struct kmem_cache, it's possible to easily tune it from userspace by adding a sysfs attribute. It may not be desirable to keep a large number of partial slabs around if a cache is used infrequently and memory, especially when constrained by a cgroup, is scarce. It's better to allow userspace to set the minimum policy per cache instead of relying explicitly on kmem_cache_shrink(). The memory savings from simply moving min_partial from struct kmem_cache_node to struct kmem_cache is obviously not significant (unless maybe you're from SGI or something), at the largest it's # allocated caches * (MAX_NUMNODES - 1) * sizeof(unsigned long) The true savings occurs when userspace reduces the number of partial slabs that would otherwise be wasted, especially on machines with a large number of nodes (ia64 with CONFIG_NODES_SHIFT at 10 for default?). As well as the kernel estimates ideal values for n->min_partial and ensures it's within a sane range, userspace has no other input other than writing to /sys/kernel/slab/cache/shrink. There simply isn't any better heuristic to add when calculating the partial values for a better estimate that works for all possible caches. And since it's currently a static value, the user really has no way of reclaiming that wasted space, which can be significant when constrained by a cgroup (either cpusets or, later, memory controller slab limits) without shrinking it entirely. This also allows the user to specify that increased fragmentation and more partial slabs are actually desired to avoid the cost of allocating new slabs at runtime for specific caches. There's also no reason why this should be a per-struct kmem_cache_node value in the first place. You could argue that a machine would have such node size asymmetries that it should be specified on a per-node basis, but we know nobody is doing that right now since it's a purely static value at the moment and there's no convenient way to tune that via slub's sysfs interface. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-23slub: move min_partial to struct kmem_cacheDavid Rientjes
Although it allows for better cacheline use, it is unnecessary to save a copy of the cache's min_partial value in each kmem_cache_node. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-20SLUB: Fix default slab order for big object sizesZhang Yanmin
The default order of kmalloc-8192 on 2*4 stoakley is an issue of calculate_order. slab_size order name ------------------------------------------------- 4096 3 sgpool-128 8192 2 kmalloc-8192 16384 3 kmalloc-16384 kmalloc-8192's default order is smaller than sgpool-128's. On 4*4 tigerton machine, a similiar issue appears on another kmem_cache. Function calculate_order uses 'min_objects /= 2;' to shrink. Plus size calculation/checking in slab_order, sometimes above issue appear. Below patch against 2.6.29-rc2 fixes it. I checked the default orders of all kmem_cache and they don't become smaller than before. So the patch wouldn't hurt performance. Signed-off-by Zhang Yanmin <yanmin.zhang@linux.intel.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-20SLUB: Introduce and use SLUB_MAX_SIZE and SLUB_PAGE_SHIFT constantsChristoph Lameter
As a preparational patch to bump up page allocator pass-through threshold, introduce two new constants SLUB_MAX_SIZE and SLUB_PAGE_SHIFT and convert mm/slub.c to use them. Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-14lockdep: annotate reclaim context (__GFP_NOFS)Nick Piggin
Here is another version, with the incremental patch rolled up, and added reclaim context annotation to kswapd, and allocation tracing to slab allocators (which may only ever reach the page allocator in rare cases, so it is good to put annotations here too). Haven't tested this version as such, but it should be getting closer to merge worthy ;) -- After noticing some code in mm/filemap.c accidentally perform a __GFP_FS allocation when it should not have been, I thought it might be a good idea to try to catch this kind of thing with lockdep. I coded up a little idea that seems to work. Unfortunately the system has to actually be in __GFP_FS page reclaim, then take the lock, before it will mark it. But at least that might still be some orders of magnitude more common (and more debuggable) than an actual deadlock condition, so we have some improvement I hope (the concept is no less complete than discovery of a lock's interrupt contexts). I guess we could even do the same thing with __GFP_IO (normal reclaim), and even GFP_NOIO locks too... but filesystems will have the most locks and fiddly code paths, so let's start there and see how it goes. It *seems* to work. I did a quick test. ================================= [ INFO: inconsistent lock state ] 2.6.28-rc6-00007-ged31348-dirty #26 --------------------------------- inconsistent {in-reclaim-W} -> {ov-reclaim-W} usage. modprobe/8526 [HC0[0]:SC0[0]:HE1:SE1] takes: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] {in-reclaim-W} state was registered at: [<ffffffff80267bdb>] __lock_acquire+0x75b/0x1a60 [<ffffffff80268f71>] lock_acquire+0x91/0xc0 [<ffffffff8070f0e1>] mutex_lock_nested+0xb1/0x310 [<ffffffffa002002b>] brd_init+0x2b/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 3929 hardirqs last enabled at (3929): [<ffffffff8070f2b5>] mutex_lock_nested+0x285/0x310 hardirqs last disabled at (3928): [<ffffffff8070f089>] mutex_lock_nested+0x59/0x310 softirqs last enabled at (3732): [<ffffffff8061f623>] sk_filter+0x83/0xe0 softirqs last disabled at (3730): [<ffffffff8061f5b6>] sk_filter+0x16/0xe0 other info that might help us debug this: 1 lock held by modprobe/8526: #0: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] stack backtrace: Pid: 8526, comm: modprobe Not tainted 2.6.28-rc6-00007-ged31348-dirty #26 Call Trace: [<ffffffff80265483>] print_usage_bug+0x193/0x1d0 [<ffffffff80266530>] mark_lock+0xaf0/0xca0 [<ffffffff80266735>] mark_held_locks+0x55/0xc0 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff802667ca>] trace_reclaim_fs+0x2a/0x60 [<ffffffff80285005>] __alloc_pages_internal+0x475/0x580 [<ffffffff8070f29e>] ? mutex_lock_nested+0x26e/0x310 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffffa002006a>] brd_init+0x6a/0x216 [brd] [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff8070f8b9>] ? mutex_unlock+0x9/0x10 [<ffffffff8070f83d>] ? __mutex_unlock_slowpath+0x10d/0x180 [<ffffffff802669ec>] ? trace_hardirqs_on_caller+0x12c/0x190 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-12mm: Export symbol ksize()Kirill A. Shutemov
Commit 7b2cd92adc5430b0c1adeb120971852b4ea1ab08 ("crypto: api - Fix zeroing on free") added modular user of ksize(). Export that to fix crypto.ko compilation. Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-01-28slub: fix per cpu kmem_cache_cpu array memory leakDavid Rientjes
The per cpu array of kmem_cache_cpu structures accomodates NR_KMEM_CACHE_CPU such structs. When this array overflows and a struct is allocated by kmalloc(), it may have an address at the upper bound of this array. If this happens, it does not get freed and the per cpu kmem_cache_cpu_free pointer will be out of bounds after kmem_cache_destroy() or cpu offlining. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-01-14SLUB: Use ->objsize from struct kmem_cache_cpu in slab_free()Pekka Enberg
There's no reason to use ->objsize from struct kmem_cache in slab_free() for the SLAB_DEBUG_OBJECTS case. All it does is generate extra cache pressure as we try very hard not to touch struct kmem_cache in the fast-path. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-01-06trivial: fix an -> a typos in documentation and commentsFrederik Schwarzer
It is always "an" if there is a vowel _spoken_ (not written). So it is: "an hour" (spoken vowel) but "a uniform" (spoken 'j') Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-01cpumask: convert mm/Rusty Russell
Impact: Use new API Convert kernel mm functions to use struct cpumask. We skip include/linux/percpu.h and mm/allocpercpu.c, which are in flux. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-29Merge branch 'topic/failslab' into for-linusPekka Enberg
Conflicts: mm/slub.c Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29Merge branches 'topic/fixes', 'topic/cleanups' and 'topic/documentation' ↵Pekka Enberg
into for-linus
2008-12-29slub: avoid leaking caches or refcounts on sysfs errorDavid Rientjes
If a slab cache is mergeable and the sysfs alias cannot be added, the target cache shall have its refcount decremented. kmem_cache_create() will return NULL, so if kmem_cache_destroy() is ever called on the target cache, it will never be freed if the refcount has been leaked. Likewise, if a slab cache is not mergeable and the sysfs link cannot be added, the new cache shall be removed from the slab_caches list. kmem_cache_create() will return NULL, so it will be impossible to call kmem_cache_destroy() on it. Both of these operations require slub_lock since refcount of all slab caches and slab_caches are protected by the lock. In the mergeable case, it would be better to restore objsize and offset back to their original values, but this could race with another merge since slub_lock was dropped. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29slub: Add might_sleep_if() to slab_alloc()OGAWA Hirofumi
Currently SLUB doesn't warn about __GFP_WAIT. Add it into slab_alloc(). Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29SLUB: failslab supportAkinobu Mita
Currently fault-injection capability for SLAB allocator is only available to SLAB. This patch makes it available to SLUB, too. [penberg@cs.helsinki.fi: unify slab and slub implementations] Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-12-10KSYM_SYMBOL_LEN fixesHugh Dickins
Miles Lane tailing /sys files hit a BUG which Pekka Enberg has tracked to my 966c8c12dc9e77f931e2281ba25d2f0244b06949 sprint_symbol(): use less stack exposing a bug in slub's list_locations() - kallsyms_lookup() writes a 0 to namebuf[KSYM_NAME_LEN-1], but that was beyond the end of page provided. The 100 slop which list_locations() allows at end of page looks roughly enough for all the other stuff it might print after the symbol before it checks again: break out KSYM_SYMBOL_LEN earlier than before. Latencytop and ftrace and are using KSYM_NAME_LEN buffers where they need KSYM_SYMBOL_LEN buffers, and vmallocinfo a 2*KSYM_NAME_LEN buffer where it wants a KSYM_SYMBOL_LEN buffer: fix those before anyone copies them. [akpm@linux-foundation.org: ftrace.h needs module.h] Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc Miles Lane <miles.lane@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-08slub: Fix incorrect use of looseNick Andrew
It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-01memcg: memory hotplug fix for notifier callbackKAMEZAWA Hiroyuki
Fixes for memcg/memory hotplug. While memory hotplug allocate/free memmap, page_cgroup doesn't free page_cgroup at OFFLINE when page_cgroup is allocated via bootomem. (Because freeing bootmem requires special care.) Then, if page_cgroup is allocated by bootmem and memmap is freed/allocated by memory hotplug, page_cgroup->page == page is no longer true. But current MEM_ONLINE handler doesn't check it and update page_cgroup->page if it's not necessary to allocate page_cgroup. (This was not found because memmap is not freed if SPARSEMEM_VMEMMAP is y.) And I noticed that MEM_ONLINE can be called against "part of section". So, freeing page_cgroup at CANCEL_ONLINE will cause trouble. (freeing used page_cgroup) Don't rollback at CANCEL. One more, current memory hotplug notifier is stopped by slub because it sets NOTIFY_STOP_MASK to return vaule. So, page_cgroup's callback never be called. (low priority than slub now.) I think this slub's behavior is not intentional(BUG). and fixes it. Another way to be considered about page_cgroup allocation: - free page_cgroup at OFFLINE even if it's from bootmem and remove specieal handler. But it requires more changes. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12041 Signed-off-by: KAMEZAWA Hiruyoki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-26slub: make early_kmem_cache_node_alloc voidDavid Rientjes
The return value for early_kmem_cache_node_alloc() is unused, so it is better defined as void. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-26slub - fix get_object_page commentCyrill Gorcunov
Use 'slab page' instead of 'slab object'. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-26SLUB: Replace __builtin_return_address(0) with _RET_IP_.Eduard - Gabriel Munteanu
This patch replaces __builtin_return_address(0) with _RET_IP_, since a previous patch moved _RET_IP_ and _THIS_IP_ to include/linux/kernel.h and they're widely available now. This makes for shorter and easier to read code. [penberg@cs.helsinki.fi: remove _RET_IP_ casts to void pointer] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-26SLUB: cleanup - define macros instead of hardcoded numbersCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-23proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.cAlexey Dobriyan
Lose dummy ->write hook in case of SLUB, it's possible now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-09-15slub: fixed uninitialized counter in struct kmem_cache_nodeSalman Qazi
Initialized total objects atomic for the node in init_kmem_cache_node. The uninitialized value was ruining the stats in /proc/slabinfo. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Salman Qazi <sqazi@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-08-20slub: Disable NUMA remote node defragmentation by defaultChristoph Lameter
Switch remote node defragmentation off by default. The current settings can cause excessive node local allocations with hackbench: SLAB: % cat /proc/meminfo MemTotal: 7701760 kB MemFree: 5940096 kB Slab: 123840 kB SLUB: % cat /proc/meminfo MemTotal: 7701376 kB MemFree: 4740928 kB Slab: 1591680 kB [Note: this feature is not related to slab defragmentation.] You can find the original discussion here: http://lkml.org/lkml/2008/8/4/308 Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-08-05SLUB: dynamic per-cache MIN_PARTIALPekka Enberg
This patch changes the static MIN_PARTIAL to a dynamic per-cache ->min_partial value that is calculated from object size. The bigger the object size, the more pages we keep on the partial list. I tested SLAB, SLUB, and SLUB with this patch on Jens Axboe's 'netio' example script of the fio benchmarking tool. The script stresses the networking subsystem which should also give a fairly good beating of kmalloc() et al. To run the test yourself, first clone the fio repository: git clone git://git.kernel.dk/fio.git and then run the following command n times on your machine: time ./fio examples/netio The results on my 2-way 64-bit x86 machine are as follows: [ the minimum, maximum, and average are captured from 50 individual runs ] real time (seconds) min max avg sd SLAB 22.76 23.38 22.98 0.17 SLUB 22.80 25.78 23.46 0.72 SLUB (dynamic) 22.74 23.54 23.00 0.20 sys time (seconds) min max avg sd SLAB 6.90 8.28 7.70 0.28 SLUB 7.42 16.95 8.89 2.28 SLUB (dynamic) 7.17 8.64 7.73 0.29 user time (seconds) min max avg sd SLAB 36.89 38.11 37.50 0.29 SLUB 30.85 37.99 37.06 1.67 SLUB (dynamic) 36.75 38.07 37.59 0.32 As you can see from the above numbers, this patch brings SLUB to the same level as SLAB for this particular workload fixing a ~2% regression. I'd expect this change to help similar workloads that allocate a lot of objects that are close to the size of a page. Cc: Matthew Wilcox <matthew@wil.cx> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-29mm: unexport ksizeAdrian Bunk
This patch removes the obsolete and no longer used exports of ksize. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24slub: record page flag overlays explicitlyAndy Whitcroft
SLUB reuses two page bits for internal purposes, it overlays PG_active and PG_error. This is hidden away in slub.c. Document these overlays explicitly in the main page-flags enum along with all the others. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19slub: dump more data on slab corruptionPekka Enberg
The limit of 128 bytes is too small when debugging slab corruption of the skb cache, for example. So increase the limit to PAGE_SIZE to make debugging corruptions easier. Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-16SLUB: simplify re on_each_cpu()Alexey Dobriyan
on_each_cpu() expands to function call on UP, too. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15slub: current is always validAlexey Dobriyan
Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-15slub: Add check for kfree() of non slab objects.Christoph Lameter
We can detect kfree()s on non slab objects by checking for PageCompound(). Works in the same way as for ksize. This helped me catch an invalid kfree(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-07-14Start using the new '%pS' infrastructure to print symbolsLinus Torvalds
This simplifies the code significantly, and was the whole point of the exercise. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10slub: Fix use-after-preempt of per-CPU data structureDmitry Adamushko
Vegard Nossum reported a crash in kmem_cache_alloc(): BUG: unable to handle kernel paging request at da87d000 IP: [<c01991c7>] kmem_cache_alloc+0xc7/0xe0 *pde = 28180163 *pte = 1a87d160 Oops: 0002 [#1] PREEMPT SMP DEBUG_PAGEALLOC Pid: 3850, comm: grep Not tainted (2.6.26-rc9-00059-gb190333 #5) EIP: 0060:[<c01991c7>] EFLAGS: 00210203 CPU: 0 EIP is at kmem_cache_alloc+0xc7/0xe0 EAX: 00000000 EBX: da87c100 ECX: 1adad71a EDX: 6b6b6b6b ESI: 00200282 EDI: da87d000 EBP: f60bfe74 ESP: f60bfe54 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 and analyzed it: "The register %ecx looks innocent but is very important here. The disassembly: mov %edx,%ecx shr $0x2,%ecx rep stos %eax,%es:(%edi) <-- the fault So %ecx has been loaded from %edx... which is 0x6b6b6b6b/POISON_FREE. (0x6b6b6b6b >> 2 == 0x1adadada.) %ecx is the counter for the memset, from here: memset(object, 0, c->objsize); i.e. %ecx was loaded from c->objsize, so "c" must have been freed. Where did "c" come from? Uh-oh... c = get_cpu_slab(s, smp_processor_id()); This looks like it has very much to do with CPU hotplug/unplug. Is there a race between SLUB/hotplug since the CPU slab is used after it has been freed?" Good analysis. Yeah, it's possible that a caller of kmem_cache_alloc() -> slab_alloc() can be migrated on another CPU right after local_irq_restore() and before memset(). The inital cpu can become offline in the mean time (or a migration is a consequence of the CPU going offline) so its 'kmem_cache_cpu' structure gets freed ( slab_cpuup_callback). At some point of time the caller continues on another CPU having an obsolete pointer... Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Christoph has movedChristoph Lameter
Remove all clameter@sgi.com addresses from the kernel tree since they will become invalid on June 27th. Change my maintainer email address for the slab allocators to cl@linux-foundation.org (which will be the new email address for the future). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03slub: Do not use 192 byte sized cache if minimum alignment is 128 byteChristoph Lameter
The 192 byte cache is not necessary if we have a basic alignment of 128 byte. If it would be used then the 192 would be aligned to the next 128 byte boundary which would result in another 256 byte cache. Two 256 kmalloc caches cause sysfs to complain about a duplicate entry. MIPS needs 128 byte aligned kmalloc caches and spits out warnings on boot without this patch. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-22slub: ksize() abuse checksPekka Enberg
Add a WARN_ON for pages that don't have PageSlab nor PageCompound set to catch the worst abusers of ksize() in the kernel. Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-05-08slub: fix atomic usage in any_slab_objects()Benjamin Herrenschmidt
any_slab_objects() does an atomic_read on an atomic_long_t, this fixes it to use atomic_long_read instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02slub: #ifdef simplificationChristoph Lameter
If we make SLUB_DEBUG depend on SYSFS then we can simplify some #ifdefs and avoid others. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-05-02slub: Whitespace cleanup and use of strict_strtoulChristoph Lameter
Fix some issues with wrapping and use strict_strtoul to make parameter passing from sysfs safer. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-05-01remove div_long_long_remRoman Zippel
x86 is the only arch right now, which provides an optimized for div_long_long_rem and it has the downside that one has to be very careful that the divide doesn't overflow. The API is a little akward, as the arguments for the unsigned divide are signed. The signed version also doesn't handle a negative divisor and produces worse code on 64bit archs. There is little incentive to keep this API alive, so this converts the few users to the new API. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
