path: root/mm/slub.c
2009-04-03kmemtrace: trace kfree() calls with NULL or zero-length objectsPekka Enberg
Impact: also output kfree(NULL) entries This patch moves the trace_kfree() calls before the ZERO_OR_NULL_PTR check so that we can trace call-sites that call kfree() with NULL many times which might be an indication of a bug. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237971957.30175.18.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace: use tracepointsEduard - Gabriel Munteanu
kmemtrace now uses tracepoints instead of markers. We no longer need to use format specifiers to pass arguments. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> [ folded: Use the new TP_PROTO and TP_ARGS to fix the build. ] [ folded: fix build when CONFIG_KMEMTRACE is disabled. ] [ folded: define tracepoints when CONFIG_TRACEPOINTS is enabled. ] Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <ae61c0f37156db8ec8dc0d5778018edde60a92e3.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-30Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (33 commits) lockdep: fix deadlock in lockdep_trace_alloc lockdep: annotate reclaim context (__GFP_NOFS), fix SLOB lockdep: annotate reclaim context (__GFP_NOFS), fix lockdep: build fix for !PROVE_LOCKING lockstat: warn about disabled lock debugging lockdep: use stringify.h lockdep: simplify check_prev_add_irq() lockdep: get_user_chars() redo lockdep: simplify get_user_chars() lockdep: add comments to mark_lock_irq() lockdep: remove macro usage from mark_held_locks() lockdep: fully reduce mark_lock_irq() lockdep: merge the !_READ mark_lock_irq() helpers lockdep: merge the _READ mark_lock_irq() helpers lockdep: simplify mark_lock_irq() helpers #3 lockdep: further simplify mark_lock_irq() helpers lockdep: simplify the mark_lock_irq() helpers lockdep: split up mark_lock_irq() lockdep: generate usage strings lockdep: generate the state bit definitions ...
2009-03-24Merge branches 'topic/slob/cleanups', 'topic/slob/fixes', 'topic/slub/core', ↵Pekka Enberg
'topic/slub/cleanups' and 'topic/slub/perf' into for-linus
2009-03-23slub: use get_track()Akinobu Mita
Use get_track() in set_track() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-03-04Merge branch 'core/locking' into tracing/ftraceIngo Molnar
2009-02-25slub: rename calculate_min_partial() to set_min_partial()David Rientjes
As suggested by Christoph Lameter, rename calculate_min_partial() to set_min_partial() as the function doesn't really do any calculations. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-23slub: add min_partial sysfs tunableDavid Rientjes
Now that a cache's min_partial has been moved to struct kmem_cache, it's possible to easily tune it from userspace by adding a sysfs attribute. It may not be desirable to keep a large number of partial slabs around if a cache is used infrequently and memory, especially when constrained by a cgroup, is scarce. It's better to allow userspace to set the minimum policy per cache instead of relying explicitly on kmem_cache_shrink(). The memory savings from simply moving min_partial from struct kmem_cache_node to struct kmem_cache is obviously not significant (unless maybe you're from SGI or something), at the largest it's # allocated caches * (MAX_NUMNODES - 1) * sizeof(unsigned long) The true savings occurs when userspace reduces the number of partial slabs that would otherwise be wasted, especially on machines with a large number of nodes (ia64 with CONFIG_NODES_SHIFT at 10 for default?). As well as the kernel estimates ideal values for n->min_partial and ensures it's within a sane range, userspace has no other input other than writing to /sys/kernel/slab/cache/shrink. There simply isn't any better heuristic to add when calculating the partial values for a better estimate that works for all possible caches. And since it's currently a static value, the user really has no way of reclaiming that wasted space, which can be significant when constrained by a cgroup (either cpusets or, later, memory controller slab limits) without shrinking it entirely. This also allows the user to specify that increased fragmentation and more partial slabs are actually desired to avoid the cost of allocating new slabs at runtime for specific caches. There's also no reason why this should be a per-struct kmem_cache_node value in the first place. You could argue that a machine would have such node size asymmetries that it should be specified on a per-node basis, but we know nobody is doing that right now since it's a purely static value at the moment and there's no convenient way to tune that via slub's sysfs interface. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-23slub: move min_partial to struct kmem_cacheDavid Rientjes
Although it allows for better cacheline use, it is unnecessary to save a copy of the cache's min_partial value in each kmem_cache_node. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-20Merge branch 'for-ingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 into tracing/kmemtrace Conflicts: mm/slub.c
2009-02-20SLUB: Introduce and use SLUB_MAX_SIZE and SLUB_PAGE_SHIFT constantsChristoph Lameter
As a preparational patch to bump up page allocator pass-through threshold, introduce two new constants SLUB_MAX_SIZE and SLUB_PAGE_SHIFT and convert mm/slub.c to use them. Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-20SLUB: Fix default slab order for big object sizesZhang Yanmin
The default order of kmalloc-8192 on 2*4 stoakley is an issue of calculate_order. slab_size order name ------------------------------------------------- 4096 3 sgpool-128 8192 2 kmalloc-8192 16384 3 kmalloc-16384 kmalloc-8192's default order is smaller than sgpool-128's. On 4*4 tigerton machine, a similiar issue appears on another kmem_cache. Function calculate_order uses 'min_objects /= 2;' to shrink. Plus size calculation/checking in slab_order, sometimes above issue appear. Below patch against 2.6.29-rc2 fixes it. I checked the default orders of all kmem_cache and they don't become smaller than before. So the patch wouldn't hurt performance. Signed-off-by Zhang Yanmin <yanmin.zhang@linux.intel.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-14lockdep: annotate reclaim context (__GFP_NOFS)Nick Piggin
Here is another version, with the incremental patch rolled up, and added reclaim context annotation to kswapd, and allocation tracing to slab allocators (which may only ever reach the page allocator in rare cases, so it is good to put annotations here too). Haven't tested this version as such, but it should be getting closer to merge worthy ;) -- After noticing some code in mm/filemap.c accidentally perform a __GFP_FS allocation when it should not have been, I thought it might be a good idea to try to catch this kind of thing with lockdep. I coded up a little idea that seems to work. Unfortunately the system has to actually be in __GFP_FS page reclaim, then take the lock, before it will mark it. But at least that might still be some orders of magnitude more common (and more debuggable) than an actual deadlock condition, so we have some improvement I hope (the concept is no less complete than discovery of a lock's interrupt contexts). I guess we could even do the same thing with __GFP_IO (normal reclaim), and even GFP_NOIO locks too... but filesystems will have the most locks and fiddly code paths, so let's start there and see how it goes. It *seems* to work. I did a quick test. ================================= [ INFO: inconsistent lock state ] 2.6.28-rc6-00007-ged31348-dirty #26 --------------------------------- inconsistent {in-reclaim-W} -> {ov-reclaim-W} usage. modprobe/8526 [HC0[0]:SC0[0]:HE1:SE1] takes: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] {in-reclaim-W} state was registered at: [<ffffffff80267bdb>] __lock_acquire+0x75b/0x1a60 [<ffffffff80268f71>] lock_acquire+0x91/0xc0 [<ffffffff8070f0e1>] mutex_lock_nested+0xb1/0x310 [<ffffffffa002002b>] brd_init+0x2b/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 3929 hardirqs last enabled at (3929): [<ffffffff8070f2b5>] mutex_lock_nested+0x285/0x310 hardirqs last disabled at (3928): [<ffffffff8070f089>] mutex_lock_nested+0x59/0x310 softirqs last enabled at (3732): [<ffffffff8061f623>] sk_filter+0x83/0xe0 softirqs last disabled at (3730): [<ffffffff8061f5b6>] sk_filter+0x16/0xe0 other info that might help us debug this: 1 lock held by modprobe/8526: #0: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] stack backtrace: Pid: 8526, comm: modprobe Not tainted 2.6.28-rc6-00007-ged31348-dirty #26 Call Trace: [<ffffffff80265483>] print_usage_bug+0x193/0x1d0 [<ffffffff80266530>] mark_lock+0xaf0/0xca0 [<ffffffff80266735>] mark_held_locks+0x55/0xc0 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff802667ca>] trace_reclaim_fs+0x2a/0x60 [<ffffffff80285005>] __alloc_pages_internal+0x475/0x580 [<ffffffff8070f29e>] ? mutex_lock_nested+0x26e/0x310 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffffa002006a>] brd_init+0x6a/0x216 [brd] [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff8070f8b9>] ? mutex_unlock+0x9/0x10 [<ffffffff8070f83d>] ? __mutex_unlock_slowpath+0x10d/0x180 [<ffffffff802669ec>] ? trace_hardirqs_on_caller+0x12c/0x190 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-13Merge branches 'tracing/ftrace', 'tracing/ring-buffer', 'tracing/sysprof', ↵Ingo Molnar
'tracing/urgent' and 'linus' into tracing/core
2009-02-12mm: Export symbol ksize()Kirill A. Shutemov
Commit 7b2cd92adc5430b0c1adeb120971852b4ea1ab08 ("crypto: api - Fix zeroing on free") added modular user of ksize(). Export that to fix crypto.ko compilation. Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-03Merge branches 'tracing/ftrace', 'tracing/kmemtrace' and 'linus' into ↵Ingo Molnar
tracing/core
2009-01-28slub: fix per cpu kmem_cache_cpu array memory leakDavid Rientjes
The per cpu array of kmem_cache_cpu structures accomodates NR_KMEM_CACHE_CPU such structs. When this array overflows and a struct is allocated by kmalloc(), it may have an address at the upper bound of this array. If this happens, it does not get freed and the per cpu kmem_cache_cpu_free pointer will be out of bounds after kmem_cache_destroy() or cpu offlining. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-01-14SLUB: Use ->objsize from struct kmem_cache_cpu in slab_free()Pekka Enberg
There's no reason to use ->objsize from struct kmem_cache in slab_free() for the SLAB_DEBUG_OBJECTS case. All it does is generate extra cache pressure as we try very hard not to touch struct kmem_cache in the fast-path. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-01-11Merge commit 'v2.6.29-rc1' into tracing/urgentIngo Molnar
2009-01-06trivial: fix an -> a typos in documentation and commentsFrederik Schwarzer
It is always "an" if there is a vowel _spoken_ (not written). So it is: "an hour" (spoken vowel) but "a uniform" (spoken 'j') Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06Merge branch 'linus' into tracing/kmemtrace2Ingo Molnar
2009-01-01cpumask: convert mm/Rusty Russell
Impact: Use new API Convert kernel mm functions to use struct cpumask. We skip include/linux/percpu.h and mm/allocpercpu.c, which are in flux. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
2008-12-31Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/x86/kernel/io_apic.c
2008-12-31Merge branch 'tracing/kmemtrace' into tracing/kmemtrace2Ingo Molnar
2008-12-31Merge branch 'linus' into tracing/kmemtraceIngo Molnar
2008-12-30tracing/kmemtrace: normalize the raw tracer event to the unified tracing APIFrederic Weisbecker
Impact: new tracer plugin This patch adapts kmemtrace raw events tracing to the unified tracing API. To enable and use this tracer, just do the following: echo kmemtrace > /debugfs/tracing/current_tracer cat /debugfs/tracing/trace You will have the following output: # tracer: kmemtrace # # # ALLOC TYPE REQ GIVEN FLAGS POINTER NODE CALLER # FREE | | | | | | | | # | type_id 1 call_site 18446744071565527833 ptr 18446612134395152256 type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1 type_id 1 call_site 18446744071565585534 ptr 18446612134405955584 type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1 type_id 0 call_site 18446744071565636711 ptr 18446612134345164672 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1 type_id 1 call_site 18446744071565585534 ptr 18446612134405955584 type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1 type_id 0 call_site 18446744071565636711 ptr 18446612134345164912 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1 type_id 1 call_site 18446744071565585534 ptr 18446612134405955584 type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1 type_id 0 call_site 18446744071565636711 ptr 18446612134345165152 bytes_req 240 bytes_alloc 240 gfp_flags 208 node -1 type_id 0 call_site 18446744071566144042 ptr 18446612134346191680 bytes_req 1304 bytes_alloc 1312 gfp_flags 208 node -1 type_id 1 call_site 18446744071565585534 ptr 18446612134405955584 type_id 0 call_site 18446744071565585597 ptr 18446612134405955584 bytes_req 4096 bytes_alloc 4096 gfp_flags 208 node -1 type_id 1 call_site 18446744071565585534 ptr 18446612134405955584 That was to stay backward compatible with the format output produced in inux/tracepoint.h. This is the default ouput, but note that I tried something else. If you change an option: echo kmem_minimalistic > /debugfs/trace_options and then cat /debugfs/trace, you will have the following output: # tracer: kmemtrace # # # ALLOC TYPE REQ GIVEN FLAGS POINTER NODE CALLER # FREE | | | | | | | | # | - C 0xffff88007c088780 file_free_rcu + K 4096 4096 000000d0 0xffff88007cad6000 -1 getname - C 0xffff88007cad6000 putname + K 4096 4096 000000d0 0xffff88007cad6000 -1 getname + K 240 240 000000d0 0xffff8800790dc780 -1 d_alloc - C 0xffff88007cad6000 putname + K 4096 4096 000000d0 0xffff88007cad6000 -1 getname + K 240 240 000000d0 0xffff8800790dc870 -1 d_alloc - C 0xffff88007cad6000 putname + K 4096 4096 000000d0 0xffff88007cad6000 -1 getname + K 240 240 000000d0 0xffff8800790dc960 -1 d_alloc + K 1304 1312 000000d0 0xffff8800791d7340 -1 reiserfs_alloc_inode - C 0xffff88007cad6000 putname + K 4096 4096 000000d0 0xffff88007cad6000 -1 getname - C 0xffff88007cad6000 putname + K 992 1000 000000d0 0xffff880079045b58 -1 alloc_inode + K 768 1024 000080d0 0xffff88007c096400 -1 alloc_pipe_info + K 240 240 000000d0 0xffff8800790dca50 -1 d_alloc + K 272 320 000080d0 0xffff88007c088780 -1 get_empty_filp + K 272 320 000080d0 0xffff88007c088000 -1 get_empty_filp Yeah I shall confess kmem_minimalistic should be: kmem_alternative. Whatever, I find it more readable but this a personal opinion of course. We can drop it if you want. On the ALLOC/FREE column, + means an allocation and - a free. On the type column, you have K = kmalloc, C = cache, P = page I would like the flags to be GFP_* strings but that would not be easy to not break the column with strings.... About the node...it seems to always be -1. I don't know why but that shouldn't be difficult to find. I moved linux/tracepoint.h to trace/tracepoint.h as well. I think that would be more easy to find the tracer headers if they are all in their common directory. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-30kmemtrace: move #include linesIngo Molnar
Impact: avoid conflicts with kmemcheck kmemcheck modifies the same area of slab.c and slub.c - move the include lines up a bit. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-29Merge branch 'topic/kmemtrace' of ↵Ingo Molnar
2008-12-29kmemtrace: remove unnecessary castsPekka Enberg
Now that we use _RET_IP_ there's no need to cast 'caller' to unsigned long. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29kmemtrace: SLUB hooks for caller-tracking functions.Eduard - Gabriel Munteanu
This patch adds kmemtrace hooks for __kmalloc_track_caller() and __kmalloc_node_track_caller(). Currently, they set the call site pointer to the value recieved as a parameter. (This could change if we implement stack trace exporting in kmemtrace.) Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29kmemtrace: SLUB hooks.Eduard - Gabriel Munteanu
This adds hooks for the SLUB allocator, to allow tracing with kmemtrace. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29SLUB: Replace __builtin_return_address(0) with _RET_IP_.Eduard - Gabriel Munteanu
This patch replaces __builtin_return_address(0) with _RET_IP_, since a previous patch moved _RET_IP_ and _THIS_IP_ to include/linux/kernel.h and they're widely available now. This makes for shorter and easier to read code. [penberg@cs.helsinki.fi: remove _RET_IP_ casts to void pointer] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29Merge branch 'topic/failslab' into for-linusPekka Enberg
Conflicts: mm/slub.c Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29Merge branches 'topic/fixes', 'topic/cleanups' and 'topic/documentation' ↵Pekka Enberg
into for-linus
2008-12-29slub: avoid leaking caches or refcounts on sysfs errorDavid Rientjes
If a slab cache is mergeable and the sysfs alias cannot be added, the target cache shall have its refcount decremented. kmem_cache_create() will return NULL, so if kmem_cache_destroy() is ever called on the target cache, it will never be freed if the refcount has been leaked. Likewise, if a slab cache is not mergeable and the sysfs link cannot be added, the new cache shall be removed from the slab_caches list. kmem_cache_create() will return NULL, so it will be impossible to call kmem_cache_destroy() on it. Both of these operations require slub_lock since refcount of all slab caches and slab_caches are protected by the lock. In the mergeable case, it would be better to restore objsize and offset back to their original values, but this could race with another merge since slub_lock was dropped. Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29slub: Add might_sleep_if() to slab_alloc()OGAWA Hirofumi
Currently SLUB doesn't warn about __GFP_WAIT. Add it into slab_alloc(). Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-29SLUB: failslab supportAkinobu Mita
Currently fault-injection capability for SLAB allocator is only available to SLAB. This patch makes it available to SLUB, too. [penberg@cs.helsinki.fi: unify slab and slub implementations] Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-12-10KSYM_SYMBOL_LEN fixesHugh Dickins
Miles Lane tailing /sys files hit a BUG which Pekka Enberg has tracked to my 966c8c12dc9e77f931e2281ba25d2f0244b06949 sprint_symbol(): use less stack exposing a bug in slub's list_locations() - kallsyms_lookup() writes a 0 to namebuf[KSYM_NAME_LEN-1], but that was beyond the end of page provided. The 100 slop which list_locations() allows at end of page looks roughly enough for all the other stuff it might print after the symbol before it checks again: break out KSYM_SYMBOL_LEN earlier than before. Latencytop and ftrace and are using KSYM_NAME_LEN buffers where they need KSYM_SYMBOL_LEN buffers, and vmallocinfo a 2*KSYM_NAME_LEN buffer where it wants a KSYM_SYMBOL_LEN buffer: fix those before anyone copies them. [akpm@linux-foundation.org: ftrace.h needs module.h] Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc Miles Lane <miles.lane@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-08slub: Fix incorrect use of looseNick Andrew
It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-12-01memcg: memory hotplug fix for notifier callbackKAMEZAWA Hiroyuki
Fixes for memcg/memory hotplug. While memory hotplug allocate/free memmap, page_cgroup doesn't free page_cgroup at OFFLINE when page_cgroup is allocated via bootomem. (Because freeing bootmem requires special care.) Then, if page_cgroup is allocated by bootmem and memmap is freed/allocated by memory hotplug, page_cgroup->page == page is no longer true. But current MEM_ONLINE handler doesn't check it and update page_cgroup->page if it's not necessary to allocate page_cgroup. (This was not found because memmap is not freed if SPARSEMEM_VMEMMAP is y.) And I noticed that MEM_ONLINE can be called against "part of section". So, freeing page_cgroup at CANCEL_ONLINE will cause trouble. (freeing used page_cgroup) Don't rollback at CANCEL. One more, current memory hotplug notifier is stopped by slub because it sets NOTIFY_STOP_MASK to return vaule. So, page_cgroup's callback never be called. (low priority than slub now.) I think this slub's behavior is not intentional(BUG). and fixes it. Another way to be considered about page_cgroup allocation: - free page_cgroup at OFFLINE even if it's from bootmem and remove specieal handler. But it requires more changes. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12041 Signed-off-by: KAMEZAWA Hiruyoki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-26slub: make early_kmem_cache_node_alloc voidDavid Rientjes
The return value for early_kmem_cache_node_alloc() is unused, so it is better defined as void. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-26slub - fix get_object_page commentCyrill Gorcunov
Use 'slab page' instead of 'slab object'. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-11-26SLUB: Replace __builtin_return_address(0) with _RET_IP_.Eduard - Gabriel Munteanu
2008-11-26SLUB: cleanup - define macros instead of hardcoded numbersCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-10-23proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.cAlexey Dobriyan
Lose dummy ->write hook in case of SLUB, it's possible now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-09-15slub: fixed uninitialized counter in struct kmem_cache_nodeSalman Qazi
Initialized total objects atomic for the node in init_kmem_cache_node. The uninitialized value was ruining the stats in /proc/slabinfo. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Salman Qazi <sqazi@google.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2008-08-20slub: Disable NUMA remote node defragmentation by defaultChristoph Lameter
Switch remote node defragmentation off by default. The current settings can cause excessive node local allocations with hackbench: SLAB: % cat /proc/meminfo MemTotal: 7701760 kB MemFree: 5940096 kB Slab: 123840 kB SLUB: % cat /proc/meminfo MemTotal: 7701376 kB MemFree: 4740928 kB Slab: 1591680 kB [Note: this feature is not related to slab defragmentation.] You can find the original discussion here: http://lkml.org/lkml/2008/8/4/308 Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
