commit 9b1ea29bc0d7b94d420f96a0f4121403efc3dd85 upstream.
This reverts commit 8ff60eb052eeba95cfb3efe16b08c9199f8121cf.
The kernel test robot reports a huge performance regression due to the
commit, and the reason seems fairly straightforward: when there is
contention on the page list (which is what causes acquire_slab() to
fail), we do _not_ want to just loop and try again, because that will
transfer the contention to the 'n->list_lock' spinlock we hold, and
just make things even worse.
This is admittedly likely a problem only on big machines - the kernel
test robot report comes from a 96-thread dual socket Intel Xeon Gold
6252 setup, but the regression there really is quite noticeable:
-47.9% regression of stress-ng.rawpkt.ops_per_sec
and the commit that was marked as being fixed (7ced37197196: "slub:
Acquire_slab() avoid loop") actually did the loop exit early very
intentionally (the hint being that "avoid loop" part of that commit
message), exactly to avoid this issue.
The correct thing to do may be to pick some kind of reasonable middle
ground: instead of breaking out of the loop on the very first sign of
contention, or trying over and over and over again, the right thing may
be to re-try _once_, and then give up on the second failure (or pick
your favorite value for "once"..).
Reported-by: kernel test robot <oliver.sang@intel.com>
Link: https://lore.kernel.org/lkml/20210301080404.GF12822@xsang-OptiPlex-9020/
Cc: Jann Horn <jannh@google.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Christoph Lameter <cl@linux.com>
commit 757fed1d0898b893d7daa84183947c70f27632f3 upstream.
This reverts commit dde3c6b72a16c2db826f54b2d49bdea26c3534a2.
syzbot report a double-free bug. The following case can cause this bug.
- mm/slab_common.c: create_cache(): if the __kmem_cache_create() fails,
it does:
out_free_cache:
kmem_cache_free(kmem_cache, s);
- but __kmem_cache_create() - at least for slub() - will have done
sysfs_slab_add(s)
-> sysfs_create_group() .. fails ..
-> kobject_del(&s->kobj); .. which frees s ...
We can't remove the kmem_cache_free() in create_cache(), because other
error cases of __kmem_cache_create() do not free this.
So, revert the commit dde3c6b72a16 ("mm/slub: fix a memory leak in
sysfs_slab_add()") to fix this.
Reported-by: syzbot+d0bd96b4696c1ef67991@syzkaller.appspotmail.com
Fixes: dde3c6b72a16 ("mm/slub: fix a memory leak in sysfs_slab_add()")
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Cc: <stable@vger.kernel.org>
commit 8ff60eb052eeba95cfb3efe16b08c9199f8121cf upstream.
acquire_slab() fails if there is contention on the freelist of the page
(probably because some other CPU is concurrently freeing an object from
the page). In that case, it might make sense to look for a different page
(since there might be more remote frees to the page from other CPUs, and
we don't want contention on struct page).
However, the current code accidentally stops looking at the partial list
completely in that case. Especially on kernels without CONFIG_NUMA set,
this means that get_partial() fails and new_slab_objects() falls back to
new_slab(), allocating new pages. This could lead to an unnecessary
increase in memory fragmentation.
Link: https://lkml.kernel.org/r/20201228130853.1871516-1-jannh@google.com
Fixes: 7ced37197196 ("slub: Acquire_slab() avoid loop")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
[ Upstream commit a68ee0573991e90af2f1785db309206408bad3e5 ]
There is no need to copy SLUB_STATS items from root memcg cache to new
memcg cache copies. Doing so could result in stack overruns because the
store function only accepts 0 to clear the stat and returns an error for
everything else while the show method would print out the whole stat.
Then, the mismatch of the lengths returns from show and store methods
happens in memcg_propagate_slab_attrs():
else if (root_cache->max_attr_size < ARRAY_SIZE(mbuf))
buf = mbuf;
max_attr_size is only 2 from slab_attr_store(), then, it uses mbuf[64]
in show_stat() later where a bounch of sprintf() would overrun the stack
variable. Fix it by always allocating a page of buffer to be used in
show_stat() if SLUB_STATS=y which should only be used for debug purpose.
# echo 1 > /sys/kernel/slab/fs_cache/shrink
BUG: KASAN: stack-out-of-bounds in number+0x421/0x6e0
Write of size 1 at addr ffffc900256cfde0 by task kworker/76:0/53251
Hardware name: HPE ProLiant DL385 Gen10/ProLiant DL385 Gen10, BIOS A40 07/10/2019
Workqueue: memcg_kmem_cache memcg_kmem_cache_create_func
Call Trace:
number+0x421/0x6e0
vsnprintf+0x451/0x8e0
sprintf+0x9e/0xd0
show_stat+0x124/0x1d0
alloc_slowpath_show+0x13/0x20
__kmem_cache_create+0x47a/0x6b0
addr ffffc900256cfde0 is located in stack of task kworker/76:0/53251 at offset 0 in frame:
process_one_work+0x0/0xb90
this frame has 1 object:
[32, 72) 'lockdep_map'
Memory state around the buggy address:
ffffc900256cfc80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffffc900256cfd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffffc900256cfd80: 00 00 00 00 00 00 00 00 00 00 00 00 f1 f1 f1 f1
ffffc900256cfe00: 00 00 00 00 00 f2 f2 f2 00 00 00 00 00 00 00 00
ffffc900256cfe80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: __kmem_cache_create+0x6ac/0x6b0
Call Trace:
Fixes: 107dab5c92d5 ("slub: slub-specific propagation changes")
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: Glauber Costa <glauber@scylladb.com>
Link: http://lkml.kernel.org/r/20200429222356.4322-1-cai@lca.pw
commit dde3c6b72a16c2db826f54b2d49bdea26c3534a2 upstream.
syzkaller reports for memory leak when kobject_init_and_add() returns an
error in the function sysfs_slab_add() [1]
When this happened, the function kobject_put() is not called for the
corresponding kobject, which potentially leads to memory leak.
This patch fixes the issue by calling kobject_put() even if
kobject_init_and_add() fails.
[1]
BUG: memory leak
unreferenced object 0xffff8880a6d4be88 (size 8):
comm "syz-executor.3", pid 946, jiffies 4295772514 (age 18.396s)
hex dump (first 8 bytes):
70 69 64 5f 33 00 ff ff pid_3...
backtrace:
kstrdup+0x35/0x70 mm/util.c:60
kstrdup_const+0x3d/0x50 mm/util.c:82
kvasprintf_const+0x112/0x170 lib/kasprintf.c:48
kobject_set_name_vargs+0x55/0x130 lib/kobject.c:289
kobject_add_varg lib/kobject.c:384 [inline]
kobject_init_and_add+0xd8/0x170 lib/kobject.c:473
sysfs_slab_add+0x1d8/0x290 mm/slub.c:5811
__kmem_cache_create+0x50a/0x570 mm/slub.c:4384
create_cache+0x113/0x1e0 mm/slab_common.c:407
kmem_cache_create_usercopy+0x1a1/0x260 mm/slab_common.c:505
kmem_cache_create+0xd/0x10 mm/slab_common.c:564
create_pid_cachep kernel/pid_namespace.c:54 [inline]
create_pid_namespace kernel/pid_namespace.c:96 [inline]
copy_pid_ns+0x77c/0x8f0 kernel/pid_namespace.c:148
create_new_namespaces+0x26b/0xa30 kernel/nsproxy.c:95
unshare_nsproxy_namespaces+0xa7/0x1e0 kernel/nsproxy.c:229
ksys_unshare+0x3d2/0x770 kernel/fork.c:2969
__do_sys_unshare kernel/fork.c:3037 [inline]
__se_sys_unshare kernel/fork.c:3035 [inline]
__x64_sys_unshare+0x2d/0x40 kernel/fork.c:3035
do_syscall_64+0xa1/0x530 arch/x86/entry/common.c:295
Fixes: 80da026a8e5d ("mm/slub: fix slab double-free in case of duplicate sysfs filename")
Link: http://lkml.kernel.org/r/20200602115033.1054-1-wanghai38@huawei.com
commit 0715e6c516f106ed553828a671d30ad9a3431536 upstream.
Sachin reports [1] a crash in SLUB __slab_alloc():
BUG: Kernel NULL pointer dereference on read at 0x000073b0
Faulting instruction address: 0xc0000000003d55f4
Oops: Kernel access of bad area, sig: 11 [#1]
LE PAGE_SIZE=64K MMU=Hash SMP NR_CPUS=2048 NUMA pSeries
Modules linked in:
CPU: 19 PID: 1 Comm: systemd Not tainted 5.6.0-rc2-next-20200218-autotest #1
NIP: c0000000003d55f4 LR: c0000000003d5b94 CTR: 0000000000000000
REGS: c0000008b37836d0 TRAP: 0300 Not tainted (5.6.0-rc2-next-20200218-autotest)
MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 24004844 XER: 00000000
CFAR: c00000000000dec4 DAR: 00000000000073b0 DSISR: 40000000 IRQMASK: 1
GPR00: c0000000003d5b94 c0000008b3783960 c00000000155d400 c0000008b301f500
GPR04: 0000000000000dc0 0000000000000002 c0000000003443d8 c0000008bb398620
GPR08: 00000008ba2f0000 0000000000000001 0000000000000000 0000000000000000
GPR12: 0000000024004844 c00000001ec52a00 0000000000000000 0000000000000000
GPR16: c0000008a1b20048 c000000001595898 c000000001750c18 0000000000000002
GPR20: c000000001750c28 c000000001624470 0000000fffffffe0 5deadbeef0000122
GPR24: 0000000000000001 0000000000000dc0 0000000000000002 c0000000003443d8
GPR28: c0000008b301f500 c0000008bb398620 0000000000000000 c00c000002287180
NIP ___slab_alloc+0x1f4/0x760
LR __slab_alloc+0x34/0x60
Call Trace:
___slab_alloc+0x334/0x760 (unreliable)
__kmalloc_node+0x110/0x490
kvmalloc_node+0x58/0x110
mem_cgroup_css_online+0x108/0x270
online_css+0x48/0xd0
cgroup_apply_control_enable+0x2ec/0x4d0
cgroup_mkdir+0x228/0x5f0
kernfs_iop_mkdir+0x90/0xf0
vfs_mkdir+0x110/0x230
do_mkdirat+0xb0/0x1a0
system_call+0x5c/0x68
This is a PowerPC platform with following NUMA topology:
available: 2 nodes (0-1)
node 0 cpus:
node 0 size: 0 MB
node 0 free: 0 MB
node 1 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
node 1 size: 35247 MB
node 1 free: 30907 MB
node distances:
node 0 1
0: 10 40
1: 40 10
possible numa nodes: 0-31
This only happens with a mmotm patch "mm/memcontrol.c: allocate
shrinker_map on appropriate NUMA node" [2] which effectively calls
kmalloc_node for each possible node. SLUB however only allocates
kmem_cache_node on online N_NORMAL_MEMORY nodes, and relies on
node_to_mem_node to return such valid node for other nodes since commit
a561ce00b09e ("slub: fall back to node_to_mem_node() node if allocating
on memoryless node"). This is however not true in this configuration
where the _node_numa_mem_ array is not initialized for nodes 0 and 2-31,
thus it contains zeroes and get_partial() ends up accessing
non-allocated kmem_cache_node.
A related issue was reported by Bharata (originally by Ramachandran) [3]
where a similar PowerPC configuration, but with mainline kernel without
patch [2] ends up allocating large amounts of pages by kmalloc-1k
kmalloc-512. This seems to have the same underlying issue with
node_to_mem_node() not behaving as expected, and might probably also
lead to an infinite loop with CONFIG_SLUB_CPU_PARTIAL [4].
This patch should fix both issues by not relying on node_to_mem_node()
anymore and instead simply falling back to NUMA_NO_NODE, when
kmalloc_node(node) is attempted for a node that's not online, or has no
usable memory. The "usable memory" condition is also changed from
node_present_pages() to N_NORMAL_MEMORY node state, as that is exactly
the condition that SLUB uses to allocate kmem_cache_node structures.
The check in get_partial() is removed completely, as the checks in
___slab_alloc() are now sufficient to prevent get_partial() being
reached with an invalid node.
[1] https://lore.kernel.org/linux-next/3381CD91-AB3D-4773-BA04-E7A072A63968@linux.vnet.ibm.com/
[2] https://lore.kernel.org/linux-mm/fff0e636-4c36-ed10-281c-8cdb0687c839@virtuozzo.com/
[3] https://lore.kernel.org/linux-mm/20200317092624.GB22538@in.ibm.com/
[4] https://lore.kernel.org/linux-mm/088b5996-faae-8a56-ef9c-5b567125ae54@suse.cz/
Fixes: a561ce00b09e ("slub: fall back to node_to_mem_node() node if allocating on memoryless node")
Reported-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
Reported-by: PUVICHAKRAVARTHY RAMACHANDRAN <puvichakravarthy@in.ibm.com>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Tested-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
Tested-by: Bharata B Rao <bharata@linux.ibm.com>
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Christopher Lameter <cl@linux.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Nathan Lynch <nathanl@linux.ibm.com>
Link: http://lkml.kernel.org/r/20200320115533.9604-1-vbabka@suse.cz
Debugged-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
commit 5076190daded2197f62fe92cf69674488be44175 upstream.
This is just a cleanup addition to Jann's fix to properly update the
transaction ID for the slub slowpath in commit fd4d9c7d0c71 ("mm: slub:
add missing TID bump..").
The transaction ID is what protects us against any concurrent accesses,
but we should really also make sure to make the 'freelist' comparison
itself always use the same freelist value that we then used as the new
next free pointer.
Jann points out that if we do all of this carefully, we could skip the
transaction ID update for all the paths that only remove entries from
the lists, and only update the TID when adding entries (to avoid the ABA
issue with cmpxchg and list handling re-adding a previously seen value).
But this patch just does the "make sure to cmpxchg the same value we
used" rather than then try to be clever.
Acked-by: Jann Horn <jannh@google.com>
commit fd4d9c7d0c71866ec0c2825189ebd2ce35bd95b8 upstream.
When kmem_cache_alloc_bulk() attempts to allocate N objects from a percpu
freelist of length M, and N > M > 0, it will first remove the M elements
from the percpu freelist, then call ___slab_alloc() to allocate the next
element and repopulate the percpu freelist. ___slab_alloc() can re-enable
IRQs via allocate_slab(), so the TID must be bumped before ___slab_alloc()
to properly commit the freelist head change.
Fix it by unconditionally bumping c->tid when entering the slowpath.
Cc: stable@vger.kernel.org
Fixes: ebe909e0fdb3 ("slub: improve bulk alloc strategy")
commit e4f8e513c3d353c134ad4eef9fd0bba12406c7c8 upstream.
A long time ago we fixed a similar deadlock in show_slab_objects() [1].
However, it is apparently due to the commits like 01fb58bcba63 ("slab:
remove synchronous synchronize_sched() from memcg cache deactivation
path") and 03afc0e25f7f ("slab: get_online_mems for
kmem_cache_{create,destroy,shrink}"), this kind of deadlock is back by
just reading files in /sys/kernel/slab which will generate a lockdep
splat below.
Since the "mem_hotplug_lock" here is only to obtain a stable online node
mask while racing with NUMA node hotplug, in the worst case, the results
may me miscalculated while doing NUMA node hotplug, but they shall be
corrected by later reads of the same files.
WARNING: possible circular locking dependency detected
cat/5224 is trying to acquire lock:
ffff900012ac3120 (mem_hotplug_lock.rw_sem){++++}, at:
show_slab_objects+0x94/0x3a8
but task is already holding lock:
b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (kn->count#45){++++}:
lock_acquire+0x31c/0x360
__kernfs_remove+0x290/0x490
kernfs_remove+0x30/0x44
sysfs_remove_dir+0x70/0x88
kobject_del+0x50/0xb0
sysfs_slab_unlink+0x2c/0x38
shutdown_cache+0xa0/0xf0
kmemcg_cache_shutdown_fn+0x1c/0x34
kmemcg_workfn+0x44/0x64
process_one_work+0x4f4/0x950
worker_thread+0x390/0x4bc
kthread+0x1cc/0x1e8
ret_from_fork+0x10/0x18
-> #1 (slab_mutex){+.+.}:
__mutex_lock_common+0x16c/0xf78
mutex_lock_nested+0x40/0x50
memcg_create_kmem_cache+0x38/0x16c
memcg_kmem_cache_create_func+0x3c/0x70
kthread+0x1cc/0x1e8
-> #0 (mem_hotplug_lock.rw_sem){++++}:
validate_chain+0xd10/0x2bcc
__lock_acquire+0x7f4/0xb8c
get_online_mems+0x54/0x150
total_objects_show+0x28/0x34
slab_attr_show+0x38/0x54
sysfs_kf_seq_show+0x198/0x2d4
kernfs_seq_show+0xa4/0xcc
seq_read+0x30c/0x8a8
kernfs_fop_read+0xa8/0x314
__vfs_read+0x88/0x20c
vfs_read+0xd8/0x10c
ksys_read+0xb0/0x120
__arm64_sys_read+0x54/0x88
el0_svc_handler+0x170/0x240
el0_svc+0x8/0xc
Chain exists of:
mem_hotplug_lock.rw_sem --> slab_mutex --> kn->count#45
Possible unsafe locking scenario:
CPU0 CPU1
lock(kn->count#45);
lock(slab_mutex);
lock(kn->count#45);
lock(mem_hotplug_lock.rw_sem);
*** DEADLOCK ***
3 locks held by cat/5224:
#0: 9eff00095b14b2a0 (&p->lock){+.+.}, at: seq_read+0x4c/0x8a8
#1: 0eff008997041480 (&of->mutex){+.+.}, at: kernfs_seq_start+0x34/0xf0
#2: b8ff009693eee398 (kn->count#45){++++}, at:
stack backtrace:
Call trace:
dump_backtrace+0x0/0x248
show_stack+0x20/0x2c
dump_stack+0xd0/0x140
print_circular_bug+0x368/0x380
check_noncircular+0x248/0x250
vfs_read+0xd8/0x10c
el0_svc+0x8/0xc
I think it is important to mention that this doesn't expose the
show_slab_objects to use-after-free. There is only a single path that
might really race here and that is the slab hotplug notifier callback
__kmem_cache_shrink (via slab_mem_going_offline_callback) but that path
doesn't really destroy kmem_cache_node data structures.
[1] http://lkml.iu.edu/hypermail/linux/kernel/1101.0/02850.html
[akpm@linux-foundation.org: add comment explaining why we don't need mem_hotplug_lock]
Link: http://lkml.kernel.org/r/1570192309-10132-1-git-send-email-cai@lca.pw
Fixes: 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path")
Fixes: 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}")
Cc: Tejun Heo <tj@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Roman Gushchin <guro@fb.com>
commit e5d9998f3e09359b372a037a6ac55ba235d95d57 upstream.
* cpu_partial determined the maximum number of objects
* kept in the per cpu partial lists of a processor.
Can't be negative.
Link: http://lkml.kernel.org/r/20180305200730.15812-15-adobriyan@gmail.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
[ Upstream commit a38965bf941b7c2af50de09c96bc5f03e136caef ]
__printf is useful to verify format and arguments. Remove the following
warning (with W=1):
mm/slub.c:721:2: warning: function might be possible candidate for `gnu_printf' format attribute [-Wsuggest-attribute=format]
Link: http://lkml.kernel.org/r/20180505200706.19986-1-malat@debian.org
Signed-off-by: Mathieu Malaterre <malat@debian.org>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
commit 478fe3037b2278d276d4cd9cd0ab06c4cb2e9b32 upstream.
memcg_propagate_slab_attrs() abuses the sysfs attribute file functions
to propagate settings from the root kmem_cache to a newly created
kmem_cache. It does that with:
attr->show(root, buf);
attr->store(new, buf, strlen(bug);
Aside of being a lazy and absurd hackery this is broken because it does
not check the return value of the show() function.
Some of the show() functions return 0 w/o touching the buffer. That
means in such a case the store function is called with the stale content
of the previous show(). That causes nonsense like invoking
kmem_cache_shrink() on a newly created kmem_cache. In the worst case it
would cause handing in an uninitialized buffer.
This should be rewritten proper by adding a propagate() callback to
those slub_attributes which must be propagated and avoid that insane
conversion to and from ASCII, but that's too large for a hot fix.
Check at least the return value of the show() function, so calling
store() with stale content is prevented.
Steven said:
"It can cause a deadlock with get_online_cpus() that has been uncovered
by recent cpu hotplug and lockdep changes that Thomas and Peter have
been doing.
CPU0 CPU1
lock(cpu_hotplug.lock);
lock(slab_mutex);
lock(slab_mutex);
*** DEADLOCK ***"
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705201244540.2255@nanos
Reported-by: Steven Rostedt <rostedt@goodmis.org>
commit 376bf125ac781d32e202760ed7deb1ae4ed35d31 upstream.
This change is primarily an attempt to make it easier to realize the
optimizations the compiler performs in-case CONFIG_MEMCG_KMEM is not
enabled.
Performance wise, even when CONFIG_MEMCG_KMEM is compiled in, the
overhead is zero. This is because, as long as no process have enabled
kmem cgroups accounting, the assignment is replaced by asm-NOP
operations. This is possible because memcg_kmem_enabled() uses a
static_key_false() construct.
It also helps readability as it avoid accessing the p[] array like:
p[size - 1] which "expose" that the array is processed backwards inside
helper function build_detached_freelist().
Lastly this also makes the code more robust, in error case like passing
NULL pointers in the array. Which were previously handled before commit
033745189b1b ("slub: add missing kmem cgroup support to
kmem_cache_free_bulk").
Fixes: 033745189b1b ("slub: add missing kmem cgroup support to kmem_cache_free_bulk")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
Adjust kmem_cache_alloc_bulk API before we have any real users.
Adjust API to return type 'int' instead of previously type 'bool'. This
is done to allow future extension of the bulk alloc API.
A future extension could be to allow SLUB to stop at a page boundary, when
specified by a flag, and then return the number of objects.
The advantage of this approach, would make it easier to make bulk alloc
run without local IRQs disabled. With an approach of cmpxchg "stealing"
the entire c->freelist or page->freelist. To avoid overshooting we would
stop processing at a slab-page boundary. Else we always end up returning
some objects at the cost of another cmpxchg.
To keep compatible with future users of this API linking against an older
kernel when using the new flag, we need to return the number of allocated
objects with this API change.
Initial implementation missed support for kmem cgroup support in
kmem_cache_free_bulk() call, add this.
If CONFIG_MEMCG_KMEM is not enabled, the compiler should be smart enough
to not add any asm code.
Incoming bulk free objects can belong to different kmem cgroups, and
object free call can happen at a later point outside memcg context. Thus,
we need to keep the orig kmem_cache, to correctly verify if a memcg object
match against its "root_cache" (s->memcg_params.root_cache).
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
The call slab_pre_alloc_hook() interacts with kmemgc and is not allowed to
be called several times inside the bulk alloc for loop, due to the call to
memcg_kmem_get_cache().
This would result in hitting the VM_BUG_ON in __memcg_kmem_get_cache.
As suggested by Vladimir Davydov, change slab_post_alloc_hook() to be able
to handle an array of objects.
A subtle detail is, loop iterator "i" in slab_post_alloc_hook() must have
same type (size_t) as size argument. This helps the compiler to easier
realize that it can remove the loop, when all debug statements inside loop
evaluates to nothing. Note, this is only an issue because the kernel is
compiled with GCC option: -fno-strict-overflow
In slab_alloc_node() the compiler inlines and optimizes the invocation of
slab_post_alloc_hook(s, flags, 1, &object) by removing the loop and access
object directly.
Reported-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com>
This change focus on improving the speed of object freeing in the
"slowpath" of kmem_cache_free_bulk.
The calls slab_free (fastpath) and __slab_free (slowpath) have been
extended with support for bulk free, which amortize the overhead of
the (locked) cmpxchg_double.
To use the new bulking feature, we build what I call a detached
freelist. The detached freelist takes advantage of three properties:
1) the free function call owns the object that is about to be freed,
thus writing into this memory is synchronization-free.
2) many freelist's can co-exist side-by-side in the same slab-page
each with a separate head pointer.
3) it is the visibility of the head pointer that needs synchronization.
Given these properties, the brilliant part is that the detached
freelist can be constructed without any need for synchronization. The
freelist is constructed directly in the page objects, without any
synchronization needed. The detached freelist is allocated on the
stack of the function call kmem_cache_free_bulk. Thus, the freelist
head pointer is not visible to other CPUs.
All objects in a SLUB freelist must belong to the same slab-page.
Thus, constructing the detached freelist is about matching objects
that belong to the same slab-page. The bulk free array is scanned is
a progressive manor with a limited look-ahead facility.
Kmem debug support is handled in call of slab_free().
Notice kmem_cache_free_bulk no longer need to disable IRQs. This
only slowed down single free bulk with approx 3 cycles.
Performance data:
Benchmarked[1] obj size 256 bytes on CPU i7-4790K @ 4.00GHz
SLUB fastpath single object quick reuse: 47 cycles(tsc) 11.931 ns
To get stable and comparable numbers, the kernel have been booted with
"slab_merge" (this also improve performance for larger bulk sizes).
Performance data, compared against fallback bulking:
bulk - fallback bulk - improvement with this patch
1 - 62 cycles(tsc) 15.662 ns - 49 cycles(tsc) 12.407 ns- improved 21.0%
2 - 55 cycles(tsc) 13.935 ns - 30 cycles(tsc) 7.506 ns - improved 45.5%
3 - 53 cycles(tsc) 13.341 ns - 23 cycles(tsc) 5.865 ns - improved 56.6%
4 - 52 cycles(tsc) 13.081 ns - 20 cycles(tsc) 5.048 ns - improved 61.5%
8 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.659 ns - improved 64.0%
16 - 49 cycles(tsc) 12.412 ns - 17 cycles(tsc) 4.495 ns - improved 65.3%
30 - 49 cycles(tsc) 12.484 ns - 18 cycles(tsc) 4.533 ns - improved 63.3%
32 - 50 cycles(tsc) 12.627 ns - 18 cycles(tsc) 4.707 ns - improved 64.0%
34 - 96 cycles(tsc) 24.243 ns - 23 cycles(tsc) 5.976 ns - improved 76.0%
48 - 83 cycles(tsc) 20.818 ns - 21 cycles(tsc) 5.329 ns - improved 74.7%
64 - 74 cycles(tsc) 18.700 ns - 20 cycles(tsc) 5.127 ns - improved 73.0%
128 - 90 cycles(tsc) 22.734 ns - 27 cycles(tsc) 6.833 ns - improved 70.0%
158 - 99 cycles(tsc) 24.776 ns - 30 cycles(tsc) 7.583 ns - improved 69.7%
250 - 104 cycles(tsc) 26.089 ns - 37 cycles(tsc) 9.280 ns - improved 64.4%
Performance data, compared current in-kernel bulking:
bulk - curr in-kernel - improvement with this patch
1 - 46 cycles(tsc) - 49 cycles(tsc) - improved (cycles:-3) -6.5%
2 - 27 cycles(tsc) - 30 cycles(tsc) - improved (cycles:-3) -11.1%
3 - 21 cycles(tsc) - 23 cycles(tsc) - improved (cycles:-2) -9.5%
4 - 18 cycles(tsc) - 20 cycles(tsc) - improved (cycles:-2) -11.1%
8 - 17 cycles(tsc) - 18 cycles(tsc) - improved (cycles:-1) -5.9%
16 - 18 cycles(tsc) - 17 cycles(tsc) - improved (cycles: 1) 5.6%
30 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
32 - 18 cycles(tsc) - 18 cycles(tsc) - improved (cycles: 0) 0.0%
34 - 78 cycles(tsc) - 23 cycles(tsc) - improved (cycles:55) 70.5%
48 - 60 cycles(tsc) - 21 cycles(tsc) - improved (cycles:39) 65.0%
64 - 49 cycles(tsc) - 20 cycles(tsc) - improved (cycles:29) 59.2%
128 - 69 cycles(tsc) - 27 cycles(tsc) - improved (cycles:42) 60.9%
158 - 79 cycles(tsc) - 30 cycles(tsc) - improved (cycles:49) 62.0%
250 - 86 cycles(tsc) - 37 cycles(tsc) - improved (cycles:49) 57.0%
Performance with normal SLUB merging is significantly slower for
larger bulking. This is believed to (primarily) be an effect of not
having to share the per-CPU data-structures, as tuning per-CPU size
can achieve similar performance.
bulk - slab_nomerge - normal SLUB merge
1 - 49 cycles(tsc) - 49 cycles(tsc) - merge slower with cycles:0
2 - 30 cycles(tsc) - 30 cycles(tsc) - merge slower with cycles:0
3 - 23 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:0
4 - 20 cycles(tsc) - 20 cycles(tsc) - merge slower with cycles:0
8 - 18 cycles(tsc) - 18 cycles(tsc) - merge slower with cycles:0
16 - 17 cycles(tsc) - 17 cycles(tsc) - merge slower with cycles:0
30 - 18 cycles(tsc) - 23 cycles(tsc) - merge slower with cycles:5
32 - 18 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:4
34 - 23 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:-1
48 - 21 cycles(tsc) - 22 cycles(tsc) - merge slower with cycles:1
64 - 20 cycles(tsc) - 48 cycles(tsc) - merge slower with cycles:28
128 - 27 cycles(tsc) - 57 cycles(tsc) - merge slower with cycles:30
158 - 30 cycles(tsc) - 59 cycles(tsc) - merge slower with cycles:29
250 - 37 cycles(tsc) - 56 cycles(tsc) - merge slower with cycles:19
Joint work with Alexander Duyck.
[1] https://github.com/netoptimizer/prototype-kernel/blob/master/kernel/mm/slab_bulk_test01.c
[akpm@linux-foundation.org: BUG_ON -> WARN_ON;return]
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Make it possible to free a freelist with several objects by adjusting API
of slab_free() and __slab_free() to have head, tail and an objects counter
(cnt).
Tail being NULL indicate single object free of head object. This allow
compiler inline constant propagation in slab_free() and
slab_free_freelist_hook() to avoid adding any overhead in case of single
object free.
This allows a freelist with several objects (all within the same
slab-page) to be free'ed using a single locked cmpxchg_double in
__slab_free() and with an unlocked cmpxchg_double in slab_free().
Object debugging on the free path is also extended to handle these
freelists. When CONFIG_SLUB_DEBUG is enabled it will also detect if
objects don't belong to the same slab-page.
These changes are needed for the next patch to bulk free the detached
freelists it introduces and constructs.
Micro benchmarking showed no performance reduction due to this change,
when debugging is turned off (compiled with CONFIG_SLUB_DEBUG).
The #ifdef of CONFIG_SLUB_DEBUG is located very far from the associated
#else. For readability mark it with a comment.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Use the new function that can do allocation while interrupts are disabled.
Avoids irq on/off sequences.
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Bulk alloc needs a function like that because it enables interrupts before
calling __slab_alloc which promptly disables them again using the expensive
local_irq_save().
We have properly typed page->rcu_head, no need to cast page->lru.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Vitaly Wool <vitalywool@gmail.com>
It's recommended to have slub's user tracking enabled with CONFIG_KASAN,
because:
a) User tracking disables slab merging which improves
detecting out-of-bounds accesses.
b) User tracking metadata acts as redzone which also improves
c) User tracking provides additional information about object.
This information helps to understand bugs.
Currently it is not enabled by default. Besides recompiling the kernel
with KASAN and reinstalling it, user also have to change the boot cmdline,
which is not very handy.
Enable slub user tracking by default with KASAN=y, since there is no good
reason to not do this.
[akpm@linux-foundation.org: little fixes, per David]
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
We have memcg_kmem_charge and memcg_kmem_uncharge methods for charging and
uncharging kmem pages to memcg, but currently they are not used for
charging slab pages (i.e. they are only used for charging pages allocated
with alloc_kmem_pages). The only reason why the slab subsystem uses
special helpers, memcg_charge_slab and memcg_uncharge_slab, is that it
needs to charge to the memcg of kmem cache while memcg_charge_kmem charges
to the memcg that the current task belongs to.
To remove this diversity, this patch adds an extra argument to
__memcg_kmem_charge that can be a pointer to a memcg or NULL. If it is
not NULL, the function tries to charge to the memcg it points to,
otherwise it charge to the current context. Next, it makes the slab
subsystem use this function to charge slab pages.
Since memcg_charge_kmem and memcg_uncharge_kmem helpers are now used only
in __memcg_kmem_charge and __memcg_kmem_uncharge, they are inlined. Since
__memcg_kmem_charge stores a pointer to the memcg in the page struct, we
don't need memcg_uncharge_slab anymore and can use free_kmem_pages.
Besides, one can now detect which memcg a slab page belongs to by reading
/proc/kpagecgroup.
Note, this patch switches slab to charge-after-alloc design. Since this
design is already used for all other memcg charges, it should not make any
difference.
[hannes@cmpxchg.org: better to have an outer function than a magic parameter for the memcg lookup]
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
In slub_order(), the order starts from max(min_order,
get_order(min_objects * size)). When (min_objects * size) has different
order from (min_objects * size + reserved), it will skip this order via a
check in the loop.
This patch optimizes this a little by calculating the start order with
`reserved' in consideration and removing the check in loop.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
get_order() is more easy to understand.
This patch just replaces it.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
In calculate_order(), it tries to calculate the best order by adjusting
the fraction and min_objects. On each iteration on min_objects, fraction
iterates on 16, 8, 4. Which means the acceptable waste increases with
1/16, 1/8, 1/4.
This patch corrects the comment according to the code.
alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page
allocator: do not check NUMA node ID when the caller knows the node is
valid") as an optimized variant of alloc_pages_node(), that doesn't
fallback to current node for nid == NUMA_NO_NODE. Unfortunately the
name of the function can easily suggest that the allocation is
restricted to the given node and fails otherwise. In truth, the node is
only preferred, unless __GFP_THISNODE is passed among the gfp flags.
The misleading name has lead to mistakes in the past, see for example
commits 5265047ac301 ("mm, thp: really limit transparent hugepage
allocation to local node") and b360edb43f8e ("mm, mempolicy:
migrate_to_node should only migrate to node").
Another issue with the name is that there's a family of
alloc_pages_exact*() functions where 'exact' means exact size (instead
of page order), which leads to more confusion.
To prevent further mistakes, this patch effectively renames
alloc_pages_exact_node() to __alloc_pages_node() to better convey that
it's an optimized variant of alloc_pages_node() not intended for general
usage. Both functions get described in comments.
It has been also considered to really provide a convenience function for
allocations restricted to a node, but the major opinion seems to be that
__GFP_THISNODE already provides that functionality and we shouldn't
duplicate the API needlessly. The number of users would be small
anyway.
Existing callers of alloc_pages_exact_node() are simply converted to
call __alloc_pages_node(), with the exception of sba_alloc_coherent()
which open-codes the check for NUMA_NO_NODE, so it is converted to use
alloc_pages_node() instead. This means it no longer performs some
VM_BUG_ON checks, and since the current check for nid in
alloc_pages_node() uses a 'nid < 0' comparison (which includes
NUMA_NO_NODE), it may hide wrong values which would be previously
exposed.
Both differences will be rectified by the next patch.
To sum up, this patch makes no functional changes, except temporarily
hiding potentially buggy callers. Restricting the checks in
alloc_pages_node() is left for the next patch which can in turn expose
more existing buggy callers.
Acked-by: Robin Holt <robinmholt@gmail.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Cliff Whickman <cpw@sgi.com>
Description is almost copied from commit fb05e7a89f50 ("net: don't wait
for order-3 page allocation").
I saw excessive direct memory reclaim/compaction triggered by slub. This
causes performance issues and add latency. Slub uses high-order
allocation to reduce internal fragmentation and management overhead. But,
direct memory reclaim/compaction has high overhead and the benefit of
high-order allocation can't compensate the overhead of both work.
This patch makes auxiliary high-order allocation atomic. If there is no
memory pressure and memory isn't fragmented, the alloction will still
success, so we don't sacrifice high-order allocation's benefit here. If
the atomic allocation fails, direct memory reclaim/compaction will not be
triggered, allocation fallback to low-order immediately, hence the direct
memory reclaim/compaction overhead is avoided. In the allocation failure
case, kswapd is waken up and trying to make high-order freepages, so
allocation could success next time.
Following is the test to measure effect of this patch.
System: QEMU, CPU 8, 512 MB
Mem: 25% memory is allocated at random position to make fragmentation.
Memory-hogger occupies 150 MB memory.
Workload: hackbench -g 20 -l 1000
Average result by 10 runs (Base va Patched)
elapsed_time(s): 4.3468 vs 2.9838
compact_stall: 461.7 vs 73.6
pgmigrate_success: 28315.9 vs 7256.1
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Shaohua Li <shli@fb.com>
Cc: Eric Dumazet <edumazet@google.com>
sysfs_slab_add() shouldn't call kobject_put at error path: this puts last
reference of kmem-cache kobject and frees it. Kmem cache will be freed
second time at error path in kmem_cache_create().
For example this happens when slub debug was enabled in runtime and
somebody creates new kmem cache:
# echo 1 | tee /sys/kernel/slab/*/sanity_checks
# modprobe configfs
"configfs_dir_cache" cannot be merged because existing slab have debug and
cannot create new slab because unique name ":t-0000096" already taken.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Initializing a new slab can introduce rather large latencies because most
of the initialization runs always with interrupts disabled.
There is no point in doing so. The newly allocated slab is not visible
yet, so there is no reason to protect it against concurrent alloc/free.
Move the expensive parts of the initialization into allocate_slab(), so
for all allocations with GFP_WAIT set, interrupts are enabled.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Per request of Joonsoo Kim adding kmem debug support.
I've tested that when debugging is disabled, then there is almost no
performance impact as this code basically gets removed by the compiler.
Need some guidance in enabling and testing this.
bulk- PREVIOUS - THIS-PATCH
1 - 43 cycles(tsc) 10.811 ns - 44 cycles(tsc) 11.236 ns improved -2.3%
2 - 27 cycles(tsc) 6.867 ns - 28 cycles(tsc) 7.019 ns improved -3.7%
3 - 21 cycles(tsc) 5.496 ns - 22 cycles(tsc) 5.526 ns improved -4.8%
4 - 24 cycles(tsc) 6.038 ns - 19 cycles(tsc) 4.786 ns improved 20.8%
8 - 17 cycles(tsc) 4.280 ns - 18 cycles(tsc) 4.572 ns improved -5.9%
16 - 17 cycles(tsc) 4.483 ns - 18 cycles(tsc) 4.658 ns improved -5.9%
30 - 18 cycles(tsc) 4.531 ns - 18 cycles(tsc) 4.568 ns improved 0.0%
32 - 58 cycles(tsc) 14.586 ns - 65 cycles(tsc) 16.454 ns improved -12.1%
34 - 53 cycles(tsc) 13.391 ns - 63 cycles(tsc) 15.932 ns improved -18.9%
48 - 65 cycles(tsc) 16.268 ns - 50 cycles(tsc) 12.506 ns improved 23.1%
64 - 53 cycles(tsc) 13.440 ns - 63 cycles(tsc) 15.929 ns improved -18.9%
128 - 79 cycles(tsc) 19.899 ns - 86 cycles(tsc) 21.583 ns improved -8.9%
158 - 90 cycles(tsc) 22.732 ns - 90 cycles(tsc) 22.552 ns improved 0.0%
250 - 95 cycles(tsc) 23.916 ns - 98 cycles(tsc) 24.589 ns improved -3.2%
This implements SLUB specific kmem_cache_free_bulk(). SLUB allocator now
both have bulk alloc and free implemented.
Choose to reenable local IRQs while calling slowpath __slab_free(). In
worst case, where all objects hit slowpath call, the performance should
still be faster than fallback function __kmem_cache_free_bulk(), because
local_irq_{disable+enable} is very fast (7-cycles), while the fallback
invokes this_cpu_cmpxchg() which is slightly slower (9-cycles).
Nitpicking, this should be faster for N>=4, due to the entry cost of
local_irq_{disable+enable}.
Do notice that the save+restore variant is very expensive, this is key to
why this optimization works.
CPU: i7-4790K CPU @ 4.00GHz
* local_irq_{disable,enable}: 7 cycles(tsc) - 1.821 ns
* local_irq_{save,restore} : 37 cycles(tsc) - 9.443 ns
Measurements on CPU CPU i7-4790K @ 4.00GHz
Baseline normal fastpath (alloc+free cost): 43 cycles(tsc) 10.834 ns
Bulk- fallback - this-patch
1 - 58 cycles(tsc) 14.542 ns - 43 cycles(tsc) 10.811 ns improved 25.9%
2 - 50 cycles(tsc) 12.659 ns - 27 cycles(tsc) 6.867 ns improved 46.0%
3 - 48 cycles(tsc) 12.168 ns - 21 cycles(tsc) 5.496 ns improved 56.2%
4 - 47 cycles(tsc) 11.987 ns - 24 cycles(tsc) 6.038 ns improved 48.9%
8 - 46 cycles(tsc) 11.518 ns - 17 cycles(tsc) 4.280 ns improved 63.0%
16 - 45 cycles(tsc) 11.366 ns - 17 cycles(tsc) 4.483 ns improved 62.2%
30 - 45 cycles(tsc) 11.433 ns - 18 cycles(tsc) 4.531 ns improved 60.0%
32 - 75 cycles(tsc) 18.983 ns - 58 cycles(tsc) 14.586 ns improved 22.7%
34 - 71 cycles(tsc) 17.940 ns - 53 cycles(tsc) 13.391 ns improved 25.4%
48 - 80 cycles(tsc) 20.077 ns - 65 cycles(tsc) 16.268 ns improved 18.8%
64 - 71 cycles(tsc) 17.799 ns - 53 cycles(tsc) 13.440 ns improved 25.4%
128 - 91 cycles(tsc) 22.980 ns - 79 cycles(tsc) 19.899 ns improved 13.2%
158 - 100 cycles(tsc) 25.241 ns - 90 cycles(tsc) 22.732 ns improved 10.0%
250 - 102 cycles(tsc) 25.583 ns - 95 cycles(tsc) 23.916 ns improved 6.9%
Call slowpath __slab_alloc() from within the bulk loop, as the side-effect
of this call likely repopulates c->freelist.
Choose to reenable local IRQs while calling slowpath.
Saving some optimizations for later. E.g. it is possible to extract
parts of __slab_alloc() and avoid the unnecessary and expensive (37
cycles) local_irq_{save,restore}. For now, be happy calling
__slab_alloc() this lower icache impact of this func and I don't have to
worry about correctness.
Baseline normal fastpath (alloc+free cost): 42 cycles(tsc) 10.601 ns
1 - 58 cycles(tsc) 14.516 ns - 49 cycles(tsc) 12.459 ns improved 15.5%
2 - 51 cycles(tsc) 12.930 ns - 38 cycles(tsc) 9.605 ns improved 25.5%
3 - 49 cycles(tsc) 12.274 ns - 34 cycles(tsc) 8.525 ns improved 30.6%
4 - 48 cycles(tsc) 12.058 ns - 32 cycles(tsc) 8.036 ns improved 33.3%
8 - 46 cycles(tsc) 11.609 ns - 31 cycles(tsc) 7.756 ns improved 32.6%
16 - 45 cycles(tsc) 11.451 ns - 32 cycles(tsc) 8.148 ns improved 28.9%
30 - 79 cycles(tsc) 19.865 ns - 68 cycles(tsc) 17.164 ns improved 13.9%
32 - 76 cycles(tsc) 19.212 ns - 66 cycles(tsc) 16.584 ns improved 13.2%
34 - 74 cycles(tsc) 18.600 ns - 63 cycles(tsc) 15.954 ns improved 14.9%
48 - 88 cycles(tsc) 22.092 ns - 77 cycles(tsc) 19.373 ns improved 12.5%
64 - 80 cycles(tsc) 20.043 ns - 68 cycles(tsc) 17.188 ns improved 15.0%
128 - 99 cycles(tsc) 24.818 ns - 89 cycles(tsc) 22.404 ns improved 10.1%
158 - 99 cycles(tsc) 24.977 ns - 92 cycles(tsc) 23.089 ns improved 7.1%
250 - 106 cycles(tsc) 26.552 ns - 99 cycles(tsc) 24.785 ns improved 6.6%
First piece: acceleration of retrieval of per cpu objects
If we are allocating lots of objects then it is advantageous to disable
interrupts and avoid the this_cpu_cmpxchg() operation to get these objects
faster.
Note that we cannot do the fast operation if debugging is enabled, because
we would have to add extra code to do all the debugging checks. And it
would not be fast anyway.
Note also that the requirement of having interrupts disabled avoids having
to do processor flag operations.
Allocate as many objects as possible in the fast way and then fall back to
the generic implementation for the rest of the objects.
Baseline normal fastpath (alloc+free cost): 42 cycles(tsc) 10.554 ns
1 - 57 cycles(tsc) 14.432 ns - 48 cycles(tsc) 12.155 ns improved 15.8%
2 - 50 cycles(tsc) 12.746 ns - 37 cycles(tsc) 9.390 ns improved 26.0%
3 - 48 cycles(tsc) 12.180 ns - 33 cycles(tsc) 8.417 ns improved 31.2%
4 - 48 cycles(tsc) 12.015 ns - 32 cycles(tsc) 8.045 ns improved 33.3%
8 - 46 cycles(tsc) 11.526 ns - 30 cycles(tsc) 7.699 ns improved 34.8%
16 - 45 cycles(tsc) 11.418 ns - 32 cycles(tsc) 8.205 ns improved 28.9%
30 - 80 cycles(tsc) 20.246 ns - 73 cycles(tsc) 18.328 ns improved 8.8%
32 - 79 cycles(tsc) 19.946 ns - 72 cycles(tsc) 18.208 ns improved 8.9%
34 - 78 cycles(tsc) 19.659 ns - 71 cycles(tsc) 17.987 ns improved 9.0%
48 - 86 cycles(tsc) 21.516 ns - 82 cycles(tsc) 20.566 ns improved 4.7%
64 - 93 cycles(tsc) 23.423 ns - 89 cycles(tsc) 22.480 ns improved 4.3%
128 - 100 cycles(tsc) 25.170 ns - 99 cycles(tsc) 24.871 ns improved 1.0%
158 - 102 cycles(tsc) 25.549 ns - 101 cycles(tsc) 25.375 ns improved 1.0%
250 - 101 cycles(tsc) 25.344 ns - 100 cycles(tsc) 25.182 ns improved 1.0%
Add the basic infrastructure for alloc/free operations on pointer arrays.
It includes a generic function in the common slab code that is used in
this infrastructure patch to create the unoptimized functionality for slab
bulk operations.
Allocators can then provide optimized allocation functions for situations
in which large numbers of objects are needed. These optimization may
avoid taking locks repeatedly and bypass metadata creation if all objects
in slab pages can be used to provide the objects required.
Allocators can extend the skeletons provided and add their own code to the
bulk alloc and free functions. They can keep the generic allocation and
freeing and just fall back to those if optimizations would not work (like
for example when debugging is on).
With this patchset the SLUB allocator now has both bulk alloc and free
implemented.
This patchset mostly optimizes the "fastpath" where objects are available
on the per CPU fastpath page. This mostly amortize the less-heavy
none-locked cmpxchg_double used on fastpath.
The "fallback" bulking (e.g __kmem_cache_free_bulk) provides a good basis
for comparison. Measurements[1] of the fallback functions
__kmem_cache_{free,alloc}_bulk have been copied from slab_common.c and
forced "noinline" to force a function call like slab_common.c.
Measurements last-patch with disabled debugging:
1 - 57 cycles(tsc) 14.448 ns - 44 cycles(tsc) 11.236 ns improved 22.8%
2 - 51 cycles(tsc) 12.768 ns - 28 cycles(tsc) 7.019 ns improved 45.1%
3 - 48 cycles(tsc) 12.232 ns - 22 cycles(tsc) 5.526 ns improved 54.2%
4 - 48 cycles(tsc) 12.025 ns - 19 cycles(tsc) 4.786 ns improved 60.4%
8 - 46 cycles(tsc) 11.558 ns - 18 cycles(tsc) 4.572 ns improved 60.9%
16 - 45 cycles(tsc) 11.458 ns - 18 cycles(tsc) 4.658 ns improved 60.0%
30 - 45 cycles(tsc) 11.499 ns - 18 cycles(tsc) 4.568 ns improved 60.0%
32 - 79 cycles(tsc) 19.917 ns - 65 cycles(tsc) 16.454 ns improved 17.7%
34 - 78 cycles(tsc) 19.655 ns - 63 cycles(tsc) 15.932 ns improved 19.2%
48 - 68 cycles(tsc) 17.049 ns - 50 cycles(tsc) 12.506 ns improved 26.5%
64 - 80 cycles(tsc) 20.009 ns - 63 cycles(tsc) 15.929 ns improved 21.3%
128 - 94 cycles(tsc) 23.749 ns - 86 cycles(tsc) 21.583 ns improved 8.5%
158 - 97 cycles(tsc) 24.299 ns - 90 cycles(tsc) 22.552 ns improved 7.2%
250 - 102 cycles(tsc) 25.681 ns - 98 cycles(tsc) 24.589 ns improved 3.9%
Benchmarking shows impressive improvements in the "fastpath" with a small
number of objects in the working set. Once the working set increases,
resulting in activating the "slowpath" (that contains the heavier locked
cmpxchg_double) the improvement decreases.
I'm currently working on also optimizing the "slowpath" (as network stack
use-case hits this), but this patchset should provide a good foundation
for further improvements. Rest of my patch queue in this area needs some
more work, but preliminary results are good. I'm attending Netfilter
Workshop[2] next week, and I'll hopefully return working on further
improvements in this area.
This patch (of 6):
s/succedd/succeed/
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
Cc: <stable@vger.kernel.org> [3.6+]
This patch moves the initialization of the size_index table slightly
earlier so that the first few kmem_cache_node's can be safely allocated
when KMALLOC_MIN_SIZE is large.
There are currently two ways to generate indices into kmalloc_caches (via
kmalloc_index() and via the size_index table in slab_common.c) and on some
arches (possibly only MIPS) they potentially disagree with each other
until create_kmalloc_caches() has been called. It seems that the
intention is that the size_index table is a fast equivalent to
kmalloc_index() and that create_kmalloc_caches() patches the table to
return the correct value for the cases where kmalloc_index()'s
if-statements apply.
The failing sequence was:
* kmalloc_caches contains NULL elements
* kmem_cache_init initialises the element that 'struct
kmem_cache_node' will be allocated to. For 32-bit Mips, this is a
56-byte struct and kmalloc_index returns KMALLOC_SHIFT_LOW (7).
* init_list is called which calls kmalloc_node to allocate a 'struct
kmem_cache_node'.
* kmalloc_slab selects the kmem_caches element using
size_index[size_index_elem(size)]. For MIPS, size is 56, and the
expression returns 6.
* This element of kmalloc_caches is NULL and allocation fails.
* If it had not already failed, it would have called
create_kmalloc_caches() at this point which would have changed
size_index[size_index_elem(size)] to 7.
I don't believe the bug to be LLVM specific but GCC doesn't normally
encounter the problem. I haven't been able to identify exactly what GCC
is doing better (probably inlining) but it seems that GCC is managing to
optimize to the point that it eliminates the problematic allocations.
This theory is supported by the fact that GCC can be made to fail in the
same way by changing inline, __inline, __inline__, and __always_inline in
include/linux/compiler-gcc.h such that they don't actually inline things.
Signed-off-by: Daniel Sanders <daniel.sanders@imgtec.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/
tree since it doesn't work reliably on non-scalar types.
This patch removes the rest of the usages of ACCESS_ONCE, and use the new
READ_ONCE API for the read accesses. This makes things cleaner, instead
of using separate/multiple sets of APIs.
Signed-off-by: Jason Low <jason.low2@hp.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Use the normal return values for bool functions
By moving the O option detection into the switch statement, we allow this
parameter to be combined with other options correctly. Previously options
like slub_debug=OFZ would only detect the 'o' and use DEBUG_DEFAULT_FLAGS
to fill in the rest of the flags.
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
Commit 9aabf810a67c ("mm/slub: optimize alloc/free fastpath by removing
preemption on/off") introduced an occasional hang for kernels built with
CONFIG_PREEMPT && !CONFIG_SMP.
The problem is the following loop the patch introduced to
slab_alloc_node and slab_free:
do {
tid = this_cpu_read(s->cpu_slab->tid);
c = raw_cpu_ptr(s->cpu_slab);
} while (IS_ENABLED(CONFIG_PREEMPT) && unlikely(tid != c->tid));
GCC 4.9 has been observed to hoist the load of c and c->tid above the
loop for !SMP kernels (as in this case raw_cpu_ptr(x) is compile-time
constant and does not force a reload). On arm64 the generated assembly
looks like:
ldr x4, [x0,#8]
loop:
ldr x1, [x0,#8]
cmp x1, x4
b.ne loop
If the thread is preempted between the load of c->tid (into x1) and tid
(into x4), and an allocation or free occurs in another thread (bumping
the cpu_slab's tid), the thread will be stuck in the loop until
s->cpu_slab->tid wraps, which may be forever in the absence of
allocations/frees on the same CPU.
This patch changes the loop condition to access c->tid with READ_ONCE.
This ensures that the value is reloaded even when the compiler would
otherwise assume it could cache the value, and also ensures that the
load will not be torn.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Steve Capper <steve.capper@linaro.org>
With this patch kasan will be able to catch bugs in memory allocated by
slub. Initially all objects in newly allocated slab page, marked as
redzone. Later, when allocation of slub object happens, requested by
caller number of bytes marked as accessible, and the rest of the object
(including slub's metadata) marked as redzone (inaccessible).
We also mark object as accessible if ksize was called for this object.
There is some places in kernel where ksize function is called to inquire
size of really allocated area. Such callers could validly access whole
allocated memory, so it should be marked as accessible.
Code in slub.c and slab_common.c files could validly access to object's
metadata, so instrumentation for this files are disabled.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Signed-off-by: Dmitry Chernenkov <dmitryc@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
It's ok for slub to access memory that marked by kasan as inaccessible
(object's metadata). Kasan shouldn't print report in that case because
these accesses are valid. Disabling instrumentation of slub.c code is not
enough to achieve this because slub passes pointer to object's metadata
into external functions like memchr_inv().
We don't want to disable instrumentation for memchr_inv() because this is
quite generic function, and we don't want to miss bugs.
metadata_access_enable/metadata_access_disable used to tell KASan where
accesses to metadata starts/end, so we could temporarily disable KASan
reports.
Cc: Dmitry Chernenkov <dmitryc@google.com>
Remove static and add function declarations to linux/slub_def.h so it
could be used by kernel address sanitizer.
printk and friends can now format bitmaps using '%*pb[l]'. cpumask
and nodemask also provide cpumask_pr_args() and nodemask_pr_args()
respectively which can be used to generate the two printf arguments
necessary to format the specified cpu/nodemask.
* This is an equivalent conversion but the whole function should be
converted to use scnprinf famiily of functions rather than
performing custom output length predictions in multiple places.
To speed up further allocations SLUB may store empty slabs in per cpu/node
partial lists instead of freeing them immediately. This prevents per
memcg caches destruction, because kmem caches created for a memory cgroup
are only destroyed after the last page charged to the cgroup is freed.
To fix this issue, this patch resurrects approach first proposed in [1].
It forbids SLUB to cache empty slabs after the memory cgroup that the
cache belongs to was destroyed. It is achieved by setting kmem_cache's
cpu_partial and min_partial constants to 0 and tuning put_cpu_partial() so
that it would drop frozen empty slabs immediately if cpu_partial = 0.
The runtime overhead is minimal. From all the hot functions, we only
touch relatively cold put_cpu_partial(): we make it call
unfreeze_partials() after freezing a slab that belongs to an offline
memory cgroup. Since slab freezing exists to avoid moving slabs from/to a
partial list on free/alloc, and there can't be allocations from dead
caches, it shouldn't cause any overhead. We do have to disable preemption
for put_cpu_partial() to achieve that though.
The original patch was accepted well and even merged to the mm tree.
However, I decided to withdraw it due to changes happening to the memcg
core at that time. I had an idea of introducing per-memcg shrinkers for
kmem caches, but now, as memcg has finally settled down, I do not see it
as an option, because SLUB shrinker would be too costly to call since SLUB
does not keep free slabs on a separate list. Besides, we currently do not
even call per-memcg shrinkers for offline memcgs. Overall, it would
introduce much more complexity to both SLUB and memcg than this small
patch.
Regarding to SLAB, there's no problem with it, because it shrinks
per-cpu/node caches periodically. Thanks to list_lru reparenting, we no
longer keep entries for offline cgroups in per-memcg arrays (such as
memcg_cache_params->memcg_caches), so we do not have to bother if a
per-memcg cache will be shrunk a bit later than it could be.
[1] http://thread.gmane.org/gmane.linux.kernel.mm/118649/focus=118650
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
It is supposed to return 0 if the cache has no remaining objects and 1
otherwise, while currently it always returns 0. Fix it.
Acked-by: Christoph Lameter <cl@linux.com>
