path: root/mm/sparse.c
2018-05-16mm: sections are not offlined during memory hotremovePavel Tatashin
commit 27227c733852f71008e9bf165950bb2edaed3a90 upstream. Memory hotplug and hotremove operate with per-block granularity. If the machine has a large amount of memory (more than 64G), the size of a memory block can span multiple sections. By mistake, during hotremove we set only the first section to offline state. The bug was discovered because kernel selftest started to fail: https://lkml.kernel.org/r/20180423011247.GK5563@yexl-desktop After commit, "mm/memory_hotplug: optimize probe routine". But, the bug is older than this commit. In this optimization we also added a check for sections to be in a proper state during hotplug operation. Link: http://lkml.kernel.org/r/20180427145257.15222-1-pasha.tatashin@oracle.com Fixes: 2d070eab2e82 ("mm: consider zone which is not fully populated to have holes") Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Steven Sistare <steven.sistare@oracle.com> Cc: Daniel Jordan <daniel.m.jordan@oracle.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10mm/sparse.c: wrong allocation for mem_sectionBaoquan He
commit d09cfbbfa0f761a97687828b5afb27b56cbf2e19 upstream. In commit 83e3c48729d9 ("mm/sparsemem: Allocate mem_section at runtime for CONFIG_SPARSEMEM_EXTREME=y") mem_section is allocated at runtime to save memory. It allocates the first dimension of array with sizeof(struct mem_section). It costs extra memory, should be sizeof(struct mem_section *). Fix it. Link: http://lkml.kernel.org/r/1513932498-20350-1-git-send-email-bhe@redhat.com Fixes: 83e3c48729 ("mm/sparsemem: Allocate mem_section at runtime for CONFIG_SPARSEMEM_EXTREME=y") Signed-off-by: Baoquan He <bhe@redhat.com> Tested-by: Dave Young <dyoung@redhat.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Atsushi Kumagai <ats-kumagai@wm.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25mm/sparsemem: Fix ARM64 boot crash when CONFIG_SPARSEMEM_EXTREME=yKirill A. Shutemov
commit 629a359bdb0e0652a8227b4ff3125431995fec6e upstream. Since commit: 83e3c48729d9 ("mm/sparsemem: Allocate mem_section at runtime for CONFIG_SPARSEMEM_EXTREME=y") we allocate the mem_section array dynamically in sparse_memory_present_with_active_regions(), but some architectures, like arm64, don't call the routine to initialize sparsemem. Let's move the initialization into memory_present() it should cover all architectures. Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Tested-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Fixes: 83e3c48729d9 ("mm/sparsemem: Allocate mem_section at runtime for CONFIG_SPARSEMEM_EXTREME=y") Link: http://lkml.kernel.org/r/20171107083337.89952-1-kirill.shutemov@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Dan Rue <dan.rue@linaro.org> Cc: Naresh Kamboju <naresh.kamboju@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25mm/sparsemem: Allocate mem_section at runtime for CONFIG_SPARSEMEM_EXTREME=yKirill A. Shutemov
commit 83e3c48729d9ebb7af5a31a504f3fd6aff0348c4 upstream. Size of the mem_section[] array depends on the size of the physical address space. In preparation for boot-time switching between paging modes on x86-64 we need to make the allocation of mem_section[] dynamic, because otherwise we waste a lot of RAM: with CONFIG_NODE_SHIFT=10, mem_section[] size is 32kB for 4-level paging and 2MB for 5-level paging mode. The patch allocates the array on the first call to sparse_memory_present_with_active_regions(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@suse.de> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20170929140821.37654-2-kirill.shutemov@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-08mm/sparse.c: fix typo in online_mem_sectionsMichal Hocko
online_mem_sections() accidentally marks online only the first section in the given range. This is a typo which hasn't been noticed because I haven't tested large 2GB blocks previously. All users of pfn_to_online_page would get confused on the the rest of the pfn range in the block. All we need to fix this is to use iterator (pfn) rather than start_pfn. Link: http://lkml.kernel.org/r/20170904112210.3401-1-mhocko@kernel.org Fixes: 2d070eab2e82 ("mm: consider zone which is not fully populated to have holes") Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-06mm, sparse, page_ext: drop ugly N_HIGH_MEMORY branches for allocationsMichal Hocko
Commit f52407ce2dea ("memory hotplug: alloc page from other node in memory online") has introduced N_HIGH_MEMORY checks to only use NUMA aware allocations when there is some memory present because the respective node might not have any memory yet at the time and so it could fail or even OOM. Things have changed since then though. Zonelists are now always initialized before we do any allocations even for hotplug (see 959ecc48fc75 ("mm/memory_hotplug.c: fix building of node hotplug zonelist")). Therefore these checks are not really needed. In fact caller of the allocator should never care about whether the node is populated because that might change at any time. Link: http://lkml.kernel.org/r/20170721143915.14161-10-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06mm, memory_hotplug: do not associate hotadded memory to zones until onlineMichal Hocko
The current memory hotplug implementation relies on having all the struct pages associate with a zone/node during the physical hotplug phase (arch_add_memory->__add_pages->__add_section->__add_zone). In the vast majority of cases this means that they are added to ZONE_NORMAL. This has been so since 9d99aaa31f59 ("[PATCH] x86_64: Support memory hotadd without sparsemem") and it wasn't a big deal back then because movable onlining didn't exist yet. Much later memory hotplug wanted to (ab)use ZONE_MOVABLE for movable onlining 511c2aba8f07 ("mm, memory-hotplug: dynamic configure movable memory and portion memory") and then things got more complicated. Rather than reconsidering the zone association which was no longer needed (because the memory hotplug already depended on SPARSEMEM) a convoluted semantic of zone shifting has been developed. Only the currently last memblock or the one adjacent to the zone_movable can be onlined movable. This essentially means that the online type changes as the new memblocks are added. Let's simulate memory hot online manually $ echo 0x100000000 > /sys/devices/system/memory/probe $ grep . /sys/devices/system/memory/memory32/valid_zones Normal Movable $ echo $((0x100000000+(128<<20))) > /sys/devices/system/memory/probe $ grep . /sys/devices/system/memory/memory3?/valid_zones /sys/devices/system/memory/memory32/valid_zones:Normal /sys/devices/system/memory/memory33/valid_zones:Normal Movable $ echo $((0x100000000+2*(128<<20))) > /sys/devices/system/memory/probe $ grep . /sys/devices/system/memory/memory3?/valid_zones /sys/devices/system/memory/memory32/valid_zones:Normal /sys/devices/system/memory/memory33/valid_zones:Normal /sys/devices/system/memory/memory34/valid_zones:Normal Movable $ echo online_movable > /sys/devices/system/memory/memory34/state $ grep . /sys/devices/system/memory/memory3?/valid_zones /sys/devices/system/memory/memory32/valid_zones:Normal /sys/devices/system/memory/memory33/valid_zones:Normal Movable /sys/devices/system/memory/memory34/valid_zones:Movable Normal This is an awkward semantic because an udev event is sent as soon as the block is onlined and an udev handler might want to online it based on some policy (e.g. association with a node) but it will inherently race with new blocks showing up. This patch changes the physical online phase to not associate pages with any zone at all. All the pages are just marked reserved and wait for the onlining phase to be associated with the zone as per the online request. There are only two requirements - existing ZONE_NORMAL and ZONE_MOVABLE cannot overlap - ZONE_NORMAL precedes ZONE_MOVABLE in physical addresses the latter one is not an inherent requirement and can be changed in the future. It preserves the current behavior and made the code slightly simpler. This is subject to change in future. This means that the same physical online steps as above will lead to the following state: Normal Movable /sys/devices/system/memory/memory32/valid_zones:Normal Movable /sys/devices/system/memory/memory33/valid_zones:Normal Movable /sys/devices/system/memory/memory32/valid_zones:Normal Movable /sys/devices/system/memory/memory33/valid_zones:Normal Movable /sys/devices/system/memory/memory34/valid_zones:Normal Movable /sys/devices/system/memory/memory32/valid_zones:Normal Movable /sys/devices/system/memory/memory33/valid_zones:Normal Movable /sys/devices/system/memory/memory34/valid_zones:Movable Implementation: The current move_pfn_range is reimplemented to check the above requirements (allow_online_pfn_range) and then updates the respective zone (move_pfn_range_to_zone), the pgdat and links all the pages in the pfn range with the zone/node. __add_pages is updated to not require the zone and only initializes sections in the range. This allowed to simplify the arch_add_memory code (s390 could get rid of quite some of code). devm_memremap_pages is the only user of arch_add_memory which relies on the zone association because it only hooks into the memory hotplug only half way. It uses it to associate the new memory with ZONE_DEVICE but doesn't allow it to be {on,off}lined via sysfs. This means that this particular code path has to call move_pfn_range_to_zone explicitly. The original zone shifting code is kept in place and will be removed in the follow up patch for an easier review. Please note that this patch also changes the original behavior when offlining a memory block adjacent to another zone (Normal vs. Movable) used to allow to change its movable type. This will be handled later. [richard.weiyang@gmail.com: simplify zone_intersects()] Link: http://lkml.kernel.org/r/20170616092335.5177-1-richard.weiyang@gmail.com [richard.weiyang@gmail.com: remove duplicate call for set_page_links] Link: http://lkml.kernel.org/r/20170616092335.5177-2-richard.weiyang@gmail.com [akpm@linux-foundation.org: remove unused local `i'] Link: http://lkml.kernel.org/r/20170515085827.16474-12-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Wei Yang <richard.weiyang@gmail.com> Tested-by: Dan Williams <dan.j.williams@intel.com> Tested-by: Reza Arbab <arbab@linux.vnet.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # For s390 bits Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Daniel Kiper <daniel.kiper@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: Igor Mammedov <imammedo@redhat.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Tobias Regnery <tobias.regnery@gmail.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: Xishi Qiu <qiuxishi@huawei.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06mm: consider zone which is not fully populated to have holesMichal Hocko
__pageblock_pfn_to_page has two users currently, set_zone_contiguous which checks whether the given zone contains holes and pageblock_pfn_to_page which then carefully returns a first valid page from the given pfn range for the given zone. This doesn't handle zones which are not fully populated though. Memory pageblocks can be offlined or might not have been onlined yet. In such a case the zone should be considered to have holes otherwise pfn walkers can touch and play with offline pages. Current callers of pageblock_pfn_to_page in compaction seem to work properly right now because they only isolate PageBuddy (isolate_freepages_block) or PageLRU resp. __PageMovable (isolate_migratepages_block) which will be always false for these pages. It would be safer to skip these pages altogether, though. In order to do this patch adds a new memory section state (SECTION_IS_ONLINE) which is set in memory_present (during boot time) or in online_pages_range during the memory hotplug. Similarly offline_mem_sections clears the bit and it is called when the memory range is offlined. pfn_to_online_page helper is then added which check the mem section and only returns a page if it is onlined already. Use the new helper in __pageblock_pfn_to_page and skip the whole page block in such a case. [mhocko@suse.com: check valid section number in pfn_to_online_page (Vlastimil), mark sections online after all struct pages are initialized in online_pages_range (Vlastimil)] Link: http://lkml.kernel.org/r/20170518164210.GD18333@dhcp22.suse.cz Link: http://lkml.kernel.org/r/20170515085827.16474-8-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Daniel Kiper <daniel.kiper@oracle.com> Cc: David Rientjes <rientjes@google.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Igor Mammedov <imammedo@redhat.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: Tobias Regnery <tobias.regnery@gmail.com> Cc: Toshi Kani <toshi.kani@hpe.com> Cc: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: Xishi Qiu <qiuxishi@huawei.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06mm, sparsemem: break out of loops earlyDave Hansen
There are a number of times that we loop over NR_MEM_SECTIONS, looking for section_present() on each section. But, when we have very large physical address spaces (large MAX_PHYSMEM_BITS), NR_MEM_SECTIONS becomes very large, making the loops quite long. With MAX_PHYSMEM_BITS=46 and a section size of 128MB, the current loops are 512k iterations, which we barely notice on modern hardware. But, raising MAX_PHYSMEM_BITS higher (like we will see on systems that support 5-level paging) makes this 64x longer and we start to notice, especially on slower systems like simulators. A 10-second delay for 512k iterations is annoying. But, a 640- second delay is crippling. This does not help if we have extremely sparse physical address spaces, but those are quite rare. We expect that most of the "slow" systems where this matters will also be quite small and non-sparse. To fix this, we track the highest section we've ever encountered. This lets us know when we will *never* see another section_present(), and lets us break out of the loops earlier. Doing the whole for_each_present_section_nr() macro is probably overkill, but it will ensure that any future loop iterations that we grow are more likely to be correct. Kirrill said "It shaved almost 40 seconds from boot time in qemu with 5-level paging enabled for me". Link: http://lkml.kernel.org/r/20170504174434.C45A4735@viggo.jf.intel.com Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03mm/sparse: refine usemap_size() a littleWei Yang
The current implementation calculates usemap_size in two steps: * calculate number of bytes to cover these bits * calculate number of "unsigned long" to cover these bytes It would be more clear by: * calculate number of "unsigned long" to cover these bits * multiple it with sizeof(unsigned long) This patch refine usemap_size() a little to make it more easy to understand. Link: http://lkml.kernel.org/r/20170310043713.96871-1-richard.weiyang@gmail.com Signed-off-by: Wei Yang <richard.weiyang@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm/memory_hotplug: set magic number to page->freelist instead of page->lru.nextYasuaki Ishimatsu
To identify that pages of page table are allocated from bootmem allocator, magic number sets to page->lru.next. But page->lru list is initialized in reserve_bootmem_region(). So when calling free_pagetable(), the function cannot find the magic number of pages. And free_pagetable() frees the pages by free_reserved_page() not put_page_bootmem(). But if the pages are allocated from bootmem allocator and used as page table, the pages have private flag. So before freeing the pages, we should clear the private flag by put_page_bootmem(). Before applying the commit 7bfec6f47bb0 ("mm, page_alloc: check multiple page fields with a single branch"), we could find the following visible issue: BUG: Bad page state in process kworker/u1024:1 page:ffffea103cfd8040 count:0 mapcount:0 mappi flags: 0x6fffff80000800(private) page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set bad because of flags: 0x800(private) <snip> Call Trace: [...] dump_stack+0x63/0x87 [...] bad_page+0x114/0x130 [...] free_pages_prepare+0x299/0x2d0 [...] free_hot_cold_page+0x31/0x150 [...] __free_pages+0x25/0x30 [...] free_pagetable+0x6f/0xb4 [...] remove_pagetable+0x379/0x7ff [...] vmemmap_free+0x10/0x20 [...] sparse_remove_one_section+0x149/0x180 [...] __remove_pages+0x2e9/0x4f0 [...] arch_remove_memory+0x63/0xc0 [...] remove_memory+0x8c/0xc0 [...] acpi_memory_device_remove+0x79/0xa5 [...] acpi_bus_trim+0x5a/0x8d [...] acpi_bus_trim+0x38/0x8d [...] acpi_device_hotplug+0x1b7/0x418 [...] acpi_hotplug_work_fn+0x1e/0x29 [...] process_one_work+0x152/0x400 [...] worker_thread+0x125/0x4b0 [...] kthread+0xd8/0xf0 [...] ret_from_fork+0x22/0x40 And the issue still silently occurs. Until freeing the pages of page table allocated from bootmem allocator, the page->freelist is never used. So the patch sets magic number to page->freelist instead of page->lru.next. [isimatu.yasuaki@jp.fujitsu.com: fix merge issue] Link: http://lkml.kernel.org/r/722b1cc4-93ac-dd8b-2be2-7a7e313b3b0b@gmail.com Link: http://lkml.kernel.org/r/2c29bd9f-5b67-02d0-18a3-8828e78bbb6f@gmail.com Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-22mm/sparse: use page_private() to get page->private valueYasuaki Ishimatsu
free_map_bootmem() uses page->private directly to set removing_section_nr argument. But to get page->private value, page_private() has been prepared. So free_map_bootmem() should use page_private() instead of page->private. Link: http://lkml.kernel.org/r/1d34eaa5-a506-8b7a-6471-490c345deef8@gmail.com Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02treewide: replace obsolete _refok by __refFabian Frederick
There was only one use of __initdata_refok and __exit_refok __init_refok was used 46 times against 82 for __ref. Those definitions are obsolete since commit 312b1485fb50 ("Introduce new section reference annotations tags: __ref, __refdata, __refconst") This patch removes the following compatibility definitions and replaces them treewide. /* compatibility defines */ #define __init_refok __ref #define __initdata_refok __refdata #define __exit_refok __ref I can also provide separate patches if necessary. (One patch per tree and check in 1 month or 2 to remove old definitions) [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Ingo Molnar <mingo@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28make __section_nr() more efficientZhou Chengming
When CONFIG_SPARSEMEM_EXTREME is disabled, __section_nr can get the section number with a subtraction directly. Link: http://lkml.kernel.org/r/1468988310-11560-1-git-send-email-zhouchengming1@huawei.com Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Tejun Heo <tj@kernel.org> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: Li Bin <huawei.libin@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: convert printk(KERN_<LEVEL> to pr_<level>Joe Perches
Most of the mm subsystem uses pr_<level> so make it consistent. Miscellanea: - Realign arguments - Add missing newline to format - kmemleak-test.c has a "kmemleak: " prefix added to the "Kmemleak testing" logging message via pr_fmt Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Tejun Heo <tj@kernel.org> [percpu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: coalesce split stringsJoe Perches
Kernel style prefers a single string over split strings when the string is 'user-visible'. Miscellanea: - Add a missing newline - Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Tejun Heo <tj@kernel.org> [percpu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15x86, mm: introduce vmem_altmap to augment vmemmap_populate()Dan Williams
In support of providing struct page for large persistent memory capacities, use struct vmem_altmap to change the default policy for allocating memory for the memmap array. The default vmemmap_populate() allocates page table storage area from the page allocator. Given persistent memory capacities relative to DRAM it may not be feasible to store the memmap in 'System Memory'. Instead vmem_altmap represents pre-allocated "device pages" to satisfy vmemmap_alloc_block_buf() requests. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: kbuild test robot <lkp@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: use macros from compiler.h instead of __attribute__((...))Gideon Israel Dsouza
To increase compiler portability there is <linux/compiler.h> which provides convenience macros for various gcc constructs. Eg: __weak for __attribute__((weak)). I've replaced all instances of gcc attributes with the right macro in the memory management (/mm) subsystem. [akpm@linux-foundation.org: while-we're-there consistency tweaks] Signed-off-by: Gideon Israel Dsouza <gidisrael@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-02sparse: fix commentLi Zhong
retmain -> remain Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-01-21mm/sparse: use memblock apis for early memory allocationsSantosh Shilimkar
Switch to memblock interfaces for early memory allocator instead of bootmem allocator. No functional change in beahvior than what it is in current code from bootmem users points of view. Archs already converted to NO_BOOTMEM now directly use memblock interfaces instead of bootmem wrappers build on top of memblock. And the archs which still uses bootmem, these new apis just fallback to exiting bootmem APIs. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Walmsley <paul@pwsan.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/sparsemem: fix a bug in free_map_bootmem when CONFIG_SPARSEMEM_VMEMMAPZhang Yanfei
We pass the number of pages which hold page structs of a memory section to free_map_bootmem(). This is right when !CONFIG_SPARSEMEM_VMEMMAP but wrong when CONFIG_SPARSEMEM_VMEMMAP. When CONFIG_SPARSEMEM_VMEMMAP, we should pass the number of pages of a memory section to free_map_bootmem. So the fix is removing the nr_pages parameter. When CONFIG_SPARSEMEM_VMEMMAP, we directly use the prefined marco PAGES_PER_SECTION in free_map_bootmem. When !CONFIG_SPARSEMEM_VMEMMAP, we calculate page numbers needed to hold the page structs for a memory section and use the value in free_map_bootmem(). This was found by reading the code. And I have no machine that support memory hot-remove to test the bug now. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13mm/sparsemem: use PAGES_PER_SECTION to remove redundant nr_pages parameterZhang Yanfei
For below functions, - sparse_add_one_section() - kmalloc_section_memmap() - __kmalloc_section_memmap() - __kfree_section_memmap() they are always invoked to operate on one memory section, so it is redundant to always pass a nr_pages parameter, which is the page numbers in one section. So we can directly use predefined macro PAGES_PER_SECTION instead of passing the parameter. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11mm/sparse: introduce alloc_usemap_and_memmapWanpeng Li
After commit 9bdac9142407 ("sparsemem: Put mem map for one node together."), vmemmap for one node will be allocated together, its logic is similar as memory allocation for pageblock flags. This patch introduces alloc_usemap_and_memmap to extract the same logic of memory alloction for pageblock flags and vmemmap. Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09mm/sparse.c: put clear_hwpoisoned_pages within CONFIG_MEMORY_HOTREMOVEZhang Yanfei
With CONFIG_MEMORY_HOTREMOVE unset, there is a compile warning: mm/sparse.c:755: warning: `clear_hwpoisoned_pages' defined but not used And Bisecting it ended up pointing to 4edd7ceff ("mm, hotplug: avoid compiling memory hotremove functions when disabled"). This is because the commit above put sparse_remove_one_section() within the protection of CONFIG_MEMORY_HOTREMOVE but the only user of clear_hwpoisoned_pages() is sparse_remove_one_section(), and it is not within the protection of CONFIG_MEMORY_HOTREMOVE. So put clear_hwpoisoned_pages within CONFIG_MEMORY_HOTREMOVE should fix the warning. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-03sparsemem: add BUILD_BUG_ON when sizeof mem_section is non-power-of-2Cody P Schafer
Instead of leaving a hidden trap for the next person who comes along and wants to add something to mem_section, add a big fat warning about it needing to be a power-of-2, and insert a BUILD_BUG_ON() in sparse_init() to catch mistakes. Right now non-power-of-2 mem_sections cause a number of WARNs at boot (which don't clearly point to the size of mem_section as an issue), but the system limps on (temporarily, at least). This is based upon Dave Hansen's earlier RFC where he ran into the same issue: "sparsemem: fix boot when SECTIONS_PER_ROOT is not power-of-2" http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/03077.html Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Jiang Liu <liuj97@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-28mm/sparse: Remove unused ret in sparse_index_initZhang Yanfei
The ret variable is not used in the function, so remove it and directly return 0 at the end of the function. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-29mm, hotplug: avoid compiling memory hotremove functions when disabledDavid Rientjes
__remove_pages() is only necessary for CONFIG_MEMORY_HOTREMOVE. PowerPC pseries will return -EOPNOTSUPP if unsupported. Adding an #ifdef causes several other functions it depends on to also become unnecessary, which saves in .text when disabled (it's disabled in most defconfigs besides powerpc, including x86). remove_memory_block() becomes static since it is not referenced outside of drivers/base/memory.c. Build tested on x86 and powerpc with CONFIG_MEMORY_HOTREMOVE both enabled and disabled. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29sparse-vmemmap: specify vmemmap population range in bytesJohannes Weiner
The sparse code, when asking the architecture to populate the vmemmap, specifies the section range as a starting page and a number of pages. This is an awkward interface, because none of the arch-specific code actually thinks of the range in terms of 'struct page' units and always translates it to bytes first. In addition, later patches mix huge page and regular page backing for the vmemmap. For this, they need to call vmemmap_populate_basepages() on sub-section ranges with PAGE_SIZE and PMD_SIZE in mind. But these are not necessarily multiples of the 'struct page' size and so this unit is too coarse. Just translate the section range into bytes once in the generic sparse code, then pass byte ranges down the stack. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Bernhard Schmidt <Bernhard.Schmidt@lrz.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: David S. Miller <davem@davemloft.net> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-failure: use num_poisoned_pages instead of mce_bad_pagesXishi Qiu
Since MCE is an x86 concept, and this code is in mm/, it would be better to use the name num_poisoned_pages instead of mce_bad_pages. [akpm@linux-foundation.org: fix mm/sparse.c] Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Suggested-by: Borislav Petkov <bp@alien8.de> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-hotplug: consider compound pages when free memmapWen Congyang
usemap could also be allocated as compound pages. Should also consider compound pages when freeing memmap. If we don't fix it, there could be problems when we free vmemmap pagetables which are stored in compound pages. The old pagetables will not be freed properly, and when we add the memory again, no new pagetable will be created. And the old pagetable entry is used, than the kernel will panic. The call trace is like the following: BUG: unable to handle kernel paging request at ffffea0040000000 IP: [<ffffffff816a483f>] sparse_add_one_section+0xef/0x166 PGD 7ff7d4067 PUD 78e035067 PMD 78e11d067 PTE 0 Oops: 0002 [#1] SMP Modules linked in: ip6table_filter ip6_tables ebtable_nat ebtables nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack ipt_REJECT xt_CHECKSUM iptable_mangle iptable_filter ip_tables bridge stp llc sunrpc binfmt_misc dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun uinput iTCO_wdt iTCO_vendor_support coretemp kvm_intel kvm crc32c_intel microcode pcspkr sg lpc_ich mfd_core i2c_i801 i2c_core i7core_edac edac_core ioatdma e1000e igb dca ptp pps_core sd_mod crc_t10dif megaraid_sas mptsas mptscsih mptbase scsi_transport_sas scsi_mod CPU 0 Pid: 4, comm: kworker/0:0 Tainted: G W 3.8.0-rc3-phy-hot-remove+ #3 FUJITSU-SV PRIMEQUEST 1800E/SB RIP: 0010:[<ffffffff816a483f>] [<ffffffff816a483f>] sparse_add_one_section+0xef/0x166 RSP: 0018:ffff8807bdcb35d8 EFLAGS: 00010006 RAX: 0000000000000000 RBX: 0000000000000200 RCX: 0000000000200000 RDX: ffff88078df01148 RSI: 0000000000000282 RDI: ffffea0040000000 RBP: ffff8807bdcb3618 R08: 4cf05005b019467a R09: 0cd98fa09631467a R10: 0000000000000000 R11: 0000000000030e20 R12: 0000000000008000 R13: ffffea0040000000 R14: ffff88078df66248 R15: ffff88078ea13b10 FS: 0000000000000000(0000) GS:ffff8807c1a00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffffea0040000000 CR3: 0000000001c0c000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kworker/0:0 (pid: 4, threadinfo ffff8807bdcb2000, task ffff8807bde18000) Call Trace: __add_pages+0x85/0x120 arch_add_memory+0x71/0xf0 add_memory+0xd6/0x1f0 acpi_memory_device_add+0x170/0x20c acpi_device_probe+0x50/0x18a really_probe+0x6c/0x320 driver_probe_device+0x47/0xa0 __device_attach+0x53/0x60 bus_for_each_drv+0x6c/0xa0 device_attach+0xa8/0xc0 bus_probe_device+0xb0/0xe0 device_add+0x301/0x570 device_register+0x1e/0x30 acpi_device_register+0x1d8/0x27c acpi_add_single_object+0x1df/0x2b9 acpi_bus_check_add+0x112/0x18f acpi_ns_walk_namespace+0x105/0x255 acpi_walk_namespace+0xcf/0x118 acpi_bus_scan+0x5b/0x7c acpi_bus_add+0x2a/0x2c container_notify_cb+0x112/0x1a9 acpi_ev_notify_dispatch+0x46/0x61 acpi_os_execute_deferred+0x27/0x34 process_one_work+0x20e/0x5c0 worker_thread+0x12e/0x370 kthread+0xee/0x100 ret_from_fork+0x7c/0xb0 Code: 00 00 48 89 df 48 89 45 c8 e8 3e 71 b1 ff 48 89 c2 48 8b 75 c8 b8 ef ff ff ff f6 02 01 75 4b 49 63 cc 31 c0 4c 89 ef 48 c1 e1 06 <f3> aa 48 8b 02 48 83 c8 01 48 85 d2 48 89 02 74 29 a8 01 74 25 RIP [<ffffffff816a483f>] sparse_add_one_section+0xef/0x166 RSP <ffff8807bdcb35d8> CR2: ffffea0040000000 ---[ end trace e7f94e3a34c442d4 ]--- Kernel panic - not syncing: Fatal exception Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-hotplug: remove memmap of sparse-vmemmapTang Chen
Introduce a new API vmemmap_free() to free and remove vmemmap pagetables. Since pagetable implements are different, each architecture has to provide its own version of vmemmap_free(), just like vmemmap_populate(). Note: vmemmap_free() is not implemented for ia64, ppc, s390, and sparc. [mhocko@suse.cz: fix implicit declaration of remove_pagetable] Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Wu Jianguo <wujianguo@huawei.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23memory-hotplug: move pgdat_resize_lock into sparse_remove_one_section()Tang Chen
In __remove_section(), we locked pgdat_resize_lock when calling sparse_remove_one_section(). This lock will disable irq. But we don't need to lock the whole function. If we do some work to free pagetables in free_section_usemap(), we need to call flush_tlb_all(), which need irq enabled. Otherwise the WARN_ON_ONCE() in smp_call_function_many() will be triggered. If we lock the whole sparse_remove_one_section(), then we come to this call trace: ------------[ cut here ]------------ WARNING: at kernel/smp.c:461 smp_call_function_many+0xbd/0x260() Hardware name: PRIMEQUEST 1800E ...... Call Trace: smp_call_function_many+0xbd/0x260 smp_call_function+0x3b/0x50 on_each_cpu+0x3b/0xc0 flush_tlb_all+0x1c/0x20 remove_pagetable+0x14e/0x1d0 vmemmap_free+0x18/0x20 sparse_remove_one_section+0xf7/0x100 __remove_section+0xa2/0xb0 __remove_pages+0xa0/0xd0 arch_remove_memory+0x6b/0xc0 remove_memory+0xb8/0xf0 acpi_memory_device_remove+0x53/0x96 acpi_device_remove+0x90/0xb2 __device_release_driver+0x7c/0xf0 device_release_driver+0x2f/0x50 acpi_bus_remove+0x32/0x6d acpi_bus_trim+0x91/0x102 acpi_bus_hot_remove_device+0x88/0x16b acpi_os_execute_deferred+0x27/0x34 process_one_work+0x20e/0x5c0 worker_thread+0x12e/0x370 kthread+0xee/0x100 ret_from_fork+0x7c/0xb0 ---[ end trace 25e85300f542aa01 ]--- Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Wu Jianguo <wujianguo@huawei.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11memory-hotplug, mm/sparse.c: clear the memory to store struct pageWen Congyang
If sparse memory vmemmap is enabled, we can't free the memory to store struct page when a memory device is hotremoved, because we may store struct page in the memory to manage the memory which doesn't belong to this memory device. When we hotadded this memory device again, we will reuse this memory to store struct page, and struct page may contain some obsolete information, and we will get bad-page state: init_memory_mapping: [mem 0x80000000-0x9fffffff] Built 2 zonelists in Node order, mobility grouping on. Total pages: 547617 Policy zone: Normal BUG: Bad page state in process bash pfn:9b6dc page:ffffea0002200020 count:0 mapcount:0 mapping: (null) index:0xfdfdfdfdfdfdfdfd page flags: 0x2fdfdfdfd5df9fd(locked|referenced|uptodate|dirty|lru|active|slab|owner_priv_1|private|private_2|writeback|head|tail|swapcache|reclaim|swapbacked|unevictable|uncached|compound_lock) Modules linked in: netconsole acpiphp pci_hotplug acpi_memhotplug loop kvm_amd kvm microcode tpm_tis tpm tpm_bios evdev psmouse serio_raw i2c_piix4 i2c_core parport_pc parport processor button thermal_sys ext3 jbd mbcache sg sr_mod cdrom ata_generic virtio_net ata_piix virtio_blk libata virtio_pci virtio_ring virtio scsi_mod Pid: 988, comm: bash Not tainted 3.6.0-rc7-guest #12 Call Trace: [<ffffffff810e9b30>] ? bad_page+0xb0/0x100 [<ffffffff810ea4c3>] ? free_pages_prepare+0xb3/0x100 [<ffffffff810ea668>] ? free_hot_cold_page+0x48/0x1a0 [<ffffffff8112cc08>] ? online_pages_range+0x68/0xa0 [<ffffffff8112cba0>] ? __online_page_increment_counters+0x10/0x10 [<ffffffff81045561>] ? walk_system_ram_range+0x101/0x110 [<ffffffff814c4f95>] ? online_pages+0x1a5/0x2b0 [<ffffffff8135663d>] ? __memory_block_change_state+0x20d/0x270 [<ffffffff81356756>] ? store_mem_state+0xb6/0xf0 [<ffffffff8119e482>] ? sysfs_write_file+0xd2/0x160 [<ffffffff8113769a>] ? vfs_write+0xaa/0x160 [<ffffffff81137977>] ? sys_write+0x47/0x90 [<ffffffff814e2f25>] ? async_page_fault+0x25/0x30 [<ffffffff814ea239>] ? system_call_fastpath+0x16/0x1b Disabling lock debugging due to kernel taint This patch clears the memory to store struct page to avoid unexpected error. Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reported-by: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11memory-hotplug: update mce_bad_pages when removing the memoryWen Congyang
When we hotremove a memory device, we will free the memory to store struct page. If the page is hwpoisoned page, we should decrease mce_bad_pages. [akpm@linux-foundation.org: cleanup ifdefs] Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Christoph Lameter <cl@linux.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm/vmemmap: fix wrong use of virt_to_pageJianguo Wu
I enable CONFIG_DEBUG_VIRTUAL and CONFIG_SPARSEMEM_VMEMMAP, when doing memory hotremove, there is a kernel BUG at arch/x86/mm/physaddr.c:20. It is caused by free_section_usemap()->virt_to_page(), virt_to_page() is only used for kernel direct mapping address, but sparse-vmemmap uses vmemmap address, so it is going wrong here. ------------[ cut here ]------------ kernel BUG at arch/x86/mm/physaddr.c:20! invalid opcode: 0000 [#1] SMP Modules linked in: acpihp_drv acpihp_slot edd cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf fuse vfat fat loop dm_mod coretemp kvm crc32c_intel ipv6 ixgbe igb iTCO_wdt i7core_edac edac_core pcspkr iTCO_vendor_support ioatdma microcode joydev sr_mod i2c_i801 dca lpc_ich mfd_core mdio tpm_tis i2c_core hid_generic tpm cdrom sg tpm_bios rtc_cmos button ext3 jbd mbcache usbhid hid uhci_hcd ehci_hcd usbcore usb_common sd_mod crc_t10dif processor thermal_sys hwmon scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh_emc scsi_dh ata_generic ata_piix libata megaraid_sas scsi_mod CPU 39 Pid: 6454, comm: sh Not tainted 3.7.0-rc1-acpihp-final+ #45 QCI QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8103c908>] [<ffffffff8103c908>] __phys_addr+0x88/0x90 RSP: 0018:ffff8804440d7c08 EFLAGS: 00010006 RAX: 0000000000000006 RBX: ffffea0012000000 RCX: 000000000000002c ... Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reviewd-by: Wen Congyang <wency@cn.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/sparse: remove index_init_lockGavin Shan
sparse_index_init() uses the index_init_lock spinlock to protect root mem_section assignment. The lock is not necessary anymore because the function is called only during boot (during paging init which is executed only from a single CPU) and from the hotplug code (by add_memory() via arch_add_memory()) which uses mem_hotplug_mutex. The lock was introduced by 28ae55c9 ("sparsemem extreme: hotplug preparation") and sparse_index_init() was used only during boot at that time. Later when the hotplug code (and add_memory()) was introduced there was no synchronization so it was possible to online more sections from the same root probably (though I am not 100% sure about that). The first synchronization has been added by 6ad696d2 ("mm: allow memory hotplug and hibernation in the same kernel") which was later replaced by the mem_hotplug_mutex - 20d6c96b ("mem-hotplug: introduce {un}lock_memory_hotplug()"). Let's remove the lock as it is not needed and it makes the code more confusing. [mhocko@suse.cz: changelog] Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/sparse: more checks on mem_section numberGavin Shan
__section_nr() was implemented to retrieve the corresponding memory section number according to its descriptor. It's possible that the specified memory section descriptor doesn't exist in the global array. So add more checking on that and report an error for a wrong case. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm/sparse: optimize sparse_index_allocGavin Shan
With CONFIG_SPARSEMEM_EXTREME, the two levels of memory section descriptors are allocated from slab or bootmem. When allocating from slab, let slab/bootmem allocator clear the memory chunk. We needn't clear it explicitly. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31mm: setup pageblock_order before it's used by sparsememXishi Qiu
On architectures with CONFIG_HUGETLB_PAGE_SIZE_VARIABLE set, such as Itanium, pageblock_order is a variable with default value of 0. It's set to the right value by set_pageblock_order() in function free_area_init_core(). But pageblock_order may be used by sparse_init() before free_area_init_core() is called along path: sparse_init() ->sparse_early_usemaps_alloc_node() ->usemap_size() ->SECTION_BLOCKFLAGS_BITS ->((1UL << (PFN_SECTION_SHIFT - pageblock_order)) * NR_PAGEBLOCK_BITS) The uninitialized pageblock_size will cause memory wasting because usemap_size() returns a much bigger value then it's really needed. For example, on an Itanium platform, sparse_init() pageblock_order=0 usemap_size=24576 free_area_init_core() before pageblock_order=0, usemap_size=24576 free_area_init_core() after pageblock_order=12, usemap_size=8 That means 24K memory has been wasted for each section, so fix it by calling set_pageblock_order() from sparse_init(). Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <liuj97@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Keping Chen <chenkeping@huawei.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-11mm: sparse: fix usemap allocation above node descriptor sectionYinghai Lu
After commit f5bf18fa22f8 ("bootmem/sparsemem: remove limit constraint in alloc_bootmem_section"), usemap allocations may easily be placed outside the optimal section that holds the node descriptor, even if there is space available in that section. This results in unnecessary hotplug dependencies that need to have the node unplugged before the section holding the usemap. The reason is that the bootmem allocator doesn't guarantee a linear search starting from the passed allocation goal but may start out at a much higher address absent an upper limit. Fix this by trying the allocation with the limit at the section end, then retry without if that fails. This keeps the fix from f5bf18fa22f8 of not panicking if the allocation does not fit in the section, but still makes sure to try to stay within the section at first. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [3.3.x, 3.4.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-11mm: sparse: fix section usemap placement calculationYinghai Lu
Commit 238305bb4d41 ("mm: remove sparsemem allocation details from the bootmem allocator") introduced a bug in the allocation goal calculation that put section usemaps not in the same section as the node descriptors, creating unnecessary hotplug dependencies between them: node 0 must be removed before remove section 16399 node 1 must be removed before remove section 16399 node 2 must be removed before remove section 16399 node 3 must be removed before remove section 16399 node 4 must be removed before remove section 16399 node 5 must be removed before remove section 16399 node 6 must be removed before remove section 16399 The reason is that it applies PAGE_SECTION_MASK to the physical address of the node descriptor when finding a suitable place to put the usemap, when this mask is actually intended to be used with PFNs. Because the PFN mask is wider, the target address will point beyond the wanted section holding the node descriptor and the node must be offlined before the section holding the usemap can go. Fix this by extending the mask to address width before use. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: remove sparsemem allocation details from the bootmem allocatorJohannes Weiner
alloc_bootmem_section() derives allocation area constraints from the specified sparsemem section. This is a bit specific for a generic memory allocator like bootmem, though, so move it over to sparsemem. As __alloc_bootmem_node_nopanic() already retries failed allocations with relaxed area constraints, the fallback code in sparsemem.c can be removed and the code becomes a bit more compact overall. [akpm@linux-foundation.org: fix build] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21bootmem/sparsemem: remove limit constraint in alloc_bootmem_sectionNishanth Aravamudan
While testing AMS (Active Memory Sharing) / CMO (Cooperative Memory Overcommit) on powerpc, we tripped the following: kernel BUG at mm/bootmem.c:483! cpu 0x0: Vector: 700 (Program Check) at [c000000000c03940] pc: c000000000a62bd8: .alloc_bootmem_core+0x90/0x39c lr: c000000000a64bcc: .sparse_early_usemaps_alloc_node+0x84/0x29c sp: c000000000c03bc0 msr: 8000000000021032 current = 0xc000000000b0cce0 paca = 0xc000000001d80000 pid = 0, comm = swapper kernel BUG at mm/bootmem.c:483! enter ? for help [c000000000c03c80] c000000000a64bcc .sparse_early_usemaps_alloc_node+0x84/0x29c [c000000000c03d50] c000000000a64f10 .sparse_init+0x12c/0x28c [c000000000c03e20] c000000000a474f4 .setup_arch+0x20c/0x294 [c000000000c03ee0] c000000000a4079c .start_kernel+0xb4/0x460 [c000000000c03f90] c000000000009670 .start_here_common+0x1c/0x2c This is BUG_ON(limit && goal + size > limit); and after some debugging, it seems that goal = 0x7ffff000000 limit = 0x80000000000 and sparse_early_usemaps_alloc_node -> sparse_early_usemaps_alloc_pgdat_section calls return alloc_bootmem_section(usemap_size() * count, section_nr); This is on a system with 8TB available via the AMS pool, and as a quirk of AMS in firmware, all of that memory shows up in node 0. So, we end up with an allocation that will fail the goal/limit constraints. In theory, we could "fall-back" to alloc_bootmem_node() in sparse_early_usemaps_alloc_node(), but since we actually have HOTREMOVE defined, we'll BUG_ON() instead. A simple solution appears to be to unconditionally remove the limit condition in alloc_bootmem_section, meaning allocations are allowed to cross section boundaries (necessary for systems of this size). Johannes Weiner pointed out that if alloc_bootmem_section() no longer guarantees section-locality, we need check_usemap_section_nr() to print possible cross-dependencies between node descriptors and the usemaps allocated through it. That makes the two loops in sparse_early_usemaps_alloc_node() identical, so re-factor the code a bit. [akpm@linux-foundation.org: code simplification] Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Anton Blanchard <anton@au1.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: <stable@vger.kernel.org> [3.3.1] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-25mm: make some struct page's constIan Campbell
These uses are read-only and in a subsequent patch I have a const struct page in my hand... [akpm@linux-foundation.org: fix warnings in lowmem_page_address()] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: remove PG_buddyAndrea Arcangeli
PG_buddy can be converted to _mapcount == -2. So the PG_compound_lock can be added to page->flags without overflowing (because of the sparse section bits increasing) with CONFIG_X86_PAE=y and CONFIG_X86_PAT=y. This also has to move the memory hotplug code from _mapcount to lru.next to avoid any risk of clashes. We can't use lru.next for PG_buddy removal, but memory hotplug can use lru.next even more easily than the mapcount instead. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25sparsemem: on no vmemmap path put mem_map on node high tooYinghai Lu
We need to put mem_map high when virtual memmap is not used. before this patch free mem pfn range on first node: [ 0.000000] 19 - 1f [ 0.000000] 28 40 - 80 95 [ 0.000000] 702 740 - 1000 1000 [ 0.000000] 347c - 347e [ 0.000000] 34e7 3500 - 3b80 3b8b [ 0.000000] 73b8b 73bc0 - 73c00 73c00 [ 0.000000] 73ddd - 73e00 [ 0.000000] 73fdd - 74000 [ 0.000000] 741dd - 74200 [ 0.000000] 743dd - 74400 [ 0.000000] 745dd - 74600 [ 0.000000] 747dd - 74800 [ 0.000000] 749dd - 74a00 [ 0.000000] 74bdd - 74c00 [ 0.000000] 74ddd - 74e00 [ 0.000000] 74fdd - 75000 [ 0.000000] 751dd - 75200 [ 0.000000] 753dd - 75400 [ 0.000000] 755dd - 75600 [ 0.000000] 757dd - 75800 [ 0.000000] 759dd - 75a00 [ 0.000000] 79bdd 79c00 - 7d540 7d550 [ 0.000000] 7f745 - 7f750 [ 0.000000] 10000b 100040 - 2080000 2080000 so only 79c00 - 7d540 are major free block under 4g... after this patch, we will get [ 0.000000] 19 - 1f [ 0.000000] 28 40 - 80 95 [ 0.000000] 702 740 - 1000 1000 [ 0.000000] 347c - 347e [ 0.000000] 34e7 3500 - 3600 3600 [ 0.000000] 37dd - 3800 [ 0.000000] 39dd - 3a00 [ 0.000000] 3bdd - 3c00 [ 0.000000] 3ddd - 3e00 [ 0.000000] 3fdd - 4000 [ 0.000000] 41dd - 4200 [ 0.000000] 43dd - 4400 [ 0.000000] 45dd - 4600 [ 0.000000] 47dd - 4800 [ 0.000000] 49dd - 4a00 [ 0.000000] 4bdd - 4c00 [ 0.000000] 4ddd - 4e00 [ 0.000000] 4fdd - 5000 [ 0.000000] 51dd - 5200 [ 0.000000] 53dd - 5400 [ 0.000000] 95dd 9600 - 7d540 7d550 [ 0.000000] 7f745 - 7f750 [ 0.000000] 17000b 170040 - 2080000 2080000 we will have 9600 - 7d540 for major free block... sparse-vmemmap path already used __alloc_bootmem_node_high() Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
