path: root/mm/swap_state.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-22mm: add_to_swap_cache() does not return -EEXISTDaisuke Nishimura
After commit 355cfa73 ("mm: modify swap_map and add SWAP_HAS_CACHE flag"), only the context which have set SWAP_HAS_CACHE flag by swapcache_prepare() or get_swap_page() would call add_to_swap_cache(). So add_to_swap_cache() doesn't return -EEXIST any more. Even though it doesn't return -EEXIST, it's not good behavior conceptually to call swapcache_prepare() in the -EEXIST case, because it means clearing SWAP_HAS_CACHE flag while the entry is on swap cache. This patch removes redundant codes and comments from callers of it, and adds VM_BUG_ON() in error path of add_to_swap_cache() and some comments. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add_to_swap_cache() must not sleepDaisuke Nishimura
After commit 355cfa73 ("mm: modify swap_map and add SWAP_HAS_CACHE flag"), read_swap_cache_async() will busy-wait while a entry doesn't exist in swap cache but it has SWAP_HAS_CACHE flag. Such entries can exist on add/delete path of swap cache. On add path, add_to_swap_cache() is called soon after SWAP_HAS_CACHE flag is set, and on delete path, swapcache_free() will be called (SWAP_HAS_CACHE flag is cleared) soon after __delete_from_swap_cache() is called. So, the busy-wait works well in most cases. But this mechanism can cause soft lockup if add_to_swap_cache() sleeps and read_swap_cache_async() tries to swap-in the same entry on the same cpu. This patch calls radix_tree_preload() before swapcache_prepare() and divides add_to_swap_cache() into two part: radix_tree_preload() part and radix_tree_insert() part(define it as __add_to_swap_cache()). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-16mm: remove file argument from swap_readpage()Minchan Kim
The file argument resulted from address_space's readpage long time ago. We don't use it any more. Let's remove unnecessary argement. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove annotation of gfp_mask in add_to_swapMinchan Kim
Hugh removed add_to_swap's gfp_mask argument. (mm: remove gfp_mask from add_to_swap) So we have to remove annotation of gfp_mask of the function. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: modify swap_map and add SWAP_HAS_CACHE flagKAMEZAWA Hiroyuki
This is a part of the patches for fixing memcg's swap accountinf leak. But, IMHO, not a bad patch even if no memcg. There are 2 kinds of references to swap. - reference from swap entry - reference from swap cache Then, - If there is swap cache && swap's refcnt is 1, there is only swap cache. (*) swapcount(entry) == 1 && find_get_page(swapper_space, entry) != NULL This counting logic have worked well for a long time. But considering that we cannot know there is a _real_ reference or not by swap_map[], current usage of counter is not very good. This patch adds a flag SWAP_HAS_CACHE and recored information that a swap entry has a cache or not. This will remove -1 magic used in swapfile.c and be a help to avoid unnecessary find_get_page(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: add swap cache interface for swap referenceKAMEZAWA Hiroyuki
In a following patch, the usage of swap cache is recorded into swap_map. This patch is for necessary interface changes to do that. 2 interfaces: - swapcache_prepare() - swapcache_free() are added for allocating/freeing refcnt from swap-cache to existing swap entries. But implementation itself is not changed under this patch. At adding swapcache_free(), memcg's hook code is moved under swapcache_free(). This is better than using scattered hooks. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29memcg: fix deadlock between lock_page_cgroup and mapping tree_lockDaisuke Nishimura
mapping->tree_lock can be acquired from interrupt context. Then, following dead lock can occur. Assume "A" as a page. CPU0: lock_page_cgroup(A) interrupted -> take mapping->tree_lock. CPU1: take mapping->tree_lock -> lock_page_cgroup(A) This patch tries to fix above deadlock by moving memcg's hook to out of mapping->tree_lock. charge/uncharge of pagecache/swapcache is protected by page lock, not tree_lock. After this patch, lock_page_cgroup() is not called under mapping->tree_lock. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller coreKAMEZAWA Hiroyuki
This patch implements per cgroup limit for usage of memory+swap. However there are SwapCache, double counting of swap-cache and swap-entry is avoided. Mem+Swap controller works as following. - memory usage is limited by memory.limit_in_bytes. - memory + swap usage is limited by memory.memsw_limit_in_bytes. This has following benefits. - A user can limit total resource usage of mem+swap. Without this, because memory resource controller doesn't take care of usage of swap, a process can exhaust all the swap (by memory leak.) We can avoid this case. And Swap is shared resource but it cannot be reclaimed (goes back to memory) until it's used. This characteristic can be trouble when the memory is divided into some parts by cpuset or memcg. Assume group A and group B. After some application executes, the system can be.. Group A -- very large free memory space but occupy 99% of swap. Group B -- under memory shortage but cannot use swap...it's nearly full. Ability to set appropriate swap limit for each group is required. Maybe someone wonder "why not swap but mem+swap ?" - The global LRU(kswapd) can swap out arbitrary pages. Swap-out means to move account from memory to swap...there is no change in usage of mem+swap. In other words, when we want to limit the usage of swap without affecting global LRU, mem+swap limit is better than just limiting swap. Accounting target information is stored in swap_cgroup which is per swap entry record. Charge is done as following. map - charge page and memsw. unmap - uncharge page/memsw if not SwapCache. swap-out (__delete_from_swap_cache) - uncharge page - record mem_cgroup information to swap_cgroup. swap-in (do_swap_page) - charged as page and memsw. record in swap_cgroup is cleared. memsw accounting is decremented. swap-free (swap_free()) - if swap entry is freed, memsw is uncharged by PAGE_SIZE. There are people work under never-swap environments and consider swap as something bad. For such people, this mem+swap controller extension is just an overhead. This overhead is avoided by config or boot option. (see Kconfig. detail is not in this patch.) TODO: - maybe more optimization can be don in swap-in path. (but not very safe.) But we just do simple accounting at this stage. [nishimura@mxp.nes.nec.co.jp: make resize limit hold mutex] [hugh@veritas.com: memswap controller core swapcache fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: handle swap cachesKAMEZAWA Hiroyuki
SwapCache support for memory resource controller (memcg) Before mem+swap controller, memcg itself should handle SwapCache in proper way. This is cut-out from it. In current memcg, SwapCache is just leaked and the user can create tons of SwapCache. This is a leak of account and should be handled. SwapCache accounting is done as following. charge (anon) - charged when it's mapped. (because of readahead, charge at add_to_swap_cache() is not sane) uncharge (anon) - uncharged when it's dropped from swapcache and fully unmapped. means it's not uncharged at unmap. Note: delete from swap cache at swap-in is done after rmap information is established. charge (shmem) - charged at swap-in. this prevents charge at add_to_page_cache(). uncharge (shmem) - uncharged when it's dropped from swapcache and not on shmem's radix-tree. at migration, check against 'old page' is modified to handle shmem. Comparing to the old version discussed (and caused troubles), we have advantages of - PCG_USED bit. - simple migrating handling. So, situation is much easier than several months ago, maybe. [hugh@veritas.com: memcg: handle swap caches build fix] Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: remove gfp_mask from add_to_swapHugh Dickins
Remove gfp_mask argument from add_to_swap(): it's misleading because its only caller, shrink_page_list(), is not atomic at that point; and in due course (implementing discard) we'll sometimes want to allocate some memory with GFP_NOIO (as is used in swap_writepage) when allocating swap. No change to the gfp_mask passed down to add_to_swap_cache(): still use __GFP_HIGH without __GFP_WAIT (with nomemalloc and nowarn as before): though it's not obvious if that's the best combination to ask for here. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: try_to_free_swap replaces remove_exclusive_swap_pageHugh Dickins
remove_exclusive_swap_page(): its problem is in living up to its name. It doesn't matter if someone else has a reference to the page (raised page_count); it doesn't matter if the page is mapped into userspace (raised page_mapcount - though that hints it may be worth keeping the swap): all that matters is that there be no more references to the swap (and no writeback in progress). swapoff (try_to_unuse) has been removing pages from swapcache for years, with no concern for page count or page mapcount, and we used to have a comment in lookup_swap_cache() recognizing that: if you go for a page of swapcache, you'll get the right page, but it could have been removed from swapcache by the time you get page lock. So, give up asking for exclusivity: get rid of remove_exclusive_swap_page(), and remove_exclusive_swap_page_ref() and remove_exclusive_swap_page_count() which were spawned for the recent LRU work: replace them by the simpler try_to_free_swap() which just checks page_swapcount(). Similarly, remove the page_count limitation from free_swap_and_count(), but assume that it's worth holding on to the swap if page is mapped and swap nowhere near full. Add a vm_swap_full() test in free_swap_cache()? It would be consistent, but I think we probably have enough for now. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: replace some BUG_ONs by VM_BUG_ONsHugh Dickins
The swap code is over-provisioned with BUG_ONs on assorted page flags, mostly dating back to 2.3. They're good documentation, and guard against developer error, but a waste of space on most systems: change them to VM_BUG_ONs, conditional on CONFIG_DEBUG_VM. Just delete the PagePrivate ones: they're later, from 2.5.69, but even less interesting now. Signed-off-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mm: pagecache insertion fewer atomicsNick Piggin
Setting and clearing the page locked when inserting it into swapcache / pagecache when it has no other references can use non-atomic page flags operations because no other CPU may be operating on it at this time. This saves one atomic operation when inserting a page into pagecache. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: add newly swapped in pages to the inactive listRik van Riel
Swapin_readahead can read in a lot of data that the processes in memory never need. Adding swap cache pages to the inactive list prevents them from putting too much pressure on the working set. This has the potential to help the programs that are already in memory, but it could also be a disadvantage to processes that are trying to get swapped in. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20define page_file_cache() functionRik van Riel
Define page_file_cache() function to answer the question: is page backed by a file? Originally part of Rik van Riel's split-lru patch. Extracted to make available for other, independent reclaim patches. Moved inline function to linux/mm_inline.h where it will be needed by subsequent "split LRU" and "noreclaim" patches. Unfortunately this needs to use a page flag, since the PG_swapbacked state needs to be preserved all the way to the point where the page is last removed from the LRU. Trying to derive the status from other info in the page resulted in wrong VM statistics in earlier split VM patchsets. The total number of page flags in use on a 32 bit machine after this patch is 19. [akpm@linux-foundation.org: fix up out-of-order merge fallout] [hugh@veritas.com: splitlru: shmem_getpage SetPageSwapBacked sooner[ Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20mm: show free swap as signedHugh Dickins
Adjust <Alt><SysRq>m show_swap_cache_info() to show "Free swap" as a signed long: the signed format is preferable, because during swapoff nr_swap_pages can legitimately go negative, so makes more sense thus (it used to be shown redundantly, once as signed and once as unsigned). Signed-off-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mm: rename page trylockNick Piggin
Converting page lock to new locking bitops requires a change of page flag operation naming, so we might as well convert it to something nicer (!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked). This also facilitates lockdeping of page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: print swapcache page count in show_swap_cache_info()Johannes Weiner
Every arch implements its own show_mem() function. Most of them share quite some code, some of them are completely identical. This series implements a generic version of this function and migrates almost all architectures to it. This patch: Most show_mem() implementations calculate the amount of pages within the swapcache every time. Move the output to a more appropriate place and use the anyway available total_swapcache_pages variable. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Dike <jdike@addtoit.com> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: spinlock tree_lockNick Piggin
mapping->tree_lock has no read lockers. convert the lock from an rwlock to a spinlock. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: speculative page referencesNick Piggin
If we can be sure that elevating the page_count on a pagecache page will pin it, we can speculatively run this operation, and subsequently check to see if we hit the right page rather than relying on holding a lock or otherwise pinning a reference to the page. This can be done if get_page/put_page behaves consistently throughout the whole tree (ie. if we "get" the page after it has been used for something else, we must be able to free it with a put_page). Actually, there is a period where the count behaves differently: when the page is free or if it is a constituent page of a compound page. We need an atomic_inc_not_zero operation to ensure we don't try to grab the page in either case. This patch introduces the core locking protocol to the pagecache (ie. adds page_cache_get_speculative, and tweaks some update-side code to make it work). Thanks to Hugh for pointing out an improvement to the algorithm setting page_count to zero when we have control of all references, in order to hold off speculative getters. [kamezawa.hiroyu@jp.fujitsu.com: fix migration_entry_wait()] [hugh@veritas.com: fix add_to_page_cache] [akpm@linux-foundation.org: repair a comment] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: add separate writeback accounting capabilityMiklos Szeredi
Add a new BDI capability flag: BDI_CAP_NO_ACCT_WB. If this flag is set, then don't update the per-bdi writeback stats from test_set_page_writeback() and test_clear_page_writeback(). Misc cleanups: - convert bdi_cap_writeback_dirty() and friends to static inline functions - create a flag that includes all three dirty/writeback related flags, since almst all users will want to have them toghether Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19mm: fix various kernel-doc commentsRandy Dunlap
Fix various kernel-doc notation in mm/: filemap.c: add function short description; convert 2 to kernel-doc fremap.c: change parameter 'prot' to @prot pagewalk.c: change "-" in function parameters to ":" slab.c: fix short description of kmem_ptr_validate() swap.c: fix description & parameters of put_pages_list() swap_state.c: fix function parameters vmalloc.c: change "@returns" to "Returns:" since that is not a parameter Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07memcgroup: revert swap_state modsHugh Dickins
If we're charging rss and we're charging cache, it seems obvious that we should be charging swapcache - as has been done. But in practice that doesn't work out so well: both swapin readahead and swapoff leave the majority of pages charged to the wrong cgroup (the cgroup that happened to read them in, rather than the cgroup to which they belong). (Which is why unuse_pte's GFP_KERNEL while holding pte lock never showed up as a problem: no allocation was ever done there, every page read being already charged to the cgroup which initiated the swapoff.) It all works rather better if we leave the charging to do_swap_page and unuse_pte, and do nothing for swapcache itself: revert mm/swap_state.c to what it was before the memory-controller patches. This also speeds up significantly a contained process working at its limit: because it no longer needs to keep waiting for swap writeback to complete. Is it unfair that swap pages become uncharged once they're unmapped, even though they're still clearly private to particular cgroups? For a short while, yes; but PageReclaim arranges for those pages to go to the end of the inactive list and be reclaimed soon if necessary. shmem/tmpfs pages are a distinct case: their charging also benefits from this change, but their second life on the lists as swapcache pages may prove more unfair - that I need to check next. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Pavel Emelianov <xemul@openvz.org> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07memory controller BUG_ON()Balbir Singh
Move mem_controller_cache_charge() above radix_tree_preload(). radix_tree_preload() disables preemption, even though the gfp_mask passed contains __GFP_WAIT, we cannot really do __GFP_WAIT allocations, thus we hit a BUG_ON() in kmem_cache_alloc(). This patch moves mem_controller_cache_charge() to above radix_tree_preload() for cache charging. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: make charging gfp mask awareBalbir Singh
Nick Piggin pointed out that swap cache and page cache addition routines could be called from non GFP_KERNEL contexts. This patch makes the charging routine aware of the gfp context. Charging might fail if the cgroup is over it's limit, in which case a suitable error is returned. This patch was tested on a Powerpc box. I am still looking at being able to test the path, through which allocations happen in non GFP_KERNEL contexts. [kamezawa.hiroyu@jp.fujitsu.com: problem with ZONE_MOVABLE] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: add switch to control what type of pages to limitBalbir Singh
Choose if we want cached pages to be accounted or not. By default both are accounted for. A new set of tunables are added. echo -n 1 > mem_control_type switches the accounting to account for only mapped pages echo -n 3 > mem_control_type switches the behaviour back [bunk@kernel.org: mm/memcontrol.c: clenups] [akpm@linux-foundation.org: fix sparc32 build] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: memory accountingBalbir Singh
Add the accounting hooks. The accounting is carried out for RSS and Page Cache (unmapped) pages. There is now a common limit and accounting for both. The RSS accounting is accounted at page_add_*_rmap() and page_remove_rmap() time. Page cache is accounted at add_to_page_cache(), __delete_from_page_cache(). Swap cache is also accounted for. Each page's page_cgroup is protected with the last bit of the page_cgroup pointer, this makes handling of race conditions involving simultaneous mappings of a page easier. A reference count is kept in the page_cgroup to deal with cases where a page might be unmapped from the RSS of all tasks, but still lives in the page cache. Credits go to Vaidyanathan Srinivasan for helping with reference counting work of the page cgroup. Almost all of the page cache accounting code has help from Vaidyanathan Srinivasan. [hugh@veritas.com: fix swapoff breakage] [akpm@linux-foundation.org: fix locking] Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: <Valdis.Kletnieks@vt.edu> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: fix PageUptodate data raceNick Piggin
After running SetPageUptodate, preceeding stores to the page contents to actually bring it uptodate may not be ordered with the store to set the page uptodate. Therefore, another CPU which checks PageUptodate is true, then reads the page contents can get stale data. Fix this by having an smp_wmb before SetPageUptodate, and smp_rmb after PageUptodate. Many places that test PageUptodate, do so with the page locked, and this would be enough to ensure memory ordering in those places if SetPageUptodate were only called while the page is locked. Unfortunately that is not always the case for some filesystems, but it could be an idea for the future. Also bring the handling of anonymous page uptodateness in line with that of file backed page management, by marking anon pages as uptodate when they _are_ uptodate, rather than when our implementation requires that they be marked as such. Doing allows us to get rid of the smp_wmb's in the page copying functions, which were especially added for anonymous pages for an analogous memory ordering problem. Both file and anonymous pages are handled with the same barriers. FAQ: Q. Why not do this in flush_dcache_page? A. Firstly, flush_dcache_page handles only one side (the smb side) of the ordering protocol; we'd still need smp_rmb somewhere. Secondly, hiding away memory barriers in a completely unrelated function is nasty; at least in the PageUptodate macros, they are located together with (half) the operations involved in the ordering. Thirdly, the smp_wmb is only required when first bringing the page uptodate, wheras flush_dcache_page should be called each time it is written to through the kernel mapping. It is logically the wrong place to put it. Q. Why does this increase my text size / reduce my performance / etc. A. Because it is adding the necessary instructions to eliminate the data-race. Q. Can it be improved? A. Yes, eg. if you were to create a rule that all SetPageUptodate operations run under the page lock, we could avoid the smp_rmb places where PageUptodate is queried under the page lock. Requires audit of all filesystems and at least some would need reworking. That's great you're interested, I'm eagerly awaiting your patches. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05tmpfs: move swap swizzling into shmemHugh Dickins
move_to_swap_cache and move_from_swap_cache functions (which swizzle a page between tmpfs page cache and swap cache, to avoid page copying) are only used by shmem.c; and our subsequent fix for unionfs needs different treatments in the two instances of move_from_swap_cache. Move them from swap_state.c into their callsites shmem_writepage, shmem_unuse_inode and shmem_getpage, making add_to_swap_cache externally visible. shmem.c likes to say set_page_dirty where swap_state.c liked to say SetPageDirty: respect that diversity, which __set_page_dirty_no_writeback makes moot (and implies we should lose that "shift page from clean_pages to dirty_pages list" comment: it's on neither). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05tmpfs: shuffle add_to_swap_cachesHugh Dickins
add_to_swap_cache doesn't amount to much: merge it into its sole caller read_swap_cache_async. But we'll be needing to call __add_to_swap_cache from shmem.c, so promote it to the new add_to_swap_cache. Both were static, so there's no interface confusion to worry about. And lose that inappropriate "Anon pages are already on the LRU" comment in the merging: they're not already on the LRU, as Nick Piggin noticed. Signed-off-by: Hugh Dickins <hugh@veritas.com> No-problems-with: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05tmpfs: move swap_state stats updateHugh Dickins
Both unionfs and memcgroups pose challenges to tmpfs and shmem. To help fix, it's best to move the swap swizzling functions from swap_state.c to shmem.c. As a preliminary to that, move swap stats updating down into __add_to_swap_cache, which will remain internal to swap_state.c. Well, actually, just move down the incrementation of add_total: remove noent_race and exist_race completely, they are relics of my 2.4.11 testing. Alt-SysRq-m users will be thrilled if 2.6.25 is at last free of "race M+N"s. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05swapin needs gfp_mask for loop on tmpfsHugh Dickins
Building in a filesystem on a loop device on a tmpfs file can hang when swapping, the loop thread caught in that infamous throttle_vm_writeout. In theory this is a long standing problem, which I've either never seen in practice, or long ago suppressed the recollection, after discounting my load and my tmpfs size as unrealistically high. But now, with the new aops, it has become easy to hang on one machine. Loop used to grab_cache_page before the old prepare_write to tmpfs, which seems to have been enough to free up some memory for any swapin needed; but the new write_begin lets tmpfs find or allocate the page (much nicer, since grab_cache_page missed tmpfs pages in swapcache). When allocating a fresh page, tmpfs respects loop's mapping_gfp_mask, which has __GFP_IO|__GFP_FS stripped off, and throttle_vm_writeout is designed to break out when __GFP_IO or GFP_FS is unset; but when tmfps swaps in, read_swap_cache_async allocates with GFP_HIGHUSER_MOVABLE regardless of the mapping_gfp_mask - hence the hang. So, pass gfp_mask down the line from shmem_getpage to shmem_swapin to swapin_readahead to read_swap_cache_async to add_to_swap_cache. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05swapin_readahead: move and rearrange argsHugh Dickins
swapin_readahead has never sat well in mm/memory.c: move it to mm/swap_state.c beside its kindred read_swap_cache_async. Why were its args in a different order? rearrange them. And since it was always followed by a read_swap_cache_async of the target page, fold that in and return struct page*. Then CONFIG_SWAP=n no longer needs valid_swaphandles and read_swap_cache_async stubs. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm: clarify __add_to_swap_cache lockingNick Piggin
__add_to_swap_cache unconditionally sets the page locked, which can be a bit alarming to the unsuspecting reader: in the code paths where the page is visible to other CPUs, the page should be (and is) already locked. Instead, just add a check to ensure the page is locked here, and teach the one path relying on the old behaviour to call SetPageLocked itself. [hugh@veritas.com: locking fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add __GFP_MOVABLE for callers to flag allocations from high memory that may ↵Mel Gorman
be migrated It is often known at allocation time whether a page may be migrated or not. This patch adds a flag called __GFP_MOVABLE and a new mask called GFP_HIGH_MOVABLE. Allocations using the __GFP_MOVABLE can be either migrated using the page migration mechanism or reclaimed by syncing with backing storage and discarding. An API function very similar to alloc_zeroed_user_highpage() is added for __GFP_MOVABLE allocations called alloc_zeroed_user_highpage_movable(). The flags used by alloc_zeroed_user_highpage() are not changed because it would change the semantics of an existing API. After this patch is applied there are no in-kernel users of alloc_zeroed_user_highpage() so it probably should be marked deprecated if this patch is merged. Note that this patch includes a minor cleanup to the use of __GFP_ZERO in shmem.c to keep all flag modifications to inode->mapping in the shmem_dir_alloc() helper function. This clean-up suggestion is courtesy of Hugh Dickens. Additional credit goes to Christoph Lameter and Linus Torvalds for shaping the concept. Credit to Hugh Dickens for catching issues with shmem swap vector and ramfs allocations. [akpm@linux-foundation.org: build fix] [hugh@veritas.com: __GFP_ZERO cleanup] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16vmscan: fix comments related to shrink_list()Anderson Briglia
Fix the shrink_list name on some files under mm/ directory. Signed-off-by: Anderson Briglia <anderson.briglia@indt.org.br> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-03[PATCH] lockdep: locking init debugging improvementIngo Molnar
Locking init improvement: - introduce and use __SPIN_LOCK_UNLOCKED for array initializations, to pass in the name string of locks, used by debugging Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_pagecache to per zone counterChristoph Lameter
Currently a single atomic variable is used to establish the size of the page cache in the whole machine. The zoned VM counters have the same method of implementation as the nr_pagecache code but also allow the determination of the pagecache size per zone. Remove the special implementation for nr_pagecache and make it a zoned counter named NR_FILE_PAGES. Updates of the page cache counters are always performed with interrupts off. We can therefore use the __ variant here. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01BUG_ON() Conversion in mm/swap_state.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-22[PATCH] page migration reorgChristoph Lameter
Centralize the page migration functions in anticipation of additional tinkering. Creates a new file mm/migrate.c 1. Extract buffer_migrate_page() from fs/buffer.c 2. Extract central migration code from vmscan.c 3. Extract some components from mempolicy.c 4. Export pageout() and remove_from_swap() from vmscan.c 5. Make it possible to configure NUMA systems without page migration and non-NUMA systems with page migration. I had to so some #ifdeffing in mempolicy.c that may need a cleanup. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] Direct Migration V9: Avoid writeback / page_migrate() methodChristoph Lameter
Migrate a page with buffers without requiring writeback This introduces a new address space operation migratepage() that may be used by a filesystem to implement its own version of page migration. A version is provided that migrates buffers attached to pages. Some filesystems (ext2, ext3, xfs) are modified to utilize this feature. The swapper address space operation are modified so that a regular migrate_page() will occur for anonymous pages without writeback (migrate_pages forces every anonymous page to have a swap entry). Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] SwapMig: add_to_swap() avoid atomic allocationsChristoph Lameter
Add gfp_mask to add_to_swap add_to_swap does allocations with GFP_ATOMIC in order not to interfere with swapping. During migration we may have use add_to_swap extensively which may lead to out of memory errors. This patch makes add_to_swap take a parameter that specifies the gfp mask. The page migration code can then make add_to_swap use GFP_KERNEL. Signed-off-by: Hirokazu Takahashi <taka@valinux.co.jp> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] mm: free_pages_and_swap_cache optHugh Dickins
Minor optimization (though it doesn't help in the PREEMPT case, severely constrained by small ZAP_BLOCK_SIZE). free_pages_and_swap_cache works in chunks of 16, calling release_pages which works in chunks of PAGEVEC_SIZE. But PAGEVEC_SIZE was dropped from 16 to 14 in 2.6.10, so we're now doing more spin_lock_irq'ing than necessary: use PAGEVEC_SIZE throughout. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm/swap_state.c: unexport swapper_spaceAdrian Bunk
I didn't find any possible modular usage in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: update comments to pte lockHugh Dickins
Updated several references to page_table_lock in common code comments. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
