path: root/mm/truncate.c
2017-06-14fs: add i_blocksize()Fabian Frederick
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream. Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs branch. This patch also fixes multiple checkpatch warnings: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' Thanks to Andrew Morton for suggesting more appropriate function instead of macro. [geliangtang@gmail.com: truncate: use i_blocksize()] Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Geliang Tang <geliangtang@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-30mm: fix false-positive WARN_ON() in truncate/invalidate for hugetlbKirill A. Shutemov
Hugetlb pages have ->index in size of the huge pages (PMD_SIZE or PUD_SIZE), not in PAGE_SIZE as other types of pages. This means we cannot user page_to_pgoff() to check whether we've got the right page for the radix-tree index. Let's introduce page_to_index() which would return radix-tree index for given page. We will be able to get rid of this once hugetlb will be switched to multi-order entries. Fixes: fc127da085c2 ("truncate: handle file thp") Link: http://lkml.kernel.org/r/20161123093053.mjbnvn5zwxw5e6lk@black.fi.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Doug Nelson <doug.nelson@intel.com> Tested-by: Doug Nelson <doug.nelson@intel.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> [4.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26truncate: handle file thpKirill A. Shutemov
For shmem/tmpfs we only need to tweak truncate_inode_page() and invalidate_mapping_pages(). truncate_inode_pages_range() and invalidate_inode_pages2_range() are adjusted to use page_to_pgoff(). Link: http://lkml.kernel.org/r/1466021202-61880-26-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19dax: New fault lockingJan Kara
Currently DAX page fault locking is racy. CPU0 (write fault) CPU1 (read fault) __dax_fault() __dax_fault() get_block(inode, block, &bh, 0) -> not mapped get_block(inode, block, &bh, 0) -> not mapped if (!buffer_mapped(&bh)) if (vmf->flags & FAULT_FLAG_WRITE) get_block(inode, block, &bh, 1) -> allocates blocks if (page) -> no if (!buffer_mapped(&bh)) if (vmf->flags & FAULT_FLAG_WRITE) { } else { dax_load_hole(); } dax_insert_mapping() And we are in a situation where we fail in dax_radix_entry() with -EIO. Another problem with the current DAX page fault locking is that there is no race-free way to clear dirty tag in the radix tree. We can always end up with clean radix tree and dirty data in CPU cache. We fix the first problem by introducing locking of exceptional radix tree entries in DAX mappings acting very similarly to page lock and thus synchronizing properly faults against the same mapping index. The same lock can later be used to avoid races when clearing radix tree dirty tag. Reviewed-by: NeilBrown <neilb@suse.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm: remove unnecessary uses of lock_page_memcg()Johannes Weiner
There are several users that nest lock_page_memcg() inside lock_page() to prevent page->mem_cgroup from changing. But the page lock prevents pages from moving between cgroups, so that is unnecessary overhead. Remove lock_page_memcg() in contexts with locked contexts and fix the debug code in the page stat functions to be okay with the page lock. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm: simplify lock_page_memcg()Johannes Weiner
Now that migration doesn't clear page->mem_cgroup of live pages anymore, it's safe to make lock_page_memcg() and the memcg stat functions take pages, and spare the callers from memcg objects. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm: memcontrol: generalize locking for the page->mem_cgroup bindingJohannes Weiner
These patches tag the page cache radix tree eviction entries with the memcg an evicted page belonged to, thus making per-cgroup LRU reclaim work properly and be as adaptive to new cache workingsets as global reclaim already is. This should have been part of the original thrash detection patch series, but was deferred due to the complexity of those patches. This patch (of 5): So far the only sites that needed to exclude charge migration to stabilize page->mem_cgroup have been per-cgroup page statistics, hence the name mem_cgroup_begin_page_stat(). But per-cgroup thrash detection will add another site that needs to ensure page->mem_cgroup lifetime. Rename these locking functions to the more generic lock_page_memcg() and unlock_page_memcg(). Since charge migration is a cgroup1 feature only, we might be able to delete it at some point, and these now easy to identify locking sites along with it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Suggested-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22dax: support dirty DAX entries in radix treeRoss Zwisler
Add support for tracking dirty DAX entries in the struct address_space radix tree. This tree is already used for dirty page writeback, and it already supports the use of exceptional (non struct page*) entries. In order to properly track dirty DAX pages we will insert new exceptional entries into the radix tree that represent dirty DAX PTE or PMD pages. These exceptional entries will also contain the writeback addresses for the PTE or PMD faults that we can use at fsync/msync time. There are currently two types of exceptional entries (shmem and shadow) that can be placed into the radix tree, and this adds a third. We rely on the fact that only one type of exceptional entry can be found in a given radix tree based on its usage. This happens for free with DAX vs shmem but we explicitly prevent shadow entries from being added to radix trees for DAX mappings. The only shadow entries that would be generated for DAX radix trees would be to track zero page mappings that were created for holes. These pages would receive minimal benefit from having shadow entries, and the choice to have only one type of exceptional entry in a given radix tree makes the logic simpler both in clear_exceptional_entry() and in the rest of DAX. Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Dave Chinner <david@fromorbit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jan Kara <jack@suse.com> Cc: Jeff Layton <jlayton@poochiereds.net> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02memcg: add per cgroup dirty page accountingGreg Thelen
When modifying PG_Dirty on cached file pages, update the new MEM_CGROUP_STAT_DIRTY counter. This is done in the same places where global NR_FILE_DIRTY is managed. The new memcg stat is visible in the per memcg memory.stat cgroupfs file. The most recent past attempt at this was http://thread.gmane.org/gmane.linux.kernel.cgroups/8632 The new accounting supports future efforts to add per cgroup dirty page throttling and writeback. It also helps an administrator break down a container's memory usage and provides evidence to understand memcg oom kills (the new dirty count is included in memcg oom kill messages). The ability to move page accounting between memcg (memory.move_charge_at_immigrate) makes this accounting more complicated than the global counter. The existing mem_cgroup_{begin,end}_page_stat() lock is used to serialize move accounting with stat updates. Typical update operation: memcg = mem_cgroup_begin_page_stat(page) if (TestSetPageDirty()) { [...] mem_cgroup_update_page_stat(memcg) } mem_cgroup_end_page_stat(memcg) Summary of mem_cgroup_end_page_stat() overhead: - Without CONFIG_MEMCG it's a no-op - With CONFIG_MEMCG and no inter memcg task movement, it's just rcu_read_lock() - With CONFIG_MEMCG and inter memcg task movement, it's rcu_read_lock() + spin_lock_irqsave() A memcg parameter is added to several routines because their callers now grab mem_cgroup_begin_page_stat() which returns the memcg later needed by for mem_cgroup_update_page_stat(). Because mem_cgroup_begin_page_stat() may disable interrupts, some adjustments are needed: - move __mark_inode_dirty() from __set_page_dirty() to its caller. __mark_inode_dirty() locking does not want interrupts disabled. - use spin_lock_irqsave(tree_lock) rather than spin_lock_irq() in __delete_from_page_cache(), replace_page_cache_page(), invalidate_complete_page2(), and __remove_mapping(). text data bss dec hex filename 8925147 1774832 1785856 12485835 be84cb vmlinux-!CONFIG_MEMCG-before 8925339 1774832 1785856 12486027 be858b vmlinux-!CONFIG_MEMCG-after +192 text bytes 8965977 1784992 1785856 12536825 bf4bf9 vmlinux-CONFIG_MEMCG-before 8966750 1784992 1785856 12537598 bf4efe vmlinux-CONFIG_MEMCG-after +773 text bytes Performance tests run on v4.0-rc1-36-g4f671fe2f952. Lower is better for all metrics, they're all wall clock or cycle counts. The read and write fault benchmarks just measure fault time, they do not include I/O time. * CONFIG_MEMCG not set: baseline patched kbuild 1m25.030000(+-0.088% 3 samples) 1m25.426667(+-0.120% 3 samples) dd write 100 MiB 0.859211561 +-15.10% 0.874162885 +-15.03% dd write 200 MiB 1.670653105 +-17.87% 1.669384764 +-11.99% dd write 1000 MiB 8.434691190 +-14.15% 8.474733215 +-14.77% read fault cycles 254.0(+-0.000% 10 samples) 253.0(+-0.000% 10 samples) write fault cycles 2021.2(+-3.070% 10 samples) 1984.5(+-1.036% 10 samples) * CONFIG_MEMCG=y root_memcg: baseline patched kbuild 1m25.716667(+-0.105% 3 samples) 1m25.686667(+-0.153% 3 samples) dd write 100 MiB 0.855650830 +-14.90% 0.887557919 +-14.90% dd write 200 MiB 1.688322953 +-12.72% 1.667682724 +-13.33% dd write 1000 MiB 8.418601605 +-14.30% 8.673532299 +-15.00% read fault cycles 266.0(+-0.000% 10 samples) 266.0(+-0.000% 10 samples) write fault cycles 2051.7(+-1.349% 10 samples) 2049.6(+-1.686% 10 samples) * CONFIG_MEMCG=y non-root_memcg: baseline patched kbuild 1m26.120000(+-0.273% 3 samples) 1m25.763333(+-0.127% 3 samples) dd write 100 MiB 0.861723964 +-15.25% 0.818129350 +-14.82% dd write 200 MiB 1.669887569 +-13.30% 1.698645885 +-13.27% dd write 1000 MiB 8.383191730 +-14.65% 8.351742280 +-14.52% read fault cycles 265.7(+-0.172% 10 samples) 267.0(+-0.000% 10 samples) write fault cycles 2070.6(+-1.512% 10 samples) 2084.4(+-2.148% 10 samples) As expected anon page faults are not affected by this patch. tj: Updated to apply on top of the recent cancel_dirty_page() changes. Signed-off-by: Sha Zhengju <handai.szj@gmail.com> Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-06-02page_writeback: revive cancel_dirty_page() in a restricted formTejun Heo
cancel_dirty_page() had some issues and b9ea25152e56 ("page_writeback: clean up mess around cancel_dirty_page()") replaced it with account_page_cleaned() which makes the caller responsible for clearing the dirty bit; unfortunately, the planned changes for cgroup writeback support requires synchronization between dirty bit manipulation and stat updates. While we can open-code such synchronization in each account_page_cleaned() callsite, that's gonna be unnecessarily awkward and verbose. This patch revives cancel_dirty_page() but in a more restricted form. All it does is TestClearPageDirty() followed by account_page_cleaned() invocation if the page was dirty. This helper covers all account_page_cleaned() usages except for __delete_from_page_cache() which is a special case anyway and left alone. As this leaves no module user for account_page_cleaned(), EXPORT_SYMBOL() is dropped from it. This patch just revives cancel_dirty_page() as a trivial wrapper to replace equivalent usages and doesn't introduce any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-04-15mm: rename deactivate_page to deactivate_file_pageMinchan Kim
"deactivate_page" was created for file invalidation so it has too specific logic for file-backed pages. So, let's change the name of the function and date to a file-specific one and yield the generic name. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Shaohua Li <shli@kernel.org> Cc: Wang, Yalin <Yalin.Wang@sonymobile.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14page_writeback: clean up mess around cancel_dirty_page()Konstantin Khlebnikov
This patch replaces cancel_dirty_page() with a helper function account_page_cleaned() which only updates counters. It's called from truncate_complete_page() and from try_to_free_buffers() (hack for ext3). Page is locked in both cases, page-lock protects against concurrent dirtiers: see commit 2d6d7f982846 ("mm: protect set_page_dirty() from ongoing truncation"). Delete_from_page_cache() shouldn't be called for dirty pages, they must be handled by caller (either written or truncated). This patch treats final dirty accounting fixup at the end of __delete_from_page_cache() as a debug check and adds WARN_ON_ONCE() around it. If something removes dirty pages without proper handling that might be a bug and unwritten data might be lost. Hugetlbfs has no dirty pages accounting, ClearPageDirty() is enough here. cancel_dirty_page() in nfs_wb_page_cancel() is redundant. This is helper for nfs_invalidate_page() and it's called only in case complete invalidation. The mess was started in v2.6.20 after commits 46d2277c796f ("Clean up and make try_to_free_buffers() not race with dirty pages") and 3e67c0987d75 ("truncate: clear page dirtiness before running try_to_free_buffers()") first was reverted right in v2.6.20 in commit ecdfc9787fe5 ("Resurrect 'try_to_free_buffers()' VM hackery"), second in v2.6.25 commit a2b345642f53 ("Fix dirty page accounting leak with ext3 data=journal"). Custom fixes were introduced between these points. NFS in v2.6.23, commit 1b3b4a1a2deb ("NFS: Fix a write request leak in nfs_invalidate_page()"). Kludge in __delete_from_page_cache() in v2.6.24, commit 3a6927906f1b ("Do dirty page accounting when removing a page from the page cache"). Since v2.6.25 all of them are redundant. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Tejun Heo <tj@kernel.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: export inode_to_bdi and use it in favor of mapping->backing_dev_infoChristoph Hellwig
Now that we got rid of the bdi abuse on character devices we can always use sb->s_bdi to get at the backing_dev_info for a file, except for the block device special case. Export inode_to_bdi and replace uses of mapping->backing_dev_info with it to prepare for the removal of mapping->backing_dev_info. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-11-07mm: Fix comment before truncate_setsize()Jan Kara
XFS doesn't always hold i_mutex when calling truncate_setsize() and it uses a different lock to serialize truncates and writes. So fix the comment before truncate_setsize(). Reported-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-10-30mm: Remove false WARN_ON from pagecache_isize_extended()Jan Kara
The WARN_ON checking whether i_mutex is held in pagecache_isize_extended() was wrong because some filesystems (e.g. XFS) use different locks for serialization of truncates / writes. So just remove the check. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2014-10-01vfs: fix data corruption when blocksize < pagesize for mmaped dataJan Kara
->page_mkwrite() is used by filesystems to allocate blocks under a page which is becoming writeably mmapped in some process' address space. This allows a filesystem to return a page fault if there is not enough space available, user exceeds quota or similar problem happens, rather than silently discarding data later when writepage is called. However VFS fails to call ->page_mkwrite() in all the cases where filesystems need it when blocksize < pagesize. For example when blocksize = 1024, pagesize = 4096 the following is problematic: ftruncate(fd, 0); pwrite(fd, buf, 1024, 0); map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0); map[0] = 'a'; ----> page_mkwrite() for index 0 is called ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */ mremap(map, 1024, 10000, 0); map[4095] = 'a'; ----> no page_mkwrite() called At the moment ->page_mkwrite() is called, filesystem can allocate only one block for the page because i_size == 1024. Otherwise it would create blocks beyond i_size which is generally undesirable. But later at ->writepage() time, we also need to store data at offset 4095 but we don't have block allocated for it. This patch introduces a helper function filesystems can use to have ->page_mkwrite() called at all the necessary moments. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-23mm/fs: fix pessimization in hole-punching pagecacheHugh Dickins
I wanted to revert my v3.1 commit d0823576bf4b ("mm: pincer in truncate_inode_pages_range"), to keep truncate_inode_pages_range() in synch with shmem_undo_range(); but have stepped back - a change to hole-punching in truncate_inode_pages_range() is a change to hole-punching in every filesystem (except tmpfs) that supports it. If there's a logical proof why no filesystem can depend for its own correctness on the pincer guarantee in truncate_inode_pages_range() - an instant when the entire hole is removed from pagecache - then let's revisit later. But the evidence is that only tmpfs suffered from the livelock, and we have no intention of extending hole-punch to ramfs. So for now just add a few comments (to match or differ from those in shmem_undo_range()), and fix one silliness noticed in d0823576bf4b... Its "index == start" addition to the hole-punch termination test was incomplete: it opened a way for the end condition to be missed, and the loop go on looking through the radix_tree, all the way to end of file. Fix that pessimization by resetting index when detected in inner loop. Note that it's actually hard to hit this case, without the obsessive concurrent faulting that trinity does: normally all pages are removed in the initial trylock_page() pass, and this loop finds nothing to do. I had to "#if 0" out the initial pass to reproduce bug and test fix. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Lukas Czerner <lczerner@redhat.com> Cc: Dave Jones <davej@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06mm: filemap: update find_get_pages_tag() to deal with shadow entriesJohannes Weiner
Dave Jones reports the following crash when find_get_pages_tag() runs into an exceptional entry: kernel BUG at mm/filemap.c:1347! RIP: find_get_pages_tag+0x1cb/0x220 Call Trace: find_get_pages_tag+0x36/0x220 pagevec_lookup_tag+0x21/0x30 filemap_fdatawait_range+0xbe/0x1e0 filemap_fdatawait+0x27/0x30 sync_inodes_sb+0x204/0x2a0 sync_inodes_one_sb+0x19/0x20 iterate_supers+0xb2/0x110 sys_sync+0x44/0xb0 ia32_do_call+0x13/0x13 1343 /* 1344 * This function is never used on a shmem/tmpfs 1345 * mapping, so a swap entry won't be found here. 1346 */ 1347 BUG(); After commit 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees") this comment and BUG() are out of date because exceptional entries can now appear in all mappings - as shadows of recently evicted pages. However, as Hugh Dickins notes, "it is truly surprising for a PAGECACHE_TAG_WRITEBACK (and probably any other PAGECACHE_TAG_*) to appear on an exceptional entry. I expect it comes down to an occasional race in RCU lookup of the radix_tree: lacking absolute synchronization, we might sometimes catch an exceptional entry, with the tag which really belongs with the unexceptional entry which was there an instant before." And indeed, not only is the tree walk lockless, the tags are also read in chunks, one radix tree node at a time. There is plenty of time for page reclaim to swoop in and replace a page that was already looked up as tagged with a shadow entry. Remove the BUG() and update the comment. While reviewing all other lookup sites for whether they properly deal with shadow entries of evicted pages, update all the comments and fix memcg file charge moving to not miss shmem/tmpfs swapcache pages. Fixes: 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees") Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Dave Jones <davej@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: keep page cache radix tree nodes in checkJohannes Weiner
Previously, page cache radix tree nodes were freed after reclaim emptied out their page pointers. But now reclaim stores shadow entries in their place, which are only reclaimed when the inodes themselves are reclaimed. This is problematic for bigger files that are still in use after they have a significant amount of their cache reclaimed, without any of those pages actually refaulting. The shadow entries will just sit there and waste memory. In the worst case, the shadow entries will accumulate until the machine runs out of memory. To get this under control, the VM will track radix tree nodes exclusively containing shadow entries on a per-NUMA node list. Per-NUMA rather than global because we expect the radix tree nodes themselves to be allocated node-locally and we want to reduce cross-node references of otherwise independent cache workloads. A simple shrinker will then reclaim these nodes on memory pressure. A few things need to be stored in the radix tree node to implement the shadow node LRU and allow tree deletions coming from the list: 1. There is no index available that would describe the reverse path from the node up to the tree root, which is needed to perform a deletion. To solve this, encode in each node its offset inside the parent. This can be stored in the unused upper bits of the same member that stores the node's height at no extra space cost. 2. The number of shadow entries needs to be counted in addition to the regular entries, to quickly detect when the node is ready to go to the shadow node LRU list. The current entry count is an unsigned int but the maximum number of entries is 64, so a shadow counter can easily be stored in the unused upper bits. 3. Tree modification needs tree lock and tree root, which are located in the address space, so store an address_space backpointer in the node. The parent pointer of the node is in a union with the 2-word rcu_head, so the backpointer comes at no extra cost as well. 4. The node needs to be linked to an LRU list, which requires a list head inside the node. This does increase the size of the node, but it does not change the number of objects that fit into a slab page. [akpm@linux-foundation.org: export the right function] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: prepare for non-page entries in page cache radix treesJohannes Weiner
shmem mappings already contain exceptional entries where swap slot information is remembered. To be able to store eviction information for regular page cache, prepare every site dealing with the radix trees directly to handle entries other than pages. The common lookup functions will filter out non-page entries and return NULL for page cache holes, just as before. But provide a raw version of the API which returns non-page entries as well, and switch shmem over to use it. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-27mm: teach truncate_inode_pages_range() to handle non page aligned rangesLukas Czerner
This commit changes truncate_inode_pages_range() so it can handle non page aligned regions of the truncate. Currently we can hit BUG_ON when the end of the range is not page aligned, but we can handle unaligned start of the range. Being able to handle non page aligned regions of the page can help file system punch_hole implementations and save some work, because once we're holding the page we might as well deal with it right away. In previous commits we've changed ->invalidatepage() prototype to accept 'length' argument to be able to specify range to invalidate. No we can use that new ability in truncate_inode_pages_range(). Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2012-12-20mm: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-09mm: use clear_page_mlock() in page_remove_rmap()Hugh Dickins
We had thought that pages could no longer get freed while still marked as mlocked; but Johannes Weiner posted this program to demonstrate that truncating an mlocked private file mapping containing COWed pages is still mishandled: #include <sys/types.h> #include <sys/mman.h> #include <sys/stat.h> #include <stdlib.h> #include <unistd.h> #include <fcntl.h> #include <stdio.h> int main(void) { char *map; int fd; system("grep mlockfreed /proc/vmstat"); fd = open("chigurh", O_CREAT|O_EXCL|O_RDWR); unlink("chigurh"); ftruncate(fd, 4096); map = mmap(NULL, 4096, PROT_WRITE, MAP_PRIVATE, fd, 0); map[0] = 11; mlock(map, sizeof(fd)); ftruncate(fd, 0); close(fd); munlock(map, sizeof(fd)); munmap(map, 4096); system("grep mlockfreed /proc/vmstat"); return 0; } The anon COWed pages are not caught by truncation's clear_page_mlock() of the pagecache pages; but unmap_mapping_range() unmaps them, so we ought to look out for them there in page_remove_rmap(). Indeed, why should truncation or invalidation be doing the clear_page_mlock() when removing from pagecache? mlock is a property of mapping in userspace, not a property of pagecache: an mlocked unmapped page is nonsensical. Reported-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: fix invalidate_complete_page2() lock orderingHugh Dickins
In fuzzing with trinity, lockdep protested "possible irq lock inversion dependency detected" when isolate_lru_page() reenabled interrupts while still holding the supposedly irq-safe tree_lock: invalidate_inode_pages2 invalidate_complete_page2 spin_lock_irq(&mapping->tree_lock) clear_page_mlock isolate_lru_page spin_unlock_irq(&zone->lru_lock) isolate_lru_page() is correct to enable interrupts unconditionally: invalidate_complete_page2() is incorrect to call clear_page_mlock() while holding tree_lock, which is supposed to nest inside lru_lock. Both truncate_complete_page() and invalidate_complete_page() call clear_page_mlock() before taking tree_lock to remove page from radix_tree. I guess invalidate_complete_page2() preferred to test PageDirty (again) under tree_lock before committing to the munlock; but since the page has already been unmapped, its state is already somewhat inconsistent, and no worse if clear_page_mlock() moved up. Reported-by: Sasha Levin <levinsasha928@gmail.com> Deciphered-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm/fs: remove truncate_rangeHugh Dickins
Remove vmtruncate_range(), and remove the truncate_range method from struct inode_operations: only tmpfs ever supported it, and tmpfs has now converted over to using the fallocate method of file_operations. Update Documentation accordingly, adding (setlease and) fallocate lines. And while we're in mm.h, remove duplicate declarations of shmem_lock() and shmem_file_setup(): everyone is now using the ones in shmem_fs.h. Based-on-patch-by: Cong Wang <amwang@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Cong Wang <amwang@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm for fs: add truncate_pagecache_range()Hugh Dickins
Holepunching filesystems ext4 and xfs are using truncate_inode_pages_range but forgetting to unmap pages first (ocfs2 remembers). This is not really a bug, since races already require truncate_inode_page() to handle that case once the page is locked; but it can be very inefficient if the file being punched happens to be mapped into many vmas. Provide a drop-in replacement truncate_pagecache_range() which does the unmapping pass first, handling the awkward mismatch between arguments to truncate_inode_pages_range() and arguments to unmap_mapping_range(). Note that holepunching does not unmap privately COWed pages in the range: POSIX requires that we do so when truncating, but it's hard to justify, difficult to implement without an i_size cutoff, and no filesystem is attempting to implement it. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: Alex Elder <elder@kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-02-23mm: fix comment typo of truncate_inode_pages_rangeLiu Bo
The typo of API truncate_inode_pages_range is not updated. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-01-23mm: cleancache: s/flush/invalidate/Dan Magenheimer
Per akpm suggestions alter the use of the term flush to be invalidate. The next patch will do this across all MM. This change is completely cosmetic. [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v10: Fixed fs: move code out of buffer.c conflict change] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-10-31mm: Map most files to use export.h instead of module.hPaul Gortmaker
The files changed within are only using the EXPORT_SYMBOL macro variants. They are not using core modular infrastructure and hence don't need module.h but only the export.h header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-03mm: a few small updates for radix-swapHugh Dickins
Remove PageSwapBacked (!page_is_file_cache) cases from add_to_page_cache_locked() and add_to_page_cache_lru(): those pages now go through shmem_add_to_page_cache(). Remove a comment on maximum tmpfs size from fsstack_copy_inode_size(), and add a comment on swap entries to invalidate_mapping_pages(). And mincore_page() uses find_get_page() on what might be shmem or a tmpfs file: allow for a radix_tree_exceptional_entry(), and proceed to find_get_page() on swapper_space if so (oh, swapper_space needs #ifdef). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: pincer in truncate_inode_pages_rangeHugh Dickins
truncate_inode_pages_range()'s final loop has a nice pincer property, bringing start and end together, squeezing out the last pages. But the range handling missed out on that, just sliding up the range, perhaps letting pages come in behind it. Add one more test to give it the same pincer effect. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: consistent truncate and invalidate loopsHugh Dickins
Make the pagevec_lookup loops in truncate_inode_pages_range(), invalidate_mapping_pages() and invalidate_inode_pages2_range() more consistent with each other. They were relying upon page->index of an unlocked page, but apologizing for it: accept it, embrace it, add comments and WARN_ONs, and simplify the index handling. invalidate_inode_pages2_range() had special handling for a wrapped page->index + 1 = 0 case; but MAX_LFS_FILESIZE doesn't let us anywhere near there, and a corrupt page->index in the radix_tree could cause more trouble than that would catch. Remove that wrapped handling. invalidate_inode_pages2_range() uses min() to limit the pagevec_lookup when near the end of the range: copy that into the other two, although it's less useful than you might think (it limits the use of the buffer, rather than the indices looked up). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: tidy vmtruncate_range and related functionsHugh Dickins
Use consistent variable names in truncate_pagecache(), truncate_setsize(), vmtruncate() and vmtruncate_range(). unmap_mapping_range() and vmtruncate_range() have mismatched interfaces: don't change either, but make the vmtruncates more precise about what they expect unmap_mapping_range() to do. vmtruncate_range() is currently called only with page-aligned start and end+1: can handle unaligned start, but unaligned end+1 would hit BUG_ON in truncate_inode_pages_range() (lacks partial clearing of the end page). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20fs: kill i_alloc_semChristoph Hellwig
i_alloc_sem is a rather special rw_semaphore. It's the last one that may be released by a non-owner, and it's write side is always mirrored by real exclusion. It's intended use it to wait for all pending direct I/O requests to finish before starting a truncate. Replace it with a hand-grown construct: - exclusion for truncates is already guaranteed by i_mutex, so it can simply fall way - the reader side is replaced by an i_dio_count member in struct inode that counts the number of pending direct I/O requests. Truncate can't proceed as long as it's non-zero - when i_dio_count reaches non-zero we wake up a pending truncate using wake_up_bit on a new bit in i_flags - new references to i_dio_count can't appear while we are waiting for it to read zero because the direct I/O count always needs i_mutex (or an equivalent like XFS's i_iolock) for starting a new operation. This scheme is much simpler, and saves the space of a spinlock_t and a struct list_head in struct inode (typically 160 bits on a non-debug 64-bit system). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move vmtruncate_range to truncate.cHugh Dickins
You would expect to find vmtruncate_range() next to vmtruncate() in mm/truncate.c: move it there. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-03-22mm: deactivate invalidated pagesMinchan Kim
Recently, there are reported problem about thrashing. (http://marc.info/?l=rsync&m=128885034930933&w=2) It happens by backup workloads(ex, nightly rsync). That's because the workload makes just use-once pages and touches pages twice. It promotes the page into active list so that it results in working set page eviction. Some app developer want to support POSIX_FADV_NOREUSE. But other OSes don't support it, either. (http://marc.info/?l=linux-mm&m=128928979512086&w=2) By other approach, app developers use POSIX_FADV_DONTNEED. But it has a problem. If kernel meets page is writing during invalidate_mapping_pages, it can't work. It makes for application programmer to use it since they always have to sync data before calling fadivse(..POSIX_FADV_DONTNEED) to make sure the pages could be discardable. At last, they can't use deferred write of kernel so that they could see performance loss. (http://insights.oetiker.ch/linux/fadvise.html) In fact, invalidation is very big hint to reclaimer. It means we don't use the page any more. So let's move the writing page into inactive list's head if we can't truncate it right now. Why I move page to head of lru on this patch, Dirty/Writeback page would be flushed sooner or later. It can prevent writeout of pageout which is less effective than flusher's writeout. Originally, I reused lru_demote of Peter with some change so added his Signed-off-by. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reported-by: Ben Gamari <bgamari.foss@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: change __remove_from_page_cache()Minchan Kim
Now we renamed remove_from_page_cache with delete_from_page_cache. As consistency of __remove_from_swap_cache and remove_from_swap_cache, we change internal page cache handling function name, too. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: truncate: change remove_from_page_cacheMinchan Kim
This patch series changes remove_from_page_cache()'s page ref counting rule. Page cache ref count is decreased in delete_from_page_cache(). So we don't need to decrease the page reference in callers. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-25memcg: more mem_cgroup_uncharge() batchingHugh Dickins
It seems odd that truncate_inode_pages_range(), called not only when truncating but also when evicting inodes, has mem_cgroup_uncharge_start and _end() batching in its second loop to clear up a few leftovers, but not in its first loop that does almost all the work: add them there too. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20mm: fix truncate_setsize() commentJan Kara
Contrary to what the comment says, truncate_setsize() should be called *before* filesystem truncated blocks. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02Call the filesystem back whenever a page is removed from the page cacheLinus Torvalds
NFS needs to be able to release objects that are stored in the page cache once the page itself is no longer visible from the page cache. This patch adds a callback to the address space operations that allows filesystems to perform page cleanups once the page has been removed from the page cache. Original patch by: Linus Torvalds <torvalds@linux-foundation.org> [trondmy: cover the cases of invalidate_inode_pages2() and truncate_inode_pages()] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
