path: root/mm/usercopy.c
2019-10-17usercopy: Avoid HIGHMEM pfn warningKees Cook
commit 314eed30ede02fa925990f535652254b5bad6b65 upstream. When running on a system with >512MB RAM with a 32-bit kernel built with: CONFIG_DEBUG_VIRTUAL=y CONFIG_HIGHMEM=y CONFIG_HARDENED_USERCOPY=y all execve()s will fail due to argv copying into kmap()ed pages, and on usercopy checking the calls ultimately of virt_to_page() will be looking for "bad" kmap (highmem) pointers due to CONFIG_DEBUG_VIRTUAL=y: ------------[ cut here ]------------ kernel BUG at ../arch/x86/mm/physaddr.c:83! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.3.0-rc8 #6 Hardware name: Dell Inc. Inspiron 1318/0C236D, BIOS A04 01/15/2009 EIP: __phys_addr+0xaf/0x100 ... Call Trace: __check_object_size+0xaf/0x3c0 ? __might_sleep+0x80/0xa0 copy_strings+0x1c2/0x370 copy_strings_kernel+0x2b/0x40 __do_execve_file+0x4ca/0x810 ? kmem_cache_alloc+0x1c7/0x370 do_execve+0x1b/0x20 ... The check is from arch/x86/mm/physaddr.c: VIRTUAL_BUG_ON((phys_addr >> PAGE_SHIFT) > max_low_pfn); Due to the kmap() in fs/exec.c: kaddr = kmap(kmapped_page); ... if (copy_from_user(kaddr+offset, str, bytes_to_copy)) ... Now we can fetch the correct page to avoid the pfn check. In both cases, hardened usercopy will need to walk the page-span checker (if enabled) to do sanity checking. Reported-by: Randy Dunlap <rdunlap@infradead.org> Tested-by: Randy Dunlap <rdunlap@infradead.org> Fixes: f5509cc18daa ("mm: Hardened usercopy") Cc: Matthew Wilcox <willy@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Link: https://lore.kernel.org/r/201909171056.7F2FFD17@keescook Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-25mm/usercopy: use memory range to be accessed for wraparound checkIsaac J. Manjarres
commit 951531691c4bcaa59f56a316e018bc2ff1ddf855 upstream. Currently, when checking to see if accessing n bytes starting at address "ptr" will cause a wraparound in the memory addresses, the check in check_bogus_address() adds an extra byte, which is incorrect, as the range of addresses that will be accessed is [ptr, ptr + (n - 1)]. This can lead to incorrectly detecting a wraparound in the memory address, when trying to read 4 KB from memory that is mapped to the the last possible page in the virtual address space, when in fact, accessing that range of memory would not cause a wraparound to occur. Use the memory range that will actually be accessed when considering if accessing a certain amount of bytes will cause the memory address to wrap around. Link: http://lkml.kernel.org/r/1564509253-23287-1-git-send-email-isaacm@codeaurora.org Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Prasad Sodagudi <psodagud@codeaurora.org> Signed-off-by: Isaac J. Manjarres <isaacm@codeaurora.org> Co-developed-by: Prasad Sodagudi <psodagud@codeaurora.org> Reviewed-by: William Kucharski <william.kucharski@oracle.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Trilok Soni <tsoni@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [kees: backport to v4.9] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-20mm: usercopy: Check for module addressesLaura Abbott
While running a compile on arm64, I hit a memory exposure usercopy: kernel memory exposure attempt detected from fffffc0000f3b1a8 (buffer_head) (1 bytes) ------------[ cut here ]------------ kernel BUG at mm/usercopy.c:75! Internal error: Oops - BUG: 0 [#1] SMP Modules linked in: ip6t_rpfilter ip6t_REJECT nf_reject_ipv6 xt_conntrack ip_set nfnetlink ebtable_broute bridge stp llc ebtable_nat ip6table_security ip6table_raw ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle iptable_security iptable_raw iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle ebtable_filter ebtables ip6table_filter ip6_tables vfat fat xgene_edac xgene_enet edac_core i2c_xgene_slimpro i2c_core at803x realtek xgene_dma mdio_xgene gpio_dwapb gpio_xgene_sb xgene_rng mailbox_xgene_slimpro nfsd auth_rpcgss nfs_acl lockd grace sunrpc xfs libcrc32c sdhci_of_arasan sdhci_pltfm sdhci mmc_core xhci_plat_hcd gpio_keys CPU: 0 PID: 19744 Comm: updatedb Tainted: G W 4.8.0-rc3-threadinfo+ #1 Hardware name: AppliedMicro X-Gene Mustang Board/X-Gene Mustang Board, BIOS 3.06.12 Aug 12 2016 task: fffffe03df944c00 task.stack: fffffe00d128c000 PC is at __check_object_size+0x70/0x3f0 LR is at __check_object_size+0x70/0x3f0 ... [<fffffc00082b4280>] __check_object_size+0x70/0x3f0 [<fffffc00082cdc30>] filldir64+0x158/0x1a0 [<fffffc0000f327e8>] __fat_readdir+0x4a0/0x558 [fat] [<fffffc0000f328d4>] fat_readdir+0x34/0x40 [fat] [<fffffc00082cd8f8>] iterate_dir+0x190/0x1e0 [<fffffc00082cde58>] SyS_getdents64+0x88/0x120 [<fffffc0008082c70>] el0_svc_naked+0x24/0x28 fffffc0000f3b1a8 is a module address. Modules may have compiled in strings which could get copied to userspace. In this instance, it looks like "." which matches with a size of 1 byte. Extend the is_vmalloc_addr check to be is_vmalloc_or_module_addr to cover all possible cases. Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org>
2016-09-07usercopy: remove page-spanning test for nowKees Cook
A custom allocator without __GFP_COMP that copies to userspace has been found in vmw_execbuf_process[1], so this disables the page-span checker by placing it behind a CONFIG for future work where such things can be tracked down later. [1] https://bugzilla.redhat.com/show_bug.cgi?id=1373326 Reported-by: Vinson Lee <vlee@freedesktop.org> Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Kees Cook <keescook@chromium.org>
2016-08-22usercopy: fix overlap check for kernel textJosh Poimboeuf
When running with a local patch which moves the '_stext' symbol to the very beginning of the kernel text area, I got the following panic with CONFIG_HARDENED_USERCOPY: usercopy: kernel memory exposure attempt detected from ffff88103dfff000 (<linear kernel text>) (4096 bytes) ------------[ cut here ]------------ kernel BUG at mm/usercopy.c:79! invalid opcode: 0000 [#1] SMP ... CPU: 0 PID: 4800 Comm: cp Not tainted 4.8.0-rc3.after+ #1 Hardware name: Dell Inc. PowerEdge R720/0X3D66, BIOS 2.5.4 01/22/2016 task: ffff880817444140 task.stack: ffff880816274000 RIP: 0010:[<ffffffff8121c796>] __check_object_size+0x76/0x413 RSP: 0018:ffff880816277c40 EFLAGS: 00010246 RAX: 000000000000006b RBX: ffff88103dfff000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffff88081f80dfa8 RDI: ffff88081f80dfa8 RBP: ffff880816277c90 R08: 000000000000054c R09: 0000000000000000 R10: 0000000000000005 R11: 0000000000000006 R12: 0000000000001000 R13: ffff88103e000000 R14: ffff88103dffffff R15: 0000000000000001 FS: 00007fb9d1750800(0000) GS:ffff88081f800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000021d2000 CR3: 000000081a08f000 CR4: 00000000001406f0 Stack: ffff880816277cc8 0000000000010000 000000043de07000 0000000000000000 0000000000001000 ffff880816277e60 0000000000001000 ffff880816277e28 000000000000c000 0000000000001000 ffff880816277ce8 ffffffff8136c3a6 Call Trace: [<ffffffff8136c3a6>] copy_page_to_iter_iovec+0xa6/0x1c0 [<ffffffff8136e766>] copy_page_to_iter+0x16/0x90 [<ffffffff811970e3>] generic_file_read_iter+0x3e3/0x7c0 [<ffffffffa06a738d>] ? xfs_file_buffered_aio_write+0xad/0x260 [xfs] [<ffffffff816e6262>] ? down_read+0x12/0x40 [<ffffffffa06a61b1>] xfs_file_buffered_aio_read+0x51/0xc0 [xfs] [<ffffffffa06a6692>] xfs_file_read_iter+0x62/0xb0 [xfs] [<ffffffff812224cf>] __vfs_read+0xdf/0x130 [<ffffffff81222c9e>] vfs_read+0x8e/0x140 [<ffffffff81224195>] SyS_read+0x55/0xc0 [<ffffffff81003a47>] do_syscall_64+0x67/0x160 [<ffffffff816e8421>] entry_SYSCALL64_slow_path+0x25/0x25 RIP: 0033:[<00007fb9d0c33c00>] 0x7fb9d0c33c00 RSP: 002b:00007ffc9c262f28 EFLAGS: 00000246 ORIG_RAX: 0000000000000000 RAX: ffffffffffffffda RBX: fffffffffff8ffff RCX: 00007fb9d0c33c00 RDX: 0000000000010000 RSI: 00000000021c3000 RDI: 0000000000000004 RBP: 00000000021c3000 R08: 0000000000000000 R09: 00007ffc9c264d6c R10: 00007ffc9c262c50 R11: 0000000000000246 R12: 0000000000010000 R13: 00007ffc9c2630b0 R14: 0000000000000004 R15: 0000000000010000 Code: 81 48 0f 44 d0 48 c7 c6 90 4d a3 81 48 c7 c0 bb b3 a2 81 48 0f 44 f0 4d 89 e1 48 89 d9 48 c7 c7 68 16 a3 81 31 c0 e8 f4 57 f7 ff <0f> 0b 48 8d 90 00 40 00 00 48 39 d3 0f 83 22 01 00 00 48 39 c3 RIP [<ffffffff8121c796>] __check_object_size+0x76/0x413 RSP <ffff880816277c40> The checked object's range [ffff88103dfff000, ffff88103e000000) is valid, so there shouldn't have been a BUG. The hardened usercopy code got confused because the range's ending address is the same as the kernel's text starting address at 0xffff88103e000000. The overlap check is slightly off. Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org>
2016-08-22usercopy: avoid potentially undefined behavior in pointer mathEric Biggers
check_bogus_address() checked for pointer overflow using this expression, where 'ptr' has type 'const void *': ptr + n < ptr Since pointer wraparound is undefined behavior, gcc at -O2 by default treats it like the following, which would not behave as intended: (long)n < 0 Fortunately, this doesn't currently happen for kernel code because kernel code is compiled with -fno-strict-overflow. But the expression should be fixed anyway to use well-defined integer arithmetic, since it could be treated differently by different compilers in the future or could be reported by tools checking for undefined behavior. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Kees Cook <keescook@chromium.org>
2016-07-26mm: Hardened usercopyKees Cook
This is the start of porting PAX_USERCOPY into the mainline kernel. This is the first set of features, controlled by CONFIG_HARDENED_USERCOPY. The work is based on code by PaX Team and Brad Spengler, and an earlier port from Casey Schaufler. Additional non-slab page tests are from Rik van Riel. This patch contains the logic for validating several conditions when performing copy_to_user() and copy_from_user() on the kernel object being copied to/from: - address range doesn't wrap around - address range isn't NULL or zero-allocated (with a non-zero copy size) - if on the slab allocator: - object size must be less than or equal to copy size (when check is implemented in the allocator, which appear in subsequent patches) - otherwise, object must not span page allocations (excepting Reserved and CMA ranges) - if on the stack - object must not extend before/after the current process stack - object must be contained by a valid stack frame (when there is arch/build support for identifying stack frames) - object must not overlap with kernel text Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Tested-by: Michael Ellerman <mpe@ellerman.id.au>
