path: root/mm/util.c
2006-10-01[PATCH] kmemdup: introduceAlexey Dobriyan
One of idiomatic ways to duplicate a region of memory is dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; memcpy(dst, src, len); which is neat code except a programmer needs to write size twice. Which sometimes leads to mistakes. If len passed to kmalloc is smaller that len passed to memcpy, it's straight overwrite-beyond-end. If len passed to memcpy is smaller than len passed to kmalloc, it's either a) legit behaviour ;-), or b) cloned buffer will contain garbage in second half. Slight trolling of commit lists shows several duplications bugs done exactly because of diverged lenghts: Linux: [CRYPTO]: Fix memcpy/memset args. [PATCH] memcpy/memset fixes OpenBSD: kerberosV/src/lib/asn1: der_copy.c:1.4 If programmer is given only one place to play with lengths, I believe, such mistakes could be avoided. With kmemdup, the snippet above will be rewritten as: dst = kmemdup(src, len, GFP_KERNEL); if (!dst) return -ENOMEM; This also leads to smaller code (kzalloc effect). Quick grep shows 200+ places where kmemdup() can be used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] slab: optimize constant-size kzalloc callsPekka Enberg
As suggested by Eric Dumazet, optimize kzalloc() calls that pass a compile-time constant size. Please note that the patch increases kernel text slightly (~200 bytes for defconfig on x86). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] slab: implement /proc/slab_allocatorsAl Viro
Implement /proc/slab_allocators. It produces output like: idr_layer_cache: 80 idr_pre_get+0x33/0x4e buffer_head: 2555 alloc_buffer_head+0x20/0x75 mm_struct: 9 mm_alloc+0x1e/0x42 mm_struct: 20 dup_mm+0x36/0x370 vm_area_struct: 384 dup_mm+0x18f/0x370 vm_area_struct: 151 do_mmap_pgoff+0x2e0/0x7c3 vm_area_struct: 1 split_vma+0x5a/0x10e vm_area_struct: 11 do_brk+0x206/0x2e2 vm_area_struct: 2 copy_vma+0xda/0x142 vm_area_struct: 9 setup_arg_pages+0x99/0x214 fs_cache: 8 copy_fs_struct+0x21/0x133 fs_cache: 29 copy_process+0xf38/0x10e3 files_cache: 30 alloc_files+0x1b/0xcf signal_cache: 81 copy_process+0xbaa/0x10e3 sighand_cache: 77 copy_process+0xe65/0x10e3 sighand_cache: 1 de_thread+0x4d/0x5f8 anon_vma: 241 anon_vma_prepare+0xd9/0xf3 size-2048: 1 add_sect_attrs+0x5f/0x145 size-2048: 2 journal_init_revoke+0x99/0x302 size-2048: 2 journal_init_revoke+0x137/0x302 size-2048: 2 journal_init_inode+0xf9/0x1c4 Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> DESC slab-leaks3-locking-fix EDESC From: Andrew Morton <akpm@osdl.org> Update for slab-remove-cachep-spinlock.patch Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] strndup_user()Davi Arnaut
This patch series creates a strndup_user() function to easy copying C strings from userspace. Also we avoid common pitfalls like userspace modifying the final \0 after the strlen_user(). Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] slob: introduce mm/util.c for shared functionsMatt Mackall
Add mm/util.c for functions common between SLAB and SLOB. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
