path: root/mm/util.c
2010-10-24export __get_user_pages_fast() functionXiao Guangrong
This function is used by KVM to pin process's page in the atomic context. Define the 'weak' function to avoid other architecture not support it Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-09mm: use memdup_userJulia Lawall
Use memdup_user when user data is immediately copied into the allocated region. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; position p; identifier l1,l2; @@ - to = \(kmalloc@p\|kzalloc@p\)(size,flag); + to = memdup_user(from,size); if ( - to==NULL + IS_ERR(to) || ...) { <+... when != goto l1; - -ENOMEM + PTR_ERR(to) ...+> } - if (copy_from_user(to, from, size) != 0) { - <+... when != goto l2; - -EFAULT - ...+> - } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-09slab: Generify kernel pointer validationPekka Enberg
As suggested by Linus, introduce a kern_ptr_validate() helper that does some sanity checks to make sure a pointer is a valid kernel pointer. This is a preparational step for fixing SLUB kmem_ptr_validate(). Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16nommu: don't need get_unmapped_area() for NOMMUDavid Howells
get_unmapped_area() is unnecessary for NOMMU as no-one calls it. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-30mm: move sys_mmap_pgoff from util.cHugh Dickins
Move sys_mmap_pgoff() from mm/util.c to mm/mmap.c and mm/nommu.c, where we'd expect to find such code: especially now that it contains the MAP_HUGETLB handling. Revert mm/util.c to how it was in 2.6.32. This patch just ignores MAP_HUGETLB in the nommu case, as in 2.6.32, whereas 2.6.33-rc2 reported -ENOSYS. Perhaps validate_mmap_request() should reject it with -EINVAL? Add that later if necessary. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11fix a struct file leak in do_mmap_pgoff()Al Viro
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-17Merge branches 'slab/documentation', 'slab/fixes', 'slob/cleanups' and ↵Pekka Enberg
'slub/fixes' into for-linus
2009-06-16mm: clean up get_user_pages_fast() documentationNick Piggin
Move more documentation for get_user_pages_fast into the new kerneldoc comment. Add some comments for get_user_pages as well. Also, move get_user_pages_fast declaration up to get_user_pages. It wasn't there initially because it was once a static inline function. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andy Grover <andy.grover@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-01slab: document kzfree() zeroing behaviorPekka Enberg
As suggested by Alan Cox, document the fact that kzfree() can zero out a great deal more memory than the what the user requested from kmalloc(). Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-13mm: document get_user_pages_fast()Andy Grover
While better than get_user_pages(), the usage of gupf(), especially the return values and the fact that it can potentially only partially pin the range, warranted some documentation. Signed-off-by: Andy Grover <andy.grover@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03kmemtrace: use tracepointsEduard - Gabriel Munteanu
kmemtrace now uses tracepoints instead of markers. We no longer need to use format specifiers to pass arguments. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> [ folded: Use the new TP_PROTO and TP_ARGS to fix the build. ] [ folded: fix build when CONFIG_KMEMTRACE is disabled. ] [ folded: define tracepoints when CONFIG_TRACEPOINTS is enabled. ] Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <ae61c0f37156db8ec8dc0d5778018edde60a92e3.1237813499.git.eduard.munteanu@linux360.ro> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-01memdup_user(): introduceLi Zefan
I notice there are many places doing copy_from_user() which follows kmalloc(): dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; if (copy_from_user(dst, src, len)) { kfree(dst); return -EFAULT } memdup_user() is a wrapper of the above code. With this new function, we don't have to write 'len' twice, which can lead to typos/mistakes. It also produces smaller code and kernel text. A quick grep shows 250+ places where memdup_user() *may* be used. I'll prepare a patchset to do this conversion. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20slab: introduce kzfree()Johannes Weiner
kzfree() is a wrapper for kfree() that additionally zeroes the underlying memory before releasing it to the slab allocator. Currently there is code which memset()s the memory region of an object before releasing it back to the slab allocator to make sure security-sensitive data are really zeroed out after use. These callsites can then just use kzfree() which saves some code, makes users greppable and allows for a stupid destructor that isn't necessarily aware of the actual object size. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12mm: Make generic weak get_user_pages_fast and EXPORT_GPL itRusty Russell
Out of line get_user_pages_fast fallback implementation, make it a weak symbol, get rid of CONFIG_HAVE_GET_USER_PAGES_FAST. Export the symbol to modules so lguest can use it. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix ip_rt_frag_needed rt_is_expired netfilter: nf_conntrack_extend: avoid unnecessary "ct->ext" dereferences netfilter: fix double-free and use-after free netfilter: arptables in netns for real netfilter: ip{,6}tables_security: fix future section mismatch selinux: use nf_register_hooks() netfilter: ebtables: use nf_register_hooks() Revert "pkt_sched: sch_sfq: dump a real number of flows" qeth: use dev->ml_priv instead of dev->priv syncookies: Make sure ECN is disabled net: drop unused BUG_TRAP() net: convert BUG_TRAP to generic WARN_ON drivers/net: convert BUG_TRAP to generic WARN_ON
2008-07-26mm/util.c must #include <linux/sched.h>Adrian Bunk
mm/util.c: In function 'arch_pick_mmap_layout': mm/util.c:144: error: dereferencing pointer to incomplete type mm/util.c:145: error: 'arch_get_unmapped_area' undeclared (first use in this function) mm/util.c:145: error: (Each undeclared identifier is reported only once mm/util.c:145: error: for each function it appears in.) mm/util.c:146: error: 'arch_unmap_area' undeclared (first use in this function) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26netfilter: fix double-free and use-after freePekka Enberg
As suggested by Patrick McHardy, introduce a __krealloc() that doesn't free the original buffer to fix a double-free and use-after-free bug introduced by me in netfilter that uses RCU. Reported-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Dieter Ries <clip2@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26uninline arch_pick_mmap_layout()Andrew Morton
Fix this, on avr32: include/linux/utsname.h:35, from init/main.c:20: include/linux/sched.h: In function 'arch_pick_mmap_layout': include/linux/sched.h:2149: error: implicit declaration of function 'PAGE_ALIGN' Reported-by: Adrian Bunk <bunk@kernel.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14fix mm/util.c:krealloc()Adrian Bunk
Commit ef8b4520bd9f8294ffce9abd6158085bde5dc902 added one NULL check for "p" in krealloc(), but that doesn't seem to be enough since there doesn't seem to be any guarantee that memcpy(ret, NULL, 0) works (spotted by the Coverity checker). For making it clearer what happens this patch also removes the pointless min(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Slab allocators: fail if ksize is called with a NULL parameterChristoph Lameter
A NULL pointer means that the object was not allocated. One cannot determine the size of an object that has not been allocated. Currently we return 0 but we really should BUG() on attempts to determine the size of something nonexistent. krealloc() interprets NULL to mean a zero sized object. Handle that separately in krealloc(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18add kstrndupJeremy Fitzhardinge
Add a kstrndup function, modelled on strndup. Like strndup this returns a string copied into its own allocated memory, but it copies no more than the specified number of bytes from the source. Remove private strndup() from irda code. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@mandriva.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Panagiotis Issaris <takis@issaris.org> Cc: Rene Scharfe <rene.scharfe@lsrfire.ath.cx>
2007-07-17Slab allocators: Cleanup zeroing allocationsChristoph Lameter
It becomes now easy to support the zeroing allocs with generic inline functions in slab.h. Provide inline definitions to allow the continued use of kzalloc, kmem_cache_zalloc etc but remove other definitions of zeroing functions from the slab allocators and util.c. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Slab allocators: consistent ZERO_SIZE_PTR support and NULL result semanticsChristoph Lameter
Define ZERO_OR_NULL_PTR macro to be able to remove the checks from the allocators. Move ZERO_SIZE_PTR related stuff into slab.h. Make ZERO_SIZE_PTR work for all slab allocators and get rid of the WARN_ON_ONCE(size == 0) that is still remaining in SLAB. Make slub return NULL like the other allocators if a too large memory segment is requested via __kmalloc. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Slab allocators: consolidate code for krealloc in mm/util.cChristoph Lameter
The size of a kmalloc object is readily available via ksize(). ksize is provided by all allocators and thus we can implement krealloc in a generic way. Implement krealloc in mm/util.c and drop slab specific implementations of krealloc. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PATCH] slab: clean up leak tracking ifdefs a little bitChristoph Hellwig
- rename ____kmalloc to kmalloc_track_caller so that people have a chance to guess what it does just from it's name. Add a comment describing it for those who don't. Also move it after kmalloc in slab.h so people get less confused when they are just looking for kmalloc - move things around in slab.c a little to reduce the ifdef mess. [penberg@cs.helsinki.fi: Fix up reversed #ifdef] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kmemdup: introduceAlexey Dobriyan
One of idiomatic ways to duplicate a region of memory is dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; memcpy(dst, src, len); which is neat code except a programmer needs to write size twice. Which sometimes leads to mistakes. If len passed to kmalloc is smaller that len passed to memcpy, it's straight overwrite-beyond-end. If len passed to memcpy is smaller than len passed to kmalloc, it's either a) legit behaviour ;-), or b) cloned buffer will contain garbage in second half. Slight trolling of commit lists shows several duplications bugs done exactly because of diverged lenghts: Linux: [CRYPTO]: Fix memcpy/memset args. [PATCH] memcpy/memset fixes OpenBSD: kerberosV/src/lib/asn1: der_copy.c:1.4 If programmer is given only one place to play with lengths, I believe, such mistakes could be avoided. With kmemdup, the snippet above will be rewritten as: dst = kmemdup(src, len, GFP_KERNEL); if (!dst) return -ENOMEM; This also leads to smaller code (kzalloc effect). Quick grep shows 200+ places where kmemdup() can be used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] slab: optimize constant-size kzalloc callsPekka Enberg
As suggested by Eric Dumazet, optimize kzalloc() calls that pass a compile-time constant size. Please note that the patch increases kernel text slightly (~200 bytes for defconfig on x86). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] slab: implement /proc/slab_allocatorsAl Viro
Implement /proc/slab_allocators. It produces output like: idr_layer_cache: 80 idr_pre_get+0x33/0x4e buffer_head: 2555 alloc_buffer_head+0x20/0x75 mm_struct: 9 mm_alloc+0x1e/0x42 mm_struct: 20 dup_mm+0x36/0x370 vm_area_struct: 384 dup_mm+0x18f/0x370 vm_area_struct: 151 do_mmap_pgoff+0x2e0/0x7c3 vm_area_struct: 1 split_vma+0x5a/0x10e vm_area_struct: 11 do_brk+0x206/0x2e2 vm_area_struct: 2 copy_vma+0xda/0x142 vm_area_struct: 9 setup_arg_pages+0x99/0x214 fs_cache: 8 copy_fs_struct+0x21/0x133 fs_cache: 29 copy_process+0xf38/0x10e3 files_cache: 30 alloc_files+0x1b/0xcf signal_cache: 81 copy_process+0xbaa/0x10e3 sighand_cache: 77 copy_process+0xe65/0x10e3 sighand_cache: 1 de_thread+0x4d/0x5f8 anon_vma: 241 anon_vma_prepare+0xd9/0xf3 size-2048: 1 add_sect_attrs+0x5f/0x145 size-2048: 2 journal_init_revoke+0x99/0x302 size-2048: 2 journal_init_revoke+0x137/0x302 size-2048: 2 journal_init_inode+0xf9/0x1c4 Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> DESC slab-leaks3-locking-fix EDESC From: Andrew Morton <akpm@osdl.org> Update for slab-remove-cachep-spinlock.patch Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Alexander Nyberg <alexn@telia.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] strndup_user()Davi Arnaut
This patch series creates a strndup_user() function to easy copying C strings from userspace. Also we avoid common pitfalls like userspace modifying the final \0 after the strlen_user(). Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] slob: introduce mm/util.c for shared functionsMatt Mackall
Add mm/util.c for functions common between SLAB and SLOB. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
