path: root/mm/vmalloc.c
2008-05-01docbook: fix vmalloc missing parameter notationRandy Dunlap
Fix vmalloc kernel-doc warning: Warning(linux-2.6.25-git14//mm/vmalloc.c:555): No description found for parameter 'caller' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30infrastructure to debug (dynamic) objectsThomas Gleixner
We can see an ever repeating problem pattern with objects of any kind in the kernel: 1) freeing of active objects 2) reinitialization of active objects Both problems can be hard to debug because the crash happens at a point where we have no chance to decode the root cause anymore. One problem spot are kernel timers, where the detection of the problem often happens in interrupt context and usually causes the machine to panic. While working on a timer related bug report I had to hack specialized code into the timer subsystem to get a reasonable hint for the root cause. This debug hack was fine for temporary use, but far from a mergeable solution due to the intrusiveness into the timer code. The code further lacked the ability to detect and report the root cause instantly and keep the system operational. Keeping the system operational is important to get hold of the debug information without special debugging aids like serial consoles and special knowledge of the bug reporter. The problems described above are not restricted to timers, but timers tend to expose it usually in a full system crash. Other objects are less explosive, but the symptoms caused by such mistakes can be even harder to debug. Instead of creating specialized debugging code for the timer subsystem a generic infrastructure is created which allows developers to verify their code and provides an easy to enable debug facility for users in case of trouble. The debugobjects core code keeps track of operations on static and dynamic objects by inserting them into a hashed list and sanity checking them on object operations and provides additional checks whenever kernel memory is freed. The tracked object operations are: - initializing an object - adding an object to a subsystem list - deleting an object from a subsystem list Each operation is sanity checked before the operation is executed and the subsystem specific code can provide a fixup function which allows to prevent the damage of the operation. When the sanity check triggers a warning message and a stack trace is printed. The list of operations can be extended if the need arises. For now it's limited to the requirements of the first user (timers). The core code enqueues the objects into hash buckets. The hash index is generated from the address of the object to simplify the lookup for the check on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a global lock. The debug code can be compiled in without being active. The runtime overhead is minimal and could be optimized by asm alternatives. A kernel command line option enables the debugging code. Thanks to Ingo Molnar for review, suggestions and cleanup patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vmallocinfo: add caller informationChristoph Lameter
Add caller information so that /proc/vmallocinfo shows where the allocation request for a slice of vmalloc memory originated. Results in output like this: 0xffffc20000000000-0xffffc20000801000 8392704 alloc_large_system_hash+0x127/0x246 pages=2048 vmalloc vpages 0xffffc20000801000-0xffffc20000806000 20480 alloc_large_system_hash+0x127/0x246 pages=4 vmalloc 0xffffc20000806000-0xffffc20000c07000 4198400 alloc_large_system_hash+0x127/0x246 pages=1024 vmalloc vpages 0xffffc20000c07000-0xffffc20000c0a000 12288 alloc_large_system_hash+0x127/0x246 pages=2 vmalloc 0xffffc20000c0a000-0xffffc20000c0c000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c0c000-0xffffc20000c0f000 12288 acpi_os_map_memory+0x13/0x1c phys=cff64000 ioremap 0xffffc20000c10000-0xffffc20000c15000 20480 acpi_os_map_memory+0x13/0x1c phys=cff65000 ioremap 0xffffc20000c16000-0xffffc20000c18000 8192 acpi_os_map_memory+0x13/0x1c phys=cff69000 ioremap 0xffffc20000c18000-0xffffc20000c1a000 8192 acpi_os_map_memory+0x13/0x1c phys=fed1f000 ioremap 0xffffc20000c1a000-0xffffc20000c1c000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c1c000-0xffffc20000c1e000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c1e000-0xffffc20000c20000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c20000-0xffffc20000c22000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c22000-0xffffc20000c24000 8192 acpi_os_map_memory+0x13/0x1c phys=cff68000 ioremap 0xffffc20000c24000-0xffffc20000c26000 8192 acpi_os_map_memory+0x13/0x1c phys=e0081000 ioremap 0xffffc20000c26000-0xffffc20000c28000 8192 acpi_os_map_memory+0x13/0x1c phys=e0080000 ioremap 0xffffc20000c28000-0xffffc20000c2d000 20480 alloc_large_system_hash+0x127/0x246 pages=4 vmalloc 0xffffc20000c2d000-0xffffc20000c31000 16384 tcp_init+0xd5/0x31c pages=3 vmalloc 0xffffc20000c31000-0xffffc20000c34000 12288 alloc_large_system_hash+0x127/0x246 pages=2 vmalloc 0xffffc20000c34000-0xffffc20000c36000 8192 init_vdso_vars+0xde/0x1f1 0xffffc20000c36000-0xffffc20000c38000 8192 pci_iomap+0x8a/0xb4 phys=d8e00000 ioremap 0xffffc20000c38000-0xffffc20000c3a000 8192 usb_hcd_pci_probe+0x139/0x295 [usbcore] phys=d8e00000 ioremap 0xffffc20000c3a000-0xffffc20000c3e000 16384 sys_swapon+0x509/0xa15 pages=3 vmalloc 0xffffc20000c40000-0xffffc20000c61000 135168 e1000_probe+0x1c4/0xa32 phys=d8a20000 ioremap 0xffffc20000c61000-0xffffc20000c6a000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20000c6a000-0xffffc20000c73000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20000c73000-0xffffc20000c7c000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20000c7c000-0xffffc20000c7f000 12288 e1000e_setup_tx_resources+0x29/0xbe pages=2 vmalloc 0xffffc20000c80000-0xffffc20001481000 8392704 pci_mmcfg_arch_init+0x90/0x118 phys=e0000000 ioremap 0xffffc20001481000-0xffffc20001682000 2101248 alloc_large_system_hash+0x127/0x246 pages=512 vmalloc 0xffffc20001682000-0xffffc20001e83000 8392704 alloc_large_system_hash+0x127/0x246 pages=2048 vmalloc vpages 0xffffc20001e83000-0xffffc20002204000 3674112 alloc_large_system_hash+0x127/0x246 pages=896 vmalloc vpages 0xffffc20002204000-0xffffc2000220d000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc2000220d000-0xffffc20002216000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20002216000-0xffffc2000221f000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc2000221f000-0xffffc20002228000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20002228000-0xffffc20002231000 36864 _xfs_buf_map_pages+0x8e/0xc0 vmap 0xffffc20002231000-0xffffc20002234000 12288 e1000e_setup_rx_resources+0x35/0x122 pages=2 vmalloc 0xffffc20002240000-0xffffc20002261000 135168 e1000_probe+0x1c4/0xa32 phys=d8a60000 ioremap 0xffffc20002261000-0xffffc2000270c000 4894720 sys_swapon+0x509/0xa15 pages=1194 vmalloc vpages 0xffffffffa0000000-0xffffffffa0022000 139264 module_alloc+0x4f/0x55 pages=33 vmalloc 0xffffffffa0022000-0xffffffffa0029000 28672 module_alloc+0x4f/0x55 pages=6 vmalloc 0xffffffffa002b000-0xffffffffa0034000 36864 module_alloc+0x4f/0x55 pages=8 vmalloc 0xffffffffa0034000-0xffffffffa003d000 36864 module_alloc+0x4f/0x55 pages=8 vmalloc 0xffffffffa003d000-0xffffffffa0049000 49152 module_alloc+0x4f/0x55 pages=11 vmalloc 0xffffffffa0049000-0xffffffffa0050000 28672 module_alloc+0x4f/0x55 pages=6 vmalloc [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vmalloc: show vmalloced areas via /proc/vmallocinfoChristoph Lameter
Implement a new proc file that allows the display of the currently allocated vmalloc memory. It allows to see the users of vmalloc. That is important if vmalloc space is scarce (i386 for example). And it's going to be important for the compound page fallback to vmalloc. Many of the current users can be switched to use compound pages with fallback. This means that the number of users of vmalloc is reduced and page tables no longer necessary to access the memory. /proc/vmallocinfo allows to review how that reduction occurs. If memory becomes fragmented and larger order allocations are no longer possible then /proc/vmallocinfo allows to see which compound page allocations fell back to virtual compound pages. That is important for new users of virtual compound pages. Such as order 1 stack allocation etc that may fallback to virtual compound pages in the future. /proc/vmallocinfo permissions are made readable-only-by-root to avoid possible information leakage. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: CONFIG_MMU=n build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19mm: fix various kernel-doc commentsRandy Dunlap
Fix various kernel-doc notation in mm/: filemap.c: add function short description; convert 2 to kernel-doc fremap.c: change parameter 'prot' to @prot pagewalk.c: change "-" in function parameters to ":" slab.c: fix short description of kmem_ptr_validate() swap.c: fix description & parameters of put_pages_list() swap_state.c: fix function parameters vmalloc.c: change "@returns" to "Returns:" since that is not a parameter Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: don't allow ioremapping of ranges larger than vmalloc spaceRobert Bragg
When running with a 16M IOREMAP_MAX_ORDER (on armv7) we found that the vmlist search routine in __get_vm_area_node can mistakenly allow a driver to ioremap a range larger than vmalloc space. If at the time of the ioremap all existing vmlist areas sit below the determined alignment then the search routine continues past all entries and exits the for loop - straight into the found: label - without ever testing for integer wrapping or that the requested size fits. We were seeing a driver successfully ioremap 128M of flash even though there was only 120M of vmalloc space. From that point the system was left with the remainder of the first 16M of space to vmalloc/ioremap within. Signed-off-by: Robert Bragg <robert@sixbynine.org> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05make __vmalloc_area_node() staticAdrian Bunk
__vmalloc_area_node() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05vmalloc: clean up page array indexingChristoph Lameter
The page array is repeatedly indexed both in vunmap and vmalloc_area_node(). Add a temporary variable to make it easier to read (and easier to patch later). Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05vmalloc: add const to void* parametersChristoph Lameter
Make vmalloc functions work the same way as kfree() and friends that take a const void * argument. [akpm@linux-foundation.org: fix consts, coding-style] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Move vmalloc_to_page() to mm/vmalloc.Christoph Lameter
We already have page table manipulation for vmalloc in vmalloc.c. Move the vmalloc_to_page() function there as well. Move the definitions for vmalloc related functions in mm.h to a newly created section. A better place would be vmalloc.h but mm.h is basic and may depend on these functions. An alternative would be to include vmalloc.h in mm.h (like done for vmstat.h). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20spelling fixes: mm/Simon Arlott
Spelling fixes in mm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Categorize GFP flagsChristoph Lameter
The function of GFP_LEVEL_MASK seems to be unclear. In order to clear up the mystery we get rid of it and replace GFP_LEVEL_MASK with 3 sets of GFP flags: GFP_RECLAIM_MASK Flags used to control page allocator reclaim behavior. GFP_CONSTRAINT_MASK Flags used to limit where allocations can occur. GFP_SLAB_BUG_MASK Flags that the slab allocator BUG()s on. These replace the uses of GFP_LEVEL mask in the slab allocators and in vmalloc.c. The use of the flags not included in these sets may occur as a result of a slab allocation standing in for a page allocation when constructing scatter gather lists. Extraneous flags are cleared and not passed through to the page allocator. __GFP_MOVABLE/RECLAIMABLE, __GFP_COLD and __GFP_COMP will now be ignored if passed to a slab allocator. Change the allocation of allocator meta data in SLAB and vmalloc to not pass through flags listed in GFP_CONSTRAINT_MASK. SLAB already removes the __GFP_THISNODE flag for such allocations. Generalize that to also cover vmalloc. The use of GFP_CONSTRAINT_MASK also includes __GFP_HARDWALL. The impact of allocator metadata placement on access latency to the cachelines of the object itself is minimal since metadata is only referenced on alloc and free. The attempt is still made to place the meta data optimally but we consistently allow fallback both in SLAB and vmalloc (SLUB does not need to allocate metadata like that). Allocator metadata may serve multiple in kernel users and thus should not be subject to the limitations arising from a single allocation context. [akpm@linux-foundation.org: fix fallback_alloc()] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: export symbols for lguest as a moduleRusty Russell
lguest does some fairly lowlevel things to support a host, which normal modules don't need: math_state_restore: When the guest triggers a Device Not Available fault, we need to be able to restore the FPU __put_task_struct: We need to hold a reference to another task for inter-guest I/O, and put_task_struct() is an inline function which calls __put_task_struct. access_process_vm: We need to access another task for inter-guest I/O. map_vm_area & __get_vm_area: We need to map the switcher shim (ie. monitor) at 0xFFC01000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19vmalloc_32 should use GFP_KERNELBenjamin Herrenschmidt
I've noticed lots of failures of vmalloc_32 on machines where it shouldn't have failed unless it was doing an atomic operation. Looking closely, I noticed that: #if defined(CONFIG_64BIT) && defined(CONFIG_ZONE_DMA32) #define GFP_VMALLOC32 GFP_DMA32 #elif defined(CONFIG_64BIT) && defined(CONFIG_ZONE_DMA) #define GFP_VMALLOC32 GFP_DMA #else #define GFP_VMALLOC32 GFP_KERNEL #endif Which seems to be incorrect, it should always -or- in the DMA flags on top of GFP_KERNEL, thus this patch. This fixes frequent errors launchin X with the nouveau DRM for example. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andi Kleen <ak@suse.de> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18Allocate and free vmalloc areasJeremy Fitzhardinge
Allocate/release a chunk of vmalloc address space: alloc_vm_area reserves a chunk of address space, and makes sure all the pagetables are constructed for that address range - but no pages. free_vm_area releases the address space range. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ian Pratt <ian.pratt@xensource.com> Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: "Jan Beulich" <JBeulich@novell.com> Cc: "Andi Kleen" <ak@muc.de>
2007-07-17Slab allocators: Replace explicit zeroing with __GFP_ZEROChristoph Lameter
kmalloc_node() and kmem_cache_alloc_node() were not available in a zeroing variant in the past. But with __GFP_ZERO it is possible now to do zeroing while allocating. Use __GFP_ZERO to remove the explicit clearing of memory via memset whereever we can. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-14[POWERPC] unmap_vm_area becomes unmap_kernel_range for the publicBenjamin Herrenschmidt
This makes unmap_vm_area static and a wrapper around a new exported unmap_kernel_range that takes an explicit range instead of a vm_area struct. This makes it more versatile for code that wants to play with kernel page tables outside of the standard vmalloc area. (One example is some rework of the PowerPC PCI IO space mapping code that depends on that patch and removes some code duplication and horrible abuse of forged struct vm_struct). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-17Make __vunmap staticBenjamin Herrenschmidt
__vunmap doesn't seem to be used outside of mm/vmalloc.c, and has no prototype in any header so let's make it static Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Fix vmalloc_32 to really allocate <4GB on 64bit platformsAndi Kleen
Ugly ifdef, but should handle all 64bit platforms that have suitable zones. On some like Altix it's probably impossible without IOMMU use to get memory <4GB this way, but they have to live with that. Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-16[PATCH] Fix strange size check in __get_vm_area_node()OGAWA Hirofumi
Recently, __get_vm_area_node() was changed like following if (unlikely(!area)) return NULL; - if (unlikely(!size)) { - kfree (area); + if (unlikely(!size)) return NULL; - } It is leaking `area', also original code seems strange already. Probably, we wanted to do this patch. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] vmalloc: optimization, cleanup, bugfixesEric Dumazet
- reorder 'struct vm_struct' to speedup lookups on CPUS with small cache lines. The fields 'next,addr,size' should be now in the same cache line, to speedup lookups. - One minor cleanup in __get_vm_area_node() - Bugfixes in vmalloc_user() and vmalloc_32_user() NULL returns from __vmalloc() and __find_vm_area() were not tested. [akpm@osdl.org: remove redundant BUG_ONs] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] Fix GFP_HIGHMEM slab panicGiridhar Pemmasani
As reported by Martin J. Bligh <mbligh@google.com>, we let through some non-slab bits to slab allocation through __get_vm_area_node when doing a vmalloc. I haven't been able to reproduce this, although I understand why it happens: vmalloc allocates memory with GFP_KERNEL | __GFP_HIGHMEM and commit 52fd24ca1db3a741f144bbc229beefe044202cac resulted in the same flags are passed down to cache_alloc_refill, causing the BUG. The following patch fixes it. Note that when calling kmalloc_node, I am masking off __GFP_HIGHMEM with GFP_LEVEL_MASK, whereas __vmalloc_area_node does the same with ~(__GFP_HIGHMEM | __GFP_ZERO). IMHO, using GFP_LEVEL_MASK is preferable, but either should fix this problem. Signed-off-by: Giridhar Pemmasani (pgiri@yahoo.com) Cc: Martin J. Bligh <mbligh@google.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] __vmalloc with GFP_ATOMIC causes 'sleeping from invalid context'Giridhar Pemmasani
If __vmalloc is called to allocate memory with GFP_ATOMIC in atomic context, the chain of calls results in __get_vm_area_node allocating memory for vm_struct with GFP_KERNEL, causing the 'sleeping from invalid context' warning. This patch fixes it by passing the gfp flags along so __get_vm_area_node allocates memory for vm_struct with the same flags. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] vmalloc(): don't pass __GFP_ZERO to slabAndrew Morton
A recent change to the vmalloc() code accidentally resulted in us passing __GFP_ZERO into the slab allocator. But we only wanted __GFP_ZERO for the actual pages whcih are being vmalloc()ed, and passing __GFP_ZERO into slab is not a rational thing to ask for. Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Spelling fix: "control" instead of "cotrol"Michael Opdenacker
This patch against fixes a spelling mistake ("control" instead of "cotrol"). Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27[PATCH] Mark __remove_vm_area() staticRolf Eike Beer
The function is exported but not used from anywhere else. It's also marked as "not for driver use" so noone out there should really care. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Fix kerneldoc comments in mm/vmalloc.cRolf Eike Beer
The empty line between the short description and the first argument description causes a section to appear twice in the generated manpage. Also the short description should really be short: the script can't handle multiple lines. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm/: make functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - slab.c: kmem_find_general_cachep() - swap.c: __page_cache_release() - vmalloc.c: __vmalloc_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] mm: fix oom roll-back of __vmalloc_area_nodeJan Kiszka
__vunmap must not rely on area->nr_pages when picking the release methode for area->pages. It may be too small when __vmalloc_area_node failed early due to lacking memory. Instead, use a flag in vmstruct to differentiate. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] mm: introduce remap_vmalloc_range()Nick Piggin
Add remap_vmalloc_range, vmalloc_user, and vmalloc_32_user so that drivers can have a nice interface for remapping vmalloc memory. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01BUG_ON() Conversion in mm/vmalloc.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] kernel-doc: fix warnings in vmalloc.cRandy Dunlap
Fix new kernel-doc errors in vmalloc.c. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: init_mm without ptlockHugh Dickins
First step in pushing down the page_table_lock. init_mm.page_table_lock has been used throughout the architectures (usually for ioremap): not to serialize kernel address space allocation (that's usually vmlist_lock), but because pud_alloc,pmd_alloc,pte_alloc_kernel expect caller holds it. Reverse that: don't lock or unlock init_mm.page_table_lock in any of the architectures; instead rely on pud_alloc,pmd_alloc,pte_alloc_kernel to take and drop it when allocating a new one, to check lest a racing task already did. Similarly no page_table_lock in vmalloc's map_vm_area. Some temporary ugliness in __pud_alloc and __pmd_alloc: since they also handle user mms, which are converted only by a later patch, for now they have to lock differently according to whether or not it's init_mm. If sources get muddled, there's a danger that an arch source taking init_mm.page_table_lock will be mixed with common source also taking it (or neither take it). So break the rules and make another change, which should break the build for such a mismatch: remove the redundant mm arg from pte_alloc_kernel (ppc64 scrapped its distinct ioremap_mm in 2.6.13). Exceptions: arm26 used pte_alloc_kernel on user mm, now pte_alloc_map; ia64 used pte_alloc_map on init_mm, now pte_alloc_kernel; parisc had bad args to pmd_alloc and pte_alloc_kernel in unused USE_HPPA_IOREMAP code; ppc64 map_io_page forgot to unlock on failure; ppc mmu_mapin_ram and ppc64 im_free took page_table_lock for no good reason. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] vmalloc_nodeChristoph Lameter
This patch adds vmalloc_node(size, node) -> Allocate necessary memory on the specified node and get_vm_area_node(size, flags, node) and the other functions that it depends on. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update kfree, vfree, and vunmap kerneldocPekka Enberg
This patch clarifies NULL handling of kfree() and vfree(). I addition, wording of calling context restriction for vfree() and vunmap() are changed from "may not" to "must not." Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arm: allow for arch-specific IOREMAP_MAX_ORDERDeepak Saxena
Version 6 of the ARM architecture introduces the concept of 16MB pages (supersections) and 36-bit (40-bit actually, but nobody uses this) physical addresses. 36-bit addressed memory and I/O and ARMv6 can only be mapped using supersections and the requirement on these is that both virtual and physical addresses be 16MB aligned. In trying to add support for ioremap() of 36-bit I/O, we run into the issue that get_vm_area() allows for a maximum of 512K alignment via the IOREMAP_MAX_ORDER constant. To work around this, we can: - Allocate a larger VM area than needed (size + (1ul << IOREMAP_MAX_ORDER)) and then align the pointer ourselves, but this ends up with 512K of wasted VM per ioremap(). - Provide a new __get_vm_area_aligned() API and make __get_vm_area() sit on top of this. I did this and it works but I don't like the idea adding another VM API just for this one case. - My preferred solution which is to allow the architecture to override the IOREMAP_MAX_ORDER constant with it's own version. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] x86_64: Fixed guard page handling again in iounmapAndi Kleen
Caused oopses again. Also fix potential mismatch in checking if change_page_attr was needed. To do it without races I needed to change mm/vmalloc.c to export a __remove_vm_area that does not take vmlist lock. Noticed by Terence Ripperda and based on a patch of his. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
