path: root/mm/vmalloc.c
2007-05-17Make __vunmap staticBenjamin Herrenschmidt
__vunmap doesn't seem to be used outside of mm/vmalloc.c, and has no prototype in any header so let's make it static Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Fix vmalloc_32 to really allocate <4GB on 64bit platformsAndi Kleen
Ugly ifdef, but should handle all 64bit platforms that have suitable zones. On some like Altix it's probably impossible without IOMMU use to get memory <4GB this way, but they have to live with that. Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-16[PATCH] Fix strange size check in __get_vm_area_node()OGAWA Hirofumi
Recently, __get_vm_area_node() was changed like following if (unlikely(!area)) return NULL; - if (unlikely(!size)) { - kfree (area); + if (unlikely(!size)) return NULL; - } It is leaking `area', also original code seems strange already. Probably, we wanted to do this patch. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] vmalloc: optimization, cleanup, bugfixesEric Dumazet
- reorder 'struct vm_struct' to speedup lookups on CPUS with small cache lines. The fields 'next,addr,size' should be now in the same cache line, to speedup lookups. - One minor cleanup in __get_vm_area_node() - Bugfixes in vmalloc_user() and vmalloc_32_user() NULL returns from __vmalloc() and __find_vm_area() were not tested. [akpm@osdl.org: remove redundant BUG_ONs] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-29[PATCH] Fix GFP_HIGHMEM slab panicGiridhar Pemmasani
As reported by Martin J. Bligh <mbligh@google.com>, we let through some non-slab bits to slab allocation through __get_vm_area_node when doing a vmalloc. I haven't been able to reproduce this, although I understand why it happens: vmalloc allocates memory with GFP_KERNEL | __GFP_HIGHMEM and commit 52fd24ca1db3a741f144bbc229beefe044202cac resulted in the same flags are passed down to cache_alloc_refill, causing the BUG. The following patch fixes it. Note that when calling kmalloc_node, I am masking off __GFP_HIGHMEM with GFP_LEVEL_MASK, whereas __vmalloc_area_node does the same with ~(__GFP_HIGHMEM | __GFP_ZERO). IMHO, using GFP_LEVEL_MASK is preferable, but either should fix this problem. Signed-off-by: Giridhar Pemmasani (pgiri@yahoo.com) Cc: Martin J. Bligh <mbligh@google.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] __vmalloc with GFP_ATOMIC causes 'sleeping from invalid context'Giridhar Pemmasani
If __vmalloc is called to allocate memory with GFP_ATOMIC in atomic context, the chain of calls results in __get_vm_area_node allocating memory for vm_struct with GFP_KERNEL, causing the 'sleeping from invalid context' warning. This patch fixes it by passing the gfp flags along so __get_vm_area_node allocates memory for vm_struct with the same flags. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] vmalloc(): don't pass __GFP_ZERO to slabAndrew Morton
A recent change to the vmalloc() code accidentally resulted in us passing __GFP_ZERO into the slab allocator. But we only wanted __GFP_ZERO for the actual pages whcih are being vmalloc()ed, and passing __GFP_ZERO into slab is not a rational thing to ask for. Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Spelling fix: "control" instead of "cotrol"Michael Opdenacker
This patch against fixes a spelling mistake ("control" instead of "cotrol"). Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27[PATCH] Mark __remove_vm_area() staticRolf Eike Beer
The function is exported but not used from anywhere else. It's also marked as "not for driver use" so noone out there should really care. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Fix kerneldoc comments in mm/vmalloc.cRolf Eike Beer
The empty line between the short description and the first argument description causes a section to appear twice in the generated manpage. Also the short description should really be short: the script can't handle multiple lines. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm/: make functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - slab.c: kmem_find_general_cachep() - swap.c: __page_cache_release() - vmalloc.c: __vmalloc_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] mm: fix oom roll-back of __vmalloc_area_nodeJan Kiszka
__vunmap must not rely on area->nr_pages when picking the release methode for area->pages. It may be too small when __vmalloc_area_node failed early due to lacking memory. Instead, use a flag in vmstruct to differentiate. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] mm: introduce remap_vmalloc_range()Nick Piggin
Add remap_vmalloc_range, vmalloc_user, and vmalloc_32_user so that drivers can have a nice interface for remapping vmalloc memory. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01BUG_ON() Conversion in mm/vmalloc.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] kernel-doc: fix warnings in vmalloc.cRandy Dunlap
Fix new kernel-doc errors in vmalloc.c. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: init_mm without ptlockHugh Dickins
First step in pushing down the page_table_lock. init_mm.page_table_lock has been used throughout the architectures (usually for ioremap): not to serialize kernel address space allocation (that's usually vmlist_lock), but because pud_alloc,pmd_alloc,pte_alloc_kernel expect caller holds it. Reverse that: don't lock or unlock init_mm.page_table_lock in any of the architectures; instead rely on pud_alloc,pmd_alloc,pte_alloc_kernel to take and drop it when allocating a new one, to check lest a racing task already did. Similarly no page_table_lock in vmalloc's map_vm_area. Some temporary ugliness in __pud_alloc and __pmd_alloc: since they also handle user mms, which are converted only by a later patch, for now they have to lock differently according to whether or not it's init_mm. If sources get muddled, there's a danger that an arch source taking init_mm.page_table_lock will be mixed with common source also taking it (or neither take it). So break the rules and make another change, which should break the build for such a mismatch: remove the redundant mm arg from pte_alloc_kernel (ppc64 scrapped its distinct ioremap_mm in 2.6.13). Exceptions: arm26 used pte_alloc_kernel on user mm, now pte_alloc_map; ia64 used pte_alloc_map on init_mm, now pte_alloc_kernel; parisc had bad args to pmd_alloc and pte_alloc_kernel in unused USE_HPPA_IOREMAP code; ppc64 map_io_page forgot to unlock on failure; ppc mmu_mapin_ram and ppc64 im_free took page_table_lock for no good reason. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] vmalloc_nodeChristoph Lameter
This patch adds vmalloc_node(size, node) -> Allocate necessary memory on the specified node and get_vm_area_node(size, flags, node) and the other functions that it depends on. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update kfree, vfree, and vunmap kerneldocPekka Enberg
This patch clarifies NULL handling of kfree() and vfree(). I addition, wording of calling context restriction for vfree() and vunmap() are changed from "may not" to "must not." Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arm: allow for arch-specific IOREMAP_MAX_ORDERDeepak Saxena
Version 6 of the ARM architecture introduces the concept of 16MB pages (supersections) and 36-bit (40-bit actually, but nobody uses this) physical addresses. 36-bit addressed memory and I/O and ARMv6 can only be mapped using supersections and the requirement on these is that both virtual and physical addresses be 16MB aligned. In trying to add support for ioremap() of 36-bit I/O, we run into the issue that get_vm_area() allows for a maximum of 512K alignment via the IOREMAP_MAX_ORDER constant. To work around this, we can: - Allocate a larger VM area than needed (size + (1ul << IOREMAP_MAX_ORDER)) and then align the pointer ourselves, but this ends up with 512K of wasted VM per ioremap(). - Provide a new __get_vm_area_aligned() API and make __get_vm_area() sit on top of this. I did this and it works but I don't like the idea adding another VM API just for this one case. - My preferred solution which is to allow the architecture to override the IOREMAP_MAX_ORDER constant with it's own version. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] x86_64: Fixed guard page handling again in iounmapAndi Kleen
Caused oopses again. Also fix potential mismatch in checking if change_page_attr was needed. To do it without races I needed to change mm/vmalloc.c to export a __remove_vm_area that does not take vmlist lock. Noticed by Terence Ripperda and based on a patch of his. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
