balance_pgdat()
After DEF_PRIORITY, balance_pgdat() considers all_unreclaimable zones to
be balanced but sleeping_prematurely does not. This can force kswapd to
stay awake longer than it should. This patch fixes it.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Eric B Munson <emunson@mgebm.net>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Simon Kirby <sim@hostway.ca>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
When kswapd wakes up, it reads its order and classzone from pgdat and
calls balance_pgdat. While its awake, it potentially reclaimes at a high
order and a low classzone index. This might have been a once-off that was
not required by subsequent callers. However, because the pgdat values
were not reset, they remain artifically high while balance_pgdat() is
running and potentially kswapd enters a second unnecessary reclaim cycle.
Reset the pgdat order and classzone index after reading.
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
sleeping_prematurely()
Before kswapd goes to sleep, it uses sleeping_prematurely() to check if
there was a race pushing a zone below its watermark. If the race
happened, it stays awake. However, balance_pgdat() can decide to reclaim
at order-0 if it decides that high-order reclaim is not working as
expected. This information is not passed back to sleeping_prematurely().
The impact is that kswapd remains awake reclaiming pages long after it
should have gone to sleep. This patch passes the adjusted order to
sleeping_prematurely and uses the same logic as balance_pgdat to decide if
it's ok to go to sleep.
of the node is balanced
When reclaiming for high-orders, kswapd is responsible for balancing a
node but it should not reclaim excessively. It avoids excessive reclaim
by considering if any zone in a node is balanced then the node is
balanced. In the cases where there are imbalanced zone sizes (e.g.
ZONE_DMA with both ZONE_DMA32 and ZONE_NORMAL), kswapd can go to sleep
prematurely as just one small zone was balanced.
This alters the sleep logic of kswapd slightly. It counts the number of
pages that make up the balanced zones. If the total number of balanced
pages is more than a quarter of the zone, kswapd will go back to sleep.
This should keep a node balanced without reclaiming an excessive number of
pages.
Simon Kirby reported the following problem
We're seeing cases on a number of servers where cache never fully
grows to use all available memory. Sometimes we see servers with 4 GB
of memory that never seem to have less than 1.5 GB free, even with a
constantly-active VM. In some cases, these servers also swap out while
this happens, even though they are constantly reading the working set
into memory. We have been seeing this happening for a long time; I
don't think it's anything recent, and it still happens on 2.6.36.
After some debugging work by Simon, Dave Hansen and others, the prevaling
theory became that kswapd is reclaiming order-3 pages requested by SLUB
too aggressive about it.
There are two apparent problems here. On the target machine, there is a
small Normal zone in comparison to DMA32. As kswapd tries to balance all
zones, it would continually try reclaiming for Normal even though DMA32
was balanced enough for callers. The second problem is that
sleeping_prematurely() does not use the same logic as balance_pgdat() when
deciding whether to sleep or not. This keeps kswapd artifically awake.
A number of tests were run and the figures from previous postings will
look very different for a few reasons. One, the old figures were forcing
my network card to use GFP_ATOMIC in attempt to replicate Simon's problem.
Second, I previous specified slub_min_order=3 again in an attempt to
reproduce Simon's problem. In this posting, I'm depending on Simon to say
whether his problem is fixed or not and these figures are to show the
impact to the ordinary cases. Finally, the "vmscan" figures are taken
from /proc/vmstat instead of the tracepoints. There is less information
but recording is less disruptive.
The first test of relevance was postmark with a process running in the
background reading a large amount of anonymous memory in blocks. The
objective was to vaguely simulate what was happening on Simon's machine
and it's memory intensive enough to have kswapd awake.
POSTMARK
traceonly kanyzone
Transactions per second: 156.00 ( 0.00%) 153.00 (-1.96%)
Data megabytes read per second: 21.51 ( 0.00%) 21.52 ( 0.05%)
Data megabytes written per second: 29.28 ( 0.00%) 29.11 (-0.58%)
Files created alone per second: 250.00 ( 0.00%) 416.00 (39.90%)
Files create/transact per second: 79.00 ( 0.00%) 76.00 (-3.95%)
Files deleted alone per second: 520.00 ( 0.00%) 420.00 (-23.81%)
Files delete/transact per second: 79.00 ( 0.00%) 76.00 (-3.95%)
MMTests Statistics: duration
User/Sys Time Running Test (seconds) 16.58 17.4
Total Elapsed Time (seconds) 218.48 222.47
VMstat Reclaim Statistics: vmscan
Direct reclaims 0 4
Direct reclaim pages scanned 0 203
Direct reclaim pages reclaimed 0 184
Kswapd pages scanned 326631 322018
Kswapd pages reclaimed 312632 309784
Kswapd low wmark quickly 1 4
Kswapd high wmark quickly 122 475
Kswapd skip congestion_wait 1 0
Pages activated 700040 705317
Pages deactivated 212113 203922
Pages written 9875 6363
Total pages scanned 326631 322221
Total pages reclaimed 312632 309968
%age total pages scanned/reclaimed 95.71% 96.20%
%age total pages scanned/written 3.02% 1.97%
proc vmstat: Faults
Major Faults 300 254
Minor Faults 645183 660284
Page ins 493588 486704
Page outs 4960088 4986704
Swap ins 1230 661
Swap outs 9869 6355
Performance is mildly affected because kswapd is no longer doing as much
work and the background memory consumer process is getting in the way.
Note that kswapd scanned and reclaimed fewer pages as it's less aggressive
and overall fewer pages were scanned and reclaimed. Swap in/out is
particularly reduced again reflecting kswapd throwing out fewer pages.
The slight performance impact is unfortunate here but it looks like a
direct result of kswapd being less aggressive. As the bug report is about
too many pages being freed by kswapd, it may have to be accepted for now.
The second test is a streaming IO benchmark that was previously used by
Johannes to show regressions in page reclaim.
MICRO
traceonly kanyzone
User/Sys Time Running Test (seconds) 29.29 28.87
Total Elapsed Time (seconds) 492.18 488.79
Direct reclaims 2128 1460
Direct reclaim pages scanned 2284822 1496067
Direct reclaim pages reclaimed 148919 110937
Kswapd pages scanned 15450014 16202876
Kswapd pages reclaimed 8503697 8537897
Kswapd low wmark quickly 3100 3397
Kswapd high wmark quickly 1860 7243
Kswapd skip congestion_wait 708 801
Pages activated 9635 9573
Pages deactivated 1432 1271
Pages written 223 1130
Total pages scanned 17734836 17698943
Total pages reclaimed 8652616 8648834
%age total pages scanned/reclaimed 48.79% 48.87%
%age total pages scanned/written 0.00% 0.01%
proc vmstat: Faults
Major Faults 165 221
Minor Faults 9655785 9656506
Page ins 3880 7228
Page outs 37692940 37480076
Swap ins 0 69
Swap outs 19 15
Again fewer pages are scanned and reclaimed as expected and this time the
test completed faster. Note that kswapd is hitting its watermarks faster
(low and high wmark quickly) which I expect is due to kswapd reclaiming
fewer pages.
I also ran fs-mark, iozone and sysbench but there is nothing interesting
to report in the figures. Performance is not significantly changed and
the reclaim statistics look reasonable.
Tgis patch:
When the allocator enters its slow path, kswapd is woken up to balance the
node. It continues working until all zones within the node are balanced.
For order-0 allocations, this makes perfect sense but for higher orders it
can have unintended side-effects. If the zone sizes are imbalanced,
kswapd may reclaim heavily within a smaller zone discarding an excessive
number of pages. The user-visible behaviour is that kswapd is awake and
reclaiming even though plenty of pages are free from a suitable zone.
This patch alters the "balance" logic for high-order reclaim allowing
kswapd to stop if any suitable zone becomes balanced to reduce the number
of pages it reclaims from other zones. kswapd still tries to ensure that
order-0 watermarks for all zones are met before sleeping.
With compaction being used instead of lumpy reclaim, the name lumpy_mode
and associated variables is a bit misleading. Rename lumpy_mode to
reclaim_mode which is a better fit. There is no functional change.
Cc: Andy Whitcroft <apw@shadowen.org>
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
Lumpy reclaim is disruptive. It reclaims a large number of pages and
ignores the age of the pages it reclaims. This can incur significant
stalls and potentially increase the number of major faults.
Compaction has reached the point where it is considered reasonably stable
(meaning it has passed a lot of testing) and is a potential candidate for
displacing lumpy reclaim. This patch introduces an alternative to lumpy
reclaim whe compaction is available called reclaim/compaction. The basic
operation is very simple - instead of selecting a contiguous range of
pages to reclaim, a number of order-0 pages are reclaimed and then
compaction is later by either kswapd (compact_zone_order()) or direct
compaction (__alloc_pages_direct_compact()).
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: use conventional task_struct naming]
Currently lumpy_mode is an enum and determines if lumpy reclaim is off,
syncronous or asyncronous. In preparation for using compaction instead of
lumpy reclaim, this patch converts the flags into a bitmap.
Currently, kswapd() has deep nesting and is slightly hard to read. Clean
this up.
thresholds
reduce_pgdat_percpu_threshold() and restore_pgdat_percpu_threshold() exist
to adjust the per-cpu vmstat thresholds while kswapd is awake to avoid
errors due to counter drift. The functions duplicate some code so this
patch replaces them with a single set_pgdat_percpu_threshold() that takes
a callback function to calculate the desired threshold as a parameter.
[akpm@linux-foundation.org: readability tweak]
[kosaki.motohiro@jp.fujitsu.com: set_pgdat_percpu_threshold(): don't use for_each_online_cpu]
Reviewed-by: Christoph Lameter <cl@linux.com>
Commit aa45484 ("calculate a better estimate of NR_FREE_PAGES when memory
is low") noted that watermarks were based on the vmstat NR_FREE_PAGES. To
avoid synchronization overhead, these counters are maintained on a per-cpu
basis and drained both periodically and when a threshold is above a
threshold. On large CPU systems, the difference between the estimate and
real value of NR_FREE_PAGES can be very high. The system can get into a
case where pages are allocated far below the min watermark potentially
causing livelock issues. The commit solved the problem by taking a better
reading of NR_FREE_PAGES when memory was low.
Unfortately, as reported by Shaohua Li this accurate reading can consume a
large amount of CPU time on systems with many sockets due to cache line
bouncing. This patch takes a different approach. For large machines
where counter drift might be unsafe and while kswapd is awake, the per-cpu
thresholds for the target pgdat are reduced to limit the level of drift to
what should be a safe level. This incurs a performance penalty in heavy
memory pressure by a factor that depends on the workload and the machine
but the machine should function correctly without accidentally exhausting
all memory on a node. There is an additional cost when kswapd wakes and
sleeps but the event is not expected to be frequent - in Shaohua's test
case, there was one recorded sleep and wake event at least.
To ensure that kswapd wakes up, a safe version of zone_watermark_ok() is
introduced that takes a more accurate reading of NR_FREE_PAGES when called
from wakeup_kswapd, when deciding whether it is really safe to go back to
sleep in sleeping_prematurely() and when deciding if a zone is really
balanced or not in balance_pgdat(). We are still using an expensive
function but limiting how often it is called.
When the test case is reproduced, the time spent in the watermark
functions is reduced. The following report is on the percentage of time
spent cumulatively spent in the functions zone_nr_free_pages(),
zone_watermark_ok(), __zone_watermark_ok(), zone_watermark_ok_safe(),
zone_page_state_snapshot(), zone_page_state().
vanilla 11.6615%
disable-threshold 0.2584%
David said:
: We had to pull aa454840 "mm: page allocator: calculate a better estimate
: of NR_FREE_PAGES when memory is low and kswapd is awake" from 2.6.36
: internally because tests showed that it would cause the machine to stall
: as the result of heavy kswapd activity. I merged it back with this fix as
: it is pending in the -mm tree and it solves the issue we were seeing, so I
: definitely think this should be pushed to -stable (and I would seriously
: consider it for 2.6.37 inclusion even at this late date).
Reported-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: Nicolas Bareil <nico@chdir.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <stable@kernel.org> [2.6.37.1, 2.6.36.x]
NFS needs to be able to release objects that are stored in the page
cache once the page itself is no longer visible from the page cache.
This patch adds a callback to the address space operations that allows
filesystems to perform page cleanups once the page has been removed
Original patch by: Linus Torvalds <torvalds@linux-foundation.org>
[trondmy: cover the cases of invalidate_inode_pages2() and
truncate_inode_pages()]
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
nr_dirty and nr_congested are increased only when the page is dirty. So
if all pages are clean, both them will be zero. In this case, we should
not mark the zone congested.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Mel Gorman <mel@csn.ul.ie>
When a page has PG_referenced, shrink_page_list() discards it only if it
is not dirty. This rule works fine if the backing filesystem is a regular
one. PG_dirty is a good signal that the page was used recently because
the flusher threads clean pages periodically. In addition, page writeback
is costlier than simple page discard.
However, when a page is on tmpfs this heuristic doesn't work because
flusher threads don't write back tmpfs pages. Consequently tmpfs pages
always rotate around the lru twice at least and adds unnecessary lru
churn. Simple tmpfs streaming io shouldn't cause large anonymous page
swap-out.
Remove this unncessary reclaim bonus of tmpfs pages.
BDIs or if significant congestion is not being encountered in the current zone
If congestion_wait() is called with no BDI congested, the caller will
sleep for the full timeout and this may be an unnecessary sleep. This
patch adds a wait_iff_congested() that checks congestion and only sleeps
if a BDI is congested else, it calls cond_resched() to ensure the caller
is not hogging the CPU longer than its quota but otherwise will not sleep.
This is aimed at reducing some of the major desktop stalls reported during
IO. For example, while kswapd is operating, it calls congestion_wait()
but it could just have been reclaiming clean page cache pages with no
congestion. Without this patch, it would sleep for a full timeout but
after this patch, it'll just call schedule() if it has been on the CPU too
long. Similar logic applies to direct reclaimers that are not making
enough progress.
Cc: Wu Fengguang <fengguang.wu@intel.com>
isolated
isolate_lru_pages() does not just isolate LRU tail pages, but also
isolates neighbour pages of the eviction page. The neighbour search does
not stop even if neighbours cannot be isolated which is excessive as the
lumpy reclaim will no longer result in a successful higher order
allocation. This patch stops the PFN neighbour pages if an isolation
fails and moves on to the next block.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
After synchrounous lumpy reclaim, the page_list is guaranteed to not have
active pages as page activation in shrink_page_list() disables lumpy
reclaim. Remove the dead code.
shrink_page_list() can decide to give up reclaiming a page under a
number of conditions such as
1. trylock_page() failure
2. page is unevictable
3. zone reclaim and page is mapped
4. PageWriteback() is true
5. page is swapbacked and swap is full
6. add_to_swap() failure
7. page is dirty and gfpmask don't have GFP_IO, GFP_FS
8. page is pinned
9. IO queue is congested
10. pageout() start IO, but not finished
With lumpy reclaim, failures result in entering synchronous lumpy reclaim
but this can be unnecessary. In cases (2), (3), (5), (6), (7) and (8),
there is no point retrying. This patch causes lumpy reclaim to abort when
it is known it will fail.
Case (9) is more interesting. current behavior is,
1. start shrink_page_list(async)
2. found queue_congested()
3. skip pageout write
4. still start shrink_page_list(sync)
5. wait on a lot of pages
6. again, found queue_congested()
7. give up pageout write again
So, it's useless time wasting. However, just skipping page reclaim is
also notgood as x86 allocating a huge page needs 512 pages for example.
It can have more dirty pages than queue congestion threshold (~=128).
After this patch, pageout() behaves as follows;
- If order > PAGE_ALLOC_COSTLY_ORDER
Ignore queue congestion always.
- If order <= PAGE_ALLOC_COSTLY_ORDER
skip write page and disable lumpy reclaim.
congestion_wait() means "wait until queue congestion is cleared".
However, synchronous lumpy reclaim does not need this congestion_wait() as
shrink_page_list(PAGEOUT_IO_SYNC) uses wait_on_page_writeback() and it
provides the necessary waiting.
There have been numerous reports of stalls that pointed at the problem
being somewhere in the VM. There are multiple roots to the problems which
means dealing with any of the root problems in isolation is tricky to
justify on their own and they would still need integration testing. This
patch series puts together two different patch sets which in combination
should tackle some of the root causes of latency problems being reported.
Patch 1 adds a tracepoint for shrink_inactive_list. For this series, the
most important results is being able to calculate the scanning/reclaim
ratio as a measure of the amount of work being done by page reclaim.
Patch 2 accounts for time spent in congestion_wait.
Patches 3-6 were originally developed by Kosaki Motohiro but reworked for
this series. It has been noted that lumpy reclaim is far too aggressive
and trashes the system somewhat. As SLUB uses high-order allocations, a
large cost incurred by lumpy reclaim will be noticeable. It was also
reported during transparent hugepage support testing that lumpy reclaim
was trashing the system and these patches should mitigate that problem
without disabling lumpy reclaim.
Patch 7 adds wait_iff_congested() and replaces some callers of
congestion_wait(). wait_iff_congested() only sleeps if there is a BDI
that is currently congested. Patch 8 notes that any BDI being congested
is not necessarily a problem because there could be multiple BDIs of
varying speeds and numberous zones. It attempts to track when a zone
being reclaimed contains many pages backed by a congested BDI and if so,
reclaimers wait on the congestion queue.
I ran a number of tests with monitoring on X86, X86-64 and PPC64. Each
machine had 3G of RAM and the CPUs were
X86: Intel P4 2-core
X86-64: AMD Phenom 4-core
PPC64: PPC970MP
Each used a single disk and the onboard IO controller. Dirty ratio was
left at 20. I'm just going to report for X86-64 and PPC64 in a vague
attempt to keep this report short. Four kernels were tested each based on
v2.6.36-rc4
traceonly-v2r2: Patches 1 and 2 to instrument vmscan reclaims and congestion_wait
lowlumpy-v2r3: Patches 1-6 to test if lumpy reclaim is better
waitcongest-v2r3: Patches 1-7 to only wait on congestion
waitwriteback-v2r4: Patches 1-8 to detect when a zone is congested
nocongest-v1r5: Patches 1-3 for testing wait_iff_congestion
nodirect-v1r5: Patches 1-10 to disable filesystem writeback for better IO
The tests run were as follows
kernbench
compile-based benchmark. Smoke test performance
sysbench
OLTP read-only benchmark. Will be re-run in the future as read-write
micro-mapped-file-stream
This is a micro-benchmark from Johannes Weiner that accesses a
large sparse-file through mmap(). It was configured to run in only
single-CPU mode but can be indicative of how well page reclaim
identifies suitable pages.
stress-highalloc
Tries to allocate huge pages under heavy load.
kernbench, iozone and sysbench did not report any performance regression
on any machine. sysbench did pressure the system lightly and there was
reclaim activity but there were no difference of major interest between
the kernels.
X86-64 micro-mapped-file-stream
traceonly-v2r2 lowlumpy-v2r3 waitcongest-v2r3 waitwriteback-v2r4
pgalloc_dma 1639.00 ( 0.00%) 667.00 (-145.73%) 1167.00 ( -40.45%) 578.00 (-183.56%)
pgalloc_dma32 2842410.00 ( 0.00%) 2842626.00 ( 0.01%) 2843043.00 ( 0.02%) 2843014.00 ( 0.02%)
pgalloc_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgsteal_dma 729.00 ( 0.00%) 85.00 (-757.65%) 609.00 ( -19.70%) 125.00 (-483.20%)
pgsteal_dma32 2338721.00 ( 0.00%) 2447354.00 ( 4.44%) 2429536.00 ( 3.74%) 2436772.00 ( 4.02%)
pgsteal_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgscan_kswapd_dma 1469.00 ( 0.00%) 532.00 (-176.13%) 1078.00 ( -36.27%) 220.00 (-567.73%)
pgscan_kswapd_dma32 4597713.00 ( 0.00%) 4503597.00 ( -2.09%) 4295673.00 ( -7.03%) 3891686.00 ( -18.14%)
pgscan_kswapd_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pgscan_direct_dma 71.00 ( 0.00%) 134.00 ( 47.01%) 243.00 ( 70.78%) 352.00 ( 79.83%)
pgscan_direct_dma32 305820.00 ( 0.00%) 280204.00 ( -9.14%) 600518.00 ( 49.07%) 957485.00 ( 68.06%)
pgscan_direct_normal 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
pageoutrun 16296.00 ( 0.00%) 21254.00 ( 23.33%) 18447.00 ( 11.66%) 20067.00 ( 18.79%)
allocstall 443.00 ( 0.00%) 273.00 ( -62.27%) 513.00 ( 13.65%) 1568.00 ( 71.75%)
These are based on the raw figures taken from /proc/vmstat. It's a rough
measure of reclaim activity. Note that allocstall counts are higher
because we are entering direct reclaim more often as a result of not
sleeping in congestion. In itself, it's not necessarily a bad thing.
It's easier to get a view of what happened from the vmscan tracepoint
report.
FTrace Reclaim Statistics: vmscan
Direct reclaims 443 273 513 1568
Direct reclaim pages scanned 305968 280402 600825 957933
Direct reclaim pages reclaimed 43503 19005 30327 117191
Direct reclaim write file async I/O 0 0 0 0
Direct reclaim write anon async I/O 0 3 4 12
Direct reclaim write file sync I/O 0 0 0 0
Direct reclaim write anon sync I/O 0 0 0 0
Wake kswapd requests 187649 132338 191695 267701
Kswapd wakeups 3 1 4 1
Kswapd pages scanned 4599269 4454162 4296815 3891906
Kswapd pages reclaimed 2295947 2428434 2399818 2319706
Kswapd reclaim write file async I/O 1 0 1 1
Kswapd reclaim write anon async I/O 59 187 41 222
Kswapd reclaim write file sync I/O 0 0 0 0
Kswapd reclaim write anon sync I/O 0 0 0 0
Time stalled direct reclaim (seconds) 4.34 2.52 6.63 2.96
Time kswapd awake (seconds) 11.15 10.25 11.01 10.19
Total pages scanned 4905237 4734564 4897640 4849839
Total pages reclaimed 2339450 2447439 2430145 2436897
%age total pages scanned/reclaimed 47.69% 51.69% 49.62% 50.25%
%age total pages scanned/written 0.00% 0.00% 0.00% 0.00%
%age file pages scanned/written 0.00% 0.00% 0.00% 0.00%
Percentage Time Spent Direct Reclaim 29.23% 19.02% 38.48% 20.25%
Percentage Time kswapd Awake 78.58% 78.85% 76.83% 79.86%
What is interesting here for nocongest in particular is that while direct
reclaim scans more pages, the overall number of pages scanned remains the
same and the ratio of pages scanned to pages reclaimed is more or less the
same. In other words, while we are sleeping less, reclaim is not doing
more work and as direct reclaim and kswapd is awake for less time, it
would appear to be doing less work.
FTrace Reclaim Statistics: congestion_wait
Direct number congest waited 87 196 64 0
Direct time congest waited 4604ms 4732ms 5420ms 0ms
Direct full congest waited 72 145 53 0
Direct number conditional waited 0 0 324 1315
Direct time conditional waited 0ms 0ms 0ms 0ms
Direct full conditional waited 0 0 0 0
KSwapd number congest waited 20 10 15 7
KSwapd time congest waited 1264ms 536ms 884ms 284ms
KSwapd full congest waited 10 4 6 2
KSwapd number conditional waited 0 0 0 0
KSwapd time conditional waited 0ms 0ms 0ms 0ms
KSwapd full conditional waited 0 0 0 0
The vanilla kernel spent 8 seconds asleep in direct reclaim and no time at
all asleep with the patches.
User/Sys Time Running Test (seconds) 10.51 10.73 10.6 11.66
Total Elapsed Time (seconds) 14.19 13.00 14.33 12.76
Overall, the tests completed faster. It is interesting to note that backing off further
when a zone is congested and not just a BDI was more efficient overall.
PPC64 micro-mapped-file-stream
pgalloc_dma 3024660.00 ( 0.00%) 3027185.00 ( 0.08%) 3025845.00 ( 0.04%) 3026281.00 ( 0.05%)
pgsteal_dma 2508073.00 ( 0.00%) 2565351.00 ( 2.23%) 2463577.00 ( -1.81%) 2532263.00 ( 0.96%)
pgscan_kswapd_dma 4601307.00 ( 0.00%) 4128076.00 ( -11.46%) 3912317.00 ( -17.61%) 3377165.00 ( -36.25%)
pgscan_direct_dma 629825.00 ( 0.00%) 971622.00 ( 35.18%) 1063938.00 ( 40.80%) 1711935.00 ( 63.21%)
pageoutrun 27776.00 ( 0.00%) 20458.00 ( -35.77%) 18763.00 ( -48.04%) 18157.00 ( -52.98%)
allocstall 977.00 ( 0.00%) 2751.00 ( 64.49%) 2098.00 ( 53.43%) 5136.00 ( 80.98%)
Similar trends to x86-64. allocstalls are up but it's not necessarily bad.
Direct reclaims 977 2709 2098 5136
Direct reclaim pages scanned 629825 963814 1063938 1711935
Direct reclaim pages reclaimed 75550 242538 150904 387647
Direct reclaim write file async I/O 0 0 0 2
Direct reclaim write anon async I/O 0 10 0 4
Wake kswapd requests 392119 1201712 571935 571921
Kswapd wakeups 3 2 3 3
Kswapd pages scanned 4601307 4128076 3912317 3377165
Kswapd pages reclaimed 2432523 2318797 2312673 2144616
Kswapd reclaim write file async I/O 20 1 1 1
Kswapd reclaim write anon async I/O 57 132 11 121
Time stalled direct reclaim (seconds) 6.19 7.30 13.04 10.88
Time kswapd awake (seconds) 21.73 26.51 25.55 23.90
Total pages scanned 5231132 5091890 4976255 5089100
Total pages reclaimed 2508073 2561335 2463577 2532263
%age total pages scanned/reclaimed 47.95% 50.30% 49.51% 49.76%
Percentage Time Spent Direct Reclaim 18.89% 20.65% 32.65% 27.65%
Percentage Time kswapd Awake 72.39% 80.68% 78.21% 77.40%
Again, a similar trend that the congestion_wait changes mean that direct
reclaim scans more pages but the overall number of pages scanned while
slightly reduced, are very similar. The ratio of scanning/reclaimed
remains roughly similar. The downside is that kswapd and direct reclaim
was awake longer and for a larger percentage of the overall workload.
It's possible there were big differences in the amount of time spent
reclaiming slab pages between the different kernels which is plausible
considering that the micro tests runs after fsmark and sysbench.
Direct number congest waited 845 1312 104 0
Direct time congest waited 19416ms 26560ms 7544ms 0ms
Direct full congest waited 745 1105 72 0
Direct number conditional waited 0 0 1322 2935
Direct time conditional waited 0ms 0ms 12ms 312ms
Direct full conditional waited 0 0 0 3
KSwapd number congest waited 39 102 75 63
KSwapd time congest waited 2484ms 6760ms 5756ms 3716ms
KSwapd full congest waited 20 48 46 25
The vanilla kernel spent 20 seconds asleep in direct reclaim and only
312ms asleep with the patches. The time kswapd spent congest waited was
also reduced by a large factor.
ser/Sys Time Running Test (seconds) 26.58 28.05 26.9 28.47
Total Elapsed Time (seconds) 30.02 32.86 32.67 30.88
With all patches applies, the completion times are very similar.
X86-64 STRESS-HIGHALLOC
traceonly-v2r2 lowlumpy-v2r3 waitcongest-v2r3waitwriteback-v2r4
Pass 1 82.00 ( 0.00%) 84.00 ( 2.00%) 85.00 ( 3.00%) 85.00 ( 3.00%)
Pass 2 90.00 ( 0.00%) 87.00 (-3.00%) 88.00 (-2.00%) 89.00 (-1.00%)
At Rest 92.00 ( 0.00%) 90.00 (-2.00%) 90.00 (-2.00%) 91.00 (-1.00%)
Success figures across the board are broadly similar.
Direct reclaims 1045 944 886 887
Direct reclaim pages scanned 135091 119604 109382 101019
Direct reclaim pages reclaimed 88599 47535 47863 46671
Direct reclaim write file async I/O 494 283 465 280
Direct reclaim write anon async I/O 29357 13710 16656 13462
Direct reclaim write file sync I/O 154 2 2 3
Direct reclaim write anon sync I/O 14594 571 509 561
Wake kswapd requests 7491 933 872 892
Kswapd wakeups 814 778 731 780
Kswapd pages scanned 7290822 15341158 11916436 13703442
Kswapd pages reclaimed 3587336 3142496 3094392 3187151
Kswapd reclaim write file async I/O 91975 32317 28022 29628
Kswapd reclaim write anon async I/O 1992022 789307 829745 849769
Time stalled direct reclaim (seconds) 4588.93 2467.16 2495.41 2547.07
Time kswapd awake (seconds) 2497.66 1020.16 1098.06 1176.82
Total pages scanned 7425913 15460762 12025818 13804461
Total pages reclaimed 3675935 3190031 3142255 3233822
%age total pages scanned/reclaimed 49.50% 20.63% 26.13% 23.43%
%age total pages scanned/written 28.66% 5.41% 7.28% 6.47%
%age file pages scanned/written 1.25% 0.21% 0.24% 0.22%
Percentage Time Spent Direct Reclaim 57.33% 42.15% 42.41% 42.99%
Percentage Time kswapd Awake 43.56% 27.87% 29.76% 31.25%
Scanned/reclaimed ratios again look good with big improvements in
efficiency. The Scanned/written ratios also look much improved. With a
better scanned/written ration, there is an expectation that IO would be
more efficient and indeed, the time spent in direct reclaim is much
reduced by the full series and kswapd spends a little less time awake.
Overall, indications here are that allocations were happening much faster
and this can be seen with a graph of the latency figures as the
allocations were taking place
http://www.csn.ul.ie/~mel/postings/vmscanreduce-20101509/highalloc-interlatency-hydra-mean.ps
Direct number congest waited 1333 204 169 4
Direct time congest waited 78896ms 8288ms 7260ms 200ms
Direct full congest waited 756 92 69 2
Direct number conditional waited 0 0 26 186
Direct time conditional waited 0ms 0ms 0ms 2504ms
Direct full conditional waited 0 0 0 25
KSwapd number congest waited 4 395 227 282
KSwapd time congest waited 384ms 25136ms 10508ms 18380ms
KSwapd full congest waited 3 232 98 176
KSwapd full conditional waited 318 0 312 9
Overall, the time spent speeping is reduced. kswapd is still hitting
congestion_wait() but that is because there are callers remaining where it
wasn't clear in advance if they should be changed to wait_iff_congested()
or not. Overall the sleep imes are reduced though - from 79ish seconds to
about 19.
User/Sys Time Running Test (seconds) 3415.43 3386.65 3388.39 3377.5
Total Elapsed Time (seconds) 5733.48 3660.33 3689.41 3765.39
With the full series, the time to complete the tests are reduced by 30%
PPC64 STRESS-HIGHALLOC
Pass 1 17.00 ( 0.00%) 34.00 (17.00%) 38.00 (21.00%) 43.00 (26.00%)
Pass 2 25.00 ( 0.00%) 37.00 (12.00%) 42.00 (17.00%) 46.00 (21.00%)
At Rest 49.00 ( 0.00%) 43.00 (-6.00%) 45.00 (-4.00%) 51.00 ( 2.00%)
Success rates there are *way* up particularly considering that the 16MB
huge pages on PPC64 mean that it's always much harder to allocate them.
stress-highalloc stress-highalloc stress-highalloc stress-highalloc
Direct reclaims 499 505 564 509
Direct reclaim pages scanned 223478 41898 51818 45605
Direct reclaim pages reclaimed 137730 21148 27161 23455
Direct reclaim write file async I/O 399 136 162 136
Direct reclaim write anon async I/O 46977 2865 4686 3998
Direct reclaim write file sync I/O 29 0 1 3
Direct reclaim write anon sync I/O 31023 159 237 239
Wake kswapd requests 420 351 360 326
Kswapd wakeups 185 294 249 277
Kswapd pages scanned 15703488 16392500 17821724 17598737
Kswapd pages reclaimed 5808466 2908858 3139386 3145435
Kswapd reclaim write file async I/O 159938 18400 18717 13473
Kswapd reclaim write anon async I/O 3467554 228957 322799 234278
Time stalled direct reclaim (seconds) 9665.35 1707.81 2374.32 1871.23
Time kswapd awake (seconds) 9401.21 1367.86 1951.75 1328.88
Total pages scanned 15926966 16434398 17873542 17644342
Total pages reclaimed 5946196 2930006 3166547 3168890
%age total pages scanned/reclaimed 37.33% 17.83% 17.72% 17.96%
%age total pages scanned/written 23.27% 1.52% 1.94% 1.43%
%age file pages scanned/written 1.01% 0.11% 0.11% 0.08%
Percentage Time Spent Direct Reclaim 44.55% 35.10% 41.42% 36.91%
Percentage Time kswapd Awake 86.71% 43.58% 52.67% 41.14%
While the scanning rates are slightly up, the scanned/reclaimed and
scanned/written figures are much improved. The time spent in direct
reclaim and with kswapd are massively reduced, mostly by the lowlumpy
patches.
Direct number congest waited 725 303 126 3
Direct time congest waited 45524ms 9180ms 5936ms 300ms
Direct full congest waited 487 190 52 3
Direct number conditional waited 0 0 200 301
Direct time conditional waited 0ms 0ms 0ms 1904ms
Direct full conditional waited 0 0 0 19
KSwapd number congest waited 0 2 23 4
KSwapd time congest waited 0ms 200ms 420ms 404ms
KSwapd full congest waited 0 2 2 4
Not as dramatic a story here but the time spent asleep is reduced and we
can still see what wait_iff_congested is going to sleep when necessary.
User/Sys Time Running Test (seconds) 12028.09 3157.17 3357.79 3199.16
Total Elapsed Time (seconds) 10842.07 3138.72 3705.54 3229.85
The time to complete this test goes way down. With the full series, we
are allocating over twice the number of huge pages in 30% of the time and
there is a corresponding impact on the allocation latency graph available
at.
http://www.csn.ul.ie/~mel/postings/vmscanreduce-20101509/highalloc-interlatency-powyah-mean.ps
This patch:
Add a trace event for shrink_inactive_list() and updates the sample
postprocessing script appropriately. It can be used to determine how many
pages were reclaimed and for non-lumpy reclaim where exactly the pages
were reclaimed from.
`priority' cannot be negative here. And the comment is obsolete.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Ying Han reported that backing aging of anon pages in no swap system
causes unnecessary TLB flush.
When I sent a patch(69c8548175), I wanted this patch but Rik pointed out
and allowed aging of anon pages to give a chance to promote from inactive
to active LRU.
It has a two problem.
1) non-swap system
Never make sense to age anon pages.
2) swap configured but still doesn't swapon
It doesn't make sense to age anon pages until swap-on time. But it's
arguable. If we have aged anon pages by swapon, VM have moved anon pages
from active to inactive. And in the time swapon by admin, the VM can't
reclaim hot pages so we can protect hot pages swapout.
But let's think about it. When does swap-on happen? It depends on admin.
we can't expect it. Nonetheless, we have done aging of anon pages to
protect hot pages swapout. It means we lost run time overhead when below
high watermark but gain hot page swap-[in/out] overhead when VM decide
swapout. Is it true? Let's think more detail. We don't promote anon
pages in case of non-swap system. So even though VM does aging of anon
pages, the pages would be in inactive LRU for a long time. It means many
of pages in there would mark access bit again. So access bit hot/code
separation would be pointless.
This patch prevents unnecessary anon pages demotion in not-yet-swapon and
non-configured swap system. Even, in non-configuared swap system
inactive_anon_is_low can be compiled out.
It could make side effect that hot anon pages could swap out when admin
does swap on. But I think sooner or later it would be steady state. So
it's not a big problem.
We could lose someting but gain more thing(TLB flush and unnecessary
function call to demote anon pages).
Signed-off-by: Ying Han <yinghan@google.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Non-NUMA systems do never create these files anyway, since they are only
created by driver subsystem when NUMA is configured.
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
This removes more dead code that was somehow missed by commit 0d99519efef
(writeback: remove unused nonblocking and congestion checks). There are
no behavior change except for the removal of two entries from one of the
ext4 tracing interface.
The nonblocking checks in ->writepages are no longer used because the
flusher now prefer to block on get_request_wait() than to skip inodes on
IO congestion. The latter will lead to more seeky IO.
The nonblocking checks in ->writepage are no longer used because it's
redundant with the WB_SYNC_NONE check.
We no long set ->nonblocking in VM page out and page migration, because
a) it's effectively redundant with WB_SYNC_NONE in current code
b) it's old semantic of "Don't get stuck on request queues" is mis-behavior:
that would skip some dirty inodes on congestion and page out others, which
is unfair in terms of LRU age.
Inspired by Christoph Hellwig. Thanks!
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Sage Weil <sage@newdream.net>
Cc: Steve French <sfrench@samba.org>
Cc: Chris Mason <chris.mason@oracle.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
M. Vefa Bicakci reported 2.6.35 kernel hang up when hibernation on his
32bit 3GB mem machine.
(https://bugzilla.kernel.org/show_bug.cgi?id=16771). Also he bisected
the regression to
commit bb21c7ce18eff8e6e7877ca1d06c6db719376e3c
Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Date: Fri Jun 4 14:15:05 2010 -0700
vmscan: fix do_try_to_free_pages() return value when priority==0 reclaim failure
At first impression, this seemed very strange because the above commit
only chenged function return value and hibernate_preallocate_memory()
ignore return value of shrink_all_memory(). But it's related.
Now, page allocation from hibernation code may enter infinite loop if the
system has highmem. The reasons are that vmscan don't care enough OOM
case when oom_killer_disabled.
The problem sequence is following as.
1. hibernation
2. oom_disable
3. alloc_pages
4. do_try_to_free_pages
if (scanning_global_lru(sc) && !all_unreclaimable)
return 1;
If kswapd is not freozen, it would set zone->all_unreclaimable to 1 and
then shrink_zones maybe return true(ie, all_unreclaimable is true). So at
last, alloc_pages could go to _nopage_. If it is, it should have no
problem.
This patch adds all_unreclaimable check to protect in direct reclaim path,
too. It can care of hibernation OOM case and help bailout
all_unreclaimable case slightly.
Reported-by: M. Vefa Bicakci <bicave@superonline.com>
Reported-by: <caiqian@redhat.com>
Tested-by: <caiqian@redhat.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Fix typo s/contenious/continuous in comment.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
mem_cgroup_soft_limit_reclaim() has zone, nid and zid argument. but nid
and zid can be calculated from zone. So remove it.
Cc: Nishimura Daisuke <d-nishimura@mtf.biglobe.ne.jp>
Currently mem_cgroup_shrink_node_zone() call shrink_zone() directly. thus
it doesn't need to initialize sc.nodemask because shrink_zone() doesn't
use it at all.
sc.nr_reclaimed and sc.nr_scanned have already been initialized few lines
above "struct scan_control sc = {}" statement.
So, This patch remove this unnecessary code.
Currently, mem_cgroup_shrink_node_zone() initialize sc.nr_to_reclaim as 0.
It mean shrink_zone() only scan 32 pages and immediately return even if
it doesn't reclaim any pages.
Fix "system goes unresponsive under memory pressure and lots of
dirty/writeback pages" bug.
http://lkml.org/lkml/2010/4/4/86
In the above thread, Andreas Mohr described that
Invoking any command locked up for minutes (note that I'm
talking about attempted additional I/O to the _other_,
_unaffected_ main system HDD - such as loading some shell
binaries -, NOT the external SSD18M!!).
This happens when the two conditions are both meet:
- under memory pressure
- writing heavily to a slow device
OOM also happens in Andreas' system. The OOM trace shows that 3 processes
are stuck in wait_on_page_writeback() in the direct reclaim path. One in
do_fork() and the other two in unix_stream_sendmsg(). They are blocked on
this condition:
(sc->order && priority < DEF_PRIORITY - 2)
which was introduced in commit 78dc583d (vmscan: low order lumpy reclaim
also should use PAGEOUT_IO_SYNC) one year ago. That condition may be too
permissive. In Andreas' case, 512MB/1024 = 512KB. If the direct reclaim
for the order-1 fork() allocation runs into a range of 512KB
hard-to-reclaim LRU pages, it will be stalled.
It's a severe problem in three ways.
Firstly, it can easily happen in daily desktop usage. vmscan priority can
easily go below (DEF_PRIORITY - 2) on _local_ memory pressure. Even if
the system has 50% globally reclaimable pages, it still has good
opportunity to have 0.1% sized hard-to-reclaim ranges. For example, a
simple dd can easily create a big range (up to 20%) of dirty pages in the
LRU lists. And order-1 to order-3 allocations are more than common with
SLUB. Try "grep -v '1 :' /proc/slabinfo" to get the list of high order
slab caches. For example, the order-1 radix_tree_node slab cache may
stall applications at swap-in time; the order-3 inode cache on most
filesystems may stall applications when trying to read some file; the
order-2 proc_inode_cache may stall applications when trying to open a
/proc file.
Secondly, once triggered, it will stall unrelated processes (not doing IO
at all) in the system. This "one slow USB device stalls the whole system"
avalanching effect is very bad.
Thirdly, once stalled, the stall time could be intolerable long for the
users. When there are 20MB queued writeback pages and USB 1.1 is writing
them in 1MB/s, wait_on_page_writeback() will stuck for up to 20 seconds.
Not to mention it may be called multiple times.
So raise the bar to only enable PAGEOUT_IO_SYNC when priority goes below
DEF_PRIORITY/3, or 6.25% LRU size. As the default dirty throttle ratio is
20%, it will hardly be triggered by pure dirty pages. We'd better treat
PAGEOUT_IO_SYNC as some last resort workaround -- its stall time is so
uncomfortably long (easily goes beyond 1s).
The bar is only raised for (order < PAGE_ALLOC_COSTLY_ORDER) allocations,
which are easy to satisfy in 1TB memory boxes. So, although 6.25% of
memory could be an awful lot of pages to scan on a system with 1TB of
memory, it won't really have to busy scan that much.
Andreas tested an older version of this patch and reported that it mostly
fixed his problem. Mel Gorman helped improve it and KOSAKI Motohiro will
fix it further in the next patch.
Reported-by: Andreas Mohr <andi@lisas.de>
Memcg also need to trace reclaim progress as direct reclaim. This patch
add it.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Presently shrink_slab() has the following scanning equation.
lru_scanned max_pass
basic_scan_objects = 4 x ------------- x -----------------------------
lru_pages shrinker->seeks (default:2)
scan_objects = min(basic_scan_objects, max_pass * 2)
If we pass very small value as lru_pages instead real number of lru pages,
shrink_slab() drop much objects rather than necessary. And now,
__zone_reclaim() pass 'order' as lru_pages by mistake. That produces a
bad result.
For example, if we receive very low memory pressure (scan = 32, order =
0), shrink_slab() via zone_reclaim() always drop _all_ icache/dcache
objects. (see above equation, very small lru_pages make very big
scan_objects result).
[akpm@linux-foundation.org: fix layout, typos]
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Rik van Riel pointed out reading reclaim_stat should be protected
lru_lock, otherwise vmscan might sweep 2x much pages.
This fault was introduced by
commit 4f98a2fee8acdb4ac84545df98cccecfd130f8db
Author: Rik van Riel <riel@redhat.com>
Date: Sat Oct 18 20:26:32 2008 -0700
vmscan: split LRU lists into anon & file sets
'slab_reclaimable' and 'nr_pages' are unsigned. Subtraction is unsafe
because negative results would be misinterpreted.
When shrink_inactive_list() isolates pages, it updates a number of
counters using temporary variables to gather them. These consume stack
and it's in the main path that calls ->writepage(). This patch moves the
accounting updates outside of the main path to reduce stack usage.
Cc: Nick Piggin <npiggin@suse.de>
Cc: Michael Rubin <mrubin@google.com>
shrink_page_list() sets up a pagevec to release pages as according as they
are free. It uses significant amounts of stack on the pagevec. This
patch adds pages to be freed via pagevec to a linked list which is then
freed en-masse at the end. This avoids using stack in the main path that
potentially calls writepage().
shrink_inactive_list() sets up a pagevec to release unfreeable pages. It
uses significant amounts of stack doing this. This patch splits
shrink_inactive_list() to take the stack usage out of the main path so
that callers to writepage() do not contain an unused pagevec on the stack.
Remove temporary variable that is only used once and does not help clarify
code.
Now, max_scan of shrink_inactive_list() is always passed less than
SWAP_CLUSTER_MAX. then, we can remove scanning pages loop in it. This
patch also help stack diet.
detail
- remove "while (nr_scanned < max_scan)" loop
- remove nr_freed (now, we use nr_reclaimed directly)
- remove nr_scan (now, we use nr_scanned directly)
- rename max_scan to nr_to_scan
- pass nr_to_scan into isolate_pages() directly instead
using SWAP_CLUSTER_MAX
Since 2.6.28 zone->prev_priority is unused. Then it can be removed
safely. It reduce stack usage slightly.
Now I have to say that I'm sorry. 2 years ago, I thought prev_priority
can be integrate again, it's useful. but four (or more) times trying
haven't got good performance number. Thus I give up such approach.
The rest of this changelog is notes on prev_priority and why it existed in
the first place and why it might be not necessary any more. This information
is based heavily on discussions between Andrew Morton, Rik van Riel and
Kosaki Motohiro who is heavily quotes from.
Historically prev_priority was important because it determined when the VM
would start unmapping PTE pages. i.e. there are no balances of note within
the VM, Anon vs File and Mapped vs Unmapped. Without prev_priority, there
is a potential risk of unnecessarily increasing minor faults as a large
amount of read activity of use-once pages could push mapped pages to the
end of the LRU and get unmapped.
There is no proof this is still a problem but currently it is not considered
to be. Active files are not deactivated if the active file list is smaller
than the inactive list reducing the liklihood that file-mapped pages are
being pushed off the LRU and referenced executable pages are kept on the
active list to avoid them getting pushed out by read activity.
Even if it is a problem, prev_priority prev_priority wouldn't works
nowadays. First of all, current vmscan still a lot of UP centric code. it
expose some weakness on some dozens CPUs machine. I think we need more and
more improvement.
The problem is, current vmscan mix up per-system-pressure, per-zone-pressure
and per-task-pressure a bit. example, prev_priority try to boost priority to
other concurrent priority. but if the another task have mempolicy restriction,
it is unnecessary, but also makes wrong big latency and exceeding reclaim.
per-task based priority + prev_priority adjustment make the emulation of
per-system pressure. but it have two issue 1) too rough and brutal emulation
2) we need per-zone pressure, not per-system.
Another example, currently DEF_PRIORITY is 12. it mean the lru rotate about
2 cycle (1/4096 + 1/2048 + 1/1024 + .. + 1) before invoking OOM-Killer.
but if 10,0000 thrreads enter DEF_PRIORITY reclaim at the same time, the
system have higher memory pressure than priority==0 (1/4096*10,000 > 2).
prev_priority can't solve such multithreads workload issue. In other word,
prev_priority concept assume the sysmtem don't have lots threads."
Add a trace event for when page reclaim queues a page for IO and records
whether it is synchronous or asynchronous. Excessive synchronous IO for a
process can result in noticeable stalls during direct reclaim. Excessive
IO from page reclaim may indicate that the system is seriously under
provisioned for the amount of dirty pages that exist.
Acked-by: Larry Woodman <lwoodman@redhat.com>
Add an event for when pages are isolated en-masse from the LRU lists.
This event augments the information available on LRU traffic and can be
used to evaluate lumpy reclaim.
Add two trace events for kswapd waking up and going asleep for the
purposes of tracking kswapd activity and two trace events for direct
reclaim beginning and ending. The information can be used to work out how
much time a process or the system is spending on the reclamation of pages
and in the case of direct reclaim, how many pages were reclaimed for that
process. High frequency triggering of these events could point to memory
pressure problems.
shrink_zones() need relatively long time and lru_pages can change
dramatically during shrink_zones(). So lru_pages should be recalculated
for each priority.
Swap token don't works when zone reclaim is enabled since it was born.
Because __zone_reclaim() always call disable_swap_token() unconditionally.
This kill swap token feature completely. As far as I know, nobody want to
that. Remove it.
We need lock_page_nosync() here because we have no reference to the
mapping when taking the page lock.
Signed-off-by: Nick Piggin <npiggin@suse.de>
The current shrinker implementation requires the registered callback
to have global state to work from. This makes it difficult to shrink
caches that are not global (e.g. per-filesystem caches). Pass the shrinker
structure to the callback so that users can embed the shrinker structure
in the context the shrinker needs to operate on and get back to it in the
callback via container_of().
Signed-off-by: Dave Chinner <dchinner@redhat.com>
