This patch adds a function to scan individual or all zones' unevictable
lists and move any pages that have become evictable onto the respective
zone's inactive list, where shrink_inactive_list() will deal with them.
Adds sysctl to scan all nodes, and per node attributes to individual
nodes' zones.
Kosaki: If evictable page found in unevictable lru when write
/proc/sys/vm/scan_unevictable_pages, print filename and file offset of
these pages.
[akpm@linux-foundation.org: fix one CONFIG_MMU=n build error]
[kosaki.motohiro@jp.fujitsu.com: adapt vmscan-unevictable-lru-scan-sysctl.patch to new sysfs API]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
Signed-off-by: Nick Piggin <npiggin@suse.de>
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Cc: Nick Piggin <npiggin@suse.de>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
Shmem segments locked into memory via shmctl(SHM_LOCKED) should not be
kept on the normal LRU, since scanning them is a waste of time and might
throw off kswapd's balancing algorithms. Place them on the unevictable
LRU list instead.
Use the AS_UNEVICTABLE flag to mark address_space of SHM_LOCKed shared
memory regions as unevictable. Then these pages will be culled off the
normal LRU lists during vmscan.
Add new wrapper function to clear the mapping's unevictable state when/if
shared memory segment is munlocked.
Add 'scan_mapping_unevictable_page()' to mm/vmscan.c to scan all pages in
the shmem segment's mapping [struct address_space] for evictability now
that they're no longer locked. If so, move them to the appropriate zone
lru list.
Changes depend on [CONFIG_]UNEVICTABLE_LRU.
[kosaki.motohiro@jp.fujitsu.com: revert shm change]
Signed-off-by: Kosaki Motohiro <kosaki.motohiro@jp.fujitsu.com>
Christoph Lameter pointed out that ram disk pages also clutter the LRU
lists. When vmscan finds them dirty and tries to clean them, the ram disk
writeback function just redirties the page so that it goes back onto the
active list. Round and round she goes...
With the ram disk driver [rd.c] replaced by the newer 'brd.c', this is no
longer the case, as ram disk pages are no longer maintained on the lru.
[This makes them unmigratable for defrag or memory hot remove, but that
can be addressed by a separate patch series.] However, the ramfs pages
behave like ram disk pages used to, so:
Define new address_space flag [shares address_space flags member with
mapping's gfp mask] to indicate that the address space contains all
unevictable pages. This will provide for efficient testing of ramfs pages
in page_evictable().
Also provide wrapper functions to set/test the unevictable state to
minimize #ifdefs in ramfs driver and any other users of this facility.
Set the unevictable state on address_space structures for new ramfs
inodes. Test the unevictable state in page_evictable() to cull
unevictable pages.
These changes depend on [CONFIG_]UNEVICTABLE_LRU.
[riel@redhat.com: undo the brd.c part]
Debugged-by: Nick Piggin <nickpiggin@yahoo.com.au>
Fix to unevictable-lru-page-statistics.patch
Add unevictable lru infrastructure vm events to the statistics patch.
Rename the "NORECL_" and "noreclaim_" symbols and text strings to
"UNEVICTABLE_" and "unevictable_", respectively.
Currently, both the infrastructure and the mlocked pages event are
added by a single patch later in the series. This makes it difficult
to add or rework the incremental patches. The events actually "belong"
with the stats, so pull them up to here.
Also, restore the event counting to putback_lru_page(). This was removed
from previous patch in series where it was "misplaced". The actual events
weren't defined that early.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
When the system contains lots of mlocked or otherwise unevictable pages,
the pageout code (kswapd) can spend lots of time scanning over these
pages. Worse still, the presence of lots of unevictable pages can confuse
kswapd into thinking that more aggressive pageout modes are required,
resulting in all kinds of bad behaviour.
Infrastructure to manage pages excluded from reclaim--i.e., hidden from
vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to
maintain "unevictable" pages on a separate per-zone LRU list, to "hide"
them from vmscan.
Kosaki Motohiro added the support for the memory controller unevictable
lru list.
Pages on the unevictable list have both PG_unevictable and PG_lru set.
Thus, PG_unevictable is analogous to and mutually exclusive with
PG_active--it specifies which LRU list the page is on.
The unevictable infrastructure is enabled by a new mm Kconfig option
A new function 'page_evictable(page, vma)' in vmscan.c tests whether or
not a page may be evictable. Subsequent patches will add the various
!evictable tests. We'll want to keep these tests light-weight for use in
shrink_active_list() and, possibly, the fault path.
To avoid races between tasks putting pages [back] onto an LRU list and
tasks that might be moving the page from non-evictable to evictable state,
the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()'
-- tests the "evictability" of a page after placing it on the LRU, before
dropping the reference. If the page has become unevictable,
putback_lru_page() will redo the 'putback', thus moving the page to the
unevictable list. This way, we avoid "stranding" evictable pages on the
unevictable list.
[akpm@linux-foundation.org: fix fallout from out-of-order merge]
[riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build]
[nishimura@mxp.nes.nec.co.jp: remove redundant mapping check]
[kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework]
[kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c]
[kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure]
[kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch]
[kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch]
Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
During an AIM7 run on a 16GB system, fork started failing around 32000
threads, despite the system having plenty of free swap and 15GB of
pageable memory. This was on x86-64, so 8k stacks.
If a higher order allocation fails, we can either:
- keep evicting pages off the end of the LRUs and hope that
we eventually create a contiguous region; this is somewhat
unlikely if the system is under enough stress by new
allocations
- after trying normal eviction for a bit, use lumpy reclaim
This patch switches the system to lumpy reclaim if the VM is having
trouble freeing enough pages, using the same threshold for detection as
used by pageout congestion wait.
Moving referenced pages back to the head of the active list creates a huge
scalability problem, because by the time a large memory system finally
runs out of free memory, every single page in the system will have been
referenced.
Not only do we not have the time to scan every single page on the active
list, but since they have will all have the referenced bit set, that bit
conveys no useful information.
A more scalable solution is to just move every page that hits the end of
the active list to the inactive list.
We clear the referenced bit off of mapped pages, which need just one
reference to be moved back onto the active list.
Unmapped pages will be moved back to the active list after two references
(see mark_page_accessed). We preserve the PG_referenced flag on unmapped
pages to preserve accesses that were made while the page was on the active
list.
We avoid evicting and scanning anonymous pages for the most part, but
under some workloads we can end up with most of memory filled with
anonymous pages. At that point, we suddenly need to clear the referenced
bits on all of memory, which can take ages on very large memory systems.
We can reduce the maximum number of pages that need to be scanned by not
taking the referenced state into account when deactivating an anonymous
page. After all, every anonymous page starts out referenced, so why
check?
If an anonymous page gets referenced again before it reaches the end of
the inactive list, we move it back to the active list.
To keep the maximum amount of necessary work reasonable, we scale the
active to inactive ratio with the size of memory, using the formula
active:inactive ratio = sqrt(memory in GB * 10).
Kswapd CPU use now seems to scale by the amount of pageout bandwidth,
instead of by the amount of memory present in the system.
[kamezawa.hiroyu@jp.fujitsu.com: fix OOM with memcg]
[kamezawa.hiroyu@jp.fujitsu.com: memcg: lru scan fix]
Split the LRU lists in two, one set for pages that are backed by real file
systems ("file") and one for pages that are backed by memory and swap
("anon"). The latter includes tmpfs.
The advantage of doing this is that the VM will not have to scan over lots
of anonymous pages (which we generally do not want to swap out), just to
find the page cache pages that it should evict.
This patch has the infrastructure and a basic policy to balance how much
we scan the anon lists and how much we scan the file lists. The big
policy changes are in separate patches.
[lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset]
[kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru]
[kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page]
[hugh@veritas.com: memcg swapbacked pages active]
[hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED]
[akpm@linux-foundation.org: fix /proc/vmstat units]
[nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration]
[kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo]
[kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()]
Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
If vm_swap_full() (swap space more than 50% full), the system will free
swap space at swapin time. With this patch, the system will also free the
swap space in the pageout code, when we decide that the page is not a
candidate for swapout (and just wasting swap space).
Signed-off-by: MinChan Kim <minchan.kim@gmail.com>
Currently we are defining explicit variables for the inactive and active
list. An indexed array can be more generic and avoid repeating similar
code in several places in the reclaim code.
We are saving a few bytes in terms of code size:
Before:
4097753 573120 4092484 8763357 85b7dd vmlinux
After:
4097729 573120 4092484 8763333 85b7c5 vmlinux
Having an easy way to add new lru lists may ease future work on the
reclaim code.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
On large memory systems, the VM can spend way too much time scanning
through pages that it cannot (or should not) evict from memory. Not only
does it use up CPU time, but it also provokes lock contention and can
leave large systems under memory presure in a catatonic state.
This patch series improves VM scalability by:
1) putting filesystem backed, swap backed and unevictable pages
onto their own LRUs, so the system only scans the pages that it
can/should evict from memory
2) switching to two handed clock replacement for the anonymous LRUs,
so the number of pages that need to be scanned when the system
starts swapping is bound to a reasonable number
3) keeping unevictable pages off the LRU completely, so the
VM does not waste CPU time scanning them. ramfs, ramdisk,
SHM_LOCKED shared memory segments and mlock()ed VMA pages
are keept on the unevictable list.
This patch:
isolate_lru_page logically belongs to be in vmscan.c than migrate.c.
It is tough, because we don't need that function without memory migration
so there is a valid argument to have it in migrate.c. However a
subsequent patch needs to make use of it in the core mm, so we can happily
move it to vmscan.c.
Also, make the function a little more generic by not requiring that it
adds an isolated page to a given list. Callers can do that.
Note that we now have '__isolate_lru_page()', that does
something quite different, visible outside of vmscan.c
for use with memory controller. Methinks we need to
rationalize these names/purposes. --lts
[akpm@linux-foundation.org: fix mm/memory_hotplug.c build]
Converting page lock to new locking bitops requires a change of page flag
operation naming, so we might as well convert it to something nicer
(!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked).
This also facilitates lockdeping of page lock.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
mapping->tree_lock has no read lockers. convert the lock from an rwlock
to a spinlock.
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
If we can be sure that elevating the page_count on a pagecache page will
pin it, we can speculatively run this operation, and subsequently check to
see if we hit the right page rather than relying on holding a lock or
otherwise pinning a reference to the page.
This can be done if get_page/put_page behaves consistently throughout the
whole tree (ie. if we "get" the page after it has been used for something
else, we must be able to free it with a put_page).
Actually, there is a period where the count behaves differently: when the
page is free or if it is a constituent page of a compound page. We need
an atomic_inc_not_zero operation to ensure we don't try to grab the page
in either case.
This patch introduces the core locking protocol to the pagecache (ie.
adds page_cache_get_speculative, and tweaks some update-side code to make
it work).
Thanks to Hugh for pointing out an improvement to the algorithm setting
page_count to zero when we have control of all references, in order to
hold off speculative getters.
[kamezawa.hiroyu@jp.fujitsu.com: fix migration_entry_wait()]
[hugh@veritas.com: fix add_to_page_cache]
[akpm@linux-foundation.org: repair a comment]
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Nick Piggin <npiggin@suse.de>
Sometimes, application responses become bad under heavy memory load.
Applications take a bit time to reclaim memory. The statistics, how long
memory reclaim takes, will be useful to measure memory usage.
This patch adds accounting memory reclaim to per-task-delay-accounting for
accounting the time of do_try_to_free_pages().
<i.e>
- When System is under low memory load,
memory reclaim may not occur.
$ free
total used free shared buffers cached
Mem: 8197800 1577300 6620500 0 4808 1516724
-/+ buffers/cache: 55768 8142032
Swap: 16386292 0 16386292
$ vmstat 1
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
r b swpd free buff cache si so bi bo in cs us sy id wa
0 0 0 5069748 10612 3014060 0 0 0 0 3 26 0 0 100 0
0 0 0 5069748 10612 3014060 0 0 0 0 4 22 0 0 100 0
0 0 0 5069748 10612 3014060 0 0 0 0 3 18 0 0 100 0
Measure the time of tar command.
$ ls -s test.dat
1501472 test.dat
$ time tar cvf test.tar test.dat
real 0m13.388s
user 0m0.116s
sys 0m5.304s
$ ./delayget -d -p <pid>
CPU count real total virtual total delay total
428 5528345500 5477116080 62749891
IO count delay total
338 8078977189
SWAP count delay total
0 0
RECLAIM count delay total
0 0
- When system is under heavy memory load
memory reclaim may occur.
$ vmstat 1
0 0 7159032 49724 1812 3012 0 0 0 0 3 24 0 0 100 0
0 0 7159032 49724 1812 3012 0 0 0 0 4 24 0 0 100 0
0 0 7159032 49848 1812 3012 0 0 0 0 3 22 0 0 100 0
In this case, one process uses more 8G memory
by execution of malloc() and memset().
real 1m38.563s <- increased by 85 sec
user 0m0.140s
sys 0m7.060s
9021 7140446250 7315277975 923201824
8965 90466349669
3 21036367
740 61011951153
In the later case, the value of RECLAIM is increasing.
So, taskstats can show how much memory reclaim influences TAT.
Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujistu.com>
"Smarter retry of costly-order allocations" patch series change behaver of
do_try_to_free_pages(). But unfortunately ret variable type was
unchanged.
Thus an overflow is possible.
Acked-by: Nishanth Aravamudan <nacc@us.ibm.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Because of page order checks in __alloc_pages(), hugepage (and similarly
large order) allocations will not retry unless explicitly marked
__GFP_REPEAT. However, the current retry logic is nearly an infinite
loop (or until reclaim does no progress whatsoever). For these costly
allocations, that seems like overkill and could potentially never
terminate. Mel observed that allowing current __GFP_REPEAT semantics for
hugepage allocations essentially killed the system. I believe this is
because we may continue to reclaim small orders of pages all over, but
never have enough to satisfy the hugepage allocation request. This is
clearly only a problem for large order allocations, of which hugepages
are the most obvious (to me).
Modify try_to_free_pages() to indicate how many pages were reclaimed.
Use that information in __alloc_pages() to eventually fail a large
__GFP_REPEAT allocation when we've reclaimed an order of pages equal to
or greater than the allocation's order. This relies on lumpy reclaim
functioning as advertised. Due to fragmentation, lumpy reclaim may not
be able to free up the order needed in one invocation, so multiple
iterations may be requred. In other words, the more fragmented memory
is, the more retry attempts __GFP_REPEAT will make (particularly for
higher order allocations).
This changes the semantics of __GFP_REPEAT subtly, but *only* for
allocations > PAGE_ALLOC_COSTLY_ORDER. With this patch, for those size
allocations, we will try up to some point (at least 1<<order reclaimed
pages), rather than forever (which is the case for allocations <=
PAGE_ALLOC_COSTLY_ORDER).
This change improves the /proc/sys/vm/nr_hugepages interface with a
follow-on patch that makes pool allocations use __GFP_REPEAT. Rather
than administrators repeatedly echo'ing a particular value into the
sysctl, and forcing reclaim into action manually, this change allows for
the sysctl to attempt a reasonable effort itself. Similarly, dynamic
pool growth should be more successful under load, as lumpy reclaim can
try to free up pages, rather than failing right away.
Choosing to reclaim only up to the order of the requested allocation
strikes a balance between not failing hugepage allocations and returning
to the caller when it's unlikely to every succeed. Because of lumpy
reclaim, if we have freed the order requested, hopefully it has been in
big chunks and those chunks will allow our allocation to succeed. If
that isn't the case after freeing up the current order, I don't think it
is likely to succeed in the future, although it is possible given a
particular fragmentation pattern.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Tested-by: Mel Gorman <mel@csn.ul.ie>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Christoph Lameter <clameter@sgi.com>
Filtering zonelists requires very frequent use of zone_idx(). This is costly
as it involves a lookup of another structure and a substraction operation. As
the zone_idx is often required, it should be quickly accessible. The node idx
could also be stored here if it was found that accessing zone->node is
significant which may be the case on workloads where nodemasks are heavily
used.
This patch introduces a struct zoneref to store a zone pointer and a zone
index. The zonelist then consists of an array of these struct zonerefs which
are looked up as necessary. Helpers are given for accessing the zone index as
well as the node index.
[kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers]
[hugh@veritas.com: mm-have-zonelist: fix memcg ooms]
[hugh@veritas.com: just return do_try_to_free_pages]
[hugh@veritas.com: do_try_to_free_pages gfp_mask redundant]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Christoph Lameter <clameter@sgi.com>
Acked-by: David Rientjes <rientjes@google.com>
Currently a node has two sets of zonelists, one for each zone type in the
system and a second set for GFP_THISNODE allocations. Based on the zones
allowed by a gfp mask, one of these zonelists is selected. All of these
zonelists consume memory and occupy cache lines.
This patch replaces the multiple zonelists per-node with two zonelists. The
first contains all populated zones in the system, ordered by distance, for
fallback allocations when the target/preferred node has no free pages. The
second contains all populated zones in the node suitable for GFP_THISNODE
allocations.
An iterator macro is introduced called for_each_zone_zonelist() that interates
through each zone allowed by the GFP flags in the selected zonelist.
The following patches replace multiple zonelists per node with two zonelists
that are filtered based on the GFP flags. The patches as a set fix a bug with
regard to the use of MPOL_BIND and ZONE_MOVABLE. With this patchset, the
MPOL_BIND will apply to the two highest zones when the highest zone is
ZONE_MOVABLE. This should be considered as an alternative fix for the
MPOL_BIND+ZONE_MOVABLE in 2.6.23 to the previously discussed hack that filters
only custom zonelists.
The first patch cleans up an inconsistency where direct reclaim uses
zonelist->zones where other places use zonelist.
The second patch introduces a helper function node_zonelist() for looking up
the appropriate zonelist for a GFP mask which simplifies patches later in the
set.
The third patch defines/remembers the "preferred zone" for numa statistics, as
it is no longer always the first zone in a zonelist.
The forth patch replaces multiple zonelists with two zonelists that are
filtered. The two zonelists are due to the fact that the memoryless patchset
introduces a second set of zonelists for __GFP_THISNODE.
The fifth patch introduces helper macros for retrieving the zone and node
indices of entries in a zonelist.
The final patch introduces filtering of the zonelists based on a nodemask.
Two zonelists exist per node, one for normal allocations and one for
__GFP_THISNODE.
Performance results varied depending on the machine configuration. In real
workloads the gain/loss will depend on how much the userspace portion of the
benchmark benefits from having more cache available due to reduced referencing
of zonelists.
These are the range of performance losses/gains when running against
2.6.24-rc4-mm1. The set and these machines are a mix of i386, x86_64 and
ppc64 both NUMA and non-NUMA.
loss to gain
Total CPU time on Kernbench: -0.86% to 1.13%
Elapsed time on Kernbench: -0.79% to 0.76%
page_test from aim9: -4.37% to 0.79%
brk_test from aim9: -0.71% to 4.07%
fork_test from aim9: -1.84% to 4.60%
exec_test from aim9: -0.71% to 1.08%
This patch:
The allocator deals with zonelists which indicate the order in which zones
should be targeted for an allocation. Similarly, direct reclaim of pages
iterates over an array of zones. For consistency, this patch converts direct
reclaim to use a zonelist. No functionality is changed by this patch. This
simplifies zonelist iterators in the next patch.
* Use new node_to_cpumask_ptr. This creates a pointer to the
cpumask for a given node. This definition is in mm patch:
asm-generic-add-node_to_cpumask_ptr-macro.patch
* Use new set_cpus_allowed_ptr function.
Depends on:
[mm-patch]: asm-generic-add-node_to_cpumask_ptr-macro.patch
[sched-devel]: sched: add new set_cpus_allowed_ptr function
[x86/latest]: x86: add cpus_scnprintf function
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Greg Banks <gnb@melbourne.sgi.com>
Signed-off-by: Mike Travis <travis@sgi.com>
Revert commit f1a9ee758de7de1e040de849fdef46e6802ea117:
Author: Rik van Riel <riel@redhat.com>
Date: Thu Feb 7 00:14:08 2008 -0800
kswapd should only wait on IO if there is IO
The current kswapd (and try_to_free_pages) code has an oddity where the
code will wait on IO, even if there is no IO in flight. This problem is
notable especially when the system scans through many unfreeable pages,
causing unnecessary stalls in the VM.
Additionally, tasks without __GFP_FS or __GFP_IO in the direct reclaim path
will sleep if a significant number of pages are encountered that should be
written out. This gives kswapd a chance to write out those pages, while
the direct reclaim task sleeps.
Because of large latencies and interactivity problems reported by Carlos,
here: http://lkml.org/lkml/2008/3/22/211
Cc: "Carlos R. Mafra" <crmafra2@gmail.com>
Each caller of mem_cgroup_move_lists is having to use page_get_page_cgroup:
it's more convenient if it acts upon the page itself not the page_cgroup; and
in a later patch this becomes important to handle within memcontrol.c.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Hirokazu Takahashi <taka@valinux.co.jp>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Cc: Paul Menage <menage@google.com>
Rename Memory Controller to Memory Resource Controller. Reflect the same
changes in the CONFIG definition for the Memory Resource Controller. Group
together the config options for Resource Counters and Memory Resource
Controller.
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
for isolate globa/cgroup lru activity
When using memory controller, there are 2 levels of memory reclaim.
1. zone memory reclaim because of system/zone memory shortage.
2. memory cgroup memory reclaim because of hitting limit.
These two can be distinguished by sc->mem_cgroup parameter.
(scan_global_lru() macro)
This patch tries to make memory cgroup reclaim routine avoid affecting
system/zone memory reclaim. This patch inserts if (scan_global_lru()) and
hook to memory_cgroup reclaim support functions.
This patch can be a help for isolating system lru activity and group lru
activity and shows what additional functions are necessary.
* mem_cgroup_calc_mapped_ratio() ... calculate mapped ratio for cgroup.
* mem_cgroup_reclaim_imbalance() ... calculate active/inactive balance in
cgroup.
* mem_cgroup_calc_reclaim_active() ... calculate the number of active pages to
be scanned in this priority in mem_cgroup.
* mem_cgroup_calc_reclaim_inactive() ... calculate the number of inactive pages
to be scanned in this priority in mem_cgroup.
* mem_cgroup_all_unreclaimable() .. checks cgroup's page is all unreclaimable
or not.
* mem_cgroup_get_reclaim_priority() ...
* mem_cgroup_note_reclaim_priority() ... record reclaim priority (temporal)
* mem_cgroup_remember_reclaim_priority()
.... record reclaim priority as
zone->prev_priority.
This value is used for calc reclaim_mapped.
[akpm@linux-foundation.org: fix unused var warning]
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Pavel Emelianov <xemul@openvz.org>
Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
macro
This is used to detect which scan_control scans global lru or mem_cgroup lru.
And compiled to be static value (1) when memory controller is not configured.
This may make the meaning obvious.
Because NODE_DATA(node)->node_zonelists[] is guaranteed to contain all
necessary zones, it is not necessary to use for_each_online_node.
And this for_each_online_node() makes reclaim routine start always
from node 0. This is not good. This patch makes reclaim start from
caller's node and just use usual (default) zonelist order.
[akpm@linux-foundation.org: fix warning]
Nick Piggin pointed out that swap cache and page cache addition routines
could be called from non GFP_KERNEL contexts. This patch makes the
charging routine aware of the gfp context. Charging might fail if the
cgroup is over it's limit, in which case a suitable error is returned.
This patch was tested on a Powerpc box. I am still looking at being able
to test the path, through which allocations happen in non GFP_KERNEL
contexts.
[kamezawa.hiroyu@jp.fujitsu.com: problem with ZONE_MOVABLE]
Make page_referenced() cgroup aware. Without this patch, page_referenced()
can cause a page to be skipped while reclaiming pages. This patch ensures
that other cgroups do not hold pages in a particular cgroup hostage. It
is required to ensure that shared pages are freed from a cgroup when they
are not actively referenced from the cgroup that brought them in
Add the page_cgroup to the per cgroup LRU. The reclaim algorithm has
been modified to make the isolate_lru_pages() as a pluggable component. The
scan_control data structure now accepts the cgroup on behalf of which
reclaims are carried out. try_to_free_pages() has been extended to become
cgroup aware.
[Lee.Schermerhorn@hp.com: initialize all scan_control's isolate_pages member]
[bunk@kernel.org: make do_try_to_free_pages() static]
[hugh@veritas.com: memcgroup: fix try_to_free order]
[kamezawa.hiroyu@jp.fujitsu.com: this unlock_page_cgroup() is unnecessary]
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Spelling fixes in mm/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Get rid of sparse related warnings from places that use integer as NULL
pointer.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Andi Kleen <ak@suse.de>
Cc: Ian Kent <raven@themaw.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Introduces new zone flag interface for testing and setting flags:
int zone_test_and_set_flag(struct zone *zone, zone_flags_t flag)
Instead of setting and clearing ZONE_RECLAIM_LOCKED each time shrink_zone() is
called, this flag is test and set before starting zone reclaim. Zone reclaim
starts in __alloc_pages() when a zone's watermark fails and the system is in
zone_reclaim_mode. If it's already in reclaim, there's no need to start again
so it is simply considered full for that allocation attempt.
There is a change of behavior with regard to concurrent zone shrinking. It is
now possible for try_to_free_pages() or kswapd to already be shrinking a
particular zone when __alloc_pages() starts zone reclaim. In this case, it is
possible for two concurrent threads to invoke shrink_zone() for a single zone.
This change forbids a zone to be in zone reclaim twice, which was always the
behavior, but allows for concurrent try_to_free_pages() or kswapd shrinking
when starting zone reclaim.
Cc: Andrea Arcangeli <andrea@suse.de>
Signed-off-by: David Rientjes <rientjes@google.com>
Convert the int all_unreclaimable member of struct zone to unsigned long
flags. This can now be used to specify several different zone flags such as
all_unreclaimable and reclaim_in_progress, which can now be removed and
converted to a per-zone flag.
Flags are set and cleared as follows:
zone_set_flag(struct zone *zone, zone_flags_t flag)
zone_clear_flag(struct zone *zone, zone_flags_t flag)
Defines the first zone flags, ZONE_ALL_UNRECLAIMABLE and ZONE_RECLAIM_LOCKED,
which have the same semantics as the old zone->all_unreclaimable and
zone->reclaim_in_progress, respectively. Also converts all current users that
set or clear either flag to use the new interface.
Helper functions are defined to test the flags:
int zone_is_all_unreclaimable(const struct zone *zone)
int zone_is_reclaim_locked(const struct zone *zone)
All flag operators are of the atomic variety because there are currently
readers that are implemented that do not take zone->lock.
[akpm@linux-foundation.org: add needed include]
Swappiness isn't a safe sysctl. Setting it to 0 for example can hang a
system. That's a corner case but even setting it to 10 or lower can waste
enormous amounts of cpu without making much progress. We've customers who
wants to use swappiness but they can't because of the current
implementation (if you change it so the system stops swapping it really
stops swapping and nothing works sane anymore if you really had to swap
something to make progress).
This patch from Kurt Garloff makes swappiness safer to use (no more huge
cpu usage or hangs with low swappiness values).
I think the prev_priority can also be nuked since it wastes 4 bytes per
zone (that would be an incremental patch but I wait the nr_scan_[in]active
to be nuked first for similar reasons). Clearly somebody at some point
noticed how broken that thing was and they had to add min(priority,
prev_priority) to give it some reliability, but they didn't go the last
mile to nuke prev_priority too. Calculating distress only in function of
not-racy priority is correct and sure more than enough without having to
add randomness into the equation.
Patch is tested on older kernels but it compiles and it's quite simple
so...
Overall I'm not very satisified by the swappiness tweak, since it doesn't
rally do anything with the dirty pagecache that may be inactive. We need
another kind of tweak that controls the inactive scan and tunes the
can_writepage feature (not yet in mainline despite having submitted it a
few times), not only the active one. That new tweak will tell the kernel
how hard to scan the inactive list for pure clean pagecache (something the
mainline kernel isn't capable of yet). We already have that feature
working in all our enterprise kernels with the default reasonable tune, or
they can't even run a readonly backup with tar without triggering huge
write I/O. I think it should be available also in mainline later.
Signed-off-by: Kurt Garloff <garloff@suse.de>
Signed-off-by: Andrea Arcangeli <andrea@suse.de>
Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn>
When a cpu is onlined on memory-less-node box, kernel panics due to touch
NULL pointer of pgdat->kswapd. Current kswapd runs only nodes which have
memory. So, calling of set_cpus_allowed() is not necessary for memory-less
node.
This is fix for it.
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
We need the check for a node with cpu in zone reclaim. Zone reclaim will not
allow remote zone reclaim if a node has a cpu.
[Lee.Schermerhorn@hp.com: Move setup of N_CPU node state mask]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Bob Picco <bob.picco@hp.com>
Cc: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Mel Gorman <mel@skynet.ie>
A node without memory does not need a kswapd. So use the memory map instead
of the online map when starting kswapd.
The current VM can get itself into trouble fairly easily on systems with a
small ZONE_HIGHMEM, which is common on i686 computers with 1GB of memory.
On one side, page_alloc() will allocate down to zone->pages_low, while on
the other side, kswapd() and balance_pgdat() will try to free memory from
every zone, until every zone has more free pages than zone->pages_high.
Highmem can be filled up to zone->pages_low with page tables, ramfs,
vmalloc allocations and other unswappable things quite easily and without
many bad side effects, since we still have a huge ZONE_NORMAL to do future
allocations from.
However, as long as the number of free pages in the highmem zone is below
zone->pages_high, kswapd will continue swapping things out from
ZONE_NORMAL, too!
Sami Farin managed to get his system into a stage where kswapd had freed
about 700MB of low memory and was still "going strong".
The attached patch will make kswapd stop paging out data from zones when
there is more than enough memory free. We do go above zone->pages_high in
order to keep pressure between zones equal in normal circumstances, but the
patch should prevent the kind of excesses that made Sami's computer totally
unusable.
contiguous areas
Lumpy reclaim works by selecting a lead page from the LRU list and then
selecting pages for reclaim from the order-aligned area of pages. In the
situation were all pages in that region are inactive and not referenced by any
process over time, it works well.
In the situation where there is even light load on the system, the pages may
not free quickly. Out of a area of 1024 pages, maybe only 950 of them are
freed when the allocation attempt occurs because lumpy reclaim returned early.
This patch alters the behaviour of direct reclaim for large contiguous
blocks.
The first attempt to call shrink_page_list() is asynchronous but if it fails,
the pages are submitted a second time and the calling process waits for the IO
to complete. This may stall allocators waiting for contiguous memory but that
should be expected behaviour for high-order users. It is preferable behaviour
to potentially queueing unnecessary areas for IO. Note that kswapd will not
stall in this fashion.
[apw@shadowen.org: update to version 2]
[apw@shadowen.org: update to version 3]
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
clear_active_flags
As pointed out by Mel when reclaim is applied at higher orders a significant
amount of IO may be started. As this takes finite time to drain reclaim will
consider more areas than ultimatly needed to satisfy the request. This leads
to more reclaim than strictly required and reduced success rates.
I was able to confirm Mel's test results on systems locally. These show that
even under light load the success rates drop off far more than expected.
Testing with a modified version of his patch (which follows) I was able to
allocate almost all of ZONE_MOVABLE with a near idle system. I ran 5 test
passes sequentially following system boot (the system has 29 hugepages in
ZONE_MOVABLE):
2.6.23-rc1 11 8 6 7 7
sync_lumpy 28 28 29 29 26
These show that although hugely better than the near 0% success normally
expected we can only allocate about a 1/4 of the zone. Using synchronous
reclaim for these allocations we get close to 100% as expected.
I have also run our standard high order tests and these show no regressions in
allocation success rates at rest, and some significant improvements under
load.
This patch:
We are transitioning pages from active to inactive in clear_active_flags,
those need counting as PGDEACTIVATE vm events.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Currently, the freezer treats all tasks as freezable, except for the kernel
threads that explicitly set the PF_NOFREEZE flag for themselves. This
approach is problematic, since it requires every kernel thread to either
set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't
care for the freezing of tasks at all.
It seems better to only require the kernel threads that want to or need to
be frozen to use some freezer-related code and to remove any
freezer-related code from the other (nonfreezable) kernel threads, which is
done in this patch.
The patch causes all kernel threads to be nonfreezable by default (ie. to
have PF_NOFREEZE set by default) and introduces the set_freezable()
function that should be called by the freezable kernel threads in order to
unset PF_NOFREEZE. It also makes all of the currently freezable kernel
threads call set_freezable(), so it shouldn't cause any (intentional)
change of behaviour to appear. Additionally, it updates documentation to
describe the freezing of tasks more accurately.
[akpm@linux-foundation.org: build fixes]
Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Gautham R Shenoy <ego@in.ibm.com>
I can never remember what the function to register to receive VM pressure
is called. I have to trace down from __alloc_pages() to find it.
It's called "set_shrinker()", and it needs Your Help.
1) Don't hide struct shrinker. It contains no magic.
2) Don't allocate "struct shrinker". It's not helpful.
3) Call them "register_shrinker" and "unregister_shrinker".
4) Call the function "shrink" not "shrinker".
5) Reduce the 17 lines of waffly comments to 13, but document it properly.
Cc: David Chinner <dgc@sgi.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
When we are out of memory of a suitable size we enter reclaim. The current
reclaim algorithm targets pages in LRU order, which is great for fairness at
order-0 but highly unsuitable if you desire pages at higher orders. To get
pages of higher order we must shoot down a very high proportion of memory;
>95% in a lot of cases.
This patch set adds a lumpy reclaim algorithm to the allocator. It targets
groups of pages at the specified order anchored at the end of the active and
inactive lists. This encourages groups of pages at the requested orders to
move from active to inactive, and active to free lists. This behaviour is
only triggered out of direct reclaim when higher order pages have been
requested.
This patch set is particularly effective when utilised with an
anti-fragmentation scheme which groups pages of similar reclaimability
together.
This patch set is based on Peter Zijlstra's lumpy reclaim V2 patch which forms
the foundation. Credit to Mel Gorman for sanitity checking.
Mel said:
The patches have an application with hugepage pool resizing.
When lumpy-reclaim is used used with ZONE_MOVABLE, the hugepages pool can
be resized with greater reliability. Testing on a desktop machine with 2GB
of RAM showed that growing the hugepage pool with ZONE_MOVABLE on it's own
was very slow as the success rate was quite low. Without lumpy-reclaim,
each attempt to grow the pool by 100 pages would yield 1 or 2 hugepages.
With lumpy-reclaim, getting 40 to 70 hugepages on each attempt was typical.
[akpm@osdl.org: ia64 pfn_to_nid fixes and loop cleanup]
[bunk@stusta.de: static declarations for internal functions]
[a.p.zijlstra@chello.nl: initial lumpy V2 implementation]
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Bob Picco <bob.picco@hp.com>
