[ Upstream commit e92bb4dd9673945179b1fc738c9817dd91bfb629 ]
When page_mapping() is called and the mapping is dereferenced in
page_evicatable() through shrink_active_list(), it is possible for the
inode to be truncated and the embedded address space to be freed at the
same time. This may lead to the following race.
CPU1 CPU2
truncate(inode) shrink_active_list()
... page_evictable(page)
truncate_inode_page(mapping, page);
delete_from_page_cache(page)
spin_lock_irqsave(&mapping->tree_lock, flags);
__delete_from_page_cache(page, NULL)
page_cache_tree_delete(..)
... mapping = page_mapping(page);
page->mapping = NULL;
spin_unlock_irqrestore(&mapping->tree_lock, flags);
page_cache_free_page(mapping, page)
put_page(page)
if (put_page_testzero(page)) -> false
- inode now has no pages and can be freed including embedded address_space
mapping_unevictable(mapping)
test_bit(AS_UNEVICTABLE, &mapping->flags);
- we've dereferenced mapping which is potentially already free.
Similar race exists between swap cache freeing and page_evicatable()
too.
The address_space in inode and swap cache will be freed after a RCU
grace period. So the races are fixed via enclosing the page_mapping()
and address_space usage in rcu_read_lock/unlock(). Some comments are
added in code to make it clear what is protected by the RCU read lock.
Link: http://lkml.kernel.org/r/20180212081227.1940-1-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Minchan Kim <minchan@kernel.org>
Cc: "Huang, Ying" <ying.huang@intel.com>
Cc: Michal Hocko <mhocko@suse.com>
[ Upstream commit 69d763fc6d3aee787a3e8c8c35092b4f4960fa5d ]
Minchan Kim asked the following question -- what locks protects
address_space destroying when race happens between inode trauncation and
__isolate_lru_page? Jan Kara clarified by describing the race as follows
CPU1 CPU2
truncate(inode) __isolate_lru_page()
put_page(page)
if (mapping && !mapping->a_ops->migratepage)
The race is theoretically possible but unlikely. Before the
delete_from_page_cache, truncate_cleanup_page is called so the page is
likely to be !PageDirty or PageWriteback which gets skipped by the only
caller that checks the mappping in __isolate_lru_page. Even if the race
occurs, a substantial amount of work has to happen during a tiny window
with no preemption but it could potentially be done using a virtual
machine to artifically slow one CPU or halt it during the critical
window.
This patch should eliminate the race with truncation by try-locking the
page before derefencing mapping and aborting if the lock was not
acquired. There was a suggestion from Huang Ying to use RCU as a
side-effect to prevent mapping being freed. However, I do not like the
solution as it's an unconventional means of preserving a mapping and
it's not a context where rcu_read_lock is obviously protecting rcu data.
Link: http://lkml.kernel.org/r/20180104102512.2qos3h5vqzeisrek@techsingularity.net
Fixes: c82449352854 ("mm: compaction: make isolate_lru_page() filter-aware again")
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Jan Kara <jack@suse.cz>
commit f2f43e566a02a3bdde0a65e6a2e88d707c212a29 upstream.
Clang and its -Wunsequenced emits a warning
mm/vmscan.c:2961:25: error: unsequenced modification and access to 'gfp_mask' [-Wunsequenced]
.gfp_mask = (gfp_mask = current_gfp_context(gfp_mask)),
While it is not clear to me whether the initialization code violates the
specification (6.7.8 par 19 (ISO/IEC 9899) looks like it disagrees) the
code is quite confusing and worth cleaning up anyway. Fix this by
reusing sc.gfp_mask rather than the updated input gfp_mask parameter.
Link: http://lkml.kernel.org/r/20170510154030.10720-1-nick.desaulniers@gmail.com
Signed-off-by: Nick Desaulniers <nick.desaulniers@gmail.com>
[natechancellor: Adjust context due to abscence of 7dea19f9ee63]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit d450abd81b081d45adb12f303a07dd44b15eb1bc ]
PF_MEMALLOC direct reclaimers get throttled on a node when the sum of
all free pages in each zone fall below half the min watermark. During
the summation, we want to exclude zones that don't have reclaimables.
Checking the same pgdat over and over again doesn't make sense.
Fixes: 599d0c954f91 ("mm, vmscan: move LRU lists to node")
Link: http://lkml.kernel.org/r/20170228214007.5621-3-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Jia He <hejianet@gmail.com>
commit bb422a738f6566f7439cd347d54e321e4fe92a9f upstream.
Syzbot caught an oops at unregister_shrinker() because combination of
commit 1d3d4437eae1bb29 ("vmscan: per-node deferred work") and fault
injection made register_shrinker() fail and the caller of
register_shrinker() did not check for failure.
[ 554.881422] FAULT_INJECTION: forcing a failure.
[ 554.881422] name failslab, interval 1, probability 0, space 0, times 0
[ 554.881438] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82
[ 554.881443] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
[ 554.881445] Call Trace:
[ 554.881459] dump_stack+0x194/0x257
[ 554.881474] ? arch_local_irq_restore+0x53/0x53
[ 554.881486] ? find_held_lock+0x35/0x1d0
[ 554.881507] should_fail+0x8c0/0xa40
[ 554.881522] ? fault_create_debugfs_attr+0x1f0/0x1f0
[ 554.881537] ? check_noncircular+0x20/0x20
[ 554.881546] ? find_next_zero_bit+0x2c/0x40
[ 554.881560] ? ida_get_new_above+0x421/0x9d0
[ 554.881577] ? find_held_lock+0x35/0x1d0
[ 554.881594] ? __lock_is_held+0xb6/0x140
[ 554.881628] ? check_same_owner+0x320/0x320
[ 554.881634] ? lock_downgrade+0x990/0x990
[ 554.881649] ? find_held_lock+0x35/0x1d0
[ 554.881672] should_failslab+0xec/0x120
[ 554.881684] __kmalloc+0x63/0x760
[ 554.881692] ? lock_downgrade+0x990/0x990
[ 554.881712] ? register_shrinker+0x10e/0x2d0
[ 554.881721] ? trace_event_raw_event_module_request+0x320/0x320
[ 554.881737] register_shrinker+0x10e/0x2d0
[ 554.881747] ? prepare_kswapd_sleep+0x1f0/0x1f0
[ 554.881755] ? _down_write_nest_lock+0x120/0x120
[ 554.881765] ? memcpy+0x45/0x50
[ 554.881785] sget_userns+0xbcd/0xe20
(...snipped...)
[ 554.898693] kasan: CONFIG_KASAN_INLINE enabled
[ 554.898724] kasan: GPF could be caused by NULL-ptr deref or user memory access
[ 554.898732] general protection fault: 0000 [#1] SMP KASAN
[ 554.898737] Dumping ftrace buffer:
[ 554.898741] (ftrace buffer empty)
[ 554.898743] Modules linked in:
[ 554.898752] CPU: 1 PID: 13231 Comm: syz-executor1 Not tainted 4.14.0-rc8+ #82
[ 554.898755] Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
[ 554.898760] task: ffff8801d1dbe5c0 task.stack: ffff8801c9e38000
[ 554.898772] RIP: 0010:__list_del_entry_valid+0x7e/0x150
[ 554.898775] RSP: 0018:ffff8801c9e3f108 EFLAGS: 00010246
[ 554.898780] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 554.898784] RDX: 0000000000000000 RSI: ffff8801c53c6f98 RDI: ffff8801c53c6fa0
[ 554.898788] RBP: ffff8801c9e3f120 R08: 1ffff100393c7d55 R09: 0000000000000004
[ 554.898791] R10: ffff8801c9e3ef70 R11: 0000000000000000 R12: 0000000000000000
[ 554.898795] R13: dffffc0000000000 R14: 1ffff100393c7e45 R15: ffff8801c53c6f98
[ 554.898800] FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
[ 554.898804] CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
[ 554.898807] CR2: 00000000dbc23000 CR3: 00000001c7269000 CR4: 00000000001406e0
[ 554.898813] DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000
[ 554.898816] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
[ 554.898818] Call Trace:
[ 554.898828] unregister_shrinker+0x79/0x300
[ 554.898837] ? perf_trace_mm_vmscan_writepage+0x750/0x750
[ 554.898844] ? down_write+0x87/0x120
[ 554.898851] ? deactivate_super+0x139/0x1b0
[ 554.898857] ? down_read+0x150/0x150
[ 554.898864] ? check_same_owner+0x320/0x320
[ 554.898875] deactivate_locked_super+0x64/0xd0
[ 554.898883] deactivate_super+0x141/0x1b0
Since allowing register_shrinker() callers to call unregister_shrinker()
when register_shrinker() failed can simplify error recovery path, this
patch makes unregister_shrinker() no-op when register_shrinker() failed.
Also, reset shrinker->nr_deferred in case unregister_shrinker() was
by error called twice.
Signed-off-by: Aliaksei Karaliou <akaraliou.dev@gmail.com>
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Glauber Costa <glauber@scylladb.com>
commit c73322d098e4b6f5f0f0fa1330bf57e218775539 upstream.
Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and
cleanups".
Jia reported a scenario in which the kswapd of a node indefinitely spins
at 100% CPU usage. We have seen similar cases at Facebook.
The kernel's current method of judging its ability to reclaim a node (or
whether to back off and sleep) is based on the amount of scanned pages
in proportion to the amount of reclaimable pages. In Jia's and our
scenarios, there are no reclaimable pages in the node, however, and the
condition for backing off is never met. Kswapd busyloops in an attempt
to restore the watermarks while having nothing to work with.
This series reworks the definition of an unreclaimable node based not on
scanning but on whether kswapd is able to actually reclaim pages in
MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria
the page allocator uses for giving up on direct reclaim and invoking the
OOM killer. If it cannot free any pages, kswapd will go to sleep and
leave further attempts to direct reclaim invocations, which will either
make progress and re-enable kswapd, or invoke the OOM killer.
Patch #1 fixes the immediate problem Jia reported, the remainder are
smaller fixlets, cleanups, and overall phasing out of the old method.
Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(),
and directly related to #5, but in itself not relevant to the series.
If the whole series is too ambitious for 4.11, I would consider the
first three patches fixes, the rest cleanups.
This patch (of 9):
Jia He reports a problem with kswapd spinning at 100% CPU when
requesting more hugepages than memory available in the system:
$ echo 4000 >/proc/sys/vm/nr_hugepages
top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01
Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers
KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3
At that time, there are no reclaimable pages left in the node, but as
kswapd fails to restore the high watermarks it refuses to go to sleep.
Kswapd needs to back away from nodes that fail to balance. Up until
commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of
nodes") kswapd had such a mechanism. It considered zones whose
theoretically reclaimable pages it had reclaimed six times over as
unreclaimable and backed away from them. This guard was erroneously
removed as the patch changed the definition of a balanced node.
However, simply restoring this code wouldn't help in the case reported
here: there *are* no reclaimable pages that could be scanned until the
threshold is met. Kswapd would stay awake anyway.
Introduce a new and much simpler way of backing off. If kswapd runs
through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single
page, make it back off from the node. This is the same number of shots
direct reclaim takes before declaring OOM. Kswapd will go to sleep on
that node until a direct reclaimer manages to reclaim some pages, thus
proving the node reclaimable again.
[hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count]
Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org
[shakeelb@google.com: fix condition for throttle_direct_reclaim]
Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com
Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reported-by: Jia He <hejianet@gmail.com>
Tested-by: Jia He <hejianet@gmail.com>
Cc: Dmitry Shmidt <dimitrysh@google.com>
commit 71ab6cfe88dcf9f6e6a65eb85cf2bda20a257682 upstream.
get_scan_count() considers the whole node LRU size when
- doing SCAN_FILE due to many page cache inactive pages
- calculating the number of pages to scan
In both cases this might lead to unexpected behavior especially on 32b
systems where we can expect lowmem memory pressure very often.
A large highmem zone can easily distort SCAN_FILE heuristic because
there might be only few file pages from the eligible zones on the node
lru and we would still enforce file lru scanning which can lead to
trashing while we could still scan anonymous pages.
The later use of lruvec_lru_size can be problematic as well. Especially
when there are not many pages from the eligible zones. We would have to
skip over many pages to find anything to reclaim but shrink_node_memcg
would only reduce the remaining number to scan by SWAP_CLUSTER_MAX at
maximum. Therefore we can end up going over a large LRU many times
without actually having chance to reclaim much if anything at all. The
closer we are out of memory on lowmem zone the worse the problem will
be.
Fix this by filtering out all the ineligible zones when calculating the
lru size for both paths and consider only sc->reclaim_idx zones.
The patch would need to be tweaked a bit to apply to 4.10 and older but
I will do that as soon as it hits the Linus tree in the next merge
window.
Link: http://lkml.kernel.org/r/20170117103702.28542-3-mhocko@kernel.org
Fixes: b2e18757f2c9 ("mm, vmscan: begin reclaiming pages on a per-node basis")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Tested-by: Trevor Cordes <trevor@tecnopolis.ca>
commit fd538803731e50367b7c59ce4ad3454426a3d671 upstream.
lruvec_lru_size returns the full size of the LRU list while we sometimes
need a value reduced only to eligible zones (e.g. for lowmem requests).
inactive_list_is_low is one such user. Later patches will add more of
them. Add a new parameter to lruvec_lru_size and allow it filter out
zones which are not eligible for the given context.
Link: http://lkml.kernel.org/r/20170117103702.28542-2-mhocko@kernel.org
commit b4536f0c829c8586544c94735c343f9b5070bd01 upstream.
Nils Holland and Klaus Ethgen have reported unexpected OOM killer
invocations with 32b kernel starting with 4.8 kernels
kworker/u4:5 invoked oom-killer: gfp_mask=0x2400840(GFP_NOFS|__GFP_NOFAIL), nodemask=0, order=0, oom_score_adj=0
kworker/u4:5 cpuset=/ mems_allowed=0
CPU: 1 PID: 2603 Comm: kworker/u4:5 Not tainted 4.9.0-gentoo #2
Mem-Info:
active_anon:58685 inactive_anon:90 isolated_anon:0
active_file:274324 inactive_file:281962 isolated_file:0
unevictable:0 dirty:649 writeback:0 unstable:0
slab_reclaimable:40662 slab_unreclaimable:17754
mapped:7382 shmem:202 pagetables:351 bounce:0
free:206736 free_pcp:332 free_cma:0
Node 0 active_anon:234740kB inactive_anon:360kB active_file:1097296kB inactive_file:1127848kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:29528kB dirty:2596kB writeback:0kB shmem:0kB shmem_thp: 0kB shmem_pmdmapped: 184320kB anon_thp: 808kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no
DMA free:3952kB min:788kB low:984kB high:1180kB active_anon:0kB inactive_anon:0kB active_file:7316kB inactive_file:0kB unevictable:0kB writepending:96kB present:15992kB managed:15916kB mlocked:0kB slab_reclaimable:3200kB slab_unreclaimable:1408kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 813 3474 3474
Normal free:41332kB min:41368kB low:51708kB high:62048kB active_anon:0kB inactive_anon:0kB active_file:532748kB inactive_file:44kB unevictable:0kB writepending:24kB present:897016kB managed:836248kB mlocked:0kB slab_reclaimable:159448kB slab_unreclaimable:69608kB kernel_stack:1112kB pagetables:1404kB bounce:0kB free_pcp:528kB local_pcp:340kB free_cma:0kB
lowmem_reserve[]: 0 0 21292 21292
HighMem free:781660kB min:512kB low:34356kB high:68200kB active_anon:234740kB inactive_anon:360kB active_file:557232kB inactive_file:1127804kB unevictable:0kB writepending:2592kB present:2725384kB managed:2725384kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:800kB local_pcp:608kB free_cma:0kB
the oom killer is clearly pre-mature because there there is still a lot
of page cache in the zone Normal which should satisfy this lowmem
request. Further debugging has shown that the reclaim cannot make any
forward progress because the page cache is hidden in the active list
which doesn't get rotated because inactive_list_is_low is not memcg
aware.
The code simply subtracts per-zone highmem counters from the respective
memcg's lru sizes which doesn't make any sense. We can simply end up
always seeing the resulting active and inactive counts 0 and return
false. This issue is not limited to 32b kernels but in practice the
effect on systems without CONFIG_HIGHMEM would be much harder to notice
because we do not invoke the OOM killer for allocations requests
targeting < ZONE_NORMAL.
Fix the issue by tracking per zone lru page counts in mem_cgroup_per_node
and subtract per-memcg highmem counts when memcg is enabled. Introduce
helper lruvec_zone_lru_size which redirects to either zone counters or
mem_cgroup_get_zone_lru_size when appropriate.
We are losing empty LRU but non-zero lru size detection introduced by
ca707239e8a7 ("mm: update_lru_size warn and reset bad lru_size") because
of the inherent zone vs. node discrepancy.
Fixes: f8d1a31163fc ("mm: consider whether to decivate based on eligible zones inactive ratio")
Link: http://lkml.kernel.org/r/20170104100825.3729-1-mhocko@kernel.org
Reported-by: Nils Holland <nholland@tisys.org>
Tested-by: Nils Holland <nholland@tisys.org>
Reported-by: Klaus Ethgen <Klaus@Ethgen.de>
Reviewed-by: Vladimir Davydov <vdavydov.dev@gmail.com>
commit 5f33a0803bbd781de916f5c7448cbbbbc763d911 upstream.
Our system uses significantly more slab memory with memcg enabled with
the latest kernel. With 3.10 kernel, slab uses 2G memory, while with
4.6 kernel, 6G memory is used. The shrinker has problem. Let's see we
have two memcg for one shrinker. In do_shrink_slab:
1. Check cg1. nr_deferred = 0, assume total_scan = 700. batch size
is 1024, then no memory is freed. nr_deferred = 700
2. Check cg2. nr_deferred = 700. Assume freeable = 20, then
total_scan = 10 or 40. Let's assume it's 10. No memory is freed.
nr_deferred = 10.
The deferred share of cg1 is lost in this case. kswapd will free no
memory even run above steps again and again.
The fix makes sure one memcg's deferred share isn't lost.
Link: http://lkml.kernel.org/r/2414be961b5d25892060315fbb56bb19d81d0c07.1476227351.git.shli@fb.com
Signed-off-by: Shaohua Li <shli@fb.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Boris Zhmurov has reported RCU stalls during the kswapd reclaim:
INFO: rcu_sched detected stalls on CPUs/tasks:
23-...: (22 ticks this GP) idle=92f/140000000000000/0 softirq=2638404/2638404 fqs=23
(detected by 4, t=6389 jiffies, g=786259, c=786258, q=42115)
Task dump for CPU 23:
kswapd1 R running task 0 148 2 0x00000008
Call Trace:
shrink_node+0xd2/0x2f0
kswapd+0x2cb/0x6a0
mem_cgroup_shrink_node+0x160/0x160
kthread+0xbd/0xe0
__switch_to+0x1fa/0x5c0
ret_from_fork+0x1f/0x40
kthread_create_on_node+0x180/0x180
a closer code inspection has shown that we might indeed miss all the
scheduling points in the reclaim path if no pages can be isolated from
the LRU list. This is a pathological case but other reports from Donald
Buczek have shown that we might indeed hit such a path:
clusterd-989 [009] .... 118023.654491: mm_vmscan_direct_reclaim_end: nr_reclaimed=193
kswapd1-86 [001] dN.. 118023.987475: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239830 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.320968: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239844 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.654375: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239858 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.987036: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239872 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.319651: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239886 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.652248: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239900 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.984870: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239914 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118084.274403: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4241133 nr_taken=0 file=1
this is minute long snapshot which didn't take a single page from the
LRU. It is not entirely clear why only 1303 pages have been scanned
during that time (maybe there was a heavy IRQ activity interfering).
In any case it looks like we can really hit long periods without
scheduling on non preemptive kernels so an explicit cond_resched() in
shrink_node_memcg which is independent on the reclaim operation is due.
Link: http://lkml.kernel.org/r/20161202095841.16648-1-mhocko@kernel.org
Reported-by: Boris Zhmurov <bb@kernelpanic.ru>
Tested-by: Boris Zhmurov <bb@kernelpanic.ru>
Reported-by: Donald Buczek <buczek@molgen.mpg.de>
Reported-by: "Christopher S. Aker" <caker@theshore.net>
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
On 4.0, we saw a stack corruption from a page fault entering direct
memory cgroup reclaim, calling into btrfs_releasepage(), which then
tried to allocate an extent and recursed back into a kmem charge ad
nauseam:
btrfs_releasepage+0x2c/0x30
try_to_release_page+0x32/0x50
shrink_page_list+0x6da/0x7a0
shrink_inactive_list+0x1e5/0x510
shrink_lruvec+0x605/0x7f0
shrink_zone+0xee/0x320
do_try_to_free_pages+0x174/0x440
try_to_free_mem_cgroup_pages+0xa7/0x130
try_charge+0x17b/0x830
memcg_charge_kmem+0x40/0x80
new_slab+0x2d9/0x5a0
__slab_alloc+0x2fd/0x44f
kmem_cache_alloc+0x193/0x1e0
alloc_extent_state+0x21/0xc0
__clear_extent_bit+0x2b5/0x400
try_release_extent_mapping+0x1a3/0x220
__btrfs_releasepage+0x31/0x70
mem_cgroup_try_charge+0x65/0x1c0
handle_mm_fault+0x117f/0x1510
__do_page_fault+0x177/0x420
do_page_fault+0xc/0x10
page_fault+0x22/0x30
On later kernels, kmem charging is opt-in rather than opt-out, and that
particular kmem allocation in btrfs_releasepage() is no longer being
charged and won't recurse and overrun the stack anymore.
But it's not impossible for an accounted allocation to happen from the
memcg direct reclaim context, and we needed to reproduce this crash many
times before we even got a useful stack trace out of it.
Like other direct reclaimers, mark tasks in memcg reclaim PF_MEMALLOC to
avoid recursing into any other form of direct reclaim. Then let
recursive charges from PF_MEMALLOC contexts bypass the cgroup limit.
Link: http://lkml.kernel.org/r/20161025141050.GA13019@cmpxchg.org
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org>
Use the existing enums instead of hardcoded index when looking at the
zonelist. This makes it more readable. No functionality change by this
patch.
Link: http://lkml.kernel.org/r/1472227078-24852-1-git-send-email-aneesh.kumar@linux.vnet.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
throttle_vm_writeout() was introduced back in 2005 to fix OOMs caused by
excessive pageout activity during the reclaim. Too many pages could be
put under writeback therefore LRUs would be full of unreclaimable pages
until the IO completes and in turn the OOM killer could be invoked.
There have been some important changes introduced since then in the
reclaim path though. Writers are throttled by balance_dirty_pages when
initiating the buffered IO and later during the memory pressure, the
direct reclaim is throttled by wait_iff_congested if the node is
considered congested by dirty pages on LRUs and the underlying bdi is
congested by the queued IO. The kswapd is throttled as well if it
encounters pages marked for immediate reclaim or under writeback which
signals that that there are too many pages under writeback already.
Finally should_reclaim_retry does congestion_wait if the reclaim cannot
make any progress and there are too many dirty/writeback pages.
Another important aspect is that we do not issue any IO from the direct
reclaim context anymore. In a heavy parallel load this could queue a
lot of IO which would be very scattered and thus unefficient which would
just make the problem worse.
This three mechanisms should throttle and keep the amount of IO in a
steady state even under heavy IO and memory pressure so yet another
throttling point doesn't really seem helpful. Quite contrary, Mikulas
Patocka has reported that swap backed by dm-crypt doesn't work properly
because the swapout IO cannot make sufficient progress as the writeout
path depends on dm_crypt worker which has to allocate memory to perform
the encryption. In order to guarantee a forward progress it relies on
the mempool allocator. mempool_alloc(), however, prefers to use the
underlying (usually page) allocator before it grabs objects from the
pool. Such an allocation can dive into the memory reclaim and
consequently to throttle_vm_writeout. If there are too many dirty or
pages under writeback it will get throttled even though it is in fact a
flusher to clear pending pages.
kworker/u4:0 D ffff88003df7f438 10488 6 2 0x00000000
Workqueue: kcryptd kcryptd_crypt [dm_crypt]
Call Trace:
schedule+0x3c/0x90
schedule_timeout+0x1d8/0x360
io_schedule_timeout+0xa4/0x110
congestion_wait+0x86/0x1f0
throttle_vm_writeout+0x44/0xd0
shrink_zone_memcg+0x613/0x720
shrink_zone+0xe0/0x300
do_try_to_free_pages+0x1ad/0x450
try_to_free_pages+0xef/0x300
__alloc_pages_nodemask+0x879/0x1210
alloc_pages_current+0xa1/0x1f0
new_slab+0x2d7/0x6a0
___slab_alloc+0x3fb/0x5c0
__slab_alloc+0x51/0x90
kmem_cache_alloc+0x27b/0x310
mempool_alloc_slab+0x1d/0x30
mempool_alloc+0x91/0x230
bio_alloc_bioset+0xbd/0x260
kcryptd_crypt+0x114/0x3b0 [dm_crypt]
Let's just drop throttle_vm_writeout altogether. It is not very much
helpful anymore.
I have tried to test a potential writeback IO runaway similar to the one
described in the original patch which has introduced that [1]. Small
virtual machine (512MB RAM, 4 CPUs, 2G of swap space and disk image on a
rather slow NFS in a sync mode on the host) with 8 parallel writers each
writing 1G worth of data. As soon as the pagecache fills up and the
direct reclaim hits then I start anon memory consumer in a loop
(allocating 300M and exiting after populating it) in the background to
make the memory pressure even stronger as well as to disrupt the steady
state for the IO. The direct reclaim is throttled because of the
congestion as well as kswapd hitting congestion_wait due to nr_immediate
but throttle_vm_writeout doesn't ever trigger the sleep throughout the
test. Dirty+writeback are close to nr_dirty_threshold with some
fluctuations caused by the anon consumer.
[1] https://www2.kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.9-rc1/2.6.9-rc1-mm3/broken-out/vm-pageout-throttling.patch
Link: http://lkml.kernel.org/r/1471171473-21418-1-git-send-email-mhocko@kernel.org
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: NeilBrown <neilb@suse.com>
Cc: Ondrej Kozina <okozina@redhat.com>
The compaction_ready() is used during direct reclaim for costly order
allocations to skip reclaim for zones where compaction should be
attempted instead. It's combining the standard compaction_suitable()
check with its own watermark check based on high watermark with extra
gap, and the result is confusing at best.
This patch attempts to better structure and document the checks
involved. First, compaction_suitable() can determine that the
allocation should either succeed already, or that compaction doesn't
have enough free pages to proceed. The third possibility is that
compaction has enough free pages, but we still decide to reclaim first -
unless we are already above the high watermark with gap. This does not
mean that the reclaim will actually reach this watermark during single
attempt, this is rather an over-reclaim protection. So document the
code as such. The check for compaction_deferred() is removed
completely, as it in fact had no proper role here.
The result after this patch is mainly a less confusing code. We also
skip some over-reclaim in cases where the allocation should already
succed.
Link: http://lkml.kernel.org/r/20160810091226.6709-12-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Tested-by: Lorenzo Stoakes <lstoakes@gmail.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Compaction uses a watermark gap of (2UL << order) pages at various
places and it's not immediately obvious why. Abstract it through a
compact_gap() wrapper to create a single place with a thorough
explanation.
[vbabka@suse.cz: clarify the comment of compact_gap()]
Link: http://lkml.kernel.org/r/7b6aed1f-fdf8-2063-9ff4-bbe4de712d37@suse.cz
Link: http://lkml.kernel.org/r/20160810091226.6709-9-vbabka@suse.cz
COMPACT_PARTIAL has historically meant that compaction returned after
doing some work without fully compacting a zone. It however didn't
distinguish if compaction terminated because it succeeded in creating
the requested high-order page. This has changed recently and now we
only return COMPACT_PARTIAL when compaction thinks it succeeded, or the
high-order watermark check in compaction_suitable() passes and no
compaction needs to be done.
So at this point we can make the return value clearer by renaming it to
COMPACT_SUCCESS. The next patch will remove some redundant tests for
success where compaction just returned COMPACT_SUCCESS.
Link: http://lkml.kernel.org/r/20160810091226.6709-4-vbabka@suse.cz
init_tlb_ubc() looked unnecessary to me: tlb_ubc is statically
initialized with zeroes in the init_task, and copied from parent to
child while it is quiescent in arch_dup_task_struct(); so I went to
delete it.
But inserted temporary debug WARN_ONs in place of init_tlb_ubc() to
check that it was always empty at that point, and found them firing:
because memcg reclaim can recurse into global reclaim (when allocating
biosets for swapout in my case), and arrive back at the init_tlb_ubc()
in shrink_node_memcg().
Resetting tlb_ubc.flush_required at that point is wrong: if the upper
level needs a deferred TLB flush, but the lower level turns out not to,
we miss a TLB flush. But fortunately, that's the only part of the
protocol that does not nest: with the initialization removed, cpumask
collects bits from upper and lower levels, and flushes TLB when needed.
Fixes: 72b252aed506 ("mm: send one IPI per CPU to TLB flush all entries after unmapping pages")
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: stable@vger.kernel.org # 4.3+
buddy allocator
Firmware Assisted Dump (FA_DUMP) on ppc64 reserves substantial amounts
of memory when booting a secondary kernel. Srikar Dronamraju reported
that multiple nodes may have no memory managed by the buddy allocator
but still return true for populated_zone().
Commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of
nodes") was reported to cause kswapd to spin at 100% CPU usage when
fadump was enabled. The old code happened to deal with the situation of
a populated node with zero free pages by co-incidence but the current
code tries to reclaim populated zones without realising that is
impossible.
We cannot just convert populated_zone() as many existing users really
need to check for present_pages. This patch introduces a managed_zone()
helper and uses it in the few cases where it is critical that the check
is made for managed pages -- zonelist construction and page reclaim.
Link: http://lkml.kernel.org/r/20160831195104.GB8119@techsingularity.net
Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
We must call shrink_slab() for each memory cgroup on both global and
memcg reclaim in shrink_node_memcg(). Commit d71df22b55099 accidentally
changed that so that now shrink_slab() is only called with memcg != NULL
on memcg reclaim. As a result, memcg-aware shrinkers (including
dentry/inode) are never invoked on global reclaim. Fix that.
Link: http://lkml.kernel.org/r/1470056590-7177-1-git-send-email-vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Rik van Riel <riel@surriel.com>
With node-lru, if there are enough reclaimable pages in highmem but
nothing in lowmem, VM can try to shrink inactive list although the
requested zone is lowmem.
The problem is that if the inactive list is full of highmem pages then a
direct reclaimer searching for a lowmem page waste CPU scanning
uselessly. It just burns out CPU. Even, many direct reclaimers are
stalled by too_many_isolated if lots of parallel reclaimer are going on
although there are no reclaimable memory in inactive list.
I tried the experiment 4 times in 32bit 2G 8 CPU KVM machine to get
elapsed time.
hackbench 500 process 2
= Old =
1st: 289s 2nd: 310s 3rd: 112s 4th: 272s
= Now =
1st: 31s 2nd: 132s 3rd: 162s 4th: 50s.
[akpm@linux-foundation.org: fixes per Mel]
Link: http://lkml.kernel.org/r/1469433119-1543-1-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Page reclaim determines whether a pgdat is unreclaimable by examining
how many pages have been scanned since a page was freed and comparing
that to the LRU sizes. Skipped pages are not reclaim candidates but
contribute to scanned. This can prematurely mark a pgdat as
unreclaimable and trigger an OOM kill.
This patch accounts for skipped pages as a partial scan so that an
unreclaimable pgdat will still be marked as such but by scaling the cost
of a skip, it'll avoid the pgdat being marked prematurely.
Link: http://lkml.kernel.org/r/1469110261-7365-6-git-send-email-mgorman@techsingularity.net
Minchan Kim reported that with per-zone lru state it was possible to
identify that a normal zone with 8^M anonymous pages could trigger OOM
with non-atomic order-0 allocations as all pages in the zone were in the
active list.
gfp_mask=0x26004c0(GFP_KERNEL|__GFP_REPEAT|__GFP_NOTRACK), order=0
Call Trace:
__alloc_pages_nodemask+0xe52/0xe60
? new_slab+0x39c/0x3b0
___slab_alloc.constprop.87+0x6da/0x840
? __alloc_skb+0x3c/0x260
? enqueue_task_fair+0x73/0xbf0
? poll_select_copy_remaining+0x140/0x140
__slab_alloc.isra.81.constprop.86+0x40/0x6d
kmem_cache_alloc+0x22c/0x260
alloc_skb_with_frags+0x4e/0x1a0
sock_alloc_send_pskb+0x16a/0x1b0
? wait_for_unix_gc+0x31/0x90
unix_stream_sendmsg+0x28d/0x340
sock_sendmsg+0x2d/0x40
sock_write_iter+0x6c/0xc0
__vfs_write+0xc0/0x120
vfs_write+0x9b/0x1a0
? __might_fault+0x49/0xa0
SyS_write+0x44/0x90
do_fast_syscall_32+0xa6/0x1e0
Mem-Info:
active_anon:101103 inactive_anon:102219 isolated_anon:0
active_file:503 inactive_file:544 isolated_file:0
unevictable:0 dirty:0 writeback:34 unstable:0
slab_reclaimable:6298 slab_unreclaimable:74669
mapped:863 shmem:0 pagetables:100998 bounce:0
free:23573 free_pcp:1861 free_cma:0
Node 0 active_anon:404412kB inactive_anon:409040kB active_file:2012kB inactive_file:2176kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:3452kB dirty:0kB writeback:136kB shmem:0kB writeback_tmp:0kB unstable:0kB pages_scanned:1320845 all_unreclaimable? yes
DMA free:3296kB min:68kB low:84kB high:100kB active_anon:5540kB inactive_anon:0kB active_file:0kB inactive_file:0kB present:15992kB managed:15916kB mlocked:0kB slab_reclaimable:248kB slab_unreclaimable:2628kB kernel_stack:792kB pagetables:2316kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 809 1965 1965
Normal free:3600kB min:3604kB low:4504kB high:5404kB active_anon:86304kB inactive_anon:0kB active_file:160kB inactive_file:376kB present:897016kB managed:858524kB mlocked:0kB slab_reclaimable:24944kB slab_unreclaimable:296048kB kernel_stack:163832kB pagetables:35892kB bounce:0kB free_pcp:3076kB local_pcp:656kB free_cma:0kB
lowmem_reserve[]: 0 0 9247 9247
HighMem free:86156kB min:512kB low:1796kB high:3080kB active_anon:312852kB inactive_anon:410024kB active_file:1924kB inactive_file:2012kB present:1183736kB managed:1183736kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:365784kB bounce:0kB free_pcp:3868kB local_pcp:720kB free_cma:0kB
lowmem_reserve[]: 0 0 0 0
DMA: 8*4kB (UM) 8*8kB (UM) 4*16kB (M) 2*32kB (UM) 2*64kB (UM) 1*128kB (M) 3*256kB (UME) 2*512kB (UE) 1*1024kB (E) 0*2048kB 0*4096kB = 3296kB
Normal: 240*4kB (UME) 160*8kB (UME) 23*16kB (ME) 3*32kB (UE) 3*64kB (UME) 2*128kB (ME) 1*256kB (U) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3408kB
HighMem: 10942*4kB (UM) 3102*8kB (UM) 866*16kB (UM) 76*32kB (UM) 11*64kB (UM) 4*128kB (UM) 1*256kB (M) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 86344kB
Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
54409 total pagecache pages
53215 pages in swap cache
Swap cache stats: add 300982, delete 247765, find 157978/226539
Free swap = 3803244kB
Total swap = 4192252kB
524186 pages RAM
295934 pages HighMem/MovableOnly
9642 pages reserved
0 pages cma reserved
The problem is due to the active deactivation logic in
inactive_list_is_low:
IOW, (inactive_anon of node * inactive_ratio > active_anon of node) due
to highmem anonymous stat so VM never deactivates normal zone's
anonymous pages.
This patch is a modified version of Minchan's original solution but
based upon it. The problem with Minchan's patch is that any low zone
with an imbalanced list could force a rotation.
In this patch, a zone-constrained global reclaim will rotate the list if
the inactive/active ratio of all eligible zones needs to be corrected.
It is possible that higher zone pages will be initially rotated
prematurely but this is the safer choice to maintain overall LRU age.
Link: http://lkml.kernel.org/r/20160722090929.GJ10438@techsingularity.net
If per-zone LRU accounting is available then there is no point
approximating whether reclaim and compaction should retry based on pgdat
statistics. This is effectively a revert of "mm, vmstat: remove zone
and node double accounting by approximating retries" with the difference
that inactive/active stats are still available. This preserves the
history of why the approximation was retried and why it had to be
reverted to handle OOM kills on 32-bit systems.
Link: http://lkml.kernel.org/r/1469110261-7365-4-git-send-email-mgorman@techsingularity.net
When I did stress test with hackbench, I got OOM message frequently
which didn't ever happen in zone-lru.
? _raw_spin_unlock_irq+0x27/0x60
? trace_hardirqs_on_caller+0xec/0x1b0
? finish_task_switch+0xa6/0x220
? alloc_set_pte+0x2ad/0x310
SyS_write+0x44/0x90
sysenter_past_esp+0x45/0x74
Mem-Info:
active_anon:104698 inactive_anon:105791 isolated_anon:192
active_file:433 inactive_file:283 isolated_file:22
unevictable:0 dirty:0 writeback:296 unstable:0
slab_reclaimable:6389 slab_unreclaimable:78927
mapped:474 shmem:0 pagetables:101426 bounce:0
free:10518 free_pcp:334 free_cma:0
Node 0 active_anon:418792kB inactive_anon:423164kB active_file:1732kB inactive_file:1132kB unevictable:0kB isolated(anon):768kB isolated(file):88kB mapped:1896kB dirty:0kB writeback:1184kB shmem:0kB writeback_tmp:0kB unstable:0kB pages_scanned:1478632 all_unreclaimable? yes
DMA free:3304kB min:68kB low:84kB high:100kB present:15992kB managed:15916kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:4088kB kernel_stack:0kB pagetables:2480kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Normal free:3436kB min:3604kB low:4504kB high:5404kB present:897016kB managed:858460kB mlocked:0kB slab_reclaimable:25556kB slab_unreclaimable:311712kB kernel_stack:164608kB pagetables:30844kB bounce:0kB free_pcp:620kB local_pcp:104kB free_cma:0kB
HighMem free:33808kB min:512kB low:1796kB high:3080kB present:1183736kB managed:1183736kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:372252kB bounce:0kB free_pcp:428kB local_pcp:72kB free_cma:0kB
DMA: 2*4kB (UM) 2*8kB (UM) 0*16kB 1*32kB (U) 1*64kB (U) 2*128kB (UM) 1*256kB (U) 1*512kB (M) 0*1024kB 1*2048kB (U) 0*4096kB = 3192kB
Normal: 33*4kB (MH) 79*8kB (ME) 11*16kB (M) 4*32kB (M) 2*64kB (ME) 2*128kB (EH) 7*256kB (EH) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3244kB
HighMem: 2590*4kB (UM) 1568*8kB (UM) 491*16kB (UM) 60*32kB (UM) 6*64kB (M) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 33064kB
25121 total pagecache pages
24160 pages in swap cache
Swap cache stats: add 86371, delete 62211, find 42865/60187
Free swap = 4015560kB
524186 pages RAM
9658 pages reserved
The order-0 allocation for normal zone failed while there are a lot of
reclaimable memory(i.e., anonymous memory with free swap). I wanted to
analyze the problem but it was hard because we removed per-zone lru stat
so I couldn't know how many of anonymous memory there are in normal/dma
zone.
When we investigate OOM problem, reclaimable memory count is crucial
stat to find a problem. Without it, it's hard to parse the OOM message
so I believe we should keep it.
With per-zone lru stat,
Mem-Info:
524186 pages RAM
9642 pages reserved
With that, we can see normal zone has a 86M reclaimable memory so we can
know something goes wrong(I will fix the problem in next patch) in
reclaim.
[mgorman@techsingularity.net: rename zone LRU stats in /proc/vmstat]
Link: http://lkml.kernel.org/r/20160725072300.GK10438@techsingularity.net
Link: http://lkml.kernel.org/r/1469110261-7365-2-git-send-email-mgorman@techsingularity.net
With node-lru, the locking is based on the pgdat. As Minchan pointed
out, there is an opportunity to reduce LRU lock release/acquire in
check_move_unevictable_pages by only changing lock on a pgdat change.
[mgorman@techsingularity.net: remove double initialisation]
Link: http://lkml.kernel.org/r/20160719074835.GC10438@techsingularity.net
Link: http://lkml.kernel.org/r/1468853426-12858-3-git-send-email-mgorman@techsingularity.net
As pointed out by Minchan Kim, shrink_zones() checks for populated zones
in a zonelist but a zonelist can never contain unpopulated zones. While
it's not related to the node-lru series, it can be cleaned up now.
Link: http://lkml.kernel.org/r/1468853426-12858-2-git-send-email-mgorman@techsingularity.net
Suggested-by: Minchan Kim <minchan@kernel.org>
Minchan Kim reported setting the following warning on a 32-bit system
although it can affect 64-bit systems.
WARNING: CPU: 4 PID: 1322 at mm/memcontrol.c:998 mem_cgroup_update_lru_size+0x103/0x110
mem_cgroup_update_lru_size(f44b4000, 1, -7): zid 1 lru_size 1 but empty
Modules linked in:
CPU: 4 PID: 1322 Comm: cp Not tainted 4.7.0-rc4-mm1+ #143
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x76/0xaf
__warn+0xea/0x110
? mem_cgroup_update_lru_size+0x103/0x110
warn_slowpath_fmt+0x3b/0x40
isolate_lru_pages.isra.61+0x2e2/0x360
shrink_active_list+0xac/0x2a0
? __delay+0xe/0x10
shrink_node_memcg+0x53c/0x7a0
shrink_node+0xab/0x2a0
do_try_to_free_pages+0xc6/0x390
try_to_free_pages+0x245/0x590
LRU list contents and counts are updated separately. Counts are updated
before pages are added to the LRU and updated after pages are removed.
The warning above is from a check in mem_cgroup_update_lru_size that
ensures that list sizes of zero are empty.
The problem is that node-lru needs to account for highmem pages if
CONFIG_HIGHMEM is set. One impact of the implementation is that the
sizes are updated in multiple passes when pages from multiple zones were
isolated. This happens whether HIGHMEM is set or not. When multiple
zones are isolated, it's possible for a debugging check in memcg to be
tripped.
This patch forces all the zone counts to be updated before the memcg
function is called.
Link: http://lkml.kernel.org/r/1468588165-12461-6-git-send-email-mgorman@techsingularity.net
Tested-by: Minchan Kim <minchan@kernel.org>
Reported-by: Minchan Kim <minchan@kernel.org>
The number of LRU pages, dirty pages and writeback pages must be
accounted for on both zones and nodes because of the reclaim retry
logic, compaction retry logic and highmem calculations all depending on
per-zone stats.
Many lowmem allocations are immune from OOM kill due to a check in
__alloc_pages_may_oom for (ac->high_zoneidx < ZONE_NORMAL) since commit
03668b3ceb0c ("oom: avoid oom killer for lowmem allocations"). The
exception is costly high-order allocations or allocations that cannot
fail. If the __alloc_pages_may_oom avoids OOM-kill for low-order lowmem
allocations then it would fall through to __alloc_pages_direct_compact.
This patch will blindly retry reclaim for zone-constrained allocations
in should_reclaim_retry up to MAX_RECLAIM_RETRIES. This is not ideal
but without per-zone stats there are not many alternatives. The impact
it that zone-constrained allocations may delay before considering the
OOM killer.
As there is no guarantee enough memory can ever be freed to satisfy
compaction, this patch avoids retrying compaction for zone-contrained
allocations.
In combination, that means that the per-node stats can be used when
deciding whether to continue reclaim using a rough approximation. While
it is possible this will make the wrong decision on occasion, it will
not infinite loop as the number of reclaim attempts is capped by
The final step is calculating the number of dirtyable highmem pages. As
those calculations only care about the global count of file pages in
highmem. This patch uses a global counter used instead of per-zone
stats as it is sufficient.
In combination, this allows the per-zone LRU and dirty state counters to
be removed.
[mgorman@techsingularity.net: fix acct_highmem_file_pages()]
Link: http://lkml.kernel.org/r/1468853426-12858-4-git-send-email-mgorman@techsingularity.netLink: http://lkml.kernel.org/r/1467970510-21195-35-git-send-email-mgorman@techsingularity.net
Suggested by: Michal Hocko <mhocko@kernel.org>
The vmstat allocstall was fairly useful in the general sense but
node-based LRUs change that. It's important to know if a stall was for
an address-limited allocation request as this will require skipping
pages from other zones. This patch adds pgstall_* counters to replace
allocstall. The sum of the counters will equal the old allocstall so it
can be trivially recalculated. A high number of address-limited
allocation requests may result in a lot of useless LRU scanning for
suitable pages.
As address-limited allocations require pages to be skipped, it's
important to know how much useless LRU scanning took place so this patch
adds pgskip* counters. This yields the following model
1. The number of address-space limited stalls can be accounted for (pgstall)
2. The amount of useless work required to reclaim the data is accounted (pgskip)
3. The total number of scans is available from pgscan_kswapd and pgscan_direct
so from that the ratio of useful to useless scans can be calculated.
[mgorman@techsingularity.net: s/pgstall/allocstall/]
Link: http://lkml.kernel.org/r/1468404004-5085-3-git-send-email-mgorman@techsingularity.netLink: http://lkml.kernel.org/r/1467970510-21195-33-git-send-email-mgorman@techsingularity.net
Acked-by: Vlastimil Babka <vbabka@suse.cz>
This is convenient when tracking down why the skip count is high because
it'll show what classzone kswapd woke up at and what zones are being
isolated.
Link: http://lkml.kernel.org/r/1467970510-21195-29-git-send-email-mgorman@techsingularity.net
buffer_heads_over_limit
The buffer_heads_over_limit limit in kswapd is inconsistent with direct
reclaim behaviour. It may force an an attempt to reclaim from all zones
and then not reclaim at all because higher zones were balanced than
required by the original request.
This patch will causes kswapd to consider reclaiming from all zones if
buffer_heads_over_limit. However, if there are eligible zones for the
allocation request that woke kswapd then no reclaim will occur even if
buffer_heads_over_limit. This avoids kswapd over-reclaiming just
because buffer_heads_over_limit.
[mgorman@techsingularity.net: fix comment about buffer_heads_over_limit]
Link: http://lkml.kernel.org/r/1468404004-5085-2-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-28-git-send-email-mgorman@techsingularity.net
As pointed out by Minchan Kim, the first call to prepare_kswapd_sleep()
always passes in 0 for `remaining' and the second call can trivially
check the parameter in advance.
Link: http://lkml.kernel.org/r/1467970510-21195-27-git-send-email-mgorman@techsingularity.net
The scan_control structure has enough information available for
compaction_ready() to make a decision. The classzone_idx manipulations
in shrink_zones() are no longer necessary as the highest populated zone
is no longer used to determine if shrink_slab should be called or not.
[mgorman@techsingularity.net remove redundant check in shrink_zones()]
Link: http://lkml.kernel.org/r/1468588165-12461-3-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-26-git-send-email-mgorman@techsingularity.net
shrink_node receives all information it needs about classzone_idx from
sc->reclaim_idx so remove the aliases.
Link: http://lkml.kernel.org/r/1467970510-21195-25-git-send-email-mgorman@techsingularity.net
As reclaim is now per-node based, convert zone_reclaim to be
node_reclaim. It is possible that a node will be reclaimed multiple
times if it has multiple zones but this is unavoidable without caching
all nodes traversed so far. The documentation and interface to
userspace is the same from a configuration perspective and will will be
similar in behaviour unless the node-local allocation requests were also
limited to lower zones.
Link: http://lkml.kernel.org/r/1467970510-21195-24-git-send-email-mgorman@techsingularity.net
kswapd is woken when zones are below the low watermark but the wakeup
decision is not taking the classzone into account. Now that reclaim is
node-based, it is only required to wake kswapd once per node and only if
all zones are unbalanced for the requested classzone.
Note that one node might be checked multiple times if the zonelist is
ordered by node because there is no cheap way of tracking what nodes
have already been visited. For zone-ordering, each node should be
checked only once.
Link: http://lkml.kernel.org/r/1467970510-21195-22-git-send-email-mgorman@techsingularity.net
As reclaim is now node-based, it follows that page write activity due to
page reclaim should also be accounted for on the node. For consistency,
also account page writes and page dirtying on a per-node basis.
After this patch, there are a few remaining zone counters that may appear
strange but are fine. NUMA stats are still per-zone as this is a
user-space interface that tools consume. NR_MLOCK, NR_SLAB_*,
NR_PAGETABLE, NR_KERNEL_STACK and NR_BOUNCE are all allocations that
potentially pin low memory and cannot trivially be reclaimed on demand.
This information is still useful for debugging a page allocation failure
warning.
Link: http://lkml.kernel.org/r/1467970510-21195-21-git-send-email-mgorman@techsingularity.net
There are now a number of accounting oddities such as mapped file pages
being accounted for on the node while the total number of file pages are
accounted on the zone. This can be coped with to some extent but it's
confusing so this patch moves the relevant file-based accounted. Due to
throttling logic in the page allocator for reliable OOM detection, it is
still necessary to track dirty and writeback pages on a per-zone basis.
[mgorman@techsingularity.net: fix NR_ZONE_WRITE_PENDING accounting]
Link: http://lkml.kernel.org/r/1468404004-5085-5-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-20-git-send-email-mgorman@techsingularity.net
Reclaim makes decisions based on the number of pages that are mapped but
it's mixing node and zone information. Account NR_FILE_MAPPED and
NR_ANON_PAGES pages on the node.
Link: http://lkml.kernel.org/r/1467970510-21195-18-git-send-email-mgorman@techsingularity.net
Memcg needs adjustment after moving LRUs to the node. Limits are
tracked per memcg but the soft-limit excess is tracked per zone. As
global page reclaim is based on the node, it is easy to imagine a
situation where a zone soft limit is exceeded even though the memcg
limit is fine.
This patch moves the soft limit tree the node. Technically, all the
variable names should also change but people are already familiar by the
meaning of "mz" even if "mn" would be a more appropriate name now.
Link: http://lkml.kernel.org/r/1467970510-21195-15-git-send-email-mgorman@techsingularity.net
Earlier patches focused on having direct reclaim and kswapd use data
that is node-centric for reclaiming but shrink_node() itself still uses
too much zone information. This patch removes unnecessary zone-based
information with the most important decision being whether to continue
reclaim or not. Some memcg APIs are adjusted as a result even though
memcg itself still uses some zone information.
[mgorman@techsingularity.net: optimization]
Link: http://lkml.kernel.org/r/1468588165-12461-2-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-14-git-send-email-mgorman@techsingularity.net
kswapd scans from highest to lowest for a zone that requires balancing.
This was necessary when reclaim was per-zone to fairly age pages on
lower zones. Now that we are reclaiming on a per-node basis, any
eligible zone can be used and pages will still be aged fairly. This
patch avoids reclaiming excessively unless buffer_heads are over the
limit and it's necessary to reclaim from a higher zone than requested by
the waker of kswapd to relieve low memory pressure.
[hillf.zj@alibaba-inc.com: Force kswapd reclaim no more than needed]
Link: http://lkml.kernel.org/r/1466518566-30034-12-git-send-email-mgorman@techsingularity.net
Link: http://lkml.kernel.org/r/1467970510-21195-13-git-send-email-mgorman@techsingularity.net
Signed-off-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Reclaim may stall if there is too much dirty or congested data on a
node. This was previously based on zone flags and the logic for
clearing the flags is in two places. As congestion/dirty tracking is
now tracked on a per-node basis, we can remove some duplicate logic.
Link: http://lkml.kernel.org/r/1467970510-21195-12-git-send-email-mgorman@techsingularity.net
Direct reclaim iterates over all zones in the zonelist and shrinking
them but this is in conflict with node-based reclaim. In the default
case, only shrink once per node.
Link: http://lkml.kernel.org/r/1467970510-21195-11-git-send-email-mgorman@techsingularity.net
kswapd goes through some complex steps trying to figure out if it should
stay awake based on the classzone_idx and the requested order. It is
unnecessarily complex and passes in an invalid classzone_idx to
balance_pgdat(). What matters most of all is whether a larger order has
been requsted and whether kswapd successfully reclaimed at the previous
order. This patch irons out the logic to check just that and the end
result is less headache inducing.
Link: http://lkml.kernel.org/r/1467970510-21195-10-git-send-email-mgorman@techsingularity.net
The balance gap was introduced to apply equal pressure to all zones when
reclaiming for a higher zone. With node-based LRU, the need for the
balance gap is removed and the code is dead so remove it.
[vbabka@suse.cz: Also remove KSWAPD_ZONE_BALANCE_GAP_RATIO]
Link: http://lkml.kernel.org/r/1467970510-21195-9-git-send-email-mgorman@techsingularity.net
Patch "mm: vmscan: Begin reclaiming pages on a per-node basis" started
thinking of reclaim in terms of nodes but kswapd is still zone-centric.
This patch gets rid of many of the node-based versus zone-based
decisions.
o A node is considered balanced when any eligible lower zone is balanced.
This eliminates one class of age-inversion problem because we avoid
reclaiming a newer page just because it's in the wrong zone
o pgdat_balanced disappears because we now only care about one zone being
balanced.
o Some anomalies related to writeback and congestion tracking being based on
zones disappear.
o kswapd no longer has to take care to reclaim zones in the reverse order
that the page allocator uses.
o Most importantly of all, reclaim from node 0 with multiple zones will
have similar aging and reclaiming characteristics as every
other node.
Link: http://lkml.kernel.org/r/1467970510-21195-8-git-send-email-mgorman@techsingularity.net
kswapd checks all eligible zones to see if they need balancing even if
it was woken for a lower zone. This made sense when we reclaimed on a
per-zone basis because we wanted to shrink zones fairly so avoid
age-inversion problems. Ideally this is completely unnecessary when
reclaiming on a per-node basis. In theory, there may still be anomalies
when all requests are for lower zones and very old pages are preserved
in higher zones but this should be the exceptional case.
Link: http://lkml.kernel.org/r/1467970510-21195-7-git-send-email-mgorman@techsingularity.net
This patch makes reclaim decisions on a per-node basis. A reclaimer
knows what zone is required by the allocation request and skips pages
from higher zones. In many cases this will be ok because it's a
GFP_HIGHMEM request of some description. On 64-bit, ZONE_DMA32 requests
will cause some problems but 32-bit devices on 64-bit platforms are
increasingly rare. Historically it would have been a major problem on
32-bit with big Highmem:Lowmem ratios but such configurations are also
now rare and even where they exist, they are not encouraged. If it
really becomes a problem, it'll manifest as very low reclaim
efficiencies.
Link: http://lkml.kernel.org/r/1467970510-21195-6-git-send-email-mgorman@techsingularity.net
