commit 72403b4a0fbdf433c1fe0127e49864658f6f6468 upstream.
Commit 0255d4918480 ("mm: Account for a THP NUMA hinting update as one
PTE update") was added to account for the number of PTE updates when
marking pages prot_numa. task_numa_work was using the old return value
to track how much address space had been updated. Altering the return
value causes the scanner to do more work than it is configured or
documented to in a single unit of work.
This patch reverts that commit and accounts for the number of THP
updates separately in vmstat. It is up to the administrator to
interpret the pair of values correctly. This is a straight-forward
operation and likely to only be of interest when actively debugging NUMA
balancing problems.
The impact of this patch is that the NUMA PTE scanner will scan slower
when THP is enabled and workloads may converge slower as a result. On
the flip size system CPU usage should be lower than recent tests
reported. This is an illustrative example of a short single JVM specjbb
test
specjbb
3.12.0 3.12.0
vanilla acctupdates
TPut 1 26143.00 ( 0.00%) 25747.00 ( -1.51%)
TPut 7 185257.00 ( 0.00%) 183202.00 ( -1.11%)
TPut 13 329760.00 ( 0.00%) 346577.00 ( 5.10%)
TPut 19 442502.00 ( 0.00%) 460146.00 ( 3.99%)
TPut 25 540634.00 ( 0.00%) 549053.00 ( 1.56%)
TPut 31 512098.00 ( 0.00%) 519611.00 ( 1.47%)
TPut 37 461276.00 ( 0.00%) 474973.00 ( 2.97%)
TPut 43 403089.00 ( 0.00%) 414172.00 ( 2.75%)
3.12.0 3.12.0
vanillaacctupdates
User 5169.64 5184.14
System 100.45 80.02
Elapsed 252.75 251.85
Performance is similar but note the reduction in system CPU time. While
this showed a performance gain, it will not be universal but at least
it'll be behaving as documented. The vmstats are obviously different but
here is an obvious interpretation of them from mmtests.
3.12.0 3.12.0
vanillaacctupdates
NUMA page range updates 1408326 11043064
NUMA huge PMD updates 0 21040
NUMA PTE updates 1408326 291624
"NUMA page range updates" == nr_pte_updates and is the value returned to
the NUMA pte scanner. NUMA huge PMD updates were the number of THP
updates which in combination can be used to calculate how many ptes were
updated from userspace.
Reported-by: Alex Thorlton <athorlton@sgi.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com>
CONFIG_HOTPLUG is going away as an option, cleanup CONFIG_HOTPLUG
ifdefs in mm files.
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Add 2 helpers (zone_end_pfn() and zone_spans_pfn()) to reduce code
duplication.
This also switches to using them in compaction (where an additional
variable needed to be renamed), page_alloc, vmstat, memory_hotplug, and
kmemleak.
Note that in compaction.c I avoid calling zone_end_pfn() repeatedly
because I expect at some point the sycronization issues with start_pfn &
spanned_pages will need fixing, either by actually using the seqlock or
clever memory barrier usage.
Cc: David Hansen <dave@linux.vnet.ibm.com>
Commit 92df3a723f84 ("mm: vmscan: throttle reclaim if encountering too
many dirty pages under writeback") introduced waiting on congested zones
based on a sane algorithm in shrink_inactive_list().
What this means is that there's no more need for throttling and
additional heuristics in balance_pgdat(). So, let's remove it and tidy
up the code.
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Several functions test MIGRATE_ISOLATE and some of those are hotpath but
MIGRATE_ISOLATE is used only if we enable CONFIG_MEMORY_ISOLATION(ie,
CMA, memory-hotplug and memory-failure) which are not common config
option. So let's not add unnecessary overhead and code when we don't
enable CONFIG_MEMORY_ISOLATION.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Now we have zone->managed_pages for "pages managed by the buddy system
in the zone", so replace zone->present_pages with zone->managed_pages if
what the user really wants is number of allocatable pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Cc: Chris Clayton <chris2553@googlemail.com>
Cc: "Rafael J . Wysocki" <rjw@sisk.pl>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jianguo Wu <wujianguo@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
Currently a zone's present_pages is calcuated as below, which is
inaccurate and may cause trouble to memory hotplug.
spanned_pages - absent_pages - memmap_pages - dma_reserve.
During fixing bugs caused by inaccurate zone->present_pages, we found
zone->present_pages has been abused. The field zone->present_pages may
have different meanings in different contexts:
1) pages existing in a zone.
2) pages managed by the buddy system.
For more discussions about the issue, please refer to:
http://lkml.org/lkml/2012/11/5/866
https://patchwork.kernel.org/patch/1346751/
This patchset tries to introduce a new field named "managed_pages" to
struct zone, which counts "pages managed by the buddy system". And revert
zone->present_pages to count "physical pages existing in a zone", which
also keep in consistence with pgdat->node_present_pages.
We will set an initial value for zone->managed_pages in function
free_area_init_core() and will adjust it later if the initial value is
inaccurate.
For DMA/normal zones, the initial value is set to:
(spanned_pages - absent_pages - memmap_pages - dma_reserve)
Later zone->managed_pages will be adjusted to the accurate value when the
bootmem allocator frees all free pages to the buddy system in function
free_all_bootmem_node() and free_all_bootmem().
The bootmem allocator doesn't touch highmem pages, so highmem zones'
managed_pages is set to the accurate value "spanned_pages - absent_pages"
in function free_area_init_core() and won't be updated anymore.
This patch also adds a new field "managed_pages" to /proc/zoneinfo
and sysrq showmem.
[akpm@linux-foundation.org: small comment tweaks]
Tested-by: Chris Clayton <chris2553@googlemail.com>
N_HIGH_MEMORY stands for the nodes that has normal or high memory.
N_MEMORY stands for the nodes that has any memory.
The code here need to handle with the nodes which have memory, we should
use N_MEMORY instead.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Lin Feng <linfeng@cn.fujitsu.com>
hzp_alloc is incremented every time a huge zero page is successfully
allocated. It includes allocations which where dropped due
race with other allocation. Note, it doesn't count every map
of the huge zero page, only its allocation.
hzp_alloc_failed is incremented if kernel fails to allocate huge zero
page and falls back to using small pages.
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
It is tricky to quantify the basic cost of automatic NUMA placement in a
meaningful manner. This patch adds some vmstats that can be used as part
of a basic costing model.
u = basic unit = sizeof(void *)
Ca = cost of struct page access = sizeof(struct page) / u
Cpte = Cost PTE access = Ca
Cupdate = Cost PTE update = (2 * Cpte) + (2 * Wlock)
where Cpte is incurred twice for a read and a write and Wlock
is a constant representing the cost of taking or releasing a
lock
Cnumahint = Cost of a minor page fault = some high constant e.g. 1000
Cpagerw = Cost to read or write a full page = Ca + PAGE_SIZE/u
Ci = Cost of page isolation = Ca + Wi
where Wi is a constant that should reflect the approximate cost
of the locking operation
Cpagecopy = Cpagerw + (Cpagerw * Wnuma) + Ci + (Ci * Wnuma)
where Wnuma is the approximate NUMA factor. 1 is local. 1.2
would imply that remote accesses are 20% more expensive
Balancing cost = Cpte * numa_pte_updates +
Cnumahint * numa_hint_faults +
Ci * numa_pages_migrated +
Cpagecopy * numa_pages_migrated
Note that numa_pages_migrated is used as a measure of how many pages
were isolated even though it would miss pages that failed to migrate. A
vmstat counter could have been added for it but the isolation cost is
pretty marginal in comparison to the overall cost so it seemed overkill.
The ideal way to measure automatic placement benefit would be to count
the number of remote accesses versus local accesses and do something like
benefit = (remote_accesses_before - remove_access_after) * Wnuma
but the information is not readily available. As a workload converges, the
expection would be that the number of remote numa hints would reduce to 0.
convergence = numa_hint_faults_local / numa_hint_faults
where this is measured for the last N number of
numa hints recorded. When the workload is fully
converged the value is 1.
This can measure if the placement policy is converging and how fast it is
doing it.
Compaction already has tracepoints to count scanned and isolated pages
but it requires that ftrace be enabled and if that information has to be
written to disk then it can be disruptive. This patch adds vmstat counters
for compaction called compact_migrate_scanned, compact_free_scanned and
compact_isolated.
With these counters, it is possible to define a basic cost model for
compaction. This approximates of how much work compaction is doing and can
be compared that with an oprofile showing TLB misses and see if the cost of
compaction is being offset by THP for example. Minimally a compaction patch
can be evaluated in terms of whether it increases or decreases cost. The
basic cost model looks like this
Fundamental unit u: a word sizeof(void *)
Cmc = Cost migrate page copy = (Ca + PAGE_SIZE/u) * 2
Cmf = Cost migrate failure = Ca * 2
Ci = Cost page isolation = (Ca + Wi)
cost of the locking operation.
Csm = Cost migrate scanning = Ca
Csf = Cost free scanning = Ca
Overall cost = (Csm * compact_migrate_scanned) +
(Csf * compact_free_scanned) +
(Ci * compact_isolated) +
(Cmc * pgmigrate_success) +
(Cmf * pgmigrate_failed)
Where the values are read from /proc/vmstat.
This is very basic and ignores certain costs such as the allocation cost
to do a migrate page copy but any improvement to the model would still
use the same vmstat counters.
The compact_pages_moved and compact_pagemigrate_failed events are
convenient for determining if compaction is active and to what
degree migration is succeeding but it's at the wrong level. Other
users of migration may also want to know if migration is working
properly and this will be particularly true for any automated
NUMA migration. This patch moves the counters down to migration
with the new events called pgmigrate_success and pgmigrate_fail.
The compact_blocks_moved counter is removed because while it was
useful for debugging initially, it's worthless now as no meaningful
conclusions can be drawn from its value.
Simply remove UNEVICTABLE_MLOCKFREED and unevictable_pgs_mlockfreed line
from /proc/vmstat: Johannes and Mel point out that it was very unlikely to
have been used by any tool, and of course we can restore it easily enough
if that turns out to be wrong.
Cc: Michel Lespinasse <walken@google.com>
Cc: Ying Han <yinghan@google.com>
During memory-hotplug, I found NR_ISOLATED_[ANON|FILE] are increasing,
causing the kernel to hang. When the system doesn't have enough free
pages, it enters reclaim but never reclaim any pages due to
too_many_isolated()==true and loops forever.
The cause is that when we do memory-hotadd after memory-remove,
__zone_pcp_update() clears a zone's ZONE_STAT_ITEMS in setup_pageset()
although the vm_stat_diff of all CPUs still have values.
In addtion, when we offline all pages of the zone, we reset them in
zone_pcp_reset without draining so we loss some zone stat item.
Reviewed-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
We should not be seeing non-0 unevictable_pgs_mlockfreed any longer. So
remove free_page_mlock() from the page freeing paths: __PG_MLOCKED is
already in PAGE_FLAGS_CHECK_AT_FREE, so free_pages_check() will now be
checking it, reporting "BUG: Bad page state" if it's ever found set.
Comment UNEVICTABLE_MLOCKFREED and unevictable_pgs_mlockfreed always 0.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Add NR_FREE_CMA_PAGES counter to be later used for checking watermark in
__zone_watermark_ok(). For simplicity and to avoid #ifdef hell make this
counter always available (not only when CONFIG_CMA=y).
[akpm@linux-foundation.org: use conventional migratetype naming]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Initalizers for deferrable delayed_work are confused.
* __DEFERRED_WORK_INITIALIZER()
* DECLARE_DEFERRED_WORK()
* INIT_DELAYED_WORK_DEFERRABLE()
Rename them to
* __DEFERRABLE_WORK_INITIALIZER()
* DECLARE_DEFERRABLE_WORK()
* INIT_DEFERRABLE_WORK()
This patch doesn't cause any functional changes.
Under significant pressure when writing back to network-backed storage,
direct reclaimers may get throttled. This is expected to be a short-lived
event and the processes get woken up again but processes do get stalled.
This patch counts how many times such stalling occurs. It's up to the
administrator whether to reduce these stalls by increasing
min_free_kbytes.
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Christoph Lameter <cl@linux.com>
extfrag_debug_root dentry local
Remove debug fs files and directory on failure. Since no one is using
"extfrag_debug_root" dentry outside of extfrag_debug_init(), make it
local to the function.
Signed-off-by: Sasikantha babu <sasikanth.v19@gmail.com>
Acked-by: David Rientjes <rientjes@google.com>
The MIGRATE_CMA migration type has two main characteristics:
(i) only movable pages can be allocated from MIGRATE_CMA
pageblocks and (ii) page allocator will never change migration
type of MIGRATE_CMA pageblocks.
This guarantees (to some degree) that page in a MIGRATE_CMA page
block can always be migrated somewhere else (unless there's no
memory left in the system).
It is designed to be used for allocating big chunks (eg. 10MiB)
of physically contiguous memory. Once driver requests
contiguous memory, pages from MIGRATE_CMA pageblocks may be
migrated away to create a contiguous block.
To minimise number of migrations, MIGRATE_CMA migration type
is the last type tried when page allocator falls back to other
migration types when requested.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Tested-by: Rob Clark <rob.clark@linaro.org>
Tested-by: Ohad Ben-Cohen <ohad@wizery.com>
Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Barry Song <Baohua.Song@csr.com>
The "pgsteal" stat is confusing because it counts both direct reclaim as
well as background reclaim. However, we have "kswapd_steal" which also
counts background reclaim value.
This patch fixes it and also makes it match the existng "pgscan_" stats.
Test:
pgsteal_kswapd_dma32 447623
pgsteal_kswapd_normal 42272677
pgsteal_kswapd_movable 0
pgsteal_direct_dma32 2801
pgsteal_direct_normal 44353270
pgsteal_direct_movable 0
Signed-off-by: Ying Han <yinghan@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Move CMPXCHG_LOCAL and rename it to HAVE_CMPXCHG_LOCAL so architectures
can simply select the option if it is supported.
Cc: Pekka Enberg <penberg@kernel.org>
Avoid false sharing of the vm_stat array.
This was found to adversely affect tmpfs I/O performance.
Tests run on a 640 cpu UV system.
With 120 threads doing parallel writes, each to different tmpfs mounts:
No patch: ~300 MB/sec
With vm_stat alignment: ~430 MB/sec
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Acked-by: Christoph Lameter <cl@gentwo.org>
When direct reclaim encounters a dirty page, it gets recycled around the
LRU for another cycle. This patch marks the page PageReclaim similar to
deactivate_page() so that the page gets reclaimed almost immediately after
the page gets cleaned. This is to avoid reclaiming clean pages that are
younger than a dirty page encountered at the end of the LRU that might
have been something like a use-once page.
Acked-by: Johannes Weiner <jweiner@redhat.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Alex Elder <aelder@sgi.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Testing from the XFS folk revealed that there is still too much I/O from
the end of the LRU in kswapd. Previously it was considered acceptable by
VM people for a small number of pages to be written back from reclaim with
testing generally showing about 0.3% of pages reclaimed were written back
(higher if memory was low). That writing back a small number of pages is
ok has been heavily disputed for quite some time and Dave Chinner
explained it well;
It doesn't have to be a very high number to be a problem. IO
is orders of magnitude slower than the CPU time it takes to
flush a page, so the cost of making a bad flush decision is
very high. And single page writeback from the LRU is almost
always a bad flush decision.
To complicate matters, filesystems respond very differently to requests
from reclaim according to Christoph Hellwig;
xfs tries to write it back if the requester is kswapd
ext4 ignores the request if it's a delayed allocation
btrfs ignores the request
As a result, each filesystem has different performance characteristics
when under memory pressure and there are many pages being dirtied. In
some cases, the request is ignored entirely so the VM cannot depend on the
IO being dispatched.
The objective of this series is to reduce writing of filesystem-backed
pages from reclaim, play nicely with writeback that is already in progress
and throttle reclaim appropriately when writeback pages are encountered.
The assumption is that the flushers will always write pages faster than if
reclaim issues the IO.
A secondary goal is to avoid the problem whereby direct reclaim splices
two potentially deep call stacks together.
There is a potential new problem as reclaim has less control over how long
before a page in a particularly zone or container is cleaned and direct
reclaimers depend on kswapd or flusher threads to do the necessary work.
However, as filesystems sometimes ignore direct reclaim requests already,
it is not expected to be a serious issue.
Patch 1 disables writeback of filesystem pages from direct reclaim
entirely. Anonymous pages are still written.
Patch 2 removes dead code in lumpy reclaim as it is no longer able
to synchronously write pages. This hurts lumpy reclaim but
there is an expectation that compaction is used for hugepage
allocations these days and lumpy reclaim's days are numbered.
Patches 3-4 add warnings to XFS and ext4 if called from
direct reclaim. With patch 1, this "never happens" and is
intended to catch regressions in this logic in the future.
Patch 5 disables writeback of filesystem pages from kswapd unless
the priority is raised to the point where kswapd is considered
to be in trouble.
Patch 6 throttles reclaimers if too many dirty pages are being
encountered and the zones or backing devices are congested.
Patch 7 invalidates dirty pages found at the end of the LRU so they
are reclaimed quickly after being written back rather than
waiting for a reclaimer to find them
I consider this series to be orthogonal to the writeback work but it is
worth noting that the writeback work affects the viability of patch 8 in
particular.
I tested this on ext4 and xfs using fs_mark, a simple writeback test based
on dd and a micro benchmark that does a streaming write to a large mapping
(exercises use-once LRU logic) followed by streaming writes to a mix of
anonymous and file-backed mappings. The command line for fs_mark when
botted with 512M looked something like
./fs_mark -d /tmp/fsmark-2676 -D 100 -N 150 -n 150 -L 25 -t 1 -S0 -s 10485760
The number of files was adjusted depending on the amount of available
memory so that the files created was about 3xRAM. For multiple threads,
the -d switch is specified multiple times.
The test machine is x86-64 with an older generation of AMD processor with
4 cores. The underlying storage was 4 disks configured as RAID-0 as this
was the best configuration of storage I had available. Swap is on a
separate disk. Dirty ratio was tuned to 40% instead of the default of
20%.
Testing was run with and without monitors to both verify that the patches
were operating as expected and that any performance gain was real and not
due to interference from monitors.
Here is a summary of results based on testing XFS.
512M1P-xfs Files/s mean 32.69 ( 0.00%) 34.44 ( 5.08%)
512M1P-xfs Elapsed Time fsmark 51.41 48.29
512M1P-xfs Elapsed Time simple-wb 114.09 108.61
512M1P-xfs Elapsed Time mmap-strm 113.46 109.34
512M1P-xfs Kswapd efficiency fsmark 62% 63%
512M1P-xfs Kswapd efficiency simple-wb 56% 61%
512M1P-xfs Kswapd efficiency mmap-strm 44% 42%
512M-xfs Files/s mean 30.78 ( 0.00%) 35.94 (14.36%)
512M-xfs Elapsed Time fsmark 56.08 48.90
512M-xfs Elapsed Time simple-wb 112.22 98.13
512M-xfs Elapsed Time mmap-strm 219.15 196.67
512M-xfs Kswapd efficiency fsmark 54% 56%
512M-xfs Kswapd efficiency simple-wb 54% 55%
512M-xfs Kswapd efficiency mmap-strm 45% 44%
512M-4X-xfs Files/s mean 30.31 ( 0.00%) 33.33 ( 9.06%)
512M-4X-xfs Elapsed Time fsmark 63.26 55.88
512M-4X-xfs Elapsed Time simple-wb 100.90 90.25
512M-4X-xfs Elapsed Time mmap-strm 261.73 255.38
512M-4X-xfs Kswapd efficiency fsmark 49% 50%
512M-4X-xfs Kswapd efficiency simple-wb 54% 56%
512M-4X-xfs Kswapd efficiency mmap-strm 37% 36%
512M-16X-xfs Files/s mean 60.89 ( 0.00%) 65.22 ( 6.64%)
512M-16X-xfs Elapsed Time fsmark 67.47 58.25
512M-16X-xfs Elapsed Time simple-wb 103.22 90.89
512M-16X-xfs Elapsed Time mmap-strm 237.09 198.82
512M-16X-xfs Kswapd efficiency fsmark 45% 46%
512M-16X-xfs Kswapd efficiency simple-wb 53% 55%
512M-16X-xfs Kswapd efficiency mmap-strm 33% 33%
Up until 512-4X, the FSmark improvements were statistically significant.
For the 4X and 16X tests the results were within standard deviations but
just barely. The time to completion for all tests is improved which is an
important result. In general, kswapd efficiency is not affected by
skipping dirty pages.
1024M1P-xfs Files/s mean 39.09 ( 0.00%) 41.15 ( 5.01%)
1024M1P-xfs Elapsed Time fsmark 84.14 80.41
1024M1P-xfs Elapsed Time simple-wb 210.77 184.78
1024M1P-xfs Elapsed Time mmap-strm 162.00 160.34
1024M1P-xfs Kswapd efficiency fsmark 69% 75%
1024M1P-xfs Kswapd efficiency simple-wb 71% 77%
1024M1P-xfs Kswapd efficiency mmap-strm 43% 44%
1024M-xfs Files/s mean 35.45 ( 0.00%) 37.00 ( 4.19%)
1024M-xfs Elapsed Time fsmark 94.59 91.00
1024M-xfs Elapsed Time simple-wb 229.84 195.08
1024M-xfs Elapsed Time mmap-strm 405.38 440.29
1024M-xfs Kswapd efficiency fsmark 79% 71%
1024M-xfs Kswapd efficiency simple-wb 74% 74%
1024M-xfs Kswapd efficiency mmap-strm 39% 42%
1024M-4X-xfs Files/s mean 32.63 ( 0.00%) 35.05 ( 6.90%)
1024M-4X-xfs Elapsed Time fsmark 103.33 97.74
1024M-4X-xfs Elapsed Time simple-wb 204.48 178.57
1024M-4X-xfs Elapsed Time mmap-strm 528.38 511.88
1024M-4X-xfs Kswapd efficiency fsmark 81% 70%
1024M-4X-xfs Kswapd efficiency simple-wb 73% 72%
1024M-4X-xfs Kswapd efficiency mmap-strm 39% 38%
1024M-16X-xfs Files/s mean 42.65 ( 0.00%) 42.97 ( 0.74%)
1024M-16X-xfs Elapsed Time fsmark 103.11 99.11
1024M-16X-xfs Elapsed Time simple-wb 200.83 178.24
1024M-16X-xfs Elapsed Time mmap-strm 397.35 459.82
1024M-16X-xfs Kswapd efficiency fsmark 84% 69%
1024M-16X-xfs Kswapd efficiency simple-wb 74% 73%
1024M-16X-xfs Kswapd efficiency mmap-strm 39% 40%
All FSMark tests up to 16X had statistically significant improvements.
For the most part, tests are completing faster with the exception of the
streaming writes to a mixture of anonymous and file-backed mappings which
were slower in two cases
In the cases where the mmap-strm tests were slower, there was more
swapping due to dirty pages being skipped. The number of additional pages
swapped is almost identical to the fewer number of pages written from
reclaim. In other words, roughly the same number of pages were reclaimed
but swapping was slower. As the test is a bit unrealistic and stresses
memory heavily, the small shift is acceptable.
4608M1P-xfs Files/s mean 29.75 ( 0.00%) 30.96 ( 3.91%)
4608M1P-xfs Elapsed Time fsmark 512.01 492.15
4608M1P-xfs Elapsed Time simple-wb 618.18 566.24
4608M1P-xfs Elapsed Time mmap-strm 488.05 465.07
4608M1P-xfs Kswapd efficiency fsmark 93% 86%
4608M1P-xfs Kswapd efficiency simple-wb 88% 84%
4608M1P-xfs Kswapd efficiency mmap-strm 46% 45%
4608M-xfs Files/s mean 27.60 ( 0.00%) 28.85 ( 4.33%)
4608M-xfs Elapsed Time fsmark 555.96 532.34
4608M-xfs Elapsed Time simple-wb 659.72 571.85
4608M-xfs Elapsed Time mmap-strm 1082.57 1146.38
4608M-xfs Kswapd efficiency fsmark 89% 91%
4608M-xfs Kswapd efficiency simple-wb 88% 82%
4608M-xfs Kswapd efficiency mmap-strm 48% 46%
4608M-4X-xfs Files/s mean 26.00 ( 0.00%) 27.47 ( 5.35%)
4608M-4X-xfs Elapsed Time fsmark 592.91 564.00
4608M-4X-xfs Elapsed Time simple-wb 616.65 575.07
4608M-4X-xfs Elapsed Time mmap-strm 1773.02 1631.53
4608M-4X-xfs Kswapd efficiency fsmark 90% 94%
4608M-4X-xfs Kswapd efficiency simple-wb 87% 82%
4608M-4X-xfs Kswapd efficiency mmap-strm 43% 43%
4608M-16X-xfs Files/s mean 26.07 ( 0.00%) 26.42 ( 1.32%)
4608M-16X-xfs Elapsed Time fsmark 602.69 585.78
4608M-16X-xfs Elapsed Time simple-wb 606.60 573.81
4608M-16X-xfs Elapsed Time mmap-strm 1549.75 1441.86
4608M-16X-xfs Kswapd efficiency fsmark 98% 98%
4608M-16X-xfs Kswapd efficiency simple-wb 88% 82%
4608M-16X-xfs Kswapd efficiency mmap-strm 44% 42%
Unlike the other tests, the fsmark results are not statistically
significant but the min and max times are both improved and for the most
part, tests completed faster.
There are other indications that this is an improvement as well. For
example, in the vast majority of cases, there were fewer pages scanned by
direct reclaim implying in many cases that stalls due to direct reclaim
are reduced. KSwapd is scanning more due to skipping dirty pages which is
unfortunate but the CPU usage is still acceptable
In an earlier set of tests, I used blktrace and in almost all cases
throughput throughout the entire test was higher. However, I ended up
discarding those results as recording blktrace data was too heavy for my
liking.
On a laptop, I plugged in a USB stick and ran a similar tests of tests
using it as backing storage. A desktop environment was running and for
the entire duration of the tests, firefox and gnome terminal were
launching and exiting to vaguely simulate a user.
1024M-xfs Files/s mean 0.41 ( 0.00%) 0.44 ( 6.82%)
1024M-xfs Elapsed Time fsmark 2053.52 1641.03
1024M-xfs Elapsed Time simple-wb 1229.53 768.05
1024M-xfs Elapsed Time mmap-strm 4126.44 4597.03
1024M-xfs Kswapd efficiency fsmark 84% 85%
1024M-xfs Kswapd efficiency simple-wb 92% 81%
1024M-xfs Kswapd efficiency mmap-strm 60% 51%
1024M-xfs Avg wait ms fsmark 5404.53 4473.87
1024M-xfs Avg wait ms simple-wb 2541.35 1453.54
1024M-xfs Avg wait ms mmap-strm 3400.25 3852.53
The mmap-strm results were hurt because firefox launching had a tendency
to push the test out of memory. On the postive side, firefox launched
marginally faster with the patches applied. Time to completion for many
tests was faster but more importantly - the "Avg wait" time as measured by
iostat was far lower implying the system would be more responsive. It was
also the case that "Avg wait ms" on the root filesystem was lower. I
tested it manually and while the system felt slightly more responsive
while copying data to a USB stick, it was marginal enough that it could be
my imagination.
This patch: do not writeback filesystem pages in direct reclaim.
When kswapd is failing to keep zones above the min watermark, a process
will enter direct reclaim in the same manner kswapd does. If a dirty page
is encountered during the scan, this page is written to backing storage
using mapping->writepage.
This causes two problems. First, it can result in very deep call stacks,
particularly if the target storage or filesystem are complex. Some
filesystems ignore write requests from direct reclaim as a result. The
second is that a single-page flush is inefficient in terms of IO. While
there is an expectation that the elevator will merge requests, this does
not always happen. Quoting Christoph Hellwig;
The elevator has a relatively small window it can operate on,
and can never fix up a bad large scale writeback pattern.
This patch prevents direct reclaim writing back filesystem pages by
checking if current is kswapd. Anonymous pages are still written to swap
as there is not the equivalent of a flusher thread for anonymous pages.
If the dirty pages cannot be written back, they are placed back on the LRU
lists. There is now a direct dependency on dirty page balancing to
prevent too many pages in the system being dirtied which would prevent
reclaim making forward progress.
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
The vmstat_text array is only defined for CONFIG_SYSFS or CONFIG_PROC_FS,
yet it is referenced for per-node vmstat with CONFIG_NUMA:
drivers/built-in.o: In function `node_read_vmstat':
node.c:(.text+0x1106df): undefined reference to `vmstat_text'
Introduced in commit fa25c503dfa2 ("mm: per-node vmstat: show proper
vmstats").
Define the array for CONFIG_NUMA as well.
[akpm@linux-foundation.org: remove unneeded ifdefs]
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Cong Wang <amwang@redhat.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Currently, cpu hotplug updates pcp->stat_threshold, but memory hotplug
doesn't. There is no reason for this.
[akpm@linux-foundation.org: fix CONFIG_SMP=n build]
commit 2ac390370a ("writeback: add
/sys/devices/system/node/<node>/vmstat") added vmstat entry. But
strangely it only show nr_written and nr_dirtied.
# cat /sys/devices/system/node/node20/vmstat
nr_written 0
nr_dirtied 0
Of course, It's not adequate. With this patch, the vmstat show all vm
stastics as /proc/vmstat.
# cat /sys/devices/system/node/node0/vmstat
nr_free_pages 899224
nr_inactive_anon 201
nr_active_anon 17380
nr_inactive_file 31572
nr_active_file 28277
nr_unevictable 0
nr_mlock 0
nr_anon_pages 17321
nr_mapped 8640
nr_file_pages 60107
nr_dirty 33
nr_writeback 0
nr_slab_reclaimable 6850
nr_slab_unreclaimable 7604
nr_page_table_pages 3105
nr_kernel_stack 175
nr_unstable 0
nr_bounce 0
nr_vmscan_write 0
nr_writeback_temp 0
nr_isolated_anon 0
nr_isolated_file 0
nr_shmem 260
nr_dirtied 1050
nr_written 938
numa_hit 962872
numa_miss 0
numa_foreign 0
numa_interleave 8617
numa_local 962872
numa_other 0
nr_anon_transparent_hugepages 0
[akpm@linux-foundation.org: no externs in .c files]
Cc: Michael Rubin <mrubin@google.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
I found it difficult to make sense of transparent huge pages without
having any counters for its actions. Add some counters to vmstat for
allocation of transparent hugepages and fallback to smaller pages.
Optional patch, but useful for development and understanding the system.
Contains improvements from Andrea Arcangeli and Johannes Weiner
[hannes@cmpxchg.org: fix vmstat_text[] entries]
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
Add a new __GFP_OTHER_NODE flag to tell the low level numa statistics in
zone_statistics() that an allocation is on behalf of another thread. This
way the local and remote counters can be still correct, even when
background daemons like khugepaged are changing memory mappings.
This only affects the accounting, but I think it's worth doing that right
to avoid confusing users.
I first tried to just pass down the right node, but this required a lot of
changes to pass down this parameter and at least one addition of a 10th
argument to a 9 argument function. Using the flag is a lot less
intrusive.
Open: should be also used for migration?
Add hugepage stat information to /proc/vmstat and /proc/meminfo.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
thresholds
reduce_pgdat_percpu_threshold() and restore_pgdat_percpu_threshold() exist
to adjust the per-cpu vmstat thresholds while kswapd is awake to avoid
errors due to counter drift. The functions duplicate some code so this
patch replaces them with a single set_pgdat_percpu_threshold() that takes
a callback function to calculate the desired threshold as a parameter.
[akpm@linux-foundation.org: readability tweak]
[kosaki.motohiro@jp.fujitsu.com: set_pgdat_percpu_threshold(): don't use for_each_online_cpu]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Christoph Lameter <cl@linux.com>
Commit aa45484 ("calculate a better estimate of NR_FREE_PAGES when memory
is low") noted that watermarks were based on the vmstat NR_FREE_PAGES. To
avoid synchronization overhead, these counters are maintained on a per-cpu
basis and drained both periodically and when a threshold is above a
threshold. On large CPU systems, the difference between the estimate and
real value of NR_FREE_PAGES can be very high. The system can get into a
case where pages are allocated far below the min watermark potentially
causing livelock issues. The commit solved the problem by taking a better
reading of NR_FREE_PAGES when memory was low.
Unfortately, as reported by Shaohua Li this accurate reading can consume a
large amount of CPU time on systems with many sockets due to cache line
bouncing. This patch takes a different approach. For large machines
where counter drift might be unsafe and while kswapd is awake, the per-cpu
thresholds for the target pgdat are reduced to limit the level of drift to
what should be a safe level. This incurs a performance penalty in heavy
memory pressure by a factor that depends on the workload and the machine
but the machine should function correctly without accidentally exhausting
all memory on a node. There is an additional cost when kswapd wakes and
sleeps but the event is not expected to be frequent - in Shaohua's test
case, there was one recorded sleep and wake event at least.
To ensure that kswapd wakes up, a safe version of zone_watermark_ok() is
introduced that takes a more accurate reading of NR_FREE_PAGES when called
from wakeup_kswapd, when deciding whether it is really safe to go back to
sleep in sleeping_prematurely() and when deciding if a zone is really
balanced or not in balance_pgdat(). We are still using an expensive
function but limiting how often it is called.
When the test case is reproduced, the time spent in the watermark
functions is reduced. The following report is on the percentage of time
spent cumulatively spent in the functions zone_nr_free_pages(),
zone_watermark_ok(), __zone_watermark_ok(), zone_watermark_ok_safe(),
zone_page_state_snapshot(), zone_page_state().
vanilla 11.6615%
disable-threshold 0.2584%
David said:
: We had to pull aa454840 "mm: page allocator: calculate a better estimate
: of NR_FREE_PAGES when memory is low and kswapd is awake" from 2.6.36
: internally because tests showed that it would cause the machine to stall
: as the result of heavy kswapd activity. I merged it back with this fix as
: it is pending in the -mm tree and it solves the issue we were seeing, so I
: definitely think this should be pushed to -stable (and I would seriously
: consider it for 2.6.37 inclusion even at this late date).
Reported-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: Nicolas Bareil <nico@chdir.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <stable@kernel.org> [2.6.37.1, 2.6.36.x]
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits)
gameport: use this_cpu_read instead of lookup
x86: udelay: Use this_cpu_read to avoid address calculation
x86: Use this_cpu_inc_return for nmi counter
x86: Replace uses of current_cpu_data with this_cpu ops
x86: Use this_cpu_ops to optimize code
vmstat: User per cpu atomics to avoid interrupt disable / enable
irq_work: Use per cpu atomics instead of regular atomics
cpuops: Use cmpxchg for xchg to avoid lock semantics
x86: this_cpu_cmpxchg and this_cpu_xchg operations
percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support
percpu,x86: relocate this_cpu_add_return() and friends
connector: Use this_cpu operations
xen: Use this_cpu_inc_return
taskstats: Use this_cpu_ops
random: Use this_cpu_inc_return
fs: Use this_cpu_inc_return in buffer.c
highmem: Use this_cpu_xx_return() operations
vmstat: Use this_cpu_inc_return for vm statistics
x86: Support for this_cpu_add, sub, dec, inc_return
percpu: Generic support for this_cpu_add, sub, dec, inc_return
Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c}
as per Tejun.
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
Currently the operations to increment vm counters must disable interrupts
in order to not mess up their housekeeping of counters.
So use this_cpu_cmpxchg() to avoid the overhead. Since we can no longer
count on preremption being disabled we still have some minor issues.
The fetching of the counter thresholds is racy.
A threshold from another cpu may be applied if we happen to be
rescheduled on another cpu. However, the following vmstat operation
will then bring the counter again under the threshold limit.
The operations for __xxx_zone_state are not changed since the caller
has taken care of the synchronization needs (and therefore the cycle
count is even less than the optimized version for the irq disable case
provided here).
The optimization using this_cpu_cmpxchg will only be used if the arch
supports efficient this_cpu_ops (must have CONFIG_CMPXCHG_LOCAL set!)
The use of this_cpu_cmpxchg reduces the cycle count for the counter
operations by %80 (inc_zone_page_state goes from 170 cycles to 32).
this_cpu_inc_return() saves us a memory access there. Code
size does not change.
V1->V2:
- Fixed the location of the __per_cpu pointer attributes
- Sparse checked
V2->V3:
- Move fixes to __percpu attribute usage to earlier patch
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
operations
this cpu operations can be used to slightly optimize the function. The
changes will avoid some address calculations and replace them with the
use of the percpu segment register.
If one would have this_cpu_inc_return and this_cpu_dec_return then it
would be possible to optimize inc_zone_page_state and
dec_zone_page_state even more.
V1->V2:
- Fix __dec_zone_state overflow handling
- Use s8 variables for temporary storage.
V2->V3:
- Put __percpu annotations in correct places.
cancel_delayed_work_sync()
cancel_rearming_delayed_work[queue]() has been superceded by
cancel_delayed_work_sync() quite some time ago. Convert all the
in-kernel users. The conversions are completely equivalent and
trivial.
Acked-by: "David S. Miller" <davem@davemloft.net>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: netdev@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: xfs-masters@oss.sgi.com
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: netfilter-devel@vger.kernel.org
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: linux-nfs@vger.kernel.org
The nr_dirty_[background_]threshold fields are misplaced before the
numa_* fields, and users will read strange values.
This is the right order. Before patch, nr_dirty_background_threshold
will read as 0 (the value from numa_miss).
numa_hit 128501
numa_miss 0
numa_foreign 0
numa_interleave 7388
numa_local 128501
numa_other 0
nr_dirty_threshold 144291
nr_dirty_background_threshold 72145
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Fix regression introduced by commit 79da826aee6 ("writeback: report
dirty thresholds in /proc/vmstat").
The incorrect pointer arithmetic can result in problems like this:
BUG: unable to handle kernel paging request at 07c06d16
IP: [<c050c336>] strnlen+0x6/0x20
Call Trace:
[<c050a249>] ? string+0x39/0xe0
[<c042be6b>] ? __wake_up_common+0x4b/0x80
[<c050afcc>] ? vsnprintf+0x1ec/0x380
[<c04b380e>] ? seq_printf+0x2e/0x60
[<c04829a6>] ? vmstat_show+0x26/0x30
[<c04b3bb6>] ? seq_read+0xa6/0x380
[<c04b3b10>] ? seq_read+0x0/0x380
[<c04d5d2f>] ? proc_reg_read+0x5f/0x90
[<c049c4a1>] ? vfs_read+0xa1/0x140
[<c04d5cd0>] ? proc_reg_read+0x0/0x90
[<c049c981>] ? sys_read+0x41/0x70
[<c0402bd0>] ? sysenter_do_call+0x12/0x26
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
This removes following warning from sparse:
mm/vmstat.c:466:5: warning: symbol 'fragmentation_index' was not declared. Should it be static?
[akpm@linux-foundation.org: move the include to top-of-file]
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
The kernel already exposes the user desired thresholds in /proc/sys/vm
with dirty_background_ratio and background_ratio. But the kernel may
alter the number requested without giving the user any indication that is
the case.
Knowing the actual ratios the kernel is honoring can help app developers
understand how their buffered IO will be sent to the disk.
$ grep threshold /proc/vmstat
nr_dirty_threshold 409111
nr_dirty_background_threshold 818223
Signed-off-by: Michael Rubin <mrubin@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
To help developers and applications gain visibility into writeback
behaviour adding two entries to vm_stat_items and /proc/vmstat. This will
allow us to track the "written" and "dirtied" counts.
# grep nr_dirtied /proc/vmstat
nr_dirtied 3747
# grep nr_written /proc/vmstat
nr_written 3618
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is
cheaper than scanning a number of lists. To avoid synchronization
overhead, counter deltas are maintained on a per-cpu basis and drained
both periodically and when the delta is above a threshold. On large CPU
systems, the difference between the estimated and real value of
NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than
number of real free page in buddy, the VM can allocate pages below min
watermark, at worst reducing the real number of pages to zero. Even if
the OOM killer kills some victim for freeing memory, it may not free
memory if the exit path requires a new page resulting in livelock.
This patch introduces a zone_page_state_snapshot() function (courtesy of
Christoph) that takes a slightly more accurate view of an arbitrary vmstat
counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid
the watermark being accidentally broken. The estimate is not perfect and
may result in cache line bounces but is expected to be lighter than the
IPI calls necessary to continually drain the per-cpu counters while kswapd
is awake.
refresh_zone_stat_thresholds() calculates parameter based on the number of
online cpus. It's called at cpu offlining but needs to be called at
onlining, too.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Since 2.6.28 zone->prev_priority is unused. Then it can be removed
safely. It reduce stack usage slightly.
Now I have to say that I'm sorry. 2 years ago, I thought prev_priority
can be integrate again, it's useful. but four (or more) times trying
haven't got good performance number. Thus I give up such approach.
The rest of this changelog is notes on prev_priority and why it existed in
the first place and why it might be not necessary any more. This information
is based heavily on discussions between Andrew Morton, Rik van Riel and
Kosaki Motohiro who is heavily quotes from.
Historically prev_priority was important because it determined when the VM
would start unmapping PTE pages. i.e. there are no balances of note within
the VM, Anon vs File and Mapped vs Unmapped. Without prev_priority, there
is a potential risk of unnecessarily increasing minor faults as a large
amount of read activity of use-once pages could push mapped pages to the
end of the LRU and get unmapped.
There is no proof this is still a problem but currently it is not considered
to be. Active files are not deactivated if the active file list is smaller
than the inactive list reducing the liklihood that file-mapped pages are
being pushed off the LRU and referenced executable pages are kept on the
active list to avoid them getting pushed out by read activity.
Even if it is a problem, prev_priority prev_priority wouldn't works
nowadays. First of all, current vmscan still a lot of UP centric code. it
expose some weakness on some dozens CPUs machine. I think we need more and
more improvement.
The problem is, current vmscan mix up per-system-pressure, per-zone-pressure
and per-task-pressure a bit. example, prev_priority try to boost priority to
other concurrent priority. but if the another task have mempolicy restriction,
it is unnecessary, but also makes wrong big latency and exceeding reclaim.
per-task based priority + prev_priority adjustment make the emulation of
per-system pressure. but it have two issue 1) too rough and brutal emulation
2) we need per-zone pressure, not per-system.
Another example, currently DEF_PRIORITY is 12. it mean the lru rotate about
2 cycle (1/4096 + 1/2048 + 1/1024 + .. + 1) before invoking OOM-Killer.
but if 10,0000 thrreads enter DEF_PRIORITY reclaim at the same time, the
system have higher memory pressure than priority==0 (1/4096*10,000 > 2).
prev_priority can't solve such multithreads workload issue. In other word,
prev_priority concept assume the sysmtem don't have lots threads."
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Nick Piggin <npiggin@suse.de>
