path: root/mm/vmstat.c
2011-10-31mm/vmstat.c: cache align vm_statDimitri Sivanich
Avoid false sharing of the vm_stat array. This was found to adversely affect tmpfs I/O performance. Tests run on a 640 cpu UV system. With 120 threads doing parallel writes, each to different tmpfs mounts: No patch: ~300 MB/sec With vm_stat alignment: ~430 MB/sec Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Acked-by: Christoph Lameter <cl@gentwo.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: vmscan: immediately reclaim end-of-LRU dirty pages when writeback completesMel Gorman
When direct reclaim encounters a dirty page, it gets recycled around the LRU for another cycle. This patch marks the page PageReclaim similar to deactivate_page() so that the page gets reclaimed almost immediately after the page gets cleaned. This is to avoid reclaiming clean pages that are younger than a dirty page encountered at the end of the LRU that might have been something like a use-once page. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Johannes Weiner <jweiner@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Alex Elder <aelder@sgi.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Chris Mason <chris.mason@oracle.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31mm: vmscan: do not writeback filesystem pages in direct reclaimMel Gorman
Testing from the XFS folk revealed that there is still too much I/O from the end of the LRU in kswapd. Previously it was considered acceptable by VM people for a small number of pages to be written back from reclaim with testing generally showing about 0.3% of pages reclaimed were written back (higher if memory was low). That writing back a small number of pages is ok has been heavily disputed for quite some time and Dave Chinner explained it well; It doesn't have to be a very high number to be a problem. IO is orders of magnitude slower than the CPU time it takes to flush a page, so the cost of making a bad flush decision is very high. And single page writeback from the LRU is almost always a bad flush decision. To complicate matters, filesystems respond very differently to requests from reclaim according to Christoph Hellwig; xfs tries to write it back if the requester is kswapd ext4 ignores the request if it's a delayed allocation btrfs ignores the request As a result, each filesystem has different performance characteristics when under memory pressure and there are many pages being dirtied. In some cases, the request is ignored entirely so the VM cannot depend on the IO being dispatched. The objective of this series is to reduce writing of filesystem-backed pages from reclaim, play nicely with writeback that is already in progress and throttle reclaim appropriately when writeback pages are encountered. The assumption is that the flushers will always write pages faster than if reclaim issues the IO. A secondary goal is to avoid the problem whereby direct reclaim splices two potentially deep call stacks together. There is a potential new problem as reclaim has less control over how long before a page in a particularly zone or container is cleaned and direct reclaimers depend on kswapd or flusher threads to do the necessary work. However, as filesystems sometimes ignore direct reclaim requests already, it is not expected to be a serious issue. Patch 1 disables writeback of filesystem pages from direct reclaim entirely. Anonymous pages are still written. Patch 2 removes dead code in lumpy reclaim as it is no longer able to synchronously write pages. This hurts lumpy reclaim but there is an expectation that compaction is used for hugepage allocations these days and lumpy reclaim's days are numbered. Patches 3-4 add warnings to XFS and ext4 if called from direct reclaim. With patch 1, this "never happens" and is intended to catch regressions in this logic in the future. Patch 5 disables writeback of filesystem pages from kswapd unless the priority is raised to the point where kswapd is considered to be in trouble. Patch 6 throttles reclaimers if too many dirty pages are being encountered and the zones or backing devices are congested. Patch 7 invalidates dirty pages found at the end of the LRU so they are reclaimed quickly after being written back rather than waiting for a reclaimer to find them I consider this series to be orthogonal to the writeback work but it is worth noting that the writeback work affects the viability of patch 8 in particular. I tested this on ext4 and xfs using fs_mark, a simple writeback test based on dd and a micro benchmark that does a streaming write to a large mapping (exercises use-once LRU logic) followed by streaming writes to a mix of anonymous and file-backed mappings. The command line for fs_mark when botted with 512M looked something like ./fs_mark -d /tmp/fsmark-2676 -D 100 -N 150 -n 150 -L 25 -t 1 -S0 -s 10485760 The number of files was adjusted depending on the amount of available memory so that the files created was about 3xRAM. For multiple threads, the -d switch is specified multiple times. The test machine is x86-64 with an older generation of AMD processor with 4 cores. The underlying storage was 4 disks configured as RAID-0 as this was the best configuration of storage I had available. Swap is on a separate disk. Dirty ratio was tuned to 40% instead of the default of 20%. Testing was run with and without monitors to both verify that the patches were operating as expected and that any performance gain was real and not due to interference from monitors. Here is a summary of results based on testing XFS. 512M1P-xfs Files/s mean 32.69 ( 0.00%) 34.44 ( 5.08%) 512M1P-xfs Elapsed Time fsmark 51.41 48.29 512M1P-xfs Elapsed Time simple-wb 114.09 108.61 512M1P-xfs Elapsed Time mmap-strm 113.46 109.34 512M1P-xfs Kswapd efficiency fsmark 62% 63% 512M1P-xfs Kswapd efficiency simple-wb 56% 61% 512M1P-xfs Kswapd efficiency mmap-strm 44% 42% 512M-xfs Files/s mean 30.78 ( 0.00%) 35.94 (14.36%) 512M-xfs Elapsed Time fsmark 56.08 48.90 512M-xfs Elapsed Time simple-wb 112.22 98.13 512M-xfs Elapsed Time mmap-strm 219.15 196.67 512M-xfs Kswapd efficiency fsmark 54% 56% 512M-xfs Kswapd efficiency simple-wb 54% 55% 512M-xfs Kswapd efficiency mmap-strm 45% 44% 512M-4X-xfs Files/s mean 30.31 ( 0.00%) 33.33 ( 9.06%) 512M-4X-xfs Elapsed Time fsmark 63.26 55.88 512M-4X-xfs Elapsed Time simple-wb 100.90 90.25 512M-4X-xfs Elapsed Time mmap-strm 261.73 255.38 512M-4X-xfs Kswapd efficiency fsmark 49% 50% 512M-4X-xfs Kswapd efficiency simple-wb 54% 56% 512M-4X-xfs Kswapd efficiency mmap-strm 37% 36% 512M-16X-xfs Files/s mean 60.89 ( 0.00%) 65.22 ( 6.64%) 512M-16X-xfs Elapsed Time fsmark 67.47 58.25 512M-16X-xfs Elapsed Time simple-wb 103.22 90.89 512M-16X-xfs Elapsed Time mmap-strm 237.09 198.82 512M-16X-xfs Kswapd efficiency fsmark 45% 46% 512M-16X-xfs Kswapd efficiency simple-wb 53% 55% 512M-16X-xfs Kswapd efficiency mmap-strm 33% 33% Up until 512-4X, the FSmark improvements were statistically significant. For the 4X and 16X tests the results were within standard deviations but just barely. The time to completion for all tests is improved which is an important result. In general, kswapd efficiency is not affected by skipping dirty pages. 1024M1P-xfs Files/s mean 39.09 ( 0.00%) 41.15 ( 5.01%) 1024M1P-xfs Elapsed Time fsmark 84.14 80.41 1024M1P-xfs Elapsed Time simple-wb 210.77 184.78 1024M1P-xfs Elapsed Time mmap-strm 162.00 160.34 1024M1P-xfs Kswapd efficiency fsmark 69% 75% 1024M1P-xfs Kswapd efficiency simple-wb 71% 77% 1024M1P-xfs Kswapd efficiency mmap-strm 43% 44% 1024M-xfs Files/s mean 35.45 ( 0.00%) 37.00 ( 4.19%) 1024M-xfs Elapsed Time fsmark 94.59 91.00 1024M-xfs Elapsed Time simple-wb 229.84 195.08 1024M-xfs Elapsed Time mmap-strm 405.38 440.29 1024M-xfs Kswapd efficiency fsmark 79% 71% 1024M-xfs Kswapd efficiency simple-wb 74% 74% 1024M-xfs Kswapd efficiency mmap-strm 39% 42% 1024M-4X-xfs Files/s mean 32.63 ( 0.00%) 35.05 ( 6.90%) 1024M-4X-xfs Elapsed Time fsmark 103.33 97.74 1024M-4X-xfs Elapsed Time simple-wb 204.48 178.57 1024M-4X-xfs Elapsed Time mmap-strm 528.38 511.88 1024M-4X-xfs Kswapd efficiency fsmark 81% 70% 1024M-4X-xfs Kswapd efficiency simple-wb 73% 72% 1024M-4X-xfs Kswapd efficiency mmap-strm 39% 38% 1024M-16X-xfs Files/s mean 42.65 ( 0.00%) 42.97 ( 0.74%) 1024M-16X-xfs Elapsed Time fsmark 103.11 99.11 1024M-16X-xfs Elapsed Time simple-wb 200.83 178.24 1024M-16X-xfs Elapsed Time mmap-strm 397.35 459.82 1024M-16X-xfs Kswapd efficiency fsmark 84% 69% 1024M-16X-xfs Kswapd efficiency simple-wb 74% 73% 1024M-16X-xfs Kswapd efficiency mmap-strm 39% 40% All FSMark tests up to 16X had statistically significant improvements. For the most part, tests are completing faster with the exception of the streaming writes to a mixture of anonymous and file-backed mappings which were slower in two cases In the cases where the mmap-strm tests were slower, there was more swapping due to dirty pages being skipped. The number of additional pages swapped is almost identical to the fewer number of pages written from reclaim. In other words, roughly the same number of pages were reclaimed but swapping was slower. As the test is a bit unrealistic and stresses memory heavily, the small shift is acceptable. 4608M1P-xfs Files/s mean 29.75 ( 0.00%) 30.96 ( 3.91%) 4608M1P-xfs Elapsed Time fsmark 512.01 492.15 4608M1P-xfs Elapsed Time simple-wb 618.18 566.24 4608M1P-xfs Elapsed Time mmap-strm 488.05 465.07 4608M1P-xfs Kswapd efficiency fsmark 93% 86% 4608M1P-xfs Kswapd efficiency simple-wb 88% 84% 4608M1P-xfs Kswapd efficiency mmap-strm 46% 45% 4608M-xfs Files/s mean 27.60 ( 0.00%) 28.85 ( 4.33%) 4608M-xfs Elapsed Time fsmark 555.96 532.34 4608M-xfs Elapsed Time simple-wb 659.72 571.85 4608M-xfs Elapsed Time mmap-strm 1082.57 1146.38 4608M-xfs Kswapd efficiency fsmark 89% 91% 4608M-xfs Kswapd efficiency simple-wb 88% 82% 4608M-xfs Kswapd efficiency mmap-strm 48% 46% 4608M-4X-xfs Files/s mean 26.00 ( 0.00%) 27.47 ( 5.35%) 4608M-4X-xfs Elapsed Time fsmark 592.91 564.00 4608M-4X-xfs Elapsed Time simple-wb 616.65 575.07 4608M-4X-xfs Elapsed Time mmap-strm 1773.02 1631.53 4608M-4X-xfs Kswapd efficiency fsmark 90% 94% 4608M-4X-xfs Kswapd efficiency simple-wb 87% 82% 4608M-4X-xfs Kswapd efficiency mmap-strm 43% 43% 4608M-16X-xfs Files/s mean 26.07 ( 0.00%) 26.42 ( 1.32%) 4608M-16X-xfs Elapsed Time fsmark 602.69 585.78 4608M-16X-xfs Elapsed Time simple-wb 606.60 573.81 4608M-16X-xfs Elapsed Time mmap-strm 1549.75 1441.86 4608M-16X-xfs Kswapd efficiency fsmark 98% 98% 4608M-16X-xfs Kswapd efficiency simple-wb 88% 82% 4608M-16X-xfs Kswapd efficiency mmap-strm 44% 42% Unlike the other tests, the fsmark results are not statistically significant but the min and max times are both improved and for the most part, tests completed faster. There are other indications that this is an improvement as well. For example, in the vast majority of cases, there were fewer pages scanned by direct reclaim implying in many cases that stalls due to direct reclaim are reduced. KSwapd is scanning more due to skipping dirty pages which is unfortunate but the CPU usage is still acceptable In an earlier set of tests, I used blktrace and in almost all cases throughput throughout the entire test was higher. However, I ended up discarding those results as recording blktrace data was too heavy for my liking. On a laptop, I plugged in a USB stick and ran a similar tests of tests using it as backing storage. A desktop environment was running and for the entire duration of the tests, firefox and gnome terminal were launching and exiting to vaguely simulate a user. 1024M-xfs Files/s mean 0.41 ( 0.00%) 0.44 ( 6.82%) 1024M-xfs Elapsed Time fsmark 2053.52 1641.03 1024M-xfs Elapsed Time simple-wb 1229.53 768.05 1024M-xfs Elapsed Time mmap-strm 4126.44 4597.03 1024M-xfs Kswapd efficiency fsmark 84% 85% 1024M-xfs Kswapd efficiency simple-wb 92% 81% 1024M-xfs Kswapd efficiency mmap-strm 60% 51% 1024M-xfs Avg wait ms fsmark 5404.53 4473.87 1024M-xfs Avg wait ms simple-wb 2541.35 1453.54 1024M-xfs Avg wait ms mmap-strm 3400.25 3852.53 The mmap-strm results were hurt because firefox launching had a tendency to push the test out of memory. On the postive side, firefox launched marginally faster with the patches applied. Time to completion for many tests was faster but more importantly - the "Avg wait" time as measured by iostat was far lower implying the system would be more responsive. It was also the case that "Avg wait ms" on the root filesystem was lower. I tested it manually and while the system felt slightly more responsive while copying data to a USB stick, it was marginal enough that it could be my imagination. This patch: do not writeback filesystem pages in direct reclaim. When kswapd is failing to keep zones above the min watermark, a process will enter direct reclaim in the same manner kswapd does. If a dirty page is encountered during the scan, this page is written to backing storage using mapping->writepage. This causes two problems. First, it can result in very deep call stacks, particularly if the target storage or filesystem are complex. Some filesystems ignore write requests from direct reclaim as a result. The second is that a single-page flush is inefficient in terms of IO. While there is an expectation that the elevator will merge requests, this does not always happen. Quoting Christoph Hellwig; The elevator has a relatively small window it can operate on, and can never fix up a bad large scale writeback pattern. This patch prevents direct reclaim writing back filesystem pages by checking if current is kswapd. Anonymous pages are still written to swap as there is not the equivalent of a flusher thread for anonymous pages. If the dirty pages cannot be written back, they are placed back on the LRU lists. There is now a direct dependency on dirty page balancing to prevent too many pages in the system being dirtied which would prevent reclaim making forward progress. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Alex Elder <aelder@sgi.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Chris Mason <chris.mason@oracle.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14numa: fix NUMA compile error when sysfs and procfs are disabledDavid Rientjes
The vmstat_text array is only defined for CONFIG_SYSFS or CONFIG_PROC_FS, yet it is referenced for per-node vmstat with CONFIG_NUMA: drivers/built-in.o: In function `node_read_vmstat': node.c:(.text+0x1106df): undefined reference to `vmstat_text' Introduced in commit fa25c503dfa2 ("mm: per-node vmstat: show proper vmstats"). Define the array for CONFIG_NUMA as well. [akpm@linux-foundation.org: remove unneeded ifdefs] Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Cong Wang <amwang@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm, mem-hotplug: update pcp->stat_threshold when memory hotplug occurKOSAKI Motohiro
Currently, cpu hotplug updates pcp->stat_threshold, but memory hotplug doesn't. There is no reason for this. [akpm@linux-foundation.org: fix CONFIG_SMP=n build] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: per-node vmstat: show proper vmstatsKOSAKI Motohiro
commit 2ac390370a ("writeback: add /sys/devices/system/node/<node>/vmstat") added vmstat entry. But strangely it only show nr_written and nr_dirtied. # cat /sys/devices/system/node/node20/vmstat nr_written 0 nr_dirtied 0 Of course, It's not adequate. With this patch, the vmstat show all vm stastics as /proc/vmstat. # cat /sys/devices/system/node/node0/vmstat nr_free_pages 899224 nr_inactive_anon 201 nr_active_anon 17380 nr_inactive_file 31572 nr_active_file 28277 nr_unevictable 0 nr_mlock 0 nr_anon_pages 17321 nr_mapped 8640 nr_file_pages 60107 nr_dirty 33 nr_writeback 0 nr_slab_reclaimable 6850 nr_slab_unreclaimable 7604 nr_page_table_pages 3105 nr_kernel_stack 175 nr_unstable 0 nr_bounce 0 nr_vmscan_write 0 nr_writeback_temp 0 nr_isolated_anon 0 nr_isolated_file 0 nr_shmem 260 nr_dirtied 1050 nr_written 938 numa_hit 962872 numa_miss 0 numa_foreign 0 numa_interleave 8617 numa_local 962872 numa_other 0 nr_anon_transparent_hugepages 0 [akpm@linux-foundation.org: no externs in .c files] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michael Rubin <mrubin@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14mm: add VM counters for transparent hugepagesAndi Kleen
I found it difficult to make sense of transparent huge pages without having any counters for its actions. Add some counters to vmstat for allocation of transparent hugepages and fallback to smaller pages. Optional patch, but useful for development and understanding the system. Contains improvements from Andrea Arcangeli and Johannes Weiner [akpm@linux-foundation.org: coding-style fixes] [hannes@cmpxchg.org: fix vmstat_text[] entries] Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14vmstat: update comment regarding stat_thresholdChristoph Lameter
Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: add __GFP_OTHER_NODE flagAndi Kleen
Add a new __GFP_OTHER_NODE flag to tell the low level numa statistics in zone_statistics() that an allocation is on behalf of another thread. This way the local and remote counters can be still correct, even when background daemons like khugepaged are changing memory mappings. This only affects the accounting, but I think it's worth doing that right to avoid confusing users. I first tried to just pass down the right node, but this required a lot of changes to pass down this parameter and at least one addition of a 10th argument to a 9 argument function. Using the flag is a lot less intrusive. Open: should be also used for migration? [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage vmstatAndrea Arcangeli
Add hugepage stat information to /proc/vmstat and /proc/meminfo. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: vmstat: use a single setter function and callback for adjusting percpu ↵Mel Gorman
thresholds reduce_pgdat_percpu_threshold() and restore_pgdat_percpu_threshold() exist to adjust the per-cpu vmstat thresholds while kswapd is awake to avoid errors due to counter drift. The functions duplicate some code so this patch replaces them with a single set_pgdat_percpu_threshold() that takes a callback function to calculate the desired threshold as a parameter. [akpm@linux-foundation.org: readability tweak] [kosaki.motohiro@jp.fujitsu.com: set_pgdat_percpu_threshold(): don't use for_each_online_cpu] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13mm: page allocator: adjust the per-cpu counter threshold when memory is lowMel Gorman
Commit aa45484 ("calculate a better estimate of NR_FREE_PAGES when memory is low") noted that watermarks were based on the vmstat NR_FREE_PAGES. To avoid synchronization overhead, these counters are maintained on a per-cpu basis and drained both periodically and when a threshold is above a threshold. On large CPU systems, the difference between the estimate and real value of NR_FREE_PAGES can be very high. The system can get into a case where pages are allocated far below the min watermark potentially causing livelock issues. The commit solved the problem by taking a better reading of NR_FREE_PAGES when memory was low. Unfortately, as reported by Shaohua Li this accurate reading can consume a large amount of CPU time on systems with many sockets due to cache line bouncing. This patch takes a different approach. For large machines where counter drift might be unsafe and while kswapd is awake, the per-cpu thresholds for the target pgdat are reduced to limit the level of drift to what should be a safe level. This incurs a performance penalty in heavy memory pressure by a factor that depends on the workload and the machine but the machine should function correctly without accidentally exhausting all memory on a node. There is an additional cost when kswapd wakes and sleeps but the event is not expected to be frequent - in Shaohua's test case, there was one recorded sleep and wake event at least. To ensure that kswapd wakes up, a safe version of zone_watermark_ok() is introduced that takes a more accurate reading of NR_FREE_PAGES when called from wakeup_kswapd, when deciding whether it is really safe to go back to sleep in sleeping_prematurely() and when deciding if a zone is really balanced or not in balance_pgdat(). We are still using an expensive function but limiting how often it is called. When the test case is reproduced, the time spent in the watermark functions is reduced. The following report is on the percentage of time spent cumulatively spent in the functions zone_nr_free_pages(), zone_watermark_ok(), __zone_watermark_ok(), zone_watermark_ok_safe(), zone_page_state_snapshot(), zone_page_state(). vanilla 11.6615% disable-threshold 0.2584% David said: : We had to pull aa454840 "mm: page allocator: calculate a better estimate : of NR_FREE_PAGES when memory is low and kswapd is awake" from 2.6.36 : internally because tests showed that it would cause the machine to stall : as the result of heavy kswapd activity. I merged it back with this fix as : it is pending in the -mm tree and it solves the issue we were seeing, so I : definitely think this should be pushed to -stable (and I would seriously : consider it for 2.6.37 inclusion even at this late date). Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reported-by: Shaohua Li <shaohua.li@intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Tested-by: Nicolas Bareil <nico@chdir.org> Cc: David Rientjes <rientjes@google.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: <stable@kernel.org> [2.6.37.1, 2.6.36.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2010-12-18vmstat: User per cpu atomics to avoid interrupt disable / enableChristoph Lameter
Currently the operations to increment vm counters must disable interrupts in order to not mess up their housekeeping of counters. So use this_cpu_cmpxchg() to avoid the overhead. Since we can no longer count on preremption being disabled we still have some minor issues. The fetching of the counter thresholds is racy. A threshold from another cpu may be applied if we happen to be rescheduled on another cpu. However, the following vmstat operation will then bring the counter again under the threshold limit. The operations for __xxx_zone_state are not changed since the caller has taken care of the synchronization needs (and therefore the cycle count is even less than the optimized version for the irq disable case provided here). The optimization using this_cpu_cmpxchg will only be used if the arch supports efficient this_cpu_ops (must have CONFIG_CMPXCHG_LOCAL set!) The use of this_cpu_cmpxchg reduces the cycle count for the counter operations by %80 (inc_zone_page_state goes from 170 cycles to 32). Signed-off-by: Christoph Lameter <cl@linux.com>
2010-12-17vmstat: Use this_cpu_inc_return for vm statisticsChristoph Lameter
this_cpu_inc_return() saves us a memory access there. Code size does not change. V1->V2: - Fixed the location of the __per_cpu pointer attributes - Sparse checked V2->V3: - Move fixes to __percpu attribute usage to earlier patch Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-17vmstat: Optimize zone counter modifications through the use of this cpu ↵Christoph Lameter
operations this cpu operations can be used to slightly optimize the function. The changes will avoid some address calculations and replace them with the use of the percpu segment register. If one would have this_cpu_inc_return and this_cpu_dec_return then it would be possible to optimize inc_zone_page_state and dec_zone_page_state even more. V1->V2: - Fix __dec_zone_state overflow handling - Use s8 variables for temporary storage. V2->V3: - Put __percpu annotations in correct places. Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-15workqueue: convert cancel_rearming_delayed_work[queue]() users to ↵Tejun Heo
cancel_delayed_work_sync() cancel_rearming_delayed_work[queue]() has been superceded by cancel_delayed_work_sync() quite some time ago. Convert all the in-kernel users. The conversions are completely equivalent and trivial. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: "David S. Miller" <davem@davemloft.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: netdev@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Alex Elder <aelder@sgi.com> Cc: xfs-masters@oss.sgi.com Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: netfilter-devel@vger.kernel.org Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: linux-nfs@vger.kernel.org
2010-12-02vmstat: fix dirty threshold orderingWu Fengguang
The nr_dirty_[background_]threshold fields are misplaced before the numa_* fields, and users will read strange values. This is the right order. Before patch, nr_dirty_background_threshold will read as 0 (the value from numa_miss). numa_hit 128501 numa_miss 0 numa_foreign 0 numa_interleave 7388 numa_local 128501 numa_other 0 nr_dirty_threshold 144291 nr_dirty_background_threshold 72145 Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Michael Rubin <mrubin@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-03vmstat: fix offset calculation on void*Wu Fengguang
Fix regression introduced by commit 79da826aee6 ("writeback: report dirty thresholds in /proc/vmstat"). The incorrect pointer arithmetic can result in problems like this: BUG: unable to handle kernel paging request at 07c06d16 IP: [<c050c336>] strnlen+0x6/0x20 Call Trace: [<c050a249>] ? string+0x39/0xe0 [<c042be6b>] ? __wake_up_common+0x4b/0x80 [<c050afcc>] ? vsnprintf+0x1ec/0x380 [<c04b380e>] ? seq_printf+0x2e/0x60 [<c04829a6>] ? vmstat_show+0x26/0x30 [<c04b3bb6>] ? seq_read+0xa6/0x380 [<c04b3b10>] ? seq_read+0x0/0x380 [<c04d5d2f>] ? proc_reg_read+0x5f/0x90 [<c049c4a1>] ? vfs_read+0xa1/0x140 [<c04d5cd0>] ? proc_reg_read+0x0/0x90 [<c049c981>] ? sys_read+0x41/0x70 [<c0402bd0>] ? sysenter_do_call+0x12/0x26 Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26vmstat: include compaction.h when CONFIG_COMPACTIONNamhyung Kim
This removes following warning from sparse: mm/vmstat.c:466:5: warning: symbol 'fragmentation_index' was not declared. Should it be static? [akpm@linux-foundation.org: move the include to top-of-file] Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: report dirty thresholds in /proc/vmstatMichael Rubin
The kernel already exposes the user desired thresholds in /proc/sys/vm with dirty_background_ratio and background_ratio. But the kernel may alter the number requested without giving the user any indication that is the case. Knowing the actual ratios the kernel is honoring can help app developers understand how their buffered IO will be sent to the disk. $ grep threshold /proc/vmstat nr_dirty_threshold 409111 nr_dirty_background_threshold 818223 Signed-off-by: Michael Rubin <mrubin@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: add nr_dirtied and nr_written to /proc/vmstatMichael Rubin
To help developers and applications gain visibility into writeback behaviour adding two entries to vm_stat_items and /proc/vmstat. This will allow us to track the "written" and "dirtied" counts. # grep nr_dirtied /proc/vmstat nr_dirtied 3747 # grep nr_written /proc/vmstat nr_written 3618 Signed-off-by: Michael Rubin <mrubin@google.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09mm: page allocator: calculate a better estimate of NR_FREE_PAGES when memory ↵Christoph Lameter
is low and kswapd is awake Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is cheaper than scanning a number of lists. To avoid synchronization overhead, counter deltas are maintained on a per-cpu basis and drained both periodically and when the delta is above a threshold. On large CPU systems, the difference between the estimated and real value of NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than number of real free page in buddy, the VM can allocate pages below min watermark, at worst reducing the real number of pages to zero. Even if the OOM killer kills some victim for freeing memory, it may not free memory if the exit path requires a new page resulting in livelock. This patch introduces a zone_page_state_snapshot() function (courtesy of Christoph) that takes a slightly more accurate view of an arbitrary vmstat counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid the watermark being accidentally broken. The estimate is not perfect and may result in cache line bounces but is expected to be lighter than the IPI calls necessary to continually drain the per-cpu counters while kswapd is awake. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09vmstat: update zone stat threshold when onlining a cpuKAMEZAWA Hiroyuki
refresh_zone_stat_thresholds() calculates parameter based on the number of online cpus. It's called at cpu offlining but needs to be called at onlining, too. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09vmscan: kill prev_priority completelyKOSAKI Motohiro
Since 2.6.28 zone->prev_priority is unused. Then it can be removed safely. It reduce stack usage slightly. Now I have to say that I'm sorry. 2 years ago, I thought prev_priority can be integrate again, it's useful. but four (or more) times trying haven't got good performance number. Thus I give up such approach. The rest of this changelog is notes on prev_priority and why it existed in the first place and why it might be not necessary any more. This information is based heavily on discussions between Andrew Morton, Rik van Riel and Kosaki Motohiro who is heavily quotes from. Historically prev_priority was important because it determined when the VM would start unmapping PTE pages. i.e. there are no balances of note within the VM, Anon vs File and Mapped vs Unmapped. Without prev_priority, there is a potential risk of unnecessarily increasing minor faults as a large amount of read activity of use-once pages could push mapped pages to the end of the LRU and get unmapped. There is no proof this is still a problem but currently it is not considered to be. Active files are not deactivated if the active file list is smaller than the inactive list reducing the liklihood that file-mapped pages are being pushed off the LRU and referenced executable pages are kept on the active list to avoid them getting pushed out by read activity. Even if it is a problem, prev_priority prev_priority wouldn't works nowadays. First of all, current vmscan still a lot of UP centric code. it expose some weakness on some dozens CPUs machine. I think we need more and more improvement. The problem is, current vmscan mix up per-system-pressure, per-zone-pressure and per-task-pressure a bit. example, prev_priority try to boost priority to other concurrent priority. but if the another task have mempolicy restriction, it is unnecessary, but also makes wrong big latency and exceeding reclaim. per-task based priority + prev_priority adjustment make the emulation of per-system pressure. but it have two issue 1) too rough and brutal emulation 2) we need per-zone pressure, not per-system. Another example, currently DEF_PRIORITY is 12. it mean the lru rotate about 2 cycle (1/4096 + 1/2048 + 1/1024 + .. + 1) before invoking OOM-Killer. but if 10,0000 thrreads enter DEF_PRIORITY reclaim at the same time, the system have higher memory pressure than priority==0 (1/4096*10,000 > 2). prev_priority can't solve such multithreads workload issue. In other word, prev_priority concept assume the sysmtem don't have lots threads." Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: use for_each_online_cpu() in vmstatMinchan Kim
The sum_vm_events passes cpumask for for_each_cpu(). But it's useless since we have for_each_online_cpu. Althougth it's tirival overhead, it's not good about coding consistency. Let's use for_each_online_cpu instead of for_each_cpu with cpumask argument. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: compaction: direct compact when a high-order allocation failsMel Gorman
Ordinarily when a high-order allocation fails, direct reclaim is entered to free pages to satisfy the allocation. With this patch, it is determined if an allocation failed due to external fragmentation instead of low memory and if so, the calling process will compact until a suitable page is freed. Compaction by moving pages in memory is considerably cheaper than paging out to disk and works where there are locked pages or no swap. If compaction fails to free a page of a suitable size, then reclaim will still occur. Direct compaction returns as soon as possible. As each block is compacted, it is checked if a suitable page has been freed and if so, it returns. [akpm@linux-foundation.org: Fix build errors] [aarcange@redhat.com: fix count_vm_event preempt in memory compaction direct reclaim] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: compaction: memory compaction coreMel Gorman
This patch is the core of a mechanism which compacts memory in a zone by relocating movable pages towards the end of the zone. A single compaction run involves a migration scanner and a free scanner. Both scanners operate on pageblock-sized areas in the zone. The migration scanner starts at the bottom of the zone and searches for all movable pages within each area, isolating them onto a private list called migratelist. The free scanner starts at the top of the zone and searches for suitable areas and consumes the free pages within making them available for the migration scanner. The pages isolated for migration are then migrated to the newly isolated free pages. [aarcange@redhat.com: Fix unsafe optimisation] [mel@csn.ul.ie: do not schedule work on other CPUs for compaction] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: export fragmentation index via debugfsMel Gorman
The fragmentation fragmentation index, is only meaningful if an allocation would fail and indicates what the failure is due to. A value of -1 such as in many of the examples above states that the allocation would succeed. If it would fail, the value is between 0 and 1. A value tending towards 0 implies the allocation failed due to a lack of memory. A value tending towards 1 implies it failed due to external fragmentation. For the most part, the huge page size will be the size of interest but not necessarily so it is exported on a per-order and per-zo basis via /sys/kernel/debug/extfrag/extfrag_index > cat /sys/kernel/debug/extfrag/extfrag_index Node 0, zone DMA -1.000 -1.000 -1.000 -1.000 -1.000 -1.000 -1.000 -1.00 Node 0, zone Normal -1.000 -1.000 -1.000 -1.000 -1.000 -1.000 -1.000 0.954 Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: export unusable free space index via debugfsMel Gorman
The unusable free space index measures how much of the available free memory cannot be used to satisfy an allocation of a given size and is a value between 0 and 1. The higher the value, the more of free memory is unusable and by implication, the worse the external fragmentation is. For the most part, the huge page size will be the size of interest but not necessarily so it is exported on a per-order and per-zone basis via /sys/kernel/debug/extfrag/unusable_index. > cat /sys/kernel/debug/extfrag/unusable_index Node 0, zone DMA 0.000 0.000 0.000 0.001 0.005 0.013 0.021 0.037 0.037 0.101 0.230 Node 0, zone Normal 0.000 0.000 0.000 0.001 0.002 0.002 0.005 0.015 0.028 0.028 0.054 [akpm@linux-foundation.org: Fix allnoconfig] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06mm: restore zone->all_unreclaimable to independence wordKOSAKI Motohiro
commit e815af95 ("change all_unreclaimable zone member to flags") changed all_unreclaimable member to bit flag. But it had an undesireble side effect. free_one_page() is one of most hot path in linux kernel and increasing atomic ops in it can reduce kernel performance a bit. Thus, this patch revert such commit partially. at least all_unreclaimable shouldn't share memory word with other zone flags. [akpm@linux-foundation.org: fix patch interaction] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-05this_cpu: Remove pageset_notifierChristoph Lameter
Remove the pageset notifier since it only marks that a processor exists on a specific node. Move that code into the vmstat notifier. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-01-05this_cpu: Page allocator conversionChristoph Lameter
Use the per cpu allocator functionality to avoid per cpu arrays in struct zone. This drastically reduces the size of struct zone for systems with large amounts of processors and allows placement of critical variables of struct zone in one cacheline even on very large systems. Another effect is that the pagesets of one processor are placed near one another. If multiple pagesets from different zones fit into one cacheline then additional cacheline fetches can be avoided on the hot paths when allocating memory from multiple zones. Bootstrap becomes simpler if we use the same scheme for UP, SMP, NUMA. #ifdefs are reduced and we can drop the zone_pcp macro. Hotplug handling is also simplified since cpu alloc can bring up and shut down cpu areas for a specific cpu as a whole. So there is no need to allocate or free individual pagesets. V7-V8: - Explain chicken egg dilemmna with percpu allocator. V4-V5: - Fix up cases where per_cpu_ptr is called before irq disable - Integrate the bootstrap logic that was separate before. tj: Build failure in pageset_cpuup_callback() due to missing ret variable fixed. Reviewed-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-12-15vmscan: stop kswapd waiting on congestion when the min watermark is not ↵KOSAKI Motohiro
being met If reclaim fails to make sufficient progress, the priority is raised. Once the priority is higher, kswapd starts waiting on congestion. However, if the zone is below the min watermark then kswapd needs to continue working without delay as there is a danger of an increased rate of GFP_ATOMIC allocation failure. This patch changes the conditions under which kswapd waits on congestion by only going to sleep if the min watermarks are being met. [mel@csn.ul.ie: add stats to track how relevant the logic is] [mel@csn.ul.ie: make kswapd only check its own zones and rename the relevant counters] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15vmscan: have kswapd sleep for a short interval and double check it should be ↵Mel Gorman
asleep After kswapd balances all zones in a pgdat, it goes to sleep. In the event of no IO congestion, kswapd can go to sleep very shortly after the high watermark was reached. If there are a constant stream of allocations from parallel processes, it can mean that kswapd went to sleep too quickly and the high watermark is not being maintained for sufficient length time. This patch makes kswapd go to sleep as a two-stage process. It first tries to sleep for HZ/10. If it is woken up by another process or the high watermark is no longer met, it's considered a premature sleep and kswapd continues work. Otherwise it goes fully to sleep. This adds more counters to distinguish between fast and slow breaches of watermarks. A "fast" premature sleep is one where the low watermark was hit in a very short time after kswapd going to sleep. A "slow" premature sleep indicates that the high watermark was breached after a very short interval. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Frans Pop <elendil@planet.nl> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29percpu: make percpu symbols under kernel/ and mm/ uniqueTejun Heo
This patch updates percpu related symbols under kernel/ and mm/ such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * kernel/lockdep.c: s/lock_stats/cpu_lock_stats/ * kernel/sched.c: s/init_rq_rt/init_rt_rq_var/ (any better idea?) s/sched_group_cpus/sched_groups/ * kernel/softirq.c: s/ksoftirqd/run_ksoftirqd/a * kernel/softlockup.c: s/(*)_timestamp/softlockup_\1_ts/ s/watchdog_task/softlockup_watchdog/ s/timestamp/ts/ for local variables * kernel/time/timer_stats: s/lookup_lock/tstats_lookup_lock/ * mm/slab.c: s/reap_work/slab_reap_work/ s/reap_node/slab_reap_node/ * mm/vmstat.c: local variable changed to avoid collision with vmstat_work Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: (slab/vmstat) Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de>
2009-09-22mm: vmstat: add isolate pagesKOSAKI Motohiro
If the system is running a heavy load of processes then concurrent reclaim can isolate a large number of pages from the LRU. /proc/vmstat and the output generated for an OOM do not show how many pages were isolated. This has been observed during process fork bomb testing (mstctl11 in LTP). This patch shows the information about isolated pages. Reproduced via: ----------------------- % ./hackbench 140 process 1000 => OOM occur active_anon:146 inactive_anon:0 isolated_anon:49245 active_file:79 inactive_file:18 isolated_file:113 unevictable:0 dirty:0 writeback:0 unstable:0 buffer:39 free:370 slab_reclaimable:309 slab_unreclaimable:5492 mapped:53 shmem:15 pagetables:28140 bounce:0 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: oom analysis: add shmem vmstatKOSAKI Motohiro
Recently we encountered OOM problems due to memory use of the GEM cache. Generally a large amuont of Shmem/Tmpfs pages tend to create a memory shortage problem. We often use the following calculation to determine the amount of shmem pages: shmem = NR_ACTIVE_ANON + NR_INACTIVE_ANON - NR_ANON_PAGES however the expression does not consider isolated and mlocked pages. This patch adds explicit accounting for pages used by shmem and tmpfs. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: oom analysis: Show kernel stack usage in /proc/meminfo and OOM log outputKOSAKI Motohiro
The amount of memory allocated to kernel stacks can become significant and cause OOM conditions. However, we do not display the amount of memory consumed by stacks. Add code to display the amount of memory used for stacks in /proc/meminfo. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: count the number of times zone_reclaim() scans and failsMel Gorman
On NUMA machines, the administrator can configure zone_reclaim_mode that is a more targetted form of direct reclaim. On machines with large NUMA distances for example, a zone_reclaim_mode defaults to 1 meaning that clean unmapped pages will be reclaimed if the zone watermarks are not being met. There is a heuristic that determines if the scan is worthwhile but it is possible that the heuristic will fail and the CPU gets tied up scanning uselessly. Detecting the situation requires some guesswork and experimentation so this patch adds a counter "zreclaim_failed" to /proc/vmstat. If during high CPU utilisation this counter is increasing rapidly, then the resolution to the problem may be to set /proc/sys/vm/zone_reclaim_mode to 0. [akpm@linux-foundation.org: name things consistently] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: don't export nr_saved_scan in /proc/zoneinfoWu Fengguang
The lru->nr_saved_scan's are not meaningful counters for even kernel developers. They typically are smaller than 32 and are always 0 for large lists. So remove them from /proc/zoneinfo. Hopefully this interface change won't break too many scripts. /proc/zoneinfo is too unstructured to be script friendly, and I wonder the affected scripts - if there are any - are still bleeding since the not long ago commit "vmscan: split LRU lists into anon & file sets", which also touched the "scanned" line :) If we are to re-export accumulated vmscan counts in the future, they can go to new lines in /proc/zoneinfo instead of the current form, or to /sys/devices/system/node/node0/meminfo? Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: cleanup the scan batching codeWu Fengguang
The vmscan batching logic is twisting. Move it into a standalone function nr_scan_try_batch() and document it. No behavior change. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: use allocation flags as an index to the zone watermarkMel Gorman
ALLOC_WMARK_MIN, ALLOC_WMARK_LOW and ALLOC_WMARK_HIGH determin whether pages_min, pages_low or pages_high is used as the zone watermark when allocating the pages. Two branches in the allocator hotpath determine which watermark to use. This patch uses the flags as an array index into a watermark array that is indexed with WMARK_* defines accessed via helpers. All call sites that use zone->pages_* are updated to use the helpers for accessing the values and the array offsets for setting. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-18[ARM] Double check memmap is actually valid with a memmap has unexpected ↵Mel Gorman
holes V2 pfn_valid() is meant to be able to tell if a given PFN has valid memmap associated with it or not. In FLATMEM, it is expected that holes always have valid memmap as long as there is valid PFNs either side of the hole. In SPARSEMEM, it is assumed that a valid section has a memmap for the entire section. However, ARM and maybe other embedded architectures in the future free memmap backing holes to save memory on the assumption the memmap is never used. The page_zone linkages are then broken even though pfn_valid() returns true. A walker of the full memmap must then do this additional check to ensure the memmap they are looking at is sane by making sure the zone and PFN linkages are still valid. This is expensive, but walkers of the full memmap are extremely rare. This was caught before for FLATMEM and hacked around but it hits again for SPARSEMEM because the page_zone linkages can look ok where the PFN linkages are totally screwed. This looks like a hatchet job but the reality is that any clean solution would end up consumning all the memory saved by punching these unexpected holes in the memmap. For example, we tried marking the memmap within the section invalid but the section size exceeds the size of the hole in most cases so pfn_valid() starts returning false where valid memmap exists. Shrinking the size of the section would increase memory consumption offsetting the gains. This patch identifies when an architecture is punching unexpected holes in the memmap that the memory model cannot automatically detect and sets ARCH_HAS_HOLES_MEMORYMODEL. At the moment, this is restricted to EP93xx which is the model sub-architecture this has been reported on but may expand later. When set, walkers of the full memmap must call memmap_valid_within() for each PFN and passing in what it expects the page and zone to be for that PFN. If it finds the linkages to be broken, it assumes the memmap is invalid for that PFN. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-02mm: align vmstat_work's timerAnton Blanchard
Even though vmstat_work is marked deferrable, there are still benefits to aligning it. For certain applications we want to keep OS jitter as low as possible and aligning timers and work so they occur together can reduce their overall impact. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: introduce for_each_populated_zone() macroKOSAKI Motohiro
Impact: cleanup In almost cases, for_each_zone() is used with populated_zone(). It's because almost function doesn't need memoryless node information. Therefore, for_each_populated_zone() can help to make code simplify. This patch has no functional change. [akpm@linux-foundation.org: small cleanup] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: use new cpumask_ functions in core code.Rusty Russell
Impact: cleanup Time to clean up remaining laggards using the old cpu_ functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Trond.Myklebust@netapp.com
