commit ac8f05da5174c560de122c499ce5dfb5d0dfbee5 upstream.
When zspage is migrated to the other zone, the zone page state should be
updated as well, otherwise the NR_ZSPAGE for each zone shows wrong
counts including proc/zoneinfo in practice.
Link: http://lkml.kernel.org/r/1575434841-48009-1-git-send-email-chanho.min@lge.com
Fixes: 91537fee0013 ("mm: add NR_ZSMALLOC to vmstat")
Signed-off-by: Chanho Min <chanho.min@lge.com>
Signed-off-by: Jinsuk Choi <jjinsuk.choi@lge.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: <stable@vger.kernel.org> [4.9+]
commit 441e254cd40dc03beec3c650ce6ce6074bc6517f upstream.
Fixes: 701d678599d0c1 ("mm/zsmalloc.c: fix race condition in zs_destroy_pool")
Link: http://lkml.kernel.org/r/201908251039.5oSbEEUT%25lkp@intel.com
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Henry Burns <henrywolfeburns@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Shakeel Butt <shakeelb@google.com>
Cc: Jonathan Adams <jwadams@google.com>
commit 701d678599d0c1623aaf4139c03eea260a75b027 upstream.
In zs_destroy_pool() we call flush_work(&pool->free_work). However, we
have no guarantee that migration isn't happening in the background at
that time.
Since migration can't directly free pages, it relies on free_work being
scheduled to free the pages. But there's nothing preventing an
in-progress migrate from queuing the work *after*
zs_unregister_migration() has called flush_work(). Which would mean
pages still pointing at the inode when we free it.
Since we know at destroy time all objects should be free, no new
migrations can come in (since zs_page_isolate() fails for fully-free
zspages). This means it is sufficient to track a "# isolated zspages"
count by class, and have the destroy logic ensure all such pages have
drained before proceeding. Keeping that state under the class spinlock
keeps the logic straightforward.
In this case a memory leak could lead to an eventual crash if compaction
hits the leaked page. This crash would only occur if people are
changing their zswap backend at runtime (which eventually starts
destruction).
Link: http://lkml.kernel.org/r/20190809181751.219326-2-henryburns@google.com
Fixes: 48b4800a1c6a ("zsmalloc: page migration support")
Signed-off-by: Henry Burns <henryburns@google.com>
commit 1a87aa03597efa9641e92875b883c94c7f872ccb upstream.
In zs_page_migrate() we call putback_zspage() after we have finished
migrating all pages in this zspage. However, the return value is
ignored. If a zs_free() races in between zs_page_isolate() and
zs_page_migrate(), freeing the last object in the zspage,
putback_zspage() will leave the page in ZS_EMPTY for potentially an
unbounded amount of time.
To fix this, we need to do the same thing as zs_page_putback() does:
schedule free_work to occur.
To avoid duplicated code, move the sequence to a new
putback_zspage_deferred() function which both zs_page_migrate() and
zs_page_putback() call.
Link: http://lkml.kernel.org/r/20190809181751.219326-1-henryburns@google.com
[ Upstream commit 1aedcafbf32b3f232c159b14cd0d423fcfe2b861 ]
Use BUG_ON(in_interrupt()) in zs_map_object(). This is not a new
BUG_ON(), it's always been there, but was recently changed to
VM_BUG_ON(). There are several problems there. First, we use use
per-CPU mappings both in zsmalloc and in zram, and interrupt may easily
corrupt those buffers. Second, and more importantly, we believe it's
possible to start leaking sensitive information. Consider the following
case:
-> process P
swap out
zram
per-cpu mapping CPU1
compress page A
-> IRQ
swap out
zram
compress page B
write page from per-cpu mapping CPU1 to zsmalloc pool
iret
-> process P
write page from per-cpu mapping CPU1 to zsmalloc pool [*]
return
* so we store overwritten data that actually belongs to another
page (task) and potentially contains sensitive data. And when
process P will page fault it's going to read (swap in) that
other task's data.
Link: http://lkml.kernel.org/r/20170929045140.4055-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
zs_stat_inc/dec/get() uses enum zs_stat_type for the stat type, however
some callers pass an enum fullness_group value. Change the type to int to
reflect the actual use of the functions and get rid of 'enum-conversion'
warnings
Link: http://lkml.kernel.org/r/20170731175000.56538-1-mka@chromium.org
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Doug Anderson <dianders@chromium.org>
Introduce a new migration mode that allow to offload the copy to a device
DMA engine. This changes the workflow of migration and not all
address_space migratepage callback can support this.
This is intended to be use by migrate_vma() which itself is use for thing
like HMM (see include/linux/hmm.h).
No additional per-filesystem migratepage testing is needed. I disables
MIGRATE_SYNC_NO_COPY in all problematic migratepage() callback and i
added comment in those to explain why (part of this patch). The commit
message is unclear it should say that any callback that wish to support
this new mode need to be aware of the difference in the migration flow
from other mode.
Some of these callbacks do extra locking while copying (aio, zsmalloc,
balloon, ...) and for DMA to be effective you want to copy multiple
pages in one DMA operations. But in the problematic case you can not
easily hold the extra lock accross multiple call to this callback.
Usual flow is:
For each page {
1 - lock page
2 - call migratepage() callback
3 - (extra locking in some migratepage() callback)
4 - migrate page state (freeze refcount, update page cache, buffer
head, ...)
5 - copy page
6 - (unlock any extra lock of migratepage() callback)
7 - return from migratepage() callback
8 - unlock page
The new mode MIGRATE_SYNC_NO_COPY:
1 - lock multiple pages
For each page {
3 - abort in all problematic migratepage() callback
head, ...)
} // finished all calls to migratepage() callback
5 - DMA copy multiple pages
6 - unlock all the pages
To support MIGRATE_SYNC_NO_COPY in the problematic case we would need a
new callback migratepages() (for instance) that deals with multiple
pages in one transaction.
Because the problematic cases are not important for current usage I did
not wanted to complexify this patchset even more for no good reason.
Link: http://lkml.kernel.org/r/20170817000548.32038-14-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: David Nellans <dnellans@nvidia.com>
Cc: Evgeny Baskakov <ebaskakov@nvidia.com>
Cc: John Hubbard <jhubbard@nvidia.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mark Hairgrove <mhairgrove@nvidia.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Sherry Cheung <SCheung@nvidia.com>
Cc: Subhash Gutti <sgutti@nvidia.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Bob Liu <liubo95@huawei.com>
zspage is not inuse
Getting -EBUSY from zs_page_migrate will make migration slow (retry) or
fail (zs_page_putback will schedule_work free_work, but it cannot ensure
the success).
I noticed this issue because my Kernel patched
(https://lkml.org/lkml/2014/5/28/113) that will remove retry in
__alloc_contig_migrate_range.
This retry will handle the -EBUSY because it will re-isolate the page
and re-call migrate_pages. Without it will make cma_alloc fail at once
with -EBUSY.
According to the review from Minchan Kim in
https://lkml.org/lkml/2014/5/28/113, I update the patch to skip
unnecessary loops but not return -EBUSY if zspage is not inuse.
Following is what I got with highalloc-performance in a vbox with 2 cpu
1G memory 512 zram as swap. And the swappiness is set to 100.
ori ne
orig new
Minor Faults 50805113 50830235
Major Faults 43918 56530
Swap Ins 42087 55680
Swap Outs 89718 104700
Allocation stalls 0 0
DMA allocs 57787 52364
DMA32 allocs 47964599 48043563
Normal allocs 0 0
Movable allocs 0 0
Direct pages scanned 45493 23167
Kswapd pages scanned 1565222 1725078
Kswapd pages reclaimed 1342222 1503037
Direct pages reclaimed 45615 25186
Kswapd efficiency 85% 87%
Kswapd velocity 1897.101 1949.042
Direct efficiency 100% 108%
Direct velocity 55.139 26.175
Percentage direct scans 2% 1%
Zone normal velocity 1952.240 1975.217
Zone dma32 velocity 0.000 0.000
Zone dma velocity 0.000 0.000
Page writes by reclaim 89764.000 105233.000
Page writes file 46 533
Page writes anon 89718 104700
Page reclaim immediate 21457 3699
Sector Reads 3259688 3441368
Sector Writes 3667252 3754836
Page rescued immediate 0 0
Slabs scanned 1042872 1160855
Direct inode steals 8042 10089
Kswapd inode steals 54295 29170
Kswapd skipped wait 0 0
THP fault alloc 175 154
THP collapse alloc 226 289
THP splits 0 0
THP fault fallback 11 14
THP collapse fail 3 2
Compaction stalls 536 646
Compaction success 322 358
Compaction failures 214 288
Page migrate success 119608 111063
Page migrate failure 2723 2593
Compaction pages isolated 250179 232652
Compaction migrate scanned 9131832 9942306
Compaction free scanned 2093272 2613998
Compaction cost 192 189
NUMA alloc hit 47124555 47193990
NUMA alloc miss 0 0
NUMA interleave hit 0 0
NUMA alloc local 47124555 47193990
NUMA base PTE updates 0 0
NUMA huge PMD updates 0 0
NUMA page range updates 0 0
NUMA hint faults 0 0
NUMA hint local faults 0 0
NUMA hint local percent 100 100
NUMA pages migrated 0 0
AutoNUMA cost 0% 0%
[akpm@linux-foundation.org: remove newline, per Minchan]
Link: http://lkml.kernel.org/r/1500889535-19648-1-git-send-email-zhuhui@xiaomi.com
Signed-off-by: Hui Zhu <zhuhui@xiaomi.com>
Mike reported kernel goes oops with ltp:zram03 testcase.
zram: Added device: zram0
zram0: detected capacity change from 0 to 107374182400
BUG: unable to handle kernel paging request at 0000306d61727a77
IP: zs_map_object+0xb9/0x260
PGD 0
P4D 0
Oops: 0000 [#1] SMP
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in: zram(E) xfs(E) libcrc32c(E) btrfs(E) xor(E) raid6_pq(E) loop(E) ebtable_filter(E) ebtables(E) ip6table_filter(E) ip6_tables(E) iptable_filter(E) ip_tables(E) x_tables(E) af_packet(E) br_netfilter(E) bridge(E) stp(E) llc(E) iscsi_ibft(E) iscsi_boot_sysfs(E) nls_iso8859_1(E) nls_cp437(E) vfat(E) fat(E) intel_powerclamp(E) coretemp(E) cdc_ether(E) kvm_intel(E) usbnet(E) mii(E) kvm(E) irqbypass(E) crct10dif_pclmul(E) crc32_pclmul(E) crc32c_intel(E) iTCO_wdt(E) ghash_clmulni_intel(E) bnx2(E) iTCO_vendor_support(E) pcbc(E) ioatdma(E) ipmi_ssif(E) aesni_intel(E) i5500_temp(E) i2c_i801(E) aes_x86_64(E) lpc_ich(E) shpchp(E) mfd_core(E) crypto_simd(E) i7core_edac(E) dca(E) glue_helper(E) cryptd(E) ipmi_si(E) button(E) acpi_cpufreq(E) ipmi_devintf(E) pcspkr(E) ipmi_msghandler(E)
nfsd(E) auth_rpcgss(E) nfs_acl(E) lockd(E) grace(E) sunrpc(E) ext4(E) crc16(E) mbcache(E) jbd2(E) sd_mod(E) ata_generic(E) i2c_algo_bit(E) ata_piix(E) drm_kms_helper(E) ahci(E) syscopyarea(E) sysfillrect(E) libahci(E) sysimgblt(E) fb_sys_fops(E) uhci_hcd(E) ehci_pci(E) ttm(E) ehci_hcd(E) libata(E) drm(E) megaraid_sas(E) usbcore(E) sg(E) dm_multipath(E) dm_mod(E) scsi_dh_rdac(E) scsi_dh_emc(E) scsi_dh_alua(E) scsi_mod(E) efivarfs(E) autofs4(E) [last unloaded: zram]
CPU: 6 PID: 12356 Comm: swapon Tainted: G E 4.13.0.g87b2c3f-default #194
Hardware name: IBM System x3550 M3 -[7944K3G]-/69Y5698 , BIOS -[D6E150AUS-1.10]- 12/15/2010
task: ffff880158d2c4c0 task.stack: ffffc90001680000
RIP: 0010:zs_map_object+0xb9/0x260
Call Trace:
zram_bvec_rw.isra.26+0xe8/0x780 [zram]
zram_rw_page+0x6e/0xa0 [zram]
bdev_read_page+0x81/0xb0
do_mpage_readpage+0x51a/0x710
mpage_readpages+0x122/0x1a0
blkdev_readpages+0x1d/0x20
__do_page_cache_readahead+0x1b2/0x270
ondemand_readahead+0x180/0x2c0
page_cache_sync_readahead+0x31/0x50
generic_file_read_iter+0x7e7/0xaf0
blkdev_read_iter+0x37/0x40
__vfs_read+0xce/0x140
vfs_read+0x9e/0x150
SyS_read+0x46/0xa0
entry_SYSCALL_64_fastpath+0x1a/0xa5
Code: 81 e6 00 c0 3f 00 81 fe 00 00 16 00 0f 85 9f 01 00 00 0f b7 13 65 ff 05 5e 07 dc 7e 66 c1 ea 02 81 e2 ff 01 00 00 49 8b 54 d4 08 <8b> 4a 48 41 0f af ce 81 e1 ff 0f 00 00 41 89 c9 48 c7 c3 a0 70
RIP: zs_map_object+0xb9/0x260 RSP: ffffc90001683988
CR2: 0000306d61727a77
He bisected the problem is [1].
After commit cf8e0fedf078 ("mm/zsmalloc: simplify zs_max_alloc_size
handling"), zram doesn't use double pointer for pool->size_class any
more in zs_create_pool so counter function zs_destroy_pool don't need to
free it, either.
Otherwise, it does kfree wrong address and then, kernel goes Oops.
Link: http://lkml.kernel.org/r/20170725062650.GA12134@bbox
Fixes: cf8e0fedf078 ("mm/zsmalloc: simplify zs_max_alloc_size handling")
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Mike Galbraith <efault@gmx.de>
Cc: Jerome Marchand <jmarchan@redhat.com>
Commit 40f9fb8cffc6 ("mm/zsmalloc: support allocating obj with size of
ZS_MAX_ALLOC_SIZE") fixes a size calculation error that prevented
zsmalloc to allocate an object of the maximal size (ZS_MAX_ALLOC_SIZE).
I think however the fix is unneededly complicated.
This patch replaces the dynamic calculation of zs_size_classes at init
time by a compile time calculation that uses the DIV_ROUND_UP() macro
already used in get_size_class_index().
[akpm@linux-foundation.org: use min_t]
Link: http://lkml.kernel.org/r/20170630114859.1979-1-jmarchan@redhat.com
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Mahendran Ganesh <opensource.ganesh@gmail.com>
is_first_page() is only called from the macro VM_BUG_ON_PAGE() which is
only compiled in as a runtime check when CONFIG_DEBUG_VM is set,
otherwise is checked at compile time and not actually compiled in.
Fixes the following warning, found with Clang:
mm/zsmalloc.c:472:12: warning: function 'is_first_page' is not needed and will not be emitted [-Wunneeded-internal-declaration]
static int is_first_page(struct page *page)
Link: http://lkml.kernel.org/r/20170524053859.29059-1-nick.desaulniers@gmail.com
Signed-off-by: Nick Desaulniers <nick.desaulniers@gmail.com>
Now 64K page system, zsamlloc has 257 classes so 8 class bit is not
enough. With that, it corrupts the system when zsmalloc stores
65536byte data(ie, index number 256) so that this patch increases class
bit for simple fix for stable backport. We should clean up this mess
soon.
index size
0 32
1 288
204 52256
256 65536
Fixes: 3783689a1 ("zsmalloc: introduce zspage structure")
Link: http://lkml.kernel.org/r/1492042622-12074-3-git-send-email-minchan@kernel.org
<linux/sched/task_stack.h>
Update files that depend on the magic.h inclusion.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The class index and fullness group are not encoded in
(first)page->mapping any more, after commit 3783689a1aa8 ("zsmalloc:
introduce zspage structure"). Instead, they are store in struct zspage.
Just delete this unneeded comment.
Link: http://lkml.kernel.org/r/1486620822-36826-1-git-send-email-xieyisheng1@huawei.com
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Hanjun Guo <guohanjun@huawei.com>
We had used page->lru to link the component pages (except the first
page) of a zspage, and used INIT_LIST_HEAD(&page->lru) to init it.
Therefore, to get the last page's next page, which is NULL, we had to
use page flag PG_Private_2 to identify it.
But now, we use page->freelist to link all of the pages in zspage and
init the page->freelist as NULL for last page, so no need to use
PG_Private_2 anymore.
This remove redundant SetPagePrivate2 in create_page_chain and
ClearPagePrivate2 in reset_page(). Save a few cycles for migration of
zsmalloc page :)
Link: http://lkml.kernel.org/r/1487076509-49270-1-git-send-email-xieyisheng1@huawei.com
Delete extra semicolon, and fix some typos.
Link: http://lkml.kernel.org/r/586F1823.4050107@huawei.com
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Install the callbacks via the state machine and let the core invoke
the callbacks on the already online CPUs.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: linux-mm@kvack.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20161126231350.10321-11-bigeasy@linutronix.de
iput() tests whether its argument is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Link: http://lkml.kernel.org/r/559cf499-4a01-25f9-c87f-24d906626a57@users.sourceforge.net
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Use ClearPagePrivate/ClearPagePrivate2 helpers to clear
PG_private/PG_private_2 in page->flags
Link: http://lkml.kernel.org/r/1467882338-4300-7-git-send-email-opensource.ganesh@gmail.com
Signed-off-by: Ganesh Mahendran <opensource.ganesh@gmail.com>
Add __init,__exit attribute for function that only called in module
init/exit to save memory.
Link: http://lkml.kernel.org/r/1467882338-4300-6-git-send-email-opensource.ganesh@gmail.com
Some minor commebnt changes:
1). update zs_malloc(),zs_create_pool() function header
2). update "Usage of struct page fields"
Link: http://lkml.kernel.org/r/1467882338-4300-5-git-send-email-opensource.ganesh@gmail.com
Currently, if a class can not be merged, the max objects of zspage in
that class may be calculated twice.
This patch calculate max objects of zspage at the begin, and pass the
value to can_merge() to decide whether the class can be merged.
Also this patch remove function get_maxobj_per_zspage(), as there is no
other place to call this function.
Link: http://lkml.kernel.org/r/1467882338-4300-4-git-send-email-opensource.ganesh@gmail.com
num of max objects in zspage is stored in each size_class now. So there
is no need to re-calculate it.
Link: http://lkml.kernel.org/r/1467882338-4300-3-git-send-email-opensource.ganesh@gmail.com
the obj index value should be updated after return from
find_alloced_obj() to avoid CPU burning caused by unnecessary object
scanning.
Link: http://lkml.kernel.org/r/1467882338-4300-2-git-send-email-opensource.ganesh@gmail.com
This is a cleanup patch. Change "index" to "obj_index" to keep
consistent with others in zsmalloc.
Link: http://lkml.kernel.org/r/1467882338-4300-1-git-send-email-opensource.ganesh@gmail.com
Randy reported below build error.
> In file included from ../include/linux/balloon_compaction.h:48:0,
> from ../mm/balloon_compaction.c:11:
> ../include/linux/compaction.h:237:51: warning: 'struct node' declared inside parameter list [enabled by default]
> static inline int compaction_register_node(struct node *node)
> ../include/linux/compaction.h:237:51: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
> ../include/linux/compaction.h:242:54: warning: 'struct node' declared inside parameter list [enabled by default]
> static inline void compaction_unregister_node(struct node *node)
It was caused by non-lru page migration which needs compaction.h but
compaction.h doesn't include any header to be standalone.
I think proper header for non-lru page migration is migrate.h rather
than compaction.h because migrate.h has already headers needed to work
non-lru page migration indirectly like isolate_mode_t, migrate_mode
MIGRATEPAGE_SUCCESS.
[akpm@linux-foundation.org: revert mm-balloon-use-general-non-lru-movable-page-feature-fix.patch temp fix]
Link: http://lkml.kernel.org/r/20160610003304.GE29779@bbox
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Gioh Kim <gi-oh.kim@profitbricks.com>
Cc: Rafael Aquini <aquini@redhat.com>
zram is very popular for some of the embedded world (e.g., TV, mobile
phones). On those system, zsmalloc's consumed memory size is never
trivial (one of example from real product system, total memory: 800M,
zsmalloc consumed: 150M), so we have used this out of tree patch to
monitor system memory behavior via /proc/vmstat.
With zsmalloc in vmstat, it helps in tracking down system behavior due
to memory usage.
[minchan@kernel.org: zsmalloc: follow up zsmalloc vmstat]
Link: http://lkml.kernel.org/r/20160607091737.GC23435@bbox
[akpm@linux-foundation.org: fix build with CONFIG_ZSMALLOC=m]
Link: http://lkml.kernel.org/r/1464919731-13255-1-git-send-email-minchan@kernel.org
Cc: Sangseok Lee <sangseok.lee@lge.com>
Cc: Chanho Min <chanho.min@lge.com>
Cc: Chan Gyun Jeong <chan.jeong@lge.com>
Static check warns using tag as bit shifter. It doesn't break current
working but not good for redability. Let's use OBJ_TAG_BIT as bit
shifter instead of OBJ_ALLOCATED_TAG.
Link: http://lkml.kernel.org/r/20160607045146.GF26230@bbox
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This patch introduces run-time migration feature for zspage.
For migration, VM uses page.lru field so it would be better to not use
page.next field which is unified with page.lru for own purpose. For
that, firstly, we can get first object offset of the page via runtime
calculation instead of using page.index so we can use page.index as link
for page chaining instead of page.next.
In case of huge object, it stores handle to page.index instead of next
link of page chaining because huge object doesn't need to next link for
page chaining. So get_next_page need to identify huge object to return
NULL. For it, this patch uses PG_owner_priv_1 flag of the page flag.
For migration, it supports three functions
* zs_page_isolate
It isolates a zspage which includes a subpage VM want to migrate from
class so anyone cannot allocate new object from the zspage.
We could try to isolate a zspage by the number of subpage so subsequent
isolation trial of other subpage of the zpsage shouldn't fail. For
that, we introduce zspage.isolated count. With that, zs_page_isolate
can know whether zspage is already isolated or not for migration so if
it is isolated for migration, subsequent isolation trial can be
successful without trying further isolation.
* zs_page_migrate
First of all, it holds write-side zspage->lock to prevent migrate other
subpage in zspage. Then, lock all objects in the page VM want to
migrate. The reason we should lock all objects in the page is due to
race between zs_map_object and zs_page_migrate.
zs_map_object zs_page_migrate
pin_tag(handle)
obj = handle_to_obj(handle)
obj_to_location(obj, &page, &obj_idx);
write_lock(&zspage->lock)
if (!trypin_tag(handle))
goto unpin_object
zspage = get_zspage(page);
read_lock(&zspage->lock);
If zs_page_migrate doesn't do trypin_tag, zs_map_object's page can be
stale by migration so it goes crash.
If it locks all of objects successfully, it copies content from old page
to new one, finally, create new zspage chain with new page. And if it's
last isolated subpage in the zspage, put the zspage back to class.
* zs_page_putback
It returns isolated zspage to right fullness_group list if it fails to
migrate a page. If it find a zspage is ZS_EMPTY, it queues zspage
freeing to workqueue. See below about async zspage freeing.
This patch introduces asynchronous zspage free. The reason to need it
is we need page_lock to clear PG_movable but unfortunately, zs_free path
should be atomic so the apporach is try to grab page_lock. If it got
page_lock of all of pages successfully, it can free zspage immediately.
Otherwise, it queues free request and free zspage via workqueue in
process context.
If zs_free finds the zspage is isolated when it try to free zspage, it
delays the freeing until zs_page_putback finds it so it will free free
the zspage finally.
In this patch, we expand fullness_list from ZS_EMPTY to ZS_FULL. First
of all, it will use ZS_EMPTY list for delay freeing. And with adding
ZS_FULL list, it makes to identify whether zspage is isolated or not via
list_empty(&zspage->list) test.
[minchan@kernel.org: zsmalloc: keep first object offset in struct page]
Link: http://lkml.kernel.org/r/1465788015-23195-1-git-send-email-minchan@kernel.org
[minchan@kernel.org: zsmalloc: zspage sanity check]
Link: http://lkml.kernel.org/r/20160603010129.GC3304@bbox
Link: http://lkml.kernel.org/r/1464736881-24886-12-git-send-email-minchan@kernel.org
Zsmalloc stores first free object's <PFN, obj_idx> position into freeobj
in each zspage. If we change it with index from first_page instead of
position, it makes page migration simple because we don't need to
correct other entries for linked list if a page is migrated out.
Link: http://lkml.kernel.org/r/1464736881-24886-11-git-send-email-minchan@kernel.org
Currently, putback_zspage does free zspage under class->lock if fullness
become ZS_EMPTY but it makes trouble to implement locking scheme for new
zspage migration. So, this patch is to separate free_zspage from
putback_zspage and free zspage out of class->lock which is preparation
for zspage migration.
Link: http://lkml.kernel.org/r/1464736881-24886-10-git-send-email-minchan@kernel.org
We have squeezed meta data of zspage into first page's descriptor. So,
to get meta data from subpage, we should get first page first of all.
But it makes trouble to implment page migration feature of zsmalloc
because any place where to get first page from subpage can be raced with
first page migration. IOW, first page it got could be stale. For
preventing it, I have tried several approahces but it made code
complicated so finally, I concluded to separate metadata from first
page. Of course, it consumes more memory. IOW, 16bytes per zspage on
32bit at the moment. It means we lost 1% at *worst case*(40B/4096B)
which is not bad I think at the cost of maintenance.
Link: http://lkml.kernel.org/r/1464736881-24886-9-git-send-email-minchan@kernel.org
For page migration, we need to create page chain of zspage dynamically
so this patch factors it out from alloc_zspage.
Link: http://lkml.kernel.org/r/1464736881-24886-8-git-send-email-minchan@kernel.org
Upcoming patch will change how to encode zspage meta so for easy review,
this patch wraps code to access metadata as accessor.
Link: http://lkml.kernel.org/r/1464736881-24886-7-git-send-email-minchan@kernel.org
Use kernel standard bit spin-lock instead of custom mess. Even, it has
a bug which doesn't disable preemption. The reason we don't have any
problem is that we have used it during preemption disable section by
class->lock spinlock. So no need to go to stable.
Link: http://lkml.kernel.org/r/1464736881-24886-6-git-send-email-minchan@kernel.org
Every zspage in a size_class has same number of max objects so we could
move it to a size_class.
Link: http://lkml.kernel.org/r/1464736881-24886-5-git-send-email-minchan@kernel.org
Some updates to commit d34f615720d1 ("mm/zsmalloc: don't fail if can't
create debugfs info"):
- add pr_warn to all stat failure cases
- do not prevent module loading on stat failure
Link: http://lkml.kernel.org/r/1463671123-5479-1-git-send-email-ddstreet@ieee.org
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Reviewed-by: Ganesh Mahendran <opensource.ganesh@gmail.com>
Cc: Dan Streetman <dan.streetman@canonical.com>
Change the return type of zs_pool_stat_create() to void, and remove the
logic to abort pool creation if the stat debugfs dir/file could not be
created.
The debugfs stat file is for debugging/information only, and doesn't
affect operation of zsmalloc; there is no reason to abort creating the
pool if the stat file can't be created. This was seen with zswap, which
used the same name for all pool creations, which caused zsmalloc to fail
to create a second pool for zswap if CONFIG_ZSMALLOC_STAT was enabled.
Pass GFP flags to zs_malloc() instead of using a fixed mask supplied to
zs_create_pool(), so we can be more flexible, but, more importantly, we
need this to switch zram to per-cpu compression streams -- zram will try
to allocate handle with preemption disabled in a fast path and switch to
a slow path (using different gfp mask) if the fast one has failed.
Apart from that, this also align zs_malloc() interface with zspool/zbud.
[sergey.senozhatsky@gmail.com: pass GFP flags to zs_malloc() instead of using a fixed mask]
Link: http://lkml.kernel.org/r/20160429150942.GA637@swordfish
Let's remove unused pool param in obj_free
Clean up function parameter ordering to order higher data structure
first.
There are many BUG_ON in zsmalloc.c which is not recommened so change
them as alternatives.
Normal rule is as follows:
1. avoid BUG_ON if possible. Instead, use VM_BUG_ON or VM_BUG_ON_PAGE
2. use VM_BUG_ON_PAGE if we need to see struct page's fields
3. use those assertion in primitive functions so higher functions can
rely on the assertion in the primitive function.
4. Don't use assertion if following instruction can trigger Oops
Clean up function parameter "struct page". Many functions of zsmalloc
expect that page paramter is "first_page" so use "first_page" rather
than "page" for code readability.
zs_can_compact() has two race conditions in its core calculation:
unsigned long obj_wasted = zs_stat_get(class, OBJ_ALLOCATED) -
zs_stat_get(class, OBJ_USED);
1) classes are not locked, so the numbers of allocated and used
objects can change by the concurrent ops happening on other CPUs
2) shrinker invokes it from preemptible context
Depending on the circumstances, thus, OBJ_ALLOCATED can become
less than OBJ_USED, which can result in either very high or
negative `total_scan' value calculated later in do_shrink_slab().
do_shrink_slab() has some logic to prevent those cases:
vmscan: shrink_slab: zs_shrinker_scan+0x0/0x28 [zsmalloc] negative objects to delete nr=-62
vmscan: shrink_slab: zs_shrinker_scan+0x0/0x28 [zsmalloc] negative objects to delete nr=-64
However, due to the way `total_scan' is calculated, not every
shrinker->count_objects() overflow can be spotted and handled.
To demonstrate the latter, I added some debugging code to do_shrink_slab()
(x86_64) and the results were:
vmscan: OVERFLOW: shrinker->count_objects() == -1 [18446744073709551615]
vmscan: but total_scan > 0: 92679974445502
vmscan: resulting total_scan: 92679974445502
vmscan: but total_scan > 0: 22634041808232578
vmscan: resulting total_scan: 22634041808232578
Even though shrinker->count_objects() has returned an overflowed value,
the resulting `total_scan' is positive, and, what is more worrisome, it
is insanely huge. This value is getting used later on in
shrinker->scan_objects() loop:
while (total_scan >= batch_size ||
total_scan >= freeable) {
unsigned long ret;
unsigned long nr_to_scan = min(batch_size, total_scan);
shrinkctl->nr_to_scan = nr_to_scan;
ret = shrinker->scan_objects(shrinker, shrinkctl);
if (ret == SHRINK_STOP)
break;
freed += ret;
count_vm_events(SLABS_SCANNED, nr_to_scan);
total_scan -= nr_to_scan;
cond_resched();
`total_scan >= batch_size' is true for a very-very long time and
'total_scan >= freeable' is also true for quite some time, because
`freeable < 0' and `total_scan' is large enough, for example,
22634041808232578. The only break condition, in the given scheme of
things, is shrinker->scan_objects() == SHRINK_STOP test, which is a
bit too weak to rely on, especially in heavy zsmalloc-usage scenarios.
To fix the issue, take a pool stat snapshot and use it instead of
racy zs_stat_get() calls.
Link: http://lkml.kernel.org/r/20160509140052.3389-1-sergey.senozhatsky@gmail.com
Cc: <stable@vger.kernel.org> [4.3+]
Add a new column to pool stats, which will tell how many pages ideally
can be freed by class compaction, so it will be easier to analyze
zsmalloc fragmentation.
At the moment, we have only numbers of FULL and ALMOST_EMPTY classes,
but they don't tell us how badly the class is fragmented internally.
The new /sys/kernel/debug/zsmalloc/zramX/classes output look as follows:
class size almost_full almost_empty obj_allocated obj_used pages_used pages_per_zspage freeable
12 224 0 2 146 5 8 4 4
13 240 0 0 0 0 0 1 0
14 256 1 13 1840 1672 115 1 10
15 272 0 0 0 0 0 1 0
49 816 0 3 745 735 149 1 2
51 848 3 4 361 306 76 4 8
52 864 12 14 378 268 81 3 21
54 896 1 12 117 57 26 2 12
57 944 0 0 0 0 0 3 0
Total 26 131 12709 10994 1071 134
For example, from this particular output we can easily conclude that
class-896 is heavily fragmented -- it occupies 26 pages, 12 can be freed
by compaction.
When unmapping a huge class page in zs_unmap_object, the page will be
unmapped by kmap_atomic. the "!area->huge" branch in __zs_unmap_object
is alway true, and no code set "area->huge" now, so we can drop it.
Signed-off-by: YiPing Xu <xuyiping@huawei.com>
record_obj() in migrate_zspage() does not preserve handle's
HANDLE_PIN_BIT, set by find_aloced_obj()->trypin_tag(), and implicitly
(accidentally) un-pins the handle, while migrate_zspage() still performs
an explicit unpin_tag() on the that handle. This additional explicit
unpin_tag() introduces a race condition with zs_free(), which can pin
that handle by this time, so the handle becomes un-pinned.
Schematically, it goes like this:
CPU0 CPU1
migrate_zspage
find_alloced_obj
trypin_tag
set HANDLE_PIN_BIT zs_free()
pin_tag()
obj_malloc() -- new object, no tag
record_obj() -- remove HANDLE_PIN_BIT set HANDLE_PIN_BIT
unpin_tag() -- remove zs_free's HANDLE_PIN_BIT
The race condition may result in a NULL pointer dereference:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
CPU: 0 PID: 19001 Comm: CookieMonsterCl Tainted:
PC is at get_zspage_mapping+0x0/0x24
LR is at obj_free.isra.22+0x64/0x128
Call trace:
zs_free+0x88/0x114
zram_free_page+0x64/0xcc
zram_slot_free_notify+0x90/0x108
swap_entry_free+0x278/0x294
free_swap_and_cache+0x38/0x11c
unmap_single_vma+0x480/0x5c8
unmap_vmas+0x44/0x60
exit_mmap+0x50/0x110
mmput+0x58/0xe0
do_exit+0x320/0x8dc
do_group_exit+0x44/0xa8
get_signal+0x538/0x580
do_signal+0x98/0x4b8
do_notify_resume+0x14/0x5c
This patch keeps the lock bit in migration path and update value
atomically.
Signed-off-by: Junil Lee <junil0814.lee@lge.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: <stable@vger.kernel.org> [4.1+]
Reoder the pages_per_zspage field in struct size_class which can
eliminate the 4 bytes hole between it and stats field.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
We are going to rework how compound_head() work. It will not use
page->first_page as we have it now.
The only other user of page->first_page beyond compound pages is
zsmalloc.
Let's use page->private instead of page->first_page here. It occupies
the same storage space.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Hocko <mhocko@suse.com>
Each `struct size_class' contains `struct zs_size_stat': an array of
NR_ZS_STAT_TYPE `unsigned long'. For zsmalloc built with no
CONFIG_ZSMALLOC_STAT this results in a waste of `2 * sizeof(unsigned
long)' per-class.
The patch removes unneeded `struct zs_size_stat' members by redefining
NR_ZS_STAT_TYPE (max stat idx in array).
Since both NR_ZS_STAT_TYPE and zs_stat_type are compile time constants,
GCC can eliminate zs_stat_inc()/zs_stat_dec() calls that use zs_stat_type
larger than NR_ZS_STAT_TYPE: CLASS_ALMOST_EMPTY and CLASS_ALMOST_FULL at
the moment.
./scripts/bloat-o-meter mm/zsmalloc.o.old mm/zsmalloc.o.new
add/remove: 0/0 grow/shrink: 0/3 up/down: 0/-39 (-39)
function old new delta
fix_fullness_group 97 94 -3
insert_zspage 100 86 -14
remove_zspage 141 119 -22
To summarize:
a) each class now uses less memory
b) we avoid a number of dec/inc stats (a minor optimization,
but still).
The gain will increase once we introduce additional stats.
A simple IO test.
iozone -t 4 -R -r 32K -s 60M -I +Z
patched base
" Initial write " 4145599.06 4127509.75
" Rewrite " 4146225.94 4223618.50
" Read " 17157606.00 17211329.50
" Re-read " 17380428.00 17267650.50
" Reverse Read " 16742768.00 16162732.75
" Stride read " 16586245.75 16073934.25
" Random read " 16349587.50 15799401.75
" Mixed workload " 10344230.62 9775551.50
" Random write " 4277700.62 4260019.69
" Pwrite " 4302049.12 4313703.88
" Pread " 6164463.16 6126536.72
" Fwrite " 7131195.00 6952586.00
" Fread " 12682602.25 12619207.50
