path: root/mm
2008-07-28vfs: pagecache usage optimization for pagesize!=blocksizeHisashi Hifumi
When we read some part of a file through pagecache, if there is a pagecache of corresponding index but this page is not uptodate, read IO is issued and this page will be uptodate. I think this is good for pagesize == blocksize environment but there is room for improvement on pagesize != blocksize environment. Because in this case a page can have multiple buffers and even if a page is not uptodate, some buffers can be uptodate. So I suggest that when all buffers which correspond to a part of a file that we want to read are uptodate, use this pagecache and copy data from this pagecache to user buffer even if a page is not uptodate. This can reduce read IO and improve system throughput. I wrote a benchmark program and got result number with this program. This benchmark do: 1: mount and open a test file. 2: create a 512MB file. 3: close a file and umount. 4: mount and again open a test file. 5: pwrite randomly 300000 times on a test file. offset is aligned by IO size(1024bytes). 6: measure time of preading randomly 100000 times on a test file. The result was: 2.6.26 330 sec 2.6.26-patched 226 sec Arch:i386 Filesystem:ext3 Blocksize:1024 bytes Memory: 1GB On ext3/4, a file is written through buffer/block. So random read/write mixed workloads or random read after random write workloads are optimized with this patch under pagesize != blocksize environment. This test result showed this. The benchmark program is as follows: #include <stdio.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <unistd.h> #include <time.h> #include <stdlib.h> #include <string.h> #include <sys/mount.h> #define LEN 1024 #define LOOP 1024*512 /* 512MB */ main(void) { unsigned long i, offset, filesize; int fd; char buf[LEN]; time_t t1, t2; if (mount("/dev/sda1", "/root/test1/", "ext3", 0, 0) < 0) { perror("cannot mount\n"); exit(1); } memset(buf, 0, LEN); fd = open("/root/test1/testfile", O_CREAT|O_RDWR|O_TRUNC); if (fd < 0) { perror("cannot open file\n"); exit(1); } for (i = 0; i < LOOP; i++) write(fd, buf, LEN); close(fd); if (umount("/root/test1/") < 0) { perror("cannot umount\n"); exit(1); } if (mount("/dev/sda1", "/root/test1/", "ext3", 0, 0) < 0) { perror("cannot mount\n"); exit(1); } fd = open("/root/test1/testfile", O_RDWR); if (fd < 0) { perror("cannot open file\n"); exit(1); } filesize = LEN * LOOP; for (i = 0; i < 300000; i++){ offset = (random() % filesize) & (~(LEN - 1)); pwrite(fd, buf, LEN, offset); } printf("start test\n"); time(&t1); for (i = 0; i < 100000; i++){ offset = (random() % filesize) & (~(LEN - 1)); pread(fd, buf, LEN, offset); } time(&t2); printf("%ld sec\n", t2-t1); close(fd); if (umount("/root/test1/") < 0) { perror("cannot umount\n"); exit(1); } } Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jan Kara <jack@ucw.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mm/hugetlb.c must #include <asm/io.h>Adrian Bunk
This patch fixes the following build error on sh caused by commit aa888a74977a8f2120ae9332376e179c39a6b07d ("hugetlb: support larger than MAX_ORDER"): mm/hugetlb.c: In function 'alloc_bootmem_huge_page': mm/hugetlb.c:958: error: implicit declaration of function 'virt_to_phys' Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: coreAndrea Arcangeli
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages. There are secondary MMUs (with secondary sptes and secondary tlbs) too. sptes in the kvm case are shadow pagetables, but when I say spte in mmu-notifier context, I mean "secondary pte". In GRU case there's no actual secondary pte and there's only a secondary tlb because the GRU secondary MMU has no knowledge about sptes and every secondary tlb miss event in the MMU always generates a page fault that has to be resolved by the CPU (this is not the case of KVM where the a secondary tlb miss will walk sptes in hardware and it will refill the secondary tlb transparently to software if the corresponding spte is present). The same way zap_page_range has to invalidate the pte before freeing the page, the spte (and secondary tlb) must also be invalidated before any page is freed and reused. Currently we take a page_count pin on every page mapped by sptes, but that means the pages can't be swapped whenever they're mapped by any spte because they're part of the guest working set. Furthermore a spte unmap event can immediately lead to a page to be freed when the pin is released (so requiring the same complex and relatively slow tlb_gather smp safe logic we have in zap_page_range and that can be avoided completely if the spte unmap event doesn't require an unpin of the page previously mapped in the secondary MMU). The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know when the VM is swapping or freeing or doing anything on the primary MMU so that the secondary MMU code can drop sptes before the pages are freed, avoiding all page pinning and allowing 100% reliable swapping of guest physical address space. Furthermore it avoids the code that teardown the mappings of the secondary MMU, to implement a logic like tlb_gather in zap_page_range that would require many IPI to flush other cpu tlbs, for each fixed number of spte unmapped. To make an example: if what happens on the primary MMU is a protection downgrade (from writeable to wrprotect) the secondary MMU mappings will be invalidated, and the next secondary-mmu-page-fault will call get_user_pages and trigger a do_wp_page through get_user_pages if it called get_user_pages with write=1, and it'll re-establishing an updated spte or secondary-tlb-mapping on the copied page. Or it will setup a readonly spte or readonly tlb mapping if it's a guest-read, if it calls get_user_pages with write=0. This is just an example. This allows to map any page pointed by any pte (and in turn visible in the primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an full MMU with both sptes and secondary-tlb like the shadow-pagetable layer with kvm), or a remote DMA in software like XPMEM (hence needing of schedule in XPMEM code to send the invalidate to the remote node, while no need to schedule in kvm/gru as it's an immediate event like invalidating primary-mmu pte). At least for KVM without this patch it's impossible to swap guests reliably. And having this feature and removing the page pin allows several other optimizations that simplify life considerably. Dependencies: 1) mm_take_all_locks() to register the mmu notifier when the whole VM isn't doing anything with "mm". This allows mmu notifier users to keep track if the VM is in the middle of the invalidate_range_begin/end critical section with an atomic counter incraese in range_begin and decreased in range_end. No secondary MMU page fault is allowed to map any spte or secondary tlb reference, while the VM is in the middle of range_begin/end as any page returned by get_user_pages in that critical section could later immediately be freed without any further ->invalidate_page notification (invalidate_range_begin/end works on ranges and ->invalidate_page isn't called immediately before freeing the page). To stop all page freeing and pagetable overwrites the mmap_sem must be taken in write mode and all other anon_vma/i_mmap locks must be taken too. 2) It'd be a waste to add branches in the VM if nobody could possibly run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of mmu notifiers, but this already allows to compile a KVM external module against a kernel with mmu notifiers enabled and from the next pull from kvm.git we'll start using them. And GRU/XPMEM will also be able to continue the development by enabling KVM=m in their config, until they submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n). This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM are all =n. The mmu_notifier_register call can fail because mm_take_all_locks may be interrupted by a signal and return -EINTR. Because mmu_notifier_reigster is used when a driver startup, a failure can be gracefully handled. Here an example of the change applied to kvm to register the mmu notifiers. Usually when a driver startups other allocations are required anyway and -ENOMEM failure paths exists already. struct kvm *kvm_arch_create_vm(void) { struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL); + int err; if (!kvm) return ERR_PTR(-ENOMEM); INIT_LIST_HEAD(&kvm->arch.active_mmu_pages); + kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops; + err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm); + if (err) { + kfree(kvm); + return ERR_PTR(err); + } + return kvm; } mmu_notifier_unregister returns void and it's reliable. The patch also adds a few needed but missing includes that would prevent kernel to compile after these changes on non-x86 archs (x86 didn't need them by luck). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix mm/filemap_xip.c build] [akpm@linux-foundation.org: fix mm/mmu_notifier.c build] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28mmu-notifiers: add mm_take_all_locks() operationAndrea Arcangeli
mm_take_all_locks holds off reclaim from an entire mm_struct. This allows mmu notifiers to register into the mm at any time with the guarantee that no mmu operation is in progress on the mm. This operation locks against the VM for all pte/vma/mm related operations that could ever happen on a certain mm. This includes vmtruncate, try_to_unmap, and all page faults. The caller must take the mmap_sem in write mode before calling mm_take_all_locks(). The caller isn't allowed to release the mmap_sem until mm_drop_all_locks() returns. mmap_sem in write mode is required in order to block all operations that could modify pagetables and free pages without need of altering the vma layout (for example populate_range() with nonlinear vmas). It's also needed in write mode to avoid new anon_vmas to be associated with existing vmas. A single task can't take more than one mm_take_all_locks() in a row or it would deadlock. mm_take_all_locks() and mm_drop_all_locks are expensive operations that may have to take thousand of locks. mm_take_all_locks() can fail if it's interrupted by signals. When mmu_notifier_register returns, we must be sure that the driver is notified if some task is in the middle of a vmtruncate for the 'mm' where the mmu notifier was registered (mmu_notifier_invalidate_range_start/end is run around the vmtruncation but mmu_notifier_register can run after mmu_notifier_invalidate_range_start and before mmu_notifier_invalidate_range_end). Same problem for rmap paths. And we've to remove page pinning to avoid replicating the tlb_gather logic inside KVM (and GRU doesn't work well with page pinning regardless of needing tlb_gather), so without mm_take_all_locks when vmtruncate frees the page, kvm would have no way to notice that it mapped into sptes a page that is going into the freelist without a chance of any further mmu_notifier notification. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28tmpfs: fix kernel BUG in shmem_delete_inodeHugh Dickins
SuSE's insserve initscript ordering program hits kernel BUG at mm/shmem.c:814 on 2.6.26. It's using posix_fadvise on directories, and the shmem_readpage method added in 2.6.23 is letting POSIX_FADV_WILLNEED allocate useless pages to a tmpfs directory, incrementing i_blocks count but never decrementing it. Fix this by assigning shmem_aops (pointing to readpage and writepage and set_page_dirty) only when it's needed, on a regular file or a long symlink. Many thanks to Kel for outstanding bugreport and steps to reproduce it. Reported-by: Kel Modderman <kel@otaku42.de> Tested-by: Kel Modderman <kel@otaku42.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-28stop_machine: Wean existing callers off stop_machine_run()Rusty Russell
2008-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (39 commits) [PATCH] fix RLIM_NOFILE handling [PATCH] get rid of corner case in dup3() entirely [PATCH] remove remaining namei_{32,64}.h crap [PATCH] get rid of indirect users of namei.h [PATCH] get rid of __user_path_lookup_open [PATCH] f_count may wrap around [PATCH] dup3 fix [PATCH] don't pass nameidata to __ncp_lookup_validate() [PATCH] don't pass nameidata to gfs2_lookupi() [PATCH] new (local) helper: user_path_parent() [PATCH] sanitize __user_walk_fd() et.al. [PATCH] preparation to __user_walk_fd cleanup [PATCH] kill nameidata passing to permission(), rename to inode_permission() [PATCH] take noexec checks to very few callers that care Re: [PATCH 3/6] vfs: open_exec cleanup [patch 4/4] vfs: immutable inode checking cleanup [patch 3/4] fat: dont call notify_change [patch 2/4] vfs: utimes cleanup [patch 1/4] vfs: utimes: move owner check into inode_change_ok() [PATCH] vfs: use kstrdup() and check failing allocation ...
2008-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix ip_rt_frag_needed rt_is_expired netfilter: nf_conntrack_extend: avoid unnecessary "ct->ext" dereferences netfilter: fix double-free and use-after free netfilter: arptables in netns for real netfilter: ip{,6}tables_security: fix future section mismatch selinux: use nf_register_hooks() netfilter: ebtables: use nf_register_hooks() Revert "pkt_sched: sch_sfq: dump a real number of flows" qeth: use dev->ml_priv instead of dev->priv syncookies: Make sure ECN is disabled net: drop unused BUG_TRAP() net: convert BUG_TRAP to generic WARN_ON drivers/net: convert BUG_TRAP to generic WARN_ON
2008-07-26mm/util.c must #include <linux/sched.h>Adrian Bunk
mm/util.c: In function 'arch_pick_mmap_layout': mm/util.c:144: error: dereferencing pointer to incomplete type mm/util.c:145: error: 'arch_get_unmapped_area' undeclared (first use in this function) mm/util.c:145: error: (Each undeclared identifier is reported only once mm/util.c:145: error: for each function it appears in.) mm/util.c:146: error: 'arch_unmap_area' undeclared (first use in this function) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[patch 3/5] vfs: change remove_suid() to file_remove_suid()Miklos Szeredi
All calls to remove_suid() are made with a file pointer, because (similarly to file_update_time) it is called when the file is written. Clean up callers by passing in a file instead of a dentry. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26netfilter: fix double-free and use-after freePekka Enberg
As suggested by Patrick McHardy, introduce a __krealloc() that doesn't free the original buffer to fix a double-free and use-after-free bug introduced by me in netfilter that uses RCU. Reported-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Dieter Ries <clip2@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26mm/swapfile.c: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - swap_lock - nr_swapfiles - struct swap_list Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make mm/memory.c:print_bad_pte() staticAdrian Bunk
This patch makes the needlessly global print_bad_pte() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm/allocpercpu.c: make 4 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - percpu_depopulate() - __percpu_depopulate_mask() - percpu_populate() - __percpu_populate_mask() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make mm/sparse.c: make a function staticAdrian Bunk
This patch makes the needlessly global sparse_early_mem_map_alloc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: print swapcache page count in show_swap_cache_info()Johannes Weiner
Every arch implements its own show_mem() function. Most of them share quite some code, some of them are completely identical. This series implements a generic version of this function and migrates almost all architectures to it. This patch: Most show_mem() implementations calculate the amount of pages within the swapcache every time. Move the output to a more appropriate place and use the anyway available total_swapcache_pages variable. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Dike <jdike@addtoit.com> Cc: David S. Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: tracehook_expect_breakpointsRoland McGrath
This adds tracehook_expect_breakpoints() as a formal hook for the nommu code to use for its, "Is text-poking likely?" check at mmap time. This names the actual semantics the code means to test, and documents it. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Use WARN() in mm/vmalloc.cArjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: spinlock tree_lockNick Piggin
mapping->tree_lock has no read lockers. convert the lock from an rwlock to a spinlock. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: lockless pagecacheNick Piggin
Combine page_cache_get_speculative with lockless radix tree lookups to introduce lockless page cache lookups (ie. no mapping->tree_lock on the read-side). The only atomicity changes this introduces is that the gang pagecache lookup functions now behave as if they are implemented with multiple find_get_page calls, rather than operating on a snapshot of the pages. In practice, this atomicity guarantee is not used anyway, and it is to replace individual lookups, so these semantics are natural. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: speculative page referencesNick Piggin
If we can be sure that elevating the page_count on a pagecache page will pin it, we can speculatively run this operation, and subsequently check to see if we hit the right page rather than relying on holding a lock or otherwise pinning a reference to the page. This can be done if get_page/put_page behaves consistently throughout the whole tree (ie. if we "get" the page after it has been used for something else, we must be able to free it with a put_page). Actually, there is a period where the count behaves differently: when the page is free or if it is a constituent page of a compound page. We need an atomic_inc_not_zero operation to ensure we don't try to grab the page in either case. This patch introduces the core locking protocol to the pagecache (ie. adds page_cache_get_speculative, and tweaks some update-side code to make it work). Thanks to Hugh for pointing out an improvement to the algorithm setting page_count to zero when we have control of all references, in order to hold off speculative getters. [kamezawa.hiroyu@jp.fujitsu.com: fix migration_entry_wait()] [hugh@veritas.com: fix add_to_page_cache] [akpm@linux-foundation.org: repair a comment] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm: readahead scan locklessNick Piggin
radix_tree_next_hole() is implemented as a series of radix_tree_lookup()s. So it can be called locklessly, under rcu_read_lock(). Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26x86: lockless get_user_pages_fast()Nick Piggin
Implement get_user_pages_fast without locking in the fastpath on x86. Do an optimistic lockless pagetable walk, without taking mmap_sem or any page table locks or even mmap_sem. Page table existence is guaranteed by turning interrupts off (combined with the fact that we're always looking up the current mm, means we can do the lockless page table walk within the constraints of the TLB shootdown design). Basically we can do this lockless pagetable walk in a similar manner to the way the CPU's pagetable walker does not have to take any locks to find present ptes. This patch (combined with the subsequent ones to convert direct IO to use it) was found to give about 10% performance improvement on a 2 socket 8 core Intel Xeon system running an OLTP workload on DB2 v9.5 "To test the effects of the patch, an OLTP workload was run on an IBM x3850 M2 server with 2 processors (quad-core Intel Xeon processors at 2.93 GHz) using IBM DB2 v9.5 running Linux 2.6.24rc7 kernel. Comparing runs with and without the patch resulted in an overall performance benefit of ~9.8%. Correspondingly, oprofiles showed that samples from __up_read and __down_read routines that is seen during thread contention for system resources was reduced from 2.8% down to .05%. Monitoring the /proc/vmstat output from the patched run showed that the counter for fast_gup contained a very high number while the fast_gup_slow value was zero." (fast_gup is the old name for get_user_pages_fast, fast_gup_slow is a counter we had for the number of times the slowpath was invoked). The main reason for the improvement is that DB2 has multiple threads each issuing direct-IO. Direct-IO uses get_user_pages, and thus the threads contend the mmap_sem cacheline, and can also contend on page table locks. I would anticipate larger performance gains on larger systems, however I think DB2 uses an adaptive mix of threads and processes, so it could be that thread contention remains pretty constant as machine size increases. In which case, we stuck with "only" a 10% gain. The downside of using get_user_pages_fast is that if there is not a pte with the correct permissions for the access, we end up falling back to get_user_pages and so the get_user_pages_fast is a bit of extra work. However this should not be the common case in most performance critical code. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: Kconfig fix] [akpm@linux-foundation.org: Makefile fix/cleanup] [akpm@linux-foundation.org: warning fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Zach Brown <zach.brown@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26hugetlb: fix CONFIG_SYSCTL=n buildNishanth Aravamudan
Fixes a build failure reported by Alan Cox: mm/hugetlb.c: In function `hugetlb_acct_memory': mm/hugetlb.c:1507: error: implicit declaration of function `cpuset_mems_nr' Also reverts Ingo's commit e44d1b2998d62a1f2f4d7eb17b56ba396535509f Author: Ingo Molnar <mingo@elte.hu> Date: Fri Jul 25 12:57:41 2008 +0200 mm/hugetlb.c: fix build failure with !CONFIG_SYSCTL which fixed the build error but added some unused-static-function warnings. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26uninline arch_pick_mmap_layout()Andrew Morton
Fix this, on avr32: include/linux/utsname.h:35, from init/main.c:20: include/linux/sched.h: In function 'arch_pick_mmap_layout': include/linux/sched.h:2149: error: implicit declaration of function 'PAGE_ALIGN' Reported-by: Adrian Bunk <bunk@kernel.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25mm/hugetlb.c: fix build failure with !CONFIG_SYSCTLIngo Molnar
on !CONFIG_SYSCTL on x86 with latest -git i get: mm/hugetlb.c: In function 'decrement_hugepage_resv_vma': mm/hugetlb.c:83: error: 'reserve' undeclared (first use in this function) mm/hugetlb.c:83: error: (Each undeclared identifier is reported only once mm/hugetlb.c:83: error: for each function it appears in.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25per-task-delay-accounting: add memory reclaim delayKeika Kobayashi
Sometimes, application responses become bad under heavy memory load. Applications take a bit time to reclaim memory. The statistics, how long memory reclaim takes, will be useful to measure memory usage. This patch adds accounting memory reclaim to per-task-delay-accounting for accounting the time of do_try_to_free_pages(). <i.e> - When System is under low memory load, memory reclaim may not occur. $ free total used free shared buffers cached Mem: 8197800 1577300 6620500 0 4808 1516724 -/+ buffers/cache: 55768 8142032 Swap: 16386292 0 16386292 $ vmstat 1 procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu---- r b swpd free buff cache si so bi bo in cs us sy id wa 0 0 0 5069748 10612 3014060 0 0 0 0 3 26 0 0 100 0 0 0 0 5069748 10612 3014060 0 0 0 0 4 22 0 0 100 0 0 0 0 5069748 10612 3014060 0 0 0 0 3 18 0 0 100 0 Measure the time of tar command. $ ls -s test.dat 1501472 test.dat $ time tar cvf test.tar test.dat real 0m13.388s user 0m0.116s sys 0m5.304s $ ./delayget -d -p <pid> CPU count real total virtual total delay total 428 5528345500 5477116080 62749891 IO count delay total 338 8078977189 SWAP count delay total 0 0 RECLAIM count delay total 0 0 - When system is under heavy memory load memory reclaim may occur. $ vmstat 1 procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu---- r b swpd free buff cache si so bi bo in cs us sy id wa 0 0 7159032 49724 1812 3012 0 0 0 0 3 24 0 0 100 0 0 0 7159032 49724 1812 3012 0 0 0 0 4 24 0 0 100 0 0 0 7159032 49848 1812 3012 0 0 0 0 3 22 0 0 100 0 In this case, one process uses more 8G memory by execution of malloc() and memset(). $ time tar cvf test.tar test.dat real 1m38.563s <- increased by 85 sec user 0m0.140s sys 0m7.060s $ ./delayget -d -p <pid> CPU count real total virtual total delay total 9021 7140446250 7315277975 923201824 IO count delay total 8965 90466349669 SWAP count delay total 3 21036367 RECLAIM count delay total 740 61011951153 In the later case, the value of RECLAIM is increasing. So, taskstats can show how much memory reclaim influences TAT. Signed-off-by: Keika Kobayashi <kobayashi.kk@ncos.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujistu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: limit change shrink usageKAMEZAWA Hiroyuki
Shrinking memory usage at limit change. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: clean up checking of the disabled flagLi Zefan
Those checks are unnecessary, because when the subsystem is disabled it can't be mounted, so those functions won't get called. The check is needed in functions which will be called in other places except cgroup. [hugh@veritas.com: further checking of disabled flag] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: remove a redundant checkKAMEZAWA Hiroyuki
Because of remove refcnt patch, it's very rare case to that mem_cgroup_charge_common() is called against a page which is accounted. mem_cgroup_charge_common() is called when. 1. a page is added into file cache. 2. an anon page is _newly_ mapped. A racy case is that a newly-swapped-in anonymous page is referred from prural threads in do_swap_page() at the same time. (a page is not Locked when mem_cgroup_charge() is called from do_swap_page.) Another case is shmem. It charges its page before calling add_to_page_cache(). Then, mem_cgroup_charge_cache() is called twice. This case is handled in mem_cgroup_cache_charge(). But this check may be too hacky... Signed-off-by : KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: add hints for branchKAMEZAWA Hiroyuki
Showing brach direction for obvious conditions. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: helper function for relcaim from shmem.KAMEZAWA Hiroyuki
A new call, mem_cgroup_shrink_usage() is added for shmem handling and relacing non-standard usage of mem_cgroup_charge/uncharge. Now, shmem calls mem_cgroup_charge() just for reclaim some pages from mem_cgroup. In general, shmem is used by some process group and not for global resource (like file caches). So, it's reasonable to reclaim pages from mem_cgroup where shmem is mainly used. [hugh@veritas.com: shmem_getpage release page sooner] [hugh@veritas.com: mem_cgroup_shrink_usage css_put] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: remove refcnt from page_cgroupKAMEZAWA Hiroyuki
memcg: performance improvements Patch Description 1/5 ... remove refcnt fron page_cgroup patch (shmem handling is fixed) 2/5 ... swapcache handling patch 3/5 ... add helper function for shmem's memory reclaim patch 4/5 ... optimize by likely/unlikely ppatch 5/5 ... remove redundunt check patch (shmem handling is fixed.) Unix bench result. == 2.6.26-rc2-mm1 + memory resource controller Execl Throughput 2915.4 lps (29.6 secs, 3 samples) C Compiler Throughput 1019.3 lpm (60.0 secs, 3 samples) Shell Scripts (1 concurrent) 5796.0 lpm (60.0 secs, 3 samples) Shell Scripts (8 concurrent) 1097.7 lpm (60.0 secs, 3 samples) Shell Scripts (16 concurrent) 565.3 lpm (60.0 secs, 3 samples) File Read 1024 bufsize 2000 maxblocks 1022128.0 KBps (30.0 secs, 3 samples) File Write 1024 bufsize 2000 maxblocks 544057.0 KBps (30.0 secs, 3 samples) File Copy 1024 bufsize 2000 maxblocks 346481.0 KBps (30.0 secs, 3 samples) File Read 256 bufsize 500 maxblocks 319325.0 KBps (30.0 secs, 3 samples) File Write 256 bufsize 500 maxblocks 148788.0 KBps (30.0 secs, 3 samples) File Copy 256 bufsize 500 maxblocks 99051.0 KBps (30.0 secs, 3 samples) File Read 4096 bufsize 8000 maxblocks 2058917.0 KBps (30.0 secs, 3 samples) File Write 4096 bufsize 8000 maxblocks 1606109.0 KBps (30.0 secs, 3 samples) File Copy 4096 bufsize 8000 maxblocks 854789.0 KBps (30.0 secs, 3 samples) Dc: sqrt(2) to 99 decimal places 126145.2 lpm (30.0 secs, 3 samples) INDEX VALUES TEST BASELINE RESULT INDEX Execl Throughput 43.0 2915.4 678.0 File Copy 1024 bufsize 2000 maxblocks 3960.0 346481.0 875.0 File Copy 256 bufsize 500 maxblocks 1655.0 99051.0 598.5 File Copy 4096 bufsize 8000 maxblocks 5800.0 854789.0 1473.8 Shell Scripts (8 concurrent) 6.0 1097.7 1829.5 ========= FINAL SCORE 991.3 == 2.6.26-rc2-mm1 + this set == Execl Throughput 3012.9 lps (29.9 secs, 3 samples) C Compiler Throughput 981.0 lpm (60.0 secs, 3 samples) Shell Scripts (1 concurrent) 5872.0 lpm (60.0 secs, 3 samples) Shell Scripts (8 concurrent) 1120.3 lpm (60.0 secs, 3 samples) Shell Scripts (16 concurrent) 578.0 lpm (60.0 secs, 3 samples) File Read 1024 bufsize 2000 maxblocks 1003993.0 KBps (30.0 secs, 3 samples) File Write 1024 bufsize 2000 maxblocks 550452.0 KBps (30.0 secs, 3 samples) File Copy 1024 bufsize 2000 maxblocks 347159.0 KBps (30.0 secs, 3 samples) File Read 256 bufsize 500 maxblocks 314644.0 KBps (30.0 secs, 3 samples) File Write 256 bufsize 500 maxblocks 151852.0 KBps (30.0 secs, 3 samples) File Copy 256 bufsize 500 maxblocks 101000.0 KBps (30.0 secs, 3 samples) File Read 4096 bufsize 8000 maxblocks 2033256.0 KBps (30.0 secs, 3 samples) File Write 4096 bufsize 8000 maxblocks 1611814.0 KBps (30.0 secs, 3 samples) File Copy 4096 bufsize 8000 maxblocks 847979.0 KBps (30.0 secs, 3 samples) Dc: sqrt(2) to 99 decimal places 128148.7 lpm (30.0 secs, 3 samples) INDEX VALUES TEST BASELINE RESULT INDEX Execl Throughput 43.0 3012.9 700.7 File Copy 1024 bufsize 2000 maxblocks 3960.0 347159.0 876.7 File Copy 256 bufsize 500 maxblocks 1655.0 101000.0 610.3 File Copy 4096 bufsize 8000 maxblocks 5800.0 847979.0 1462.0 Shell Scripts (8 concurrent) 6.0 1120.3 1867.2 ========= FINAL SCORE 1004.6 This patch: Remove refcnt from page_cgroup(). After this, * A page is charged only when !page_mapped() && no page_cgroup is assigned. * Anon page is newly mapped. * File page is added to mapping->tree. * A page is uncharged only when * Anon page is fully unmapped. * File page is removed from LRU. There is no change in behavior from user's view. This patch also removes unnecessary calls in rmap.c which was used only for refcnt mangement. [akpm@linux-foundation.org: fix warning] [hugh@veritas.com: fix shmem_unuse_inode charging] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: better migration handlingKAMEZAWA Hiroyuki
This patch changes page migration under memory controller to use a different algorithm. (thanks to Christoph for new idea.) Before: - page_cgroup is migrated from an old page to a new page. After: - a new page is accounted , no reuse of page_cgroup. Pros: - We can avoid compliated lock depndencies and races in migration. Cons: - new param to mem_cgroup_charge_common(). - mem_cgroup_getref() is added for handling ref_cnt ping-pong. This version simplifies complicated lock dependency in page migraiton under memory resource controller. new refcnt sequence is following. a mapped page: prepage_migration() ..... +1 to NEW page try_to_unmap() ..... all refs to OLD page is gone. move_pages() ..... +1 to NEW page if page cache. remap... ..... all refs from *map* is added to NEW one. end_migration() ..... -1 to New page. page's mapcount + (page_is_cache) refs are added to NEW one. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: avoid unnecessary initializationKAMEZAWA Hiroyuki
* remove over-killing initialization (in fast path) * makeing the condition for PAGE_CGROUP_FLAG_ACTIVE be more obvious. Signed-off-by: KAMEAZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: make global var read_mostlyKAMEZAWA Hiroyuki
mem_cgroup_subsys and page_cgroup_cache should be read_mostly and MEM_CGROUP_RECLAIM_RETRIES can be just a fixed number. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cgroup files: convert res_counter_write() to be a cgroups write_string() handlerPaul Menage
Currently res_counter_write() is a raw file handler even though it's ultimately taking a number, since in some cases it wants to pre-process the string when converting it to a number. This patch converts res_counter_write() from a raw file handler to a write_string() handler; this allows some of the boilerplate copying/locking/checking to be removed, and simplies the cleanup path, since these functions are now performed by the cgroups framework. [lizf@cn.fujitsu.com: build fix] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: fix race between free buffer and commit transactionMingming Cao
journal_try_to_free_buffers() could race with jbd commit transaction when the later is holding the buffer reference while waiting for the data buffer to flush to disk. If the caller of journal_try_to_free_buffers() request tries hard to release the buffers, it will treat the failure as error and return back to the caller. We have seen the directo IO failed due to this race. Some of the caller of releasepage() also expecting the buffer to be dropped when passed with GFP_KERNEL mask to the releasepage()->journal_try_to_free_buffers(). With this patch, if the caller is passing the __GFP_WAIT and __GFP_FS to indicating this call could wait, in case of try_to_free_buffers() failed, let's waiting for journal_commit_transaction() to finish commit the current committing transaction, then try to free those buffers again. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mingming Cao <cmm@us.ibm.com> Reviewed-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25pdflush: use time_after() instead of open-coding itOGAWA Hirofumi
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: fix ever-decreasing swap priorityHugh Dickins
Vegard Nossum has noticed the ever-decreasing negative priority in a swapon /swapoff loop, which eventually would misprioritize when int wraps positive. Not worth spending much code on, but probably better fixed. It's easy to handle the swapping on and off of just one area, but there's not much point if a pair or more still misbehave. To handle the general case, swapoff should compact negative priorities, keeping them always from -1 to -MAX_SWAPFILES. That's a change, but should cause no regression, since these negative (unspecified) priorities are disjoint from the the positive specified priorities 0 to 32767. One small functional difference, which seems appropriate: when swapoff fails to free all swap from a negative priority area, that area is now reinserted at lowest priority, rather than at its original priority. In moving down swapon's setting of priority, I notice that an area is visible to /proc/swaps when it has swap_map set, yet that was being set before all the visible fields were properly filled in: corrected. Signed-off-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: make CONFIG_MIGRATION available w/o CONFIG_NUMAGerald Schaefer
We'd like to support CONFIG_MEMORY_HOTREMOVE on s390, which depends on CONFIG_MIGRATION. So far, CONFIG_MIGRATION is only available with NUMA support. This patch makes CONFIG_MIGRATION selectable for architectures that define ARCH_ENABLE_MEMORY_HOTREMOVE. When MIGRATION is enabled w/o NUMA, the kernel won't compile because migrate_vmas() does not know about vm_ops->migrate() and vma_migratable() does not know about policy_zone. To fix this, those two functions can be restricted to '#ifdef CONFIG_NUMA' because they are not being used w/o NUMA. vma_migratable() is moved over from migrate.h to mempolicy.h. [kosaki.motohiro@jp.fujitsu.com: build fix] Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: KOSAKI Motorhiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory-hotplug: add sysfs removable attribute for hotplug memory removeBadari Pulavarty
Memory may be hot-removed on a per-memory-block basis, particularly on POWER where the SPARSEMEM section size often matches the memory-block size. A user-level agent must be able to identify which sections of memory are likely to be removable before attempting the potentially expensive operation. This patch adds a file called "removable" to the memory directory in sysfs to help such an agent. In this patch, a memory block is considered removable if; o It contains only MOVABLE pageblocks o It contains only pageblocks with free pages regardless of pageblock type On the other hand, a memory block starting with a PageReserved() page will never be considered removable. Without this patch, the user-agent is forced to choose a memory block to remove randomly. Sample output of the sysfs files: ./memory/memory0/removable: 0 ./memory/memory1/removable: 0 ./memory/memory2/removable: 0 ./memory/memory3/removable: 0 ./memory/memory4/removable: 0 ./memory/memory5/removable: 0 ./memory/memory6/removable: 0 ./memory/memory7/removable: 1 ./memory/memory8/removable: 0 ./memory/memory9/removable: 0 ./memory/memory10/removable: 0 ./memory/memory11/removable: 0 ./memory/memory12/removable: 0 ./memory/memory13/removable: 0 ./memory/memory14/removable: 0 ./memory/memory15/removable: 0 ./memory/memory16/removable: 0 ./memory/memory17/removable: 1 ./memory/memory18/removable: 1 ./memory/memory19/removable: 1 ./memory/memory20/removable: 1 ./memory/memory21/removable: 1 ./memory/memory22/removable: 1 Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory-hotplug: don't calculate vm_total_pages twice when rebuilding ↵Kent Liu
zonelists in online_pages() If zonelist is required to be rebuilt in online_pages(), there is no need to recalculate vm_total_pages in that function, as it has been updated in the call build_all_zonelists(). Signed-off-by: Kent Liu <kent.liu@linux.intel.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory hotplug: small fixes to bootmem freeing for memory hotremoveYasunori Goto
- Change some naming * Magic -> types * MIX_INFO -> MIX_SECTION_INFO * Change definition of bootmem type from direct hex value - __free_pages_bootmem() becomes __meminit. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory hotplug: allocate usemap on the section with pgdatYasunori Goto
Usemaps are allocated on the section which has pgdat by this. Because usemap size is very small, many other sections usemaps are allocated on only one page. If a section has usemap, it can't be removed until removing other sections. This dependency is not desirable for memory removing. Pgdat has similar feature. When a section has pgdat area, it must be the last section for removing on the node. So, if section A has pgdat and section B has usemap for section A, Both sections can't be removed due to dependency each other. To solve this issue, this patch collects usemap on same section with pgdat as much as possible. If other sections doesn't have any dependency, this section will be able to be removed finally. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: David Miller <davem@davemloft.net> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hiroyuki KAMEZAWA <kamezawa.hiroyu@jp.fujitsu.com> Cc: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: remove initialization of static per-cpu variablesVegard Nossum
This was required by some old, no-longer-used gcc on sparc. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: make register_page_bootmem_info_section() staticAdrian Bunk
Make the needlessly global register_page_bootmem_info_section() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm/page_alloc.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global variables static: - required_kernelcore - zone_movable_pfn[] - make the following needlessly global functions static: - move_freepages() - move_freepages_block() - setup_pageset() - find_usable_zone_for_movable() - adjust_zone_range_for_zone_movable() - __absent_pages_in_range() - find_min_pfn_for_node() - find_zone_movable_pfns_for_nodes() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
