path: root/mm
2014-02-22mm/memory-failure.c: move refcount only in !MF_COUNT_INCREASEDNaoya Horiguchi
commit 8d547ff4ac5927245e0833ac18528f939da0ee0e upstream. mce-test detected a test failure when injecting error to a thp tail page. This is because we take page refcount of the tail page in madvise_hwpoison() while the fix in commit a3e0f9e47d5e ("mm/memory-failure.c: transfer page count from head page to tail page after split thp") assumes that we always take refcount on the head page. When a real memory error happens we take refcount on the head page where memory_failure() is called without MF_COUNT_INCREASED set, so it seems to me that testing memory error on thp tail page using madvise makes little sense. This patch cancels moving refcount in !MF_COUNT_INCREASED for valid testing. [akpm@linux-foundation.org: s/&&/&/] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20mm: fix process accidentally killed by mce because of huge page migrationXishi Qiu
Based on c8721bbbdd36382de51cd6b7a56322e0acca2414 upstream, but only the bugfix portion pulled out. Hi Naoya or Greg, We found a bug in 3.10.x. The problem is that we accidentally have a hwpoisoned hugepage in free hugepage list. It could happend in the the following scenario: process A process B migrate_huge_page put_page (old hugepage) linked to free hugepage list hugetlb_fault hugetlb_no_page alloc_huge_page dequeue_huge_page_vma dequeue_huge_page_node (steal hwpoisoned hugepage) set_page_hwpoison_huge_page dequeue_hwpoisoned_huge_page (fail to dequeue) I tested this bug, one process keeps allocating huge page, and I use sysfs interface to soft offline a huge page, then received: "MCE: Killing UCP:2717 due to hardware memory corruption fault at 8200034" Upstream kernel is free from this bug because of these two commits: f15bdfa802bfa5eb6b4b5a241b97ec9fa1204a35 mm/memory-failure.c: fix memory leak in successful soft offlining c8721bbbdd36382de51cd6b7a56322e0acca2414 mm: memory-hotplug: enable memory hotplug to handle hugepage The first one, although the problem is about memory leak, this patch moves unset_migratetype_isolate(), which is important to avoid the race. The latter is not a bug fix and it's too big, so I rewrite a small one. The following patch can fix this bug.(please apply f15bdfa802bf first) Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20mm/memory-failure.c: fix memory leak in successful soft offliningNaoya Horiguchi
commit f15bdfa802bfa5eb6b4b5a241b97ec9fa1204a35 upstream. After a successful page migration by soft offlining, the source page is not properly freed and it's never reusable even if we unpoison it afterward. This is caused by the race between freeing page and setting PG_hwpoison. In successful soft offlining, the source page is put (and the refcount becomes 0) by putback_lru_page() in unmap_and_move(), where it's linked to pagevec and actual freeing back to buddy is delayed. So if PG_hwpoison is set for the page before freeing, the freeing does not functions as expected (in such case freeing aborts in free_pages_prepare() check.) This patch tries to make sure to free the source page before setting PG_hwpoison on it. To avoid reallocating, the page keeps MIGRATE_ISOLATE until after setting PG_hwpoison. This patch also removes obsolete comments about "keeping elevated refcount" because what they say is not true. Unlike memory_failure(), soft_offline_page() uses no special page isolation code, and the soft-offlined pages have no elevated. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20mm: __set_page_dirty_nobuffers() uses spin_lock_irqsave() instead of ↵KOSAKI Motohiro
spin_lock_irq() commit a85d9df1ea1d23682a0ed1e100e6965006595d06 upstream. During aio stress test, we observed the following lockdep warning. This mean AIO+numa_balancing is currently deadlockable. The problem is, aio_migratepage disable interrupt, but __set_page_dirty_nobuffers unintentionally enable it again. Generally, all helper function should use spin_lock_irqsave() instead of spin_lock_irq() because they don't know caller at all. other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&ctx->completion_lock)->rlock); <Interrupt> lock(&(&ctx->completion_lock)->rlock); *** DEADLOCK *** dump_stack+0x19/0x1b print_usage_bug+0x1f7/0x208 mark_lock+0x21d/0x2a0 mark_held_locks+0xb9/0x140 trace_hardirqs_on_caller+0x105/0x1d0 trace_hardirqs_on+0xd/0x10 _raw_spin_unlock_irq+0x2c/0x50 __set_page_dirty_nobuffers+0x8c/0xf0 migrate_page_copy+0x434/0x540 aio_migratepage+0xb1/0x140 move_to_new_page+0x7d/0x230 migrate_pages+0x5e5/0x700 migrate_misplaced_page+0xbc/0xf0 do_numa_page+0x102/0x190 handle_pte_fault+0x241/0x970 handle_mm_fault+0x265/0x370 __do_page_fault+0x172/0x5a0 do_page_fault+0x1a/0x70 page_fault+0x28/0x30 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13mm, oom: base root bonus on current usageDavid Rientjes
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream. A 3% of system memory bonus is sometimes too excessive in comparison to other processes. With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM killer tries to avoid killing privileged tasks by subtracting 3% of overall memory (system or cgroup) from their per-task consumption. But as a result, all root tasks that consume less than 3% of overall memory are considered equal, and so it only takes 33+ privileged tasks pushing the system out of memory for the OOM killer to do something stupid and kill dhclient or other root-owned processes. For example, on a 32G machine it can't tell the difference between the 1M agetty and the 10G fork bomb member. The changelog describes this 3% boost as the equivalent to the global overcommit limit being 3% higher for privileged tasks, but this is not the same as discounting 3% of overall memory from _every privileged task individually_ during OOM selection. Replace the 3% of system memory bonus with a 3% of current memory usage bonus. By giving root tasks a bonus that is proportional to their actual size, they remain comparable even when relatively small. In the example above, the OOM killer will discount the 1M agetty's 256 badness points down to 179, and the 10G fork bomb's 262144 points down to 183500 points and make the right choice, instead of discounting both to 0 and killing agetty because it's first in the task list. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13slub: Fix calculation of cpu slabsLi Zefan
commit 8afb1474db4701d1ab80cd8251137a3260e6913e upstream. /sys/kernel/slab/:t-0000048 # cat cpu_slabs 231 N0=16 N1=215 /sys/kernel/slab/:t-0000048 # cat slabs 145 N0=36 N1=109 See, the number of slabs is smaller than that of cpu slabs. The bug was introduced by commit 49e2258586b423684f03c278149ab46d8f8b6700 ("slub: per cpu cache for partial pages"). We should use page->pages instead of page->pobjects when calculating the number of cpu partial slabs. This also fixes the mapping of slabs and nodes. As there's no variable storing the number of total/active objects in cpu partial slabs, and we don't have user interfaces requiring those statistics, I just add WARN_ON for those cases. Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13mm/page-writeback.c: do not count anon pages as dirtyable memoryJohannes Weiner
commit a1c3bfb2f67ef766de03f1f56bdfff9c8595ab14 upstream. The VM is currently heavily tuned to avoid swapping. Whether that is good or bad is a separate discussion, but as long as the VM won't swap to make room for dirty cache, we can not consider anonymous pages when calculating the amount of dirtyable memory, the baseline to which dirty_background_ratio and dirty_ratio are applied. A simple workload that occupies a significant size (40+%, depending on memory layout, storage speeds etc.) of memory with anon/tmpfs pages and uses the remainder for a streaming writer demonstrates this problem. In that case, the actual cache pages are a small fraction of what is considered dirtyable overall, which results in an relatively large portion of the cache pages to be dirtied. As kswapd starts rotating these, random tasks enter direct reclaim and stall on IO. Only consider free pages and file pages dirtyable. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Tejun Heo <tj@kernel.org> Tested-by: Tejun Heo <tj@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13mm/page-writeback.c: fix dirty_balance_reserve subtraction from dirtyable memoryJohannes Weiner
commit a804552b9a15c931cfc2a92a2e0aed1add8b580a upstream. Tejun reported stuttering and latency spikes on a system where random tasks would enter direct reclaim and get stuck on dirty pages. Around 50% of memory was occupied by tmpfs backed by an SSD, and another disk (rotating) was reading and writing at max speed to shrink a partition. : The problem was pretty ridiculous. It's a 8gig machine w/ one ssd and 10k : rpm harddrive and I could reliably reproduce constant stuttering every : several seconds for as long as buffered IO was going on on the hard drive : either with tmpfs occupying somewhere above 4gig or a test program which : allocates about the same amount of anon memory. Although swap usage was : zero, turning off swap also made the problem go away too. : : The trigger conditions seem quite plausible - high anon memory usage w/ : heavy buffered IO and swap configured - and it's highly likely that this : is happening in the wild too. (this can happen with copying large files : to usb sticks too, right?) This patch (of 2): The dirty_balance_reserve is an approximation of the fraction of free pages that the page allocator does not make available for page cache allocations. As a result, it has to be taken into account when calculating the amount of "dirtyable memory", the baseline to which dirty_background_ratio and dirty_ratio are applied. However, currently the reserve is subtracted from the sum of free and reclaimable pages, which is non-sensical and leads to erroneous results when the system is dominated by unreclaimable pages and the dirty_balance_reserve is bigger than free+reclaimable. In that case, at least the already allocated cache should be considered dirtyable. Fix the calculation by subtracting the reserve from the amount of free pages, then adding the reclaimable pages on top. [akpm@linux-foundation.org: fix CONFIG_HIGHMEM build] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Tejun Heo <tj@kernel.org> Tested-by: Tejun Heo <tj@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13mm/memory-failure.c: shift page lock from head page to tail page after thp splitNaoya Horiguchi
commit 54b9dd14d09f24927285359a227aa363ce46089e upstream. After thp split in hwpoison_user_mappings(), we hold page lock on the raw error page only between try_to_unmap, hence we are in danger of race condition. I found in the RHEL7 MCE-relay testing that we have "bad page" error when a memory error happens on a thp tail page used by qemu-kvm: Triggering MCE exception on CPU 10 mce: [Hardware Error]: Machine check events logged MCE exception done on CPU 10 MCE 0x38c535: Killing qemu-kvm:8418 due to hardware memory corruption MCE 0x38c535: dirty LRU page recovery: Recovered qemu-kvm[8418]: segfault at 20 ip 00007ffb0f0f229a sp 00007fffd6bc5240 error 4 in qemu-kvm[7ffb0ef14000+420000] BUG: Bad page state in process qemu-kvm pfn:38c400 page:ffffea000e310000 count:0 mapcount:0 mapping: (null) index:0x7ffae3c00 page flags: 0x2fffff0008001d(locked|referenced|uptodate|dirty|swapbacked) Modules linked in: hwpoison_inject mce_inject vhost_net macvtap macvlan ... CPU: 0 PID: 8418 Comm: qemu-kvm Tainted: G M -------------- 3.10.0-54.0.1.el7.mce_test_fixed.x86_64 #1 Hardware name: NEC NEC Express5800/R120b-1 [N8100-1719F]/MS-91E7-001, BIOS 4.6.3C19 02/10/2011 Call Trace: dump_stack+0x19/0x1b bad_page.part.59+0xcf/0xe8 free_pages_prepare+0x148/0x160 free_hot_cold_page+0x31/0x140 free_hot_cold_page_list+0x46/0xa0 release_pages+0x1c1/0x200 free_pages_and_swap_cache+0xad/0xd0 tlb_flush_mmu.part.46+0x4c/0x90 tlb_finish_mmu+0x55/0x60 exit_mmap+0xcb/0x170 mmput+0x67/0xf0 vhost_dev_cleanup+0x231/0x260 [vhost_net] vhost_net_release+0x3f/0x90 [vhost_net] __fput+0xe9/0x270 ____fput+0xe/0x10 task_work_run+0xc4/0xe0 do_exit+0x2bb/0xa40 do_group_exit+0x3f/0xa0 get_signal_to_deliver+0x1d0/0x6e0 do_signal+0x48/0x5e0 do_notify_resume+0x71/0xc0 retint_signal+0x48/0x8c The reason of this bug is that a page fault happens before unlocking the head page at the end of memory_failure(). This strange page fault is trying to access to address 0x20 and I'm not sure why qemu-kvm does this, but anyway as a result the SIGSEGV makes qemu-kvm exit and on the way we catch the bad page bug/warning because we try to free a locked page (which was the former head page.) To fix this, this patch suggests to shift page lock from head page to tail page just after thp split. SIGSEGV still happens, but it affects only error affected VMs, not a whole system. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06mm/mempolicy.c: fix mempolicy printing in numa_mapsDavid Rientjes
commit 8790c71a18e5d2d93532ae250bcf5eddbba729cd upstream. As a result of commit 5606e3877ad8 ("mm: numa: Migrate on reference policy"), /proc/<pid>/numa_maps prints the mempolicy for any <pid> as "prefer:N" for the local node, N, of the process reading the file. This should only be printed when the mempolicy of <pid> is MPOL_PREFERRED for node N. If the process is actually only using the default mempolicy for local node allocation, make sure "default" is printed as expected. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Robert Lippert <rlippert@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06mm: hugetlbfs: fix hugetlbfs optimizationAndrea Arcangeli
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream. Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database caused by THP") can cause dereference of a dangling pointer if split_huge_page runs during PageHuge() if there are updates to the tail_page->private field. Also it is repeating compound_head twice for hugetlbfs and it is running compound_head+compound_trans_head for THP when a single one is needed in both cases. The new code within the PageSlab() check doesn't need to verify that the THP page size is never bigger than the smallest hugetlbfs page size, to avoid memory corruption. A longstanding theoretical race condition was found while fixing the above (see the change right after the skip_unlock label, that is relevant for the compound_lock path too). By re-establishing the _mapcount tail refcounting for all compound pages, this also fixes the below problem: echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages BUG: Bad page state in process bash pfn:59a01 page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0 page flags: 0x1c00000000008000(tail) Modules linked in: CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x55/0x76 bad_page+0xd5/0x130 free_pages_prepare+0x213/0x280 __free_pages+0x36/0x80 update_and_free_page+0xc1/0xd0 free_pool_huge_page+0xc2/0xe0 set_max_huge_pages.part.58+0x14c/0x220 nr_hugepages_store_common.isra.60+0xd0/0xf0 nr_hugepages_store+0x13/0x20 kobj_attr_store+0xf/0x20 sysfs_write_file+0x189/0x1e0 vfs_write+0xc5/0x1f0 SyS_write+0x55/0xb0 system_call_fastpath+0x16/0x1b Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Khalid Aziz <khalid.aziz@oracle.com> Cc: Pravin Shelar <pshelar@nicira.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Christoph Lameter <cl@linux.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guillaume Morin <guillaume@morinfr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-25thp: fix copy_page_rep GPF by testing is_huge_zero_pmd once onlyHugh Dickins
commit eecc1e426d681351a6026a7d3e7d225f38955b6c upstream. We see General Protection Fault on RSI in copy_page_rep: that RSI is what you get from a NULL struct page pointer. RIP: 0010:[<ffffffff81154955>] [<ffffffff81154955>] copy_page_rep+0x5/0x10 RSP: 0000:ffff880136e15c00 EFLAGS: 00010286 RAX: ffff880000000000 RBX: ffff880136e14000 RCX: 0000000000000200 RDX: 6db6db6db6db6db7 RSI: db73880000000000 RDI: ffff880dd0c00000 RBP: ffff880136e15c18 R08: 0000000000000200 R09: 000000000005987c R10: 000000000005987c R11: 0000000000000200 R12: 0000000000000001 R13: ffffea00305aa000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f195752f700(0000) GS:ffff880c7fc20000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000093010000 CR3: 00000001458e1000 CR4: 00000000000027e0 Call Trace: copy_user_huge_page+0x93/0xab do_huge_pmd_wp_page+0x710/0x815 handle_mm_fault+0x15d8/0x1d70 __do_page_fault+0x14d/0x840 do_page_fault+0x2f/0x90 page_fault+0x22/0x30 do_huge_pmd_wp_page() tests is_huge_zero_pmd(orig_pmd) four times: but since shrink_huge_zero_page() can free the huge_zero_page, and we have no hold of our own on it here (except where the fourth test holds page_table_lock and has checked pmd_same), it's possible for it to answer yes the first time, but no to the second or third test. Change all those last three to tests for NULL page. (Note: this is not the same issue as trinity's DEBUG_PAGEALLOC BUG in copy_page_rep with RSI: ffff88009c422000, reported by Sasha Levin in https://lkml.org/lkml/2013/3/29/103. I believe that one is due to the source page being split, and a tail page freed, while copy is in progress; and not a problem without DEBUG_PAGEALLOC, since the pmd_same check will prevent a miscopy from being made visible.) Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page") Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-25mm/memory-failure.c: recheck PageHuge() after hugetlb page migrate successfullyJianguo Wu
commit a49ecbcd7b0d5a1cda7d60e03df402dd0ef76ac8 upstream. After a successful hugetlb page migration by soft offline, the source page will either be freed into hugepage_freelists or buddy(over-commit page). If page is in buddy, page_hstate(page) will be NULL. It will hit a NULL pointer dereference in dequeue_hwpoisoned_huge_page(). BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff81163761>] dequeue_hwpoisoned_huge_page+0x131/0x1d0 PGD c23762067 PUD c24be2067 PMD 0 Oops: 0000 [#1] SMP So check PageHuge(page) after call migrate_pages() successfully. [wujg: backport to 3.10: - adjust context] Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09memcg: fix memcg_size() calculationVladimir Davydov
commit 695c60830764945cf61a2cc623eb1392d137223e upstream. The mem_cgroup structure contains nr_node_ids pointers to mem_cgroup_per_node objects, not the objects themselves. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Glauber Costa <glommer@openvz.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm/memory-failure.c: transfer page count from head page to tail page after ↵Naoya Horiguchi
split thp commit a3e0f9e47d5ef7858a26cc12d90ad5146e802d47 upstream. Memory failures on thp tail pages cause kernel panic like below: mce: [Hardware Error]: Machine check events logged MCE exception done on CPU 7 BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff811b7cd1>] dequeue_hwpoisoned_huge_page+0x131/0x1e0 PGD bae42067 PUD ba47d067 PMD 0 Oops: 0000 [#1] SMP ... CPU: 7 PID: 128 Comm: kworker/7:2 Tainted: G M O 3.13.0-rc4-131217-1558-00003-g83b7df08e462 #25 ... Call Trace: me_huge_page+0x3e/0x50 memory_failure+0x4bb/0xc20 mce_process_work+0x3e/0x70 process_one_work+0x171/0x420 worker_thread+0x11b/0x3a0 ? manage_workers.isra.25+0x2b0/0x2b0 kthread+0xe4/0x100 ? kthread_create_on_node+0x190/0x190 ret_from_fork+0x7c/0xb0 ? kthread_create_on_node+0x190/0x190 ... RIP dequeue_hwpoisoned_huge_page+0x131/0x1e0 CR2: 0000000000000058 The reasoning of this problem is shown below: - when we have a memory error on a thp tail page, the memory error handler grabs a refcount of the head page to keep the thp under us. - Before unmapping the error page from processes, we split the thp, where page refcounts of both of head/tail pages don't change. - Then we call try_to_unmap() over the error page (which was a tail page before). We didn't pin the error page to handle the memory error, this error page is freed and removed from LRU list. - We never have the error page on LRU list, so the first page state check returns "unknown page," then we move to the second check with the saved page flag. - The saved page flag have PG_tail set, so the second page state check returns "hugepage." - We call me_huge_page() for freed error page, then we hit the above panic. The root cause is that we didn't move refcount from the head page to the tail page after split thp. So this patch suggests to do this. This panic was introduced by commit 524fca1e73 ("HWPOISON: fix misjudgement of page_action() for errors on mlocked pages"). Note that we did have the same refcount problem before this commit, but it was just ignored because we had only first page state check which returned "unknown page." The commit changed the refcount problem from "doesn't work" to "kernel panic." Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: fix use-after-free in sys_remap_file_pagesRik van Riel
commit 4eb919825e6c3c7fb3630d5621f6d11e98a18b3a upstream. remap_file_pages calls mmap_region, which may merge the VMA with other existing VMAs, and free "vma". This can lead to a use-after-free bug. Avoid the bug by remembering vm_flags before calling mmap_region, and not trying to dereference vma later. Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: PaX Team <pageexec@freemail.hu> Cc: Kees Cook <keescook@chromium.org> Cc: Michel Lespinasse <walken@google.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm/hugetlb: check for pte NULL pointer in __page_check_address()Jianguo Wu
commit 98398c32f6687ee1e1f3ae084effb4b75adb0747 upstream. In __page_check_address(), if address's pud is not present, huge_pte_offset() will return NULL, we should check the return value. Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: qiuxishi <qiuxishi@huawei.com> Cc: Hanjun Guo <guohanjun@huawei.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm/compaction: respect ignore_skip_hint in update_pageblock_skipJoonsoo Kim
commit 6815bf3f233e0b10c99a758497d5d236063b010b upstream. update_pageblock_skip() only fits to compaction which tries to isolate by pageblock unit. If isolate_migratepages_range() is called by CMA, it try to isolate regardless of pageblock unit and it don't reference get_pageblock_skip() by ignore_skip_hint. We should also respect it on update_pageblock_skip() to prevent from setting the wrong information. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: fix TLB flush race between migration, and change_protection_rangeRik van Riel
commit 20841405940e7be0617612d521e206e4b6b325db upstream. There are a few subtle races, between change_protection_range (used by mprotect and change_prot_numa) on one side, and NUMA page migration and compaction on the other side. The basic race is that there is a time window between when the PTE gets made non-present (PROT_NONE or NUMA), and the TLB is flushed. During that time, a CPU may continue writing to the page. This is fine most of the time, however compaction or the NUMA migration code may come in, and migrate the page away. When that happens, the CPU may continue writing, through the cached translation, to what is no longer the current memory location of the process. This only affects x86, which has a somewhat optimistic pte_accessible. All other architectures appear to be safe, and will either always flush, or flush whenever there is a valid mapping, even with no permissions (SPARC). The basic race looks like this: CPU A CPU B CPU C load TLB entry make entry PTE/PMD_NUMA fault on entry read/write old page start migrating page change PTE/PMD to new page read/write old page [*] flush TLB reload TLB from new entry read/write new page lose data [*] the old page may belong to a new user at this point! The obvious fix is to flush remote TLB entries, by making sure that pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may still be accessible if there is a TLB flush pending for the mm. This should fix both NUMA migration and compaction. [mgorman@suse.de: fix build] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: numa: avoid unnecessary work on the failure pathMel Gorman
commit eb4489f69f224356193364dc2762aa009738ca7f upstream. If a PMD changes during a THP migration then migration aborts but the failure path is doing more work than is necessary. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: numa: ensure anon_vma is locked to prevent parallel THP splitsMel Gorman
commit c3a489cac38d43ea6dc4ac240473b44b46deecf7 upstream. The anon_vma lock prevents parallel THP splits and any associated complexity that arises when handling splits during THP migration. This patch checks if the lock was successfully acquired and bails from THP migration if it failed for any reason. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09mm: clear pmd_numa before invalidatingMel Gorman
commit 67f87463d3a3362424efcbe8b40e4772fd34fc61 upstream. On x86, PMD entries are similar to _PAGE_PROTNONE protection and are handled as NUMA hinting faults. The following two page table protection bits are what defines them _PAGE_NUMA:set _PAGE_PRESENT:clear A PMD is considered present if any of the _PAGE_PRESENT, _PAGE_PROTNONE, _PAGE_PSE or _PAGE_NUMA bits are set. If pmdp_invalidate encounters a pmd_numa, it clears the present bit leaving _PAGE_NUMA which will be considered not present by the CPU but present by pmd_present. The existing caller of pmdp_invalidate should handle it but it's an inconsistent state for a PMD. This patch keeps the state consistent when calling pmdp_invalidate. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08mm: numa: return the number of base pages altered by protection changesMel Gorman
commit 72403b4a0fbdf433c1fe0127e49864658f6f6468 upstream. Commit 0255d4918480 ("mm: Account for a THP NUMA hinting update as one PTE update") was added to account for the number of PTE updates when marking pages prot_numa. task_numa_work was using the old return value to track how much address space had been updated. Altering the return value causes the scanner to do more work than it is configured or documented to in a single unit of work. This patch reverts that commit and accounts for the number of THP updates separately in vmstat. It is up to the administrator to interpret the pair of values correctly. This is a straight-forward operation and likely to only be of interest when actively debugging NUMA balancing problems. The impact of this patch is that the NUMA PTE scanner will scan slower when THP is enabled and workloads may converge slower as a result. On the flip size system CPU usage should be lower than recent tests reported. This is an illustrative example of a short single JVM specjbb test specjbb 3.12.0 3.12.0 vanilla acctupdates TPut 1 26143.00 ( 0.00%) 25747.00 ( -1.51%) TPut 7 185257.00 ( 0.00%) 183202.00 ( -1.11%) TPut 13 329760.00 ( 0.00%) 346577.00 ( 5.10%) TPut 19 442502.00 ( 0.00%) 460146.00 ( 3.99%) TPut 25 540634.00 ( 0.00%) 549053.00 ( 1.56%) TPut 31 512098.00 ( 0.00%) 519611.00 ( 1.47%) TPut 37 461276.00 ( 0.00%) 474973.00 ( 2.97%) TPut 43 403089.00 ( 0.00%) 414172.00 ( 2.75%) 3.12.0 3.12.0 vanillaacctupdates User 5169.64 5184.14 System 100.45 80.02 Elapsed 252.75 251.85 Performance is similar but note the reduction in system CPU time. While this showed a performance gain, it will not be universal but at least it'll be behaving as documented. The vmstats are obviously different but here is an obvious interpretation of them from mmtests. 3.12.0 3.12.0 vanillaacctupdates NUMA page range updates 1408326 11043064 NUMA huge PMD updates 0 21040 NUMA PTE updates 1408326 291624 "NUMA page range updates" == nr_pte_updates and is the value returned to the NUMA pte scanner. NUMA huge PMD updates were the number of THP updates which in combination can be used to calculate how many ptes were updated from userspace. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Alex Thorlton <athorlton@sgi.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04mm: ensure get_unmapped_area() returns higher address than mmap_min_addrAkira Takeuchi
commit 2afc745f3e3079ab16c826be4860da2529054dd2 upstream. This patch fixes the problem that get_unmapped_area() can return illegal address and result in failing mmap(2) etc. In case that the address higher than PAGE_SIZE is set to /proc/sys/vm/mmap_min_addr, the address lower than mmap_min_addr can be returned by get_unmapped_area(), even if you do not pass any virtual address hint (i.e. the second argument). This is because the current get_unmapped_area() code does not take into account mmap_min_addr. This leads to two actual problems as follows: 1. mmap(2) can fail with EPERM on the process without CAP_SYS_RAWIO, although any illegal parameter is not passed. 2. The bottom-up search path after the top-down search might not work in arch_get_unmapped_area_topdown(). Note: The first and third chunk of my patch, which changes "len" check, are for more precise check using mmap_min_addr, and not for solving the above problem. [How to reproduce] --- test.c ------------------------------------------------- #include <stdio.h> #include <unistd.h> #include <sys/mman.h> #include <sys/errno.h> int main(int argc, char *argv[]) { void *ret = NULL, *last_map; size_t pagesize = sysconf(_SC_PAGESIZE); do { last_map = ret; ret = mmap(0, pagesize, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0); // printf("ret=%p\n", ret); } while (ret != MAP_FAILED); if (errno != ENOMEM) { printf("ERR: unexpected errno: %d (last map=%p)\n", errno, last_map); } return 0; } --------------------------------------------------------------- $ gcc -m32 -o test test.c $ sudo sysctl -w vm.mmap_min_addr=65536 vm.mmap_min_addr = 65536 $ ./test (run as non-priviledge user) ERR: unexpected errno: 1 (last map=0x10000) Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29slub: Handle NULL parameter in kmem_cache_flagsChristoph Lameter
commit c6f58d9b362b45c52afebe4342c9137d0dabe47f upstream. Andreas Herrmann writes: When I've used slub_debug kernel option (e.g. "slub_debug=,skbuff_fclone_cache" or similar) on a debug session I've seen a panic like: Highbank #setenv bootargs console=ttyAMA0 root=/dev/sda2 kgdboc.kgdboc=ttyAMA0,115200 slub_debug=,kmalloc-4096 earlyprintk=ttyAMA0 ... Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = c0004000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] SMP ARM Modules linked in: CPU: 0 PID: 0 Comm: swapper Tainted: G W 3.12.0-00048-gbe408cd #314 task: c0898360 ti: c088a000 task.ti: c088a000 PC is at strncmp+0x1c/0x84 LR is at kmem_cache_flags.isra.46.part.47+0x44/0x60 pc : [<c02c6da0>] lr : [<c0110a3c>] psr: 200001d3 sp : c088bea8 ip : c088beb8 fp : c088beb4 r10: 00000000 r9 : 413fc090 r8 : 00000001 r7 : 00000000 r6 : c2984a08 r5 : c0966e78 r4 : 00000000 r3 : 0000006b r2 : 0000000c r1 : 00000000 r0 : c2984a08 Flags: nzCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 0000404a DAC: 00000015 Process swapper (pid: 0, stack limit = 0xc088a248) Stack: (0xc088bea8 to 0xc088c000) bea0: c088bed4 c088beb8 c0110a3c c02c6d90 c0966e78 00000040 bec0: ef001f00 00000040 c088bf14 c088bed8 c0112070 c0110a04 00000005 c010fac8 bee0: c088bf5c c088bef0 c010fac8 ef001f00 00000040 00000000 00000040 00000001 bf00: 413fc090 00000000 c088bf34 c088bf18 c0839190 c0112040 00000000 ef001f00 bf20: 00000000 00000000 c088bf54 c088bf38 c0839200 c083914c 00000006 c0961c4c bf40: c0961c28 00000000 c088bf7c c088bf58 c08392ac c08391c0 c08a2ed8 c0966e78 bf60: c086b874 c08a3f50 c0961c28 00000001 c088bfb4 c088bf80 c083b258 c0839248 bf80: 2f800000 0f000000 c08935b4 ffffffff c08cd400 ffffffff c08cd400 c0868408 bfa0: c29849c0 00000000 c088bff4 c088bfb8 c0824974 c083b1e4 ffffffff ffffffff bfc0: c08245c0 00000000 00000000 c0868408 00000000 10c5387d c0892bcc c0868404 bfe0: c0899440 0000406a 00000000 c088bff8 00008074 c0824824 00000000 00000000 [<c02c6da0>] (strncmp+0x1c/0x84) from [<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60) [<c0110a3c>] (kmem_cache_flags.isra.46.part.47+0x44/0x60) from [<c0112070>] (__kmem_cache_create+0x3c/0x410) [<c0112070>] (__kmem_cache_create+0x3c/0x410) from [<c0839190>] (create_boot_cache+0x50/0x74) [<c0839190>] (create_boot_cache+0x50/0x74) from [<c0839200>] (create_kmalloc_cache+0x4c/0x88) [<c0839200>] (create_kmalloc_cache+0x4c/0x88) from [<c08392ac>] (create_kmalloc_caches+0x70/0x114) [<c08392ac>] (create_kmalloc_caches+0x70/0x114) from [<c083b258>] (kmem_cache_init+0x80/0xe0) [<c083b258>] (kmem_cache_init+0x80/0xe0) from [<c0824974>] (start_kernel+0x15c/0x318) [<c0824974>] (start_kernel+0x15c/0x318) from [<00008074>] (0x8074) Code: e3520000 01a00002 089da800 e5d03000 (e5d1c000) ---[ end trace 1b75b31a2719ed1d ]--- Kernel panic - not syncing: Fatal exception Problem is that slub_debug option is not parsed before create_boot_cache is called. Solve this by changing slub_debug to early_param. Kernels 3.11, 3.10 are also affected. I am not sure about older kernels. Christoph Lameter explains: kmem_cache_flags may be called with NULL parameter during early boot. Skip the test in that case. Reported-by: Andreas Herrmann <andreas.herrmann@calxeda.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm/vmalloc.c: fix an overflow bug in alloc_vmap_area()Zhang Yanfei
commit bcb615a81b1765864c71c50afb56631e7a1e5283 upstream. When searching a vmap area in the vmalloc space, we use (addr + size - 1) to check if the value is less than addr, which is an overflow. But we assign (addr + size) to vmap_area->va_end. So if we come across the below case: (addr + size - 1) : not overflow (addr + size) : overflow we will assign an overflow value (e.g 0) to vmap_area->va_end, And this will trigger BUG in __insert_vmap_area, causing system panic. So using (addr + size) to check the overflow should be the correct behaviour, not (addr + size - 1). Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Reported-by: Ghennadi Procopciuc <unix140@gmail.com> Tested-by: Daniel Baluta <dbaluta@ixiacom.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Anatoly Muliarski <x86ever@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm/pagewalk.c: fix walk_page_range() access of wrong PTEsChen LinX
commit 3017f079efd6af199b0852b5c425364513db460e upstream. When walk_page_range walk a memory map's page tables, it'll skip VM_PFNMAP area, then variable 'next' will to assign to vma->vm_end, it maybe larger than 'end'. In next loop, 'addr' will be larger than 'next'. Then in /proc/XXXX/pagemap file reading procedure, the 'addr' will growing forever in pagemap_pte_range, pte_to_pagemap_entry will access the wrong pte. BUG: Bad page map in process procrank pte:8437526f pmd:785de067 addr:9108d000 vm_flags:00200073 anon_vma:f0d99020 mapping: (null) index:9108d CPU: 1 PID: 4974 Comm: procrank Tainted: G B W O 3.10.1+ #1 Call Trace: dump_stack+0x16/0x18 print_bad_pte+0x114/0x1b0 vm_normal_page+0x56/0x60 pagemap_pte_range+0x17a/0x1d0 walk_page_range+0x19e/0x2c0 pagemap_read+0x16e/0x200 vfs_read+0x84/0x150 SyS_read+0x4a/0x80 syscall_call+0x7/0xb Signed-off-by: Liu ShuoX <shuox.liu@intel.com> Signed-off-by: Chen LinX <linx.z.chen@intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: Account for a THP NUMA hinting update as one PTE updateMel Gorman
commit 0255d491848032f6c601b6410c3b8ebded3a37b1 upstream. A THP PMD update is accounted for as 512 pages updated in vmstat. This is large difference when estimating the cost of automatic NUMA balancing and can be misleading when comparing results that had collapsed versus split THP. This patch addresses the accounting issue. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-10-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: Close races between THP migration and PMD numa clearingMel Gorman
commit 3f926ab945b60a5824369d21add7710622a2eac0 upstream. THP migration uses the page lock to guard against parallel allocations but there are cases like this still open Task A Task B --------------------- --------------------- do_huge_pmd_numa_page do_huge_pmd_numa_page lock_page mpol_misplaced == -1 unlock_page goto clear_pmdnuma lock_page mpol_misplaced == 2 migrate_misplaced_transhuge pmd = pmd_mknonnuma set_pmd_at During hours of testing, one crashed with weird errors and while I have no direct evidence, I suspect something like the race above happened. This patch extends the page lock to being held until the pmd_numa is cleared to prevent migration starting in parallel while the pmd_numa is being cleared. It also flushes the old pmd entry and orders pagetable insertion before rmap insertion. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-9-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: numa: Sanitize task_numa_fault() callsitesMel Gorman
commit c61109e34f60f6e85bb43c5a1cd51c0e3db40847 upstream. There are three callers of task_numa_fault(): - do_huge_pmd_numa_page(): Accounts against the current node, not the node where the page resides, unless we migrated, in which case it accounts against the node we migrated to. - do_numa_page(): Accounts against the current node, not the node where the page resides, unless we migrated, in which case it accounts against the node we migrated to. - do_pmd_numa_page(): Accounts not at all when the page isn't migrated, otherwise accounts against the node we migrated towards. This seems wrong to me; all three sites should have the same sementaics, furthermore we should accounts against where the page really is, we already know where the task is. So modify all three sites to always account; we did after all receive the fault; and always account to where the page is after migration, regardless of success. They all still differ on when they clear the PTE/PMD; ideally that would get sorted too. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-8-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: Prevent parallel splits during THP migrationMel Gorman
commit 587fe586f44a48f9691001ba6c45b86c8e4ba21f upstream. THP migrations are serialised by the page lock but on its own that does not prevent THP splits. If the page is split during THP migration then the pmd_same checks will prevent page table corruption but the unlock page and other fix-ups potentially will cause corruption. This patch takes the anon_vma lock to prevent parallel splits during migration. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-7-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: Wait for THP migrations to complete during NUMA hinting faultsMel Gorman
commit 42836f5f8baa33085f547098b74aa98991ee9216 upstream. The locking for migrating THP is unusual. While normal page migration prevents parallel accesses using a migration PTE, THP migration relies on a combination of the page_table_lock, the page lock and the existance of the NUMA hinting PTE to guarantee safety but there is a bug in the scheme. If a THP page is currently being migrated and another thread traps a fault on the same page it checks if the page is misplaced. If it is not, then pmd_numa is cleared. The problem is that it checks if the page is misplaced without holding the page lock meaning that the racing thread can be migrating the THP when the second thread clears the NUMA bit and faults a stale page. This patch checks if the page is potentially being migrated and stalls using the lock_page if it is potentially being migrated before checking if the page is misplaced or not. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-6-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: numa: Do not account for a hinting fault if we racedMel Gorman
commit 1dd49bfa3465756b3ce72214b58a33e4afb67aa3 upstream. If another task handled a hinting fault in parallel then do not double account for it. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1381141781-10992-5-git-send-email-mgorman@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13mm: make generic_access_phys available for modulesUwe Kleine-König
commit 5a73633ef01cd8772defa6a3c34a588376a1df4c upstream. In the next commit this function will be used in the uio subsystem Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04writeback: fix negative bdi max pauseFengguang Wu
commit e3b6c655b91e01a1dade056cfa358581b47a5351 upstream. Toralf runs trinity on UML/i386. After some time it hangs and the last message line is BUG: soft lockup - CPU#0 stuck for 22s! [trinity-child0:1521] It's found that pages_dirtied becomes very large. More than 1000000000 pages in this case: period = HZ * pages_dirtied / task_ratelimit; BUG_ON(pages_dirtied > 2000000000); BUG_ON(pages_dirtied > 1000000000); <--------- UML debug printf shows that we got negative pause here: ick: pause : -984 ick: pages_dirtied : 0 ick: task_ratelimit: 0 pause: + if (pause < 0) { + extern int printf(char *, ...); + printf("ick : pause : %li\n", pause); + printf("ick: pages_dirtied : %lu\n", pages_dirtied); + printf("ick: task_ratelimit: %lu\n", task_ratelimit); + BUG_ON(1); + } trace_balance_dirty_pages(bdi, Since pause is bounded by [min_pause, max_pause] where min_pause is also bounded by max_pause. It's suspected and demonstrated that the max_pause calculation goes wrong: ick: pause : -717 ick: min_pause : -177 ick: max_pause : -717 ick: pages_dirtied : 14 ick: task_ratelimit: 0 The problem lies in the two "long = unsigned long" assignments in bdi_max_pause() which might go negative if the highest bit is 1, and the min_t(long, ...) check failed to protect it falling under 0. Fix all of them by using "unsigned long" throughout the function. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Richard Weinberger <richard@nod.at> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-04mm: fix BUG in __split_huge_page_pmdHugh Dickins
commit 750e8165f5e87b6a142be953640eabb13a9d350a upstream. Occasionally we hit the BUG_ON(pmd_trans_huge(*pmd)) at the end of __split_huge_page_pmd(): seen when doing madvise(,,MADV_DONTNEED). It's invalid: we don't always have down_write of mmap_sem there: a racing do_huge_pmd_wp_page() might have copied-on-write to another huge page before our split_huge_page() got the anon_vma lock. Forget the BUG_ON, just go back and try again if this happens. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18cope with potentially long ->d_dname() output for shmem/hugetlbAl Viro
commit 118b23022512eb2f41ce42db70dc0568d00be4ba upstream. dynamic_dname() is both too much and too little for those - the output may be well in excess of 64 bytes dynamic_dname() assumes to be enough (thanks to ashmem feeding really long names to shmem_file_setup()) and vsnprintf() is an overkill for those guys. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Colin Cross <ccross@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13mm: avoid reinserting isolated balloon pages into LRU listsRafael Aquini
commit 117aad1e9e4d97448d1df3f84b08bd65811e6d6a upstream. Isolated balloon pages can wrongly end up in LRU lists when migrate_pages() finishes its round without draining all the isolated page list. The same issue can happen when reclaim_clean_pages_from_list() tries to reclaim pages from an isolated page list, before migration, in the CMA path. Such balloon page leak opens a race window against LRU lists shrinkers that leads us to the following kernel panic: BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 IP: [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 PGD 3cda2067 PUD 3d713067 PMD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 340 Comm: kswapd0 Not tainted 3.12.0-rc1-22626-g4367597 #87 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 RIP: shrink_page_list+0x24e/0x897 RSP: 0000:ffff88003da499b8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88003e82bd60 RCX: 00000000000657d5 RDX: 0000000000000000 RSI: 000000000000031f RDI: ffff88003e82bd40 RBP: ffff88003da49ab0 R08: 0000000000000001 R09: 0000000081121a45 R10: ffffffff81121a45 R11: ffff88003c4a9a28 R12: ffff88003e82bd40 R13: ffff88003da0e800 R14: 0000000000000001 R15: ffff88003da49d58 FS: 0000000000000000(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000067d9000 CR3: 000000003ace5000 CR4: 00000000000407b0 Call Trace: shrink_inactive_list+0x240/0x3de shrink_lruvec+0x3e0/0x566 __shrink_zone+0x94/0x178 shrink_zone+0x3a/0x82 balance_pgdat+0x32a/0x4c2 kswapd+0x2f0/0x372 kthread+0xa2/0xaa ret_from_fork+0x7c/0xb0 Code: 80 7d 8f 01 48 83 95 68 ff ff ff 00 4c 89 e7 e8 5a 7b 00 00 48 85 c0 49 89 c5 75 08 80 7d 8f 00 74 3e eb 31 48 8b 80 18 01 00 00 <48> 8b 74 0d 48 8b 78 30 be 02 00 00 00 ff d2 eb RIP [<ffffffff810c2625>] shrink_page_list+0x24e/0x897 RSP <ffff88003da499b8> CR2: 0000000000000028 ---[ end trace 703d2451af6ffbfd ]--- Kernel panic - not syncing: Fatal exception This patch fixes the issue, by assuring the proper tests are made at putback_movable_pages() & reclaim_clean_pages_from_list() to avoid isolated balloon pages being wrongly reinserted in LRU lists. [akpm@linux-foundation.org: clarify awkward comment text] Signed-off-by: Rafael Aquini <aquini@redhat.com> Reported-by: Luiz Capitulino <lcapitulino@redhat.com> Tested-by: Luiz Capitulino <lcapitulino@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13mm/bounce.c: fix a regression where MS_SNAP_STABLE (stable pages ↵Darrick J. Wong
snapshotting) was ignored commit 83b2944fd2532b92db099cb3ada12df32a05b368 upstream. The "force" parameter in __blk_queue_bounce was being ignored, which means that stable page snapshots are not always happening (on ext3). This of course leads to DIF disks reporting checksum errors, so fix this regression. The regression was introduced in commit 6bc454d15004 ("bounce: Refactor __blk_queue_bounce to not use bi_io_vec") Reported-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Cc: Kent Overstreet <koverstreet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01mm: fix aio performance regression for database caused by THPKhalid Aziz
commit 7cb2ef56e6a8b7b368b2e883a0a47d02fed66911 upstream. I am working with a tool that simulates oracle database I/O workload. This tool (orion to be specific - <http://docs.oracle.com/cd/E11882_01/server.112/e16638/iodesign.htm#autoId24>) allocates hugetlbfs pages using shmget() with SHM_HUGETLB flag. It then does aio into these pages from flash disks using various common block sizes used by database. I am looking at performance with two of the most common block sizes - 1M and 64K. aio performance with these two block sizes plunged after Transparent HugePages was introduced in the kernel. Here are performance numbers: pre-THP 2.6.39 3.11-rc5 1M read 8384 MB/s 5629 MB/s 6501 MB/s 64K read 7867 MB/s 4576 MB/s 4251 MB/s I have narrowed the performance impact down to the overheads introduced by THP in __get_page_tail() and put_compound_page() routines. perf top shows >40% of cycles being spent in these two routines. Every time direct I/O to hugetlbfs pages starts, kernel calls get_page() to grab a reference to the pages and calls put_page() when I/O completes to put the reference away. THP introduced significant amount of locking overhead to get_page() and put_page() when dealing with compound pages because hugepages can be split underneath get_page() and put_page(). It added this overhead irrespective of whether it is dealing with hugetlbfs pages or transparent hugepages. This resulted in 20%-45% drop in aio performance when using hugetlbfs pages. Since hugetlbfs pages can not be split, there is no reason to go through all the locking overhead for these pages from what I can see. I added code to __get_page_tail() and put_compound_page() to bypass all the locking code when working with hugetlbfs pages. This improved performance significantly. Performance numbers with this patch: pre-THP 3.11-rc5 3.11-rc5 + Patch 1M read 8384 MB/s 6501 MB/s 8371 MB/s 64K read 7867 MB/s 4251 MB/s 6510 MB/s Performance with 64K read is still lower than what it was before THP, but still a 53% improvement. It does mean there is more work to be done but I will take a 53% improvement for now. Please take a look at the following patch and let me know if it looks reasonable. [akpm@linux-foundation.org: tweak comments] Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Cc: Pravin B Shelar <pshelar@nicira.com> Cc: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26mm/huge_memory.c: fix potential NULL pointer dereferenceLibin
commit a8f531ebc33052642b4bd7b812eedf397108ce64 upstream. In collapse_huge_page() there is a race window between releasing the mmap_sem read lock and taking the mmap_sem write lock, so find_vma() may return NULL. So check the return value to avoid NULL pointer dereference. collapse_huge_page khugepaged_alloc_page up_read(&mm->mmap_sem) down_write(&mm->mmap_sem) vma = find_vma(mm, address) Signed-off-by: Libin <huawei.libin@huawei.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26memcg: fix multiple large threshold notificationsGreg Thelen
commit 2bff24a3707093c435ab3241c47dcdb5f16e432b upstream. A memory cgroup with (1) multiple threshold notifications and (2) at least one threshold >=2G was not reliable. Specifically the notifications would either not fire or would not fire in the proper order. The __mem_cgroup_threshold() signaling logic depends on keeping 64 bit thresholds in sorted order. mem_cgroup_usage_register_event() sorts them with compare_thresholds(), which returns the difference of two 64 bit thresholds as an int. If the difference is positive but has bit[31] set, then sort() treats the difference as negative and breaks sort order. This fix compares the two arbitrary 64 bit thresholds returning the classic -1, 0, 1 result. The test below sets two notifications (at 0x1000 and 0x81001000): cd /sys/fs/cgroup/memory mkdir x for x in 4096 2164264960; do cgroup_event_listener x/memory.usage_in_bytes $x | sed "s/^/$x listener:/" & done echo $$ > x/cgroup.procs anon_leaker 500M v3.11-rc7 fails to signal the 4096 event listener: Leaking... Done leaking pages. Patched v3.11-rc7 properly notifies: Leaking... 4096 listener:2013:8:31:14:13:36 Done leaking pages. The fixed bug is old. It appears to date back to the introduction of memcg threshold notifications in v2.6.34-rc1-116-g2e72b6347c94 "memcg: implement memory thresholds" Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07memcg: check that kmem_cache has memcg_params before accessing itAndrey Vagin
commit 6f6b8951897e487ea6f77b90ea01f70a9c363770 upstream. If the system had a few memory groups and all of them were destroyed, memcg_limited_groups_array_size has non-zero value, but all new caches are created without memcg_params, because memcg_kmem_enabled() returns false. We try to enumirate child caches in a few places and all of them are potentially dangerous. For example my kernel is compiled with CONFIG_SLAB and it crashed when I tryed to mount a NFS share after a few experiments with kmemcg. BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0 PGD b942a067 PUD b999f067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: fscache(+) ip6table_filter ip6_tables iptable_filter ip_tables i2c_piix4 pcspkr virtio_net virtio_balloon i2c_core floppy CPU: 0 PID: 357 Comm: modprobe Not tainted 3.11.0-rc7+ #59 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8800b9f98240 ti: ffff8800ba32e000 task.ti: ffff8800ba32e000 RIP: 0010:[<ffffffff8118166a>] [<ffffffff8118166a>] do_tune_cpucache+0x8a/0xd0 RSP: 0018:ffff8800ba32fb70 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000006 RDX: 0000000000000000 RSI: ffff8800b9f98910 RDI: 0000000000000246 RBP: ffff8800ba32fba0 R08: 0000000000000002 R09: 0000000000000004 R10: 0000000000000001 R11: 0000000000000001 R12: 0000000000000010 R13: 0000000000000008 R14: 00000000000000d0 R15: ffff8800375d0200 FS: 00007f55f1378740(0000) GS:ffff8800bfa00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f24feba57a0 CR3: 0000000037b51000 CR4: 00000000000006f0 Call Trace: enable_cpucache+0x49/0x100 setup_cpu_cache+0x215/0x280 __kmem_cache_create+0x2fa/0x450 kmem_cache_create_memcg+0x214/0x350 kmem_cache_create+0x2b/0x30 fscache_init+0x19b/0x230 [fscache] do_one_initcall+0xfa/0x1b0 load_module+0x1c41/0x26d0 SyS_finit_module+0x86/0xb0 system_call_fastpath+0x16/0x1b Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Christoph Lameter <cl@linux.com> Cc: Glauber Costa <glommer@openvz.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20Fix TLB gather virtual address range invalidation corner casesLinus Torvalds
commit 2b047252d087be7f2ba088b4933cd904f92e6fce upstream. Ben Tebulin reported: "Since v3.7.2 on two independent machines a very specific Git repository fails in 9/10 cases on git-fsck due to an SHA1/memory failures. This only occurs on a very specific repository and can be reproduced stably on two independent laptops. Git mailing list ran out of ideas and for me this looks like some very exotic kernel issue" and bisected the failure to the backport of commit 53a59fc67f97 ("mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPT"). That commit itself is not actually buggy, but what it does is to make it much more likely to hit the partial TLB invalidation case, since it introduces a new case in tlb_next_batch() that previously only ever happened when running out of memory. The real bug is that the TLB gather virtual memory range setup is subtly buggered. It was introduced in commit 597e1c3580b7 ("mm/mmu_gather: enable tlb flush range in generic mmu_gather"), and the range handling was already fixed at least once in commit e6c495a96ce0 ("mm: fix the TLB range flushed when __tlb_remove_page() runs out of slots"), but that fix was not complete. The problem with the TLB gather virtual address range is that it isn't set up by the initial tlb_gather_mmu() initialization (which didn't get the TLB range information), but it is set up ad-hoc later by the functions that actually flush the TLB. And so any such case that forgot to update the TLB range entries would potentially miss TLB invalidates. Rather than try to figure out exactly which particular ad-hoc range setup was missing (I personally suspect it's the hugetlb case in zap_huge_pmd(), which didn't have the same logic as zap_pte_range() did), this patch just gets rid of the problem at the source: make the TLB range information available to tlb_gather_mmu(), and initialize it when initializing all the other tlb gather fields. This makes the patch larger, but conceptually much simpler. And the end result is much more understandable; even if you want to play games with partial ranges when invalidating the TLB contents in chunks, now the range information is always there, and anybody who doesn't want to bother with it won't introduce subtle bugs. Ben verified that this fixes his problem. Reported-bisected-and-tested-by: Ben Tebulin <tebulin@googlemail.com> Build-testing-by: Stephen Rothwell <sfr@canb.auug.org.au> Build-testing-by: Richard Weinberger <richard.weinberger@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20memcg: don't initialize kmem-cache destroying work for root cachesAndrey Vagin
commit 3e6b11df245180949938734bc192eaf32f3a06b3 upstream. struct memcg_cache_params has a union. Different parts of this union are used for root and non-root caches. A part with destroying work is used only for non-root caches. I fixed the same problem in another place v3.9-rc1-16204-gf101a94, but didn't notice this one. This patch fixes the kernel panic: [ 46.848187] BUG: unable to handle kernel paging request at 000000fffffffeb8 [ 46.849026] IP: [<ffffffff811a484c>] kmem_cache_destroy_memcg_children+0x6c/0xc0 [ 46.849092] PGD 0 [ 46.849092] Oops: 0000 [#1] SMP ... Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Glauber Costa <glommer@openvz.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04mm: mempolicy: fix mbind_range() && vma_adjust() interactionOleg Nesterov
commit 3964acd0dbec123aa0a621973a2a0580034b4788 upstream. vma_adjust() does vma_set_policy(vma, vma_policy(next)) and this is doubly wrong: 1. This leaks vma->vm_policy if it is not NULL and not equal to next->vm_policy. This can happen if vma_merge() expands "area", not prev (case 8). 2. This sets the wrong policy if vma_merge() joins prev and area, area is the vma the caller needs to update and it still has the old policy. Revert commit 1444f92c8498 ("mm: merging memory blocks resets mempolicy") which introduced these problems. Change mbind_range() to recheck mpol_equal() after vma_merge() to fix the problem that commit tried to address. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven T Hampson <steven.t.hampson@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04mm: fix the TLB range flushed when __tlb_remove_page() runs out of slotsVineet Gupta
commit e6c495a96ce02574e765d5140039a64c8d4e8c9e upstream. zap_pte_range loops from @addr to @end. In the middle, if it runs out of batching slots, TLB entries needs to be flushed for @start to @interim, NOT @interim to @end. Since ARC port doesn't use page free batching I can't test it myself but this seems like the right thing to do. Observed this when working on a fix for the issue at thread: http://www.spinics.net/lists/linux-arch/msg21736.html Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21mm/memory-hotplug: fix lowmem count overflow when offline pagesWanpeng Li
commit cea27eb2a202959783f81254c48c250ddd80e129 upstream. The logic for the memory-remove code fails to correctly account the Total High Memory when a memory block which contains High Memory is offlined as shown in the example below. The following patch fixes it. Before logic memory remove: MemTotal: 7603740 kB MemFree: 6329612 kB Buffers: 94352 kB Cached: 872008 kB SwapCached: 0 kB Active: 626932 kB Inactive: 519216 kB Active(anon): 180776 kB Inactive(anon): 222944 kB Active(file): 446156 kB Inactive(file): 296272 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 7294672 kB HighFree: 5704696 kB LowTotal: 309068 kB LowFree: 624916 kB After logic memory remove: MemTotal: 7079452 kB MemFree: 5805976 kB Buffers: 94372 kB Cached: 872000 kB SwapCached: 0 kB Active: 626936 kB Inactive: 519236 kB Active(anon): 180780 kB Inactive(anon): 222944 kB Active(file): 446156 kB Inactive(file): 296292 kB Unevictable: 0 kB Mlocked: 0 kB HighTotal: 7294672 kB HighFree: 5181024 kB LowTotal: 4294752076 kB LowFree: 624952 kB [mhocko@suse.cz: fix CONFIG_HIGHMEM=n build] Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21memcg, kmem: fix reference count handling on the error pathMichal Hocko
commit f37a96914d1aea10fed8d9af10251f0b9caea31b upstream. mem_cgroup_css_online calls mem_cgroup_put if memcg_init_kmem fails. This is not correct because only memcg_propagate_kmem takes an additional reference while mem_cgroup_sockets_init is allowed to fail as well (although no current implementation fails) but it doesn't take any reference. This all suggests that it should be memcg_propagate_kmem that should clean up after itself so this patch moves mem_cgroup_put over there. Unfortunately this is not that easy (as pointed out by Li Zefan) because memcg_kmem_mark_dead marks the group dead (KMEM_ACCOUNTED_DEAD) if it is marked active (KMEM_ACCOUNTED_ACTIVE) which is the case even if memcg_propagate_kmem fails so the additional reference is dropped in that case in kmem_cgroup_destroy which means that the reference would be dropped two times. The easiest way then would be to simply remove mem_cgrroup_put from mem_cgroup_css_online and rely on kmem_cgroup_destroy doing the right thing. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Li Zefan <lizefan@huawei.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Glauber Costa <glommer@openvz.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21slab: fix init_lock_keysChristoph Lameter
commit 0f8f8094d28eb53368ac09186ea6b3a324cc7d44 upstream. Some architectures (e.g. powerpc built with CONFIG_PPC_256K_PAGES=y CONFIG_FORCE_MAX_ZONEORDER=11) get PAGE_SHIFT + MAX_ORDER > 26. In 3.10 kernels, CONFIG_LOCKDEP=y with PAGE_SHIFT + MAX_ORDER > 26 makes init_lock_keys() dereference beyond kmalloc_caches[26]. This leads to an unbootable system (kernel panic at initializing SLAB) if one of kmalloc_caches[26...PAGE_SHIFT+MAX_ORDER-1] is not NULL. Fix this by making sure that init_lock_keys() does not dereference beyond kmalloc_caches[26] arrays. Signed-off-by: Christoph Lameter <cl@linux.com> Reported-by: Tetsuo Handa <penguin-kernel@I-Love.SAKURA.ne.jp> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
