[ Upstream commit a46cbf3bc53b6a93fb84a5ffb288c354fa807954 ]
It's possible to isolate some freepages in a pageblock and then fail
split_free_page() due to the low watermark check. In this case, we hit
VM_BUG_ON() because the freeing scanner terminated early without a
contended lock or enough freepages.
This should never have been a VM_BUG_ON() since it's not a fatal
condition. It should have been a VM_WARN_ON() at best, or even handled
gracefully.
Regardless, we need to terminate anytime the full pageblock scan was not
done. The logic belongs in isolate_freepages_block(), so handle its
state gracefully by terminating the pageblock loop and making a note to
restart at the same pageblock next time since it was not possible to
complete the scan this time.
[rientjes@google.com: don't rescan pages in a pageblock]
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1607111244150.83138@chino.kir.corp.google.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606291436300.145590@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Minchan Kim <minchan@kernel.org>
Tested-by: Minchan Kim <minchan@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: <stable@vger.kernel.org>
[ Upstream commit f5f61a320bf6275f37fcabf6645b4ac8e683c007 ]
Handling the position where compaction free scanner should restart
(stored in cc->free_pfn) got more complex with commit e14c720efdd7 ("mm,
compaction: remember position within pageblock in free pages scanner").
Currently the position is updated in each loop iteration of
isolate_freepages(), although it should be enough to update it only when
breaking from the loop. There's also an extra check outside the loop
updates the position in case we have met the migration scanner.
This can be simplified if we move the test for having isolated enough
from the for-loop header next to the test for contention, and
determining the restart position only in these cases. We can reuse the
isolate_start_pfn variable for this instead of setting cc->free_pfn
directly. Outside the loop, we can simply set cc->free_pfn to current
value of isolate_start_pfn without any extra check.
Also add a VM_BUG_ON to catch possible mistake in the future, in case we
later add a new condition that terminates isolate_freepages_block()
prematurely without also considering the condition in
isolate_freepages().
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Minchan Kim <minchan@kernel.org>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Christoph Lameter <cl@linux.com>
compound page arrival"
When I pulled in 4.1.28 into my stable 4.1-rt tree and ran the tests,
it crashed with a severe OOM killing everything. I then tested 4.1.28
without -rt and it had the same issue. I did a bisect between 4.1.27
and 4.1.28 and found that the bug started at:
commit 8f182270dfec "mm/swap.c: flush lru pvecs on compound page
arrival"
Looking at that patch and what's in mainline, I see that there's a
mismatch in one of the hunks:
Mainline:
@@ -391,9 +391,8 @@ static void __lru_cache_add(struct page *page)
struct pagevec *pvec = &get_cpu_var(lru_add_pvec);
get_page(page);
- if (!pagevec_space(pvec))
+ if (!pagevec_add(pvec, page) || PageCompound(page))
__pagevec_lru_add(pvec);
- pagevec_add(pvec, page);
put_cpu_var(lru_add_pvec);
Stable 4.1.28:
@@ -631,9 +631,8 @@ static void __lru_cache_add(struct page *page)
page_cache_get(page);
+ if (!pagevec_space(pvec) || PageCompound(page))
Where mainline replace pagevec_space() with pagevec_add, and stable did
not.
Fixing this makes the OOM go away.
Note, 3.18 has the same bug.
[ Upstream commit 7f556567036cb7f89aabe2f0954b08566b4efb53 ]
The well-spotted fallocate undo fix is good in most cases, but not when
fallocate failed on the very first page. index 0 then passes lend -1
to shmem_undo_range(), and that has two bad effects: (a) that it will
undo every fallocation throughout the file, unrestricted by the current
range; but more importantly (b) it can cause the undo to hang, because
lend -1 is treated as truncation, which makes it keep on retrying until
every page has gone, but those already fully instantiated will never go
away. Big thank you to xfstests generic/269 which demonstrates this.
Fixes: b9b4bb26af01 ("tmpfs: don't undo fallocate past its last page")
Cc: stable@vger.kernel.org
[ Upstream commit bc22af74f271ef76b2e6f72f3941f91f0da3f5f8 ]
Khugepaged attempts to raise min_free_kbytes if its set too low.
However, on boot khugepaged sets min_free_kbytes first from
subsys_initcall(), and then the mm 'core' over-rides min_free_kbytes
after from init_per_zone_wmark_min(), via a module_init() call.
Khugepaged used to use a late_initcall() to set min_free_kbytes (such
that it occurred after the core initialization), however this was
removed when the initialization of min_free_kbytes was integrated into
the starting of the khugepaged thread.
The fix here is simply to invoke the core initialization using a
core_initcall() instead of module_init(), such that the previous
initialization ordering is restored. I didn't restore the
late_initcall() since start_stop_khugepaged() already sets
min_free_kbytes via set_recommended_min_free_kbytes().
This was noticed when we had a number of page allocation failures when
moving a workload to a kernel with this new initialization ordering. On
an 8GB system this restores min_free_kbytes back to 67584 from 11365
when CONFIG_TRANSPARENT_HUGEPAGE=y is set and either
CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y or
CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y.
Fixes: 79553da293d3 ("thp: cleanup khugepaged startup")
Signed-off-by: Jason Baron <jbaron@akamai.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
[ Upstream commit 6f25a14a7053b69917e2ebea0d31dd444cd31fd5 ]
It is incorrect to use next_node to find a target node, it will return
MAX_NUMNODES or invalid node. This will lead to crash in buddy system
allocation.
Fixes: c8721bbbdd36 ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: "Laura Abbott" <lauraa@codeaurora.org>
Cc: Hui Zhu <zhuhui@xiaomi.com>
Cc: Wang Xiaoqiang <wangxq10@lzu.edu.cn>
[ Upstream commit a4f04f2c6955aff5e2c08dcb40aca247ff4d7370 ]
If the memory compaction free scanner cannot successfully split a free
page (only possible due to per-zone low watermark), terminate the free
scanner rather than continuing to scan memory needlessly. If the
watermark is insufficient for a free page of order <= cc->order, then
terminate the scanner since all future splits will also likely fail.
This prevents the compaction freeing scanner from scanning all memory on
very large zones (very noticeable for zones > 128GB, for instance) when
all splits will likely fail while holding zone->lock.
compaction_alloc() iterating a 128GB zone has been benchmarked to take
over 400ms on some systems whereas any free page isolated and ready to
be split ends up failing in split_free_page() because of the low
watermark check and thus the iteration continues.
The next time compaction occurs, the freeing scanner will likely start
at the end of the zone again since no success was made previously and we
get the same lengthy iteration until the zone is brought above the low
watermark. All thp page faults can take >400ms in such a state without
this fix.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211820350.97086@chino.kir.corp.google.com
[ Upstream commit 9fcd6d2e052eef525e94a9ae58dbe7ed4df4f5a7 ]
The compaction free scanner is looking for PageBuddy() pages and
skipping all others. For large compound pages such as THP or hugetlbfs,
we can save a lot of iterations if we skip them at once using their
compound_order(). This is generally unsafe and we can read a bogus
value of order due to a race, but if we are careful, the only danger is
skipping too much.
When tested with stress-highalloc from mmtests on 4GB system with 1GB
hugetlbfs pages, the vmstat compact_free_scanned count decreased by at
least 15%.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
[ Upstream commit 8f182270dfec432e93fae14f9208a6b9af01009f ]
Currently we can have compound pages held on per cpu pagevecs, which
leads to a lot of memory unavailable for reclaim when needed. In the
systems with hundreads of processors it can be GBs of memory.
On of the way of reproducing the problem is to not call munmap
explicitly on all mapped regions (i.e. after receiving SIGTERM). After
that some pages (with THP enabled also huge pages) may end up on
lru_add_pvec, example below.
void main() {
#pragma omp parallel
size_t size = 55 * 1000 * 1000; // smaller than MEM/CPUS
void *p = mmap(NULL, size, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS , -1, 0);
if (p != MAP_FAILED)
memset(p, 0, size);
//munmap(p, size); // uncomment to make the problem go away
When we run it with THP enabled it will leave significant amount of
memory on lru_add_pvec. This memory will be not reclaimed if we hit
OOM, so when we run above program in a loop:
for i in `seq 100`; do ./a.out; done
many processes (95% in my case) will be killed by OOM.
The primary point of the LRU add cache is to save the zone lru_lock
contention with a hope that more pages will belong to the same zone and
so their addition can be batched. The huge page is already a form of
batched addition (it will add 512 worth of memory in one go) so skipping
the batching seems like a safer option when compared to a potential
excess in the caching which can be quite large and much harder to fix
because lru_add_drain_all is way to expensive and it is not really clear
what would be a good moment to call it.
Similarly we can reproduce the problem on lru_deactivate_pvec by adding:
madvise(p, size, MADV_FREE); after memset.
This patch flushes lru pvecs on compound page arrival making the problem
less severe - after applying it kill rate of above example drops to 0%,
due to reducing maximum amount of memory held on pvec from 28MB (with
THP) to 56kB per CPU.
Suggested-by: Michal Hocko <mhocko@suse.com>
Link: http://lkml.kernel.org/r/1466180198-18854-1-git-send-email-lukasz.odzioba@intel.com
Signed-off-by: Lukasz Odzioba <lukasz.odzioba@intel.com>
Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: Ming Li <mingli199x@qq.com>
[ Upstream commit b9b4bb26af017dbe930cd4df7f9b2fc3a0497bfe ]
When fallocate is interrupted it will undo a range that extends one byte
past its range of allocated pages. This can corrupt an in-use page by
zeroing out its first byte. Instead, undo using the inclusive byte
range.
Fixes: 1635f6a74152f1d ("tmpfs: undo fallocation on failure")
Link: http://lkml.kernel.org/r/1462713387-16724-1-git-send-email-anthony.romano@coreos.com
Signed-off-by: Anthony Romano <anthony.romano@coreos.com>
Cc: Brandon Philips <brandon@ifup.co>
[ Upstream commit 1118dce773d84f39ebd51a9fe7261f9169cb056e ]
Export these symbols such that UBIFS can implement
->migratepage.
Signed-off-by: Richard Weinberger <richard@nod.at>
Acked-by: Christoph Hellwig <hch@lst.de>
destruction
[ Upstream commit 6710e594f71ccaad8101bc64321152af7cd9ea28 ]
For non-atomic allocations, pcpu_alloc() can try to extend the area
map synchronously after dropping pcpu_lock; however, the extension
wasn't synchronized against chunk destruction and the chunk might get
freed while extension is in progress.
This patch fixes the bug by putting most of non-atomic allocations
under pcpu_alloc_mutex to synchronize against pcpu_balance_work which
is responsible for async chunk management including destruction.
Reported-and-tested-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: stable@vger.kernel.org # v3.18+
Fixes: 1a4d76076cda ("percpu: implement asynchronous chunk population")
[ Upstream commit 4f996e234dad488e5d9ba0858bc1bae12eff82c3 ]
Atomic allocations can trigger async map extensions which is serviced
by chunk->map_extend_work. pcpu_balance_work which is responsible for
destroying idle chunks wasn't synchronizing properly against
chunk->map_extend_work and may end up freeing the chunk while the work
item is still in flight.
This patch fixes the bug by rolling async map extension operations
into pcpu_balance_work.
Fixes: 9c824b6a172c ("percpu: make sure chunk->map array has available space")
[ Upstream commit 14af4a5e9b26ad251f81c174e8a43f3e179434a5 ]
/proc/sys/vm/stat_refresh warns nr_isolated_anon and nr_isolated_file go
increasingly negative under compaction: which would add delay when
should be none, or no delay when should delay. The bug in compaction
was due to a recent mmotm patch, but much older instance of the bug was
also noticed in isolate_migratepages_range() which is used for CMA and
gigantic hugepage allocations.
The bug is caused by putback_movable_pages() in an error path
decrementing the isolated counters without them being previously
incremented by acct_isolated(). Fix isolate_migratepages_range() by
removing the error-path putback, thus reaching acct_isolated() with
migratepages still isolated, and leaving putback to caller like most
other places do.
Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()")
[vbabka@suse.cz: expanded the changelog]
Cc: Michal Hocko <mhocko@kernel.org>
[ Upstream commit f4c18e6f7b5bbb5b528b3334115806b0d76f50f9 ]
The race condition addressed in commit add05cecef80 ("mm: soft-offline:
don't free target page in successful page migration") was not closed
completely, because that can happen not only for soft-offline, but also
for hard-offline. Consider that a slab page is about to be freed into
buddy pool, and then an uncorrected memory error hits the page just
after entering __free_one_page(), then VM_BUG_ON_PAGE(page->flags &
PAGE_FLAGS_CHECK_AT_PREP) is triggered, despite the fact that it's not
necessary because the data on the affected page is not consumed.
To solve it, this patch drops __PG_HWPOISON from page flag checks at
allocation/free time. I think it's justified because __PG_HWPOISON
flags is defined to prevent the page from being reused, and setting it
outside the page's alloc-free cycle is a designed behavior (not a bug.)
For recent months, I was annoyed about BUG_ON when soft-offlined page
remains on lru cache list for a while, which is avoided by calling
put_page() instead of putback_lru_page() in page migration's success
path. This means that this patch reverts a major change from commit
add05cecef80 about the new refcounting rule of soft-offlined pages, so
"reuse window" revives. This will be closed by a subsequent patch.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Dean Nelson <dnelson@redhat.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
[ Upstream commit add05cecef803f3372c5fc1d2a964171872daf9f ]
Stress testing showed that soft offline events for a process iterating
"mmap-pagefault-munmap" loop can trigger
VM_BUG_ON(PAGE_FLAGS_CHECK_AT_PREP) in __free_one_page():
Soft offlining page 0x70fe1 at 0x70100008d000
Soft offlining page 0x705fb at 0x70300008d000
page:ffffea0001c3f840 count:0 mapcount:0 mapping: (null) index:0x2
flags: 0x1fffff80800000(hwpoison)
page dumped because: VM_BUG_ON_PAGE(page->flags & ((1 << 25) - 1))
kernel BUG at /src/linux-dev/mm/page_alloc.c:585!
invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: cfg80211 rfkill crc32c_intel microcode ppdev parport_pc pcspkr serio_raw virtio_balloon parport i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi floppy
CPU: 3 PID: 1779 Comm: test_base_madv_ Not tainted 4.0.0-v4.0-150511-1451-00009-g82360a3730e6 #139
RIP: free_pcppages_bulk+0x52a/0x6f0
Call Trace:
drain_pages_zone+0x3d/0x50
drain_local_pages+0x1d/0x30
on_each_cpu_mask+0x46/0x80
drain_all_pages+0x14b/0x1e0
soft_offline_page+0x432/0x6e0
SyS_madvise+0x73c/0x780
system_call_fastpath+0x12/0x17
Code: ff 89 45 b4 48 8b 45 c0 48 83 b8 a8 00 00 00 00 0f 85 e3 fb ff ff 0f 1f 00 0f 0b 48 8b 7d 90 48 c7 c6 e8 95 a6 81 e8 e6 32 02 00 <0f> 0b 8b 45 cc 49 89 47 30 41 8b 47 18 83 f8 ff 0f 85 10 ff ff
RIP [<ffffffff811a806a>] free_pcppages_bulk+0x52a/0x6f0
RSP <ffff88007a117d28>
---[ end trace 53926436e76d1f35 ]---
When soft offline successfully migrates page, the source page is supposed
to be freed. But there is a race condition where a source page looks
isolated (i.e. the refcount is 0 and the PageHWPoison is set) but
somewhat linked to pcplist. Then another soft offline event calls
drain_all_pages() and tries to free such hwpoisoned page, which is
forbidden.
This odd page state seems to happen due to the race between put_page() in
putback_lru_page() and __pagevec_lru_add_fn(). But I don't want to play
with tweaking drain code as done in commit 9ab3b598d2df "mm: hwpoison:
drop lru_add_drain_all() in __soft_offline_page()", or to change page
freeing code for this soft offline's purpose.
Instead, let's think about the difference between hard offline and soft
offline. There is an interesting difference in how to isolate the in-use
page between these, that is, hard offline marks PageHWPoison of the target
page at first, and doesn't free it by keeping its refcount 1. OTOH, soft
offline tries to free the target page then marks PageHWPoison. This
difference might be the source of complexity and result in bugs like the
above. So making soft offline isolate with keeping refcount can be a
solution for this problem.
We can pass to page migration code the "reason" which shows the caller, so
let's use this more to avoid calling putback_lru_page() when called from
soft offline, which effectively does the isolation for soft offline. With
this change, target pages of soft offline never be reused without changing
migratetype, so this patch also removes the related code.
[ Upstream commit 7bf52fb891b64b8d61caf0b82060adb9db761aec ]
We have been reclaimed highmem zone if buffer_heads is over limit but
commit 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from
shrink_zone()") changed the behavior so it doesn't reclaim highmem zone
although buffer_heads is over the limit. This patch restores the logic.
Fixes: 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from shrink_zone()")
Signed-off-by: Minchan Kim <minchan@kernel.org>
[ Upstream commit 3486b85a29c1741db99d0c522211c82d2b7a56d0 ]
Khugepaged detects own VMAs by checking vm_file and vm_ops but this way
it cannot distinguish private /dev/zero mappings from other special
mappings like /dev/hpet which has no vm_ops and popultes PTEs in mmap.
This fixes false-positive VM_BUG_ON and prevents installing THP where
they are not expected.
Link: http://lkml.kernel.org/r/CACT4Y+ZmuZMV5CjSFOeXviwQdABAgT7T+StKfTqan9YDtgEi5g@mail.gmail.com
Fixes: 78f11a255749 ("mm: thp: fix /dev/zero MAP_PRIVATE and vm_flags cleanups")
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit d9dddbf556674bf125ecd925b24e43a5cf2a568a ]
Hanjun Guo has reported that a CMA stress test causes broken accounting of
CMA and free pages:
> Before the test, I got:
> -bash-4.3# cat /proc/meminfo | grep Cma
> CmaTotal: 204800 kB
> CmaFree: 195044 kB
> After running the test:
> CmaTotal: 204800 kB
> CmaFree: 6602584 kB
> So the freed CMA memory is more than total..
> Also the the MemFree is more than mem total:
> MemTotal: 16342016 kB
> MemFree: 22367268 kB
> MemAvailable: 22370528 kB
Laura Abbott has confirmed the issue and suspected the freepage accounting
rewrite around 3.18/4.0 by Joonsoo Kim. Joonsoo had a theory that this is
caused by unexpected merging between MIGRATE_ISOLATE and MIGRATE_CMA
pageblocks:
> CMA isolates MAX_ORDER aligned blocks, but, during the process,
> partialy isolated block exists. If MAX_ORDER is 11 and
> pageblock_order is 9, two pageblocks make up MAX_ORDER
> aligned block and I can think following scenario because pageblock
> (un)isolation would be done one by one.
> (each character means one pageblock. 'C', 'I' means MIGRATE_CMA,
> MIGRATE_ISOLATE, respectively.
> CC -> IC -> II (Isolation)
> II -> CI -> CC (Un-isolation)
> If some pages are freed at this intermediate state such as IC or CI,
> that page could be merged to the other page that is resident on
> different type of pageblock and it will cause wrong freepage count.
This was supposed to be prevented by CMA operating on MAX_ORDER blocks,
but since it doesn't hold the zone->lock between pageblocks, a race
window does exist.
It's also likely that unexpected merging can occur between
MIGRATE_ISOLATE and non-CMA pageblocks. This should be prevented in
__free_one_page() since commit 3c605096d315 ("mm/page_alloc: restrict
max order of merging on isolated pageblock"). However, we only check
the migratetype of the pageblock where buddy merging has been initiated,
not the migratetype of the buddy pageblock (or group of pageblocks)
which can be MIGRATE_ISOLATE.
Joonsoo has suggested checking for buddy migratetype as part of
page_is_buddy(), but that would add extra checks in allocator hotpath
and bloat-o-meter has shown significant code bloat (the function is
inline).
This patch reduces the bloat at some expense of more complicated code.
The buddy-merging while-loop in __free_one_page() is initially bounded
to pageblock_border and without any migratetype checks. The checks are
placed outside, bumping the max_order if merging is allowed, and
returning to the while-loop with a statement which can't be possibly
considered harmful.
This fixes the accounting bug and also removes the arguably weird state
in the original commit 3c605096d315 where buddies could be left
unmerged.
Fixes: 3c605096d315 ("mm/page_alloc: restrict max order of merging on isolated pageblock")
Link: https://lkml.org/lkml/2016/3/2/280
Reported-by: Hanjun Guo <guohanjun@huawei.com>
Tested-by: Hanjun Guo <guohanjun@huawei.com>
Debugged-by: Laura Abbott <labbott@redhat.com>
Debugged-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> [3.18+]
[ Upstream commit d00181b96eb86c914cb327d1de974a1b71366e1b ]
Let's try to be consistent about data type of page order.
[sfr@canb.auug.org.au: fix build (type of pageblock_order)]
[hughd@google.com: some configs end up with MAX_ORDER and pageblock_order having different types]
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
[ Upstream commit d70ddd7a5d9aa335f9b4b0c3d879e1e70ee1e4e3 ]
__free_pages_bootmem prepares a page for release to the buddy allocator
and assumes that the struct page is initialised. Parallel initialisation
of struct pages defers initialisation and __free_pages_bootmem can be
called for struct pages that cannot yet map struct page to PFN. This
patch passes PFN to __free_pages_bootmem with no other functional change.
Tested-by: Nate Zimmer <nzimmer@sgi.com>
Tested-by: Waiman Long <waiman.long@hp.com>
Tested-by: Daniel J Blueman <daniel@numascale.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Nate Zimmer <nzimmer@sgi.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: Scott Norton <scott.norton@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
[ Upstream commit 588083bb37a3cea8533c392370a554417c8f29cb ]
When setting memory.high below usage, nothing happens until the next
charge comes along, and then it will only reclaim its own charge and not
the now potentially huge excess of the new memory.high. This can cause
groups to stay in excess of their memory.high indefinitely.
To fix that, when shrinking memory.high, kick off a reclaim cycle that
goes after the delta.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Vladimir Davydov <vdavydov@virtuozzo.com>
[ Upstream commit caaee6234d05a58c5b4d05e7bf766131b810a657 ]
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit 8479eba7781fa9ffb28268840de6facfc12c35a7 ]
Commit 4167e9b2cf10 ("mm: remove GFP_THISNODE") removed the GFP_THISNODE
flag combination due to confusing semantics. It noted that
alloc_misplaced_dst_page() was one such user after changes made by
commit e97ca8e5b864 ("mm: fix GFP_THISNODE callers and clarify").
Unfortunately when GFP_THISNODE was removed, users of
alloc_misplaced_dst_page() started waking kswapd and entering direct
reclaim because the wrong GFP flags are cleared. The consequence is
that workloads that used to fit into memory now get reclaimed which is
addressed by this patch.
The problem can be demonstrated with "mutilate" that exercises memcached
which is software dedicated to memory object caching. The configuration
uses 80% of memory and is run 3 times for varying numbers of clients.
The results on a 4-socket NUMA box are
mutilate
4.4.0 4.4.0
vanilla numaswap-v1
Hmean 1 8394.71 ( 0.00%) 8395.32 ( 0.01%)
Hmean 4 30024.62 ( 0.00%) 34513.54 ( 14.95%)
Hmean 7 32821.08 ( 0.00%) 70542.96 (114.93%)
Hmean 12 55229.67 ( 0.00%) 93866.34 ( 69.96%)
Hmean 21 39438.96 ( 0.00%) 85749.21 (117.42%)
Hmean 30 37796.10 ( 0.00%) 50231.49 ( 32.90%)
Hmean 47 18070.91 ( 0.00%) 38530.13 (113.22%)
The metric is queries/second with the more the better. The results are
way outside of the noise and the reason for the improvement is obvious
from some of the vmstats
4.4.0 4.4.0
vanillanumaswap-v1r1
Minor Faults 1929399272 2146148218
Major Faults 19746529 3567
Swap Ins 57307366 9913
Swap Outs 50623229 17094
Allocation stalls 35909 443
DMA allocs 0 0
DMA32 allocs 72976349 170567396
Normal allocs 5306640898 5310651252
Movable allocs 0 0
Direct pages scanned 404130893 799577
Kswapd pages scanned 160230174 0
Kswapd pages reclaimed 55928786 0
Direct pages reclaimed 1843936 41921
Page writes file 2391 0
Page writes anon 50623229 17094
The vanilla kernel is swapping like crazy with large amounts of direct
reclaim and kswapd activity. The figures are aggregate but it's known
that the bad activity is throughout the entire test.
Note that simple streaming anon/file memory consumers also see this
problem but it's not as obvious. In those cases, kswapd is awake when
it should not be.
As there are at least two reclaim-related bugs out there, it's worth
spelling out the user-visible impact. This patch only addresses bugs
related to excessive reclaim on NUMA hardware when the working set is
larger than a NUMA node. There is a bug related to high kswapd CPU
usage but the reports are against laptops and other UMA hardware and is
not addressed by this patch.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Cc: <stable@vger.kernel.org> [4.1+]
[ Upstream commit ad33bb04b2a6cee6c1f99fabb15cddbf93ff0433 ]
pmd_trans_unstable()/pmd_none_or_trans_huge_or_clear_bad() were
introduced to locklessy (but atomically) detect when a pmd is a regular
(stable) pmd or when the pmd is unstable and can infinitely transition
from pmd_none() and pmd_trans_huge() from under us, while only holding
the mmap_sem for reading (for writing not).
While holding the mmap_sem only for reading, MADV_DONTNEED can run from
under us and so before we can assume the pmd to be a regular stable pmd
we need to compare it against pmd_none() and pmd_trans_huge() in an
atomic way, with pmd_trans_unstable(). The old pmd_trans_huge() left a
tiny window for a race.
Useful applications are unlikely to notice the difference as doing
MADV_DONTNEED concurrently with a page fault would lead to undefined
behavior.
[akpm@linux-foundation.org: tidy up comment grammar/layout]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
[ Upstream commit 48f7df329474b49d83d0dffec1b6186647f11976 ]
Grazvydas Ignotas has reported a regression in remap_file_pages()
emulation.
Testcase:
#define _GNU_SOURCE
#include <assert.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/mman.h>
#define SIZE (4096 * 3)
int main(int argc, char **argv)
unsigned long *p;
long i;
p = mmap(NULL, SIZE, PROT_READ | PROT_WRITE,
MAP_SHARED | MAP_ANONYMOUS, -1, 0);
if (p == MAP_FAILED) {
perror("mmap");
return -1;
for (i = 0; i < SIZE / 4096; i++)
p[i * 4096 / sizeof(*p)] = i;
if (remap_file_pages(p, 4096, 0, 1, 0)) {
perror("remap_file_pages");
return -1;
if (remap_file_pages(p, 4096 * 2, 0, 1, 0)) {
return -1;
assert(p[0] == 1);
munmap(p, SIZE);
return 0;
The second remap_file_pages() fails with -EINVAL.
The reason is that remap_file_pages() emulation assumes that the target
vma covers whole area we want to over map. That assumption is broken by
first remap_file_pages() call: it split the area into two vma.
The solution is to check next adjacent vmas, if they map the same file
with the same flags.
Fixes: c8d78c1823f4 ("mm: replace remap_file_pages() syscall with emulation")
Reported-by: Grazvydas Ignotas <notasas@gmail.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Cc: <stable@vger.kernel.org> [4.0+]
[ Upstream commit 12352d3cae2cebe18805a91fab34b534d7444231 ]
Sequence vma_lock_anon_vma() - vma_unlock_anon_vma() isn't safe if
anon_vma appeared between lock and unlock. We have to check anon_vma
first or call anon_vma_prepare() to be sure that it's here. There are
only few users of these legacy helpers. Let's get rid of them.
This patch fixes anon_vma lock imbalance in validate_mm(). Write lock
isn't required here, read lock is enough.
And reorders expand_downwards/expand_upwards: security_mmap_addr() and
wrapping-around check don't have to be under anon vma lock.
Link: https://lkml.kernel.org/r/CACT4Y+Y908EjM2z=706dv4rV6dWtxTLK9nFg9_7DhRMLppBo2g@mail.gmail.com
[ Upstream commit 7162a1e87b3e380133dadc7909081bb70d0a7041 ]
Tetsuo Handa reported underflow of NR_MLOCK on munlock.
Testcase:
#include <stdio.h>
#include <stdlib.h>
#define BASE ((void *)0x400000000000)
#define SIZE (1UL << 21)
int main(int argc, char *argv[])
void *addr;
system("grep Mlocked /proc/meminfo");
addr = mmap(BASE, SIZE, PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_PRIVATE | MAP_LOCKED | MAP_FIXED,
-1, 0);
if (addr == MAP_FAILED)
printf("mmap() failed\n"), exit(1);
munmap(addr, SIZE);
return 0;
It happens on munlock_vma_page() due to unfortunate choice of nr_pages
data type:
__mod_zone_page_state(zone, NR_MLOCK, -nr_pages);
For unsigned int nr_pages, implicitly casted to long in
__mod_zone_page_state(), it becomes something around UINT_MAX.
munlock_vma_page() usually called for THP as small pages go though
pagevec.
Let's make nr_pages signed int.
Similar fixes in 6cdb18ad98a4 ("mm/vmstat: fix overflow in
mod_zone_page_state()") used `long' type, but `int' here is OK for a
count of the number of sub-pages in a huge page.
Fixes: ff6a6da60b89 ("mm: accelerate munlock() treatment of THP pages")
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [4.4+]
[ Upstream commit c102f07ca0b04f2cb49cfc161c83f6239d17f491 ]
record_obj() in migrate_zspage() does not preserve handle's
HANDLE_PIN_BIT, set by find_aloced_obj()->trypin_tag(), and implicitly
(accidentally) un-pins the handle, while migrate_zspage() still performs
an explicit unpin_tag() on the that handle. This additional explicit
unpin_tag() introduces a race condition with zs_free(), which can pin
that handle by this time, so the handle becomes un-pinned.
Schematically, it goes like this:
CPU0 CPU1
migrate_zspage
find_alloced_obj
trypin_tag
set HANDLE_PIN_BIT zs_free()
pin_tag()
obj_malloc() -- new object, no tag
record_obj() -- remove HANDLE_PIN_BIT set HANDLE_PIN_BIT
unpin_tag() -- remove zs_free's HANDLE_PIN_BIT
The race condition may result in a NULL pointer dereference:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
CPU: 0 PID: 19001 Comm: CookieMonsterCl Tainted:
PC is at get_zspage_mapping+0x0/0x24
LR is at obj_free.isra.22+0x64/0x128
Call trace:
zs_free+0x88/0x114
zram_free_page+0x64/0xcc
zram_slot_free_notify+0x90/0x108
swap_entry_free+0x278/0x294
free_swap_and_cache+0x38/0x11c
unmap_single_vma+0x480/0x5c8
unmap_vmas+0x44/0x60
exit_mmap+0x50/0x110
mmput+0x58/0xe0
do_exit+0x320/0x8dc
do_group_exit+0x44/0xa8
get_signal+0x538/0x580
do_signal+0x98/0x4b8
do_notify_resume+0x14/0x5c
This patch keeps the lock bit in migration path and update value
atomically.
Signed-off-by: Junil Lee <junil0814.lee@lge.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
[ Upstream commit 6611d8d76132f86faa501de9451a89bf23fb2371 ]
A spare array holding mem cgroup threshold events is kept around to make
sure we can always safely deregister an event and have an array to store
the new set of events in.
In the scenario where we're going from 1 to 0 registered events, the
pointer to the primary array containing 1 event is copied to the spare
slot, and then the spare slot is freed because no events are left.
However, it is freed before calling synchronize_rcu(), which means
readers may still be accessing threshold->primary after it is freed.
Fixed by only freeing after synchronize_rcu().
Signed-off-by: Martijn Coenen <maco@google.com>
[ Upstream commit d96b339f453997f2f08c52da3f41423be48c978f ]
I saw the following BUG_ON triggered in a testcase where a process calls
madvise(MADV_SOFT_OFFLINE) on thps, along with a background process that
calls migratepages command repeatedly (doing ping-pong among different
NUMA nodes) for the first process:
Soft offlining page 0x60000 at 0x700000600000
__get_any_page: 0x60000 free buddy page
page:ffffea0001800000 count:0 mapcount:-127 mapping: (null) index:0x1
flags: 0x1fffc0000000000()
page dumped because: VM_BUG_ON_PAGE(atomic_read(&page->_count) == 0)
kernel BUG at /src/linux-dev/include/linux/mm.h:342!
Modules linked in: cfg80211 rfkill crc32c_intel serio_raw virtio_balloon i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi
CPU: 3 PID: 3035 Comm: test_alloc_gene Tainted: G O 4.4.0-rc8-v4.4-rc8-160107-1501-00000-rc8+ #74
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88007c63d5c0 ti: ffff88007c210000 task.ti: ffff88007c210000
RIP: 0010:[<ffffffff8118998c>] [<ffffffff8118998c>] put_page+0x5c/0x60
RSP: 0018:ffff88007c213e00 EFLAGS: 00010246
Call Trace:
put_hwpoison_page+0x4e/0x80
soft_offline_page+0x501/0x520
SyS_madvise+0x6bc/0x6f0
entry_SYSCALL_64_fastpath+0x12/0x6a
Code: 8b fc ff ff 5b 5d c3 48 89 df e8 b0 fa ff ff 48 89 df 31 f6 e8 c6 7d ff ff 5b 5d c3 48 c7 c6 08 54 a2 81 48 89 df e8 a4 c5 01 00 <0f> 0b 66 90 66 66 66 66 90 55 48 89 e5 41 55 41 54 53 48 8b 47
RIP [<ffffffff8118998c>] put_page+0x5c/0x60
RSP <ffff88007c213e00>
The root cause resides in get_any_page() which retries to get a refcount
of the page to be soft-offlined. This function calls
put_hwpoison_page(), expecting that the target page is putback to LRU
list. But it can be also freed to buddy. So the second check need to
care about such case.
Fixes: af8fae7c0886 ("mm/memory-failure.c: clean up soft_offline_page()")
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Steve Capper <steve.capper@linaro.org>
Cc: <stable@vger.kernel.org> [3.9+]
[ Upstream commit 21ea9fb69e7c4b1b1559c3e410943d3ff248ffcb ]
In balloon_page_dequeue, pages_lock should cover the loop
(ie, list_for_each_entry_safe). Otherwise, the cursor page could
be isolated by compaction and then list_del by isolation could
poison the page->lru.{prev,next} so the loop finally could
access wrong address like this. This patch fixes the bug.
general protection fault: 0000 [#1] SMP
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 2 PID: 82 Comm: vballoon Not tainted 4.4.0-rc5-mm1-access_bit+ #1906
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8800a7ff0000 ti: ffff8800a7fec000 task.ti: ffff8800a7fec000
RIP: 0010:[<ffffffff8115e754>] [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130
RSP: 0018:ffff8800a7fefdc0 EFLAGS: 00010246
RAX: ffff88013fff9a70 RBX: ffffea000056fe00 RCX: 0000000000002b7d
RDX: ffff88013fff9a70 RSI: ffffea000056fe00 RDI: ffff88013fff9a68
RBP: ffff8800a7fefde8 R08: ffffea000056fda0 R09: 0000000000000000
R10: ffff8800a7fefd90 R11: 0000000000000001 R12: dead0000000000e0
R13: ffffea000056fe20 R14: ffff880138809070 R15: ffff880138809060
FS: 0000000000000000(0000) GS:ffff88013fc40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f229c10e000 CR3: 00000000b8b53000 CR4: 00000000000006a0
Stack:
0000000000000100 ffff880138809088 ffff880138809000 ffff880138809060
0000000000000046 ffff8800a7fefe28 ffffffff812c86d3 ffff880138809020
ffff880138809000 fffffffffff91900 0000000000000100 ffff880138809060
Call Trace:
[<ffffffff812c86d3>] leak_balloon+0x93/0x1a0
[<ffffffff812c8bc7>] balloon+0x217/0x2a0
[<ffffffff8143739e>] ? __schedule+0x31e/0x8b0
[<ffffffff81078160>] ? abort_exclusive_wait+0xb0/0xb0
[<ffffffff812c89b0>] ? update_balloon_stats+0xf0/0xf0
[<ffffffff8105b6e9>] kthread+0xc9/0xe0
[<ffffffff8105b620>] ? kthread_park+0x60/0x60
[<ffffffff8143b4af>] ret_from_fork+0x3f/0x70
Code: 8d 60 e0 0f 84 af 00 00 00 48 8b 43 20 a8 01 75 3b 48 89 d8 f0 0f ba 28 00 72 10 48 8b 03 f6 c4 08 75 2f 48 89 df e8 8c 83 f9 ff <49> 8b 44 24 20 4d 8d 6c 24 20 48 83 e8 20 4d 39 f5 74 7a 4c 89
RIP [<ffffffff8115e754>] balloon_page_dequeue+0x54/0x130
RSP <ffff8800a7fefdc0>
---[ end trace 43cf28060d708d5f ]---
Kernel panic - not syncing: Fatal exception
Kernel Offset: disabled
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
commit 47aee4d8e314384807e98b67ade07f6da476aa75 upstream.
Use is_zero_pfn() on pteval only after pte_present() check on pteval
(It might be better idea to introduce is_zero_pte() which checks
pte_present() first).
Otherwise when working on a swap or migration entry and if pte_pfn's
result is equal to zero_pfn by chance, we lose user's data in
__collapse_huge_page_copy(). So if you're unlucky, the application
segfaults and finally you could see below message on exit:
BUG: Bad rss-counter state mm:ffff88007f099300 idx:2 val:3
Fixes: ca0984caa823 ("mm: incorporate zero pages into transparent huge pages")
commit 296291cdd1629c308114504b850dc343eabc2782 upstream.
Currently a simple program below issues a sendfile(2) system call which
takes about 62 days to complete in my test KVM instance.
int fd;
off_t off = 0;
fd = open("file", O_RDWR | O_TRUNC | O_SYNC | O_CREAT, 0644);
ftruncate(fd, 2);
lseek(fd, 0, SEEK_END);
sendfile(fd, fd, &off, 0xfffffff);
Now you should not ask kernel to do a stupid stuff like copying 256MB in
2-byte chunks and call fsync(2) after each chunk but if you do, sysadmin
should have a way to stop you.
We actually do have a check for fatal_signal_pending() in
generic_perform_write() which triggers in this path however because we
always succeed in writing something before the check is done, we return
value > 0 from generic_perform_write() and thus the information about
signal gets lost.
Fix the problem by doing the signal check before writing anything. That
way generic_perform_write() returns -EINTR, the error gets propagated up
and the sendfile loop terminates early.
Signed-off-by: Jan Kara <jack@suse.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
commit 424cdc14138088ada1b0e407a2195b2783c6e5ef upstream.
page_counter_memparse() returns pages for the threshold, while
mem_cgroup_usage() returns bytes for memory usage. Convert the
threshold to bytes.
Fixes: 3e32cb2e0a12b6915 ("memcg: rename cgroup_event to mem_cgroup_event").
Signed-off-by: Shaohua Li <shli@fb.com>
commit 03a2d2a3eafe4015412cf4e9675ca0e2d9204074 upstream.
Commit description is copied from the original post of this bug:
http://comments.gmane.org/gmane.linux.kernel.mm/135349
Kernels after v3.9 use kmalloc_size(INDEX_NODE + 1) to get the next
larger cache size than the size index INDEX_NODE mapping. In kernels
3.9 and earlier we used malloc_sizes[INDEX_L3 + 1].cs_size.
However, sometimes we can't get the right output we expected via
kmalloc_size(INDEX_NODE + 1), causing a BUG().
The mapping table in the latest kernel is like:
index = {0, 1, 2 , 3, 4, 5, 6, n}
size = {0, 96, 192, 8, 16, 32, 64, 2^n}
The mapping table before 3.10 is like this:
index = {0 , 1 , 2, 3, 4 , 5 , 6, n}
size = {32, 64, 96, 128, 192, 256, 512, 2^(n+3)}
The problem on my mips64 machine is as follows:
(1) When configured DEBUG_SLAB && DEBUG_PAGEALLOC && DEBUG_LOCK_ALLOC
&& DEBUG_SPINLOCK, the sizeof(struct kmem_cache_node) will be "150",
and the macro INDEX_NODE turns out to be "2": #define INDEX_NODE
kmalloc_index(sizeof(struct kmem_cache_node))
(2) Then the result of kmalloc_size(INDEX_NODE + 1) is 8.
(3) Then "if(size >= kmalloc_size(INDEX_NODE + 1)" will lead to "size
= PAGE_SIZE".
(4) Then "if ((size >= (PAGE_SIZE >> 3))" test will be satisfied and
"flags |= CFLGS_OFF_SLAB" will be covered.
(5) if (flags & CFLGS_OFF_SLAB)" test will be satisfied and will go to
"cachep->slabp_cache = kmalloc_slab(slab_size, 0u)", and the result
here may be NULL while kernel bootup.
(6) Finally,"BUG_ON(ZERO_OR_NULL_PTR(cachep->slabp_cache));" causes the
BUG info as the following shows (may be only mips64 has this problem):
This patch fixes the problem of kmalloc_size(INDEX_NODE + 1) and removes
the BUG by adding 'size >= 256' check to guarantee that all necessary
small sized slabs are initialized regardless sequence of slab size in
mapping table.
Fixes: e33660165c90 ("slab: Use common kmalloc_index/kmalloc_size...")
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reported-by: Liuhailong <liu.hailong6@zte.com.cn>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
commit 2f84a8990ebbe235c59716896e017c6b2ca1200f upstream.
SunDong reported the following on
https://bugzilla.kernel.org/show_bug.cgi?id=103841
I think I find a linux bug, I have the test cases is constructed. I
can stable recurring problems in fedora22(4.0.4) kernel version,
arch for x86_64. I construct transparent huge page, when the parent
and child process with MAP_SHARE, MAP_PRIVATE way to access the same
huge page area, it has the opportunity to lead to huge page copy on
write failure, and then it will munmap the child corresponding mmap
area, but then the child mmap area with VM_MAYSHARE attributes, child
process munmap this area can trigger VM_BUG_ON in set_vma_resv_flags
functions (vma - > vm_flags & VM_MAYSHARE).
There were a number of problems with the report (e.g. it's hugetlbfs that
triggers this, not transparent huge pages) but it was fundamentally
correct in that a VM_BUG_ON in set_vma_resv_flags() can be triggered that
looks like this
vma ffff8804651fd0d0 start 00007fc474e00000 end 00007fc475e00000
next ffff8804651fd018 prev ffff8804651fd188 mm ffff88046b1b1800
prot 8000000000000027 anon_vma (null) vm_ops ffffffff8182a7a0
pgoff 0 file ffff88106bdb9800 private_data (null)
flags: 0x84400fb(read|write|shared|mayread|maywrite|mayexec|mayshare|dontexpand|hugetlb)
kernel BUG at mm/hugetlb.c:462!
SMP
Modules linked in: xt_pkttype xt_LOG xt_limit [..]
CPU: 38 PID: 26839 Comm: map Not tainted 4.0.4-default #1
Hardware name: Dell Inc. PowerEdge R810/0TT6JF, BIOS 2.7.4 04/26/2012
set_vma_resv_flags+0x2d/0x30
The VM_BUG_ON is correct because private and shared mappings have
different reservation accounting but the warning clearly shows that the
VMA is shared.
When a private COW fails to allocate a new page then only the process
that created the VMA gets the page -- all the children unmap the page.
If the children access that data in the future then they get killed.
The problem is that the same file is mapped shared and private. During
the COW, the allocation fails, the VMAs are traversed to unmap the other
private pages but a shared VMA is found and the bug is triggered. This
patch identifies such VMAs and skips them.
Reported-by: SunDong <sund_sky@126.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 3aaa76e125c1dd58c9b599baa8c6021896874c12 upstream.
Since commit bcc54222309c ("mm: hugetlb: introduce page_huge_active")
each hugetlb page maintains its active flag to avoid a race condition
betwe= en multiple calls of isolate_huge_page(), but current kernel
doesn't set the f= lag on a hugepage allocated by migration because the
proper putback routine isn= 't called. This means that users could
still encounter the race referred to by bcc54222309c in this special
case, so this patch fixes it.
Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active")
commit c54839a722a02818677bcabe57e957f0ce4f841d upstream.
reclaim_clean_pages_from_list() assumes that shrink_page_list() returns
number of pages removed from the candidate list. But shrink_page_list()
puts back mlocked pages without passing it to caller and without
counting as nr_reclaimed. This increases nr_isolated.
To fix this, this patch changes shrink_page_list() to pass unevictable
pages back to caller. Caller will take care those pages.
Minchan said:
It fixes two issues.
1. With unevictable page, cma_alloc will be successful.
Exactly speaking, cma_alloc of current kernel will fail due to
unevictable pages.
2. fix leaking of NR_ISOLATED counter of vmstat
With it, too_many_isolated works. Otherwise, it could make hang until
the process get SIGKILL.
Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com>
Acked-by: Minchan Kim <minchan@kernel.org>
commit 2f064f3485cd29633ad1b3cfb00cc519509a3d72 upstream.
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
commit 036138080a4376e5f3e5d0cca8ac99084c5cf06e upstream.
Hugetlbfs pages will get a refcount in get_any_page() or
madvise_hwpoison() if soft offlining through madvise. The refcount which
is held by the soft offline path should be released if we fail to isolate
hugetlbfs pages.
Fix it by reducing the refcount for both isolation success and failure.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit 4f32be677b124a49459e2603321c7a5605ceb9f8 upstream.
After trying to drain pages from pagevec/pageset, we try to get reference
count of the page again, however, the reference count of the page is not
reduced if the page is still not on LRU list.
Fix it by adding the put_page() to drop the page reference which is from
__get_any_page().
commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream.
Nikolay has reported a hang when a memcg reclaim got stuck with the
following backtrace:
PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync"
#0 __schedule at ffffffff815ab152
#1 schedule at ffffffff815ab76e
#2 schedule_timeout at ffffffff815ae5e5
#3 io_schedule_timeout at ffffffff815aad6a
#4 bit_wait_io at ffffffff815abfc6
#5 __wait_on_bit at ffffffff815abda5
#6 wait_on_page_bit at ffffffff8111fd4f
#7 shrink_page_list at ffffffff81135445
#8 shrink_inactive_list at ffffffff81135845
#9 shrink_lruvec at ffffffff81135ead
#10 shrink_zone at ffffffff811360c3
#11 shrink_zones at ffffffff81136eff
#12 do_try_to_free_pages at ffffffff8113712f
#13 try_to_free_mem_cgroup_pages at ffffffff811372be
#14 try_charge at ffffffff81189423
#15 mem_cgroup_try_charge at ffffffff8118c6f5
#16 __add_to_page_cache_locked at ffffffff8112137d
#17 add_to_page_cache_lru at ffffffff81121618
#18 pagecache_get_page at ffffffff8112170b
#19 grow_dev_page at ffffffff811c8297
#20 __getblk_slow at ffffffff811c91d6
#21 __getblk_gfp at ffffffff811c92c1
#22 ext4_ext_grow_indepth at ffffffff8124565c
#23 ext4_ext_create_new_leaf at ffffffff81246ca8
#24 ext4_ext_insert_extent at ffffffff81246f09
#25 ext4_ext_map_blocks at ffffffff8124a848
#26 ext4_map_blocks at ffffffff8121a5b7
#27 mpage_map_one_extent at ffffffff8121b1fa
#28 mpage_map_and_submit_extent at ffffffff8121f07b
#29 ext4_writepages at ffffffff8121f6d5
#30 do_writepages at ffffffff8112c490
#31 __filemap_fdatawrite_range at ffffffff81120199
#32 filemap_flush at ffffffff8112041c
#33 ext4_alloc_da_blocks at ffffffff81219da1
#34 ext4_rename at ffffffff81229b91
#35 ext4_rename2 at ffffffff81229e32
#36 vfs_rename at ffffffff811a08a5
#37 SYSC_renameat2 at ffffffff811a3ffc
#38 sys_renameat2 at ffffffff811a408e
#39 sys_rename at ffffffff8119e51e
#40 system_call_fastpath at ffffffff815afa89
Dave Chinner has properly pointed out that this is a deadlock in the
reclaim code because ext4 doesn't submit pages which are marked by
PG_writeback right away.
The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM
with too many dirty pages") and it was applied only when may_enter_fs
was specified. The code has been changed by c3b94f44fcb0 ("memcg:
further prevent OOM with too many dirty pages") which has removed the
__GFP_FS restriction with a reasoning that we do not get into the fs
code. But this is not sufficient apparently because the fs doesn't
necessarily submit pages marked PG_writeback for IO right away.
ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily
submit the bio. Instead it tries to map more pages into the bio and
mpage_map_one_extent might trigger memcg charge which might end up
waiting on a page which is marked PG_writeback but hasn't been submitted
yet so we would end up waiting for something that never finishes.
Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2)
before we go to wait on the writeback. The page fault path, which is
the only path that triggers memcg oom killer since 3.12, shouldn't
require GFP_NOFS and so we shouldn't reintroduce the premature OOM
killer issue which was originally addressed by the heuristic.
As per David Chinner the xfs is doing similar thing since 2.6.15 already
so ext4 is not the only affected filesystem. Moreover he notes:
: For example: IO completion might require unwritten extent conversion
: which executes filesystem transactions and GFP_NOFS allocations. The
: writeback flag on the pages can not be cleared until unwritten
: extent conversion completes. Hence memory reclaim cannot wait on
: page writeback to complete in GFP_NOFS context because it is not
: safe to do so, memcg reclaim or otherwise.
Cc: stable@vger.kernel.org # 3.9+
[tytso@mit.edu: corrected the control flow]
Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages")
Reported-by: Nikolay Borisov <kernel@kyup.com>
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream.
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
do_anonymous_page().
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 641844f5616d7c6597309f560838f996466d7aac upstream.
Currently the initial value of order in dissolve_free_huge_page is 64 or
32, which leads to the following warning in static checker:
mm/hugetlb.c:1203 dissolve_free_huge_pages()
warn: potential right shift more than type allows '9,18,64'
This is a potential risk of infinite loop, because 1 << order (== 0) is used
in for-loop like this:
for (pfn =3D start_pfn; pfn < end_pfn; pfn +=3D 1 << order)
So this patch fixes it by using global minimum_order calculated at boot time.
28313 469 84236 113018 1b97a mm/hugetlb.o
28256 473 84236 112965 1b945 mm/hugetlb.o (patched)
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 0867a57c4f80a566dda1bac975b42fcd857cb489 upstream.
Since commit 077fcf116c8c ("mm/thp: allocate transparent hugepages on
local node"), we handle THP allocations on page fault in a special way -
for non-interleave memory policies, the allocation is only attempted on
the node local to the current CPU, if the policy's nodemask allows the
node.
This is motivated by the assumption that THP benefits cannot offset the
cost of remote accesses, so it's better to fallback to base pages on the
local node (which might still be available, while huge pages are not due
to fragmentation) than to allocate huge pages on a remote node.
The nodemask check prevents us from violating e.g. MPOL_BIND policies
where the local node is not among the allowed nodes. However, the
current implementation can still give surprising results for the
MPOL_PREFERRED policy when the preferred node is different than the
current CPU's local node.
In such case we should honor the preferred node and not use the local
node, which is what this patch does. If hugepage allocation on the
preferred node fails, we fall back to base pages and don't try other
nodes, with the same motivation as is done for the local node hugepage
allocations. The patch also moves the MPOL_INTERLEAVE check around to
simplify the hugepage specific test.
The difference can be demonstrated using in-tree transhuge-stress test
on the following 2-node machine where half memory on one node was
occupied to show the difference.
> numactl --hardware
available: 2 nodes (0-1)
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 24 25 26 27 28 29 30 31 32 33 34 35
node 0 size: 7878 MB
node 0 free: 3623 MB
node 1 cpus: 12 13 14 15 16 17 18 19 20 21 22 23 36 37 38 39 40 41 42 43 44 45 46 47
node 1 size: 8045 MB
node 1 free: 7818 MB
node distances:
node 0 1
0: 10 21
1: 21 10
Before the patch:
> numactl -p0 -C0 ./transhuge-stress
transhuge-stress: 2.197 s/loop, 0.276 ms/page, 7249.168 MiB/s 7962 succeed, 0 failed, 1786 different pages
> numactl -p0 -C12 ./transhuge-stress
transhuge-stress: 2.962 s/loop, 0.372 ms/page, 5376.172 MiB/s 7962 succeed, 0 failed, 3873 different pages
Number of successful THP allocations corresponds to free memory on node 0 in
the first case and node 1 in the second case, i.e. -p parameter is ignored and
cpu binding "wins".
After the patch:
transhuge-stress: 2.183 s/loop, 0.274 ms/page, 7295.516 MiB/s 7962 succeed, 0 failed, 1760 different pages
transhuge-stress: 2.878 s/loop, 0.361 ms/page, 5533.638 MiB/s 7962 succeed, 0 failed, 1750 different pages
> numactl -p1 -C0 ./transhuge-stress
transhuge-stress: 4.628 s/loop, 0.581 ms/page, 3440.893 MiB/s 7962 succeed, 0 failed, 3918 different pages
The -p parameter is respected regardless of cpu binding.
> numactl -C0 ./transhuge-stress
transhuge-stress: 2.202 s/loop, 0.277 ms/page, 7230.003 MiB/s 7962 succeed, 0 failed, 1750 different pages
> numactl -C12 ./transhuge-stress
transhuge-stress: 3.020 s/loop, 0.379 ms/page, 5273.324 MiB/s 7962 succeed, 0 failed, 3916 different pages
Without -p parameter, hugepage restriction to CPU-local node works as before.
Fixes: 077fcf116c8c ("mm/thp: allocate transparent hugepages on local node")
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 8a8c35fadfaf55629a37ef1a8ead1b8fb32581d2 upstream.
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tejun Heo <tj@kernel.org>
commit c5f3b1a51a591c18c8b33983908e7fdda6ae417e upstream.
The kmemleak scanning thread can run for minutes. Callbacks like
kmemleak_free() are allowed during this time, the race being taken care
of by the object->lock spinlock. Such lock also prevents a memory block
from being freed or unmapped while it is being scanned by blocking the
kmemleak_free() -> ... -> __delete_object() function until the lock is
released in scan_object().
When a kmemleak error occurs (e.g. it fails to allocate its metadata),
kmemleak_enabled is set and __delete_object() is no longer called on
freed objects. If kmemleak_scan is running at the same time,
kmemleak_free() no longer waits for the object scanning to complete,
allowing the corresponding memory block to be freed or unmapped (in the
case of vfree()). This leads to kmemleak_scan potentially triggering a
page fault.
This patch separates the kmemleak_free() enabling/disabling from the
overall kmemleak_enabled nob so that we can defer the disabling of the
object freeing tracking until the scanning thread completed. The
kmemleak_free_part() is deliberately ignored by this patch since this is
only called during boot before the scanning thread started.
Reported-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
Tested-by: Vignesh Radhakrishnan <vigneshr@codeaurora.org>
It appears that, at some point last year, XFS made directory handling
changes which bring it into lockdep conflict with shmem_zero_setup():
it is surprising that mmap() can clone an inode while holding mmap_sem,
but that has been so for many years.
Since those few lockdep traces that I've seen all implicated selinux,
I'm hoping that we can use the __shmem_file_setup(,,,S_PRIVATE) which
v3.13's commit c7277090927a ("security: shmem: implement kernel private
shmem inodes") introduced to avoid LSM checks on kernel-internal inodes:
the mmap("/dev/zero") cloned inode is indeed a kernel-internal detail.
This also covers the !CONFIG_SHMEM use of ramfs to support /dev/zero
(and MAP_SHARED|MAP_ANONYMOUS). I thought there were also drivers
which cloned inode in mmap(), but if so, I cannot locate them now.
Reported-and-tested-by: Prarit Bhargava <prarit@redhat.com>
Reported-and-tested-by: Daniel Wagner <wagi@monom.org>
Reported-and-tested-by: Morten Stevens <mstevens@fedoraproject.org>
If zs_create_pool()->create_handle_cache()->kmem_cache_create() or
pool->name allocation fails, zs_create_pool()->destroy_handle_cache()
will dereference the NULL pool->handle_cachep.
Modify destroy_handle_cache() to avoid this.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
