path: root/mm
2019-12-18Merge tag 'v4.14.159' into 4.14-2.0.x-imxMarcel Ziswiler
This is the 4.14.159 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/cpuidle-imx6sx.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/input/keyboard/imx_keypad.c drivers/net/can/flexcan.c drivers/net/can/rx-offload.c drivers/net/wireless/ath/ath10k/pci.c drivers/pci/dwc/pci-imx6.c drivers/spi/spi-fsl-lpspi.c drivers/usb/dwc3/gadget.c
2019-12-17mm/shmem.c: cast the type of unmap_start to u64Chen Jun
commit aa71ecd8d86500da6081a72da6b0b524007e0627 upstream. In 64bit system. sb->s_maxbytes of shmem filesystem is MAX_LFS_FILESIZE, which equal LLONG_MAX. If offset > LLONG_MAX - PAGE_SIZE, offset + len < LLONG_MAX in shmem_fallocate, which will pass the checking in vfs_fallocate. /* Check for wrap through zero too */ if (((offset + len) > inode->i_sb->s_maxbytes) || ((offset + len) < 0)) return -EFBIG; loff_t unmap_start = round_up(offset, PAGE_SIZE) in shmem_fallocate causes a overflow. Syzkaller reports a overflow problem in mm/shmem: UBSAN: Undefined behaviour in mm/shmem.c:2014:10 signed integer overflow: '9223372036854775807 + 1' cannot be represented in type 'long long int' CPU: 0 PID:17076 Comm: syz-executor0 Not tainted 4.1.46+ #1 Hardware name: linux, dummy-virt (DT) Call trace: dump_backtrace+0x0/0x2c8 arch/arm64/kernel/traps.c:100 show_stack+0x20/0x30 arch/arm64/kernel/traps.c:238 __dump_stack lib/dump_stack.c:15 [inline] ubsan_epilogue+0x18/0x70 lib/ubsan.c:164 handle_overflow+0x158/0x1b0 lib/ubsan.c:195 shmem_fallocate+0x6d0/0x820 mm/shmem.c:2104 vfs_fallocate+0x238/0x428 fs/open.c:312 SYSC_fallocate fs/open.c:335 [inline] SyS_fallocate+0x54/0xc8 fs/open.c:239 The highest bit of unmap_start will be appended with sign bit 1 (overflow) when calculate shmem_falloc.start: shmem_falloc.start = unmap_start >> PAGE_SHIFT. Fix it by casting the type of unmap_start to u64, when right shifted. This bug is found in LTS Linux 4.1. It also seems to exist in mainline. Link: http://lkml.kernel.org/r/1573867464-5107-1-git-send-email-chenjun102@huawei.com Signed-off-by: Chen Jun <chenjun102@huawei.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Qian Cai <cai@lca.pw> Cc: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17mm/vmstat.c: fix NUMA statistics updatesJanne Huttunen
[ Upstream commit 13c9aaf7fa01cc7600c61981609feadeef3354ec ] Scan through the whole array to see if an update is needed. While we're at it, use sizeof() to be safe against any possible type changes in the future. The bug here is that we wouldn't sync per-cpu counters into global ones if there was an update of numa_stats for higher cpus. Highly theoretical one though because it is much more probable that zone_stats are updated so we would refresh anyway. So I wouldn't bother to mark this for stable, yet something nice to fix. [mhocko@suse.com: changelog enhancement] Link: http://lkml.kernel.org/r/1541601517-17282-1-git-send-email-janne.huttunen@nokia.com Fixes: 1d90ca897cb0 ("mm: update NUMA counter threshold size") Signed-off-by: Janne Huttunen <janne.huttunen@nokia.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-05vmscan: return NODE_RECLAIM_NOSCAN in node_reclaim() when CONFIG_NUMA is nWei Yang
[ Upstream commit 8b09549c2bfd9f3f8f4cdad74107ef4f4ff9cdd7 ] Commit fa5e084e43eb ("vmscan: do not unconditionally treat zones that fail zone_reclaim() as full") changed the return value of node_reclaim(). The original return value 0 means NODE_RECLAIM_SOME after this commit. While the return value of node_reclaim() when CONFIG_NUMA is n is not changed. This will leads to call zone_watermark_ok() again. This patch fixes the return value by adjusting to NODE_RECLAIM_NOSCAN. Since node_reclaim() is only called in page_alloc.c, move it to mm/internal.h. Link: http://lkml.kernel.org/r/20181113080436.22078-1-richard.weiyang@gmail.com Signed-off-by: Wei Yang <richard.weiyang@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Matthew Wilcox <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01mm/memory_hotplug: don't access uninitialized memmaps in shrink_zone_span()David Hildenbrand
commit 7ce700bf11b5e2cb84e4352bbdf2123a7a239c84 upstream. Let's limit shrinking to !ZONE_DEVICE so we can fix the current code. We should never try to touch the memmap of offline sections where we could have uninitialized memmaps and could trigger BUGs when calling page_to_nid() on poisoned pages. There is no reliable way to distinguish an uninitialized memmap from an initialized memmap that belongs to ZONE_DEVICE, as we don't have anything like SECTION_IS_ONLINE we can use similar to pfn_to_online_section() for !ZONE_DEVICE memory. E.g., set_zone_contiguous() similarly relies on pfn_to_online_section() and will therefore never set a ZONE_DEVICE zone consecutive. Stopping to shrink the ZONE_DEVICE therefore results in no observable changes, besides /proc/zoneinfo indicating different boundaries - something we can totally live with. Before commit d0dc12e86b31 ("mm/memory_hotplug: optimize memory hotplug"), the memmap was initialized with 0 and the node with the right value. So the zone might be wrong but not garbage. After that commit, both the zone and the node will be garbage when touching uninitialized memmaps. Toshiki reported a BUG (race between delayed initialization of ZONE_DEVICE memmaps without holding the memory hotplug lock and concurrent zone shrinking). https://lkml.org/lkml/2019/11/14/1040 "Iteration of create and destroy namespace causes the panic as below: kernel BUG at mm/page_alloc.c:535! CPU: 7 PID: 2766 Comm: ndctl Not tainted 5.4.0-rc4 #6 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.11.0-0-g63451fca13-prebuilt.qemu-project.org 04/01/2014 RIP: 0010:set_pfnblock_flags_mask+0x95/0xf0 Call Trace: memmap_init_zone_device+0x165/0x17c memremap_pages+0x4c1/0x540 devm_memremap_pages+0x1d/0x60 pmem_attach_disk+0x16b/0x600 [nd_pmem] nvdimm_bus_probe+0x69/0x1c0 really_probe+0x1c2/0x3e0 driver_probe_device+0xb4/0x100 device_driver_attach+0x4f/0x60 bind_store+0xc9/0x110 kernfs_fop_write+0x116/0x190 vfs_write+0xa5/0x1a0 ksys_write+0x59/0xd0 do_syscall_64+0x5b/0x180 entry_SYSCALL_64_after_hwframe+0x44/0xa9 While creating a namespace and initializing memmap, if you destroy the namespace and shrink the zone, it will initialize the memmap outside the zone and trigger VM_BUG_ON_PAGE(!zone_spans_pfn(page_zone(page), pfn), page) in set_pfnblock_flags_mask()." This BUG is also mitigated by this commit, where we for now stop to shrink the ZONE_DEVICE zone until we can do it in a safe and clean way. Link: http://lkml.kernel.org/r/20191006085646.5768-5-david@redhat.com Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [visible after d0dc12e86b319] Signed-off-by: David Hildenbrand <david@redhat.com> Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Reported-by: Toshiki Fukasawa <t-fukasawa@vx.jp.nec.com> Cc: Oscar Salvador <osalvador@suse.de> Cc: David Hildenbrand <david@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Alexander Duyck <alexander.h.duyck@linux.intel.com> Cc: Alexander Potapenko <glider@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Cc: Damian Tometzki <damian.tometzki@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Halil Pasic <pasic@linux.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Jason Gunthorpe <jgg@ziepe.ca> Cc: Jun Yao <yaojun8558363@gmail.com> Cc: Logan Gunthorpe <logang@deltatee.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: "Matthew Wilcox (Oracle)" <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Pankaj Gupta <pagupta@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pavel Tatashin <pavel.tatashin@microsoft.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Qian Cai <cai@lca.pw> Cc: Rich Felker <dalias@libc.org> Cc: Robin Murphy <robin.murphy@arm.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Wei Yang <richardw.yang@linux.intel.com> Cc: Will Deacon <will@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Yu Zhao <yuzhao@google.com> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David Hildenbrand <david@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-01mm/memory_hotplug: make add_memory() take the device_hotplug_lockDavid Hildenbrand
[ Upstream commit 8df1d0e4a265f25dc1e7e7624ccdbcb4a6630c89 ] add_memory() currently does not take the device_hotplug_lock, however is aleady called under the lock from arch/powerpc/platforms/pseries/hotplug-memory.c drivers/acpi/acpi_memhotplug.c to synchronize against CPU hot-remove and similar. In general, we should hold the device_hotplug_lock when adding memory to synchronize against online/offline request (e.g. from user space) - which already resulted in lock inversions due to device_lock() and mem_hotplug_lock - see 30467e0b3be ("mm, hotplug: fix concurrent memory hot-add deadlock"). add_memory()/add_memory_resource() will create memory block devices, so this really feels like the right thing to do. Holding the device_hotplug_lock makes sure that a memory block device can really only be accessed (e.g. via .online/.state) from user space, once the memory has been fully added to the system. The lock is not held yet in drivers/xen/balloon.c arch/powerpc/platforms/powernv/memtrace.c drivers/s390/char/sclp_cmd.c drivers/hv/hv_balloon.c So, let's either use the locked variants or take the lock. Don't export add_memory_resource(), as it once was exported to be used by XEN, which is never built as a module. If somebody requires it, we also have to export a locked variant (as device_hotplug_lock is never exported). Link: http://lkml.kernel.org/r/20180925091457.28651-3-david@redhat.com Signed-off-by: David Hildenbrand <david@redhat.com> Reviewed-by: Pavel Tatashin <pavel.tatashin@microsoft.com> Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Rashmica Gupta <rashmica.g@gmail.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Juergen Gross <jgross@suse.com> Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com> Cc: John Allen <jallen@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mathieu Malaterre <malat@debian.org> Cc: Pavel Tatashin <pavel.tatashin@microsoft.com> Cc: YASUAKI ISHIMATSU <yasu.isimatu@gmail.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Philippe Ombredanne <pombredanne@nexb.com> Cc: Stephen Hemminger <sthemmin@microsoft.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01mm/page-writeback.c: fix range_cyclic writeback vs writepages deadlockDave Chinner
[ Upstream commit 64081362e8ff4587b4554087f3cfc73d3e0a4cd7 ] We've recently seen a workload on XFS filesystems with a repeatable deadlock between background writeback and a multi-process application doing concurrent writes and fsyncs to a small range of a file. range_cyclic writeback Process 1 Process 2 xfs_vm_writepages write_cache_pages writeback_index = 2 cycled = 0 .... find page 2 dirty lock Page 2 ->writepage page 2 writeback page 2 clean page 2 added to bio no more pages write() locks page 1 dirties page 1 locks page 2 dirties page 1 fsync() .... xfs_vm_writepages write_cache_pages start index 0 find page 1 towrite lock Page 1 ->writepage page 1 writeback page 1 clean page 1 added to bio find page 2 towrite lock Page 2 page 2 is writeback <blocks> write() locks page 1 dirties page 1 fsync() .... xfs_vm_writepages write_cache_pages start index 0 !done && !cycled sets index to 0, restarts lookup find page 1 dirty find page 1 towrite lock Page 1 page 1 is writeback <blocks> lock Page 1 <blocks> DEADLOCK because: - process 1 needs page 2 writeback to complete to make enough progress to issue IO pending for page 1 - writeback needs page 1 writeback to complete so process 2 can progress and unlock the page it is blocked on, then it can issue the IO pending for page 2 - process 2 can't make progress until process 1 issues IO for page 1 The underlying cause of the problem here is that range_cyclic writeback is processing pages in descending index order as we hold higher index pages in a structure controlled from above write_cache_pages(). The write_cache_pages() caller needs to be able to submit these pages for IO before write_cache_pages restarts writeback at mapping index 0 to avoid wcp inverting the page lock/writeback wait order. generic_writepages() is not susceptible to this bug as it has no private context held across write_cache_pages() - filesystems using this infrastructure always submit pages in ->writepage immediately and so there is no problem with range_cyclic going back to mapping index 0. However: mpage_writepages() has a private bio context, exofs_writepages() has page_collect fuse_writepages() has fuse_fill_wb_data nfs_writepages() has nfs_pageio_descriptor xfs_vm_writepages() has xfs_writepage_ctx All of these ->writepages implementations can hold pages under writeback in their private structures until write_cache_pages() returns, and hence they are all susceptible to this deadlock. Also worth noting is that ext4 has it's own bastardised version of write_cache_pages() and so it /may/ have an equivalent deadlock. I looked at the code long enough to understand that it has a similar retry loop for range_cyclic writeback reaching the end of the file and then promptly ran away before my eyes bled too much. I'll leave it for the ext4 developers to determine if their code is actually has this deadlock and how to fix it if it has. There's a few ways I can see avoid this deadlock. There's probably more, but these are the first I've though of: 1. get rid of range_cyclic altogether 2. range_cyclic always stops at EOF, and we start again from writeback index 0 on the next call into write_cache_pages() 2a. wcp also returns EAGAIN to ->writepages implementations to indicate range cyclic has hit EOF. writepages implementations can then flush the current context and call wpc again to continue. i.e. lift the retry into the ->writepages implementation 3. range_cyclic uses trylock_page() rather than lock_page(), and it skips pages it can't lock without blocking. It will already do this for pages under writeback, so this seems like a no-brainer 3a. all non-WB_SYNC_ALL writeback uses trylock_page() to avoid blocking as per pages under writeback. I don't think #1 is an option - range_cyclic prevents frequently dirtied lower file offset from starving background writeback of rarely touched higher file offsets. #2 is simple, and I don't think it will have any impact on performance as going back to the start of the file implies an immediate seek. We'll have exactly the same number of seeks if we switch writeback to another inode, and then come back to this one later and restart from index 0. #2a is pretty much "status quo without the deadlock". Moving the retry loop up into the wcp caller means we can issue IO on the pending pages before calling wcp again, and so avoid locking or waiting on pages in the wrong order. I'm not convinced we need to do this given that we get the same thing from #2 on the next writeback call from the writeback infrastructure. #3 is really just a band-aid - it doesn't fix the access/wait inversion problem, just prevents it from becoming a deadlock situation. I'd prefer we fix the inversion, not sweep it under the carpet like this. #3a is really an optimisation that just so happens to include the band-aid fix of #3. So it seems that the simplest way to fix this issue is to implement solution #2 Link: http://lkml.kernel.org/r/20181005054526.21507-1-david@fromorbit.com Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Jan Kara <jack@suse.de> Cc: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01mm/ksm.c: don't WARN if page is still mapped in remove_stable_node()Andrey Ryabinin
commit 9a63236f1ad82d71a98aa80320b6cb618fb32f44 upstream. It's possible to hit the WARN_ON_ONCE(page_mapped(page)) in remove_stable_node() when it races with __mmput() and squeezes in between ksm_exit() and exit_mmap(). WARNING: CPU: 0 PID: 3295 at mm/ksm.c:888 remove_stable_node+0x10c/0x150 Call Trace: remove_all_stable_nodes+0x12b/0x330 run_store+0x4ef/0x7b0 kernfs_fop_write+0x200/0x420 vfs_write+0x154/0x450 ksys_write+0xf9/0x1d0 do_syscall_64+0x99/0x510 entry_SYSCALL_64_after_hwframe+0x49/0xbe Remove the warning as there is nothing scary going on. Link: http://lkml.kernel.org/r/20191119131850.5675-1-aryabinin@virtuozzo.com Fixes: cbf86cfe04a6 ("ksm: remove old stable nodes more thoroughly") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-24mm/memory_hotplug: fix updating the node spanDavid Hildenbrand
commit 656d571193262a11c2daa4012e53e4d645bbce56 upstream. We recently started updating the node span based on the zone span to avoid touching uninitialized memmaps. Currently, we will always detect the node span to start at 0, meaning a node can easily span too many pages. pgdat_is_empty() will still work correctly if all zones span no pages. We should skip over all zones without spanned pages and properly handle the first detected zone that spans pages. Unfortunately, in contrast to the zone span (/proc/zoneinfo), the node span cannot easily be inspected and tested. The node span gives no real guarantees when an architecture supports memory hotplug, meaning it can easily contain holes or span pages of different nodes. The node span is not really used after init on architectures that support memory hotplug. E.g., we use it in mm/memory_hotplug.c:try_offline_node() and in mm/kmemleak.c:kmemleak_scan(). These users seem to be fine. Link: http://lkml.kernel.org/r/20191027222714.5313-1-david@redhat.com Fixes: 00d6c019b5bc ("mm/memory_hotplug: don't access uninitialized memmaps in shrink_pgdat_span()") Signed-off-by: David Hildenbrand <david@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Oscar Salvador <osalvador@suse.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-24mm/memory_hotplug: don't access uninitialized memmaps in shrink_pgdat_span()David Hildenbrand
commit 00d6c019b5bc175cee3770e0e659f2b5f4804ea5 upstream. We might use the nid of memmaps that were never initialized. For example, if the memmap was poisoned, we will crash the kernel in pfn_to_nid() right now. Let's use the calculated boundaries of the separate zones instead. This now also avoids having to iterate over a whole bunch of subsections again, after shrinking one zone. Before commit d0dc12e86b31 ("mm/memory_hotplug: optimize memory hotplug"), the memmap was initialized to 0 and the node was set to the right value. After that commit, the node might be garbage. We'll have to fix shrink_zone_span() next. Link: http://lkml.kernel.org/r/20191006085646.5768-4-david@redhat.com Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [d0dc12e86b319] Signed-off-by: David Hildenbrand <david@redhat.com> Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> Cc: Oscar Salvador <osalvador@suse.de> Cc: David Hildenbrand <david@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Pavel Tatashin <pasha.tatashin@soleen.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Wei Yang <richardw.yang@linux.intel.com> Cc: Alexander Duyck <alexander.h.duyck@linux.intel.com> Cc: Alexander Potapenko <glider@google.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Cc: Damian Tometzki <damian.tometzki@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Halil Pasic <pasic@linux.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ira Weiny <ira.weiny@intel.com> Cc: Jason Gunthorpe <jgg@ziepe.ca> Cc: Jun Yao <yaojun8558363@gmail.com> Cc: Logan Gunthorpe <logang@deltatee.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: "Matthew Wilcox (Oracle)" <willy@infradead.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Pankaj Gupta <pagupta@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pavel Tatashin <pavel.tatashin@microsoft.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Qian Cai <cai@lca.pw> Cc: Rich Felker <dalias@libc.org> Cc: Robin Murphy <robin.murphy@arm.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Lendacky <thomas.lendacky@amd.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Gorbik <gor@linux.ibm.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wei Yang <richard.weiyang@gmail.com> Cc: Will Deacon <will@kernel.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Yu Zhao <yuzhao@google.com> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-20memfd: Use radix_tree_deref_slot_protected to avoid the warning.zhong jiang
The commit 391d4ee568b5 ("memfd: Fix locking when tagging pins") introduces the following warning messages. *WARNING: suspicious RCU usage in memfd_wait_for_pins* It is because we still use radix_tree_deref_slot without read_rcu_lock. We should use radix_tree_deref_slot_protected instead in the case. Cc: stable@vger.kernel.org Fixes: 391d4ee568b5 ("memfd: Fix locking when tagging pins") Signed-off-by: zhong jiang <zhongjiang@huawei.com> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-20mm: hugetlb: switch to css_tryget() in hugetlb_cgroup_charge_cgroup()Roman Gushchin
commit 0362f326d86c645b5e96b7dbc3ee515986ed019d upstream. An exiting task might belong to an offline cgroup. In this case an attempt to grab a cgroup reference from the task can end up with an infinite loop in hugetlb_cgroup_charge_cgroup(), because neither the cgroup will become online, neither the task will be migrated to a live cgroup. Fix this by switching over to css_tryget(). As css_tryget_online() can't guarantee that the cgroup won't go offline, in most cases the check doesn't make sense. In this particular case users of hugetlb_cgroup_charge_cgroup() are not affected by this change. A similar problem is described by commit 18fa84a2db0e ("cgroup: Use css_tryget() instead of css_tryget_online() in task_get_css()"). Link: http://lkml.kernel.org/r/20191106225131.3543616-2-guro@fb.com Signed-off-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Shakeel Butt <shakeelb@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-20mm: memcg: switch to css_tryget() in get_mem_cgroup_from_mm()Roman Gushchin
commit 00d484f354d85845991b40141d40ba9e5eb60faf upstream. We've encountered a rcu stall in get_mem_cgroup_from_mm(): rcu: INFO: rcu_sched self-detected stall on CPU rcu: 33-....: (21000 ticks this GP) idle=6c6/1/0x4000000000000002 softirq=35441/35441 fqs=5017 (t=21031 jiffies g=324821 q=95837) NMI backtrace for cpu 33 <...> RIP: 0010:get_mem_cgroup_from_mm+0x2f/0x90 <...> __memcg_kmem_charge+0x55/0x140 __alloc_pages_nodemask+0x267/0x320 pipe_write+0x1ad/0x400 new_sync_write+0x127/0x1c0 __kernel_write+0x4f/0xf0 dump_emit+0x91/0xc0 writenote+0xa0/0xc0 elf_core_dump+0x11af/0x1430 do_coredump+0xc65/0xee0 get_signal+0x132/0x7c0 do_signal+0x36/0x640 exit_to_usermode_loop+0x61/0xd0 do_syscall_64+0xd4/0x100 entry_SYSCALL_64_after_hwframe+0x44/0xa9 The problem is caused by an exiting task which is associated with an offline memcg. We're iterating over and over in the do {} while (!css_tryget_online()) loop, but obviously the memcg won't become online and the exiting task won't be migrated to a live memcg. Let's fix it by switching from css_tryget_online() to css_tryget(). As css_tryget_online() cannot guarantee that the memcg won't go offline, the check is usually useless, except some rare cases when for example it determines if something should be presented to a user. A similar problem is described by commit 18fa84a2db0e ("cgroup: Use css_tryget() instead of css_tryget_online() in task_get_css()"). Johannes: : The bug aside, it doesn't matter whether the cgroup is online for the : callers. It used to matter when offlining needed to evacuate all charges : from the memcg, and so needed to prevent new ones from showing up, but we : don't care now. Link: http://lkml.kernel.org/r/20191106225131.3543616-1-guro@fb.com Signed-off-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Shakeel Butt <shakeeb@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Michal Koutn <mkoutny@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12mm/filemap.c: don't initiate writeback if mapping has no dirty pagesKonstantin Khlebnikov
commit c3aab9a0bd91b696a852169479b7db1ece6cbf8c upstream. Functions like filemap_write_and_wait_range() should do nothing if inode has no dirty pages or pages currently under writeback. But they anyway construct struct writeback_control and this does some atomic operations if CONFIG_CGROUP_WRITEBACK=y - on fast path it locks inode->i_lock and updates state of writeback ownership, on slow path might be more work. Current this path is safely avoided only when inode mapping has no pages. For example generic_file_read_iter() calls filemap_write_and_wait_range() at each O_DIRECT read - pretty hot path. This patch skips starting new writeback if mapping has no dirty tags set. If writeback is already in progress filemap_write_and_wait_range() will wait for it. Link: http://lkml.kernel.org/r/156378816804.1087.8607636317907921438.stgit@buzz Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12mm, vmstat: hide /proc/pagetypeinfo from normal usersMichal Hocko
commit abaed0112c1db08be15a784a2c5c8a8b3063cdd3 upstream. /proc/pagetypeinfo is a debugging tool to examine internal page allocator state wrt to fragmentation. It is not very useful for any other use so normal users really do not need to read this file. Waiman Long has noticed that reading this file can have negative side effects because zone->lock is necessary for gathering data and that a) interferes with the page allocator and its users and b) can lead to hard lockups on large machines which have very long free_list. Reduce both issues by simply not exporting the file to regular users. Link: http://lkml.kernel.org/r/20191025072610.18526-2-mhocko@kernel.org Fixes: 467c996c1e19 ("Print out statistics in relation to fragmentation avoidance to /proc/pagetypeinfo") Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Waiman Long <longman@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Waiman Long <longman@redhat.com> Acked-by: Rafael Aquini <aquini@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: David Hildenbrand <david@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Roman Gushchin <guro@fb.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Jann Horn <jannh@google.com> Cc: Song Liu <songliubraving@fb.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29hugetlbfs: don't access uninitialized memmaps in pfn_range_valid_gigantic()David Hildenbrand
commit f231fe4235e22e18d847e05cbe705deaca56580a upstream. Uninitialized memmaps contain garbage and in the worst case trigger kernel BUGs, especially with CONFIG_PAGE_POISONING. They should not get touched. Let's make sure that we only consider online memory (managed by the buddy) that has initialized memmaps. ZONE_DEVICE is not applicable. page_zone() will call page_to_nid(), which will trigger VM_BUG_ON_PGFLAGS(PagePoisoned(page), page) with CONFIG_PAGE_POISONING and CONFIG_DEBUG_VM_PGFLAGS when called on uninitialized memmaps. This can be the case when an offline memory block (e.g., never onlined) is spanned by a zone. Note: As explained by Michal in [1], alloc_contig_range() will verify the range. So it boils down to the wrong access in this function. [1] http://lkml.kernel.org/r/20180423000943.GO17484@dhcp22.suse.cz Link: http://lkml.kernel.org/r/20191015120717.4858-1-david@redhat.com Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [visible after d0dc12e86b319] Signed-off-by: David Hildenbrand <david@redhat.com> Reported-by: Michal Hocko <mhocko@kernel.org> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Cc: Anshuman Khandual <anshuman.khandual@arm.com> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29mm/page_owner: don't access uninitialized memmaps when reading ↵Qian Cai
/proc/pagetypeinfo commit a26ee565b6cd8dc2bf15ff6aa70bbb28f928b773 upstream. Uninitialized memmaps contain garbage and in the worst case trigger kernel BUGs, especially with CONFIG_PAGE_POISONING. They should not get touched. For example, when not onlining a memory block that is spanned by a zone and reading /proc/pagetypeinfo with CONFIG_DEBUG_VM_PGFLAGS and CONFIG_PAGE_POISONING, we can trigger a kernel BUG: :/# echo 1 > /sys/devices/system/memory/memory40/online :/# echo 1 > /sys/devices/system/memory/memory42/online :/# cat /proc/pagetypeinfo > test.file page:fffff2c585200000 is uninitialized and poisoned raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p)) There is not page extension available. ------------[ cut here ]------------ kernel BUG at include/linux/mm.h:1107! invalid opcode: 0000 [#1] SMP NOPTI Please note that this change does not affect ZONE_DEVICE, because pagetypeinfo_showmixedcount_print() is called from mm/vmstat.c:pagetypeinfo_showmixedcount() only for populated zones, and ZONE_DEVICE is never populated (zone->present_pages always 0). [david@redhat.com: move check to outer loop, add comment, rephrase description] Link: http://lkml.kernel.org/r/20191011140638.8160-1-david@redhat.com Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") # visible after d0dc12e86b319 Signed-off-by: Qian Cai <cai@lca.pw> Signed-off-by: David Hildenbrand <david@redhat.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Miles Chen <miles.chen@mediatek.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Qian Cai <cai@lca.pw> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29mm/slub: fix a deadlock in show_slab_objects()Qian Cai
commit e4f8e513c3d353c134ad4eef9fd0bba12406c7c8 upstream. A long time ago we fixed a similar deadlock in show_slab_objects() [1]. However, it is apparently due to the commits like 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path") and 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}"), this kind of deadlock is back by just reading files in /sys/kernel/slab which will generate a lockdep splat below. Since the "mem_hotplug_lock" here is only to obtain a stable online node mask while racing with NUMA node hotplug, in the worst case, the results may me miscalculated while doing NUMA node hotplug, but they shall be corrected by later reads of the same files. WARNING: possible circular locking dependency detected ------------------------------------------------------ cat/5224 is trying to acquire lock: ffff900012ac3120 (mem_hotplug_lock.rw_sem){++++}, at: show_slab_objects+0x94/0x3a8 but task is already holding lock: b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (kn->count#45){++++}: lock_acquire+0x31c/0x360 __kernfs_remove+0x290/0x490 kernfs_remove+0x30/0x44 sysfs_remove_dir+0x70/0x88 kobject_del+0x50/0xb0 sysfs_slab_unlink+0x2c/0x38 shutdown_cache+0xa0/0xf0 kmemcg_cache_shutdown_fn+0x1c/0x34 kmemcg_workfn+0x44/0x64 process_one_work+0x4f4/0x950 worker_thread+0x390/0x4bc kthread+0x1cc/0x1e8 ret_from_fork+0x10/0x18 -> #1 (slab_mutex){+.+.}: lock_acquire+0x31c/0x360 __mutex_lock_common+0x16c/0xf78 mutex_lock_nested+0x40/0x50 memcg_create_kmem_cache+0x38/0x16c memcg_kmem_cache_create_func+0x3c/0x70 process_one_work+0x4f4/0x950 worker_thread+0x390/0x4bc kthread+0x1cc/0x1e8 ret_from_fork+0x10/0x18 -> #0 (mem_hotplug_lock.rw_sem){++++}: validate_chain+0xd10/0x2bcc __lock_acquire+0x7f4/0xb8c lock_acquire+0x31c/0x360 get_online_mems+0x54/0x150 show_slab_objects+0x94/0x3a8 total_objects_show+0x28/0x34 slab_attr_show+0x38/0x54 sysfs_kf_seq_show+0x198/0x2d4 kernfs_seq_show+0xa4/0xcc seq_read+0x30c/0x8a8 kernfs_fop_read+0xa8/0x314 __vfs_read+0x88/0x20c vfs_read+0xd8/0x10c ksys_read+0xb0/0x120 __arm64_sys_read+0x54/0x88 el0_svc_handler+0x170/0x240 el0_svc+0x8/0xc other info that might help us debug this: Chain exists of: mem_hotplug_lock.rw_sem --> slab_mutex --> kn->count#45 Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(kn->count#45); lock(slab_mutex); lock(kn->count#45); lock(mem_hotplug_lock.rw_sem); *** DEADLOCK *** 3 locks held by cat/5224: #0: 9eff00095b14b2a0 (&p->lock){+.+.}, at: seq_read+0x4c/0x8a8 #1: 0eff008997041480 (&of->mutex){+.+.}, at: kernfs_seq_start+0x34/0xf0 #2: b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0 stack backtrace: Call trace: dump_backtrace+0x0/0x248 show_stack+0x20/0x2c dump_stack+0xd0/0x140 print_circular_bug+0x368/0x380 check_noncircular+0x248/0x250 validate_chain+0xd10/0x2bcc __lock_acquire+0x7f4/0xb8c lock_acquire+0x31c/0x360 get_online_mems+0x54/0x150 show_slab_objects+0x94/0x3a8 total_objects_show+0x28/0x34 slab_attr_show+0x38/0x54 sysfs_kf_seq_show+0x198/0x2d4 kernfs_seq_show+0xa4/0xcc seq_read+0x30c/0x8a8 kernfs_fop_read+0xa8/0x314 __vfs_read+0x88/0x20c vfs_read+0xd8/0x10c ksys_read+0xb0/0x120 __arm64_sys_read+0x54/0x88 el0_svc_handler+0x170/0x240 el0_svc+0x8/0xc I think it is important to mention that this doesn't expose the show_slab_objects to use-after-free. There is only a single path that might really race here and that is the slab hotplug notifier callback __kmem_cache_shrink (via slab_mem_going_offline_callback) but that path doesn't really destroy kmem_cache_node data structures. [1] http://lkml.iu.edu/hypermail/linux/kernel/1101.0/02850.html [akpm@linux-foundation.org: add comment explaining why we don't need mem_hotplug_lock] Link: http://lkml.kernel.org/r/1570192309-10132-1-git-send-email-cai@lca.pw Fixes: 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path") Fixes: 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}") Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29memfd: Fix locking when tagging pinsMatthew Wilcox (Oracle)
The RCU lock is insufficient to protect the radix tree iteration as a deletion from the tree can occur before we take the spinlock to tag the entry. In 4.19, this has manifested as a bug with the following trace: kernel BUG at lib/radix-tree.c:1429! invalid opcode: 0000 [#1] SMP KASAN PTI CPU: 7 PID: 6935 Comm: syz-executor.2 Not tainted 4.19.36 #25 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:radix_tree_tag_set+0x200/0x2f0 lib/radix-tree.c:1429 Code: 00 00 5b 5d 41 5c 41 5d 41 5e 41 5f c3 48 89 44 24 10 e8 a3 29 7e fe 48 8b 44 24 10 48 0f ab 03 e9 d2 fe ff ff e8 90 29 7e fe <0f> 0b 48 c7 c7 e0 5a 87 84 e8 f0 e7 08 ff 4c 89 ef e8 4a ff ac fe RSP: 0018:ffff88837b13fb60 EFLAGS: 00010016 RAX: 0000000000040000 RBX: ffff8883c5515d58 RCX: ffffffff82cb2ef0 RDX: 0000000000000b72 RSI: ffffc90004cf2000 RDI: ffff8883c5515d98 RBP: ffff88837b13fb98 R08: ffffed106f627f7e R09: ffffed106f627f7e R10: 0000000000000001 R11: ffffed106f627f7d R12: 0000000000000004 R13: ffffea000d7fea80 R14: 1ffff1106f627f6f R15: 0000000000000002 FS: 00007fa1b8df2700(0000) GS:ffff8883e2fc0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fa1b8df1db8 CR3: 000000037d4d2001 CR4: 0000000000160ee0 Call Trace: memfd_tag_pins mm/memfd.c:51 [inline] memfd_wait_for_pins+0x2c5/0x12d0 mm/memfd.c:81 memfd_add_seals mm/memfd.c:215 [inline] memfd_fcntl+0x33d/0x4a0 mm/memfd.c:247 do_fcntl+0x589/0xeb0 fs/fcntl.c:421 __do_sys_fcntl fs/fcntl.c:463 [inline] __se_sys_fcntl fs/fcntl.c:448 [inline] __x64_sys_fcntl+0x12d/0x180 fs/fcntl.c:448 do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:293 The problem does not occur in mainline due to the XArray rewrite which changed the locking to exclude modification of the tree during iteration. At the time, nobody realised this was a bugfix. Backport the locking changes to stable. Cc: stable@vger.kernel.org Reported-by: zhong jiang <zhongjiang@huawei.com> Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-11usercopy: Avoid HIGHMEM pfn warningKees Cook
commit 314eed30ede02fa925990f535652254b5bad6b65 upstream. When running on a system with >512MB RAM with a 32-bit kernel built with: CONFIG_DEBUG_VIRTUAL=y CONFIG_HIGHMEM=y CONFIG_HARDENED_USERCOPY=y all execve()s will fail due to argv copying into kmap()ed pages, and on usercopy checking the calls ultimately of virt_to_page() will be looking for "bad" kmap (highmem) pointers due to CONFIG_DEBUG_VIRTUAL=y: ------------[ cut here ]------------ kernel BUG at ../arch/x86/mm/physaddr.c:83! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.3.0-rc8 #6 Hardware name: Dell Inc. Inspiron 1318/0C236D, BIOS A04 01/15/2009 EIP: __phys_addr+0xaf/0x100 ... Call Trace: __check_object_size+0xaf/0x3c0 ? __might_sleep+0x80/0xa0 copy_strings+0x1c2/0x370 copy_strings_kernel+0x2b/0x40 __do_execve_file+0x4ca/0x810 ? kmem_cache_alloc+0x1c7/0x370 do_execve+0x1b/0x20 ... The check is from arch/x86/mm/physaddr.c: VIRTUAL_BUG_ON((phys_addr >> PAGE_SHIFT) > max_low_pfn); Due to the kmap() in fs/exec.c: kaddr = kmap(kmapped_page); ... if (copy_from_user(kaddr+offset, str, bytes_to_copy)) ... Now we can fetch the correct page to avoid the pfn check. In both cases, hardened usercopy will need to walk the page-span checker (if enabled) to do sanity checking. Reported-by: Randy Dunlap <rdunlap@infradead.org> Tested-by: Randy Dunlap <rdunlap@infradead.org> Fixes: f5509cc18daa ("mm: Hardened usercopy") Cc: Matthew Wilcox <willy@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Link: https://lore.kernel.org/r/201909171056.7F2FFD17@keescook Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-05mm/compaction.c: clear total_{migrate,free}_scanned before scanning a new zoneYafang Shao
[ Upstream commit a94b525241c0fff3598809131d7cfcfe1d572d8c ] total_{migrate,free}_scanned will be added to COMPACTMIGRATE_SCANNED and COMPACTFREE_SCANNED in compact_zone(). We should clear them before scanning a new zone. In the proc triggered compaction, we forgot clearing them. [laoar.shao@gmail.com: introduce a helper compact_zone_counters_init()] Link: http://lkml.kernel.org/r/1563869295-25748-1-git-send-email-laoar.shao@gmail.com [akpm@linux-foundation.org: expand compact_zone_counters_init() into its single callsite, per mhocko] [vbabka@suse.cz: squash compact_zone() list_head init as well] Link: http://lkml.kernel.org/r/1fb6f7da-f776-9e42-22f8-bbb79b030b98@suse.cz [akpm@linux-foundation.org: kcompactd_do_work(): avoid unnecessary initialization of cc.zone] Link: http://lkml.kernel.org/r/1563789275-9639-1-git-send-email-laoar.shao@gmail.com Fixes: 7f354a548d1c ("mm, compaction: add vmstats for kcompactd work") Signed-off-by: Yafang Shao <laoar.shao@gmail.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Yafang Shao <shaoyafang@didiglobal.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-05memcg, kmem: do not fail __GFP_NOFAIL chargesMichal Hocko
commit e55d9d9bfb69405bd7615c0f8d229d8fafb3e9b8 upstream. Thomas has noticed the following NULL ptr dereference when using cgroup v1 kmem limit: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 PGD 0 P4D 0 Oops: 0000 [#1] PREEMPT SMP PTI CPU: 3 PID: 16923 Comm: gtk-update-icon Not tainted 4.19.51 #42 Hardware name: Gigabyte Technology Co., Ltd. Z97X-Gaming G1/Z97X-Gaming G1, BIOS F9 07/31/2015 RIP: 0010:create_empty_buffers+0x24/0x100 Code: cd 0f 1f 44 00 00 0f 1f 44 00 00 41 54 49 89 d4 ba 01 00 00 00 55 53 48 89 fb e8 97 fe ff ff 48 89 c5 48 89 c2 eb 03 48 89 ca <48> 8b 4a 08 4c 09 22 48 85 c9 75 f1 48 89 6a 08 48 8b 43 18 48 8d RSP: 0018:ffff927ac1b37bf8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: fffff2d4429fd740 RCX: 0000000100097149 RDX: 0000000000000000 RSI: 0000000000000082 RDI: ffff9075a99fbe00 RBP: 0000000000000000 R08: fffff2d440949cc8 R09: 00000000000960c0 R10: 0000000000000002 R11: 0000000000000000 R12: 0000000000000000 R13: ffff907601f18360 R14: 0000000000002000 R15: 0000000000001000 FS: 00007fb55b288bc0(0000) GS:ffff90761f8c0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 000000007aebc002 CR4: 00000000001606e0 Call Trace: create_page_buffers+0x4d/0x60 __block_write_begin_int+0x8e/0x5a0 ? ext4_inode_attach_jinode.part.82+0xb0/0xb0 ? jbd2__journal_start+0xd7/0x1f0 ext4_da_write_begin+0x112/0x3d0 generic_perform_write+0xf1/0x1b0 ? file_update_time+0x70/0x140 __generic_file_write_iter+0x141/0x1a0 ext4_file_write_iter+0xef/0x3b0 __vfs_write+0x17e/0x1e0 vfs_write+0xa5/0x1a0 ksys_write+0x57/0xd0 do_syscall_64+0x55/0x160 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Tetsuo then noticed that this is because the __memcg_kmem_charge_memcg fails __GFP_NOFAIL charge when the kmem limit is reached. This is a wrong behavior because nofail allocations are not allowed to fail. Normal charge path simply forces the charge even if that means to cross the limit. Kmem accounting should be doing the same. Link: http://lkml.kernel.org/r/20190906125608.32129-1-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Thomas Lindroth <thomas.lindroth@gmail.com> Debugged-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Thomas Lindroth <thomas.lindroth@gmail.com> Cc: Shakeel Butt <shakeelb@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-05memcg, oom: don't require __GFP_FS when invoking memcg OOM killerTetsuo Handa
commit f9c645621a28e37813a1de96d9cbd89cde94a1e4 upstream. Masoud Sharbiani noticed that commit 29ef680ae7c21110 ("memcg, oom: move out_of_memory back to the charge path") broke memcg OOM called from __xfs_filemap_fault() path. It turned out that try_charge() is retrying forever without making forward progress because mem_cgroup_oom(GFP_NOFS) cannot invoke the OOM killer due to commit 3da88fb3bacfaa33 ("mm, oom: move GFP_NOFS check to out_of_memory"). Allowing forced charge due to being unable to invoke memcg OOM killer will lead to global OOM situation. Also, just returning -ENOMEM will be risky because OOM path is lost and some paths (e.g. get_user_pages()) will leak -ENOMEM. Therefore, invoking memcg OOM killer (despite GFP_NOFS) will be the only choice we can choose for now. Until 29ef680ae7c21110, we were able to invoke memcg OOM killer when GFP_KERNEL reclaim failed [1]. But since 29ef680ae7c21110, we need to invoke memcg OOM killer when GFP_NOFS reclaim failed [2]. Although in the past we did invoke memcg OOM killer for GFP_NOFS [3], we might get pre-mature memcg OOM reports due to this patch. [1] leaker invoked oom-killer: gfp_mask=0x6200ca(GFP_HIGHUSER_MOVABLE), nodemask=(null), order=0, oom_score_adj=0 CPU: 0 PID: 2746 Comm: leaker Not tainted 4.18.0+ #19 Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018 Call Trace: dump_stack+0x63/0x88 dump_header+0x67/0x27a ? mem_cgroup_scan_tasks+0x91/0xf0 oom_kill_process+0x210/0x410 out_of_memory+0x10a/0x2c0 mem_cgroup_out_of_memory+0x46/0x80 mem_cgroup_oom_synchronize+0x2e4/0x310 ? high_work_func+0x20/0x20 pagefault_out_of_memory+0x31/0x76 mm_fault_error+0x55/0x115 ? handle_mm_fault+0xfd/0x220 __do_page_fault+0x433/0x4e0 do_page_fault+0x22/0x30 ? page_fault+0x8/0x30 page_fault+0x1e/0x30 RIP: 0033:0x4009f0 Code: 03 00 00 00 e8 71 fd ff ff 48 83 f8 ff 49 89 c6 74 74 48 89 c6 bf c0 0c 40 00 31 c0 e8 69 fd ff ff 45 85 ff 7e 21 31 c9 66 90 <41> 0f be 14 0e 01 d3 f7 c1 ff 0f 00 00 75 05 41 c6 04 0e 2a 48 83 RSP: 002b:00007ffe29ae96f0 EFLAGS: 00010206 RAX: 000000000000001b RBX: 0000000000000000 RCX: 0000000001ce1000 RDX: 0000000000000000 RSI: 000000007fffffe5 RDI: 0000000000000000 RBP: 000000000000000c R08: 0000000000000000 R09: 00007f94be09220d R10: 0000000000000002 R11: 0000000000000246 R12: 00000000000186a0 R13: 0000000000000003 R14: 00007f949d845000 R15: 0000000002800000 Task in /leaker killed as a result of limit of /leaker memory: usage 524288kB, limit 524288kB, failcnt 158965 memory+swap: usage 0kB, limit 9007199254740988kB, failcnt 0 kmem: usage 2016kB, limit 9007199254740988kB, failcnt 0 Memory cgroup stats for /leaker: cache:844KB rss:521136KB rss_huge:0KB shmem:0KB mapped_file:0KB dirty:132KB writeback:0KB inactive_anon:0KB active_anon:521224KB inactive_file:1012KB active_file:8KB unevictable:0KB Memory cgroup out of memory: Kill process 2746 (leaker) score 998 or sacrifice child Killed process 2746 (leaker) total-vm:536704kB, anon-rss:521176kB, file-rss:1208kB, shmem-rss:0kB oom_reaper: reaped process 2746 (leaker), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [2] leaker invoked oom-killer: gfp_mask=0x600040(GFP_NOFS), nodemask=(null), order=0, oom_score_adj=0 CPU: 1 PID: 2746 Comm: leaker Not tainted 4.18.0+ #20 Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018 Call Trace: dump_stack+0x63/0x88 dump_header+0x67/0x27a ? mem_cgroup_scan_tasks+0x91/0xf0 oom_kill_process+0x210/0x410 out_of_memory+0x109/0x2d0 mem_cgroup_out_of_memory+0x46/0x80 try_charge+0x58d/0x650 ? __radix_tree_replace+0x81/0x100 mem_cgroup_try_charge+0x7a/0x100 __add_to_page_cache_locked+0x92/0x180 add_to_page_cache_lru+0x4d/0xf0 iomap_readpages_actor+0xde/0x1b0 ? iomap_zero_range_actor+0x1d0/0x1d0 iomap_apply+0xaf/0x130 iomap_readpages+0x9f/0x150 ? iomap_zero_range_actor+0x1d0/0x1d0 xfs_vm_readpages+0x18/0x20 [xfs] read_pages+0x60/0x140 __do_page_cache_readahead+0x193/0x1b0 ondemand_readahead+0x16d/0x2c0 page_cache_async_readahead+0x9a/0xd0 filemap_fault+0x403/0x620 ? alloc_set_pte+0x12c/0x540 ? _cond_resched+0x14/0x30 __xfs_filemap_fault+0x66/0x180 [xfs] xfs_filemap_fault+0x27/0x30 [xfs] __do_fault+0x19/0x40 __handle_mm_fault+0x8e8/0xb60 handle_mm_fault+0xfd/0x220 __do_page_fault+0x238/0x4e0 do_page_fault+0x22/0x30 ? page_fault+0x8/0x30 page_fault+0x1e/0x30 RIP: 0033:0x4009f0 Code: 03 00 00 00 e8 71 fd ff ff 48 83 f8 ff 49 89 c6 74 74 48 89 c6 bf c0 0c 40 00 31 c0 e8 69 fd ff ff 45 85 ff 7e 21 31 c9 66 90 <41> 0f be 14 0e 01 d3 f7 c1 ff 0f 00 00 75 05 41 c6 04 0e 2a 48 83 RSP: 002b:00007ffda45c9290 EFLAGS: 00010206 RAX: 000000000000001b RBX: 0000000000000000 RCX: 0000000001a1e000 RDX: 0000000000000000 RSI: 000000007fffffe5 RDI: 0000000000000000 RBP: 000000000000000c R08: 0000000000000000 R09: 00007f6d061ff20d R10: 0000000000000002 R11: 0000000000000246 R12: 00000000000186a0 R13: 0000000000000003 R14: 00007f6ce59b2000 R15: 0000000002800000 Task in /leaker killed as a result of limit of /leaker memory: usage 524288kB, limit 524288kB, failcnt 7221 memory+swap: usage 0kB, limit 9007199254740988kB, failcnt 0 kmem: usage 1944kB, limit 9007199254740988kB, failcnt 0 Memory cgroup stats for /leaker: cache:3632KB rss:518232KB rss_huge:0KB shmem:0KB mapped_file:0KB dirty:0KB writeback:0KB inactive_anon:0KB active_anon:518408KB inactive_file:3908KB active_file:12KB unevictable:0KB Memory cgroup out of memory: Kill process 2746 (leaker) score 992 or sacrifice child Killed process 2746 (leaker) total-vm:536704kB, anon-rss:518264kB, file-rss:1188kB, shmem-rss:0kB oom_reaper: reaped process 2746 (leaker), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB [3] leaker invoked oom-killer: gfp_mask=0x50, order=0, oom_score_adj=0 leaker cpuset=/ mems_allowed=0 CPU: 1 PID: 3206 Comm: leaker Not tainted 3.10.0-957.27.2.el7.x86_64 #1 Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018 Call Trace: [<ffffffffaf364147>] dump_stack+0x19/0x1b [<ffffffffaf35eb6a>] dump_header+0x90/0x229 [<ffffffffaedbb456>] ? find_lock_task_mm+0x56/0xc0 [<ffffffffaee32a38>] ? try_get_mem_cgroup_from_mm+0x28/0x60 [<ffffffffaedbb904>] oom_kill_process+0x254/0x3d0 [<ffffffffaee36c36>] mem_cgroup_oom_synchronize+0x546/0x570 [<ffffffffaee360b0>] ? mem_cgroup_charge_common+0xc0/0xc0 [<ffffffffaedbc194>] pagefault_out_of_memory+0x14/0x90 [<ffffffffaf35d072>] mm_fault_error+0x6a/0x157 [<ffffffffaf3717c8>] __do_page_fault+0x3c8/0x4f0 [<ffffffffaf371925>] do_page_fault+0x35/0x90 [<ffffffffaf36d768>] page_fault+0x28/0x30 Task in /leaker killed as a result of limit of /leaker memory: usage 524288kB, limit 524288kB, failcnt 20628 memory+swap: usage 524288kB, limit 9007199254740988kB, failcnt 0 kmem: usage 0kB, limit 9007199254740988kB, failcnt 0 Memory cgroup stats for /leaker: cache:840KB rss:523448KB rss_huge:0KB mapped_file:0KB swap:0KB inactive_anon:0KB active_anon:523448KB inactive_file:464KB active_file:376KB unevictable:0KB Memory cgroup out of memory: Kill process 3206 (leaker) score 970 or sacrifice child Killed process 3206 (leaker) total-vm:536692kB, anon-rss:523304kB, file-rss:412kB, shmem-rss:0kB Bisected by Masoud Sharbiani. Link: http://lkml.kernel.org/r/cbe54ed1-b6ba-a056-8899-2dc42526371d@i-love.sakura.ne.jp Fixes: 3da88fb3bacfaa33 ("mm, oom: move GFP_NOFS check to out_of_memory") [necessary after 29ef680ae7c21110] Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: Masoud Sharbiani <msharbiani@apple.com> Tested-by: Masoud Sharbiani <msharbiani@apple.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [4.19+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-09-06mm/zsmalloc.c: fix build when CONFIG_COMPACTION=nAndrew Morton
commit 441e254cd40dc03beec3c650ce6ce6074bc6517f upstream. Fixes: 701d678599d0c1 ("mm/zsmalloc.c: fix race condition in zs_destroy_pool") Link: http://lkml.kernel.org/r/201908251039.5oSbEEUT%25lkp@intel.com Reported-by: kbuild test robot <lkp@intel.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-29mm/zsmalloc.c: fix race condition in zs_destroy_poolHenry Burns
commit 701d678599d0c1623aaf4139c03eea260a75b027 upstream. In zs_destroy_pool() we call flush_work(&pool->free_work). However, we have no guarantee that migration isn't happening in the background at that time. Since migration can't directly free pages, it relies on free_work being scheduled to free the pages. But there's nothing preventing an in-progress migrate from queuing the work *after* zs_unregister_migration() has called flush_work(). Which would mean pages still pointing at the inode when we free it. Since we know at destroy time all objects should be free, no new migrations can come in (since zs_page_isolate() fails for fully-free zspages). This means it is sufficient to track a "# isolated zspages" count by class, and have the destroy logic ensure all such pages have drained before proceeding. Keeping that state under the class spinlock keeps the logic straightforward. In this case a memory leak could lead to an eventual crash if compaction hits the leaked page. This crash would only occur if people are changing their zswap backend at runtime (which eventually starts destruction). Link: http://lkml.kernel.org/r/20190809181751.219326-2-henryburns@google.com Fixes: 48b4800a1c6a ("zsmalloc: page migration support") Signed-off-by: Henry Burns <henryburns@google.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-29mm/zsmalloc.c: migration can leave pages in ZS_EMPTY indefinitelyHenry Burns
commit 1a87aa03597efa9641e92875b883c94c7f872ccb upstream. In zs_page_migrate() we call putback_zspage() after we have finished migrating all pages in this zspage. However, the return value is ignored. If a zs_free() races in between zs_page_isolate() and zs_page_migrate(), freeing the last object in the zspage, putback_zspage() will leave the page in ZS_EMPTY for potentially an unbounded amount of time. To fix this, we need to do the same thing as zs_page_putback() does: schedule free_work to occur. To avoid duplicated code, move the sequence to a new putback_zspage_deferred() function which both zs_page_migrate() and zs_page_putback() call. Link: http://lkml.kernel.org/r/20190809181751.219326-1-henryburns@google.com Fixes: 48b4800a1c6a ("zsmalloc: page migration support") Signed-off-by: Henry Burns <henryburns@google.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Henry Burns <henrywolfeburns@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Shakeel Butt <shakeelb@google.com> Cc: Jonathan Adams <jwadams@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-29mm, page_owner: handle THP splits correctlyVlastimil Babka
commit f7da677bc6e72033f0981b9d58b5c5d409fa641e upstream. THP splitting path is missing the split_page_owner() call that split_page() has. As a result, split THP pages are wrongly reported in the page_owner file as order-9 pages. Furthermore when the former head page is freed, the remaining former tail pages are not listed in the page_owner file at all. This patch fixes that by adding the split_page_owner() call into __split_huge_page(). Link: http://lkml.kernel.org/r/20190820131828.22684-2-vbabka@suse.cz Fixes: a9627bc5e34e ("mm/page_owner: introduce split_page_owner and replace manual handling") Reported-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Matthew Wilcox <willy@infradead.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-25mm/memcontrol.c: fix use after free in mem_cgroup_iter()Miles Chen
commit 54a83d6bcbf8f4700013766b974bf9190d40b689 upstream. This patch is sent to report an use after free in mem_cgroup_iter() after merging commit be2657752e9e ("mm: memcg: fix use after free in mem_cgroup_iter()"). I work with android kernel tree (4.9 & 4.14), and commit be2657752e9e ("mm: memcg: fix use after free in mem_cgroup_iter()") has been merged to the trees. However, I can still observe use after free issues addressed in the commit be2657752e9e. (on low-end devices, a few times this month) backtrace: css_tryget <- crash here mem_cgroup_iter shrink_node shrink_zones do_try_to_free_pages try_to_free_pages __perform_reclaim __alloc_pages_direct_reclaim __alloc_pages_slowpath __alloc_pages_nodemask To debug, I poisoned mem_cgroup before freeing it: static void __mem_cgroup_free(struct mem_cgroup *memcg) for_each_node(node) free_mem_cgroup_per_node_info(memcg, node); free_percpu(memcg->stat); + /* poison memcg before freeing it */ + memset(memcg, 0x78, sizeof(struct mem_cgroup)); kfree(memcg); } The coredump shows the position=0xdbbc2a00 is freed. (gdb) p/x ((struct mem_cgroup_per_node *)0xe5009e00)->iter[8] $13 = {position = 0xdbbc2a00, generation = 0x2efd} 0xdbbc2a00: 0xdbbc2e00 0x00000000 0xdbbc2800 0x00000100 0xdbbc2a10: 0x00000200 0x78787878 0x00026218 0x00000000 0xdbbc2a20: 0xdcad6000 0x00000001 0x78787800 0x00000000 0xdbbc2a30: 0x78780000 0x00000000 0x0068fb84 0x78787878 0xdbbc2a40: 0x78787878 0x78787878 0x78787878 0xe3fa5cc0 0xdbbc2a50: 0x78787878 0x78787878 0x00000000 0x00000000 0xdbbc2a60: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a70: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a80: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a90: 0x00000001 0x00000000 0x00000000 0x00100000 0xdbbc2aa0: 0x00000001 0xdbbc2ac8 0x00000000 0x00000000 0xdbbc2ab0: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2ac0: 0x00000000 0x00000000 0xe5b02618 0x00001000 0xdbbc2ad0: 0x00000000 0x78787878 0x78787878 0x78787878 0xdbbc2ae0: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2af0: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b00: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b10: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b20: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b30: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b40: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b50: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b60: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b70: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b80: 0x78787878 0x78787878 0x00000000 0x78787878 0xdbbc2b90: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2ba0: 0x78787878 0x78787878 0x78787878 0x78787878 In the reclaim path, try_to_free_pages() does not setup sc.target_mem_cgroup and sc is passed to do_try_to_free_pages(), ..., shrink_node(). In mem_cgroup_iter(), root is set to root_mem_cgroup because sc->target_mem_cgroup is NULL. It is possible to assign a memcg to root_mem_cgroup.nodeinfo.iter in mem_cgroup_iter(). try_to_free_pages struct scan_control sc = {...}, target_mem_cgroup is 0x0; do_try_to_free_pages shrink_zones shrink_node mem_cgroup *root = sc->target_mem_cgroup; memcg = mem_cgroup_iter(root, NULL, &reclaim); mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... css = css_next_descendant_pre(css, &root->css); memcg = mem_cgroup_from_css(css); cmpxchg(&iter->position, pos, memcg); My device uses memcg non-hierarchical mode. When we release a memcg: invalidate_reclaim_iterators() reaches only dead_memcg and its parents. If non-hierarchical mode is used, invalidate_reclaim_iterators() never reaches root_mem_cgroup. static void invalidate_reclaim_iterators(struct mem_cgroup *dead_memcg) { struct mem_cgroup *memcg = dead_memcg; for (; memcg; memcg = parent_mem_cgroup(memcg) ... } So the use after free scenario looks like: CPU1 CPU2 try_to_free_pages do_try_to_free_pages shrink_zones shrink_node mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... css = css_next_descendant_pre(css, &root->css); memcg = mem_cgroup_from_css(css); cmpxchg(&iter->position, pos, memcg); invalidate_reclaim_iterators(memcg); ... __mem_cgroup_free() kfree(memcg); try_to_free_pages do_try_to_free_pages shrink_zones shrink_node mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... mz = mem_cgroup_nodeinfo(root, reclaim->pgdat->node_id); iter = &mz->iter[reclaim->priority]; pos = READ_ONCE(iter->position); css_tryget(&pos->css) <- use after free To avoid this, we should also invalidate root_mem_cgroup.nodeinfo.iter in invalidate_reclaim_iterators(). [cai@lca.pw: fix -Wparentheses compilation warning] Link: http://lkml.kernel.org/r/1564580753-17531-1-git-send-email-cai@lca.pw Link: http://lkml.kernel.org/r/20190730015729.4406-1-miles.chen@mediatek.com Fixes: 5ac8fb31ad2e ("mm: memcontrol: convert reclaim iterator to simple css refcounting") Signed-off-by: Miles Chen <miles.chen@mediatek.com> Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-25mm/usercopy: use memory range to be accessed for wraparound checkIsaac J. Manjarres
commit 951531691c4bcaa59f56a316e018bc2ff1ddf855 upstream. Currently, when checking to see if accessing n bytes starting at address "ptr" will cause a wraparound in the memory addresses, the check in check_bogus_address() adds an extra byte, which is incorrect, as the range of addresses that will be accessed is [ptr, ptr + (n - 1)]. This can lead to incorrectly detecting a wraparound in the memory address, when trying to read 4 KB from memory that is mapped to the the last possible page in the virtual address space, when in fact, accessing that range of memory would not cause a wraparound to occur. Use the memory range that will actually be accessed when considering if accessing a certain amount of bytes will cause the memory address to wrap around. Link: http://lkml.kernel.org/r/1564509253-23287-1-git-send-email-isaacm@codeaurora.org Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Prasad Sodagudi <psodagud@codeaurora.org> Signed-off-by: Isaac J. Manjarres <isaacm@codeaurora.org> Co-developed-by: Prasad Sodagudi <psodagud@codeaurora.org> Reviewed-by: William Kucharski <william.kucharski@oracle.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Trilok Soni <tsoni@codeaurora.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [kees: backport to v4.14] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-16mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()Joerg Roedel
commit 3f8fd02b1bf1d7ba964485a56f2f4b53ae88c167 upstream. On x86-32 with PTI enabled, parts of the kernel page-tables are not shared between processes. This can cause mappings in the vmalloc/ioremap area to persist in some page-tables after the region is unmapped and released. When the region is re-used the processes with the old mappings do not fault in the new mappings but still access the old ones. This causes undefined behavior, in reality often data corruption, kernel oopses and panics and even spontaneous reboots. Fix this problem by activly syncing unmaps in the vmalloc/ioremap area to all page-tables in the system before the regions can be re-used. References: https://bugzilla.suse.com/show_bug.cgi?id=1118689 Fixes: 5d72b4fba40ef ('x86, mm: support huge I/O mapping capability I/F') Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com> Link: https://lkml.kernel.org/r/20190719184652.11391-4-joro@8bytes.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-06mm/cma.c: fail if fixed declaration can't be honoredDoug Berger
[ Upstream commit c633324e311243586675e732249339685e5d6faa ] The description of cma_declare_contiguous() indicates that if the 'fixed' argument is true the reserved contiguous area must be exactly at the address of the 'base' argument. However, the function currently allows the 'base', 'size', and 'limit' arguments to be silently adjusted to meet alignment constraints. This commit enforces the documented behavior through explicit checks that return an error if the region does not fit within a specified region. Link: http://lkml.kernel.org/r/1561422051-16142-1-git-send-email-opendmb@gmail.com Fixes: 5ea3b1b2f8ad ("cma: add placement specifier for "cma=" kernel parameter") Signed-off-by: Doug Berger <opendmb@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Yue Hu <huyue2@yulong.com> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31mm/mmu_notifier: use hlist_add_head_rcu()Jean-Philippe Brucker
[ Upstream commit 543bdb2d825fe2400d6e951f1786d92139a16931 ] Make mmu_notifier_register() safer by issuing a memory barrier before registering a new notifier. This fixes a theoretical bug on weakly ordered CPUs. For example, take this simplified use of notifiers by a driver: my_struct->mn.ops = &my_ops; /* (1) */ mmu_notifier_register(&my_struct->mn, mm) ... hlist_add_head(&mn->hlist, &mm->mmu_notifiers); /* (2) */ ... Once mmu_notifier_register() releases the mm locks, another thread can invalidate a range: mmu_notifier_invalidate_range() ... hlist_for_each_entry_rcu(mn, &mm->mmu_notifiers, hlist) { if (mn->ops->invalidate_range) The read side relies on the data dependency between mn and ops to ensure that the pointer is properly initialized. But the write side doesn't have any dependency between (1) and (2), so they could be reordered and the readers could dereference an invalid mn->ops. mmu_notifier_register() does take all the mm locks before adding to the hlist, but those have acquire semantics which isn't sufficient. By calling hlist_add_head_rcu() instead of hlist_add_head() we update the hlist using a store-release, ensuring that readers see prior initialization of my_struct. This situation is better illustated by litmus test MP+onceassign+derefonce. Link: http://lkml.kernel.org/r/20190502133532.24981-1-jean-philippe.brucker@arm.com Fixes: cddb8a5c14aa ("mmu-notifiers: core") Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com> Cc: Jérôme Glisse <jglisse@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31mm/gup.c: remove some BUG_ONs from get_gate_page()Andy Lutomirski
[ Upstream commit b5d1c39f34d1c9bca0c4b9ae2e339fbbe264a9c7 ] If we end up without a PGD or PUD entry backing the gate area, don't BUG -- just fail gracefully. It's not entirely implausible that this could happen some day on x86. It doesn't right now even with an execute-only emulated vsyscall page because the fixmap shares the PUD, but the core mm code shouldn't rely on that particular detail to avoid OOPSing. Link: http://lkml.kernel.org/r/a1d9f4efb75b9d464e59fd6af00104b21c58f6f7.1561610798.git.luto@kernel.org Signed-off-by: Andy Lutomirski <luto@kernel.org> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Florian Weimer <fweimer@redhat.com> Cc: Jann Horn <jannh@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31mm/gup.c: mark undo_dev_pagemap as __maybe_unusedGuenter Roeck
[ Upstream commit 790c73690c2bbecb3f6f8becbdb11ddc9bcff8cc ] Several mips builds generate the following build warning. mm/gup.c:1788:13: warning: 'undo_dev_pagemap' defined but not used The function is declared unconditionally but only called from behind various ifdefs. Mark it __maybe_unused. Link: http://lkml.kernel.org/r/1562072523-22311-1-git-send-email-linux@roeck-us.net Signed-off-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Robin Murphy <robin.murphy@arm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31mm/kmemleak.c: fix check for softirq contextDmitry Vyukov
[ Upstream commit 6ef9056952532c3b746de46aa10d45b4d7797bd8 ] in_softirq() is a wrong predicate to check if we are in a softirq context. It also returns true if we have BH disabled, so objects are falsely stamped with "softirq" comm. The correct predicate is in_serving_softirq(). If user does cat from /sys/kernel/debug/kmemleak previously they would see this, which is clearly wrong, this is system call context (see the comm): unreferenced object 0xffff88805bd661c0 (size 64): comm "softirq", pid 0, jiffies 4294942959 (age 12.400s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 ff ff ff ff 00 00 00 00 ................ 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ backtrace: [<0000000007dcb30c>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline] [<0000000007dcb30c>] slab_post_alloc_hook mm/slab.h:439 [inline] [<0000000007dcb30c>] slab_alloc mm/slab.c:3326 [inline] [<0000000007dcb30c>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 [<00000000969722b7>] kmalloc include/linux/slab.h:547 [inline] [<00000000969722b7>] kzalloc include/linux/slab.h:742 [inline] [<00000000969722b7>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline] [<00000000969722b7>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085 [<00000000a4134b5f>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475 [<00000000d20248ad>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957 [<000000003d367be7>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246 [<000000003c7c76af>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616 [<000000000c1aeb23>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130 [<000000000157b92b>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078 [<00000000a9f3d058>] __do_sys_setsockopt net/socket.c:2089 [inline] [<00000000a9f3d058>] __se_sys_setsockopt net/socket.c:2086 [inline] [<00000000a9f3d058>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086 [<000000001b8da885>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301 [<00000000ba770c62>] entry_SYSCALL_64_after_hwframe+0x44/0xa9 now they will see this: unreferenced object 0xffff88805413c800 (size 64): comm "syz-executor.4", pid 8960, jiffies 4294994003 (age 14.350s) hex dump (first 32 bytes): 00 7a 8a 57 80 88 ff ff e0 00 00 01 00 00 00 00 .z.W............ 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ backtrace: [<00000000c5d3be64>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline] [<00000000c5d3be64>] slab_post_alloc_hook mm/slab.h:439 [inline] [<00000000c5d3be64>] slab_alloc mm/slab.c:3326 [inline] [<00000000c5d3be64>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 [<0000000023865be2>] kmalloc include/linux/slab.h:547 [inline] [<0000000023865be2>] kzalloc include/linux/slab.h:742 [inline] [<0000000023865be2>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline] [<0000000023865be2>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085 [<000000003029a9d4>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475 [<00000000ccd0a87c>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957 [<00000000a85a3785>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246 [<00000000ec13c18d>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616 [<0000000052d748e3>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130 [<00000000512f1014>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078 [<00000000181758bc>] __do_sys_setsockopt net/socket.c:2089 [inline] [<00000000181758bc>] __se_sys_setsockopt net/socket.c:2086 [inline] [<00000000181758bc>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086 [<00000000d4b73623>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301 [<00000000c1098bec>] entry_SYSCALL_64_after_hwframe+0x44/0xa9 Link: http://lkml.kernel.org/r/20190517171507.96046-1-dvyukov@gmail.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-31mm: vmscan: scan anonymous pages on file refaultsKuo-Hsin Yang
commit 2c012a4ad1a2cd3fb5a0f9307b9d219f84eda1fa upstream. When file refaults are detected and there are many inactive file pages, the system never reclaim anonymous pages, the file pages are dropped aggressively when there are still a lot of cold anonymous pages and system thrashes. This issue impacts the performance of applications with large executable, e.g. chrome. With this patch, when file refault is detected, inactive_list_is_low() always returns true for file pages in get_scan_count() to enable scanning anonymous pages. The problem can be reproduced by the following test program. ---8<--- void fallocate_file(const char *filename, off_t size) { struct stat st; int fd; if (!stat(filename, &st) && st.st_size >= size) return; fd = open(filename, O_WRONLY | O_CREAT, 0600); if (fd < 0) { perror("create file"); exit(1); } if (posix_fallocate(fd, 0, size)) { perror("fallocate"); exit(1); } close(fd); } long *alloc_anon(long size) { long *start = malloc(size); memset(start, 1, size); return start; } long access_file(const char *filename, long size, long rounds) { int fd, i; volatile char *start1, *end1, *start2; const int page_size = getpagesize(); long sum = 0; fd = open(filename, O_RDONLY); if (fd == -1) { perror("open"); exit(1); } /* * Some applications, e.g. chrome, use a lot of executable file * pages, map some of the pages with PROT_EXEC flag to simulate * the behavior. */ start1 = mmap(NULL, size / 2, PROT_READ | PROT_EXEC, MAP_SHARED, fd, 0); if (start1 == MAP_FAILED) { perror("mmap"); exit(1); } end1 = start1 + size / 2; start2 = mmap(NULL, size / 2, PROT_READ, MAP_SHARED, fd, size / 2); if (start2 == MAP_FAILED) { perror("mmap"); exit(1); } for (i = 0; i < rounds; ++i) { struct timeval before, after; volatile char *ptr1 = start1, *ptr2 = start2; gettimeofday(&before, NULL); for (; ptr1 < end1; ptr1 += page_size, ptr2 += page_size) sum += *ptr1 + *ptr2; gettimeofday(&after, NULL); printf("File access time, round %d: %f (sec) ", i, (after.tv_sec - before.tv_sec) + (after.tv_usec - before.tv_usec) / 1000000.0); } return sum; } int main(int argc, char *argv[]) { const long MB = 1024 * 1024; long anon_mb, file_mb, file_rounds; const char filename[] = "large"; long *ret1; long ret2; if (argc != 4) { printf("usage: thrash ANON_MB FILE_MB FILE_ROUNDS "); exit(0); } anon_mb = atoi(argv[1]); file_mb = atoi(argv[2]); file_rounds = atoi(argv[3]); fallocate_file(filename, file_mb * MB); printf("Allocate %ld MB anonymous pages ", anon_mb); ret1 = alloc_anon(anon_mb * MB); printf("Access %ld MB file pages ", file_mb); ret2 = access_file(filename, file_mb * MB, file_rounds); printf("Print result to prevent optimization: %ld ", *ret1 + ret2); return 0; } ---8<--- Running the test program on 2GB RAM VM with kernel 5.2.0-rc5, the program fills ram with 2048 MB memory, access a 200 MB file for 10 times. Without this patch, the file cache is dropped aggresively and every access to the file is from disk. $ ./thrash 2048 200 10 Allocate 2048 MB anonymous pages Access 200 MB file pages File access time, round 0: 2.489316 (sec) File access time, round 1: 2.581277 (sec) File access time, round 2: 2.487624 (sec) File access time, round 3: 2.449100 (sec) File access time, round 4: 2.420423 (sec) File access time, round 5: 2.343411 (sec) File access time, round 6: 2.454833 (sec) File access time, round 7: 2.483398 (sec) File access time, round 8: 2.572701 (sec) File access time, round 9: 2.493014 (sec) With this patch, these file pages can be cached. $ ./thrash 2048 200 10 Allocate 2048 MB anonymous pages Access 200 MB file pages File access time, round 0: 2.475189 (sec) File access time, round 1: 2.440777 (sec) File access time, round 2: 2.411671 (sec) File access time, round 3: 1.955267 (sec) File access time, round 4: 0.029924 (sec) File access time, round 5: 0.000808 (sec) File access time, round 6: 0.000771 (sec) File access time, round 7: 0.000746 (sec) File access time, round 8: 0.000738 (sec) File access time, round 9: 0.000747 (sec) Checked the swap out stats during the test [1], 19006 pages swapped out with this patch, 3418 pages swapped out without this patch. There are more swap out, but I think it's within reasonable range when file backed data set doesn't fit into the memory. $ ./thrash 2000 100 2100 5 1 # ANON_MB FILE_EXEC FILE_NOEXEC ROUNDS PROCESSES Allocate 2000 MB anonymous pages active_anon: 1613644, inactive_anon: 348656, active_file: 892, inactive_file: 1384 (kB) pswpout: 7972443, pgpgin: 478615246 Access 100 MB executable file pages Access 2100 MB regular file pages File access time, round 0: 12.165, (sec) active_anon: 1433788, inactive_anon: 478116, active_file: 17896, inactive_file: 24328 (kB) File access time, round 1: 11.493, (sec) active_anon: 1430576, inactive_anon: 477144, active_file: 25440, inactive_file: 26172 (kB) File access time, round 2: 11.455, (sec) active_anon: 1427436, inactive_anon: 476060, active_file: 21112, inactive_file: 28808 (kB) File access time, round 3: 11.454, (sec) active_anon: 1420444, inactive_anon: 473632, active_file: 23216, inactive_file: 35036 (kB) File access time, round 4: 11.479, (sec) active_anon: 1413964, inactive_anon: 471460, active_file: 31728, inactive_file: 32224 (kB) pswpout: 7991449 (+ 19006), pgpgin: 489924366 (+ 11309120) With 4 processes accessing non-overlapping parts of a large file, 30316 pages swapped out with this patch, 5152 pages swapped out without this patch. The swapout number is small comparing to pgpgin. [1]: https://github.com/vovo/testing/blob/master/mem_thrash.c Link: http://lkml.kernel.org/r/20190701081038.GA83398@google.com Fixes: e9868505987a ("mm,vmscan: only evict file pages when we have plenty") Fixes: 7c5bd705d8f9 ("mm: memcg: only evict file pages when we have plenty") Signed-off-by: Kuo-Hsin Yang <vovoy@chromium.org> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Sonny Rao <sonnyrao@chromium.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Rik van Riel <riel@redhat.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: <stable@vger.kernel.org> [4.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [backported to 4.14.y, 4.19.y, 5.1.y: adjust context] Signed-off-by: Kuo-Hsin Yang <vovoy@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-31mm: add filemap_fdatawait_range_keep_errors()Ross Zwisler
commit aa0bfcd939c30617385ffa28682c062d78050eba upstream. In the spirit of filemap_fdatawait_range() and filemap_fdatawait_keep_errors(), introduce filemap_fdatawait_range_keep_errors() which both takes a range upon which to wait and does not clear errors from the address space. Signed-off-by: Ross Zwisler <zwisler@google.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-12Merge tag 'v4.14.126' into 4.14-2.0.x-imxMax Krummenacher
This is the 4.14.126 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: drivers/gpio/gpio-vf610.c: Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip drivers/gpu/drm/bridge/adv7511/adv7511_drv.c: Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection Use drm_mode_vrefresh(mode) helper drivers/net/ethernet/freescale/fec_main.c: Keep downstream file. drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup sound/soc/fsl/Kconfig: Follow commit ea751227c813 ASoC: imx: fix fiq dependencies Logical Conflicts: sound/soc/fsl/fsl_sai.c: Revert upstream d7325abe29b as downstream fixed it differently drivers/clk/imx/clk-imx6sl.c Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
2019-07-10mm/vmscan.c: prevent useless kswapd loopsShakeel Butt
commit dffcac2cb88e4ec5906235d64a83d802580b119e upstream. In production we have noticed hard lockups on large machines running large jobs due to kswaps hoarding lru lock within isolate_lru_pages when sc->reclaim_idx is 0 which is a small zone. The lru was couple hundred GiBs and the condition (page_zonenum(page) > sc->reclaim_idx) in isolate_lru_pages() was basically skipping GiBs of pages while holding the LRU spinlock with interrupt disabled. On further inspection, it seems like there are two issues: (1) If kswapd on the return from balance_pgdat() could not sleep (i.e. node is still unbalanced), the classzone_idx is unintentionally set to 0 and the whole reclaim cycle of kswapd will try to reclaim only the lowest and smallest zone while traversing the whole memory. (2) Fundamentally isolate_lru_pages() is really bad when the allocation has woken kswapd for a smaller zone on a very large machine running very large jobs. It can hoard the LRU spinlock while skipping over 100s of GiBs of pages. This patch only fixes (1). (2) needs a more fundamental solution. To fix (1), in the kswapd context, if pgdat->kswapd_classzone_idx is invalid use the classzone_idx of the previous kswapd loop otherwise use the one the waker has requested. Link: http://lkml.kernel.org/r/20190701201847.251028-1-shakeelb@google.com Fixes: e716f2eb24de ("mm, vmscan: prevent kswapd sleeping prematurely due to mismatched classzone_idx") Signed-off-by: Shakeel Butt <shakeelb@google.com> Reviewed-by: Yang Shi <yang.shi@linux.alibaba.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hdanton@sina.com> Cc: Roman Gushchin <guro@fb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-10mm/mlock.c: change count_mm_mlocked_page_nr return typeswkhack
[ Upstream commit 0874bb49bb21bf24deda853e8bf61b8325e24bcb ] On a 64-bit machine the value of "vma->vm_end - vma->vm_start" may be negative when using 32 bit ints and the "count >> PAGE_SHIFT"'s result will be wrong. So change the local variable and return value to unsigned long to fix the problem. Link: http://lkml.kernel.org/r/20190513023701.83056-1-swkhack@gmail.com Fixes: 0cf2f6f6dc60 ("mm: mlock: check against vma for actual mlock() size") Signed-off-by: swkhack <swkhack@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-03mm/page_idle.c: fix oops because end_pfn is larger than max_pfnColin Ian King
commit 7298e3b0a149c91323b3205d325e942c3b3b9ef6 upstream. Currently the calcuation of end_pfn can round up the pfn number to more than the actual maximum number of pfns, causing an Oops. Fix this by ensuring end_pfn is never more than max_pfn. This can be easily triggered when on systems where the end_pfn gets rounded up to more than max_pfn using the idle-page stress-ng stress test: sudo stress-ng --idle-page 0 BUG: unable to handle kernel paging request at 00000000000020d8 #PF error: [normal kernel read fault] PGD 0 P4D 0 Oops: 0000 [#1] SMP PTI CPU: 1 PID: 11039 Comm: stress-ng-idle- Not tainted 5.0.0-5-generic #6-Ubuntu Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:page_idle_get_page+0xc8/0x1a0 Code: 0f b1 0a 75 7d 48 8b 03 48 89 c2 48 c1 e8 33 83 e0 07 48 c1 ea 36 48 8d 0c 40 4c 8d 24 88 49 c1 e4 07 4c 03 24 d5 00 89 c3 be <49> 8b 44 24 58 48 8d b8 80 a1 02 00 e8 07 d5 77 00 48 8b 53 08 48 RSP: 0018:ffffafd7c672fde8 EFLAGS: 00010202 RAX: 0000000000000005 RBX: ffffe36341fff700 RCX: 000000000000000f RDX: 0000000000000284 RSI: 0000000000000275 RDI: 0000000001fff700 RBP: ffffafd7c672fe00 R08: ffffa0bc34056410 R09: 0000000000000276 R10: ffffa0bc754e9b40 R11: ffffa0bc330f6400 R12: 0000000000002080 R13: ffffe36341fff700 R14: 0000000000080000 R15: ffffa0bc330f6400 FS: 00007f0ec1ea5740(0000) GS:ffffa0bc7db00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000020d8 CR3: 0000000077d68000 CR4: 00000000000006e0 Call Trace: page_idle_bitmap_write+0x8c/0x140 sysfs_kf_bin_write+0x5c/0x70 kernfs_fop_write+0x12e/0x1b0 __vfs_write+0x1b/0x40 vfs_write+0xab/0x1b0 ksys_write+0x55/0xc0 __x64_sys_write+0x1a/0x20 do_syscall_64+0x5a/0x110 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Link: http://lkml.kernel.org/r/20190618124352.28307-1-colin.king@canonical.com Fixes: 33c3fc71c8cf ("mm: introduce idle page tracking") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-07-03mm/mempolicy.c: fix an incorrect rebind node in mpol_rebind_nodemaskzhong jiang
commit 29b190fa774dd1b72a1a6f19687d55dc72ea83be upstream. mpol_rebind_nodemask() is called for MPOL_BIND and MPOL_INTERLEAVE mempoclicies when the tasks's cpuset's mems_allowed changes. For policies created without MPOL_F_STATIC_NODES or MPOL_F_RELATIVE_NODES, it works by remapping the policy's allowed nodes (stored in v.nodes) using the previous value of mems_allowed (stored in w.cpuset_mems_allowed) as the domain of map and the new mems_allowed (passed as nodes) as the range of the map (see the comment of bitmap_remap() for details). The result of remapping is stored back as policy's nodemask in v.nodes, and the new value of mems_allowed should be stored in w.cpuset_mems_allowed to facilitate the next rebind, if it happens. However, 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies when updating cpusets") introduced a bug where the result of remapping is stored in w.cpuset_mems_allowed instead. Thus, a mempolicy's allowed nodes can evolve in an unexpected way after a series of rebinding due to cpuset mems_allowed changes, possibly binding to a wrong node or a smaller number of nodes which may e.g. overload them. This patch fixes the bug so rebinding again works as intended. [vbabka@suse.cz: new changlog] Link: http://lkml.kernel.org/r/ef6a69c6-c052-b067-8f2c-9d615c619bb9@suse.cz Link: http://lkml.kernel.org/r/1558768043-23184-1-git-send-email-zhongjiang@huawei.com Fixes: 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies when updating cpusets") Signed-off-by: zhong jiang <zhongjiang@huawei.com> Reviewed-by: Vlastimil Babka <vbabka@suse.cz> Cc: Oscar Salvador <osalvador@suse.de> Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Ralph Campbell <rcampbell@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22coredump: fix race condition between collapse_huge_page() and core dumpingAndrea Arcangeli
commit 59ea6d06cfa9247b586a695c21f94afa7183af74 upstream. When fixing the race conditions between the coredump and the mmap_sem holders outside the context of the process, we focused on mmget_not_zero()/get_task_mm() callers in 04f5866e41fb70 ("coredump: fix race condition between mmget_not_zero()/get_task_mm() and core dumping"), but those aren't the only cases where the mmap_sem can be taken outside of the context of the process as Michal Hocko noticed while backporting that commit to older -stable kernels. If mmgrab() is called in the context of the process, but then the mm_count reference is transferred outside the context of the process, that can also be a problem if the mmap_sem has to be taken for writing through that mm_count reference. khugepaged registration calls mmgrab() in the context of the process, but the mmap_sem for writing is taken later in the context of the khugepaged kernel thread. collapse_huge_page() after taking the mmap_sem for writing doesn't modify any vma, so it's not obvious that it could cause a problem to the coredump, but it happens to modify the pmd in a way that breaks an invariant that pmd_trans_huge_lock() relies upon. collapse_huge_page() needs the mmap_sem for writing just to block concurrent page faults that call pmd_trans_huge_lock(). Specifically the invariant that "!pmd_trans_huge()" cannot become a "pmd_trans_huge()" doesn't hold while collapse_huge_page() runs. The coredump will call __get_user_pages() without mmap_sem for reading, which eventually can invoke a lockless page fault which will need a functional pmd_trans_huge_lock(). So collapse_huge_page() needs to use mmget_still_valid() to check it's not running concurrently with the coredump... as long as the coredump can invoke page faults without holding the mmap_sem for reading. This has "Fixes: khugepaged" to facilitate backporting, but in my view it's more a bug in the coredump code that will eventually have to be rewritten to stop invoking page faults without the mmap_sem for reading. So the long term plan is still to drop all mmget_still_valid(). Link: http://lkml.kernel.org/r/20190607161558.32104-1-aarcange@redhat.com Fixes: ba76149f47d8 ("thp: khugepaged") Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michal Hocko <mhocko@suse.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jann Horn <jannh@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Peter Xu <peterx@redhat.com> Cc: Jason Gunthorpe <jgg@mellanox.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-19mm/vmscan.c: fix trying to reclaim unevictable LRU pageMinchan Kim
commit a58f2cef26e1ca44182c8b22f4f4395e702a5795 upstream. There was the below bug report from Wu Fangsuo. On the CMA allocation path, isolate_migratepages_range() could isolate unevictable LRU pages and reclaim_clean_page_from_list() can try to reclaim them if they are clean file-backed pages. page:ffffffbf02f33b40 count:86 mapcount:84 mapping:ffffffc08fa7a810 index:0x24 flags: 0x19040c(referenced|uptodate|arch_1|mappedtodisk|unevictable|mlocked) raw: 000000000019040c ffffffc08fa7a810 0000000000000024 0000005600000053 raw: ffffffc009b05b20 ffffffc009b05b20 0000000000000000 ffffffc09bf3ee80 page dumped because: VM_BUG_ON_PAGE(PageLRU(page) || PageUnevictable(page)) page->mem_cgroup:ffffffc09bf3ee80 ------------[ cut here ]------------ kernel BUG at /home/build/farmland/adroid9.0/kernel/linux/mm/vmscan.c:1350! Internal error: Oops - BUG: 0 [#1] PREEMPT SMP Modules linked in: CPU: 0 PID: 7125 Comm: syz-executor Tainted: G S 4.14.81 #3 Hardware name: ASR AQUILAC EVB (DT) task: ffffffc00a54cd00 task.stack: ffffffc009b00000 PC is at shrink_page_list+0x1998/0x3240 LR is at shrink_page_list+0x1998/0x3240 pc : [<ffffff90083a2158>] lr : [<ffffff90083a2158>] pstate: 60400045 sp : ffffffc009b05940 .. shrink_page_list+0x1998/0x3240 reclaim_clean_pages_from_list+0x3c0/0x4f0 alloc_contig_range+0x3bc/0x650 cma_alloc+0x214/0x668 ion_cma_allocate+0x98/0x1d8 ion_alloc+0x200/0x7e0 ion_ioctl+0x18c/0x378 do_vfs_ioctl+0x17c/0x1780 SyS_ioctl+0xac/0xc0 Wu found it's due to commit ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu"). Before that, unevictable pages go to cull_mlocked so that we can't reach the VM_BUG_ON_PAGE line. To fix the issue, this patch filters out unevictable LRU pages from the reclaim_clean_pages_from_list in CMA. Link: http://lkml.kernel.org/r/20190524071114.74202-1-minchan@kernel.org Fixes: ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu") Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Wu Fangsuo <fangsuowu@asrmicro.com> Debugged-by: Wu Fangsuo <fangsuowu@asrmicro.com> Tested-by: Wu Fangsuo <fangsuowu@asrmicro.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Pankaj Suryawanshi <pankaj.suryawanshi@einfochips.com> Cc: <stable@vger.kernel.org> [4.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-19mm/list_lru.c: fix memory leak in __memcg_init_list_lru_nodeShakeel Butt
commit 3510955b327176fd4cbab5baa75b449f077722a2 upstream. Syzbot reported following memory leak: ffffffffda RBX: 0000000000000003 RCX: 0000000000441f79 BUG: memory leak unreferenced object 0xffff888114f26040 (size 32): comm "syz-executor626", pid 7056, jiffies 4294948701 (age 39.410s) hex dump (first 32 bytes): 40 60 f2 14 81 88 ff ff 40 60 f2 14 81 88 ff ff @`......@`...... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: slab_post_alloc_hook mm/slab.h:439 [inline] slab_alloc mm/slab.c:3326 [inline] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 kmalloc include/linux/slab.h:547 [inline] __memcg_init_list_lru_node+0x58/0xf0 mm/list_lru.c:352 memcg_init_list_lru_node mm/list_lru.c:375 [inline] memcg_init_list_lru mm/list_lru.c:459 [inline] __list_lru_init+0x193/0x2a0 mm/list_lru.c:626 alloc_super+0x2e0/0x310 fs/super.c:269 sget_userns+0x94/0x2a0 fs/super.c:609 sget+0x8d/0xb0 fs/super.c:660 mount_nodev+0x31/0xb0 fs/super.c:1387 fuse_mount+0x2d/0x40 fs/fuse/inode.c:1236 legacy_get_tree+0x27/0x80 fs/fs_context.c:661 vfs_get_tree+0x2e/0x120 fs/super.c:1476 do_new_mount fs/namespace.c:2790 [inline] do_mount+0x932/0xc50 fs/namespace.c:3110 ksys_mount+0xab/0x120 fs/namespace.c:3319 __do_sys_mount fs/namespace.c:3333 [inline] __se_sys_mount fs/namespace.c:3330 [inline] __x64_sys_mount+0x26/0x30 fs/namespace.c:3330 do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301 entry_SYSCALL_64_after_hwframe+0x44/0xa9 This is a simple off by one bug on the error path. Link: http://lkml.kernel.org/r/20190528043202.99980-1-shakeelb@google.com Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists") Reported-by: syzbot+f90a420dfe2b1b03cb2c@syzkaller.appspotmail.com Signed-off-by: Shakeel Butt <shakeelb@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-15percpu: do not search past bitmap when allocating an areaDennis Zhou
[ Upstream commit 8c43004af01635cc9fbb11031d070e5e0d327ef2 ] pcpu_find_block_fit() guarantees that a fit is found within PCPU_BITMAP_BLOCK_BITS. Iteration is used to determine the first fit as it compares against the block's contig_hint. This can lead to incorrectly scanning past the end of the bitmap. The behavior was okay given the check after for bit_off >= end and the correctness of the hints from pcpu_find_block_fit(). This patch fixes this by bounding the end offset by the number of bits in a chunk. Signed-off-by: Dennis Zhou <dennis@kernel.org> Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15percpu: remove spurious lock dependency between percpu and schedJohn Sperbeck
[ Upstream commit 198790d9a3aeaef5792d33a560020861126edc22 ] In free_percpu() we sometimes call pcpu_schedule_balance_work() to queue a work item (which does a wakeup) while holding pcpu_lock. This creates an unnecessary lock dependency between pcpu_lock and the scheduler's pi_lock. There are other places where we call pcpu_schedule_balance_work() without hold pcpu_lock, and this case doesn't need to be different. Moving the call outside the lock prevents the following lockdep splat when running tools/testing/selftests/bpf/{test_maps,test_progs} in sequence with lockdep enabled: ====================================================== WARNING: possible circular locking dependency detected 5.1.0-dbg-DEV #1 Not tainted ------------------------------------------------------ kworker/23:255/18872 is trying to acquire lock: 000000000bc79290 (&(&pool->lock)->rlock){-.-.}, at: __queue_work+0xb2/0x520 but task is already holding lock: 00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #4 (pcpu_lock){..-.}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 pcpu_alloc+0xfa/0x780 __alloc_percpu_gfp+0x12/0x20 alloc_htab_elem+0x184/0x2b0 __htab_percpu_map_update_elem+0x252/0x290 bpf_percpu_hash_update+0x7c/0x130 __do_sys_bpf+0x1912/0x1be0 __x64_sys_bpf+0x1a/0x20 do_syscall_64+0x59/0x400 entry_SYSCALL_64_after_hwframe+0x49/0xbe -> #3 (&htab->buckets[i].lock){....}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 htab_map_update_elem+0x1af/0x3a0 -> #2 (&rq->lock){-.-.}: lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 task_fork_fair+0x37/0x160 sched_fork+0x211/0x310 copy_process.part.43+0x7b1/0x2160 _do_fork+0xda/0x6b0 kernel_thread+0x29/0x30 rest_init+0x22/0x260 arch_call_rest_init+0xe/0x10 start_kernel+0x4fd/0x520 x86_64_start_reservations+0x24/0x26 x86_64_start_kernel+0x6f/0x72 secondary_startup_64+0xa4/0xb0 -> #1 (&p->pi_lock){-.-.}: lock_acquire+0x9e/0x180 _raw_spin_lock_irqsave+0x3a/0x50 try_to_wake_up+0x41/0x600 wake_up_process+0x15/0x20 create_worker+0x16b/0x1e0 workqueue_init+0x279/0x2ee kernel_init_freeable+0xf7/0x288 kernel_init+0xf/0x180 ret_from_fork+0x24/0x30 -> #0 (&(&pool->lock)->rlock){-.-.}: __lock_acquire+0x101f/0x12a0 lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 __queue_work+0xb2/0x520 queue_work_on+0x38/0x80 free_percpu+0x221/0x260 pcpu_freelist_destroy+0x11/0x20 stack_map_free+0x2a/0x40 bpf_map_free_deferred+0x3c/0x50 process_one_work+0x1f7/0x580 worker_thread+0x54/0x410 kthread+0x10f/0x150 ret_from_fork+0x24/0x30 other info that might help us debug this: Chain exists of: &(&pool->lock)->rlock --> &htab->buckets[i].lock --> pcpu_lock Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(pcpu_lock); lock(&htab->buckets[i].lock); lock(pcpu_lock); lock(&(&pool->lock)->rlock); *** DEADLOCK *** 3 locks held by kworker/23:255/18872: #0: 00000000b36a6e16 ((wq_completion)events){+.+.}, at: process_one_work+0x17a/0x580 #1: 00000000dfd966f0 ((work_completion)(&map->work)){+.+.}, at: process_one_work+0x17a/0x580 #2: 00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260 stack backtrace: CPU: 23 PID: 18872 Comm: kworker/23:255 Not tainted 5.1.0-dbg-DEV #1 Hardware name: ... Workqueue: events bpf_map_free_deferred Call Trace: dump_stack+0x67/0x95 print_circular_bug.isra.38+0x1c6/0x220 check_prev_add.constprop.50+0x9f6/0xd20 __lock_acquire+0x101f/0x12a0 lock_acquire+0x9e/0x180 _raw_spin_lock+0x2f/0x40 __queue_work+0xb2/0x520 queue_work_on+0x38/0x80 free_percpu+0x221/0x260 pcpu_freelist_destroy+0x11/0x20 stack_map_free+0x2a/0x40 bpf_map_free_deferred+0x3c/0x50 process_one_work+0x1f7/0x580 worker_thread+0x54/0x410 kthread+0x10f/0x150 ret_from_fork+0x24/0x30 Signed-off-by: John Sperbeck <jsperbeck@google.com> Signed-off-by: Dennis Zhou <dennis@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/slab.c: fix an infinite loop in leaks_show()Qian Cai
[ Upstream commit 745e10146c31b1c6ed3326286704ae251b17f663 ] "cat /proc/slab_allocators" could hang forever on SMP machines with kmemleak or object debugging enabled due to other CPUs running do_drain() will keep making kmemleak_object or debug_objects_cache dirty and unable to escape the first loop in leaks_show(), do { set_store_user_clean(cachep); drain_cpu_caches(cachep); ... } while (!is_store_user_clean(cachep)); For example, do_drain slabs_destroy slab_destroy kmem_cache_free __cache_free ___cache_free kmemleak_free_recursive delete_object_full __delete_object put_object free_object_rcu kmem_cache_free cache_free_debugcheck --> dirty kmemleak_object One approach is to check cachep->name and skip both kmemleak_object and debug_objects_cache in leaks_show(). The other is to set store_user_clean after drain_cpu_caches() which leaves a small window between drain_cpu_caches() and set_store_user_clean() where per-CPU caches could be dirty again lead to slightly wrong information has been stored but could also speed up things significantly which sounds like a good compromise. For example, # cat /proc/slab_allocators 0m42.778s # 1st approach 0m0.737s # 2nd approach [akpm@linux-foundation.org: tweak comment] Link: http://lkml.kernel.org/r/20190411032635.10325-1-cai@lca.pw Fixes: d31676dfde25 ("mm/slab: alternative implementation for DEBUG_SLAB_LEAK") Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/cma_debug.c: fix the break condition in cma_maxchunk_get()Yue Hu
[ Upstream commit f0fd50504a54f5548eb666dc16ddf8394e44e4b7 ] If not find zero bit in find_next_zero_bit(), it will return the size parameter passed in, so the start bit should be compared with bitmap_maxno rather than cma->count. Although getting maxchunk is working fine due to zero value of order_per_bit currently, the operation will be stuck if order_per_bit is set as non-zero. Link: http://lkml.kernel.org/r/20190319092734.276-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Joe Perches <joe@perches.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Safonov <d.safonov@partner.samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-15mm/cma.c: fix the bitmap status to show failed allocation reasonYue Hu
[ Upstream commit 2b59e01a3aa665f751d1410b99fae9336bd424e1 ] Currently one bit in cma bitmap represents number of pages rather than one page, cma->count means cma size in pages. So to find available pages via find_next_zero_bit()/find_next_bit() we should use cma size not in pages but in bits although current free pages number is correct due to zero value of order_per_bit. Once order_per_bit is changed the bitmap status will be incorrect. The size input in cma_debug_show_areas() is not correct. It will affect the available pages at some position to debug the failure issue. This is an example with order_per_bit = 1 Before this change: [ 4.120060] cma: number of available pages: 1@93+4@108+7@121+7@137+7@153+7@169+7@185+7@201+3@213+3@221+3@229+3@237+3@245+3@253+3@261+3@269+3@277+3@285+3@293+3@301+3@309+3@317+3@325+19@333+15@369+512@512=> 638 free of 1024 total pages After this change: [ 4.143234] cma: number of available pages: 2@93+8@108+14@121+14@137+14@153+14@169+14@185+14@201+6@213+6@221+6@229+6@237+6@245+6@253+6@261+6@269+6@277+6@285+6@293+6@301+6@309+6@317+6@325+38@333+30@369=> 252 free of 1024 total pages Obviously the bitmap status before is incorrect. Link: http://lkml.kernel.org/r/20190320060829.9144-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Laura Abbott <labbott@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
