path: root/mm
2015-11-09mm: make sendfile(2) killableJan Kara
commit 296291cdd1629c308114504b850dc343eabc2782 upstream. Currently a simple program below issues a sendfile(2) system call which takes about 62 days to complete in my test KVM instance. int fd; off_t off = 0; fd = open("file", O_RDWR | O_TRUNC | O_SYNC | O_CREAT, 0644); ftruncate(fd, 2); lseek(fd, 0, SEEK_END); sendfile(fd, fd, &off, 0xfffffff); Now you should not ask kernel to do a stupid stuff like copying 256MB in 2-byte chunks and call fsync(2) after each chunk but if you do, sysadmin should have a way to stop you. We actually do have a check for fatal_signal_pending() in generic_perform_write() which triggers in this path however because we always succeed in writing something before the check is done, we return value > 0 from generic_perform_write() and thus the information about signal gets lost. Fix the problem by doing the signal check before writing anything. That way generic_perform_write() returns -EINTR, the error gets propagated up and the sendfile loop terminates early. Signed-off-by: Jan Kara <jack@suse.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-10-28mm/slab: fix unexpected index mapping result of kmalloc_size(INDEX_NODE+1)Joonsoo Kim
commit 03a2d2a3eafe4015412cf4e9675ca0e2d9204074 upstream. Commit description is copied from the original post of this bug: http://comments.gmane.org/gmane.linux.kernel.mm/135349 Kernels after v3.9 use kmalloc_size(INDEX_NODE + 1) to get the next larger cache size than the size index INDEX_NODE mapping. In kernels 3.9 and earlier we used malloc_sizes[INDEX_L3 + 1].cs_size. However, sometimes we can't get the right output we expected via kmalloc_size(INDEX_NODE + 1), causing a BUG(). The mapping table in the latest kernel is like: index = {0, 1, 2 , 3, 4, 5, 6, n} size = {0, 96, 192, 8, 16, 32, 64, 2^n} The mapping table before 3.10 is like this: index = {0 , 1 , 2, 3, 4 , 5 , 6, n} size = {32, 64, 96, 128, 192, 256, 512, 2^(n+3)} The problem on my mips64 machine is as follows: (1) When configured DEBUG_SLAB && DEBUG_PAGEALLOC && DEBUG_LOCK_ALLOC && DEBUG_SPINLOCK, the sizeof(struct kmem_cache_node) will be "150", and the macro INDEX_NODE turns out to be "2": #define INDEX_NODE kmalloc_index(sizeof(struct kmem_cache_node)) (2) Then the result of kmalloc_size(INDEX_NODE + 1) is 8. (3) Then "if(size >= kmalloc_size(INDEX_NODE + 1)" will lead to "size = PAGE_SIZE". (4) Then "if ((size >= (PAGE_SIZE >> 3))" test will be satisfied and "flags |= CFLGS_OFF_SLAB" will be covered. (5) if (flags & CFLGS_OFF_SLAB)" test will be satisfied and will go to "cachep->slabp_cache = kmalloc_slab(slab_size, 0u)", and the result here may be NULL while kernel bootup. (6) Finally,"BUG_ON(ZERO_OR_NULL_PTR(cachep->slabp_cache));" causes the BUG info as the following shows (may be only mips64 has this problem): This patch fixes the problem of kmalloc_size(INDEX_NODE + 1) and removes the BUG by adding 'size >= 256' check to guarantee that all necessary small sized slabs are initialized regardless sequence of slab size in mapping table. Fixes: e33660165c90 ("slab: Use common kmalloc_index/kmalloc_size...") Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Liuhailong <liu.hailong6@zte.com.cn> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-10-28mm: hugetlbfs: skip shared VMAs when unmapping private pages to satisfy a faultMel Gorman
commit 2f84a8990ebbe235c59716896e017c6b2ca1200f upstream. SunDong reported the following on https://bugzilla.kernel.org/show_bug.cgi?id=103841 I think I find a linux bug, I have the test cases is constructed. I can stable recurring problems in fedora22(4.0.4) kernel version, arch for x86_64. I construct transparent huge page, when the parent and child process with MAP_SHARE, MAP_PRIVATE way to access the same huge page area, it has the opportunity to lead to huge page copy on write failure, and then it will munmap the child corresponding mmap area, but then the child mmap area with VM_MAYSHARE attributes, child process munmap this area can trigger VM_BUG_ON in set_vma_resv_flags functions (vma - > vm_flags & VM_MAYSHARE). There were a number of problems with the report (e.g. it's hugetlbfs that triggers this, not transparent huge pages) but it was fundamentally correct in that a VM_BUG_ON in set_vma_resv_flags() can be triggered that looks like this vma ffff8804651fd0d0 start 00007fc474e00000 end 00007fc475e00000 next ffff8804651fd018 prev ffff8804651fd188 mm ffff88046b1b1800 prot 8000000000000027 anon_vma (null) vm_ops ffffffff8182a7a0 pgoff 0 file ffff88106bdb9800 private_data (null) flags: 0x84400fb(read|write|shared|mayread|maywrite|mayexec|mayshare|dontexpand|hugetlb) ------------ kernel BUG at mm/hugetlb.c:462! SMP Modules linked in: xt_pkttype xt_LOG xt_limit [..] CPU: 38 PID: 26839 Comm: map Not tainted 4.0.4-default #1 Hardware name: Dell Inc. PowerEdge R810/0TT6JF, BIOS 2.7.4 04/26/2012 set_vma_resv_flags+0x2d/0x30 The VM_BUG_ON is correct because private and shared mappings have different reservation accounting but the warning clearly shows that the VMA is shared. When a private COW fails to allocate a new page then only the process that created the VMA gets the page -- all the children unmap the page. If the children access that data in the future then they get killed. The problem is that the same file is mapped shared and private. During the COW, the allocation fails, the VMAs are traversed to unmap the other private pages but a shared VMA is found and the bug is triggered. This patch identifies such VMAs and skips them. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reported-by: SunDong <sund_sky@126.com> Reviewed-by: Michal Hocko <mhocko@suse.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-09-30vmscan: fix increasing nr_isolated incurred by putback unevictable pagesJaewon Kim
commit c54839a722a02818677bcabe57e957f0ce4f841d upstream. reclaim_clean_pages_from_list() assumes that shrink_page_list() returns number of pages removed from the candidate list. But shrink_page_list() puts back mlocked pages without passing it to caller and without counting as nr_reclaimed. This increases nr_isolated. To fix this, this patch changes shrink_page_list() to pass unevictable pages back to caller. Caller will take care those pages. Minchan said: It fixes two issues. 1. With unevictable page, cma_alloc will be successful. Exactly speaking, cma_alloc of current kernel will fail due to unevictable pages. 2. fix leaking of NR_ISOLATED counter of vmstat With it, too_many_isolated works. Otherwise, it could make hang until the process get SIGKILL. Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-08-25mm/hwpoison: fix page refcount of unknown non LRU pageWanpeng Li
commit 4f32be677b124a49459e2603321c7a5605ceb9f8 upstream. After trying to drain pages from pagevec/pageset, we try to get reference count of the page again, however, the reference count of the page is not reduced if the page is still not on LRU list. Fix it by adding the put_page() to drop the page reference which is from __get_any_page(). Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-08-25mm, vmscan: Do not wait for page writeback for GFP_NOFS allocationsMichal Hocko
commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream. Nikolay has reported a hang when a memcg reclaim got stuck with the following backtrace: PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync" #0 __schedule at ffffffff815ab152 #1 schedule at ffffffff815ab76e #2 schedule_timeout at ffffffff815ae5e5 #3 io_schedule_timeout at ffffffff815aad6a #4 bit_wait_io at ffffffff815abfc6 #5 __wait_on_bit at ffffffff815abda5 #6 wait_on_page_bit at ffffffff8111fd4f #7 shrink_page_list at ffffffff81135445 #8 shrink_inactive_list at ffffffff81135845 #9 shrink_lruvec at ffffffff81135ead #10 shrink_zone at ffffffff811360c3 #11 shrink_zones at ffffffff81136eff #12 do_try_to_free_pages at ffffffff8113712f #13 try_to_free_mem_cgroup_pages at ffffffff811372be #14 try_charge at ffffffff81189423 #15 mem_cgroup_try_charge at ffffffff8118c6f5 #16 __add_to_page_cache_locked at ffffffff8112137d #17 add_to_page_cache_lru at ffffffff81121618 #18 pagecache_get_page at ffffffff8112170b #19 grow_dev_page at ffffffff811c8297 #20 __getblk_slow at ffffffff811c91d6 #21 __getblk_gfp at ffffffff811c92c1 #22 ext4_ext_grow_indepth at ffffffff8124565c #23 ext4_ext_create_new_leaf at ffffffff81246ca8 #24 ext4_ext_insert_extent at ffffffff81246f09 #25 ext4_ext_map_blocks at ffffffff8124a848 #26 ext4_map_blocks at ffffffff8121a5b7 #27 mpage_map_one_extent at ffffffff8121b1fa #28 mpage_map_and_submit_extent at ffffffff8121f07b #29 ext4_writepages at ffffffff8121f6d5 #30 do_writepages at ffffffff8112c490 #31 __filemap_fdatawrite_range at ffffffff81120199 #32 filemap_flush at ffffffff8112041c #33 ext4_alloc_da_blocks at ffffffff81219da1 #34 ext4_rename at ffffffff81229b91 #35 ext4_rename2 at ffffffff81229e32 #36 vfs_rename at ffffffff811a08a5 #37 SYSC_renameat2 at ffffffff811a3ffc #38 sys_renameat2 at ffffffff811a408e #39 sys_rename at ffffffff8119e51e #40 system_call_fastpath at ffffffff815afa89 Dave Chinner has properly pointed out that this is a deadlock in the reclaim code because ext4 doesn't submit pages which are marked by PG_writeback right away. The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM with too many dirty pages") and it was applied only when may_enter_fs was specified. The code has been changed by c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages") which has removed the __GFP_FS restriction with a reasoning that we do not get into the fs code. But this is not sufficient apparently because the fs doesn't necessarily submit pages marked PG_writeback for IO right away. ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily submit the bio. Instead it tries to map more pages into the bio and mpage_map_one_extent might trigger memcg charge which might end up waiting on a page which is marked PG_writeback but hasn't been submitted yet so we would end up waiting for something that never finishes. Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2) before we go to wait on the writeback. The page fault path, which is the only path that triggers memcg oom killer since 3.12, shouldn't require GFP_NOFS and so we shouldn't reintroduce the premature OOM killer issue which was originally addressed by the heuristic. As per David Chinner the xfs is doing similar thing since 2.6.15 already so ext4 is not the only affected filesystem. Moreover he notes: : For example: IO completion might require unwritten extent conversion : which executes filesystem transactions and GFP_NOFS allocations. The : writeback flag on the pages can not be cleared until unwritten : extent conversion completes. Hence memory reclaim cannot wait on : page writeback to complete in GFP_NOFS context because it is not : safe to do so, memcg reclaim or otherwise. [tytso@mit.edu: corrected the control flow] Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages") Reported-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-08-19mm: avoid setting up anonymous pages into file mappingKirill A. Shutemov
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream. Reading page fault handler code I've noticed that under right circumstances kernel would map anonymous pages into file mappings: if the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated on ->mmap(), kernel would handle page fault to not populated pte with do_anonymous_page(). Let's change page fault handler to use do_anonymous_page() only on anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not shared. For file mappings without vm_ops->fault() or shred VMA without vm_ops, page fault on pte_none() entry would lead to SIGBUS. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-06-23mm/memory_hotplug.c: set zone->wait_table to null after freeing itGu Zheng
commit 85bd839983778fcd0c1c043327b14a046e979b39 upstream. Izumi found the following oops when hot re-adding a node: BUG: unable to handle kernel paging request at ffffc90008963690 IP: __wake_up_bit+0x20/0x70 Oops: 0000 [#1] SMP CPU: 68 PID: 1237 Comm: rs:main Q:Reg Not tainted 4.1.0-rc5 #80 Hardware name: FUJITSU PRIMEQUEST2800E/SB, BIOS PRIMEQUEST 2000 Series BIOS Version 1.87 04/28/2015 task: ffff880838df8000 ti: ffff880017b94000 task.ti: ffff880017b94000 RIP: 0010:[<ffffffff810dff80>] [<ffffffff810dff80>] __wake_up_bit+0x20/0x70 RSP: 0018:ffff880017b97be8 EFLAGS: 00010246 RAX: ffffc90008963690 RBX: 00000000003c0000 RCX: 000000000000a4c9 RDX: 0000000000000000 RSI: ffffea101bffd500 RDI: ffffc90008963648 RBP: ffff880017b97c08 R08: 0000000002000020 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff8a0797c73800 R13: ffffea101bffd500 R14: 0000000000000001 R15: 00000000003c0000 FS: 00007fcc7ffff700(0000) GS:ffff880874800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffc90008963690 CR3: 0000000836761000 CR4: 00000000001407e0 Call Trace: unlock_page+0x6d/0x70 generic_write_end+0x53/0xb0 xfs_vm_write_end+0x29/0x80 [xfs] generic_perform_write+0x10a/0x1e0 xfs_file_buffered_aio_write+0x14d/0x3e0 [xfs] xfs_file_write_iter+0x79/0x120 [xfs] __vfs_write+0xd4/0x110 vfs_write+0xac/0x1c0 SyS_write+0x58/0xd0 system_call_fastpath+0x12/0x76 Code: 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 20 65 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 8d 47 48 <48> 39 47 48 48 c7 45 e8 00 00 00 00 48 c7 45 f0 00 00 00 00 48 RIP [<ffffffff810dff80>] __wake_up_bit+0x20/0x70 RSP <ffff880017b97be8> CR2: ffffc90008963690 Reproduce method (re-add a node):: Hot-add nodeA --> remove nodeA --> hot-add nodeA (panic) This seems an use-after-free problem, and the root cause is zone->wait_table was not set to *NULL* after free it in try_offline_node. When hot re-add a node, we will reuse the pgdat of it, so does the zone struct, and when add pages to the target zone, it will init the zone first (including the wait_table) if the zone is not initialized. The judgement of zone initialized is based on zone->wait_table: static inline bool zone_is_initialized(struct zone *zone) { return !!zone->wait_table; } so if we do not set the zone->wait_table to *NULL* after free it, the memory hotplug routine will skip the init of new zone when hot re-add the node, and the wait_table still points to the freed memory, then we will access the invalid address when trying to wake up the waiting people after the i/o operation with the page is done, such as mentioned above. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Reviewed by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-06-03mm, numa: really disable NUMA balancing by default on single node machinesMel Gorman
commit b0dc2b9bb4ab782115b964310518ee0b17784277 upstream. NUMA balancing is meant to be disabled by default on UMA machines but the check is using nr_node_ids (highest node) instead of num_online_nodes (online nodes). The consequences are that a UMA machine with a node ID of 1 or higher will enable NUMA balancing. This will incur useless overhead due to minor faults with the impact depending on the workload. These are the impact on the stats when running a kernel build on a single node machine whose node ID happened to be 1: vanilla patched NUMA base PTE updates 5113158 0 NUMA huge PMD updates 643 0 NUMA page range updates 5442374 0 NUMA hint faults 2109622 0 NUMA hint local faults 2109622 0 NUMA hint local percent 100 100 NUMA pages migrated 0 0 Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-06-03mm: numa: initialise numa balancing after jump label initialisationMel Gorman
commit c297663c0b3930491a3cb2aba4b6e5a7159c3503 upstream. The command line parsing takes place before jump labels are initialised which generates a warning if numa_balancing= is specified and CONFIG_JUMP_LABEL is set. On older kernels before commit c4b2c0c5f647 ("static_key: WARN on usage before jump_label_init was called") the kernel would have crashed. This patch enables automatic numa balancing later in the initialisation process if numa_balancing= is specified. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-16mm: soft-offline: fix num_poisoned_pages counting on concurrent eventsNaoya Horiguchi
commit 602498f9aa43d4951eece3fd6ad95a6d0a78d537 upstream. If multiple soft offline events hit one free page/hugepage concurrently, soft_offline_page() can handle the free page/hugepage multiple times, which makes num_poisoned_pages counter increased more than once. This patch fixes this wrong counting by checking TestSetPageHWPoison for normal papes and by checking the return value of dequeue_hwpoisoned_huge_page() for hugepages. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Dean Nelson <dnelson@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-16writeback: use |1 instead of +1 to protect against div by zeroTejun Heo
commit 464d1387acb94dc43ba772b35242345e3d2ead1b upstream. mm/page-writeback.c has several places where 1 is added to the divisor to prevent division by zero exceptions; however, if the original divisor is equivalent to -1, adding 1 leads to division by zero. There are three places where +1 is used for this purpose - one in pos_ratio_polynom() and two in bdi_position_ratio(). The second one in bdi_position_ratio() actually triggered div-by-zero oops on a machine running a 3.10 kernel. The divisor is x_intercept - bdi_setpoint + 1 == span + 1 span is confirmed to be (u32)-1. It isn't clear how it ended up that but it could be from write bandwidth calculation underflow fixed by c72efb658f7c ("writeback: fix possible underflow in write bandwidth calculation"). At any rate, +1 isn't a proper protection against div-by-zero. This patch converts all +1 protections to |1. Note that bdi_update_dirty_ratelimit() was already using |1 before this patch. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-16mm/memory-failure: call shake_page() when error hits thp tail pageNaoya Horiguchi
commit 09789e5de18e4e442870b2d700831f5cb802eb05 upstream. Currently memory_failure() calls shake_page() to sweep pages out from pcplists only when the victim page is 4kB LRU page or thp head page. But we should do this for a thp tail page too. Consider that a memory error hits a thp tail page whose head page is on a pcplist when memory_failure() runs. Then, the current kernel skips shake_pages() part, so hwpoison_user_mappings() returns without calling split_huge_page() nor try_to_unmap() because PageLRU of the thp head is still cleared due to the skip of shake_page(). As a result, me_huge_page() runs for the thp, which is broken behavior. One effect is a leak of the thp. And another is to fail to isolate the memory error, so later access to the error address causes another MCE, which kills the processes which used the thp. This patch fixes this problem by calling shake_page() for thp tail case. Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Dean Nelson <dnelson@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-15mm: fix anon_vma->degree underflow in anon_vma endless growing preventionLeon Yu
commit 3fe89b3e2a7bbf3e97657104b9b33a9d81b950b3 upstream. I have constantly stumbled upon "kernel BUG at mm/rmap.c:399!" after upgrading to 3.19 and had no luck with 4.0-rc1 neither. So, after looking into new logic introduced by commit 7a3ef208e662 ("mm: prevent endless growth of anon_vma hierarchy"), I found chances are that unlink_anon_vmas() is called without incrementing dst->anon_vma->degree in anon_vma_clone() due to allocation failure. If dst->anon_vma is not NULL in error path, its degree will be incorrectly decremented in unlink_anon_vmas() and eventually underflow when exiting as a result of another call to unlink_anon_vmas(). That's how "kernel BUG at mm/rmap.c:399!" is triggered for me. This patch fixes the underflow by dropping dst->anon_vma when allocation fails. It's safe to do so regardless of original value of dst->anon_vma because dst->anon_vma doesn't have valid meaning if anon_vma_clone() fails. Besides, callers don't care dst->anon_vma in such case neither. Also suggested by Michal Hocko, we can clean up vma_adjust() a bit as anon_vma_clone() now does the work. [akpm@linux-foundation.org: tweak comment] Fixes: 7a3ef208e662 ("mm: prevent endless growth of anon_vma hierarchy") Signed-off-by: Leon Yu <chianglungyu@gmail.com> Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-15mm: fix corner case in anon_vma endless growing preventionKonstantin Khlebnikov
commit b800c91a0517071156e772d4fb329ad33590da62 upstream. Fix for BUG_ON(anon_vma->degree) splashes in unlink_anon_vmas() ("kernel BUG at mm/rmap.c:399!") caused by commit 7a3ef208e662 ("mm: prevent endless growth of anon_vma hierarchy") Anon_vma_clone() is usually called for a copy of source vma in destination argument. If source vma has anon_vma it should be already in dst->anon_vma. NULL in dst->anon_vma is used as a sign that it's called from anon_vma_fork(). In this case anon_vma_clone() finds anon_vma for reusing. Vma_adjust() calls it differently and this breaks anon_vma reusing logic: anon_vma_clone() links vma to old anon_vma and updates degree counters but vma_adjust() overrides vma->anon_vma right after that. As a result final unlink_anon_vmas() decrements degree for wrong anon_vma. This patch assigns ->anon_vma before calling anon_vma_clone(). Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Reported-and-tested-by: Chris Clayton <chris2553@googlemail.com> Reported-and-tested-by: Oded Gabbay <oded.gabbay@amd.com> Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Daniel Forrest <dan.forrest@ssec.wisc.edu> Cc: Michal Hocko <mhocko@suse.cz> Cc: stable@vger.kernel.org # to match back-porting of 7a3ef208e662 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-05-15mm: prevent endless growth of anon_vma hierarchyKonstantin Khlebnikov
commit 7a3ef208e662f4b63d43a23f61a64a129c525bbc upstream. Constantly forking task causes unlimited grow of anon_vma chain. Each next child allocates new level of anon_vmas and links vma to all previous levels because pages might be inherited from any level. This patch adds heuristic which decides to reuse existing anon_vma instead of forking new one. It adds counter anon_vma->degree which counts linked vmas and directly descending anon_vmas and reuses anon_vma if counter is lower than two. As a result each anon_vma has either vma or at least two descending anon_vmas. In such trees half of nodes are leafs with alive vmas, thus count of anon_vmas is no more than two times bigger than count of vmas. This heuristic reuses anon_vmas as few as possible because each reuse adds false aliasing among vmas and rmap walker ought to scan more ptes when it searches where page is might be mapped. Link: http://lkml.kernel.org/r/20120816024610.GA5350@evergreen.ssec.wisc.edu Fixes: 5beb49305251 ("mm: change anon_vma linking to fix multi-process server scalability issue") [akpm@linux-foundation.org: fix typo, per Rik] Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Reported-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Tested-by: Michal Hocko <mhocko@suse.cz> Tested-by: Jerome Marchand <jmarchan@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: <stable@vger.kernel.org> [2.6.34+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-30mm/hugetlb: use pmd_page() in follow_huge_pmd()Gerald Schaefer
commit 97534127012f0e396eddea4691f4c9b170aed74b upstream. Commit 61f77eda9bbf ("mm/hugetlb: reduce arch dependent code around follow_huge_*") broke follow_huge_pmd() on s390, where pmd and pte layout differ and using pte_page() on a huge pmd will return wrong results. Using pmd_page() instead fixes this. All architectures that were touched by that commit have pmd_page() defined, so this should not break anything on other architectures. Fixes: 61f77eda "mm/hugetlb: reduce arch dependent code around follow_huge_*" Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.cz>, Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-27nick kvfree() from apparmorAl Viro
commit 39f1f78d53b9bcbca91967380c5f0f2305a5c55f upstream. too many places open-code it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-22writeback: fix possible underflow in write bandwidth calculationTejun Heo
commit c72efb658f7c8b27ca3d0efb5cfd5ded9fcac89e upstream. From 1ebf33901ecc75d9496862dceb1ef0377980587c Mon Sep 17 00:00:00 2001 From: Tejun Heo <tj@kernel.org> Date: Mon, 23 Mar 2015 00:08:19 -0400 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty") introduced account_page_redirty() which reverts stat updates for a redirtied page, making BDI_DIRTIED no longer monotonically increasing. bdi_update_write_bandwidth() uses the delta in BDI_DIRTIED as the basis for bandwidth calculation. While unlikely, since the above patch, the newer value may be lower than the recorded past value and underflow the bandwidth calculation leading to a wild result. Fix it by subtracing min of the old and new values when calculating delta. AFAIK, there hasn't been any report of it happening but the resulting erratic behavior would be non-critical and temporary, so it's possible that the issue is happening without being reported. The risk of the fix is very low, so tagged for -stable. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Greg Thelen <gthelen@google.com> Fixes: 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty") Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-22writeback: add missing INITIAL_JIFFIES init in global_update_bandwidth()Tejun Heo
commit 7d70e15480c0450d2bfafaad338a32e884fc215e upstream. global_update_bandwidth() uses static variable update_time as the timestamp for the last update but forgets to initialize it to INITIALIZE_JIFFIES. This means that global_dirty_limit will be 5 mins into the future on 32bit and some large amount jiffies into the past on 64bit. This isn't critical as the only effect is that global_dirty_limit won't be updated for the first 5 mins after booting on 32bit machines, especially given the auxiliary nature of global_dirty_limit's role - protecting against global dirty threshold's sudden dips; however, it does lead to unintended suboptimal behavior. Fix it. Fixes: c42843f2f0bb ("writeback: introduce smoothed global dirty limit") Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-22mm/memory hotplug: postpone the reset of obsolete pgdatGu Zheng
commit b0dc3a342af36f95a68fe229b8f0f73552c5ca08 upstream. Qiu Xishi reported the following BUG when testing hot-add/hot-remove node under stress condition: BUG: unable to handle kernel paging request at 0000000000025f60 IP: next_online_pgdat+0x1/0x50 PGD 0 Oops: 0000 [#1] SMP ACPI: Device does not support D3cold Modules linked in: fuse nls_iso8859_1 nls_cp437 vfat fat loop dm_mod coretemp mperf crc32c_intel ghash_clmulni_intel aesni_intel ablk_helper cryptd lrw gf128mul glue_helper aes_x86_64 pcspkr microcode igb dca i2c_algo_bit ipv6 megaraid_sas iTCO_wdt i2c_i801 i2c_core iTCO_vendor_support tg3 sg hwmon ptp lpc_ich pps_core mfd_core acpi_pad rtc_cmos button ext3 jbd mbcache sd_mod crc_t10dif scsi_dh_alua scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh ahci libahci libata scsi_mod [last unloaded: rasf] CPU: 23 PID: 238 Comm: kworker/23:1 Tainted: G O 3.10.15-5885-euler0302 #1 Hardware name: HUAWEI TECHNOLOGIES CO.,LTD. Huawei N1/Huawei N1, BIOS V100R001 03/02/2015 Workqueue: events vmstat_update task: ffffa800d32c0000 ti: ffffa800d32ae000 task.ti: ffffa800d32ae000 RIP: 0010: next_online_pgdat+0x1/0x50 RSP: 0018:ffffa800d32afce8 EFLAGS: 00010286 RAX: 0000000000001440 RBX: ffffffff81da53b8 RCX: 0000000000000082 RDX: 0000000000000000 RSI: 0000000000000082 RDI: 0000000000000000 RBP: ffffa800d32afd28 R08: ffffffff81c93bfc R09: ffffffff81cbdc96 R10: 00000000000040ec R11: 00000000000000a0 R12: ffffa800fffb3440 R13: ffffa800d32afd38 R14: 0000000000000017 R15: ffffa800e6616800 FS: 0000000000000000(0000) GS:ffffa800e6600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000025f60 CR3: 0000000001a0b000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: refresh_cpu_vm_stats+0xd0/0x140 vmstat_update+0x11/0x50 process_one_work+0x194/0x3d0 worker_thread+0x12b/0x410 kthread+0xc6/0xd0 ret_from_fork+0x7c/0xb0 The cause is the "memset(pgdat, 0, sizeof(*pgdat))" at the end of try_offline_node, which will reset all the content of pgdat to 0, as the pgdat is accessed lock-free, so that the users still using the pgdat will panic, such as the vmstat_update routine. process A: offline node XX: vmstat_updat() refresh_cpu_vm_stats() for_each_populated_zone() find online node XX cond_resched() offline cpu and memory, then try_offline_node() node_set_offline(nid), and memset(pgdat, 0, sizeof(*pgdat)) zone = next_zone(zone) pg_data_t *pgdat = zone->zone_pgdat; // here pgdat is NULL now next_online_pgdat(pgdat) next_online_node(pgdat->node_id); // NULL pointer access So the solution here is postponing the reset of obsolete pgdat from try_offline_node() to hotadd_new_pgdat(), and just resetting pgdat->nr_zones and pgdat->classzone_idx to be 0 rather than the memset 0 to avoid breaking pointer information in pgdat. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Xishi Qiu <qiuxishi@huawei.com> Suggested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09mm: thp: give transparent hugepage code a separate copy_pageDave Hansen
commit 30b0a105d9f7141e4cbf72ae5511832457d89788 upstream. Right now, the migration code in migrate_page_copy() uses copy_huge_page() for hugetlbfs and thp pages: if (PageHuge(page) || PageTransHuge(page)) copy_huge_page(newpage, page); So, yay for code reuse. But: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); and a non-hugetlbfs page has no page_hstate(). This works 99% of the time because page_hstate() determines the hstate from the page order alone. Since the page order of a THP page matches the default hugetlbfs page order, it works. But, if you change the default huge page size on the boot command-line (say default_hugepagesz=1G), then we might not even *have* a 2MB hstate so page_hstate() returns null and copy_huge_page() oopses pretty fast since copy_huge_page() dereferences the hstate: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) { ... Mel noticed that the migration code is really the only user of these functions. This moves all the copy code over to migrate.c and makes copy_huge_page() work for THP by checking for it explicitly. I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add THP migration for the NUMA working set scanning fault case") [akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09mm/hugetlb: fix getting refcount 0 page in hugetlb_fault()Naoya Horiguchi
commit 0f792cf949a0be506c2aa8bfac0605746b146dda upstream. When running the test which causes the race as shown in the previous patch, we can hit the BUG "get_page() on refcount 0 page" in hugetlb_fault(). This race happens when pte turns into migration entry just after the first check of is_hugetlb_entry_migration() in hugetlb_fault() passed with false. To fix this, we need to check pte_present() again after huge_ptep_get(). This patch also reorders taking ptl and doing pte_page(), because pte_page() should be done in ptl. Due to this reordering, we need use trylock_page() in page != pagecache_page case to respect locking order. Fixes: 66aebce747ea ("hugetlb: fix race condition in hugetlb_fault()") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: <stable@vger.kernel.org> [3.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> [backport to 3.12]
2015-03-16mm/hugetlb: take page table lock in follow_huge_pmd()Naoya Horiguchi
commit e66f17ff71772b209eed39de35aaa99ba819c93d upstream. We have a race condition between move_pages() and freeing hugepages, where move_pages() calls follow_page(FOLL_GET) for hugepages internally and tries to get its refcount without preventing concurrent freeing. This race crashes the kernel, so this patch fixes it by moving FOLL_GET code for hugepages into follow_huge_pmd() with taking the page table lock. This patch intentionally removes page==NULL check after pte_page. This is justified because pte_page() never returns NULL for any architectures or configurations. This patch changes the behavior of follow_huge_pmd() for tail pages and then tail pages can be pinned/returned. So the caller must be changed to properly handle the returned tail pages. We could have a choice to add the similar locking to follow_huge_(addr|pud) for consistency, but it's not necessary because currently these functions don't support FOLL_GET flag, so let's leave it for future development. Here is the reproducer: $ cat movepages.c #include <stdio.h> #include <stdlib.h> #include <numaif.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 #define PS 0x1000 int main(int argc, char *argv[]) { int i; int nr_hp = strtol(argv[1], NULL, 0); int nr_p = nr_hp * HPS / PS; int ret; void **addrs; int *status; int *nodes; pid_t pid; pid = strtol(argv[2], NULL, 0); addrs = malloc(sizeof(char *) * nr_p + 1); status = malloc(sizeof(char *) * nr_p + 1); nodes = malloc(sizeof(char *) * nr_p + 1); while (1) { for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 1; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 0; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); } return 0; } $ cat hugepage.c #include <stdio.h> #include <sys/mman.h> #include <string.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 int main(int argc, char *argv[]) { int nr_hp = strtol(argv[1], NULL, 0); char *p; while (1) { p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0); if (p != (void *)ADDR_INPUT) { perror("mmap"); break; } memset(p, 0, nr_hp * HPS); munmap(p, nr_hp * HPS); } } $ sysctl vm.nr_hugepages=40 $ ./hugepage 10 & $ ./movepages 10 $(pgrep -f hugepage) Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz> [backport to 3.12]
2015-03-16mm/hugetlb: reduce arch dependent code around follow_huge_*Naoya Horiguchi
commit 61f77eda9bbf0d2e922197ed2dcf88638a639ce5 upstream. Currently we have many duplicates in definitions around follow_huge_addr(), follow_huge_pmd(), and follow_huge_pud(), so this patch tries to remove the m. The basic idea is to put the default implementation for these functions in mm/hugetlb.c as weak symbols (regardless of CONFIG_ARCH_WANT_GENERAL_HUGETL B), and to implement arch-specific code only when the arch needs it. For follow_huge_addr(), only powerpc and ia64 have their own implementation, and in all other architectures this function just returns ERR_PTR(-EINVAL). So this patch sets returning ERR_PTR(-EINVAL) as default. As for follow_huge_(pmd|pud)(), if (pmd|pud)_huge() is implemented to always return 0 in your architecture (like in ia64 or sparc,) it's never called (the callsite is optimized away) no matter how implemented it is. So in such architectures, we don't need arch-specific implementation. In some architecture (like mips, s390 and tile,) their current arch-specific follow_huge_(pmd|pud)() are effectively identical with the common code, so this patch lets these architecture use the common code. One exception is metag, where pmd_huge() could return non-zero but it expects follow_huge_pmd() to always return NULL. This means that we need arch-specific implementation which returns NULL. This behavior looks strange to me (because non-zero pmd_huge() implies that the architecture supports PMD-based hugepage, so follow_huge_pmd() can/should return some relevant value,) but that's beyond this cleanup patch, so let's keep it. Justification of non-trivial changes: - in s390, follow_huge_pmd() checks !MACHINE_HAS_HPAGE at first, and this patch removes the check. This is OK because we can assume MACHINE_HAS_HPAGE is true when follow_huge_pmd() can be called (note that pmd_huge() has the same check and always returns 0 for !MACHINE_HAS_HPAGE.) - in s390 and mips, we use HPAGE_MASK instead of PMD_MASK as done in common code. This patch forces these archs use PMD_MASK, but it's OK because they are identical in both archs. In s390, both of HPAGE_SHIFT and PMD_SHIFT are 20. In mips, HPAGE_SHIFT is defined as (PAGE_SHIFT + PAGE_SHIFT - 3) and PMD_SHIFT is define as (PAGE_SHIFT + PAGE_SHIFT + PTE_ORDER - 3), but PTE_ORDER is always 0, so these are identical. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-16mm: hwpoison: drop lru_add_drain_all() in __soft_offline_page()Naoya Horiguchi
commit 9ab3b598d2dfbdb0153ffa7e4b1456bbff59a25d upstream. A race condition starts to be visible in recent mmotm, where a PG_hwpoison flag is set on a migration source page *before* it's back in buddy page poo= l. This is problematic because no page flag is supposed to be set when freeing (see __free_one_page().) So the user-visible effect of this race is that it could trigger the BUG_ON() when soft-offlining is called. The root cause is that we call lru_add_drain_all() to make sure that the page is in buddy, but that doesn't work because this function just schedule= s a work item and doesn't wait its completion. drain_all_pages() does drainin= g directly, so simply dropping lru_add_drain_all() solves this problem. Fixes: f15bdfa802bf ("mm/memory-failure.c: fix memory leak in successful soft offlining") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Chen Gong <gong.chen@linux.intel.com> Cc: <stable@vger.kernel.org> [3.11+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12vm: make stack guard page errors return VM_FAULT_SIGSEGV rather than SIGBUSLinus Torvalds
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream. The stack guard page error case has long incorrectly caused a SIGBUS rather than a SIGSEGV, but nobody actually noticed until commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") because that error case was never actually triggered in any normal situations. Now that we actually report the error, people noticed the wrong signal that resulted. So far, only the test suite of libsigsegv seems to have actually cared, but there are real applications that use libsigsegv, so let's not wait for any of those to break. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/memory.c: actually remap enough memoryGrazvydas Ignotas
commit 9cb12d7b4ccaa976f97ce0c5fd0f1b6a83bc2a75 upstream. For whatever reason, generic_access_phys() only remaps one page, but actually allows to access arbitrary size. It's quite easy to trigger large reads, like printing out large structure with gdb, which leads to a crash. Fix it by remapping correct size. Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure") Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/compaction: fix wrong order check in compact_finished()Joonsoo Kim
commit 372549c2a3778fd3df445819811c944ad54609ca upstream. What we want to check here is whether there is highorder freepage in buddy list of other migratetype in order to steal it without fragmentation. But, current code just checks cc->order which means allocation request order. So, this is wrong. Without this fix, non-movable synchronous compaction below pageblock order would not stopped until compaction is complete, because migratetype of most pageblocks are movable and high order freepage made by compaction is usually on movable type buddy list. There is some report related to this bug. See below link. http://www.spinics.net/lists/linux-mm/msg81666.html Although the issued system still has load spike comes from compaction, this makes that system completely stable and responsive according to his report. stress-highalloc test in mmtests with non movable order 7 allocation doesn't show any notable difference in allocation success rate, but, it shows more compaction success rate. Compaction success rate (Compaction success * 100 / Compaction stalls, %) 18.47 : 28.94 Fixes: 1fb3f8ca0e92 ("mm: compaction: capture a suitable high-order page immediately when it is made available") Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/nommu.c: fix arithmetic overflow in __vm_enough_memory()Roman Gushchin
commit 8138a67a5557ffea3a21dfd6f037842d4e748513 upstream. I noticed that "allowed" can easily overflow by falling below 0, because (total_vm / 32) can be larger than "allowed". The problem occurs in OVERCOMMIT_NONE mode. In this case, a huge allocation can success and overcommit the system (despite OVERCOMMIT_NONE mode). All subsequent allocations will fall (system-wide), so system become unusable. The problem was masked out by commit c9b1d0981fcc ("mm: limit growth of 3% hardcoded other user reserve"), but it's easy to reproduce it on older kernels: 1) set overcommit_memory sysctl to 2 2) mmap() large file multiple times (with VM_SHARED flag) 3) try to malloc() large amount of memory It also can be reproduced on newer kernels, but miss-configured sysctl_user_reserve_kbytes is required. Fix this issue by switching to signed arithmetic here. Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Cc: Andrew Shewmaker <agshew@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/mmap.c: fix arithmetic overflow in __vm_enough_memory()Roman Gushchin
commit 5703b087dc8eaf47bfb399d6cf512d471beff405 upstream. I noticed, that "allowed" can easily overflow by falling below 0, because (total_vm / 32) can be larger than "allowed". The problem occurs in OVERCOMMIT_NONE mode. In this case, a huge allocation can success and overcommit the system (despite OVERCOMMIT_NONE mode). All subsequent allocations will fall (system-wide), so system become unusable. The problem was masked out by commit c9b1d0981fcc ("mm: limit growth of 3% hardcoded other user reserve"), but it's easy to reproduce it on older kernels: 1) set overcommit_memory sysctl to 2 2) mmap() large file multiple times (with VM_SHARED flag) 3) try to malloc() large amount of memory It also can be reproduced on newer kernels, but miss-configured sysctl_user_reserve_kbytes is required. Fix this issue by switching to signed arithmetic here. [akpm@linux-foundation.org: use min_t] Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Cc: Andrew Shewmaker <agshew@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/hugetlb: add migration entry check in __unmap_hugepage_rangeNaoya Horiguchi
commit 9fbc1f635fd0bd28cb32550211bf095753ac637a upstream. If __unmap_hugepage_range() tries to unmap the address range over which hugepage migration is on the way, we get the wrong page because pte_page() doesn't work for migration entries. This patch simply clears the pte for migration entries as we do for hwpoison entries. Fixes: 290408d4a2 ("hugetlb: hugepage migration core") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mm/hugetlb: add migration/hwpoisoned entry check in hugetlb_change_protectionNaoya Horiguchi
commit a8bda28d87c38c6aa93de28ba5d30cc18e865a11 upstream. There is a race condition between hugepage migration and change_protection(), where hugetlb_change_protection() doesn't care about migration entries and wrongly overwrites them. That causes unexpected results like kernel crash. HWPoison entries also can cause the same problem. This patch adds is_hugetlb_entry_(migration|hwpoisoned) check in this function to do proper actions. Fixes: 290408d4a2 ("hugetlb: hugepage migration core") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-01mm/hugetlb: pmd_huge() returns true for non-present hugepageNaoya Horiguchi
commit cbef8478bee55775ac312a574aad48af7bb9cf9f upstream. Migrating hugepages and hwpoisoned hugepages are considered as non-present hugepages, and they are referenced via migration entries and hwpoison entries in their page table slots. This behavior causes race condition because pmd_huge() doesn't tell non-huge pages from migrating/hwpoisoned hugepages. follow_page_mask() is one example where the kernel would call follow_page_pte() for such hugepage while this function is supposed to handle only normal pages. To avoid this, this patch makes pmd_huge() return true when pmd_none() is true *and* pmd_present() is false. We don't have to worry about mixing up non-present pmd entry with normal pmd (pointing to leaf level pte entry) because pmd_present() is true in normal pmd. The same race condition could happen in (x86-specific) gup_pmd_range(), where this patch simply adds pmd_present() check instead of pmd_huge(). This is because gup_pmd_range() is fast path. If we have non-present hugepage in this function, we will go into gup_huge_pmd(), then return 0 at flag mask check, and finally fall back to the slow path. Fixes: 290408d4a2 ("hugetlb: hugepage migration core") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-09mm: pagewalk: call pte_hole() for VM_PFNMAP during walk_page_rangeShiraz Hashim
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream. walk_page_range() silently skips vma having VM_PFNMAP set, which leads to undesirable behaviour at client end (who called walk_page_range). Userspace applications get the wrong data, so the effect is like just confusing users (if the applications just display the data) or sometimes killing the processes (if the applications do something with misunderstanding virtual addresses due to the wrong data.) For example for pagemap_read, when no callbacks are called against VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual address range at wrong index. Eventually userspace may get wrong pagemap data for a task. Corresponding to a VM_PFNMAP marked vma region, kernel may report mappings from subsequent vma regions. User space in turn may account more pages (than really are) to the task. In my case I was using procmem, procrack (Android utility) which uses pagemap interface to account RSS pages of a task. Due to this bug it was giving a wrong picture for vmas (with VM_PFNMAP set). Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas") Signed-off-by: Shiraz Hashim <shashim@codeaurora.org> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-29mm: get rid of radix tree gfp mask for pagecache_get_pageMichal Hocko
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream. Commit 2457aec63745 ("mm: non-atomically mark page accessed during page cache allocation where possible") has added a separate parameter for specifying gfp mask for radix tree allocations. Not only this is less than optimal from the API point of view because it is error prone, it is also buggy currently because grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then the radix tree allocation wouldn't obey the restriction and might recurse into filesystem and cause deadlocks. This is the case for most filesystems unfortunately because only ext4 and gfs2 are using AOP_FLAG_NOFS. Let's simply remove radix_gfp_mask parameter because the allocation context is same for both page cache and for the radix tree. Just make sure that the radix tree gets only the sane subset of the mask (e.g. do not pass __GFP_WRITE). Long term it is more preferable to convert remaining users of AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this interface even further. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26mm: Don't count the stack guard page towards RLIMIT_STACKLinus Torvalds
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream. Commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") made sure that we return the error properly for stack growth conditions. It also theorized that counting the guard page towards the stack limit might break something, but also said "Let's see if anybody notices". Somebody did notice. Apparently android-x86 sets the stack limit very close to the limit indeed, and including the guard page in the rlimit check causes the android 'zygote' process problems. So this adds the (fairly trivial) code to make the stack rlimit check be against the actual real stack size, rather than the size of the vma that includes the guard page. Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org> Cc: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26mm: propagate error from stack expansion even for guard pageLinus Torvalds
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream. Jay Foad reports that the address sanitizer test (asan) sometimes gets confused by a stack pointer that ends up being outside the stack vma that is reported by /proc/maps. This happens due to an interaction between RLIMIT_STACK and the guard page: when we do the guard page check, we ignore the potential error from the stack expansion, which effectively results in a missing guard page, since the expected stack expansion won't have been done. And since /proc/maps explicitly ignores the guard page (commit d7824370e263: "mm: fix up some user-visible effects of the stack guard page"), the stack pointer ends up being outside the reported stack area. This is the minimal patch: it just propagates the error. It also effectively makes the guard page part of the stack limit, which in turn measn that the actual real stack is one page less than the stack limit. Let's see if anybody notices. We could teach acct_stack_growth() to allow an extra page for a grow-up/grow-down stack in the rlimit test, but I don't want to add more complexity if it isn't needed. Reported-and-tested-by: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26mm, vmscan: prevent kswapd livelock due to pfmemalloc-throttled process ↵Vlastimil Babka
being killed commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream. Charles Shirron and Paul Cassella from Cray Inc have reported kswapd stuck in a busy loop with nothing left to balance, but kswapd_try_to_sleep() failing to sleep. Their analysis found the cause to be a combination of several factors: 1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait 2. The process has been killed (by OOM in this case), but has not yet been scheduled to remove itself from the waitqueue and die. 3. kswapd checks for throttled processes in prepare_kswapd_sleep(): if (waitqueue_active(&pgdat->pfmemalloc_wait)) { wake_up(&pgdat->pfmemalloc_wait); return false; // kswapd will not go to sleep } However, for a process that was already killed, wake_up() does not remove the process from the waitqueue, since try_to_wake_up() checks its state first and returns false when the process is no longer waiting. 4. kswapd is running on the same CPU as the only CPU that the process is allowed to run on (through cpus_allowed, or possibly single-cpu system). 5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd encounters no voluntary preemption points and repeatedly fails prepare_kswapd_sleep(), blocking the process from running and removing itself from the waitqueue, which would let kswapd sleep. So, the source of the problem is that we prevent kswapd from going to sleep until there are processes waiting on the pfmemalloc_wait queue, and a process waiting on a queue is guaranteed to be removed from the queue only when it gets scheduled. This was done to make sure that no process is left sleeping on pfmemalloc_wait when kswapd itself goes to sleep. However, it isn't necessary to postpone kswapd sleep until the pfmemalloc_wait queue actually empties. To prevent processes from being left sleeping, it's actually enough to guarantee that all processes waiting on pfmemalloc_wait queue have been woken up by the time we put kswapd to sleep. This patch therefore fixes this issue by substituting 'wake_up' with 'wake_up_all' and removing 'return false' in the code snippet from prepare_kswapd_sleep() above. Note that if any process puts itself in the queue after this waitqueue_active() check, or after the wake up itself, it means that the process will also wake up kswapd - and since we are under prepare_to_wait(), the wake up won't be missed. Also we update the comment prepare_kswapd_sleep() to hopefully more clearly describe the races it is preventing. Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-13thp: close race between split and zap huge pagesKirill A. Shutemov
commit b5a8cad376eebbd8598642697e92a27983aee802 upstream. [stable 3.12 note] This commit was supposed to fix a completely other issue. But in 3.12, with commit f72e7dcdd25229446b102e587ef2f826f76bff28 (mm: let mm_find_pmd fix buggy race with THP fault), we need this commit as well (it fixes the issue as a by-product). Hugh Dickins writes: <== citation starts here> Fine for this to go in, but there is one catch, which I discovered when backporting to v3.11: it needed one more hunk. I haven't checked your base tree, but if this applies then I believe you need it - most of the time no problem, but it can case page migration to fail to find a migration entry it inserted earlier, then BUG_ON(!PageLocked(p)) in migration_entry_to_page() soon after. Here's what I wrote back then: Note on rebase to v3.11: added a hunk to replace the use of mm_find_pmd() in page_check_address_pmd(). This call had been similarly replaced by the time of my v3.16 commit, in Kirill Shutemov's v3.15 b5a8cad376ee ("thp: close race between split and zap huge pages"): which we do not need as such, since it's fixing v3.13 117b0791ac42 ("mm, thp: move ptl taking inside page_check_address_pmd()"), from a split page-table-lock series we are not backporting. But without this additional hunk, rmap sometimes broke when the new semantic for mm_find_pmd() was used here. <== end of citation> But instead of appending hunks to commits, I am taking a full, backported version of commit b5a8cad376ee with this note prepended. So the changelog of b5a8cad376ee is left below, but does not apply to 3.12 yet. [=== stable 3.12 note ends here] Sasha Levin has reported two THP BUGs[1][2]. I believe both of them have the same root cause. Let's look to them one by one. The first bug[1] is "kernel BUG at mm/huge_memory.c:1829!". It's BUG_ON(mapcount != page_mapcount(page)) in __split_huge_page(). From my testing I see that page_mapcount() is higher than mapcount here. I think it happens due to race between zap_huge_pmd() and page_check_address_pmd(). page_check_address_pmd() misses PMD which is under zap: CPU0 CPU1 zap_huge_pmd() pmdp_get_and_clear() __split_huge_page() anon_vma_interval_tree_foreach() __split_huge_page_splitting() page_check_address_pmd() mm_find_pmd() /* * We check if PMD present without taking ptl: no * serialization against zap_huge_pmd(). We miss this PMD, * it's not accounted to 'mapcount' in __split_huge_page(). */ pmd_present(pmd) == 0 BUG_ON(mapcount != page_mapcount(page)) // CRASH!!! page_remove_rmap(page) atomic_add_negative(-1, &page->_mapcount) The second bug[2] is "kernel BUG at mm/huge_memory.c:1371!". It's VM_BUG_ON_PAGE(!PageHead(page), page) in zap_huge_pmd(). This happens in similar way: CPU0 CPU1 zap_huge_pmd() pmdp_get_and_clear() page_remove_rmap(page) atomic_add_negative(-1, &page->_mapcount) __split_huge_page() anon_vma_interval_tree_foreach() __split_huge_page_splitting() page_check_address_pmd() mm_find_pmd() pmd_present(pmd) == 0 /* The same comment as above */ /* * No crash this time since we already decremented page->_mapcount in * zap_huge_pmd(). */ BUG_ON(mapcount != page_mapcount(page)) /* * We split the compound page here into small pages without * serialization against zap_huge_pmd() */ __split_huge_page_refcount() VM_BUG_ON_PAGE(!PageHead(page), page); // CRASH!!! So my understanding the problem is pmd_present() check in mm_find_pmd() without taking page table lock. The bug was introduced by me commit with commit 117b0791ac42. Sorry for that. :( Let's open code mm_find_pmd() in page_check_address_pmd() and do the check under page table lock. Note that __page_check_address() does the same for PTE entires if sync != 0. I've stress tested split and zap code paths for 36+ hours by now and don't see crashes with the patch applied. Before it took <20 min to trigger the first bug and few hours for second one (if we ignore first). [1] https://lkml.kernel.org/g/<53440991.9090001@oracle.com> [2] https://lkml.kernel.org/g/<5310C56C.60709@oracle.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Bob Liu <lliubbo@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Dave Jones <davej@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-09mm: let mm_find_pmd fix buggy race with THP faultHugh Dickins
commit f72e7dcdd25229446b102e587ef2f826f76bff28 upstream. Trinity has reported: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: __lock_acquire (kernel/locking/lockdep.c:3070 (discriminator 1)) CPU: 6 PID: 16173 Comm: trinity-c364 Tainted: G W 3.15.0-rc1-next-20140415-sasha-00020-gaa90d09 #398 lock_acquire (arch/x86/include/asm/current.h:14 kernel/locking/lockdep.c:3602) _raw_spin_lock (include/linux/spinlock_api_smp.h:143 kernel/locking/spinlock.c:151) remove_migration_pte (mm/migrate.c:137) rmap_walk (mm/rmap.c:1628 mm/rmap.c:1699) remove_migration_ptes (mm/migrate.c:224) migrate_pages (mm/migrate.c:922 mm/migrate.c:960 mm/migrate.c:1126) migrate_misplaced_page (mm/migrate.c:1733) __handle_mm_fault (mm/memory.c:3762 mm/memory.c:3812 mm/memory.c:3925) handle_mm_fault (mm/memory.c:3948) __get_user_pages (mm/memory.c:1851) __mlock_vma_pages_range (mm/mlock.c:255) __mm_populate (mm/mlock.c:711) SyS_mlockall (include/linux/mm.h:1799 mm/mlock.c:817 mm/mlock.c:791) I believe this comes about because, whereas collapsing and splitting THP functions take anon_vma lock in write mode (which excludes concurrent rmap walks), faulting THP functions (write protection and misplaced NUMA) do not - and mostly they do not need to. But they do use a pmdp_clear_flush(), set_pmd_at() sequence which, for an instant (indeed, for a long instant, given the inter-CPU TLB flush in there), leaves *pmd neither present not trans_huge. Which can confuse a concurrent rmap walk, as when removing migration ptes, seen in the dumped trace. Although that rmap walk has a 4k page to insert, anon_vmas containing THPs are in no way segregated from 4k-page anon_vmas, so the 4k-intent mm_find_pmd() does need to cope with that instant when a trans_huge pmd is temporarily absent. I don't think we need strengthen the locking at the THP end: it's easily handled with an ACCESS_ONCE() before testing both conditions. And since mm_find_pmd() had only one caller who wanted a THP rather than a pmd, let's slightly repurpose it to fail when it hits a THP or non-present pmd, and open code split_huge_page_address() again. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Dave Jones <davej@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-07mm: fix anon_vma_clone() error treatmentDaniel Forrest
commit c4ea95d7cd08d9ffd7fa75e6c5e0332d596dd11e upstream. Andrew Morton noticed that the error return from anon_vma_clone() was being dropped and replaced with -ENOMEM (which is not itself a bug because the only error return value from anon_vma_clone() is -ENOMEM). I did an audit of callers of anon_vma_clone() and discovered an actual bug where the error return was being lost. In __split_vma(), between Linux 3.11 and 3.12 the code was changed so the err variable is used before the call to anon_vma_clone() and the default initial value of -ENOMEM is overwritten. So a failure of anon_vma_clone() will return success since err at this point is now zero. Below is a patch which fixes this bug and also propagates the error return value from anon_vma_clone() in all cases. Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()") Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tim Hartrick <tim@edgecast.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-07mm: fix swapoff hang after page migration and forkHugh Dickins
commit 2022b4d18a491a578218ce7a4eca8666db895a73 upstream. I've been seeing swapoff hangs in recent testing: it's cycling around trying unsuccessfully to find an mm for some remaining pages of swap. I have been exercising swap and page migration more heavily recently, and now notice a long-standing error in copy_one_pte(): it's trying to add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing so even when it's a migration entry or an hwpoison entry. Which wouldn't matter much, except it adds dst_mm next to src_mm, assuming src_mm is already on the mmlist: which may not be so. Then if pages are later swapped out from dst_mm, swapoff won't be able to find where to replace them. There's already a !non_swap_entry() test for stats: move that up before the swap_duplicate() and the addition to mmlist. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kelley Nielsen <kelleynnn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-07mm/vmpressure.c: fix race in vmpressure_work_fn()Andrew Morton
commit 91b57191cfd152c02ded0745250167d0263084f8 upstream. In some android devices, there will be a "divide by zero" exception. vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051 [akpm@linux-foundation.org: neaten] Reported-by: ji_ang <ji_ang@163.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-07mm: frontswap: invalidate expired data on a dup-store failureWeijie Yang
commit fb993fa1a2f669215fa03a09eed7848f2663e336 upstream. If a frontswap dup-store failed, it should invalidate the expired page in the backend, or it could trigger some data corruption issue. Such as: 1. use zswap as the frontswap backend with writeback feature 2. store a swap page(version_1) to entry A, success 3. dup-store a newer page(version_2) to the same entry A, fail 4. use __swap_writepage() write version_2 page to swapfile, success 5. zswap do shrink, writeback version_1 page to swapfile 6. version_2 page is overwrited by version_1, data corrupt. This patch fixes this issue by invalidating expired data immediately when meet a dup-store failure. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-12-03fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
commit d311d79de305f1ada47cadd672e6ed1b28a949eb upstream. It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13mm: Remove false WARN_ON from pagecache_isize_extended()Jan Kara
commit f55fefd1a5a339b1bd08c120b93312d6eb64a9fb upstream. The WARN_ON checking whether i_mutex is held in pagecache_isize_extended() was wrong because some filesystems (e.g. XFS) use different locks for serialization of truncates / writes. So just remove the check. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13cgroup/kmemleak: add kmemleak_free() for cgroup deallocations.Wang Nan
commit 401507d67d5c2854f5a88b3f93f64fc6f267bca5 upstream. Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but corresponding kmemleak_free() is missing, which makes kmemleak be wrongly disabled after memory offlining. Log is pasted at the end of this commit message. This patch add kmemleak_free() into free_page_cgroup(). During page offlining, this patch removes corresponding entries in kmemleak rbtree. After that, the freed memory can be allocated again by other subsystems without killing kmemleak. bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak Offlined Pages 32768 kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing) CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x46/0x58 create_object+0x266/0x2c0 kmemleak_alloc+0x26/0x50 kmem_cache_alloc+0xd3/0x160 __sigqueue_alloc+0x49/0xd0 __send_signal+0xcb/0x410 send_signal+0x45/0x90 __group_send_sig_info+0x13/0x20 do_notify_parent+0x1bb/0x260 do_exit+0x767/0xa40 do_group_exit+0x44/0xa0 SyS_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b kmemleak: Kernel memory leak detector disabled kmemleak: Object 0xffff880016900000 (size 524288): kmemleak: comm "swapper/0", pid 0, jiffies 4294667296 kmemleak: min_count = 0 kmemleak: count = 0 kmemleak: flags = 0x1 kmemleak: checksum = 0 kmemleak: backtrace: log_early+0x63/0x77 kmemleak_alloc+0x4b/0x50 init_section_page_cgroup+0x7f/0xf5 page_cgroup_init+0xc5/0xd0 start_kernel+0x333/0x408 x86_64_start_reservations+0x2a/0x2c x86_64_start_kernel+0xf5/0xfc Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations) Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13mm: free compound page with correct orderYu Zhao
commit 5ddacbe92b806cd5b4f8f154e8e46ac267fff55c upstream. Compound page should be freed by put_page() or free_pages() with correct order. Not doing so will cause tail pages leaked. The compound order can be obtained by compound_order() or use HPAGE_PMD_ORDER in our case. Some people would argue the latter is faster but I prefer the former which is more general. This bug was observed not just on our servers (the worst case we saw is 11G leaked on a 48G machine) but also on our workstations running Ubuntu based distro. $ cat /proc/vmstat | grep thp_zero_page_alloc thp_zero_page_alloc 55 thp_zero_page_alloc_failed 0 This means there is (thp_zero_page_alloc - 1) * (2M - 4K) memory leaked. Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page") Signed-off-by: Yu Zhao <yuzhao@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: Bob Liu <lliubbo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
