path: root/mm
2015-03-13Merge branch 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfsLinus Torvalds
Pull gadgetfs fixes from Al Viro: "Assorted fixes around AIO on gadgetfs: leaks, use-after-free, troubles caused by ->f_op flipping" * 'gadget' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: gadgetfs: really get rid of switching ->f_op gadgetfs: get rid of flipping ->f_op in ep_config() gadget: switch ep_io_operations to ->read_iter/->write_iter gadgetfs: use-after-free in ->aio_read() gadget/function/f_fs.c: switch to ->{read,write}_iter() gadget/function/f_fs.c: use put iov_iter into io_data gadget/function/f_fs.c: close leaks move iov_iter.c from mm/ to lib/ new helper: dup_iter()
2015-03-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "13 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: memcg: disable hierarchy support if bound to the legacy cgroup hierarchy mm: reorder can_do_mlock to fix audit denial kasan, module: move MODULE_ALIGN macro into <linux/moduleloader.h> kasan, module, vmalloc: rework shadow allocation for modules fanotify: fix event filtering with FAN_ONDIR set mm/nommu.c: export symbol max_mapnr arch/c6x/include/asm/pgtable.h: define dummy pgprot_writecombine for !MMU nilfs2: fix deadlock of segment constructor during recovery mm: cma: fix CMA aligned offset calculation mm, hugetlb: close race when setting PageTail for gigantic pages mm, oom: do not fail __GFP_NOFAIL allocation if oom killer is disabled drivers/rtc/rtc-s3c.c: add .needs_src_clk to s3c6410 RTC data ocfs2: make append_dio an incompat feature
2015-03-12memcg: disable hierarchy support if bound to the legacy cgroup hierarchyVladimir Davydov
If the memory cgroup controller is initially mounted in the scope of the default cgroup hierarchy and then remounted to a legacy hierarchy, it will still have hierarchy support enabled, which is incorrect. We should disable hierarchy support if bound to the legacy cgroup hierarchy. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: reorder can_do_mlock to fix audit denialJeff Vander Stoep
A userspace call to mmap(MAP_LOCKED) may result in the successful locking of memory while also producing a confusing audit log denial. can_do_mlock checks capable and rlimit. If either of these return positive can_do_mlock returns true. The capable check leads to an LSM hook used by apparmour and selinux which produce the audit denial. Reordering so rlimit is checked first eliminates the denial on success, only recording a denial when the lock is unsuccessful as a result of the denial. Signed-off-by: Jeff Vander Stoep <jeffv@google.com> Acked-by: Nick Kralevich <nnk@google.com> Cc: Jeff Vander Stoep <jeffv@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Paul Cassella <cassella@cray.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12kasan, module, vmalloc: rework shadow allocation for modulesAndrey Ryabinin
Current approach in handling shadow memory for modules is broken. Shadow memory could be freed only after memory shadow corresponds it is no longer used. vfree() called from interrupt context could use memory its freeing to store 'struct llist_node' in it: void vfree(const void *addr) { ... if (unlikely(in_interrupt())) { struct vfree_deferred *p = this_cpu_ptr(&vfree_deferred); if (llist_add((struct llist_node *)addr, &p->list)) schedule_work(&p->wq); Later this list node used in free_work() which actually frees memory. Currently module_memfree() called in interrupt context will free shadow before freeing module's memory which could provoke kernel crash. So shadow memory should be freed after module's memory. However, such deallocation order could race with kasan_module_alloc() in module_alloc(). Free shadow right before releasing vm area. At this point vfree()'d memory is not used anymore and yet not available for other allocations. New VM_KASAN flag used to indicate that vm area has dynamically allocated shadow memory so kasan frees shadow only if it was previously allocated. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm/nommu.c: export symbol max_mapnrgchen gchen
Several modules may need max_mapnr, so export, the related error with allmodconfig under c6x: MODPOST 3327 modules ERROR: "max_mapnr" [fs/pstore/ramoops.ko] undefined! ERROR: "max_mapnr" [drivers/media/v4l2-core/videobuf2-dma-contig.ko] undefined! Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: cma: fix CMA aligned offset calculationDanesh Petigara
The CMA aligned offset calculation is incorrect for non-zero order_per_bit values. For example, if cma->order_per_bit=1, cma->base_pfn= 0x2f800000 and align_order=12, the function returns a value of 0x17c00 instead of 0x400. This patch fixes the CMA aligned offset calculation. The previous calculation was wrong and would return too-large values for the offset, so that when cma_alloc looks for free pages in the bitmap with the requested alignment > order_per_bit, it starts too far into the bitmap and so CMA allocations will fail despite there actually being plenty of free pages remaining. It will also probably have the wrong alignment. With this change, we will get the correct offset into the bitmap. One affected user is powerpc KVM, which has kvm_cma->order_per_bit set to KVM_CMA_CHUNK_ORDER - PAGE_SHIFT, or 18 - 12 = 6. [gregory.0xf0@gmail.com: changelog additions] Signed-off-by: Danesh Petigara <dpetigara@broadcom.com> Reviewed-by: Gregory Fong <gregory.0xf0@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm, hugetlb: close race when setting PageTail for gigantic pagesDavid Rientjes
Now that gigantic pages are dynamically allocatable, care must be taken to ensure that p->first_page is valid before setting PageTail. If this isn't done, then it is possible to race and have compound_head() return NULL. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm, oom: do not fail __GFP_NOFAIL allocation if oom killer is disabledMichal Hocko
Tetsuo Handa has pointed out that __GFP_NOFAIL allocations might fail after OOM killer is disabled if the allocation is performed by a kernel thread. This behavior was introduced from the very beginning by 7f33d49a2ed5 ("mm, PM/Freezer: Disable OOM killer when tasks are frozen"). This means that the basic contract for the allocation request is broken and the context requesting such an allocation might blow up unexpectedly. There are basically two ways forward. 1) move oom_killer_disable after kernel threads are frozen. This has a risk that the OOM victim wouldn't be able to finish because it would depend on an already frozen kernel thread. This would be really tricky to debug. 2) do not fail GFP_NOFAIL allocation no matter what and risk a potential Freezable kernel threads will loop and fail the suspend. Incidental allocations after kernel threads are frozen will at least dump a warning - if we are lucky and the serial console is still active of course... This patch implements the later option because it is safer. We would see warning rather than allocation failures for the kernel threads which would blow up otherwise and have a higher chances to identify __GFP_NOFAIL users from deeper pm code. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: David Rientjes <rientjes@gooogle.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: thp: Return the correct value for change_huge_pmdMel Gorman
The wrong value is being returned by change_huge_pmd since commit 10c1045f28e8 ("mm: numa: avoid unnecessary TLB flushes when setting NUMA hinting entries") which allows a fallthrough that tries to adjust non-existent PTEs. This patch corrects it. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-12mm: fix up numa read-only thread grouping logicLinus Torvalds
Dave Chinner reported that commit 4d9424669946 ("mm: convert p[te|md]_mknonnuma and remaining page table manipulations") slowed down his xfsrepair test enormously. In particular, it was using more system time due to extra TLB flushing. The ultimate reason turns out to be how the change to use the regular page table accessor functions broke the NUMA grouping logic. The old special mknuma/mknonnuma code accessed the page table present bit and the magic NUMA bit directly, while the new code just changes the page protections using PROT_NONE and the regular vma protections. That sounds equivalent, and from a fault standpoint it really is, but a subtle side effect is that the *other* protection bits of the page table entries also change. And the code to decide how to group the NUMA entries together used the writable bit to decide whether a particular page was likely to be shared read-only or not. And with the change to make the NUMA handling use the regular permission setting functions, that writable bit was basically always cleared for private mappings due to COW. So even if the page actually ends up being written to in the end, the NUMA balancing would act as if it was always shared RO. This code is a heuristic anyway, so the fix - at least for now - is to instead check whether the page is dirty rather than writable. The bit doesn't change with protection changes. NOTE! This also adds a FIXME comment to revisit this issue, Not only should we probably re-visit the whole "is this a shared read-only page" heuristic (we might want to take the vma permissions into account and base this more on those than the per-page ones, and also look at whether the particular access that triggers it is a write or not), but the whole COW issue shows that we should think about the NUMA fault handling some more. For example, maybe we should do the early-COW thing that a regular fault does. Or maybe we should accept that while using the same bits as PROTNONE was a good thing (and got rid of the specual NUMA bit), we might still want to just preseve the other protection bits across NUMA faulting. Those are bigger questions, left for later. This just fixes up the heuristic so that it at least approximates working again. More analysis and work needed. Reported-by: Dave Chinner <david@fromorbit.com> Tested-by: Mel Gorman <mgorman@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org>, Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Two smaller fixes for this cycle: - A fixup from Keith so that NVMe compiles without BLK_INTEGRITY, basically just moving the code around appropriately. - A fixup for shm, fixing an oops in shmem_mapping() for mapping with no inode. From Sasha" [ The shmem fix doesn't look block-layer-related, but fixes a bug that happened due to the backing_dev_info removal.. - Linus ] * 'for-linus' of git://git.kernel.dk/linux-block: mm: shmem: check for mapping owner before dereferencing NVMe: Fix for BLK_DEV_INTEGRITY not set
2015-02-28mm: page_alloc: revert inadvertent !__GFP_FS retry behavior changeJohannes Weiner
Historically, !__GFP_FS allocations were not allowed to invoke the OOM killer once reclaim had failed, but nevertheless kept looping in the allocator. Commit 9879de7373fc ("mm: page_alloc: embed OOM killing naturally into allocation slowpath"), which should have been a simple cleanup patch, accidentally changed the behavior to aborting the allocation at that point. This creates problems with filesystem callers (?) that currently rely on the allocator waiting for other tasks to intervene. Revert the behavior as it shouldn't have been changed as part of a cleanup patch. Fixes: 9879de7373fc ("mm: page_alloc: embed OOM killing naturally into allocation slowpath") Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Dave Chinner <david@fromorbit.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: <stable@vger.kernel.org> [3.19.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28mm: memcontrol: use "max" instead of "infinity" in control knobsJohannes Weiner
The memcg control knobs indicate the highest possible value using the symbolic name "infinity", which is long and awkward to type. Switch to the string "max", which is just as descriptive but shorter and sweeter. This changes a user interface, so do it before the release and before the development flag is dropped from the default hierarchy. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28memcg: fix low limit calculationMichal Hocko
A memcg is considered low limited even when the current usage is equal to the low limit. This leads to interesting side effects e.g. groups/hierarchies with no memory accounted are considered protected and so the reclaim will emit MEMCG_LOW event when encountering them. Another and much bigger issue was reported by Joonsoo Kim. He has hit a NULL ptr dereference with the legacy cgroup API which even doesn't have low limit exposed. The limit is 0 by default but the initial check fails for memcg with 0 consumption and parent_mem_cgroup() would return NULL if use_hierarchy is 0 and so page_counter_read would try to dereference NULL. I suppose that the current implementation is just an overlook because the documentation in Documentation/cgroups/unified-hierarchy.txt says: "The memory.low boundary on the other hand is a top-down allocated reserve. A cgroup enjoys reclaim protection when it and all its ancestors are below their low boundaries" Fix the usage and the low limit comparision in mem_cgroup_low accordingly. Fixes: 241994ed8649 (mm: memcontrol: default hierarchy interface for memory) Reported-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28mm/nommu: fix memory leakJoonsoo Kim
Maxime reported the following memory leak regression due to commit dbc8358c7237 ("mm/nommu: use alloc_pages_exact() rather than its own implementation"). On v3.19, I am facing a memory leak. Each time I run a command one page is lost. Here an example with busybox's free command: / # free total used free shared buffers cached Mem: 7928 1972 5956 0 0 492 -/+ buffers/cache: 1480 6448 / # free total used free shared buffers cached Mem: 7928 1976 5952 0 0 492 -/+ buffers/cache: 1484 6444 / # free total used free shared buffers cached Mem: 7928 1980 5948 0 0 492 -/+ buffers/cache: 1488 6440 / # free total used free shared buffers cached Mem: 7928 1984 5944 0 0 492 -/+ buffers/cache: 1492 6436 / # free total used free shared buffers cached Mem: 7928 1988 5940 0 0 492 -/+ buffers/cache: 1496 6432 At some point, the system fails to sastisfy 256KB allocations: free: page allocation failure: order:6, mode:0xd0 CPU: 0 PID: 67 Comm: free Not tainted 3.19.0-05389-gacf2cf1-dirty #64 Hardware name: STM32 (Device Tree Support) show_stack+0xb/0xc warn_alloc_failed+0x97/0xbc __alloc_pages_nodemask+0x295/0x35c __get_free_pages+0xb/0x24 alloc_pages_exact+0x19/0x24 do_mmap_pgoff+0x423/0x658 vm_mmap_pgoff+0x3f/0x4e load_flat_file+0x20d/0x4f8 load_flat_binary+0x3f/0x26c search_binary_handler+0x51/0xe4 do_execveat_common+0x271/0x35c do_execve+0x19/0x1c ret_fast_syscall+0x1/0x4a Mem-info: Normal per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 active_anon:0 inactive_anon:0 isolated_anon:0 active_file:0 inactive_file:0 isolated_file:0 unevictable:123 dirty:0 writeback:0 unstable:0 free:1515 slab_reclaimable:17 slab_unreclaimable:139 mapped:0 shmem:0 pagetables:0 bounce:0 free_cma:0 Normal free:6060kB min:352kB low:440kB high:528kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:492kB isolated(anon):0ks lowmem_reserve[]: 0 0 Normal: 23*4kB (U) 22*8kB (U) 24*16kB (U) 23*32kB (U) 23*64kB (U) 23*128kB (U) 1*256kB (U) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 6060kB 123 total pagecache pages 2048 pages of RAM 1538 free pages 66 reserved pages 109 slab pages -46 pages shared 0 pages swap cached nommu: Allocation of length 221184 from process 67 (free) failed Normal per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 active_anon:0 inactive_anon:0 isolated_anon:0 active_file:0 inactive_file:0 isolated_file:0 unevictable:123 dirty:0 writeback:0 unstable:0 free:1515 slab_reclaimable:17 slab_unreclaimable:139 mapped:0 shmem:0 pagetables:0 bounce:0 free_cma:0 Normal free:6060kB min:352kB low:440kB high:528kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:492kB isolated(anon):0ks lowmem_reserve[]: 0 0 Normal: 23*4kB (U) 22*8kB (U) 24*16kB (U) 23*32kB (U) 23*64kB (U) 23*128kB (U) 1*256kB (U) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 6060kB 123 total pagecache pages Unable to allocate RAM for process text/data, errno 12 SEGV This problem happens because we allocate ordered page through __get_free_pages() in do_mmap_private() in some cases and we try to free individual pages rather than ordered page in free_page_series(). In this case, freeing pages whose refcount is not 0 won't be freed to the page allocator so memory leak happens. To fix the problem, this patch changes __get_free_pages() to alloc_pages_exact() since alloc_pages_exact() returns physically-contiguous pages but each pages are refcounted. Fixes: dbc8358c7237 ("mm/nommu: use alloc_pages_exact() rather than its own implementation"). Reported-by: Maxime Coquelin <mcoquelin.stm32@gmail.com> Tested-by: Maxime Coquelin <mcoquelin.stm32@gmail.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: <stable@vger.kernel.org> [3.19] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-23mm: shmem: check for mapping owner before dereferencingSasha Levin
mapping->host can be NULL and shouldn't be dereferenced before being checked. [ 1295.741844] GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] SMP KASAN [ 1295.746387] Dumping ftrace buffer: [ 1295.748217] (ftrace buffer empty) [ 1295.749527] Modules linked in: [ 1295.750268] CPU: 62 PID: 23410 Comm: trinity-c70 Not tainted 3.19.0-next-20150219-sasha-00045-g9130270f #1939 [ 1295.750268] task: ffff8803a49db000 ti: ffff8803a4dc8000 task.ti: ffff8803a4dc8000 [ 1295.750268] RIP: shmem_mapping (mm/shmem.c:1458) [ 1295.750268] RSP: 0000:ffff8803a4dcfbf8 EFLAGS: 00010206 [ 1295.750268] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 00000000000f2804 [ 1295.750268] RDX: 0000000000000005 RSI: 0400000000000794 RDI: 0000000000000028 [ 1295.750268] RBP: ffff8803a4dcfc08 R08: 0000000000000000 R09: 00000000031de000 [ 1295.750268] R10: dffffc0000000000 R11: 00000000031c1000 R12: 0400000000000794 [ 1295.750268] R13: 00000000031c2000 R14: 00000000031de000 R15: ffff880e3bdc1000 [ 1295.750268] FS: 00007f8703c7e700(0000) GS:ffff881164800000(0000) knlGS:0000000000000000 [ 1295.750268] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 1295.750268] CR2: 0000000004e58000 CR3: 00000003a9f3c000 CR4: 00000000000007a0 [ 1295.750268] DR0: ffffffff81000000 DR1: 0000009494949494 DR2: 0000000000000000 [ 1295.750268] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 00000000000d0602 [ 1295.750268] Stack: [ 1295.750268] ffff8803a4dcfec8 ffffffffbb1dc770 ffff8803a4dcfc38 ffffffffad6f230b [ 1295.750268] ffffffffad6f2b0d 0000014100000000 ffff88001e17c08b ffff880d9453fe08 [ 1295.750268] ffff8803a4dcfd18 ffffffffad6f2ce2 ffff8803a49dbcd8 ffff8803a49dbce0 [ 1295.750268] Call Trace: [ 1295.750268] mincore_page (mm/mincore.c:61) [ 1295.750268] ? mincore_pte_range (include/linux/spinlock.h:312 mm/mincore.c:131) [ 1295.750268] mincore_pte_range (mm/mincore.c:151) [ 1295.750268] ? mincore_unmapped_range (mm/mincore.c:113) [ 1295.750268] __walk_page_range (mm/pagewalk.c:51 mm/pagewalk.c:90 mm/pagewalk.c:116 mm/pagewalk.c:204) [ 1295.750268] walk_page_range (mm/pagewalk.c:275) [ 1295.750268] SyS_mincore (mm/mincore.c:191 mm/mincore.c:253 mm/mincore.c:220) [ 1295.750268] ? mincore_pte_range (mm/mincore.c:220) [ 1295.750268] ? mincore_unmapped_range (mm/mincore.c:113) [ 1295.750268] ? __mincore_unmapped_range (mm/mincore.c:105) [ 1295.750268] ? ptlock_free (mm/mincore.c:24) [ 1295.750268] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1610) [ 1295.750268] ia32_do_call (arch/x86/ia32/ia32entry.S:446) [ 1295.750268] Code: e5 48 c1 ea 03 53 48 89 fb 48 83 ec 08 80 3c 02 00 75 4f 48 b8 00 00 00 00 00 fc ff df 48 8b 1b 48 8d 7b 28 48 89 fa 48 c1 ea 03 <80> 3c 02 00 75 3f 48 b8 00 00 00 00 00 fc ff df 48 8b 5b 28 48 All code ======== 0: e5 48 in $0x48,%eax 2: c1 ea 03 shr $0x3,%edx 5: 53 push %rbx 6: 48 89 fb mov %rdi,%rbx 9: 48 83 ec 08 sub $0x8,%rsp d: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) 11: 75 4f jne 0x62 13: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax 1a: fc ff df 1d: 48 8b 1b mov (%rbx),%rbx 20: 48 8d 7b 28 lea 0x28(%rbx),%rdi 24: 48 89 fa mov %rdi,%rdx 27: 48 c1 ea 03 shr $0x3,%rdx 2b:* 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) <-- trapping instruction 2f: 75 3f jne 0x70 31: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax 38: fc ff df 3b: 48 8b 5b 28 mov 0x28(%rbx),%rbx 3f: 48 rex.W ... Code starting with the faulting instruction =========================================== 0: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) 4: 75 3f jne 0x45 6: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax d: fc ff df 10: 48 8b 5b 28 mov 0x28(%rbx),%rbx 14: 48 rex.W ... [ 1295.750268] RIP shmem_mapping (mm/shmem.c:1458) [ 1295.750268] RSP <ffff8803a4dcfbf8> Fixes: 97b713ba3e ("fs: kill BDI_CAP_SWAP_BACKED") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-02-22Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted stuff from this cycle. The big ones here are multilayer overlayfs from Miklos and beginning of sorting ->d_inode accesses out from David" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits) autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation procfs: fix race between symlink removals and traversals debugfs: leave freeing a symlink body until inode eviction Documentation/filesystems/Locking: ->get_sb() is long gone trylock_super(): replacement for grab_super_passive() fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry) SELinux: Use d_is_positive() rather than testing dentry->d_inode Smack: Use d_is_positive() rather than testing dentry->d_inode TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR() Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb VFS: Split DCACHE_FILE_TYPE into regular and special types VFS: Add a fallthrough flag for marking virtual dentries VFS: Add a whiteout dentry type VFS: Introduce inode-getting helpers for layered/unioned fs environments Infiniband: Fix potential NULL d_inode dereference posix_acl: fix reference leaks in posix_acl_create autofs4: Wrong format for printing dentry ...
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-19Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "Yann E Morin was supposed to take over kconfig maintainership, but this hasn't happened. So I'm sending a few kconfig patches that I collected: - Fix for missing va_end in kconfig - merge_config.sh displays used if given too few arguments - s/boolean/bool/ in Kconfig files for consistency, with the plan to only support bool in the future" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: use va_end to match corresponding va_start merge_config.sh: Display usage if given too few arguments kconfig: use bool instead of boolean for type definition attributes
2015-02-17move iov_iter.c from mm/ to lib/Al Viro
2015-02-17new helper: dup_iter()Al Viro
Copy iter and kmemdup the underlying array for the copy. Returns a pointer to result of kmemdup() to be kfree()'d later. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17Merge branch 'lazytime' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull lazytime mount option support from Al Viro: "Lazytime stuff from tytso" * 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ext4: add optimization for the lazytime mount option vfs: add find_inode_nowait() function vfs: add support for a lazytime mount option
2015-02-17Merge branch 'iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull iov_iter updates from Al Viro: "More iov_iter work - missing counterpart of iov_iter_init() for bvec-backed ones and vfs_read_iter()/vfs_write_iter() - wrappers for sync calls of ->read_iter()/->write_iter()" * 'iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: add vfs_iter_{read,write} helpers new helper: iov_iter_bvec()
2015-02-16vfs: remove get_xip_memMatthew Wilcox
All callers of get_xip_mem() are now gone. Remove checks for it, initialisers of it, documentation of it and the only implementation of it. Also remove mm/filemap_xip.c as it is now empty. Also remove documentation of the long-gone get_xip_page(). Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16dax,ext2: replace xip_truncate_page with dax_truncate_pageMatthew Wilcox
It takes a get_block parameter just like nobh_truncate_page() and block_truncate_page() Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16dax,ext2: replace the XIP page fault handler with the DAX page fault handlerMatthew Wilcox
Instead of calling aops->get_xip_mem from the fault handler, the filesystem passes a get_block_t that is used to find the appropriate blocks. This requires that all architectures implement copy_user_page(). At the time of writing, mips and arm do not. Patches exist and are in progress. [akpm@linux-foundation.org: remap_file_pages went away] Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16dax,ext2: replace XIP read and write with DAX I/OMatthew Wilcox
Use the generic AIO infrastructure instead of custom read and write methods. In addition to giving us support for AIO, this adds the missing locking between read() and truncate(). Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16vfs,ext2: introduce IS_DAX(inode)Matthew Wilcox
Use an inode flag to tag inodes which should avoid using the page cache. Convert ext2 to use it instead of mapping_is_xip(). Prevent I/Os to files tagged with the DAX flag from falling back to buffered I/O. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16mm: allow page fault handlers to perform the COWMatthew Wilcox
Currently COW of an XIP file is done by first bringing in a read-only mapping, then retrying the fault and copying the page. It is much more efficient to tell the fault handler that a COW is being attempted (by passing in the pre-allocated page in the vm_fault structure), and allow the handler to perform the COW operation itself. The handler cannot insert the page itself if there is already a read-only mapping at that address, so allow the handler to return VM_FAULT_LOCKED and set the fault_page to be NULL. This indicates to the MM code that the i_mmap_lock is held instead of the page lock. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16mm: fix XIP fault vs truncate raceMatthew Wilcox
DAX is a replacement for the variation of XIP currently supported by the ext2 filesystem. We have three different things in the tree called 'XIP', and the new focus is on access to data rather than executables, so a name change was in order. DAX stands for Direct Access. The X is for eXciting. The new focus on data access has resulted in more careful attention to races that exist in the current XIP code, but are not hit by the use-case that it was designed for. XIP's architecture worked fine for ext2, but DAX is architected to work with modern filsystems such as ext4 and XFS. DAX is not intended for use with btrfs; the value that btrfs adds relies on manipulating data and writing data to different locations, while DAX's value is for write-in-place and keeping the kernel from touching the data. DAX was developed in order to support NV-DIMMs, but it's become clear that its usefuless extends beyond NV-DIMMs and there are several potential customers including the tracing machinery. Other people want to place the kernel log in an area of memory, as long as they have a BIOS that does not clear DRAM on reboot. Patch 1 is a bug fix, probably worth including in 3.18. Patches 2 & 3 are infrastructure for DAX. Patches 4-8 replace the XIP code with its DAX equivalents, transforming ext2 to use the DAX code as we go. Note that patch 10 is the Documentation patch. Patches 9-15 clean up after the XIP code, removing the infrastructure that is no longer needed and renaming various XIP things to DAX. Most of these patches were added after Jan found things he didn't like in an earlier version of the ext4 patch ... that had been copied from ext2. So ext2 i being transformed to do things the same way that ext4 will later. The ability to mount ext2 filesystems with the 'xip' option is retained, although the 'dax' option is now preferred. Patch 16 adds some DAX infrastructure to support ext4. Patch 17 adds DAX support to ext4. It is broadly similar to ext2's DAX support, but it is more efficient than ext4's due to its support for unwritten extents. Patch 18 is another cleanup patch renaming XIP to DAX. My thanks to Mathieu Desnoyers for his reviews of the v11 patchset. Most of the changes below were based on his feedback. This patch (of 18): Pagecache faults recheck i_size after taking the page lock to ensure that the fault didn't race against a truncate. We don't have a page to lock in the XIP case, so use i_mmap_lock_read() instead. It is locked in the truncate path in unmap_mapping_range() after updating i_size. So while we hold it in the fault path, we are guaranteed that either i_size has already been updated in the truncate path, or that the truncate will subsequently call zap_page_range_single() and so remove the mapping we have just inserted. There is a window of time in which i_size has been reduced and the thread has a mapping to a page which will be removed from the file, but this is harmless as the page will not be allocated to a different purpose before the thread's access to it is revoked. [akpm@linux-foundation.org: switch to i_mmap_lock_read(), add comment in unmap_single_vma()] Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-14Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux Pull ACCESS_ONCE() rule tightening from Christian Borntraeger: "Tighten rules for ACCESS_ONCE This series tightens the rules for ACCESS_ONCE to only work on scalar types. It also contains the necessary fixups as indicated by build bots of linux-next. Now everything is in place to prevent new non-scalar users of ACCESS_ONCE and we can continue to convert code to READ_ONCE/WRITE_ONCE" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/borntraeger/linux: kernel: Fix sparse warning for ACCESS_ONCE next: sh: Fix compile error kernel: tighten rules for ACCESS ONCE mm/gup: Replace ACCESS_ONCE with READ_ONCE x86/spinlock: Leftover conversion ACCESS_ONCE->READ_ONCE x86/xen/p2m: Replace ACCESS_ONCE with READ_ONCE ppc/hugetlbfs: Replace ACCESS_ONCE with READ_ONCE ppc/kvm: Replace ACCESS_ONCE with READ_ONCE
2015-02-13kasan: enable instrumentation of global variablesAndrey Ryabinin
This feature let us to detect accesses out of bounds of global variables. This will work as for globals in kernel image, so for globals in modules. Currently this won't work for symbols in user-specified sections (e.g. __init, __read_mostly, ...) The idea of this is simple. Compiler increases each global variable by redzone size and add constructors invoking __asan_register_globals() function. Information about global variable (address, size, size with redzone ...) passed to __asan_register_globals() so we could poison variable's redzone. This patch also forces module_alloc() to return 8*PAGE_SIZE aligned address making shadow memory handling ( kasan_module_alloc()/kasan_module_free() ) more simple. Such alignment guarantees that each shadow page backing modules address space correspond to only one module_alloc() allocation. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: vmalloc: pass additional vm_flags to __vmalloc_node_range()Andrey Ryabinin
For instrumenting global variables KASan will shadow memory backing memory for modules. So on module loading we will need to allocate memory for shadow and map it at address in shadow that corresponds to the address allocated in module_alloc(). __vmalloc_node_range() could be used for this purpose, except it puts a guard hole after allocated area. Guard hole in shadow memory should be a problem because at some future point we might need to have a shadow memory at address occupied by guard hole. So we could fail to allocate shadow for module_alloc(). Now we have VM_NO_GUARD flag disabling guard page, so we need to pass into __vmalloc_node_range(). Add new parameter 'vm_flags' to __vmalloc_node_range() function. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: vmalloc: add flag preventing guard hole allocationAndrey Ryabinin
For instrumenting global variables KASan will shadow memory backing memory for modules. So on module loading we will need to allocate memory for shadow and map it at address in shadow that corresponds to the address allocated in module_alloc(). __vmalloc_node_range() could be used for this purpose, except it puts a guard hole after allocated area. Guard hole in shadow memory should be a problem because at some future point we might need to have a shadow memory at address occupied by guard hole. So we could fail to allocate shadow for module_alloc(). Add a new vm_struct flag 'VM_NO_GUARD' indicating that vm area doesn't have a guard hole. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kasan: enable stack instrumentationAndrey Ryabinin
Stack instrumentation allows to detect out of bounds memory accesses for variables allocated on stack. Compiler adds redzones around every variable on stack and poisons redzones in function's prologue. Such approach significantly increases stack usage, so all in-kernel stacks size were doubled. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13x86_64: kasan: add interceptors for memset/memmove/memcpy functionsAndrey Ryabinin
Recently instrumentation of builtin functions calls was removed from GCC 5.0. To check the memory accessed by such functions, userspace asan always uses interceptors for them. So now we should do this as well. This patch declares memset/memmove/memcpy as weak symbols. In mm/kasan/kasan.c we have our own implementation of those functions which checks memory before accessing it. Default memset/memmove/memcpy now now always have aliases with '__' prefix. For files that built without kasan instrumentation (e.g. mm/slub.c) original mem* replaced (via #define) with prefixed variants, cause we don't want to check memory accesses there. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kmemleak: disable kasan instrumentation for kmemleakAndrey Ryabinin
kmalloc internally round up allocation size, and kmemleak uses rounded up size as object's size. This makes kasan to complain while kmemleak scans memory or calculates of object's checksum. The simplest solution here is to disable kasan. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: slub: add kernel address sanitizer support for slub allocatorAndrey Ryabinin
With this patch kasan will be able to catch bugs in memory allocated by slub. Initially all objects in newly allocated slab page, marked as redzone. Later, when allocation of slub object happens, requested by caller number of bytes marked as accessible, and the rest of the object (including slub's metadata) marked as redzone (inaccessible). We also mark object as accessible if ksize was called for this object. There is some places in kernel where ksize function is called to inquire size of really allocated area. Such callers could validly access whole allocated memory, so it should be marked as accessible. Code in slub.c and slab_common.c files could validly access to object's metadata, so instrumentation for this files are disabled. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Signed-off-by: Dmitry Chernenkov <dmitryc@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: slub: introduce metadata_access_enable()/metadata_access_disable()Andrey Ryabinin
It's ok for slub to access memory that marked by kasan as inaccessible (object's metadata). Kasan shouldn't print report in that case because these accesses are valid. Disabling instrumentation of slub.c code is not enough to achieve this because slub passes pointer to object's metadata into external functions like memchr_inv(). We don't want to disable instrumentation for memchr_inv() because this is quite generic function, and we don't want to miss bugs. metadata_access_enable/metadata_access_disable used to tell KASan where accesses to metadata starts/end, so we could temporarily disable KASan reports. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: slub: share object_err functionAndrey Ryabinin
Remove static and add function declarations to linux/slub_def.h so it could be used by kernel address sanitizer. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: page_alloc: add kasan hooks on alloc and free pathsAndrey Ryabinin
Add kernel address sanitizer hooks to mark allocated page's addresses as accessible in corresponding shadow region. Mark freed pages as inaccessible. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kasan: disable memory hotplugAndrey Ryabinin
Currently memory hotplug won't work with KASan. As we don't have shadow for hotplugged memory, kernel will crash on the first access to it. To make this work we will need to allocate shadow for new memory. At some future point proper memory hotplug support will be implemented. Until then, print a warning at startup and disable memory hot-add. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kasan: add kernel address sanitizer infrastructureAndrey Ryabinin
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It provides fast and comprehensive solution for finding use-after-free and out-of-bounds bugs. KASAN uses compile-time instrumentation for checking every memory access, therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with putting symbol aliases into the wrong section, which breaks kasan instrumentation of globals. This patch only adds infrastructure for kernel address sanitizer. It's not available for use yet. The idea and some code was borrowed from [1]. Basic idea: The main idea of KASAN is to use shadow memory to record whether each byte of memory is safe to access or not, and use compiler's instrumentation to check the shadow memory on each memory access. Address sanitizer uses 1/8 of the memory addressable in kernel for shadow memory and uses direct mapping with a scale and offset to translate a memory address to its corresponding shadow address. Here is function to translate address to corresponding shadow address: unsigned long kasan_mem_to_shadow(unsigned long addr) { return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET; } where KASAN_SHADOW_SCALE_SHIFT = 3. So for every 8 bytes there is one corresponding byte of shadow memory. The following encoding used for each shadow byte: 0 means that all 8 bytes of the corresponding memory region are valid for access; k (1 <= k <= 7) means that the first k bytes are valid for access, and other (8 - k) bytes are not; Any negative value indicates that the entire 8-bytes are inaccessible. Different negative values used to distinguish between different kinds of inaccessible memory (redzones, freed memory) (see mm/kasan/kasan.h). To be able to detect accesses to bad memory we need a special compiler. Such compiler inserts a specific function calls (__asan_load*(addr), __asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16. These functions check whether memory region is valid to access or not by checking corresponding shadow memory. If access is not valid an error printed. Historical background of the address sanitizer from Dmitry Vyukov: "We've developed the set of tools, AddressSanitizer (Asan), ThreadSanitizer and MemorySanitizer, for user space. We actively use them for testing inside of Google (continuous testing, fuzzing, running prod services). To date the tools have found more than 10'000 scary bugs in Chromium, Google internal codebase and various open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and lots of others): [2] [3] [4]. The tools are part of both gcc and clang compilers. We have not yet done massive testing under the Kernel AddressSanitizer (it's kind of chicken and egg problem, you need it to be upstream to start applying it extensively). To date it has found about 50 bugs. Bugs that we've found in upstream kernel are listed in [5]. We've also found ~20 bugs in out internal version of the kernel. Also people from Samsung and Oracle have found some. [...] As others noted, the main feature of AddressSanitizer is its performance due to inline compiler instrumentation and simple linear shadow memory. User-space Asan has ~2x slowdown on computational programs and ~2x memory consumption increase. Taking into account that kernel usually consumes only small fraction of CPU and memory when running real user-space programs, I would expect that kernel Asan will have ~10-30% slowdown and similar memory consumption increase (when we finish all tuning). I agree that Asan can well replace kmemcheck. We have plans to start working on Kernel MemorySanitizer that finds uses of unitialized memory. Asan+Msan will provide feature-parity with kmemcheck. As others noted, Asan will unlikely replace debug slab and pagealloc that can be enabled at runtime. Asan uses compiler instrumentation, so even if it is disabled, it still incurs visible overheads. Asan technology is easily portable to other architectures. Compiler instrumentation is fully portable. Runtime has some arch-dependent parts like shadow mapping and atomic operation interception. They are relatively easy to port." Comparison with other debugging features: ======================================== KMEMCHECK: - KASan can do almost everything that kmemcheck can. KASan uses compile-time instrumentation, which makes it significantly faster than kmemcheck. The only advantage of kmemcheck over KASan is detection of uninitialized memory reads. Some brief performance testing showed that kasan could be x500-x600 times faster than kmemcheck: $ netperf -l 30 MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET Recv Send Send Socket Socket Message Elapsed Size Size Size Time Throughput bytes bytes bytes secs. 10^6bits/sec no debug: 87380 16384 16384 30.00 41624.72 kasan inline: 87380 16384 16384 30.00 12870.54 kasan outline: 87380 16384 16384 30.00 10586.39 kmemcheck: 87380 16384 16384 30.03 20.23 - Also kmemcheck couldn't work on several CPUs. It always sets number of CPUs to 1. KASan doesn't have such limitation. DEBUG_PAGEALLOC: - KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page granularity level, so it able to find more bugs. SLUB_DEBUG (poisoning, redzones): - SLUB_DEBUG has lower overhead than KASan. - SLUB_DEBUG in most cases are not able to detect bad reads, KASan able to detect both reads and writes. - In some cases (e.g. redzone overwritten) SLUB_DEBUG detect bugs only on allocation/freeing of object. KASan catch bugs right before it will happen, so we always know exact place of first bad read/write. [1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel [2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs [3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs [4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs [5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies Based on work by Andrey Konovalov. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13slub: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. * This is an equivalent conversion but the whole function should be converted to use scnprinf famiily of functions rather than performing custom output length predictions in multiple places. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13percpu: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm/slab: convert cache name allocations to kstrdup_constAndrzej Hajda
slab frequently performs duplication of strings located in read-only memory section. Replacing kstrdup by kstrdup_const allows to avoid such operations. [akpm@linux-foundation.org: make the handling of kmem_cache.name const-correct] Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mike Turquette <mturquette@linaro.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13mm/util: add kstrdup_constAndrzej Hajda
kstrdup() is often used to duplicate strings where neither source neither destination will be ever modified. In such case we can just reuse the source instead of duplicating it. The problem is that we must be sure that the source is non-modifiable and its life-time is long enough. I suspect the good candidates for such strings are strings located in kernel .rodata section, they cannot be modifed because the section is read-only and their life-time is equal to kernel life-time. This small patchset proposes alternative version of kstrdup - kstrdup_const, which returns source string if it is located in .rodata otherwise it fallbacks to kstrdup. To verify if the source is in .rodata function checks if the address is between sentinels __start_rodata, __end_rodata. I guess it should work with all architectures. The main patch is accompanied by four patches constifying kstrdup for cases where situtation described above happens frequently. I have tested the patchset on mobile platform (exynos4210-trats) and it saves 3272 string allocations. Since minimal allocation is 32 or 64 bytes depending on Kconfig options the patchset saves respectively about 100KB or 200KB of memory. Stats from tested platform show that the main offender is sysfs: By caller: 2260 __kernfs_new_node 631 clk_register+0xc8/0x1b8 318 clk_register+0x34/0x1b8 51 kmem_cache_create 12 alloc_vfsmnt By string (with count >= 5): 883 power 876 subsystem 135 parameters 132 device 61 iommu_group ... This patch (of 5): Add an alternative version of kstrdup which returns pointer to constant char array. The function checks if input string is in persistent and read-only memory section, if yes it returns the input string, otherwise it fallbacks to kstrdup. kstrdup_const is accompanied by kfree_const performing conditional memory deallocation of the string. Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mike Turquette <mturquette@linaro.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third set of updates from Andrew Morton: - the rest of MM [ This includes getting rid of the numa hinting bits, in favor of just generic protnone logic. Yay. - Linus ] - core kernel - procfs - some of lib/ (lots of lib/ material this time) * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (104 commits) lib/lcm.c: replace include lib/percpu_ida.c: remove redundant includes lib/strncpy_from_user.c: replace module.h include lib/stmp_device.c: replace module.h include lib/sort.c: move include inside #if 0 lib/show_mem.c: remove redundant include lib/radix-tree.c: change to simpler include lib/plist.c: remove redundant include lib/nlattr.c: remove redundant include lib/kobject_uevent.c: remove redundant include lib/llist.c: remove redundant include lib/md5.c: simplify include lib/list_sort.c: rearrange includes lib/genalloc.c: remove redundant include lib/idr.c: remove redundant include lib/halfmd4.c: simplify includes lib/dynamic_queue_limits.c: simplify includes lib/sort.c: use simpler includes lib/interval_tree.c: simplify includes hexdump: make it return number of bytes placed in buffer ...
