path: root/mm
2020-04-13mm: mempolicy: require at least one nodeid for MPOL_PREFERREDRandy Dunlap
commit aa9f7d5172fac9bf1f09e678c35e287a40a7b7dd upstream. Using an empty (malformed) nodelist that is not caught during mount option parsing leads to a stack-out-of-bounds access. The option string that was used was: "mpol=prefer:,". However, MPOL_PREFERRED requires a single node number, which is not being provided here. Add a check that 'nodes' is not empty after parsing for MPOL_PREFERRED's nodeid. Fixes: 095f1fc4ebf3 ("mempolicy: rework shmem mpol parsing and display") Reported-by: Entropy Moe <3ntr0py1337@gmail.com> Reported-by: syzbot+b055b1a6b2b958707a21@syzkaller.appspotmail.com Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: syzbot+b055b1a6b2b958707a21@syzkaller.appspotmail.com Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Link: http://lkml.kernel.org/r/89526377-7eb6-b662-e1d8-4430928abde9@infradead.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02x86/mm: split vmalloc_sync_all()Joerg Roedel
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream. Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in the vunmap() code-path. While this change was necessary to maintain correctness on x86-32-pae kernels, it also adds additional cycles for architectures that don't need it. Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported severe performance regressions in micro-benchmarks because it now also calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But the vmalloc_sync_all() implementation on x86-64 is only needed for newly created mappings. To avoid the unnecessary work on x86-64 and to gain the performance back, split up vmalloc_sync_all() into two functions: * vmalloc_sync_mappings(), and * vmalloc_sync_unmappings() Most call-sites to vmalloc_sync_all() only care about new mappings being synchronized. The only exception is the new call-site added in the above mentioned commit. Shile Zhang directed us to a report of an 80% regression in reaim throughput. Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()") Reported-by: kernel test robot <oliver.sang@intel.com> Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Borislav Petkov <bp@suse.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES] Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/ Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mm, slub: prevent kmalloc_node crashes and memory leaksVlastimil Babka
commit 0715e6c516f106ed553828a671d30ad9a3431536 upstream. Sachin reports [1] a crash in SLUB __slab_alloc(): BUG: Kernel NULL pointer dereference on read at 0x000073b0 Faulting instruction address: 0xc0000000003d55f4 Oops: Kernel access of bad area, sig: 11 [#1] LE PAGE_SIZE=64K MMU=Hash SMP NR_CPUS=2048 NUMA pSeries Modules linked in: CPU: 19 PID: 1 Comm: systemd Not tainted 5.6.0-rc2-next-20200218-autotest #1 NIP: c0000000003d55f4 LR: c0000000003d5b94 CTR: 0000000000000000 REGS: c0000008b37836d0 TRAP: 0300 Not tainted (5.6.0-rc2-next-20200218-autotest) MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 24004844 XER: 00000000 CFAR: c00000000000dec4 DAR: 00000000000073b0 DSISR: 40000000 IRQMASK: 1 GPR00: c0000000003d5b94 c0000008b3783960 c00000000155d400 c0000008b301f500 GPR04: 0000000000000dc0 0000000000000002 c0000000003443d8 c0000008bb398620 GPR08: 00000008ba2f0000 0000000000000001 0000000000000000 0000000000000000 GPR12: 0000000024004844 c00000001ec52a00 0000000000000000 0000000000000000 GPR16: c0000008a1b20048 c000000001595898 c000000001750c18 0000000000000002 GPR20: c000000001750c28 c000000001624470 0000000fffffffe0 5deadbeef0000122 GPR24: 0000000000000001 0000000000000dc0 0000000000000002 c0000000003443d8 GPR28: c0000008b301f500 c0000008bb398620 0000000000000000 c00c000002287180 NIP ___slab_alloc+0x1f4/0x760 LR __slab_alloc+0x34/0x60 Call Trace: ___slab_alloc+0x334/0x760 (unreliable) __slab_alloc+0x34/0x60 __kmalloc_node+0x110/0x490 kvmalloc_node+0x58/0x110 mem_cgroup_css_online+0x108/0x270 online_css+0x48/0xd0 cgroup_apply_control_enable+0x2ec/0x4d0 cgroup_mkdir+0x228/0x5f0 kernfs_iop_mkdir+0x90/0xf0 vfs_mkdir+0x110/0x230 do_mkdirat+0xb0/0x1a0 system_call+0x5c/0x68 This is a PowerPC platform with following NUMA topology: available: 2 nodes (0-1) node 0 cpus: node 0 size: 0 MB node 0 free: 0 MB node 1 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 node 1 size: 35247 MB node 1 free: 30907 MB node distances: node 0 1 0: 10 40 1: 40 10 possible numa nodes: 0-31 This only happens with a mmotm patch "mm/memcontrol.c: allocate shrinker_map on appropriate NUMA node" [2] which effectively calls kmalloc_node for each possible node. SLUB however only allocates kmem_cache_node on online N_NORMAL_MEMORY nodes, and relies on node_to_mem_node to return such valid node for other nodes since commit a561ce00b09e ("slub: fall back to node_to_mem_node() node if allocating on memoryless node"). This is however not true in this configuration where the _node_numa_mem_ array is not initialized for nodes 0 and 2-31, thus it contains zeroes and get_partial() ends up accessing non-allocated kmem_cache_node. A related issue was reported by Bharata (originally by Ramachandran) [3] where a similar PowerPC configuration, but with mainline kernel without patch [2] ends up allocating large amounts of pages by kmalloc-1k kmalloc-512. This seems to have the same underlying issue with node_to_mem_node() not behaving as expected, and might probably also lead to an infinite loop with CONFIG_SLUB_CPU_PARTIAL [4]. This patch should fix both issues by not relying on node_to_mem_node() anymore and instead simply falling back to NUMA_NO_NODE, when kmalloc_node(node) is attempted for a node that's not online, or has no usable memory. The "usable memory" condition is also changed from node_present_pages() to N_NORMAL_MEMORY node state, as that is exactly the condition that SLUB uses to allocate kmem_cache_node structures. The check in get_partial() is removed completely, as the checks in ___slab_alloc() are now sufficient to prevent get_partial() being reached with an invalid node. [1] https://lore.kernel.org/linux-next/3381CD91-AB3D-4773-BA04-E7A072A63968@linux.vnet.ibm.com/ [2] https://lore.kernel.org/linux-mm/fff0e636-4c36-ed10-281c-8cdb0687c839@virtuozzo.com/ [3] https://lore.kernel.org/linux-mm/20200317092624.GB22538@in.ibm.com/ [4] https://lore.kernel.org/linux-mm/088b5996-faae-8a56-ef9c-5b567125ae54@suse.cz/ Fixes: a561ce00b09e ("slub: fall back to node_to_mem_node() node if allocating on memoryless node") Reported-by: Sachin Sant <sachinp@linux.vnet.ibm.com> Reported-by: PUVICHAKRAVARTHY RAMACHANDRAN <puvichakravarthy@in.ibm.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Tested-by: Sachin Sant <sachinp@linux.vnet.ibm.com> Tested-by: Bharata B Rao <bharata@linux.ibm.com> Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Hocko <mhocko@kernel.org> Cc: Christopher Lameter <cl@linux.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Kirill Tkhai <ktkhai@virtuozzo.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Nathan Lynch <nathanl@linux.ibm.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20200320115533.9604-1-vbabka@suse.cz Debugged-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02mm: slub: be more careful about the double cmpxchg of freelistLinus Torvalds
commit 5076190daded2197f62fe92cf69674488be44175 upstream. This is just a cleanup addition to Jann's fix to properly update the transaction ID for the slub slowpath in commit fd4d9c7d0c71 ("mm: slub: add missing TID bump.."). The transaction ID is what protects us against any concurrent accesses, but we should really also make sure to make the 'freelist' comparison itself always use the same freelist value that we then used as the new next free pointer. Jann points out that if we do all of this carefully, we could skip the transaction ID update for all the paths that only remove entries from the lists, and only update the TID when adding entries (to avoid the ABA issue with cmpxchg and list handling re-adding a previously seen value). But this patch just does the "make sure to cmpxchg the same value we used" rather than then try to be clever. Acked-by: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02memcg: fix NULL pointer dereference in __mem_cgroup_usage_unregister_eventChunguang Xu
commit 7d36665a5886c27ca4c4d0afd3ecc50b400f3587 upstream. An eventfd monitors multiple memory thresholds of the cgroup, closes them, the kernel deletes all events related to this eventfd. Before all events are deleted, another eventfd monitors the memory threshold of this cgroup, leading to a crash: BUG: kernel NULL pointer dereference, address: 0000000000000004 #PF: supervisor write access in kernel mode #PF: error_code(0x0002) - not-present page PGD 800000033058e067 P4D 800000033058e067 PUD 3355ce067 PMD 0 Oops: 0002 [#1] SMP PTI CPU: 2 PID: 14012 Comm: kworker/2:6 Kdump: loaded Not tainted 5.6.0-rc4 #3 Hardware name: LENOVO 20AWS01K00/20AWS01K00, BIOS GLET70WW (2.24 ) 05/21/2014 Workqueue: events memcg_event_remove RIP: 0010:__mem_cgroup_usage_unregister_event+0xb3/0x190 RSP: 0018:ffffb47e01c4fe18 EFLAGS: 00010202 RAX: 0000000000000001 RBX: ffff8bb223a8a000 RCX: 0000000000000001 RDX: 0000000000000001 RSI: ffff8bb22fb83540 RDI: 0000000000000001 RBP: ffffb47e01c4fe48 R08: 0000000000000000 R09: 0000000000000010 R10: 000000000000000c R11: 071c71c71c71c71c R12: ffff8bb226aba880 R13: ffff8bb223a8a480 R14: 0000000000000000 R15: 0000000000000000 FS:  0000000000000000(0000) GS:ffff8bb242680000(0000) knlGS:0000000000000000 CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000004 CR3: 000000032c29c003 CR4: 00000000001606e0 Call Trace: memcg_event_remove+0x32/0x90 process_one_work+0x172/0x380 worker_thread+0x49/0x3f0 kthread+0xf8/0x130 ret_from_fork+0x35/0x40 CR2: 0000000000000004 We can reproduce this problem in the following ways: 1. We create a new cgroup subdirectory and a new eventfd, and then we monitor multiple memory thresholds of the cgroup through this eventfd. 2. closing this eventfd, and __mem_cgroup_usage_unregister_event () will be called multiple times to delete all events related to this eventfd. The first time __mem_cgroup_usage_unregister_event() is called, the kernel will clear all items related to this eventfd in thresholds-> primary. Since there is currently only one eventfd, thresholds-> primary becomes empty, so the kernel will set thresholds-> primary and hresholds-> spare to NULL. If at this time, the user creates a new eventfd and monitor the memory threshold of this cgroup, kernel will re-initialize thresholds-> primary. Then when __mem_cgroup_usage_unregister_event () is called for the second time, because thresholds-> primary is not empty, the system will access thresholds-> spare, but thresholds-> spare is NULL, which will trigger a crash. In general, the longer it takes to delete all events related to this eventfd, the easier it is to trigger this problem. The solution is to check whether the thresholds associated with the eventfd has been cleared when deleting the event. If so, we do nothing. [akpm@linux-foundation.org: fix comment, per Kirill] Fixes: 907860ed381a ("cgroups: make cftype.unregister_event() void-returning") Signed-off-by: Chunguang Xu <brookxu@tencent.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/077a6f67-aefa-4591-efec-f2f3af2b0b02@gmail.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-20mm: slub: add missing TID bump in kmem_cache_alloc_bulk()Jann Horn
commit fd4d9c7d0c71866ec0c2825189ebd2ce35bd95b8 upstream. When kmem_cache_alloc_bulk() attempts to allocate N objects from a percpu freelist of length M, and N > M > 0, it will first remove the M elements from the percpu freelist, then call ___slab_alloc() to allocate the next element and repopulate the percpu freelist. ___slab_alloc() can re-enable IRQs via allocate_slab(), so the TID must be bumped before ___slab_alloc() to properly commit the freelist head change. Fix it by unconditionally bumping c->tid when entering the slowpath. Cc: stable@vger.kernel.org Fixes: ebe909e0fdb3 ("slub: improve bulk alloc strategy") Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-11mm: prevent get_user_pages() from overflowing page refcountLinus Torvalds
commit 8fde12ca79aff9b5ba951fce1a2641901b8d8e64 upstream. If the page refcount wraps around past zero, it will be freed while there are still four billion references to it. One of the possible avenues for an attacker to try to make this happen is by doing direct IO on a page multiple times. This patch makes get_user_pages() refuse to take a new page reference if there are already more than two billion references to the page. Reported-by: Jann Horn <jannh@google.com> Acked-by: Matthew Wilcox <willy@infradead.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ 4.4.y backport notes: Ajay: - Added local variable 'err' with-in follow_hugetlb_page() from 2be7cfed995e, to resolve compilation error - Added page_ref_count() - Added missing refcount overflow checks on x86 and s390 (Vlastimil, thanks for this change) Srivatsa: - Replaced call to get_page_foll() with try_get_page_foll() ] Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu> Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-11mm, gup: ensure real head page is ref-counted when using hugepagesPunit Agrawal
commit d63206ee32b6e64b0e12d46e5d6004afd9913713 upstream. When speculatively taking references to a hugepage using page_cache_add_speculative() in gup_huge_pmd(), it is assumed that the page returned by pmd_page() is the head page. Although normally true, this assumption doesn't hold when the hugepage comprises of successive page table entries such as when using contiguous bit on arm64 at PTE or PMD levels. This can be addressed by ensuring that the page passed to page_cache_add_speculative() is the real head or by de-referencing the head page within the function. We take the first approach to keep the usage pattern aligned with page_cache_get_speculative() where users already pass the appropriate page, i.e., the de-referenced head. Apply the same logic to fix gup_huge_[pud|pgd]() as well. [punit.agrawal@arm.com: fix arm64 ltp failure] Link: http://lkml.kernel.org/r/20170619170145.25577-5-punit.agrawal@arm.com Link: http://lkml.kernel.org/r/20170522133604.11392-3-punit.agrawal@arm.com Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Steve Capper <steve.capper@arm.com> Cc: Michal Hocko <mhocko@suse.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-11mm, gup: remove broken VM_BUG_ON_PAGE compound check for hugepagesWill Deacon
commit a3e328556d41bb61c55f9dfcc62d6a826ea97b85 upstream. When operating on hugepages with DEBUG_VM enabled, the GUP code checks the compound head for each tail page prior to calling page_cache_add_speculative. This is broken, because on the fast-GUP path (where we don't hold any page table locks) we can be racing with a concurrent invocation of split_huge_page_to_list. split_huge_page_to_list deals with this race by using page_ref_freeze to freeze the page and force concurrent GUPs to fail whilst the component pages are modified. This modification includes clearing the compound_head field for the tail pages, so checking this prior to a successful call to page_cache_add_speculative can lead to false positives: In fact, page_cache_add_speculative *already* has this check once the page refcount has been successfully updated, so we can simply remove the broken calls to VM_BUG_ON_PAGE. Link: http://lkml.kernel.org/r/20170522133604.11392-2-punit.agrawal@arm.com Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Steve Capper <steve.capper@arm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu> Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-11mm: add 'try_get_page()' helper functionLinus Torvalds
commit 88b1a17dfc3ed7728316478fae0f5ad508f50397 upsteam. This is the same as the traditional 'get_page()' function, but instead of unconditionally incrementing the reference count of the page, it only does so if the count was "safe". It returns whether the reference count was incremented (and is marked __must_check, since the caller obviously has to be aware of it). Also like 'get_page()', you can't use this function unless you already had a reference to the page. The intent is that you can use this exactly like get_page(), but in situations where you want to limit the maximum reference count. The code currently does an unconditional WARN_ON_ONCE() if we ever hit the reference count issues (either zero or negative), as a notification that the conditional non-increment actually happened. NOTE! The count access for the "safety" check is inherently racy, but that doesn't matter since the buffer we use is basically half the range of the reference count (ie we look at the sign of the count). Acked-by: Matthew Wilcox <willy@infradead.org> Cc: Jann Horn <jannh@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ 4.4.y backport notes: Srivatsa: - Adapted try_get_page() to match the get_page() implementation in 4.4.y, except for the refcount check. - Added try_get_page_foll() which will be needed in a subsequent patch. ] Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu> Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-03-11mm: make page ref count overflow check tighter and more explicitLinus Torvalds
commit f958d7b528b1b40c44cfda5eabe2d82760d868c3 upsteam. We have a VM_BUG_ON() to check that the page reference count doesn't underflow (or get close to overflow) by checking the sign of the count. That's all fine, but we actually want to allow people to use a "get page ref unless it's already very high" helper function, and we want that one to use the sign of the page ref (without triggering this VM_BUG_ON). Change the VM_BUG_ON to only check for small underflows (or _very_ close to overflowing), and ignore overflows which have strayed into negative territory. Acked-by: Matthew Wilcox <willy@infradead.org> Cc: Jann Horn <jannh@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ 4.4.y backport notes: Ajay: Open-coded atomic refcount access due to missing page_ref_count() helper in 4.4.y Srivatsa: Added overflow check to get_page_foll() and related code. ] Signed-off-by: Srivatsa S. Bhat (VMware) <srivatsa@csail.mit.edu> Signed-off-by: Ajay Kaher <akaher@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-02-05mm/mempolicy.c: fix out of bounds write in mpol_parse_str()Dan Carpenter
commit c7a91bc7c2e17e0a9c8b9745a2cb118891218fd1 upstream. What we are trying to do is change the '=' character to a NUL terminator and then at the end of the function we restore it back to an '='. The problem is there are two error paths where we jump to the end of the function before we have replaced the '=' with NUL. We end up putting the '=' in the wrong place (possibly one element before the start of the buffer). Link: http://lkml.kernel.org/r/20200115055426.vdjwvry44nfug7yy@kili.mountain Reported-by: syzbot+e64a13c5369a194d67df@syzkaller.appspotmail.com Fixes: 095f1fc4ebf3 ("mempolicy: rework shmem mpol parsing and display") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Dmitry Vyukov <dvyukov@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23mm/page-writeback.c: avoid potential division by zero in wb_min_max_ratio()Wen Yang
commit 6d9e8c651dd979aa666bee15f086745f3ea9c4b3 upstream. Patch series "use div64_ul() instead of div_u64() if the divisor is unsigned long". We were first inspired by commit b0ab99e7736a ("sched: Fix possible divide by zero in avg_atom () calculation"), then refer to the recently analyzed mm code, we found this suspicious place. 201 if (min) { 202 min *= this_bw; 203 do_div(min, tot_bw); 204 } And we also disassembled and confirmed it: /usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 201 0xffffffff811c37da <__wb_calc_thresh+234>: xor %r10d,%r10d 0xffffffff811c37dd <__wb_calc_thresh+237>: test %rax,%rax 0xffffffff811c37e0 <__wb_calc_thresh+240>: je 0xffffffff811c3800 <__wb_calc_thresh+272> /usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 202 0xffffffff811c37e2 <__wb_calc_thresh+242>: imul %r8,%rax /usr/src/debug/kernel-4.9.168-016.ali3000/linux-4.9.168-016.ali3000.alios7.x86_64/mm/page-writeback.c: 203 0xffffffff811c37e6 <__wb_calc_thresh+246>: mov %r9d,%r10d ---> truncates it to 32 bits here 0xffffffff811c37e9 <__wb_calc_thresh+249>: xor %edx,%edx 0xffffffff811c37eb <__wb_calc_thresh+251>: div %r10 0xffffffff811c37ee <__wb_calc_thresh+254>: imul %rbx,%rax 0xffffffff811c37f2 <__wb_calc_thresh+258>: shr $0x2,%rax 0xffffffff811c37f6 <__wb_calc_thresh+262>: mul %rcx 0xffffffff811c37f9 <__wb_calc_thresh+265>: shr $0x2,%rdx 0xffffffff811c37fd <__wb_calc_thresh+269>: mov %rdx,%r10 This series uses div64_ul() instead of div_u64() if the divisor is unsigned long, to avoid truncation to 32-bit on 64-bit platforms. This patch (of 3): The variables 'min' and 'max' are unsigned long and do_div truncates them to 32 bits, which means it can test non-zero and be truncated to zero for division. Fix this issue by using div64_ul() instead. Link: http://lkml.kernel.org/r/20200102081442.8273-2-wenyang@linux.alibaba.com Fixes: 693108a8a667 ("writeback: make bdi->min/max_ratio handling cgroup writeback aware") Signed-off-by: Wen Yang <wenyang@linux.alibaba.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Qian Cai <cai@lca.pw> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23mm/page_alloc.c: calculate 'available' memory in a separate functionIgor Redko
commit d02bd27bd33dd7e8d22594cd568b81be0cb584cd upstream. Add a new field, VIRTIO_BALLOON_S_AVAIL, to virtio_balloon memory statistics protocol, corresponding to 'Available' in /proc/meminfo. It indicates to the hypervisor how big the balloon can be inflated without pushing the guest system to swap. This metric would be very useful in VM orchestration software to improve memory management of different VMs under overcommit. This patch (of 2): Factor out calculation of the available memory counter into a separate exportable function, in order to be able to use it in other parts of the kernel. In particular, it appears a relevant metric to report to the hypervisor via virtio-balloon statistics interface (in a followup patch). Signed-off-by: Igor Redko <redkoi@virtuozzo.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Reviewed-by: Roman Kagan <rkagan@virtuozzo.com> Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 4.4 as dependency of commit a1078e821b60 "xen: let alloc_xenballooned_pages() fail if not enough memory free"] Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-21mm/shmem.c: cast the type of unmap_start to u64Chen Jun
commit aa71ecd8d86500da6081a72da6b0b524007e0627 upstream. In 64bit system. sb->s_maxbytes of shmem filesystem is MAX_LFS_FILESIZE, which equal LLONG_MAX. If offset > LLONG_MAX - PAGE_SIZE, offset + len < LLONG_MAX in shmem_fallocate, which will pass the checking in vfs_fallocate. /* Check for wrap through zero too */ if (((offset + len) > inode->i_sb->s_maxbytes) || ((offset + len) < 0)) return -EFBIG; loff_t unmap_start = round_up(offset, PAGE_SIZE) in shmem_fallocate causes a overflow. Syzkaller reports a overflow problem in mm/shmem: UBSAN: Undefined behaviour in mm/shmem.c:2014:10 signed integer overflow: '9223372036854775807 + 1' cannot be represented in type 'long long int' CPU: 0 PID:17076 Comm: syz-executor0 Not tainted 4.1.46+ #1 Hardware name: linux, dummy-virt (DT) Call trace: dump_backtrace+0x0/0x2c8 arch/arm64/kernel/traps.c:100 show_stack+0x20/0x30 arch/arm64/kernel/traps.c:238 __dump_stack lib/dump_stack.c:15 [inline] ubsan_epilogue+0x18/0x70 lib/ubsan.c:164 handle_overflow+0x158/0x1b0 lib/ubsan.c:195 shmem_fallocate+0x6d0/0x820 mm/shmem.c:2104 vfs_fallocate+0x238/0x428 fs/open.c:312 SYSC_fallocate fs/open.c:335 [inline] SyS_fallocate+0x54/0xc8 fs/open.c:239 The highest bit of unmap_start will be appended with sign bit 1 (overflow) when calculate shmem_falloc.start: shmem_falloc.start = unmap_start >> PAGE_SHIFT. Fix it by casting the type of unmap_start to u64, when right shifted. This bug is found in LTS Linux 4.1. It also seems to exist in mainline. Link: http://lkml.kernel.org/r/1573867464-5107-1-git-send-email-chenjun102@huawei.com Signed-off-by: Chen Jun <chenjun102@huawei.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Qian Cai <cai@lca.pw> Cc: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-28mm/page-writeback.c: fix range_cyclic writeback vs writepages deadlockDave Chinner
[ Upstream commit 64081362e8ff4587b4554087f3cfc73d3e0a4cd7 ] We've recently seen a workload on XFS filesystems with a repeatable deadlock between background writeback and a multi-process application doing concurrent writes and fsyncs to a small range of a file. range_cyclic writeback Process 1 Process 2 xfs_vm_writepages write_cache_pages writeback_index = 2 cycled = 0 .... find page 2 dirty lock Page 2 ->writepage page 2 writeback page 2 clean page 2 added to bio no more pages write() locks page 1 dirties page 1 locks page 2 dirties page 1 fsync() .... xfs_vm_writepages write_cache_pages start index 0 find page 1 towrite lock Page 1 ->writepage page 1 writeback page 1 clean page 1 added to bio find page 2 towrite lock Page 2 page 2 is writeback <blocks> write() locks page 1 dirties page 1 fsync() .... xfs_vm_writepages write_cache_pages start index 0 !done && !cycled sets index to 0, restarts lookup find page 1 dirty find page 1 towrite lock Page 1 page 1 is writeback <blocks> lock Page 1 <blocks> DEADLOCK because: - process 1 needs page 2 writeback to complete to make enough progress to issue IO pending for page 1 - writeback needs page 1 writeback to complete so process 2 can progress and unlock the page it is blocked on, then it can issue the IO pending for page 2 - process 2 can't make progress until process 1 issues IO for page 1 The underlying cause of the problem here is that range_cyclic writeback is processing pages in descending index order as we hold higher index pages in a structure controlled from above write_cache_pages(). The write_cache_pages() caller needs to be able to submit these pages for IO before write_cache_pages restarts writeback at mapping index 0 to avoid wcp inverting the page lock/writeback wait order. generic_writepages() is not susceptible to this bug as it has no private context held across write_cache_pages() - filesystems using this infrastructure always submit pages in ->writepage immediately and so there is no problem with range_cyclic going back to mapping index 0. However: mpage_writepages() has a private bio context, exofs_writepages() has page_collect fuse_writepages() has fuse_fill_wb_data nfs_writepages() has nfs_pageio_descriptor xfs_vm_writepages() has xfs_writepage_ctx All of these ->writepages implementations can hold pages under writeback in their private structures until write_cache_pages() returns, and hence they are all susceptible to this deadlock. Also worth noting is that ext4 has it's own bastardised version of write_cache_pages() and so it /may/ have an equivalent deadlock. I looked at the code long enough to understand that it has a similar retry loop for range_cyclic writeback reaching the end of the file and then promptly ran away before my eyes bled too much. I'll leave it for the ext4 developers to determine if their code is actually has this deadlock and how to fix it if it has. There's a few ways I can see avoid this deadlock. There's probably more, but these are the first I've though of: 1. get rid of range_cyclic altogether 2. range_cyclic always stops at EOF, and we start again from writeback index 0 on the next call into write_cache_pages() 2a. wcp also returns EAGAIN to ->writepages implementations to indicate range cyclic has hit EOF. writepages implementations can then flush the current context and call wpc again to continue. i.e. lift the retry into the ->writepages implementation 3. range_cyclic uses trylock_page() rather than lock_page(), and it skips pages it can't lock without blocking. It will already do this for pages under writeback, so this seems like a no-brainer 3a. all non-WB_SYNC_ALL writeback uses trylock_page() to avoid blocking as per pages under writeback. I don't think #1 is an option - range_cyclic prevents frequently dirtied lower file offset from starving background writeback of rarely touched higher file offsets. #2 is simple, and I don't think it will have any impact on performance as going back to the start of the file implies an immediate seek. We'll have exactly the same number of seeks if we switch writeback to another inode, and then come back to this one later and restart from index 0. #2a is pretty much "status quo without the deadlock". Moving the retry loop up into the wcp caller means we can issue IO on the pending pages before calling wcp again, and so avoid locking or waiting on pages in the wrong order. I'm not convinced we need to do this given that we get the same thing from #2 on the next writeback call from the writeback infrastructure. #3 is really just a band-aid - it doesn't fix the access/wait inversion problem, just prevents it from becoming a deadlock situation. I'd prefer we fix the inversion, not sweep it under the carpet like this. #3a is really an optimisation that just so happens to include the band-aid fix of #3. So it seems that the simplest way to fix this issue is to implement solution #2 Link: http://lkml.kernel.org/r/20181005054526.21507-1-david@fromorbit.com Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Jan Kara <jack@suse.de> Cc: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-28mm/ksm.c: don't WARN if page is still mapped in remove_stable_node()Andrey Ryabinin
commit 9a63236f1ad82d71a98aa80320b6cb618fb32f44 upstream. It's possible to hit the WARN_ON_ONCE(page_mapped(page)) in remove_stable_node() when it races with __mmput() and squeezes in between ksm_exit() and exit_mmap(). WARNING: CPU: 0 PID: 3295 at mm/ksm.c:888 remove_stable_node+0x10c/0x150 Call Trace: remove_all_stable_nodes+0x12b/0x330 run_store+0x4ef/0x7b0 kernfs_fop_write+0x200/0x420 vfs_write+0x154/0x450 ksys_write+0xf9/0x1d0 do_syscall_64+0x99/0x510 entry_SYSCALL_64_after_hwframe+0x49/0xbe Remove the warning as there is nothing scary going on. Link: http://lkml.kernel.org/r/20191119131850.5675-1-aryabinin@virtuozzo.com Fixes: cbf86cfe04a6 ("ksm: remove old stable nodes more thoroughly") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-25memfd: Use radix_tree_deref_slot_protected to avoid the warning.zhong jiang
The commit eb4058d8daf8 ("memfd: Fix locking when tagging pins") introduces the following warning messages. *WARNING: suspicious RCU usage in memfd_wait_for_pins* It is because we still use radix_tree_deref_slot without read_rcu_lock. We should use radix_tree_deref_slot_protected instead in the case. Cc: stable@vger.kernel.org Fixes: eb4058d8daf8 ("memfd: Fix locking when tagging pins") Signed-off-by: zhong jiang <zhongjiang@huawei.com> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-25mm: hugetlb: switch to css_tryget() in hugetlb_cgroup_charge_cgroup()Roman Gushchin
commit 0362f326d86c645b5e96b7dbc3ee515986ed019d upstream. An exiting task might belong to an offline cgroup. In this case an attempt to grab a cgroup reference from the task can end up with an infinite loop in hugetlb_cgroup_charge_cgroup(), because neither the cgroup will become online, neither the task will be migrated to a live cgroup. Fix this by switching over to css_tryget(). As css_tryget_online() can't guarantee that the cgroup won't go offline, in most cases the check doesn't make sense. In this particular case users of hugetlb_cgroup_charge_cgroup() are not affected by this change. A similar problem is described by commit 18fa84a2db0e ("cgroup: Use css_tryget() instead of css_tryget_online() in task_get_css()"). Link: http://lkml.kernel.org/r/20191106225131.3543616-2-guro@fb.com Signed-off-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Shakeel Butt <shakeelb@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-25mm: memcg: switch to css_tryget() in get_mem_cgroup_from_mm()Roman Gushchin
commit 00d484f354d85845991b40141d40ba9e5eb60faf upstream. We've encountered a rcu stall in get_mem_cgroup_from_mm(): rcu: INFO: rcu_sched self-detected stall on CPU rcu: 33-....: (21000 ticks this GP) idle=6c6/1/0x4000000000000002 softirq=35441/35441 fqs=5017 (t=21031 jiffies g=324821 q=95837) NMI backtrace for cpu 33 <...> RIP: 0010:get_mem_cgroup_from_mm+0x2f/0x90 <...> __memcg_kmem_charge+0x55/0x140 __alloc_pages_nodemask+0x267/0x320 pipe_write+0x1ad/0x400 new_sync_write+0x127/0x1c0 __kernel_write+0x4f/0xf0 dump_emit+0x91/0xc0 writenote+0xa0/0xc0 elf_core_dump+0x11af/0x1430 do_coredump+0xc65/0xee0 get_signal+0x132/0x7c0 do_signal+0x36/0x640 exit_to_usermode_loop+0x61/0xd0 do_syscall_64+0xd4/0x100 entry_SYSCALL_64_after_hwframe+0x44/0xa9 The problem is caused by an exiting task which is associated with an offline memcg. We're iterating over and over in the do {} while (!css_tryget_online()) loop, but obviously the memcg won't become online and the exiting task won't be migrated to a live memcg. Let's fix it by switching from css_tryget_online() to css_tryget(). As css_tryget_online() cannot guarantee that the memcg won't go offline, the check is usually useless, except some rare cases when for example it determines if something should be presented to a user. A similar problem is described by commit 18fa84a2db0e ("cgroup: Use css_tryget() instead of css_tryget_online() in task_get_css()"). Johannes: : The bug aside, it doesn't matter whether the cgroup is online for the : callers. It used to matter when offlining needed to evacuate all charges : from the memcg, and so needed to prevent new ones from showing up, but we : don't care now. Link: http://lkml.kernel.org/r/20191106225131.3543616-1-guro@fb.com Signed-off-by: Roman Gushchin <guro@fb.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Shakeel Butt <shakeeb@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Michal Koutn <mkoutny@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12mm/filemap.c: don't initiate writeback if mapping has no dirty pagesKonstantin Khlebnikov
commit c3aab9a0bd91b696a852169479b7db1ece6cbf8c upstream. Functions like filemap_write_and_wait_range() should do nothing if inode has no dirty pages or pages currently under writeback. But they anyway construct struct writeback_control and this does some atomic operations if CONFIG_CGROUP_WRITEBACK=y - on fast path it locks inode->i_lock and updates state of writeback ownership, on slow path might be more work. Current this path is safely avoided only when inode mapping has no pages. For example generic_file_read_iter() calls filemap_write_and_wait_range() at each O_DIRECT read - pretty hot path. This patch skips starting new writeback if mapping has no dirty tags set. If writeback is already in progress filemap_write_and_wait_range() will wait for it. Link: http://lkml.kernel.org/r/156378816804.1087.8607636317907921438.stgit@buzz Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12mm, vmstat: hide /proc/pagetypeinfo from normal usersMichal Hocko
commit abaed0112c1db08be15a784a2c5c8a8b3063cdd3 upstream. /proc/pagetypeinfo is a debugging tool to examine internal page allocator state wrt to fragmentation. It is not very useful for any other use so normal users really do not need to read this file. Waiman Long has noticed that reading this file can have negative side effects because zone->lock is necessary for gathering data and that a) interferes with the page allocator and its users and b) can lead to hard lockups on large machines which have very long free_list. Reduce both issues by simply not exporting the file to regular users. Link: http://lkml.kernel.org/r/20191025072610.18526-2-mhocko@kernel.org Fixes: 467c996c1e19 ("Print out statistics in relation to fragmentation avoidance to /proc/pagetypeinfo") Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Waiman Long <longman@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Waiman Long <longman@redhat.com> Acked-by: Rafael Aquini <aquini@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: David Hildenbrand <david@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Roman Gushchin <guro@fb.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Jann Horn <jannh@google.com> Cc: Song Liu <songliubraving@fb.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29mm/slub: fix a deadlock in show_slab_objects()Qian Cai
commit e4f8e513c3d353c134ad4eef9fd0bba12406c7c8 upstream. A long time ago we fixed a similar deadlock in show_slab_objects() [1]. However, it is apparently due to the commits like 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path") and 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}"), this kind of deadlock is back by just reading files in /sys/kernel/slab which will generate a lockdep splat below. Since the "mem_hotplug_lock" here is only to obtain a stable online node mask while racing with NUMA node hotplug, in the worst case, the results may me miscalculated while doing NUMA node hotplug, but they shall be corrected by later reads of the same files. WARNING: possible circular locking dependency detected ------------------------------------------------------ cat/5224 is trying to acquire lock: ffff900012ac3120 (mem_hotplug_lock.rw_sem){++++}, at: show_slab_objects+0x94/0x3a8 but task is already holding lock: b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (kn->count#45){++++}: lock_acquire+0x31c/0x360 __kernfs_remove+0x290/0x490 kernfs_remove+0x30/0x44 sysfs_remove_dir+0x70/0x88 kobject_del+0x50/0xb0 sysfs_slab_unlink+0x2c/0x38 shutdown_cache+0xa0/0xf0 kmemcg_cache_shutdown_fn+0x1c/0x34 kmemcg_workfn+0x44/0x64 process_one_work+0x4f4/0x950 worker_thread+0x390/0x4bc kthread+0x1cc/0x1e8 ret_from_fork+0x10/0x18 -> #1 (slab_mutex){+.+.}: lock_acquire+0x31c/0x360 __mutex_lock_common+0x16c/0xf78 mutex_lock_nested+0x40/0x50 memcg_create_kmem_cache+0x38/0x16c memcg_kmem_cache_create_func+0x3c/0x70 process_one_work+0x4f4/0x950 worker_thread+0x390/0x4bc kthread+0x1cc/0x1e8 ret_from_fork+0x10/0x18 -> #0 (mem_hotplug_lock.rw_sem){++++}: validate_chain+0xd10/0x2bcc __lock_acquire+0x7f4/0xb8c lock_acquire+0x31c/0x360 get_online_mems+0x54/0x150 show_slab_objects+0x94/0x3a8 total_objects_show+0x28/0x34 slab_attr_show+0x38/0x54 sysfs_kf_seq_show+0x198/0x2d4 kernfs_seq_show+0xa4/0xcc seq_read+0x30c/0x8a8 kernfs_fop_read+0xa8/0x314 __vfs_read+0x88/0x20c vfs_read+0xd8/0x10c ksys_read+0xb0/0x120 __arm64_sys_read+0x54/0x88 el0_svc_handler+0x170/0x240 el0_svc+0x8/0xc other info that might help us debug this: Chain exists of: mem_hotplug_lock.rw_sem --> slab_mutex --> kn->count#45 Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(kn->count#45); lock(slab_mutex); lock(kn->count#45); lock(mem_hotplug_lock.rw_sem); *** DEADLOCK *** 3 locks held by cat/5224: #0: 9eff00095b14b2a0 (&p->lock){+.+.}, at: seq_read+0x4c/0x8a8 #1: 0eff008997041480 (&of->mutex){+.+.}, at: kernfs_seq_start+0x34/0xf0 #2: b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0 stack backtrace: Call trace: dump_backtrace+0x0/0x248 show_stack+0x20/0x2c dump_stack+0xd0/0x140 print_circular_bug+0x368/0x380 check_noncircular+0x248/0x250 validate_chain+0xd10/0x2bcc __lock_acquire+0x7f4/0xb8c lock_acquire+0x31c/0x360 get_online_mems+0x54/0x150 show_slab_objects+0x94/0x3a8 total_objects_show+0x28/0x34 slab_attr_show+0x38/0x54 sysfs_kf_seq_show+0x198/0x2d4 kernfs_seq_show+0xa4/0xcc seq_read+0x30c/0x8a8 kernfs_fop_read+0xa8/0x314 __vfs_read+0x88/0x20c vfs_read+0xd8/0x10c ksys_read+0xb0/0x120 __arm64_sys_read+0x54/0x88 el0_svc_handler+0x170/0x240 el0_svc+0x8/0xc I think it is important to mention that this doesn't expose the show_slab_objects to use-after-free. There is only a single path that might really race here and that is the slab hotplug notifier callback __kmem_cache_shrink (via slab_mem_going_offline_callback) but that path doesn't really destroy kmem_cache_node data structures. [1] http://lkml.iu.edu/hypermail/linux/kernel/1101.0/02850.html [akpm@linux-foundation.org: add comment explaining why we don't need mem_hotplug_lock] Link: http://lkml.kernel.org/r/1570192309-10132-1-git-send-email-cai@lca.pw Fixes: 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path") Fixes: 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}") Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Roman Gushchin <guro@fb.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-29memfd: Fix locking when tagging pinsMatthew Wilcox (Oracle)
The RCU lock is insufficient to protect the radix tree iteration as a deletion from the tree can occur before we take the spinlock to tag the entry. In 4.19, this has manifested as a bug with the following trace: kernel BUG at lib/radix-tree.c:1429! invalid opcode: 0000 [#1] SMP KASAN PTI CPU: 7 PID: 6935 Comm: syz-executor.2 Not tainted 4.19.36 #25 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:radix_tree_tag_set+0x200/0x2f0 lib/radix-tree.c:1429 Code: 00 00 5b 5d 41 5c 41 5d 41 5e 41 5f c3 48 89 44 24 10 e8 a3 29 7e fe 48 8b 44 24 10 48 0f ab 03 e9 d2 fe ff ff e8 90 29 7e fe <0f> 0b 48 c7 c7 e0 5a 87 84 e8 f0 e7 08 ff 4c 89 ef e8 4a ff ac fe RSP: 0018:ffff88837b13fb60 EFLAGS: 00010016 RAX: 0000000000040000 RBX: ffff8883c5515d58 RCX: ffffffff82cb2ef0 RDX: 0000000000000b72 RSI: ffffc90004cf2000 RDI: ffff8883c5515d98 RBP: ffff88837b13fb98 R08: ffffed106f627f7e R09: ffffed106f627f7e R10: 0000000000000001 R11: ffffed106f627f7d R12: 0000000000000004 R13: ffffea000d7fea80 R14: 1ffff1106f627f6f R15: 0000000000000002 FS: 00007fa1b8df2700(0000) GS:ffff8883e2fc0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007fa1b8df1db8 CR3: 000000037d4d2001 CR4: 0000000000160ee0 Call Trace: memfd_tag_pins mm/memfd.c:51 [inline] memfd_wait_for_pins+0x2c5/0x12d0 mm/memfd.c:81 memfd_add_seals mm/memfd.c:215 [inline] memfd_fcntl+0x33d/0x4a0 mm/memfd.c:247 do_fcntl+0x589/0xeb0 fs/fcntl.c:421 __do_sys_fcntl fs/fcntl.c:463 [inline] __se_sys_fcntl fs/fcntl.c:448 [inline] __x64_sys_fcntl+0x12d/0x180 fs/fcntl.c:448 do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:293 The problem does not occur in mainline due to the XArray rewrite which changed the locking to exclude modification of the tree during iteration. At the time, nobody realised this was a bugfix. Backport the locking changes to stable. Cc: stable@vger.kernel.org Reported-by: zhong jiang <zhongjiang@huawei.com> Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-08-25mm/memcontrol.c: fix use after free in mem_cgroup_iter()Miles Chen
commit 54a83d6bcbf8f4700013766b974bf9190d40b689 upstream. This patch is sent to report an use after free in mem_cgroup_iter() after merging commit be2657752e9e ("mm: memcg: fix use after free in mem_cgroup_iter()"). I work with android kernel tree (4.9 & 4.14), and commit be2657752e9e ("mm: memcg: fix use after free in mem_cgroup_iter()") has been merged to the trees. However, I can still observe use after free issues addressed in the commit be2657752e9e. (on low-end devices, a few times this month) backtrace: css_tryget <- crash here mem_cgroup_iter shrink_node shrink_zones do_try_to_free_pages try_to_free_pages __perform_reclaim __alloc_pages_direct_reclaim __alloc_pages_slowpath __alloc_pages_nodemask To debug, I poisoned mem_cgroup before freeing it: static void __mem_cgroup_free(struct mem_cgroup *memcg) for_each_node(node) free_mem_cgroup_per_node_info(memcg, node); free_percpu(memcg->stat); + /* poison memcg before freeing it */ + memset(memcg, 0x78, sizeof(struct mem_cgroup)); kfree(memcg); } The coredump shows the position=0xdbbc2a00 is freed. (gdb) p/x ((struct mem_cgroup_per_node *)0xe5009e00)->iter[8] $13 = {position = 0xdbbc2a00, generation = 0x2efd} 0xdbbc2a00: 0xdbbc2e00 0x00000000 0xdbbc2800 0x00000100 0xdbbc2a10: 0x00000200 0x78787878 0x00026218 0x00000000 0xdbbc2a20: 0xdcad6000 0x00000001 0x78787800 0x00000000 0xdbbc2a30: 0x78780000 0x00000000 0x0068fb84 0x78787878 0xdbbc2a40: 0x78787878 0x78787878 0x78787878 0xe3fa5cc0 0xdbbc2a50: 0x78787878 0x78787878 0x00000000 0x00000000 0xdbbc2a60: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a70: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a80: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2a90: 0x00000001 0x00000000 0x00000000 0x00100000 0xdbbc2aa0: 0x00000001 0xdbbc2ac8 0x00000000 0x00000000 0xdbbc2ab0: 0x00000000 0x00000000 0x00000000 0x00000000 0xdbbc2ac0: 0x00000000 0x00000000 0xe5b02618 0x00001000 0xdbbc2ad0: 0x00000000 0x78787878 0x78787878 0x78787878 0xdbbc2ae0: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2af0: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b00: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b10: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b20: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b30: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b40: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b50: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b60: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b70: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2b80: 0x78787878 0x78787878 0x00000000 0x78787878 0xdbbc2b90: 0x78787878 0x78787878 0x78787878 0x78787878 0xdbbc2ba0: 0x78787878 0x78787878 0x78787878 0x78787878 In the reclaim path, try_to_free_pages() does not setup sc.target_mem_cgroup and sc is passed to do_try_to_free_pages(), ..., shrink_node(). In mem_cgroup_iter(), root is set to root_mem_cgroup because sc->target_mem_cgroup is NULL. It is possible to assign a memcg to root_mem_cgroup.nodeinfo.iter in mem_cgroup_iter(). try_to_free_pages struct scan_control sc = {...}, target_mem_cgroup is 0x0; do_try_to_free_pages shrink_zones shrink_node mem_cgroup *root = sc->target_mem_cgroup; memcg = mem_cgroup_iter(root, NULL, &reclaim); mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... css = css_next_descendant_pre(css, &root->css); memcg = mem_cgroup_from_css(css); cmpxchg(&iter->position, pos, memcg); My device uses memcg non-hierarchical mode. When we release a memcg: invalidate_reclaim_iterators() reaches only dead_memcg and its parents. If non-hierarchical mode is used, invalidate_reclaim_iterators() never reaches root_mem_cgroup. static void invalidate_reclaim_iterators(struct mem_cgroup *dead_memcg) { struct mem_cgroup *memcg = dead_memcg; for (; memcg; memcg = parent_mem_cgroup(memcg) ... } So the use after free scenario looks like: CPU1 CPU2 try_to_free_pages do_try_to_free_pages shrink_zones shrink_node mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... css = css_next_descendant_pre(css, &root->css); memcg = mem_cgroup_from_css(css); cmpxchg(&iter->position, pos, memcg); invalidate_reclaim_iterators(memcg); ... __mem_cgroup_free() kfree(memcg); try_to_free_pages do_try_to_free_pages shrink_zones shrink_node mem_cgroup_iter() if (!root) root = root_mem_cgroup; ... mz = mem_cgroup_nodeinfo(root, reclaim->pgdat->node_id); iter = &mz->iter[reclaim->priority]; pos = READ_ONCE(iter->position); css_tryget(&pos->css) <- use after free To avoid this, we should also invalidate root_mem_cgroup.nodeinfo.iter in invalidate_reclaim_iterators(). [cai@lca.pw: fix -Wparentheses compilation warning] Link: http://lkml.kernel.org/r/1564580753-17531-1-git-send-email-cai@lca.pw Link: http://lkml.kernel.org/r/20190730015729.4406-1-miles.chen@mediatek.com Fixes: 5ac8fb31ad2e ("mm: memcontrol: convert reclaim iterator to simple css refcounting") Signed-off-by: Miles Chen <miles.chen@mediatek.com> Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-25mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()Joerg Roedel
commit 3f8fd02b1bf1d7ba964485a56f2f4b53ae88c167 upstream. On x86-32 with PTI enabled, parts of the kernel page-tables are not shared between processes. This can cause mappings in the vmalloc/ioremap area to persist in some page-tables after the region is unmapped and released. When the region is re-used the processes with the old mappings do not fault in the new mappings but still access the old ones. This causes undefined behavior, in reality often data corruption, kernel oopses and panics and even spontaneous reboots. Fix this problem by activly syncing unmaps in the vmalloc/ioremap area to all page-tables in the system before the regions can be re-used. References: https://bugzilla.suse.com/show_bug.cgi?id=1118689 Fixes: 5d72b4fba40ef ('x86, mm: support huge I/O mapping capability I/F') Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com> Link: https://lkml.kernel.org/r/20190719184652.11391-4-joro@8bytes.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-06mm/cma.c: fail if fixed declaration can't be honoredDoug Berger
[ Upstream commit c633324e311243586675e732249339685e5d6faa ] The description of cma_declare_contiguous() indicates that if the 'fixed' argument is true the reserved contiguous area must be exactly at the address of the 'base' argument. However, the function currently allows the 'base', 'size', and 'limit' arguments to be silently adjusted to meet alignment constraints. This commit enforces the documented behavior through explicit checks that return an error if the region does not fit within a specified region. Link: http://lkml.kernel.org/r/1561422051-16142-1-git-send-email-opendmb@gmail.com Fixes: 5ea3b1b2f8ad ("cma: add placement specifier for "cma=" kernel parameter") Signed-off-by: Doug Berger <opendmb@gmail.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Yue Hu <huyue2@yulong.com> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-08-04mm, vmstat: make quiet_vmstat lighterMichal Hocko
commit f01f17d3705bb6081c9e5728078f64067982be36 upstream. Mike has reported a considerable overhead of refresh_cpu_vm_stats from the idle entry during pipe test: 12.89% [kernel] [k] refresh_cpu_vm_stats.isra.12 4.75% [kernel] [k] __schedule 4.70% [kernel] [k] mutex_unlock 3.14% [kernel] [k] __switch_to This is caused by commit 0eb77e988032 ("vmstat: make vmstat_updater deferrable again and shut down on idle") which has placed quiet_vmstat into cpu_idle_loop. The main reason here seems to be that the idle entry has to get over all zones and perform atomic operations for each vmstat entry even though there might be no per cpu diffs. This is a pointless overhead for _each_ idle entry. Make sure that quiet_vmstat is as light as possible. First of all it doesn't make any sense to do any local sync if the current cpu is already set in oncpu_stat_off because vmstat_update puts itself there only if there is nothing to do. Then we can check need_update which should be a cheap way to check for potential per-cpu diffs and only then do refresh_cpu_vm_stats. The original patch also did cancel_delayed_work which we are not doing here. There are two reasons for that. Firstly cancel_delayed_work from idle context will blow up on RT kernels (reported by Mike): CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.5.0-rt3 #7 Hardware name: MEDION MS-7848/MS-7848, BIOS M7848W08.20C 09/23/2013 Call Trace: dump_stack+0x49/0x67 ___might_sleep+0xf5/0x180 rt_spin_lock+0x20/0x50 try_to_grab_pending+0x69/0x240 cancel_delayed_work+0x26/0xe0 quiet_vmstat+0x75/0xa0 cpu_idle_loop+0x38/0x3e0 cpu_startup_entry+0x13/0x20 start_secondary+0x114/0x140 And secondly, even on !RT kernels it might add some non trivial overhead which is not necessary. Even if the vmstat worker wakes up and preempts idle then it will be most likely a single shot noop because the stats were already synced and so it would end up on the oncpu_stat_off anyway. We just need to teach both vmstat_shepherd and vmstat_update to stop scheduling the worker if there is nothing to do. [mgalbraith@suse.de: cancel pending work of the cpu_stat_off CPU] Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Mike Galbraith <mgalbraith@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Daniel Wagner <wagi@monom.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-04vmstat: Remove BUG_ON from vmstat_updateChristoph Lameter
commit 587198ba5206cdf0d30855f7361af950a4172cd6 upstream. If we detect that there is nothing to do just set the flag and do not check if it was already set before. Races really do not matter. If the flag is set by any code then the shepherd will start dealing with the situation and reenable the vmstat workers when necessary again. Since commit 0eb77e988032 ("vmstat: make vmstat_updater deferrable again and shut down on idle") quiet_vmstat might update cpu_stat_off and mark a particular cpu to be handled by vmstat_shepherd. This might trigger a VM_BUG_ON in vmstat_update because the work item might have been sleeping during the idle period and see the cpu_stat_off updated after the wake up. The VM_BUG_ON is therefore misleading and no more appropriate. Moreover it doesn't really suite any protection from real bugs because vmstat_shepherd will simply reschedule the vmstat_work anytime it sees a particular cpu set or vmstat_update would do the same from the worker context directly. Even when the two would race the result wouldn't be incorrect as the counters update is fully idempotent. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Christoph Lameter <cl@linux.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Daniel Wagner <wagi@monom.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-08-04mm/mmu_notifier: use hlist_add_head_rcu()Jean-Philippe Brucker
[ Upstream commit 543bdb2d825fe2400d6e951f1786d92139a16931 ] Make mmu_notifier_register() safer by issuing a memory barrier before registering a new notifier. This fixes a theoretical bug on weakly ordered CPUs. For example, take this simplified use of notifiers by a driver: my_struct->mn.ops = &my_ops; /* (1) */ mmu_notifier_register(&my_struct->mn, mm) ... hlist_add_head(&mn->hlist, &mm->mmu_notifiers); /* (2) */ ... Once mmu_notifier_register() releases the mm locks, another thread can invalidate a range: mmu_notifier_invalidate_range() ... hlist_for_each_entry_rcu(mn, &mm->mmu_notifiers, hlist) { if (mn->ops->invalidate_range) The read side relies on the data dependency between mn and ops to ensure that the pointer is properly initialized. But the write side doesn't have any dependency between (1) and (2), so they could be reordered and the readers could dereference an invalid mn->ops. mmu_notifier_register() does take all the mm locks before adding to the hlist, but those have acquire semantics which isn't sufficient. By calling hlist_add_head_rcu() instead of hlist_add_head() we update the hlist using a store-release, ensuring that readers see prior initialization of my_struct. This situation is better illustated by litmus test MP+onceassign+derefonce. Link: http://lkml.kernel.org/r/20190502133532.24981-1-jean-philippe.brucker@arm.com Fixes: cddb8a5c14aa ("mmu-notifiers: core") Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com> Cc: Jérôme Glisse <jglisse@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-08-04mm/kmemleak.c: fix check for softirq contextDmitry Vyukov
[ Upstream commit 6ef9056952532c3b746de46aa10d45b4d7797bd8 ] in_softirq() is a wrong predicate to check if we are in a softirq context. It also returns true if we have BH disabled, so objects are falsely stamped with "softirq" comm. The correct predicate is in_serving_softirq(). If user does cat from /sys/kernel/debug/kmemleak previously they would see this, which is clearly wrong, this is system call context (see the comm): unreferenced object 0xffff88805bd661c0 (size 64): comm "softirq", pid 0, jiffies 4294942959 (age 12.400s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 ff ff ff ff 00 00 00 00 ................ 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ backtrace: [<0000000007dcb30c>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline] [<0000000007dcb30c>] slab_post_alloc_hook mm/slab.h:439 [inline] [<0000000007dcb30c>] slab_alloc mm/slab.c:3326 [inline] [<0000000007dcb30c>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 [<00000000969722b7>] kmalloc include/linux/slab.h:547 [inline] [<00000000969722b7>] kzalloc include/linux/slab.h:742 [inline] [<00000000969722b7>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline] [<00000000969722b7>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085 [<00000000a4134b5f>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475 [<00000000d20248ad>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957 [<000000003d367be7>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246 [<000000003c7c76af>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616 [<000000000c1aeb23>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130 [<000000000157b92b>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078 [<00000000a9f3d058>] __do_sys_setsockopt net/socket.c:2089 [inline] [<00000000a9f3d058>] __se_sys_setsockopt net/socket.c:2086 [inline] [<00000000a9f3d058>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086 [<000000001b8da885>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301 [<00000000ba770c62>] entry_SYSCALL_64_after_hwframe+0x44/0xa9 now they will see this: unreferenced object 0xffff88805413c800 (size 64): comm "syz-executor.4", pid 8960, jiffies 4294994003 (age 14.350s) hex dump (first 32 bytes): 00 7a 8a 57 80 88 ff ff e0 00 00 01 00 00 00 00 .z.W............ 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ backtrace: [<00000000c5d3be64>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline] [<00000000c5d3be64>] slab_post_alloc_hook mm/slab.h:439 [inline] [<00000000c5d3be64>] slab_alloc mm/slab.c:3326 [inline] [<00000000c5d3be64>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 [<0000000023865be2>] kmalloc include/linux/slab.h:547 [inline] [<0000000023865be2>] kzalloc include/linux/slab.h:742 [inline] [<0000000023865be2>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline] [<0000000023865be2>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085 [<000000003029a9d4>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475 [<00000000ccd0a87c>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957 [<00000000a85a3785>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246 [<00000000ec13c18d>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616 [<0000000052d748e3>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130 [<00000000512f1014>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078 [<00000000181758bc>] __do_sys_setsockopt net/socket.c:2089 [inline] [<00000000181758bc>] __se_sys_setsockopt net/socket.c:2086 [inline] [<00000000181758bc>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086 [<00000000d4b73623>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301 [<00000000c1098bec>] entry_SYSCALL_64_after_hwframe+0x44/0xa9 Link: http://lkml.kernel.org/r/20190517171507.96046-1-dvyukov@gmail.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-10mm/page_idle.c: fix oops because end_pfn is larger than max_pfnColin Ian King
commit 7298e3b0a149c91323b3205d325e942c3b3b9ef6 upstream. Currently the calcuation of end_pfn can round up the pfn number to more than the actual maximum number of pfns, causing an Oops. Fix this by ensuring end_pfn is never more than max_pfn. This can be easily triggered when on systems where the end_pfn gets rounded up to more than max_pfn using the idle-page stress-ng stress test: sudo stress-ng --idle-page 0 BUG: unable to handle kernel paging request at 00000000000020d8 #PF error: [normal kernel read fault] PGD 0 P4D 0 Oops: 0000 [#1] SMP PTI CPU: 1 PID: 11039 Comm: stress-ng-idle- Not tainted 5.0.0-5-generic #6-Ubuntu Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 RIP: 0010:page_idle_get_page+0xc8/0x1a0 Code: 0f b1 0a 75 7d 48 8b 03 48 89 c2 48 c1 e8 33 83 e0 07 48 c1 ea 36 48 8d 0c 40 4c 8d 24 88 49 c1 e4 07 4c 03 24 d5 00 89 c3 be <49> 8b 44 24 58 48 8d b8 80 a1 02 00 e8 07 d5 77 00 48 8b 53 08 48 RSP: 0018:ffffafd7c672fde8 EFLAGS: 00010202 RAX: 0000000000000005 RBX: ffffe36341fff700 RCX: 000000000000000f RDX: 0000000000000284 RSI: 0000000000000275 RDI: 0000000001fff700 RBP: ffffafd7c672fe00 R08: ffffa0bc34056410 R09: 0000000000000276 R10: ffffa0bc754e9b40 R11: ffffa0bc330f6400 R12: 0000000000002080 R13: ffffe36341fff700 R14: 0000000000080000 R15: ffffa0bc330f6400 FS: 00007f0ec1ea5740(0000) GS:ffffa0bc7db00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000020d8 CR3: 0000000077d68000 CR4: 00000000000006e0 Call Trace: page_idle_bitmap_write+0x8c/0x140 sysfs_kf_bin_write+0x5c/0x70 kernfs_fop_write+0x12e/0x1b0 __vfs_write+0x1b/0x40 vfs_write+0xab/0x1b0 ksys_write+0x55/0xc0 __x64_sys_write+0x1a/0x20 do_syscall_64+0x5a/0x110 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Link: http://lkml.kernel.org/r/20190618124352.28307-1-colin.king@canonical.com Fixes: 33c3fc71c8cf ("mm: introduce idle page tracking") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22coredump: fix race condition between mmget_not_zero()/get_task_mm() and core ↵Andrea Arcangeli
dumping commit 04f5866e41fb70690e28397487d8bd8eea7d712a upstream. The core dumping code has always run without holding the mmap_sem for writing, despite that is the only way to ensure that the entire vma layout will not change from under it. Only using some signal serialization on the processes belonging to the mm is not nearly enough. This was pointed out earlier. For example in Hugh's post from Jul 2017: https://lkml.kernel.org/r/alpine.LSU.2.11.1707191716030.2055@eggly.anvils "Not strictly relevant here, but a related note: I was very surprised to discover, only quite recently, how handle_mm_fault() may be called without down_read(mmap_sem) - when core dumping. That seems a misguided optimization to me, which would also be nice to correct" In particular because the growsdown and growsup can move the vm_start/vm_end the various loops the core dump does around the vma will not be consistent if page faults can happen concurrently. Pretty much all users calling mmget_not_zero()/get_task_mm() and then taking the mmap_sem had the potential to introduce unexpected side effects in the core dumping code. Adding mmap_sem for writing around the ->core_dump invocation is a viable long term fix, but it requires removing all copy user and page faults and to replace them with get_dump_page() for all binary formats which is not suitable as a short term fix. For the time being this solution manually covers the places that can confuse the core dump either by altering the vma layout or the vma flags while it runs. Once ->core_dump runs under mmap_sem for writing the function mmget_still_valid() can be dropped. Allowing mmap_sem protected sections to run in parallel with the coredump provides some minor parallelism advantage to the swapoff code (which seems to be safe enough by never mangling any vma field and can keep doing swapins in parallel to the core dumping) and to some other corner case. In order to facilitate the backporting I added "Fixes: 86039bd3b4e6" however the side effect of this same race condition in /proc/pid/mem should be reproducible since before 2.6.12-rc2 so I couldn't add any other "Fixes:" because there's no hash beyond the git genesis commit. Because find_extend_vma() is the only location outside of the process context that could modify the "mm" structures under mmap_sem for reading, by adding the mmget_still_valid() check to it, all other cases that take the mmap_sem for reading don't need the new check after mmget_not_zero()/get_task_mm(). The expand_stack() in page fault context also doesn't need the new check, because all tasks under core dumping are frozen. Link: http://lkml.kernel.org/r/20190325224949.11068-1-aarcange@redhat.com Fixes: 86039bd3b4e6 ("userfaultfd: add new syscall to provide memory externalization") Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Jann Horn <jannh@google.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Xu <peterx@redhat.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Jann Horn <jannh@google.com> Acked-by: Jason Gunthorpe <jgg@mellanox.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Joel Fernandes (Google) <joel@joelfernandes.org> [mhocko@suse.com: stable 4.4 backport - drop infiniband part because of missing 5f9794dc94f59 - drop userfaultfd_event_wait_completion hunk because of missing 9cd75c3cd4c3d] - handle binder_update_page_range because of missing 720c241924046 - handle mlx5_ib_disassociate_ucontext - akaher@vmware.com ] Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22mm/list_lru.c: fix memory leak in __memcg_init_list_lru_nodeShakeel Butt
commit 3510955b327176fd4cbab5baa75b449f077722a2 upstream. Syzbot reported following memory leak: ffffffffda RBX: 0000000000000003 RCX: 0000000000441f79 BUG: memory leak unreferenced object 0xffff888114f26040 (size 32): comm "syz-executor626", pid 7056, jiffies 4294948701 (age 39.410s) hex dump (first 32 bytes): 40 60 f2 14 81 88 ff ff 40 60 f2 14 81 88 ff ff @`......@`...... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: slab_post_alloc_hook mm/slab.h:439 [inline] slab_alloc mm/slab.c:3326 [inline] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553 kmalloc include/linux/slab.h:547 [inline] __memcg_init_list_lru_node+0x58/0xf0 mm/list_lru.c:352 memcg_init_list_lru_node mm/list_lru.c:375 [inline] memcg_init_list_lru mm/list_lru.c:459 [inline] __list_lru_init+0x193/0x2a0 mm/list_lru.c:626 alloc_super+0x2e0/0x310 fs/super.c:269 sget_userns+0x94/0x2a0 fs/super.c:609 sget+0x8d/0xb0 fs/super.c:660 mount_nodev+0x31/0xb0 fs/super.c:1387 fuse_mount+0x2d/0x40 fs/fuse/inode.c:1236 legacy_get_tree+0x27/0x80 fs/fs_context.c:661 vfs_get_tree+0x2e/0x120 fs/super.c:1476 do_new_mount fs/namespace.c:2790 [inline] do_mount+0x932/0xc50 fs/namespace.c:3110 ksys_mount+0xab/0x120 fs/namespace.c:3319 __do_sys_mount fs/namespace.c:3333 [inline] __se_sys_mount fs/namespace.c:3330 [inline] __x64_sys_mount+0x26/0x30 fs/namespace.c:3330 do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301 entry_SYSCALL_64_after_hwframe+0x44/0xa9 This is a simple off by one bug on the error path. Link: http://lkml.kernel.org/r/20190528043202.99980-1-shakeelb@google.com Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists") Reported-by: syzbot+f90a420dfe2b1b03cb2c@syzkaller.appspotmail.com Signed-off-by: Shakeel Butt <shakeelb@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com> Cc: <stable@vger.kernel.org> [4.0+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22mm/cma_debug.c: fix the break condition in cma_maxchunk_get()Yue Hu
[ Upstream commit f0fd50504a54f5548eb666dc16ddf8394e44e4b7 ] If not find zero bit in find_next_zero_bit(), it will return the size parameter passed in, so the start bit should be compared with bitmap_maxno rather than cma->count. Although getting maxchunk is working fine due to zero value of order_per_bit currently, the operation will be stuck if order_per_bit is set as non-zero. Link: http://lkml.kernel.org/r/20190319092734.276-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Joe Perches <joe@perches.com> Cc: David Rientjes <rientjes@google.com> Cc: Dmitry Safonov <d.safonov@partner.samsung.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-22mm/cma.c: fix crash on CMA allocation if bitmap allocation failsYue Hu
[ Upstream commit 1df3a339074e31db95c4790ea9236874b13ccd87 ] f022d8cb7ec7 ("mm: cma: Don't crash on allocation if CMA area can't be activated") fixes the crash issue when activation fails via setting cma->count as 0, same logic exists if bitmap allocation fails. Link: http://lkml.kernel.org/r/20190325081309.6004-1-zbestahu@gmail.com Signed-off-by: Yue Hu <huyue2@yulong.com> Reviewed-by: Anshuman Khandual <anshuman.khandual@arm.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-22hugetlbfs: on restore reserve error path retain subpool reservationMike Kravetz
[ Upstream commit 0919e1b69ab459e06df45d3ba6658d281962db80 ] When a huge page is allocated, PagePrivate() is set if the allocation consumed a reservation. When freeing a huge page, PagePrivate is checked. If set, it indicates the reservation should be restored. PagePrivate being set at free huge page time mostly happens on error paths. When huge page reservations are created, a check is made to determine if the mapping is associated with an explicitly mounted filesystem. If so, pages are also reserved within the filesystem. The default action when freeing a huge page is to decrement the usage count in any associated explicitly mounted filesystem. However, if the reservation is to be restored the reservation/use count within the filesystem should not be decrementd. Otherwise, a subsequent page allocation and free for the same mapping location will cause the file filesystem usage to go 'negative'. Filesystem Size Used Avail Use% Mounted on nodev 4.0G -4.0M 4.1G - /opt/hugepool To fix, when freeing a huge page do not adjust filesystem usage if PagePrivate() is set to indicate the reservation should be restored. I did not cc stable as the problem has been around since reserves were added to hugetlbfs and nobody has noticed. Link: http://lkml.kernel.org/r/20190328234704.27083-2-mike.kravetz@oracle.com Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-11memcg: make it work on sparse non-0-node systemsJiri Slaby
commit 3e8589963773a5c23e2f1fe4bcad0e9a90b7f471 upstream. We have a single node system with node 0 disabled: Scanning NUMA topology in Northbridge 24 Number of physical nodes 2 Skipping disabled node 0 Node 1 MemBase 0000000000000000 Limit 00000000fbff0000 NODE_DATA(1) allocated [mem 0xfbfda000-0xfbfeffff] This causes crashes in memcg when system boots: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 #PF error: [normal kernel read fault] ... RIP: 0010:list_lru_add+0x94/0x170 ... Call Trace: d_lru_add+0x44/0x50 dput.part.34+0xfc/0x110 __fput+0x108/0x230 task_work_run+0x9f/0xc0 exit_to_usermode_loop+0xf5/0x100 It is reproducible as far as 4.12. I did not try older kernels. You have to have a new enough systemd, e.g. 241 (the reason is unknown -- was not investigated). Cannot be reproduced with systemd 234. The system crashes because the size of lru array is never updated in memcg_update_all_list_lrus and the reads are past the zero-sized array, causing dereferences of random memory. The root cause are list_lru_memcg_aware checks in the list_lru code. The test in list_lru_memcg_aware is broken: it assumes node 0 is always present, but it is not true on some systems as can be seen above. So fix this by avoiding checks on node 0. Remember the memcg-awareness by a bool flag in struct list_lru. Link: http://lkml.kernel.org/r/20190522091940.3615-1-jslaby@suse.cz Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists") Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Suggested-by: Vladimir Davydov <vdavydov.dev@gmail.com> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Reviewed-by: Shakeel Butt <shakeelb@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-11hugetlb: use same fault hash key for shared and private mappingsMike Kravetz
commit 1b426bac66e6cc83c9f2d92b96e4e72acf43419a upstream. hugetlb uses a fault mutex hash table to prevent page faults of the same pages concurrently. The key for shared and private mappings is different. Shared keys off address_space and file index. Private keys off mm and virtual address. Consider a private mappings of a populated hugetlbfs file. A fault will map the page from the file and if needed do a COW to map a writable page. Hugetlbfs hole punch uses the fault mutex to prevent mappings of file pages. It uses the address_space file index key. However, private mappings will use a different key and could race with this code to map the file page. This causes problems (BUG) for the page cache remove code as it expects the page to be unmapped. A sample stack is: page dumped because: VM_BUG_ON_PAGE(page_mapped(page)) kernel BUG at mm/filemap.c:169! ... RIP: 0010:unaccount_page_cache_page+0x1b8/0x200 ... Call Trace: __delete_from_page_cache+0x39/0x220 delete_from_page_cache+0x45/0x70 remove_inode_hugepages+0x13c/0x380 ? __add_to_page_cache_locked+0x162/0x380 hugetlbfs_fallocate+0x403/0x540 ? _cond_resched+0x15/0x30 ? __inode_security_revalidate+0x5d/0x70 ? selinux_file_permission+0x100/0x130 vfs_fallocate+0x13f/0x270 ksys_fallocate+0x3c/0x80 __x64_sys_fallocate+0x1a/0x20 do_syscall_64+0x5b/0x180 entry_SYSCALL_64_after_hwframe+0x44/0xa9 There seems to be another potential COW issue/race with this approach of different private and shared keys as noted in commit 8382d914ebf7 ("mm, hugetlb: improve page-fault scalability"). Since every hugetlb mapping (even anon and private) is actually a file mapping, just use the address_space index key for all mappings. This results in potentially more hash collisions. However, this should not be the common case. Link: http://lkml.kernel.org/r/20190328234704.27083-3-mike.kravetz@oracle.com Link: http://lkml.kernel.org/r/20190412165235.t4sscoujczfhuiyt@linux-r8p5 Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages") Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Davidlohr Bueso <dbueso@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-11writeback: synchronize sync(2) against cgroup writeback membership switchesTejun Heo
commit 7fc5854f8c6efae9e7624970ab49a1eac2faefb1 upstream. sync_inodes_sb() can race against cgwb (cgroup writeback) membership switches and fail to writeback some inodes. For example, if an inode switches to another wb while sync_inodes_sb() is in progress, the new wb might not be visible to bdi_split_work_to_wbs() at all or the inode might jump from a wb which hasn't issued writebacks yet to one which already has. This patch adds backing_dev_info->wb_switch_rwsem to synchronize cgwb switch path against sync_inodes_sb() so that sync_inodes_sb() is guaranteed to see all the target wbs and inodes can't jump wbs to escape syncing. v2: Fixed misplaced rwsem init. Spotted by Jiufei. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jiufei Xue <xuejiufei@gmail.com> Link: http://lkml.kernel.org/r/dc694ae2-f07f-61e1-7097-7c8411cee12d@gmail.com Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-11mm/mincore.c: make mincore() more conservativeJiri Kosina
commit 134fca9063ad4851de767d1768180e5dede9a881 upstream. The semantics of what mincore() considers to be resident is not completely clear, but Linux has always (since 2.3.52, which is when mincore() was initially done) treated it as "page is available in page cache". That's potentially a problem, as that [in]directly exposes meta-information about pagecache / memory mapping state even about memory not strictly belonging to the process executing the syscall, opening possibilities for sidechannel attacks. Change the semantics of mincore() so that it only reveals pagecache information for non-anonymous mappings that belog to files that the calling process could (if it tried to) successfully open for writing; otherwise we'd be including shared non-exclusive mappings, which - is the sidechannel - is not the usecase for mincore(), as that's primarily used for data, not (shared) text [jkosina@suse.cz: v2] Link: http://lkml.kernel.org/r/20190312141708.6652-2-vbabka@suse.cz [mhocko@suse.com: restructure can_do_mincore() conditions] Link: http://lkml.kernel.org/r/nycvar.YFH.7.76.1903062342020.19912@cbobk.fhfr.pm Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Josh Snyder <joshs@netflix.com> Acked-by: Michal Hocko <mhocko@suse.com> Originally-by: Linus Torvalds <torvalds@linux-foundation.org> Originally-by: Dominique Martinet <asmadeus@codewreck.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Chinner <david@fromorbit.com> Cc: Kevin Easton <kevin@guarana.org> Cc: Matthew Wilcox <willy@infradead.org> Cc: Cyril Hrubis <chrubis@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Daniel Gruss <daniel@gruss.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-27mm/vmstat.c: fix /proc/vmstat format for CONFIG_DEBUG_TLBFLUSH=y CONFIG_SMP=nKonstantin Khlebnikov
commit e8277b3b52240ec1caad8e6df278863e4bf42eac upstream. Commit 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly") depends on skipping vmstat entries with empty name introduced in 7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in /proc/vmstat") but reverted in b29940c1abd7 ("mm: rename and change semantics of nr_indirectly_reclaimable_bytes"). So skipping no longer works and /proc/vmstat has misformatted lines " 0". This patch simply shows debug counters "nr_tlb_remote_*" for UP. Link: http://lkml.kernel.org/r/155481488468.467.4295519102880913454.stgit@buzz Fixes: 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly") Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Roman Gushchin <guro@fb.com> Cc: Jann Horn <jannh@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-27mm/slab.c: kmemleak no scan alien cachesQian Cai
[ Upstream commit 92d1d07daad65c300c7d0b68bbef8867e9895d54 ] Kmemleak throws endless warnings during boot due to in __alloc_alien_cache(), alc = kmalloc_node(memsize, gfp, node); init_arraycache(&alc->ac, entries, batch); kmemleak_no_scan(ac); Kmemleak does not track the array cache (alc->ac) but the alien cache (alc) instead, so let it track the latter by lifting kmemleak_no_scan() out of init_arraycache(). There is another place that calls init_arraycache(), but alloc_kmem_cache_cpus() uses the percpu allocation where will never be considered as a leak. kmemleak: Found object by alias at 0xffff8007b9aa7e38 CPU: 190 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc2+ #2 Call trace: dump_backtrace+0x0/0x168 show_stack+0x24/0x30 dump_stack+0x88/0xb0 lookup_object+0x84/0xac find_and_get_object+0x84/0xe4 kmemleak_no_scan+0x74/0xf4 setup_kmem_cache_node+0x2b4/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 ret_from_fork+0x10/0x18 kmemleak: Object 0xffff8007b9aa7e00 (size 256): kmemleak: comm "swapper/0", pid 1, jiffies 4294697137 kmemleak: min_count = 1 kmemleak: count = 0 kmemleak: flags = 0x1 kmemleak: checksum = 0 kmemleak: backtrace: kmemleak_alloc+0x84/0xb8 kmem_cache_alloc_node_trace+0x31c/0x3a0 __kmalloc_node+0x58/0x78 setup_kmem_cache_node+0x26c/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 kmemleak: Not scanning unknown object at 0xffff8007b9aa7e38 CPU: 190 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc2+ #2 Call trace: dump_backtrace+0x0/0x168 show_stack+0x24/0x30 dump_stack+0x88/0xb0 kmemleak_no_scan+0x90/0xf4 setup_kmem_cache_node+0x2b4/0x35c __do_tune_cpucache+0x250/0x2d4 do_tune_cpucache+0x4c/0xe4 enable_cpucache+0xc8/0x110 setup_cpu_cache+0x40/0x1b8 __kmem_cache_create+0x240/0x358 create_cache+0xc0/0x198 kmem_cache_create_usercopy+0x158/0x20c kmem_cache_create+0x50/0x64 fsnotify_init+0x58/0x6c do_one_initcall+0x194/0x388 kernel_init_freeable+0x668/0x688 kernel_init+0x18/0x124 ret_from_fork+0x10/0x18 Link: http://lkml.kernel.org/r/20190129184518.39808-1-cai@lca.pw Fixes: 1fe00d50a9e8 ("slab: factor out initialization of array cache") Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-27mm/vmalloc.c: fix kernel BUG at mm/vmalloc.c:512!Uladzislau Rezki (Sony)
[ Upstream commit afd07389d3f4933c7f7817a92fb5e053d59a3182 ] One of the vmalloc stress test case triggers the kernel BUG(): <snip> [60.562151] ------------[ cut here ]------------ [60.562154] kernel BUG at mm/vmalloc.c:512! [60.562206] invalid opcode: 0000 [#1] PREEMPT SMP PTI [60.562247] CPU: 0 PID: 430 Comm: vmalloc_test/0 Not tainted 4.20.0+ #161 [60.562293] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014 [60.562351] RIP: 0010:alloc_vmap_area+0x36f/0x390 <snip> it can happen due to big align request resulting in overflowing of calculated address, i.e. it becomes 0 after ALIGN()'s fixup. Fix it by checking if calculated address is within vstart/vend range. Link: http://lkml.kernel.org/r/20190124115648.9433-2-urezki@gmail.com Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Fernandes <joelaf@google.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Garnier <thgarnie@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-27mm/page_ext.c: fix an imbalance with kmemleakQian Cai
[ Upstream commit 0c81585499601acd1d0e1cbf424cabfaee60628c ] After offlining a memory block, kmemleak scan will trigger a crash, as it encounters a page ext address that has already been freed during memory offlining. At the beginning in alloc_page_ext(), it calls kmemleak_alloc(), but it does not call kmemleak_free() in free_page_ext(). BUG: unable to handle kernel paging request at ffff888453d00000 PGD 128a01067 P4D 128a01067 PUD 128a04067 PMD 47e09e067 PTE 800ffffbac2ff060 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN PTI CPU: 1 PID: 1594 Comm: bash Not tainted 5.0.0-rc8+ #15 Hardware name: HP ProLiant DL180 Gen9/ProLiant DL180 Gen9, BIOS U20 10/25/2017 RIP: 0010:scan_block+0xb5/0x290 Code: 85 6e 01 00 00 48 b8 00 00 30 f5 81 88 ff ff 48 39 c3 0f 84 5b 01 00 00 48 89 d8 48 c1 e8 03 42 80 3c 20 00 0f 85 87 01 00 00 <4c> 8b 3b e8 f3 0c fa ff 4c 39 3d 0c 6b 4c 01 0f 87 08 01 00 00 4c RSP: 0018:ffff8881ec57f8e0 EFLAGS: 00010082 RAX: 0000000000000000 RBX: ffff888453d00000 RCX: ffffffffa61e5a54 RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff888453d00000 RBP: ffff8881ec57f920 R08: fffffbfff4ed588d R09: fffffbfff4ed588c R10: fffffbfff4ed588c R11: ffffffffa76ac463 R12: dffffc0000000000 R13: ffff888453d00ff9 R14: ffff8881f80cef48 R15: ffff8881f80cef48 FS: 00007f6c0e3f8740(0000) GS:ffff8881f7680000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffff888453d00000 CR3: 00000001c4244003 CR4: 00000000001606a0 Call Trace: scan_gray_list+0x269/0x430 kmemleak_scan+0x5a8/0x10f0 kmemleak_write+0x541/0x6ca full_proxy_write+0xf8/0x190 __vfs_write+0xeb/0x980 vfs_write+0x15a/0x4f0 ksys_write+0xd2/0x1b0 __x64_sys_write+0x73/0xb0 do_syscall_64+0xeb/0xaaa entry_SYSCALL_64_after_hwframe+0x44/0xa9 RIP: 0033:0x7f6c0dad73b8 Code: 89 02 48 c7 c0 ff ff ff ff eb b3 0f 1f 80 00 00 00 00 f3 0f 1e fa 48 8d 05 65 63 2d 00 8b 00 85 c0 75 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 41 54 49 89 d4 55 RSP: 002b:00007ffd5b863cb8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001 RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00007f6c0dad73b8 RDX: 0000000000000005 RSI: 000055a9216e1710 RDI: 0000000000000001 RBP: 000055a9216e1710 R08: 000000000000000a R09: 00007ffd5b863840 R10: 000000000000000a R11: 0000000000000246 R12: 00007f6c0dda9780 R13: 0000000000000005 R14: 00007f6c0dda4740 R15: 0000000000000005 Modules linked in: nls_iso8859_1 nls_cp437 vfat fat kvm_intel kvm irqbypass efivars ip_tables x_tables xfs sd_mod ahci libahci igb i2c_algo_bit libata i2c_core dm_mirror dm_region_hash dm_log dm_mod efivarfs CR2: ffff888453d00000 ---[ end trace ccf646c7456717c5 ]--- Kernel panic - not syncing: Fatal exception Shutting down cpus with NMI Kernel Offset: 0x24c00000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff) ---[ end Kernel panic - not syncing: Fatal exception ]--- Link: http://lkml.kernel.org/r/20190227173147.75650-1-cai@lca.pw Signed-off-by: Qian Cai <cai@lca.pw> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-27mm/cma.c: cma_declare_contiguous: correct err handlingPeng Fan
[ Upstream commit 0d3bd18a5efd66097ef58622b898d3139790aa9d ] In case cma_init_reserved_mem failed, need to free the memblock allocated by memblock_reserve or memblock_alloc_range. Quote Catalin's comments: https://lkml.org/lkml/2019/2/26/482 Kmemleak is supposed to work with the memblock_{alloc,free} pair and it ignores the memblock_reserve() as a memblock_alloc() implementation detail. It is, however, tolerant to memblock_free() being called on a sub-range or just a different range from a previous memblock_alloc(). So the original patch looks fine to me. FWIW: Link: http://lkml.kernel.org/r/20190227144631.16708-1-peng.fan@nxp.com Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Mike Rapoport <rppt@linux.ibm.com> Cc: Laura Abbott <labbott@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-27mm: mempolicy: make mbind() return -EIO when MPOL_MF_STRICT is specifiedYang Shi
commit a7f40cfe3b7ada57af9b62fd28430eeb4a7cfcb7 upstream. When MPOL_MF_STRICT was specified and an existing page was already on a node that does not follow the policy, mbind() should return -EIO. But commit 6f4576e3687b ("mempolicy: apply page table walker on queue_pages_range()") broke the rule. And commit c8633798497c ("mm: mempolicy: mbind and migrate_pages support thp migration") didn't return the correct value for THP mbind() too. If MPOL_MF_STRICT is set, ignore vma_migratable() to make sure it reaches queue_pages_to_pte_range() or queue_pages_pmd() to check if an existing page was already on a node that does not follow the policy. And, non-migratable vma may be used, return -EIO too if MPOL_MF_MOVE or MPOL_MF_MOVE_ALL was specified. Tested with https://github.com/metan-ucw/ltp/blob/master/testcases/kernel/syscalls/mbind/mbind02.c [akpm@linux-foundation.org: tweak code comment] Link: http://lkml.kernel.org/r/1553020556-38583-1-git-send-email-yang.shi@linux.alibaba.com Fixes: 6f4576e3687b ("mempolicy: apply page table walker on queue_pages_range()") Signed-off-by: Yang Shi <yang.shi@linux.alibaba.com> Signed-off-by: Oscar Salvador <osalvador@suse.de> Reported-by: Cyril Hrubis <chrubis@suse.cz> Suggested-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: Rafael Aquini <aquini@redhat.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03vmstat: make vmstat_updater deferrable again and shut down on idleChristoph Lameter
[ Upstream commit 0eb77e9880321915322d42913c3b53241739c8aa ] Currently the vmstat updater is not deferrable as a result of commit ba4877b9ca51 ("vmstat: do not use deferrable delayed work for vmstat_update"). This in turn can cause multiple interruptions of the applications because the vmstat updater may run at Make vmstate_update deferrable again and provide a function that folds the differentials when the processor is going to idle mode thus addressing the issue of the above commit in a clean way. Note that the shepherd thread will continue scanning the differentials from another processor and will reenable the vmstat workers if it detects any changes. Fixes: ba4877b9ca51 ("vmstat: do not use deferrable delayed work for vmstat_update") Signed-off-by: Christoph Lameter <cl@linux.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-03mm/rmap: replace BUG_ON(anon_vma->degree) with VM_WARN_ONKonstantin Khlebnikov
commit e4c5800a3991f0c6a766983535dfc10d51802cf6 upstream. This check effectively catches anon vma hierarchy inconsistence and some vma corruptions. It was effective for catching corner cases in anon vma reusing logic. For now this code seems stable so check could be hidden under CONFIG_DEBUG_VM and replaced with WARN because it's not so fatal. Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Suggested-by: Vasily Averin <vvs@virtuozzo.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23mm/vmalloc: fix size check for remap_vmalloc_range_partial()Roman Penyaev
commit 401592d2e095947344e10ec0623adbcd58934dd4 upstream. When VM_NO_GUARD is not set area->size includes adjacent guard page, thus for correct size checking get_vm_area_size() should be used, but not area->size. This fixes possible kernel oops when userspace tries to mmap an area on 1 page bigger than was allocated by vmalloc_user() call: the size check inside remap_vmalloc_range_partial() accounts non-existing guard page also, so check successfully passes but vmalloc_to_page() returns NULL (guard page does not physically exist). The following code pattern example should trigger an oops: static int oops_mmap(struct file *file, struct vm_area_struct *vma) { void *mem; mem = vmalloc_user(4096); BUG_ON(!mem); /* Do not care about mem leak */ return remap_vmalloc_range(vma, mem, 0); } And userspace simply mmaps size + PAGE_SIZE: mmap(NULL, 8192, PROT_WRITE|PROT_READ, MAP_PRIVATE, fd, 0); Possible candidates for oops which do not have any explicit size checks: *** drivers/media/usb/stkwebcam/stk-webcam.c: v4l_stk_mmap[789] ret = remap_vmalloc_range(vma, sbuf->buffer, 0); Or the following one: *** drivers/video/fbdev/core/fbmem.c static int fb_mmap(struct file *file, struct vm_area_struct * vma) ... res = fb->fb_mmap(info, vma); Where fb_mmap callback calls remap_vmalloc_range() directly without any explicit checks: *** drivers/video/fbdev/vfb.c static int vfb_mmap(struct fb_info *info, struct vm_area_struct *vma) { return remap_vmalloc_range(vma, (void *)info->fix.smem_start, vma->vm_pgoff); } Link: http://lkml.kernel.org/r/20190103145954.16942-2-rpenyaev@suse.de Signed-off-by: Roman Penyaev <rpenyaev@suse.de> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Joe Perches <joe@perches.com> Cc: "Luis R. Rodriguez" <mcgrof@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
