commit 5f478e4ea5c5560b4e40eb136991a09f9389f331 upstream.
When !CONFIG_CGROUP_WRITEBACK, bdi has single bdi_writeback_congested
at bdi->wb_congested. cgwb_bdi_init() allocates it with kzalloc() and
doesn't do further initialization. This usually works fine as the
reference count gets bumped to 1 by wb_init() and the put from
wb_exit() releases it.
However, when wb_init() fails, it puts the wb base ref automatically
freeing the wb and the explicit kfree() in cgwb_bdi_init() error path
ends up trying to free the same pointer the second time causing a
double-free.
Fix it by explicitly initilizing the refcnt to 1 and putting the base
ref from cgwb_bdi_destroy().
Fixes: a13f35e87140 ("writeback: don't embed root bdi_writeback_congested in bdi_writeback")
Signed-off-by: Jens Axboe <axboe@fb.com>
commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream.
Reading a sysfs "memoryN/valid_zones" file leads to the following oops
when the first page of a range is not backed by struct page.
show_valid_zones() assumes that 'start_pfn' is always valid for
page_zone().
BUG: unable to handle kernel paging request at ffffea017a000000
IP: show_valid_zones+0x6f/0x160
This issue may happen on x86-64 systems with 64GiB or more memory since
their memory block size is bumped up to 2GiB. [1] An example of such
systems is desribed below. 0x3240000000 is only aligned by 1GiB and
this memory block starts from 0x3200000000, which is not backed by
struct page.
BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable
Since test_pages_in_a_zone() already checks holes, fix this issue by
extending this function to return 'valid_start' and 'valid_end' for a
given range. show_valid_zones() then proceeds with the valid range.
[1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on
large-memory x86-64 systems")'
Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: <stable@vger.kernel.org> [4.4+]
commit 5abf186a30a89d5b9c18a6bf93a2c192c9fd52f6 upstream.
do_generic_file_read() can be told to perform a large request from
userspace. If the system is under OOM and the reading task is the OOM
victim then it has an access to memory reserves and finishing the full
request can lead to the full memory depletion which is dangerous. Make
sure we rather go with a short read and allow the killed task to
terminate.
Link: http://lkml.kernel.org/r/20170201092706.9966-3-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
commit deb88a2a19e85842d79ba96b05031739ec327ff4 upstream.
Patch series "fix a kernel oops when reading sysfs valid_zones", v2.
A sysfs memory file is created for each 2GiB memory block on x86-64 when
the system has 64GiB or more memory. [1] When the start address of a
memory block is not backed by struct page, i.e. a memory range is not
aligned by 2GiB, reading its 'valid_zones' attribute file leads to a
kernel oops. This issue was observed on multiple x86-64 systems with
more than 64GiB of memory. This patch-set fixes this issue.
Patch 1 first fixes an issue in test_pages_in_a_zone(), which does not
test the start section.
Patch 2 then fixes the kernel oops by extending test_pages_in_a_zone()
to return valid [start, end).
Note for stable kernels: The memory block size change was made by commit
bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64
systems"), which was accepted to 3.9. However, this patch-set depends
on (and fixes) the change to test_pages_in_a_zone() made by commit
5f0f2887f4de ("mm/memory_hotplug.c: check for missing sections in
test_pages_in_a_zone()"), which was accepted to 4.4.
So, I recommend that we backport it up to 4.4.
This patch (of 2):
test_pages_in_a_zone() does not check 'start_pfn' when it is aligned by
section since 'sec_end_pfn' is set equal to 'pfn'. Since this function
is called for testing the range of a sysfs memory file, 'start_pfn' is
always aligned by section.
Fix it by properly setting 'sec_end_pfn' to the next section pfn.
Also make sure that this function returns 1 only when the range belongs
to a zone.
Link: http://lkml.kernel.org/r/20170127222149.30893-2-toshi.kani@hpe.com
Cc: Andrew Banman <abanman@sgi.com>
Cc: Greg KH <greg@kroah.com>
commit d7b028f56a971a2e4d8d7887540a144eeefcd4ab upstream.
Add zswap_init_failed bool that prevents changing any of the module
params, if init_zswap() fails, and set zswap_enabled to false. Change
'enabled' param to a callback, and check zswap_init_failed before
allowing any change to 'enabled', 'zpool', or 'compressor' params.
Any driver that is built-in to the kernel will not be unloaded if its
init function returns error, and its module params remain accessible for
users to change via sysfs. Since zswap uses param callbacks, which
assume that zswap has been initialized, changing the zswap params after
a failed initialization will result in WARNING due to the param
callbacks expecting a pool to already exist. This prevents that by
immediately exiting any of the param callbacks if initialization failed.
This was reported here:
https://marc.info/?l=linux-mm&m=147004228125528&w=4
And fixes this WARNING:
[ 429.723476] WARNING: CPU: 0 PID: 5140 at mm/zswap.c:503 __zswap_pool_current+0x56/0x60
The warning is just noise, and not serious. However, when init fails,
zswap frees all its percpu dstmem pages and its kmem cache. The kmem
cache might be serious, if kmem_cache_alloc(NULL, gfp) has problems; but
the percpu dstmem pages are definitely a problem, as they're used as
temporary buffer for compressed pages before copying into place in the
zpool.
If the user does get zswap enabled after an init failure, then zswap
will likely Oops on the first page it tries to compress (or worse, start
corrupting memory).
Fixes: 90b0fc26d5db ("zswap: change zpool/compressor at runtime")
Link: http://lkml.kernel.org/r/20170124200259.16191-2-ddstreet@ieee.org
Signed-off-by: Dan Streetman <dan.streetman@canonical.com>
Reported-by: Marcin Miroslaw <marcin@mejor.pl>
Cc: Seth Jennings <sjenning@redhat.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
commit 3674534b775354516e5c148ea48f51d4d1909a78 upstream.
When memory.move_charge_at_immigrate is enabled and precharges are
depleted during move, mem_cgroup_move_charge_pte_range() will attempt to
increase the size of the precharge.
Prevent precharges from ever looping by setting __GFP_NORETRY. This was
probably the intention of the GFP_KERNEL & ~__GFP_NORETRY, which is
pointless as written.
Fixes: 0029e19ebf84 ("mm: memcontrol: remove explicit OOM parameter in charge path")
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1701130208510.69402@chino.kir.corp.google.com
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
commit d51e9894d27492783fc6d1b489070b4ba66ce969 upstream.
Since commit be97a41b291e ("mm/mempolicy.c: merge alloc_hugepage_vma to
alloc_pages_vma") alloc_pages_vma() can potentially free a mempolicy by
mpol_cond_put() before accessing the embedded nodemask by
__alloc_pages_nodemask(). The commit log says it's so "we can use a
single exit path within the function" but that's clearly wrong. We can
still do that when doing mpol_cond_put() after the allocation attempt.
Make sure the mempolicy is not freed prematurely, otherwise
__alloc_pages_nodemask() can end up using a bogus nodemask, which could
lead e.g. to premature OOM.
Fixes: be97a41b291e ("mm/mempolicy.c: merge alloc_hugepage_vma to alloc_pages_vma")
Link: http://lkml.kernel.org/r/20170118141124.8345-1-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit e5bbc8a6c992901058bc09e2ce01d16c111ff047 upstream.
return_unused_surplus_pages() decrements the global reservation count,
and frees any unused surplus pages that were backing the reservation.
Commit 7848a4bf51b3 ("mm/hugetlb.c: add cond_resched_lock() in
return_unused_surplus_pages()") added a call to cond_resched_lock in the
loop freeing the pages.
As a result, the hugetlb_lock could be dropped, and someone else could
use the pages that will be freed in subsequent iterations of the loop.
This could result in inconsistent global hugetlb page state, application
api failures (such as mmap) failures or application crashes.
When dropping the lock in return_unused_surplus_pages, make sure that
the global reservation count (resv_huge_pages) remains sufficiently
large to prevent someone else from claiming pages about to be freed.
Analyzed by Paul Cassella.
Fixes: 7848a4bf51b3 ("mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()")
Link: http://lkml.kernel.org/r/1483991767-6879-1-git-send-email-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reported-by: Paul Cassella <cassella@cray.com>
Suggested-by: Michal Hocko <mhocko@kernel.org>
Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
commit 90cae1fe1c3540f791d5b8e025985fa5e699b2bb upstream.
As a part of memory initialisation the architecture passes an array to
free_area_init_nodes() which specifies the max PFN of each memory zone.
This array is not necessarily monotonic (due to unused zones) so this
array is parsed to build monotonic lists of the min and max PFN for each
zone. ZONE_MOVABLE is special cased here as its limits are managed by
the mm subsystem rather than the architecture. Unfortunately, this
special casing is broken when ZONE_MOVABLE is the not the last zone in
the zone list. The core of the issue is:
if (i == ZONE_MOVABLE)
continue;
arch_zone_lowest_possible_pfn[i] =
arch_zone_highest_possible_pfn[i-1];
As ZONE_MOVABLE is skipped the lowest_possible_pfn of the next zone will
be set to zero. This patch fixes this bug by adding explicitly tracking
where the next zone should start rather than relying on the contents
arch_zone_highest_possible_pfn[].
Thie is low priority. To get bitten by this you need to enable a zone
that appears after ZONE_MOVABLE in the zone_type enum. As far as I can
tell this means running a kernel with ZONE_DEVICE or ZONE_CMA enabled,
so I can't see this affecting too many people.
I only noticed this because I've been fiddling with ZONE_DEVICE on
powerpc and 4.6 broke my test kernel. This bug, in conjunction with the
changes in Taku Izumi's kernelcore=mirror patch (d91749c1dda71) and
powerpc being the odd architecture which initialises max_zone_pfn[] to
~0ul instead of 0 caused all of system memory to be placed into
ZONE_DEVICE at boot, followed a panic since device memory cannot be used
for kernel allocations. I've already submitted a patch to fix the
powerpc specific bits, but I figured this should be fixed too.
Link: http://lkml.kernel.org/r/1462435033-15601-1-git-send-email-oohall@gmail.com
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit 5f33a0803bbd781de916f5c7448cbbbbc763d911 upstream.
Our system uses significantly more slab memory with memcg enabled with
the latest kernel. With 3.10 kernel, slab uses 2G memory, while with
4.6 kernel, 6G memory is used. The shrinker has problem. Let's see we
have two memcg for one shrinker. In do_shrink_slab:
1. Check cg1. nr_deferred = 0, assume total_scan = 700. batch size
is 1024, then no memory is freed. nr_deferred = 700
2. Check cg2. nr_deferred = 700. Assume freeable = 20, then
total_scan = 10 or 40. Let's assume it's 10. No memory is freed.
nr_deferred = 10.
The deferred share of cg1 is lost in this case. kswapd will free no
memory even run above steps again and again.
The fix makes sure one memcg's deferred share isn't lost.
Link: http://lkml.kernel.org/r/2414be961b5d25892060315fbb56bb19d81d0c07.1476227351.git.shli@fb.com
Signed-off-by: Shaohua Li <shli@fb.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream.
During exec dumpable is cleared if the file that is being executed is
not readable by the user executing the file. A bug in
ptrace_may_access allows reading the file if the executable happens to
enter into a subordinate user namespace (aka clone(CLONE_NEWUSER),
unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER).
This problem is fixed with only necessary userspace breakage by adding
a user namespace owner to mm_struct, captured at the time of exec, so
it is clear in which user namespace CAP_SYS_PTRACE must be present in
to be able to safely give read permission to the executable.
The function ptrace_may_access is modified to verify that the ptracer
has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns.
This ensures that if the task changes it's cred into a subordinate
user namespace it does not become ptraceable.
The function ptrace_attach is modified to only set PT_PTRACE_CAP when
CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of
PT_PTRACE_CAP is to be a flag to note that whatever permission changes
the task might go through the tracer has sufficient permissions for
it not to be an issue. task->cred->user_ns is always the same
as or descendent of mm->user_ns. Which guarantees that having
CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks
credentials.
To prevent regressions mm->dumpable and mm->user_ns are not considered
when a task has no mm. As simply failing ptrace_may_attach causes
regressions in privileged applications attempting to read things
such as /proc/<pid>/stat
Tested-by: Cyrill Gorcunov <gorcunov@openvz.org>
Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces")
commit 045d599a286bc01daa3510d59272440a17b23c2e upstream.
kasan_global struct is part of compiler/runtime ABI. gcc revision
241983 has added a new field to kasan_global struct. Update kernel
definition of kasan_global struct to include the new field.
Without this patch KASAN is broken with gcc 7.
Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
commit dd111be69114cc867f8e826284559bfbc1c40e37 upstream.
When root activates a swap partition whose header has the wrong
endianness, nr_badpages elements of badpages are swabbed before
nr_badpages has been checked, leading to a buffer overrun of up to 8GB.
This normally is not a security issue because it can only be exploited
by root (more specifically, a process with CAP_SYS_ADMIN or the ability
to modify a swap file/partition), and such a process can already e.g.
modify swapped-out memory of any other userspace process on the system.
Link: http://lkml.kernel.org/r/1477949533-2509-1-git-send-email-jann@thejh.net
Signed-off-by: Jann Horn <jann@thejh.net>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit badbda53e505089062e194c614e6f23450bc98b2 upstream.
pageblock_order can be (at least) an unsigned int or an unsigned long
depending on the kernel config and architecture, so use max_t(unsigned
long, ...) when comparing it.
fixes these warnings:
In file included from include/asm-generic/bug.h:13:0,
from arch/powerpc/include/asm/bug.h:127,
from include/linux/bug.h:4,
from include/linux/mmdebug.h:4,
from include/linux/mm.h:8,
from include/linux/memblock.h:18,
from mm/cma.c:28:
mm/cma.c: In function 'cma_init_reserved_mem':
include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast
(void) (&_max1 == &_max2); ^
mm/cma.c:186:27: note: in expansion of macro 'max'
alignment = PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order);
mm/cma.c: In function 'cma_declare_contiguous':
include/linux/kernel.h:747:9: note: in definition of macro 'max'
typeof(y) _max2 = (y); ^
mm/cma.c:270:29: note: in expansion of macro 'max'
(phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order));
include/linux/kernel.h:747:21: note: in definition of macro 'max'
Link: http://lkml.kernel.org/r/20160526150748.5be38a4f@canb.auug.org.au
commit 89a2848381b5fcd9c4d9c0cd97680e3b28730e31 upstream.
On 4.0, we saw a stack corruption from a page fault entering direct
memory cgroup reclaim, calling into btrfs_releasepage(), which then
tried to allocate an extent and recursed back into a kmem charge ad
nauseam:
btrfs_releasepage+0x2c/0x30
try_to_release_page+0x32/0x50
shrink_page_list+0x6da/0x7a0
shrink_inactive_list+0x1e5/0x510
shrink_lruvec+0x605/0x7f0
shrink_zone+0xee/0x320
do_try_to_free_pages+0x174/0x440
try_to_free_mem_cgroup_pages+0xa7/0x130
try_charge+0x17b/0x830
memcg_charge_kmem+0x40/0x80
new_slab+0x2d9/0x5a0
__slab_alloc+0x2fd/0x44f
kmem_cache_alloc+0x193/0x1e0
alloc_extent_state+0x21/0xc0
__clear_extent_bit+0x2b5/0x400
try_release_extent_mapping+0x1a3/0x220
__btrfs_releasepage+0x31/0x70
mem_cgroup_try_charge+0x65/0x1c0
handle_mm_fault+0x117f/0x1510
__do_page_fault+0x177/0x420
do_page_fault+0xc/0x10
page_fault+0x22/0x30
On later kernels, kmem charging is opt-in rather than opt-out, and that
particular kmem allocation in btrfs_releasepage() is no longer being
charged and won't recurse and overrun the stack anymore.
But it's not impossible for an accounted allocation to happen from the
memcg direct reclaim context, and we needed to reproduce this crash many
times before we even got a useful stack trace out of it.
Like other direct reclaimers, mark tasks in memcg reclaim PF_MEMALLOC to
avoid recursing into any other form of direct reclaim. Then let
recursive charges from PF_MEMALLOC contexts bypass the cgroup limit.
Link: http://lkml.kernel.org/r/20161025141050.GA13019@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Tejun Heo <tj@kernel.org>
commit 1bc11d70b5db7c6bb1414b283d7f09b1fe1ac0d0 upstream.
As described in https://bugzilla.kernel.org/show_bug.cgi?id=177821:
After some analysis it seems to be that the problem is in alloc_super().
In case list_lru_init_memcg() fails it goes into destroy_super(), which
calls list_lru_destroy().
And in list_lru_init() we see that in case memcg_init_list_lru() fails,
lru->node is freed, but not set NULL, which then leads list_lru_destroy()
to believe it is initialized and call memcg_destroy_list_lru().
memcg_destroy_list_lru() in turn can access lru->node[i].memcg_lrus,
which is NULL.
[akpm@linux-foundation.org: add comment]
Signed-off-by: Alexander Polakov <apolyakov@beget.ru>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
commit 2247bb335ab9c40058484cac36ea74ee652f3b7b upstream.
Patch series "mm/hugetlb: memory offline issues with hugepages", v4.
This addresses several issues with hugepages and memory offline. While
the first patch fixes a panic, and is therefore rather important, the
last patch is just a performance optimization.
The second patch fixes a theoretical issue with reserved hugepages,
while still leaving some ugly usability issue, see description.
This patch (of 3):
dissolve_free_huge_pages() will either run into the VM_BUG_ON() or a
list corruption and addressing exception when trying to set a memory
block offline that is part (but not the first part) of a "gigantic"
hugetlb page with a size > memory block size.
When no other smaller hugetlb page sizes are present, the VM_BUG_ON()
will trigger directly. In the other case we will run into an addressing
exception later, because dissolve_free_huge_page() will not work on the
head page of the compound hugetlb page which will result in a NULL
hstate from page_hstate().
To fix this, first remove the VM_BUG_ON() because it is wrong, and then
use the compound head page in dissolve_free_huge_page(). This means
that an unused pre-allocated gigantic page that has any part of itself
inside the memory block that is going offline will be dissolved
completely. Losing an unused gigantic hugepage is preferable to failing
the memory offline, for example in the situation where a (possibly
faulty) memory DIMM needs to go offline.
Changes for v4.4 stable:
- make it apply w/o commit c1470b33 "mm/hugetlb: fix incorrect
hugepages count during mem hotplug"
Fixes: c8721bbb ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Link: http://lkml.kernel.org/r/20160926172811.94033-2-gerald.schaefer@de.ibm.com
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Rui Teng <rui.teng@linux.vnet.ibm.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
commit 3ddf40e8c31964b744ff10abb48c8e36a83ec6e7 upstream.
Commit 22f2ac51b6d6 ("mm: workingset: fix crash in shadow node shrinker
caused by replace_page_cache_page()") switched replace_page_cache() from
raw radix tree operations to page_cache_tree_insert() but didn't take
into account that the latter function, unlike the raw radix tree op,
handles mapping->nrpages. As a result, that counter is bumped for each
page replacement rather than balanced out even.
The mapping->nrpages counter is used to skip needless radix tree walks
when invalidating, truncating, syncing inodes without pages, as well as
statistics for userspace. Since the error is positive, we'll do more
page cache tree walks than necessary; we won't miss a necessary one.
And we'll report more buffer pages to userspace than there are. The
error is limited to fuse inodes.
Fixes: 22f2ac51b6d6 ("mm: workingset: fix crash in shadow node shrinker caused by replace_page_cache_page()")
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: stable@vger.kernel.org
commit 22f2ac51b6d643666f4db093f13144f773ff3f3a upstream.
Antonio reports the following crash when using fuse under memory pressure:
kernel BUG at /build/linux-a2WvEb/linux-4.4.0/mm/workingset.c:346!
invalid opcode: 0000 [#1] SMP
Modules linked in: all of them
CPU: 2 PID: 63 Comm: kswapd0 Not tainted 4.4.0-36-generic #55-Ubuntu
Hardware name: System manufacturer System Product Name/P8H67-M PRO, BIOS 3904 04/27/2013
task: ffff88040cae6040 ti: ffff880407488000 task.ti: ffff880407488000
RIP: shadow_lru_isolate+0x181/0x190
Call Trace:
__list_lru_walk_one.isra.3+0x8f/0x130
list_lru_walk_one+0x23/0x30
scan_shadow_nodes+0x34/0x50
shrink_slab.part.40+0x1ed/0x3d0
shrink_zone+0x2ca/0x2e0
kswapd+0x51e/0x990
kthread+0xd8/0xf0
ret_from_fork+0x3f/0x70
which corresponds to the following sanity check in the shadow node
tracking:
BUG_ON(node->count & RADIX_TREE_COUNT_MASK);
The workingset code tracks radix tree nodes that exclusively contain
shadow entries of evicted pages in them, and this (somewhat obscure)
line checks whether there are real pages left that would interfere with
reclaim of the radix tree node under memory pressure.
While discussing ways how fuse might sneak pages into the radix tree
past the workingset code, Miklos pointed to replace_page_cache_page(),
and indeed there is a problem there: it properly accounts for the old
page being removed - __delete_from_page_cache() does that - but then
does a raw raw radix_tree_insert(), not accounting for the replacement
page. Eventually the page count bits in node->count underflow while
leaving the node incorrectly linked to the shadow node LRU.
To address this, make sure replace_page_cache_page() uses the tracked
page insertion code, page_cache_tree_insert(). This fixes the page
accounting and makes sure page-containing nodes are properly unlinked
from the shadow node LRU again.
Also, make the sanity checks a bit less obscure by using the helpers for
checking the number of pages and shadows in a radix tree node.
[mhocko@suse.com: backport for 4.4]
Fixes: 449dd6984d0e ("mm: keep page cache radix tree nodes in check")
Link: http://lkml.kernel.org/r/20160919155822.29498-1-hannes@cmpxchg.org
Reported-by: Antonio SJ Musumeci <trapexit@spawn.link>
Debugged-by: Miklos Szeredi <miklos@szeredi.hu>
commit d3798ae8c6f3767c726403c2ca6ecc317752c9dd upstream.
When the underflow checks were added to workingset_node_shadow_dec(),
they triggered immediately:
kernel BUG at ./include/linux/swap.h:276!
Modules linked in: isofs usb_storage fuse xt_CHECKSUM ipt_MASQUERADE nf_nat_masquerade_ipv4 tun nf_conntrack_netbios_ns nf_conntrack_broadcast ip6t_REJECT nf_reject_ipv6
soundcore wmi acpi_als pinctrl_sunrisepoint kfifo_buf tpm_tis industrialio acpi_pad pinctrl_intel tpm_tis_core tpm nfsd auth_rpcgss nfs_acl lockd grace sunrpc dm_crypt
CPU: 0 PID: 20929 Comm: blkid Not tainted 4.8.0-rc8-00087-gbe67d60ba944 #1
Hardware name: System manufacturer System Product Name/Z170-K, BIOS 1803 05/06/2016
task: ffff8faa93ecd940 task.stack: ffff8faa7f478000
RIP: page_cache_tree_insert+0xf1/0x100
Call Trace:
__add_to_page_cache_locked+0x12e/0x270
add_to_page_cache_lru+0x4e/0xe0
mpage_readpages+0x112/0x1d0
blkdev_readpages+0x1d/0x20
__do_page_cache_readahead+0x1ad/0x290
force_page_cache_readahead+0xaa/0x100
page_cache_sync_readahead+0x3f/0x50
generic_file_read_iter+0x5af/0x740
blkdev_read_iter+0x35/0x40
__vfs_read+0xe1/0x130
vfs_read+0x96/0x130
SyS_read+0x55/0xc0
entry_SYSCALL_64_fastpath+0x13/0x8f
Code: 03 00 48 8b 5d d8 65 48 33 1c 25 28 00 00 00 44 89 e8 75 19 48 83 c4 18 5b 41 5c 41 5d 41 5e 5d c3 0f 0b 41 bd ef ff ff ff eb d7 <0f> 0b e8 88 68 ef ff 0f 1f 84 00
RIP page_cache_tree_insert+0xf1/0x100
This is a long-standing bug in the way shadow entries are accounted in
the radix tree nodes. The shrinker needs to know when radix tree nodes
contain only shadow entries, no pages, so node->count is split in half
to count shadows in the upper bits and pages in the lower bits.
Unfortunately, the radix tree implementation doesn't know of this and
assumes all entries are in node->count. When there is a shadow entry
directly in root->rnode and the tree is later extended, the radix tree
implementation will copy that entry into the new node and and bump its
node->count, i.e. increases the page count bits. Once the shadow gets
removed and we subtract from the upper counter, node->count underflows
and triggers the warning. Afterwards, without node->count reaching 0
again, the radix tree node is leaked.
Limit shadow entries to when we have actual radix tree nodes and can
count them properly. That means we lose the ability to detect refaults
from files that had only the first page faulted in at eviction time.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 19be0eaffa3ac7d8eb6784ad9bdbc7d67ed8e619 upstream.
This is an ancient bug that was actually attempted to be fixed once
(badly) by me eleven years ago in commit 4ceb5db9757a ("Fix
get_user_pages() race for write access") but that was then undone due to
problems on s390 by commit f33ea7f404e5 ("fix get_user_pages bug").
In the meantime, the s390 situation has long been fixed, and we can now
fix it by checking the pte_dirty() bit properly (and do it better). The
s390 dirty bit was implemented in abf09bed3cce ("s390/mm: implement
software dirty bits") which made it into v3.9. Earlier kernels will
have to look at the page state itself.
Also, the VM has become more scalable, and what used a purely
theoretical race back then has become easier to trigger.
To fix it, we introduce a new internal FOLL_COW flag to mark the "yes,
we already did a COW" rather than play racy games with FOLL_WRITE that
is very fundamental, and then use the pte dirty flag to validate that
the FOLL_COW flag is still valid.
Reported-and-tested-by: Phil "not Paul" Oester <kernel@linuxace.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Nick Piggin <npiggin@gmail.com>
commit 5b398e416e880159fe55eefd93c6588fa072cd66 upstream.
I hit the following hung task when runing a OOM LTP test case with 4.1
kernel.
Call trace:
[<ffffffc000086a88>] __switch_to+0x74/0x8c
[<ffffffc000a1bae0>] __schedule+0x23c/0x7bc
[<ffffffc000a1c09c>] schedule+0x3c/0x94
[<ffffffc000a1eb84>] rwsem_down_write_failed+0x214/0x350
[<ffffffc000a1e32c>] down_write+0x64/0x80
[<ffffffc00021f794>] __ksm_exit+0x90/0x19c
[<ffffffc0000be650>] mmput+0x118/0x11c
[<ffffffc0000c3ec4>] do_exit+0x2dc/0xa74
[<ffffffc0000c46f8>] do_group_exit+0x4c/0xe4
[<ffffffc0000d0f34>] get_signal+0x444/0x5e0
[<ffffffc000089fcc>] do_signal+0x1d8/0x450
[<ffffffc00008a35c>] do_notify_resume+0x70/0x78
The oom victim cannot terminate because it needs to take mmap_sem for
write while the lock is held by ksmd for read which loops in the page
allocator
ksm_do_scan
scan_get_next_rmap_item
down_read
get_next_rmap_item
alloc_rmap_item #ksmd will loop permanently.
There is no way forward because the oom victim cannot release any memory
in 4.1 based kernel. Since 4.6 we have the oom reaper which would solve
this problem because it would release the memory asynchronously.
Nevertheless we can relax alloc_rmap_item requirements and use
__GFP_NORETRY because the allocation failure is acceptable as ksm_do_scan
would just retry later after the lock got dropped.
Such a patch would be also easy to backport to older stable kernels which
do not have oom_reaper.
While we are at it add GFP_NOWARN so the admin doesn't have to be alarmed
by the allocation failure.
Link: http://lkml.kernel.org/r/1474165570-44398-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Suggested-by: Hugh Dickins <hughd@google.com>
Suggested-by: Michal Hocko <mhocko@suse.cz>
commit b385d21f27d86426472f6ae92a231095f7de2a8d upstream.
init_tlb_ubc() looked unnecessary to me: tlb_ubc is statically
initialized with zeroes in the init_task, and copied from parent to
child while it is quiescent in arch_dup_task_struct(); so I went to
delete it.
But inserted temporary debug WARN_ONs in place of init_tlb_ubc() to
check that it was always empty at that point, and found them firing:
because memcg reclaim can recurse into global reclaim (when allocating
biosets for swapout in my case), and arrive back at the init_tlb_ubc()
in shrink_node_memcg().
Resetting tlb_ubc.flush_required at that point is wrong: if the upper
level needs a deferred TLB flush, but the lower level turns out not to,
we miss a TLB flush. But fortunately, that's the only part of the
protocol that does not nest: with the initialization removed, cpumask
collects bits from upper and lower levels, and flushes TLB when needed.
Fixes: 72b252aed506 ("mm: send one IPI per CPU to TLB flush all entries after unmapping pages")
Acked-by: Mel Gorman <mgorman@techsingularity.net>
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ]
Commit b76437579d13 ("procfs: mark thread stack correctly in
proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps.
Finding the task of a stack VMA requires walking the entire thread list,
turning this into quadratic behavior: a thousand threads means a
thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a
million combinations.
The cost is not in proportion to the usefulness as described in the
patch.
Drop the [stack:TID] annotation to make /proc/<pid>/maps (and
/proc/<pid>/numa_maps) usable again for higher thread counts.
The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as
identifying the stack VMA there is an O(1) operation.
Siddesh said:
"The end users needed a way to identify thread stacks programmatically and
there wasn't a way to do that. I'm afraid I no longer remember (or have
access to the resources that would aid my memory since I changed
employers) the details of their requirement. However, I did do this on my
own time because I thought it was an interesting project for me and nobody
really gave any feedback then as to its utility, so as far as I am
concerned you could roll back the main thread maps information since the
information is available in the thread-specific files"
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com>
Cc: Shaohua Li <shli@fb.com>
commit c17b1f42594eb71b8d3eb5a6dfc907a7eb88a51d upstream.
We account HugeTLB's shared page table to all processes who share it.
The accounting happens during huge_pmd_share().
If somebody populates pud entry under us, we should decrease pagetable's
refcount and decrease nr_pmds of the process.
By mistake, I increase nr_pmds again in this case. :-/ It will lead to
"BUG: non-zero nr_pmds on freeing mm: 2" on process' exit.
Let's fix this by increasing nr_pmds only when we're sure that the page
table will be used.
Link: http://lkml.kernel.org/r/20160617122506.GC6534@node.shutemov.name
Fixes: dc6c9a35b66b ("mm: account pmd page tables to the process")
Reported-by: zhongjiang <zhongjiang@huawei.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
commit 649920c6ab93429b94bc7c1aa7c0e8395351be32 upstream.
In powerpc servers with large memory(32TB), we watched several soft
lockups for hugepage under stress tests.
The call traces are as follows:
1.
get_page_from_freelist+0x2d8/0xd50
__alloc_pages_nodemask+0x180/0xc20
alloc_fresh_huge_page+0xb0/0x190
set_max_huge_pages+0x164/0x3b0
2.
prep_new_huge_page+0x5c/0x100
alloc_fresh_huge_page+0xc8/0x190
This patch fixes such soft lockups. It is safe to call cond_resched()
there because it is out of spin_lock/unlock section.
Link: http://lkml.kernel.org/r/1469674442-14848-1-git-send-email-hejianet@gmail.com
Signed-off-by: Jia He <hejianet@gmail.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit df08c32ce3be5be138c1dbfcba203314a3a7cd6f upstream.
The name for a bdi of a gendisk is derived from the gendisk's devt.
However, since the gendisk is destroyed before the bdi it leaves a
window where a new gendisk could dynamically reuse the same devt while a
bdi with the same name is still live. Arrange for the bdi to hold a
reference against its "owner" disk device while it is registered.
Otherwise we can hit sysfs duplicate name collisions like the following:
WARNING: CPU: 10 PID: 2078 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x64/0x80
sysfs: cannot create duplicate filename '/devices/virtual/bdi/259:1'
Hardware name: HP ProLiant DL580 Gen8, BIOS P79 05/06/2015
0000000000000286 0000000002c04ad5 ffff88006f24f970 ffffffff8134caec
ffff88006f24f9c0 0000000000000000 ffff88006f24f9b0 ffffffff8108c351
0000001f0000000c ffff88105d236000 ffff88105d1031e0 ffff8800357427f8
Call Trace:
[<ffffffff8134caec>] dump_stack+0x63/0x87
[<ffffffff8108c351>] __warn+0xd1/0xf0
[<ffffffff8108c3cf>] warn_slowpath_fmt+0x5f/0x80
[<ffffffff812a0d34>] sysfs_warn_dup+0x64/0x80
[<ffffffff812a0e1e>] sysfs_create_dir_ns+0x7e/0x90
[<ffffffff8134faaa>] kobject_add_internal+0xaa/0x320
[<ffffffff81358d4e>] ? vsnprintf+0x34e/0x4d0
[<ffffffff8134ff55>] kobject_add+0x75/0xd0
[<ffffffff816e66b2>] ? mutex_lock+0x12/0x2f
[<ffffffff8148b0a5>] device_add+0x125/0x610
[<ffffffff8148b788>] device_create_groups_vargs+0xd8/0x100
[<ffffffff8148b7cc>] device_create_vargs+0x1c/0x20
[<ffffffff811b775c>] bdi_register+0x8c/0x180
[<ffffffff811b7877>] bdi_register_dev+0x27/0x30
[<ffffffff813317f5>] add_disk+0x175/0x4a0
Reported-by: Yi Zhang <yizhan@redhat.com>
Tested-by: Yi Zhang <yizhan@redhat.com>
Fixed up missing 0 return in bdi_register_owner().
commit 615d66c37c755c49ce022c9e5ac0875d27d2603d upstream.
Since commit 73f576c04b94 ("mm: memcontrol: fix cgroup creation failure
after many small jobs") swap entries do not pin memcg->css.refcnt
directly. Instead, they pin memcg->id.ref. So we should adjust the
reference counters accordingly when moving swap charges between cgroups.
Fixes: 73f576c04b941 ("mm: memcontrol: fix cgroup creation failure after many small jobs")
Link: http://lkml.kernel.org/r/9ce297c64954a42dc90b543bc76106c4a94f07e8.1470219853.git.vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
commit 1f47b61fb4077936465dcde872a4e5cc4fe708da upstream.
An offline memory cgroup might have anonymous memory or shmem left
charged to it and no swap. Since only swap entries pin the id of an
offline cgroup, such a cgroup will have no id and so an attempt to
swapout its anon/shmem will not store memory cgroup info in the swap
cgroup map. As a result, memcg->swap or memcg->memsw will never get
uncharged from it and any of its ascendants.
Fix this by always charging swapout to the first ancestor cgroup that
hasn't released its id yet.
[hannes@cmpxchg.org: add comment to mem_cgroup_swapout]
[vdavydov@virtuozzo.com: use WARN_ON_ONCE() in mem_cgroup_id_get_online()]
Link: http://lkml.kernel.org/r/20160803123445.GJ13263@esperanza
Link: http://lkml.kernel.org/r/5336daa5c9a32e776067773d9da655d2dc126491.1470219853.git.vdavydov@virtuozzo.com
Cc: <stable@vger.kernel.org> [3.19+]
commit 73f576c04b9410ed19660f74f97521bee6e1c546 upstream.
The memory controller has quite a bit of state that usually outlives the
cgroup and pins its CSS until said state disappears. At the same time
it imposes a 16-bit limit on the CSS ID space to economically store IDs
in the wild. Consequently, when we use cgroups to contain frequent but
small and short-lived jobs that leave behind some page cache, we quickly
run into the 64k limitations of outstanding CSSs. Creating a new cgroup
fails with -ENOSPC while there are only a few, or even no user-visible
cgroups in existence.
Although pinning CSSs past cgroup removal is common, there are only two
instances that actually need an ID after a cgroup is deleted: cache
shadow entries and swapout records.
Cache shadow entries reference the ID weakly and can deal with the CSS
having disappeared when it's looked up later. They pose no hurdle.
Swap-out records do need to pin the css to hierarchically attribute
swapins after the cgroup has been deleted; though the only pages that
remain swapped out after offlining are tmpfs/shmem pages. And those
references are under the user's control, so they are manageable.
This patch introduces a private 16-bit memcg ID and switches swap and
cache shadow entries over to using that. This ID can then be recycled
after offlining when the CSS remains pinned only by objects that don't
specifically need it.
This script demonstrates the problem by faulting one cache page in a new
cgroup and deleting it again:
set -e
mkdir -p pages
for x in `seq 128000`; do
[ $((x % 1000)) -eq 0 ] && echo $x
mkdir /cgroup/foo
echo $$ >/cgroup/foo/cgroup.procs
echo trex >pages/$x
echo $$ >/cgroup/cgroup.procs
rmdir /cgroup/foo
done
When run on an unpatched kernel, we eventually run out of possible IDs
even though there are no visible cgroups:
[root@ham ~]# ./cssidstress.sh
65000
mkdir: cannot create directory '/cgroup/foo': No space left on device
After this patch, the IDs get released upon cgroup destruction and the
cache and css objects get released once memory reclaim kicks in.
[hannes@cmpxchg.org: init the IDR]
Link: http://lkml.kernel.org/r/20160621154601.GA22431@cmpxchg.org
Fixes: b2052564e66d ("mm: memcontrol: continue cache reclaim from offlined groups")
Link: http://lkml.kernel.org/r/20160617162516.GD19084@cmpxchg.org
Reported-by: John Garcia <john.garcia@mesosphere.io>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Nikolay Borisov <kernel@kyup.com>
uninitialised
commit ef70b6f41cda6270165a6f27b2548ed31cfa3cb2 upstream.
early_page_uninitialised looks up an arbitrary PFN. While a machine
without node 0 will boot with "mm, page_alloc: Always return a valid
node from early_pfn_to_nid", it works because it assumes that nodes are
always in PFN order. This is not guaranteed so this patch adds
robustness by always checking if the node being checked is online.
Link: http://lkml.kernel.org/r/1468008031-3848-4-git-send-email-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
commit e4568d3803852d00effd41dcdd489e726b998879 upstream.
early_pfn_to_nid can return node 0 if a PFN is invalid on machines that
has no node 0. A machine with only node 1 was observed to crash with
the following message:
BUG: unable to handle kernel paging request at 000000000002a3c8
PGD 0
Modules linked in:
Hardware name: Supermicro H8DSP-8/H8DSP-8, BIOS 080011 06/30/2006
task: ffffffff81c0d500 ti: ffffffff81c00000 task.ti: ffffffff81c00000
RIP: reserve_bootmem_region+0x6a/0xef
CR2: 000000000002a3c8 CR3: 0000000001c06000 CR4: 00000000000006b0
Call Trace:
free_all_bootmem+0x4b/0x12a
mem_init+0x70/0xa3
start_kernel+0x25b/0x49b
The problem is that early_page_uninitialised uses the early_pfn_to_nid
helper which returns node 0 for invalid PFNs. No caller of
early_pfn_to_nid cares except early_page_uninitialised. This patch has
early_pfn_to_nid always return a valid node.
Link: http://lkml.kernel.org/r/1468008031-3848-3-git-send-email-mgorman@techsingularity.net
commit a46cbf3bc53b6a93fb84a5ffb288c354fa807954 upstream.
It's possible to isolate some freepages in a pageblock and then fail
split_free_page() due to the low watermark check. In this case, we hit
VM_BUG_ON() because the freeing scanner terminated early without a
contended lock or enough freepages.
This should never have been a VM_BUG_ON() since it's not a fatal
condition. It should have been a VM_WARN_ON() at best, or even handled
gracefully.
Regardless, we need to terminate anytime the full pageblock scan was not
done. The logic belongs in isolate_freepages_block(), so handle its
state gracefully by terminating the pageblock loop and making a note to
restart at the same pageblock next time since it was not possible to
complete the scan this time.
[rientjes@google.com: don't rescan pages in a pageblock]
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1607111244150.83138@chino.kir.corp.google.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606291436300.145590@chino.kir.corp.google.com
Reported-by: Minchan Kim <minchan@kernel.org>
Tested-by: Minchan Kim <minchan@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit a4f04f2c6955aff5e2c08dcb40aca247ff4d7370 upstream.
If the memory compaction free scanner cannot successfully split a free
page (only possible due to per-zone low watermark), terminate the free
scanner rather than continuing to scan memory needlessly. If the
watermark is insufficient for a free page of order <= cc->order, then
terminate the scanner since all future splits will also likely fail.
This prevents the compaction freeing scanner from scanning all memory on
very large zones (very noticeable for zones > 128GB, for instance) when
all splits will likely fail while holding zone->lock.
compaction_alloc() iterating a 128GB zone has been benchmarked to take
over 400ms on some systems whereas any free page isolated and ready to
be split ends up failing in split_free_page() because of the low
watermark check and thus the iteration continues.
The next time compaction occurs, the freeing scanner will likely start
at the end of the zone again since no success was made previously and we
get the same lengthy iteration until the zone is brought above the low
watermark. All thp page faults can take >400ms in such a state without
this fix.
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1606211820350.97086@chino.kir.corp.google.com
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit e838a45f9392a5bd2be1cd3ab0b16ae85857461c upstream.
Commit d0164adc89f6 ("mm, page_alloc: distinguish between being unable
to sleep, unwilling to sleep and avoiding waking kswapd") modified
__GFP_WAIT to explicitly identify the difference between atomic callers
and those that were unwilling to sleep. Later the definition was
removed entirely.
The GFP_RECLAIM_MASK is the set of flags that affect watermark checking
and reclaim behaviour but __GFP_ATOMIC was never added. Without it,
atomic users of the slab allocator strip the __GFP_ATOMIC flag and
cannot access the page allocator atomic reserves. This patch addresses
the problem.
The user-visible impact depends on the workload but potentially atomic
allocations unnecessarily fail without this path.
Link: http://lkml.kernel.org/r/20160610093832.GK2527@techsingularity.net
Reported-by: Marcin Wojtas <mw@semihalf.com>
commit 7f556567036cb7f89aabe2f0954b08566b4efb53 upstream.
The well-spotted fallocate undo fix is good in most cases, but not when
fallocate failed on the very first page. index 0 then passes lend -1
to shmem_undo_range(), and that has two bad effects: (a) that it will
undo every fallocation throughout the file, unrestricted by the current
range; but more importantly (b) it can cause the undo to hang, because
lend -1 is treated as truncation, which makes it keep on retrying until
every page has gone, but those already fully instantiated will never go
away. Big thank you to xfstests generic/269 which demonstrates this.
Fixes: b9b4bb26af01 ("tmpfs: don't undo fallocate past its last page")
commit b9b4bb26af017dbe930cd4df7f9b2fc3a0497bfe upstream.
When fallocate is interrupted it will undo a range that extends one byte
past its range of allocated pages. This can corrupt an in-use page by
zeroing out its first byte. Instead, undo using the inclusive byte
range.
Fixes: 1635f6a74152f1d ("tmpfs: undo fallocation on failure")
Link: http://lkml.kernel.org/r/1462713387-16724-1-git-send-email-anthony.romano@coreos.com
Signed-off-by: Anthony Romano <anthony.romano@coreos.com>
Cc: Brandon Philips <brandon@ifup.co>
destruction
commit 6710e594f71ccaad8101bc64321152af7cd9ea28 upstream.
For non-atomic allocations, pcpu_alloc() can try to extend the area
map synchronously after dropping pcpu_lock; however, the extension
wasn't synchronized against chunk destruction and the chunk might get
freed while extension is in progress.
This patch fixes the bug by putting most of non-atomic allocations
under pcpu_alloc_mutex to synchronize against pcpu_balance_work which
is responsible for async chunk management including destruction.
Reported-and-tested-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Fixes: 1a4d76076cda ("percpu: implement asynchronous chunk population")
commit 4f996e234dad488e5d9ba0858bc1bae12eff82c3 upstream.
Atomic allocations can trigger async map extensions which is serviced
by chunk->map_extend_work. pcpu_balance_work which is responsible for
destroying idle chunks wasn't synchronizing properly against
chunk->map_extend_work and may end up freeing the chunk while the work
item is still in flight.
This patch fixes the bug by rolling async map extension operations
into pcpu_balance_work.
Fixes: 9c824b6a172c ("percpu: make sure chunk->map array has available space")
commit 1118dce773d84f39ebd51a9fe7261f9169cb056e upstream.
Export these symbols such that UBIFS can implement
->migratepage.
Signed-off-by: Richard Weinberger <richard@nod.at>
Acked-by: Christoph Hellwig <hch@lst.de>
commit 62a584fe05eef1f80ed49a286a29328f1a224fb9 upstream.
As vm.dirty_[background_]bytes can't be applied verbatim to multiple
cgroup writeback domains, they get converted to percentages in
domain_dirty_limits() and applied the same way as
vm.dirty_[background]ratio. However, if the specified bytes is lower
than 1% of available memory, the calculated ratios become zero and the
writeback domain gets throttled constantly.
Fix it by using per-PAGE_SIZE instead of percentage for ratio
calculations. Also, the updated DIV_ROUND_UP() usages now should
yield 1/4096 (0.0244%) as the minimum ratio as long as the specified
bytes are above zero.
Reported-by: Miao Xie <miaoxie@huawei.com>
Link: http://lkml.kernel.org/g/57333E75.3080309@huawei.com
Fixes: 9fc3a43e1757 ("writeback: separate out domain_dirty_limits()")
Adjusted comment based on Jan's suggestion.
memcg_offline_kmem()
commit 3a06bb78ceeceacc86a1e31133a7944013f9775b upstream.
memcg_offline_kmem() may be called from memcg_free_kmem() after a css
init failure. memcg_free_kmem() is a ->css_free callback which is
called without cgroup_mutex and memcg_offline_kmem() ends up using
css_for_each_descendant_pre() without any locking. Fix it by adding rcu
read locking around it.
mkdir: cannot create directory `65530': No space left on device
[ INFO: suspicious RCU usage. ]
4.6.0-work+ #321 Not tainted
kernel/cgroup.c:4008 cgroup_mutex or RCU read lock required!
[ 527.243970] other info that might help us debug this:
[ 527.244715]
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by kworker/0:5/1664:
#0: ("cgroup_destroy"){.+.+..}, at: [<ffffffff81060ab5>] process_one_work+0x165/0x4a0
#1: ((&css->destroy_work)#3){+.+...}, at: [<ffffffff81060ab5>] process_one_work+0x165/0x4a0
[ 527.248098] stack backtrace:
CPU: 0 PID: 1664 Comm: kworker/0:5 Not tainted 4.6.0-work+ #321
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
Workqueue: cgroup_destroy css_free_work_fn
Call Trace:
dump_stack+0x68/0xa1
lockdep_rcu_suspicious+0xd7/0x110
css_next_descendant_pre+0x7d/0xb0
memcg_offline_kmem.part.44+0x4a/0xc0
mem_cgroup_css_free+0x1ec/0x200
css_free_work_fn+0x49/0x5e0
process_one_work+0x1c5/0x4a0
worker_thread+0x49/0x490
kthread+0xea/0x100
ret_from_fork+0x1f/0x40
Link: http://lkml.kernel.org/r/20160526203018.GG23194@mtj.duckdns.org
Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com>
commit 4b50bcc7eda4d3cc9e3f2a0aa60e590fedf728c5 upstream.
Since commit 92923ca3aace ("mm: meminit: only set page reserved in the
memblock region") the reserved bit is set on reserved memblock regions.
However start and end address are passed as unsigned long. This is only
32bit on i386, so it can end up marking the wrong pages reserved for
ranges at 4GB and above.
This was observed on a 32bit Xen dom0 which was booted with initial
memory set to a value below 4G but allowing to balloon in memory
(dom0_mem=1024M for example). This would define a reserved bootmem
region for the additional memory (for example on a 8GB system there was
a reverved region covering the 4GB-8GB range). But since the addresses
were passed on as unsigned long, this was actually marking all pages
from 0 to 4GB as reserved.
Fixes: 92923ca3aacef63 ("mm: meminit: only set page reserved in the memblock region")
Link: http://lkml.kernel.org/r/1463491221-10573-1-git-send-email-stefan.bader@canonical.com
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit 44f43e99fe70833058482d183e99fdfd11220996 upstream.
zs_can_compact() has two race conditions in its core calculation:
unsigned long obj_wasted = zs_stat_get(class, OBJ_ALLOCATED) -
zs_stat_get(class, OBJ_USED);
1) classes are not locked, so the numbers of allocated and used
objects can change by the concurrent ops happening on other CPUs
2) shrinker invokes it from preemptible context
Depending on the circumstances, thus, OBJ_ALLOCATED can become
less than OBJ_USED, which can result in either very high or
negative `total_scan' value calculated later in do_shrink_slab().
do_shrink_slab() has some logic to prevent those cases:
vmscan: shrink_slab: zs_shrinker_scan+0x0/0x28 [zsmalloc] negative objects to delete nr=-62
vmscan: shrink_slab: zs_shrinker_scan+0x0/0x28 [zsmalloc] negative objects to delete nr=-64
However, due to the way `total_scan' is calculated, not every
shrinker->count_objects() overflow can be spotted and handled.
To demonstrate the latter, I added some debugging code to do_shrink_slab()
(x86_64) and the results were:
vmscan: OVERFLOW: shrinker->count_objects() == -1 [18446744073709551615]
vmscan: but total_scan > 0: 92679974445502
vmscan: resulting total_scan: 92679974445502
vmscan: but total_scan > 0: 22634041808232578
vmscan: resulting total_scan: 22634041808232578
Even though shrinker->count_objects() has returned an overflowed value,
the resulting `total_scan' is positive, and, what is more worrisome, it
is insanely huge. This value is getting used later on in
shrinker->scan_objects() loop:
while (total_scan >= batch_size ||
total_scan >= freeable) {
unsigned long ret;
unsigned long nr_to_scan = min(batch_size, total_scan);
shrinkctl->nr_to_scan = nr_to_scan;
ret = shrinker->scan_objects(shrinker, shrinkctl);
if (ret == SHRINK_STOP)
break;
freed += ret;
count_vm_events(SLABS_SCANNED, nr_to_scan);
total_scan -= nr_to_scan;
cond_resched();
`total_scan >= batch_size' is true for a very-very long time and
'total_scan >= freeable' is also true for quite some time, because
`freeable < 0' and `total_scan' is large enough, for example,
22634041808232578. The only break condition, in the given scheme of
things, is shrinker->scan_objects() == SHRINK_STOP test, which is a
bit too weak to rely on, especially in heavy zsmalloc-usage scenarios.
To fix the issue, take a pool stat snapshot and use it instead of
racy zs_stat_get() calls.
Link: http://lkml.kernel.org/r/20160509140052.3389-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 74d369443325063a5f0260e63971decb950fd8fa upstream.
Commit 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use
wb_domain aware operations") unintentionally changed this function's
meaning from "are there more dirty pages than the background writeback
threshold" to "are there more dirty pages than the writeback threshold".
The background writeback threshold is typically half of the writeback
threshold, so this had the effect of raising the number of dirty pages
required to cause a writeback worker to perform background writeout.
This can cause a very severe performance regression when a BDI uses
BDI_CAP_STRICTLIMIT because balance_dirty_pages() and the writeback worker
can now disagree on whether writeback should be initiated.
For example, in a system having 1GB of RAM, a single spinning disk, and a
"pass-through" FUSE filesystem mounted over the disk, application code
mmapped a 128MB file on the disk and was randomly dirtying pages in that
mapping.
Because FUSE uses strictlimit and has a default max_ratio of only 1%, in
balance_dirty_pages, thresh is ~200, bg_thresh is ~100, and the
dirty_freerun_ceiling is the average of those, ~150. So, it pauses the
dirtying processes when we have 151 dirty pages and wakes up a background
writeback worker. But the worker tests the wrong threshold (200 instead of
100), so it does not initiate writeback and just returns.
Thus, balance_dirty_pages keeps looping, sleeping and then waking up the
worker who will do nothing. It remains stuck in this state until the few
dirty pages that we have finally expire and we write them back for that
reason. Then the whole process repeats, resulting in near-zero throughput
through the FUSE BDI.
The fix is to call the parameterized variant of wb_calc_thresh, so that the
worker will do writeback if the bg_thresh is exceeded which was the
behavior before the referenced commit.
Fixes: 947e9762a8dd ("writeback: update wb_over_bg_thresh() to use wb_domain aware operations")
Signed-off-by: Howard Cochran <hcochran@kernelspring.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Tested-by Sedat Dilek <sedat.dilek@gmail.com>
commit bc22af74f271ef76b2e6f72f3941f91f0da3f5f8 upstream.
Khugepaged attempts to raise min_free_kbytes if its set too low.
However, on boot khugepaged sets min_free_kbytes first from
subsys_initcall(), and then the mm 'core' over-rides min_free_kbytes
after from init_per_zone_wmark_min(), via a module_init() call.
Khugepaged used to use a late_initcall() to set min_free_kbytes (such
that it occurred after the core initialization), however this was
removed when the initialization of min_free_kbytes was integrated into
the starting of the khugepaged thread.
The fix here is simply to invoke the core initialization using a
core_initcall() instead of module_init(), such that the previous
initialization ordering is restored. I didn't restore the
late_initcall() since start_stop_khugepaged() already sets
min_free_kbytes via set_recommended_min_free_kbytes().
This was noticed when we had a number of page allocation failures when
moving a workload to a kernel with this new initialization ordering. On
an 8GB system this restores min_free_kbytes back to 67584 from 11365
when CONFIG_TRANSPARENT_HUGEPAGE=y is set and either
CONFIG_TRANSPARENT_HUGEPAGE_ALWAYS=y or
CONFIG_TRANSPARENT_HUGEPAGE_MADVISE=y.
Fixes: 79553da293d3 ("thp: cleanup khugepaged startup")
Signed-off-by: Jason Baron <jbaron@akamai.com>
commit 32a4e169039927bfb6ee9f0ccbbe3a8aaf13a4bc upstream.
Instead of using "zswap" as the name for all zpools created, add an
atomic counter and use "zswap%x" with the counter number for each zpool
created, to provide a unique name for each new zpool.
As zsmalloc, one of the zpool implementations, requires/expects a unique
name for each pool created, zswap should provide a unique name. The
zsmalloc pool creation does not fail if a new pool with a conflicting
name is created, unless CONFIG_ZSMALLOC_STAT is enabled; in that case,
zsmalloc pool creation fails with -ENOMEM. Then zswap will be unable to
change its compressor parameter if its zpool is zsmalloc; it also will
be unable to change its zpool parameter back to zsmalloc, if it has any
existing old zpool using zsmalloc with page(s) in it. Attempts to
change the parameters will result in failure to create the zpool. This
changes zswap to provide a unique name for each zpool creation.
Fixes: f1c54846ee45 ("zswap: dynamic pool creation")
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dan Streetman <dan.streetman@canonical.com>
commit 14af4a5e9b26ad251f81c174e8a43f3e179434a5 upstream.
/proc/sys/vm/stat_refresh warns nr_isolated_anon and nr_isolated_file go
increasingly negative under compaction: which would add delay when
should be none, or no delay when should delay. The bug in compaction
was due to a recent mmotm patch, but much older instance of the bug was
also noticed in isolate_migratepages_range() which is used for CMA and
gigantic hugepage allocations.
The bug is caused by putback_movable_pages() in an error path
decrementing the isolated counters without them being previously
incremented by acct_isolated(). Fix isolate_migratepages_range() by
removing the error-path putback, thus reaching acct_isolated() with
migratepages still isolated, and leaving putback to caller like most
other places do.
Fixes: edc2ca612496 ("mm, compaction: move pageblock checks up from isolate_migratepages_range()")
[vbabka@suse.cz: expanded the changelog]
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit d7e69488bd04de165667f6bc741c1c0ec6042ab9 upstream.
Currently, migration code increses num_poisoned_pages on *failed*
migration page as well as successfully migrated one at the trial of
memory-failure. It will make the stat wrong. As well, it marks the
page as PG_HWPoison even if the migration trial failed. It would mean
we cannot recover the corrupted page using memory-failure facility.
This patches fixes it.
Signed-off-by: Minchan Kim <minchan@kernel.org>
commit 7bf52fb891b64b8d61caf0b82060adb9db761aec upstream.
We have been reclaimed highmem zone if buffer_heads is over limit but
commit 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from
shrink_zone()") changed the behavior so it doesn't reclaim highmem zone
although buffer_heads is over the limit. This patch restores the logic.
Fixes: 6b4f7799c6a5 ("mm: vmscan: invoke slab shrinkers from shrink_zone()")
