path: root/mm
2015-10-01vmscan: fix increasing nr_isolated incurred by putback unevictable pagesJaewon Kim
commit c54839a722a02818677bcabe57e957f0ce4f841d upstream. reclaim_clean_pages_from_list() assumes that shrink_page_list() returns number of pages removed from the candidate list. But shrink_page_list() puts back mlocked pages without passing it to caller and without counting as nr_reclaimed. This increases nr_isolated. To fix this, this patch changes shrink_page_list() to pass unevictable pages back to caller. Caller will take care those pages. Minchan said: It fixes two issues. 1. With unevictable page, cma_alloc will be successful. Exactly speaking, cma_alloc of current kernel will fail due to unevictable pages. 2. fix leaking of NR_ISOLATED counter of vmstat With it, too_many_isolated works. Otherwise, it could make hang until the process get SIGKILL. Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13mm/hwpoison: fix page refcount of unknown non LRU pageWanpeng Li
commit 4f32be677b124a49459e2603321c7a5605ceb9f8 upstream. After trying to drain pages from pagevec/pageset, we try to get reference count of the page again, however, the reference count of the page is not reduced if the page is still not on LRU list. Fix it by adding the put_page() to drop the page reference which is from __get_any_page(). Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-16mm, vmscan: Do not wait for page writeback for GFP_NOFS allocationsMichal Hocko
commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream. Nikolay has reported a hang when a memcg reclaim got stuck with the following backtrace: PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync" #0 __schedule at ffffffff815ab152 #1 schedule at ffffffff815ab76e #2 schedule_timeout at ffffffff815ae5e5 #3 io_schedule_timeout at ffffffff815aad6a #4 bit_wait_io at ffffffff815abfc6 #5 __wait_on_bit at ffffffff815abda5 #6 wait_on_page_bit at ffffffff8111fd4f #7 shrink_page_list at ffffffff81135445 #8 shrink_inactive_list at ffffffff81135845 #9 shrink_lruvec at ffffffff81135ead #10 shrink_zone at ffffffff811360c3 #11 shrink_zones at ffffffff81136eff #12 do_try_to_free_pages at ffffffff8113712f #13 try_to_free_mem_cgroup_pages at ffffffff811372be #14 try_charge at ffffffff81189423 #15 mem_cgroup_try_charge at ffffffff8118c6f5 #16 __add_to_page_cache_locked at ffffffff8112137d #17 add_to_page_cache_lru at ffffffff81121618 #18 pagecache_get_page at ffffffff8112170b #19 grow_dev_page at ffffffff811c8297 #20 __getblk_slow at ffffffff811c91d6 #21 __getblk_gfp at ffffffff811c92c1 #22 ext4_ext_grow_indepth at ffffffff8124565c #23 ext4_ext_create_new_leaf at ffffffff81246ca8 #24 ext4_ext_insert_extent at ffffffff81246f09 #25 ext4_ext_map_blocks at ffffffff8124a848 #26 ext4_map_blocks at ffffffff8121a5b7 #27 mpage_map_one_extent at ffffffff8121b1fa #28 mpage_map_and_submit_extent at ffffffff8121f07b #29 ext4_writepages at ffffffff8121f6d5 #30 do_writepages at ffffffff8112c490 #31 __filemap_fdatawrite_range at ffffffff81120199 #32 filemap_flush at ffffffff8112041c #33 ext4_alloc_da_blocks at ffffffff81219da1 #34 ext4_rename at ffffffff81229b91 #35 ext4_rename2 at ffffffff81229e32 #36 vfs_rename at ffffffff811a08a5 #37 SYSC_renameat2 at ffffffff811a3ffc #38 sys_renameat2 at ffffffff811a408e #39 sys_rename at ffffffff8119e51e #40 system_call_fastpath at ffffffff815afa89 Dave Chinner has properly pointed out that this is a deadlock in the reclaim code because ext4 doesn't submit pages which are marked by PG_writeback right away. The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM with too many dirty pages") and it was applied only when may_enter_fs was specified. The code has been changed by c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages") which has removed the __GFP_FS restriction with a reasoning that we do not get into the fs code. But this is not sufficient apparently because the fs doesn't necessarily submit pages marked PG_writeback for IO right away. ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily submit the bio. Instead it tries to map more pages into the bio and mpage_map_one_extent might trigger memcg charge which might end up waiting on a page which is marked PG_writeback but hasn't been submitted yet so we would end up waiting for something that never finishes. Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2) before we go to wait on the writeback. The page fault path, which is the only path that triggers memcg oom killer since 3.12, shouldn't require GFP_NOFS and so we shouldn't reintroduce the premature OOM killer issue which was originally addressed by the heuristic. As per David Chinner the xfs is doing similar thing since 2.6.15 already so ext4 is not the only affected filesystem. Moreover he notes: : For example: IO completion might require unwritten extent conversion : which executes filesystem transactions and GFP_NOFS allocations. The : writeback flag on the pages can not be cleared until unwritten : extent conversion completes. Hence memory reclaim cannot wait on : page writeback to complete in GFP_NOFS context because it is not : safe to do so, memcg reclaim or otherwise. [tytso@mit.edu: corrected the control flow] Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages") Reported-by: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-10mm: avoid setting up anonymous pages into file mappingKirill A. Shutemov
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream. Reading page fault handler code I've noticed that under right circumstances kernel would map anonymous pages into file mappings: if the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated on ->mmap(), kernel would handle page fault to not populated pte with do_anonymous_page(). Let's change page fault handler to use do_anonymous_page() only on anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not shared. For file mappings without vm_ops->fault() or shred VMA without vm_ops, page fault on pte_none() entry would lead to SIGBUS. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Willy Tarreau <w@1wt.eu> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-22mm/memory_hotplug.c: set zone->wait_table to null after freeing itGu Zheng
commit 85bd839983778fcd0c1c043327b14a046e979b39 upstream. Izumi found the following oops when hot re-adding a node: BUG: unable to handle kernel paging request at ffffc90008963690 IP: __wake_up_bit+0x20/0x70 Oops: 0000 [#1] SMP CPU: 68 PID: 1237 Comm: rs:main Q:Reg Not tainted 4.1.0-rc5 #80 Hardware name: FUJITSU PRIMEQUEST2800E/SB, BIOS PRIMEQUEST 2000 Series BIOS Version 1.87 04/28/2015 task: ffff880838df8000 ti: ffff880017b94000 task.ti: ffff880017b94000 RIP: 0010:[<ffffffff810dff80>] [<ffffffff810dff80>] __wake_up_bit+0x20/0x70 RSP: 0018:ffff880017b97be8 EFLAGS: 00010246 RAX: ffffc90008963690 RBX: 00000000003c0000 RCX: 000000000000a4c9 RDX: 0000000000000000 RSI: ffffea101bffd500 RDI: ffffc90008963648 RBP: ffff880017b97c08 R08: 0000000002000020 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff8a0797c73800 R13: ffffea101bffd500 R14: 0000000000000001 R15: 00000000003c0000 FS: 00007fcc7ffff700(0000) GS:ffff880874800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffc90008963690 CR3: 0000000836761000 CR4: 00000000001407e0 Call Trace: unlock_page+0x6d/0x70 generic_write_end+0x53/0xb0 xfs_vm_write_end+0x29/0x80 [xfs] generic_perform_write+0x10a/0x1e0 xfs_file_buffered_aio_write+0x14d/0x3e0 [xfs] xfs_file_write_iter+0x79/0x120 [xfs] __vfs_write+0xd4/0x110 vfs_write+0xac/0x1c0 SyS_write+0x58/0xd0 system_call_fastpath+0x12/0x76 Code: 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 20 65 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 8d 47 48 <48> 39 47 48 48 c7 45 e8 00 00 00 00 48 c7 45 f0 00 00 00 00 48 RIP [<ffffffff810dff80>] __wake_up_bit+0x20/0x70 RSP <ffff880017b97be8> CR2: ffffc90008963690 Reproduce method (re-add a node):: Hot-add nodeA --> remove nodeA --> hot-add nodeA (panic) This seems an use-after-free problem, and the root cause is zone->wait_table was not set to *NULL* after free it in try_offline_node. When hot re-add a node, we will reuse the pgdat of it, so does the zone struct, and when add pages to the target zone, it will init the zone first (including the wait_table) if the zone is not initialized. The judgement of zone initialized is based on zone->wait_table: static inline bool zone_is_initialized(struct zone *zone) { return !!zone->wait_table; } so if we do not set the zone->wait_table to *NULL* after free it, the memory hotplug routine will skip the init of new zone when hot re-add the node, and the wait_table still points to the freed memory, then we will access the invalid address when trying to wake up the waiting people after the i/o operation with the page is done, such as mentioned above. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Reviewed by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17mm/memory-failure: call shake_page() when error hits thp tail pageNaoya Horiguchi
commit 09789e5de18e4e442870b2d700831f5cb802eb05 upstream. Currently memory_failure() calls shake_page() to sweep pages out from pcplists only when the victim page is 4kB LRU page or thp head page. But we should do this for a thp tail page too. Consider that a memory error hits a thp tail page whose head page is on a pcplist when memory_failure() runs. Then, the current kernel skips shake_pages() part, so hwpoison_user_mappings() returns without calling split_huge_page() nor try_to_unmap() because PageLRU of the thp head is still cleared due to the skip of shake_page(). As a result, me_huge_page() runs for the thp, which is broken behavior. One effect is a leak of the thp. And another is to fail to isolate the memory error, so later access to the error address causes another MCE, which kills the processes which used the thp. This patch fixes this problem by calling shake_page() for thp tail case. Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Dean Nelson <dnelson@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29vm: make stack guard page errors return VM_FAULT_SIGSEGV rather than SIGBUSLinus Torvalds
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream. The stack guard page error case has long incorrectly caused a SIGBUS rather than a SIGSEGV, but nobody actually noticed until commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") because that error case was never actually triggered in any normal situations. Now that we actually report the error, people noticed the wrong signal that resulted. So far, only the test suite of libsigsegv seems to have actually cared, but there are real applications that use libsigsegv, so let's not wait for any of those to break. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-29vm: add VM_FAULT_SIGSEGV handling supportLinus Torvalds
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream. The core VM already knows about VM_FAULT_SIGBUS, but cannot return a "you should SIGSEGV" error, because the SIGSEGV case was generally handled by the caller - usually the architecture fault handler. That results in lots of duplication - all the architecture fault handlers end up doing very similar "look up vma, check permissions, do retries etc" - but it generally works. However, there are cases where the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV. In particular, when accessing the stack guard page, libsigsegv expects a SIGSEGV. And it usually got one, because the stack growth is handled by that duplicated architecture fault handler. However, when the generic VM layer started propagating the error return from the stack expansion in commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page"), that now exposed the existing VM_FAULT_SIGBUS result to user space. And user space really expected SIGSEGV, not SIGBUS. To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those duplicate architecture fault handlers about it. They all already have the code to handle SIGSEGV, so it's about just tying that new return value to the existing code, but it's all a bit annoying. This is the mindless minimal patch to do this. A more extensive patch would be to try to gather up the mostly shared fault handling logic into one generic helper routine, and long-term we really should do that cleanup. Just from this patch, you can generally see that most architectures just copied (directly or indirectly) the old x86 way of doing things, but in the meantime that original x86 model has been improved to hold the VM semaphore for shorter times etc and to handle VM_FAULT_RETRY and other "newer" things, so it would be a good idea to bring all those improvements to the generic case and teach other architectures about them too. Reported-and-tested-by: Takashi Iwai <tiwai@suse.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots" Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [shengyong: Backport to 3.10 - adjust context - ignore modification for arch nios2, because 3.10 does not support it - ignore modification for driver lustre, because 3.10 does not support it - ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support this flag - add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not separate it to copro_fault.c - add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it to gup.c ] Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-19writeback: fix possible underflow in write bandwidth calculationTejun Heo
commit c72efb658f7c8b27ca3d0efb5cfd5ded9fcac89e upstream. From 1ebf33901ecc75d9496862dceb1ef0377980587c Mon Sep 17 00:00:00 2001 From: Tejun Heo <tj@kernel.org> Date: Mon, 23 Mar 2015 00:08:19 -0400 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty") introduced account_page_redirty() which reverts stat updates for a redirtied page, making BDI_DIRTIED no longer monotonically increasing. bdi_update_write_bandwidth() uses the delta in BDI_DIRTIED as the basis for bandwidth calculation. While unlikely, since the above patch, the newer value may be lower than the recorded past value and underflow the bandwidth calculation leading to a wild result. Fix it by subtracing min of the old and new values when calculating delta. AFAIK, there hasn't been any report of it happening but the resulting erratic behavior would be non-critical and temporary, so it's possible that the issue is happening without being reported. The risk of the fix is very low, so tagged for -stable. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Greg Thelen <gthelen@google.com> Fixes: 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty") Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-19writeback: add missing INITIAL_JIFFIES init in global_update_bandwidth()Tejun Heo
commit 7d70e15480c0450d2bfafaad338a32e884fc215e upstream. global_update_bandwidth() uses static variable update_time as the timestamp for the last update but forgets to initialize it to INITIALIZE_JIFFIES. This means that global_dirty_limit will be 5 mins into the future on 32bit and some large amount jiffies into the past on 64bit. This isn't critical as the only effect is that global_dirty_limit won't be updated for the first 5 mins after booting on 32bit machines, especially given the auxiliary nature of global_dirty_limit's role - protecting against global dirty threshold's sudden dips; however, it does lead to unintended suboptimal behavior. Fix it. Fixes: c42843f2f0bb ("writeback: introduce smoothed global dirty limit") Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-19mm/memory hotplug: postpone the reset of obsolete pgdatGu Zheng
commit b0dc3a342af36f95a68fe229b8f0f73552c5ca08 upstream. Qiu Xishi reported the following BUG when testing hot-add/hot-remove node under stress condition: BUG: unable to handle kernel paging request at 0000000000025f60 IP: next_online_pgdat+0x1/0x50 PGD 0 Oops: 0000 [#1] SMP ACPI: Device does not support D3cold Modules linked in: fuse nls_iso8859_1 nls_cp437 vfat fat loop dm_mod coretemp mperf crc32c_intel ghash_clmulni_intel aesni_intel ablk_helper cryptd lrw gf128mul glue_helper aes_x86_64 pcspkr microcode igb dca i2c_algo_bit ipv6 megaraid_sas iTCO_wdt i2c_i801 i2c_core iTCO_vendor_support tg3 sg hwmon ptp lpc_ich pps_core mfd_core acpi_pad rtc_cmos button ext3 jbd mbcache sd_mod crc_t10dif scsi_dh_alua scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh ahci libahci libata scsi_mod [last unloaded: rasf] CPU: 23 PID: 238 Comm: kworker/23:1 Tainted: G O 3.10.15-5885-euler0302 #1 Hardware name: HUAWEI TECHNOLOGIES CO.,LTD. Huawei N1/Huawei N1, BIOS V100R001 03/02/2015 Workqueue: events vmstat_update task: ffffa800d32c0000 ti: ffffa800d32ae000 task.ti: ffffa800d32ae000 RIP: 0010: next_online_pgdat+0x1/0x50 RSP: 0018:ffffa800d32afce8 EFLAGS: 00010286 RAX: 0000000000001440 RBX: ffffffff81da53b8 RCX: 0000000000000082 RDX: 0000000000000000 RSI: 0000000000000082 RDI: 0000000000000000 RBP: ffffa800d32afd28 R08: ffffffff81c93bfc R09: ffffffff81cbdc96 R10: 00000000000040ec R11: 00000000000000a0 R12: ffffa800fffb3440 R13: ffffa800d32afd38 R14: 0000000000000017 R15: ffffa800e6616800 FS: 0000000000000000(0000) GS:ffffa800e6600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000025f60 CR3: 0000000001a0b000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: refresh_cpu_vm_stats+0xd0/0x140 vmstat_update+0x11/0x50 process_one_work+0x194/0x3d0 worker_thread+0x12b/0x410 kthread+0xc6/0xd0 ret_from_fork+0x7c/0xb0 The cause is the "memset(pgdat, 0, sizeof(*pgdat))" at the end of try_offline_node, which will reset all the content of pgdat to 0, as the pgdat is accessed lock-free, so that the users still using the pgdat will panic, such as the vmstat_update routine. process A: offline node XX: vmstat_updat() refresh_cpu_vm_stats() for_each_populated_zone() find online node XX cond_resched() offline cpu and memory, then try_offline_node() node_set_offline(nid), and memset(pgdat, 0, sizeof(*pgdat)) zone = next_zone(zone) pg_data_t *pgdat = zone->zone_pgdat; // here pgdat is NULL now next_online_pgdat(pgdat) next_online_node(pgdat->node_id); // NULL pointer access So the solution here is postponing the reset of obsolete pgdat from try_offline_node() to hotadd_new_pgdat(), and just resetting pgdat->nr_zones and pgdat->classzone_idx to be 0 rather than the memset 0 to avoid breaking pointer information in pgdat. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Reported-by: Xishi Qiu <qiuxishi@huawei.com> Suggested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18mm/memory.c: actually remap enough memoryGrazvydas Ignotas
commit 9cb12d7b4ccaa976f97ce0c5fd0f1b6a83bc2a75 upstream. For whatever reason, generic_access_phys() only remaps one page, but actually allows to access arbitrary size. It's quite easy to trigger large reads, like printing out large structure with gdb, which leads to a crash. Fix it by remapping correct size. Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure") Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18mm/compaction: fix wrong order check in compact_finished()Joonsoo Kim
commit 372549c2a3778fd3df445819811c944ad54609ca upstream. What we want to check here is whether there is highorder freepage in buddy list of other migratetype in order to steal it without fragmentation. But, current code just checks cc->order which means allocation request order. So, this is wrong. Without this fix, non-movable synchronous compaction below pageblock order would not stopped until compaction is complete, because migratetype of most pageblocks are movable and high order freepage made by compaction is usually on movable type buddy list. There is some report related to this bug. See below link. http://www.spinics.net/lists/linux-mm/msg81666.html Although the issued system still has load spike comes from compaction, this makes that system completely stable and responsive according to his report. stress-highalloc test in mmtests with non movable order 7 allocation doesn't show any notable difference in allocation success rate, but, it shows more compaction success rate. Compaction success rate (Compaction success * 100 / Compaction stalls, %) 18.47 : 28.94 Fixes: 1fb3f8ca0e92 ("mm: compaction: capture a suitable high-order page immediately when it is made available") Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18mm/nommu.c: fix arithmetic overflow in __vm_enough_memory()Roman Gushchin
commit 8138a67a5557ffea3a21dfd6f037842d4e748513 upstream. I noticed that "allowed" can easily overflow by falling below 0, because (total_vm / 32) can be larger than "allowed". The problem occurs in OVERCOMMIT_NONE mode. In this case, a huge allocation can success and overcommit the system (despite OVERCOMMIT_NONE mode). All subsequent allocations will fall (system-wide), so system become unusable. The problem was masked out by commit c9b1d0981fcc ("mm: limit growth of 3% hardcoded other user reserve"), but it's easy to reproduce it on older kernels: 1) set overcommit_memory sysctl to 2 2) mmap() large file multiple times (with VM_SHARED flag) 3) try to malloc() large amount of memory It also can be reproduced on newer kernels, but miss-configured sysctl_user_reserve_kbytes is required. Fix this issue by switching to signed arithmetic here. Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Cc: Andrew Shewmaker <agshew@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18mm/mmap.c: fix arithmetic overflow in __vm_enough_memory()Roman Gushchin
commit 5703b087dc8eaf47bfb399d6cf512d471beff405 upstream. I noticed, that "allowed" can easily overflow by falling below 0, because (total_vm / 32) can be larger than "allowed". The problem occurs in OVERCOMMIT_NONE mode. In this case, a huge allocation can success and overcommit the system (despite OVERCOMMIT_NONE mode). All subsequent allocations will fall (system-wide), so system become unusable. The problem was masked out by commit c9b1d0981fcc ("mm: limit growth of 3% hardcoded other user reserve"), but it's easy to reproduce it on older kernels: 1) set overcommit_memory sysctl to 2 2) mmap() large file multiple times (with VM_SHARED flag) 3) try to malloc() large amount of memory It also can be reproduced on newer kernels, but miss-configured sysctl_user_reserve_kbytes is required. Fix this issue by switching to signed arithmetic here. [akpm@linux-foundation.org: use min_t] Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Cc: Andrew Shewmaker <agshew@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-18mm/hugetlb: add migration entry check in __unmap_hugepage_rangeNaoya Horiguchi
commit 9fbc1f635fd0bd28cb32550211bf095753ac637a upstream. If __unmap_hugepage_range() tries to unmap the address range over which hugepage migration is on the way, we get the wrong page because pte_page() doesn't work for migration entries. This patch simply clears the pte for migration entries as we do for hwpoison entries. Fixes: 290408d4a2 ("hugetlb: hugepage migration core") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-11mm: pagewalk: call pte_hole() for VM_PFNMAP during walk_page_rangeShiraz Hashim
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream. walk_page_range() silently skips vma having VM_PFNMAP set, which leads to undesirable behaviour at client end (who called walk_page_range). Userspace applications get the wrong data, so the effect is like just confusing users (if the applications just display the data) or sometimes killing the processes (if the applications do something with misunderstanding virtual addresses due to the wrong data.) For example for pagemap_read, when no callbacks are called against VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual address range at wrong index. Eventually userspace may get wrong pagemap data for a task. Corresponding to a VM_PFNMAP marked vma region, kernel may report mappings from subsequent vma regions. User space in turn may account more pages (than really are) to the task. In my case I was using procmem, procrack (Android utility) which uses pagemap interface to account RSS pages of a task. Due to this bug it was giving a wrong picture for vmas (with VM_PFNMAP set). Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas") Signed-off-by: Shiraz Hashim <shashim@codeaurora.org> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: Don't count the stack guard page towards RLIMIT_STACKLinus Torvalds
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream. Commit fee7e49d4514 ("mm: propagate error from stack expansion even for guard page") made sure that we return the error properly for stack growth conditions. It also theorized that counting the guard page towards the stack limit might break something, but also said "Let's see if anybody notices". Somebody did notice. Apparently android-x86 sets the stack limit very close to the limit indeed, and including the guard page in the rlimit check causes the android 'zygote' process problems. So this adds the (fairly trivial) code to make the stack rlimit check be against the actual real stack size, rather than the size of the vma that includes the guard page. Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org> Cc: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm: propagate error from stack expansion even for guard pageLinus Torvalds
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream. Jay Foad reports that the address sanitizer test (asan) sometimes gets confused by a stack pointer that ends up being outside the stack vma that is reported by /proc/maps. This happens due to an interaction between RLIMIT_STACK and the guard page: when we do the guard page check, we ignore the potential error from the stack expansion, which effectively results in a missing guard page, since the expected stack expansion won't have been done. And since /proc/maps explicitly ignores the guard page (commit d7824370e263: "mm: fix up some user-visible effects of the stack guard page"), the stack pointer ends up being outside the reported stack area. This is the minimal patch: it just propagates the error. It also effectively makes the guard page part of the stack limit, which in turn measn that the actual real stack is one page less than the stack limit. Let's see if anybody notices. We could teach acct_stack_growth() to allow an extra page for a grow-up/grow-down stack in the rlimit test, but I don't want to add more complexity if it isn't needed. Reported-and-tested-by: Jay Foad <jay.foad@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16mm, vmscan: prevent kswapd livelock due to pfmemalloc-throttled process ↵Vlastimil Babka
being killed commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream. Charles Shirron and Paul Cassella from Cray Inc have reported kswapd stuck in a busy loop with nothing left to balance, but kswapd_try_to_sleep() failing to sleep. Their analysis found the cause to be a combination of several factors: 1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait 2. The process has been killed (by OOM in this case), but has not yet been scheduled to remove itself from the waitqueue and die. 3. kswapd checks for throttled processes in prepare_kswapd_sleep(): if (waitqueue_active(&pgdat->pfmemalloc_wait)) { wake_up(&pgdat->pfmemalloc_wait); return false; // kswapd will not go to sleep } However, for a process that was already killed, wake_up() does not remove the process from the waitqueue, since try_to_wake_up() checks its state first and returns false when the process is no longer waiting. 4. kswapd is running on the same CPU as the only CPU that the process is allowed to run on (through cpus_allowed, or possibly single-cpu system). 5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd encounters no voluntary preemption points and repeatedly fails prepare_kswapd_sleep(), blocking the process from running and removing itself from the waitqueue, which would let kswapd sleep. So, the source of the problem is that we prevent kswapd from going to sleep until there are processes waiting on the pfmemalloc_wait queue, and a process waiting on a queue is guaranteed to be removed from the queue only when it gets scheduled. This was done to make sure that no process is left sleeping on pfmemalloc_wait when kswapd itself goes to sleep. However, it isn't necessary to postpone kswapd sleep until the pfmemalloc_wait queue actually empties. To prevent processes from being left sleeping, it's actually enough to guarantee that all processes waiting on pfmemalloc_wait queue have been woken up by the time we put kswapd to sleep. This patch therefore fixes this issue by substituting 'wake_up' with 'wake_up_all' and removing 'return false' in the code snippet from prepare_kswapd_sleep() above. Note that if any process puts itself in the queue after this waitqueue_active() check, or after the wake up itself, it means that the process will also wake up kswapd - and since we are under prepare_to_wait(), the wake up won't be missed. Also we update the comment prepare_kswapd_sleep() to hopefully more clearly describe the races it is preventing. Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage") Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm: fix swapoff hang after page migration and forkHugh Dickins
commit 2022b4d18a491a578218ce7a4eca8666db895a73 upstream. I've been seeing swapoff hangs in recent testing: it's cycling around trying unsuccessfully to find an mm for some remaining pages of swap. I have been exercising swap and page migration more heavily recently, and now notice a long-standing error in copy_one_pte(): it's trying to add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing so even when it's a migration entry or an hwpoison entry. Which wouldn't matter much, except it adds dst_mm next to src_mm, assuming src_mm is already on the mmlist: which may not be so. Then if pages are later swapped out from dst_mm, swapoff won't be able to find where to replace them. There's already a !non_swap_entry() test for stats: move that up before the swap_duplicate() and the addition to mmlist. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kelley Nielsen <kelleynnn@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-16mm: frontswap: invalidate expired data on a dup-store failureWeijie Yang
commit fb993fa1a2f669215fa03a09eed7848f2663e336 upstream. If a frontswap dup-store failed, it should invalidate the expired page in the backend, or it could trigger some data corruption issue. Such as: 1. use zswap as the frontswap backend with writeback feature 2. store a swap page(version_1) to entry A, success 3. dup-store a newer page(version_2) to the same entry A, fail 4. use __swap_writepage() write version_2 page to swapfile, success 5. zswap do shrink, writeback version_1 page to swapfile 6. version_2 page is overwrited by version_1, data corrupt. This patch fixes this issue by invalidating expired data immediately when meet a dup-store failure. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
commit 4942642080ea82d99ab5b653abb9a12b7ba31f4a upstream. Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: do not trap chargers with full callstack on OOMJohannes Weiner
commit 3812c8c8f3953921ef18544110dafc3505c1ac62 upstream. The memcg OOM handling is incredibly fragile and can deadlock. When a task fails to charge memory, it invokes the OOM killer and loops right there in the charge code until it succeeds. Comparably, any other task that enters the charge path at this point will go to a waitqueue right then and there and sleep until the OOM situation is resolved. The problem is that these tasks may hold filesystem locks and the mmap_sem; locks that the selected OOM victim may need to exit. For example, in one reported case, the task invoking the OOM killer was about to charge a page cache page during a write(), which holds the i_mutex. The OOM killer selected a task that was just entering truncate() and trying to acquire the i_mutex: OOM invoking task: mem_cgroup_handle_oom+0x241/0x3b0 mem_cgroup_cache_charge+0xbe/0xe0 add_to_page_cache_locked+0x4c/0x140 add_to_page_cache_lru+0x22/0x50 grab_cache_page_write_begin+0x8b/0xe0 ext3_write_begin+0x88/0x270 generic_file_buffered_write+0x116/0x290 __generic_file_aio_write+0x27c/0x480 generic_file_aio_write+0x76/0xf0 # takes ->i_mutex do_sync_write+0xea/0x130 vfs_write+0xf3/0x1f0 sys_write+0x51/0x90 system_call_fastpath+0x18/0x1d OOM kill victim: do_truncate+0x58/0xa0 # takes i_mutex do_last+0x250/0xa30 path_openat+0xd7/0x440 do_filp_open+0x49/0xa0 do_sys_open+0x106/0x240 sys_open+0x20/0x30 system_call_fastpath+0x18/0x1d The OOM handling task will retry the charge indefinitely while the OOM killed task is not releasing any resources. A similar scenario can happen when the kernel OOM killer for a memcg is disabled and a userspace task is in charge of resolving OOM situations. In this case, ALL tasks that enter the OOM path will be made to sleep on the OOM waitqueue and wait for userspace to free resources or increase the group's limit. But a userspace OOM handler is prone to deadlock itself on the locks held by the waiting tasks. For example one of the sleeping tasks may be stuck in a brk() call with the mmap_sem held for writing but the userspace handler, in order to pick an optimal victim, may need to read files from /proc/<pid>, which tries to acquire the same mmap_sem for reading and deadlocks. This patch changes the way tasks behave after detecting a memcg OOM and makes sure nobody loops or sleeps with locks held: 1. When OOMing in a user fault, invoke the OOM killer and restart the fault instead of looping on the charge attempt. This way, the OOM victim can not get stuck on locks the looping task may hold. 2. When OOMing in a user fault but somebody else is handling it (either the kernel OOM killer or a userspace handler), don't go to sleep in the charge context. Instead, remember the OOMing memcg in the task struct and then fully unwind the page fault stack with -ENOMEM. pagefault_out_of_memory() will then call back into the memcg code to check if the -ENOMEM came from the memcg, and then either put the task to sleep on the memcg's OOM waitqueue or just restart the fault. The OOM victim can no longer get stuck on any lock a sleeping task may hold. Debugged by Michal Hocko. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: azurIt <azurit@pobox.sk> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: rework and document OOM waiting and wakeupJohannes Weiner
commit fb2a6fc56be66c169f8b80e07ed999ba453a2db2 upstream. The memcg OOM handler open-codes a sleeping lock for OOM serialization (trylock, wait, repeat) because the required locking is so specific to memcg hierarchies. However, it would be nice if this construct would be clearly recognizable and not be as obfuscated as it is right now. Clean up as follows: 1. Remove the return value of mem_cgroup_oom_unlock() 2. Rename mem_cgroup_oom_lock() to mem_cgroup_oom_trylock(). 3. Pull the prepare_to_wait() out of the memcg_oom_lock scope. This makes it more obvious that the task has to be on the waitqueue before attempting to OOM-trylock the hierarchy, to not miss any wakeups before going to sleep. It just didn't matter until now because it was all lumped together into the global memcg_oom_lock spinlock section. 4. Pull the mem_cgroup_oom_notify() out of the memcg_oom_lock scope. It is proctected by the hierarchical OOM-lock. 5. The memcg_oom_lock spinlock is only required to propagate the OOM lock in any given hierarchy atomically. Restrict its scope to mem_cgroup_oom_(trylock|unlock). 6. Do not wake up the waitqueue unconditionally at the end of the function. Only the lockholder has to wake up the next in line after releasing the lock. Note that the lockholder kicks off the OOM-killer, which in turn leads to wakeups from the uncharges of the exiting task. But a contender is not guaranteed to see them if it enters the OOM path after the OOM kills but before the lockholder releases the lock. Thus there has to be an explicit wakeup after releasing the lock. 7. Put the OOM task on the waitqueue before marking the hierarchy as under OOM as that is the point where we start to receive wakeups. No point in listening before being on the waitqueue. 8. Likewise, unmark the hierarchy before finishing the sleep, for symmetry. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: enable memcg OOM killer only for user faultsJohannes Weiner
commit 519e52473ebe9db5cdef44670d5a97f1fd53d721 upstream. System calls and kernel faults (uaccess, gup) can handle an out of memory situation gracefully and just return -ENOMEM. Enable the memcg OOM killer only for user faults, where it's really the only option available. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14mm: Remove false WARN_ON from pagecache_isize_extended()Jan Kara
commit f55fefd1a5a339b1bd08c120b93312d6eb64a9fb upstream. The WARN_ON checking whether i_mutex is held in pagecache_isize_extended() was wrong because some filesystems (e.g. XFS) use different locks for serialization of truncates / writes. So just remove the check. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14cgroup/kmemleak: add kmemleak_free() for cgroup deallocations.Wang Nan
commit 401507d67d5c2854f5a88b3f93f64fc6f267bca5 upstream. Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but corresponding kmemleak_free() is missing, which makes kmemleak be wrongly disabled after memory offlining. Log is pasted at the end of this commit message. This patch add kmemleak_free() into free_page_cgroup(). During page offlining, this patch removes corresponding entries in kmemleak rbtree. After that, the freed memory can be allocated again by other subsystems without killing kmemleak. bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak Offlined Pages 32768 kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing) CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 Call Trace: dump_stack+0x46/0x58 create_object+0x266/0x2c0 kmemleak_alloc+0x26/0x50 kmem_cache_alloc+0xd3/0x160 __sigqueue_alloc+0x49/0xd0 __send_signal+0xcb/0x410 send_signal+0x45/0x90 __group_send_sig_info+0x13/0x20 do_notify_parent+0x1bb/0x260 do_exit+0x767/0xa40 do_group_exit+0x44/0xa0 SyS_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b kmemleak: Kernel memory leak detector disabled kmemleak: Object 0xffff880016900000 (size 524288): kmemleak: comm "swapper/0", pid 0, jiffies 4294667296 kmemleak: min_count = 0 kmemleak: count = 0 kmemleak: flags = 0x1 kmemleak: checksum = 0 kmemleak: backtrace: log_early+0x63/0x77 kmemleak_alloc+0x4b/0x50 init_section_page_cgroup+0x7f/0xf5 page_cgroup_init+0xc5/0xd0 start_kernel+0x333/0x408 x86_64_start_reservations+0x2a/0x2c x86_64_start_kernel+0xf5/0xfc Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations) Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14OOM, PM: OOM killed task shouldn't escape PM suspendMichal Hocko
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream. PM freezer relies on having all tasks frozen by the time devices are getting frozen so that no task will touch them while they are getting frozen. But OOM killer is allowed to kill an already frozen task in order to handle OOM situtation. In order to protect from late wake ups OOM killer is disabled after all tasks are frozen. This, however, still keeps a window open when a killed task didn't manage to die by the time freeze_processes finishes. Reduce the race window by checking all tasks after OOM killer has been disabled. This is still not race free completely unfortunately because oom_killer_disable cannot stop an already ongoing OOM killer so a task might still wake up from the fridge and get killed without freeze_processes noticing. Full synchronization of OOM and freezer is, however, too heavy weight for this highly unlikely case. Introduce and check oom_kills counter which gets incremented early when the allocator enters __alloc_pages_may_oom path and only check all the tasks if the counter changes during the freezing attempt. The counter is updated so early to reduce the race window since allocator checked oom_killer_disabled which is set by PM-freezing code. A false positive will push the PM-freezer into a slow path but that is not a big deal. Changes since v1 - push the re-check loop out of freeze_processes into check_frozen_processes and invert the condition to make the code more readable as per Rafael Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring) Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14vfs: fix data corruption when blocksize < pagesize for mmaped dataJan Kara
commit 90a8020278c1598fafd071736a0846b38510309c upstream. ->page_mkwrite() is used by filesystems to allocate blocks under a page which is becoming writeably mmapped in some process' address space. This allows a filesystem to return a page fault if there is not enough space available, user exceeds quota or similar problem happens, rather than silently discarding data later when writepage is called. However VFS fails to call ->page_mkwrite() in all the cases where filesystems need it when blocksize < pagesize. For example when blocksize = 1024, pagesize = 4096 the following is problematic: ftruncate(fd, 0); pwrite(fd, buf, 1024, 0); map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0); map[0] = 'a'; ----> page_mkwrite() for index 0 is called ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */ mremap(map, 1024, 10000, 0); map[4095] = 'a'; ----> no page_mkwrite() called At the moment ->page_mkwrite() is called, filesystem can allocate only one block for the page because i_size == 1024. Otherwise it would create blocks beyond i_size which is generally undesirable. But later at ->writepage() time, we also need to store data at offset 4095 but we don't have block allocated for it. This patch introduces a helper function filesystems can use to have ->page_mkwrite() called at all the necessary moments. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14Revert "percpu: free percpu allocation info for uniprocessor system"Guenter Roeck
commit bb2e226b3bef596dd56be97df655d857b4603923 upstream. This reverts commit 3189eddbcafc ("percpu: free percpu allocation info for uniprocessor system"). The commit causes a hang with a crisv32 image. This may be an architecture problem, but at least for now the revert is necessary to be able to boot a crisv32 image. Cc: Tejun Heo <tj@kernel.org> Cc: Honggang Li <enjoymindful@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 3189eddbcafc ("percpu: free percpu allocation info for uniprocessor system") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09mm: numa: Do not mark PTEs pte_numa when splitting huge pagesMel Gorman
commit abc40bd2eeb77eb7c2effcaf63154aad929a1d5f upstream. This patch reverts 1ba6e0b50b ("mm: numa: split_huge_page: transfer the NUMA type from the pmd to the pte"). If a huge page is being split due a protection change and the tail will be in a PROT_NONE vma then NUMA hinting PTEs are temporarily created in the protected VMA. VM_RW|VM_PROTNONE |-----------------| ^ split here In the specific case above, it should get fixed up by change_pte_range() but there is a window of opportunity for weirdness to happen. Similarly, if a huge page is shrunk and split during a protection update but before pmd_numa is cleared then a pte_numa can be left behind. Instead of adding complexity trying to deal with the case, this patch will not mark PTEs NUMA when splitting a huge page. NUMA hinting faults will not be triggered which is marginal in comparison to the complexity in dealing with the corner cases during THP split. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09mm, thp: move invariant bug check out of loop in __split_huge_page_mapWaiman Long
commit f8303c2582b889351e261ff18c4d8eb197a77db2 upstream. In __split_huge_page_map(), the check for page_mapcount(page) is invariant within the for loop. Because of the fact that the macro is implemented using atomic_read(), the redundant check cannot be optimized away by the compiler leading to unnecessary read to the page structure. This patch moves the invariant bug check out of the loop so that it will be done only once. On a 3.16-rc1 based kernel, the execution time of a microbenchmark that broke up 1000 transparent huge pages using munmap() had an execution time of 38,245us and 38,548us with and without the patch respectively. The performance gain is about 1%. Signed-off-by: Waiman Long <Waiman.Long@hp.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Scott J Norton <scott.norton@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05vm_is_stack: use for_each_thread() rather then buggy while_each_thread()Oleg Nesterov
commit 4449a51a7c281602d3a385044ab928322a122a02 upstream. Aleksei hit the soft lockup during reading /proc/PID/smaps. David investigated the problem and suggested the right fix. while_each_thread() is racy and should die, this patch updates vm_is_stack(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Aleksei Besogonov <alex.besogonov@gmail.com> Tested-by: Aleksei Besogonov <alex.besogonov@gmail.com> Suggested-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05oom_kill: add rcu_read_lock() into find_lock_task_mm()Oleg Nesterov
commit 4d4048be8a93769350efa31d2482a038b7de73d0 upstream. find_lock_task_mm() expects it is called under rcu or tasklist lock, but it seems that at least oom_unkillable_task()->task_in_mem_cgroup() and mem_cgroup_out_of_memory()->oom_badness() can call it lockless. Perhaps we could fix the callers, but this patch simply adds rcu lock into find_lock_task_mm(). This also allows to simplify a bit one of its callers, oom_kill_process(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Sergey Dyasly <dserrg@gmail.com> Cc: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05oom_kill: has_intersects_mems_allowed() needs rcu_read_lock()Oleg Nesterov
commit ad96244179fbd55b40c00f10f399bc04739b8e1f upstream. At least out_of_memory() calls has_intersects_mems_allowed() without even rcu_read_lock(), this is obviously buggy. Add the necessary rcu_read_lock(). This means that we can not simply return from the loop, we need "bool ret" and "break". While at it, swap the names of task_struct's (the argument and the local). This cleans up the code a little bit and avoids the unnecessary initialization. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Reviewed-by: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05oom_kill: change oom_kill.c to use for_each_thread()Oleg Nesterov
commit 1da4db0cd5c8a31d4468ec906b413e75e604b465 upstream. Change oom_kill.c to use for_each_thread() rather than the racy while_each_thread() which can loop forever if we race with exit. Note also that most users were buggy even if while_each_thread() was fine, the task can exit even _before_ rcu_read_lock(). Fortunately the new for_each_thread() only requires the stable task_struct, so this change fixes both problems. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Reviewed-by: Sameer Nanda <snanda@chromium.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05percpu: perform tlb flush after pcpu_map_pages() failureTejun Heo
commit 849f5169097e1ba35b90ac9df76b5bb6f9c0aabd upstream. If pcpu_map_pages() fails midway, it unmaps the already mapped pages. Currently, it doesn't flush tlb after the partial unmapping. This may be okay in most cases as the established mapping hasn't been used at that point but it can go wrong and when it goes wrong it'd be extremely difficult to track down. Flush tlb after the partial unmapping. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05percpu: fix pcpu_alloc_pages() failure pathTejun Heo
commit f0d279654dea22b7a6ad34b9334aee80cda62cde upstream. When pcpu_alloc_pages() fails midway, pcpu_free_pages() is invoked to free what has already been allocated. The invocation is across the whole requested range and pcpu_free_pages() will try to free all non-NULL pages; unfortunately, this is incorrect as pcpu_get_pages_and_bitmap(), unlike what its comment suggests, doesn't clear the pages array and thus the array may have entries from the previous invocations making the partial failure path free incorrect pages. Fix it by open-coding the partial freeing of the already allocated pages. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05percpu: free percpu allocation info for uniprocessor systemHonggang Li
commit 3189eddbcafcc4d827f7f19facbeddec4424eba8 upstream. Currently, only SMP system free the percpu allocation info. Uniprocessor system should free it too. For example, one x86 UML virtual machine with 256MB memory, UML kernel wastes one page memory. Signed-off-by: Honggang Li <enjoymindful@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05shmem: fix nlink for rename overwrite directoryMiklos Szeredi
commit b928095b0a7cff7fb9fcf4c706348ceb8ab2c295 upstream. If overwriting an empty directory with rename, then need to drop the extra nlink. Test prog: #include <stdio.h> #include <fcntl.h> #include <err.h> #include <sys/stat.h> int main(void) { const char *test_dir1 = "test-dir1"; const char *test_dir2 = "test-dir2"; int res; int fd; struct stat statbuf; res = mkdir(test_dir1, 0777); if (res == -1) err(1, "mkdir(\"%s\")", test_dir1); res = mkdir(test_dir2, 0777); if (res == -1) err(1, "mkdir(\"%s\")", test_dir2); fd = open(test_dir2, O_RDONLY); if (fd == -1) err(1, "open(\"%s\")", test_dir2); res = rename(test_dir1, test_dir2); if (res == -1) err(1, "rename(\"%s\", \"%s\")", test_dir1, test_dir2); res = fstat(fd, &statbuf); if (res == -1) err(1, "fstat(%i)", fd); if (statbuf.st_nlink != 0) { fprintf(stderr, "nlink is %lu, should be 0\n", statbuf.st_nlink); return 1; } return 0; } Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-07mm, thp: do not allow thp faults to avoid cpuset restrictionsDavid Rientjes
commit b104a35d32025ca740539db2808aa3385d0f30eb upstream. The page allocator relies on __GFP_WAIT to determine if ALLOC_CPUSET should be set in allocflags. ALLOC_CPUSET controls if a page allocation should be restricted only to the set of allowed cpuset mems. Transparent hugepages clears __GFP_WAIT when defrag is disabled to prevent the fault path from using memory compaction or direct reclaim. Thus, it is unfairly able to allocate outside of its cpuset mems restriction as a side-effect. This patch ensures that ALLOC_CPUSET is only cleared when the gfp mask is truly GFP_ATOMIC by verifying it is also not a thp allocation. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Alex Thorlton <athorlton@sgi.com> Tested-by: Alex Thorlton <athorlton@sgi.com> Cc: Bob Liu <lliubbo@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Hedi Berriche <hedi@sgi.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-31mm: hugetlb: fix copy_hugetlb_page_range()Naoya Horiguchi
commit 0253d634e0803a8376a0d88efee0bf523d8673f9 upstream. Commit 4a705fef9862 ("hugetlb: fix copy_hugetlb_page_range() to handle migration/hwpoisoned entry") changed the order of huge_ptep_set_wrprotect() and huge_ptep_get(), which leads to breakage in some workloads like hugepage-backed heap allocation via libhugetlbfs. This patch fixes it. The test program for the problem is shown below: $ cat heap.c #include <unistd.h> #include <stdlib.h> #include <string.h> #define HPS 0x200000 int main() { int i; char *p = malloc(HPS); memset(p, '1', HPS); for (i = 0; i < 5; i++) { if (!fork()) { memset(p, '2', HPS); p = malloc(HPS); memset(p, '3', HPS); free(p); return 0; } } sleep(1); free(p); return 0; } $ export HUGETLB_MORECORE=yes ; export HUGETLB_NO_PREFAULT= ; hugectl --heap ./heap Fixes 4a705fef9862 ("hugetlb: fix copy_hugetlb_page_range() to handle migration/hwpoisoned entry"), so is applicable to -stable kernels which include it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Guillaume Morin <guillaume@morinfr.org> Suggested-by: Guillaume Morin <guillaume@morinfr.org> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-31slab_common: fix the check for duplicate slab namesMikulas Patocka
commit 694617474e33b8603fc76e090ed7d09376514b1a upstream. The patch 3e374919b314f20e2a04f641ebc1093d758f66a4 is supposed to fix the problem where kmem_cache_create incorrectly reports duplicate cache name and fails. The problem is described in the header of that patch. However, the patch doesn't really fix the problem because of these reasons: * the logic to test for debugging is reversed. It was intended to perform the check only if slub debugging is enabled (which implies that caches with the same parameters are not merged). Therefore, there should be #if !defined(CONFIG_SLUB) || defined(CONFIG_SLUB_DEBUG_ON) The current code has the condition reversed and performs the test if debugging is disabled. * slub debugging may be enabled or disabled based on kernel command line, CONFIG_SLUB_DEBUG_ON is just the default settings. Therefore the test based on definition of CONFIG_SLUB_DEBUG_ON is unreliable. This patch fixes the problem by removing the test "!defined(CONFIG_SLUB_DEBUG_ON)". Therefore, duplicate names are never checked if the SLUB allocator is used. Note to stable kernel maintainers: when backporint this patch, please backport also the patch 3e374919b314f20e2a04f641ebc1093d758f66a4. Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-31slab_common: Do not check for duplicate slab namesChristoph Lameter
commit 3e374919b314f20e2a04f641ebc1093d758f66a4 upstream. SLUB can alias multiple slab kmem_create_requests to one slab cache to save memory and increase the cache hotness. As a result the name of the slab can be stale. Only check the name for duplicates if we are in debug mode where we do not merge multiple caches. This fixes the following problem reported by Jonathan Brassow: The problem with kmem_cache* is this: *) Assume CONFIG_SLUB is set 1) kmem_cache_create(name="foo-a") - creates new kmem_cache structure 2) kmem_cache_create(name="foo-b") - If identical cache characteristics, it will be merged with the previously created cache associated with "foo-a". The cache's refcount will be incremented and an alias will be created via sysfs_slab_alias(). 3) kmem_cache_destroy(<ptr>) - Attempting to destroy cache associated with "foo-a", but instead the refcount is simply decremented. I don't even think the sysfs aliases are ever removed... 4) kmem_cache_create(name="foo-a") - This FAILS because kmem_cache_sanity_check colides with the existing name ("foo-a") associated with the non-removed cache. This is a problem for RAID (specifically dm-raid) because the name used for the kmem_cache_create is ("raid%d-%p", level, mddev). If the cache persists for long enough, the memory address of an old mddev will be reused for a new mddev - causing an identical formulation of the cache name. Even though kmem_cache_destory had long ago been used to delete the old cache, the merging of caches has cause the name and cache of that old instance to be preserved and causes a colision (and thus failure) in kmem_cache_create(). I see this regularly in my testing. Reported-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28shmem: fix splicing from a hole while it's punchedHugh Dickins
commit b1a366500bd537b50c3aad26dc7df083ec03a448 upstream. shmem_fault() is the actual culprit in trinity's hole-punch starvation, and the most significant cause of such problems: since a page faulted is one that then appears page_mapped(), needing unmap_mapping_range() and i_mmap_mutex to be unmapped again. But it is not the only way in which a page can be brought into a hole in the radix_tree while that hole is being punched; and Vlastimil's testing implies that if enough other processors are busy filling in the hole, then shmem_undo_range() can be kept from completing indefinitely. shmem_file_splice_read() is the main other user of SGP_CACHE, which can instantiate shmem pagecache pages in the read-only case (without holding i_mutex, so perhaps concurrently with a hole-punch). Probably it's silly not to use SGP_READ already (using the ZERO_PAGE for holes): which ought to be safe, but might bring surprises - not a change to be rushed. shmem_read_mapping_page_gfp() is an internal interface used by drivers/gpu/drm GEM (and next by uprobes): it should be okay. And shmem_file_read_iter() uses the SGP_DIRTY variant of SGP_CACHE, when called internally by the kernel (perhaps for a stacking filesystem, which might rely on holes to be reserved): it's unclear whether it could be provoked to keep hole-punch busy or not. We could apply the same umbrella as now used in shmem_fault() to shmem_file_splice_read() and the others; but it looks ugly, and use over a range raises questions - should it actually be per page? can these get starved themselves? The origin of this part of the problem is my v3.1 commit d0823576bf4b ("mm: pincer in truncate_inode_pages_range"), once it was duplicated into shmem.c. It seemed like a nice idea at the time, to ensure (barring RCU lookup fuzziness) that there's an instant when the entire hole is empty; but the indefinitely repeated scans to ensure that make it vulnerable. Revert that "enhancement" to hole-punch from shmem_undo_range(), but retain the unproblematic rescanning when it's truncating; add a couple of comments there. Remove the "indices[0] >= end" test: that is now handled satisfactorily by the inner loop, and mem_cgroup_uncharge_start()/end() are too light to be worth avoiding here. But if we do not always loop indefinitely, we do need to handle the case of swap swizzled back to page before shmem_free_swap() gets it: add a retry for that case, as suggested by Konstantin Khlebnikov; and for the case of page swizzled back to swap, as suggested by Johannes Weiner. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Suggested-by: Vlastimil Babka <vbabka@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lukas Czerner <lczerner@redhat.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28shmem: fix faulting into a hole, not taking i_mutexHugh Dickins
commit 8e205f779d1443a94b5ae81aa359cb535dd3021e upstream. Commit f00cdc6df7d7 ("shmem: fix faulting into a hole while it's punched") was buggy: Sasha sent a lockdep report to remind us that grabbing i_mutex in the fault path is a no-no (write syscall may already hold i_mutex while faulting user buffer). We tried a completely different approach (see following patch) but that proved inadequate: good enough for a rational workload, but not good enough against trinity - which forks off so many mappings of the object that contention on i_mmap_mutex while hole-puncher holds i_mutex builds into serious starvation when concurrent faults force the puncher to fall back to single-page unmap_mapping_range() searches of the i_mmap tree. So return to the original umbrella approach, but keep away from i_mutex this time. We really don't want to bloat every shmem inode with a new mutex or completion, just to protect this unlikely case from trinity. So extend the original with wait_queue_head on stack at the hole-punch end, and wait_queue item on the stack at the fault end. This involves further use of i_lock to guard against the races: lockdep has been happy so far, and I see fs/inode.c:unlock_new_inode() holds i_lock around wake_up_bit(), which is comparable to what we do here. i_lock is more convenient, but we could switch to shmem's info->lock. This issue has been tagged with CVE-2014-4171, which will require commit f00cdc6df7d7 and this and the following patch to be backported: we suggest to 3.1+, though in fact the trinity forkbomb effect might go back as far as 2.6.16, when madvise(,,MADV_REMOVE) came in - or might not, since much has changed, with i_mmap_mutex a spinlock before 3.0. Anyone running trinity on 3.0 and earlier? I don't think we need care. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lukas Czerner <lczerner@redhat.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-28shmem: fix faulting into a hole while it's punchedHugh Dickins
commit f00cdc6df7d7cfcabb5b740911e6788cb0802bdb upstream. Trinity finds that mmap access to a hole while it's punched from shmem can prevent the madvise(MADV_REMOVE) or fallocate(FALLOC_FL_PUNCH_HOLE) from completing, until the reader chooses to stop; with the puncher's hold on i_mutex locking out all other writers until it can complete. It appears that the tmpfs fault path is too light in comparison with its hole-punching path, lacking an i_data_sem to obstruct it; but we don't want to slow down the common case. Extend shmem_fallocate()'s existing range notification mechanism, so shmem_fault() can refrain from faulting pages into the hole while it's punched, waiting instead on i_mutex (when safe to sleep; or repeatedly faulting when not). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17cpuset,mempolicy: fix sleeping function called from invalid contextGu Zheng
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream. When runing with the kernel(3.15-rc7+), the follow bug occurs: [ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586 [ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python [ 9969.441175] INFO: lockdep is turned off. [ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85 [ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012 [ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18 [ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c [ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000 [ 9969.974071] Call Trace: [ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66 [ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130 [ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0 [ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210 [ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140 [ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150 [ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40 [ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10 [ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50 [ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40 [ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380 [ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0 [ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20 [ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90 [ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b The cause is that cpuset_mems_allowed() try to take mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in __mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock protection region to protect the access to cpuset only in current_cpuset_is_being_rebound(). So that we can avoid this bug. This patch is a temporary solution that just addresses the bug mentioned above, can not fix the long-standing issue about cpuset.mems rebinding on fork(): "When the forker's task_struct is duplicated (which includes ->mems_allowed) and it races with an update to cpuset_being_rebound in update_tasks_nodemask() then the task's mems_allowed doesn't get updated. And the child task's mems_allowed can be wrong if the cpuset's nodemask changes before the child has been added to the cgroup's tasklist." Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09mm: fix crashes from mbind() merging vmasHugh Dickins
commit d05f0cdcbe6388723f1900c549b4850360545201 upstream. In v2.6.34 commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") introduced vma merging to mbind(), but it should have also changed the convention of passing start vma from queue_pages_range() (formerly check_range()) to new_vma_page(): vma merging may have already freed that structure, resulting in BUG at mm/mempolicy.c:1738 and probably worse crashes. Fixes: 9d8cebd4bcd7 ("mm: fix mbind vma merge problem") Reported-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
