path: root/mm
2012-07-25Merge remote branch 'fsl-linux-sdk/imx_3.0.35' into imx_3.0.35_androidXinyu Chen
Conflicts: arch/arm/configs/imx6_defconfig arch/arm/configs/imx6_updater_defconfig arch/arm/configs/imx6s_defconfig arch/arm/include/asm/dma-mapping.h arch/arm/kernel/smp.c arch/arm/mach-mx6/Kconfig arch/arm/mach-mx6/board-mx6dl_arm2.h arch/arm/mach-mx6/board-mx6dl_sabresd.h arch/arm/mach-mx6/board-mx6q_arm2.c arch/arm/mach-mx6/board-mx6q_arm2.h arch/arm/mach-mx6/board-mx6q_sabreauto.c arch/arm/mach-mx6/board-mx6q_sabreauto.h arch/arm/mach-mx6/board-mx6q_sabrelite.c arch/arm/mach-mx6/board-mx6q_sabresd.c arch/arm/mach-mx6/board-mx6q_sabresd.h arch/arm/mach-mx6/board-mx6sl_arm2.c arch/arm/mach-mx6/board-mx6sl_arm2.h arch/arm/mach-mx6/board-mx6solo_sabreauto.h arch/arm/mach-mx6/bus_freq.c arch/arm/mach-mx6/clock.c arch/arm/mach-mx6/clock_mx6sl.c arch/arm/mach-mx6/cpu.c arch/arm/mach-mx6/crm_regs.h arch/arm/mach-mx6/devices-imx6q.h arch/arm/mach-mx6/devices.c arch/arm/mach-mx6/mx6_anatop_regulator.c arch/arm/mach-mx6/pcie.c arch/arm/mach-mx6/system.c arch/arm/mm/dma-mapping.c arch/arm/plat-mxc/devices/Makefile arch/arm/plat-mxc/devices/platform-imx-dcp.c arch/arm/plat-mxc/devices/platform-imx-ocotp.c arch/arm/plat-mxc/devices/platform-imx-rngb.c arch/arm/plat-mxc/devices/platform-mxc_hdmi.c arch/arm/plat-mxc/include/mach/devices-common.h arch/arm/plat-mxc/include/mach/esdhc.h arch/arm/plat-mxc/include/mach/iomux-mx6dl.h arch/arm/plat-mxc/include/mach/iomux-mx6q.h arch/arm/plat-mxc/include/mach/memory.h arch/arm/plat-mxc/include/mach/mx6.h arch/arm/plat-mxc/include/mach/mxc_edid.h arch/arm/plat-mxc/include/mach/mxc_hdmi.h arch/arm/plat-mxc/system.c drivers/Kconfig drivers/char/hw_random/fsl-rngc.c drivers/cpufreq/Makefile drivers/cpufreq/cpufreq_interactive.c drivers/crypto/Kconfig drivers/crypto/caam/caamalg.c drivers/crypto/caam/compat.h drivers/crypto/caam/ctrl.c drivers/crypto/caam/desc_constr.h drivers/crypto/caam/intern.h drivers/crypto/dcp.c drivers/dma/pch_dma.c drivers/input/keyboard/gpio_keys.c drivers/input/touchscreen/egalax_ts.c drivers/input/touchscreen/max11801_ts.c drivers/media/video/mxc/capture/Kconfig drivers/media/video/mxc/capture/adv7180.c drivers/media/video/mxc/capture/ipu_csi_enc.c drivers/media/video/mxc/capture/ipu_prp_vf_sdc.c drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.c drivers/media/video/mxc/capture/mxc_v4l2_capture.c drivers/media/video/mxc/capture/ov5640_mipi.c drivers/media/video/mxc/output/mxc_vout.c drivers/misc/Kconfig drivers/misc/Makefile drivers/mmc/card/block.c drivers/mmc/core/mmc.c drivers/mmc/host/mmci.c drivers/mmc/host/sdhci-esdhc-imx.c drivers/mmc/host/sdhci.c drivers/mmc/host/sdhci.h drivers/mxc/Kconfig drivers/mxc/Makefile drivers/mxc/asrc/mxc_asrc.c drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_context.c drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_hardware.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_command.c drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_event.c drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal.h drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_base.h drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_options.h drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_os.c drivers/mxc/ipu3/ipu_device.c drivers/mxc/vpu/mxc_vpu.c drivers/net/fec.c drivers/net/wireless/Makefile drivers/power/sabresd_battery.c drivers/regulator/core.c drivers/tty/serial/imx.c drivers/usb/core/hub.c drivers/usb/gadget/arcotg_udc.c drivers/usb/gadget/fsl_updater.c drivers/usb/gadget/inode.c drivers/usb/host/ehci-hub.c drivers/video/mxc/ldb.c drivers/video/mxc/mipi_dsi.c drivers/video/mxc/mxc_dispdrv.c drivers/video/mxc/mxc_dispdrv.h drivers/video/mxc/mxc_edid.c drivers/video/mxc/mxc_elcdif_fb.c drivers/video/mxc/mxc_ipuv3_fb.c drivers/video/mxc/mxc_spdc_fb.c drivers/video/mxc_hdmi.c drivers/watchdog/imx2_wdt.c fs/proc/base.c include/linux/mmc/host.h include/linux/mmc/sdhci.h include/linux/mxc_v4l2.h kernel/power/main.c sound/soc/codecs/mxc_hdmi.c sound/soc/codecs/mxc_spdif.c sound/soc/codecs/wm8962.c sound/soc/imx/Kconfig sound/soc/imx/Makefile sound/soc/imx/imx-cs42888.c sound/soc/imx/imx-esai.c sound/soc/imx/imx-wm8958.c sound/soc/imx/imx-wm8962.c
2012-07-25ENGR00217721-4 implement dma_pool_alloc_nonbufferable interfaceTony LIU
mm core part - After USB driver prime a bulk transfer(whatever IN or OUT, take OUT for example) on ep1, only one dTD is primed, an USB Interrupt (bit 0 of USBSTS) will be issued, and find that endptcomplete register is 0x2 which means an OUT transfer on ep1 is completed, at this time the ep1 out queue head status is 0x1e18000, and next dtd pointer is 0x1 which means transfer is done and everything is OK, while the dTD token status is 0x2008080 which means this dTD is still active, not completed yet. - Audio SDMA and Ethernet have the similar issue - root cause is not found yet - work around: change the non-cacheable bufferable memory to non-cacheable non-bufferable memory to make this issue disappear. Signed-off-by: Tony LIU <junjie.liu@freescale.com>
2012-07-25mm: Hold a file reference in madvise_removeAndy Lutomirski
commit 9ab4233dd08036fe34a89c7dc6f47a8bf2eb29eb upstream. Otherwise the code races with munmap (causing a use-after-free of the vma) or with close (causing a use-after-free of the struct file). The bug was introduced by commit 90ed52ebe481 ("[PATCH] holepunch: fix mmap_sem i_mutex deadlock") [bwh: Backported to 3.2: - Adjust context - madvise_remove() calls vmtruncate_range(), not do_fallocate()] [luto: Backported to 3.0: Adjust context] Cc: Hugh Dickins <hugh@veritas.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-25ENGR00216013-1 memblock: add memblock_end_of_DRAM_with_reserved() function.Zhang Jiejing
add a function to check the end address including reserved memory, this API can provide the top address of phy memory, it can be used to check if the phy memory is valild in some driver like VPU. Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
2012-07-10ENGR00216013-1 memblock: add memblock_end_of_DRAM_with_reserved() function.Zhang Jiejing
2012-06-17hugetlb: fix resv_map leak in error pathDave Hansen
commit c50ac050811d6485616a193eb0f37bfbd191cc89 and 4523e1458566a0e8ecfaff90f380dd23acc44d27 upstream. When called for anonymous (non-shared) mappings, hugetlb_reserve_pages() does a resv_map_alloc(). It depends on code in hugetlbfs's vm_ops->close() to release that allocation. However, in the mmap() failure path, we do a plain unmap_region() without the remove_vma() which actually calls vm_ops->close(). This is a decent fix. This leak could get reintroduced if new code (say, after hugetlb_reserve_pages() in hugetlbfs_file_mmap()) decides to return an error. But, I think it would have to unroll the reservation anyway. Christoph's test case: http://marc.info/?l=linux-mm&m=133728900729735 This patch applies to 3.4 and later. A version for earlier kernels is at https://lkml.org/lkml/2012/5/22/418. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Christoph Lameter <cl@linux.com> Tested-by: Christoph Lameter <cl@linux.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17mm: fix faulty initialization in vmalloc_init()KyongHo
commit dbda591d920b4c7692725b13e3f68ecb251e9080 upstream. The transfer of ->flags causes some of the static mapping virtual addresses to be prematurely freed (before the mapping is removed) because VM_LAZY_FREE gets "set" if tmp->flags has VM_IOREMAP set. This might cause subsequent vmalloc/ioremap calls to fail because it might allocate one of the freed virtual address ranges that aren't unmapped. va->flags has different types of flags from tmp->flags. If a region with VM_IOREMAP set is registered with vm_area_add_early(), it will be removed by __purge_vmap_area_lazy(). Fix vmalloc_init() to correctly initialize vmap_area for the given vm_struct. Also initialise va->vm. If it is not set, find_vm_area() for the early vm regions will always fail. Signed-off-by: KyongHo Cho <pullip.cho@samsung.com> Cc: "Olav Haugan" <ohaugan@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17mm/vmalloc.c: change void* into explict vm_struct*Minchan Kim
commit db1aecafef58b5dda39c4228debe2c845e4a27ab upstream. vmap_area->private is void* but we don't use the field for various purpose but use only for vm_struct. So change it to a vm_struct* with naming to improve for readability and type checking. Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10mm: consider all swapped back pages in used-once logicMichal Hocko
commit e48982734ea0500d1eba4f9d96195acc5406cad6 upstream. Commit 645747462435 ("vmscan: detect mapped file pages used only once") made mapped pages have another round in inactive list because they might be just short lived and so we could consider them again next time. This heuristic helps to reduce pressure on the active list with a streaming IO worklods. This patch fixes a regression introduced by this commit for heavy shmem based workloads because unlike Anon pages, which are excluded from this heuristic because they are usually long lived, shmem pages are handled as a regular page cache. This doesn't work quite well, unfortunately, if the workload is mostly backed by shmem (in memory database sitting on 80% of memory) with a streaming IO in the background (backup - up to 20% of memory). Anon inactive list is full of (dirty) shmem pages when watermarks are hit. Shmem pages are kept in the inactive list (they are referenced) in the first round and it is hard to reclaim anything else so we reach lower scanning priorities very quickly which leads to an excessive swap out. Let's fix this by excluding all swap backed pages (they tend to be long lived wrt. the regular page cache anyway) from used-once heuristic and rather activate them if they are referenced. The customer's workload is shmem backed database (80% of RAM) and they are measuring transactions/s with an IO in the background (20%). Transactions touch more or less random rows in the table. The transaction rate fell by a factor of 3 (in the worst case) because of commit 64574746. This patch restores the previous numbers. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan@kernel.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy linkagesMel Gorman
commit 05f144a0d5c2207a0349348127f996e104ad7404 upstream. Dave Jones' system call fuzz testing tool "trinity" triggered the following bug error with slab debugging enabled ============================================================================= BUG numa_policy (Not tainted): Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154 __slab_alloc+0x3d3/0x445 kmem_cache_alloc+0x29d/0x2b0 mpol_new+0xa3/0x140 sys_mbind+0x142/0x620 system_call_fastpath+0x16/0x1b INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154 __slab_free+0x2e/0x1de kmem_cache_free+0x25a/0x260 __mpol_put+0x27/0x30 remove_vma+0x68/0x90 exit_mmap+0x118/0x140 mmput+0x73/0x110 exit_mm+0x108/0x130 do_exit+0x162/0xb90 do_group_exit+0x4f/0xc0 sys_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080 INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0 This implied a reference counting bug and the problem happened during mbind(). mbind() applies a new memory policy to a range and uses mbind_range() to merge existing VMAs or split them as necessary. In the event of splits, mpol_dup() will allocate a new struct mempolicy and maintain existing reference counts whose rules are documented in Documentation/vm/numa_memory_policy.txt . The problem occurs with shared memory policies. The vm_op->set_policy increments the reference count if necessary and split_vma() and vma_merge() have already handled the existing reference counts. However, policy_vma() screws it up by replacing an existing vma->vm_policy with one that potentially has the wrong reference count leading to a premature free. This patch removes the damage caused by policy_vma(). With this patch applied Dave's trinity tool runs an mbind test for 5 minutes without error. /proc/slabinfo reported that there are no numa_policy or shared_policy_node objects allocated after the test completed and the shared memory region was deleted. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Dave Jones <davej@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Stephen Wilson <wilsons@start.ca> Cc: Christoph Lameter <cl@linux.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21memcg: free spare array to avoid memory leakSha Zhengju
commit 8c7577637ca31385e92769a77e2ab5b428e8b99c upstream. When the last event is unregistered, there is no need to keep the spare array anymore. So free it to avoid memory leak. Signed-off-by: Sha Zhengju <handai.szj@taobao.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21mm: nobootmem: fix sign extend problem in __free_pages_memory()Russ Anderson
commit 6bc2e853c6b46a6041980d58200ad9b0a73a60ff upstream. Systems with 8 TBytes of memory or greater can hit a problem where only the the first 8 TB of memory shows up. This is due to "int i" being smaller than "unsigned long start_aligned", causing the high bits to be dropped. The fix is to change `i' to unsigned long to match start_aligned and end_aligned. Thanks to Jack Steiner for assistance tracking this down. Signed-off-by: Russ Anderson <rja@sgi.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Tejun Heo <tj@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21hugetlb: prevent BUG_ON in hugetlb_fault() -> hugetlb_cow()Chris Metcalf
commit 4998a6c0edce7fae9c0a5463f6ec3fa585258ee7 upstream. Commit 66aebce747eaf ("hugetlb: fix race condition in hugetlb_fault()") added code to avoid a race condition by elevating the page refcount in hugetlb_fault() while calling hugetlb_cow(). However, one code path in hugetlb_cow() includes an assertion that the page count is 1, whereas it may now also have the value 2 in this path. The consensus is that this BUG_ON has served its purpose, so rather than extending it to cover both cases, we just remove it. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Hillf Danton <dhillf@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21percpu: pcpu_embed_first_chunk() should free unused parts after all allocs ↵Tejun Heo
are complete commit 42b64281453249dac52861f9b97d18552a7ec62b upstream. pcpu_embed_first_chunk() allocates memory for each node, copies percpu data and frees unused portions of it before proceeding to the next group. This assumes that allocations for different nodes doesn't overlap; however, depending on memory topology, the bootmem allocator may end up allocating memory from a different node than the requested one which may overlap with the portion freed from one of the previous percpu areas. This leads to percpu groups for different nodes overlapping which is a serious bug. This patch separates out copy & partial free from the allocation loop such that all allocations are complete before partial frees happen. This also fixes overlapping frees which could happen on allocation failure path - out_free_areas path frees whole groups but the groups could have portions freed at that point. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Pavel V. Panteleev" <pp_84@mail.ru> Tested-by: "Pavel V. Panteleev" <pp_84@mail.ru> LKML-Reference: <E1SNhwY-0007ui-V7.pp_84-mail-ru@f220.mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27mm: fix s390 BUG by __set_page_dirty_no_writeback on swapHugh Dickins
commit aca50bd3b4c4bb5528a1878158ba7abce41de534 upstream. Mel reports a BUG_ON(slot == NULL) in radix_tree_tag_set() on s390 3.0.13: called from __set_page_dirty_nobuffers() when page_remove_rmap() tries to transfer dirty flag from s390 storage key to struct page and radix_tree. That would be because of reclaim's shrink_page_list() calling add_to_swap() on this page at the same time: first PageSwapCache is set (causing page_mapping(page) to appear as &swapper_space), then page->private set, then tree_lock taken, then page inserted into radix_tree - so there's an interval before taking the lock when the radix_tree slot is empty. We could fix this by moving __add_to_swap_cache()'s spin_lock_irq up before the SetPageSwapCache. But a better fix is simply to do what's five years overdue: Ken Chen introduced __set_page_dirty_no_writeback() (if !PageDirty TestSetPageDirty) for tmpfs to skip all the radix_tree overhead, and swap is just the same - it ignores the radix_tree tag, and does not participate in dirty page accounting, so should be using __set_page_dirty_no_writeback() too. s390 testing now confirms that this does indeed fix the problem. Reported-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ken Chen <kenchen@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22hugetlb: fix race condition in hugetlb_fault()Chris Metcalf
commit 66aebce747eaf9bc456bf1f1b217d8db843031d0 upstream. The race is as follows: Suppose a multi-threaded task forks a new process (on cpu A), thus bumping up the ref count on all the pages. While the fork is occurring (and thus we have marked all the PTEs as read-only), another thread in the original process (on cpu B) tries to write to a huge page, taking an access violation from the write-protect and calling hugetlb_cow(). Now, suppose the fork() fails. It will undo the COW and decrement the ref count on the pages, so the ref count on the huge page drops back to 1. Meanwhile hugetlb_cow() also decrements the ref count by one on the original page, since the original address space doesn't need it any more, having copied a new page to replace the original page. This leaves the ref count at zero, and when we call unlock_page(), we panic. fork on CPU A fault on CPU B ============= ============== ... down_write(&parent->mmap_sem); down_write_nested(&child->mmap_sem); ... while duplicating vmas if error break; ... up_write(&child->mmap_sem); up_write(&parent->mmap_sem); ... down_read(&parent->mmap_sem); ... lock_page(page); handle COW page_mapcount(old_page) == 2 alloc and prepare new_page ... handle error page_remove_rmap(page); put_page(page); ... fold new_page into pte page_remove_rmap(page); put_page(page); ... oops ==> unlock_page(page); up_read(&parent->mmap_sem); The solution is to take an extra reference to the page while we are holding the lock on it. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-05slub: fix a possible memleak in __slab_alloc()Eric Dumazet
commit 73736e0387ba0e6d2b703407b4d26168d31516a7 upstream. Zhihua Che reported a possible memleak in slub allocator on CONFIG_PREEMPT=y builds. It is possible current thread migrates right before disabling irqs in __slab_alloc(). We must check again c->freelist, and perform a normal allocation instead of scratching c->freelist. Many thanks to Zhihua Che for spotting this bug, introduced in 2.6.39 V2: Its also possible an IRQ freed one (or several) object(s) and populated c->freelist, so its not a CONFIG_PREEMPT only problem. Reported-by: Zhihua Che <zhihua.che@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02slub: Do not hold slub_lock when calling sysfs_slab_add()Christoph Lameter
commit 66c4c35c6bc5a1a452b024cf0364635b28fd94e4 upstream. sysfs_slab_add() calls various sysfs functions that actually may end up in userspace doing all sorts of things. Release the slub_lock after adding the kmem_cache structure to the list. At that point the address of the kmem_cache is not known so we are guaranteed exlusive access to the following modifications to the kmem_cache structure. If the sysfs_slab_add fails then reacquire the slub_lock to remove the kmem_cache structure from the list. Reported-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02bootmem/sparsemem: remove limit constraint in alloc_bootmem_sectionNishanth Aravamudan
commit f5bf18fa22f8c41a13eb8762c7373eb3a93a7333 upstream. While testing AMS (Active Memory Sharing) / CMO (Cooperative Memory Overcommit) on powerpc, we tripped the following: kernel BUG at mm/bootmem.c:483! cpu 0x0: Vector: 700 (Program Check) at [c000000000c03940] pc: c000000000a62bd8: .alloc_bootmem_core+0x90/0x39c lr: c000000000a64bcc: .sparse_early_usemaps_alloc_node+0x84/0x29c sp: c000000000c03bc0 msr: 8000000000021032 current = 0xc000000000b0cce0 paca = 0xc000000001d80000 pid = 0, comm = swapper kernel BUG at mm/bootmem.c:483! enter ? for help [c000000000c03c80] c000000000a64bcc .sparse_early_usemaps_alloc_node+0x84/0x29c [c000000000c03d50] c000000000a64f10 .sparse_init+0x12c/0x28c [c000000000c03e20] c000000000a474f4 .setup_arch+0x20c/0x294 [c000000000c03ee0] c000000000a4079c .start_kernel+0xb4/0x460 [c000000000c03f90] c000000000009670 .start_here_common+0x1c/0x2c This is BUG_ON(limit && goal + size > limit); and after some debugging, it seems that goal = 0x7ffff000000 limit = 0x80000000000 and sparse_early_usemaps_alloc_node -> sparse_early_usemaps_alloc_pgdat_section calls return alloc_bootmem_section(usemap_size() * count, section_nr); This is on a system with 8TB available via the AMS pool, and as a quirk of AMS in firmware, all of that memory shows up in node 0. So, we end up with an allocation that will fail the goal/limit constraints. In theory, we could "fall-back" to alloc_bootmem_node() in sparse_early_usemaps_alloc_node(), but since we actually have HOTREMOVE defined, we'll BUG_ON() instead. A simple solution appears to be to unconditionally remove the limit condition in alloc_bootmem_section, meaning allocations are allowed to cross section boundaries (necessary for systems of this size). Johannes Weiner pointed out that if alloc_bootmem_section() no longer guarantees section-locality, we need check_usemap_section_nr() to print possible cross-dependencies between node descriptors and the usemaps allocated through it. That makes the two loops in sparse_early_usemaps_alloc_node() identical, so re-factor the code a bit. [akpm@linux-foundation.org: code simplification] Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Anton Blanchard <anton@au1.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02mm: thp: fix pmd_bad() triggering in code paths holding mmap_sem read modeAndrea Arcangeli
commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream. In some cases it may happen that pmd_none_or_clear_bad() is called with the mmap_sem hold in read mode. In those cases the huge page faults can allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a false positive from pmd_bad() that will not like to see a pmd materializing as trans huge. It's not khugepaged causing the problem, khugepaged holds the mmap_sem in write mode (and all those sites must hold the mmap_sem in read mode to prevent pagetables to go away from under them, during code review it seems vm86 mode on 32bit kernels requires that too unless it's restricted to 1 thread per process or UP builds). The race is only with the huge pagefaults that can convert a pmd_none() into a pmd_trans_huge(). Effectively all these pmd_none_or_clear_bad() sites running with mmap_sem in read mode are somewhat speculative with the page faults, and the result is always undefined when they run simultaneously. This is probably why it wasn't common to run into this. For example if the madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page fault, the hugepage will not be zapped, if the page fault runs first it will be zapped. Altering pmd_bad() not to error out if it finds hugepmds won't be enough to fix this, because zap_pmd_range would then proceed to call zap_pte_range (which would be incorrect if the pmd become a pmd_trans_huge()). The simplest way to fix this is to read the pmd in the local stack (regardless of what we read, no need of actual CPU barriers, only compiler barrier needed), and be sure it is not changing under the code that computes its value. Even if the real pmd is changing under the value we hold on the stack, we don't care. If we actually end up in zap_pte_range it means the pmd was not none already and it was not huge, and it can't become huge from under us (khugepaged locking explained above). All we need is to enforce that there is no way anymore that in a code path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad can run into a hugepmd. The overhead of a barrier() is just a compiler tweak and should not be measurable (I only added it for THP builds). I don't exclude different compiler versions may have prevented the race too by caching the value of *pmd on the stack (that hasn't been verified, but it wouldn't be impossible considering pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines and there's no external function called in between pmd_trans_huge and pmd_none_or_clear_bad). if (pmd_trans_huge(*pmd)) { if (next-addr != HPAGE_PMD_SIZE) { VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem)); split_huge_page_pmd(vma->vm_mm, pmd); } else if (zap_huge_pmd(tlb, vma, pmd, addr)) continue; /* fall through */ } if (pmd_none_or_clear_bad(pmd)) Because this race condition could be exercised without special privileges this was reported in CVE-2012-1179. The race was identified and fully explained by Ulrich who debugged it. I'm quoting his accurate explanation below, for reference. ====== start quote ======= mapcount 0 page_mapcount 1 kernel BUG at mm/huge_memory.c:1384! At some point prior to the panic, a "bad pmd ..." message similar to the following is logged on the console: mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7). The "bad pmd ..." message is logged by pmd_clear_bad() before it clears the page's PMD table entry. 143 void pmd_clear_bad(pmd_t *pmd) 144 { -> 145 pmd_ERROR(*pmd); 146 pmd_clear(pmd); 147 } After the PMD table entry has been cleared, there is an inconsistency between the actual number of PMD table entries that are mapping the page and the page's map count (_mapcount field in struct page). When the page is subsequently reclaimed, __split_huge_page() detects this inconsistency. 1381 if (mapcount != page_mapcount(page)) 1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n", 1383 mapcount, page_mapcount(page)); -> 1384 BUG_ON(mapcount != page_mapcount(page)); The root cause of the problem is a race of two threads in a multithreaded process. Thread B incurs a page fault on a virtual address that has never been accessed (PMD entry is zero) while Thread A is executing an madvise() system call on a virtual address within the same 2 MB (huge page) range. virtual address space .---------------------. | | | | .-|---------------------| | | | | | |<-- B(fault) | | | 2 MB | |/////////////////////|-. huge < |/////////////////////| > A(range) page | |/////////////////////|-' | | | | | | '-|---------------------| | | | | '---------------------' - Thread A is executing an madvise(..., MADV_DONTNEED) system call on the virtual address range "A(range)" shown in the picture. sys_madvise // Acquire the semaphore in shared mode. down_read(&current->mm->mmap_sem) ... madvise_vma switch (behavior) case MADV_DONTNEED: madvise_dontneed zap_page_range unmap_vmas unmap_page_range zap_pud_range zap_pmd_range // // Assume that this huge page has never been accessed. // I.e. content of the PMD entry is zero (not mapped). // if (pmd_trans_huge(*pmd)) { // We don't get here due to the above assumption. } // // Assume that Thread B incurred a page fault and .---------> // sneaks in here as shown below. | // | if (pmd_none_or_clear_bad(pmd)) | { | if (unlikely(pmd_bad(*pmd))) | pmd_clear_bad | { | pmd_ERROR | // Log "bad pmd ..." message here. | pmd_clear | // Clear the page's PMD entry. | // Thread B incremented the map count | // in page_add_new_anon_rmap(), but | // now the page is no longer mapped | // by a PMD entry (-> inconsistency). | } | } | v - Thread B is handling a page fault on virtual address "B(fault)" shown in the picture. ... do_page_fault __do_page_fault // Acquire the semaphore in shared mode. down_read_trylock(&mm->mmap_sem) ... handle_mm_fault if (pmd_none(*pmd) && transparent_hugepage_enabled(vma)) // We get here due to the above assumption (PMD entry is zero). do_huge_pmd_anonymous_page alloc_hugepage_vma // Allocate a new transparent huge page here. ... __do_huge_pmd_anonymous_page ... spin_lock(&mm->page_table_lock) ... page_add_new_anon_rmap // Here we increment the page's map count (starts at -1). atomic_set(&page->_mapcount, 0) set_pmd_at // Here we set the page's PMD entry which will be cleared // when Thread A calls pmd_clear_bad(). ... spin_unlock(&mm->page_table_lock) The mmap_sem does not prevent the race because both threads are acquiring it in shared mode (down_read). Thread B holds the page_table_lock while the page's map count and PMD table entry are updated. However, Thread A does not synchronize on that lock. ====== end quote ======= [akpm@linux-foundation.org: checkpatch fixes] Reported-by: Ulrich Obergfell <uobergfe@redhat.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Jones <davej@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mm: thp: fix BUG on mm->nr_ptesAndrea Arcangeli
commit 1c641e84719429bbfe62a95ed3545ee7fe24408f upstream. Dave Jones reports a few Fedora users hitting the BUG_ON(mm->nr_ptes...) in exit_mmap() recently. Quoting Hugh's discovery and explanation of the SMP race condition: "mm->nr_ptes had unusual locking: down_read mmap_sem plus page_table_lock when incrementing, down_write mmap_sem (or mm_users 0) when decrementing; whereas THP is careful to increment and decrement it under page_table_lock. Now most of those paths in THP also hold mmap_sem for read or write (with appropriate checks on mm_users), but two do not: when split_huge_page() is called by hwpoison_user_mappings(), and when called by add_to_swap(). It's conceivable that the latter case is responsible for the exit_mmap() BUG_ON mm->nr_ptes that has been reported on Fedora." The simplest way to fix it without having to alter the locking is to make split_huge_page() a noop in nr_ptes terms, so by counting the preallocated pagetables that exists for every mapped hugepage. It was an arbitrary choice not to count them and either way is not wrong or right, because they are not used but they're still allocated. Reported-by: Dave Jones <davej@redhat.com> Reported-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12NOMMU: Don't need to clear vm_mm when deleting a VMADavid Howells
commit b94cfaf6685d691dc3fab023cf32f65e9b7be09c upstream. Don't clear vm_mm in a deleted VMA as it's unnecessary and might conceivably break the filesystem or driver VMA close routine. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12mm: memcg: Correct unregistring of events attached to the same eventfdAnton Vorontsov
commit 371528caec553785c37f73fa3926ea0de84f986f upstream. There is an issue when memcg unregisters events that were attached to the same eventfd: - On the first call mem_cgroup_usage_unregister_event() removes all events attached to a given eventfd, and if there were no events left, thresholds->primary would become NULL; - Since there were several events registered, cgroups core will call mem_cgroup_usage_unregister_event() again, but now kernel will oops, as the function doesn't expect that threshold->primary may be NULL. That's a good question whether mem_cgroup_usage_unregister_event() should actually remove all events in one go, but nowadays it can't do any better as cftype->unregister_event callback doesn't pass any private event-associated cookie. So, let's fix the issue by simply checking for threshold->primary. FWIW, w/o the patch the following oops may be observed: BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffff810be32c>] mem_cgroup_usage_unregister_event+0x9c/0x1f0 Pid: 574, comm: kworker/0:2 Not tainted 3.3.0-rc4+ #9 Bochs Bochs RIP: 0010:[<ffffffff810be32c>] [<ffffffff810be32c>] mem_cgroup_usage_unregister_event+0x9c/0x1f0 RSP: 0018:ffff88001d0b9d60 EFLAGS: 00010246 Process kworker/0:2 (pid: 574, threadinfo ffff88001d0b8000, task ffff88001de91cc0) Call Trace: [<ffffffff8107092b>] cgroup_event_remove+0x2b/0x60 [<ffffffff8103db94>] process_one_work+0x174/0x450 [<ffffffff8103e413>] worker_thread+0x123/0x2d0 Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kirill A. Shutemov <kirill@shutemov.name> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29NOMMU: Lock i_mmap_mutex for access to the VMA prio listDavid Howells
commit 918e556ec214ed2f584e4cac56d7b29e4bb6bf27 upstream. Lock i_mmap_mutex for access to the VMA prio list to prevent concurrent access. Currently, certain parts of the mmap handling are protected by the region mutex, but not all. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20slub: fix a possible memleak in __slab_alloc()Eric Dumazet
2012-02-13mm: fix UP THP spin_is_locked BUGsHugh Dickins
commit b9980cdcf2524c5fe15d8cbae9c97b3ed6385563 upstream. Fix CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_SMP=n CONFIG_DEBUG_VM=y CONFIG_DEBUG_SPINLOCK=n kernel: spin_is_locked() is then always false, and so triggers some BUGs in Transparent HugePage codepaths. asm-generic/bug.h mentions this problem, and provides a WARN_ON_SMP(x); but being too lazy to add VM_BUG_ON_SMP, BUG_ON_SMP, WARN_ON_SMP_ONCE, VM_WARN_ON_SMP_ONCE, just test NR_CPUS != 1 in the existing VM_BUG_ONs. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13mm: compaction: check for overlapping nodes during isolation for migrationMel Gorman
commit dc9086004b3d5db75997a645b3fe08d9138b7ad0 upstream. When isolating pages for migration, migration starts at the start of a zone while the free scanner starts at the end of the zone. Migration avoids entering a new zone by never going beyond the free scanned. Unfortunately, in very rare cases nodes can overlap. When this happens, migration isolates pages without the LRU lock held, corrupting lists which will trigger errors in reclaim or during page free such as in the following oops BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff810f795c>] free_pcppages_bulk+0xcc/0x450 PGD 1dda554067 PUD 1e1cb58067 PMD 0 Oops: 0000 [#1] SMP CPU 37 Pid: 17088, comm: memcg_process_s Tainted: G X RIP: free_pcppages_bulk+0xcc/0x450 Process memcg_process_s (pid: 17088, threadinfo ffff881c2926e000, task ffff881c2926c0c0) Call Trace: free_hot_cold_page+0x17e/0x1f0 __pagevec_free+0x90/0xb0 release_pages+0x22a/0x260 pagevec_lru_move_fn+0xf3/0x110 putback_lru_page+0x66/0xe0 unmap_and_move+0x156/0x180 migrate_pages+0x9e/0x1b0 compact_zone+0x1f3/0x2f0 compact_zone_order+0xa2/0xe0 try_to_compact_pages+0xdf/0x110 __alloc_pages_direct_compact+0xee/0x1c0 __alloc_pages_slowpath+0x370/0x830 __alloc_pages_nodemask+0x1b1/0x1c0 alloc_pages_vma+0x9b/0x160 do_huge_pmd_anonymous_page+0x160/0x270 do_page_fault+0x207/0x4c0 page_fault+0x25/0x30 The "X" in the taint flag means that external modules were loaded but but is unrelated to the bug triggering. The real problem was because the PFN layout looks like this Zone PFN ranges: DMA 0x00000010 -> 0x00001000 DMA32 0x00001000 -> 0x00100000 Normal 0x00100000 -> 0x01e80000 Movable zone start PFN for each node early_node_map[14] active PFN ranges 0: 0x00000010 -> 0x0000009b 0: 0x00000100 -> 0x0007a1ec 0: 0x0007a354 -> 0x0007a379 0: 0x0007f7ff -> 0x0007f800 0: 0x00100000 -> 0x00680000 1: 0x00680000 -> 0x00e80000 0: 0x00e80000 -> 0x01080000 1: 0x01080000 -> 0x01280000 0: 0x01280000 -> 0x01480000 1: 0x01480000 -> 0x01680000 0: 0x01680000 -> 0x01880000 1: 0x01880000 -> 0x01a80000 0: 0x01a80000 -> 0x01c80000 1: 0x01c80000 -> 0x01e80000 The fix is straight-forward. isolate_migratepages() has to make a similar check to isolate_freepage to ensure that it never isolates pages from a zone it does not hold the LRU lock for. This was discovered in a 3.0-based kernel but it affects 3.1.x, 3.2.x and current mainline. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13mm: compaction: check pfn_valid when entering a new MAX_ORDER_NR_PAGES block ↵Mel Gorman
during isolation for migration commit 0bf380bc70ecba68cb4d74dc656cc2fa8c4d801a upstream. When isolating for migration, migration starts at the start of a zone which is not necessarily pageblock aligned. Further, it stops isolating when COMPACT_CLUSTER_MAX pages are isolated so migrate_pfn is generally not aligned. This allows isolate_migratepages() to call pfn_to_page() on an invalid PFN which can result in a crash. This was originally reported against a 3.0-based kernel with the following trace in a crash dump. PID: 9902 TASK: d47aecd0 CPU: 0 COMMAND: "memcg_process_s" #0 [d72d3ad0] crash_kexec at c028cfdb #1 [d72d3b24] oops_end at c05c5322 #2 [d72d3b38] __bad_area_nosemaphore at c0227e60 #3 [d72d3bec] bad_area at c0227fb6 #4 [d72d3c00] do_page_fault at c05c72ec #5 [d72d3c80] error_code (via page_fault) at c05c47a4 EAX: 00000000 EBX: 000c0000 ECX: 00000001 EDX: 00000807 EBP: 000c0000 DS: 007b ESI: 00000001 ES: 007b EDI: f3000a80 GS: 6f50 CS: 0060 EIP: c030b15a ERR: ffffffff EFLAGS: 00010002 #6 [d72d3cb4] isolate_migratepages at c030b15a #7 [d72d3d14] zone_watermark_ok at c02d26cb #8 [d72d3d2c] compact_zone at c030b8de #9 [d72d3d68] compact_zone_order at c030bba1 #10 [d72d3db4] try_to_compact_pages at c030bc84 #11 [d72d3ddc] __alloc_pages_direct_compact at c02d61e7 #12 [d72d3e08] __alloc_pages_slowpath at c02d66c7 #13 [d72d3e78] __alloc_pages_nodemask at c02d6a97 #14 [d72d3eb8] alloc_pages_vma at c030a845 #15 [d72d3ed4] do_huge_pmd_anonymous_page at c03178eb #16 [d72d3f00] handle_mm_fault at c02f36c6 #17 [d72d3f30] do_page_fault at c05c70ed #18 [d72d3fb0] error_code (via page_fault) at c05c47a4 EAX: b71ff000 EBX: 00000001 ECX: 00001600 EDX: 00000431 DS: 007b ESI: 08048950 ES: 007b EDI: bfaa3788 SS: 007b ESP: bfaa36e0 EBP: bfaa3828 GS: 6f50 CS: 0073 EIP: 080487c8 ERR: ffffffff EFLAGS: 00010202 It was also reported by Herbert van den Bergh against 3.1-based kernel with the following snippet from the console log. BUG: unable to handle kernel paging request at 01c00008 IP: [<c0522399>] isolate_migratepages+0x119/0x390 *pdpt = 000000002f7ce001 *pde = 0000000000000000 It is expected that it also affects 3.2.x and current mainline. The problem is that pfn_valid is only called on the first PFN being checked and that PFN is not necessarily aligned. Lets say we have a case like this H = MAX_ORDER_NR_PAGES boundary | = pageblock boundary m = cc->migrate_pfn f = cc->free_pfn o = memory hole H------|------H------|----m-Hoooooo|ooooooH-f----|------H The migrate_pfn is just below a memory hole and the free scanner is beyond the hole. When isolate_migratepages started, it scans from migrate_pfn to migrate_pfn+pageblock_nr_pages which is now in a memory hole. It checks pfn_valid() on the first PFN but then scans into the hole where there are not necessarily valid struct pages. This patch ensures that isolate_migratepages calls pfn_valid when necessary. Reported-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com> Tested-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13mm/filemap_xip.c: fix race condition in xip_file_fault()Carsten Otte
commit 99f02ef1f18631eb0a4e0ea0a3d56878dbcb4b90 upstream. Fix a race condition that shows in conjunction with xip_file_fault() when two threads of the same user process fault on the same memory page. In this case, the race winner will install the page table entry and the unlucky loser will cause an oops: xip_file_fault calls vm_insert_pfn (via vm_insert_mixed) which drops out at this check: retval = -EBUSY; if (!pte_none(*pte)) goto out_unlock; The resulting -EBUSY return value will trigger a BUG_ON() in xip_file_fault. This fix simply considers the fault as fixed in this case, because the race winner has successfully installed the pte. [akpm@linux-foundation.org: use conventional (and consistent) comment layout] Reported-by: David Sadler <dsadler@us.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Reported-by: Louis Alex Eisner <leisner@cs.ucsd.edu> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13readahead: fix pipeline break caused by block plugShaohua Li
commit 3deaa7190a8da38453c4fabd9dec7f66d17fff67 upstream. Herbert Poetzl reported a performance regression since 2.6.39. The test is a simple dd read, but with big block size. The reason is: T1: ra (A, A+128k), (A+128k, A+256k) T2: lock_page for page A, submit the 256k T3: hit page A+128K, ra (A+256k, A+384). the range isn't submitted because of plug and there isn't any lock_page till we hit page A+256k because all pages from A to A+256k is in memory T4: hit page A+256k, ra (A+384, A+ 512). Because of plug, the range isn't submitted again. T5: lock_page A+256k, so (A+256k, A+512k) will be submitted. The task is waitting for (A+256k, A+512k) finish. There is no request to disk in T3 and T4, so readahead pipeline breaks. We really don't need block plug for generic_file_aio_read() for buffered I/O. The readahead already has plug and has fine grained control when I/O should be submitted. Deleting plug for buffered I/O fixes the regression. One side effect is plug makes the request size 256k, the size is 128k without it. This is because default ra size is 128k and not a reason we need plug here. Vivek said: : We submit some readahead IO to device request queue but because of nested : plug, queue never gets unplugged. When read logic reaches a page which is : not in page cache, it waits for page to be read from the disk : (lock_page_killable()) and that time we flush the plug list. : : So effectively read ahead logic is kind of broken in parts because of : nested plugging. Removing top level plug (generic_file_aio_read()) for : buffered reads, will allow unplugging queue earlier for readahead. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Reported-by: Herbert Poetzl <herbert@13thfloor.at> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02Merge branch 'android-3.0' into imx_3.0.15_androidXinyu Chen
Conflicts: drivers/misc/Kconfig drivers/misc/Makefile drivers/net/wireless/Makefile kernel/power/main.c sound/soc/soc-core.c
2012-01-25mm: fix NULL ptr dereference in __count_immobile_pagesMichal Hocko
commit 687875fb7de4a95223af20ee024282fa9099f860 upstream. Fix the following NULL ptr dereference caused by cat /sys/devices/system/memory/memory0/removable Pid: 13979, comm: sed Not tainted 3.0.13-0.5-default #1 IBM BladeCenter LS21 -[7971PAM]-/Server Blade RIP: __count_immobile_pages+0x4/0x100 Process sed (pid: 13979, threadinfo ffff880221c36000, task ffff88022e788480) Call Trace: is_pageblock_removable_nolock+0x34/0x40 is_mem_section_removable+0x74/0xf0 show_mem_removable+0x41/0x70 sysfs_read_file+0xfe/0x1c0 vfs_read+0xc7/0x130 sys_read+0x53/0xa0 system_call_fastpath+0x16/0x1b We are crashing because we are trying to dereference NULL zone which came from pfn=0 (struct page ffffea0000000000). According to the boot log this page is marked reserved: e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) and early_node_map confirms that: early_node_map[3] active PFN ranges 1: 0x00000010 -> 0x0000009c 1: 0x00000100 -> 0x000bffa3 1: 0x00100000 -> 0x00240000 The problem is that memory_present works in PAGE_SECTION_MASK aligned blocks so the reserved range sneaks into the the section as well. This also means that free_area_init_node will not take care of those reserved pages and they stay uninitialized. When we try to read the removable status we walk through all available sections and hope that the zone is valid for all pages in the section. But this is not true in this case as the zone and nid are not initialized. We have only one node in this particular case and it is marked as node=1 (rather than 0) and that made the problem visible because page_to_nid will return 0 and there are no zones on the node. Let's check that the zone is valid and that the given pfn falls into its boundaries and mark the section not removable. This might cause some false positives, probably, but we do not have any sane way to find out whether the page is reserved by the platform or it is just not used for whatever other reasons. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25memcg: add mem_cgroup_replace_page_cache() to fix LRU issueKAMEZAWA Hiroyuki
commit ab936cbcd02072a34b60d268f94440fd5cf1970b upstream. Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a function replace_page_cache_page(). This function replaces a page in the radix-tree with a new page. WHen doing this, memory cgroup needs to fix up the accounting information. memcg need to check PCG_USED bit etc. In some(many?) cases, 'newpage' is on LRU before calling replace_page_cache(). So, memcg's LRU accounting information should be fixed, too. This patch adds mem_cgroup_replace_page_cache() and removes the old hooks. In that function, old pages will be unaccounted without touching res_counter and new page will be accounted to the memcg (of old page). WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid races with LRU handling. Background: replace_page_cache_page() is called by FUSE code in its splice() handling. Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated page and may be on LRU. LRU mis-accounting will be critical for memory cgroup because rmdir() checks the whole LRU is empty and there is no account leak. If a page is on the other LRU than it should be, rmdir() will fail. This bug was added in March 2011, but no bug report yet. I guess there are not many people who use memcg and FUSE at the same time with upstream kernels. The result of this bug is that admin cannot destroy a memcg because of account leak. So, no panic, no deadlock. And, even if an active cgroup exist, umount can succseed. So no problem at shutdown. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06mm: hugetlb: fix non-atomic enqueue of huge pageHillf Danton
commit b0365c8d0cb6e79eb5f21418ae61ab511f31b575 upstream. If a huge page is enqueued under the protection of hugetlb_lock, then the operation is atomic and safe. Signed-off-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06memcg: keep root group unchanged if creation failsHillf Danton
commit a41c58a6665cc995e237303b05db42100b71b65e upstream. If the request is to create non-root group and we fail to meet it, we should leave the root unchanged. Signed-off-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06vfs: __read_cache_page should use gfp argument rather than GFP_KERNELDave Kleikamp
commit e6f67b8c05f5e129e126f4409ddac6f25f58ffcb upstream. lockdep reports a deadlock in jfs because a special inode's rw semaphore is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not used when __read_cache_page() calls add_to_page_cache_lru(). Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06oom: fix integer overflow of points in oom_badnessFrantisek Hrbata
commit ff05b6f7ae762b6eb464183eec994b28ea09f6dd upstream. An integer overflow will happen on 64bit archs if task's sum of rss, swapents and nr_ptes exceeds (2^31)/1000 value. This was introduced by commit f755a04 oom: use pte pages in OOM score where the oom score computation was divided into several steps and it's no longer computed as one expression in unsigned long(rss, swapents, nr_pte are unsigned long), where the result value assigned to points(int) is in range(1..1000). So there could be an int overflow while computing 176 points *= 1000; and points may have negative value. Meaning the oom score for a mem hog task will be one. 196 if (points <= 0) 197 return 1; For example: [ 3366] 0 3366 35390480 24303939 5 0 0 oom01 Out of memory: Kill process 3366 (oom01) score 1 or sacrifice child Here the oom1 process consumes more than 24303939(rss)*4096~=92GB physical memory, but it's oom score is one. In this situation the mem hog task is skipped and oom killer kills another and most probably innocent task with oom score greater than one. The points variable should be of type long instead of int to prevent the int overflow. Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06percpu: fix per_cpu_ptr_to_phys() handling of non-page-aligned addressesEugene Surovegin
commit 9f57bd4d6dc69a4e3bf43044fa00fcd24dd363e3 upstream. per_cpu_ptr_to_phys() incorrectly rounds up its result for non-kmalloc case to the page boundary, which is bogus for any non-page-aligned address. This affects the only in-tree user of this function - sysfs handler for per-cpu 'crash_notes' physical address. The trouble is that the crash_notes per-cpu variable is not page-aligned: crash_notes = 0xc08e8ed4 PER-CPU OFFSET VALUES: CPU 0: 3711f000 CPU 1: 37129000 CPU 2: 37133000 CPU 3: 3713d000 So, the per-cpu addresses are: crash_notes on CPU 0: f7a07ed4 => phys 36b57ed4 crash_notes on CPU 1: f7a11ed4 => phys 36b4ded4 crash_notes on CPU 2: f7a1bed4 => phys 36b43ed4 crash_notes on CPU 3: f7a25ed4 => phys 36b39ed4 However, /sys/devices/system/cpu/cpu*/crash_notes says: /sys/devices/system/cpu/cpu0/crash_notes: 36b57000 /sys/devices/system/cpu/cpu1/crash_notes: 36b4d000 /sys/devices/system/cpu/cpu2/crash_notes: 36b43000 /sys/devices/system/cpu/cpu3/crash_notes: 36b39000 As you can see, all values are rounded down to a page boundary. Consequently, this is where kexec sets up the NOTE segments, and thus where the secondary kernel is looking for them. However, when the first kernel crashes, it saves the notes to the unaligned addresses, where they are not found. Fix it by adding offset_in_page() to the translated page address. -tj: Combined Eugene's and Petr's commit messages. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21percpu: fix chunk range calculationTejun Heo
commit a855b84c3d8c73220d4d3cd392a7bee7c83de70e upstream. Percpu allocator recorded the cpus which map to the first and last units in pcpu_first/last_unit_cpu respectively and used them to determine the address range of a chunk - e.g. it assumed that the first unit has the lowest address in a chunk while the last unit has the highest address. This simply isn't true. Groups in a chunk can have arbitrary positive or negative offsets from the previous one and there is no guarantee that the first unit occupies the lowest offset while the last one the highest. Fix it by actually comparing unit offsets to determine cpus occupying the lowest and highest offsets. Also, rename pcu_first/last_unit_cpu to pcpu_low/high_unit_cpu to avoid confusion. The chunk address range is used to flush cache on vmalloc area map/unmap and decide whether a given address is in the first chunk by per_cpu_ptr_to_phys() and the bug was discovered by invalid per_cpu_ptr_to_phys() translation for crash_note. Kudos to Dave Young for tracking down the problem. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: WANG Cong <xiyou.wangcong@gmail.com> Reported-by: Dave Young <dyoung@redhat.com> Tested-by: Dave Young <dyoung@redhat.com> LKML-Reference: <4EC21F67.10905@redhat.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21mm: vmalloc: check for page allocation failure before vmlist insertionMel Gorman
commit 1368edf0647ac112d8cfa6ce47257dc950c50f5c upstream. Commit f5252e00 ("mm: avoid null pointer access in vm_struct via /proc/vmallocinfo") adds newly allocated vm_structs to the vmlist after it is fully initialised. Unfortunately, it did not check that __vmalloc_area_node() successfully populated the area. In the event of allocation failure, the vmalloc area is freed but the pointer to freed memory is inserted into the vmlist leading to a a crash later in get_vmalloc_info(). This patch adds a check for ____vmalloc_area_node() failure within __vmalloc_node_range. It does not use "goto fail" as in the previous error path as a warning was already displayed by __vmalloc_area_node() before it called vfree in its failure path. Credit goes to Luciano Chavez for doing all the real work of identifying exactly where the problem was. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com> Tested-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21mm: Ensure that pfn_valid() is called once per pageblock when reserving ↵Michal Hocko
pageblocks commit d021563888312018ca65681096f62e36c20e63cc upstream. setup_zone_migrate_reserve() expects that zone->start_pfn starts at pageblock_nr_pages aligned pfn otherwise we could access beyond an existing memblock resulting in the following panic if CONFIG_HOLES_IN_ZONE is not configured and we do not check pfn_valid: IP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180 *pdpt = 0000000000000000 *pde = f000ff53f000ff53 Oops: 0000 [#1] SMP Pid: 1, comm: swapper Not tainted 3.0.7-0.7-pae #1 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform EIP: 0060:[<c02d331d>] EFLAGS: 00010006 CPU: 0 EIP is at setup_zone_migrate_reserve+0xcd/0x180 EAX: 000c0000 EBX: f5801fc0 ECX: 000c0000 EDX: 00000000 ESI: 000c01fe EDI: 000c01fe EBP: 00140000 ESP: f2475f58 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 1, ti=f2474000 task=f2472cd0 task.ti=f2474000) Call Trace: [<c02d389c>] __setup_per_zone_wmarks+0xec/0x160 [<c02d3a1f>] setup_per_zone_wmarks+0xf/0x20 [<c08a771c>] init_per_zone_wmark_min+0x27/0x86 [<c020111b>] do_one_initcall+0x2b/0x160 [<c086639d>] kernel_init+0xbe/0x157 [<c05cae26>] kernel_thread_helper+0x6/0xd Code: a5 39 f5 89 f7 0f 46 fd 39 cf 76 40 8b 03 f6 c4 08 74 32 eb 91 90 89 c8 c1 e8 0e 0f be 80 80 2f 86 c0 8b 14 85 60 2f 86 c0 89 c8 <2b> 82 b4 12 00 00 c1 e0 05 03 82 ac 12 00 00 8b 00 f6 c4 08 0f EIP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180 SS:ESP 0068:f2475f58 CR2: 00000000000012b4 We crashed in pageblock_is_reserved() when accessing pfn 0xc0000 because highstart_pfn = 0x36ffe. The issue was introduced in 3.0-rc1 by 6d3163ce ("mm: check if any page in a pageblock is reserved before marking it MIGRATE_RESERVE"). Make sure that start_pfn is always aligned to pageblock_nr_pages to ensure that pfn_valid s always called at the start of each pageblock. Architectures with holes in pageblocks will be correctly handled by pfn_valid_within in pageblock_is_reserved. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Dang Bo <bdang@vmware.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Arve Hjnnevg <arve@android.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21thp: set compound tail page _count to zeroYouquan Song
commit 58a84aa92723d1ac3e1cc4e3b0ff49291663f7e1 upstream. Commit 70b50f94f1644 ("mm: thp: tail page refcounting fix") keeps all page_tail->_count zero at all times. But the current kernel does not set page_tail->_count to zero if a 1GB page is utilized. So when an IOMMU 1GB page is used by KVM, it wil result in a kernel oops because a tail page's _count does not equal zero. kernel BUG at include/linux/mm.h:386! invalid opcode: 0000 [#1] SMP Call Trace: gup_pud_range+0xb8/0x19d get_user_pages_fast+0xcb/0x192 ? trace_hardirqs_off+0xd/0xf hva_to_pfn+0x119/0x2f2 gfn_to_pfn_memslot+0x2c/0x2e kvm_iommu_map_pages+0xfd/0x1c1 kvm_iommu_map_memslots+0x7c/0xbd kvm_iommu_map_guest+0xaa/0xbf kvm_vm_ioctl_assigned_device+0x2ef/0xa47 kvm_vm_ioctl+0x36c/0x3a2 do_vfs_ioctl+0x49e/0x4e4 sys_ioctl+0x5a/0x7c system_call_fastpath+0x16/0x1b RIP gup_huge_pud+0xf2/0x159 Signed-off-by: Youquan Song <youquan.song@intel.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09hugetlb: release pages in the error path of hugetlb_cow()Hillf Danton
commit ea4039a34c4c206d015d34a49d0b00868e37db1d upstream. If we fail to prepare an anon_vma, the {new, old}_page should be released, or they will leak. Signed-off-by: Hillf Danton <dhillf@gmail.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21backing-dev: ensure wakeup_timer is deletedRabin Vincent
commit 7a401a972df8e184b3d1a3fc958c0a4ddee8d312 upstream. bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links from all super_blocks and then del_timer_sync() the writeback timer. However, this can race with __mark_inode_dirty(), leading to bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi we're unregistering, after we've called del_timer_sync(). This can end up with the bdi being freed with an active timer inside it, as in the case of the following dump after the removal of an SD card. Fix this by redoing the del_timer_sync() in bdi_destory(). ------------[ cut here ]------------ WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8() ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180 Modules linked in: Backtrace: [<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c) r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000 [<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c) [<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40) r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29 r3:00000009 [<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8) r3:c02b1b29 r2:c02bc662 [<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc) r6:c7964000 r5:00000001 r4:c7964000 [<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8) [<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78) [<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84) r5:c79641f0 r4:c796420c [<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80) r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c [<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c) r5:c79643b4 r4:c79641f0 [<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74) r4:c7964000 [<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8) r5:00000000 r4:c794c400 [<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38) r5:c794c400 r4:c0322824 [<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170) r5:c78d5e00 r4:c74083c0 [<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c) r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0 r3:00000000 [<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c) r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0 [<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70) r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4 [<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70) r5:c794dc00 r4:c794dc00 [<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194) r5:c794dc00 r4:c7942300 [<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310) r6:c7942300 r5:00000000 r4:00000000 r3:00000000 [<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30) ---[ end trace e5c83c92ada51c76 ]--- Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mm: thp: tail page refcounting fixAndrea Arcangeli
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream. Michel while working on the working set estimation code, noticed that calling get_page_unless_zero() on a random pfn_to_page(random_pfn) wasn't safe, if the pfn ended up being a tail page of a transparent hugepage under splitting by __split_huge_page_refcount(). He then found the problem could also theoretically materialize with page_cache_get_speculative() during the speculative radix tree lookups that uses get_page_unless_zero() in SMP if the radix tree page is freed and reallocated and get_user_pages is called on it before page_cache_get_speculative has a chance to call get_page_unless_zero(). So the best way to fix the problem is to keep page_tail->_count zero at all times. This will guarantee that get_page_unless_zero() can never succeed on any tail page. page_tail->_mapcount is guaranteed zero and is unused for all tail pages of a compound page, so we can simply account the tail page references there and transfer them to tail_page->_count in __split_huge_page_refcount() (in addition to the head_page->_mapcount). While debugging this s/_count/_mapcount/ change I also noticed get_page is called by direct-io.c on pages returned by get_user_pages. That wasn't entirely safe because the two atomic_inc in get_page weren't atomic. As opposed to other get_user_page users like secondary-MMU page fault to establish the shadow pagetables would never call any superflous get_page after get_user_page returns. It's safer to make get_page universally safe for tail pages and to use get_page_foll() within follow_page (inside get_user_pages()). get_page_foll() is safe to do the refcounting for tail pages without taking any locks because it is run within PT lock protected critical sections (PT lock for pte and page_table_lock for pmd_trans_huge). The standard get_page() as invoked by direct-io instead will now take the compound_lock but still only for tail pages. The direct-io paths are usually I/O bound and the compound_lock is per THP so very finegrined, so there's no risk of scalability issues with it. A simple direct-io benchmarks with all lockdep prove locking and spinlock debugging infrastructure enabled shows identical performance and no overhead. So it's worth it. Ideally direct-io should stop calling get_page() on pages returned by get_user_pages(). The spinlock in get_page() is already optimized away for no-THP builds but doing get_page() on tail pages returned by GUP is generally a rare operation and usually only run in I/O paths. This new refcounting on page_tail->_mapcount in addition to avoiding new RCU critical sections will also allow the working set estimation code to work without any further complexity associated to the tail page refcounting with THP. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michel Lespinasse <walken@google.com> Reviewed-by: Michel Lespinasse <walken@google.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mm: avoid null pointer access in vm_struct via /proc/vmallocinfoMitsuo Hayasaka
commit f5252e009d5b87071a919221e4f6624184005368 upstream. The /proc/vmallocinfo shows information about vmalloc allocations in vmlist that is a linklist of vm_struct. It, however, may access pages field of vm_struct where a page was not allocated. This results in a null pointer access and leads to a kernel panic. Why this happens: In __vmalloc_node_range() called from vmalloc(), newly allocated vm_struct is added to vmlist at __get_vm_area_node() and then, some fields of vm_struct such as nr_pages and pages are set at __vmalloc_area_node(). In other words, it is added to vmlist before it is fully initialized. At the same time, when the /proc/vmallocinfo is read, it accesses the pages field of vm_struct according to the nr_pages field at show_numa_info(). Thus, a null pointer access happens. The patch adds the newly allocated vm_struct to the vmlist *after* it is fully initialized. So, it can avoid accessing the pages field with unallocated page when show_numa_info() is called. Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-27Merge commit 'v3.0.8' into android-3.0Colin Cross
2011-10-26mm: avoid livelock on !__GFP_FS allocationsMel Gorman
Under the following conditions, __alloc_pages_slowpath can loop forever: gfp_mask & __GFP_WAIT is true gfp_mask & __GFP_FS is false reclaim and compaction make no progress order <= PAGE_ALLOC_COSTLY_ORDER The gfp conditions are normally invalid, because !__GFP_FS disables most of the reclaim methods that __GFP_WAIT would wait for. However, these conditions happen very often during suspend and resume, when pm_restrict_gfp_mask() effectively converts all GFP_KERNEL allocations into __GFP_WAIT. The oom killer is not run because gfp_mask & __GFP_FS is false, but should_alloc_retry will always return true when order is less than PAGE_ALLOC_COSTLY_ORDER. __alloc_pages_slowpath will loop forever between the rebalance label and should_alloc_retry, unless another thread happens to release enough pages to satisfy the allocation. Add a check to detect when PM has disabled __GFP_FS, and do not retry if reclaim is not making any progress. [taken from patch on lkml by Mel Gorman, commit message by ccross] Change-Id: I864a24e9d9fd98bd0e3d6e9c1e85b6c1b766850e Signed-off-by: Colin Cross <ccross@android.com>
2011-10-25mm: fix race between mremap and removing migration entryHugh Dickins
commit 486cf46f3f9be5f2a966016c1a8fe01e32cde09e upstream. I don't usually pay much attention to the stale "? " addresses in stack backtraces, but this lucky report from Pawel Sikora hints that mremap's move_ptes() has inadequate locking against page migration. 3.0 BUG_ON(!PageLocked(p)) in migration_entry_to_page(): kernel BUG at include/linux/swapops.h:105! RIP: 0010:[<ffffffff81127b76>] [<ffffffff81127b76>] migration_entry_wait+0x156/0x160 [<ffffffff811016a1>] handle_pte_fault+0xae1/0xaf0 [<ffffffff810feee2>] ? __pte_alloc+0x42/0x120 [<ffffffff8112c26b>] ? do_huge_pmd_anonymous_page+0xab/0x310 [<ffffffff81102a31>] handle_mm_fault+0x181/0x310 [<ffffffff81106097>] ? vma_adjust+0x537/0x570 [<ffffffff81424bed>] do_page_fault+0x11d/0x4e0 [<ffffffff81109a05>] ? do_mremap+0x2d5/0x570 [<ffffffff81421d5f>] page_fault+0x1f/0x30 mremap's down_write of mmap_sem, together with i_mmap_mutex or lock, and pagetable locks, were good enough before page migration (with its requirement that every migration entry be found) came in, and enough while migration always held mmap_sem; but not enough nowadays, when there's memory hotremove and compaction. The danger is that move_ptes() lets a migration entry dodge around behind remove_migration_pte()'s back, so it's in the old location when looking at the new, then in the new location when looking at the old. Either mremap's move_ptes() must additionally take anon_vma lock(), or migration's remove_migration_pte() must stop peeking for is_swap_entry() before it takes pagetable lock. Consensus chooses the latter: we prefer to add overhead to migration than to mremapping, which gets used by JVMs and by exec stack setup. Reported-and-tested-by: Paweł Sikora <pluto@agmk.net> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03memcg: fix vmscan count in small memcgsKAMEZAWA Hiroyuki
commit 4508378b9523e22a2a0175d8bf64d932fb10a67d upstream. Commit 246e87a93934 ("memcg: fix get_scan_count() for small targets") fixes the memcg/kswapd behavior against small targets and prevent vmscan priority too high. But the implementation is too naive and adds another problem to small memcg. It always force scan to 32 pages of file/anon and doesn't handle swappiness and other rotate_info. It makes vmscan to scan anon LRU regardless of swappiness and make reclaim bad. This patch fixes it by adjusting scanning count with regard to swappiness at el. At a test "cat 1G file under 300M limit." (swappiness=20) before patch scanned_pages_by_limit 360919 scanned_anon_pages_by_limit 180469 scanned_file_pages_by_limit 180450 rotated_pages_by_limit 31 rotated_anon_pages_by_limit 25 rotated_file_pages_by_limit 6 freed_pages_by_limit 180458 freed_anon_pages_by_limit 19 freed_file_pages_by_limit 180439 elapsed_ns_by_limit 429758872 after patch scanned_pages_by_limit 180674 scanned_anon_pages_by_limit 24 scanned_file_pages_by_limit 180650 rotated_pages_by_limit 35 rotated_anon_pages_by_limit 24 rotated_file_pages_by_limit 11 freed_pages_by_limit 180634 freed_anon_pages_by_limit 0 freed_file_pages_by_limit 180634 elapsed_ns_by_limit 367119089 scanned_pages_by_system 0 the numbers of scanning anon are decreased(as expected), and elapsed time reduced. By this patch, small memcgs will work better. (*) Because the amount of file-cache is much bigger than anon, recalaim_stat's rotate-scan counter make scanning files more. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
