path: root/mm
2009-01-27uclinux: add process name to allocation error messageGreg Ungerer
This patch adds the name of the process to the bad allocation error message on non-MMU systems. Changed suggested by jsujjavanich@syntech-fuelmaster.com Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2009-01-21nommu: Stub in vm_map_ram()/vm_unmap_ram()/vm_unmap_aliases().Paul Mundt
Presently we do not support these interfaces, so make them BUG() wrappers as per the rest of the vmap interface on nommu. Fixes up the modular xfs build. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-01-15memcg: fix a race when setting memory.swappinessLi Zefan
(suppose: memcg->use_hierarchy == 0 and memcg->swappiness == 60) echo 10 > /memcg/0/swappiness | mem_cgroup_swappiness_write() | ... | echo 1 > /memcg/0/use_hierarchy | mkdir /mnt/0/1 | sub_memcg->swappiness = 60; memcg->swappiness = 10; | In the above scenario, we end up having 2 different swappiness values in a single hierarchy. We should hold cgroup_lock() when cheking cgrp->children list. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15memcg: fix section mismatchLi Zefan
At system boot when creating the top cgroup, mem_cgroup_create() calls enable_swap_cgroup() which is marked as __init, so mark mem_cgroup_create() as __ref to avoid false section mismatch warning. Reported-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by; KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15revert "mm: vmalloc use mutex for purge"Andrew Morton
Revert commit e97a630eb0f5b8b380fd67504de6cedebb489003 ("mm: vmalloc use mutex for purge") Bryan Donlan reports: : After testing 2.6.29-rc1 on xen-x86 with a btrfs root filesystem, I : got the OOPS quoted below and a hard freeze shortly after boot. : Boot messages and config are attached. : : ------------[ cut here ]------------ : Kernel BUG at c05ef80d [verbose debug info unavailable] : invalid opcode: 0000 [#1] SMP : last sysfs file: /sys/block/xvdc/size : Modules linked in: : : Pid: 0, comm: swapper Not tainted (2.6.29-rc1 #6) : EIP: 0061:[<c05ef80d>] EFLAGS: 00010087 CPU: 2 : EIP is at schedule+0x7cd/0x950 : EAX: d5aeca80 EBX: 00000002 ECX: 00000000 EDX: d4cb9a40 : ESI: c12f5600 EDI: d4cb9a40 EBP: d6033fa4 ESP: d6033ef4 : DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0069 : Process swapper (pid: 0, ti=d6032000 task=d6020b70 task.ti=d6032000) : Stack: : 000d85bc 00000000 000186a0 00000000 0dd11410 c0105417 c12efe00 0dc367c3 : 00000011 c0105d46 d5a5d310 deadbeef d4cb9a40 c07cc600 c05f1340 c12e0060 : deadbeef d6020b70 d6020d08 00000002 c014377d 00000000 c12f5600 00002c22 : Call Trace: : [<c0105417>] xen_force_evtchn_callback+0x17/0x30 : [<c0105d46>] check_events+0x8/0x12 : [<c05f1340>] _spin_unlock_irqrestore+0x20/0x40 : [<c014377d>] hrtimer_start_range_ns+0x12d/0x2e0 : [<c014c4f6>] tick_nohz_restart_sched_tick+0x146/0x160 : [<c0107485>] cpu_idle+0xa5/0xc0 and bisected it to this commit. Let's remove it now while we have a think about the problem. Reported-by: Bryan Donlan <bdonlan@gmail.com> Tested-by: Christophe Saout <christophe@saout.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15memcg: make oom less frequentlyDaisuke Nishimura
In previous implementation, mem_cgroup_try_charge checked the return value of mem_cgroup_try_to_free_pages, and just retried if some pages had been reclaimed. But now, try_charge(and mem_cgroup_hierarchical_reclaim called from it) only checks whether the usage is less than the limit. This patch tries to change the behavior as before to cause oom less frequently. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15memcg: fix hierarchical reclaimDaisuke Nishimura
If root_mem has no children, last_scaned_child is set to root_mem itself. But after some children added to root_mem, mem_cgroup_get_next_node can mem_cgroup_put the root_mem although root_mem has not been mem_cgroup_get. This patch fixes this behavior by: - Set last_scanned_child to NULL if root_mem has no children or DFS search has returned to root_mem itself(root_mem is not a "child" of root_mem). Make mem_cgroup_get_first_node return root_mem in this case. There are no mem_cgroup_get/put for root_mem. - Rename mem_cgroup_get_next_node to __mem_cgroup_get_next_node, and mem_cgroup_get_first_node to mem_cgroup_get_next_node. Make mem_cgroup_hierarchical_reclaim call only new mem_cgroup_get_next_node. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15memcg: fix error path of mem_cgroup_move_parentDaisuke Nishimura
There is a bug in error path of mem_cgroup_move_parent. Extra refcnt got from try_charge should be dropped, and usages incremented by try_charge should be decremented in both error paths: A: failure at get_page_unless_zero B: failure at isolate_lru_page This bug makes this parent directory unremovable. In case of A, rmdir doesn't return, because res.usage doesn't go down to 0 at mem_cgroup_force_empty even after all the pc in lru are removed. In case of B, rmdir fails and returns -EBUSY, because it has extra ref counts even after res.usage goes down to 0. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15memcg: fix mem_cgroup_get_reclaim_stat_from_pageDaisuke Nishimura
In case of swapin, a new page is added to lru before it is charged, so page->pc->mem_cgroup points to NULL or last mem_cgroup the page was charged before. In the latter case, if the mem_cgroup has already freed by rmdir, the area pointed to by page->pc->mem_cgroup may have invalid data. Actually, I saw general protection fault. general protection fault: 0000 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu15/cache/index1/shared_cpu_map CPU 4 Modules linked in: ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp ipv6 autofs4 hidp rfcomm l2cap bluetooth sunrpc dm_mirror dm_region_hash dm_log dm_multipath dm_mod rfkill input_polldev sbs sbshc battery ac lp sg ide_cd_mod cdrom button serio_raw acpi_memhotplug parport_pc e1000 rtc_cmos parport rtc_core rtc_lib i2c_i801 i2c_core shpchp pcspkr ata_piix libata megaraid_mbox megaraid_mm sd_mod scsi_mod ext3 jbd ehci_hcd ohci_hcd uhci_hcd [last unloaded: microcode] Pid: 26038, comm: page01 Tainted: G W 2.6.28-rc9-mm1-mmotm-2008-12-22-16-14-f2ab3dea #1 RIP: 0010:[<ffffffff8028e710>] [<ffffffff8028e710>] update_page_reclaim_stat+0x2f/0x42 RSP: 0000:ffff8801ee457da8 EFLAGS: 00010002 RAX: 32353438312021c8 RBX: 0000000000000000 RCX: 32353438312021c8 RDX: 0000000000000000 RSI: ffff8800cb0b1000 RDI: ffff8801164d1d28 RBP: ffff880110002cb8 R08: ffff88010f2eae23 R09: 0000000000000001 R10: ffff8800bc514b00 R11: ffff880110002c00 R12: 0000000000000000 R13: ffff88000f484100 R14: 0000000000000003 R15: 00000000001200d2 FS: 00007f8a261726f0(0000) GS:ffff88010f2eaa80(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f8a25d22000 CR3: 00000001ef18c000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process page01 (pid: 26038, threadinfo ffff8801ee456000, task ffff8800b585b960) Stack: ffffe200071ee568 ffff880110001f00 0000000000000000 ffffffff8028ea17 ffff88000f484100 0000000000000000 0000000000000020 00007f8a25d22000 ffff8800bc514b00 ffffffff8028ec34 0000000000000000 0000000000016fd8 Call Trace: [<ffffffff8028ea17>] ? ____pagevec_lru_add+0xc1/0x13c [<ffffffff8028ec34>] ? drain_cpu_pagevecs+0x36/0x89 [<ffffffff802a4f8c>] ? swapin_readahead+0x78/0x98 [<ffffffff8029a37a>] ? handle_mm_fault+0x3d9/0x741 [<ffffffff804da654>] ? do_page_fault+0x3ce/0x78c [<ffffffff804d7a42>] ? trace_hardirqs_off_thunk+0x3a/0x3c [<ffffffff804d860f>] ? page_fault+0x1f/0x30 Code: cc 55 48 8d af b8 0d 00 00 48 89 f7 53 89 d3 e8 39 85 02 00 48 63 d3 48 ff 44 d5 10 45 85 e4 74 05 48 ff 44 d5 00 48 85 c0 74 0e <48> ff 44 d0 10 45 85 e4 74 04 48 ff 04 d0 5b 5d 41 5c c3 41 54 RIP [<ffffffff8028e710>] update_page_reclaim_stat+0x2f/0x42 RSP <ffff8801ee457da8> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15alpha: fix vmalloc breakageIvan Kokshaysky
On alpha, we have to map some stuff in the VMALLOC space very early in the boot process (to make SRM console callbacks work and so on, see arch/alpha/mm/init.c). For old VM allocator, we just manually placed a vm_struct onto the global vmlist and this worked for ages. Unfortunately, the new allocator isn't aware of this, so it constantly tries to allocate the VM space which is already in use, making vmalloc on alpha defunct. This patch forces KVA to import vmlist entries on init. [akpm@linux-foundation.org: remove unneeded check (per Johannes)] Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Nick Piggin <npiggin@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 28Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 14Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 13Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-13x86 PAT: change track_pfn_vma_new to take pgprot_t pointer paramvenkatesh.pallipadi@intel.com
Impact: cleanup Change the protection parameter for track_pfn_vma_new() into a pgprot_t pointer. Subsequent patch changes the x86 PAT handling to return a compatible memtype in pgprot_t, if what was requested cannot be allowed due to conflicts. No fuctionality change in this patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-13x86 PAT: remove PFNMAP type on track_pfn_vma_new() errorvenkatesh.pallipadi@intel.com
Impact: fix (harmless) double-free of memtype entries and avoid warning On track_pfn_vma_new() failure, reset the vm_flags so that there will be no second cleanup happening when upper level routines call unmap_vmas(). This patch fixes part of the bug reported here: http://marc.info/?l=linux-kernel&m=123108883716357&w=2 Specifically the error message: X:5010 freeing invalid memtype d0000000-d0101000 Is due to multiple frees on error path, will not happen with the patch below. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12lockdep, mm: fix might_fault() annotationPeter Zijlstra
Some code (nfs/sunrpc) uses socket ops on kernel memory while holding the mmap_sem, this is safe because kernel memory doesn't get paged out, therefore we'll never actually fault, and the might_fault() annotations will generate false positives. Reported-by: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-08cgroups: use hierarchy_mutex in memory controllerPaul Menage
Update the memory controller to use its hierarchy_mutex rather than calling cgroup_lock() to protected against cgroup_mkdir()/cgroup_rmdir() from occurring in its hierarchy. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix shmem's swap accountingKAMEZAWA Hiroyuki
Now, you can see following even when swap accounting is enabled. 1. Create Group 01, and 02. 2. allocate a "file" on tmpfs by a task under 01. 3. swap out the "file" (by memory pressure) 4. Read "file" from a task in group 02. 5. the charge of "file" is moved to group 02. This is not ideal behavior. This is because SwapCache which was loaded by read-ahead is not taken into account.. This is a patch to fix shmem's swapcache behavior. - remove mem_cgroup_cache_charge_swapin(). - Add SwapCache handler routine to mem_cgroup_cache_charge(). By this, shmem's file cache is charged at add_to_page_cache() with GFP_NOWAIT. - pass the page of swapcache to shrink_mem_cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix LRU accounting for SwapCacheKAMEZAWA Hiroyuki
Now, a page can be deleted from SwapCache while do_swap_page(). memcg-fix-swap-accounting-leak-v3.patch handles that, but, LRU handling is still broken. (above behavior broke assumption of memcg-synchronized-lru patch.) This patch is a fix for LRU handling (especially for per-zone counters). At charging SwapCache, - Remove page_cgroup from LRU if it's not used. - Add page cgroup to LRU if it's not linked to. Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: use css_tryget in memcgKAMEZAWA Hiroyuki
From:KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> css_tryget() newly is added and we can know css is alive or not and get refcnt of css in very safe way. ("alive" here means "rmdir/destroy" is not called.) This patch replaces css_get() to css_tryget(), where I cannot explain why css_get() is safe. And removes memcg->obsolete flag. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix double free and make refcnt saneKAMEZAWA Hiroyuki
1. Fix double-free BUG in error route of mem_cgroup_create(). mem_cgroup_free() itself frees per-zone-info. 2. Making refcnt of memcg simple. Add 1 refcnt at creation and call free when refcnt goes down to 0. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix swap accounting leakKAMEZAWA Hiroyuki
Fix swapin charge operation of memcg. Now, memcg has hooks to swap-out operation and checks SwapCache is really unused or not. That check depends on contents of struct page. I.e. If PageAnon(page) && page_mapped(page), the page is recoginized as still-in-use. Now, reuse_swap_page() calles delete_from_swap_cache() before establishment of any rmap. Then, in followinig sequence (Page fault with WRITE) try_charge() (charge += PAGESIZE) commit_charge() (Check page_cgroup is used or not..) reuse_swap_page() -> delete_from_swapcache() -> mem_cgroup_uncharge_swapcache() (charge -= PAGESIZE) ...... New charge is uncharged soon.... To avoid this, move commit_charge() after page_mapcount() goes up to 1. By this, try_charge() (usage += PAGESIZE) reuse_swap_page() (may usage -= PAGESIZE if PCG_USED is set) commit_charge() (If page_cgroup is not marked as PCG_USED, add new charge.) Accounting will be correct. Changelog (v2) -> (v3) - fixed invalid charge to swp_entry==0. - updated documentation. Changelog (v1) -> (v2) - fixed comment. [nishimura@mxp.nes.nec.co.jp: swap accounting leak doc fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: change try_to_free_pages to hierarchical_reclaimDaisuke Nishimura
mem_cgroup_hierarchicl_reclaim() works properly even when !use_hierarchy now (by memcg-hierarchy-avoid-unnecessary-reclaim.patch), so, instead of try_to_free_mem_cgroup_pages(), it should be used in many cases. The only exception is force_empty. The group has no children in this case. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: avoid deadlock caused by race between oom and cpuset_attachDaisuke Nishimura
mpol_rebind_mm(), which can be called from cpuset_attach(), does down_write(mm->mmap_sem). This means down_write(mm->mmap_sem) can be called under cgroup_mutex. OTOH, page fault path does down_read(mm->mmap_sem) and calls mem_cgroup_try_charge_xxx(), which may eventually calls mem_cgroup_out_of_memory(). And mem_cgroup_out_of_memory() calls cgroup_lock(). This means cgroup_lock() can be called under down_read(mm->mmap_sem). If those two paths race, deadlock can happen. This patch avoid this deadlock by: - remove cgroup_lock() from mem_cgroup_out_of_memory(). - define new mutex (memcg_tasklist) and serialize mem_cgroup_move_task() (->attach handler of memory cgroup) and mem_cgroup_out_of_memory. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_try_chargeDaisuke Nishimura
After previous patch, mem_cgroup_try_charge is not used by anyone, so we can remove it. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: don't trigger oom at page migrationDaisuke Nishimura
I think triggering OOM at mem_cgroup_prepare_migration would be just a bit overkill. Returning -ENOMEM would be enough for mem_cgroup_prepare_migration. The caller would handle the case anyway. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: show real limit under hierarchy modeKAMEZAWA Hiroyuki
Show "real" limit of memcg. This helps my debugging and maybe useful for users. While testing hierarchy like this mount -t cgroup none /cgroup -t memory mkdir /cgroup/A set use_hierarchy==1 to "A" mkdir /cgroup/A/01 mkdir /cgroup/A/01/02 mkdir /cgroup/A/01/03 mkdir /cgroup/A/01/03/04 mkdir /cgroup/A/08 mkdir /cgroup/A/08/01 .... and set each own limit to them, "real" limit of each memcg is unclear. This patch shows real limit by checking all ancestors. Changelog: (v1) -> (v2) - remove "if" and use "min(a,b)" Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix calculation of active_ratioKOSAKI Motohiro
Currently, inactive_ratio of memcg is calculated at setting limit. because page_alloc.c does so and current implementation is straightforward porting. However, memcg introduced hierarchy feature recently. In hierarchy restriction, memory limit is not only decided memory.limit_in_bytes of current cgroup, but also parent limit and sibling memory usage. Then, The optimal inactive_ratio is changed frequently. So, everytime calculation is better. Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swappinessKOSAKI Motohiro
Currently, /proc/sys/vm/swappiness can change swappiness ratio for global reclaim. However, memcg reclaim doesn't have tuning parameter for itself. In general, the optimal swappiness depend on workload. (e.g. hpc workload need to low swappiness than the others.) Then, per cgroup swappiness improve administrator tunability. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: protect prev_priorityKOSAKI Motohiro
Currently, mem_cgroup doesn't have own lock and almost its member doesn't need. (e.g. mem_cgroup->info is protected by zone lock, mem_cgroup->stat is per cpu variable) However, there is one explict exception. mem_cgroup->prev_priorit need lock, but doesn't protect. Luckly, this is NOT bug because prev_priority isn't used for current reclaim code. However, we plan to use prev_priority future again. Therefore, fixing is better. In addition, we plan to reuse this lock for another member. Then "reclaim_param_lock" name is better than "prev_priority_lock". Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: rename scan global lruKAMEZAWA Hiroyuki
Rename scan_global_lru() to scanning_global_lru(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: show reclaim statKOSAKI Motohiro
Add the following four fields to memory.stat file: - inactive_ratio - recent_rotated_anon - recent_rotated_file - recent_scanned_anon - recent_scanned_file Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_cal_reclaim()KOSAKI Motohiro
Now, get_scan_ratio() return correct value although memcg reclaim. Then, mem_cgroup_calc_reclaim() can be removed. So, memcg reclaim get the same capability of anon/file reclaim balancing as global reclaim now. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add zone_reclaim_statKOSAKI Motohiro
Introduce mem_cgroup_per_zone::reclaim_stat member and its statics collecting function. Now, get_scan_ratio() can calculate correct value on memcg reclaim. [hugh@veritas.com: avoid reclaim_stat oops when disabled] Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_zone_nr_pages()KOSAKI Motohiro
Introduce mem_cgroup_zone_nr_pages(). It is called by zone_nr_pages() helper function. This patch doesn't have any behavior change. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add inactive_anon_is_low()KOSAKI Motohiro
The inactive_anon_is_low() is key component of active/inactive anon balancing on reclaim. However current inactive_anon_is_low() function only consider global reclaim. Therefore, we need following ugly scan_global_lru() condition. if (lru == LRU_ACTIVE_ANON && (!scan_global_lru(sc) || inactive_anon_is_low(zone))) { shrink_active_list(nr_to_scan, zone, sc, priority, file); return 0; it cause that memcg reclaim always deactivate pages when shrink_list() is called. To make mem_cgroup_inactive_anon_is_low() improve active/inactive anon balancing of memcgroup. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: "Pekka Enberg" <penberg@cs.helsinki.fi> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add null check to page_cgroup_zoneinfo()KOSAKI Motohiro
If CONFIG_CGROUP_MEM_RES_CTLR_SWAP=y, page_cgroup::mem_cgroup can be NULL. Therefore null checking is better. A later patch uses this function. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08mm: make get_scan_ratio() safe for memcgKOSAKI Motohiro
Currently, get_scan_ratio() always calculate the balancing value for global reclaim and memcg reclaim doesn't use it. Therefore it doesn't have scan_global_lru() condition. However, we plan to expand get_scan_ratio() to be usable for memcg too, latter. Then, The dependency code of global reclaim in the get_scan_ratio() insert into scan_global_lru() condision explictly. This patch doesn't have any functional change. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08mm: add zone nr_pages helper functionKOSAKI Motohiro
Add zone_nr_pages() helper function. It is used by a later patch. This patch doesn't have any functional change. Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08mm: introduce zone_reclaim structKOSAKI Motohiro
Add zone_reclam_stat struct for later enhancement. A later patch uses this. This patch doesn't any behavior change (yet). Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08inactive_anon_is_low: move to vmscanKOSAKI Motohiro
The inactive_anon_is_low() is called only vmscan. Then it can move to vmscan.c This patch doesn't have any functional change. Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: hierarchy avoid unnecessary reclaimDaisuke Nishimura
If hierarchy is not used, no tree-walk is necessary. Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swapout refcnt fixKAMEZAWA Hiroyuki
css's refcnt is dropped before end of following access. Hold it until end of access. Reported-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory swap controller: fix limit checkDaisuke Nishimura
There are scatterd calls of res_counter_check_under_limit(), and most of them don't take mem+swap accounting into account. define mem_cgroup_check_under_limit() and avoid direct use of res_counter_check_limit(). Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: check group leader fixNikanth Karthikesan
Remove unnecessary codes (...fragments of not-implemented functionalilty...) Reported-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: revert gfp mask fixKAMEZAWA Hiroyuki
My patch, memcg-fix-gfp_mask-of-callers-of-charge.patch changed gfp_mask of callers of charge to be GFP_HIGHUSER_MOVABLE for showing what will happen at memory reclaim. But in recent discussion, it's NACKed because it sounds ugly. This patch is for reverting it and add some clean up to gfp_mask of callers of charge. No behavior change but need review before generating HUNK in deep queue. This patch also adds explanation to meaning of gfp_mask passed to charge functions in memcontrol.h. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
