path: root/mm
2007-07-24Merge branch 'request-queue-t' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'request-queue-t' of git://git.kernel.dk/linux-2.6-block: [BLOCK] Add request_queue_t and mark it deprecated [BLOCK] Get rid of request_queue_t typedef
2007-07-24slab: correctly handle __GFP_ZEROAndrew Morton
Use the correct local variable when calling into the page allocator. Local `flags' can have __GFP_ZERO set, which causes us to pass __GFP_ZERO into the page allocator, possibly from illegal contexts. The page allocator will later do prep_zero_page()->kmap_atomic(..., KM_USER0) from irq contexts and will then go BUG. Cc: Mike Galbraith <efault@gmx.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24fix hugetlb page allocation leakKen Chen
dequeue_huge_page() has a serious memory leak upon hugetlb page allocation. The for loop continues on allocating hugetlb pages out of all allowable zone, where this function is supposedly only dequeue one and only one pages. Fixed it by breaking out of the for loop once a hugetlb page is found. Signed-off-by: Ken Chen <kenchen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-22x86_64: fix section mismatch warning in init.cSam Ravnborg
Fix following warning: WARNING: vmlinux.o(.text+0x188ea): Section mismatch: reference to .init.text:__alloc_bootmem_core (between 'alloc_bootmem_high_node' and 'get_gate_vma') alloc_bootmem_high_node() is only used from __init scope so declare it __init. And in addition declare the weak variant __init too. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21slob: reduce list scanningMatt Mackall
The version of SLOB in -mm always scans its free list from the beginning, which results in small allocations and free segments clustering at the beginning of the list over time. This causes the average search to scan over a large stretch at the beginning on each allocation. By starting each page search where the last one left off, we evenly distribute the allocations and greatly shorten the average search. Without this patch, kernel compiles on a 1.5G machine take a large amount of system time for list scanning. With this patch, compiles are within a few seconds of performance of a SLAB kernel with no notable change in system time. Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21remove handle_mm_fault exportChristoph Hellwig
Now that arch/powerpc/platforms/cell/spufs/fault.c is always built in the kernel there is no need to export handle_mm_fault anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21nommu: vmalloc_32_user()/vm_insert_page() and symbol exports.Paul Mundt
Trying to survive an allmodconfig on a nommu platform results in many screen lengths of module unhappiness. Many of the mmap related things that binfmt_flat hooks in to are never exported despite being global, and there are also missing definitions for vmalloc_32_user() and vm_insert_page(). I've implemented vmalloc_32_user() trying to stick as close to the mm/vmalloc.c implementation as possible, though we don't have any need for VM_USERMAP, so groveling for the VMA can be skipped. vm_insert_page() has been stubbed for now in order to keep the build happy. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20mm: fix memory hotplug oops from ZONE_MOVABLE changes.Paul Mundt
zone_movable_pfn is presently marked as __initdata and referenced from adjust_zone_range_for_zone_movable(), which in turn is referenced by zone_spanned_pages_in_node(). Both of these are __meminit annotated. When memory hotplug is enabled, this will oops on a hot-add, due to zone_movable_pfn having been freed. __meminitdata annotation gives the desired behaviour. This will only impact platforms that enable both memory hotplug and ARCH_POPULATES_NODE_MAP. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19slub: fix ksize() for zero-sized pointersLinus Torvalds
The slab and slob allocators already did this right, but slub would call "get_object_page()" on the magic ZERO_SIZE_PTR, with all kinds of nasty end results. Noted by Ingo Molnar. Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Fix up non-NUMA SLAB configuration for zero-sized allocationsLinus Torvalds
I suspect Christoph tested his code only in the NUMA configuration, for the combination of SLAB+non-NUMA the zero-sized kmalloc's would not work. Of course, this would only trigger in configurations where those zero- sized allocations happen (not very common), so that may explain why it wasn't more widely noticed. Seen by by Andi Kleen under qemu, and there seems to be a report by Michael Tsirkin on it too. Cc: Andi Kleen <ak@suse.de> Cc: Roland Dreier <rdreier@cisco.com> Cc: Michael S. Tsirkin <mst@dev.mellanox.co.il> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: export symbols for lguest as a moduleRusty Russell
lguest does some fairly lowlevel things to support a host, which normal modules don't need: math_state_restore: When the guest triggers a Device Not Available fault, we need to be able to restore the FPU __put_task_struct: We need to hold a reference to another task for inter-guest I/O, and put_task_struct() is an inline function which calls __put_task_struct. access_process_vm: We need to access another task for inter-guest I/O. map_vm_area & __get_vm_area: We need to map the switcher shim (ie. monitor) at 0xFFC01000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19move page writeback acounting out of macrosAndrew Morton
page-writeback accounting is presently performed in the page-flags macros. This is inconsistent and a bit ugly and makes it awkward to implement per-backing_dev under-writeback page accounting. So move this accounting down to the callsite(s). Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19hugetlb: use set_compound_page_dtorAkinobu Mita
Use appropriate accessor function to set compound page destructor function. Cc: William Irwin <wli@holomorphy.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19Remove nid_lock from alloc_fresh_huge_pageHugh Dickins
The fix to that race in alloc_fresh_huge_page() which could give an illegal node ID did not need nid_lock at all: the fix was to replace static int nid by static int prev_nid and do the work on local int nid. nid_lock did make sure that racers strictly roundrobin the nodes, but that's not something we need to enforce strictly. Kill nid_lock. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19vmalloc_32 should use GFP_KERNELBenjamin Herrenschmidt
I've noticed lots of failures of vmalloc_32 on machines where it shouldn't have failed unless it was doing an atomic operation. Looking closely, I noticed that: #if defined(CONFIG_64BIT) && defined(CONFIG_ZONE_DMA32) #define GFP_VMALLOC32 GFP_DMA32 #elif defined(CONFIG_64BIT) && defined(CONFIG_ZONE_DMA) #define GFP_VMALLOC32 GFP_DMA #else #define GFP_VMALLOC32 GFP_KERNEL #endif Which seems to be incorrect, it should always -or- in the DMA flags on top of GFP_KERNEL, thus this patch. This fixes frequent errors launchin X with the nouveau DRM for example. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andi Kleen <ak@suse.de> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19FRV: work around a possible compiler bugDavid Howells
Work around a possible bug in the FRV compiler. What appears to be happening is that gcc resolves the __builtin_constant_p() in kmalloc() to true, but then fails to reduce the therefore constant conditions in the if-statements it guards to constant results. When compiling with -O2 or -Os, one single spurious error crops up in cpuup_callback() in mm/slab.c. This can be avoided by making the memsize variable const. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19dequeue_huge_page() warning fixAndrew Morton
mm/hugetlb.c: In function `dequeue_huge_page': mm/hugetlb.c:72: warning: 'nid' might be used uninitialized in this function Cc: Christoph Lameter <clameter@sgi.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <hermes@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: variable length argument supportOllie Wild
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from the old mm into the new mm. We create the new mm before the binfmt code runs, and place the new stack at the very top of the address space. Once the binfmt code runs and figures out where the stack should be, we move it downwards. It is a bit peculiar in that we have one task with two mm's, one of which is inactive. [a.p.zijlstra@chello.nl: limit stack size] Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-arch@vger.kernel.org> Cc: Hugh Dickins <hugh@veritas.com> [bunk@stusta.de: unexport bprm_mm_init] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: sanify file_ra_state namesFengguang Wu
Rename some file_ra_state variables and remove some accessors. It results in much simpler code. Kudos to Rusty! Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: split ondemand readahead interface into two functionsRusty Russell
Split ondemand readahead interface into two functions. I think this makes it a little clearer for non-readahead experts (like Rusty). Internally they both call ondemand_readahead(), but the page argument is changed to an obvious boolean flag. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: share PG_readahead and PG_reclaimFengguang Wu
Share the same page flag bit for PG_readahead and PG_reclaim. One is used only on file reads, another is only for emergency writes. One is used mostly for fresh/young pages, another is for old pages. Combinations of possible interactions are: a) clear PG_reclaim => implicit clear of PG_readahead it will delay an asynchronous readahead into a synchronous one it actually does _good_ for readahead: the pages will be reclaimed soon, it's readahead thrashing! in this case, synchronous readahead makes more sense. b) clear PG_readahead => implicit clear of PG_reclaim one(and only one) page will not be reclaimed in time it can be avoided by checking PageWriteback(page) in readahead first c) set PG_reclaim => implicit set of PG_readahead will confuse readahead and make it restart the size rampup process it's a trivial problem, and can mostly be avoided by checking PageWriteback(page) first in readahead d) set PG_readahead => implicit set of PG_reclaim PG_readahead will never be set on already cached pages. PG_reclaim will always be cleared on dirtying a page. so not a problem. In summary, a) we get better behavior b,d) possible interactions can be avoided c) racy condition exists that might affect readahead, but the chance is _really_ low, and the hurt on readahead is trivial. Compound pages also use PG_reclaim, but for now they do not interact with reclaim/readahead code. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: remove the old algorithmFengguang Wu
Remove the old readahead algorithm. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: convert filemap invocationsFengguang Wu
Convert filemap reads to use on-demand readahead. The new call scheme is to - call readahead on non-cached page - call readahead on look-ahead page - update prev_index when finished with the read request Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: on-demand readahead logicFengguang Wu
This is a minimal readahead algorithm that aims to replace the current one. It is more flexible and reliable, while maintaining almost the same behavior and performance. Also it is full integrated with adaptive readahead. It is designed to be called on demand: - on a missing page, to do synchronous readahead - on a lookahead page, to do asynchronous readahead In this way it eliminated the awkward workarounds for cache hit/miss, readahead thrashing, retried read, and unaligned read. It also adopts the data structure introduced by adaptive readahead, parameterizes readahead pipelining with `lookahead_index', and reduces the current/ahead windows to one single window. HEURISTICS The logic deals with four cases: - sequential-next found a consistent readahead window, so push it forward - random standalone small read, so read as is - sequential-first create a new readahead window for a sequential/oversize request - lookahead-clueless hit a lookahead page not associated with the readahead window, so create a new readahead window and ramp it up In each case, three parameters are determined: - readahead index: where the next readahead begins - readahead size: how much to readahead - lookahead size: when to do the next readahead (for pipelining) BEHAVIORS The old behaviors are maximally preserved for trivial sequential/random reads. Notable changes are: - It no longer imposes strict sequential checks. It might help some interleaved cases, and clustered random reads. It does introduce risks of a random lookahead hit triggering an unexpected readahead. But in general it is more likely to do good than to do evil. - Interleaved reads are supported in a minimal way. Their chances of being detected and proper handled are still low. - Readahead thrashings are better handled. The current readahead leads to tiny average I/O sizes, because it never turn back for the thrashed pages. They have to be fault in by do_generic_mapping_read() one by one. Whereas the on-demand readahead will redo readahead for them. OVERHEADS The new code reduced the overheads of - excessively calling the readahead routine on small sized reads (the current readahead code insists on seeing all requests) - doing a lot of pointless page-cache lookups for small cached files (the current readahead only turns itself off after 256 cache hits, unfortunately most files are < 1MB, so never see that chance) That accounts for speedup of - 0.3% on 1-page sequential reads on sparse file - 1.2% on 1-page cache hot sequential reads - 3.2% on 256-page cache hot sequential reads - 1.3% on cache hot `tar /lib` However, it does introduce one extra page-cache lookup per cache miss, which impacts random reads slightly. That's 1% overheads for 1-page random reads on sparse file. PERFORMANCE The basic benchmark setup is - 2.6.20 kernel with on-demand readahead - 1MB max readahead size - 2.9GHz Intel Core 2 CPU - 2GB memory - 160G/8M Hitachi SATA II 7200 RPM disk The benchmarks show that - it maintains the same performance for trivial sequential/random reads - sysbench/OLTP performance on MySQL gains up to 8% - performance on readahead thrashing gains up to 3 times iozone throughput (KB/s): roughly the same ========================================== iozone -c -t1 -s 4096m -r 64k 2.6.20 on-demand gain first run " Initial write " 61437.27 64521.53 +5.0% " Rewrite " 47893.02 48335.20 +0.9% " Read " 62111.84 62141.49 +0.0% " Re-read " 62242.66 62193.17 -0.1% " Reverse Read " 50031.46 49989.79 -0.1% " Stride read " 8657.61 8652.81 -0.1% " Random read " 13914.28 13898.23 -0.1% " Mixed workload " 19069.27 19033.32 -0.2% " Random write " 14849.80 14104.38 -5.0% " Pwrite " 62955.30 65701.57 +4.4% " Pread " 62209.99 62256.26 +0.1% second run " Initial write " 60810.31 66258.69 +9.0% " Rewrite " 49373.89 57833.66 +17.1% " Read " 62059.39 62251.28 +0.3% " Re-read " 62264.32 62256.82 -0.0% " Reverse Read " 49970.96 50565.72 +1.2% " Stride read " 8654.81 8638.45 -0.2% " Random read " 13901.44 13949.91 +0.3% " Mixed workload " 19041.32 19092.04 +0.3% " Random write " 14019.99 14161.72 +1.0% " Pwrite " 64121.67 68224.17 +6.4% " Pread " 62225.08 62274.28 +0.1% In summary, writes are unstable, reads are pretty close on average: access pattern 2.6.20 on-demand gain Read 62085.61 62196.38 +0.2% Re-read 62253.49 62224.99 -0.0% Reverse Read 50001.21 50277.75 +0.6% Stride read 8656.21 8645.63 -0.1% Random read 13907.86 13924.07 +0.1% Mixed workload 19055.29 19062.68 +0.0% Pread 62217.53 62265.27 +0.1% aio-stress: roughly the same ============================ aio-stress -l -s4096 -r128 -t1 -o1 knoppix511-dvd-cn.iso aio-stress -l -s4096 -r128 -t1 -o3 knoppix511-dvd-cn.iso 2.6.20 on-demand delta sequential 92.57s 92.54s -0.0% random 311.87s 312.15s +0.1% sysbench fileio: roughly the same ================================= sysbench --test=fileio --file-io-mode=async --file-test-mode=rndrw \ --file-total-size=4G --file-block-size=64K \ --num-threads=001 --max-requests=10000 --max-time=900 run threads 2.6.20 on-demand delta first run 1 59.1974s 59.2262s +0.0% 2 58.0575s 58.2269s +0.3% 4 48.0545s 47.1164s -2.0% 8 41.0684s 41.2229s +0.4% 16 35.8817s 36.4448s +1.6% 32 32.6614s 32.8240s +0.5% 64 23.7601s 24.1481s +1.6% 128 24.3719s 23.8225s -2.3% 256 23.2366s 22.0488s -5.1% second run 1 59.6720s 59.5671s -0.2% 8 41.5158s 41.9541s +1.1% 64 25.0200s 23.9634s -4.2% 256 22.5491s 20.9486s -7.1% Note that the numbers are not very stable because of the writes. The overall performance is close when we sum all seconds up: sum all up 495.046s 491.514s -0.7% sysbench oltp (trans/sec): up to 8% gain ======================================== sysbench --test=oltp --oltp-table-size=10000000 --oltp-read-only \ --mysql-socket=/var/run/mysqld/mysqld.sock \ --mysql-user=root --mysql-password=readahead \ --num-threads=064 --max-requests=10000 --max-time=900 run 10000-transactions run threads 2.6.20 on-demand gain 1 62.81 64.56 +2.8% 2 67.97 70.93 +4.4% 4 81.81 85.87 +5.0% 8 94.60 97.89 +3.5% 16 99.07 104.68 +5.7% 32 95.93 104.28 +8.7% 64 96.48 103.68 +7.5% 5000-transactions run 1 48.21 48.65 +0.9% 8 68.60 70.19 +2.3% 64 70.57 74.72 +5.9% 2000-transactions run 1 37.57 38.04 +1.3% 2 38.43 38.99 +1.5% 4 45.39 46.45 +2.3% 8 51.64 52.36 +1.4% 16 54.39 55.18 +1.5% 32 52.13 54.49 +4.5% 64 54.13 54.61 +0.9% That's interesting results. Some investigations show that - MySQL is accessing the db file non-uniformly: some parts are more hot than others - It is mostly doing 4-page random reads, and sometimes doing two reads in a row, the latter one triggers a 16-page readahead. - The on-demand readahead leaves many lookahead pages (flagged PG_readahead) there. Many of them will be hit, and trigger more readahead pages. Which might save more seeks. - Naturally, the readahead windows tend to lie in hot areas, and the lookahead pages in hot areas is more likely to be hit. - The more overall read density, the more possible gain. That also explains the adaptive readahead tricks for clustered random reads. readahead thrashing: 3 times better =================================== We boot kernel with "mem=128m single", and start a 100KB/s stream on every second, until reaching 200 streams. max throughput min avg I/O size 2.6.20: 5MB/s 16KB on-demand: 15MB/s 140KB Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: data structure and routinesFengguang Wu
Extend struct file_ra_state to support the on-demand readahead logic. Also define some helpers for it. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: MIN_RA_PAGES/MAX_RA_PAGES macrosFengguang Wu
Define two convenient macros for read-ahead: - MAX_RA_PAGES: rounded down counterpart of VM_MAX_READAHEAD - MIN_RA_PAGES: rounded _up_ counterpart of VM_MIN_READAHEAD Note that the rounded up MIN_RA_PAGES will work flawlessly with _large_ page sizes like 64k. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: add look-ahead support to __do_page_cache_readahead()Fengguang Wu
Add look-ahead support to __do_page_cache_readahead(). It works by - mark the Nth backwards page with PG_readahead, (which instructs the page's first reader to invoke readahead) - and only do the marking for newly allocated pages. (to prevent blindly doing readahead on already cached pages) Look-ahead is a technique to achieve I/O pipelining: While the application is working through a chunk of cached pages, the kernel reads-ahead the next chunk of pages _before_ time of need. It effectively hides low level I/O latencies to high level applications. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: introduce PG_readaheadFengguang Wu
Introduce a new page flag: PG_readahead. It acts as a look-ahead mark, which tells the page reader: Hey, it's time to invoke the read-ahead logic. For the sake of I/O pipelining, don't wait until it runs out of cached pages! Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19only allow nonlinear vmas for ram backed filesystemsMiklos Szeredi
page_mkclean() doesn't re-protect ptes for non-linear mappings, so a later re-dirty through such a mapping will not generate a fault, PG_dirty will not reflect the dirty state and the dirty count will be skewed. This implies that msync() is also currently broken for nonlinear mappings. The easiest solution is to emulate remap_file_pages on non-linear mappings with simple mmap() for non ram-backed filesystems. Applications continue to work (albeit slower), as long as the number of remappings remain below the maximum vma count. However all currently known real uses of non-linear mappings are for ram backed filesystems, which this patch doesn't affect. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fix clear_page_dirty_for_io vs fault raceNick Piggin
Fix msync data loss and (less importantly) dirty page accounting inaccuracies due to the race remaining in clear_page_dirty_for_io(). The deleted comment explains what the race was, and the added comments explain how it is fixed. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #1Nick Piggin
Change ->fault prototype. We now return an int, which contains VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte. FAULT_RET_ code tells the VM whether a page was found, whether it has been locked, and potentially other things. This is not quite the way he wanted it yet, but that's changed in the next patch (which requires changes to arch code). This means we no longer set VM_CAN_INVALIDATE in the vma in order to say that a page is locked which requires filemap_nopage to go away (because we can no longer remain backward compatible without that flag), but we were going to do that anyway. struct fault_data is renamed to struct vm_fault as Linus asked. address is now a void __user * that we should firmly encourage drivers not to use without really good reason. The page is now returned via a page pointer in the vm_fault struct. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19ocfs2: release page lock before calling ->page_mkwriteMark Fasheh
__do_fault() was calling ->page_mkwrite() with the page lock held, which violates the locking rules for that callback. Release and retake the page lock around the callback to avoid deadlocking file systems which manually take it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: merge populate and nopage into fault (fixes nonlinear)Nick Piggin
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes the virtual address -> file offset differently from linear mappings. ->populate is a layering violation because the filesystem/pagecache code should need to know anything about the virtual memory mapping. The hitch here is that the ->nopage handler didn't pass down enough information (ie. pgoff). But it is more logical to pass pgoff rather than have the ->nopage function calculate it itself anyway (because that's a similar layering violation). Having the populate handler install the pte itself is likewise a nasty thing to be doing. This patch introduces a new fault handler that replaces ->nopage and ->populate and (later) ->nopfn. Most of the old mechanism is still in place so there is a lot of duplication and nice cleanups that can be removed if everyone switches over. The rationale for doing this in the first place is that nonlinear mappings are subject to the pagefault vs invalidate/truncate race too, and it seemed stupid to duplicate the synchronisation logic rather than just consolidate the two. After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in pagecache. Seems like a fringe functionality anyway. NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no users have hit mainline yet. [akpm@linux-foundation.org: cleanup] [randy.dunlap@oracle.com: doc. fixes for readahead] [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fix fault vs invalidate race for linear mappingsNick Piggin
Fix the race between invalidate_inode_pages and do_no_page. Andrea Arcangeli identified a subtle race between invalidation of pages from pagecache with userspace mappings, and do_no_page. The issue is that invalidation has to shoot down all mappings to the page, before it can be discarded from the pagecache. Between shooting down ptes to a particular page, and actually dropping the struct page from the pagecache, do_no_page from any process might fault on that page and establish a new mapping to the page just before it gets discarded from the pagecache. The most common case where such invalidation is used is in file truncation. This case was catered for by doing a sort of open-coded seqlock between the file's i_size, and its truncate_count. Truncation will decrease i_size, then increment truncate_count before unmapping userspace pages; do_no_page will read truncate_count, then find the page if it is within i_size, and then check truncate_count under the page table lock and back out and retry if it had subsequently been changed (ptl will serialise against unmapping, and ensure a potentially updated truncate_count is actually visible). Complexity and documentation issues aside, the locking protocol fails in the case where we would like to invalidate pagecache inside i_size. do_no_page can come in anytime and filemap_nopage is not aware of the invalidation in progress (as it is when it is outside i_size). The end result is that dangling (->mapping == NULL) pages that appear to be from a particular file may be mapped into userspace with nonsense data. Valid mappings to the same place will see a different page. Andrea implemented two working fixes, one using a real seqlock, another using a page->flags bit. He also proposed using the page lock in do_no_page, but that was initially considered too heavyweight. However, it is not a global or per-file lock, and the page cacheline is modified in do_no_page to increment _count and _mapcount anyway, so a further modification should not be a large performance hit. Scalability is not an issue. This patch implements this latter approach. ->nopage implementations return with the page locked if it is possible for their underlying file to be invalidated (in that case, they must set a special vm_flags bit to indicate so). do_no_page only unlocks the page after setting up the mapping completely. invalidation is excluded because it holds the page lock during invalidation of each page (and ensures that the page is not mapped while holding the lock). This also allows significant simplifications in do_no_page, because we have the page locked in the right place in the pagecache from the start. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18Allocate and free vmalloc areasJeremy Fitzhardinge
Allocate/release a chunk of vmalloc address space: alloc_vm_area reserves a chunk of address space, and makes sure all the pagetables are constructed for that address range - but no pages. free_vm_area releases the address space range. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ian Pratt <ian.pratt@xensource.com> Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: "Jan Beulich" <JBeulich@novell.com> Cc: "Andi Kleen" <ak@muc.de>
2007-07-18add kstrndupJeremy Fitzhardinge
Add a kstrndup function, modelled on strndup. Like strndup this returns a string copied into its own allocated memory, but it copies no more than the specified number of bytes from the source. Remove private strndup() from irda code. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@mandriva.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Panagiotis Issaris <takis@issaris.org> Cc: Rene Scharfe <rene.scharfe@lsrfire.ath.cx>
2007-07-17knfsd: nfsd4: vary maximum delegation limit based on RAM sizeMeelap Shah
Our original NFSv4 delegation policy was to give out a read delegation on any open when it was possible to. Since the lifetime of a delegation isn't limited to that of an open, a client may quite reasonably hang on to a delegation as long as it has the inode cached. This becomes an obvious problem the first time a client's inode cache approaches the size of the server's total memory. Our first quick solution was to add a hard-coded limit. This patch makes a mild incremental improvement by varying that limit according to the server's total memory size, allowing at most 4 delegations per megabyte of RAM. My quick back-of-the-envelope calculation finds that in the worst case (where every delegation is for a different inode), a delegation could take about 1.5K, which would make the worst case usage about 6% of memory. The new limit works out to be about the same as the old on a 1-gig server. [akpm@linux-foundation.org: Don't needlessly bloat vmlinux] [akpm@linux-foundation.org: Make it right for highmem machines] Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kallsyms: make KSYM_NAME_LEN include space for trailing '\0'Tejun Heo
KSYM_NAME_LEN is peculiar in that it does not include the space for the trailing '\0', forcing all users to use KSYM_NAME_LEN + 1 when allocating buffer. This is nonsense and error-prone. Moreover, when the caller forgets that it's very likely to subtly bite back by corrupting the stack because the last position of the buffer is always cleared to zero. This patch increments KSYM_NAME_LEN by one and updates code accordingly. * off-by-one bug in asm-powerpc/kprobes.h::kprobe_lookup_name() macro is fixed. * Where MODULE_NAME_LEN and KSYM_NAME_LEN were used together, MODULE_NAME_LEN was treated as if it didn't include space for the trailing '\0'. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17CONFIG_BOUNCE to avoid useless inclusion of bounce buffer logicChristoph Lameter
The bounce buffer logic is included on systems that do not need it. If a system does not have zones like ZONE_DMA and ZONE_HIGHMEM that can lead to the use of bounce buffers then there is no need to reserve memory pools etc etc. This is true f.e. for SGI Altix. Also nicifies the Makefile and gets rid of the tricky "and" there. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fs: introduce some page/buffer invariantsNick Piggin
It is a bug to set a page dirty if it is not uptodate unless it has buffers. If the page has buffers, then the page may be dirty (some buffers dirty) but not uptodate (some buffers not uptodate). The exception to this rule is if the set_page_dirty caller is racing with truncate or invalidate. A buffer can not be set dirty if it is not uptodate. If either of these situations occurs, it indicates there could be some data loss problem. Some of these warnings could be a harmless one where the page or buffer is set uptodate immediately after it is dirtied, however we should fix those up, and enforce this ordering. Bring the order of operations for truncate into line with those of invalidate. This will prevent a page from being able to go !uptodate while we're holding the tree_lock, which is probably a good thing anyway. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17MM: Make needlessly global hugetlb_no_page() static.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17SLUB: Fix CONFIG_SLUB_DEBUG use for CONFIG_NUMAChristoph Lameter
We currently cannot disable CONFIG_SLUB_DEBUG for CONFIG_NUMA. Now that embedded systems start to use NUMA we may need this. Put an #ifdef around places where NUMA only code uses fields only valid for CONFIG_SLUB_DEBUG. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17SLUB: Move sysfs operations outside of slub_lockChristoph Lameter
Sysfs can do a gazillion things when called. Make sure that we do not call any sysfs functions while holding the slub_lock. Just protect the essentials: 1. The list of all slab caches 2. The kmalloc_dma array 3. The ref counters of the slabs. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17SLUB: Do not allocate object bit array on stackChristoph Lameter
The objects per slab increase with the current patches in mm since we allow up to order 3 allocs by default. More patches in mm actually allow to use 2M or higher sized slabs. For slab validation we need per object bitmaps in order to check a slab. We end up with up to 64k objects per slab resulting in a potential requirement of 8K stack space. That does not look good. Allocate the bit arrays via kmalloc. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Slab allocators: Replace explicit zeroing with __GFP_ZEROChristoph Lameter
kmalloc_node() and kmem_cache_alloc_node() were not available in a zeroing variant in the past. But with __GFP_ZERO it is possible now to do zeroing while allocating. Use __GFP_ZERO to remove the explicit clearing of memory via memset whereever we can. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
