path: root/mm
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08Remove unused variable in get_unmapped_areaRoland McGrath
Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: mm: Deferred IO supportJaya Kumar
This implements deferred IO support in fbdev. Deferred IO is a way to delay and repurpose IO. This implementation is done using mm's page_mkwrite and page_mkclean hooks in order to detect, delay and then rewrite IO. This functionality is used by hecubafb. [adaplas] This is useful for graphics hardware with no directly addressable/mappable framebuffer. Implementing this will allow the "framebuffer" to be accesible from user space via mmap(). Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/slab_allocators and rmmodAlexey Dobriyan
Same story as with cat /proc/*/wchan race vs rmmod race, only /proc/slab_allocators want more info than just symbol name. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Remove do_sync_file_range()Mark Fasheh
Remove do_sync_file_range() and convert callers to just use do_sync_mapping_range(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Factor outstanding I/O error handlingGuillaume Chazarain
Cleanup: setting an outstanding error on a mapping was open coded too many times. Factor it out in mapping_set_error(). Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add white list into modpost.c for memory hotplug code and ia64's machvec sectionYasunori Goto
This patch is add white list into modpost.c for some functions and ia64's section to fix section mismatchs. sparse_index_alloc() and zone_wait_table_init() calls bootmem allocator at boot time, and kmalloc/vmalloc at hotplug time. If config memory hotplug is on, there are references of bootmem allocater(init text) from them (normal text). This is cause of section mismatch. Bootmem is called by many functions and it must be used only at boot time. I think __init of them should keep for section mismatch check. So, I would like to register sparse_index_alloc() and zone_wait_table_init() into white list. In addition, ia64's .machvec section is function table of some platform dependent code. It is mixture of .init.text and normal text. These reference of __init functions are valid too. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08mm: move common segment checks to separate helper functionDmitriy Monakhov
[akpm@linux-foundation.org: cleanup] Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Cc: Christoph Hellwig <hch@lst.de> Acked-by: Anton Altaparmakov <aia21@cam.ac.uk> Acked-by: David Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Increase slab redzone to 64bitsDavid Woodhouse
There are two problems with the existing redzone implementation. Firstly, it's causing misalignment of structures which contain a 64-bit integer, such as netfilter's 'struct ipt_entry' -- causing netfilter modules to fail to load because of the misalignment. (In particular, the first check in net/ipv4/netfilter/ip_tables.c::check_entry_size_and_hooks()) On ppc32 and sparc32, amongst others, __alignof__(uint64_t) == 8. With slab debugging, we use 32-bit redzones. And allocated slab objects aren't sufficiently aligned to hold a structure containing a uint64_t. By _just_ setting ARCH_KMALLOC_MINALIGN to __alignof__(u64) we'd disable redzone checks on those architectures. By using 64-bit redzones we avoid that loss of debugging, and also fix the other problem while we're at it. When investigating this, I noticed that on 64-bit platforms we're using a 32-bit value of RED_ACTIVE/RED_INACTIVE in the 64-bit memory location set aside for the redzone. Which means that the four bytes immediately before or after the allocated object at 0x00,0x00,0x00,0x00 for LE and BE machines, respectively. Which is probably not the most useful choice of poison value. One way to fix both of those at once is just to switch to 64-bit redzones in all cases. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Fix up SLUB compileLinus Torvalds
The newly merged SLUB allocator patches had been generated before the removal of "struct subsystem", and ended up applying fine, but wouldn't build based on the current tree as a result. Fix up that merge error - not that SLUB is likely really ready for showtime yet, but at least I can fix the trivial stuff. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SERIAL] sunsu: Fix section mismatch warnings. [SPARC64]: pgtable_cache_init() should be __init. [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/prom.c [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/pci.c [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/console.c [MM]: sparse_init() should be __init. [SPARC64]: Update defconfig. [VIDEO]: Add Sun XVR-2500 framebuffer driver. [VIDEO]: Add Sun XVR-500 framebuffer driver. [SPARC64]: SUN4U PCI-E controller support. [SPARC]: Fix comment typo in smp4m_blackbox_current(). [SCSI] SUNESP: sun_esp.c needs linux/delay.h Fix up conflict in arch/sparc64/mm/init.c manually due to removal of pgtable_cache_init() through the -mm patches (even though that patch was also by David ;) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07freezer: fix racy usage of try_to_freeze in kswapdRafael J. Wysocki
Currently we can miss freeze_process()->signal_wake_up() in kswapd() if it happens between try_to_freeze() and prepare_to_wait(). To prevent this from happening we should check freezing(current) before calling schedule(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07swsusp: use inline functions for changing page flagsRafael J. Wysocki
Replace direct invocations of SetPageNosave(), SetPageNosaveFree() etc. with calls to inline functions that can be changed in subsequent patches without modifying the code calling them. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slob: fix page order calculation on not 4KB pageAkinobu Mita
SLOB doesn't calculate correct page order when page size is not 4KB. This patch fixes it with using get_order() instead of find_order() which is SLOB version of get_order(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Matt Mackall <mpm@selenic.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Slab allocators: remove useless __GFP_NO_GROW flagChristoph Lameter
There is no user remaining and I have never seen any use of that flag. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slab allocators: Remove SLAB_CTOR_ATOMICChristoph Lameter
SLAB_CTOR atomic is never used which is no surprise since I cannot imagine that one would want to do something serious in a constructor or destructor. In particular given that the slab allocators run with interrupts disabled. Actions in constructors and destructors are by their nature very limited and usually do not go beyond initializing variables and list operations. (The i386 pgd ctor and dtors do take a spinlock in constructor and destructor..... I think that is the furthest we go at this point.) There is no flag passed to the destructor so removing SLAB_CTOR_ATOMIC also establishes a certain symmetry. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07get_unmapped_area doesn't need hugetlbfs hacks anymoreBenjamin Herrenschmidt
Remove the hugetlbfs specific hacks in toplevel get_unmapped_area() now that all archs and hugetlbfs itself do the right thing for both cases. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: William Irwin <bill.irwin@oracle.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07get_unmapped_area handles MAP_FIXED in generic codeBenjamin Herrenschmidt
generic arch_get_unmapped_area() now handles MAP_FIXED. Now that all implementations have been fixed, change the toplevel get_unmapped_area() to call into arch or drivers for the MAP_FIXED case. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Irwin <bill.irwin@oracle.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07oom: fix constraint deadlockDavid Rientjes
Fixes a deadlock in the OOM killer for allocations that are not __GFP_HARDWALL. Before the OOM killer checks for the allocation constraint, it takes callback_mutex. constrained_alloc() iterates through each zone in the allocation zonelist and calls cpuset_zone_allowed_softwall() to determine whether an allocation for gfp_mask is possible. If a zone's node is not in the OOM-triggering task's mems_allowed, it is not exiting, and we did not fail on a __GFP_HARDWALL allocation, cpuset_zone_allowed_softwall() attempts to take callback_mutex to check the nearest exclusive ancestor of current's cpuset. This results in deadlock. We now take callback_mutex after iterating through the zonelist since we don't need it yet. Cc: Andi Kleen <ak@suse.de> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Martin J. Bligh <mbligh@mbligh.org> Signed-off-by: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: fix handling of panic_on_oom when cpusets are in useYasunori Goto
The current panic_on_oom may not work if there is a process using cpusets/mempolicy, because other nodes' memory may remain. But some people want failover by panic ASAP even if they are used. This patch makes new setting for its request. This is tested on my ia64 box which has 3 nodes. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ethan Solomita <solo@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07fault injection: fix failslab with CONFIG_NUMAAkinobu Mita
Currently failslab injects failures into ____cache_alloc(). But with enabling CONFIG_NUMA it's not enough to let actual slab allocator functions (kmalloc, kmem_cache_alloc, ...) return NULL. This patch moves fault injection hook inside of __cache_alloc() and __cache_alloc_node(). These are lower call path than ____cache_alloc() and enable to inject faulures to slab allocators with CONFIG_NUMA. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slab allocators: Remove obsolete SLAB_MUST_HWCACHE_ALIGNChristoph Lameter
This patch was recently posted to lkml and acked by Pekka. The flag SLAB_MUST_HWCACHE_ALIGN is 1. Never checked by SLAB at all. 2. A duplicate of SLAB_HWCACHE_ALIGN for SLUB 3. Fulfills the role of SLAB_HWCACHE_ALIGN for SLOB. The only remaining use is in sparc64 and ppc64 and their use there reflects some earlier role that the slab flag once may have had. If its specified then SLAB_HWCACHE_ALIGN is also specified. The flag is confusing, inconsistent and has no purpose. Remove it. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: madvise avoid exclusive mmap_semNick Piggin
Avoid down_write of the mmap_sem in madvise when we can help it. Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07include KERN_* constant in printk() calls in mm/slab.cmatze
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slob: handle SLAB_PANIC flagAkinobu Mita
kmem_cache_create() for slob doesn't handle SLAB_PANIC. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Quicklists for page table pagesChristoph Lameter
On x86_64 this cuts allocation overhead for page table pages down to a fraction (kernel compile / editing load. TSC based measurement of times spend in each function): no quicklist pte_alloc 1569048 4.3s(401ns/2.7us/179.7us) pmd_alloc 780988 2.1s(337ns/2.7us/86.1us) pud_alloc 780072 2.2s(424ns/2.8us/300.6us) pgd_alloc 260022 1s(920ns/4us/263.1us) quicklist: pte_alloc 452436 573.4ms(8ns/1.3us/121.1us) pmd_alloc 196204 174.5ms(7ns/889ns/46.1us) pud_alloc 195688 172.4ms(7ns/881ns/151.3us) pgd_alloc 65228 9.8ms(8ns/150ns/6.1us) pgd allocations are the most complex and there we see the most dramatic improvement (may be we can cut down the amount of pgds cached somewhat?). But even the pte allocations still see a doubling of performance. 1. Proven code from the IA64 arch. The method used here has been fine tuned for years and is NUMA aware. It is based on the knowledge that accesses to page table pages are sparse in nature. Taking a page off the freelists instead of allocating a zeroed pages allows a reduction of number of cachelines touched in addition to getting rid of the slab overhead. So performance improves. This is particularly useful if pgds contain standard mappings. We can save on the teardown and setup of such a page if we have some on the quicklists. This includes avoiding lists operations that are otherwise necessary on alloc and free to track pgds. 2. Light weight alternative to use slab to manage page size pages Slab overhead is significant and even page allocator use is pretty heavy weight. The use of a per cpu quicklist means that we touch only two cachelines for an allocation. There is no need to access the page_struct (unless arch code needs to fiddle around with it). So the fast past just means bringing in one cacheline at the beginning of the page. That same cacheline may then be used to store the page table entry. Or a second cacheline may be used if the page table entry is not in the first cacheline of the page. The current code will zero the page which means touching 32 cachelines (assuming 128 byte). We get down from 32 to 2 cachelines in the fast path. 3. x86_64 gets lightweight page table page management. This will allow x86_64 arch code to faster repopulate pgds and other page table entries. The list operations for pgds are reduced in the same way as for i386 to the point where a pgd is allocated from the page allocator and when it is freed back to the page allocator. A pgd can pass through the quicklists without having to be reinitialized. 64 Consolidation of code from multiple arches So far arches have their own implementation of quicklist management. This patch moves that feature into the core allowing an easier maintenance and consistent management of quicklists. Page table pages have the characteristics that they are typically zero or in a known state when they are freed. This is usually the exactly same state as needed after allocation. So it makes sense to build a list of freed page table pages and then consume the pages already in use first. Those pages have already been initialized correctly (thus no need to zero them) and are likely already cached in such a way that the MMU can use them most effectively. Page table pages are used in a sparse way so zeroing them on allocation is not too useful. Such an implementation already exits for ia64. Howver, that implementation did not support constructors and destructors as needed by i386 / x86_64. It also only supported a single quicklist. The implementation here has constructor and destructor support as well as the ability for an arch to specify how many quicklists are needed. Quicklists are defined by an arch defining CONFIG_QUICKLIST. If more than one quicklist is necessary then we can define NR_QUICK for additional lists. F.e. i386 needs two and thus has config NR_QUICK int default 2 If an arch has requested quicklist support then pages can be allocated from the quicklist (or from the page allocator if the quicklist is empty) via: quicklist_alloc(<quicklist-nr>, <gfpflags>, <constructor>) Page table pages can be freed using: quicklist_free(<quicklist-nr>, <destructor>, <page>) Pages must have a definite state after allocation and before they are freed. If no constructor is specified then pages will be zeroed on allocation and must be zeroed before they are freed. If a constructor is used then the constructor will establish a definite page state. F.e. the i386 and x86_64 pgd constructors establish certain mappings. Constructors and destructors can also be used to track the pages. i386 and x86_64 use a list of pgds in order to be able to dynamically update standard mappings. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slub: remove object activities out of checking functionsChristoph Lameter
Make sure that the check function really only check things and do not perform activities. Extract the tracing and object seeding out of the two check functions and place them into slab_alloc and slab_free Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB: Free slabs and sort partial slab lists in kmem_cache_shrinkChristoph Lameter
At kmem_cache_shrink check if we have any empty slabs on the partial if so then remove them. Also--as an anti-fragmentation measure--sort the partial slabs so that the most fully allocated ones come first and the least allocated last. The next allocations may fill up the nearly full slabs. Having the least allocated slabs last gives them the maximum chance that their remaining objects may be freed. Thus we can hopefully minimize the partial slabs. I think this is the best one can do in terms antifragmentation measures. Real defragmentation (meaning moving objects out of slabs with the least free objects to those that are almost full) can be implemted by reverse scanning through the list produced here but that would mean that we need to provide a callback at slab cache creation that allows the deletion or moving of an object. This will involve slab API changes, so defer for now. Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slub: add ability to list alloc / free callers per slabChristoph Lameter
This patch enables listing the callers who allocated or freed objects in a cache. For example to list the allocators for kmalloc-128 do cat /sys/slab/kmalloc-128/alloc_calls 7 sn_io_slot_fixup+0x40/0x700 7 sn_io_slot_fixup+0x80/0x700 9 sn_bus_fixup+0xe0/0x380 6 param_sysfs_setup+0xf0/0x280 276 percpu_populate+0xf0/0x1a0 19 __register_chrdev_region+0x30/0x360 8 expand_files+0x2e0/0x6e0 1 sys_epoll_create+0x60/0x200 1 __mounts_open+0x140/0x2c0 65 kmem_alloc+0x110/0x280 3 alloc_disk_node+0xe0/0x200 33 as_get_io_context+0x90/0x280 74 kobject_kset_add_dir+0x40/0x140 12 pci_create_bus+0x2a0/0x5c0 1 acpi_ev_create_gpe_block+0x120/0x9e0 41 con_insert_unipair+0x100/0x1c0 1 uart_open+0x1c0/0xba0 1 dma_pool_create+0xe0/0x340 2 neigh_table_init_no_netlink+0x260/0x4c0 6 neigh_parms_alloc+0x30/0x200 1 netlink_kernel_create+0x130/0x320 5 fz_hash_alloc+0x50/0xe0 2 sn_common_hubdev_init+0xd0/0x6e0 28 kernel_param_sysfs_setup+0x30/0x180 72 process_zones+0x70/0x2e0 cat /sys/slab/kmalloc-128/free_calls 558 <not-available> 3 sn_io_slot_fixup+0x600/0x700 84 free_fdtable_rcu+0x120/0x260 2 seq_release+0x40/0x60 6 kmem_free+0x70/0xc0 24 free_as_io_context+0x20/0x200 1 acpi_get_object_info+0x3a0/0x3e0 1 acpi_add_single_object+0xcf0/0x1e40 2 con_release_unimap+0x80/0x140 1 free+0x20/0x40 SLAB_STORE_USER must be enabled for a slab cache by either booting with "slab_debug" or enabling user tracking specifically for the slab of interest. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB: Add MIN_PARTIALChristoph Lameter
We leave a mininum of partial slabs on nodes when we search for partial slabs on other node. Define a constant for that value. Then modify slub to keep MIN_PARTIAL slabs around. This avoids bad situations where a function frees the last object in a slab (which results in the page being returned to the page allocator) only to then allocate one again (which requires getting a page back from the page allocator if the partial list was empty). Keeping a couple of slabs on the partial list reduces overhead. Empty slabs are added to the end of the partial list to insure that partially allocated slabs are consumed first (defragmentation). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slub: validation of slabs (metadata and guard zones)Christoph Lameter
This enables validation of slab. Validation means that all objects are checked to see if there are redzone violations, if padding has been overwritten or any pointers have been corrupted. Also checks the consistency of slab counters. Validation enables the detection of metadata corruption without the kernel having to execute code that actually uses (allocs/frees) and object. It allows one to make sure that the slab metainformation and the guard values around an object have not been compromised. A single slabcache can be checked by writing a 1 to the "validate" file. i.e. echo 1 >/sys/slab/kmalloc-128/validate or use the slabinfo tool to check all slabs slabinfo -v Error messages will show up in the syslog. Note that validation can only reach slabs that are on a list. This means that we are usually restricted to partial slabs and active slabs unless SLAB_STORE_USER is active which will build a full slab list and allows validation of slabs that are fully in use. Booting with "slub_debug" set will enable SLAB_STORE_USER and then full diagnostic are available. Note that we attempt to push cpu slabs back to the lists when we start the check. If the cpu slab is reactivated before we get to it (another processor grabs it before we get to it) then it cannot be checked. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slub: enable tracking of full slabsChristoph Lameter
If slab tracking is on then build a list of full slabs so that we can verify the integrity of all slabs and are also able to built list of alloc/free callers. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slub: fix object trackingChristoph Lameter
Object tracking did not work the right way for several call chains. Fix this up by adding a new parameter to slub_alloc and slub_free that specifies the caller address explicitly. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Add virt_to_head_page and consolidate code in slab and slubChristoph Lameter
2007-05-07mm: optimize compound_head() by avoiding a shared page flagChristoph Lameter
The patch adds PageTail(page) and PageHead(page) to check if a page is the head or the tail of a compound page. This is done by masking the two bits describing the state of a compound page and then comparing them. So one comparision and a branch instead of two bit checks and two branches. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB: allocate smallest object size if the user asks for 0 bytesChristoph Lameter
Makes SLUB behave like SLAB in this area to avoid issues.... Throw a stack dump to alert people. At some point the behavior should be switched back. NULL is no memory as far as I can tell and if the use asked for 0 bytes then he need to get no memory. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB: change default alignmentsChristoph Lameter
Structures may contain u64 items on 32 bit platforms that are only able to address 64 bit items on 64 bit boundaries. Change the mininum alignment of slabs to conform to those expectations. ARCH_KMALLOC_MINALIGN must be changed for good since a variety of structure are mixed in the general slabs. ARCH_SLAB_MINALIGN is changed because currently there is no consistent specification of object alignment. We may have that in the future when the KMEM_CACHE and related macros are used to generate slabs. These pass the alignment of the structure generated by the compiler to the slab. With KMEM_CACHE etc we could align structures that do not contain 64 bit values to 32 bit boundaries potentially saving some memory. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLUB coreChristoph Lameter
This is a new slab allocator which was motivated by the complexity of the existing code in mm/slab.c. It attempts to address a variety of concerns with the existing implementation. A. Management of object queues A particular concern was the complex management of the numerous object queues in SLAB. SLUB has no such queues. Instead we dedicate a slab for each allocating CPU and use objects from a slab directly instead of queueing them up. B. Storage overhead of object queues SLAB Object queues exist per node, per CPU. The alien cache queue even has a queue array that contain a queue for each processor on each node. For very large systems the number of queues and the number of objects that may be caught in those queues grows exponentially. On our systems with 1k nodes / processors we have several gigabytes just tied up for storing references to objects for those queues This does not include the objects that could be on those queues. One fears that the whole memory of the machine could one day be consumed by those queues. C. SLAB meta data overhead SLAB has overhead at the beginning of each slab. This means that data cannot be naturally aligned at the beginning of a slab block. SLUB keeps all meta data in the corresponding page_struct. Objects can be naturally aligned in the slab. F.e. a 128 byte object will be aligned at 128 byte boundaries and can fit tightly into a 4k page with no bytes left over. SLAB cannot do this. D. SLAB has a complex cache reaper SLUB does not need a cache reaper for UP systems. On SMP systems the per CPU slab may be pushed back into partial list but that operation is simple and does not require an iteration over a list of objects. SLAB expires per CPU, shared and alien object queues during cache reaping which may cause strange hold offs. E. SLAB has complex NUMA policy layer support SLUB pushes NUMA policy handling into the page allocator. This means that allocation is coarser (SLUB does interleave on a page level) but that situation was also present before 2.6.13. SLABs application of policies to individual slab objects allocated in SLAB is certainly a performance concern due to the frequent references to memory policies which may lead a sequence of objects to come from one node after another. SLUB will get a slab full of objects from one node and then will switch to the next. F. Reduction of the size of partial slab lists SLAB has per node partial lists. This means that over time a large number of partial slabs may accumulate on those lists. These can only be reused if allocator occur on specific nodes. SLUB has a global pool of partial slabs and will consume slabs from that pool to decrease fragmentation. G. Tunables SLAB has sophisticated tuning abilities for each slab cache. One can manipulate the queue sizes in detail. However, filling the queues still requires the uses of the spin lock to check out slabs. SLUB has a global parameter (min_slab_order) for tuning. Increasing the minimum slab order can decrease the locking overhead. The bigger the slab order the less motions of pages between per CPU and partial lists occur and the better SLUB will be scaling. G. Slab merging We often have slab caches with similar parameters. SLUB detects those on boot up and merges them into the corresponding general caches. This leads to more effective memory use. About 50% of all caches can be eliminated through slab merging. This will also decrease slab fragmentation because partial allocated slabs can be filled up again. Slab merging can be switched off by specifying slub_nomerge on boot up. Note that merging can expose heretofore unknown bugs in the kernel because corrupted objects may now be placed differently and corrupt differing neighboring objects. Enable sanity checks to find those. H. Diagnostics The current slab diagnostics are difficult to use and require a recompilation of the kernel. SLUB contains debugging code that is always available (but is kept out of the hot code paths). SLUB diagnostics can be enabled via the "slab_debug" option. Parameters can be specified to select a single or a group of slab caches for diagnostics. This means that the system is running with the usual performance and it is much more likely that race conditions can be reproduced. I. Resiliency If basic sanity checks are on then SLUB is capable of detecting common error conditions and recover as best as possible to allow the system to continue. J. Tracing Tracing can be enabled via the slab_debug=T,<slabcache> option during boot. SLUB will then protocol all actions on that slabcache and dump the object contents on free. K. On demand DMA cache creation. Generally DMA caches are not needed. If a kmalloc is used with __GFP_DMA then just create this single slabcache that is needed. For systems that have no ZONE_DMA requirement the support is completely eliminated. L. Performance increase Some benchmarks have shown speed improvements on kernbench in the range of 5-10%. The locking overhead of slub is based on the underlying base allocation size. If we can reliably allocate larger order pages then it is possible to increase slub performance much further. The anti-fragmentation patches may enable further performance increases. Tested on: i386 UP + SMP, x86_64 UP + SMP + NUMA emulation, IA64 NUMA + Simulator SLUB Boot options slub_nomerge Disable merging of slabs slub_min_order=x Require a minimum order for slab caches. This increases the managed chunk size and therefore reduces meta data and locking overhead. slub_min_objects=x Mininum objects per slab. Default is 8. slub_max_order=x Avoid generating slabs larger than order specified. slub_debug Enable all diagnostics for all caches slub_debug=<options> Enable selective options for all caches slub_debug=<o>,<cache> Enable selective options for a certain set of caches Available Debug options F Double Free checking, sanity and resiliency R Red zoning P Object / padding poisoning U Track last free / alloc T Trace all allocs / frees (only use for individual slabs). To use SLUB: Apply this patch and then select SLUB as the default slab allocator. [hugh@veritas.com: fix an oops-causing locking error] [akpm@linux-foundation.org: various stupid cleanups and small fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slab: mark set_up_list3s() __initAndrew Morton
It is only ever used prior to free_initmem(). (It will cause a warning when we run the section checking, but that's a false-positive and it simply changes the source of an existing warning, which is also a false-positive) Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Do not disable interrupts when reading min_free_kbytesMel Gorman
The sysctl handler for min_free_kbytes calls setup_per_zone_pages_min() on read or write. This function iterates through every zone and calls spin_lock_irqsave() on the zone LRU lock. When reading min_free_kbytes, this is a total waste of time that disables interrupts on the local processor. It might even be noticable machines with large numbers of zones if a process started constantly reading min_free_kbytes. This patch only calls setup_per_zone_pages_min() only on write. Tested on an x86 laptop and it did the right thing. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07slab: NUMA kmem_cache dietEric Dumazet
Some NUMA machines have a big MAX_NUMNODES (possibly 1024), but fewer possible nodes. This patch dynamically sizes the 'struct kmem_cache' to allocate only needed space. I moved nodelists[] field at the end of struct kmem_cache, and use the following computation in kmem_cache_init() cache_cache.buffer_size = offsetof(struct kmem_cache, nodelists) + nr_node_ids * sizeof(struct kmem_list3 *); On my two nodes x86_64 machine, kmem_cache.obj_size is now 192 instead of 704 (This is because on x86_64, MAX_NUMNODES is 64) On bigger NUMA setups, this might reduce the gfporder of "cache_cache" Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLAB: don't allocate empty shared cachesEric Dumazet
We can avoid allocating empty shared caches and avoid unecessary check of cache->limit. We save some memory. We avoid bringing into CPU cache unecessary cache lines. All accesses to l3->shared are already checking NULL pointers so this patch is safe. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07SLAB: use num_possible_cpus() in enable_cpucache()Eric Dumazet
The existing comment in mm/slab.c is *perfect*, so I reproduce it : /* * CPU bound tasks (e.g. network routing) can exhibit cpu bound * allocation behaviour: Most allocs on one cpu, most free operations * on another cpu. For these cases, an efficient object passing between * cpus is necessary. This is provided by a shared array. The array * replaces Bonwick's magazine layer. * On uniprocessor, it's functionally equivalent (but less efficient) * to a larger limit. Thus disabled by default. */ As most shiped linux kernels are now compiled with CONFIG_SMP, there is no way a preprocessor #if can detect if the machine is UP or SMP. Better to use num_possible_cpus(). This means on UP we allocate a 'size=0 shared array', to be more efficient. Another patch can later avoid the allocations of 'empty shared arrays', to save some memory. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07readahead: code cleanupJan Kara
Rename file_ra_state.prev_page to prev_index and file_ra_state.offset to prev_offset. Also update of prev_index in do_generic_mapping_read() is now moved close to the update of prev_offset. [wfg@mail.ustc.edu.cn: fix it] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07readahead: improve heuristic detecting sequential readsJan Kara
Introduce ra.offset and store in it an offset where the previous read ended. This way we can detect whether reads are really sequential (and thus we should not mark the page as accessed repeatedly) or whether they are random and just happen to be in the same page (and the page should really be marked accessed again). Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Add unitialized_var() macro for suppressing gcc warningsBorislav Petkov
Introduce a macro for suppressing gcc from generating a warning about a probable uninitialized state of a variable. Example: - spinlock_t *ptl; + spinlock_t *uninitialized_var(ptl); Not a happy solution, but those warnings are obnoxious. - Using the usual pointlessly-set-it-to-zero approach wastes several bytes of text. - Using a macro means we can (hopefully) do something else if gcc changes cause the `x = x' hack to stop working - Using a macro means that people who are worried about hiding true bugs can easily turn it off. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
