Slub reloads the per cpu slab if the page does not satisfy the NUMA condition. Track
those reloads since doing so has a performance impact.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
We can avoid deactivate slab in special cases if we do the
deactivation of slabs in each code flow that leads to new_slab.
Disabling interrupts can be avoided now. However, list operation still require
disabling interrupts since allocations can occur from interrupt
contexts and there is no way to perform atomic list operations.
The acquition of the list_lock therefore has to disable interrupts as well.
Dropping interrupt handling significantly simplifies the slowpath.
We will be calling free_debug_processing with interrupts disabled
in some case when the later patches are applied. Some of the
functions called by free_debug_processing expect interrupts to be
off.
Locking slabs is no longer necesary if the arch supports cmpxchg operations
and if no debuggin features are used on a slab. If the arch does not support
cmpxchg then we fallback to use the slab lock to do a cmpxchg like operation.
The patch also changes the lock order. Slab locks are subsumed to the node lock
now. With that approach slab_trylocking is no longer necessary.
Rework the allocation paths so that updates of the page freelist, frozen state
and number of objects use cmpxchg_double_slab().
We need more information about the slab for the cmpxchg implementation.
Acked-by: David Rientjes <rientjes@google.com>
The allocator fastpath rework does change the usage of the list_lock.
Remove the list_lock processing from the functions that hide them from the
critical sections and move them into those critical sections.
This in turn simplifies the support functions (no __ variant needed anymore)
and simplifies the lock handling on bootstrap.
Inline add_partial since it becomes pretty simple.
Add a function that operates on the second doubleword in the page struct
and manipulates the object counters, the freelist and the frozen attribute.
This is necessary because the frozen bit has to be handled in the same cmpxchg_double
with the freelist and the counters.
Do not use a page flag for the frozen bit. It needs to be part
of the state that is handled with cmpxchg_double(). So use a bit
in the counter struct in the page struct for that purpose.
Do the irq handling in allocate_slab() instead of __slab_alloc().
__slab_alloc() is already cluttered and allocate_slab() is already
fiddling around with gfp flags.
v6->v7:
Only increment ORDER_FALLBACK if we get a page during fallback
Commit d149e3b25d7c ("memcg: add the soft_limit reclaim in global direct
reclaim") adds a softlimit hook to shrink_zones(). By this, soft limit
is called as
try_to_free_pages()
do_try_to_free_pages()
shrink_zones()
mem_cgroup_soft_limit_reclaim()
Then, direct reclaim is memcg softlimit hint aware, now.
But, the memory cgroup's "limit" path can call softlimit shrinker.
try_to_free_mem_cgroup_pages()
shrink_zones()
This will cause a global reclaim when a memcg hits limit.
This is bug. soft_limit_reclaim() should be called when
scanning_global_lru(sc) == true.
And the commit adds a variable "total_scanned" for counting softlimit
scanned pages....it's not "total". This patch removes the variable and
update sc->nr_scanned instead of it. This will affect shrink_slab()'s
scan condition but, global LRU is scanned by softlimit and I think this
change makes sense.
TODO: avoid too much scanning of a zone when softlimit did enough work.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Under heavy memory and filesystem load, users observe the assertion
mapping->nrpages == 0 in end_writeback() trigger. This can be caused by
page reclaim reclaiming the last page from a mapping in the following
race:
CPU0 CPU1
shrink_page_list()
__remove_mapping()
__delete_from_page_cache()
radix_tree_delete()
evict_inode()
truncate_inode_pages()
truncate_inode_pages_range()
pagevec_lookup() - finds nothing
end_writeback()
mapping->nrpages != 0 -> BUG
page->mapping = NULL
mapping->nrpages--
Fix the problem by doing a reliable check of mapping->nrpages under
mapping->tree_lock in end_writeback().
Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out
by Miklos Szeredi <mszeredi@suse.de>.
Cc: Jay <jinshan.xiong@whamcloud.com>
Cc: Miklos Szeredi <mszeredi@suse.de>
Cc: <stable@kernel.org>
We cannot take a mutex while holding a spinlock, so flip the order and
fix the locking documentation.
Acked-by: Andi Kleen <ak@linux.intel.com>
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp()
is unsuited to tmpfs, because it inserts a page into pagecache before
calling the filesystem's ->readpage: tmpfs may have pages in swapcache
which only it knows how to locate and switch to filecache.
At present tmpfs provides a ->readpage method, and copes with this by
copying pages; but soon we can simplify it by removing its ->readpage.
Provide shmem_read_mapping_page_gfp() now, ready for that transition,
Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h,
with shmem_read_mapping_page() inline for the common mapping_gfp case.
(shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the
read_mapping_page functions use the mapping's ->readpage, and the
read_cache_page functions use the supplied filler, so I think
read_cache_page_gfp was slightly misnamed.)
2.6.35's new truncate convention gave tmpfs the opportunity to control
its file truncation, no longer enforced from outside by vmtruncate().
We shall want to build upon that, to handle pagecache and swap together.
Slightly redefine the ->truncate_range interface: let it now be called
between the unmap_mapping_range()s, with the filesystem responsible for
doing the truncate_inode_pages_range() from it - just as the filesystem
is nowadays responsible for doing that from its ->setattr.
Let's rename shmem_notify_change() to shmem_setattr(). Instead of
calling the generic truncate_setsize(), bring that code in so we can
call shmem_truncate_range() - which will later be updated to perform its
own variant of truncate_inode_pages_range().
Remove the punch_hole unmap_mapping_range() from shmem_truncate_range():
now that the COW's unmap_mapping_range() comes after ->truncate_range,
there is no need to call it a third time.
Export shmem_truncate_range() and add it to the list in shmem_fs.h, so
that i915_gem_object_truncate() can call it explicitly in future; get
this patch in first, then update drm/i915 once this is available (until
then, i915 will just be doing the truncate_inode_pages() twice).
Though introduced five years ago, no other filesystem is implementing
->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we
expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly,
whereupon ->truncate_range can be removed from inode_operations -
shmem_truncate_range() will help i915 across that transition too.
Before adding any more global entry points into shmem.c, gather such
prototypes into shmem_fs.h. Remove mm's own declarations from swap.h,
but for now leave the ones in mm.h: because shmem_file_setup() and
shmem_zero_setup() are called from various places, and we should not
force other subsystems to update immediately.
You would expect to find vmtruncate_range() next to vmtruncate() in
mm/truncate.c: move it there.
Acked-by: Christoph Hellwig <hch@infradead.org>
Commit 959ecc48fc75 ("mm/memory_hotplug.c: fix building of node hotplug
zonelist") does not protect the build_all_zonelists() call with
zonelists_mutex as needed. This can lead to races in constructing
zonelist ordering if a concurrent build is underway. Protecting this
with lock_memory_hotplug() is insufficient since zonelists can be
rebuild though sysfs as well.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
The error handling in mem_online_node() is incorrect: hotadd_new_pgdat()
returns NULL if the new pgdat could not have been allocated and a pointer
to it otherwise.
mem_online_node() should fail if hotadd_new_pgdat() fails, not the
inverse. This fixes an issue when memoryless nodes are not onlined and
their sysfs interface is not registered when their first cpu is brought
up.
The bug was introduced by commit cf23422b9d76 ("cpu/mem hotplug: enable
CPUs online before local memory online") iow v2.6.35.
Cc: stable@kernel.org
Hugh Dickins points out that lockdep (correctly) spots a potential
deadlock on the anon_vma lock, because we now do a GFP_KERNEL allocation
of anon_vma_chain while doing anon_vma_clone(). The problem is that
page reclaim will want to take the anon_vma lock of any anonymous pages
that it will try to reclaim.
So re-organize the code in anon_vma_clone() slightly: first do just a
GFP_NOWAIT allocation, which will usually work fine. But if that fails,
let's just drop the lock and re-do the allocation, now with GFP_KERNEL.
End result: not only do we avoid the locking problem, this also ends up
getting better concurrency in case the allocation does need to block.
Tim Chen reports that with all these anon_vma locking tweaks, we're now
almost back up to the spinlock performance.
Reported-and-tested-by: Hugh Dickins <hughd@google.com>
Tested-by: Tim Chen <tim.c.chen@linux.intel.com>
This matches the anon_vma_clone() case, and uses the same lock helper
functions. Because of the need to potentially release the anon_vma's,
it's a bit more complex, though.
We traverse the 'vma->anon_vma_chain' in two phases: the first loop gets
the anon_vma lock (with the helper function that only takes the lock
once for the whole loop), and removes any entries that don't need any
more processing.
The second phase just traverses the remaining list entries (without
holding the anon_vma lock), and does any actual freeing of the
anon_vma's that is required.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Hugh Dickins <hughd@google.com>
In anon_vma_clone() we traverse the vma->anon_vma_chain of the source
vma, locking the anon_vma for each entry.
But they are all going to have the same root entry, which means that
we're locking and unlocking the same lock over and over again. Which is
expensive in locked operations, but can get _really_ expensive when that
root entry sees any kind of lock contention.
In fact, Tim Chen reports a big performance regression due to this: when
we switched to use a mutex instead of a spinlock, the contention case
gets much worse.
So to alleviate this all, this commit creates a small helper function
(lock_anon_vma_root()) that can be used to take the lock just once
rather than taking and releasing it over and over again.
We still have the same "take the lock and release" it behavior in the
exit path (in unlink_anon_vmas()), but that one is a bit harder to fix
since we're actually freeing the anon_vma entries as we go, and that
will touch the lock too.
Reported-and-tested-by: Tim Chen <tim.c.chen@linux.intel.com>
swapcache will reach the below code path in migrate_page_move_mapping,
and swapcache is accounted as NR_FILE_PAGES but it's not accounted as
NR_SHMEM.
Hugh pointed out we must use PageSwapCache instead of comparing
mapping to &swapper_space, to avoid build failure with CONFIG_SWAP=n.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
We have some users of this function that date back to before the vma
list was doubly linked, and just are silly. These days, you can find
the previous vma by just following the vma->vm_prev pointer.
In some cases you don't need any find_vma() lookup at all, and in other
cases you're better off with the regular "find_vma()" that uses the vma
cache front-end lookup.
Some "find_vma_prev()" users are still valid, though. For example, in
the case of a stack that grows up, it can be the case that we don't find
any 'vma' at all (because we're looking up an address that is past the
last vma), and that the stack that we want to grow is the 'prev' vma.
But that kind of special case aside, we generally should prefer to use
'find_vma()'.
Noticed due to a totally unrelated POWER memory corruption bug that just
happened to hit in 'find_vma_prev()' and made me go "Hmm - why are we
using that function here?".
Andrea Righi reported a case where an exiting task can race against
ksmd::scan_get_next_rmap_item (http://lkml.org/lkml/2011/6/1/742) easily
triggering a NULL pointer dereference in ksmd.
ksm_scan.mm_slot == &ksm_mm_head with only one registered mm
CPU 1 (__ksm_exit) CPU 2 (scan_get_next_rmap_item)
list_empty() is false
lock slot == &ksm_mm_head
list_del(slot->mm_list)
(list now empty)
unlock
lock
slot = list_entry(slot->mm_list.next)
(list is empty, so slot is still ksm_mm_head)
unlock
slot->mm == NULL ... Oops
Close this race by revalidating that the new slot is not simply the list
head again.
Andrea's test case:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#define BUFSIZE getpagesize()
int main(int argc, char **argv)
void *ptr;
if (posix_memalign(&ptr, getpagesize(), BUFSIZE) < 0) {
perror("posix_memalign");
exit(1);
if (madvise(ptr, BUFSIZE, MADV_MERGEABLE) < 0) {
perror("madvise");
exit(1);
*(char *)NULL = 0;
return 0;
Reported-by: Andrea Righi <andrea@betterlinux.com>
Tested-by: Andrea Righi <andrea@betterlinux.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
is asynchronous V2
Asynchronous compaction is used when promoting to huge pages. This is all
very nice but if there are a number of processes in compacting memory, a
large number of pages can be isolated. An "asynchronous" process can
stall for long periods of time as a result with a user reporting that
firefox can stall for 10s of seconds. This patch aborts asynchronous
compaction if too many pages are isolated as it's better to fail a
hugepage promotion than stall a process.
[minchan.kim@gmail.com: return COMPACT_PARTIAL for abort]
Reported-and-tested-by: Ury Stankevich <urykhy@gmail.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
It is unsafe to run page_count during the physical pfn scan because
compound_head could trip on a dangling pointer when reading
page->first_page if the compound page is being freed by another CPU.
[mgorman@suse.de: split out patch]
next zone
Compaction works with two scanners, a migration and a free scanner. When
the scanners crossover, migration within the zone is complete. The
location of the scanner is recorded on each cycle to avoid excesive
scanning.
When a zone is small and mostly reserved, it's very easy for the migration
scanner to be close to the end of the zone. Then the following situation
can occurs
o migration scanner isolates some pages near the end of the zone
o free scanner starts at the end of the zone but finds that the
migration scanner is already there
o free scanner gets reinitialised for the next cycle as
cc->migrate_pfn + pageblock_nr_pages
moving the free scanner into the next zone
o migration scanner moves into the next zone
When this happens, NR_ISOLATED accounting goes haywire because some of the
accounting happens against the wrong zone. One zones counter remains
positive while the other goes negative even though the overall global
count is accurate. This was reported on X86-32 with !SMP because !SMP
allows the negative counters to be visible. The fact that it is the bug
should theoritically be possible there.
fragmentation_index() returns -1000 when the allocation might succeed
This doesn't match the comment and code in compaction_suitable(). I
thought compaction_suitable should return COMPACT_PARTIAL in -1000
case, because in this case allocation could succeed depending on
watermarks.
The impact of this is that compaction starts and compact_finished() is
called which rechecks the watermarks and the free lists. It should have
the same result in that compaction should not start but is more expensive.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Pages isolated for migration are accounted with the vmstat counters
NR_ISOLATE_[ANON|FILE]. Callers of migrate_pages() are expected to
increment these counters when pages are isolated from the LRU. Once the
pages have been migrated, they are put back on the LRU or freed and the
isolated count is decremented.
Memory failure is not properly accounting for pages it isolates causing
the NR_ISOLATED counters to be negative. On SMP builds, this goes
unnoticed as negative counters are treated as 0 due to expected per-cpu
drift. On UP builds, the counter is treated by too_many_isolated() as a
large value causing processes to enter D state during page reclaim or
compaction. This patch accounts for pages isolated by memory failure
correctly.
[mel@csn.ul.ie: rewrote changelog]
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Based on Michal Hocko's comment.
We are not draining per cpu cached charges during soft limit reclaim
because background reclaim doesn't care about charges. It tries to free
some memory and charges will not give any.
Cached charges might influence only selection of the biggest soft limit
offender but as the call is done only after the selection has been already
done it makes no change.
For performance, memory cgroup caches some "charge" from res_counter into
per cpu cache. This works well but because it's cache, it needs to be
flushed in some cases. Typical cases are
1. when someone hit limit.
2. when rmdir() is called and need to charges to be 0.
But "1" has problem.
Recently, with large SMP machines, we see many kworker runs because of
flushing memcg's cache. Bad things in implementation are that even if a
cpu contains a cache for memcg not related to a memcg which hits limit,
drain code is called.
This patch does
A) check percpu cache contains a useful data or not.
B) check other asynchronous percpu draining doesn't run.
C) don't call local cpu callback.
(*)This patch avoid changing the calling condition with hard-limit.
When I run "cat 1Gfile > /dev/null" under 300M limit memcg,
[Before]
13767 kamezawa 20 0 98.6m 424 416 D 10.0 0.0 0:00.61 cat
58 root 20 0 0 0 0 S 0.6 0.0 0:00.09 kworker/2:1
60 root 20 0 0 0 0 S 0.6 0.0 0:00.08 kworker/4:1
4 root 20 0 0 0 0 S 0.3 0.0 0:00.02 kworker/0:0
57 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/1:1
61 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/5:1
62 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/6:1
63 root 20 0 0 0 0 S 0.3 0.0 0:00.05 kworker/7:1
[After]
2676 root 20 0 98.6m 416 416 D 9.3 0.0 0:00.87 cat
2626 kamezawa 20 0 15192 1312 920 R 0.3 0.0 0:00.28 top
1 root 20 0 19384 1496 1204 S 0.0 0.0 0:00.66 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksoftirqd/0
4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0
[akpm@linux-foundation.org: make percpu_charge_mutex static, tweak comments]
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Tested-by: Ying Han <yinghan@google.com>
Hierarchical reclaim doesn't swap out if memsw and resource limits are
thye same (memsw_is_minimum == true) because we would hit mem+swap limit
anyway (during hard limit reclaim).
If it comes to the soft limit we shouldn't consider memsw_is_minimum at
all because it doesn't make much sense. Either the soft limit is bellow
the hard limit and then we cannot hit mem+swap limit or the direct reclaim
takes a precedence.
Commit 21a3c9646873 ("memcg: allocate memory cgroup structures in local
nodes") makes page_cgroup allocation as NUMA aware. But that caused a
problem https://bugzilla.kernel.org/show_bug.cgi?id=36192.
The problem was getting a NID from invalid struct pages, which was not
initialized because it was out-of-node, out of [node_start_pfn,
node_end_pfn)
Now, with sparsemem, page_cgroup_init scans pfn from 0 to max_pfn. But
this may scan a pfn which is not on any node and can access memmap which
is not initialized.
This makes page_cgroup_init() for SPARSEMEM node aware and remove a code
to get nid from page->flags. (Then, we'll use valid NID always.)
[akpm@linux-foundation.org: try to fix up comments]
Commit 406eb0c9ba76 ("memcg: add memory.numastat api for numa
statistics") adds memory.numa_stat file for memory cgroup. But the file
permissions are wrong.
[kamezawa@bluextal linux-2.6]$ ls -l /cgroup/memory/A/memory.numa_stat
---------- 1 root root 0 Jun 9 18:36 /cgroup/memory/A/memory.numa_stat
This patch fixes the permission as
[root@bluextal kamezawa]# ls -l /cgroup/memory/A/memory.numa_stat
-r--r--r-- 1 root root 0 Jun 10 16:49 /cgroup/memory/A/memory.numa_stat
Acked-by: Ying Han <yinghan@google.com>
When 1GB hugepages are allocated on a system, free(1) reports less
available memory than what really is installed in the box. Also, if the
total size of hugepages allocated on a system is over half of the total
memory size, CommitLimit becomes a negative number.
The problem is that gigantic hugepages (order > MAX_ORDER) can only be
allocated at boot with bootmem, thus its frames are not accounted to
'totalram_pages'. However, they are accounted to hugetlb_total_pages()
What happens to turn CommitLimit into a negative number is this
calculation, in fs/proc/meminfo.c:
allowed = ((totalram_pages - hugetlb_total_pages())
* sysctl_overcommit_ratio / 100) + total_swap_pages;
A similar calculation occurs in __vm_enough_memory() in mm/mmap.c.
Also, every vm statistic which depends on 'totalram_pages' will render
confusing values, as if system were 'missing' some part of its memory.
Impact of this bug:
When gigantic hugepages are allocated and sysctl_overcommit_memory ==
OVERCOMMIT_NEVER. In a such situation, __vm_enough_memory() goes through
the mentioned 'allowed' calculation and might end up mistakenly returning
-ENOMEM, thus forcing the system to start reclaiming pages earlier than it
would be ususal, and this could cause detrimental impact to overall
system's performance, depending on the workload.
Besides the aforementioned scenario, I can only think of this causing
annoyances with memory reports from /proc/meminfo and free(1).
[akpm@linux-foundation.org: standardize comment layout]
Reported-by: Russ Anderson <rja@sgi.com>
Signed-off-by: Rafael Aquini <aquini@linux.com>
Acked-by: Russ Anderson <rja@sgi.com>
Cc: Christoph Lameter <cl@linux.com>
During memory hotplug we refresh zonelists when we online a page in a new
zone. It means that the node's zonelist is not initialized until pages
are onlined. So for example, "nid" passed by MEM_GOING_ONLINE notifier
will point to NODE_DATA(nid) which has no zone fallback list. Moreover,
if we hot-add cpu-only nodes, alloc_pages() will do no fallback.
This patch makes a zonelist when a new pgdata is available.
Note: in production, at fujitsu, memory should be onlined before cpu
and our server didn't have any memory-less nodes and had no problems.
But recent changes in MEM_GOING_ONLINE+page_cgroup
will access not initialized zonelist of node.
Anyway, there are memory-less node and we need some care.
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Commit 56de7263fcf3 ("mm: compaction: direct compact when a high-order
allocation fails") introduced a check for cc->order == -1 in
compact_finished. We should continue compacting in that case because
the request came from userspace and there is no particular order to
compact for. Similar check has been added by 82478fb7 (mm: compaction:
prevent division-by-zero during user-requested compaction) for
compaction_suitable.
The check is, however, done after zone_watermark_ok which uses order as a
right hand argument for shifts. Not only watermark check is pointless if
we can break out without it but it also uses 1 << -1 which is not well
defined (at least from C standard). Let's move the -1 check above
zone_watermark_ok.
[minchan.kim@gmail.com> - caught compaction_suitable]
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com>
Running a ktest.pl test, I hit the following bug on x86_32:
WARNING: at arch/x86/mm/highmem_32.c:81 __kunmap_atomic+0x64/0xc1()
Hardware name:
Modules linked in:
Pid: 93, comm: sh Not tainted 2.6.39-test+ #1
Call Trace:
[<c04450da>] warn_slowpath_common+0x7c/0x91
[<c042f5df>] ? __kunmap_atomic+0x64/0xc1
[<c042f5df>] ? __kunmap_atomic+0x64/0xc1^M
[<c0445111>] warn_slowpath_null+0x22/0x24
[<c042f5df>] __kunmap_atomic+0x64/0xc1
[<c04d4a22>] unmap_vmas+0x43a/0x4e0
[<c04d9065>] exit_mmap+0x91/0xd2
[<c0443057>] mmput+0x43/0xad
[<c0448358>] exit_mm+0x111/0x119
[<c044855f>] do_exit+0x1ff/0x5fa
[<c0454ea2>] ? set_current_blocked+0x3c/0x40
[<c0454f24>] ? sigprocmask+0x7e/0x8e
[<c0448b55>] do_group_exit+0x65/0x88
[<c0448b90>] sys_exit_group+0x18/0x1c
[<c0c3915f>] sysenter_do_call+0x12/0x38
---[ end trace 8055f74ea3c0eb62 ]---
Running a ktest.pl git bisect, found the culprit: commit e303297e6c3a
("mm: extended batches for generic mmu_gather")
But although this was the commit triggering the bug, it was not the one
originally responsible for the bug. That was commit d16dfc550f53 ("mm:
mmu_gather rework").
The code in zap_pte_range() has something that looks like the following:
pte = pte_offset_map_lock(mm, pmd, addr, &ptl);
do {
} while (pte++, addr += PAGE_SIZE, addr != end);
pte_unmap_unlock(pte - 1, ptl);
The pte starts off pointing at the first element in the page table
directory that was returned by the pte_offset_map_lock(). When it's done
with the page, pte will be pointing to anything between the next entry and
the first entry of the next page inclusive. By doing a pte - 1, this puts
the pte back onto the original page, which is all that pte_unmap_unlock()
needs.
In most archs (64 bit), this is not an issue as the pte is ignored in the
pte_unmap_unlock(). But on 32 bit archs, where things may be kmapped, it
is essential that the pte passed to pte_unmap_unlock() resides on the same
page that was given by pte_offest_map_lock().
The problem came in d16dfc55 ("mm: mmu_gather rework") where it introduced
a "break;" from the while loop. This alone did not seem to easily trigger
the bug. But the modifications made by e303297e6 caused that "break;" to
be hit on the first iteration, before the pte++.
The pte not being incremented will now cause pte_unmap_unlock(pte - 1) to
be pointing to the previous page. This will cause the wrong page to be
unmapped, and also trigger the warning above.
The simple solution is to just save the pointer given by
pte_offset_map_lock() and use it in the unlock.
While testing for memcg aware swap token, I observed a swap token was
often grabbed an intermittent running process (eg init, auditd) and they
never release a token.
Why?
Some processes (eg init, auditd, audispd) wake up when a process exiting.
And swap token can be get first page-in process when a process exiting
makes no swap token owner. Thus such above intermittent running process
often get a token.
And currently, swap token priority is only decreased at page fault path.
Then, if the process sleep immediately after to grab swap token, the swap
token priority never be decreased. That's obviously undesirable.
This patch implement very poor (and lightweight) priority aging. It only
be affect to the above corner case and doesn't change swap tendency
workload performance (eg multi process qsbench load)
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This is useful for observing swap token activity.
example output:
zsh-1845 [000] 598.962716: update_swap_token_priority:
mm=ffff88015eaf7700 old_prio=1 new_prio=0
memtoy-1830 [001] 602.033900: update_swap_token_priority:
mm=ffff880037a45880 old_prio=947 new_prio=949
memtoy-1830 [000] 602.041509: update_swap_token_priority:
mm=ffff880037a45880 old_prio=949 new_prio=951
memtoy-1830 [000] 602.051959: update_swap_token_priority:
mm=ffff880037a45880 old_prio=951 new_prio=953
memtoy-1830 [000] 602.052188: update_swap_token_priority:
mm=ffff880037a45880 old_prio=953 new_prio=955
memtoy-1830 [001] 602.427184: put_swap_token:
token_mm=ffff880037a45880
zsh-1789 [000] 602.427281: replace_swap_token:
old_token_mm= (null) old_prio=0 new_token_mm=ffff88015eaf7018
new_prio=2
zsh-1789 [001] 602.433456: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=2 new_prio=4
zsh-1789 [000] 602.437613: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=4 new_prio=6
zsh-1789 [000] 602.443924: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=6 new_prio=8
zsh-1789 [000] 602.451873: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=8 new_prio=10
zsh-1789 [001] 602.462639: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=10 new_prio=12
Acked-by: Rik van Riel<riel@redhat.com>
Currently, memcg reclaim can disable swap token even if the swap token mm
doesn't belong in its memory cgroup. It's slightly risky. If an admin
creates very small mem-cgroup and silly guy runs contentious heavy memory
pressure workload, every tasks are going to lose swap token and then
system may become unresponsive. That's bad.
This patch adds 'memcg' parameter into disable_swap_token(). and if the
parameter doesn't match swap token, VM doesn't disable it.
Reviewed-by: Rik van Riel<riel@redhat.com>
Fix new kernel-doc warnings in mm/memory.c:
Warning(mm/memory.c:1327): No description found for parameter 'tlb'
Warning(mm/memory.c:1327): Excess function parameter 'tlbp' description in 'unmap_vmas'
Johannes noticed the vmstat update is already taken care of by
khugepaged_alloc_hugepage() internally. The only places that are required
to update the vmstat are the callers of alloc_hugepage (callers of
khugepaged_alloc_hugepage aren't).
Reported-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: Johannes Weiner <jweiner@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLAB: Record actual last user of freed objects.
slub: always align cpu_slab to honor cmpxchg_double requirement
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
vfs: make unlink() and rmdir() return ENOENT in preference to EROFS
lmLogOpen() broken failure exit
usb: remove bad dput after dentry_unhash
more conservative S_NOSEC handling
Al Viro observes that in the hugetlb case, handle_mm_fault() may return
a value of the kind ENOSPC when its caller is expecting a value of the
kind VM_FAULT_SIGBUS: fix alloc_huge_page()'s failure returns.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Caching "we have already removed suid/caps" was overenthusiastic as merged.
On network filesystems we might have had suid/caps set on another client,
silently picked by this client on revalidate, all of that *without* clearing
the S_NOSEC flag.
AFAICS, the only reasonably sane way to deal with that is
* new superblock flag; unless set, S_NOSEC is not going to be set.
* local block filesystems set it in their ->mount() (more accurately,
mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than
local block ones clear it)
* if any network filesystem (or a cluster one) wants to use S_NOSEC,
it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when
inode attribute changes are picked from other clients.
It's not an earth-shattering hole (anybody that can set suid on another client
will almost certainly be able to write to the file before doing that anyway),
but it's a bug that needs fixing.
