don't limit the number of pages isolated during CMA page migration.
Bug 1550455
Change-Id: Ib6edcb090b30212302543098a05b85e669ade45d
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/495283
(cherry picked from commit ec9ed2b5c4418c658fe2a3b00b0baf6179b3b452)
Reviewed-on: http://git-master/r/592898
GVS: Gerrit_Virtual_Submit
allocation of CMA memory for user stack would cause
permanent migration failures and result in CMA
allocation failures.
Bug 1550455
Change-Id: I75ac13416dbcf1810c89641cefdd0d56726cc36a
Reviewed-on: http://git-master/r/495322
(cherry picked from commit 3c59fb443605d5975b9d8e250c4ca52ae1650fe5)
Reviewed-on: http://git-master/r/592897
This prevents the following crash seen during boot-up:
Unable to handle kernel NULL pointer dereference at virtual address 00000041
pgd = ffffffc037f68000
[00000041] *pgd=0000000000000000
Internal error: Oops: 96000005 [#1] PREEMPT SMP
Modules linked in: inv_bmp180 inv_ak8975 inv_mpu
CPU: 0 PID: 1457 Comm: IntentService[F Not tainted 3.10.40-g4abcb3f #1
task: ffffffc0393e0080 ti: ffffffc0393e8000 task.ti: ffffffc0393e8000
PC is at follow_page_mask+0x1c/0x378
LR is at __get_user_pages.part.88+0x124/0x700
pc : [<ffffffc00016c314>] lr : [<ffffffc00016e1d4>] pstate: 40000045
Bug 1525355
Change-Id: Ieed6942d7beb32964484f97d5cc671b42c4b60cb
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/427723
Tested-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
find_lock_task_mm() expects it is called under rcu or tasklist lock, but
it seems that at least oom_unkillable_task()->task_in_mem_cgroup() and
mem_cgroup_out_of_memory()->oom_badness() can call it lockless.
Perhaps we could fix the callers, but this patch simply adds rcu lock
into find_lock_task_mm(). This also allows to simplify a bit one of its
callers, oom_kill_process().
Cc: Sergey Dyasly <dserrg@gmail.com>
Cc: Sameer Nanda <snanda@chromium.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
Acked-by: David Rientjes <rientjes@google.com>
Change-Id: I5f214dec13b34e05c4b5fc8bc29df3ab7400efa1
Reviewed-on: http://git-master/r/421705
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Tested-by: Kerwin Wan <kerwinw@nvidia.com>
At least out_of_memory() calls has_intersects_mems_allowed() without
even rcu_read_lock(), this is obviously buggy.
Add the necessary rcu_read_lock(). This means that we can not simply
return from the loop, we need "bool ret" and "break".
While at it, swap the names of task_struct's (the argument and the
local). This cleans up the code a little bit and avoids the unnecessary
initialization.
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Change-Id: Iee512a4e3446b1ec8fb7fcc434f1cf18a13a5645
Reviewed-on: http://git-master/r/421704
When __get_user_pages() is called with FOLL_DURABLE flag,
ensure that no page in CMA pageblocks gets locked.
This workarounds the permanent migration failures caused
by locking the pages by get_user_pages() call for a long
period of time.
bug 1517584
Change-Id: I11b7c87e78f1022d6fded85a1ed6bac73c5f0a7c
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/421678
Ensure that newly allocated pages, which are faulted in
in FOLL_DURABLE mode comes from non-movalbe pageblocks,
to workaround migration failures with CMA
bug 1517584
Change-Id: I76d2185cc7e77992db585a71efaa06a5c0105a76
Reviewed-on: http://git-master/r/421677
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
__get_user_pages() is already exported function,
so get_user_pages() can be easily inlined to the
caller functions.
bug 1517584
Change-Id: If700fa3c6ead133299fa99a702887584b76e5ffb
Reviewed-on: http://git-master/r/421676
introduce migrate_replace_page for migrating
page to the given target
bug 1517584
Change-Id: I5f1d3bcb19ca7d9c9cf7234e8d3472a42c4f40af
Reviewed-on: http://git-master/r/421675
into promotion_build
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Change oom_kill.c to use for_each_thread() rather than the racy
while_each_thread() which can loop forever if we race with exit.
Note also that most users were buggy even if while_each_thread() was
fine, the task can exit even _before_ rcu_read_lock().
Fortunately the new for_each_thread() only requires the stable
task_struct, so this change fixes both problems.
Bug 200004307
(cherry picked from commit 1da4db0cd5c8a31d4468ec906b413e75e604b465)
Change-Id: Iecf2804ab94f17adf1bad6d0b2ddc560e66544e6
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/418860
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
currently, __purge_vmap_area_lazy will do a TLBI on the smallest
single range that includes all purgable vmap_areas. This patch
will do TLBIs per vmap_area, reducing the number of invalidated
pages.
Change-Id: I40b9c8c533e6814be076d454ef7ebdbe408c08e0
Signed-off-by: Rich Wiley <rwiley@nvidia.com>
Reviewed-on: http://git-master/r/407748
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
commit 55f67141a8927b2be3e51840da37b8a2320143ed upstream.
When I decrease the value of nr_hugepage in procfs a lot, softlockup
happens. It is because there is no chance of context switch during this
process.
On the other hand, when I allocate a large number of hugepages, there is
some chance of context switch. Hence softlockup doesn't happen during
this process. So it's necessary to add the context switch in the
freeing process as same as allocating process to avoid softlockup.
When I freed 12 TB hugapages with kernel-2.6.32-358.el6, the freeing
process occupied a CPU over 150 seconds and following softlockup message
appeared twice or more.
$ echo 6000000 > /proc/sys/vm/nr_hugepages
$ cat /proc/sys/vm/nr_hugepages
6000000
$ grep ^Huge /proc/meminfo
HugePages_Total: 6000000
HugePages_Free: 6000000
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
$ echo 0 > /proc/sys/vm/nr_hugepages
BUG: soft lockup - CPU#16 stuck for 67s! [sh:12883] ...
Pid: 12883, comm: sh Not tainted 2.6.32-358.el6.x86_64 #1
Call Trace:
free_pool_huge_page+0xb8/0xd0
set_max_huge_pages+0x128/0x190
hugetlb_sysctl_handler_common+0x113/0x140
hugetlb_sysctl_handler+0x1e/0x20
proc_sys_call_handler+0x97/0xd0
proc_sys_write+0x14/0x20
vfs_write+0xb8/0x1a0
sys_write+0x51/0x90
__audit_syscall_exit+0x265/0x290
system_call_fastpath+0x16/0x1b
I have not confirmed this problem with upstream kernels because I am not
able to prepare the machine equipped with 12TB memory now. However I
confirmed that the amount of decreasing hugepages was directly
proportional to the amount of required time.
I measured required times on a smaller machine. It showed 130-145
hugepages decreased in a millisecond.
Amount of decreasing Required time Decreasing rate
hugepages (msec) (pages/msec)
10,000 pages == 20GB 70 - 74 135-142
30,000 pages == 60GB 208 - 229 131-144
It means decrement of 6TB hugepages will trigger softlockup with the
default threshold 20sec, in this decreasing rate.
Signed-off-by: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 57e68e9cd65b4b8eb4045a1e0d0746458502554c upstream.
A BUG_ON(!PageLocked) was triggered in mlock_vma_page() by Sasha Levin
fuzzing with trinity. The call site try_to_unmap_cluster() does not lock
the pages other than its check_page parameter (which is already locked).
The BUG_ON in mlock_vma_page() is not documented and its purpose is
somewhat unclear, but apparently it serializes against page migration,
which could otherwise fail to transfer the PG_mlocked flag. This would
not be fatal, as the page would be eventually encountered again, but
NR_MLOCK accounting would become distorted nevertheless. This patch adds
a comment to the BUG_ON in mlock_vma_page() and munlock_vma_page() to that
effect.
The call site try_to_unmap_cluster() is fixed so that for page !=
check_page, trylock_page() is attempted (to avoid possible deadlocks as we
already have check_page locked) and mlock_vma_page() is performed only
upon success. If the page lock cannot be obtained, the page is left
without PG_mlocked, which is again not a problem in the whole unevictable
memory design.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Bob Liu <bob.liu@oracle.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Michel Lespinasse <walken@google.com>
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream.
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Derek Basehore <dbasehore@chromium.org>
commit 6ca738d60c563d5c6cf6253ee4b8e76fa77b2b9e upstream.
bdi_wakeup_thread_delayed() used the mod_delayed_work() function to
schedule work to writeback dirty inodes. The problem with this is that
it can delay work that is scheduled for immediate execution, such as the
work from sync_inodes_sb(). This can happen since mod_delayed_work()
can now steal work from a work_queue. This fixes the problem by using
queue_delayed_work() instead. This is a regression caused by commit
839a8e8660b6 ("writeback: replace custom worker pool implementation with
unbound workqueue").
The reason that this causes a problem is that laptop-mode will change
the delay, dirty_writeback_centisecs, to 60000 (10 minutes) by default.
In the case that bdi_wakeup_thread_delayed() races with
sync_inodes_sb(), sync will be stopped for 10 minutes and trigger a hung
task. Even if dirty_writeback_centisecs is not long enough to cause a
hung task, we still don't want to delay sync for that long.
We fix the problem by using queue_delayed_work() when we want to
schedule writeback sometime in future. This function doesn't change the
timer if it is already armed.
For the same reason, we also change bdi_writeback_workfn() to
immediately queue the work again in the case that the work_list is not
empty. The same problem can happen if the sync work is run on the
rescue worker.
[jack@suse.cz: update changelog, add comment, use bdi_wakeup_thread_delayed()]
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Cc: Alexander Viro <viro@zento.linux.org.uk>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Benson Leung <bleung@chromium.org>
Cc: Sonny Rao <sonnyrao@chromium.org>
Cc: Luigi Semenzato <semenzato@chromium.org>
commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
This is more or less the generic variant of commit 41aacc1eea64 ("x86
get_unmapped_area: Access mmap_legacy_base through mm_struct member").
So effectively architectures which use an own arch_pick_mmap_layout()
implementation but call the generic arch_get_unmapped_area() now can
also randomize their mmap_base.
All architectures which have an own arch_pick_mmap_layout() and call the
generic arch_get_unmapped_area() (arm64, s390, tile) currently set
mmap_base to TASK_UNMAPPED_BASE. This is also true for the generic
arch_pick_mmap_layout() function. So this change is a no-op currently.
Cc: Radu Caragea <sinaelgl@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Bug 1486057
Cherry-pick upstream patch 4e99b02131b280b064d30a5926ef1c4763f3097b
Change-Id: I027ce31f1b9e87c2953bfa0a9d82288d92ba11fd
Signed-off-by: Li Li <lli5@nvidia.com>
Reviewed-on: http://git-master/r/387939
Reviewed-by: Eric Miao <emiao@nvidia.com>
Reviewed-by: Peter Zu <pzu@nvidia.com>
change_protection_range will only flush the tlb if change_pte_range
reports that it has actually changed the permissions of at least
one page. This patch prevents change_pte_range from counting pages
that it doesn't actually modify.
Change-Id: I53b9b2c7a635ba1395200b9ff70f6f40a053f987
Reviewed-on: http://git-master/r/385239
commit 4fb1a86fb5e4209a7d4426d4e586c58e9edc74ac upstream.
Sometimes the cleanup after memcg hierarchy testing gets stuck in
mem_cgroup_reparent_charges(), unable to bring non-kmem usage down to 0.
There may turn out to be several causes, but a major cause is this: the
workitem to offline parent can get run before workitem to offline child;
parent's mem_cgroup_reparent_charges() circles around waiting for the
child's pages to be reparented to its lrus, but it's holding
cgroup_mutex which prevents the child from reaching its
mem_cgroup_reparent_charges().
Further testing showed that an ordered workqueue for cgroup_destroy_wq
is not always good enough: percpu_ref_kill_and_confirm's call_rcu_sched
stage on the way can mess up the order before reaching the workqueue.
Instead, when offlining a memcg, call mem_cgroup_reparent_charges() on
all its children (and grandchildren, in the correct order) to have their
charges reparented first.
[The version for 3.10.34 (or perhaps now 3.10.35) is this below.
Yes, more differences, and the old mem_cgroup_reparent_charges line
is intentionally left in for 3.10 whereas it was removed for 3.12+:
that's because the css/cgroup iterator changed in between, it used
not to supply the root of the subtree, but nowadays it does - Hugh]
Fixes: e5fca243abae ("cgroup: use a dedicated workqueue for cgroup destruction")
Signed-off-by: Filipe Brandenburger <filbranden@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 2af120bc040c5ebcda156df6be6a66610ab6957f upstream.
We received several reports of bad page state when freeing CMA pages
previously allocated with alloc_contig_range:
BUG: Bad page state in process Binder_A pfn:63202
page:d21130b0 count:0 mapcount:1 mapping: (null) index:0x7dfbf
page flags: 0x40080068(uptodate|lru|active|swapbacked)
Based on the page state, it looks like the page was still in use. The
page flags do not make sense for the use case though. Further debugging
showed that despite alloc_contig_range returning success, at least one
page in the range still remained in the buddy allocator.
There is an issue with isolate_freepages_block. In strict mode (which
CMA uses), if any pages in the range cannot be isolated,
isolate_freepages_block should return failure 0. The current check
keeps track of the total number of isolated pages and compares against
the size of the range:
if (strict && nr_strict_required > total_isolated)
total_isolated = 0;
After taking the zone lock, if one of the pages in the range is not in
the buddy allocator, we continue through the loop and do not increment
total_isolated. If in the last iteration of the loop we isolate more
than one page (e.g. last page needed is a higher order page), the check
for total_isolated may pass and we fail to detect that a page was
skipped. The fix is to bail out if the loop immediately if we are in
strict mode. There's no benfit to continuing anyway since we need all
pages to be isolated. Additionally, drop the error checking based on
nr_strict_required and just check the pfn ranges. This matches with
what isolate_freepages_range does.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Acked-by: Minchan Kim <minchan@kernel.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit ecc736fc3c71c411a9d201d8588c9e7e049e5d8c upstream.
Hugh has reported an endless loop when the hardlimit reclaim sees the
same group all the time. This might happen when the reclaim races with
the memcg removal.
shrink_zone
[rmdir root]
mem_cgroup_iter(root, NULL, reclaim)
// prev = NULL
rcu_read_lock()
mem_cgroup_iter_load
last_visited = iter->last_visited // gets root || NULL
css_tryget(last_visited) // failed
last_visited = NULL [1]
memcg = root = __mem_cgroup_iter_next(root, NULL)
mem_cgroup_iter_update
iter->last_visited = root;
reclaim->generation = iter->generation
mem_cgroup_iter(root, root, reclaim)
// prev = root
rcu_read_lock
[1]
The issue seemed to be introduced by commit 5f5781619718 ("memcg: relax
memcg iter caching") which has replaced unconditional css_get/css_put by
css_tryget/css_put for the cached iterator.
This patch fixes the issue by skipping css_tryget on the root of the
tree walk in mem_cgroup_iter_load and symmetrically doesn't release it
in mem_cgroup_iter_update.
Reported-by: Hugh Dickins <hughd@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
Cc: <stable@vger.kernel.org> [3.10+]
commit 8d547ff4ac5927245e0833ac18528f939da0ee0e upstream.
mce-test detected a test failure when injecting error to a thp tail
page. This is because we take page refcount of the tail page in
madvise_hwpoison() while the fix in commit a3e0f9e47d5e
("mm/memory-failure.c: transfer page count from head page to tail page
after split thp") assumes that we always take refcount on the head page.
When a real memory error happens we take refcount on the head page where
memory_failure() is called without MF_COUNT_INCREASED set, so it seems
to me that testing memory error on thp tail page using madvise makes
little sense.
This patch cancels moving refcount in !MF_COUNT_INCREASED for valid
testing.
[akpm@linux-foundation.org: s/&&/&/]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Chen Gong <gong.chen@linux.intel.com>
Based on c8721bbbdd36382de51cd6b7a56322e0acca2414 upstream, but only the
bugfix portion pulled out.
Hi Naoya or Greg,
We found a bug in 3.10.x.
The problem is that we accidentally have a hwpoisoned hugepage in free
hugepage list. It could happend in the the following scenario:
process A process B
migrate_huge_page
put_page (old hugepage)
linked to free hugepage list
hugetlb_fault
hugetlb_no_page
alloc_huge_page
dequeue_huge_page_vma
dequeue_huge_page_node
(steal hwpoisoned hugepage)
set_page_hwpoison_huge_page
dequeue_hwpoisoned_huge_page
(fail to dequeue)
I tested this bug, one process keeps allocating huge page, and I
use sysfs interface to soft offline a huge page, then received:
"MCE: Killing UCP:2717 due to hardware memory corruption fault at 8200034"
Upstream kernel is free from this bug because of these two commits:
f15bdfa802bfa5eb6b4b5a241b97ec9fa1204a35
mm/memory-failure.c: fix memory leak in successful soft offlining
mm: memory-hotplug: enable memory hotplug to handle hugepage
The first one, although the problem is about memory leak, this patch
moves unset_migratetype_isolate(), which is important to avoid the race.
The latter is not a bug fix and it's too big, so I rewrite a small one.
The following patch can fix this bug.(please apply f15bdfa802bf first)
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit f15bdfa802bfa5eb6b4b5a241b97ec9fa1204a35 upstream.
After a successful page migration by soft offlining, the source page is
not properly freed and it's never reusable even if we unpoison it
afterward.
This is caused by the race between freeing page and setting PG_hwpoison.
In successful soft offlining, the source page is put (and the refcount
becomes 0) by putback_lru_page() in unmap_and_move(), where it's linked
to pagevec and actual freeing back to buddy is delayed. So if
PG_hwpoison is set for the page before freeing, the freeing does not
functions as expected (in such case freeing aborts in
free_pages_prepare() check.)
This patch tries to make sure to free the source page before setting
PG_hwpoison on it. To avoid reallocating, the page keeps
MIGRATE_ISOLATE until after setting PG_hwpoison.
This patch also removes obsolete comments about "keeping elevated
refcount" because what they say is not true. Unlike memory_failure(),
soft_offline_page() uses no special page isolation code, and the
soft-offlined pages have no elevated.
Cc: Xishi Qiu <qiuxishi@huawei.com>
spin_lock_irq()
commit a85d9df1ea1d23682a0ed1e100e6965006595d06 upstream.
During aio stress test, we observed the following lockdep warning. This
mean AIO+numa_balancing is currently deadlockable.
The problem is, aio_migratepage disable interrupt, but
__set_page_dirty_nobuffers unintentionally enable it again.
Generally, all helper function should use spin_lock_irqsave() instead of
spin_lock_irq() because they don't know caller at all.
Possible unsafe locking scenario:
CPU0
lock(&(&ctx->completion_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
dump_stack+0x19/0x1b
print_usage_bug+0x1f7/0x208
mark_lock+0x21d/0x2a0
mark_held_locks+0xb9/0x140
trace_hardirqs_on_caller+0x105/0x1d0
trace_hardirqs_on+0xd/0x10
_raw_spin_unlock_irq+0x2c/0x50
__set_page_dirty_nobuffers+0x8c/0xf0
migrate_page_copy+0x434/0x540
aio_migratepage+0xb1/0x140
move_to_new_page+0x7d/0x230
migrate_pages+0x5e5/0x700
migrate_misplaced_page+0xbc/0xf0
do_numa_page+0x102/0x190
handle_pte_fault+0x241/0x970
handle_mm_fault+0x265/0x370
__do_page_fault+0x172/0x5a0
do_page_fault+0x1a/0x70
page_fault+0x28/0x30
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream.
A 3% of system memory bonus is sometimes too excessive in comparison to
other processes.
With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM
killer tries to avoid killing privileged tasks by subtracting 3% of
overall memory (system or cgroup) from their per-task consumption. But
as a result, all root tasks that consume less than 3% of overall memory
are considered equal, and so it only takes 33+ privileged tasks pushing
the system out of memory for the OOM killer to do something stupid and
kill dhclient or other root-owned processes. For example, on a 32G
machine it can't tell the difference between the 1M agetty and the 10G
fork bomb member.
The changelog describes this 3% boost as the equivalent to the global
overcommit limit being 3% higher for privileged tasks, but this is not
the same as discounting 3% of overall memory from _every privileged task
individually_ during OOM selection.
Replace the 3% of system memory bonus with a 3% of current memory usage
bonus.
By giving root tasks a bonus that is proportional to their actual size,
they remain comparable even when relatively small. In the example
above, the OOM killer will discount the 1M agetty's 256 badness points
down to 179, and the 10G fork bomb's 262144 points down to 183500 points
and make the right choice, instead of discounting both to 0 and killing
agetty because it's first in the task list.
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
commit 8afb1474db4701d1ab80cd8251137a3260e6913e upstream.
/sys/kernel/slab/:t-0000048 # cat cpu_slabs
231 N0=16 N1=215
/sys/kernel/slab/:t-0000048 # cat slabs
145 N0=36 N1=109
See, the number of slabs is smaller than that of cpu slabs.
The bug was introduced by commit 49e2258586b423684f03c278149ab46d8f8b6700
("slub: per cpu cache for partial pages").
We should use page->pages instead of page->pobjects when calculating
the number of cpu partial slabs. This also fixes the mapping of slabs
and nodes.
As there's no variable storing the number of total/active objects in
cpu partial slabs, and we don't have user interfaces requiring those
statistics, I just add WARN_ON for those cases.
Acked-by: Christoph Lameter <cl@linux.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit a1c3bfb2f67ef766de03f1f56bdfff9c8595ab14 upstream.
The VM is currently heavily tuned to avoid swapping. Whether that is
good or bad is a separate discussion, but as long as the VM won't swap
to make room for dirty cache, we can not consider anonymous pages when
calculating the amount of dirtyable memory, the baseline to which
dirty_background_ratio and dirty_ratio are applied.
A simple workload that occupies a significant size (40+%, depending on
memory layout, storage speeds etc.) of memory with anon/tmpfs pages and
uses the remainder for a streaming writer demonstrates this problem. In
that case, the actual cache pages are a small fraction of what is
considered dirtyable overall, which results in an relatively large
portion of the cache pages to be dirtied. As kswapd starts rotating
these, random tasks enter direct reclaim and stall on IO.
Only consider free pages and file pages dirtyable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Tejun Heo <tj@kernel.org>
Tested-by: Tejun Heo <tj@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
commit a804552b9a15c931cfc2a92a2e0aed1add8b580a upstream.
Tejun reported stuttering and latency spikes on a system where random
tasks would enter direct reclaim and get stuck on dirty pages. Around
50% of memory was occupied by tmpfs backed by an SSD, and another disk
(rotating) was reading and writing at max speed to shrink a partition.
: The problem was pretty ridiculous. It's a 8gig machine w/ one ssd and 10k
: rpm harddrive and I could reliably reproduce constant stuttering every
: several seconds for as long as buffered IO was going on on the hard drive
: either with tmpfs occupying somewhere above 4gig or a test program which
: allocates about the same amount of anon memory. Although swap usage was
: zero, turning off swap also made the problem go away too.
: The trigger conditions seem quite plausible - high anon memory usage w/
: heavy buffered IO and swap configured - and it's highly likely that this
: is happening in the wild too. (this can happen with copying large files
: to usb sticks too, right?)
This patch (of 2):
The dirty_balance_reserve is an approximation of the fraction of free
pages that the page allocator does not make available for page cache
allocations. As a result, it has to be taken into account when
calculating the amount of "dirtyable memory", the baseline to which
However, currently the reserve is subtracted from the sum of free and
reclaimable pages, which is non-sensical and leads to erroneous results
when the system is dominated by unreclaimable pages and the
dirty_balance_reserve is bigger than free+reclaimable. In that case, at
least the already allocated cache should be considered dirtyable.
Fix the calculation by subtracting the reserve from the amount of free
pages, then adding the reclaimable pages on top.
[akpm@linux-foundation.org: fix CONFIG_HIGHMEM build]
commit 54b9dd14d09f24927285359a227aa363ce46089e upstream.
After thp split in hwpoison_user_mappings(), we hold page lock on the
raw error page only between try_to_unmap, hence we are in danger of race
condition.
I found in the RHEL7 MCE-relay testing that we have "bad page" error
when a memory error happens on a thp tail page used by qemu-kvm:
Triggering MCE exception on CPU 10
mce: [Hardware Error]: Machine check events logged
MCE exception done on CPU 10
MCE 0x38c535: Killing qemu-kvm:8418 due to hardware memory corruption
MCE 0x38c535: dirty LRU page recovery: Recovered
qemu-kvm[8418]: segfault at 20 ip 00007ffb0f0f229a sp 00007fffd6bc5240 error 4 in qemu-kvm[7ffb0ef14000+420000]
BUG: Bad page state in process qemu-kvm pfn:38c400
page:ffffea000e310000 count:0 mapcount:0 mapping: (null) index:0x7ffae3c00
page flags: 0x2fffff0008001d(locked|referenced|uptodate|dirty|swapbacked)
Modules linked in: hwpoison_inject mce_inject vhost_net macvtap macvlan ...
CPU: 0 PID: 8418 Comm: qemu-kvm Tainted: G M -------------- 3.10.0-54.0.1.el7.mce_test_fixed.x86_64 #1
Hardware name: NEC NEC Express5800/R120b-1 [N8100-1719F]/MS-91E7-001, BIOS 4.6.3C19 02/10/2011
Call Trace:
bad_page.part.59+0xcf/0xe8
free_pages_prepare+0x148/0x160
free_hot_cold_page+0x31/0x140
free_hot_cold_page_list+0x46/0xa0
release_pages+0x1c1/0x200
free_pages_and_swap_cache+0xad/0xd0
tlb_flush_mmu.part.46+0x4c/0x90
tlb_finish_mmu+0x55/0x60
exit_mmap+0xcb/0x170
mmput+0x67/0xf0
vhost_dev_cleanup+0x231/0x260 [vhost_net]
vhost_net_release+0x3f/0x90 [vhost_net]
__fput+0xe9/0x270
____fput+0xe/0x10
task_work_run+0xc4/0xe0
do_exit+0x2bb/0xa40
do_group_exit+0x3f/0xa0
get_signal_to_deliver+0x1d0/0x6e0
do_signal+0x48/0x5e0
do_notify_resume+0x71/0xc0
retint_signal+0x48/0x8c
The reason of this bug is that a page fault happens before unlocking the
head page at the end of memory_failure(). This strange page fault is
trying to access to address 0x20 and I'm not sure why qemu-kvm does
this, but anyway as a result the SIGSEGV makes qemu-kvm exit and on the
way we catch the bad page bug/warning because we try to free a locked
page (which was the former head page.)
To fix this, this patch suggests to shift page lock from head page to
tail page just after thp split. SIGSEGV still happens, but it affects
only error affected VMs, not a whole system.
Tegra Profiler: add mmap calls
Bug 1447662
Change-Id: I96614ab3c320fd028cf861ea970b5199bdcae1c7
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/360152
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
commit 8790c71a18e5d2d93532ae250bcf5eddbba729cd upstream.
As a result of commit 5606e3877ad8 ("mm: numa: Migrate on reference
policy"), /proc/<pid>/numa_maps prints the mempolicy for any <pid> as
"prefer:N" for the local node, N, of the process reading the file.
This should only be printed when the mempolicy of <pid> is
MPOL_PREFERRED for node N.
If the process is actually only using the default mempolicy for local
node allocation, make sure "default" is printed as expected.
Reported-by: Robert Lippert <rlippert@google.com>
Cc: <stable@vger.kernel.org> [3.7+]
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Guillaume Morin <guillaume@morinfr.org>
commit eecc1e426d681351a6026a7d3e7d225f38955b6c upstream.
We see General Protection Fault on RSI in copy_page_rep: that RSI is
what you get from a NULL struct page pointer.
RIP: 0010:[<ffffffff81154955>] [<ffffffff81154955>] copy_page_rep+0x5/0x10
RSP: 0000:ffff880136e15c00 EFLAGS: 00010286
RAX: ffff880000000000 RBX: ffff880136e14000 RCX: 0000000000000200
RDX: 6db6db6db6db6db7 RSI: db73880000000000 RDI: ffff880dd0c00000
RBP: ffff880136e15c18 R08: 0000000000000200 R09: 000000000005987c
R10: 000000000005987c R11: 0000000000000200 R12: 0000000000000001
R13: ffffea00305aa000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f195752f700(0000) GS:ffff880c7fc20000(0000) knlGS:0000000000000000
CR2: 0000000093010000 CR3: 00000001458e1000 CR4: 00000000000027e0
Call Trace:
copy_user_huge_page+0x93/0xab
do_huge_pmd_wp_page+0x710/0x815
handle_mm_fault+0x15d8/0x1d70
__do_page_fault+0x14d/0x840
do_page_fault+0x2f/0x90
page_fault+0x22/0x30
do_huge_pmd_wp_page() tests is_huge_zero_pmd(orig_pmd) four times: but
since shrink_huge_zero_page() can free the huge_zero_page, and we have
no hold of our own on it here (except where the fourth test holds
page_table_lock and has checked pmd_same), it's possible for it to
answer yes the first time, but no to the second or third test. Change
all those last three to tests for NULL page.
(Note: this is not the same issue as trinity's DEBUG_PAGEALLOC BUG
in copy_page_rep with RSI: ffff88009c422000, reported by Sasha Levin
in https://lkml.org/lkml/2013/3/29/103. I believe that one is due
to the source page being split, and a tail page freed, while copy
is in progress; and not a problem without DEBUG_PAGEALLOC, since
the pmd_same check will prevent a miscopy from being made visible.)
Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page")
commit a49ecbcd7b0d5a1cda7d60e03df402dd0ef76ac8 upstream.
After a successful hugetlb page migration by soft offline, the source
page will either be freed into hugepage_freelists or buddy(over-commit
page). If page is in buddy, page_hstate(page) will be NULL. It will
hit a NULL pointer dereference in dequeue_hwpoisoned_huge_page().
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff81163761>] dequeue_hwpoisoned_huge_page+0x131/0x1d0
PGD c23762067 PUD c24be2067 PMD 0
Oops: 0000 [#1] SMP
So check PageHuge(page) after call migrate_pages() successfully.
[wujg: backport to 3.10:
- adjust context]
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
With arm64 the range passed to flush_tlb_kernel_range() can be huge.
Add a parameter for how large area will be flushed by area. Beyond
that the whole TLB is flushed.
Set the threshold to 512MB.
Bug 1432908
Change-Id: I685fc2c3ffaad8979bfa8fde27e8c2948a2104cc
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/351026
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Change-Id: I3a09d5dd6abc07ef79c64899053e1de3b4f6a95f
Reviewed-on: http://git-master/r/351025
Bug 1400829
Change-Id: I46956125eef8b5bf35e350f65ae5f27fd043f0f2
Reviewed-on: http://git-master/r/354085
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
commit 695c60830764945cf61a2cc623eb1392d137223e upstream.
The mem_cgroup structure contains nr_node_ids pointers to
mem_cgroup_per_node objects, not the objects themselves.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Glauber Costa <glommer@openvz.org>
Cc: Balbir Singh <bsingharora@gmail.com>
split thp
commit a3e0f9e47d5ef7858a26cc12d90ad5146e802d47 upstream.
Memory failures on thp tail pages cause kernel panic like below:
MCE exception done on CPU 7
IP: [<ffffffff811b7cd1>] dequeue_hwpoisoned_huge_page+0x131/0x1e0
PGD bae42067 PUD ba47d067 PMD 0
Oops: 0000 [#1] SMP
CPU: 7 PID: 128 Comm: kworker/7:2 Tainted: G M O 3.13.0-rc4-131217-1558-00003-g83b7df08e462 #25
Call Trace:
me_huge_page+0x3e/0x50
memory_failure+0x4bb/0xc20
mce_process_work+0x3e/0x70
process_one_work+0x171/0x420
worker_thread+0x11b/0x3a0
? manage_workers.isra.25+0x2b0/0x2b0
kthread+0xe4/0x100
? kthread_create_on_node+0x190/0x190
ret_from_fork+0x7c/0xb0
RIP dequeue_hwpoisoned_huge_page+0x131/0x1e0
CR2: 0000000000000058
The reasoning of this problem is shown below:
- when we have a memory error on a thp tail page, the memory error
handler grabs a refcount of the head page to keep the thp under us.
- Before unmapping the error page from processes, we split the thp,
where page refcounts of both of head/tail pages don't change.
- Then we call try_to_unmap() over the error page (which was a tail
page before). We didn't pin the error page to handle the memory error,
this error page is freed and removed from LRU list.
- We never have the error page on LRU list, so the first page state
check returns "unknown page," then we move to the second check
with the saved page flag.
- The saved page flag have PG_tail set, so the second page state check
returns "hugepage."
- We call me_huge_page() for freed error page, then we hit the above panic.
The root cause is that we didn't move refcount from the head page to the
tail page after split thp. So this patch suggests to do this.
This panic was introduced by commit 524fca1e73 ("HWPOISON: fix
misjudgement of page_action() for errors on mlocked pages"). Note that we
did have the same refcount problem before this commit, but it was just
ignored because we had only first page state check which returned "unknown
page." The commit changed the refcount problem from "doesn't work" to
"kernel panic."
commit 4eb919825e6c3c7fb3630d5621f6d11e98a18b3a upstream.
remap_file_pages calls mmap_region, which may merge the VMA with other
existing VMAs, and free "vma". This can lead to a use-after-free bug.
Avoid the bug by remembering vm_flags before calling mmap_region, and
not trying to dereference vma later.
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
commit 98398c32f6687ee1e1f3ae084effb4b75adb0747 upstream.
In __page_check_address(), if address's pud is not present,
huge_pte_offset() will return NULL, we should check the return value.
Cc: qiuxishi <qiuxishi@huawei.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 6815bf3f233e0b10c99a758497d5d236063b010b upstream.
update_pageblock_skip() only fits to compaction which tries to isolate
by pageblock unit. If isolate_migratepages_range() is called by CMA, it
try to isolate regardless of pageblock unit and it don't reference
get_pageblock_skip() by ignore_skip_hint. We should also respect it on
update_pageblock_skip() to prevent from setting the wrong information.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Cc: Alex Thorlton <athorlton@sgi.com>
commit eb4489f69f224356193364dc2762aa009738ca7f upstream.
If a PMD changes during a THP migration then migration aborts but the
failure path is doing more work than is necessary.
commit c3a489cac38d43ea6dc4ac240473b44b46deecf7 upstream.
The anon_vma lock prevents parallel THP splits and any associated
complexity that arises when handling splits during THP migration. This
patch checks if the lock was successfully acquired and bails from THP
migration if it failed for any reason.
commit 67f87463d3a3362424efcbe8b40e4772fd34fc61 upstream.
On x86, PMD entries are similar to _PAGE_PROTNONE protection and are
handled as NUMA hinting faults. The following two page table protection
bits are what defines them
_PAGE_NUMA:set _PAGE_PRESENT:clear
A PMD is considered present if any of the _PAGE_PRESENT, _PAGE_PROTNONE,
_PAGE_PSE or _PAGE_NUMA bits are set. If pmdp_invalidate encounters a
pmd_numa, it clears the present bit leaving _PAGE_NUMA which will be
considered not present by the CPU but present by pmd_present. The
existing caller of pmdp_invalidate should handle it but it's an
inconsistent state for a PMD. This patch keeps the state consistent
when calling pmdp_invalidate.
