path: root/mm
2017-10-21slub: do not merge cache if slub_debug contains a never-merge flagGrygorii Maistrenko
[ Upstream commit c6e28895a4372992961888ffaadc9efc643b5bfe ] In case CONFIG_SLUB_DEBUG_ON=n, find_mergeable() gets debug features from commandline but never checks if there are features from the SLAB_NEVER_MERGE set. As a result selected by slub_debug caches are always mergeable if they have been created without a custom constructor set or without one of the SLAB_* debug features on. This moves the SLAB_NEVER_MERGE check below the flags update from commandline to make sure it won't merge the slab cache if one of the debug features is on. Link: http://lkml.kernel.org/r/20170101124451.GA4740@lp-laptop-d Signed-off-by: Grygorii Maistrenko <grygoriimkd@gmail.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27mm: prevent double decrease of nr_reserved_highatomicMinchan Kim
commit 4855e4a7f29d6d10b0b9c84e189c770c9a94e91e upstream. There is race between page freeing and unreserved highatomic. CPU 0 CPU 1 free_hot_cold_page mt = get_pfnblock_migratetype set_pcppage_migratetype(page, mt) unreserve_highatomic_pageblock spin_lock_irqsave(&zone->lock) move_freepages_block set_pageblock_migratetype(page) spin_unlock_irqrestore(&zone->lock) free_pcppages_bulk __free_one_page(mt) <- mt is stale By above race, a page on CPU 0 could go non-highorderatomic free list since the pageblock's type is changed. By that, unreserve logic of highorderatomic can decrease reserved count on a same pageblock severak times and then it will make mismatch between nr_reserved_highatomic and the number of reserved pageblock. So, this patch verifies whether the pageblock is highatomic or not and decrease the count only if the pageblock is highatomic. Link: http://lkml.kernel.org/r/1476259429-18279-3-git-send-email-minchan@kernel.org Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sangseok Lee <sangseok.lee@lge.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Miles Chen <miles.chen@mediatek.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24Sanitize 'move_pages()' permission checksLinus Torvalds
commit 197e7e521384a23b9e585178f3f11c9fa08274b9 upstream. The 'move_paghes()' system call was introduced long long ago with the same permission checks as for sending a signal (except using CAP_SYS_NICE instead of CAP_SYS_KILL for the overriding capability). That turns out to not be a great choice - while the system call really only moves physical page allocations around (and you need other capabilities to do a lot of it), you can check the return value to map out some the virtual address choices and defeat ASLR of a binary that still shares your uid. So change the access checks to the more common 'ptrace_may_access()' model instead. This tightens the access checks for the uid, and also effectively changes the CAP_SYS_NICE check to CAP_SYS_PTRACE, but it's unlikely that anybody really _uses_ this legacy system call any more (we hav ebetter NUMA placement models these days), so I expect nobody to notice. Famous last words. Reported-by: Otto Ebeling <otto.ebeling@iki.fi> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Willy Tarreau <w@1wt.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24mm/mempolicy: fix use after free when calling get_mempolicyzhong jiang
commit 73223e4e2e3867ebf033a5a8eb2e5df0158ccc99 upstream. I hit a use after free issue when executing trinity and repoduced it with KASAN enabled. The related call trace is as follows. BUG: KASan: use after free in SyS_get_mempolicy+0x3c8/0x960 at addr ffff8801f582d766 Read of size 2 by task syz-executor1/798 INFO: Allocated in mpol_new.part.2+0x74/0x160 age=3 cpu=1 pid=799 __slab_alloc+0x768/0x970 kmem_cache_alloc+0x2e7/0x450 mpol_new.part.2+0x74/0x160 mpol_new+0x66/0x80 SyS_mbind+0x267/0x9f0 system_call_fastpath+0x16/0x1b INFO: Freed in __mpol_put+0x2b/0x40 age=4 cpu=1 pid=799 __slab_free+0x495/0x8e0 kmem_cache_free+0x2f3/0x4c0 __mpol_put+0x2b/0x40 SyS_mbind+0x383/0x9f0 system_call_fastpath+0x16/0x1b INFO: Slab 0xffffea0009cb8dc0 objects=23 used=8 fp=0xffff8801f582de40 flags=0x200000000004080 INFO: Object 0xffff8801f582d760 @offset=5984 fp=0xffff8801f582d600 Bytes b4 ffff8801f582d750: ae 01 ff ff 00 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ Object ffff8801f582d760: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk Object ffff8801f582d770: 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkk. Redzone ffff8801f582d778: bb bb bb bb bb bb bb bb ........ Padding ffff8801f582d8b8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ Memory state around the buggy address: ffff8801f582d600: fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc fc ffff8801f582d680: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >ffff8801f582d700: fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb fc !shared memory policy is not protected against parallel removal by other thread which is normally protected by the mmap_sem. do_get_mempolicy, however, drops the lock midway while we can still access it later. Early premature up_read is a historical artifact from times when put_user was called in this path see https://lwn.net/Articles/124754/ but that is gone since 8bccd85ffbaf ("[PATCH] Implement sys_* do_* layering in the memory policy layer."). but when we have the the current mempolicy ref count model. The issue was introduced accordingly. Fix the issue by removing the premature release. Link: http://lkml.kernel.org/r/1502950924-27521-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhong jiang <zhongjiang@huawei.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-16mm: ratelimit PFNs busy info messageJonathan Toppins
commit 75dddef32514f7aa58930bde6a1263253bc3d4ba upstream. The RDMA subsystem can generate several thousand of these messages per second eventually leading to a kernel crash. Ratelimit these messages to prevent this crash. Doug said: "I've been carrying a version of this for several kernel versions. I don't remember when they started, but we have one (and only one) class of machines: Dell PE R730xd, that generate these errors. When it happens, without a rate limit, we get rcu timeouts and kernel oopses. With the rate limit, we just get a lot of annoying kernel messages but the machine continues on, recovers, and eventually the memory operations all succeed" And: "> Well... why are all these EBUSY's occurring? It sounds inefficient > (at least) but if it is expected, normal and unavoidable then > perhaps we should just remove that message altogether? I don't have an answer to that question. To be honest, I haven't looked real hard. We never had this at all, then it started out of the blue, but only on our Dell 730xd machines (and it hits all of them), but no other classes or brands of machines. And we have our 730xd machines loaded up with different brands and models of cards (for instance one dedicated to mlx4 hardware, one for qib, one for mlx5, an ocrdma/cxgb4 combo, etc), so the fact that it hit all of the machines meant it wasn't tied to any particular brand/model of RDMA hardware. To me, it always smelled of a hardware oddity specific to maybe the CPUs or mainboard chipsets in these machines, so given that I'm not an mm expert anyway, I never chased it down. A few other relevant details: it showed up somewhere around 4.8/4.9 or thereabouts. It never happened before, but the prinkt has been there since the 3.18 days, so possibly the test to trigger this message was changed, or something else in the allocator changed such that the situation started happening on these machines? And, like I said, it is specific to our 730xd machines (but they are all identical, so that could mean it's something like their specific ram configuration is causing the allocator to hit this on these machine but not on other machines in the cluster, I don't want to say it's necessarily the model of chipset or CPU, there are other bits of identicalness between these machines)" Link: http://lkml.kernel.org/r/499c0f6cc10d6eb829a67f2a4d75b4228a9b356e.1501695897.git.jtoppins@redhat.com Signed-off-by: Jonathan Toppins <jtoppins@redhat.com> Reviewed-by: Doug Ledford <dledford@redhat.com> Tested-by: Doug Ledford <dledford@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-12mm/mempool: avoid KASAN marking mempool poison checks as use-after-freeMatthew Dawson
commit 7640131032db9118a78af715ac77ba2debeeb17c upstream. When removing an element from the mempool, mark it as unpoisoned in KASAN before verifying its contents for SLUB/SLAB debugging. Otherwise KASAN will flag the reads checking the element use-after-free writes as use-after-free reads. Signed-off-by: Matthew Dawson <matthew@mjdsystems.ca> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrii Bordunov <aborduno@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11mm: don't dereference struct page fields of invalid pagesArd Biesheuvel
[ Upstream commit f073bdc51771f5a5c7a8d1191bfc3ae371d44de7 ] The VM_BUG_ON() check in move_freepages() checks whether the node id of a page matches the node id of its zone. However, it does this before having checked whether the struct page pointer refers to a valid struct page to begin with. This is guaranteed in most cases, but may not be the case if CONFIG_HOLES_IN_ZONE=y. So reorder the VM_BUG_ON() with the pfn_valid_within() check. Link: http://lkml.kernel.org/r/1481706707-6211-2-git-send-email-ard.biesheuvel@linaro.org Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Hanjun Guo <hanjun.guo@linaro.org> Cc: Yisheng Xie <xieyisheng1@huawei.com> Cc: Robert Richter <rrichter@cavium.com> Cc: James Morse <james.morse@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11mm, mprotect: flush TLB if potentially racing with a parallel reclaim ↵Mel Gorman
leaving stale TLB entries commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream. Stable note for 4.4: The upstream patch patches madvise(MADV_FREE) but 4.4 does not have support for that feature. The changelog is left as-is but the hunk related to madvise is omitted from the backport. Nadav Amit identified a theoritical race between page reclaim and mprotect due to TLB flushes being batched outside of the PTL being held. He described the race as follows: CPU0 CPU1 ---- ---- user accesses memory using RW PTE [PTE now cached in TLB] try_to_unmap_one() ==> ptep_get_and_clear() ==> set_tlb_ubc_flush_pending() mprotect(addr, PROT_READ) ==> change_pte_range() ==> [ PTE non-present - no flush ] user writes using cached RW PTE ... try_to_unmap_flush() The same type of race exists for reads when protecting for PROT_NONE and also exists for operations that can leave an old TLB entry behind such as munmap, mremap and madvise. For some operations like mprotect, it's not necessarily a data integrity issue but it is a correctness issue as there is a window where an mprotect that limits access still allows access. For munmap, it's potentially a data integrity issue although the race is massive as an munmap, mmap and return to userspace must all complete between the window when reclaim drops the PTL and flushes the TLB. However, it's theoritically possible so handle this issue by flushing the mm if reclaim is potentially currently batching TLB flushes. Other instances where a flush is required for a present pte should be ok as either the page lock is held preventing parallel reclaim or a page reference count is elevated preventing a parallel free leading to corruption. In the case of page_mkclean there isn't an obvious path that userspace could take advantage of without using the operations that are guarded by this patch. Other users such as gup as a race with reclaim looks just at PTEs. huge page variants should be ok as they don't race with reclaim. mincore only looks at PTEs. userfault also should be ok as if a parallel reclaim takes place, it will either fault the page back in or read some of the data before the flush occurs triggering a fault. Note that a variant of this patch was acked by Andy Lutomirski but this was for the x86 parts on top of his PCID work which didn't make the 4.13 merge window as expected. His ack is dropped from this version and there will be a follow-on patch on top of PCID that will include his ack. [akpm@linux-foundation.org: tweak comments] [akpm@linux-foundation.org: fix spello] Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de Reported-by: Nadav Amit <nadav.amit@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11mm/page_alloc: Remove kernel address exposure in free_reserved_area()Josh Poimboeuf
commit adb1fe9ae2ee6ef6bc10f3d5a588020e7664dfa7 upstream. Linus suggested we try to remove some of the low-hanging fruit related to kernel address exposure in dmesg. The only leaks I see on my local system are: Freeing SMP alternatives memory: 32K (ffffffff9e309000 - ffffffff9e311000) Freeing initrd memory: 10588K (ffffa0b736b42000 - ffffa0b737599000) Freeing unused kernel memory: 3592K (ffffffff9df87000 - ffffffff9e309000) Freeing unused kernel memory: 1352K (ffffa0b7288ae000 - ffffa0b728a00000) Freeing unused kernel memory: 632K (ffffa0b728d62000 - ffffa0b728e00000) Linus says: "I suspect we should just remove [the addresses in the 'Freeing' messages]. I'm sure they are useful in theory, but I suspect they were more useful back when the whole "free init memory" was originally done. These days, if we have a use-after-free, I suspect the init-mem situation is the easiest situation by far. Compared to all the dynamic allocations which are much more likely to show it anyway. So having debug output for that case is likely not all that productive." With this patch the freeing messages now look like this: Freeing SMP alternatives memory: 32K Freeing initrd memory: 10588K Freeing unused kernel memory: 3592K Freeing unused kernel memory: 1352K Freeing unused kernel memory: 632K Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/6836ff90c45b71d38e5d4405aec56fa9e5d1d4b2.1477405374.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21mm: fix overflow check in expand_upwards()Helge Deller
commit 37511fb5c91db93d8bd6e3f52f86e5a7ff7cfcdf upstream. Jörn Engel noticed that the expand_upwards() function might not return -ENOMEM in case the requested address is (unsigned long)-PAGE_SIZE and if the architecture didn't defined TASK_SIZE as multiple of PAGE_SIZE. Affected architectures are arm, frv, m68k, blackfin, h8300 and xtensa which all define TASK_SIZE as 0xffffffff, but since none of those have an upwards-growing stack we currently have no actual issue. Nevertheless let's fix this just in case any of the architectures with an upward-growing stack (currently parisc, metag and partly ia64) define TASK_SIZE similar. Link: http://lkml.kernel.org/r/20170702192452.GA11868@p100.box Fixes: bd726c90b6b8 ("Allow stack to grow up to address space limit") Signed-off-by: Helge Deller <deller@gmx.de> Reported-by: Jörn Engel <joern@purestorage.com> Cc: Hugh Dickins <hughd@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21mm/list_lru.c: fix list_lru_count_node() to be race freeSahitya Tummala
commit 2c80cd57c74339889a8752b20862a16c28929c3a upstream. list_lru_count_node() iterates over all memcgs to get the total number of entries on the node but it can race with memcg_drain_all_list_lrus(), which migrates the entries from a dead cgroup to another. This can return incorrect number of entries from list_lru_count_node(). Fix this by keeping track of entries per node and simply return it in list_lru_count_node(). Link: http://lkml.kernel.org/r/1498707555-30525-1-git-send-email-stummala@codeaurora.org Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Alexander Polakov <apolyakov@beget.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15mm: fix classzone_idx underflow in shrink_zones()Vlastimil Babka
[Not upstream as that would take 34+ patches] We've got reported a BUG in do_try_to_free_pages(): BUG: unable to handle kernel paging request at ffff8ffffff28990 IP: [<ffffffff8119abe0>] do_try_to_free_pages+0x140/0x490 PGD 0 Oops: 0000 [#1] SMP megaraid_sas sg scsi_mod efivarfs autofs4 Supported: No, Unsupported modules are loaded Workqueue: kacpi_hotplug acpi_hotplug_work_fn task: ffff88ffd0d4c540 ti: ffff88ffd0e48000 task.ti: ffff88ffd0e48000 RIP: 0010:[<ffffffff8119abe0>] [<ffffffff8119abe0>] do_try_to_free_pages+0x140/0x490 RSP: 0018:ffff88ffd0e4ba60 EFLAGS: 00010206 RAX: 000006fffffff900 RBX: 00000000ffffffff RCX: ffff88fffff29000 RDX: 000000ffffffff00 RSI: 0000000000000003 RDI: 00000000024200c8 RBP: 0000000001320122 R08: 0000000000000000 R09: ffff88ffd0e4bbac R10: 0000000000000000 R11: 0000000000000000 R12: ffff88ffd0e4bae0 R13: 0000000000000e00 R14: ffff88fffff2a500 R15: ffff88fffff2b300 FS: 0000000000000000(0000) GS:ffff88ffe6440000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffff8ffffff28990 CR3: 0000000001c0a000 CR4: 00000000003406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Stack: 00000002db570a80 024200c80000001e ffff88fffff2b300 0000000000000000 ffff88fffffd5700 ffff88ffd0d4c540 ffff88ffd0d4c540 ffffffff0000000c 0000000000000000 0000000000000040 00000000024200c8 ffff88ffd0e4bae0 Call Trace: [<ffffffff8119afea>] try_to_free_pages+0xba/0x170 [<ffffffff8118cf2f>] __alloc_pages_nodemask+0x53f/0xb20 [<ffffffff811d39ff>] alloc_pages_current+0x7f/0x100 [<ffffffff811e2232>] migrate_pages+0x202/0x710 [<ffffffff815dadaa>] __offline_pages.constprop.23+0x4ba/0x790 [<ffffffff81463263>] memory_subsys_offline+0x43/0x70 [<ffffffff8144cbed>] device_offline+0x7d/0xa0 [<ffffffff81392fa2>] acpi_bus_offline+0xa5/0xef [<ffffffff81394a77>] acpi_device_hotplug+0x21b/0x41f [<ffffffff8138dab7>] acpi_hotplug_work_fn+0x1a/0x23 [<ffffffff81093cee>] process_one_work+0x14e/0x410 [<ffffffff81094546>] worker_thread+0x116/0x490 [<ffffffff810999ed>] kthread+0xbd/0xe0 [<ffffffff815e4e7f>] ret_from_fork+0x3f/0x70 This translates to the loop in shrink_zone(): classzone_idx = requested_highidx; while (!populated_zone(zone->zone_pgdat->node_zones + classzone_idx)) classzone_idx--; where no zone is populated, so classzone_idx becomes -1 (in RBX). Added debugging output reveals that we enter the function with sc->gfp_mask == GFP_NOFS|__GFP_NOFAIL|__GFP_HARDWALL|__GFP_MOVABLE requested_highidx = gfp_zone(sc->gfp_mask) == 2 (ZONE_NORMAL) Inside the for loop, however: gfp_zone(sc->gfp_mask) == 3 (ZONE_MOVABLE) This means we have gone through this branch: if (buffer_heads_over_limit) sc->gfp_mask |= __GFP_HIGHMEM; This changes the gfp_zone() result, but requested_highidx remains unchanged. On nodes where the only populated zone is movable, the inner while loop will check only lower zones, which are not populated, and underflow classzone_idx. To sum up, the bug occurs in configurations with ZONE_MOVABLE (such as when booted with the movable_node parameter) and only in situations when buffer_heads_over_limit is true, and there's an allocation with __GFP_MOVABLE and without __GFP_HIGHMEM performing direct reclaim. This patch makes sure that classzone_idx starts with the correct zone. Mainline has been affected in versions 4.6 and 4.7, but the culprit commit has been also included in stable trees. In mainline, this has been fixed accidentally as part of 34-patch series (plus follow-up fixes) "Move LRU page reclaim from zones to nodes", which makes the mainline commit unsuitable for stable backport, unfortunately. Fixes: 7bf52fb891b6 ("mm: vmscan: reclaim highmem zone if buffer_heads is over limit") Obsoleted-by: b2e18757f2c9 ("mm, vmscan: begin reclaiming pages on a per-node basis") Debugged-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05mm: numa: avoid waiting on freed migrated pagesMark Rutland
commit 3c226c637b69104f6b9f1c6ec5b08d7b741b3229 upstream. In do_huge_pmd_numa_page(), we attempt to handle a migrating thp pmd by waiting until the pmd is unlocked before we return and retry. However, we can race with migrate_misplaced_transhuge_page(): // do_huge_pmd_numa_page // migrate_misplaced_transhuge_page() // Holds 0 refs on page // Holds 2 refs on page vmf->ptl = pmd_lock(vma->vm_mm, vmf->pmd); /* ... */ if (pmd_trans_migrating(*vmf->pmd)) { page = pmd_page(*vmf->pmd); spin_unlock(vmf->ptl); ptl = pmd_lock(mm, pmd); if (page_count(page) != 2)) { /* roll back */ } /* ... */ mlock_migrate_page(new_page, page); /* ... */ spin_unlock(ptl); put_page(page); put_page(page); // page freed here wait_on_page_locked(page); goto out; } This can result in the freed page having its waiters flag set unexpectedly, which trips the PAGE_FLAGS_CHECK_AT_PREP checks in the page alloc/free functions. This has been observed on arm64 KVM guests. We can avoid this by having do_huge_pmd_numa_page() take a reference on the page before dropping the pmd lock, mirroring what we do in __migration_entry_wait(). When we hit the race, migrate_misplaced_transhuge_page() will see the reference and abort the migration, as it may do today in other cases. Fixes: b8916634b77bffb2 ("mm: Prevent parallel splits during THP migration") Link: http://lkml.kernel.org/r/1497349722-6731-2-git-send-email-will.deacon@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Steve Capper <steve.capper@arm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05mm, swap_cgroup: reschedule when neeed in swap_cgroup_swapoff()David Rientjes
commit 460bcec84e11c75122ace5976214abbc596eb91b upstream. We got need_resched() warnings in swap_cgroup_swapoff() because swap_cgroup_ctrl[type].length is particularly large. Reschedule when needed. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1704061315270.80559@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-26mm: fix new crash in unmapped_area_topdown()Hugh Dickins
commit f4cb767d76cf7ee72f97dd76f6cfa6c76a5edc89 upstream. Trinity gets kernel BUG at mm/mmap.c:1963! in about 3 minutes of mmap testing. That's the VM_BUG_ON(gap_end < gap_start) at the end of unmapped_area_topdown(). Linus points out how MAP_FIXED (which does not have to respect our stack guard gap intentions) could result in gap_end below gap_start there. Fix that, and the similar case in its alternative, unmapped_area(). Fixes: 1be7107fbe18 ("mm: larger stack guard gap, between vmas") Reported-by: Dave Jones <davej@codemonkey.org.uk> Debugged-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-26Allow stack to grow up to address space limitHelge Deller
commit bd726c90b6b8ce87602208701b208a208e6d5600 upstream. Fix expand_upwards() on architectures with an upward-growing stack (parisc, metag and partly IA-64) to allow the stack to reliably grow exactly up to the address space limit given by TASK_SIZE. Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-26mm: larger stack guard gap, between vmasHugh Dickins
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream. Stack guard page is a useful feature to reduce a risk of stack smashing into a different mapping. We have been using a single page gap which is sufficient to prevent having stack adjacent to a different mapping. But this seems to be insufficient in the light of the stack usage in userspace. E.g. glibc uses as large as 64kB alloca() in many commonly used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX] which is 256kB or stack strings with MAX_ARG_STRLEN. This will become especially dangerous for suid binaries and the default no limit for the stack size limit because those applications can be tricked to consume a large portion of the stack and a single glibc call could jump over the guard page. These attacks are not theoretical, unfortunatelly. Make those attacks less probable by increasing the stack guard gap to 1MB (on systems with 4k pages; but make it depend on the page size because systems with larger base pages might cap stack allocations in the PAGE_SIZE units) which should cover larger alloca() and VLA stack allocations. It is obviously not a full fix because the problem is somehow inherent, but it should reduce attack space a lot. One could argue that the gap size should be configurable from userspace, but that can be done later when somebody finds that the new 1MB is wrong for some special case applications. For now, add a kernel command line option (stack_guard_gap) to specify the stack gap size (in page units). Implementation wise, first delete all the old code for stack guard page: because although we could get away with accounting one extra page in a stack vma, accounting a larger gap can break userspace - case in point, a program run with "ulimit -S -v 20000" failed when the 1MB gap was counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK and strict non-overcommit mode. Instead of keeping gap inside the stack vma, maintain the stack guard gap as a gap between vmas: using vm_start_gap() in place of vm_start (or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few places which need to respect the gap - mainly arch_get_unmapped_area(), and and the vma tree's subtree_gap support for that. Original-patch-by: Oleg Nesterov <oleg@redhat.com> Original-patch-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Tested-by: Helge Deller <deller@gmx.de> # parisc Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [wt: backport to 4.11: adjust context] [wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide] [wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes] Signed-off-by: Willy Tarreau <w@1wt.eu> [gkh: minor build fixes for 4.4] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-26swap: cond_resched in swap_cgroup_prepare()Yu Zhao
commit ef70762948dde012146926720b70e79736336764 upstream. I saw need_resched() warnings when swapping on large swapfile (TBs) because continuously allocating many pages in swap_cgroup_prepare() took too long. We already cond_resched when freeing page in swap_cgroup_swapoff(). Do the same for the page allocation. Link: http://lkml.kernel.org/r/20170604200109.17606-1-yuzhao@google.com Signed-off-by: Yu Zhao <yuzhao@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-26mm/memory-failure.c: use compound_head() flags for huge pagesJames Morse
commit 7258ae5c5a2ce2f5969e8b18b881be40ab55433d upstream. memory_failure() chooses a recovery action function based on the page flags. For huge pages it uses the tail page flags which don't have anything interesting set, resulting in: > Memory failure: 0x9be3b4: Unknown page state > Memory failure: 0x9be3b4: recovery action for unknown page: Failed Instead, save a copy of the head page's flags if this is a huge page, this means if there are no relevant flags for this tail page, we use the head pages flags instead. This results in the me_huge_page() recovery action being called: > Memory failure: 0x9b7969: recovery action for huge page: Delayed For hugepages that have not yet been allocated, this allows the hugepage to be dequeued. Fixes: 524fca1e7356 ("HWPOISON: fix misjudgement of page_action() for errors on mlocked pages") Link: http://lkml.kernel.org/r/20170524130204.21845-1-james.morse@arm.com Signed-off-by: James Morse <james.morse@arm.com> Tested-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-17kasan: respect /proc/sys/kernel/traceoff_on_warningPeter Zijlstra
[ Upstream commit 4f40c6e5627ea73b4e7c615c59631f38cc880885 ] After much waiting I finally reproduced a KASAN issue, only to find my trace-buffer empty of useful information because it got spooled out :/ Make kasan_report honour the /proc/sys/kernel/traceoff_on_warning interface. Link: http://lkml.kernel.org/r/20170125164106.3514-1-aryabinin@virtuozzo.com Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Acked-by: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14mm: consider memblock reservations for deferred memory initialization sizingMichal Hocko
commit 864b9a393dcb5aed09b8fd31b9bbda0fdda99374 upstream. We have seen an early OOM killer invocation on ppc64 systems with crashkernel=4096M: kthreadd invoked oom-killer: gfp_mask=0x16040c0(GFP_KERNEL|__GFP_COMP|__GFP_NOTRACK), nodemask=7, order=0, oom_score_adj=0 kthreadd cpuset=/ mems_allowed=7 CPU: 0 PID: 2 Comm: kthreadd Not tainted 4.4.68-1.gd7fe927-default #1 Call Trace: dump_stack+0xb0/0xf0 (unreliable) dump_header+0xb0/0x258 out_of_memory+0x5f0/0x640 __alloc_pages_nodemask+0xa8c/0xc80 kmem_getpages+0x84/0x1a0 fallback_alloc+0x2a4/0x320 kmem_cache_alloc_node+0xc0/0x2e0 copy_process.isra.25+0x260/0x1b30 _do_fork+0x94/0x470 kernel_thread+0x48/0x60 kthreadd+0x264/0x330 ret_from_kernel_thread+0x5c/0xa4 Mem-Info: active_anon:0 inactive_anon:0 isolated_anon:0 active_file:0 inactive_file:0 isolated_file:0 unevictable:0 dirty:0 writeback:0 unstable:0 slab_reclaimable:5 slab_unreclaimable:73 mapped:0 shmem:0 pagetables:0 bounce:0 free:0 free_pcp:0 free_cma:0 Node 7 DMA free:0kB min:0kB low:0kB high:0kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:52428800kB managed:110016kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:320kB slab_unreclaimable:4672kB kernel_stack:1152kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes lowmem_reserve[]: 0 0 0 0 Node 7 DMA: 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 0kB 0 total pagecache pages 0 pages in swap cache Swap cache stats: add 0, delete 0, find 0/0 Free swap = 0kB Total swap = 0kB 819200 pages RAM 0 pages HighMem/MovableOnly 817481 pages reserved 0 pages cma reserved 0 pages hwpoisoned the reason is that the managed memory is too low (only 110MB) while the rest of the the 50GB is still waiting for the deferred intialization to be done. update_defer_init estimates the initial memoty to initialize to 2GB at least but it doesn't consider any memory allocated in that range. In this particular case we've had Reserving 4096MB of memory at 128MB for crashkernel (System RAM: 51200MB) so the low 2GB is mostly depleted. Fix this by considering memblock allocations in the initial static initialization estimation. Move the max_initialise to reset_deferred_meminit and implement a simple memblock_reserved_memory helper which iterates all reserved blocks and sums the size of all that start below the given address. The cumulative size is than added on top of the initial estimation. This is still not ideal because reset_deferred_meminit doesn't consider holes and so reservation might be above the initial estimation whihch we ignore but let's make the logic simpler until we really need to handle more complicated cases. Fixes: 3a80a7fa7989 ("mm: meminit: initialise a subset of struct pages if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set") Link: http://lkml.kernel.org/r/20170531104010.GI27783@dhcp22.suse.cz Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@suse.de> Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14fs: add i_blocksize()Fabian Frederick
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream. Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs branch. This patch also fixes multiple checkpatch warnings: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' Thanks to Andrew Morton for suggesting more appropriate function instead of macro. [geliangtang@gmail.com: truncate: use i_blocksize()] Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Geliang Tang <geliangtang@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07mlock: fix mlock count can not decrease in race conditionYisheng Xie
commit 70feee0e1ef331b22cc51f383d532a0d043fbdcc upstream. Kefeng reported that when running the follow test, the mlock count in meminfo will increase permanently: [1] testcase linux:~ # cat test_mlockal grep Mlocked /proc/meminfo for j in `seq 0 10` do for i in `seq 4 15` do ./p_mlockall >> log & done sleep 0.2 done # wait some time to let mlock counter decrease and 5s may not enough sleep 5 grep Mlocked /proc/meminfo linux:~ # cat p_mlockall.c #include <sys/mman.h> #include <stdlib.h> #include <stdio.h> #define SPACE_LEN 4096 int main(int argc, char ** argv) { int ret; void *adr = malloc(SPACE_LEN); if (!adr) return -1; ret = mlockall(MCL_CURRENT | MCL_FUTURE); printf("mlcokall ret = %d\n", ret); ret = munlockall(); printf("munlcokall ret = %d\n", ret); free(adr); return 0; } In __munlock_pagevec() we should decrement NR_MLOCK for each page where we clear the PageMlocked flag. Commit 1ebb7cc6a583 ("mm: munlock: batch NR_MLOCK zone state updates") has introduced a bug where we don't decrement NR_MLOCK for pages where we clear the flag, but fail to isolate them from the lru list (e.g. when the pages are on some other cpu's percpu pagevec). Since PageMlocked stays cleared, the NR_MLOCK accounting gets permanently disrupted by this. Fix it by counting the number of page whose PageMlock flag is cleared. Fixes: 1ebb7cc6a583 (" mm: munlock: batch NR_MLOCK zone state updates") Link: http://lkml.kernel.org/r/1495678405-54569-1-git-send-email-xieyisheng1@huawei.com Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com> Reported-by: Kefeng Wang <wangkefeng.wang@huawei.com> Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Joern Engel <joern@logfs.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michel Lespinasse <walken@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Xishi Qiu <qiuxishi@huawei.com> Cc: zhongjiang <zhongjiang@huawei.com> Cc: Hanjun Guo <guohanjun@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07mm/migrate: fix refcount handling when !hugepage_migration_supported()Punit Agrawal
commit 30809f559a0d348c2dfd7ab05e9a451e2384962e upstream. On failing to migrate a page, soft_offline_huge_page() performs the necessary update to the hugepage ref-count. But when !hugepage_migration_supported() , unmap_and_move_hugepage() also decrements the page ref-count for the hugepage. The combined behaviour leaves the ref-count in an inconsistent state. This leads to soft lockups when running the overcommitted hugepage test from mce-tests suite. Soft offlining pfn 0x83ed600 at process virtual address 0x400000000000 soft offline: 0x83ed600: migration failed 1, type 1fffc00000008008 (uptodate|head) INFO: rcu_preempt detected stalls on CPUs/tasks: Tasks blocked on level-0 rcu_node (CPUs 0-7): P2715 (detected by 7, t=5254 jiffies, g=963, c=962, q=321) thugetlb_overco R running task 0 2715 2685 0x00000008 Call trace: dump_backtrace+0x0/0x268 show_stack+0x24/0x30 sched_show_task+0x134/0x180 rcu_print_detail_task_stall_rnp+0x54/0x7c rcu_check_callbacks+0xa74/0xb08 update_process_times+0x34/0x60 tick_sched_handle.isra.7+0x38/0x70 tick_sched_timer+0x4c/0x98 __hrtimer_run_queues+0xc0/0x300 hrtimer_interrupt+0xac/0x228 arch_timer_handler_phys+0x3c/0x50 handle_percpu_devid_irq+0x8c/0x290 generic_handle_irq+0x34/0x50 __handle_domain_irq+0x68/0xc0 gic_handle_irq+0x5c/0xb0 Address this by changing the putback_active_hugepage() in soft_offline_huge_page() to putback_movable_pages(). This only triggers on systems that enable memory failure handling (ARCH_SUPPORTS_MEMORY_FAILURE) but not hugepage migration (!ARCH_ENABLE_HUGEPAGE_MIGRATION). I imagine this wasn't triggered as there aren't many systems running this configuration. [akpm@linux-foundation.org: remove dead comment, per Naoya] Link: http://lkml.kernel.org/r/20170525135146.32011-1-punit.agrawal@arm.com Reported-by: Manoj Iyer <manoj.iyer@canonical.com> Tested-by: Manoj Iyer <manoj.iyer@canonical.com> Suggested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07slub/memcg: cure the brainless abuse of sysfs attributesThomas Gleixner
commit 478fe3037b2278d276d4cd9cd0ab06c4cb2e9b32 upstream. memcg_propagate_slab_attrs() abuses the sysfs attribute file functions to propagate settings from the root kmem_cache to a newly created kmem_cache. It does that with: attr->show(root, buf); attr->store(new, buf, strlen(bug); Aside of being a lazy and absurd hackery this is broken because it does not check the return value of the show() function. Some of the show() functions return 0 w/o touching the buffer. That means in such a case the store function is called with the stale content of the previous show(). That causes nonsense like invoking kmem_cache_shrink() on a newly created kmem_cache. In the worst case it would cause handing in an uninitialized buffer. This should be rewritten proper by adding a propagate() callback to those slub_attributes which must be propagated and avoid that insane conversion to and from ASCII, but that's too large for a hot fix. Check at least the return value of the show() function, so calling store() with stale content is prevented. Steven said: "It can cause a deadlock with get_online_cpus() that has been uncovered by recent cpu hotplug and lockdep changes that Thomas and Peter have been doing. Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(cpu_hotplug.lock); lock(slab_mutex); lock(cpu_hotplug.lock); lock(slab_mutex); *** DEADLOCK ***" Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705201244540.2255@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thpKeno Fischer
commit 8310d48b125d19fcd9521d83b8293e63eb1646aa upstream. In commit 19be0eaffa3a ("mm: remove gup_flags FOLL_WRITE games from __get_user_pages()"), the mm code was changed from unsetting FOLL_WRITE after a COW was resolved to setting the (newly introduced) FOLL_COW instead. Simultaneously, the check in gup.c was updated to still allow writes with FOLL_FORCE set if FOLL_COW had also been set. However, a similar check in huge_memory.c was forgotten. As a result, remote memory writes to ro regions of memory backed by transparent huge pages cause an infinite loop in the kernel (handle_mm_fault sets FOLL_COW and returns 0 causing a retry, but follow_trans_huge_pmd bails out immidiately because `(flags & FOLL_WRITE) && !pmd_write(*pmd)` is true. While in this state the process is stil SIGKILLable, but little else works (e.g. no ptrace attach, no other signals). This is easily reproduced with the following code (assuming thp are set to always): #include <assert.h> #include <fcntl.h> #include <stdint.h> #include <stdio.h> #include <string.h> #include <sys/mman.h> #include <sys/stat.h> #include <sys/types.h> #include <sys/wait.h> #include <unistd.h> #define TEST_SIZE 5 * 1024 * 1024 int main(void) { int status; pid_t child; int fd = open("/proc/self/mem", O_RDWR); void *addr = mmap(NULL, TEST_SIZE, PROT_READ, MAP_ANONYMOUS | MAP_PRIVATE, 0, 0); assert(addr != MAP_FAILED); pid_t parent_pid = getpid(); if ((child = fork()) == 0) { void *addr2 = mmap(NULL, TEST_SIZE, PROT_READ | PROT_WRITE, MAP_ANONYMOUS | MAP_PRIVATE, 0, 0); assert(addr2 != MAP_FAILED); memset(addr2, 'a', TEST_SIZE); pwrite(fd, addr2, TEST_SIZE, (uintptr_t)addr); return 0; } assert(child == waitpid(child, &status, 0)); assert(WIFEXITED(status) && WEXITSTATUS(status) == 0); return 0; } Fix this by updating follow_trans_huge_pmd in huge_memory.c analogously to the update in gup.c in the original commit. The same pattern exists in follow_devmap_pmd. However, we should not be able to reach that check with FOLL_COW set, so add WARN_ONCE to make sure we notice if we ever do. [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/20170106015025.GA38411@juliacomputing.com Signed-off-by: Keno Fischer <keno@juliacomputing.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Greg Thelen <gthelen@google.com> Cc: Nicholas Piggin <npiggin@gmail.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [AmitP: Minor refactoring of upstream changes for linux-3.18.y, where follow_devmap_pmd() doesn't exist.] Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12mm/mempolicy.c: fix error handling in set_mempolicy and mbind.Chris Salls
commit cf01fb9985e8deb25ccf0ea54d916b8871ae0e62 upstream. In the case that compat_get_bitmap fails we do not want to copy the bitmap to the user as it will contain uninitialized stack data and leak sensitive data. Signed-off-by: Chris Salls <salls@cs.ucsb.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08mm, hugetlb: use pte_present() instead of pmd_present() in follow_huge_pmd()Naoya Horiguchi
commit c9d398fa237882ea07167e23bcfc5e6847066518 upstream. I found the race condition which triggers the following bug when move_pages() and soft offline are called on a single hugetlb page concurrently. Soft offlining page 0x119400 at 0x700000000000 BUG: unable to handle kernel paging request at ffffea0011943820 IP: follow_huge_pmd+0x143/0x190 PGD 7ffd2067 PUD 7ffd1067 PMD 0 [61163.582052] Oops: 0000 [#1] SMP Modules linked in: binfmt_misc ppdev virtio_balloon parport_pc pcspkr i2c_piix4 parport i2c_core acpi_cpufreq ip_tables xfs libcrc32c ata_generic pata_acpi virtio_blk 8139too crc32c_intel ata_piix serio_raw libata virtio_pci 8139cp virtio_ring virtio mii floppy dm_mirror dm_region_hash dm_log dm_mod [last unloaded: cap_check] CPU: 0 PID: 22573 Comm: iterate_numa_mo Tainted: P OE 4.11.0-rc2-mm1+ #2 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011 RIP: 0010:follow_huge_pmd+0x143/0x190 RSP: 0018:ffffc90004bdbcd0 EFLAGS: 00010202 RAX: 0000000465003e80 RBX: ffffea0004e34d30 RCX: 00003ffffffff000 RDX: 0000000011943800 RSI: 0000000000080001 RDI: 0000000465003e80 RBP: ffffc90004bdbd18 R08: 0000000000000000 R09: ffff880138d34000 R10: ffffea0004650000 R11: 0000000000c363b0 R12: ffffea0011943800 R13: ffff8801b8d34000 R14: ffffea0000000000 R15: 000077ff80000000 FS: 00007fc977710740(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffea0011943820 CR3: 000000007a746000 CR4: 00000000001406f0 Call Trace: follow_page_mask+0x270/0x550 SYSC_move_pages+0x4ea/0x8f0 SyS_move_pages+0xe/0x10 do_syscall_64+0x67/0x180 entry_SYSCALL64_slow_path+0x25/0x25 RIP: 0033:0x7fc976e03949 RSP: 002b:00007ffe72221d88 EFLAGS: 00000246 ORIG_RAX: 0000000000000117 RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fc976e03949 RDX: 0000000000c22390 RSI: 0000000000001400 RDI: 0000000000005827 RBP: 00007ffe72221e00 R08: 0000000000c2c3a0 R09: 0000000000000004 R10: 0000000000c363b0 R11: 0000000000000246 R12: 0000000000400650 R13: 00007ffe72221ee0 R14: 0000000000000000 R15: 0000000000000000 Code: 81 e4 ff ff 1f 00 48 21 c2 49 c1 ec 0c 48 c1 ea 0c 4c 01 e2 49 bc 00 00 00 00 00 ea ff ff 48 c1 e2 06 49 01 d4 f6 45 bc 04 74 90 <49> 8b 7c 24 20 40 f6 c7 01 75 2b 4c 89 e7 8b 47 1c 85 c0 7e 2a RIP: follow_huge_pmd+0x143/0x190 RSP: ffffc90004bdbcd0 CR2: ffffea0011943820 ---[ end trace e4f81353a2d23232 ]--- Kernel panic - not syncing: Fatal exception Kernel Offset: disabled This bug is triggered when pmd_present() returns true for non-present hugetlb, so fixing the present check in follow_huge_pmd() prevents it. Using pmd_present() to determine present/non-present for hugetlb is not correct, because pmd_present() checks multiple bits (not only _PAGE_PRESENT) for historical reason and it can misjudge hugetlb state. Fixes: e66f17ff7177 ("mm/hugetlb: take page table lock in follow_huge_pmd()") Link: http://lkml.kernel.org/r/1490149898-20231-1-git-send-email-n-horiguchi@ah.jp.nec.com Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26percpu: acquire pcpu_lock when updating pcpu_nr_empty_pop_pagesTahsin Erdogan
commit 320661b08dd6f1746d5c7ab4eb435ec64b97cd45 upstream. Update to pcpu_nr_empty_pop_pages in pcpu_alloc() is currently done without holding pcpu_lock. This can lead to bad updates to the variable. Add missing lock calls. Fixes: b539b87fed37 ("percpu: implmeent pcpu_nr_empty_pop_pages and chunk->nr_populated") Signed-off-by: Tahsin Erdogan <tahsin@google.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-18mm: memcontrol: avoid unused function warningArnd Bergmann
commit 358c07fcc3b60ab08d77f1684de8bd81bcf49a1a upstream. A bugfix in v4.8-rc2 introduced a harmless warning when CONFIG_MEMCG_SWAP is disabled but CONFIG_MEMCG is enabled: mm/memcontrol.c:4085:27: error: 'mem_cgroup_id_get_online' defined but not used [-Werror=unused-function] static struct mem_cgroup *mem_cgroup_id_get_online(struct mem_cgroup *memcg) This moves the function inside of the #ifdef block that hides the calling function, to avoid the warning. Fixes: 1f47b61fb407 ("mm: memcontrol: fix swap counter leak on swapout from offline cgroup") Link: http://lkml.kernel.org/r/20160824113733.2776701-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12mm: do not access page->mapping directly on page_endioMinchan Kim
commit dd8416c47715cf324c9a16f13273f9fda87acfed upstream. With rw_page, page_endio is used for completing IO on a page and it propagates write error to the address space if the IO fails. The problem is it accesses page->mapping directly which might be okay for file-backed pages but it shouldn't for anonymous page. Otherwise, it can corrupt one of field from anon_vma under us and system goes panic randomly. swap_writepage bdev_writepage ops->rw_page I encountered the BUG during developing new zram feature and it was really hard to figure it out because it made random crash, somtime mmap_sem lockdep, sometime other places where places never related to zram/zsmalloc, and not reproducible with some configuration. When I consider how that bug is subtle and people do fast-swap test with brd, it's worth to add stable mark, I think. Fixes: dd6bd0d9c7db ("swap: use bdev_read_page() / bdev_write_page()") Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Matthew Wilcox <willy@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12mm: vmpressure: fix sending wrong events on underflowVinayak Menon
commit e1587a4945408faa58d0485002c110eb2454740c upstream. At the end of a window period, if the reclaimed pages is greater than scanned, an unsigned underflow can result in a huge pressure value and thus a critical event. Reclaimed pages is found to go higher than scanned because of the addition of reclaimed slab pages to reclaimed in shrink_node without a corresponding increment to scanned pages. Minchan Kim mentioned that this can also happen in the case of a THP page where the scanned is 1 and reclaimed could be 512. Link: http://lkml.kernel.org/r/1486641577-11685-1-git-send-email-vinmenon@codeaurora.org Signed-off-by: Vinayak Menon <vinmenon@codeaurora.org> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Shiraz Hashim <shashim@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12mm/page_alloc: fix nodes for reclaim in fast pathGavin Shan
commit e02dc017c3032dcdce1b993af0db135462e1b4b7 upstream. When @node_reclaim_node isn't 0, the page allocator tries to reclaim pages if the amount of free memory in the zones are below the low watermark. On Power platform, none of NUMA nodes are scanned for page reclaim because no nodes match the condition in zone_allows_reclaim(). On Power platform, RECLAIM_DISTANCE is set to 10 which is the distance of Node-A to Node-A. So the preferred node even won't be scanned for page reclaim. __alloc_pages_nodemask() get_page_from_freelist() zone_allows_reclaim() Anton proposed the test code as below: # cat alloc.c : int main(int argc, char *argv[]) { void *p; unsigned long size; unsigned long start, end; start = time(NULL); size = strtoul(argv[1], NULL, 0); printf("To allocate %ldGB memory\n", size); size <<= 30; p = malloc(size); assert(p); memset(p, 0, size); end = time(NULL); printf("Used time: %ld seconds\n", end - start); sleep(3600); return 0; } The system I use for testing has two NUMA nodes. Both have 128GB memory. In below scnario, the page caches on node#0 should be reclaimed when it encounters pressure to accommodate request of allocation. # echo 2 > /proc/sys/vm/zone_reclaim_mode; \ sync; \ echo 3 > /proc/sys/vm/drop_caches; \ # taskset -c 0 cat file.32G > /dev/null; \ grep FilePages /sys/devices/system/node/node0/meminfo Node 0 FilePages: 33619712 kB # taskset -c 0 ./alloc 128 # grep FilePages /sys/devices/system/node/node0/meminfo Node 0 FilePages: 33619840 kB # grep MemFree /sys/devices/system/node/node0/meminfo Node 0 MemFree: 186816 kB With the patch applied, the pagecache on node-0 is reclaimed when its free memory is running out. It's the expected behaviour. # echo 2 > /proc/sys/vm/zone_reclaim_mode; \ sync; \ echo 3 > /proc/sys/vm/drop_caches # taskset -c 0 cat file.32G > /dev/null; \ grep FilePages /sys/devices/system/node/node0/meminfo Node 0 FilePages: 33605568 kB # taskset -c 0 ./alloc 128 # grep FilePages /sys/devices/system/node/node0/meminfo Node 0 FilePages: 1379520 kB # grep MemFree /sys/devices/system/node/node0/meminfo Node 0 MemFree: 317120 kB Fixes: 5f7a75acdb24 ("mm: page_alloc: do not cache reclaim distances") Link: http://lkml.kernel.org/r/1486532455-29613-1-git-send-email-gwshan@linux.vnet.ibm.com Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Anton Blanchard <anton@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-26block: fix double-free in the failure path of cgwb_bdi_init()Tejun Heo
commit 5f478e4ea5c5560b4e40eb136991a09f9389f331 upstream. When !CONFIG_CGROUP_WRITEBACK, bdi has single bdi_writeback_congested at bdi->wb_congested. cgwb_bdi_init() allocates it with kzalloc() and doesn't do further initialization. This usually works fine as the reference count gets bumped to 1 by wb_init() and the put from wb_exit() releases it. However, when wb_init() fails, it puts the wb base ref automatically freeing the wb and the explicit kfree() in cgwb_bdi_init() error path ends up trying to free the same pointer the second time causing a double-free. Fix it by explicitly initilizing the refcnt to 1 and putting the base ref from cgwb_bdi_destroy(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Dmitry Vyukov <dvyukov@google.com> Fixes: a13f35e87140 ("writeback: don't embed root bdi_writeback_congested in bdi_writeback") Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09base/memory, hotplug: fix a kernel oops in show_valid_zones()Toshi Kani
commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream. Reading a sysfs "memoryN/valid_zones" file leads to the following oops when the first page of a range is not backed by struct page. show_valid_zones() assumes that 'start_pfn' is always valid for page_zone(). BUG: unable to handle kernel paging request at ffffea017a000000 IP: show_valid_zones+0x6f/0x160 This issue may happen on x86-64 systems with 64GiB or more memory since their memory block size is bumped up to 2GiB. [1] An example of such systems is desribed below. 0x3240000000 is only aligned by 1GiB and this memory block starts from 0x3200000000, which is not backed by struct page. BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable Since test_pages_in_a_zone() already checks holes, fix this issue by extending this function to return 'valid_start' and 'valid_end' for a given range. show_valid_zones() then proceeds with the valid range. [1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems")' Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Zhang Zhen <zhenzhang.zhang@huawei.com> Cc: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: <stable@vger.kernel.org> [4.4+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mm, fs: check for fatal signals in do_generic_file_read()Michal Hocko
commit 5abf186a30a89d5b9c18a6bf93a2c192c9fd52f6 upstream. do_generic_file_read() can be told to perform a large request from userspace. If the system is under OOM and the reading task is the OOM victim then it has an access to memory reserves and finishing the full request can lead to the full memory depletion which is dangerous. Make sure we rather go with a short read and allow the killed task to terminate. Link: http://lkml.kernel.org/r/20170201092706.9966-3-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mm/memory_hotplug.c: check start_pfn in test_pages_in_a_zone()Toshi Kani
commit deb88a2a19e85842d79ba96b05031739ec327ff4 upstream. Patch series "fix a kernel oops when reading sysfs valid_zones", v2. A sysfs memory file is created for each 2GiB memory block on x86-64 when the system has 64GiB or more memory. [1] When the start address of a memory block is not backed by struct page, i.e. a memory range is not aligned by 2GiB, reading its 'valid_zones' attribute file leads to a kernel oops. This issue was observed on multiple x86-64 systems with more than 64GiB of memory. This patch-set fixes this issue. Patch 1 first fixes an issue in test_pages_in_a_zone(), which does not test the start section. Patch 2 then fixes the kernel oops by extending test_pages_in_a_zone() to return valid [start, end). Note for stable kernels: The memory block size change was made by commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems"), which was accepted to 3.9. However, this patch-set depends on (and fixes) the change to test_pages_in_a_zone() made by commit 5f0f2887f4de ("mm/memory_hotplug.c: check for missing sections in test_pages_in_a_zone()"), which was accepted to 4.4. So, I recommend that we backport it up to 4.4. [1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems")' This patch (of 2): test_pages_in_a_zone() does not check 'start_pfn' when it is aligned by section since 'sec_end_pfn' is set equal to 'pfn'. Since this function is called for testing the range of a sysfs memory file, 'start_pfn' is always aligned by section. Fix it by properly setting 'sec_end_pfn' to the next section pfn. Also make sure that this function returns 1 only when the range belongs to a zone. Link: http://lkml.kernel.org/r/20170127222149.30893-2-toshi.kani@hpe.com Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Andrew Banman <abanman@sgi.com> Cc: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09zswap: disable changing params if init failsDan Streetman
commit d7b028f56a971a2e4d8d7887540a144eeefcd4ab upstream. Add zswap_init_failed bool that prevents changing any of the module params, if init_zswap() fails, and set zswap_enabled to false. Change 'enabled' param to a callback, and check zswap_init_failed before allowing any change to 'enabled', 'zpool', or 'compressor' params. Any driver that is built-in to the kernel will not be unloaded if its init function returns error, and its module params remain accessible for users to change via sysfs. Since zswap uses param callbacks, which assume that zswap has been initialized, changing the zswap params after a failed initialization will result in WARNING due to the param callbacks expecting a pool to already exist. This prevents that by immediately exiting any of the param callbacks if initialization failed. This was reported here: https://marc.info/?l=linux-mm&m=147004228125528&w=4 And fixes this WARNING: [ 429.723476] WARNING: CPU: 0 PID: 5140 at mm/zswap.c:503 __zswap_pool_current+0x56/0x60 The warning is just noise, and not serious. However, when init fails, zswap frees all its percpu dstmem pages and its kmem cache. The kmem cache might be serious, if kmem_cache_alloc(NULL, gfp) has problems; but the percpu dstmem pages are definitely a problem, as they're used as temporary buffer for compressed pages before copying into place in the zpool. If the user does get zswap enabled after an init failure, then zswap will likely Oops on the first page it tries to compress (or worse, start corrupting memory). Fixes: 90b0fc26d5db ("zswap: change zpool/compressor at runtime") Link: http://lkml.kernel.org/r/20170124200259.16191-2-ddstreet@ieee.org Signed-off-by: Dan Streetman <dan.streetman@canonical.com> Reported-by: Marcin Miroslaw <marcin@mejor.pl> Cc: Seth Jennings <sjenning@redhat.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-01mm, memcg: do not retry precharge chargesDavid Rientjes
commit 3674534b775354516e5c148ea48f51d4d1909a78 upstream. When memory.move_charge_at_immigrate is enabled and precharges are depleted during move, mem_cgroup_move_charge_pte_range() will attempt to increase the size of the precharge. Prevent precharges from ever looping by setting __GFP_NORETRY. This was probably the intention of the GFP_KERNEL & ~__GFP_NORETRY, which is pointless as written. Fixes: 0029e19ebf84 ("mm: memcontrol: remove explicit OOM parameter in charge path") Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1701130208510.69402@chino.kir.corp.google.com Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-01mm/mempolicy.c: do not put mempolicy before using its nodemaskVlastimil Babka
commit d51e9894d27492783fc6d1b489070b4ba66ce969 upstream. Since commit be97a41b291e ("mm/mempolicy.c: merge alloc_hugepage_vma to alloc_pages_vma") alloc_pages_vma() can potentially free a mempolicy by mpol_cond_put() before accessing the embedded nodemask by __alloc_pages_nodemask(). The commit log says it's so "we can use a single exit path within the function" but that's clearly wrong. We can still do that when doing mpol_cond_put() after the allocation attempt. Make sure the mempolicy is not freed prematurely, otherwise __alloc_pages_nodemask() can end up using a bogus nodemask, which could lead e.g. to premature OOM. Fixes: be97a41b291e ("mm/mempolicy.c: merge alloc_hugepage_vma to alloc_pages_vma") Link: http://lkml.kernel.org/r/20170118141124.8345-1-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-19mm/hugetlb.c: fix reservation race when freeing surplus pagesMike Kravetz
commit e5bbc8a6c992901058bc09e2ce01d16c111ff047 upstream. return_unused_surplus_pages() decrements the global reservation count, and frees any unused surplus pages that were backing the reservation. Commit 7848a4bf51b3 ("mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()") added a call to cond_resched_lock in the loop freeing the pages. As a result, the hugetlb_lock could be dropped, and someone else could use the pages that will be freed in subsequent iterations of the loop. This could result in inconsistent global hugetlb page state, application api failures (such as mmap) failures or application crashes. When dropping the lock in return_unused_surplus_pages, make sure that the global reservation count (resv_huge_pages) remains sufficiently large to prevent someone else from claiming pages about to be freed. Analyzed by Paul Cassella. Fixes: 7848a4bf51b3 ("mm/hugetlb.c: add cond_resched_lock() in return_unused_surplus_pages()") Link: http://lkml.kernel.org/r/1483991767-6879-1-git-send-email-mike.kravetz@oracle.com Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Reported-by: Paul Cassella <cassella@cray.com> Suggested-by: Michal Hocko <mhocko@kernel.org> Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15mm/init: fix zone boundary creationOliver O'Halloran
commit 90cae1fe1c3540f791d5b8e025985fa5e699b2bb upstream. As a part of memory initialisation the architecture passes an array to free_area_init_nodes() which specifies the max PFN of each memory zone. This array is not necessarily monotonic (due to unused zones) so this array is parsed to build monotonic lists of the min and max PFN for each zone. ZONE_MOVABLE is special cased here as its limits are managed by the mm subsystem rather than the architecture. Unfortunately, this special casing is broken when ZONE_MOVABLE is the not the last zone in the zone list. The core of the issue is: if (i == ZONE_MOVABLE) continue; arch_zone_lowest_possible_pfn[i] = arch_zone_highest_possible_pfn[i-1]; As ZONE_MOVABLE is skipped the lowest_possible_pfn of the next zone will be set to zero. This patch fixes this bug by adding explicitly tracking where the next zone should start rather than relying on the contents arch_zone_highest_possible_pfn[]. Thie is low priority. To get bitten by this you need to enable a zone that appears after ZONE_MOVABLE in the zone_type enum. As far as I can tell this means running a kernel with ZONE_DEVICE or ZONE_CMA enabled, so I can't see this affecting too many people. I only noticed this because I've been fiddling with ZONE_DEVICE on powerpc and 4.6 broke my test kernel. This bug, in conjunction with the changes in Taku Izumi's kernelcore=mirror patch (d91749c1dda71) and powerpc being the odd architecture which initialises max_zone_pfn[] to ~0ul instead of 0 caused all of system memory to be placed into ZONE_DEVICE at boot, followed a panic since device memory cannot be used for kernel allocations. I've already submitted a patch to fix the powerpc specific bits, but I figured this should be fixed too. Link: http://lkml.kernel.org/r/1462435033-15601-1-git-send-email-oohall@gmail.com Signed-off-by: Oliver O'Halloran <oohall@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06mm/vmscan.c: set correct defer count for shrinkerShaohua Li
commit 5f33a0803bbd781de916f5c7448cbbbbc763d911 upstream. Our system uses significantly more slab memory with memcg enabled with the latest kernel. With 3.10 kernel, slab uses 2G memory, while with 4.6 kernel, 6G memory is used. The shrinker has problem. Let's see we have two memcg for one shrinker. In do_shrink_slab: 1. Check cg1. nr_deferred = 0, assume total_scan = 700. batch size is 1024, then no memory is freed. nr_deferred = 700 2. Check cg2. nr_deferred = 700. Assume freeable = 20, then total_scan = 10 or 40. Let's assume it's 10. No memory is freed. nr_deferred = 10. The deferred share of cg1 is lost in this case. kswapd will free no memory even run above steps again and again. The fix makes sure one memcg's deferred share isn't lost. Link: http://lkml.kernel.org/r/2414be961b5d25892060315fbb56bb19d81d0c07.1476227351.git.shli@fb.com Signed-off-by: Shaohua Li <shli@fb.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06mm: Add a user_ns owner to mm_struct and fix ptrace permission checksEric W. Biederman
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream. During exec dumpable is cleared if the file that is being executed is not readable by the user executing the file. A bug in ptrace_may_access allows reading the file if the executable happens to enter into a subordinate user namespace (aka clone(CLONE_NEWUSER), unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER). This problem is fixed with only necessary userspace breakage by adding a user namespace owner to mm_struct, captured at the time of exec, so it is clear in which user namespace CAP_SYS_PTRACE must be present in to be able to safely give read permission to the executable. The function ptrace_may_access is modified to verify that the ptracer has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns. This ensures that if the task changes it's cred into a subordinate user namespace it does not become ptraceable. The function ptrace_attach is modified to only set PT_PTRACE_CAP when CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of PT_PTRACE_CAP is to be a flag to note that whatever permission changes the task might go through the tracer has sufficient permissions for it not to be an issue. task->cred->user_ns is always the same as or descendent of mm->user_ns. Which guarantees that having CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks credentials. To prevent regressions mm->dumpable and mm->user_ns are not considered when a task has no mm. As simply failing ptrace_may_attach causes regressions in privileged applications attempting to read things such as /proc/<pid>/stat Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Cyrill Gorcunov <gorcunov@openvz.org> Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-08kasan: update kasan_global for gcc 7Dmitry Vyukov
commit 045d599a286bc01daa3510d59272440a17b23c2e upstream. kasan_global struct is part of compiler/runtime ABI. gcc revision 241983 has added a new field to kasan_global struct. Update kernel definition of kasan_global struct to include the new field. Without this patch KASAN is broken with gcc 7. Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Alexander Potapenko <glider@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18swapfile: fix memory corruption via malformed swapfileJann Horn
commit dd111be69114cc867f8e826284559bfbc1c40e37 upstream. When root activates a swap partition whose header has the wrong endianness, nr_badpages elements of badpages are swabbed before nr_badpages has been checked, leading to a buffer overrun of up to 8GB. This normally is not a security issue because it can only be exploited by root (more specifically, a process with CAP_SYS_ADMIN or the ability to modify a swap file/partition), and such a process can already e.g. modify swapped-out memory of any other userspace process on the system. Link: http://lkml.kernel.org/r/1477949533-2509-1-git-send-email-jann@thejh.net Signed-off-by: Jann Horn <jann@thejh.net> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Jerome Marchand <jmarchan@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mm/cma: silence warnings due to max() usageStephen Rothwell
commit badbda53e505089062e194c614e6f23450bc98b2 upstream. pageblock_order can be (at least) an unsigned int or an unsigned long depending on the kernel config and architecture, so use max_t(unsigned long, ...) when comparing it. fixes these warnings: In file included from include/asm-generic/bug.h:13:0, from arch/powerpc/include/asm/bug.h:127, from include/linux/bug.h:4, from include/linux/mmdebug.h:4, from include/linux/mm.h:8, from include/linux/memblock.h:18, from mm/cma.c:28: mm/cma.c: In function 'cma_init_reserved_mem': include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); ^ mm/cma.c:186:27: note: in expansion of macro 'max' alignment = PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order); ^ mm/cma.c: In function 'cma_declare_contiguous': include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); ^ include/linux/kernel.h:747:9: note: in definition of macro 'max' typeof(y) _max2 = (y); ^ mm/cma.c:270:29: note: in expansion of macro 'max' (phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order)); ^ include/linux/kernel.h:748:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); ^ include/linux/kernel.h:747:21: note: in definition of macro 'max' typeof(y) _max2 = (y); ^ mm/cma.c:270:29: note: in expansion of macro 'max' (phys_addr_t)PAGE_SIZE << max(MAX_ORDER - 1, pageblock_order)); ^ [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/20160526150748.5be38a4f@canb.auug.org.au Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mm: memcontrol: do not recurse in direct reclaimJohannes Weiner
commit 89a2848381b5fcd9c4d9c0cd97680e3b28730e31 upstream. On 4.0, we saw a stack corruption from a page fault entering direct memory cgroup reclaim, calling into btrfs_releasepage(), which then tried to allocate an extent and recursed back into a kmem charge ad nauseam: [...] btrfs_releasepage+0x2c/0x30 try_to_release_page+0x32/0x50 shrink_page_list+0x6da/0x7a0 shrink_inactive_list+0x1e5/0x510 shrink_lruvec+0x605/0x7f0 shrink_zone+0xee/0x320 do_try_to_free_pages+0x174/0x440 try_to_free_mem_cgroup_pages+0xa7/0x130 try_charge+0x17b/0x830 memcg_charge_kmem+0x40/0x80 new_slab+0x2d9/0x5a0 __slab_alloc+0x2fd/0x44f kmem_cache_alloc+0x193/0x1e0 alloc_extent_state+0x21/0xc0 __clear_extent_bit+0x2b5/0x400 try_release_extent_mapping+0x1a3/0x220 __btrfs_releasepage+0x31/0x70 btrfs_releasepage+0x2c/0x30 try_to_release_page+0x32/0x50 shrink_page_list+0x6da/0x7a0 shrink_inactive_list+0x1e5/0x510 shrink_lruvec+0x605/0x7f0 shrink_zone+0xee/0x320 do_try_to_free_pages+0x174/0x440 try_to_free_mem_cgroup_pages+0xa7/0x130 try_charge+0x17b/0x830 mem_cgroup_try_charge+0x65/0x1c0 handle_mm_fault+0x117f/0x1510 __do_page_fault+0x177/0x420 do_page_fault+0xc/0x10 page_fault+0x22/0x30 On later kernels, kmem charging is opt-in rather than opt-out, and that particular kmem allocation in btrfs_releasepage() is no longer being charged and won't recurse and overrun the stack anymore. But it's not impossible for an accounted allocation to happen from the memcg direct reclaim context, and we needed to reproduce this crash many times before we even got a useful stack trace out of it. Like other direct reclaimers, mark tasks in memcg reclaim PF_MEMALLOC to avoid recursing into any other form of direct reclaim. Then let recursive charges from PF_MEMALLOC contexts bypass the cgroup limit. Link: http://lkml.kernel.org/r/20161025141050.GA13019@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10mm/list_lru.c: avoid error-path NULL pointer derefAlexander Polakov
commit 1bc11d70b5db7c6bb1414b283d7f09b1fe1ac0d0 upstream. As described in https://bugzilla.kernel.org/show_bug.cgi?id=177821: After some analysis it seems to be that the problem is in alloc_super(). In case list_lru_init_memcg() fails it goes into destroy_super(), which calls list_lru_destroy(). And in list_lru_init() we see that in case memcg_init_list_lru() fails, lru->node is freed, but not set NULL, which then leads list_lru_destroy() to believe it is initialized and call memcg_destroy_list_lru(). memcg_destroy_list_lru() in turn can access lru->node[i].memcg_lrus, which is NULL. [akpm@linux-foundation.org: add comment] Signed-off-by: Alexander Polakov <apolyakov@beget.ru> Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31mm/hugetlb: fix memory offline with hugepage size > memory block sizeGerald Schaefer
commit 2247bb335ab9c40058484cac36ea74ee652f3b7b upstream. Patch series "mm/hugetlb: memory offline issues with hugepages", v4. This addresses several issues with hugepages and memory offline. While the first patch fixes a panic, and is therefore rather important, the last patch is just a performance optimization. The second patch fixes a theoretical issue with reserved hugepages, while still leaving some ugly usability issue, see description. This patch (of 3): dissolve_free_huge_pages() will either run into the VM_BUG_ON() or a list corruption and addressing exception when trying to set a memory block offline that is part (but not the first part) of a "gigantic" hugetlb page with a size > memory block size. When no other smaller hugetlb page sizes are present, the VM_BUG_ON() will trigger directly. In the other case we will run into an addressing exception later, because dissolve_free_huge_page() will not work on the head page of the compound hugetlb page which will result in a NULL hstate from page_hstate(). To fix this, first remove the VM_BUG_ON() because it is wrong, and then use the compound head page in dissolve_free_huge_page(). This means that an unused pre-allocated gigantic page that has any part of itself inside the memory block that is going offline will be dissolved completely. Losing an unused gigantic hugepage is preferable to failing the memory offline, for example in the situation where a (possibly faulty) memory DIMM needs to go offline. Changes for v4.4 stable: - make it apply w/o commit c1470b33 "mm/hugetlb: fix incorrect hugepages count during mem hotplug" Fixes: c8721bbb ("mm: memory-hotplug: enable memory hotplug to handle hugepage") Link: http://lkml.kernel.org/r/20160926172811.94033-2-gerald.schaefer@de.ibm.com Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Rui Teng <rui.teng@linux.vnet.ibm.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
