path: root/mm
2010-08-26slab: fix object alignmentCarsten Otte
commit 1ab335d8f85792e3b107ff8237d53cf64db714df upstream. This patch fixes alignment of slab objects in case CONFIG_DEBUG_PAGEALLOC is active. Before this spot in kmem_cache_create, we have this situation: - align contains the required alignment of the object - cachep->obj_offset is 0 or equals align in case of CONFIG_DEBUG_SLAB - size equals the size of the object, or object plus trailing redzone in case of CONFIG_DEBUG_SLAB This spot tries to fill one page per object if the object is in certain size limits, however setting obj_offset to PAGE_SIZE - size does break the object alignment since size may not be aligned with the required alignment. This patch simply adds an ALIGN(size, align) to the equation and fixes the object size detection accordingly. This code in drivers/s390/cio/qdio_setup_init has lead to incorrectly aligned slab objects (sizeof(struct qdio_q) equals 1792): qdio_q_cache = kmem_cache_create("qdio_q", sizeof(struct qdio_q), 256, 0, NULL); Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make stack guard page logic use vm_prev pointerLinus Torvalds
commit 0e8e50e20c837eeec8323bba7dcd25fe5479194c upstream. Like the mlock() change previously, this makes the stack guard check code use vma->vm_prev to see what the mapping below the current stack is, rather than have to look it up with find_vma(). Also, accept an abutting stack segment, since that happens naturally if you split the stack with mlock or mprotect. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make the mlock() stack guard page checks stricterLinus Torvalds
commit 7798330ac8114c731cfab83e634c6ecedaa233d7 upstream. If we've split the stack vma, only the lowest one has the guard page. Now that we have a doubly linked list of vma's, checking this is trivial. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-26mm: make the vma list be doubly linkedLinus Torvalds
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream. It's a really simple list, and several of the users want to go backwards in it to find the previous vma. So rather than have to look up the previous entry with 'find_vma_prev()' or something similar, just make it doubly linked instead. Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-20mm: fix up some user-visible effects of the stack guard pageLinus Torvalds
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream. This commit makes the stack guard page somewhat less visible to user space. It does this by: - not showing the guard page in /proc/<pid>/maps It looks like lvm-tools will actually read /proc/self/maps to figure out where all its mappings are, and effectively do a specialized "mlockall()" in user space. By not showing the guard page as part of the mapping (by just adding PAGE_SIZE to the start for grows-up pages), lvm-tools ends up not being aware of it. - by also teaching the _real_ mlock() functionality not to try to lock the guard page. That would just expand the mapping down to create a new guard page, so there really is no point in trying to lock it in place. It would perhaps be nice to show the guard page specially in /proc/<pid>/maps (or at least mark grow-down segments some way), but let's not open ourselves up to more breakage by user space from programs that depends on the exact deails of the 'maps' file. Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools source code to see what was going on with the whole new warning. Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-20mm: fix page table unmap for stack guard page properlyLinus Torvalds
commit 11ac552477e32835cb6970bf0a70c210807f5673 upstream. We do in fact need to unmap the page table _before_ doing the whole stack guard page logic, because if it is needed (mainly 32-bit x86 with PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it will do a kmap_atomic/kunmap_atomic. And those kmaps will create an atomic region that we cannot do allocations in. However, the whole stack expand code will need to do anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an atomic region. Now, a better model might actually be to do the anon_vma_prepare() when _creating_ a VM_GROWSDOWN segment, and not have to worry about any of this at page fault time. But in the meantime, this is the straightforward fix for the issue. See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details. Reported-by: Wylda <wylda@volny.cz> Reported-by: Sedat Dilek <sedat.dilek@gmail.com> Reported-by: Mike Pagano <mpagano@gentoo.org> Reported-by: François Valenduc <francois.valenduc@tvcablenet.be> Tested-by: Ed Tomlinson <edt@aei.ca> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: fix missing page table unmap for stack guard page failure caseLinus Torvalds
commit 5528f9132cf65d4d892bcbc5684c61e7822b21e9 upstream. .. which didn't show up in my tests because it's a no-op on x86-64 and most other architectures. But we enter the function with the last-level page table mapped, and should unmap it at exit. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: keep a guard page below a grow-down stack segmentLinus Torvalds
commit 320b2b8de12698082609ebbc1a17165727f4c893 upstream. This is a rather minimally invasive patch to solve the problem of the user stack growing into a memory mapped area below it. Whenever we fill the first page of the stack segment, expand the segment down by one page. Now, admittedly some odd application might _want_ the stack to grow down into the preceding memory mapping, and so we may at some point need to make this a process tunable (some people might also want to have more than a single page of guarding), but let's try the minimal approach first. Tested with trivial application that maps a single page just below the stack, and then starts recursing. Without this, we will get a SIGSEGV _after_ the stack has smashed the mapping. With this patch, we'll get a nice SIGBUS just as the stack touches the page just above the mapping. Requested-by: Keith Packard <keithp@keithp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-13mm: fix corruption of hibernation caused by reusing swap during image savingKAMEZAWA Hiroyuki
commit 966cca029f739716fbcc8068b8c6dfe381f86fc3 upstream. Since 2.6.31, swap_map[]'s refcounting was changed to show that a used swap entry is just for swap-cache, can be reused. Then, while scanning free entry in swap_map[], a swap entry may be able to be reclaimed and reused. It was caused by commit c9e444103b5e7a5 ("mm: reuse unused swap entry if necessary"). But this caused deta corruption at resume. The scenario is - Assume a clean-swap cache, but mapped. - at hibernation_snapshot[], clean-swap-cache is saved as clean-swap-cache and swap_map[] is marked as SWAP_HAS_CACHE. - then, save_image() is called. And reuse SWAP_HAS_CACHE entry to save image, and break the contents. After resume: - the memory reclaim runs and finds clean-not-referenced-swap-cache and discards it because it's marked as clean. But here, the contents on disk and swap-cache is inconsistent. Hance memory is corrupted. This patch avoids the bug by not reclaiming swap-entry during hibernation. This is a quick fix for backporting. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Ondreg Zary <linux@rainbow-software.org> Tested-by: Ondreg Zary <linux@rainbow-software.org> Tested-by: Andrea Gelmini <andrea.gelmini@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-30mm: fix ia64 crash when gcore reads gate areaHugh Dickins
Debian's ia64 autobuilders have been seeing kernel freeze or reboot when running the gdb testsuite (Debian bug 588574): dannf bisected to 2.6.32 62eede62dafb4a6633eae7ffbeb34c60dba5e7b1 "mm: ZERO_PAGE without PTE_SPECIAL"; and reproduced it with gdb's gcore on a simple target. I'd missed updating the gate_vma handling in __get_user_pages(): that happens to use vm_normal_page() (nowadays failing on the zero page), yet reported success even when it failed to get a page - boom when access_process_vm() tried to copy that to its intermediate buffer. Fix this, resisting cleanups: in particular, leave it for now reporting success when not asked to get any pages - very probably safe to change, but let's not risk it without testing exposure. Why did ia64 crash with 16kB pages, but succeed with 64kB pages? Because setup_gate() pads each 64kB of its gate area with zero pages. Reported-by: Andreas Barth <aba@not.so.argh.org> Bisected-by: dann frazier <dannf@debian.org> Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: dann frazier <dannf@dannf.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-20x86,nobootmem: make alloc_bootmem_node fall back to other node when 32bit ↵Yinghai Lu
numa is used Borislav Petkov reported his 32bit numa system has problem: [ 0.000000] Reserving total of 4c00 pages for numa KVA remap [ 0.000000] kva_start_pfn ~ 32800 max_low_pfn ~ 375fe [ 0.000000] max_pfn = 238000 [ 0.000000] 8202MB HIGHMEM available. [ 0.000000] 885MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 375fe000 [ 0.000000] low ram: 0 - 375fe000 [ 0.000000] alloc (nid=8 100000 - 7ee00000) (1000000 - ffffffff) 1000 1000 => 34e7000 [ 0.000000] alloc (nid=8 100000 - 7ee00000) (1000000 - ffffffff) 200 40 => 34c9d80 [ 0.000000] alloc (nid=0 100000 - 7ee00000) (1000000 - ffffffffffffffff) 180 40 => 34e6140 [ 0.000000] alloc (nid=1 80000000 - c7e60000) (1000000 - ffffffffffffffff) 240 40 => 80000000 [ 0.000000] BUG: unable to handle kernel paging request at 40000000 [ 0.000000] IP: [<c2c8cff1>] __alloc_memory_core_early+0x147/0x1d6 [ 0.000000] *pdpt = 0000000000000000 *pde = f000ff53f000ff00 ... [ 0.000000] Call Trace: [ 0.000000] [<c2c8b4f8>] ? __alloc_bootmem_node+0x216/0x22f [ 0.000000] [<c2c90c9b>] ? sparse_early_usemaps_alloc_node+0x5a/0x10b [ 0.000000] [<c2c9149e>] ? sparse_init+0x1dc/0x499 [ 0.000000] [<c2c79118>] ? paging_init+0x168/0x1df [ 0.000000] [<c2c780ff>] ? native_pagetable_setup_start+0xef/0x1bb looks like it allocates too much high address for bootmem. Try to cut limit with get_max_mapped() Reported-by: Borislav Petkov <borislav.petkov@amd.com> Tested-by: Conny Seidel <conny.seidel@amd.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: <stable@kernel.org> [2.6.34.x] Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-20mm/vmscan.c: fix mapping use after freeNick Piggin
We need lock_page_nosync() here because we have no reference to the mapping when taking the page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-19mm: add context argument to shrinker callbackDave Chinner
The current shrinker implementation requires the registered callback to have global state to work from. This makes it difficult to shrink caches that are not global (e.g. per-filesystem caches). Pass the shrinker structure to the callback so that users can embed the shrinker structure in the context the shrinker needs to operate on and get back to it in the callback via container_of(). Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-07-19Merge branch 'kmemleak' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm * 'kmemleak' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm: kmemleak: Add support for NO_BOOTMEM configurations kmemleak: Annotate false positive in init_section_page_cgroup()
2010-07-19kmemleak: Add support for NO_BOOTMEM configurationsCatalin Marinas
With commits 08677214 and 59be5a8e, alloc_bootmem()/free_bootmem() and friends use the early_res functions for memory management when NO_BOOTMEM is enabled. This patch adds the kmemleak calls in the corresponding code paths for bootmem allocations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org
2010-07-19kmemleak: Annotate false positive in init_section_page_cgroup()Catalin Marinas
The pointer to the page_cgroup table allocated in init_section_page_cgroup() is stored in section->page_cgroup as (base - pfn). Since this value does not point to the beginning or inside the allocated memory block, kmemleak reports a false positive. This was reported in bugzilla.kernel.org as #16297. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Adrien Dessemond <adrien.dessemond@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-08Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: writeback: simplify the write back thread queue writeback: split writeback_inodes_wb writeback: remove writeback_inodes_wbc fs-writeback: fix kernel-doc warnings splice: check f_mode for seekable file splice: direct_splice_actor() should not use pos in sd
2010-07-06writeback: simplify the write back thread queueChristoph Hellwig
First remove items from work_list as soon as we start working on them. This means we don't have to track any pending or visited state and can get rid of all the RCU magic freeing the work items - we can simply free them once the operation has finished. Second use a real completion for tracking synchronous requests - if the caller sets the completion pointer we complete it, otherwise use it as a boolean indicator that we can free the work item directly. Third unify struct wb_writeback_args and struct bdi_work into a single data structure, wb_writeback_work. Previous we set all parameters into a struct wb_writeback_args, copied it into struct bdi_work, copied it again on the stack to use it there. Instead of just allocate one structure dynamically or on the stack and use it all the way through the stack. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-07-06writeback: remove writeback_inodes_wbcChristoph Hellwig
This was just an odd wrapper around writeback_inodes_wb. Removing this also allows to get rid of the bdi member of struct writeback_control which was rather out of place there. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-29mempolicy: fix dangling reference to tmpfs superblock mpolLee Schermerhorn
My patch to "Factor out duplicate put/frees in mpol_shared_policy_init() to a common return path"; and Dan Carpenter's fix thereto both left a dangling reference to the incoming tmpfs superblock mempolicy structure. A similar leak was introduced earlier when the nodemask was moved offstack to the scratch area despite the note in the comment block regarding the incoming ref. Move the remaining 'put of the incoming "mpol" to the common exit path to drop the reference. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Dan Carpenter <error27@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29memcg: fix wake up in oom wait queueKAMEZAWA Hiroyuki
OOM-waitqueue should be waken up when oom_disable is canceled. This is a fix for 3c11ecf448eff8f1 ("memcg: oom kill disable and oom status"). How to test: Create a cgroup A... 1. set memory.limit and memory.memsw.limit to be small value 2. echo 1 > /cgroup/A/memory.oom_control, this disables oom-kill. 3. run a program which must cause OOM. A program executed in 3 will sleep by oom_waiqueue in memcg. Then, how to wake it up is problem. 1. echo 0 > /cgroup/A/memory.oom_control (enable OOM-killer) 2. echo big mem > /cgroup/A/memory.memsw.limit_in_bytes(allow more swap) etc.. Without the patch, a task in slept can not be waken up. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Don't count_vm_events for discard bio in submit_bio. cfq: fix recursive call in cfq_blkiocg_update_completion_stats() cfq-iosched: Fixed boot warning with BLK_CGROUP=y and CFQ_GROUP_IOSCHED=n cfq: Don't allow queue merges for queues that have no process references block: fix DISCARD_BARRIER requests cciss: set SCSI max cmd len to 16, as default is wrong cpqarray: fix two more wrong section type cpqarray: fix wrong __init type on pci probe function drbd: Fixed a race between disk-attach and unexpected state changes writeback: fix pin_sb_for_writeback writeback: add missing requeue_io in writeback_inodes_wb writeback: simplify and split bdi_start_writeback writeback: simplify wakeup_flusher_threads writeback: fix writeback_inodes_wb from writeback_inodes_sb writeback: enforce s_umount locking in writeback_inodes_sb writeback: queue work on stack in writeback_inodes_sb writeback: fix writeback completion notifications
2010-06-18percpu: fix first chunk match in per_cpu_ptr_to_phys()Tejun Heo
per_cpu_ptr_to_phys() determines whether the passed in @addr belongs to the first_chunk or not by just matching the address against the address range of the base unit (unit0, used by cpu0). When an adress from another cpu was passed in, it will always determine that the address doesn't belong to the first chunk even when it does. This makes the function return a bogus physical address which may lead to crash. This problem was discovered by Cliff Wickman while investigating a crash during kdump on a SGI UV system. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Cliff Wickman <cpw@sgi.com> Tested-by: Cliff Wickman <cpw@sgi.com> Cc: stable@kernel.org
2010-06-17percpu: fix trivial bugs in pcpu_build_alloc_info()Pavel V. Panteleev
Fix the following two trivial bugs in pcpu_build_alloc_info() * we should memset group_cnt to 0 by size of group_cnt, not size of group_map (both are of the same size, so the bug isn't dangerous) * we can delete useless variable group_cnt_max. Signed-off-by: Pavel V. Panteleev <pp_84@mail.ru> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-06-11writeback: simplify and split bdi_start_writebackChristoph Hellwig
bdi_start_writeback now never gets a superblock passed, so we can just remove that case. And to further untangle the code and flatten the call stack split it into two trivial helpers for it's two callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-08writeback: limit write_cache_pages integrity scanning to current EOFDave Chinner
sync can currently take a really long time if a concurrent writer is extending a file. The problem is that the dirty pages on the address space grow in the same direction as write_cache_pages scans, so if the writer keeps ahead of writeback, the writeback will not terminate until the writer stops adding dirty pages. For a data integrity sync, we only need to write the pages dirty at the time we start the writeback, so we can stop scanning once we get to the page that was at the end of the file at the time the scan started. This will prevent operations like copying a large file preventing sync from completing as it will not write back pages that were dirtied after the sync was started. This does not impact the existing integrity guarantees, as any dirty page (old or new) within the EOF range at the start of the scan will still be captured. This patch will not prevent sync from blocking on large writes into holes. That requires more complex intervention while this patch only addresses the common append-case of this sync holdoff. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-08writeback: pay attention to wbc->nr_to_write in write_cache_pagesDave Chinner
If a filesystem writes more than one page in ->writepage, write_cache_pages fails to notice this and continues to attempt writeback when wbc->nr_to_write has gone negative - this trace was captured from XFS: wbc_writeback_start: towrt=1024 wbc_writepage: towrt=1024 wbc_writepage: towrt=0 wbc_writepage: towrt=-1 wbc_writepage: towrt=-5 wbc_writepage: towrt=-21 wbc_writepage: towrt=-85 This has adverse effects on filesystem writeback behaviour. write_cache_pages() needs to terminate after a certain number of pages are written, not after a certain number of calls to ->writepage are made. This is a regression introduced by 17bc6c30cf6bfffd816bdc53682dd46fc34a2cf4 ("vfs: Add no_nrwrite_index_update writeback control flag"), but cannot be reverted directly due to subsequent bug fixes that have gone in on top of it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Minix: Clean up left over label fix truncate inode time modification breakage fix setattr error handling in sysfs, configfs fcntl: return -EFAULT if copy_to_user fails wrong type for 'magic' argument in simple_fill_super() fix the deadlock in qib_fs mqueue doesn't need make_bad_inode()
2010-06-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (27 commits) block: make blk_init_free_list and elevator_init idempotent block: avoid unconditionally freeing previously allocated request_queue pipe: change /proc/sys/fs/pipe-max-pages to byte sized interface pipe: change the privilege required for growing a pipe beyond system max pipe: adjust minimum pipe size to 1 page block: disable preemption before using sched_clock() cciss: call BUG() earlier Preparing 8.3.8rc2 drbd: Reduce verbosity drbd: use drbd specific ratelimit instead of global printk_ratelimit drbd: fix hang on local read errors while disconnected drbd: Removed the now empty w_io_error() function drbd: removed duplicated #includes drbd: improve usage of MSG_MORE drbd: need to set socket bufsize early to take effect drbd: improve network latency, TCP_QUICKACK drbd: Revert "drbd: Create new current UUID as late as possible" brd: support discard Revert "writeback: fix WB_SYNC_NONE writeback from umount" Revert "writeback: ensure that WB_SYNC_NONE writeback with sb pinned is sync" ...
2010-06-04vmscan: fix do_try_to_free_pages() return value when priority==0 reclaim failureKOSAKI Motohiro
Greg Thelen reported recent Johannes's stack diet patch makes kernel hang. His test is following. mount -t cgroup none /cgroups -o memory mkdir /cgroups/cg1 echo $$ > /cgroups/cg1/tasks dd bs=1024 count=1024 if=/dev/null of=/data/foo echo $$ > /cgroups/tasks echo 1 > /cgroups/cg1/memory.force_empty Actually, This OOM hard to try logic have been corrupted since following two years old patch. commit a41f24ea9fd6169b147c53c2392e2887cc1d9247 Author: Nishanth Aravamudan <nacc@us.ibm.com> Date: Tue Apr 29 00:58:25 2008 -0700 page allocator: smarter retry of costly-order allocations Original intention was "return success if the system have shrinkable zones though priority==0 reclaim was failure". But the above patch changed to "return nr_reclaimed if .....". Oh, That forgot nr_reclaimed may be 0 if priority==0 reclaim failure. And Johannes's patch 0aeb2339e54e ("vmscan: remove all_unreclaimable scan control") made it more corrupt. Originally, priority==0 reclaim failure on memcg return 0, but this patch changed to return 1. It totally confused memcg. This patch fixes it completely. Reported-by: Greg Thelen <gthelen@google.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Greg Thelen <gthelen@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04fix truncate inode time modification breakageNick Piggin
mtime and ctime should be changed only if the file size has actually changed. Patches changing ext2 and tmpfs from vmtruncate to new truncate sequence has caused regressions where they always update timestamps. There is some strange cases in POSIX where truncate(2) must not update times unless the size has acutally changed, see 6e656be89. This area is all still rather buggy in different ways in a lot of filesystems and needs a cleanup and audit (ideally the vfs will provide a simple attribute or call to direct all filesystems exactly which attributes to change). But coming up with the best solution will take a while and is not appropriate for rc anyway. So fix recent regression for now. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-01Merge branch 'master' into for-linusJens Axboe
Conflicts: fs/pipe.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-06-01Revert "writeback: fix WB_SYNC_NONE writeback from umount"Jens Axboe
This reverts commit e913fc825dc685a444cb4c1d0f9d32f372f59861. We are investigating a hang associated with the WB_SYNC_NONE changes, so revert them for now. Conflicts: fs/fs-writeback.c mm/page-writeback.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-30Merge branch 'slub/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slub/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLUB: Allow full duplication of kmalloc array for 390 slub: move kmem_cache_node into it's own cacheline
2010-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: mm: export generic_pipe_buf_*() to modules fuse: support splice() reading from fuse device fuse: allow splice to move pages mm: export remove_from_page_cache() to modules mm: export lru_cache_add_*() to modules fuse: support splice() writing to fuse device fuse: get page reference for readpages fuse: use get_user_pages_fast() fuse: remove unneeded variable
2010-05-27tmpfs: convert to use the new truncate conventionnpiggin@suse.de
Cc: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (27 commits) Btrfs: add more error checking to btrfs_dirty_inode Btrfs: allow unaligned DIO Btrfs: drop verbose enospc printk Btrfs: Fix block generation verification race Btrfs: fix preallocation and nodatacow checks in O_DIRECT Btrfs: avoid ENOSPC errors in btrfs_dirty_inode Btrfs: move O_DIRECT space reservation to btrfs_direct_IO Btrfs: rework O_DIRECT enospc handling Btrfs: use async helpers for DIO write checksumming Btrfs: don't walk around with task->state != TASK_RUNNING Btrfs: do aio_write instead of write Btrfs: add basic DIO read/write support direct-io: do not merge logically non-contiguous requests direct-io: add a hook for the fs to provide its own submit_bio function fs: allow short direct-io reads to be completed via buffered IO Btrfs: Metadata ENOSPC handling for balance Btrfs: Pre-allocate space for data relocation Btrfs: Metadata ENOSPC handling for tree log Btrfs: Metadata reservation for orphan inodes Btrfs: Introduce global metadata reservation ...
2010-05-27numa: slab: use numa_mem_id() for slab local memory nodeLee Schermerhorn
Example usage of generic "numa_mem_id()": The mainline slab code, since ~ 2.6.19, does not handle memoryless nodes well. Specifically, the "fast path"--____cache_alloc()--will never succeed as slab doesn't cache offnode object on the per cpu queues, and for memoryless nodes, all memory will be "off node" relative to numa_node_id(). This adds significant overhead to all kmem cache allocations, incurring a significant regression relative to earlier kernels [from before slab.c was reorganized]. This patch uses the generic topology function "numa_mem_id()" to return the "effective local memory node" for the calling context. This is the first node in the local node's generic fallback zonelist-- the same node that "local" mempolicy-based allocations would use. This lets slab cache these "local" allocations and avoid fallback/refill on every allocation. N.B.: Slab will need to handle node and memory hotplug events that could change the value returned by numa_mem_id() for any given node if recent changes to address memory hotplug don't already address this. E.g., flush all per cpu slab queues before rebuilding the zonelists while the "machine" is held in the stopped state. Performance impact on "hackbench 400 process 200" 2.6.34-rc3-mmotm-100405-1609 no-patch this-patch ia64 no memoryless nodes [avg of 10]: 11.713 11.637 ~0.65 diff ia64 cpus all on memless nodes [10]: 228.259 26.484 ~8.6x speedup The slowdown of the patched kernel from ~12 sec to ~28 seconds when configured with memoryless nodes is the result of all cpus allocating from a single node's mm pagepool. The cache lines of the single node are distributed/interleaved over the memory of the real physical nodes, but the zone lock, list heads, ... of the single node with memory still each live in a single cache line that is accessed from all processors. x86_64 [8x6 AMD] [avg of 40]: 2.883 2.845 Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27numa: introduce numa_mem_id()- effective local memory node idLee Schermerhorn
Introduce numa_mem_id(), based on generic percpu variable infrastructure to track "nearest node with memory" for archs that support memoryless nodes. Define API in <linux/topology.h> when CONFIG_HAVE_MEMORYLESS_NODES defined, else stubs. Architectures will define HAVE_MEMORYLESS_NODES if/when they support them. Archs can override definitions of: numa_mem_id() - returns node number of "local memory" node set_numa_mem() - initialize [this cpus'] per cpu variable 'numa_mem' cpu_to_mem() - return numa_mem for specified cpu; may be used as lvalue Generic initialization of 'numa_mem' occurs in __build_all_zonelists(). This will initialize the boot cpu at boot time, and all cpus on change of numa_zonelist_order, or when node or memory hot-plug requires zonelist rebuild. Archs that support memoryless nodes will need to initialize 'numa_mem' for secondary cpus as they're brought on-line. [akpm@linux-foundation.org: fix build] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27numa: add generic percpu var numa_node_id() implementationLee Schermerhorn
Rework the generic version of the numa_node_id() function to use the new generic percpu variable infrastructure. Guard the new implementation with a new config option: CONFIG_USE_PERCPU_NUMA_NODE_ID. Archs which support this new implemention will default this option to 'y' when NUMA is configured. This config option could be removed if/when all archs switch over to the generic percpu implementation of numa_node_id(). Arch support involves: 1) converting any existing per cpu variable implementations to use this implementation. x86_64 is an instance of such an arch. 2) archs that don't use a per cpu variable for numa_node_id() will need to initialize the new per cpu variable "numa_node" as cpus are brought on-line. ia64 is an example. 3) Defining USE_PERCPU_NUMA_NODE_ID in arch dependent Kconfig--e.g., when NUMA is configured. This is required because I have retained the old implementation by default to allow archs to be modified incrementally, as desired. Subsequent patches will convert x86_64 and ia64 to use this implemenation. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27slab: convert cpu notifier to return encapsulate errno valueAkinobu Mita
By the previous modification, the cpu notifier can return encapsulate errno value. This converts the cpu notifiers for slab. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cpusets: new round-robin rotor for SLAB allocationsJack Steiner
We have observed several workloads running on multi-node systems where memory is assigned unevenly across the nodes in the system. There are numerous reasons for this but one is the round-robin rotor in cpuset_mem_spread_node(). For example, a simple test that writes a multi-page file will allocate pages on nodes 0 2 4 6 ... Odd nodes are skipped. (Sometimes it allocates on odd nodes & skips even nodes). An example is shown below. The program "lfile" writes a file consisting of 10 pages. The program then mmaps the file & uses get_mempolicy(..., MPOL_F_NODE) to determine the nodes where the file pages were allocated. The output is shown below: # ./lfile allocated on nodes: 2 4 6 0 1 2 6 0 2 There is a single rotor that is used for allocating both file pages & slab pages. Writing the file allocates both a data page & a slab page (buffer_head). This advances the RR rotor 2 nodes for each page allocated. A quick confirmation seems to confirm this is the cause of the uneven allocation: # echo 0 >/dev/cpuset/memory_spread_slab # ./lfile allocated on nodes: 6 7 8 9 0 1 2 3 4 5 This patch introduces a second rotor that is used for slab allocations. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: clean up memory thresholdsKirill A. Shutemov
Introduce struct mem_cgroup_thresholds. It helps to reduce number of checks of thresholds type (memory or mem+swap). [akpm@linux-foundation.org: repair comment] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27cgroups: make cftype.unregister_event() void-returningKirill A. Shutemov
Since we are unable to handle an error returned by cftype.unregister_event() properly, let's make the callback void-returning. mem_cgroup_unregister_event() has been rewritten to be a "never fail" function. On mem_cgroup_usage_register_event() we save old buffer for thresholds array and reuse it in mem_cgroup_usage_unregister_event() to avoid allocation. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27memcg: fix mis-accounting of file mapped racy with migrationakpm@linux-foundation.org
FILE_MAPPED per memcg of migrated file cache is not properly updated, because our hook in page_add_file_rmap() can't know to which memcg FILE_MAPPED should be counted. Basically, this patch is for fixing the bug but includes some big changes to fix up other messes. Now, at migrating mapped file, events happen in following sequence. 1. allocate a new page. 2. get memcg of an old page. 3. charge ageinst a new page before migration. But at this point, no changes to new page's page_cgroup, no commit for the charge. (IOW, PCG_USED bit is not set.) 4. page migration replaces radix-tree, old-page and new-page. 5. page migration remaps the new page if the old page was mapped. 6. Here, the new page is unlocked. 7. memcg commits the charge for newpage, Mark the new page's page_cgroup as PCG_USED. Because "commit" happens after page-remap, we can count FILE_MAPPED at "5", because we should avoid to trust page_cgroup->mem_cgroup. if PCG_USED bit is unset. (Note: memcg's LRU removal code does that but LRU-isolation logic is used for helping it. When we overwrite page_cgroup->mem_cgroup, page_cgroup is not on LRU or page_cgroup->mem_cgroup is NULL.) We can lose file_mapped accounting information at 5 because FILE_MAPPED is updated only when mapcount changes 0->1. So we should catch it. BTW, historically, above implemntation comes from migration-failure of anonymous page. Because we charge both of old page and new page with mapcount=0, we can't catch - the page is really freed before remap. - migration fails but it's freed before remap or .....corner cases. New migration sequence with memcg is: 1. allocate a new page. 2. mark PageCgroupMigration to the old page. 3. charge against a new page onto the old page's memcg. (here, new page's pc is marked as PageCgroupUsed.) 4. page migration replaces radix-tree, page table, etc... 5. At remapping, new page's page_cgroup is now makrked as "USED" We can catch 0->1 event and FILE_MAPPED will be properly updated. And we can catch SWAPOUT event after unlock this and freeing this page by unmap() can be caught. 7. Clear PageCgroupMigration of the old page. So, FILE_MAPPED will be correctly updated. Then, for what MIGRATION flag is ? Without it, at migration failure, we may have to charge old page again because it may be fully unmapped. "charge" means that we have to dive into memory reclaim or something complated. So, it's better to avoid charge it again. Before this patch, __commit_charge() was working for both of the old/new page and fixed up all. But this technique has some racy condtion around FILE_MAPPED and SWAPOUT etc... Now, the kernel use MIGRATION flag and don't uncharge old page until the end of migration. I hope this change will make memcg's page migration much simpler. This page migration has caused several troubles. Worth to add a flag for simplification. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mm: memcontrol - uninitialised return valuePhil Carmody
Only an out of memory error will cause ret to be set. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mm: remove unnecessary use of atomicPhil Carmody
The bottom 4 hunks are atomically changing memory to which there are no aliases as it's freshly allocated, so there's no need to use atomic operations. The other hunks are just atomic_read and atomic_set, and do not involve any read-modify-write. The use of atomic_{read,set} doesn't prevent a read/write or write/write race, so if a race were possible (I'm not saying one is), then it would still be there even with atomic_set. See: http://digitalvampire.org/blog/index.php/2007/05/13/atomic-cargo-cults/ Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Acked-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
