commit a58f2cef26e1ca44182c8b22f4f4395e702a5795 upstream.
There was the below bug report from Wu Fangsuo.
On the CMA allocation path, isolate_migratepages_range() could isolate
unevictable LRU pages and reclaim_clean_page_from_list() can try to
reclaim them if they are clean file-backed pages.
page:ffffffbf02f33b40 count:86 mapcount:84 mapping:ffffffc08fa7a810 index:0x24
flags: 0x19040c(referenced|uptodate|arch_1|mappedtodisk|unevictable|mlocked)
raw: 000000000019040c ffffffc08fa7a810 0000000000000024 0000005600000053
raw: ffffffc009b05b20 ffffffc009b05b20 0000000000000000 ffffffc09bf3ee80
page dumped because: VM_BUG_ON_PAGE(PageLRU(page) || PageUnevictable(page))
page->mem_cgroup:ffffffc09bf3ee80
kernel BUG at /home/build/farmland/adroid9.0/kernel/linux/mm/vmscan.c:1350!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 7125 Comm: syz-executor Tainted: G S 4.14.81 #3
Hardware name: ASR AQUILAC EVB (DT)
task: ffffffc00a54cd00 task.stack: ffffffc009b00000
PC is at shrink_page_list+0x1998/0x3240
LR is at shrink_page_list+0x1998/0x3240
pc : [<ffffff90083a2158>] lr : [<ffffff90083a2158>] pstate: 60400045
sp : ffffffc009b05940
reclaim_clean_pages_from_list+0x3c0/0x4f0
alloc_contig_range+0x3bc/0x650
cma_alloc+0x214/0x668
ion_cma_allocate+0x98/0x1d8
ion_alloc+0x200/0x7e0
ion_ioctl+0x18c/0x378
do_vfs_ioctl+0x17c/0x1780
SyS_ioctl+0xac/0xc0
Wu found it's due to commit ad6b67041a45 ("mm: remove SWAP_MLOCK in
ttu"). Before that, unevictable pages go to cull_mlocked so that we
can't reach the VM_BUG_ON_PAGE line.
To fix the issue, this patch filters out unevictable LRU pages from the
reclaim_clean_pages_from_list in CMA.
Link: http://lkml.kernel.org/r/20190524071114.74202-1-minchan@kernel.org
Fixes: ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu")
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reported-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Debugged-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Tested-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Pankaj Suryawanshi <pankaj.suryawanshi@einfochips.com>
Cc: <stable@vger.kernel.org> [4.12+]
commit 3510955b327176fd4cbab5baa75b449f077722a2 upstream.
Syzbot reported following memory leak:
ffffffffda RBX: 0000000000000003 RCX: 0000000000441f79
BUG: memory leak
unreferenced object 0xffff888114f26040 (size 32):
comm "syz-executor626", pid 7056, jiffies 4294948701 (age 39.410s)
hex dump (first 32 bytes):
40 60 f2 14 81 88 ff ff 40 60 f2 14 81 88 ff ff @`......@`......
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
slab_post_alloc_hook mm/slab.h:439 [inline]
slab_alloc mm/slab.c:3326 [inline]
kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553
kmalloc include/linux/slab.h:547 [inline]
__memcg_init_list_lru_node+0x58/0xf0 mm/list_lru.c:352
memcg_init_list_lru_node mm/list_lru.c:375 [inline]
memcg_init_list_lru mm/list_lru.c:459 [inline]
__list_lru_init+0x193/0x2a0 mm/list_lru.c:626
alloc_super+0x2e0/0x310 fs/super.c:269
sget_userns+0x94/0x2a0 fs/super.c:609
sget+0x8d/0xb0 fs/super.c:660
mount_nodev+0x31/0xb0 fs/super.c:1387
fuse_mount+0x2d/0x40 fs/fuse/inode.c:1236
legacy_get_tree+0x27/0x80 fs/fs_context.c:661
vfs_get_tree+0x2e/0x120 fs/super.c:1476
do_new_mount fs/namespace.c:2790 [inline]
do_mount+0x932/0xc50 fs/namespace.c:3110
ksys_mount+0xab/0x120 fs/namespace.c:3319
__do_sys_mount fs/namespace.c:3333 [inline]
__se_sys_mount fs/namespace.c:3330 [inline]
__x64_sys_mount+0x26/0x30 fs/namespace.c:3330
do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301
entry_SYSCALL_64_after_hwframe+0x44/0xa9
This is a simple off by one bug on the error path.
Link: http://lkml.kernel.org/r/20190528043202.99980-1-shakeelb@google.com
Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists")
Reported-by: syzbot+f90a420dfe2b1b03cb2c@syzkaller.appspotmail.com
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.0+]
[ Upstream commit 8c43004af01635cc9fbb11031d070e5e0d327ef2 ]
pcpu_find_block_fit() guarantees that a fit is found within
PCPU_BITMAP_BLOCK_BITS. Iteration is used to determine the first fit as
it compares against the block's contig_hint. This can lead to
incorrectly scanning past the end of the bitmap. The behavior was okay
given the check after for bit_off >= end and the correctness of the
hints from pcpu_find_block_fit().
This patch fixes this by bounding the end offset by the number of bits
in a chunk.
Signed-off-by: Dennis Zhou <dennis@kernel.org>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
[ Upstream commit 198790d9a3aeaef5792d33a560020861126edc22 ]
In free_percpu() we sometimes call pcpu_schedule_balance_work() to
queue a work item (which does a wakeup) while holding pcpu_lock.
This creates an unnecessary lock dependency between pcpu_lock and
the scheduler's pi_lock. There are other places where we call
pcpu_schedule_balance_work() without hold pcpu_lock, and this case
doesn't need to be different.
Moving the call outside the lock prevents the following lockdep splat
when running tools/testing/selftests/bpf/{test_maps,test_progs} in
sequence with lockdep enabled:
WARNING: possible circular locking dependency detected
5.1.0-dbg-DEV #1 Not tainted
kworker/23:255/18872 is trying to acquire lock:
000000000bc79290 (&(&pool->lock)->rlock){-.-.}, at: __queue_work+0xb2/0x520
but task is already holding lock:
00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #4 (pcpu_lock){..-.}:
lock_acquire+0x9e/0x180
_raw_spin_lock_irqsave+0x3a/0x50
pcpu_alloc+0xfa/0x780
__alloc_percpu_gfp+0x12/0x20
alloc_htab_elem+0x184/0x2b0
__htab_percpu_map_update_elem+0x252/0x290
bpf_percpu_hash_update+0x7c/0x130
__do_sys_bpf+0x1912/0x1be0
__x64_sys_bpf+0x1a/0x20
do_syscall_64+0x59/0x400
entry_SYSCALL_64_after_hwframe+0x49/0xbe
-> #3 (&htab->buckets[i].lock){....}:
htab_map_update_elem+0x1af/0x3a0
-> #2 (&rq->lock){-.-.}:
_raw_spin_lock+0x2f/0x40
task_fork_fair+0x37/0x160
sched_fork+0x211/0x310
copy_process.part.43+0x7b1/0x2160
_do_fork+0xda/0x6b0
kernel_thread+0x29/0x30
rest_init+0x22/0x260
arch_call_rest_init+0xe/0x10
start_kernel+0x4fd/0x520
x86_64_start_reservations+0x24/0x26
x86_64_start_kernel+0x6f/0x72
secondary_startup_64+0xa4/0xb0
-> #1 (&p->pi_lock){-.-.}:
try_to_wake_up+0x41/0x600
wake_up_process+0x15/0x20
create_worker+0x16b/0x1e0
workqueue_init+0x279/0x2ee
kernel_init_freeable+0xf7/0x288
kernel_init+0xf/0x180
ret_from_fork+0x24/0x30
-> #0 (&(&pool->lock)->rlock){-.-.}:
__lock_acquire+0x101f/0x12a0
queue_work_on+0x38/0x80
free_percpu+0x221/0x260
pcpu_freelist_destroy+0x11/0x20
stack_map_free+0x2a/0x40
bpf_map_free_deferred+0x3c/0x50
process_one_work+0x1f7/0x580
worker_thread+0x54/0x410
kthread+0x10f/0x150
Chain exists of:
&(&pool->lock)->rlock --> &htab->buckets[i].lock --> pcpu_lock
Possible unsafe locking scenario:
CPU0 CPU1
lock(pcpu_lock);
lock(&htab->buckets[i].lock);
lock(pcpu_lock);
lock(&(&pool->lock)->rlock);
*** DEADLOCK ***
3 locks held by kworker/23:255/18872:
#0: 00000000b36a6e16 ((wq_completion)events){+.+.},
at: process_one_work+0x17a/0x580
#1: 00000000dfd966f0 ((work_completion)(&map->work)){+.+.},
#2: 00000000e3e7a6aa (pcpu_lock){..-.},
stack backtrace:
CPU: 23 PID: 18872 Comm: kworker/23:255 Not tainted 5.1.0-dbg-DEV #1
Hardware name: ...
Workqueue: events bpf_map_free_deferred
Call Trace:
dump_stack+0x67/0x95
print_circular_bug.isra.38+0x1c6/0x220
check_prev_add.constprop.50+0x9f6/0xd20
kthread+0x10f/0x150
Signed-off-by: John Sperbeck <jsperbeck@google.com>
[ Upstream commit 745e10146c31b1c6ed3326286704ae251b17f663 ]
"cat /proc/slab_allocators" could hang forever on SMP machines with
kmemleak or object debugging enabled due to other CPUs running do_drain()
will keep making kmemleak_object or debug_objects_cache dirty and unable
to escape the first loop in leaks_show(),
do {
set_store_user_clean(cachep);
drain_cpu_caches(cachep);
} while (!is_store_user_clean(cachep));
For example,
do_drain
slabs_destroy
slab_destroy
kmem_cache_free
__cache_free
___cache_free
kmemleak_free_recursive
delete_object_full
__delete_object
put_object
free_object_rcu
kmem_cache_free
cache_free_debugcheck --> dirty kmemleak_object
One approach is to check cachep->name and skip both kmemleak_object and
debug_objects_cache in leaks_show(). The other is to set store_user_clean
after drain_cpu_caches() which leaves a small window between
drain_cpu_caches() and set_store_user_clean() where per-CPU caches could
be dirty again lead to slightly wrong information has been stored but
could also speed up things significantly which sounds like a good
compromise. For example,
# cat /proc/slab_allocators
0m42.778s # 1st approach
0m0.737s # 2nd approach
[akpm@linux-foundation.org: tweak comment]
Link: http://lkml.kernel.org/r/20190411032635.10325-1-cai@lca.pw
Fixes: d31676dfde25 ("mm/slab: alternative implementation for DEBUG_SLAB_LEAK")
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
[ Upstream commit f0fd50504a54f5548eb666dc16ddf8394e44e4b7 ]
If not find zero bit in find_next_zero_bit(), it will return the size
parameter passed in, so the start bit should be compared with bitmap_maxno
rather than cma->count. Although getting maxchunk is working fine due to
zero value of order_per_bit currently, the operation will be stuck if
order_per_bit is set as non-zero.
Link: http://lkml.kernel.org/r/20190319092734.276-1-zbestahu@gmail.com
Signed-off-by: Yue Hu <huyue2@yulong.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Joe Perches <joe@perches.com>
Cc: Dmitry Safonov <d.safonov@partner.samsung.com>
[ Upstream commit 2b59e01a3aa665f751d1410b99fae9336bd424e1 ]
Currently one bit in cma bitmap represents number of pages rather than
one page, cma->count means cma size in pages. So to find available pages
via find_next_zero_bit()/find_next_bit() we should use cma size not in
pages but in bits although current free pages number is correct due to
zero value of order_per_bit. Once order_per_bit is changed the bitmap
status will be incorrect.
The size input in cma_debug_show_areas() is not correct. It will
affect the available pages at some position to debug the failure issue.
This is an example with order_per_bit = 1
Before this change:
[ 4.120060] cma: number of available pages: 1@93+4@108+7@121+7@137+7@153+7@169+7@185+7@201+3@213+3@221+3@229+3@237+3@245+3@253+3@261+3@269+3@277+3@285+3@293+3@301+3@309+3@317+3@325+19@333+15@369+512@512=> 638 free of 1024 total pages
After this change:
[ 4.143234] cma: number of available pages: 2@93+8@108+14@121+14@137+14@153+14@169+14@185+14@201+6@213+6@221+6@229+6@237+6@245+6@253+6@261+6@269+6@277+6@285+6@293+6@301+6@309+6@317+6@325+38@333+30@369=> 252 free of 1024 total pages
Obviously the bitmap status before is incorrect.
Link: http://lkml.kernel.org/r/20190320060829.9144-1-zbestahu@gmail.com
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Laura Abbott <labbott@redhat.com>
[ Upstream commit 1df3a339074e31db95c4790ea9236874b13ccd87 ]
f022d8cb7ec7 ("mm: cma: Don't crash on allocation if CMA area can't be
activated") fixes the crash issue when activation fails via setting
cma->count as 0, same logic exists if bitmap allocation fails.
Link: http://lkml.kernel.org/r/20190325081309.6004-1-zbestahu@gmail.com
Reviewed-by: Anshuman Khandual <anshuman.khandual@arm.com>
[ Upstream commit 299c83dce9ea3a79bb4b5511d2cb996b6b8e5111 ]
342332e6a925 ("mm/page_alloc.c: introduce kernelcore=mirror option") and
later patches rewrote the calculation of node spanned pages.
e506b99696a2 ("mem-hotplug: fix node spanned pages when we have a movable
node"), but the current code still has problems,
When we have a node with only zone_movable and the node id is not zero,
the size of node spanned pages is double added.
That's because we have an empty normal zone, and zone_start_pfn or
zone_end_pfn is not between arch_zone_lowest_possible_pfn and
arch_zone_highest_possible_pfn, so we need to use clamp to constrain the
range just like the commit <96e907d13602> (bootmem: Reimplement
__absent_pages_in_range() using for_each_mem_pfn_range()).
e.g.
Zone ranges:
DMA [mem 0x0000000000001000-0x0000000000ffffff]
DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Normal [mem 0x0000000100000000-0x000000023fffffff]
Movable zone start for each node
Node 0: 0x0000000100000000
Node 1: 0x0000000140000000
Early memory node ranges
node 0: [mem 0x0000000000001000-0x000000000009efff]
node 0: [mem 0x0000000000100000-0x00000000bffdffff]
node 0: [mem 0x0000000100000000-0x000000013fffffff]
node 1: [mem 0x0000000140000000-0x000000023fffffff]
node 0 DMA spanned:0xfff present:0xf9e absent:0x61
node 0 DMA32 spanned:0xff000 present:0xbefe0 absent:0x40020
node 0 Normal spanned:0 present:0 absent:0
node 0 Movable spanned:0x40000 present:0x40000 absent:0
On node 0 totalpages(node_present_pages): 1048446
node_spanned_pages:1310719
node 1 DMA spanned:0 present:0 absent:0
node 1 DMA32 spanned:0 present:0 absent:0
node 1 Normal spanned:0x100000 present:0x100000 absent:0
node 1 Movable spanned:0x100000 present:0x100000 absent:0
On node 1 totalpages(node_present_pages): 2097152
node_spanned_pages:2097152
Memory: 6967796K/12582392K available (16388K kernel code, 3686K rwdata,
4468K rodata, 2160K init, 10444K bss, 5614596K reserved, 0K
cma-reserved)
It shows that the current memory of node 1 is double added.
After this patch, the problem is fixed.
node 1 Normal spanned:0 present:0 absent:0
On node 1 totalpages(node_present_pages): 1048576
node_spanned_pages:1048576
memory: 6967796K/8388088K available (16388K kernel code, 3686K rwdata,
4468K rodata, 2160K init, 10444K bss, 1420292K reserved, 0K
cma-reserved)
Link: http://lkml.kernel.org/r/1554178276-10372-1-git-send-email-fanglinxu@huawei.com
Signed-off-by: Linxu Fang <fanglinxu@huawei.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Pavel Tatashin <pavel.tatashin@microsoft.com>
Cc: Oscar Salvador <osalvador@suse.de>
[ Upstream commit 0919e1b69ab459e06df45d3ba6658d281962db80 ]
When a huge page is allocated, PagePrivate() is set if the allocation
consumed a reservation. When freeing a huge page, PagePrivate is checked.
If set, it indicates the reservation should be restored. PagePrivate
being set at free huge page time mostly happens on error paths.
When huge page reservations are created, a check is made to determine if
the mapping is associated with an explicitly mounted filesystem. If so,
pages are also reserved within the filesystem. The default action when
freeing a huge page is to decrement the usage count in any associated
explicitly mounted filesystem. However, if the reservation is to be
restored the reservation/use count within the filesystem should not be
decrementd. Otherwise, a subsequent page allocation and free for the same
mapping location will cause the file filesystem usage to go 'negative'.
Filesystem Size Used Avail Use% Mounted on
nodev 4.0G -4.0M 4.1G - /opt/hugepool
To fix, when freeing a huge page do not adjust filesystem usage if
PagePrivate() is set to indicate the reservation should be restored.
I did not cc stable as the problem has been around since reserves were
added to hugetlbfs and nobody has noticed.
Link: http://lkml.kernel.org/r/20190328234704.27083-2-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
[ Upstream commit 734fb89968900b5c5f8edd5038bd4cdeab8c61d2 ]
To avoid random config build issue, select mmu notifier when HMM is
selected. In any cases when HMM get selected it will be by users that
will also wants the mmu notifier.
Link: http://lkml.kernel.org/r/20190403193318.16478-2-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: Ralph Campbell <rcampbell@nvidia.com>
Cc: John Hubbard <jhubbard@nvidia.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Souptick Joarder <jrdr.linux@gmail.com>
commit 3e8589963773a5c23e2f1fe4bcad0e9a90b7f471 upstream.
We have a single node system with node 0 disabled:
Scanning NUMA topology in Northbridge 24
Number of physical nodes 2
Skipping disabled node 0
Node 1 MemBase 0000000000000000 Limit 00000000fbff0000
NODE_DATA(1) allocated [mem 0xfbfda000-0xfbfeffff]
This causes crashes in memcg when system boots:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
#PF error: [normal kernel read fault]
RIP: 0010:list_lru_add+0x94/0x170
Call Trace:
d_lru_add+0x44/0x50
dput.part.34+0xfc/0x110
__fput+0x108/0x230
task_work_run+0x9f/0xc0
exit_to_usermode_loop+0xf5/0x100
It is reproducible as far as 4.12. I did not try older kernels. You have
to have a new enough systemd, e.g. 241 (the reason is unknown -- was not
investigated). Cannot be reproduced with systemd 234.
The system crashes because the size of lru array is never updated in
memcg_update_all_list_lrus and the reads are past the zero-sized array,
causing dereferences of random memory.
The root cause are list_lru_memcg_aware checks in the list_lru code. The
test in list_lru_memcg_aware is broken: it assumes node 0 is always
present, but it is not true on some systems as can be seen above.
So fix this by avoiding checks on node 0. Remember the memcg-awareness by
a bool flag in struct list_lru.
Link: http://lkml.kernel.org/r/20190522091940.3615-1-jslaby@suse.cz
Suggested-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Reviewed-by: Shakeel Butt <shakeelb@google.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
commit 1b426bac66e6cc83c9f2d92b96e4e72acf43419a upstream.
hugetlb uses a fault mutex hash table to prevent page faults of the
same pages concurrently. The key for shared and private mappings is
different. Shared keys off address_space and file index. Private keys
off mm and virtual address. Consider a private mappings of a populated
hugetlbfs file. A fault will map the page from the file and if needed
do a COW to map a writable page.
Hugetlbfs hole punch uses the fault mutex to prevent mappings of file
pages. It uses the address_space file index key. However, private
mappings will use a different key and could race with this code to map
the file page. This causes problems (BUG) for the page cache remove
code as it expects the page to be unmapped. A sample stack is:
page dumped because: VM_BUG_ON_PAGE(page_mapped(page))
kernel BUG at mm/filemap.c:169!
RIP: 0010:unaccount_page_cache_page+0x1b8/0x200
Call Trace:
__delete_from_page_cache+0x39/0x220
delete_from_page_cache+0x45/0x70
remove_inode_hugepages+0x13c/0x380
? __add_to_page_cache_locked+0x162/0x380
hugetlbfs_fallocate+0x403/0x540
? _cond_resched+0x15/0x30
? __inode_security_revalidate+0x5d/0x70
? selinux_file_permission+0x100/0x130
vfs_fallocate+0x13f/0x270
ksys_fallocate+0x3c/0x80
__x64_sys_fallocate+0x1a/0x20
do_syscall_64+0x5b/0x180
There seems to be another potential COW issue/race with this approach
of different private and shared keys as noted in commit 8382d914ebf7
("mm, hugetlb: improve page-fault scalability").
Since every hugetlb mapping (even anon and private) is actually a file
mapping, just use the address_space index key for all mappings. This
results in potentially more hash collisions. However, this should not
be the common case.
Link: http://lkml.kernel.org/r/20190328234704.27083-3-mike.kravetz@oracle.com
Link: http://lkml.kernel.org/r/20190412165235.t4sscoujczfhuiyt@linux-r8p5
Fixes: b5cec28d36f5 ("hugetlbfs: truncate_hugepages() takes a range of pages")
Reviewed-by: Davidlohr Bueso <dbueso@suse.de>
commit 134fca9063ad4851de767d1768180e5dede9a881 upstream.
The semantics of what mincore() considers to be resident is not
completely clear, but Linux has always (since 2.3.52, which is when
mincore() was initially done) treated it as "page is available in page
cache".
That's potentially a problem, as that [in]directly exposes
meta-information about pagecache / memory mapping state even about
memory not strictly belonging to the process executing the syscall,
opening possibilities for sidechannel attacks.
Change the semantics of mincore() so that it only reveals pagecache
information for non-anonymous mappings that belog to files that the
calling process could (if it tried to) successfully open for writing;
otherwise we'd be including shared non-exclusive mappings, which
- is the sidechannel
- is not the usecase for mincore(), as that's primarily used for data,
not (shared) text
[jkosina@suse.cz: v2]
Link: http://lkml.kernel.org/r/20190312141708.6652-2-vbabka@suse.cz
[mhocko@suse.com: restructure can_do_mincore() conditions]
Link: http://lkml.kernel.org/r/nycvar.YFH.7.76.1903062342020.19912@cbobk.fhfr.pm
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Josh Snyder <joshs@netflix.com>
Originally-by: Linus Torvalds <torvalds@linux-foundation.org>
Originally-by: Dominique Martinet <asmadeus@codewreck.org>
Cc: Kevin Easton <kevin@guarana.org>
Cc: Cyril Hrubis <chrubis@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Daniel Gruss <daniel@gruss.cc>
[ Upstream commit cae85cb8add35f678cf487139d05e083ce2f570a ]
Aneesh has reported that PPC triggers the following warning when
excercising DAX code:
IP set_pte_at+0x3c/0x190
LR insert_pfn+0x208/0x280
Call Trace:
insert_pfn+0x68/0x280
dax_iomap_pte_fault.isra.7+0x734/0xa40
__xfs_filemap_fault+0x280/0x2d0
do_wp_page+0x48c/0xa40
__handle_mm_fault+0x8d0/0x1fd0
handle_mm_fault+0x140/0x250
__do_page_fault+0x300/0xd60
handle_page_fault+0x18
Now that is WARN_ON in set_pte_at which is
VM_WARN_ON(pte_hw_valid(*ptep) && !pte_protnone(*ptep));
The problem is that on some architectures set_pte_at() cannot cope with
a situation where there is already some (different) valid entry present.
Use ptep_set_access_flags() instead to modify the pfn which is built to
deal with modifying existing PTE.
Link: http://lkml.kernel.org/r/20190311084537.16029-1-jack@suse.cz
Fixes: b2770da64254 "mm: add vm_insert_mixed_mkwrite()"
Reported-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Cc: Chandan Rajendra <chandan@linux.ibm.com>
[ Upstream commit 3b991208b897f52507168374033771a984b947b1 ]
During !CONFIG_CGROUP reclaim, we expand the inactive list size if it's
thrashing on the node that is about to be reclaimed. But when cgroups
are enabled, we suddenly ignore the node scope and use the cgroup scope
only. The result is that pressure bleeds between NUMA nodes depending
on whether cgroups are merely compiled into Linux. This behavioral
difference is unexpected and undesirable.
When the refault adaptivity of the inactive list was first introduced,
there were no statistics at the lruvec level - the intersection of node
and memcg - so it was better than nothing.
But now that we have that infrastructure, use lruvec_page_state() to
make the list balancing decision always NUMA aware.
[hannes@cmpxchg.org: fix bisection hole]
Link: http://lkml.kernel.org/r/20190417155241.GB23013@cmpxchg.org
Link: http://lkml.kernel.org/r/20190412144438.2645-1-hannes@cmpxchg.org
Fixes: 2a2e48854d70 ("mm: vmscan: fix IO/refault regression in cache workingset transition")
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Roman Gushchin <guro@fb.com>
[ Upstream commit fcf88917dd435c6a4cb2830cb086ee58605a1d85 ]
The commit 510ded33e075 ("slab: implement slab_root_caches list")
changes the name of the list node within "struct kmem_cache" from "list"
to "root_caches_node", but leaks_show() still use the "list" which
causes a crash when reading /proc/slab_allocators.
You need to have CONFIG_SLAB=y and CONFIG_MEMCG=y to see the problem,
because without MEMCG all slab caches are root caches, and the "list"
node happens to be the right one.
Fixes: 510ded33e075 ("slab: implement slab_root_caches list")
Reviewed-by: Tobin C. Harding <tobin@kernel.org>
commit dce5b0bdeec61bdbee56121ceb1d014151d5cab1 upstream.
The only references outside of the #ifdef have been removed, so now we
get a warning in non-SMP configurations:
mm/kmemleak.c:1404:13: error: unused function 'scan_large_block' [-Werror,-Wunused-function]
Add a new #ifdef around it.
Link: http://lkml.kernel.org/r/20190416123148.3502045-1-arnd@arndb.de
Fixes: 298a32b13208 ("kmemleak: powerpc: skip scanning holes in the .bss section")
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Vincent Whitchurch <vincent.whitchurch@axis.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
[ Upstream commit 298a32b132087550d3fa80641ca58323c5dfd4d9 ]
Commit 2d4f567103ff ("KVM: PPC: Introduce kvm_tmp framework") adds
kvm_tmp[] into the .bss section and then free the rest of unused spaces
back to the page allocator.
kernel_init
kvm_guest_init
kvm_free_tmp
free_reserved_area
free_unref_page
free_unref_page_prepare
With DEBUG_PAGEALLOC=y, it will unmap those pages from kernel. As the
result, kmemleak scan will trigger a panic when it scans the .bss
section with unmapped pages.
This patch creates dedicated kmemleak objects for the .data, .bss and
potentially .data..ro_after_init sections to allow partial freeing via
the kmemleak_free_part() in the powerpc kvm_free_tmp() function.
Link: http://lkml.kernel.org/r/20190321171917.62049-1-catalin.marinas@arm.com
Reported-by: Qian Cai <cai@lca.pw>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Qian Cai <cai@lca.pw>
Cc: Avi Kivity <avi@redhat.com>
Cc: Radim Krcmar <rkrcmar@redhat.com>
commit e496612c5130567fc9d5f1969ca4b86665aa3cbb upstream.
Shakeel Butt reported he has observed in production systems that the job
loader gets stuck for 10s of seconds while doing a mount operation. It
turns out that it was stuck in register_shrinker() because some
unrelated job was under memory pressure and was spending time in
shrink_slab(). Machines have a lot of shrinkers registered and jobs
under memory pressure have to traverse all of those memcg-aware
shrinkers and affect unrelated jobs which want to register their own
shrinkers.
To solve the issue, this patch simply bails out slab shrinking if it is
found that someone wants to register a shrinker in parallel. A downside
is it could cause unfair shrinking between shrinkers. However, it
should be rare and we can add compilcated logic if we find it's not
enough.
[akpm@linux-foundation.org: tweak code comment]
Link: http://lkml.kernel.org/r/20171115005602.GB23810@bbox
Link: http://lkml.kernel.org/r/1511481899-20335-1-git-send-email-minchan@kernel.org
Reported-by: Shakeel Butt <shakeelb@google.com>
Tested-by: Shakeel Butt <shakeelb@google.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
[rkolchmeyer: Backported to 4.14: adjusted context]
Signed-off-by: Robert Kolchmeyer <rkolchmeyer@google.com>
commit 8fde12ca79aff9b5ba951fce1a2641901b8d8e64 upstream.
If the page refcount wraps around past zero, it will be freed while
there are still four billion references to it. One of the possible
avenues for an attacker to try to make this happen is by doing direct IO
on a page multiple times. This patch makes get_user_pages() refuse to
take a new page reference if there are already more than two billion
references to the page.
Reported-by: Jann Horn <jannh@google.com>
Acked-by: Matthew Wilcox <willy@infradead.org>
Cc: stable@kernel.org
commit f2c57d91b0d96aa13ccff4e3b178038f17b00658 upstream.
In DAX mode a write pagefault can race with write(2) in the following
way:
CPU0 CPU1
write fault for mapped zero page (hole)
dax_iomap_rw()
iomap_apply()
xfs_file_iomap_begin()
- allocates blocks
dax_iomap_actor()
invalidate_inode_pages2_range()
- invalidates radix tree entries in given range
dax_iomap_pte_fault()
grab_mapping_entry()
- no entry found, creates empty
- finds already allocated block
vmf_insert_mixed_mkwrite()
- WARNs and does nothing because there
is still zero page mapped in PTE
unmap_mapping_pages()
This race results in WARN_ON from insert_pfn() and is occasionally
triggered by fstest generic/344. Note that the race is otherwise
harmless as before write(2) on CPU0 is finished, we will invalidate page
tables properly and thus user of mmap will see modified data from
write(2) from that point on. So just restrict the warning only to the
case when the PFN in PTE is not zero page.
Link: http://lkml.kernel.org/r/20180824154542.26872-1-jack@suse.cz
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
commit 00206a69ee32f03e6f40837684dcbe475ea02266 upstream.
Since commit ad67b74d2469d9b8 ("printk: hash addresses printed with %p"),
at boot "____ptrval____" is printed instead of actual addresses:
percpu: Embedded 38 pages/cpu @(____ptrval____) s124376 r0 d31272 u524288
Instead of changing the print to "%px", and leaking kernel addresses,
just remove the print completely, cfr. e.g. commit 071929dbdd865f77
("arm64: Stop printing the virtual memory layout").
Signed-off-by: Matteo Croce <mcroce@redhat.com>
commit e8277b3b52240ec1caad8e6df278863e4bf42eac upstream.
Commit 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly")
depends on skipping vmstat entries with empty name introduced in
7aaf77272358 ("mm: don't show nr_indirectly_reclaimable in
/proc/vmstat") but reverted in b29940c1abd7 ("mm: rename and change
semantics of nr_indirectly_reclaimable_bytes").
So skipping no longer works and /proc/vmstat has misformatted lines " 0".
This patch simply shows debug counters "nr_tlb_remote_*" for UP.
Link: http://lkml.kernel.org/r/155481488468.467.4295519102880913454.stgit@buzz
Fixes: 58bc4c34d249 ("mm/vmstat.c: skip NR_TLB_REMOTE_FLUSH* properly")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Jann Horn <jannh@google.com>
dumping
commit 04f5866e41fb70690e28397487d8bd8eea7d712a upstream.
The core dumping code has always run without holding the mmap_sem for
writing, despite that is the only way to ensure that the entire vma
layout will not change from under it. Only using some signal
serialization on the processes belonging to the mm is not nearly enough.
This was pointed out earlier. For example in Hugh's post from Jul 2017:
https://lkml.kernel.org/r/alpine.LSU.2.11.1707191716030.2055@eggly.anvils
"Not strictly relevant here, but a related note: I was very surprised
to discover, only quite recently, how handle_mm_fault() may be called
without down_read(mmap_sem) - when core dumping. That seems a
misguided optimization to me, which would also be nice to correct"
In particular because the growsdown and growsup can move the
vm_start/vm_end the various loops the core dump does around the vma will
not be consistent if page faults can happen concurrently.
Pretty much all users calling mmget_not_zero()/get_task_mm() and then
taking the mmap_sem had the potential to introduce unexpected side
effects in the core dumping code.
Adding mmap_sem for writing around the ->core_dump invocation is a
viable long term fix, but it requires removing all copy user and page
faults and to replace them with get_dump_page() for all binary formats
which is not suitable as a short term fix.
For the time being this solution manually covers the places that can
confuse the core dump either by altering the vma layout or the vma flags
while it runs. Once ->core_dump runs under mmap_sem for writing the
function mmget_still_valid() can be dropped.
Allowing mmap_sem protected sections to run in parallel with the
coredump provides some minor parallelism advantage to the swapoff code
(which seems to be safe enough by never mangling any vma field and can
keep doing swapins in parallel to the core dumping) and to some other
corner case.
In order to facilitate the backporting I added "Fixes: 86039bd3b4e6"
however the side effect of this same race condition in /proc/pid/mem
should be reproducible since before 2.6.12-rc2 so I couldn't add any
other "Fixes:" because there's no hash beyond the git genesis commit.
Because find_extend_vma() is the only location outside of the process
context that could modify the "mm" structures under mmap_sem for
reading, by adding the mmget_still_valid() check to it, all other cases
that take the mmap_sem for reading don't need the new check after
mmget_not_zero()/get_task_mm(). The expand_stack() in page fault
context also doesn't need the new check, because all tasks under core
dumping are frozen.
Link: http://lkml.kernel.org/r/20190325224949.11068-1-aarcange@redhat.com
Fixes: 86039bd3b4e6 ("userfaultfd: add new syscall to provide memory externalization")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Peter Xu <peterx@redhat.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Jann Horn <jannh@google.com>
Acked-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 4117992df66a26fa33908b4969e04801534baab1 ]
KASAN does not play well with the page poisoning (CONFIG_PAGE_POISONING).
It triggers false positives in the allocation path:
BUG: KASAN: use-after-free in memchr_inv+0x2ea/0x330
Read of size 8 at addr ffff88881f800000 by task swapper/0
CPU: 0 PID: 0 Comm: swapper Not tainted 5.0.0-rc1+ #54
Call Trace:
dump_stack+0xe0/0x19a
print_address_description.cold.2+0x9/0x28b
kasan_report.cold.3+0x7a/0xb5
__asan_report_load8_noabort+0x19/0x20
kernel_poison_pages+0x103/0x3d5
get_page_from_freelist+0x15e7/0x4d90
because KASAN has not yet unpoisoned the shadow page for allocation
before it checks memchr_inv() but only found a stale poison pattern.
Also, false positives in free path,
BUG: KASAN: slab-out-of-bounds in kernel_poison_pages+0x29e/0x3d5
Write of size 4096 at addr ffff8888112cc000 by task swapper/0/1
CPU: 5 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc1+ #55
Call Trace:
check_memory_region+0x22d/0x250
memset+0x28/0x40
__free_pages_ok+0x75f/0x13e0
due to KASAN adds poisoned redzones around slab objects, but the page
poisoning needs to poison the whole page.
Link: http://lkml.kernel.org/r/20190114233405.67843-1-cai@lca.pw
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit 92d1d07daad65c300c7d0b68bbef8867e9895d54 ]
Kmemleak throws endless warnings during boot due to in
__alloc_alien_cache(),
alc = kmalloc_node(memsize, gfp, node);
init_arraycache(&alc->ac, entries, batch);
kmemleak_no_scan(ac);
Kmemleak does not track the array cache (alc->ac) but the alien cache
(alc) instead, so let it track the latter by lifting kmemleak_no_scan()
out of init_arraycache().
There is another place that calls init_arraycache(), but
alloc_kmem_cache_cpus() uses the percpu allocation where will never be
considered as a leak.
kmemleak: Found object by alias at 0xffff8007b9aa7e38
CPU: 190 PID: 1 Comm: swapper/0 Not tainted 5.0.0-rc2+ #2
Call trace:
dump_backtrace+0x0/0x168
show_stack+0x24/0x30
dump_stack+0x88/0xb0
lookup_object+0x84/0xac
find_and_get_object+0x84/0xe4
kmemleak_no_scan+0x74/0xf4
setup_kmem_cache_node+0x2b4/0x35c
__do_tune_cpucache+0x250/0x2d4
do_tune_cpucache+0x4c/0xe4
enable_cpucache+0xc8/0x110
setup_cpu_cache+0x40/0x1b8
__kmem_cache_create+0x240/0x358
create_cache+0xc0/0x198
kmem_cache_create_usercopy+0x158/0x20c
kmem_cache_create+0x50/0x64
fsnotify_init+0x58/0x6c
do_one_initcall+0x194/0x388
kernel_init_freeable+0x668/0x688
kernel_init+0x18/0x124
ret_from_fork+0x10/0x18
kmemleak: Object 0xffff8007b9aa7e00 (size 256):
kmemleak: comm "swapper/0", pid 1, jiffies 4294697137
kmemleak: min_count = 1
kmemleak: count = 0
kmemleak: flags = 0x1
kmemleak: checksum = 0
kmemleak: backtrace:
kmemleak_alloc+0x84/0xb8
kmem_cache_alloc_node_trace+0x31c/0x3a0
__kmalloc_node+0x58/0x78
setup_kmem_cache_node+0x26c/0x35c
kmemleak: Not scanning unknown object at 0xffff8007b9aa7e38
Call trace:
kmemleak_no_scan+0x90/0xf4
Link: http://lkml.kernel.org/r/20190129184518.39808-1-cai@lca.pw
Fixes: 1fe00d50a9e8 ("slab: factor out initialization of array cache")
[ Upstream commit afd07389d3f4933c7f7817a92fb5e053d59a3182 ]
One of the vmalloc stress test case triggers the kernel BUG():
<snip>
[60.562151] ------------[ cut here ]------------
[60.562154] kernel BUG at mm/vmalloc.c:512!
[60.562206] invalid opcode: 0000 [#1] PREEMPT SMP PTI
[60.562247] CPU: 0 PID: 430 Comm: vmalloc_test/0 Not tainted 4.20.0+ #161
[60.562293] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
[60.562351] RIP: 0010:alloc_vmap_area+0x36f/0x390
<snip>
it can happen due to big align request resulting in overflowing of
calculated address, i.e. it becomes 0 after ALIGN()'s fixup.
Fix it by checking if calculated address is within vstart/vend range.
Link: http://lkml.kernel.org/r/20190124115648.9433-2-urezki@gmail.com
Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com>
Cc: Joel Fernandes <joelaf@google.com>
Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com>
Cc: Thomas Garnier <thgarnie@google.com>
[ Upstream commit 2e25644e8da4ed3a27e7b8315aaae74660be72dc ]
Syzbot with KMSAN reports (excerpt):
BUG: KMSAN: uninit-value in mpol_rebind_policy mm/mempolicy.c:353 [inline]
BUG: KMSAN: uninit-value in mpol_rebind_mm+0x249/0x370 mm/mempolicy.c:384
CPU: 1 PID: 17420 Comm: syz-executor4 Not tainted 4.20.0-rc7+ #15
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:295
update_tasks_nodemask+0x608/0xca0 kernel/cgroup/cpuset.c:1120
update_nodemasks_hier kernel/cgroup/cpuset.c:1185 [inline]
update_nodemask kernel/cgroup/cpuset.c:1253 [inline]
cpuset_write_resmask+0x2a98/0x34b0 kernel/cgroup/cpuset.c:1728
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmem_cache_alloc+0x572/0xb90 mm/slub.c:2777
mpol_new mm/mempolicy.c:276 [inline]
do_mbind mm/mempolicy.c:1180 [inline]
kernel_mbind+0x8a7/0x31a0 mm/mempolicy.c:1347
__do_sys_mbind mm/mempolicy.c:1354 [inline]
As it's difficult to report where exactly the uninit value resides in
the mempolicy object, we have to guess a bit. mm/mempolicy.c:353
contains this part of mpol_rebind_policy():
if (!mpol_store_user_nodemask(pol) &&
nodes_equal(pol->w.cpuset_mems_allowed, *newmask))
"mpol_store_user_nodemask(pol)" is testing pol->flags, which I couldn't
ever see being uninitialized after leaving mpol_new(). So I'll guess
it's actually about accessing pol->w.cpuset_mems_allowed on line 354,
but still part of statement starting on line 353.
For w.cpuset_mems_allowed to be not initialized, and the nodes_equal()
reachable for a mempolicy where mpol_set_nodemask() is called in
do_mbind(), it seems the only possibility is a MPOL_PREFERRED policy
with empty set of nodes, i.e. MPOL_LOCAL equivalent, with MPOL_F_LOCAL
flag. Let's exclude such policies from the nodes_equal() check. Note
the uninit access should be benign anyway, as rebinding this kind of
policy is always a no-op. Therefore no actual need for stable
inclusion.
Link: http://lkml.kernel.org/r/a71997c3-e8ae-a787-d5ce-3db05768b27c@suse.cz
Link: http://lkml.kernel.org/r/73da3e9c-cc84-509e-17d9-0c434bb9967d@suse.cz
Reported-by: syzbot+b19c2dc2c990ea657a71@syzkaller.appspotmail.com
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: zhong jiang <zhongjiang@huawei.com>
[ Upstream commit 0c81585499601acd1d0e1cbf424cabfaee60628c ]
After offlining a memory block, kmemleak scan will trigger a crash, as
it encounters a page ext address that has already been freed during
memory offlining. At the beginning in alloc_page_ext(), it calls
kmemleak_alloc(), but it does not call kmemleak_free() in
free_page_ext().
BUG: unable to handle kernel paging request at ffff888453d00000
PGD 128a01067 P4D 128a01067 PUD 128a04067 PMD 47e09e067 PTE 800ffffbac2ff060
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN PTI
CPU: 1 PID: 1594 Comm: bash Not tainted 5.0.0-rc8+ #15
Hardware name: HP ProLiant DL180 Gen9/ProLiant DL180 Gen9, BIOS U20 10/25/2017
RIP: 0010:scan_block+0xb5/0x290
Code: 85 6e 01 00 00 48 b8 00 00 30 f5 81 88 ff ff 48 39 c3 0f 84 5b 01 00 00 48 89 d8 48 c1 e8 03 42 80 3c 20 00 0f 85 87 01 00 00 <4c> 8b 3b e8 f3 0c fa ff 4c 39 3d 0c 6b 4c 01 0f 87 08 01 00 00 4c
RSP: 0018:ffff8881ec57f8e0 EFLAGS: 00010082
RAX: 0000000000000000 RBX: ffff888453d00000 RCX: ffffffffa61e5a54
RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff888453d00000
RBP: ffff8881ec57f920 R08: fffffbfff4ed588d R09: fffffbfff4ed588c
R10: fffffbfff4ed588c R11: ffffffffa76ac463 R12: dffffc0000000000
R13: ffff888453d00ff9 R14: ffff8881f80cef48 R15: ffff8881f80cef48
FS: 00007f6c0e3f8740(0000) GS:ffff8881f7680000(0000) knlGS:0000000000000000
CR2: ffff888453d00000 CR3: 00000001c4244003 CR4: 00000000001606a0
Call Trace:
scan_gray_list+0x269/0x430
kmemleak_scan+0x5a8/0x10f0
kmemleak_write+0x541/0x6ca
full_proxy_write+0xf8/0x190
__vfs_write+0xeb/0x980
vfs_write+0x15a/0x4f0
ksys_write+0xd2/0x1b0
__x64_sys_write+0x73/0xb0
do_syscall_64+0xeb/0xaaa
RIP: 0033:0x7f6c0dad73b8
Code: 89 02 48 c7 c0 ff ff ff ff eb b3 0f 1f 80 00 00 00 00 f3 0f 1e fa 48 8d 05 65 63 2d 00 8b 00 85 c0 75 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 41 54 49 89 d4 55
RSP: 002b:00007ffd5b863cb8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00007f6c0dad73b8
RDX: 0000000000000005 RSI: 000055a9216e1710 RDI: 0000000000000001
RBP: 000055a9216e1710 R08: 000000000000000a R09: 00007ffd5b863840
R10: 000000000000000a R11: 0000000000000246 R12: 00007f6c0dda9780
R13: 0000000000000005 R14: 00007f6c0dda4740 R15: 0000000000000005
Modules linked in: nls_iso8859_1 nls_cp437 vfat fat kvm_intel kvm irqbypass efivars ip_tables x_tables xfs sd_mod ahci libahci igb i2c_algo_bit libata i2c_core dm_mirror dm_region_hash dm_log dm_mod efivarfs
---[ end trace ccf646c7456717c5 ]---
Kernel panic - not syncing: Fatal exception
Shutting down cpus with NMI
Kernel Offset: 0x24c00000 from 0xffffffff81000000 (relocation range:
0xffffffff80000000-0xffffffffbfffffff)
---[ end Kernel panic - not syncing: Fatal exception ]---
Link: http://lkml.kernel.org/r/20190227173147.75650-1-cai@lca.pw
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
[ Upstream commit 0d3bd18a5efd66097ef58622b898d3139790aa9d ]
In case cma_init_reserved_mem failed, need to free the memblock
allocated by memblock_reserve or memblock_alloc_range.
Quote Catalin's comments:
https://lkml.org/lkml/2019/2/26/482
Kmemleak is supposed to work with the memblock_{alloc,free} pair and it
ignores the memblock_reserve() as a memblock_alloc() implementation
detail. It is, however, tolerant to memblock_free() being called on
a sub-range or just a different range from a previous memblock_alloc().
So the original patch looks fine to me. FWIW:
Link: http://lkml.kernel.org/r/20190227144631.16708-1-peng.fan@nxp.com
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
commit a7f40cfe3b7ada57af9b62fd28430eeb4a7cfcb7 upstream.
When MPOL_MF_STRICT was specified and an existing page was already on a
node that does not follow the policy, mbind() should return -EIO. But
commit 6f4576e3687b ("mempolicy: apply page table walker on
queue_pages_range()") broke the rule.
And commit c8633798497c ("mm: mempolicy: mbind and migrate_pages support
thp migration") didn't return the correct value for THP mbind() too.
If MPOL_MF_STRICT is set, ignore vma_migratable() to make sure it
reaches queue_pages_to_pte_range() or queue_pages_pmd() to check if an
existing page was already on a node that does not follow the policy.
And, non-migratable vma may be used, return -EIO too if MPOL_MF_MOVE or
MPOL_MF_MOVE_ALL was specified.
Tested with https://github.com/metan-ucw/ltp/blob/master/testcases/kernel/syscalls/mbind/mbind02.c
Link: http://lkml.kernel.org/r/1553020556-38583-1-git-send-email-yang.shi@linux.alibaba.com
Fixes: 6f4576e3687b ("mempolicy: apply page table walker on queue_pages_range()")
Signed-off-by: Yang Shi <yang.shi@linux.alibaba.com>
Signed-off-by: Oscar Salvador <osalvador@suse.de>
Reported-by: Cyril Hrubis <chrubis@suse.cz>
Suggested-by: Kirill A. Shutemov <kirill@shutemov.name>
Acked-by: Rafael Aquini <aquini@redhat.com>
Reviewed-by: Oscar Salvador <osalvador@suse.de>
Acked-by: David Rientjes <rientjes@google.com>
commit d2b2c6dd227ba5b8a802858748ec9a780cb75b47 upstream.
Our MIPS 1004Kc SoCs were seeing random userspace crashes with SIGILL
and SIGSEGV that could not be traced back to a userspace code bug. They
had all the magic signs of an I/D cache coherency issue.
Now recently we noticed that the /proc/sys/vm/compact_memory interface
was quite efficient at provoking this class of userspace crashes.
Studying the code in mm/migrate.c there is a distinction made between
migrating a page that is mapped at the instant of migration and one that
is not mapped. Our problem turned out to be the non-mapped pages.
For the non-mapped page the code performs a copy of the page content and
all relevant meta-data of the page without doing the required D-cache
maintenance. This leaves dirty data in the D-cache of the CPU and on
the 1004K cores this data is not visible to the I-cache. A subsequent
page-fault that triggers a mapping of the page will happily serve the
process with potentially stale code.
What about ARM then, this bug should have seen greater exposure? Well
ARM became immune to this flaw back in 2010, see commit c01778001a4f
("ARM: 6379/1: Assume new page cache pages have dirty D-cache").
My proposed fix moves the D-cache maintenance inside move_to_new_page to
make it common for both cases.
Link: http://lkml.kernel.org/r/20190315083502.11849-1-larper@axis.com
Fixes: 97ee0524614 ("flush cache before installing new page at migraton")
Signed-off-by: Lars Persson <larper@axis.com>
Reviewed-by: Paul Burton <paul.burton@mips.com>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
commit 401592d2e095947344e10ec0623adbcd58934dd4 upstream.
When VM_NO_GUARD is not set area->size includes adjacent guard page,
thus for correct size checking get_vm_area_size() should be used, but
not area->size.
This fixes possible kernel oops when userspace tries to mmap an area on
1 page bigger than was allocated by vmalloc_user() call: the size check
inside remap_vmalloc_range_partial() accounts non-existing guard page
also, so check successfully passes but vmalloc_to_page() returns NULL
(guard page does not physically exist).
The following code pattern example should trigger an oops:
static int oops_mmap(struct file *file, struct vm_area_struct *vma)
void *mem;
mem = vmalloc_user(4096);
BUG_ON(!mem);
/* Do not care about mem leak */
return remap_vmalloc_range(vma, mem, 0);
And userspace simply mmaps size + PAGE_SIZE:
mmap(NULL, 8192, PROT_WRITE|PROT_READ, MAP_PRIVATE, fd, 0);
Possible candidates for oops which do not have any explicit size
checks:
*** drivers/media/usb/stkwebcam/stk-webcam.c:
v4l_stk_mmap[789] ret = remap_vmalloc_range(vma, sbuf->buffer, 0);
Or the following one:
*** drivers/video/fbdev/core/fbmem.c
static int
fb_mmap(struct file *file, struct vm_area_struct * vma)
res = fb->fb_mmap(info, vma);
Where fb_mmap callback calls remap_vmalloc_range() directly without any
explicit checks:
*** drivers/video/fbdev/vfb.c
static int vfb_mmap(struct fb_info *info,
return remap_vmalloc_range(vma, (void *)info->fix.smem_start, vma->vm_pgoff);
Link: http://lkml.kernel.org/r/20190103145954.16942-2-rpenyaev@suse.de
Signed-off-by: Roman Penyaev <rpenyaev@suse.de>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
commit 46612b751c4941c5c0472ddf04027e877ae5990f upstream.
When soft_offline_in_use_page() runs on a thp tail page after pmd is
split, we trigger the following VM_BUG_ON_PAGE():
Memory failure: 0x3755ff: non anonymous thp
__get_any_page: 0x3755ff: unknown zero refcount page type 2fffff80000000
Soft offlining pfn 0x34d805 at process virtual address 0x20fff000
page:ffffea000d360140 count:0 mapcount:0 mapping:0000000000000000 index:0x1
flags: 0x2fffff80000000()
raw: 002fffff80000000 ffffea000d360108 ffffea000d360188 0000000000000000
raw: 0000000000000001 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: VM_BUG_ON_PAGE(page_ref_count(page) == 0)
kernel BUG at ./include/linux/mm.h:519!
soft_offline_in_use_page() passed refcount and page lock from tail page
to head page, which is not needed because we can pass any subpage to
split_huge_page().
Naoya had fixed a similar issue in c3901e722b29 ("mm: hwpoison: fix thp
split handling in memory_failure()"). But he missed fixing soft
offline.
Link: http://lkml.kernel.org/r/1551452476-24000-1-git-send-email-zhongjiang@huawei.com
Fixes: 61f5d698cc97 ("mm: re-enable THP")
Signed-off-by: zhongjiang <zhongjiang@huawei.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [4.5+]
[ Upstream commit 29b00e609960ae0fcff382f4c7079dd0874a5311 ]
When we made the shmem_reserve_inode call in shmem_link conditional, we
forgot to update the declaration for ret so that it always has a known
value. Dan Carpenter pointed out this deficiency in the original patch.
Fixes: 1062af920c07 ("tmpfs: fix link accounting when a tmpfile is linked in")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Matej Kupljen <matej.kupljen@gmail.com>
[ Upstream commit 1062af920c07f5b54cf5060fde3339da6df0cf6b ]
tmpfs has a peculiarity of accounting hard links as if they were
separate inodes: so that when the number of inodes is limited, as it is
by default, a user cannot soak up an unlimited amount of unreclaimable
dcache memory just by repeatedly linking a file.
But when v3.11 added O_TMPFILE, and the ability to use linkat() on the
fd, we missed accommodating this new case in tmpfs: "df -i" shows that
an extra "inode" remains accounted after the file is unlinked and the fd
closed and the actual inode evicted. If a user repeatedly links
tmpfiles into a tmpfs, the limit will be hit (ENOSPC) even after they
are deleted.
Just skip the extra reservation from shmem_link() in this case: there's
a sense in which this first link of a tmpfile is then cheaper than a
hard link of another file, but the accounting works out, and there's
still good limiting, so no need to do anything more complicated.
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1902182134370.7035@eggly.anvils
Fixes: f4e0c30c191 ("allow the temp files created by open() to be linked to")
Reported-by: Matej Kupljen <matej.kupljen@gmail.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
[ Upstream commit 2c2ade81741c66082f8211f0b96cf509cc4c0218 ]
The basic idea behind ->pagecnt_bias is: If we pre-allocate the maximum
number of references that we might need to create in the fastpath later,
the bump-allocation fastpath only has to modify the non-atomic bias value
that tracks the number of extra references we hold instead of the atomic
refcount. The maximum number of allocations we can serve (under the
assumption that no allocation is made with size 0) is nc->size, so that's
the bias used.
However, even when all memory in the allocation has been given away, a
reference to the page is still held; and in the `offset < 0` slowpath, the
page may be reused if everyone else has dropped their references.
This means that the necessary number of references is actually
`nc->size+1`.
Luckily, from a quick grep, it looks like the only path that can call
page_frag_alloc(fragsz=1) is TAP with the IFF_NAPI_FRAGS flag, which
requires CAP_NET_ADMIN in the init namespace and is only intended to be
used for kernel testing and fuzzing.
To test for this issue, put a `WARN_ON(page_ref_count(page) == 0)` in the
`offset < 0` path, below the virt_to_page() call, and then repeatedly call
writev() on a TAP device with IFF_TAP|IFF_NO_PI|IFF_NAPI_FRAGS|IFF_NAPI,
with a vector consisting of 15 elements containing 1 byte each.
Signed-off-by: Jann Horn <jannh@google.com>
[ Upstream commit 2f1ee0913ce58efe7f18fbd518bd54c598559b89 ]
This reverts commit fe53ca54270a ("mm: use early_pfn_to_nid in
page_ext_init").
When booting a system with "page_owner=on",
start_kernel
page_ext_init
invoke_init_callbacks
init_section_page_ext
init_page_owner
init_early_allocated_pages
init_zones_in_node
init_pages_in_zone
lookup_page_ext
page_to_nid
The issue here is that page_to_nid() will not work since some page flags
have no node information until later in page_alloc_init_late() due to
DEFERRED_STRUCT_PAGE_INIT. Hence, it could trigger an out-of-bounds
access with an invalid nid.
UBSAN: Undefined behaviour in ./include/linux/mm.h:1104:50
index 7 is out of range for type 'zone [5]'
Also, kernel will panic since flags were poisoned earlier with,
CONFIG_DEBUG_VM_PGFLAGS=y
CONFIG_NODE_NOT_IN_PAGE_FLAGS=n
start_kernel
setup_arch
pagetable_init
paging_init
sparse_init
sparse_init_nid
memblock_alloc_try_nid_raw
It did not handle it well in init_pages_in_zone() which ends up calling
page_to_nid().
page:ffffea0004200000 is uninitialized and poisoned
raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p))
page_owner info is not active (free page?)
kernel BUG at include/linux/mm.h:990!
RIP: 0010:init_page_owner+0x486/0x520
This means that assumptions behind commit fe53ca54270a ("mm: use
early_pfn_to_nid in page_ext_init") are incomplete. Therefore, revert
the commit for now. A proper way to move the page_owner initialization
to sooner is to hook into memmap initialization.
Link: http://lkml.kernel.org/r/20190115202812.75820-1-cai@lca.pw
Acked-by: Michal Hocko <mhocko@kernel.org>
Cc: Pasha Tatashin <Pavel.Tatashin@microsoft.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Yang Shi <yang.shi@linaro.org>
[ Upstream commit 414fd080d125408cb15d04ff4907e1dd8145c8c7 ]
For dax pmd, pmd_trans_huge() returns false but pmd_huge() returns true
on x86. So the function works as long as hugetlb is configured.
However, dax doesn't depend on hugetlb.
Link: http://lkml.kernel.org/r/20190111034033.601-1-yuzhao@google.com
Signed-off-by: Yu Zhao <yuzhao@google.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Keith Busch <keith.busch@intel.com>
Cc: "Michael S . Tsirkin" <mst@redhat.com>
Cc: Wei Yang <richard.weiyang@gmail.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
[ Upstream commit 24feb47c5fa5b825efb0151f28906dfdad027e61 ]
If memory end is not aligned with the sparse memory section boundary,
the mapping of such a section is only partly initialized. This may lead
to VM_BUG_ON due to uninitialized struct pages access from
test_pages_in_a_zone() function triggered by memory_hotplug sysfs
handlers.
Here are the the panic examples:
kernel parameter mem=2050M
page:000003d082008000 is uninitialized and poisoned
Call Trace:
test_pages_in_a_zone+0xde/0x160
show_valid_zones+0x5c/0x190
dev_attr_show+0x34/0x70
sysfs_kf_seq_show+0xc8/0x148
seq_read+0x204/0x480
__vfs_read+0x32/0x178
vfs_read+0x82/0x138
ksys_read+0x5a/0xb0
system_call+0xdc/0x2d8
Last Breaking-Event-Address:
Kernel panic - not syncing: Fatal exception: panic_on_oops
Fix this by checking whether the pfn to check is within the zone.
[mhocko@suse.com: separated this change from http://lkml.kernel.org/r/20181105150401.97287-2-zaslonko@linux.ibm.com]
Link: http://lkml.kernel.org/r/20190128144506.15603-3-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Mikhail Zaslonko <zaslonko@linux.ibm.com>
Tested-by: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com>
Tested-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Mikhail Gavrilov <mikhail.v.gavrilov@gmail.com>
Cc: Pavel Tatashin <pasha.tatashin@soleen.com>
[ Upstream commit efad4e475c312456edb3c789d0996d12ed744c13 ]
Patch series "mm, memory_hotplug: fix uninitialized pages fallouts", v2.
Mikhail Zaslonko has posted fixes for the two bugs quite some time ago
[1]. I have pushed back on those fixes because I believed that it is
much better to plug the problem at the initialization time rather than
play whack-a-mole all over the hotplug code and find all the places
which expect the full memory section to be initialized.
We have ended up with commit 2830bf6f05fb ("mm, memory_hotplug:
initialize struct pages for the full memory section") merged and cause a
regression [2][3]. The reason is that there might be memory layouts
when two NUMA nodes share the same memory section so the merged fix is
simply incorrect.
In order to plug this hole we really have to be zone range aware in
those handlers. I have split up the original patch into two. One is
unchanged (patch 2) and I took a different approach for `removable'
crash.
[1] http://lkml.kernel.org/r/20181105150401.97287-2-zaslonko@linux.ibm.com
[2] https://bugzilla.redhat.com/show_bug.cgi?id=1666948
[3] http://lkml.kernel.org/r/20190125163938.GA20411@dhcp22.suse.cz
This patch (of 2):
Mikhail has reported the following VM_BUG_ON triggered when reading sysfs
removable state of a memory block:
page:000003d08300c000 is uninitialized and poisoned
Call Trace:
is_mem_section_removable+0xb4/0x190
show_mem_removable+0x9a/0xd8
vfs_read+0x82/0x138
ksys_read+0x5a/0xb0
The reason is that the memory block spans the zone boundary and we are
stumbling over an unitialized struct page. Fix this by enforcing zone
range in is_mem_section_removable so that we never run away from a zone.
Link: http://lkml.kernel.org/r/20190128144506.15603-2-mhocko@kernel.org
Reported-by: Mikhail Zaslonko <zaslonko@linux.ibm.com>
Debugged-by: Mikhail Zaslonko <zaslonko@linux.ibm.com>
commit cb6acd01e2e43fd8bad11155752b7699c3d0fb76 upstream.
hugetlb pages should only be migrated if they are 'active'. The
routines set/clear_page_huge_active() modify the active state of hugetlb
pages.
When a new hugetlb page is allocated at fault time, set_page_huge_active
is called before the page is locked. Therefore, another thread could
race and migrate the page while it is being added to page table by the
fault code. This race is somewhat hard to trigger, but can be seen by
strategically adding udelay to simulate worst case scheduling behavior.
Depending on 'how' the code races, various BUG()s could be triggered.
To address this issue, simply delay the set_page_huge_active call until
after the page is successfully added to the page table.
Hugetlb pages can also be leaked at migration time if the pages are
associated with a file in an explicitly mounted hugetlbfs filesystem.
For example, consider a two node system with 4GB worth of huge pages
available. A program mmaps a 2G file in a hugetlbfs filesystem. It
then migrates the pages associated with the file from one node to
another. When the program exits, huge page counts are as follows:
node0
1024 free_hugepages
1024 nr_hugepages
node1
0 free_hugepages
1024 nr_hugepages
nodev 4.0G 2.0G 2.0G 50% /var/opt/hugepool
That is as expected. 2G of huge pages are taken from the free_hugepages
counts, and 2G is the size of the file in the explicitly mounted
filesystem. If the file is then removed, the counts become:
node0
1024 free_hugepages
1024 nr_hugepages
node1
1024 free_hugepages
1024 nr_hugepages
Note that the filesystem still shows 2G of pages used, while there
actually are no huge pages in use. The only way to 'fix' the filesystem
accounting is to unmount the filesystem
If a hugetlb page is associated with an explicitly mounted filesystem,
this information in contained in the page_private field. At migration
time, this information is not preserved. To fix, simply transfer
page_private from old to new page at migration time if necessary.
There is a related race with removing a huge page from a file and
migration. When a huge page is removed from the pagecache, the
page_mapping() field is cleared, yet page_private remains set until the
page is actually freed by free_huge_page(). A page could be migrated
while in this state. However, since page_mapping() is not set the
hugetlbfs specific routine to transfer page_private is not called and we
leak the page count in the filesystem.
To fix that, check for this condition before migrating a huge page. If
the condition is detected, return EBUSY for the page.
Link: http://lkml.kernel.org/r/74510272-7319-7372-9ea6-ec914734c179@oracle.com
Link: http://lkml.kernel.org/r/20190212221400.3512-1-mike.kravetz@oracle.com
Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active")
[mike.kravetz@oracle.com: v2]
Link: http://lkml.kernel.org/r/7534d322-d782-8ac6-1c8d-a8dc380eb3ab@oracle.com
[mike.kravetz@oracle.com: update comment and changelog]
Link: http://lkml.kernel.org/r/420bcfd6-158b-38e4-98da-26d0cd85bd01@oracle.com
commit 0a1d52994d440e21def1c2174932410b4f2a98a1 upstream.
security_mmap_addr() does a capability check with current_cred(), but
we can reach this code from contexts like a VFS write handler where
current_cred() must not be used.
This can be abused on systems without SMAP to make NULL pointer
dereferences exploitable again.
Fixes: 8869477a49c3 ("security: protect from stack expansion into low vm addresses")
[ Upstream commit 7fc5854f8c6efae9e7624970ab49a1eac2faefb1 ]
sync_inodes_sb() can race against cgwb (cgroup writeback) membership
switches and fail to writeback some inodes. For example, if an inode
switches to another wb while sync_inodes_sb() is in progress, the new
wb might not be visible to bdi_split_work_to_wbs() at all or the inode
might jump from a wb which hasn't issued writebacks yet to one which
already has.
This patch adds backing_dev_info->wb_switch_rwsem to synchronize cgwb
switch path against sync_inodes_sb() so that sync_inodes_sb() is
guaranteed to see all the target wbs and inodes can't jump wbs to
escape syncing.
v2: Fixed misplaced rwsem init. Spotted by Jiufei.
Reported-by: Jiufei Xue <xuejiufei@gmail.com>
Link: http://lkml.kernel.org/r/dc694ae2-f07f-61e1-7097-7c8411cee12d@gmail.com
Acked-by: Jan Kara <jack@suse.cz>
commit 050c17f239fd53adb55aa768d4f41bc76c0fe045 upstream.
The system call, get_mempolicy() [1], passes an unsigned long *nodemask
pointer and an unsigned long maxnode argument which specifies the length
of the user's nodemask array in bits (which is rounded up). The manual
page says that if the maxnode value is too small, get_mempolicy will
return EINVAL but there is no system call to return this minimum value.
To determine this value, some programs search /proc/<pid>/status for a
line starting with "Mems_allowed:" and use the number of digits in the
mask to determine the minimum value. A recent change to the way this line
is formatted [2] causes these programs to compute a value less than
MAX_NUMNODES so get_mempolicy() returns EINVAL.
Change get_mempolicy(), the older compat version of get_mempolicy(), and
the copy_nodes_to_user() function to use nr_node_ids instead of
MAX_NUMNODES, thus preserving the defacto method of computing the minimum
size for the nodemask array and the maxnode argument.
[1] http://man7.org/linux/man-pages/man2/get_mempolicy.2.html
[2] https://lore.kernel.org/lkml/1545405631-6808-1-git-send-email-longman@redhat.com
Link: http://lkml.kernel.org/r/20190211180245.22295-1-rcampbell@nvidia.com
Fixes: 4fb8e5b89bcbbbb ("include/linux/nodemask.h: use nr_node_ids (not MAX_NUMNODES) in __nodemask_pr_numnodes()")
Signed-off-by: Ralph Campbell <rcampbell@nvidia.com>
Suggested-by: Alexander Duyck <alexander.duyck@gmail.com>
Cc: Waiman Long <longman@redhat.com>
[ Upstream commit 6ab7d47bcbf0144a8cb81536c2cead4cde18acfe ]
From Michael Cree:
"Bisection lead to commit b38d08f3181c ("percpu: restructure
locking") as being the cause of lockups at initial boot on
the kernel built for generic Alpha.
On a suggestion by Tejun Heo that:
So, the only thing I can think of is that it's calling
spin_unlock_irq() while irq handling isn't set up yet.
Can you please try the followings?
1. Convert all spin_[un]lock_irq() to
spin_lock_irqsave/unlock_irqrestore()."
Fixes: b38d08f3181c ("percpu: restructure locking")
Reported-and-tested-by: Michael Cree <mcree@orcon.net.nz>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Dennis Zhou <dennis@kernel.org>
That we we can also poll non blk-mq queues. Mostly needed for
the NVMe multipath code, but could also be useful elsewhere.
Reviewed-by: Hannes Reinecke <hare@suse.com>
(cherry picked from commit ea435e1b9392a33deceaea2a16ebaa3397bead93)
commit e0a352fabce61f730341d119fbedf71ffdb8663f upstream.
We had a race in the old balloon compaction code before b1123ea6d3b3
("mm: balloon: use general non-lru movable page feature") refactored it
that became visible after backporting 195a8c43e93d ("virtio-balloon:
deflate via a page list") without the refactoring.
The bug existed from commit d6d86c0a7f8d ("mm/balloon_compaction:
redesign ballooned pages management") till b1123ea6d3b3 ("mm: balloon:
use general non-lru movable page feature"). d6d86c0a7f8d
("mm/balloon_compaction: redesign ballooned pages management") was
backported to 3.12, so the broken kernels are stable kernels [3.12 -
4.7].
There was a subtle race between dropping the page lock of the newpage in
__unmap_and_move() and checking for __is_movable_balloon_page(newpage).
Just after dropping this page lock, virtio-balloon could go ahead and
deflate the newpage, effectively dequeueing it and clearing PageBalloon,
in turn making __is_movable_balloon_page(newpage) fail.
This resulted in dropping the reference of the newpage via
putback_lru_page(newpage) instead of put_page(newpage), leading to
page->lru getting modified and a !LRU page ending up in the LRU lists.
With 195a8c43e93d ("virtio-balloon: deflate via a page list")
backported, one would suddenly get corrupted lists in
release_pages_balloon():
- WARNING: CPU: 13 PID: 6586 at lib/list_debug.c:59 __list_del_entry+0xa1/0xd0
- list_del corruption. prev->next should be ffffe253961090a0, but was dead000000000100
Nowadays this race is no longer possible, but it is hidden behind very
ugly handling of __ClearPageMovable() and __PageMovable().
__ClearPageMovable() will not make __PageMovable() fail, only
PageMovable(). So the new check (__PageMovable(newpage)) will still
hold even after newpage was dequeued by virtio-balloon.
If anybody would ever change that special handling, the BUG would be
introduced again. So instead, make it explicit and use the information
of the original isolated page before migration.
This patch can be backported fairly easy to stable kernels (in contrast
to the refactoring).
Link: http://lkml.kernel.org/r/20190129233217.10747-1-david@redhat.com
Fixes: d6d86c0a7f8d ("mm/balloon_compaction: redesign ballooned pages management")
Signed-off-by: David Hildenbrand <david@redhat.com>
Reported-by: Vratislav Bendel <vbendel@redhat.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Vratislav Bendel <vbendel@redhat.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: <stable@vger.kernel.org> [3.12 - 4.7]
commit 6376360ecbe525a9c17b3d081dfd88ba3e4ed65b upstream.
Currently memory_failure() is racy against process's exiting, which
results in kernel crash by null pointer dereference.
The root cause is that memory_failure() uses force_sig() to forcibly
kill asynchronous (meaning not in the current context) processes. As
discussed in thread https://lkml.org/lkml/2010/6/8/236 years ago for OOM
fixes, this is not a right thing to do. OOM solves this issue by using
do_send_sig_info() as done in commit d2d393099de2 ("signal:
oom_kill_task: use SEND_SIG_FORCED instead of force_sig()"), so this
patch is suggesting to do the same for hwpoison. do_send_sig_info()
properly accesses to siglock with lock_task_sighand(), so is free from
the reported race.
I confirmed that the reported bug reproduces with inserting some delay
in kill_procs(), and it never reproduces with this patch.
Note that memory_failure() can send another type of signal using
force_sig_mceerr(), and the reported race shouldn't happen on it because
force_sig_mceerr() is called only for synchronous processes (i.e.
BUS_MCEERR_AR happens only when some process accesses to the corrupted
memory.)
Link: http://lkml.kernel.org/r/20190116093046.GA29835@hori1.linux.bs1.fc.nec.co.jp
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reported-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Reviewed-by: William Kucharski <william.kucharski@oracle.com>
