This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
commit 24cecc37746393432d994c0dbc251fb9ac7c5d72 upstream.
The ARMv8 64-bit architecture supports execute-only user permissions by
clearing the PTE_USER and PTE_UXN bits, practically making it a mostly
privileged mapping but from which user running at EL0 can still execute.
The downside, however, is that the kernel at EL1 inadvertently reading
such mapping would not trip over the PAN (privileged access never)
protection.
Revert the relevant bits from commit cab15ce604e5 ("arm64: Introduce
execute-only page access permissions") so that PROT_EXEC implies
PROT_READ (and therefore PTE_USER) until the architecture gains proper
support for execute-only user mappings.
Fixes: cab15ce604e5 ("arm64: Introduce execute-only page access permissions")
Cc: <stable@vger.kernel.org> # 4.9.x-
Acked-by: Will Deacon <will@kernel.org>
commit ac8f05da5174c560de122c499ce5dfb5d0dfbee5 upstream.
When zspage is migrated to the other zone, the zone page state should be
updated as well, otherwise the NR_ZSPAGE for each zone shows wrong
counts including proc/zoneinfo in practice.
Link: http://lkml.kernel.org/r/1575434841-48009-1-git-send-email-chanho.min@lge.com
Fixes: 91537fee0013 ("mm: add NR_ZSMALLOC to vmstat")
Signed-off-by: Chanho Min <chanho.min@lge.com>
Signed-off-by: Jinsuk Choi <jjinsuk.choi@lge.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: <stable@vger.kernel.org> [4.9+]
commit aa71ecd8d86500da6081a72da6b0b524007e0627 upstream.
In 64bit system. sb->s_maxbytes of shmem filesystem is MAX_LFS_FILESIZE,
which equal LLONG_MAX.
If offset > LLONG_MAX - PAGE_SIZE, offset + len < LLONG_MAX in
shmem_fallocate, which will pass the checking in vfs_fallocate.
/* Check for wrap through zero too */
if (((offset + len) > inode->i_sb->s_maxbytes) || ((offset + len) < 0))
return -EFBIG;
loff_t unmap_start = round_up(offset, PAGE_SIZE) in shmem_fallocate
causes a overflow.
Syzkaller reports a overflow problem in mm/shmem:
UBSAN: Undefined behaviour in mm/shmem.c:2014:10
signed integer overflow: '9223372036854775807 + 1' cannot be represented in type 'long long int'
CPU: 0 PID:17076 Comm: syz-executor0 Not tainted 4.1.46+ #1
Hardware name: linux, dummy-virt (DT)
Call trace:
dump_backtrace+0x0/0x2c8 arch/arm64/kernel/traps.c:100
show_stack+0x20/0x30 arch/arm64/kernel/traps.c:238
__dump_stack lib/dump_stack.c:15 [inline]
ubsan_epilogue+0x18/0x70 lib/ubsan.c:164
handle_overflow+0x158/0x1b0 lib/ubsan.c:195
shmem_fallocate+0x6d0/0x820 mm/shmem.c:2104
vfs_fallocate+0x238/0x428 fs/open.c:312
SYSC_fallocate fs/open.c:335 [inline]
SyS_fallocate+0x54/0xc8 fs/open.c:239
The highest bit of unmap_start will be appended with sign bit 1
(overflow) when calculate shmem_falloc.start:
shmem_falloc.start = unmap_start >> PAGE_SHIFT.
Fix it by casting the type of unmap_start to u64, when right shifted.
This bug is found in LTS Linux 4.1. It also seems to exist in mainline.
Link: http://lkml.kernel.org/r/1573867464-5107-1-git-send-email-chenjun102@huawei.com
Signed-off-by: Chen Jun <chenjun102@huawei.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Qian Cai <cai@lca.pw>
Cc: Kefeng Wang <wangkefeng.wang@huawei.com>
[ Upstream commit 13c9aaf7fa01cc7600c61981609feadeef3354ec ]
Scan through the whole array to see if an update is needed. While we're
at it, use sizeof() to be safe against any possible type changes in the
future.
The bug here is that we wouldn't sync per-cpu counters into global ones
if there was an update of numa_stats for higher cpus. Highly
theoretical one though because it is much more probable that zone_stats
are updated so we would refresh anyway. So I wouldn't bother to mark
this for stable, yet something nice to fix.
[mhocko@suse.com: changelog enhancement]
Link: http://lkml.kernel.org/r/1541601517-17282-1-git-send-email-janne.huttunen@nokia.com
Fixes: 1d90ca897cb0 ("mm: update NUMA counter threshold size")
Signed-off-by: Janne Huttunen <janne.huttunen@nokia.com>
[ Upstream commit 8b09549c2bfd9f3f8f4cdad74107ef4f4ff9cdd7 ]
Commit fa5e084e43eb ("vmscan: do not unconditionally treat zones that
fail zone_reclaim() as full") changed the return value of
node_reclaim(). The original return value 0 means NODE_RECLAIM_SOME
after this commit.
While the return value of node_reclaim() when CONFIG_NUMA is n is not
changed. This will leads to call zone_watermark_ok() again.
This patch fixes the return value by adjusting to NODE_RECLAIM_NOSCAN.
Since node_reclaim() is only called in page_alloc.c, move it to
mm/internal.h.
Link: http://lkml.kernel.org/r/20181113080436.22078-1-richard.weiyang@gmail.com
Signed-off-by: Wei Yang <richard.weiyang@gmail.com>
Reviewed-by: Matthew Wilcox <willy@infradead.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit 7ce700bf11b5e2cb84e4352bbdf2123a7a239c84 upstream.
Let's limit shrinking to !ZONE_DEVICE so we can fix the current code.
We should never try to touch the memmap of offline sections where we
could have uninitialized memmaps and could trigger BUGs when calling
page_to_nid() on poisoned pages.
There is no reliable way to distinguish an uninitialized memmap from an
initialized memmap that belongs to ZONE_DEVICE, as we don't have
anything like SECTION_IS_ONLINE we can use similar to
pfn_to_online_section() for !ZONE_DEVICE memory.
E.g., set_zone_contiguous() similarly relies on pfn_to_online_section()
and will therefore never set a ZONE_DEVICE zone consecutive. Stopping
to shrink the ZONE_DEVICE therefore results in no observable changes,
besides /proc/zoneinfo indicating different boundaries - something we
can totally live with.
Before commit d0dc12e86b31 ("mm/memory_hotplug: optimize memory
hotplug"), the memmap was initialized with 0 and the node with the right
value. So the zone might be wrong but not garbage. After that commit,
both the zone and the node will be garbage when touching uninitialized
memmaps.
Toshiki reported a BUG (race between delayed initialization of
ZONE_DEVICE memmaps without holding the memory hotplug lock and
concurrent zone shrinking).
https://lkml.org/lkml/2019/11/14/1040
"Iteration of create and destroy namespace causes the panic as below:
kernel BUG at mm/page_alloc.c:535!
CPU: 7 PID: 2766 Comm: ndctl Not tainted 5.4.0-rc4 #6
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.11.0-0-g63451fca13-prebuilt.qemu-project.org 04/01/2014
RIP: 0010:set_pfnblock_flags_mask+0x95/0xf0
Call Trace:
memmap_init_zone_device+0x165/0x17c
memremap_pages+0x4c1/0x540
devm_memremap_pages+0x1d/0x60
pmem_attach_disk+0x16b/0x600 [nd_pmem]
nvdimm_bus_probe+0x69/0x1c0
really_probe+0x1c2/0x3e0
driver_probe_device+0xb4/0x100
device_driver_attach+0x4f/0x60
bind_store+0xc9/0x110
kernfs_fop_write+0x116/0x190
vfs_write+0xa5/0x1a0
ksys_write+0x59/0xd0
do_syscall_64+0x5b/0x180
entry_SYSCALL_64_after_hwframe+0x44/0xa9
While creating a namespace and initializing memmap, if you destroy the
namespace and shrink the zone, it will initialize the memmap outside
the zone and trigger VM_BUG_ON_PAGE(!zone_spans_pfn(page_zone(page),
pfn), page) in set_pfnblock_flags_mask()."
This BUG is also mitigated by this commit, where we for now stop to
shrink the ZONE_DEVICE zone until we can do it in a safe and clean way.
Link: http://lkml.kernel.org/r/20191006085646.5768-5-david@redhat.com
Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [visible after d0dc12e86b319]
Signed-off-by: David Hildenbrand <david@redhat.com>
Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Reported-by: Toshiki Fukasawa <t-fukasawa@vx.jp.nec.com>
Cc: Oscar Salvador <osalvador@suse.de>
Cc: David Hildenbrand <david@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Pavel Tatashin <pasha.tatashin@soleen.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Alexander Duyck <alexander.h.duyck@linux.intel.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Damian Tometzki <damian.tometzki@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Halil Pasic <pasic@linux.ibm.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Jun Yao <yaojun8558363@gmail.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: "Matthew Wilcox (Oracle)" <willy@infradead.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Pankaj Gupta <pagupta@redhat.com>
Cc: Pavel Tatashin <pavel.tatashin@microsoft.com>
Cc: Rich Felker <dalias@libc.org>
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: Steve Capper <steve.capper@arm.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Cc: Wei Yang <richard.weiyang@gmail.com>
Cc: Wei Yang <richardw.yang@linux.intel.com>
Cc: Will Deacon <will@kernel.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Yu Zhao <yuzhao@google.com>
Cc: <stable@vger.kernel.org> [4.13+]
[ Upstream commit 8df1d0e4a265f25dc1e7e7624ccdbcb4a6630c89 ]
add_memory() currently does not take the device_hotplug_lock, however
is aleady called under the lock from
arch/powerpc/platforms/pseries/hotplug-memory.c
drivers/acpi/acpi_memhotplug.c
to synchronize against CPU hot-remove and similar.
In general, we should hold the device_hotplug_lock when adding memory to
synchronize against online/offline request (e.g. from user space) - which
already resulted in lock inversions due to device_lock() and
mem_hotplug_lock - see 30467e0b3be ("mm, hotplug: fix concurrent memory
hot-add deadlock"). add_memory()/add_memory_resource() will create memory
block devices, so this really feels like the right thing to do.
Holding the device_hotplug_lock makes sure that a memory block device
can really only be accessed (e.g. via .online/.state) from user space,
once the memory has been fully added to the system.
The lock is not held yet in
drivers/xen/balloon.c
arch/powerpc/platforms/powernv/memtrace.c
drivers/s390/char/sclp_cmd.c
drivers/hv/hv_balloon.c
So, let's either use the locked variants or take the lock.
Don't export add_memory_resource(), as it once was exported to be used by
XEN, which is never built as a module. If somebody requires it, we also
have to export a locked variant (as device_hotplug_lock is never
exported).
Link: http://lkml.kernel.org/r/20180925091457.28651-3-david@redhat.com
Reviewed-by: Pavel Tatashin <pavel.tatashin@microsoft.com>
Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Reviewed-by: Rashmica Gupta <rashmica.g@gmail.com>
Reviewed-by: Oscar Salvador <osalvador@suse.de>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: Len Brown <lenb@kernel.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Cc: John Allen <jallen@linux.vnet.ibm.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mathieu Malaterre <malat@debian.org>
Cc: YASUAKI ISHIMATSU <yasu.isimatu@gmail.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
[ Upstream commit 64081362e8ff4587b4554087f3cfc73d3e0a4cd7 ]
We've recently seen a workload on XFS filesystems with a repeatable
deadlock between background writeback and a multi-process application
doing concurrent writes and fsyncs to a small range of a file.
range_cyclic
writeback Process 1 Process 2
xfs_vm_writepages
write_cache_pages
writeback_index = 2
cycled = 0
find page 2 dirty
lock Page 2
->writepage
page 2 writeback
page 2 clean
page 2 added to bio
no more pages
write()
locks page 1
dirties page 1
locks page 2
dirties page 1
fsync()
xfs_vm_writepages
write_cache_pages
start index 0
find page 1 towrite
lock Page 1
->writepage
page 1 writeback
page 1 clean
page 1 added to bio
find page 2 towrite
lock Page 2
page 2 is writeback
<blocks>
write()
locks page 1
dirties page 1
fsync()
xfs_vm_writepages
write_cache_pages
start index 0
!done && !cycled
sets index to 0, restarts lookup
find page 1 dirty
find page 1 towrite
lock Page 1
page 1 is writeback
<blocks>
lock Page 1
<blocks>
DEADLOCK because:
- process 1 needs page 2 writeback to complete to make
enough progress to issue IO pending for page 1
- writeback needs page 1 writeback to complete so process 2
can progress and unlock the page it is blocked on, then it
can issue the IO pending for page 2
- process 2 can't make progress until process 1 issues IO
for page 1
The underlying cause of the problem here is that range_cyclic writeback is
processing pages in descending index order as we hold higher index pages
in a structure controlled from above write_cache_pages(). The
write_cache_pages() caller needs to be able to submit these pages for IO
before write_cache_pages restarts writeback at mapping index 0 to avoid
wcp inverting the page lock/writeback wait order.
generic_writepages() is not susceptible to this bug as it has no private
context held across write_cache_pages() - filesystems using this
infrastructure always submit pages in ->writepage immediately and so there
is no problem with range_cyclic going back to mapping index 0.
However:
mpage_writepages() has a private bio context,
exofs_writepages() has page_collect
fuse_writepages() has fuse_fill_wb_data
nfs_writepages() has nfs_pageio_descriptor
xfs_vm_writepages() has xfs_writepage_ctx
All of these ->writepages implementations can hold pages under writeback
in their private structures until write_cache_pages() returns, and hence
they are all susceptible to this deadlock.
Also worth noting is that ext4 has it's own bastardised version of
write_cache_pages() and so it /may/ have an equivalent deadlock. I looked
at the code long enough to understand that it has a similar retry loop for
range_cyclic writeback reaching the end of the file and then promptly ran
away before my eyes bled too much. I'll leave it for the ext4 developers
to determine if their code is actually has this deadlock and how to fix it
if it has.
There's a few ways I can see avoid this deadlock. There's probably more,
but these are the first I've though of:
1. get rid of range_cyclic altogether
2. range_cyclic always stops at EOF, and we start again from
writeback index 0 on the next call into write_cache_pages()
2a. wcp also returns EAGAIN to ->writepages implementations to
indicate range cyclic has hit EOF. writepages implementations can
then flush the current context and call wpc again to continue. i.e.
lift the retry into the ->writepages implementation
3. range_cyclic uses trylock_page() rather than lock_page(), and it
skips pages it can't lock without blocking. It will already do this
for pages under writeback, so this seems like a no-brainer
3a. all non-WB_SYNC_ALL writeback uses trylock_page() to avoid
blocking as per pages under writeback.
I don't think #1 is an option - range_cyclic prevents frequently
dirtied lower file offset from starving background writeback of
rarely touched higher file offsets.
#2 is simple, and I don't think it will have any impact on
performance as going back to the start of the file implies an
immediate seek. We'll have exactly the same number of seeks if we
switch writeback to another inode, and then come back to this one
later and restart from index 0.
#2a is pretty much "status quo without the deadlock". Moving the
retry loop up into the wcp caller means we can issue IO on the
pending pages before calling wcp again, and so avoid locking or
waiting on pages in the wrong order. I'm not convinced we need to do
this given that we get the same thing from #2 on the next writeback
call from the writeback infrastructure.
#3 is really just a band-aid - it doesn't fix the access/wait
inversion problem, just prevents it from becoming a deadlock
situation. I'd prefer we fix the inversion, not sweep it under the
carpet like this.
#3a is really an optimisation that just so happens to include the
band-aid fix of #3.
So it seems that the simplest way to fix this issue is to implement
solution #2
Link: http://lkml.kernel.org/r/20181005054526.21507-1-david@fromorbit.com
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Jan Kara <jack@suse.de>
Cc: Nicholas Piggin <npiggin@gmail.com>
commit 9a63236f1ad82d71a98aa80320b6cb618fb32f44 upstream.
It's possible to hit the WARN_ON_ONCE(page_mapped(page)) in
remove_stable_node() when it races with __mmput() and squeezes in
between ksm_exit() and exit_mmap().
WARNING: CPU: 0 PID: 3295 at mm/ksm.c:888 remove_stable_node+0x10c/0x150
Call Trace:
remove_all_stable_nodes+0x12b/0x330
run_store+0x4ef/0x7b0
kernfs_fop_write+0x200/0x420
vfs_write+0x154/0x450
ksys_write+0xf9/0x1d0
do_syscall_64+0x99/0x510
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Remove the warning as there is nothing scary going on.
Link: http://lkml.kernel.org/r/20191119131850.5675-1-aryabinin@virtuozzo.com
Fixes: cbf86cfe04a6 ("ksm: remove old stable nodes more thoroughly")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit 656d571193262a11c2daa4012e53e4d645bbce56 upstream.
We recently started updating the node span based on the zone span to
avoid touching uninitialized memmaps.
Currently, we will always detect the node span to start at 0, meaning a
node can easily span too many pages. pgdat_is_empty() will still work
correctly if all zones span no pages. We should skip over all zones
without spanned pages and properly handle the first detected zone that
spans pages.
Unfortunately, in contrast to the zone span (/proc/zoneinfo), the node
span cannot easily be inspected and tested. The node span gives no real
guarantees when an architecture supports memory hotplug, meaning it can
easily contain holes or span pages of different nodes.
The node span is not really used after init on architectures that
support memory hotplug.
E.g., we use it in mm/memory_hotplug.c:try_offline_node() and in
mm/kmemleak.c:kmemleak_scan(). These users seem to be fine.
Link: http://lkml.kernel.org/r/20191027222714.5313-1-david@redhat.com
Fixes: 00d6c019b5bc ("mm/memory_hotplug: don't access uninitialized memmaps in shrink_pgdat_span()")
commit 00d6c019b5bc175cee3770e0e659f2b5f4804ea5 upstream.
We might use the nid of memmaps that were never initialized. For
example, if the memmap was poisoned, we will crash the kernel in
pfn_to_nid() right now. Let's use the calculated boundaries of the
separate zones instead. This now also avoids having to iterate over a
whole bunch of subsections again, after shrinking one zone.
hotplug"), the memmap was initialized to 0 and the node was set to the
right value. After that commit, the node might be garbage.
We'll have to fix shrink_zone_span() next.
Link: http://lkml.kernel.org/r/20191006085646.5768-4-david@redhat.com
Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") [d0dc12e86b319]
The commit 391d4ee568b5 ("memfd: Fix locking when tagging pins")
introduces the following warning messages.
*WARNING: suspicious RCU usage in memfd_wait_for_pins*
It is because we still use radix_tree_deref_slot without read_rcu_lock.
We should use radix_tree_deref_slot_protected instead in the case.
Cc: stable@vger.kernel.org
Fixes: 391d4ee568b5 ("memfd: Fix locking when tagging pins")
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 0362f326d86c645b5e96b7dbc3ee515986ed019d upstream.
An exiting task might belong to an offline cgroup. In this case an
attempt to grab a cgroup reference from the task can end up with an
infinite loop in hugetlb_cgroup_charge_cgroup(), because neither the
cgroup will become online, neither the task will be migrated to a live
cgroup.
Fix this by switching over to css_tryget(). As css_tryget_online()
can't guarantee that the cgroup won't go offline, in most cases the
check doesn't make sense. In this particular case users of
hugetlb_cgroup_charge_cgroup() are not affected by this change.
A similar problem is described by commit 18fa84a2db0e ("cgroup: Use
css_tryget() instead of css_tryget_online() in task_get_css()").
Link: http://lkml.kernel.org/r/20191106225131.3543616-2-guro@fb.com
Signed-off-by: Roman Gushchin <guro@fb.com>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Shakeel Butt <shakeelb@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit 00d484f354d85845991b40141d40ba9e5eb60faf upstream.
We've encountered a rcu stall in get_mem_cgroup_from_mm():
rcu: INFO: rcu_sched self-detected stall on CPU
rcu: 33-....: (21000 ticks this GP) idle=6c6/1/0x4000000000000002 softirq=35441/35441 fqs=5017
(t=21031 jiffies g=324821 q=95837) NMI backtrace for cpu 33
RIP: 0010:get_mem_cgroup_from_mm+0x2f/0x90
__memcg_kmem_charge+0x55/0x140
__alloc_pages_nodemask+0x267/0x320
pipe_write+0x1ad/0x400
new_sync_write+0x127/0x1c0
__kernel_write+0x4f/0xf0
dump_emit+0x91/0xc0
writenote+0xa0/0xc0
elf_core_dump+0x11af/0x1430
do_coredump+0xc65/0xee0
get_signal+0x132/0x7c0
do_signal+0x36/0x640
exit_to_usermode_loop+0x61/0xd0
do_syscall_64+0xd4/0x100
The problem is caused by an exiting task which is associated with an
offline memcg. We're iterating over and over in the do {} while
(!css_tryget_online()) loop, but obviously the memcg won't become online
and the exiting task won't be migrated to a live memcg.
Let's fix it by switching from css_tryget_online() to css_tryget().
As css_tryget_online() cannot guarantee that the memcg won't go offline,
the check is usually useless, except some rare cases when for example it
determines if something should be presented to a user.
Johannes:
: The bug aside, it doesn't matter whether the cgroup is online for the
: callers. It used to matter when offlining needed to evacuate all charges
: from the memcg, and so needed to prevent new ones from showing up, but we
: don't care now.
Link: http://lkml.kernel.org/r/20191106225131.3543616-1-guro@fb.com
Reviewed-by: Shakeel Butt <shakeeb@google.com>
Cc: Michal Koutn <mkoutny@suse.com>
commit c3aab9a0bd91b696a852169479b7db1ece6cbf8c upstream.
Functions like filemap_write_and_wait_range() should do nothing if inode
has no dirty pages or pages currently under writeback. But they anyway
construct struct writeback_control and this does some atomic operations if
CONFIG_CGROUP_WRITEBACK=y - on fast path it locks inode->i_lock and
updates state of writeback ownership, on slow path might be more work.
Current this path is safely avoided only when inode mapping has no pages.
For example generic_file_read_iter() calls filemap_write_and_wait_range()
at each O_DIRECT read - pretty hot path.
This patch skips starting new writeback if mapping has no dirty tags set.
If writeback is already in progress filemap_write_and_wait_range() will
wait for it.
Link: http://lkml.kernel.org/r/156378816804.1087.8607636317907921438.stgit@buzz
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Tejun Heo <tj@kernel.org>
commit abaed0112c1db08be15a784a2c5c8a8b3063cdd3 upstream.
/proc/pagetypeinfo is a debugging tool to examine internal page
allocator state wrt to fragmentation. It is not very useful for any
other use so normal users really do not need to read this file.
Waiman Long has noticed that reading this file can have negative side
effects because zone->lock is necessary for gathering data and that a)
interferes with the page allocator and its users and b) can lead to hard
lockups on large machines which have very long free_list.
Reduce both issues by simply not exporting the file to regular users.
Link: http://lkml.kernel.org/r/20191025072610.18526-2-mhocko@kernel.org
Fixes: 467c996c1e19 ("Print out statistics in relation to fragmentation avoidance to /proc/pagetypeinfo")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Waiman Long <longman@redhat.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Waiman Long <longman@redhat.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Roman Gushchin <guro@fb.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Jann Horn <jannh@google.com>
Cc: Song Liu <songliubraving@fb.com>
commit f231fe4235e22e18d847e05cbe705deaca56580a upstream.
Uninitialized memmaps contain garbage and in the worst case trigger
kernel BUGs, especially with CONFIG_PAGE_POISONING. They should not get
touched.
Let's make sure that we only consider online memory (managed by the
buddy) that has initialized memmaps. ZONE_DEVICE is not applicable.
page_zone() will call page_to_nid(), which will trigger
VM_BUG_ON_PGFLAGS(PagePoisoned(page), page) with CONFIG_PAGE_POISONING
and CONFIG_DEBUG_VM_PGFLAGS when called on uninitialized memmaps. This
can be the case when an offline memory block (e.g., never onlined) is
spanned by a zone.
Note: As explained by Michal in [1], alloc_contig_range() will verify
the range. So it boils down to the wrong access in this function.
[1] http://lkml.kernel.org/r/20180423000943.GO17484@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/20191015120717.4858-1-david@redhat.com
Reported-by: Michal Hocko <mhocko@kernel.org>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
/proc/pagetypeinfo
commit a26ee565b6cd8dc2bf15ff6aa70bbb28f928b773 upstream.
touched.
For example, when not onlining a memory block that is spanned by a zone
and reading /proc/pagetypeinfo with CONFIG_DEBUG_VM_PGFLAGS and
CONFIG_PAGE_POISONING, we can trigger a kernel BUG:
:/# echo 1 > /sys/devices/system/memory/memory40/online
:/# echo 1 > /sys/devices/system/memory/memory42/online
:/# cat /proc/pagetypeinfo > test.file
page:fffff2c585200000 is uninitialized and poisoned
raw: ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
page dumped because: VM_BUG_ON_PAGE(PagePoisoned(p))
There is not page extension available.
kernel BUG at include/linux/mm.h:1107!
invalid opcode: 0000 [#1] SMP NOPTI
Please note that this change does not affect ZONE_DEVICE, because
pagetypeinfo_showmixedcount_print() is called from
mm/vmstat.c:pagetypeinfo_showmixedcount() only for populated zones, and
ZONE_DEVICE is never populated (zone->present_pages always 0).
[david@redhat.com: move check to outer loop, add comment, rephrase description]
Link: http://lkml.kernel.org/r/20191011140638.8160-1-david@redhat.com
Fixes: f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") # visible after d0dc12e86b319
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Miles Chen <miles.chen@mediatek.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
commit e4f8e513c3d353c134ad4eef9fd0bba12406c7c8 upstream.
A long time ago we fixed a similar deadlock in show_slab_objects() [1].
However, it is apparently due to the commits like 01fb58bcba63 ("slab:
remove synchronous synchronize_sched() from memcg cache deactivation
path") and 03afc0e25f7f ("slab: get_online_mems for
kmem_cache_{create,destroy,shrink}"), this kind of deadlock is back by
just reading files in /sys/kernel/slab which will generate a lockdep
splat below.
Since the "mem_hotplug_lock" here is only to obtain a stable online node
mask while racing with NUMA node hotplug, in the worst case, the results
may me miscalculated while doing NUMA node hotplug, but they shall be
corrected by later reads of the same files.
WARNING: possible circular locking dependency detected
cat/5224 is trying to acquire lock:
ffff900012ac3120 (mem_hotplug_lock.rw_sem){++++}, at:
show_slab_objects+0x94/0x3a8
but task is already holding lock:
b8ff009693eee398 (kn->count#45){++++}, at: kernfs_seq_start+0x44/0xf0
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (kn->count#45){++++}:
lock_acquire+0x31c/0x360
__kernfs_remove+0x290/0x490
kernfs_remove+0x30/0x44
sysfs_remove_dir+0x70/0x88
kobject_del+0x50/0xb0
sysfs_slab_unlink+0x2c/0x38
shutdown_cache+0xa0/0xf0
kmemcg_cache_shutdown_fn+0x1c/0x34
kmemcg_workfn+0x44/0x64
process_one_work+0x4f4/0x950
worker_thread+0x390/0x4bc
kthread+0x1cc/0x1e8
ret_from_fork+0x10/0x18
-> #1 (slab_mutex){+.+.}:
__mutex_lock_common+0x16c/0xf78
mutex_lock_nested+0x40/0x50
memcg_create_kmem_cache+0x38/0x16c
memcg_kmem_cache_create_func+0x3c/0x70
kthread+0x1cc/0x1e8
-> #0 (mem_hotplug_lock.rw_sem){++++}:
validate_chain+0xd10/0x2bcc
__lock_acquire+0x7f4/0xb8c
get_online_mems+0x54/0x150
total_objects_show+0x28/0x34
slab_attr_show+0x38/0x54
sysfs_kf_seq_show+0x198/0x2d4
kernfs_seq_show+0xa4/0xcc
seq_read+0x30c/0x8a8
kernfs_fop_read+0xa8/0x314
__vfs_read+0x88/0x20c
vfs_read+0xd8/0x10c
ksys_read+0xb0/0x120
__arm64_sys_read+0x54/0x88
el0_svc_handler+0x170/0x240
el0_svc+0x8/0xc
Chain exists of:
mem_hotplug_lock.rw_sem --> slab_mutex --> kn->count#45
Possible unsafe locking scenario:
CPU0 CPU1
lock(kn->count#45);
lock(slab_mutex);
lock(kn->count#45);
lock(mem_hotplug_lock.rw_sem);
*** DEADLOCK ***
3 locks held by cat/5224:
#0: 9eff00095b14b2a0 (&p->lock){+.+.}, at: seq_read+0x4c/0x8a8
#1: 0eff008997041480 (&of->mutex){+.+.}, at: kernfs_seq_start+0x34/0xf0
#2: b8ff009693eee398 (kn->count#45){++++}, at:
stack backtrace:
Call trace:
dump_backtrace+0x0/0x248
show_stack+0x20/0x2c
dump_stack+0xd0/0x140
print_circular_bug+0x368/0x380
check_noncircular+0x248/0x250
vfs_read+0xd8/0x10c
el0_svc+0x8/0xc
I think it is important to mention that this doesn't expose the
show_slab_objects to use-after-free. There is only a single path that
might really race here and that is the slab hotplug notifier callback
__kmem_cache_shrink (via slab_mem_going_offline_callback) but that path
doesn't really destroy kmem_cache_node data structures.
[1] http://lkml.iu.edu/hypermail/linux/kernel/1101.0/02850.html
[akpm@linux-foundation.org: add comment explaining why we don't need mem_hotplug_lock]
Link: http://lkml.kernel.org/r/1570192309-10132-1-git-send-email-cai@lca.pw
Fixes: 01fb58bcba63 ("slab: remove synchronous synchronize_sched() from memcg cache deactivation path")
Fixes: 03afc0e25f7f ("slab: get_online_mems for kmem_cache_{create,destroy,shrink}")
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
The RCU lock is insufficient to protect the radix tree iteration as
a deletion from the tree can occur before we take the spinlock to
tag the entry. In 4.19, this has manifested as a bug with the following
trace:
kernel BUG at lib/radix-tree.c:1429!
invalid opcode: 0000 [#1] SMP KASAN PTI
CPU: 7 PID: 6935 Comm: syz-executor.2 Not tainted 4.19.36 #25
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
RIP: 0010:radix_tree_tag_set+0x200/0x2f0 lib/radix-tree.c:1429
Code: 00 00 5b 5d 41 5c 41 5d 41 5e 41 5f c3 48 89 44 24 10 e8 a3 29 7e fe 48 8b 44 24 10 48 0f ab 03 e9 d2 fe ff ff e8 90 29 7e fe <0f> 0b 48 c7 c7 e0 5a 87 84 e8 f0 e7 08 ff 4c 89 ef e8 4a ff ac fe
RSP: 0018:ffff88837b13fb60 EFLAGS: 00010016
RAX: 0000000000040000 RBX: ffff8883c5515d58 RCX: ffffffff82cb2ef0
RDX: 0000000000000b72 RSI: ffffc90004cf2000 RDI: ffff8883c5515d98
RBP: ffff88837b13fb98 R08: ffffed106f627f7e R09: ffffed106f627f7e
R10: 0000000000000001 R11: ffffed106f627f7d R12: 0000000000000004
R13: ffffea000d7fea80 R14: 1ffff1106f627f6f R15: 0000000000000002
FS: 00007fa1b8df2700(0000) GS:ffff8883e2fc0000(0000) knlGS:0000000000000000
CR2: 00007fa1b8df1db8 CR3: 000000037d4d2001 CR4: 0000000000160ee0
Call Trace:
memfd_tag_pins mm/memfd.c:51 [inline]
memfd_wait_for_pins+0x2c5/0x12d0 mm/memfd.c:81
memfd_add_seals mm/memfd.c:215 [inline]
memfd_fcntl+0x33d/0x4a0 mm/memfd.c:247
do_fcntl+0x589/0xeb0 fs/fcntl.c:421
__do_sys_fcntl fs/fcntl.c:463 [inline]
__se_sys_fcntl fs/fcntl.c:448 [inline]
__x64_sys_fcntl+0x12d/0x180 fs/fcntl.c:448
do_syscall_64+0xc8/0x580 arch/x86/entry/common.c:293
The problem does not occur in mainline due to the XArray rewrite which
changed the locking to exclude modification of the tree during iteration.
At the time, nobody realised this was a bugfix. Backport the locking
changes to stable.
Reported-by: zhong jiang <zhongjiang@huawei.com>
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 314eed30ede02fa925990f535652254b5bad6b65 upstream.
When running on a system with >512MB RAM with a 32-bit kernel built with:
CONFIG_DEBUG_VIRTUAL=y
CONFIG_HIGHMEM=y
CONFIG_HARDENED_USERCOPY=y
all execve()s will fail due to argv copying into kmap()ed pages, and on
usercopy checking the calls ultimately of virt_to_page() will be looking
for "bad" kmap (highmem) pointers due to CONFIG_DEBUG_VIRTUAL=y:
kernel BUG at ../arch/x86/mm/physaddr.c:83!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.3.0-rc8 #6
Hardware name: Dell Inc. Inspiron 1318/0C236D, BIOS A04 01/15/2009
EIP: __phys_addr+0xaf/0x100
Call Trace:
__check_object_size+0xaf/0x3c0
? __might_sleep+0x80/0xa0
copy_strings+0x1c2/0x370
copy_strings_kernel+0x2b/0x40
__do_execve_file+0x4ca/0x810
? kmem_cache_alloc+0x1c7/0x370
do_execve+0x1b/0x20
The check is from arch/x86/mm/physaddr.c:
VIRTUAL_BUG_ON((phys_addr >> PAGE_SHIFT) > max_low_pfn);
Due to the kmap() in fs/exec.c:
kaddr = kmap(kmapped_page);
if (copy_from_user(kaddr+offset, str, bytes_to_copy)) ...
Now we can fetch the correct page to avoid the pfn check. In both cases,
hardened usercopy will need to walk the page-span checker (if enabled)
to do sanity checking.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
Fixes: f5509cc18daa ("mm: Hardened usercopy")
Cc: Matthew Wilcox <willy@infradead.org>
Link: https://lore.kernel.org/r/201909171056.7F2FFD17@keescook
[ Upstream commit a94b525241c0fff3598809131d7cfcfe1d572d8c ]
total_{migrate,free}_scanned will be added to COMPACTMIGRATE_SCANNED and
COMPACTFREE_SCANNED in compact_zone(). We should clear them before
scanning a new zone. In the proc triggered compaction, we forgot clearing
them.
[laoar.shao@gmail.com: introduce a helper compact_zone_counters_init()]
Link: http://lkml.kernel.org/r/1563869295-25748-1-git-send-email-laoar.shao@gmail.com
[akpm@linux-foundation.org: expand compact_zone_counters_init() into its single callsite, per mhocko]
[vbabka@suse.cz: squash compact_zone() list_head init as well]
Link: http://lkml.kernel.org/r/1fb6f7da-f776-9e42-22f8-bbb79b030b98@suse.cz
[akpm@linux-foundation.org: kcompactd_do_work(): avoid unnecessary initialization of cc.zone]
Link: http://lkml.kernel.org/r/1563789275-9639-1-git-send-email-laoar.shao@gmail.com
Fixes: 7f354a548d1c ("mm, compaction: add vmstats for kcompactd work")
Signed-off-by: Yafang Shao <laoar.shao@gmail.com>
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Yafang Shao <shaoyafang@didiglobal.com>
commit e55d9d9bfb69405bd7615c0f8d229d8fafb3e9b8 upstream.
Thomas has noticed the following NULL ptr dereference when using cgroup
v1 kmem limit:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
PGD 0
P4D 0
Oops: 0000 [#1] PREEMPT SMP PTI
CPU: 3 PID: 16923 Comm: gtk-update-icon Not tainted 4.19.51 #42
Hardware name: Gigabyte Technology Co., Ltd. Z97X-Gaming G1/Z97X-Gaming G1, BIOS F9 07/31/2015
RIP: 0010:create_empty_buffers+0x24/0x100
Code: cd 0f 1f 44 00 00 0f 1f 44 00 00 41 54 49 89 d4 ba 01 00 00 00 55 53 48 89 fb e8 97 fe ff ff 48 89 c5 48 89 c2 eb 03 48 89 ca <48> 8b 4a 08 4c 09 22 48 85 c9 75 f1 48 89 6a 08 48 8b 43 18 48 8d
RSP: 0018:ffff927ac1b37bf8 EFLAGS: 00010286
RAX: 0000000000000000 RBX: fffff2d4429fd740 RCX: 0000000100097149
RDX: 0000000000000000 RSI: 0000000000000082 RDI: ffff9075a99fbe00
RBP: 0000000000000000 R08: fffff2d440949cc8 R09: 00000000000960c0
R10: 0000000000000002 R11: 0000000000000000 R12: 0000000000000000
R13: ffff907601f18360 R14: 0000000000002000 R15: 0000000000001000
FS: 00007fb55b288bc0(0000) GS:ffff90761f8c0000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000007aebc002 CR4: 00000000001606e0
Call Trace:
create_page_buffers+0x4d/0x60
__block_write_begin_int+0x8e/0x5a0
? ext4_inode_attach_jinode.part.82+0xb0/0xb0
? jbd2__journal_start+0xd7/0x1f0
ext4_da_write_begin+0x112/0x3d0
generic_perform_write+0xf1/0x1b0
? file_update_time+0x70/0x140
__generic_file_write_iter+0x141/0x1a0
ext4_file_write_iter+0xef/0x3b0
__vfs_write+0x17e/0x1e0
ksys_write+0x57/0xd0
do_syscall_64+0x55/0x160
Tetsuo then noticed that this is because the __memcg_kmem_charge_memcg
fails __GFP_NOFAIL charge when the kmem limit is reached. This is a wrong
behavior because nofail allocations are not allowed to fail. Normal
charge path simply forces the charge even if that means to cross the
limit. Kmem accounting should be doing the same.
Link: http://lkml.kernel.org/r/20190906125608.32129-1-mhocko@kernel.org
Reported-by: Thomas Lindroth <thomas.lindroth@gmail.com>
Debugged-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Thomas Lindroth <thomas.lindroth@gmail.com>
Cc: Shakeel Butt <shakeelb@google.com>
commit f9c645621a28e37813a1de96d9cbd89cde94a1e4 upstream.
Masoud Sharbiani noticed that commit 29ef680ae7c21110 ("memcg, oom: move
out_of_memory back to the charge path") broke memcg OOM called from
__xfs_filemap_fault() path. It turned out that try_charge() is retrying
forever without making forward progress because mem_cgroup_oom(GFP_NOFS)
cannot invoke the OOM killer due to commit 3da88fb3bacfaa33 ("mm, oom:
move GFP_NOFS check to out_of_memory").
Allowing forced charge due to being unable to invoke memcg OOM killer will
lead to global OOM situation. Also, just returning -ENOMEM will be risky
because OOM path is lost and some paths (e.g. get_user_pages()) will leak
-ENOMEM. Therefore, invoking memcg OOM killer (despite GFP_NOFS) will be
the only choice we can choose for now.
Until 29ef680ae7c21110, we were able to invoke memcg OOM killer when
GFP_KERNEL reclaim failed [1]. But since 29ef680ae7c21110, we need to
invoke memcg OOM killer when GFP_NOFS reclaim failed [2]. Although in the
past we did invoke memcg OOM killer for GFP_NOFS [3], we might get
pre-mature memcg OOM reports due to this patch.
[1]
leaker invoked oom-killer: gfp_mask=0x6200ca(GFP_HIGHUSER_MOVABLE), nodemask=(null), order=0, oom_score_adj=0
CPU: 0 PID: 2746 Comm: leaker Not tainted 4.18.0+ #19
Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 04/13/2018
Call Trace:
dump_stack+0x63/0x88
dump_header+0x67/0x27a
? mem_cgroup_scan_tasks+0x91/0xf0
oom_kill_process+0x210/0x410
out_of_memory+0x10a/0x2c0
mem_cgroup_out_of_memory+0x46/0x80
mem_cgroup_oom_synchronize+0x2e4/0x310
? high_work_func+0x20/0x20
pagefault_out_of_memory+0x31/0x76
mm_fault_error+0x55/0x115
? handle_mm_fault+0xfd/0x220
__do_page_fault+0x433/0x4e0
do_page_fault+0x22/0x30
? page_fault+0x8/0x30
page_fault+0x1e/0x30
RIP: 0033:0x4009f0
Code: 03 00 00 00 e8 71 fd ff ff 48 83 f8 ff 49 89 c6 74 74 48 89 c6 bf c0 0c 40 00 31 c0 e8 69 fd ff ff 45 85 ff 7e 21 31 c9 66 90 <41> 0f be 14 0e 01 d3 f7 c1 ff 0f 00 00 75 05 41 c6 04 0e 2a 48 83
RSP: 002b:00007ffe29ae96f0 EFLAGS: 00010206
RAX: 000000000000001b RBX: 0000000000000000 RCX: 0000000001ce1000
RDX: 0000000000000000 RSI: 000000007fffffe5 RDI: 0000000000000000
RBP: 000000000000000c R08: 0000000000000000 R09: 00007f94be09220d
R10: 0000000000000002 R11: 0000000000000246 R12: 00000000000186a0
R13: 0000000000000003 R14: 00007f949d845000 R15: 0000000002800000
Task in /leaker killed as a result of limit of /leaker
memory: usage 524288kB, limit 524288kB, failcnt 158965
memory+swap: usage 0kB, limit 9007199254740988kB, failcnt 0
kmem: usage 2016kB, limit 9007199254740988kB, failcnt 0
Memory cgroup stats for /leaker: cache:844KB rss:521136KB rss_huge:0KB shmem:0KB mapped_file:0KB dirty:132KB writeback:0KB inactive_anon:0KB active_anon:521224KB inactive_file:1012KB active_file:8KB unevictable:0KB
Memory cgroup out of memory: Kill process 2746 (leaker) score 998 or sacrifice child
Killed process 2746 (leaker) total-vm:536704kB, anon-rss:521176kB, file-rss:1208kB, shmem-rss:0kB
oom_reaper: reaped process 2746 (leaker), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
[2]
leaker invoked oom-killer: gfp_mask=0x600040(GFP_NOFS), nodemask=(null), order=0, oom_score_adj=0
CPU: 1 PID: 2746 Comm: leaker Not tainted 4.18.0+ #20
Call Trace:
out_of_memory+0x109/0x2d0
try_charge+0x58d/0x650
? __radix_tree_replace+0x81/0x100
mem_cgroup_try_charge+0x7a/0x100
__add_to_page_cache_locked+0x92/0x180
add_to_page_cache_lru+0x4d/0xf0
iomap_readpages_actor+0xde/0x1b0
? iomap_zero_range_actor+0x1d0/0x1d0
iomap_apply+0xaf/0x130
iomap_readpages+0x9f/0x150
xfs_vm_readpages+0x18/0x20 [xfs]
read_pages+0x60/0x140
__do_page_cache_readahead+0x193/0x1b0
ondemand_readahead+0x16d/0x2c0
page_cache_async_readahead+0x9a/0xd0
filemap_fault+0x403/0x620
? alloc_set_pte+0x12c/0x540
? _cond_resched+0x14/0x30
__xfs_filemap_fault+0x66/0x180 [xfs]
xfs_filemap_fault+0x27/0x30 [xfs]
__do_fault+0x19/0x40
__handle_mm_fault+0x8e8/0xb60
__do_page_fault+0x238/0x4e0
RIP: 0033:0x4009f0
RSP: 002b:00007ffda45c9290 EFLAGS: 00010206
RAX: 000000000000001b RBX: 0000000000000000 RCX: 0000000001a1e000
RBP: 000000000000000c R08: 0000000000000000 R09: 00007f6d061ff20d
R13: 0000000000000003 R14: 00007f6ce59b2000 R15: 0000000002800000
memory: usage 524288kB, limit 524288kB, failcnt 7221
kmem: usage 1944kB, limit 9007199254740988kB, failcnt 0
Memory cgroup stats for /leaker: cache:3632KB rss:518232KB rss_huge:0KB shmem:0KB mapped_file:0KB dirty:0KB writeback:0KB inactive_anon:0KB active_anon:518408KB inactive_file:3908KB active_file:12KB unevictable:0KB
Memory cgroup out of memory: Kill process 2746 (leaker) score 992 or sacrifice child
Killed process 2746 (leaker) total-vm:536704kB, anon-rss:518264kB, file-rss:1188kB, shmem-rss:0kB
[3]
leaker invoked oom-killer: gfp_mask=0x50, order=0, oom_score_adj=0
leaker cpuset=/ mems_allowed=0
CPU: 1 PID: 3206 Comm: leaker Not tainted 3.10.0-957.27.2.el7.x86_64 #1
Call Trace:
[<ffffffffaf364147>] dump_stack+0x19/0x1b
[<ffffffffaf35eb6a>] dump_header+0x90/0x229
[<ffffffffaedbb456>] ? find_lock_task_mm+0x56/0xc0
[<ffffffffaee32a38>] ? try_get_mem_cgroup_from_mm+0x28/0x60
[<ffffffffaedbb904>] oom_kill_process+0x254/0x3d0
[<ffffffffaee36c36>] mem_cgroup_oom_synchronize+0x546/0x570
[<ffffffffaee360b0>] ? mem_cgroup_charge_common+0xc0/0xc0
[<ffffffffaedbc194>] pagefault_out_of_memory+0x14/0x90
[<ffffffffaf35d072>] mm_fault_error+0x6a/0x157
[<ffffffffaf3717c8>] __do_page_fault+0x3c8/0x4f0
[<ffffffffaf371925>] do_page_fault+0x35/0x90
[<ffffffffaf36d768>] page_fault+0x28/0x30
memory: usage 524288kB, limit 524288kB, failcnt 20628
memory+swap: usage 524288kB, limit 9007199254740988kB, failcnt 0
kmem: usage 0kB, limit 9007199254740988kB, failcnt 0
Memory cgroup stats for /leaker: cache:840KB rss:523448KB rss_huge:0KB mapped_file:0KB swap:0KB inactive_anon:0KB active_anon:523448KB inactive_file:464KB active_file:376KB unevictable:0KB
Memory cgroup out of memory: Kill process 3206 (leaker) score 970 or sacrifice child
Killed process 3206 (leaker) total-vm:536692kB, anon-rss:523304kB, file-rss:412kB, shmem-rss:0kB
Bisected by Masoud Sharbiani.
Link: http://lkml.kernel.org/r/cbe54ed1-b6ba-a056-8899-2dc42526371d@i-love.sakura.ne.jp
Fixes: 3da88fb3bacfaa33 ("mm, oom: move GFP_NOFS check to out_of_memory") [necessary after 29ef680ae7c21110]
Reported-by: Masoud Sharbiani <msharbiani@apple.com>
Tested-by: Masoud Sharbiani <msharbiani@apple.com>
Cc: <stable@vger.kernel.org> [4.19+]
commit 441e254cd40dc03beec3c650ce6ce6074bc6517f upstream.
Fixes: 701d678599d0c1 ("mm/zsmalloc.c: fix race condition in zs_destroy_pool")
Link: http://lkml.kernel.org/r/201908251039.5oSbEEUT%25lkp@intel.com
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Henry Burns <henrywolfeburns@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jonathan Adams <jwadams@google.com>
commit 701d678599d0c1623aaf4139c03eea260a75b027 upstream.
In zs_destroy_pool() we call flush_work(&pool->free_work). However, we
have no guarantee that migration isn't happening in the background at
that time.
Since migration can't directly free pages, it relies on free_work being
scheduled to free the pages. But there's nothing preventing an
in-progress migrate from queuing the work *after*
zs_unregister_migration() has called flush_work(). Which would mean
pages still pointing at the inode when we free it.
Since we know at destroy time all objects should be free, no new
migrations can come in (since zs_page_isolate() fails for fully-free
zspages). This means it is sufficient to track a "# isolated zspages"
count by class, and have the destroy logic ensure all such pages have
drained before proceeding. Keeping that state under the class spinlock
keeps the logic straightforward.
In this case a memory leak could lead to an eventual crash if compaction
hits the leaked page. This crash would only occur if people are
changing their zswap backend at runtime (which eventually starts
destruction).
Link: http://lkml.kernel.org/r/20190809181751.219326-2-henryburns@google.com
Fixes: 48b4800a1c6a ("zsmalloc: page migration support")
Signed-off-by: Henry Burns <henryburns@google.com>
commit 1a87aa03597efa9641e92875b883c94c7f872ccb upstream.
In zs_page_migrate() we call putback_zspage() after we have finished
migrating all pages in this zspage. However, the return value is
ignored. If a zs_free() races in between zs_page_isolate() and
zs_page_migrate(), freeing the last object in the zspage,
putback_zspage() will leave the page in ZS_EMPTY for potentially an
unbounded amount of time.
To fix this, we need to do the same thing as zs_page_putback() does:
schedule free_work to occur.
To avoid duplicated code, move the sequence to a new
putback_zspage_deferred() function which both zs_page_migrate() and
zs_page_putback() call.
Link: http://lkml.kernel.org/r/20190809181751.219326-1-henryburns@google.com
commit f7da677bc6e72033f0981b9d58b5c5d409fa641e upstream.
THP splitting path is missing the split_page_owner() call that
split_page() has.
As a result, split THP pages are wrongly reported in the page_owner file
as order-9 pages. Furthermore when the former head page is freed, the
remaining former tail pages are not listed in the page_owner file at
all. This patch fixes that by adding the split_page_owner() call into
__split_huge_page().
Link: http://lkml.kernel.org/r/20190820131828.22684-2-vbabka@suse.cz
Fixes: a9627bc5e34e ("mm/page_owner: introduce split_page_owner and replace manual handling")
Reported-by: Kirill A. Shutemov <kirill@shutemov.name>
commit 54a83d6bcbf8f4700013766b974bf9190d40b689 upstream.
This patch is sent to report an use after free in mem_cgroup_iter()
after merging commit be2657752e9e ("mm: memcg: fix use after free in
mem_cgroup_iter()").
I work with android kernel tree (4.9 & 4.14), and commit be2657752e9e
("mm: memcg: fix use after free in mem_cgroup_iter()") has been merged
to the trees. However, I can still observe use after free issues
addressed in the commit be2657752e9e. (on low-end devices, a few times
this month)
backtrace:
css_tryget <- crash here
mem_cgroup_iter
shrink_node
shrink_zones
do_try_to_free_pages
try_to_free_pages
__perform_reclaim
__alloc_pages_direct_reclaim
__alloc_pages_slowpath
To debug, I poisoned mem_cgroup before freeing it:
static void __mem_cgroup_free(struct mem_cgroup *memcg)
for_each_node(node)
free_mem_cgroup_per_node_info(memcg, node);
free_percpu(memcg->stat);
+ /* poison memcg before freeing it */
+ memset(memcg, 0x78, sizeof(struct mem_cgroup));
kfree(memcg);
The coredump shows the position=0xdbbc2a00 is freed.
(gdb) p/x ((struct mem_cgroup_per_node *)0xe5009e00)->iter[8]
$13 = {position = 0xdbbc2a00, generation = 0x2efd}
0xdbbc2a00: 0xdbbc2e00 0x00000000 0xdbbc2800 0x00000100
0xdbbc2a10: 0x00000200 0x78787878 0x00026218 0x00000000
0xdbbc2a20: 0xdcad6000 0x00000001 0x78787800 0x00000000
0xdbbc2a30: 0x78780000 0x00000000 0x0068fb84 0x78787878
0xdbbc2a40: 0x78787878 0x78787878 0x78787878 0xe3fa5cc0
0xdbbc2a50: 0x78787878 0x78787878 0x00000000 0x00000000
0xdbbc2a60: 0x00000000 0x00000000 0x00000000 0x00000000
0xdbbc2a70: 0x00000000 0x00000000 0x00000000 0x00000000
0xdbbc2a80: 0x00000000 0x00000000 0x00000000 0x00000000
0xdbbc2a90: 0x00000001 0x00000000 0x00000000 0x00100000
0xdbbc2aa0: 0x00000001 0xdbbc2ac8 0x00000000 0x00000000
0xdbbc2ab0: 0x00000000 0x00000000 0x00000000 0x00000000
0xdbbc2ac0: 0x00000000 0x00000000 0xe5b02618 0x00001000
0xdbbc2ad0: 0x00000000 0x78787878 0x78787878 0x78787878
0xdbbc2ae0: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2af0: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b00: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b10: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b20: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b30: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b40: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b50: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b60: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b70: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2b80: 0x78787878 0x78787878 0x00000000 0x78787878
0xdbbc2b90: 0x78787878 0x78787878 0x78787878 0x78787878
0xdbbc2ba0: 0x78787878 0x78787878 0x78787878 0x78787878
In the reclaim path, try_to_free_pages() does not setup
sc.target_mem_cgroup and sc is passed to do_try_to_free_pages(), ...,
shrink_node().
In mem_cgroup_iter(), root is set to root_mem_cgroup because
sc->target_mem_cgroup is NULL. It is possible to assign a memcg to
root_mem_cgroup.nodeinfo.iter in mem_cgroup_iter().
try_to_free_pages
struct scan_control sc = {...}, target_mem_cgroup is 0x0;
shrink_zones
shrink_node
mem_cgroup *root = sc->target_mem_cgroup;
memcg = mem_cgroup_iter(root, NULL, &reclaim);
mem_cgroup_iter()
if (!root)
root = root_mem_cgroup;
css = css_next_descendant_pre(css, &root->css);
memcg = mem_cgroup_from_css(css);
cmpxchg(&iter->position, pos, memcg);
My device uses memcg non-hierarchical mode. When we release a memcg:
invalidate_reclaim_iterators() reaches only dead_memcg and its parents.
If non-hierarchical mode is used, invalidate_reclaim_iterators() never
reaches root_mem_cgroup.
static void invalidate_reclaim_iterators(struct mem_cgroup *dead_memcg)
struct mem_cgroup *memcg = dead_memcg;
for (; memcg; memcg = parent_mem_cgroup(memcg)
So the use after free scenario looks like:
CPU1 CPU2
try_to_free_pages
shrink_zones
shrink_node
mem_cgroup_iter()
if (!root)
invalidate_reclaim_iterators(memcg);
__mem_cgroup_free()
kfree(memcg);
try_to_free_pages
shrink_zones
shrink_node
mem_cgroup_iter()
if (!root)
mz = mem_cgroup_nodeinfo(root, reclaim->pgdat->node_id);
iter = &mz->iter[reclaim->priority];
pos = READ_ONCE(iter->position);
css_tryget(&pos->css) <- use after free
To avoid this, we should also invalidate root_mem_cgroup.nodeinfo.iter
in invalidate_reclaim_iterators().
[cai@lca.pw: fix -Wparentheses compilation warning]
Link: http://lkml.kernel.org/r/1564580753-17531-1-git-send-email-cai@lca.pw
Link: http://lkml.kernel.org/r/20190730015729.4406-1-miles.chen@mediatek.com
Fixes: 5ac8fb31ad2e ("mm: memcontrol: convert reclaim iterator to simple css refcounting")
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
commit 951531691c4bcaa59f56a316e018bc2ff1ddf855 upstream.
Currently, when checking to see if accessing n bytes starting at address
"ptr" will cause a wraparound in the memory addresses, the check in
check_bogus_address() adds an extra byte, which is incorrect, as the
range of addresses that will be accessed is [ptr, ptr + (n - 1)].
This can lead to incorrectly detecting a wraparound in the memory
address, when trying to read 4 KB from memory that is mapped to the the
last possible page in the virtual address space, when in fact, accessing
that range of memory would not cause a wraparound to occur.
Use the memory range that will actually be accessed when considering if
accessing a certain amount of bytes will cause the memory address to
wrap around.
Link: http://lkml.kernel.org/r/1564509253-23287-1-git-send-email-isaacm@codeaurora.org
Signed-off-by: Prasad Sodagudi <psodagud@codeaurora.org>
Signed-off-by: Isaac J. Manjarres <isaacm@codeaurora.org>
Co-developed-by: Prasad Sodagudi <psodagud@codeaurora.org>
Reviewed-by: William Kucharski <william.kucharski@oracle.com>
Cc: Trilok Soni <tsoni@codeaurora.org>
[kees: backport to v4.14]
commit 3f8fd02b1bf1d7ba964485a56f2f4b53ae88c167 upstream.
On x86-32 with PTI enabled, parts of the kernel page-tables are not shared
between processes. This can cause mappings in the vmalloc/ioremap area to
persist in some page-tables after the region is unmapped and released.
When the region is re-used the processes with the old mappings do not fault
in the new mappings but still access the old ones.
This causes undefined behavior, in reality often data corruption, kernel
oopses and panics and even spontaneous reboots.
Fix this problem by activly syncing unmaps in the vmalloc/ioremap area to
all page-tables in the system before the regions can be re-used.
References: https://bugzilla.suse.com/show_bug.cgi?id=1118689
Fixes: 5d72b4fba40ef ('x86, mm: support huge I/O mapping capability I/F')
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
Link: https://lkml.kernel.org/r/20190719184652.11391-4-joro@8bytes.org
[ Upstream commit c633324e311243586675e732249339685e5d6faa ]
The description of cma_declare_contiguous() indicates that if the
'fixed' argument is true the reserved contiguous area must be exactly at
the address of the 'base' argument.
However, the function currently allows the 'base', 'size', and 'limit'
arguments to be silently adjusted to meet alignment constraints. This
commit enforces the documented behavior through explicit checks that
return an error if the region does not fit within a specified region.
Link: http://lkml.kernel.org/r/1561422051-16142-1-git-send-email-opendmb@gmail.com
Fixes: 5ea3b1b2f8ad ("cma: add placement specifier for "cma=" kernel parameter")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Yue Hu <huyue2@yulong.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 543bdb2d825fe2400d6e951f1786d92139a16931 ]
Make mmu_notifier_register() safer by issuing a memory barrier before
registering a new notifier. This fixes a theoretical bug on weakly
ordered CPUs. For example, take this simplified use of notifiers by a
driver:
my_struct->mn.ops = &my_ops; /* (1) */
mmu_notifier_register(&my_struct->mn, mm)
hlist_add_head(&mn->hlist, &mm->mmu_notifiers); /* (2) */
Once mmu_notifier_register() releases the mm locks, another thread can
invalidate a range:
mmu_notifier_invalidate_range()
hlist_for_each_entry_rcu(mn, &mm->mmu_notifiers, hlist) {
if (mn->ops->invalidate_range)
The read side relies on the data dependency between mn and ops to ensure
that the pointer is properly initialized. But the write side doesn't have
any dependency between (1) and (2), so they could be reordered and the
readers could dereference an invalid mn->ops. mmu_notifier_register()
does take all the mm locks before adding to the hlist, but those have
acquire semantics which isn't sufficient.
By calling hlist_add_head_rcu() instead of hlist_add_head() we update the
hlist using a store-release, ensuring that readers see prior
initialization of my_struct. This situation is better illustated by
litmus test MP+onceassign+derefonce.
Link: http://lkml.kernel.org/r/20190502133532.24981-1-jean-philippe.brucker@arm.com
Fixes: cddb8a5c14aa ("mmu-notifiers: core")
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Cc: Jérôme Glisse <jglisse@redhat.com>
[ Upstream commit b5d1c39f34d1c9bca0c4b9ae2e339fbbe264a9c7 ]
If we end up without a PGD or PUD entry backing the gate area, don't BUG
-- just fail gracefully.
It's not entirely implausible that this could happen some day on x86. It
doesn't right now even with an execute-only emulated vsyscall page because
the fixmap shares the PUD, but the core mm code shouldn't rely on that
particular detail to avoid OOPSing.
Link: http://lkml.kernel.org/r/a1d9f4efb75b9d464e59fd6af00104b21c58f6f7.1561610798.git.luto@kernel.org
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Florian Weimer <fweimer@redhat.com>
[ Upstream commit 790c73690c2bbecb3f6f8becbdb11ddc9bcff8cc ]
Several mips builds generate the following build warning.
mm/gup.c:1788:13: warning: 'undo_dev_pagemap' defined but not used
The function is declared unconditionally but only called from behind
various ifdefs. Mark it __maybe_unused.
Link: http://lkml.kernel.org/r/1562072523-22311-1-git-send-email-linux@roeck-us.net
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
[ Upstream commit 6ef9056952532c3b746de46aa10d45b4d7797bd8 ]
in_softirq() is a wrong predicate to check if we are in a softirq
context. It also returns true if we have BH disabled, so objects are
falsely stamped with "softirq" comm. The correct predicate is
in_serving_softirq().
If user does cat from /sys/kernel/debug/kmemleak previously they would
see this, which is clearly wrong, this is system call context (see the
comm):
unreferenced object 0xffff88805bd661c0 (size 64):
comm "softirq", pid 0, jiffies 4294942959 (age 12.400s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 ff ff ff ff 00 00 00 00 ................
00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................
backtrace:
[<0000000007dcb30c>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<0000000007dcb30c>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<0000000007dcb30c>] slab_alloc mm/slab.c:3326 [inline]
[<0000000007dcb30c>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553
[<00000000969722b7>] kmalloc include/linux/slab.h:547 [inline]
[<00000000969722b7>] kzalloc include/linux/slab.h:742 [inline]
[<00000000969722b7>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline]
[<00000000969722b7>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085
[<00000000a4134b5f>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475
[<00000000d20248ad>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957
[<000000003d367be7>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246
[<000000003c7c76af>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616
[<000000000c1aeb23>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130
[<000000000157b92b>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078
[<00000000a9f3d058>] __do_sys_setsockopt net/socket.c:2089 [inline]
[<00000000a9f3d058>] __se_sys_setsockopt net/socket.c:2086 [inline]
[<00000000a9f3d058>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086
[<000000001b8da885>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301
[<00000000ba770c62>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
now they will see this:
unreferenced object 0xffff88805413c800 (size 64):
comm "syz-executor.4", pid 8960, jiffies 4294994003 (age 14.350s)
00 7a 8a 57 80 88 ff ff e0 00 00 01 00 00 00 00 .z.W............
backtrace:
[<00000000c5d3be64>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<00000000c5d3be64>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<00000000c5d3be64>] slab_alloc mm/slab.c:3326 [inline]
[<00000000c5d3be64>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553
[<0000000023865be2>] kmalloc include/linux/slab.h:547 [inline]
[<0000000023865be2>] kzalloc include/linux/slab.h:742 [inline]
[<0000000023865be2>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline]
[<0000000023865be2>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085
[<000000003029a9d4>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475
[<00000000ccd0a87c>] do_ip_setsockopt.isra.0+0x19fe/0x1c00 net/ipv4/ip_sockglue.c:957
[<00000000a85a3785>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246
[<00000000ec13c18d>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616
[<0000000052d748e3>] sock_common_setsockopt+0x3e/0x50 net/core/sock.c:3130
[<00000000512f1014>] __sys_setsockopt+0x9e/0x120 net/socket.c:2078
[<00000000181758bc>] __do_sys_setsockopt net/socket.c:2089 [inline]
[<00000000181758bc>] __se_sys_setsockopt net/socket.c:2086 [inline]
[<00000000181758bc>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086
[<00000000d4b73623>] do_syscall_64+0x7c/0x1a0 arch/x86/entry/common.c:301
[<00000000c1098bec>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Link: http://lkml.kernel.org/r/20190517171507.96046-1-dvyukov@gmail.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 2c012a4ad1a2cd3fb5a0f9307b9d219f84eda1fa upstream.
When file refaults are detected and there are many inactive file pages,
the system never reclaim anonymous pages, the file pages are dropped
aggressively when there are still a lot of cold anonymous pages and
system thrashes. This issue impacts the performance of applications
with large executable, e.g. chrome.
With this patch, when file refault is detected, inactive_list_is_low()
always returns true for file pages in get_scan_count() to enable
scanning anonymous pages.
The problem can be reproduced by the following test program.
---8<---
void fallocate_file(const char *filename, off_t size)
struct stat st;
int fd;
if (!stat(filename, &st) && st.st_size >= size)
return;
fd = open(filename, O_WRONLY | O_CREAT, 0600);
if (fd < 0) {
perror("create file");
exit(1);
if (posix_fallocate(fd, 0, size)) {
perror("fallocate");
exit(1);
close(fd);
long *alloc_anon(long size)
long *start = malloc(size);
memset(start, 1, size);
return start;
long access_file(const char *filename, long size, long rounds)
int fd, i;
volatile char *start1, *end1, *start2;
const int page_size = getpagesize();
long sum = 0;
fd = open(filename, O_RDONLY);
if (fd == -1) {
perror("open");
exit(1);
* Some applications, e.g. chrome, use a lot of executable file
* pages, map some of the pages with PROT_EXEC flag to simulate
* the behavior.
start1 = mmap(NULL, size / 2, PROT_READ | PROT_EXEC, MAP_SHARED,
fd, 0);
if (start1 == MAP_FAILED) {
perror("mmap");
exit(1);
end1 = start1 + size / 2;
start2 = mmap(NULL, size / 2, PROT_READ, MAP_SHARED, fd, size / 2);
if (start2 == MAP_FAILED) {
perror("mmap");
exit(1);
for (i = 0; i < rounds; ++i) {
struct timeval before, after;
volatile char *ptr1 = start1, *ptr2 = start2;
gettimeofday(&before, NULL);
for (; ptr1 < end1; ptr1 += page_size, ptr2 += page_size)
sum += *ptr1 + *ptr2;
gettimeofday(&after, NULL);
printf("File access time, round %d: %f (sec)
", i,
(after.tv_sec - before.tv_sec) +
(after.tv_usec - before.tv_usec) / 1000000.0);
return sum;
int main(int argc, char *argv[])
const long MB = 1024 * 1024;
long anon_mb, file_mb, file_rounds;
const char filename[] = "large";
long *ret1;
long ret2;
if (argc != 4) {
printf("usage: thrash ANON_MB FILE_MB FILE_ROUNDS
exit(0);
anon_mb = atoi(argv[1]);
file_mb = atoi(argv[2]);
file_rounds = atoi(argv[3]);
fallocate_file(filename, file_mb * MB);
printf("Allocate %ld MB anonymous pages
", anon_mb);
ret1 = alloc_anon(anon_mb * MB);
printf("Access %ld MB file pages
", file_mb);
ret2 = access_file(filename, file_mb * MB, file_rounds);
printf("Print result to prevent optimization: %ld
*ret1 + ret2);
return 0;
---8<---
Running the test program on 2GB RAM VM with kernel 5.2.0-rc5, the program
fills ram with 2048 MB memory, access a 200 MB file for 10 times. Without
this patch, the file cache is dropped aggresively and every access to the
file is from disk.
$ ./thrash 2048 200 10
Allocate 2048 MB anonymous pages
Access 200 MB file pages
File access time, round 0: 2.489316 (sec)
File access time, round 1: 2.581277 (sec)
File access time, round 2: 2.487624 (sec)
File access time, round 3: 2.449100 (sec)
File access time, round 4: 2.420423 (sec)
File access time, round 5: 2.343411 (sec)
File access time, round 6: 2.454833 (sec)
File access time, round 7: 2.483398 (sec)
File access time, round 8: 2.572701 (sec)
File access time, round 9: 2.493014 (sec)
With this patch, these file pages can be cached.
File access time, round 0: 2.475189 (sec)
File access time, round 1: 2.440777 (sec)
File access time, round 2: 2.411671 (sec)
File access time, round 3: 1.955267 (sec)
File access time, round 4: 0.029924 (sec)
File access time, round 5: 0.000808 (sec)
File access time, round 6: 0.000771 (sec)
File access time, round 7: 0.000746 (sec)
File access time, round 8: 0.000738 (sec)
File access time, round 9: 0.000747 (sec)
Checked the swap out stats during the test [1], 19006 pages swapped out
with this patch, 3418 pages swapped out without this patch. There are
more swap out, but I think it's within reasonable range when file backed
data set doesn't fit into the memory.
$ ./thrash 2000 100 2100 5 1 # ANON_MB FILE_EXEC FILE_NOEXEC ROUNDS
PROCESSES Allocate 2000 MB anonymous pages active_anon: 1613644,
inactive_anon: 348656, active_file: 892, inactive_file: 1384 (kB)
pswpout: 7972443, pgpgin: 478615246 Access 100 MB executable file pages
Access 2100 MB regular file pages File access time, round 0: 12.165,
(sec) active_anon: 1433788, inactive_anon: 478116, active_file: 17896,
inactive_file: 24328 (kB) File access time, round 1: 11.493, (sec)
active_anon: 1430576, inactive_anon: 477144, active_file: 25440,
inactive_file: 26172 (kB) File access time, round 2: 11.455, (sec)
active_anon: 1427436, inactive_anon: 476060, active_file: 21112,
inactive_file: 28808 (kB) File access time, round 3: 11.454, (sec)
active_anon: 1420444, inactive_anon: 473632, active_file: 23216,
inactive_file: 35036 (kB) File access time, round 4: 11.479, (sec)
active_anon: 1413964, inactive_anon: 471460, active_file: 31728,
inactive_file: 32224 (kB) pswpout: 7991449 (+ 19006), pgpgin: 489924366
(+ 11309120)
With 4 processes accessing non-overlapping parts of a large file, 30316
pages swapped out with this patch, 5152 pages swapped out without this
patch. The swapout number is small comparing to pgpgin.
[1]: https://github.com/vovo/testing/blob/master/mem_thrash.c
Link: http://lkml.kernel.org/r/20190701081038.GA83398@google.com
Fixes: e9868505987a ("mm,vmscan: only evict file pages when we have plenty")
Fixes: 7c5bd705d8f9 ("mm: memcg: only evict file pages when we have plenty")
Signed-off-by: Kuo-Hsin Yang <vovoy@chromium.org>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Sonny Rao <sonnyrao@chromium.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: <stable@vger.kernel.org> [4.12+]
[backported to 4.14.y, 4.19.y, 5.1.y: adjust context]
commit aa0bfcd939c30617385ffa28682c062d78050eba upstream.
In the spirit of filemap_fdatawait_range() and
filemap_fdatawait_keep_errors(), introduce
filemap_fdatawait_range_keep_errors() which both takes a range upon
which to wait and does not clear errors from the address space.
Signed-off-by: Ross Zwisler <zwisler@google.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit dffcac2cb88e4ec5906235d64a83d802580b119e upstream.
In production we have noticed hard lockups on large machines running
large jobs due to kswaps hoarding lru lock within isolate_lru_pages when
sc->reclaim_idx is 0 which is a small zone. The lru was couple hundred
GiBs and the condition (page_zonenum(page) > sc->reclaim_idx) in
isolate_lru_pages() was basically skipping GiBs of pages while holding
the LRU spinlock with interrupt disabled.
On further inspection, it seems like there are two issues:
(1) If kswapd on the return from balance_pgdat() could not sleep (i.e.
node is still unbalanced), the classzone_idx is unintentionally set
to 0 and the whole reclaim cycle of kswapd will try to reclaim only
the lowest and smallest zone while traversing the whole memory.
(2) Fundamentally isolate_lru_pages() is really bad when the
allocation has woken kswapd for a smaller zone on a very large machine
running very large jobs. It can hoard the LRU spinlock while skipping
over 100s of GiBs of pages.
This patch only fixes (1). (2) needs a more fundamental solution. To
fix (1), in the kswapd context, if pgdat->kswapd_classzone_idx is
invalid use the classzone_idx of the previous kswapd loop otherwise use
the one the waker has requested.
Link: http://lkml.kernel.org/r/20190701201847.251028-1-shakeelb@google.com
Fixes: e716f2eb24de ("mm, vmscan: prevent kswapd sleeping prematurely due to mismatched classzone_idx")
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reviewed-by: Yang Shi <yang.shi@linux.alibaba.com>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Hillf Danton <hdanton@sina.com>
[ Upstream commit 0874bb49bb21bf24deda853e8bf61b8325e24bcb ]
On a 64-bit machine the value of "vma->vm_end - vma->vm_start" may be
negative when using 32 bit ints and the "count >> PAGE_SHIFT"'s result
will be wrong. So change the local variable and return value to
unsigned long to fix the problem.
Link: http://lkml.kernel.org/r/20190513023701.83056-1-swkhack@gmail.com
Fixes: 0cf2f6f6dc60 ("mm: mlock: check against vma for actual mlock() size")
Signed-off-by: swkhack <swkhack@gmail.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
commit 7298e3b0a149c91323b3205d325e942c3b3b9ef6 upstream.
Currently the calcuation of end_pfn can round up the pfn number to more
than the actual maximum number of pfns, causing an Oops. Fix this by
ensuring end_pfn is never more than max_pfn.
This can be easily triggered when on systems where the end_pfn gets
rounded up to more than max_pfn using the idle-page stress-ng stress test:
sudo stress-ng --idle-page 0
BUG: unable to handle kernel paging request at 00000000000020d8
#PF error: [normal kernel read fault]
PGD 0 P4D 0
Oops: 0000 [#1] SMP PTI
CPU: 1 PID: 11039 Comm: stress-ng-idle- Not tainted 5.0.0-5-generic #6-Ubuntu
RIP: 0010:page_idle_get_page+0xc8/0x1a0
Code: 0f b1 0a 75 7d 48 8b 03 48 89 c2 48 c1 e8 33 83 e0 07 48 c1 ea 36 48 8d 0c 40 4c 8d 24 88 49 c1 e4 07 4c 03 24 d5 00 89 c3 be <49> 8b 44 24 58 48 8d b8 80 a1 02 00 e8 07 d5 77 00 48 8b 53 08 48
RSP: 0018:ffffafd7c672fde8 EFLAGS: 00010202
RAX: 0000000000000005 RBX: ffffe36341fff700 RCX: 000000000000000f
RDX: 0000000000000284 RSI: 0000000000000275 RDI: 0000000001fff700
RBP: ffffafd7c672fe00 R08: ffffa0bc34056410 R09: 0000000000000276
R10: ffffa0bc754e9b40 R11: ffffa0bc330f6400 R12: 0000000000002080
R13: ffffe36341fff700 R14: 0000000000080000 R15: ffffa0bc330f6400
FS: 00007f0ec1ea5740(0000) GS:ffffa0bc7db00000(0000) knlGS:0000000000000000
CR2: 00000000000020d8 CR3: 0000000077d68000 CR4: 00000000000006e0
Call Trace:
page_idle_bitmap_write+0x8c/0x140
sysfs_kf_bin_write+0x5c/0x70
kernfs_fop_write+0x12e/0x1b0
__vfs_write+0x1b/0x40
vfs_write+0xab/0x1b0
ksys_write+0x55/0xc0
__x64_sys_write+0x1a/0x20
do_syscall_64+0x5a/0x110
Link: http://lkml.kernel.org/r/20190618124352.28307-1-colin.king@canonical.com
Fixes: 33c3fc71c8cf ("mm: introduce idle page tracking")
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
commit 29b190fa774dd1b72a1a6f19687d55dc72ea83be upstream.
mpol_rebind_nodemask() is called for MPOL_BIND and MPOL_INTERLEAVE
mempoclicies when the tasks's cpuset's mems_allowed changes. For
policies created without MPOL_F_STATIC_NODES or MPOL_F_RELATIVE_NODES,
it works by remapping the policy's allowed nodes (stored in v.nodes)
using the previous value of mems_allowed (stored in
w.cpuset_mems_allowed) as the domain of map and the new mems_allowed
(passed as nodes) as the range of the map (see the comment of
bitmap_remap() for details).
The result of remapping is stored back as policy's nodemask in v.nodes,
and the new value of mems_allowed should be stored in
w.cpuset_mems_allowed to facilitate the next rebind, if it happens.
However, 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies
when updating cpusets") introduced a bug where the result of remapping
is stored in w.cpuset_mems_allowed instead. Thus, a mempolicy's
allowed nodes can evolve in an unexpected way after a series of
rebinding due to cpuset mems_allowed changes, possibly binding to a
wrong node or a smaller number of nodes which may e.g. overload them.
This patch fixes the bug so rebinding again works as intended.
[vbabka@suse.cz: new changlog]
Link: http://lkml.kernel.org/r/ef6a69c6-c052-b067-8f2c-9d615c619bb9@suse.cz
Link: http://lkml.kernel.org/r/1558768043-23184-1-git-send-email-zhongjiang@huawei.com
Fixes: 213980c0f23b ("mm, mempolicy: simplify rebinding mempolicies when updating cpusets")
Cc: Oscar Salvador <osalvador@suse.de>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: Ralph Campbell <rcampbell@nvidia.com>
commit 59ea6d06cfa9247b586a695c21f94afa7183af74 upstream.
When fixing the race conditions between the coredump and the mmap_sem
holders outside the context of the process, we focused on
mmget_not_zero()/get_task_mm() callers in 04f5866e41fb70 ("coredump: fix
race condition between mmget_not_zero()/get_task_mm() and core
dumping"), but those aren't the only cases where the mmap_sem can be
taken outside of the context of the process as Michal Hocko noticed
while backporting that commit to older -stable kernels.
If mmgrab() is called in the context of the process, but then the
mm_count reference is transferred outside the context of the process,
that can also be a problem if the mmap_sem has to be taken for writing
through that mm_count reference.
khugepaged registration calls mmgrab() in the context of the process,
but the mmap_sem for writing is taken later in the context of the
khugepaged kernel thread.
collapse_huge_page() after taking the mmap_sem for writing doesn't
modify any vma, so it's not obvious that it could cause a problem to the
coredump, but it happens to modify the pmd in a way that breaks an
invariant that pmd_trans_huge_lock() relies upon. collapse_huge_page()
needs the mmap_sem for writing just to block concurrent page faults that
call pmd_trans_huge_lock().
Specifically the invariant that "!pmd_trans_huge()" cannot become a
"pmd_trans_huge()" doesn't hold while collapse_huge_page() runs.
The coredump will call __get_user_pages() without mmap_sem for reading,
which eventually can invoke a lockless page fault which will need a
functional pmd_trans_huge_lock().
So collapse_huge_page() needs to use mmget_still_valid() to check it's
not running concurrently with the coredump... as long as the coredump
can invoke page faults without holding the mmap_sem for reading.
This has "Fixes: khugepaged" to facilitate backporting, but in my view
it's more a bug in the coredump code that will eventually have to be
rewritten to stop invoking page faults without the mmap_sem for reading.
So the long term plan is still to drop all mmget_still_valid().
Link: http://lkml.kernel.org/r/20190607161558.32104-1-aarcange@redhat.com
Fixes: ba76149f47d8 ("thp: khugepaged")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Michal Hocko <mhocko@suse.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Peter Xu <peterx@redhat.com>
Cc: Jason Gunthorpe <jgg@mellanox.com>
commit a58f2cef26e1ca44182c8b22f4f4395e702a5795 upstream.
There was the below bug report from Wu Fangsuo.
On the CMA allocation path, isolate_migratepages_range() could isolate
unevictable LRU pages and reclaim_clean_page_from_list() can try to
reclaim them if they are clean file-backed pages.
page:ffffffbf02f33b40 count:86 mapcount:84 mapping:ffffffc08fa7a810 index:0x24
flags: 0x19040c(referenced|uptodate|arch_1|mappedtodisk|unevictable|mlocked)
raw: 000000000019040c ffffffc08fa7a810 0000000000000024 0000005600000053
raw: ffffffc009b05b20 ffffffc009b05b20 0000000000000000 ffffffc09bf3ee80
page dumped because: VM_BUG_ON_PAGE(PageLRU(page) || PageUnevictable(page))
page->mem_cgroup:ffffffc09bf3ee80
kernel BUG at /home/build/farmland/adroid9.0/kernel/linux/mm/vmscan.c:1350!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 7125 Comm: syz-executor Tainted: G S 4.14.81 #3
Hardware name: ASR AQUILAC EVB (DT)
task: ffffffc00a54cd00 task.stack: ffffffc009b00000
PC is at shrink_page_list+0x1998/0x3240
LR is at shrink_page_list+0x1998/0x3240
pc : [<ffffff90083a2158>] lr : [<ffffff90083a2158>] pstate: 60400045
sp : ffffffc009b05940
reclaim_clean_pages_from_list+0x3c0/0x4f0
alloc_contig_range+0x3bc/0x650
cma_alloc+0x214/0x668
ion_cma_allocate+0x98/0x1d8
ion_alloc+0x200/0x7e0
ion_ioctl+0x18c/0x378
do_vfs_ioctl+0x17c/0x1780
SyS_ioctl+0xac/0xc0
Wu found it's due to commit ad6b67041a45 ("mm: remove SWAP_MLOCK in
ttu"). Before that, unevictable pages go to cull_mlocked so that we
can't reach the VM_BUG_ON_PAGE line.
To fix the issue, this patch filters out unevictable LRU pages from the
reclaim_clean_pages_from_list in CMA.
Link: http://lkml.kernel.org/r/20190524071114.74202-1-minchan@kernel.org
Fixes: ad6b67041a45 ("mm: remove SWAP_MLOCK in ttu")
Signed-off-by: Minchan Kim <minchan@kernel.org>
Reported-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Debugged-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Tested-by: Wu Fangsuo <fangsuowu@asrmicro.com>
Cc: Pankaj Suryawanshi <pankaj.suryawanshi@einfochips.com>
commit 3510955b327176fd4cbab5baa75b449f077722a2 upstream.
Syzbot reported following memory leak:
ffffffffda RBX: 0000000000000003 RCX: 0000000000441f79
BUG: memory leak
unreferenced object 0xffff888114f26040 (size 32):
comm "syz-executor626", pid 7056, jiffies 4294948701 (age 39.410s)
40 60 f2 14 81 88 ff ff 40 60 f2 14 81 88 ff ff @`......@`......
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
__memcg_init_list_lru_node+0x58/0xf0 mm/list_lru.c:352
memcg_init_list_lru_node mm/list_lru.c:375 [inline]
memcg_init_list_lru mm/list_lru.c:459 [inline]
__list_lru_init+0x193/0x2a0 mm/list_lru.c:626
alloc_super+0x2e0/0x310 fs/super.c:269
sget_userns+0x94/0x2a0 fs/super.c:609
sget+0x8d/0xb0 fs/super.c:660
mount_nodev+0x31/0xb0 fs/super.c:1387
fuse_mount+0x2d/0x40 fs/fuse/inode.c:1236
legacy_get_tree+0x27/0x80 fs/fs_context.c:661
vfs_get_tree+0x2e/0x120 fs/super.c:1476
do_new_mount fs/namespace.c:2790 [inline]
do_mount+0x932/0xc50 fs/namespace.c:3110
ksys_mount+0xab/0x120 fs/namespace.c:3319
__do_sys_mount fs/namespace.c:3333 [inline]
__se_sys_mount fs/namespace.c:3330 [inline]
__x64_sys_mount+0x26/0x30 fs/namespace.c:3330
do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301
This is a simple off by one bug on the error path.
Link: http://lkml.kernel.org/r/20190528043202.99980-1-shakeelb@google.com
Fixes: 60d3fd32a7a9 ("list_lru: introduce per-memcg lists")
Reported-by: syzbot+f90a420dfe2b1b03cb2c@syzkaller.appspotmail.com
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.0+]
[ Upstream commit 8c43004af01635cc9fbb11031d070e5e0d327ef2 ]
pcpu_find_block_fit() guarantees that a fit is found within
PCPU_BITMAP_BLOCK_BITS. Iteration is used to determine the first fit as
it compares against the block's contig_hint. This can lead to
incorrectly scanning past the end of the bitmap. The behavior was okay
given the check after for bit_off >= end and the correctness of the
hints from pcpu_find_block_fit().
This patch fixes this by bounding the end offset by the number of bits
in a chunk.
Signed-off-by: Dennis Zhou <dennis@kernel.org>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
[ Upstream commit 198790d9a3aeaef5792d33a560020861126edc22 ]
In free_percpu() we sometimes call pcpu_schedule_balance_work() to
queue a work item (which does a wakeup) while holding pcpu_lock.
This creates an unnecessary lock dependency between pcpu_lock and
the scheduler's pi_lock. There are other places where we call
pcpu_schedule_balance_work() without hold pcpu_lock, and this case
doesn't need to be different.
Moving the call outside the lock prevents the following lockdep splat
when running tools/testing/selftests/bpf/{test_maps,test_progs} in
sequence with lockdep enabled:
5.1.0-dbg-DEV #1 Not tainted
kworker/23:255/18872 is trying to acquire lock:
000000000bc79290 (&(&pool->lock)->rlock){-.-.}, at: __queue_work+0xb2/0x520
00000000e3e7a6aa (pcpu_lock){..-.}, at: free_percpu+0x36/0x260
-> #4 (pcpu_lock){..-.}:
lock_acquire+0x9e/0x180
_raw_spin_lock_irqsave+0x3a/0x50
pcpu_alloc+0xfa/0x780
__alloc_percpu_gfp+0x12/0x20
alloc_htab_elem+0x184/0x2b0
__htab_percpu_map_update_elem+0x252/0x290
bpf_percpu_hash_update+0x7c/0x130
__do_sys_bpf+0x1912/0x1be0
__x64_sys_bpf+0x1a/0x20
do_syscall_64+0x59/0x400
entry_SYSCALL_64_after_hwframe+0x49/0xbe
-> #3 (&htab->buckets[i].lock){....}:
htab_map_update_elem+0x1af/0x3a0
-> #2 (&rq->lock){-.-.}:
_raw_spin_lock+0x2f/0x40
task_fork_fair+0x37/0x160
sched_fork+0x211/0x310
copy_process.part.43+0x7b1/0x2160
_do_fork+0xda/0x6b0
kernel_thread+0x29/0x30
rest_init+0x22/0x260
arch_call_rest_init+0xe/0x10
start_kernel+0x4fd/0x520
x86_64_start_reservations+0x24/0x26
x86_64_start_kernel+0x6f/0x72
secondary_startup_64+0xa4/0xb0
-> #1 (&p->pi_lock){-.-.}:
try_to_wake_up+0x41/0x600
wake_up_process+0x15/0x20
create_worker+0x16b/0x1e0
workqueue_init+0x279/0x2ee
kernel_init_freeable+0xf7/0x288
kernel_init+0xf/0x180
ret_from_fork+0x24/0x30
-> #0 (&(&pool->lock)->rlock){-.-.}:
__lock_acquire+0x101f/0x12a0
queue_work_on+0x38/0x80
free_percpu+0x221/0x260
pcpu_freelist_destroy+0x11/0x20
stack_map_free+0x2a/0x40
bpf_map_free_deferred+0x3c/0x50
process_one_work+0x1f7/0x580
worker_thread+0x54/0x410
kthread+0x10f/0x150
Chain exists of:
&(&pool->lock)->rlock --> &htab->buckets[i].lock --> pcpu_lock
CPU0 CPU1
lock(pcpu_lock);
lock(&htab->buckets[i].lock);
lock(pcpu_lock);
lock(&(&pool->lock)->rlock);
*** DEADLOCK ***
3 locks held by kworker/23:255/18872:
#0: 00000000b36a6e16 ((wq_completion)events){+.+.},
at: process_one_work+0x17a/0x580
#1: 00000000dfd966f0 ((work_completion)(&map->work)){+.+.},
#2: 00000000e3e7a6aa (pcpu_lock){..-.},
stack backtrace:
CPU: 23 PID: 18872 Comm: kworker/23:255 Not tainted 5.1.0-dbg-DEV #1
Hardware name: ...
Workqueue: events bpf_map_free_deferred
Call Trace:
dump_stack+0x67/0x95
print_circular_bug.isra.38+0x1c6/0x220
check_prev_add.constprop.50+0x9f6/0xd20
kthread+0x10f/0x150
Signed-off-by: John Sperbeck <jsperbeck@google.com>
[ Upstream commit 745e10146c31b1c6ed3326286704ae251b17f663 ]
"cat /proc/slab_allocators" could hang forever on SMP machines with
kmemleak or object debugging enabled due to other CPUs running do_drain()
will keep making kmemleak_object or debug_objects_cache dirty and unable
to escape the first loop in leaks_show(),
do {
set_store_user_clean(cachep);
drain_cpu_caches(cachep);
} while (!is_store_user_clean(cachep));
For example,
do_drain
slabs_destroy
slab_destroy
kmem_cache_free
__cache_free
___cache_free
kmemleak_free_recursive
delete_object_full
__delete_object
put_object
free_object_rcu
kmem_cache_free
cache_free_debugcheck --> dirty kmemleak_object
One approach is to check cachep->name and skip both kmemleak_object and
debug_objects_cache in leaks_show(). The other is to set store_user_clean
after drain_cpu_caches() which leaves a small window between
drain_cpu_caches() and set_store_user_clean() where per-CPU caches could
be dirty again lead to slightly wrong information has been stored but
could also speed up things significantly which sounds like a good
compromise. For example,
# cat /proc/slab_allocators
0m42.778s # 1st approach
0m0.737s # 2nd approach
[akpm@linux-foundation.org: tweak comment]
Link: http://lkml.kernel.org/r/20190411032635.10325-1-cai@lca.pw
Fixes: d31676dfde25 ("mm/slab: alternative implementation for DEBUG_SLAB_LEAK")
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
[ Upstream commit f0fd50504a54f5548eb666dc16ddf8394e44e4b7 ]
If not find zero bit in find_next_zero_bit(), it will return the size
parameter passed in, so the start bit should be compared with bitmap_maxno
rather than cma->count. Although getting maxchunk is working fine due to
zero value of order_per_bit currently, the operation will be stuck if
order_per_bit is set as non-zero.
Link: http://lkml.kernel.org/r/20190319092734.276-1-zbestahu@gmail.com
Signed-off-by: Yue Hu <huyue2@yulong.com>
Cc: Joe Perches <joe@perches.com>
Cc: Dmitry Safonov <d.safonov@partner.samsung.com>
