commit 2673b4cf5d59c3ee5e0c12f6d734d38770324dc4 upstream.
While 7a401a972df8e18 ("backing-dev: ensure wakeup_timer is deleted")
addressed the problem of the bdi being freed with a queued wakeup
timer, there are other races that could happen if the wakeup timer
expires after/during bdi_unregister(), before bdi_destroy() is called.
wakeup_timer_fn() could attempt to wakeup a task which has already has
been freed, or could access a NULL bdi->dev via the wake_forker_thread
tracepoint.
Reported-by: Chanho Min <chanho.min@lge.com>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit b9980cdcf2524c5fe15d8cbae9c97b3ed6385563 upstream.
Fix CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_SMP=n CONFIG_DEBUG_VM=y
CONFIG_DEBUG_SPINLOCK=n kernel: spin_is_locked() is then always false,
and so triggers some BUGs in Transparent HugePage codepaths.
asm-generic/bug.h mentions this problem, and provides a WARN_ON_SMP(x);
but being too lazy to add VM_BUG_ON_SMP, BUG_ON_SMP, WARN_ON_SMP_ONCE,
VM_WARN_ON_SMP_ONCE, just test NR_CPUS != 1 in the existing VM_BUG_ONs.
commit dc9086004b3d5db75997a645b3fe08d9138b7ad0 upstream.
When isolating pages for migration, migration starts at the start of a
zone while the free scanner starts at the end of the zone. Migration
avoids entering a new zone by never going beyond the free scanned.
Unfortunately, in very rare cases nodes can overlap. When this happens,
migration isolates pages without the LRU lock held, corrupting lists
which will trigger errors in reclaim or during page free such as in the
following oops
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff810f795c>] free_pcppages_bulk+0xcc/0x450
PGD 1dda554067 PUD 1e1cb58067 PMD 0
Oops: 0000 [#1] SMP
CPU 37
Pid: 17088, comm: memcg_process_s Tainted: G X
RIP: free_pcppages_bulk+0xcc/0x450
Process memcg_process_s (pid: 17088, threadinfo ffff881c2926e000, task ffff881c2926c0c0)
Call Trace:
free_hot_cold_page+0x17e/0x1f0
__pagevec_free+0x90/0xb0
release_pages+0x22a/0x260
pagevec_lru_move_fn+0xf3/0x110
putback_lru_page+0x66/0xe0
unmap_and_move+0x156/0x180
migrate_pages+0x9e/0x1b0
compact_zone+0x1f3/0x2f0
compact_zone_order+0xa2/0xe0
try_to_compact_pages+0xdf/0x110
__alloc_pages_direct_compact+0xee/0x1c0
__alloc_pages_slowpath+0x370/0x830
__alloc_pages_nodemask+0x1b1/0x1c0
alloc_pages_vma+0x9b/0x160
do_huge_pmd_anonymous_page+0x160/0x270
do_page_fault+0x207/0x4c0
page_fault+0x25/0x30
The "X" in the taint flag means that external modules were loaded but but
is unrelated to the bug triggering. The real problem was because the PFN
layout looks like this
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
DMA32 0x00001000 -> 0x00100000
Normal 0x00100000 -> 0x01e80000
Movable zone start PFN for each node
early_node_map[14] active PFN ranges
0: 0x00000010 -> 0x0000009b
0: 0x00000100 -> 0x0007a1ec
0: 0x0007a354 -> 0x0007a379
0: 0x0007f7ff -> 0x0007f800
0: 0x00100000 -> 0x00680000
1: 0x00680000 -> 0x00e80000
0: 0x00e80000 -> 0x01080000
1: 0x01080000 -> 0x01280000
0: 0x01280000 -> 0x01480000
1: 0x01480000 -> 0x01680000
0: 0x01680000 -> 0x01880000
1: 0x01880000 -> 0x01a80000
0: 0x01a80000 -> 0x01c80000
1: 0x01c80000 -> 0x01e80000
The fix is straight-forward. isolate_migratepages() has to make a
similar check to isolate_freepage to ensure that it never isolates pages
from a zone it does not hold the LRU lock for.
This was discovered in a 3.0-based kernel but it affects 3.1.x, 3.2.x
and current mainline.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
during isolation for migration
commit 0bf380bc70ecba68cb4d74dc656cc2fa8c4d801a upstream.
When isolating for migration, migration starts at the start of a zone
which is not necessarily pageblock aligned. Further, it stops isolating
when COMPACT_CLUSTER_MAX pages are isolated so migrate_pfn is generally
not aligned. This allows isolate_migratepages() to call pfn_to_page() on
an invalid PFN which can result in a crash. This was originally reported
against a 3.0-based kernel with the following trace in a crash dump.
PID: 9902 TASK: d47aecd0 CPU: 0 COMMAND: "memcg_process_s"
#0 [d72d3ad0] crash_kexec at c028cfdb
#1 [d72d3b24] oops_end at c05c5322
#2 [d72d3b38] __bad_area_nosemaphore at c0227e60
#3 [d72d3bec] bad_area at c0227fb6
#4 [d72d3c00] do_page_fault at c05c72ec
#5 [d72d3c80] error_code (via page_fault) at c05c47a4
EAX: 00000000 EBX: 000c0000 ECX: 00000001 EDX: 00000807 EBP: 000c0000
DS: 007b ESI: 00000001 ES: 007b EDI: f3000a80 GS: 6f50
CS: 0060 EIP: c030b15a ERR: ffffffff EFLAGS: 00010002
#6 [d72d3cb4] isolate_migratepages at c030b15a
#7 [d72d3d14] zone_watermark_ok at c02d26cb
#8 [d72d3d2c] compact_zone at c030b8de
#9 [d72d3d68] compact_zone_order at c030bba1
#10 [d72d3db4] try_to_compact_pages at c030bc84
#11 [d72d3ddc] __alloc_pages_direct_compact at c02d61e7
#12 [d72d3e08] __alloc_pages_slowpath at c02d66c7
#13 [d72d3e78] __alloc_pages_nodemask at c02d6a97
#14 [d72d3eb8] alloc_pages_vma at c030a845
#15 [d72d3ed4] do_huge_pmd_anonymous_page at c03178eb
#16 [d72d3f00] handle_mm_fault at c02f36c6
#17 [d72d3f30] do_page_fault at c05c70ed
#18 [d72d3fb0] error_code (via page_fault) at c05c47a4
EAX: b71ff000 EBX: 00000001 ECX: 00001600 EDX: 00000431
DS: 007b ESI: 08048950 ES: 007b EDI: bfaa3788
SS: 007b ESP: bfaa36e0 EBP: bfaa3828 GS: 6f50
CS: 0073 EIP: 080487c8 ERR: ffffffff EFLAGS: 00010202
It was also reported by Herbert van den Bergh against 3.1-based kernel
with the following snippet from the console log.
BUG: unable to handle kernel paging request at 01c00008
IP: [<c0522399>] isolate_migratepages+0x119/0x390
*pdpt = 000000002f7ce001 *pde = 0000000000000000
It is expected that it also affects 3.2.x and current mainline.
The problem is that pfn_valid is only called on the first PFN being
checked and that PFN is not necessarily aligned. Lets say we have a case
like this
H = MAX_ORDER_NR_PAGES boundary
| = pageblock boundary
m = cc->migrate_pfn
f = cc->free_pfn
o = memory hole
H------|------H------|----m-Hoooooo|ooooooH-f----|------H
The migrate_pfn is just below a memory hole and the free scanner is beyond
the hole. When isolate_migratepages started, it scans from migrate_pfn to
migrate_pfn+pageblock_nr_pages which is now in a memory hole. It checks
pfn_valid() on the first PFN but then scans into the hole where there are
not necessarily valid struct pages.
This patch ensures that isolate_migratepages calls pfn_valid when
necessary.
Reported-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Tested-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
commit 99f02ef1f18631eb0a4e0ea0a3d56878dbcb4b90 upstream.
Fix a race condition that shows in conjunction with xip_file_fault() when
two threads of the same user process fault on the same memory page.
In this case, the race winner will install the page table entry and the
unlucky loser will cause an oops: xip_file_fault calls vm_insert_pfn (via
vm_insert_mixed) which drops out at this check:
retval = -EBUSY;
if (!pte_none(*pte))
goto out_unlock;
The resulting -EBUSY return value will trigger a BUG_ON() in
xip_file_fault.
This fix simply considers the fault as fixed in this case, because the
race winner has successfully installed the pte.
[akpm@linux-foundation.org: use conventional (and consistent) comment layout]
Reported-by: David Sadler <dsadler@us.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Reported-by: Louis Alex Eisner <leisner@cs.ucsd.edu>
commit 3deaa7190a8da38453c4fabd9dec7f66d17fff67 upstream.
Herbert Poetzl reported a performance regression since 2.6.39. The test
is a simple dd read, but with big block size. The reason is:
T1: ra (A, A+128k), (A+128k, A+256k)
T2: lock_page for page A, submit the 256k
T3: hit page A+128K, ra (A+256k, A+384). the range isn't submitted
because of plug and there isn't any lock_page till we hit page A+256k
because all pages from A to A+256k is in memory
T4: hit page A+256k, ra (A+384, A+ 512). Because of plug, the range isn't
submitted again.
T5: lock_page A+256k, so (A+256k, A+512k) will be submitted. The task is
waitting for (A+256k, A+512k) finish.
There is no request to disk in T3 and T4, so readahead pipeline breaks.
We really don't need block plug for generic_file_aio_read() for buffered
I/O. The readahead already has plug and has fine grained control when I/O
should be submitted. Deleting plug for buffered I/O fixes the regression.
One side effect is plug makes the request size 256k, the size is 128k
without it. This is because default ra size is 128k and not a reason we
need plug here.
Vivek said:
: We submit some readahead IO to device request queue but because of nested
: plug, queue never gets unplugged. When read logic reaches a page which is
: not in page cache, it waits for page to be read from the disk
: (lock_page_killable()) and that time we flush the plug list.
: So effectively read ahead logic is kind of broken in parts because of
: nested plugging. Removing top level plug (generic_file_aio_read()) for
: buffered reads, will allow unplugging queue earlier for readahead.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
commit 245132643e1cfcd145bbc86a716c1818371fcb93 upstream.
Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in
find_get_pages") correctly fixed an infinite loop; but left a problem
that find_get_pages() on shmem would return 0 (appearing to callers to
mean end of tree) when it meets a run of nr_pages swap entries.
The only uses of find_get_pages() on shmem are via pagevec_lookup(),
called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's
scan_mapping_unevictable_pages(). The first is already commented, and
not worth worrying about; but the second can leave pages on the
Unevictable list after an unusual sequence of swapping and locking.
Fix that by using shmem_find_get_pages_and_swap() (then ignoring the
swap) instead of pagevec_lookup().
But I don't want to contaminate vmscan.c with shmem internals, nor
shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into
shmem.c, renaming it shmem_unlock_mapping(); and rename
check_move_unevictable_page() to check_move_unevictable_pages(), looping
down an array of pages, oftentimes under the same lock.
Leave out the "rotate unevictable list" block: that's a leftover from
when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed
handling involved looking at pages at tail of LRU.
Was there significance to the sequence first ClearPageUnevictable, then
test page_evictable, then SetPageUnevictable here? I think not, we're
under LRU lock, and have no barriers between those.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Michel Lespinasse <walken@google.com>
commit 85046579bde15e532983438f86b36856e358f417 upstream.
scan_mapping_unevictable_pages() is used to make SysV SHM_LOCKed pages
evictable again once the shared memory is unlocked. It does this with
pagevec_lookup()s across the whole object (which might occupy most of
memory), and takes 300ms to unlock 7GB here. A cond_resched() every
PAGEVEC_SIZE pages would be good.
However, KOSAKI-san points out that this is called under shmem.c's
info->lock, and it's also under shm.c's shm_lock(), both spinlocks.
There is no strong reason for that: we need to take these pages off the
unevictable list soonish, but those locks are not required for it.
So move the call to scan_mapping_unevictable_pages() from shmem.c's
unlock handling up to shm.c's unlock handling. Remove the recently
added barrier, not needed now we have spin_unlock() before the scan.
Use get_file(), with subsequent fput(), to make sure we have a reference
to mapping throughout scan_mapping_unevictable_pages(): that's something
that was previously guaranteed by the shm_lock().
Remove shmctl's lru_add_drain_all(): we don't fault in pages at SHM_LOCK
time, and we lazily discover them to be Unevictable later, so it serves
no purpose for SHM_LOCK; and serves no purpose for SHM_UNLOCK, since
pages still on pagevec are not marked Unevictable.
The original code avoided redundant rescans by checking VM_LOCKED flag
at its level: now avoid them by checking shp's SHM_LOCKED.
The original code called scan_mapping_unevictable_pages() on a locked
area at shm_destroy() time: perhaps we once had accounting cross-checks
which required that, but not now, so skip the overhead and just let
inode eviction deal with them.
Put check_move_unevictable_page() and scan_mapping_unevictable_pages()
under CONFIG_SHMEM (with stub for the TINY case when ramfs is used),
more as comment than to save space; comment them used for SHM_UNLOCK.
commit 687875fb7de4a95223af20ee024282fa9099f860 upstream.
Fix the following NULL ptr dereference caused by
cat /sys/devices/system/memory/memory0/removable
Pid: 13979, comm: sed Not tainted 3.0.13-0.5-default #1 IBM BladeCenter LS21 -[7971PAM]-/Server Blade
RIP: __count_immobile_pages+0x4/0x100
Process sed (pid: 13979, threadinfo ffff880221c36000, task ffff88022e788480)
Call Trace:
is_pageblock_removable_nolock+0x34/0x40
is_mem_section_removable+0x74/0xf0
show_mem_removable+0x41/0x70
sysfs_read_file+0xfe/0x1c0
vfs_read+0xc7/0x130
sys_read+0x53/0xa0
system_call_fastpath+0x16/0x1b
We are crashing because we are trying to dereference NULL zone which
came from pfn=0 (struct page ffffea0000000000). According to the boot
log this page is marked reserved:
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
and early_node_map confirms that:
early_node_map[3] active PFN ranges
1: 0x00000010 -> 0x0000009c
1: 0x00000100 -> 0x000bffa3
1: 0x00100000 -> 0x00240000
The problem is that memory_present works in PAGE_SECTION_MASK aligned
blocks so the reserved range sneaks into the the section as well. This
also means that free_area_init_node will not take care of those reserved
pages and they stay uninitialized.
When we try to read the removable status we walk through all available
sections and hope that the zone is valid for all pages in the section.
But this is not true in this case as the zone and nid are not initialized.
We have only one node in this particular case and it is marked as node=1
(rather than 0) and that made the problem visible because page_to_nid will
return 0 and there are no zones on the node.
Let's check that the zone is valid and that the given pfn falls into its
boundaries and mark the section not removable. This might cause some
false positives, probably, but we do not have any sane way to find out
whether the page is reserved by the platform or it is just not used for
whatever other reasons.
commit ab936cbcd02072a34b60d268f94440fd5cf1970b upstream.
Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a
function replace_page_cache_page(). This function replaces a page in the
radix-tree with a new page. WHen doing this, memory cgroup needs to fix
up the accounting information. memcg need to check PCG_USED bit etc.
In some(many?) cases, 'newpage' is on LRU before calling
replace_page_cache(). So, memcg's LRU accounting information should be
fixed, too.
This patch adds mem_cgroup_replace_page_cache() and removes the old hooks.
In that function, old pages will be unaccounted without touching
res_counter and new page will be accounted to the memcg (of old page).
WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid
races with LRU handling.
Background:
replace_page_cache_page() is called by FUSE code in its splice() handling.
Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated
page and may be on LRU. LRU mis-accounting will be critical for memory cgroup
because rmdir() checks the whole LRU is empty and there is no account leak.
If a page is on the other LRU than it should be, rmdir() will fail.
This bug was added in March 2011, but no bug report yet. I guess there
are not many people who use memcg and FUSE at the same time with upstream
kernels.
The result of this bug is that admin cannot destroy a memcg because of
account leak. So, no panic, no deadlock. And, even if an active cgroup
exist, umount can succseed. So no problem at shutdown.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Miklos Szeredi <mszeredi@suse.cz>
commit 73736e0387ba0e6d2b703407b4d26168d31516a7 upstream.
Zhihua Che reported a possible memleak in slub allocator on
CONFIG_PREEMPT=y builds.
It is possible current thread migrates right before disabling irqs in
__slab_alloc(). We must check again c->freelist, and perform a normal
allocation instead of scratching c->freelist.
Many thanks to Zhihua Che for spotting this bug, introduced in 2.6.39
V2: Its also possible an IRQ freed one (or several) object(s) and
populated c->freelist, so its not a CONFIG_PREEMPT only problem.
Reported-by: Zhihua Che <zhihua.che@gmail.com>
Acked-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
If a huge page is enqueued under the protection of hugetlb_lock, then the
operation is atomic and safe.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: <stable@vger.kernel.org> [2.6.37+]
commit 8aacc9f550 ("mm/mempolicy.c: fix pgoff in mbind vma merge") is the
slightly incorrect fix.
Why? Think following case.
1. map 4 pages of a file at offset 0
[0123]
2. map 2 pages just after the first mapping of the same file but with
page offset 2
[0123][23]
3. mbind() 2 pages from the first mapping at offset 2.
mbind_range() should treat new vma is,
[0123][23]
|23|
mbind vma
but it does
[0123][23]
|01|
mbind vma
Oops. then, it makes wrong vma merge and splitting ([01][0123] or similar).
This patch fixes it.
[testcase]
test result - before the patch
case4: 126: test failed. expect '2,4', actual '2,2,2'
case5: passed
case6: passed
case7: passed
case8: passed
case_n: 246: test failed. expect '4,2', actual '1,4'
kernel BUG at mm/filemap.c:135!
invalid opcode: 0000 [#4] SMP DEBUG_PAGEALLOC
(snip long bug on messages)
test result - after the patch
case4: passed
case5: passed
case6: passed
case7: passed
case8: passed
case_n: passed
source: mbind_vma_test.c
#include <numaif.h>
#include <numa.h>
#include <sys/mman.h>
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
static unsigned long pagesize;
void* mmap_addr;
struct bitmask *nmask;
char buf[1024];
FILE *file;
char retbuf[10240] = "";
int mapped_fd;
char *rubysrc = "ruby -e '\
pid = %d; \
vstart = 0x%llx; \
vend = 0x%llx; \
s = `pmap -q #{pid}`; \
rary = []; \
s.each_line {|line|; \
ary=line.split(\" \"); \
addr = ary[0].to_i(16); \
if(vstart <= addr && addr < vend) then \
rary.push(ary[1].to_i()/4); \
end; \
print rary.join(\",\"); \
void init(void)
void* addr;
char buf[128];
nmask = numa_allocate_nodemask();
numa_bitmask_setbit(nmask, 0);
pagesize = getpagesize();
sprintf(buf, "%s", "mbind_vma_XXXXXX");
mapped_fd = mkstemp(buf);
if (mapped_fd == -1)
perror("mkstemp "), exit(1);
unlink(buf);
if (lseek(mapped_fd, pagesize*8, SEEK_SET) < 0)
perror("lseek "), exit(1);
if (write(mapped_fd, "\0", 1) < 0)
perror("write "), exit(1);
addr = mmap(NULL, pagesize*8, PROT_NONE,
MAP_SHARED, mapped_fd, 0);
if (addr == MAP_FAILED)
perror("mmap "), exit(1);
if (mprotect(addr+pagesize, pagesize*6, PROT_READ|PROT_WRITE) < 0)
perror("mprotect "), exit(1);
mmap_addr = addr + pagesize;
/* make page populate */
memset(mmap_addr, 0, pagesize*6);
void fin(void)
void* addr = mmap_addr - pagesize;
munmap(addr, pagesize*8);
memset(buf, 0, sizeof(buf));
memset(retbuf, 0, sizeof(retbuf));
void mem_bind(int index, int len)
int err;
err = mbind(mmap_addr+pagesize*index, pagesize*len,
MPOL_BIND, nmask->maskp, nmask->size, 0);
if (err)
perror("mbind "), exit(err);
void mem_interleave(int index, int len)
int err;
MPOL_INTERLEAVE, nmask->maskp, nmask->size, 0);
if (err)
void mem_unbind(int index, int len)
int err;
MPOL_DEFAULT, NULL, 0, 0);
if (err)
void Assert(char *expected, char *value, char *name, int line)
if (strcmp(expected, value) == 0) {
fprintf(stderr, "%s: passed\n", name);
return;
else {
fprintf(stderr, "%s: %d: test failed. expect '%s', actual '%s'\n",
name, line,
expected, value);
// exit(1);
AAAA
PPPPPPNNNNNN
might become
PPNNNNNNNNNN
case 4 below
void case4(void)
init();
sprintf(buf, rubysrc, getpid(), mmap_addr, mmap_addr+pagesize*6);
mem_bind(0, 4);
mem_unbind(2, 2);
file = popen(buf, "r");
fread(retbuf, sizeof(retbuf), 1, file);
Assert("2,4", retbuf, "case4", __LINE__);
fin();
AAAA
PPPPPPNNNNNN
might become
PPPPPPPPPPNN
case 5 below
void case5(void)
init();
mem_bind(0, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case5", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPPPPP 6
void case6(void)
init();
mem_bind(0, 2);
mem_bind(4, 2);
mem_bind(2, 2);
Assert("6", retbuf, "case6", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPPPPPXXXX 7
void case7(void)
init();
mem_bind(0, 2);
mem_interleave(4, 2);
mem_bind(2, 2);
Assert("4,2", retbuf, "case7", __LINE__);
fin();
AAAA
PPPPNNNNXXXX
might become
PPPPNNNNNNNN 8
void case8(void)
init();
mem_bind(0, 2);
mem_interleave(2, 2);
Assert("2,4", retbuf, "case8", __LINE__);
fin();
void case_n(void)
init();
/* make redundunt mappings [0][1234][34][7] */
mmap(mmap_addr + pagesize*4, pagesize*2, PROT_READ|PROT_WRITE,
MAP_FIXED|MAP_SHARED, mapped_fd, pagesize*3);
/* Expect to do nothing. */
mem_unbind(2, 2);
Assert("4,2", retbuf, "case_n", __LINE__);
fin();
int main(int argc, char** argv)
case4();
case5();
case6();
case7();
case8();
case_n();
return 0;
Cc: Caspar Zhang <caspar@casparzhang.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: <stable@vger.kernel.org> [3.1.x]
lockdep reports a deadlock in jfs because a special inode's rw semaphore
is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not
used when __read_cache_page() calls add_to_page_cache_lru().
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: stable@kernel.org
Static storage is not required for the struct vmap_area in
__get_vm_area_node.
Removing "static" to store this variable on the stack instead.
Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com>
Acked-by: David Rientjes <rientjes@google.com>
An integer overflow will happen on 64bit archs if task's sum of rss,
swapents and nr_ptes exceeds (2^31)/1000 value. This was introduced by
commit
f755a04 oom: use pte pages in OOM score
where the oom score computation was divided into several steps and it's no
longer computed as one expression in unsigned long(rss, swapents, nr_pte
are unsigned long), where the result value assigned to points(int) is in
range(1..1000). So there could be an int overflow while computing
176 points *= 1000;
and points may have negative value. Meaning the oom score for a mem hog task
will be one.
196 if (points <= 0)
197 return 1;
For example:
[ 3366] 0 3366 35390480 24303939 5 0 0 oom01
Out of memory: Kill process 3366 (oom01) score 1 or sacrifice child
Here the oom1 process consumes more than 24303939(rss)*4096~=92GB physical
memory, but it's oom score is one.
In this situation the mem hog task is skipped and oom killer kills another and
most probably innocent task with oom score greater than one.
The points variable should be of type long instead of int to prevent the
int overflow.
Signed-off-by: Frantisek Hrbata <fhrbata@redhat.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: <stable@vger.kernel.org> [2.6.36+]
If the request is to create non-root group and we fail to meet it, we
should leave the root unchanged.
Cc: Balbir Singh <bsingharora@gmail.com>
per_cpu_ptr_to_phys() incorrectly rounds up its result for non-kmalloc
case to the page boundary, which is bogus for any non-page-aligned
address.
This affects the only in-tree user of this function - sysfs handler
for per-cpu 'crash_notes' physical address. The trouble is that the
crash_notes per-cpu variable is not page-aligned:
crash_notes = 0xc08e8ed4
PER-CPU OFFSET VALUES:
CPU 0: 3711f000
CPU 1: 37129000
CPU 2: 37133000
CPU 3: 3713d000
So, the per-cpu addresses are:
crash_notes on CPU 0: f7a07ed4 => phys 36b57ed4
crash_notes on CPU 1: f7a11ed4 => phys 36b4ded4
crash_notes on CPU 2: f7a1bed4 => phys 36b43ed4
crash_notes on CPU 3: f7a25ed4 => phys 36b39ed4
However, /sys/devices/system/cpu/cpu*/crash_notes says:
/sys/devices/system/cpu/cpu0/crash_notes: 36b57000
/sys/devices/system/cpu/cpu1/crash_notes: 36b4d000
/sys/devices/system/cpu/cpu2/crash_notes: 36b43000
/sys/devices/system/cpu/cpu3/crash_notes: 36b39000
As you can see, all values are rounded down to a page
boundary. Consequently, this is where kexec sets up the NOTE segments,
and thus where the secondary kernel is looking for them. However, when
the first kernel crashes, it saves the notes to the unaligned
addresses, where they are not found.
Fix it by adding offset_in_page() to the translated page address.
-tj: Combined Eugene's and Petr's commit messages.
Signed-off-by: Eugene Surovegin <ebs@ebshome.net>
Reported-by: Petr Tesarik <ptesarik@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: set max_pause to lowest value on zero bdi_dirty
writeback: permit through good bdi even when global dirty exceeded
writeback: comment on the bdi dirty threshold
fs: Make write(2) interruptible by a fatal signal
writeback: Fix issue on make htmldocs
Commit f5252e00 ("mm: avoid null pointer access in vm_struct via
/proc/vmallocinfo") adds newly allocated vm_structs to the vmlist after
it is fully initialised. Unfortunately, it did not check that
__vmalloc_area_node() successfully populated the area. In the event of
allocation failure, the vmalloc area is freed but the pointer to freed
memory is inserted into the vmlist leading to a a crash later in
get_vmalloc_info().
This patch adds a check for ____vmalloc_area_node() failure within
__vmalloc_node_range. It does not use "goto fail" as in the previous
error path as a warning was already displayed by __vmalloc_area_node()
before it called vfree in its failure path.
Credit goes to Luciano Chavez for doing all the real work of identifying
exactly where the problem was.
Reported-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com>
Tested-by: Luciano Chavez <lnx1138@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> [3.1.x+]
pageblocks
setup_zone_migrate_reserve() expects that zone->start_pfn starts at
pageblock_nr_pages aligned pfn otherwise we could access beyond an
existing memblock resulting in the following panic if
CONFIG_HOLES_IN_ZONE is not configured and we do not check pfn_valid:
IP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180
*pdpt = 0000000000000000 *pde = f000ff53f000ff53
Oops: 0000 [#1] SMP
Pid: 1, comm: swapper Not tainted 3.0.7-0.7-pae #1 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform
EIP: 0060:[<c02d331d>] EFLAGS: 00010006 CPU: 0
EIP is at setup_zone_migrate_reserve+0xcd/0x180
EAX: 000c0000 EBX: f5801fc0 ECX: 000c0000 EDX: 00000000
ESI: 000c01fe EDI: 000c01fe EBP: 00140000 ESP: f2475f58
DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
Process swapper (pid: 1, ti=f2474000 task=f2472cd0 task.ti=f2474000)
Call Trace:
[<c02d389c>] __setup_per_zone_wmarks+0xec/0x160
[<c02d3a1f>] setup_per_zone_wmarks+0xf/0x20
[<c08a771c>] init_per_zone_wmark_min+0x27/0x86
[<c020111b>] do_one_initcall+0x2b/0x160
[<c086639d>] kernel_init+0xbe/0x157
[<c05cae26>] kernel_thread_helper+0x6/0xd
Code: a5 39 f5 89 f7 0f 46 fd 39 cf 76 40 8b 03 f6 c4 08 74 32 eb 91 90 89 c8 c1 e8 0e 0f be 80 80 2f 86 c0 8b 14 85 60 2f 86 c0 89 c8 <2b> 82 b4 12 00 00 c1 e0 05 03 82 ac 12 00 00 8b 00 f6 c4 08 0f
EIP: [<c02d331d>] setup_zone_migrate_reserve+0xcd/0x180 SS:ESP 0068:f2475f58
CR2: 00000000000012b4
We crashed in pageblock_is_reserved() when accessing pfn 0xc0000 because
highstart_pfn = 0x36ffe.
The issue was introduced in 3.0-rc1 by 6d3163ce ("mm: check if any page
in a pageblock is reserved before marking it MIGRATE_RESERVE").
Make sure that start_pfn is always aligned to pageblock_nr_pages to
ensure that pfn_valid s always called at the start of each pageblock.
Architectures with holes in pageblocks will be correctly handled by
pfn_valid_within in pageblock_is_reserved.
Tested-by: Dang Bo <bdang@vmware.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Arve Hjnnevg <arve@android.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> [3.0+]
Avoid unlocking and unlocked page if we failed to lock it.
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Commit 70b50f94f1644 ("mm: thp: tail page refcounting fix") keeps all
page_tail->_count zero at all times. But the current kernel does not
set page_tail->_count to zero if a 1GB page is utilized. So when an
IOMMU 1GB page is used by KVM, it wil result in a kernel oops because a
tail page's _count does not equal zero.
kernel BUG at include/linux/mm.h:386!
invalid opcode: 0000 [#1] SMP
Call Trace:
gup_pud_range+0xb8/0x19d
get_user_pages_fast+0xcb/0x192
? trace_hardirqs_off+0xd/0xf
hva_to_pfn+0x119/0x2f2
gfn_to_pfn_memslot+0x2c/0x2e
kvm_iommu_map_pages+0xfd/0x1c1
kvm_iommu_map_memslots+0x7c/0xbd
kvm_iommu_map_guest+0xaa/0xbf
kvm_vm_ioctl_assigned_device+0x2ef/0xa47
kvm_vm_ioctl+0x36c/0x3a2
do_vfs_ioctl+0x49e/0x4e4
sys_ioctl+0x5a/0x7c
RIP gup_huge_pud+0xf2/0x159
Signed-off-by: Youquan Song <youquan.song@intel.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
khugepaged can sometimes cause suspend to fail, requiring that the user
retry the suspend operation.
Use wait_event_freezable_timeout() instead of
schedule_timeout_interruptible() to avoid missing freezer wakeups. A
try_to_freeze() would have been needed in the khugepaged_alloc_hugepage
tight loop too in case of the allocation failing repeatedly, and
wait_event_freezable_timeout will provide it too.
khugepaged would still freeze just fine by trying again the next minute
but it's better if it freezes immediately.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Jiri Slaby <jslaby@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: "Rafael J. Wysocki" <rjw@suse.com>
Use atomic-long operations instead of looping around cmpxchg().
[akpm@linux-foundation.org: massage atomic.h inclusions]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
A shrinker function can return -1, means that it cannot do anything
without a risk of deadlock. For example prune_super() does this if it
cannot grab a superblock refrence, even if nr_to_scan=0. Currently we
interpret this -1 as a ULONG_MAX size shrinker and evaluate `total_scan'
according to this. So the next time around this shrinker can cause
really big pressure. Let's skip such shrinkers instead.
Also make total_scan signed, otherwise the check (total_scan < 0) below
never works.
Some trace shows lots of bdi_dirty=0 lines where it's actually some
small value if w/o the accounting errors in the per-cpu bdi stats.
In this case the max pause time should really be set to the smallest
(non-zero) value to avoid IO queue underrun and improve throughput.
On a system with 1 local mount and 1 NFS mount, if the NFS server
becomes not responding when dd to the NFS mount, the NFS dirty pages may
exceed the global dirty limit and _every_ task involving writing will be
blocked. The whole system appears unresponsive.
The workaround is to permit through the bdi's that only has a small
number of dirty pages. The number chosen (bdi_stat_error pages) is not
enough to enable the local disk to run in optimal throughput, however is
enough to make the system responsive on a broken NFS mount. The user can
then kill the dirtiers on the NFS mount and increase the global dirty
limit to bring up the local disk's throughput.
It risks allowing dirty pages to grow much larger than the global dirty
limit when there are 1000+ mounts, however that's very unlikely to happen,
especially in low memory profiles.
We do "floating proportions" to let active devices to grow its target
share of dirty pages and stalled/inactive devices to decrease its target
share over time.
It works well except in the case of "an inactive disk suddenly goes
busy", where the initial target share may be too small. To mitigate
this, bdi_position_ratio() has the below line to raise a small
bdi_thresh when it's safe to do so, so that the disk be feed with enough
dirty pages for efficient IO and in turn fast rampup of bdi_thresh:
bdi_thresh = max(bdi_thresh, (limit - dirty) / 8);
balance_dirty_pages() normally does negative feedback control which
adjusts ratelimit to balance the bdi dirty pages around the target.
In some extreme cases when that is not enough, it will have to block
the tasks completely until the bdi dirty pages drop below bdi_thresh.
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Commit 30765b92 ("slab, lockdep: Annotate the locks before using
them") moves the init_lock_keys() call from after g_cpucache_up =
FULL, to before it. And overlooks the fact that init_node_lock_keys()
tests for it and ignores everything !FULL.
Introduce a LATE stage and change the lockdep test to be <LATE.
Cc: Pekka Enberg <penberg@kernel.org>
Currently write(2) to a file is not interruptible by any signal.
Sometimes this is desirable, e.g. when you want to quickly kill a
process hogging your disk. Also, with commit 499d05ecf990 ("mm: Make
task in balance_dirty_pages() killable"), it's necessary to abort the
current write accordingly to avoid it quickly dirtying lots more pages
at unthrottled rate.
This patch makes write interruptible by SIGKILL. We do not allow write
to be interruptible by any other signal because that has larger
potential of screwing some badly written applications.
Reported-by: Kazuya Mio <k-mio@sx.jp.nec.com>
Tested-by: Kazuya Mio <k-mio@sx.jp.nec.com>
Acked-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
* 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
slub: avoid potential NULL dereference or corruption
slub: use irqsafe_cpu_cmpxchg for put_cpu_partial
slub: move discard_slab out of node lock
slub: use correct parameter to add a page to partial list tail
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-3.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: explain why per_cpu_ptr_to_phys() is more complicated than necessary
percpu: fix chunk range calculation
percpu: rename pcpu_mem_alloc to pcpu_mem_zalloc
show_slab_objects() can trigger NULL dereferences or memory corruption.
Another cpu can change its c->page to NULL or c->node to NUMA_NO_NODE
while we use them.
Use ACCESS_ONCE(c->page) and ACCESS_ONCE(c->node) to make sure this
cannot happen.
The cmpxchg must be irq safe. The fallback for this_cpu_cmpxchg only
disables preemption which results in per cpu partial page operation
potentially failing on non x86 platforms.
This patch fixes the following problem reported by Christian Kujau:
I seem to hit it with heavy disk & cpu IO is in progress on this
PowerBook
G4. Full dmesg & .config: http://nerdbynature.de/bits/3.2.0-rc1/oops/
I've enabled some debug options and now it really points to slub.c:2166
http://nerdbynature.de/bits/3.2.0-rc1/oops/oops4m.jpg
With debug options enabled I'm currently in the xmon debugger, not sure
what to make of it yet, I'll try to get something useful out of it :)
Reported-by: Christian Kujau <lists@nerdbynature.de>
Tested-by: Christian Kujau <lists@nerdbynature.de>
Signed-off-by: Christoph Lameter <cl@linux.com>
Add comments about current per_cpu_ptr_to_phys implementation to
explain why the logic is more complicated than necessary.
-tj: relocated comment into kerneldoc comment
Signed-off-by: Dave Young <dyoung@redhat.com>
writeback: remove vm_dirties and task->dirties
writeback: hard throttle 1000+ dd on a slow USB stick
mm: Make task in balance_dirty_pages() killable
Percpu allocator recorded the cpus which map to the first and last
units in pcpu_first/last_unit_cpu respectively and used them to
determine the address range of a chunk - e.g. it assumed that the
first unit has the lowest address in a chunk while the last unit has
the highest address.
This simply isn't true. Groups in a chunk can have arbitrary positive
or negative offsets from the previous one and there is no guarantee
that the first unit occupies the lowest offset while the last one the
highest.
Fix it by actually comparing unit offsets to determine cpus occupying
the lowest and highest offsets. Also, rename pcu_first/last_unit_cpu
to pcpu_low/high_unit_cpu to avoid confusion.
The chunk address range is used to flush cache on vmalloc area
map/unmap and decide whether a given address is in the first chunk by
per_cpu_ptr_to_phys() and the bug was discovered by invalid
per_cpu_ptr_to_phys() translation for crash_note.
Kudos to Dave Young for tracking down the problem.
Reported-by: WANG Cong <xiyou.wangcong@gmail.com>
Reported-by: Dave Young <dyoung@redhat.com>
Tested-by: Dave Young <dyoung@redhat.com>
LKML-Reference: <4EC21F67.10905@redhat.com>
Cc: stable @kernel.org
Currently pcpu_mem_alloc() is implemented always return zeroed memory.
So rename it to make user like pcpu_get_pages_and_bitmap() know don't
reinit it.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen-gntalloc: signedness bug in add_grefs()
xen-gntalloc: integer overflow in gntalloc_ioctl_alloc()
xen-gntdev: integer overflow in gntdev_alloc_map()
xen:pvhvm: enable PVHVM VCPU placement when using more than 32 CPUs.
xen/balloon: Avoid OOM when requesting highmem
xen: Remove hanging references to CONFIG_XEN_PLATFORM_PCI
xen: map foreign pages for shared rings by updating the PTEs directly
* 'for-linus' of git://git.kernel.dk/linux-block:
block: add missed trace_block_plug
paride: fix potential information leak in pg_read()
bio: change some signed vars to unsigned
block: avoid unnecessary plug list flush
cciss: auto engage SCSI mid layer at driver load time
loop: cleanup set_status interface
include/linux/bio.h: use a static inline function for bio_integrity_clone()
loop: prevent information leak after failed read
block: Always check length of all iov entries in blk_rq_map_user_iov()
The Windows driver .inf disables ASPM on all cciss devices. Do the same.
block: Revert "[SCSI] genhd: add a new attribute "alias" in gendisk"
They are not used any more.
The sleep based balance_dirty_pages() can pause at most MAX_PAUSE=200ms
on every 1 4KB-page, which means it cannot throttle a task under
4KB/200ms=20KB/s. So when there are more than 512 dd writing to a
10MB/s USB stick, its bdi dirty pages could grow out of control.
Even if we can increase MAX_PAUSE, the minimal (task_ratelimit = 1)
means a limit of 4KB/s.
They can eventually be safeguarded by the global limit check
(nr_dirty < dirty_thresh). However if someone is also writing to an
HDD at the same time, it'll get poor HDD write performance.
We at least want to maintain good write performance for other devices
when one device is attacked by some "massive parallel" workload, or
suffers from slow write bandwidth, or somehow get stalled due to some
error condition (eg. NFS server not responding).
For a stalled device, we need to completely block its dirtiers, too,
before its bdi dirty pages grow all the way up to the global limit and
leave no space for the other functional devices.
So change the loop exit condition to
* Always enforce global dirty limit; also enforce bdi dirty limit
* if the normal max_pause sleeps cannot keep things under control.
if (nr_dirty < dirty_thresh &&
(bdi_dirty < bdi_thresh || bdi->dirty_ratelimit > 1))
break;
which can be further simplified to
if (task_ratelimit)
break;
When mapping a foreign page with xenbus_map_ring_valloc() with the
GNTTABOP_map_grant_ref hypercall, set the GNTMAP_contains_pte flag and
pass a pointer to the PTE (in init_mm).
After the page is mapped, the usual fault mechanism can be used to
update additional MMs. This allows the vmalloc_sync_all() to be
removed from alloc_vm_area().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
[v1: Squashed fix by Michal for no-mmu case]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
There is no reason why task in balance_dirty_pages() shouldn't be killable
and it helps in recovering from some error conditions (like when filesystem
goes in error state and cannot accept writeback anymore but we still want to
kill processes using it to be able to unmount it).
There will be follow up patches to further abort the generic_perform_write()
and other filesystem write loops, to avoid large write + SIGKILL combination
exceeding the dirty limit and possibly strange OOM.
Reviewed-by: Neil Brown <neilb@suse.de>
If we fail to prepare an anon_vma, the {new, old}_page should be released,
or they will leak.
Cc: Johannes Weiner <jweiner@redhat.com>
Commit c9f01245 ("oom: remove oom_disable_count") has removed the
oom_disable_count counter which has been used for early break out from
oom_badness so we could never select a task with oom_score_adj set to
OOM_SCORE_ADJ_MIN (oom disabled).
Now that the counter is gone we are always going through heuristics
calculation and we always return a non zero positive value. This means
that we can end up killing a task with OOM disabled because it is
indistinguishable from regular tasks with 1% resp. CAP_SYS_ADMIN tasks
with 3% usage of memory or tasks with oom_score_adj set but OOM enabled.
Let's break out early if the task should have OOM disabled.
Cc: Ying Han <yinghan@google.com>
Lockdep reports there is potential deadlock for slub node list_lock.
discard_slab() is called with the lock hold in unfreeze_partials(),
which could trigger a slab allocation, which could hold the lock again.
discard_slab() doesn't need hold the lock actually, if the slab is
already removed from partial list.
Reported-and-tested-by: Yong Zhang <yong.zhang0@gmail.com>
Reported-and-tested-by: Julie Sullivan <kernelmail.jms@gmail.com>
unfreeze_partials() needs add the page to partial list tail, since such page
hasn't too many free objects. We now explictly use DEACTIVATE_TO_TAIL for this,
while DEACTIVATE_TO_TAIL != 1. This will cause performance regression (eg, more
lock contention in node->list_lock) without below fix.
bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links
from all super_blocks and then del_timer_sync() the writeback timer.
However, this can race with __mark_inode_dirty(), leading to
bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi
we're unregistering, after we've called del_timer_sync().
This can end up with the bdi being freed with an active timer inside it,
as in the case of the following dump after the removal of an SD card.
Fix this by redoing the del_timer_sync() in bdi_destory().
WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8()
ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180
Modules linked in:
Backtrace:
[<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c)
r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000
[<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c)
[<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40)
r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29
r3:00000009
[<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8)
r3:c02b1b29 r2:c02bc662
[<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc)
r6:c7964000 r5:00000001 r4:c7964000
[<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8)
[<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78)
[<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84)
r5:c79641f0 r4:c796420c
[<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80)
r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c
[<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c)
r5:c79643b4 r4:c79641f0
[<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74)
r4:c7964000
[<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8)
r5:00000000 r4:c794c400
[<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38)
r5:c794c400 r4:c0322824
[<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170)
r5:c78d5e00 r4:c74083c0
[<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c)
r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0
r3:00000000
[<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c)
r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0
[<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70)
r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4
[<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70)
r5:c794dc00 r4:c794dc00
[<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194)
r5:c794dc00 r4:c7942300
[<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310)
r6:c7942300 r5:00000000 r4:00000000 r3:00000000
[<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30)
---[ end trace e5c83c92ada51c76 ]---
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
