path: root/mm
2009-12-08page allocator: always wake kswapd when restarting an allocation attempt ↵Mel Gorman
after direct reclaim failed commit cc4a6851466039a8a688c843962a05689059ff3b upstream. If a direct reclaim makes no forward progress, it considers whether it should go OOM or not. Whether OOM is triggered or not, it may retry the allocation afterwards. In times past, this would always wake kswapd as well but currently, kswapd is not woken up after direct reclaim fails. For order-0 allocations, this makes little difference but if there is a heavy mix of higher-order allocations that direct reclaim is failing for, it might mean that kswapd is not rewoken for higher orders as much as it did previously. This patch wakes up kswapd when an allocation is being retried after a direct reclaim failure. It would be expected that kswapd is already awake, but this has the effect of telling kswapd to reclaim at the higher order as well. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-08page allocator: Do not allow interrupts to use ALLOC_HARDERMel Gorman
commit 9d0ed60fe9cd1fbf57f755cd27a23ae9114d7210 upstream. Commit 341ce06f69abfafa31b9468410a13dbd60e2b237 ("page allocator: calculate the alloc_flags for allocation only once") altered watermark logic slightly by allowing rt_tasks that are handling an interrupt to set ALLOC_HARDER. This patch brings the watermark logic more in line with 2.6.30. This change results in a reduction of the number high-order GFP_ATOMIC allocation failures reported. See http://www.gossamer-threads.com/lists/linux/kernel/1144153 [rientjes@google.com: Spotted the problem] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-08memcg: fix wrong pointer initialization at page migration when memcg is ↵KAMEZAWA Hiroyuki
disabled. commit e00e431612c3a6e437a01f2129fd3843da0c982a upstream. Lee Schermerhorn reported that he saw bad pointer dereference in mem_cgroup_end_migration() when he disabled memcg by boot option. memcg's page migration logic works as mem_cgroup_prepare_migration(page, &ptr); do page migration mem_cgroup_end_migration(page, ptr); Now, ptr is not initialized in prepare_migration when memcg is disabled by boot option. This causes panic in end_migration. This patch fixes it. Reported-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-08highmem: Fix debug_kmap_atomic() to also handle KM_IRQ_PTE, KM_NMI, and ↵Soeren Sandmann
KM_NMI_PTE commit d4515646699b6ad7b1a98ceb871296b957f3ef47 upstream. Previously calling debug_kmap_atomic() with these types would cause spurious warnings. (triggered by SysProf using perf events) Signed-off-by: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: a.p.zijlstra@chello.nl LKML-Reference: <ye8vdhz8krw.fsf@camel23.daimi.au.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-08highmem: Fix race in debug_kmap_atomic() which could cause warn_count to ↵Soeren Sandmann
underflow commit 5ebd4c22897dce65845807a9bd3a31cc4e142b53 upstream. debug_kmap_atomic() tries to prevent ever printing more than 10 warnings, but it does so by testing whether an unsigned integer is equal to 0. However, if the warning is caused by a nested IRQ, then this counter may underflow and the stream of warnings will never end. Fix that by using a signed integer instead. Signed-off-by: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: a.p.zijlstra@chello.nl LKML-Reference: <ye8zl7b8ktj.fsf@camel23.daimi.au.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-09vmscan: limit VM_EXEC protection to file pagesWu Fengguang
commit 41e20983fe553b39bc2b00e07c7a379f0c86a4bc upstream. It is possible to have !Anon but SwapBacked pages, and some apps could create huge number of such pages with MAP_SHARED|MAP_ANONYMOUS. These pages go into the ANON lru list, and hence shall not be protected: we only care mapped executable files. Failing to do so may trigger OOM. Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-09mm: remove incorrect swap_count() from try_to_unuse()Bo Liu
commit 32c5fc10e79a7053ac5728b01a0bff55cbcb9d49 upstream. In try_to_unuse(), swcount is a local copy of *swap_map, including the SWAP_HAS_CACHE bit; but a wrong comparison against swap_count(*swap_map), which masks off the SWAP_HAS_CACHE bit, succeeded where it should fail. That had the effect of resetting the mm from which to start searching for the next swap page, to an irrelevant mm instead of to an mm in which this swap page had been found: which may increase search time by ~20%. But we're used to swapoff being slow, so never noticed the slowdown. Remove that one spurious use of swap_count(): Bo Liu thought it merely redundant, Hugh rewrote the description since it was measurably wrong. Signed-off-by: Bo Liu <bo-liu@hotmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-09NOMMU: Don't pass NULL pointers to fput() in do_mmap_pgoff()David Howells
commit 89a8640279f8bb78aaf778d1fc5c4a6778f18064 upstream. Don't pass NULL pointers to fput() in the error handling paths of the NOMMU do_mmap_pgoff() as it can't handle it. The following can be used as a test program: int main() { static long long a[1024 * 1024 * 20] = { 0 }; return a;} Without the patch, the code oopses in atomic_long_dec_and_test() as called by fput() after the kernel complains that it can't allocate that big a chunk of memory. With the patch, the kernel just complains about the allocation size and then the program segfaults during execve() as execve() can't complete the allocation of all the new ELF program segments. Reported-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-09do_mbind(): fix memory leakKOSAKI Motohiro
commit b05ca7385a2848abdc72051f832722641daed8b0 upstream. If migrate_prep is failed, new variable is leaked. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-09mbind(): fix leak of never putback pagesKOSAKI Motohiro
commit ab8a3e14e6f8e567560f664bbd29aefb306a274e upstream. If mbind() receives an invalid address, do_mbind leaks a page. The following test program detects this leak. This patch fixes it. migrate_efault.c ======================================= #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; static void* make_hole_mapping(void) { void* addr; addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) return NULL; /* make page populate */ memset(addr, 0, pagesize*3); /* make memory hole */ munmap(addr+pagesize, pagesize); return addr; } int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = make_hole_mapping(); err = mbind(addr, pagesize*3, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) perror("mbind "); return 0; } ======================================= Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-12mm: add_to_swap_cache() must not sleepDaisuke Nishimura
commit 31a5639623a487d6db996c8138c9e53fef2e2d91 upstream. After commit 355cfa73 ("mm: modify swap_map and add SWAP_HAS_CACHE flag"), read_swap_cache_async() will busy-wait while a entry doesn't exist in swap cache but it has SWAP_HAS_CACHE flag. Such entries can exist on add/delete path of swap cache. On add path, add_to_swap_cache() is called soon after SWAP_HAS_CACHE flag is set, and on delete path, swapcache_free() will be called (SWAP_HAS_CACHE flag is cleared) soon after __delete_from_swap_cache() is called. So, the busy-wait works well in most cases. But this mechanism can cause soft lockup if add_to_swap_cache() sleeps and read_swap_cache_async() tries to swap-in the same entry on the same cpu. This patch calls radix_tree_preload() before swapcache_prepare() and divides add_to_swap_cache() into two part: radix_tree_preload() part and radix_tree_insert() part(define it as __add_to_swap_cache()). Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05NOMMU: Fix MAP_PRIVATE mmap() of objects where the data can be mapped directlyDavid Howells
commit 645d83c5db970a1c57225e155113b4aa2451e920 upstream. Fix MAP_PRIVATE mmap() of files and devices where the data in the backing store might be mapped directly. Use the BDI_CAP_MAP_DIRECT capability flag to govern whether or not we should be trying to map a file directly. This can be used to determine whether or not a region has been filled in at the point where we call do_mmap_shared() or do_mmap_private(). The BDI_CAP_MAP_DIRECT capability flag is cleared by validate_mmap_request() if there's any reason we can't use it. It's also cleared in do_mmap_pgoff() if f_op->get_unmapped_area() fails. Without this fix, attempting to run a program from a RomFS image on a non-mappable MTD partition results in a BUG as the kernel attempts XIP, and this can be caught in gdb: Program received signal SIGABRT, Aborted. 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 (gdb) bt #0 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 #1 0xc005f168 in do_mmap_pgoff (file=0xc31a6620, addr=<value optimized out>, len=3808, prot=3, flags=6146, pgoff=0) at mm/nommu.c:1373 #2 0xc00a96b8 in elf_fdpic_map_file (params=0xc33fbbec, file=0xc31a6620, mm=0xc31bef60, what=0xc0213144 "executable") at mm.h:1145 #3 0xc00aa8b4 in load_elf_fdpic_binary (bprm=0xc316cb00, regs=<value optimized out>) at fs/binfmt_elf_fdpic.c:343 #4 0xc006b588 in search_binary_handler (bprm=0x6, regs=0xc33fbce0) at fs/exec.c:1234 #5 0xc006c648 in do_execve (filename=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460, regs=0xc33fbce0) at fs/exec.c:1356 #6 0xc0008cf0 in sys_execve (name=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460) at arch/frv/kernel/process.c:263 #7 0xc00075dc in __syscall_call () at arch/frv/kernel/entry.S:897 Note that this fix does the following commit differently: commit a190887b58c32d19c2eee007c5eb8faa970a69ba Author: David Howells <dhowells@redhat.com> Date: Sat Sep 5 11:17:07 2009 -0700 nommu: fix error handling in do_mmap_pgoff() Reported-by: Graff Yang <graff.yang@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mmap: avoid unnecessary anon_vma lock acquisition in vma_adjust()Lee Schermerhorn
commit 252c5f94d944487e9f50ece7942b0fbf659c5c31 upstream. We noticed very erratic behavior [throughput] with the AIM7 shared workload running on recent distro [SLES11] and mainline kernels on an 8-socket, 32-core, 256GB x86_64 platform. On the SLES11 kernel [2.6.27.19+] with Barcelona processors, as we increased the load [10s of thousands of tasks], the throughput would vary between two "plateaus"--one at ~65K jobs per minute and one at ~130K jpm. The simple patch below causes the results to smooth out at the ~130k plateau. But wait, there's more: We do not see this behavior on smaller platforms--e.g., 4 socket/8 core. This could be the result of the larger number of cpus on the larger platform--a scalability issue--or it could be the result of the larger number of interconnect "hops" between some nodes in this platform and how the tasks for a given load end up distributed over the nodes' cpus and memories--a stochastic NUMA effect. The variability in the results are less pronounced [on the same platform] with Shanghai processors and with mainline kernels. With 31-rc6 on Shanghai processors and 288 file systems on 288 fibre attached storage volumes, the curves [jpm vs load] are both quite flat with the patched kernel consistently producing ~3.9% better throughput [~80K jpm vs ~77K jpm] than the unpatched kernel. Profiling indicated that the "slow" runs were incurring high[er] contention on an anon_vma lock in vma_adjust(), apparently called from the sbrk() system call. The patch: A comment in mm/mmap.c:vma_adjust() suggests that we don't really need the anon_vma lock when we're only adjusting the end of a vma, as is the case for brk(). The comment questions whether it's worth while to optimize for this case. Apparently, on the newer, larger x86_64 platforms, with interesting NUMA topologies, it is worth while--especially considering that the patch [if correct!] is quite simple. We can detect this condition--no overlap with next vma--by noting a NULL "importer". The anon_vma pointer will also be NULL in this case, so simply avoid loading vma->anon_vma to avoid the lock. However, we DO need to take the anon_vma lock when we're inserting a vma ['insert' non-NULL] even when we have no overlap [NULL "importer"], so we need to check for 'insert', as well. And Hugh points out that we should also take it when adjusting vm_start (so that rmap.c can rely upon vma_address() while it holds the anon_vma lock). akpm: Zhang Yanmin reprts a 150% throughput improvement with aim7, so it might be -stable material even though thiss isn't a regression: "this issue is not clear on dual socket Nehalem machine (2*4*2 cpu), but is severe on large machine (4*8*2 cpu)" [hugh.dickins@tiscali.co.uk: test vma start too] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: Eric Whitney <eric.whitney@hp.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mm: fix anonymous dirtyingHugh Dickins
commit 1ac0cb5d0e22d5e483f56b2bc12172dec1cf7536 upstream. do_anonymous_page() has been wrong to dirty the pte regardless. If it's not going to mark the pte writable, then it won't help to mark it dirty here, and clogs up memory with pages which will need swap instead of being thrown away. Especially wrong if no overcommit is chosen, and this vma is not yet VM_ACCOUNTed - we could exceed the limit and OOM despite no overcommit. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mm: munlock use follow_pageHugh Dickins
commit 408e82b78bcc9f1b47c76e833c3df97f675947de upstream. Hiroaki Wakabayashi points out that when mlock() has been interrupted by SIGKILL, the subsequent munlock() takes unnecessarily long because its use of __get_user_pages() insists on faulting in all the pages which mlock() never reached. It's worse than slowness if mlock() is terminated by Out Of Memory kill: the munlock_vma_pages_all() in exit_mmap() insists on faulting in all the pages which mlock() could not find memory for; so innocent bystanders are killed too, and perhaps the system hangs. __get_user_pages() does a lot that's silly for munlock(): so remove the munlock option from __mlock_vma_pages_range(), and use a simple loop of follow_page()s in munlock_vma_pages_range() instead; ignoring absent pages, and not marking present pages as accessed or dirty. (Change munlock() to only go so far as mlock() reached? That does not work out, given the convention that mlock() claims complete success even when it has to give up early - in part so that an underlying file can be extended later, and those pages locked which earlier would give SIGBUS.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Hiroaki Wakabayashi <primulaelatior@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05page-allocator: limit the number of MIGRATE_RESERVE pageblocks per zoneMel Gorman
commit 78986a678f6ec3759a01976749f4437d8bf2d6c3 upstream. After anti-fragmentation was merged, a bug was reported whereby devices that depended on high-order atomic allocations were failing. The solution was to preserve a property in the buddy allocator which tended to keep the minimum number of free pages in the zone at the lower physical addresses and contiguous. To preserve this property, MIGRATE_RESERVE was introduced and a number of pageblocks at the start of a zone would be marked "reserve", the number of which depended on min_free_kbytes. Anti-fragmentation works by avoiding the mixing of page migratetypes within the same pageblock. One way of helping this is to increase min_free_kbytes because it becomes less like that it will be necessary to place pages of of MIGRATE_RESERVE is unbounded, the free memory is kept there in large contiguous blocks instead of helping anti-fragmentation as much as it should. With the page-allocator tracepoint patches applied, it was found during anti-fragmentation tests that the number of fragmentation-related events were far higher than expected even with min_free_kbytes at higher values. This patch limits the number of MIGRATE_RESERVE blocks that exist per zone to two. For example, with a sufficient min_free_kbytes, 4MB of memory will be kept aside on an x86-64 and remain more or less free and contiguous for the systems uptime. This should be sufficient for devices depending on high-order atomic allocations while helping fragmentation control when min_free_kbytes is tuned appropriately. As side-effect of this patch is that the reserve variable is converted to int as unsigned long was the wrong type to use when ensuring that only the required number of reserve blocks are created. With the patches applied, fragmentation-related events as measured by the page allocator tracepoints were significantly reduced when running some fragmentation stress-tests on systems with min_free_kbytes tuned to a value appropriate for hugepage allocations at runtime. On x86, the events recorded were reduced by 99.8%, on x86-64 by 99.72% and on ppc64 by 99.83%. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05hugetlb: restore interleaving of bootmem huge pages (2.6.31)Lee Schermerhorn
Not upstream as it is fixed differently in .32 I noticed that alloc_bootmem_huge_page() will only advance to the next node on failure to allocate a huge page. I asked about this on linux-mm and linux-numa, cc'ing the usual huge page suspects. Mel Gorman responded: I strongly suspect that the same node being used until allocation failure instead of round-robin is an oversight and not deliberate at all. It appears to be a side-effect of a fix made way back in commit 63b4613c3f0d4b724ba259dc6c201bb68b884e1a ["hugetlb: fix hugepage allocation with memoryless nodes"]. Prior to that patch it looked like allocations would always round-robin even when allocation was successful. Andy Whitcroft countered that the existing behavior looked like Andi Kleen's original implementation and suggested that we ask him. We did and Andy replied that his intention was to interleave the allocations. So, ... This patch moves the advance of the hstate next node from which to allocate up before the test for success of the attempted allocation. This will unconditionally advance the next node from which to alloc, interleaving successful allocations over the nodes with sufficient contiguous memory, and skipping over nodes that fail the huge page allocation attempt. Note that alloc_bootmem_huge_page() will only be called for huge pages of order > MAX_ORDER. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Eric Whitney <eric.whitney@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: don't assume existence of cpu0
2009-09-05Merge branch 'slab/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: Fix kmem_cache_destroy() with SLAB_DESTROY_BY_RCU
2009-09-05page-allocator: always change pageblock ownership when anti-fragmentation is ↵Mel Gorman
disabled On low-memory systems, anti-fragmentation gets disabled as fragmentation cannot be avoided on a sufficiently large boundary to be worthwhile. Once disabled, there is a period of time when all the pageblocks are marked MOVABLE and the expectation is that they get marked UNMOVABLE at each call to __rmqueue_fallback(). However, when MAX_ORDER is large the pageblocks do not change ownership because the normal criteria are not met. This has the effect of prematurely breaking up too many large contiguous blocks. This is most serious on NOMMU systems which depend on high-order allocations to boot. This patch causes pageblocks to change ownership on every fallback when anti-fragmentation is disabled. This prevents the large blocks being prematurely broken up. This is a fix to commit 49255c619fbd482d704289b5eb2795f8e3b7ff2e [page allocator: move check for disabled anti-fragmentation out of fastpath] and the problem affects 2.6.31-rc8. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05nommu: fix error handling in do_mmap_pgoff()David Howells
Fix the error handling in do_mmap_pgoff(). If do_mmap_shared_file() or do_mmap_private() fail, we jump to the error_put_region label at which point we cann __put_nommu_region() on the region - but we haven't yet added the region to the tree, and so __put_nommu_region() may BUG because the region tree is empty or it may corrupt the region tree. To get around this, we can afford to add the region to the region tree before calling do_mmap_shared_file() or do_mmap_private() as we keep nommu_region_sem write-locked, so no-one can race with us by seeing a transient region. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-03slub: Fix kmem_cache_destroy() with SLAB_DESTROY_BY_RCUEric Dumazet
kmem_cache_destroy() should call rcu_barrier() *after* kmem_cache_close() and *before* sysfs_slab_remove() or risk rcu_free_slab() being called after kmem_cache is deleted (kfreed). rmmod nf_conntrack can crash the machine because it has to kmem_cache_destroy() a SLAB_DESTROY_BY_RCU enabled cache. Cc: <stable@kernel.org> Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-09-01percpu: don't assume existence of cpu0Tejun Heo
percpu incorrectly assumed that cpu0 was always there which led to the following warning and eventual oops on sparc machines w/o cpu0. WARNING: at mm/percpu.c:651 pcpu_map+0xdc/0x100() Modules linked in: Call Trace: [000000000045eb70] warn_slowpath_common+0x50/0xa0 [000000000045ebdc] warn_slowpath_null+0x1c/0x40 [00000000004d493c] pcpu_map+0xdc/0x100 [00000000004d59a4] pcpu_alloc+0x3e4/0x4e0 [00000000004d5af8] __alloc_percpu+0x18/0x40 [00000000005b112c] __percpu_counter_init+0x4c/0xc0 ... Unable to handle kernel NULL pointer dereference ... I7: <sysfs_new_dirent+0x30/0x120> Disabling lock debugging due to kernel taint Caller[000000000053c1b0]: sysfs_new_dirent+0x30/0x120 Caller[000000000053c7a4]: create_dir+0x24/0xc0 Caller[000000000053c870]: sysfs_create_dir+0x30/0x80 Caller[00000000005990e8]: kobject_add_internal+0xc8/0x200 ... Kernel panic - not syncing: Attempted to kill the idle task! This patch fixes the problem by backporting parts from devel branch to make percpu core not depend on the existence of cpu0. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Meelis Roos <mroos@linux.ee> Cc: David Miller <davem@davemloft.net>
2009-08-26mm: fix for infinite churning of mlocked pagesMinchan Kim
An mlocked page might lose the isolatation race. This causes the page to clear PG_mlocked while it remains in a VM_LOCKED vma. This means it can be put onto the [in]active list. We can rescue it by using try_to_unmap() in shrink_page_list(). But now, As Wu Fengguang pointed out, vmscan has a bug. If the page has PG_referenced, it can't reach try_to_unmap() in shrink_page_list() but is put into the active list. If the page is referenced repeatedly, it can remain on the [in]active list without being moving to the unevictable list. This patch fixes it. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <<kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: use the right flag for get_vm_area() percpu, sparc64: fix sparse possible cpu map handling init: set nr_cpu_ids before setup_per_cpu_areas()
2009-08-18mm: build_zonelists(): move clear node_load[] to __build_all_zonelists()Bo Liu
If node_load[] is cleared everytime build_zonelists() is called,node_load[] will have no help to find the next node that should appear in the given node's fallback list. Because of the bug, zonelist's node_order is not calculated as expected. This bug affects on big machine, which has asynmetric node distance. [synmetric NUMA's node distance] 0 1 2 0 10 12 12 1 12 10 12 2 12 12 10 [asynmetric NUMA's node distance] 0 1 2 0 10 12 20 1 12 10 14 2 20 14 10 This (my bug) is very old but no one has reported this for a long time. Maybe because the number of asynmetric NUMA is very small and they use cpuset for customizing node memory allocation fallback. [akpm@linux-foundation.org: fix CONFIG_NUMA=n build] Signed-off-by: Bo Liu <bo-liu@hotmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18nommu: check fd read permission in validate_mmap_request()Graff Yang
According to the POSIX (1003.1-2008), the file descriptor shall have been opened with read permission, regardless of the protection options specified to mmap(). The ltp test cases mmap06/07 need this. Signed-off-by: Graff Yang <graff.yang@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18mm: revert "oom: move oom_adj value"KOSAKI Motohiro
The commit 2ff05b2b (oom: move oom_adj value) moveed the oom_adj value to the mm_struct. It was a very good first step for sanitize OOM. However Paul Menage reported the commit makes regression to his job scheduler. Current OOM logic can kill OOM_DISABLED process. Why? His program has the code of similar to the following. ... set_oom_adj(OOM_DISABLE); /* The job scheduler never killed by oom */ ... if (vfork() == 0) { set_oom_adj(0); /* Invoked child can be killed */ execve("foo-bar-cmd"); } .... vfork() parent and child are shared the same mm_struct. then above set_oom_adj(0) doesn't only change oom_adj for vfork() child, it's also change oom_adj for vfork() parent. Then, vfork() parent (job scheduler) lost OOM immune and it was killed. Actually, fork-setting-exec idiom is very frequently used in userland program. We must not break this assumption. Then, this patch revert commit 2ff05b2b and related commit. Reverted commit list --------------------- - commit 2ff05b2b4e (oom: move oom_adj value from task_struct to mm_struct) - commit 4d8b9135c3 (oom: avoid unnecessary mm locking and scanning for OOM_DISABLE) - commit 8123681022 (oom: only oom kill exiting tasks with attached memory) - commit 933b787b57 (mm: copy over oom_adj value at fork time) Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-17Security/SELinux: seperate lsm specific mmap_min_addrEric Paris
Currently SELinux enforcement of controls on the ability to map low memory is determined by the mmap_min_addr tunable. This patch causes SELinux to ignore the tunable and instead use a seperate Kconfig option specific to how much space the LSM should protect. The tunable will now only control the need for CAP_SYS_RAWIO and SELinux permissions will always protect the amount of low memory designated by CONFIG_LSM_MMAP_MIN_ADDR. This allows users who need to disable the mmap_min_addr controls (usual reason being they run WINE as a non-root user) to do so and still have SELinux controls preventing confined domains (like a web server) from being able to map some area of low memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-14percpu: use the right flag for get_vm_area()Amerigo Wang
get_vm_area() only accepts VM_* flags, not GFP_*. And according to the doc of get_vm_area(), here should be VM_ALLOC. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu>
2009-08-14percpu, sparc64: fix sparse possible cpu map handlingTejun Heo
percpu code has been assuming num_possible_cpus() == nr_cpu_ids which is incorrect if cpu_possible_map contains holes. This causes percpu code to access beyond allocated memories and vmalloc areas. On a sparc64 machine with cpus 0 and 2 (u60), this triggers the following warning or fails boot. WARNING: at /devel/tj/os/work/mm/vmalloc.c:106 vmap_page_range_noflush+0x1f0/0x240() Modules linked in: Call Trace: [00000000004b17d0] vmap_page_range_noflush+0x1f0/0x240 [00000000004b1840] map_vm_area+0x20/0x60 [00000000004b1950] __vmalloc_area_node+0xd0/0x160 [0000000000593434] deflate_init+0x14/0xe0 [0000000000583b94] __crypto_alloc_tfm+0xd4/0x1e0 [00000000005844f0] crypto_alloc_base+0x50/0xa0 [000000000058b898] alg_test_comp+0x18/0x80 [000000000058dad4] alg_test+0x54/0x180 [000000000058af00] cryptomgr_test+0x40/0x60 [0000000000473098] kthread+0x58/0x80 [000000000042b590] kernel_thread+0x30/0x60 [0000000000472fd0] kthreadd+0xf0/0x160 ---[ end trace 429b268a213317ba ]--- This patch fixes generic percpu functions and sparc64 setup_per_cpu_areas() so that they handle sparse cpu_possible_map properly. Please note that on x86, cpu_possible_map() doesn't contain holes and thus num_possible_cpus() == nr_cpu_ids and this patch doesn't cause any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu>
2009-08-10mempool.c: clean up type-castingFigo.zhang
clean up type-casting twice. "size_t" is typedef as "unsigned long" in 64-bit system, and "unsigned int" in 32-bit system, and the intermediate cast to 'long' is pointless. Signed-off-by: Figo.zhang <figo1802@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07mm: make set_mempolicy(MPOL_INTERLEAV) N_HIGH_MEMORY awareKAMEZAWA Hiroyuki
At first, init_task's mems_allowed is initialized as this. init_task->mems_allowed == node_state[N_POSSIBLE] And cpuset's top_cpuset mask is initialized as this top_cpuset->mems_allowed = node_state[N_HIGH_MEMORY] Before 2.6.29: policy's mems_allowed is initialized as this. 1. update tasks->mems_allowed by its cpuset->mems_allowed. 2. policy->mems_allowed = nodes_and(tasks->mems_allowed, user's mask) Updating task's mems_allowed in reference to top_cpuset's one. cpuset's mems_allowed is aware of N_HIGH_MEMORY, always. In 2.6.30: After commit 58568d2a8215cb6f55caf2332017d7bdff954e1c ("cpuset,mm: update tasks' mems_allowed in time"), policy's mems_allowed is initialized as this. 1. policy->mems_allowd = nodes_and(task->mems_allowed, user's mask) Here, if task is in top_cpuset, task->mems_allowed is not updated from init's one. Assume user excutes command as #numactrl --interleave=all ,.... policy->mems_allowd = nodes_and(N_POSSIBLE, ALL_SET_MASK) Then, policy's mems_allowd can includes a possible node, which has no pgdat. MPOL's INTERLEAVE just scans nodemask of task->mems_allowd and access this directly. NODE_DATA(nid)->zonelist even if NODE_DATA(nid)==NULL Then, what's we need is making policy->mems_allowed be aware of N_HIGH_MEMORY. This patch does that. But to do so, extra nodemask will be on statck. Because I know cpumask has a new interface of CPUMASK_ALLOC(), I added it to node. This patch stands on old behavior. But I feel this fix itself is just a Band-Aid. But to do fundametal fix, we have to take care of memory hotplug and it takes time. (task->mems_allowd should be N_HIGH_MEMORY, I think.) mpol_set_nodemask() should be aware of N_HIGH_MEMORY and policy's nodemask should be includes only online nodes. In old behavior, this is guaranteed by frequent reference to cpuset's code. Now, most of them are removed and mempolicy has to check it by itself. To do check, a few nodemask_t will be used for calculating nodemask. But, size of nodemask_t can be big and it's not good to allocate them on stack. Now, cpumask_t has CPUMASK_ALLOC/FREE an easy code for get scratch area. NODEMASK_ALLOC/FREE shoudl be there. [akpm@linux-foundation.org: cleanups & tweaks] Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Paul Menage <menage@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Rientjes <rientjes@google.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Hibernate: Replace bdget call with simple atomic_inc of i_count PM / ACPI: HP G7000 Notebook needs a SCI_EN resume quirk
2009-07-29page-allocator: allow too high-order warning messages to be suppressed with ↵Mel Gorman
__GFP_NOWARN The page allocator warns once when an order >= MAX_ORDER is specified. This is to catch callers of the allocator that are always falling back to their worst-case when it was not expected. However, there are cases where the caller is behaving correctly but cannot suppress the warning. This patch allows the warning to be suppressed by the callers by specifying __GFP_NOWARN. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: David Rientjes <rientjes@google.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29cgroup avoid permanent sleep at rmdirKAMEZAWA Hiroyuki
After commit ec64f51545fffbc4cb968f0cea56341a4b07e85a ("cgroup: fix frequent -EBUSY at rmdir"), cgroup's rmdir (especially against memcg) doesn't return -EBUSY by temporary ref counts. That commit expects all refs after pre_destroy() is temporary but...it wasn't. Then, rmdir can wait permanently. This patch tries to fix that and change followings. - set CGRP_WAIT_ON_RMDIR flag before pre_destroy(). - clear CGRP_WAIT_ON_RMDIR flag when the subsys finds racy case. if there are sleeping ones, wakes them up. - rmdir() sleeps only when CGRP_WAIT_ON_RMDIR flag is set. Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: Paul Menage <menage@google.com> Acked-by: Balbir Sigh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29hugetlbfs: fix i_blocks accountingEric Sandeen
As reported in Red Hat bz #509671, i_blocks for files on hugetlbfs get accounting wrong when doing something like: $ > foo $ date > foo date: write error: Invalid argument $ /usr/bin/stat foo File: `foo' Size: 0 Blocks: 18446744073709547520 IO Block: 2097152 regular ... This is because hugetlb_unreserve_pages() is unconditionally removing blocks_per_huge_page(h) on each call rather than using the freed amount. If there were 0 blocks, it goes negative, resulting in the above. This is a regression from commit a5516438959d90b071ff0a484ce4f3f523dc3152 ("hugetlb: modular state for hugetlb page size") which did: - inode->i_blocks -= BLOCKS_PER_HUGEPAGE * freed; + inode->i_blocks -= blocks_per_huge_page(h); so just put back the freed multiplier, and it's all happy again. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Andi Kleen <andi@firstfloor.org> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29mm: avoid endless looping for oom killed tasksDavid Rientjes
If a task is oom killed and still cannot find memory when trying with no watermarks, it's better to fail the allocation attempt than to loop endlessly. Direct reclaim has already failed and the oom killer will be a no-op since current has yet to die, so there is no other alternative for allocations that are not __GFP_NOFAIL. Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29page-allocator: preserve PFN ordering when __GFP_COLD is setMel Gorman
Fix a post-2.6.24 performace regression caused by 3dfa5721f12c3d5a441448086bee156887daa961 ("page-allocator: preserve PFN ordering when __GFP_COLD is set"). Narayanan reports "The regression is around 15%. There is no disk controller as our setup is based on Samsung OneNAND used as a memory mapped device on a OMAP2430 based board." The page allocator tries to preserve contiguous PFN ordering when returning pages such that repeated callers to the allocator have a strong chance of getting physically contiguous pages, particularly when external fragmentation is low. However, of the bulk of the allocations have __GFP_COLD set as they are due to aio_read() for example, then the PFNs are in reverse PFN order. This can cause performance degration when used with IO controllers that could have merged the requests. This patch attempts to preserve the contiguous ordering of PFNs for users of __GFP_COLD. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reported-by: Narayananu Gopalakrishnan <narayanan.g@samsung.com> Tested-by: Narayanan Gopalakrishnan <narayanan.g@samsung.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29kmemleak: Protect the seq start/next/stop sequence by rcu_read_lock()Catalin Marinas
Objects passed to kmemleak_seq_next() have an incremented reference count (hence not freed) but they may point via object_list.next to other freed objects. To avoid this, the whole start/next/stop sequence must be protected by rcu_read_lock(). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29PM / Hibernate: Replace bdget call with simple atomic_inc of i_countAlan Jenkins
Create bdgrab(). This function copies an existing reference to a block_device. It is safe to call from any context. Hibernation code wishes to copy a reference to the active swap device. Right now it calls bdget() under a spinlock, but this is wrong because bdget() can sleep. It doesn't need a full bdget() because we already hold a reference to active swap devices (and the spinlock protects against swapoff). Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13827 Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12Merge branch 'kmemleak' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'kmemleak' of git://linux-arm.org/linux-2.6: kmemleak: Remove alloc_bootmem annotations introduced in the past kmemleak: Add callbacks to the bootmem allocator kmemleak: Allow partial freeing of memory blocks kmemleak: Trace the kmalloc_large* functions in slub kmemleak: Scan objects allocated during a scanning episode kmemleak: Do not acquire scan_mutex in kmemleak_open() kmemleak: Remove the reported leaks number limitation kmemleak: Add more cond_resched() calls in the scanning thread kmemleak: Renice the scanning thread to +10
2009-07-10Fix congestion_wait() sync/async vs read/write confusionJens Axboe
Commit 1faa16d22877f4839bd433547d770c676d1d964c accidentally broke the bdi congestion wait queue logic, causing us to wait on congestion for WRITE (== 1) when we really wanted BLK_RW_ASYNC (== 0) instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-09kmemleak: Remove alloc_bootmem annotations introduced in the pastCatalin Marinas
kmemleak_alloc() calls were added in some places where alloc_bootmem was called. Since now kmemleak tracks bootmem allocations, these explicit calls should be run. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-07-08kmemleak: Add callbacks to the bootmem allocatorCatalin Marinas
This patch adds kmemleak_alloc/free callbacks to the bootmem allocator. This would allow scanning of such blocks and help avoiding a whole class of false positives and more kmemleak annotations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
2009-07-08kmemleak: Allow partial freeing of memory blocksCatalin Marinas
Functions like free_bootmem() are allowed to free only part of a memory block. This patch adds support for this via the kmemleak_free_part() callback which removes the original object and creates one or two additional objects as a result of the memory block split. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-07-08kmemleak: Trace the kmalloc_large* functions in slubCatalin Marinas
The kmalloc_large() and kmalloc_large_node() functions were missed when adding the kmemleak hooks to the slub allocator. However, they should be traced to avoid false positives. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-07-08kmemleak: Scan objects allocated during a scanning episodeCatalin Marinas
Many of the false positives in kmemleak happen on busy systems where objects are allocated during a kmemleak scanning episode. These objects aren't scanned by default until the next memory scan. When such object is added, for example, at the head of a list, it is possible that all the other objects in the list become unreferenced until the next scan. This patch adds checking for newly allocated objects at the end of the scan and repeats the scanning on these objects. If Linux allocates new objects at a higher rate than their scanning, it stops after a predefined number of passes. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-07-08kmemleak: Do not acquire scan_mutex in kmemleak_open()Catalin Marinas
Initially, the scan_mutex was acquired in kmemleak_open() and released in kmemleak_release() (corresponding to /sys/kernel/debug/kmemleak operations). This was causing some lockdep reports when the file was closed from a different task than the one opening it. This patch moves the scan_mutex acquiring in kmemleak_write() or kmemleak_seq_start() with releasing in kmemleak_seq_stop(). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
