commit 6afcf8ef0ca0a69d014f8edb613d94821f0ae700 upstream.
Since commit bda807d44454 ("mm: migrate: support non-lru movable page
migration") isolate_migratepages_block) can isolate !PageLRU pages which
would acct_isolated account as NR_ISOLATED_*. Accounting these non-lru
pages NR_ISOLATED_{ANON,FILE} doesn't make any sense and it can misguide
heuristics based on those counters such as pgdat_reclaimable_pages resp.
too_many_isolated which would lead to unexpected stalls during the
direct reclaim without any good reason. Note that
__alloc_contig_migrate_range can isolate a lot of pages at once.
On mobile devices such as 512M ram android Phone, it may use a big zram
swap. In some cases zram(zsmalloc) uses too many non-lru but
migratedable pages, such as:
MemTotal: 468148 kB
Normal free:5620kB
Free swap:4736kB
Total swap:409596kB
ZRAM: 164616kB(zsmalloc non-lru pages)
active_anon:60700kB
inactive_anon:60744kB
active_file:34420kB
inactive_file:37532kB
Fix this by only accounting lru pages to NR_ISOLATED_* in
isolate_migratepages_block right after they were isolated and we still
know they were on LRU. Drop acct_isolated because it is called after
the fact and we've lost that information. Batching per-cpu counter
doesn't make much improvement anyway. Also make sure that we uncharge
only LRU pages when putting them back on the LRU in
putback_movable_pages resp. when unmap_and_move migrates the page.
[mhocko@suse.com: replace acct_isolated() with direct counting]
Fixes: bda807d44454 ("mm: migrate: support non-lru movable page migration")
Link: http://lkml.kernel.org/r/20161019080240.9682-1-mhocko@kernel.org
Signed-off-by: Ming Ling <ming.ling@spreadtrum.com>
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Joonsoo Kim <js1304@gmail.com>
commit 59749e6ce53735d8b696763742225f126e94603f upstream.
The radix tree counts valid entries in each tree node. Entries stored
in the tree cannot be removed by simpling storing NULL in the slot or
the internal counters will be off and the node never gets freed again.
When collapsing a shmem page fails, restore the holes that were filled
with radix_tree_insert() with a proper radix tree deletion.
Fixes: f3f0e1d2150b ("khugepaged: add support of collapse for tmpfs/shmem pages")
Link: http://lkml.kernel.org/r/20161117191138.22769-3-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Jan Kara <jack@suse.cz>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@linuxonhyperv.com>
commit 91a45f71078a6569ec3ca5bef74e1ab58121d80e upstream.
Patch series "mm: workingset: radix tree subtleties & single-page file
refaults", v3.
This is another revision of the radix tree / workingset patches based on
feedback from Jan and Kirill.
This is a follow-up to d3798ae8c6f3 ("mm: filemap: don't plant shadow
entries without radix tree node"). That patch fixed an issue that was
caused mainly by the page cache sneaking special shadow page entries
into the radix tree and relying on subtleties in the radix tree code to
make that work. The fix also had to stop tracking refaults for
single-page files because shadow pages stored as direct pointers in
radix_tree_root->rnode weren't properly handled during tree extension.
These patches make the radix tree code explicitely support and track
such special entries, to eliminate the subtleties and to restore the
thrash detection for single-page files.
This patch (of 9):
When a radix tree iteration drops the tree lock, another thread might
swoop in and free the node holding the current slot. The iteration
needs to do another tree lookup from the current index to continue.
[kirill.shutemov@linux.intel.com: re-lookup for replacement]
Link: http://lkml.kernel.org/r/20161117191138.22769-2-hannes@cmpxchg.org
commit 3999f52e3198e76607446ab1a4610c1ddc406c56 upstream.
We cannot use the pte value used in set_pte_at for pte_same comparison,
because archs like ppc64, filter/add new pte flag in set_pte_at.
Instead fetch the pte value inside hugetlb_cow. We are comparing pte
value to make sure the pte didn't change since we dropped the page table
lock. hugetlb_cow get called with page table lock held, and we can take
a copy of the pte value before we drop the page table lock.
With hugetlbfs, we optimize the MAP_PRIVATE write fault path with no
previous mapping (huge_pte_none entries), by forcing a cow in the fault
path. This avoid take an addition fault to covert a read-only mapping
to read/write. Here we were comparing a recently instantiated pte (via
set_pte_at) to the pte values from linux page table. As explained above
on ppc64 such pte_same check returned wrong result, resulting in us
taking an additional fault on ppc64.
Fixes: 6a119eae942c ("powerpc/mm: Add a _PAGE_PTE bit")
Link: http://lkml.kernel.org/r/20161018154245.18023-1-aneesh.kumar@linux.vnet.ibm.com
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Reported-by: Jan Stancek <jstancek@redhat.com>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
corrupted
commit a6de734bc002fe2027ccc074fbbd87d72957b7a4 upstream.
Vlastimil Babka pointed out that commit 479f854a207c ("mm, page_alloc:
defer debugging checks of pages allocated from the PCP") will allow the
per-cpu list counter to be out of sync with the per-cpu list contents if
a struct page is corrupted.
The consequence is an infinite loop if the per-cpu lists get fully
drained by free_pcppages_bulk because all the lists are empty but the
count is positive. The infinite loop occurs here
do {
batch_free++;
if (++migratetype == MIGRATE_PCPTYPES)
migratetype = 0;
list = &pcp->lists[migratetype];
} while (list_empty(list));
What the user sees is a bad page warning followed by a soft lockup with
interrupts disabled in free_pcppages_bulk().
This patch keeps the accounting in sync.
Fixes: 479f854a207c ("mm, page_alloc: defer debugging checks of pages allocated from the PCP")
Link: http://lkml.kernel.org/r/20161202112951.23346-2-mgorman@techsingularity.net
Cc: Christoph Lameter <cl@linux.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 5f33a0803bbd781de916f5c7448cbbbbc763d911 upstream.
Our system uses significantly more slab memory with memcg enabled with
the latest kernel. With 3.10 kernel, slab uses 2G memory, while with
4.6 kernel, 6G memory is used. The shrinker has problem. Let's see we
have two memcg for one shrinker. In do_shrink_slab:
1. Check cg1. nr_deferred = 0, assume total_scan = 700. batch size
is 1024, then no memory is freed. nr_deferred = 700
2. Check cg2. nr_deferred = 700. Assume freeable = 20, then
total_scan = 10 or 40. Let's assume it's 10. No memory is freed.
nr_deferred = 10.
The deferred share of cg1 is lost in this case. kswapd will free no
memory even run above steps again and again.
The fix makes sure one memcg's deferred share isn't lost.
Link: http://lkml.kernel.org/r/2414be961b5d25892060315fbb56bb19d81d0c07.1476227351.git.shli@fb.com
Signed-off-by: Shaohua Li <shli@fb.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Vladimir Davydov <vdavydov@parallels.com>
commit 84d77d3f06e7e8dea057d10e8ec77ad71f721be3 upstream.
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit d05c5f7ba164aed3db02fb188c26d0dd94f5455b upstream.
We truncated the possible read iterator to s_maxbytes in commit
c2a9737f45e2 ("vfs,mm: fix a dead loop in truncate_inode_pages_range()"),
but our end condition handling was wrong: it's not an error to try to
read at the end of the file.
Reading past the end should return EOF (0), not EINVAL.
See for example
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1649342
http://lists.gnu.org/archive/html/bug-coreutils/2016-12/msg00008.html
where a md5sum of a maximally sized file fails because the final read is
exactly at s_maxbytes.
Fixes: c2a9737f45e2 ("vfs,mm: fix a dead loop in truncate_inode_pages_range()")
Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com>
Cc: Wei Fang <fangwei1@huawei.com>
commit bfedb589252c01fa505ac9f6f2a3d5d68d707ef4 upstream.
During exec dumpable is cleared if the file that is being executed is
not readable by the user executing the file. A bug in
ptrace_may_access allows reading the file if the executable happens to
enter into a subordinate user namespace (aka clone(CLONE_NEWUSER),
unshare(CLONE_NEWUSER), or setns(fd, CLONE_NEWUSER).
This problem is fixed with only necessary userspace breakage by adding
a user namespace owner to mm_struct, captured at the time of exec, so
it is clear in which user namespace CAP_SYS_PTRACE must be present in
to be able to safely give read permission to the executable.
The function ptrace_may_access is modified to verify that the ptracer
has CAP_SYS_ADMIN in task->mm->user_ns instead of task->cred->user_ns.
This ensures that if the task changes it's cred into a subordinate
user namespace it does not become ptraceable.
The function ptrace_attach is modified to only set PT_PTRACE_CAP when
CAP_SYS_PTRACE is held over task->mm->user_ns. The intent of
PT_PTRACE_CAP is to be a flag to note that whatever permission changes
the task might go through the tracer has sufficient permissions for
it not to be an issue. task->cred->user_ns is always the same
as or descendent of mm->user_ns. Which guarantees that having
CAP_SYS_PTRACE over mm->user_ns is the worst case for the tasks
credentials.
To prevent regressions mm->dumpable and mm->user_ns are not considered
when a task has no mm. As simply failing ptrace_may_attach causes
regressions in privileged applications attempting to read things
such as /proc/<pid>/stat
Tested-by: Cyrill Gorcunov <gorcunov@openvz.org>
Fixes: 8409cca70561 ("userns: allow ptrace from non-init user namespaces")
The shmem hole punching with fallocate(FALLOC_FL_PUNCH_HOLE) does not
want to race with generating new pages by faulting them in.
However, the wait-queue used to delay the page faulting has a serious
problem: the wait queue head (in shmem_fallocate()) is allocated on the
stack, and the code expects that "wake_up_all()" will make sure that all
the queue entries are gone before the stack frame is de-allocated.
And that is not at all necessarily the case.
Yes, a normal wake-up sequence will remove the wait-queue entry that
caused the wakeup (see "autoremove_wake_function()"), but the key
wording there is "that caused the wakeup". When there are multiple
possible wakeup sources, the wait queue entry may well stay around.
And _particularly_ in a page fault path, we may be faulting in new pages
from user space while we also have other things going on, and there may
well be other pending wakeups.
So despite the "wake_up_all()", it's not at all guaranteed that all list
entries are removed from the wait queue head on the stack.
Fix this by introducing a new wakeup function that removes the list
entry unconditionally, even if the target process had already woken up
for other reasons. Use that "synchronous" function to set up the
waiters in shmem_fault().
This problem has never been seen in the wild afaik, but Dave Jones has
reported it on and off while running trinity. We thought we fixed the
stack corruption with the blk-mq rq_list locking fix (commit
7fe311302f7d: "blk-mq: update hardware and software queues for sleeping
alloc"), but it turns out there was _another_ stack corruptor hiding
in the trinity runs.
Vegard Nossum (also running trinity) was able to trigger this one fairly
consistently, and made us look once again at the shmem code due to the
faults often being in that area.
Reported-and-tested-by: Vegard Nossum <vegard.nossum@oracle.com>.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Boris Zhmurov has reported RCU stalls during the kswapd reclaim:
INFO: rcu_sched detected stalls on CPUs/tasks:
23-...: (22 ticks this GP) idle=92f/140000000000000/0 softirq=2638404/2638404 fqs=23
(detected by 4, t=6389 jiffies, g=786259, c=786258, q=42115)
Task dump for CPU 23:
kswapd1 R running task 0 148 2 0x00000008
Call Trace:
shrink_node+0xd2/0x2f0
kswapd+0x2cb/0x6a0
mem_cgroup_shrink_node+0x160/0x160
kthread+0xbd/0xe0
__switch_to+0x1fa/0x5c0
ret_from_fork+0x1f/0x40
kthread_create_on_node+0x180/0x180
a closer code inspection has shown that we might indeed miss all the
scheduling points in the reclaim path if no pages can be isolated from
the LRU list. This is a pathological case but other reports from Donald
Buczek have shown that we might indeed hit such a path:
clusterd-989 [009] .... 118023.654491: mm_vmscan_direct_reclaim_end: nr_reclaimed=193
kswapd1-86 [001] dN.. 118023.987475: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239830 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.320968: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239844 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.654375: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239858 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118024.987036: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239872 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.319651: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239886 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.652248: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239900 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118025.984870: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4239914 nr_taken=0 file=1
kswapd1-86 [001] dN.. 118084.274403: mm_vmscan_lru_isolate: isolate_mode=0 classzone=0 order=0 nr_requested=32 nr_scanned=4241133 nr_taken=0 file=1
this is minute long snapshot which didn't take a single page from the
LRU. It is not entirely clear why only 1303 pages have been scanned
during that time (maybe there was a heavy IRQ activity interfering).
In any case it looks like we can really hit long periods without
scheduling on non preemptive kernels so an explicit cond_resched() in
shrink_node_memcg which is independent on the reclaim operation is due.
Link: http://lkml.kernel.org/r/20161202095841.16648-1-mhocko@kernel.org
Reported-by: Boris Zhmurov <bb@kernelpanic.ru>
Tested-by: Boris Zhmurov <bb@kernelpanic.ru>
Reported-by: Donald Buczek <buczek@molgen.mpg.de>
Reported-by: "Christopher S. Aker" <caker@theshore.net>
Reported-by: Paul Menzel <pmenzel@molgen.mpg.de>
Commit 0a6b76dd23fa ("mm: workingset: make shadow node shrinker memcg
aware") has made the workingset shadow nodes shrinker memcg aware. The
implementation is not correct though because memcg_kmem_enabled() might
become true while we are doing a global reclaim when the sc->memcg might
be NULL which is exactly what Marek has seen:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000400
IP: [<ffffffff8122d520>] mem_cgroup_node_nr_lru_pages+0x20/0x40
PGD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 60 Comm: kswapd0 Tainted: G O 4.8.10-12.pvops.qubes.x86_64 #1
task: ffff880011863b00 task.stack: ffff880011868000
RIP: mem_cgroup_node_nr_lru_pages+0x20/0x40
RSP: e02b:ffff88001186bc70 EFLAGS: 00010293
RAX: 0000000000000000 RBX: ffff88001186bd20 RCX: 0000000000000002
RDX: 000000000000000c RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88001186bc70 R08: 28f5c28f5c28f5c3 R09: 0000000000000000
R10: 0000000000006c34 R11: 0000000000000333 R12: 00000000000001f6
R13: ffffffff81c6f6a0 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff880013c00000(0000) knlGS:ffff880013d00000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 0000000000000400 CR3: 00000000122f2000 CR4: 0000000000042660
Call Trace:
count_shadow_nodes+0x9a/0xa0
shrink_slab.part.42+0x119/0x3e0
shrink_node+0x22c/0x320
kswapd+0x32c/0x700
kthread+0xd8/0xf0
Code: 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 3b 35 dd eb b1 00 55 48 89 e5 73 2c 89 d2 31 c9 31 c0 4c 63 ce 48 0f a3 ca 73 13 <4a> 8b b4 cf 00 04 00 00 41 89 c8 4a 03 84 c6 80 00 00 00 83 c1
RIP mem_cgroup_node_nr_lru_pages+0x20/0x40
RSP <ffff88001186bc70>
---[ end trace 100494b9edbdfc4d ]---
This patch fixes the issue by checking sc->memcg rather than
memcg_kmem_enabled() which is sufficient because shrink_slab makes sure
that only memcg aware shrinkers will get non-NULL memcgs and only if
memcg_kmem_enabled is true.
Fixes: 0a6b76dd23fa ("mm: workingset: make shadow node shrinker memcg aware")
Link: http://lkml.kernel.org/r/20161201132156.21450-1-mhocko@kernel.org
Reported-by: Marek Marczykowski-Górecki <marmarek@mimuw.edu.pl>
Tested-by: Marek Marczykowski-Górecki <marmarek@mimuw.edu.pl>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Acked-by: Balbir Singh <bsingharora@gmail.com>
Cc: <stable@vger.kernel.org> [4.6+]
Hugetlb pages have ->index in size of the huge pages (PMD_SIZE or
PUD_SIZE), not in PAGE_SIZE as other types of pages. This means we
cannot user page_to_pgoff() to check whether we've got the right page
for the radix-tree index.
Let's introduce page_to_index() which would return radix-tree index for
given page.
We will be able to get rid of this once hugetlb will be switched to
multi-order entries.
Fixes: fc127da085c2 ("truncate: handle file thp")
Link: http://lkml.kernel.org/r/20161123093053.mjbnvn5zwxw5e6lk@black.fi.intel.com
Reported-by: Doug Nelson <doug.nelson@intel.com>
Tested-by: Doug Nelson <doug.nelson@intel.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [4.8+]
Gcc revision 241896 implements use-after-scope detection. Will be
available in gcc 7. Support it in KASAN.
Gcc emits 2 new callbacks to poison/unpoison large stack objects when
they go in/out of scope. Implement the callbacks and add a test.
[dvyukov@google.com: v3]
Link: http://lkml.kernel.org/r/1479998292-144502-1-git-send-email-dvyukov@google.com
Link: http://lkml.kernel.org/r/1479226045-145148-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: <stable@vger.kernel.org> [4.0+]
kasan_global struct is part of compiler/runtime ABI. gcc revision
241983 has added a new field to kasan_global struct. Update kernel
definition of kasan_global struct to include the new field.
Without this patch KASAN is broken with gcc 7.
Link: http://lkml.kernel.org/r/1479219743-28682-1-git-send-email-dvyukov@google.com
The following program triggers BUG() in munlock_vma_pages_range():
// autogenerated by syzkaller (http://github.com/google/syzkaller)
#include <sys/mman.h>
int main()
mmap((void*)0x20105000ul, 0xc00000ul, 0x2ul, 0x2172ul, -1, 0);
mremap((void*)0x201fd000ul, 0x4000ul, 0xc00000ul, 0x3ul, 0x203f0000ul);
return 0;
The test-case constructs the situation when munlock_vma_pages_range()
finds PTE-mapped THP-head in the middle of page table and, by mistake,
skips HPAGE_PMD_NR pages after that.
As result, on the next iteration it hits the middle of PMD-mapped THP
and gets upset seeing mlocked tail page.
The solution is only skip HPAGE_PMD_NR pages if the THP was mlocked
during munlock_vma_page(). It would guarantee that the page is
PMD-mapped as we never mlock PTE-mapeed THPs.
Fixes: e90309c9f772 ("thp: allow mlocked THP again")
Link: http://lkml.kernel.org/r/20161115132703.7s7rrgmwttegcdh4@black.fi.intel.com
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: <stable@vger.kernel.org> [4.5+]
Commit b46e756f5e47 ("thp: extract khugepaged from mm/huge_memory.c")
moved code from huge_memory.c to khugepaged.c. Some of this code should
be compiled only when CONFIG_SYSFS is enabled but the condition around
this code was not moved into khugepaged.c.
The result is a compilation error when CONFIG_SYSFS is disabled:
mm/built-in.o: In function `khugepaged_defrag_store': khugepaged.c:(.text+0x2d095): undefined reference to `single_hugepage_flag_store'
mm/built-in.o: In function `khugepaged_defrag_show': khugepaged.c:(.text+0x2d0ab): undefined reference to `single_hugepage_flag_show'
This commit adds the #ifdef CONFIG_SYSFS around the code related to
sysfs.
Link: http://lkml.kernel.org/r/20161114203448.24197-1-jeremy.lefaure@lse.epita.fr
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Linus found there still is a race in mremap after commit 5d1904204c99
("mremap: fix race between mremap() and page cleanning").
As described by Linus:
"the issue is that another thread might make the pte be dirty (in the
hardware walker, so no locking of ours will make any difference)
*after* we checked whether it was dirty, but *before* we removed it
from the page tables"
Fix it by moving the check after we removed it from the page table.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Prior to 3.15, there was a race between zap_pte_range() and
page_mkclean() where writes to a page could be lost. Dave Hansen
discovered by inspection that there is a similar race between
move_ptes() and page_mkclean().
We've been able to reproduce the issue by enlarging the race window with
a msleep(), but have not been able to hit it without modifying the code.
So, we think it's a real issue, but is difficult or impossible to hit in
practice.
The zap_pte_range() issue is fixed by commit 1cf35d47712d("mm: split
'tlb_flush_mmu()' into tlb flushing and memory freeing parts"). And
this patch is to fix the race between page_mkclean() and mremap().
Here is one possible way to hit the race: suppose a process mmapped a
file with READ | WRITE and SHARED, it has two threads and they are bound
to 2 different CPUs, e.g. CPU1 and CPU2. mmap returned X, then thread
1 did a write to addr X so that CPU1 now has a writable TLB for addr X
on it. Thread 2 starts mremaping from addr X to Y while thread 1
cleaned the page and then did another write to the old addr X again.
The 2nd write from thread 1 could succeed but the value will get lost.
thread 1 thread 2
(bound to CPU1) (bound to CPU2)
1: write 1 to addr X to get a
writeable TLB on this CPU
2: mremap starts
3: move_ptes emptied PTE for addr X
and setup new PTE for addr Y and
then dropped PTL for X and Y
4: page laundering for N by doing
fadvise FADV_DONTNEED. When done,
pageframe N is deemed clean.
5: *write 2 to addr X
6: tlb flush for addr X
7: munmap (Y, pagesize) to make the
page unmapped
8: fadvise with FADV_DONTNEED again
to kick the page off the pagecache
9: pread the page from file to verify
the value. If 1 is there, it means
we have lost the written 2.
*the write may or may not cause segmentation fault, it depends on
if the TLB is still on the CPU.
Please note that this is only one specific way of how the race could
occur, it didn't mean that the race could only occur in exact the above
config, e.g. more than 2 threads could be involved and fadvise() could
be done in another thread, etc.
For anonymous pages, they could race between mremap() and page reclaim:
THP: a huge PMD is moved by mremap to a new huge PMD, then the new huge
PMD gets unmapped/splitted/pagedout before the flush tlb happened for
the old huge PMD in move_page_tables() and we could still write data to
it. The normal anonymous page has similar situation.
To fix this, check for any dirty PTE in move_ptes()/move_huge_pmd() and
if any, did the flush before dropping the PTL. If we did the flush for
every move_ptes()/move_huge_pmd() call then we do not need to do the
flush in move_pages_tables() for the whole range. But if we didn't, we
still need to do the whole range flush.
Alternatively, we can track which part of the range is flushed in
move_ptes()/move_huge_pmd() and which didn't to avoid flushing the whole
range in move_page_tables(). But that would require multiple tlb
flushes for the different sub-ranges and should be less efficient than
the single whole range flush.
KBuild test on my Sandybridge desktop doesn't show any noticeable change.
v4.9-rc4:
real 5m14.048s
user 32m19.800s
sys 4m50.320s
With this commit:
real 5m13.888s
user 32m19.330s
sys 4m51.200s
Reported-by: Dave Hansen <dave.hansen@intel.com>
Limit the number of kmemleak false positives by including
.data.ro_after_init in memory scanning. To achieve this we need to add
symbols for start and end of the section to the linker scripts.
The problem was been uncovered by commit 56989f6d8568 ("genetlink: mark
families as __ro_after_init").
Link: http://lkml.kernel.org/r/1478274173-15218-1-git-send-email-jakub.kicinski@netronome.com
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
While testing OBJFREELIST_SLAB integration with pagealloc, we found a
bug where kmem_cache(sys) would be created with both CFLGS_OFF_SLAB &
CFLGS_OBJFREELIST_SLAB. When it happened, critical allocations needed
for loading drivers or creating new caches will fail.
The original kmem_cache is created early making OFF_SLAB not possible.
When kmem_cache(sys) is created, OFF_SLAB is possible and if pagealloc
is enabled it will try to enable it first under certain conditions.
Given kmem_cache(sys) reuses the original flag, you can have both flags
at the same time resulting in allocation failures and odd behaviors.
This fix discards allocator specific flags from memcg before calling
create_cache.
The bug exists since 4.6-rc1 and affects testing debug pagealloc
configurations.
Fixes: b03a017bebc4 ("mm/slab: introduce new slab management type, OBJFREELIST_SLAB")
Link: http://lkml.kernel.org/r/1478553075-120242-1-git-send-email-thgarnie@google.com
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Thomas Garnier <thgarnie@google.com>
Tested-by: Thomas Garnier <thgarnie@google.com>
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Starting from 4.9-rc1 kernel, I started noticing some test failures of
sendfile(2) and splice(2) (sendfile0N and splice01 from LTP) when
testing on sub-page block size filesystems (tested both XFS and ext4),
these syscalls start to return EIO in the tests. e.g.
sendfile02 1 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 26, got: -1
sendfile02 2 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 24, got: -1
sendfile02 3 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 22, got: -1
sendfile02 4 TFAIL : sendfile02.c:133: sendfile(2) failed to return expected value, expected: 20, got: -1
This is because that in sub-page block size cases, we don't need the
whole page to be uptodate, only the part we care about is uptodate is OK
(if fs has ->is_partially_uptodate defined).
But page_cache_pipe_buf_confirm() doesn't have the ability to check the
partially-uptodate case, it needs the whole page to be uptodate. So it
returns EIO in this case.
This is a regression introduced by commit 82c156f85384 ("switch
generic_file_splice_read() to use of ->read_iter()"). Prior to the
change, generic_file_splice_read() doesn't allow partially-uptodate page
either, so it worked fine.
Fix it by skipping the partially-uptodate check if we're working on a
pipe in do_generic_file_read(), so we read the whole page from disk as
long as the page is not uptodate.
I think the other way to fix it is to add the ability to check & allow
partially-uptodate page to page_cache_pipe_buf_confirm(), but that is
much harder to do and seems gain little.
Link: http://lkml.kernel.org/r/1477986187-12717-1-git-send-email-guaneryu@gmail.com
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
Error paths in hugetlb_cow() and hugetlb_no_page() may free a newly
allocated huge page.
If a reservation was associated with the huge page, alloc_huge_page()
consumed the reservation while allocating. When the newly allocated
page is freed in free_huge_page(), it will increment the global
reservation count. However, the reservation entry in the reserve map
will remain.
This is not an issue for shared mappings as the entry in the reserve map
indicates a reservation exists. But, an entry in a private mapping
reserve map indicates the reservation was consumed and no longer exists.
This results in an inconsistency between the reserve map and the global
reservation count. This 'leaks' a reserved huge page.
Create a new routine restore_reserve_on_error() to restore the reserve
entry in these specific error paths. This routine makes use of a new
function vma_add_reservation() which will add a reserve entry for a
specific address/page.
In general, these error paths were rarely (if ever) taken on most
architectures. However, powerpc contained arch specific code that that
resulted in an extra fault and execution of these error paths on all
private mappings.
Fixes: 67961f9db8c4 ("mm/hugetlb: fix huge page reserve accounting for private mappings)
Link: http://lkml.kernel.org/r/1476933077-23091-2-git-send-email-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Kirill A . Shutemov <kirill.shutemov@linux.intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
When memory_failure() runs on a thp tail page after pmd is split, we
trigger the following VM_BUG_ON_PAGE():
page:ffffd7cd819b0040 count:0 mapcount:0 mapping: (null) index:0x1
flags: 0x1fffc000400000(hwpoison)
page dumped because: VM_BUG_ON_PAGE(!page_count(p))
kernel BUG at /src/linux-dev/mm/memory-failure.c:1132!
memory_failure() passed refcount and page lock from tail page to head
page, which is not needed because we can pass any subpage to
split_huge_page().
Fixes: 61f5d698cc97 ("mm: re-enable THP")
Link: http://lkml.kernel.org/r/1477961577-7183-1-git-send-email-n-horiguchi@ah.jp.nec.com
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
When root activates a swap partition whose header has the wrong
endianness, nr_badpages elements of badpages are swabbed before
nr_badpages has been checked, leading to a buffer overrun of up to 8GB.
This normally is not a security issue because it can only be exploited
by root (more specifically, a process with CAP_SYS_ADMIN or the ability
to modify a swap file/partition), and such a process can already e.g.
modify swapped-out memory of any other userspace process on the system.
Link: http://lkml.kernel.org/r/1477949533-2509-1-git-send-email-jann@thejh.net
Signed-off-by: Jann Horn <jann@thejh.net>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
CMA allocation request size is represented by size_t that gets truncated
when same is passed as int to bitmap_find_next_zero_area_off.
We observe that during fuzz testing when cma allocation request is too
high, bitmap_find_next_zero_area_off still returns success due to the
truncation. This leads to kernel crash, as subsequent code assumes that
requested memory is available.
Fail cma allocation in case the request breaches the corresponding cma
region size.
Link: http://lkml.kernel.org/r/1478189211-3467-1-git-send-email-shashim@codeaurora.org
Signed-off-by: Shiraz Hashim <shashim@codeaurora.org>
If shmem_alloc_page() does not set PageLocked and PageSwapBacked, then
shmem_replace_page() needs to do so for itself. Without this, it puts
newpage on the wrong lru, re-unlocks the unlocked newpage, and system
descends into "Bad page" reports and freeze; or if CONFIG_DEBUG_VM=y, it
hits an earlier VM_BUG_ON_PAGE(!PageLocked), depending on config.
But shmem_replace_page() is not a common path: it's only called when
swapin (or swapoff) finds the page was already read into an unsuitable
zone: usually all zones are suitable, but gem objects for a few drm
devices (gma500, omapdrm, crestline, broadwater) require zone DMA32 if
there's more than 4GB of ram.
Fixes: 800d8c63b2e9 ("shmem: add huge pages support")
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.1611062003510.11253@eggly.anvils
Cc: <stable@vger.kernel.org> [4.8.x]
Commit 63f53dea0c98 ("mm: warn about allocations which stall for too
long") by error embedded "\n" in the format string, resulting in strange
output.
[ 722.876655] kworker/0:1: page alloction stalls for 160001ms, order:0
[ 722.876656] , mode:0x2400000(GFP_NOIO)
[ 722.876657] CPU: 0 PID: 6966 Comm: kworker/0:1 Not tainted 4.8.0+ #69
Link: http://lkml.kernel.org/r/1476026219-7974-1-git-send-email-penguin-kernel@I-love.SAKURA.ne.jp
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugin fixes from Kees Cook:
- make sure required exports from gcc plugins are visible to gcc
- switch latent_entropy to unsigned long to avoid stack frame bloat
* tag 'gcc-plugins-v4.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
latent_entropy: Fix wrong gcc code generation with 64 bit variables
gcc-plugins: Export symbols needed by gcc
The stack frame size could grow too large when the plugin used long long
on 32-bit architectures when the given function had too many basic blocks.
The gcc warning was:
drivers/pci/hotplug/ibmphp_ebda.c: In function 'ibmphp_access_ebda':
drivers/pci/hotplug/ibmphp_ebda.c:409:1: warning: the frame size of 1108 bytes is larger than 1024 bytes [-Wframe-larger-than=]
This switches latent_entropy from u64 to unsigned long.
Thanks to PaX Team and Emese Revfy for the patch.
Merge misc fixes from Andrew Morton:
"20 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
drivers/misc/sgi-gru/grumain.c: remove bogus 0x prefix from printk
cris/arch-v32: cryptocop: print a hex number after a 0x prefix
ipack: print a hex number after a 0x prefix
block: DAC960: print a hex number after a 0x prefix
fs: exofs: print a hex number after a 0x prefix
lib/genalloc.c: start search from start of chunk
mm: memcontrol: do not recurse in direct reclaim
CREDITS: update credit information for Martin Kepplinger
proc: fix NULL dereference when reading /proc/<pid>/auxv
mm: kmemleak: ensure that the task stack is not freed during scanning
lib/stackdepot.c: bump stackdepot capacity from 16MB to 128MB
latent_entropy: raise CONFIG_FRAME_WARN by default
kconfig.h: remove config_enabled() macro
ipc: account for kmem usage on mqueue and msg
mm/slab: improve performance of gathering slabinfo stats
mm: page_alloc: use KERN_CONT where appropriate
mm/list_lru.c: avoid error-path NULL pointer deref
h8300: fix syscall restarting
kcov: properly check if we are in an interrupt
mm/slab: fix kmemcg cache creation delayed issue
On 4.0, we saw a stack corruption from a page fault entering direct
memory cgroup reclaim, calling into btrfs_releasepage(), which then
tried to allocate an extent and recursed back into a kmem charge ad
nauseam:
btrfs_releasepage+0x2c/0x30
try_to_release_page+0x32/0x50
shrink_page_list+0x6da/0x7a0
shrink_inactive_list+0x1e5/0x510
shrink_lruvec+0x605/0x7f0
shrink_zone+0xee/0x320
do_try_to_free_pages+0x174/0x440
try_to_free_mem_cgroup_pages+0xa7/0x130
try_charge+0x17b/0x830
memcg_charge_kmem+0x40/0x80
new_slab+0x2d9/0x5a0
__slab_alloc+0x2fd/0x44f
kmem_cache_alloc+0x193/0x1e0
alloc_extent_state+0x21/0xc0
__clear_extent_bit+0x2b5/0x400
try_release_extent_mapping+0x1a3/0x220
__btrfs_releasepage+0x31/0x70
mem_cgroup_try_charge+0x65/0x1c0
handle_mm_fault+0x117f/0x1510
__do_page_fault+0x177/0x420
do_page_fault+0xc/0x10
page_fault+0x22/0x30
On later kernels, kmem charging is opt-in rather than opt-out, and that
particular kmem allocation in btrfs_releasepage() is no longer being
charged and won't recurse and overrun the stack anymore.
But it's not impossible for an accounted allocation to happen from the
memcg direct reclaim context, and we needed to reproduce this crash many
times before we even got a useful stack trace out of it.
Like other direct reclaimers, mark tasks in memcg reclaim PF_MEMALLOC to
avoid recursing into any other form of direct reclaim. Then let
recursive charges from PF_MEMALLOC contexts bypass the cgroup limit.
Link: http://lkml.kernel.org/r/20161025141050.GA13019@cmpxchg.org
Cc: Tejun Heo <tj@kernel.org>
Commit 68f24b08ee89 ("sched/core: Free the stack early if
CONFIG_THREAD_INFO_IN_TASK") may cause the task->stack to be freed
during kmemleak_scan() execution, leading to either a NULL pointer fault
(if task->stack is NULL) or kmemleak accessing already freed memory.
This patch uses the new try_get_task_stack() API to ensure that the task
stack is not freed during kmemleak stack scanning.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=173901.
Fixes: 68f24b08ee89 ("sched/core: Free the stack early if CONFIG_THREAD_INFO_IN_TASK")
Link: http://lkml.kernel.org/r/1476266223-14325-1-git-send-email-catalin.marinas@arm.com
Reported-by: CAI Qian <caiqian@redhat.com>
Tested-by: CAI Qian <caiqian@redhat.com>
Cc: CAI Qian <caiqian@redhat.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
On large systems, when some slab caches grow to millions of objects (and
many gigabytes), running 'cat /proc/slabinfo' can take up to 1-2
seconds. During this time, interrupts are disabled while walking the
slab lists (slabs_full, slabs_partial, and slabs_free) for each node,
and this sometimes causes timeouts in other drivers (for instance,
Infiniband).
This patch optimizes 'cat /proc/slabinfo' by maintaining a counter for
total number of allocated slabs per node, per cache. This counter is
updated when a slab is created or destroyed. This enables us to skip
traversing the slabs_full list while gathering slabinfo statistics, and
since slabs_full tends to be the biggest list when the cache is large,
it results in a dramatic performance improvement. Getting slabinfo
statistics now only requires walking the slabs_free and slabs_partial
lists, and those lists are usually much smaller than slabs_full.
We tested this after growing the dentry cache to 70GB, and the
performance improved from 2s to 5ms.
Link: http://lkml.kernel.org/r/1472517876-26814-1-git-send-email-aruna.ramakrishna@oracle.com
Signed-off-by: Aruna Ramakrishna <aruna.ramakrishna@oracle.com>
Acked-by: David Rientjes <rientjes@google.com>
Recent changes to printk require KERN_CONT uses to continue logging
messages. So add KERN_CONT where necessary.
Fixes: 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines")
Link: http://lkml.kernel.org/r/c7df37c8665134654a17aaeb8b9f6ace1d6db58b.1476239034.git.joe@perches.com
Reported-by: Mark Rutland <mark.rutland@arm.com>
As described in https://bugzilla.kernel.org/show_bug.cgi?id=177821:
After some analysis it seems to be that the problem is in alloc_super().
In case list_lru_init_memcg() fails it goes into destroy_super(), which
calls list_lru_destroy().
And in list_lru_init() we see that in case memcg_init_list_lru() fails,
lru->node is freed, but not set NULL, which then leads list_lru_destroy()
to believe it is initialized and call memcg_destroy_list_lru().
memcg_destroy_list_lru() in turn can access lru->node[i].memcg_lrus,
which is NULL.
[akpm@linux-foundation.org: add comment]
Signed-off-by: Alexander Polakov <apolyakov@beget.ru>
There is a bug report that SLAB makes extreme load average due to over
2000 kworker thread.
https://bugzilla.kernel.org/show_bug.cgi?id=172981
This issue is caused by kmemcg feature that try to create new set of
kmem_caches for each memcg. Recently, kmem_cache creation is slowed by
synchronize_sched() and futher kmem_cache creation is also delayed since
kmem_cache creation is synchronized by a global slab_mutex lock. So,
the number of kworker that try to create kmem_cache increases quietly.
synchronize_sched() is for lockless access to node's shared array but
it's not needed when a new kmem_cache is created. So, this patch rules
out that case.
Fixes: 801faf0db894 ("mm/slab: lockless decision to grow cache")
Link: http://lkml.kernel.org/r/1475734855-4837-1-git-send-email-iamjoonsoo.kim@lge.com
Reported-by: Doug Smythies <dsmythies@telus.net>
Tested-by: Doug Smythies <dsmythies@telus.net>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
No, KASAN may not be able to co-exist with HOTPLUG_MEMORY at runtime,
but for build testing there is no reason not to allow them together.
This hopefully means better build coverage and fewer embarrasing silly
problems like the one fixed by commit 9db4f36e82c2 ("mm: remove unused
variable in memory hotplug") in the future.
When I removed the per-zone bitlock hashed waitqueues in commit
9dcb8b685fc3 ("mm: remove per-zone hashtable of bitlock waitqueues"), I
removed all the magic hotplug memory initialization of said waitqueues
too.
But when I actually _tested_ the resulting build, I stupidly assumed
that "allmodconfig" would enable memory hotplug. And it doesn't,
because it enables KASAN instead, which then disables hotplug memory
support.
As a result, my build test of the per-zone waitqueues was totally
broken, and I didn't notice that the compiler warns about the now unused
iterator variable 'i'.
I guess I should be happy that that seems to be the worst breakage from
my clearly horribly failed test coverage.
The per-zone waitqueues exist because of a scalability issue with the
page waitqueues on some NUMA machines, but it turns out that they hurt
normal loads, and now with the vmalloced stacks they also end up
breaking gfs2 that uses a bit_wait on a stack object:
wait_on_bit(&gh->gh_iflags, HIF_WAIT, TASK_UNINTERRUPTIBLE)
where 'gh' can be a reference to the local variable 'mount_gh' on the
stack of fill_super().
The reason the per-zone hash table breaks for this case is that there is
no "zone" for virtual allocations, and trying to look up the physical
page to get at it will fail (with a BUG_ON()).
It turns out that I actually complained to the mm people about the
per-zone hash table for another reason just a month ago: the zone lookup
also hurts the regular use of "unlock_page()" a lot, because the zone
lookup ends up forcing several unnecessary cache misses and generates
horrible code.
As part of that earlier discussion, we had a much better solution for
the NUMA scalability issue - by just making the page lock have a
separate contention bit, the waitqueue doesn't even have to be looked at
for the normal case.
Peter Zijlstra already has a patch for that, but let's see if anybody
even notices. In the meantime, let's fix the actual gfs2 breakage by
simplifying the bitlock waitqueues and removing the per-zone issue.
Reported-by: Andreas Gruenbacher <agruenba@redhat.com>
Tested-by: Bob Peterson <rpeterso@redhat.com>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Steven Whitehouse <swhiteho@redhat.com>
This patch unexports the low-level __get_user_pages() function.
Recent refactoring of the get_user_pages* functions allow flags to be
passed through get_user_pages() which eliminates the need for access to
this function from its one user, kvm.
We can see that the two calls to get_user_pages() which replace
__get_user_pages() in kvm_main.c are equivalent by examining their call
stacks:
get_user_page_nowait():
get_user_pages(start, 1, flags, page, NULL)
__get_user_pages_locked(current, current->mm, start, 1, page, NULL, NULL,
false, flags | FOLL_TOUCH)
__get_user_pages(current, current->mm, start, 1,
flags | FOLL_TOUCH | FOLL_GET, page, NULL, NULL)
check_user_page_hwpoison():
get_user_pages(addr, 1, flags, NULL, NULL)
__get_user_pages_locked(current, current->mm, addr, 1, NULL, NULL, NULL,
__get_user_pages(current, current->mm, addr, 1, flags | FOLL_TOUCH, NULL,
NULL, NULL)
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Pull vmap stack fixes from Ingo Molnar:
"This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack
accesses that used to be just somewhat questionable are now totally
buggy.
These changes try to do it without breaking the ABI: the fields are
left there, they are just reporting zero, or reporting narrower
information (the maps file change)"
* 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm: Change vm_is_stack_for_task() to vm_is_stack_for_current()
fs/proc: Stop trying to report thread stacks
fs/proc: Stop reporting eip and esp in /proc/PID/stat
mm/numa: Remove duplicated include from mprotect.c
Asking for a non-current task's stack can't be done without races
unless the task is frozen in kernel mode. As far as I know,
vm_is_stack_for_task() never had a safe non-current use case.
The __unused annotation is because some KSTK_ESP implementations
ignore their parameter, which IMO is further justification for this
patch.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Jann Horn <jann@thejh.net>
Cc: Linux API <linux-api@vger.kernel.org>
Cc: Tycho Andersen <tycho.andersen@canonical.com>
Link: http://lkml.kernel.org/r/4c3f68f426e6c061ca98b4fc7ef85ffbb0a25b0c.1475257877.git.luto@kernel.org
Merge the gup_flags cleanups from Lorenzo Stoakes:
"This patch series adjusts functions in the get_user_pages* family such
that desired FOLL_* flags are passed as an argument rather than
implied by flags.
The purpose of this change is to make the use of FOLL_FORCE explicit
so it is easier to grep for and clearer to callers that this flag is
being used. The use of FOLL_FORCE is an issue as it overrides missing
VM_READ/VM_WRITE flags for the VMA whose pages we are reading
from/writing to, which can result in surprising behaviour.
The patch series came out of the discussion around commit 38e088546522
("mm: check VMA flags to avoid invalid PROT_NONE NUMA balancing"),
which addressed a BUG_ON() being triggered when a page was faulted in
with PROT_NONE set but having been overridden by FOLL_FORCE.
do_numa_page() was run on the assumption the page _must_ be one marked
for NUMA node migration as an actual PROT_NONE page would have been
dealt with prior to this code path, however FOLL_FORCE introduced a
situation where this assumption did not hold.
See
https://marc.info/?l=linux-mm&m=147585445805166
for the patch proposal"
Additionally, there's a fix for an ancient bug related to FOLL_FORCE and
FOLL_WRITE by me.
[ This branch was rebased recently to add a few more acked-by's and
reviewed-by's ]
* gup_flag-cleanups:
mm: replace access_process_vm() write parameter with gup_flags
mm: replace access_remote_vm() write parameter with gup_flags
mm: replace __access_remote_vm() write parameter with gup_flags
mm: replace get_user_pages_remote() write/force parameters with gup_flags
mm: replace get_user_pages() write/force parameters with gup_flags
mm: replace get_vaddr_frames() write/force parameters with gup_flags
mm: replace get_user_pages_locked() write/force parameters with gup_flags
mm: replace get_user_pages_unlocked() write/force parameters with gup_flags
mm: remove write/force parameters from __get_user_pages_unlocked()
mm: remove write/force parameters from __get_user_pages_locked()
mm: remove gup_flags FOLL_WRITE games from __get_user_pages()
This removes the 'write' argument from access_process_vm() and replaces
it with 'gup_flags' as use of this function previously silently implied
FOLL_FORCE, whereas after this patch callers explicitly pass this flag.
We make this explicit as use of FOLL_FORCE can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Cc: linux-mm@kvack.org
Cc: Mel Gorman <mgorman@techsingularity.net>
Link: http://lkml.kernel.org/r/1476719259-6214-1-git-send-email-weiyj.lk@gmail.com
This removes the 'write' argument from access_remote_vm() and replaces
This removes the 'write' argument from __access_remote_vm() and replaces
This removes the 'write' and 'force' from get_user_pages_remote() and
replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
Acked-by: Christian König <christian.koenig@amd.com>
